20121031 for BSP test version!!!
<4>IsdnDvr_init() SUCCESS, Major Numer is 253
<3>IPSEC SPU: SUCCEEDED
<4>GACT probability NOT on
<4>Mirror/redirect action on
<4>u32 classifier
<4> input device check on
<4> Actions configured
<6>TCP cubic registered
<6>Initializing XFRM netlink socket
<6>NET: Registered protocol family 10
<6>IPv6 over IPv4 tunneling driver
<6>NET: Registered protocol family 17
<6>NET: Registered protocol family 15
<6>Initializing MCPD Module
<6>Ebtables v2.0 registered
<6>ebt_time registered
<6>ebt_ftos registered
<6>ebt_wmm_mark registered
<6>802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
<6>All bugs added by David S. Miller <[email protected]>
<4>VFS: Mounted root (jffs2 filesystem) readonly on device 31:0.
<6>Freeing unused kernel memory: 156k freed
<4>Warning: unable to open an initial console.
<6>usb 1-2: new high speed USB device using ehci_hcd and address 2
<6>usb 1-2: configuration #1 chosen from 1 choice
<6>scsi0 : SCSI emulation for USB Mass Storage devices
<7>usb-storage: device found at 2
<7>usb-storage: waiting for device to settle before scanning
<3>usbfs: unrecognised mount option "defaults" or missing value
<4>usbfs: mount parameter error.
<4>chipinfo: module license 'proprietary' taints kernel.
<4>Disabling lock debugging due to kernel taint
<4>brcmchipinfo: brcm_chipinfo_init entry
<4>Broadcom Ingress QoS Module Char Driver v0.1 Oct 22 2014 14:38:28 Registered<243>[0m
<4>
<4>Broadcom Ingress QoS ver 0.1 initialized
<4>BPM: tot_mem_size=134217728B (128MB), buf_mem_size=20132655B (19MB), num of buffers=9460, buf size=2128
<4>Broadcom BPM Module Char Driver v0.1 Oct 22 2014 14:37:24 Registered<244>[0m
<4>[0;34m[NTC bpm] bpm_set_status: BPM status : enabled
<4>[0m
<0>fcache_construct:6664 Debug :Jul 18 2014 17:13:08
<4>NBUFF v1.0 Initialized
<4>[0;36;44mInitialized fcache state[0m
<4>[0;36;44mBroadcom Packet Flow Cache Char Driver v2.2 Oct 22 2014 14:38:29 Registered<242>[0m
<4>Created Proc FS /procfs/fcache
<4>[0;36;44mBroadcom Packet Flow Cache registered with netdev chain[0m
<4>[0;36;44mBroadcom Packet Flow Cache learning via BLOG enabled.[0m
<4>[0;36;44mConstructed Broadcom Packet Flow Cache v2.2 Oct 22 2014 14:38:29[0m
<4>chipId 0x631680D0
<4>WARNING -- could not register sysrq key for FAP!
<4>Broadcom Forwarding Assist Processor (FAP) Char Driver v0.1 Oct 22 2014 14:38:23 Registered <241>
<4>Enabling SMISBUS PHYS_FAP_BASE[0] is 0x10c01000
<4>FAP Soft Reset Done
<4>4ke Reset Done
<4>Enabling SMISBUS PHYS_FAP_BASE[1] is 0x10c01000
<4>4ke Reset Done
<4>FAP Debug values at 0xa5d9df10 0xa5e1df10
<4>Allocated FAP0 GSO Buffers (0xA5DAEF98) : 1048576 bytes @ 0xA5F00000
<4>Allocated FAP1 GSO Buffers (0xA5E2EF98) : 1048576 bytes @ 0xA5800000
<4>Allocated FAP0 TM SDRAM Queue Storage (a5daef9c) : 341376 bytes @ a5e80000
<4>Allocated FAP1 TM SDRAM Queue Storage (a5e2ef9c) : 341376 bytes @ a5900000
<4>[0;34m[NTC fapProto] fapReset : Reset FAP Protocol layer[0m
<4>fapDrv_construct: FAP0: pManagedMemory=b0820650. wastage 8 bytes
<4>fapDrv_construct: FAP1: pManagedMemory=b0a20650. wastage 8 bytes
<4>bcmPktDma_bind: FAP Driver binding successfull
<4>[FAP0] GSO Buffer set to 0xA5F00000
<4>[FAP1] GSO Buffer set to 0xA5800000
<4>[FAP0] FAP BPM Initialized.
