# showdsldstat
mode: ATA
running (voip=0,tr069=0)
speed 0/0
PPPoE Forward: disabled
0: name internet
0: no sync vcc 1/32/PPPoE/32/UBR/0/0/ stay online 0
0: counter in=0/0, out=0/0 bytes/pkts
# dsl_pipe ld 0
DSL: ++++++++++++++++ loading ADSL FW ++++++++++++++++++++
file path is /lib/modules/vinax_fw_adsl.bin
fw size is 0
DSL: loading firmware binary /lib/modules/vinax_fw_adsl.bin
DSL: firmware binary size 540916 bytes
DSL[00]: Device Start EVT - UsrRst, DrvState 1 --> 1
DSL[00]: Line in reset - block!
fw size is 0
DSL[00]: line 0 on device 0 not accessible!
[... Habe ich entfernt...]
nReturn=0 nLine=0
# DSL[00]: Device Start EVT - UsrRst, DrvState 1 --> 1
DSL[00]: VINAX line recovered.
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000100
dsl_daemon: new modem state 256
Setting inventory DSL-FW version number to 9.5.2.1.1.6
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000200
dsl_daemon: new modem state 512
# cat /dev/debug
[153]dect_uicp_prot_handle_connect, new conn
[4294942855][DECTDRV-CATIQ] API_FP_SETUP_ADVANCED_REQ: codec_list = 0x00
[DECTDRV] SwAllocateCc(CallerId=46)
[DECTDRV] SwAllocateCc(CallerId=31)
[4294942855][DCTDRV] (FP_SW_SETUP_ind) BASECTRL_TASK->PROTOCOLMAPTASK [2E F8 48 00 31 46 4F 00 00 00 00 00]
[DECTDRV] [1] codecListGlobalCapabilities: 0x00, codecList(Given)Capabilities: 0x00
[4294942855][DCTDRV] (FP_MNCC_SETUP_REQ) PROTOCOLMAPTASK->FP_CC_TASK
[4294942855][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[DECT_INFOELE] CC ccei:1 OUT SETUP 05 07 80 A8 00 03 0C 83 AE 06 07 A0 A5 01 12 07 36 60 E0 80 E4 4F
[DECT_INFOELE] IE Var 05 Port ID : Len 7 : Content 80 A8 00 03 0C 83 AE
[DECT_INFOELE] IE Var 06 Fixed ID : Len 7 : Content A0 A5 01 12 07 36 60
[DECT_INFOELE] IE Dub E0 Basic Service : Len 1 : Content 80
[DECT_INFOELE] Call Class "Normal call setup"
[DECT_INFOELE] Basic Service Type "Basic speech"
[DECT_INFOELE] IE Dub E4 Signal : Len 1 : Content 4F
[4294942855][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294942858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 15 D5 00 02 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[4294942858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 15 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[DECTDRV] [1]SendPacketToLce, state: 3, inst: 1
[4294942858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[DECT_INFOELE] CC ccei:1 OUT 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D
[DECT_INFOELE] IE Var 7B Escape To Proprietary : Len 19 : Content 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D
[idle]: 17% (run 82%)
[4294942898][DCTDRV] (FP_MAC_START_STOP_REQ) UI_TASK->FP_CCF_TASK
[4294942898][DCTDRV] (FP_MAC_SET_REPEATER_MODE) UI_TASK->FP_CCF_TASK
[4294942898][DCTDRV] (RFPI_REQ) UI_TASK->FP_CCF_TASK
[4294942900][DECTSTUB] FP_MAC_START_REQ, ignore, already started
[4294942903][DCTDRV] (RFPI_CFM) FP_CCF_TASK->UI_TASK
[4294942903][DCTDRV] (STUB_FP_CAP_IND) FP_CCF_TASK->UI_TASK
[4294943156][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 4% (run 95%)
[4294943456][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 70% (run 29%)
[4294943756][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 84% (run 15%)
[4294944056][DCTDRV] (FP_MNCC_REJECT_IND) FP_CC_TASK->PROTOCOLMAPTASK [92 0C 01 00]
[4294944056][DCTDRV] (FP_SW_REJECT_req) PROTOCOLMAPTASK->BASECTRL_TASK [37 F8 48 11]
[DECTDRV] FP_SW_REJECT_ind ei:99 reason:11
[DECTDRV] SwFreeCc(Cc=0x95FF1680 ei=0x48)
[DECTDRV] SwFreeCc(Cc=0x95FF1600 ei=0x99)
[idle]: 82% (run 17%)
[idle]: 69% (run 30%)
[idle]: 81% (run 18%)
[4294944858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 15 D5 00 02 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[4294944858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 15 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[DECTDRV] FP_MNCC_FACILITY_REQ, link no 1
[DECTDRV] [1]SendPacketToLce, state: 0, inst: 1
[4294944858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[4294944858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
Green AP PS switched on after scanning
ath_newstate: Resetting VAP dfswait_run
Incr nodes. Number of nodes are 1
Transition to power save Off
[4294945159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 86% (run 13%)
[4294945459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294945759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294946858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 15 D5 00 02 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[4294946858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 15 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[4294946858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[4294946858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
Incr nodes. Number of nodes are 2
[4294947159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294947459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 85% (run 14%)
[4294947759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294948858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 15 D5 00 02 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[4294948858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 15 7B 13 81 00 02 54 0B 01 47 69 67 61 73 65 74 20 2E 2E 5B 01 8D]