<4>[FAP1] FAP BPM Initialized.
<4>[FAP0] FAP TM: ON
<4>[FAP1] FAP TM: ON
<4>bcmxtmcfg: bcmxtmcfg_init entry
<5>scsi 0:0:0:0: Direct-Access Verbatim PQ: 0 ANSI: 4
<7>usb-storage: device scan complete
<5>sd 0:0:0:0: [sda] 61440000 512-byte hardware sectors: (31.4 GB/29.2 GiB)
<5>sd 0:0:0:0: [sda] Write Protect is off
<7>sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
<3>sd 0:0:0:0: [sda] Assuming drive cache: write through
<6> sda: sda1
<5>sd 0:0:0:0: [sda] Attached SCSI removable disk
<3>FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
<3>EXT3-fs: Unrecognized mount option "iocharset=utf8" or missing value
<4>adsl: adsl_init entry
<6>kjournald starting. Commit interval 5 seconds
<6>EXT3 FS on sda1, internal journal
<6>EXT3-fs: recovery complete.
<6>EXT3-fs: mounted filesystem with writeback data mode.
<4>Broadcom BCM63168D0 Ethernet Network Device v0.1 Oct 22 2014 14:40:02
<4>Broadcom GMAC Char Driver v0.1 Oct 22 2014 14:40:06 Registered<249>[0m
<4>Broadcom GMAC Driver v0.1 Oct 22 2014 14:40:06 Initialized
<4>fapDrv_psmAlloc: fapIdx=1, size: 4800, offset=b0a20650 bytes remaining 7000
<4>ETH Init: Ch:0 - 200 tx BDs at 0xb0a20650
<4>fapDrv_psmAlloc: fapIdx=0, size: 4800, offset=b0820650 bytes remaining 7000
<4>ETH Init: Ch:1 - 200 tx BDs at 0xb0820650
<4>fapDrv_psmAlloc: wastage 8 bytes
<4>fapDrv_psmAlloc: fapIdx=0, size: 4808, offset=b0821910 bytes remaining 2184
<4>ETH Init: Ch:0 - 600 rx BDs at 0xb0821910
<4>fapDrv_psmAlloc: fapIdx=1, size: 4808, offset=b0a21910 bytes remaining 2184
<4>ETH Init: Ch:1 - 600 rx BDs at 0xb0a21910
<4>dgasp: kerSysRegisterDyingGaspHandler: bcmsw registered
<4>eth0: MAC Address: E8:37:7A:16:AF:F2
<4>eth1: MAC Address: E8:37:7A:16:AF:F2
<4>eth2: MAC Address: E8:37:7A:16:AF:F2
<4>eth3: MAC Address: E8:37:7A:16:AF:F2
<4>eth4: MAC Address: E8:37:7A:16:AF:F3
<4>[0;34m[NTC arl] arlEnable : Enabled ARL binding to FAP[0m
<4>Broadcom Adress Resolution Logic Processor (ARL) Char Driver v0.1 Oct 22 2014 14:37:24 Registered <245>
<4>--SMP support
<4>wl: dsl_tx_pkt_flush_len=338
<4>wl: high_wmark_tot=6149
<7>PCI: Setting latency timer of device 0000:00:00.0 to 64
<4>wl0: online cpus 2
<4>wl: passivemode=1
<4>wl: napimode=0
<4>wl0: allocskbmode=1 currallocskbsz=512
<4>si_doattach: incoming bus is PCI but it's a lie, switching to SI devid:0x435f
<4>Found chip type UBUS (0x22016362), chip id = 0x6362
<4>Chipc: rev 35, caps 0x10000000, chipst 0x0 pmurev 6, pmucaps 0x84c2806
<4>ipxotp_init: No OTP
<4>otp_init failed.
<4>Neither SPROM nor OTP has valid image
<4>wl:srom/otp not programmed, using main memory mapped srom info(wombo board)
<4>wl:loading /etc/wlan/bcm6362_map.bin
<4>srom rev:8
<4>wl: reading /etc/wlan/bcmcmn_nvramvars.bin, file size=32
<4>[0] watchdog=60000
<4>s=sromrev=8
<4>s=boardrev=0x1204
<4>s=boardflags=0x200
<4>s=boardflags2=0x0
<4>s=boardtype=0x5bb
<4>s=subvid=0x14e4
<4>s=boardnum=0
<4>s=regrev=0
<4>s=pa0b0=0xff87
<4>s=pa0b1=0x180f
<4>s=pa0b2=0xfaea
<4>s=pa0itssit=32
<4>s=pa0maxpwr=60
<4>s=opo=17
<4>s=aa2g=3
<4>s=aa5g=3
<4>s=ag0=2
<4>s=ag1=2
<4>s=ag2=2
<4>s=ag3=255
<4>s=pa1b0=0xff15
<4>s=pa1b1=0x1455
<4>s=pa1b2=0xfb95
<4>s=pa1lob0=0xfea2
<4>s=pa1lob1=0x149a
<4>s=pa1lob2=0xfafc
<4>s=pa1hib0=0xff28
<4>s=pa1hib1=0x1315
<4>s=pa1hib2=0xfbf0
<4>s=pa1itssit=62
<4>s=pa1maxpwr=60
<4>s=pa1lomaxpwr=64
<4>s=pa1himaxpwr=56
<4>s=bxa2g=3
<4>s=rssisav2g=7
<4>s=rssismc2g=15
<4>s=rssismf2g=15
<4>s=bxa5g=3
<4>s=rssisav5g=7
<4>s=rssismc5g=15
<4>s=rssismf5g=15
<4>s=tri2g=255
<4>s=tri5g=255
<4>s=tri5gl=255
<4>s=tri5gh=255
<4>s=rxpo2g=-1
<4>s=rxpo5g=-1
<4>s=txchain=3
<4>s=rxchain=3
<4>s=antswitch=0
<4>s=tssipos2g=1
<4>s=extpagain2g=2
<4>s=pdetrange2g=2
<4>s=triso2g=3
<4>s=antswctl2g=0
<4>s=tssipos5g=1
<4>s=extpagain5g=2
<4>s=pdetrange5g=2
<4>s=triso5g=3
<4>s=antswctl5g=0
<4>s=ccode=
<4>s=macaddr=00:00:00:00:00:00
<4>s=tempthresh=120
<4>s=tempoffset=0
<4>s=rawtempsense=0x1ff
<4>s=measpower=0x7f
<4>s=tempsense_slope=0xff
<4>s=tempcorrx=0x3f
<4>s=tempsense_option=0x3
<4>s=freqoffset_corr=0xf
<4>s=iqcal_swp_dis=0x1
<4>s=hw_iqcal_en=0x1
<4>s=elna2g=255
<4>s=elna5g=255
<4>s=phycal_tempdelta=30
<4>s=temps_period=0
<4>s=temps_hysteresis=0
<4>s=measpower1=0x7f
<4>s=measpower2=0x7f
<4>s=cck2gpo=4369
<4>s=ofdm2gpo=286331153
<4>s=ofdm5gpo=0
<4>s=ofdm5glpo=0
<4>s=ofdm5ghpo=0
<4>s=mcs2gpo0=21845
<4>s=mcs2gpo1=21845
<4>s=mcs2gpo2=21845
<4>s=mcs2gpo3=21845
<4>s=mcs2gpo4=21845
<4>s=mcs2gpo5=21845
<4>s=mcs2gpo6=21845
<4>s=mcs2gpo7=21845
<4>s=mcs5gpo0=0
<4>s=mcs5gpo1=0
<4>s=mcs5gpo2=0
<4>s=mcs5gpo3=0
<4>s=mcs5gpo4=0
<4>s=mcs5gpo5=0
<4>s=mcs5gpo6=0
<4>s=mcs5gpo7=0
<4>s=mcs5glpo0=0
<4>s=mcs5glpo1=0
<4>s=mcs5glpo2=0