[4294948858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[4294948858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294949159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294949459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294949759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 58% (run 41%)
[4294950858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 14 D5 00 02 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294950858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 14 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294950858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[DECT_INFOELE] CC ccei:1 OUT 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90
[DECT_INFOELE] IE Var 7B Escape To Proprietary : Len 18 : Content 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90
[4294950858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294951159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294951459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294951759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 26% (run 73%)
[idle]: 71% (run 28%)
[4294952858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 14 D5 00 02 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294952858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 14 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294952858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[4294952858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294953159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[idle]: 39% (run 60%)
[4294953459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294953759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294954858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 14 D5 00 02 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294954858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 14 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294954858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[4294954858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294955159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294955459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294955759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294956858][DCTDRV] (FP_SW_FACILITY_ind) BASECTRL_TASK->PROTOCOLMAPTASK [B3 F8 01 14 D5 00 02 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294956858][DCTDRV] (FP_MNCC_FACILITY_REQ) PROTOCOLMAPTASK->FP_CC_TASK [A0 0C 01 14 7B 12 81 00 02 58 0A 02 08 01 00 02 00 03 00 05 00 5B 01 90]
[4294956858][DCTDRV] (FP_CC_DATA_REQ) FP_CC_TASK->FP_DLC_LCE_TASK
[4294956858][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294957159][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
unlocking interrupts
VINAX: GOT INTERRUPT: user reset
locking interrupts
device already started--> execute FW Download
VINAX_DRV[00]: Start Download - DMA transfere
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[53] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[54] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[55] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <code> page[61] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[62] found - skipped
checked download state machine (= 4)
VINAX_DRV[00]: DL/CS - Wait for 1. Response
[idle]: 55% (run 44%)
state has changed
VINAX_DRV[00]: ERROR - DL/CS missing 1. response
[4294957459][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
[4294957759][DCTDRV] (FP_MAC_PAGE_REQ) FP_DLC_LCE_TASK->FP_CCF_TASK
AVM: no response from Modem! Workaround...now!
1) SW reset
reset done. wait for first modem response.
no response! Try again?
2) SW reset
locking interrupts
Done. Modem state= 0
workaround worked! (after 2 attempt(s))
exiting workaround.
na bitte geht doch
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[40] found - skipped
state has changed
VINAX_DRV[00]: DL/CS 1. response received - done
++++++++++++++++++++++++++++ OAM activate ++++++++++++++++++++++++
++++++++++++++++++++++++++++ OAM activated!!!! ++++++++++++++++++++++++
================== Short Packet Filter deactivated =============
================== ethernet OAM control =============
================== ADSL Detected ==================
avm_vinax_configurePacketFilter_PPPoE: pDfeDynCntrl=94690400, with_vlan=0
================== packet filter configured =============
================== packet filter activated =============
================== cell extraction configured 1 =============
================== cell extraction configured 2 =============
================== cell extraction configured 3 =============
================== cell extraction configured 4 =============
================== cell extraction configured 5 =============
================== cell extraction configured 6 =============
================== cell extraction configured 7 =============
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[41] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[12] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[13] found - skipped
[idle]: 85% (run 14%)cat: read error: Broken pipe