<4>s=mcs5glpo3=0
<4>s=mcs5glpo4=0
<4>s=mcs5glpo5=0
<4>s=mcs5glpo6=0
<4>s=mcs5glpo7=0
<4>s=mcs5ghpo0=0
<4>s=mcs5ghpo1=0
<4>s=mcs5ghpo2=0
<4>s=mcs5ghpo3=0
<4>s=mcs5ghpo4=0
<4>s=mcs5ghpo5=0
<4>s=mcs5ghpo6=0
<4>s=mcs5ghpo7=0
<4>s=cddpo=0
<4>s=stbcpo=0
<4>s=bw40po=0
<4>s=bwduppo=0
<4>s=pcieingress_war=15
<4>s=rxgainerr2ga0=63
<4>s=rxgainerr2ga1=31
<4>s=rxgainerr2ga2=31
<4>s=rxgainerr5gla0=63
<4>s=rxgainerr5gla1=31
<4>s=rxgainerr5gla2=31
<4>s=rxgainerr5gma0=63
<4>s=rxgainerr5gma1=31
<4>s=rxgainerr5gma2=31
<4>s=rxgainerr5gha0=63
<4>s=rxgainerr5gha1=31
<4>s=rxgainerr5gha2=31
<4>s=rxgainerr5gua0=63
<4>s=rxgainerr5gua1=31
<4>s=rxgainerr5gua2=31
<4>s=noiselvl2ga0=31
<4>s=noiselvl2ga1=31
<4>s=noiselvl2ga2=31
<4>s=noiselvl5gla0=31
<4>s=noiselvl5gla1=31
<4>s=noiselvl5gla2=31
<4>s=noiselvl5gma0=31
<4>s=noiselvl5gma1=31
<4>s=noiselvl5gma2=31
<4>s=noiselvl5gha0=31
<4>s=noiselvl5gha1=31
<4>s=noiselvl5gha2=31
<4>s=noiselvl5gua0=31
<4>s=noiselvl5gua1=31
<4>s=noiselvl5gua2=31
<4>s=subband5gver=7
<4>s=maxp2ga0=60
<4>s=itt2ga0=32
<4>s=itt5ga0=62
<4>s=pa2gw0a0=0xff87
<4>s=pa2gw1a0=0x180f
<4>s=pa2gw2a0=0xfaea
<4>s=maxp5ga0=60
<4>s=maxp5gha0=56
<4>s=maxp5gla0=64
<4>s=pa5gw0a0=0xff15
<4>s=pa5gw1a0=0x1455
<4>s=pa5gw2a0=0xfb95
<4>s=pa5glw0a0=0xfea2
<4>s=pa5glw1a0=0x149a
<4>s=pa5glw2a0=0xfafc
<4>s=pa5ghw0a0=0xff28
<4>s=pa5ghw1a0=0x1315
<4>s=pa5ghw2a0=0xfbf0
<4>s=maxp2ga1=60
<4>s=itt2ga1=32
<4>s=itt5ga1=62
<4>s=pa2gw0a1=0xffd7
<4>s=pa2gw1a1=0x1811
<4>s=pa2gw2a1=0xfb66
<4>s=maxp5ga1=60
<4>s=maxp5gha1=56
<4>s=maxp5gla1=64
<4>s=pa5gw0a1=0xfe87
<4>s=pa5gw1a1=0x110f
<4>s=pa5gw2a1=0xfb4b
<4>s=pa5glw0a1=0xfebe
<4>s=pa5glw1a1=0x1478
<4>s=pa5glw2a1=0xfb1a
<4>s=pa5ghw0a1=0xff8d
<4>s=pa5ghw1a1=0x1146
<4>s=pa5ghw2a1=0xfcd6
<4>s=maxp2ga2=255
<4>s=itt2ga2=255
<4>s=itt5ga2=255
<4>s=pa2gw0a2=0xffff
<4>s=pa2gw1a2=0xffff
<4>s=pa2gw2a2=0xffff
<4>s=maxp5ga2=255
<4>s=maxp5gha2=255
<4>s=maxp5gla2=255
<4>s=pa5gw0a2=0xffff
<4>s=pa5gw1a2=0xffff
<4>s=pa5gw2a2=0xffff
<4>s=pa5glw0a2=0xffff
<4>s=pa5glw1a2=0xffff
<4>s=pa5glw2a2=0xffff
<4>s=pa5ghw0a2=0xffff
<4>s=pa5ghw1a2=0xffff
<4>s=pa5ghw2a2=0xffff
<4>s=maxp2ga3=255
<4>s=itt2ga3=255
<4>s=itt5ga3=255
<4>s=pa2gw0a3=0xffff
<4>s=pa2gw1a3=0xffff
<4>s=pa2gw2a3=0xffff
<4>s=maxp5ga3=255
<4>s=maxp5gha3=255
<4>s=maxp5gla3=255
<4>s=pa5gw0a3=0xffff
<4>s=pa5gw1a3=0xffff
<4>s=pa5gw2a3=0xffff
<4>s=pa5glw0a3=0xffff
<4>s=pa5glw1a3=0xffff
<4>s=pa5glw2a3=0xffff
<4>s=pa5ghw0a3=0xffff
<4>s=pa5ghw1a3=0xffff
<4>s=pa5ghw2a3=0xffff
<4>s=watchdog=60000
<4>wlc_bmac_attach, deviceid 0x435f nbands 2
<4>wl0: wlc_bmac_attach: chiprev 1 corerev 22 cccap 0x10000000 maccap 0xb0a04805 band 2.4G, phy_type 4 phy_rev 8
<4>wl0: wlc_bmac_attach: chiprev 1 corerev 22 cccap 0x10000000 maccap 0xb0a04805 band 5G, phy_type 4 phy_rev 8
<4>wl0: wlc_ampdu_tx_set: AGG Mode = HOST txmaxpkts 6
<4>wl0: Broadcom BCM435f 802.11 Wireless Controller 6.30.163.23.cpe4.12L06B.1 (Compiled in . at 14:40:49 on Oct 22 2014)
<4>dgasp: kerSysRegisterDyingGaspHandler: wl0 registered
<4>PCI: Enabling device 0000:02:00.0 (0000 -> 0002)
<7>PCI: Setting latency timer of device 0000:02:00.0 to 64
<4>wl1: online cpus 2
<4>wl: napimode=0
<4>wl1: allocskbmode=1 currallocskbsz=3500
<4>Found chip type AI (0x15134360)
<4>Chipc: rev 43, caps 0x58680001, chipst 0x9a6d pmurev 17, pmucaps 0x10a22b11
<4>wl:loading /etc/wlan/bcm4360_map.bin
<4>srom rev:11
<4>wl: reading /etc/wlan/bcm4360_nvramvars.bin, file size=32
<4>[0] ledbh10=0x88
<4>s=sromrev=11
<4>s=boardrev=0x1353
<4>s=boardflags=0x10000000
<4>s=boardflags2=0x2
<4>s=boardtype=0x633
<4>s=subvid=0x14e4
<4>s=boardflags3=0x0
<4>s=boardnum=0
<4>s=ccode=
<4>s=regrev=0
<4>s=aa2g=7
<4>s=aa5g=7
<4>s=agbg0=69
<4>s=agbg1=69
<4>s=agbg2=69
<4>s=aga0=69
<4>s=aga1=69
<4>s=aga2=69
<4>s=txchain=7
<4>s=rxchain=7
<4>s=antswitch=0
<4>s=tssiposslope2g=1
<4>s=epagain2g=0
<4>s=pdgain2g=10
<4>s=tworangetssi2g=0
<4>s=papdcap2g=0
<4>s=femctrl=6
<4>s=tssiposslope5g=1
<4>s=epagain5g=0
<4>s=pdgain5g=10
<4>s=tworangetssi5g=0
<4>s=papdcap5g=0
<4>s=gainctrlsph=0
<4>s=tempthresh=255
<4>s=tempoffset=255
<4>s=measpower=0x7f
<4>s=tempcorrx=0x3f
<4>s=xtalfreq=65535
<4>s=phycal_tempdelta=255
<4>s=temps_period=15
<4>s=temps_hysteresis=15
<4>s=tssifloor2g=0x3ff
<4>s=tssifloor5g=0x3ff,0x3ff,0x3ff,0x3ff
<4>s=pdoffset2g40ma0=15
<4>s=pdoffset2g40ma1=15
<4>s=pdoffset2g40ma2=15
<4>s=pdoffset2g40mvalid=1
<4>s=pdoffset40ma0=1030
<4>s=pdoffset40ma1=18162
<4>s=pdoffset40ma2=15775
<4>s=pdoffset80ma0=0
<4>s=pdoffset80ma1=0
<4>s=pdoffset80ma2=0
<4>s=subband5gver=0x4
<4>s=cckbw202gpo=0
<4>s=cckbw20ul2gpo=0
<4>s=mcsbw202gpo=2571386880
<4>s=mcsbw402gpo=2571386880
<4>s=dot11agofdmhrbw202gpo=17408
<4>s=ofdmlrbw202gpo=0
<4>s=mcsbw205glpo=2290649224
<4>s=mcsbw405glpo=2290649224
<4>s=mcsbw805glpo=2290649224
<4>s=mcsbw205gmpo=2290649224
<4>s=mcsbw405gmpo=2290649224
<4>s=mcsbw805gmpo=2290649224
<4>s=mcsbw205ghpo=2290649224
<4>s=mcsbw405ghpo=2290649224
<4>s=mcsbw805ghpo=2290649224
<4>s=mcslr5glpo=0
<4>s=mcslr5gmpo=0
<4>s=mcslr5ghpo=0
<4>s=sb20in40hrpo=0
<4>s=sb20in80and160hr5glpo=0
<4>s=sb40and80hr5glpo=0
<4>s=sb20in80and160hr5gmpo=0
<4>s=sb40and80hr5gmpo=0
<4>s=sb20in80and160hr5ghpo=0
<4>s=sb40and80hr5ghpo=0
<4>s=sb20in40lrpo=0
<4>s=sb20in80and160lr5glpo=0
<4>s=sb40and80lr5glpo=0
<4>s=sb20in80and160lr5gmpo=0
<4>s=sb40and80lr5gmpo=0
<4>s=sb20in80and160lr5ghpo=0
<4>s=sb40and80lr5ghpo=0
<4>s=dot11agduphrpo=0
<4>s=dot11agduplrpo=0
<4>s=sar2g=18
<4>s=sar5g=15
<4>s=noiselvl5ga0=31,31,31,31
<4>s=noiselvl5ga1=31,31,31,31
<4>s=noiselvl5ga2=31,31,31,31
<4>s=rxgainerr5ga0=63,63,63,63
<4>s=rxgainerr5ga1=31,31,31,31
<4>s=rxgainerr5ga2=31,31,31,31
<4>s=rpcal2g=0
<4>s=rpcal5gb0=0
<4>s=rpcal5gb1=0
<4>s=rpcal5gb2=0
<4>s=rpcal5gb3=0
<4>s=maxp2ga0=66
<4>s=pa2ga0=0xff24,0x188e,0xfce6
<4>s=rxgains5gmelnagaina0=7
<4>s=rxgains5gmtrisoa0=15
<4>s=rxgains5gmtrelnabypa0=1
<4>s=rxgains5ghelnagaina0=7
<4>s=rxgains5ghtrisoa0=15
<4>s=rxgains5ghtrelnabypa0=1
<4>s=rxgains2gelnagaina0=0
<4>s=rxgains2gtrisoa0=0
<4>s=rxgains2gtrelnabypa0=0
<4>s=rxgains5gelnagaina0=3
<4>s=rxgains5gtrisoa0=6
<4>s=rxgains5gtrelnabypa0=1
<4>s=maxp5ga0=64,64,64,64
<4>s=pa5ga0=0xff31,0x15c1,0xfd1a,0xff4f,0x1695,0xfd30,0xff3a,0x158f,0xfd34,0xff59,0x1652,0xfd41
<4>s=maxp2ga1=66
<4>s=pa2ga1=0xff3e,0x15f9,0xfd36
<4>s=rxgains5gmelnagaina1=7
<4>s=rxgains5gmtrisoa1=15
<4>s=rxgains5gmtrelnabypa1=1
<4>s=rxgains5ghelnagaina1=7
<4>s=rxgains5ghtrisoa1=15
<4>s=rxgains5ghtrelnabypa1=1
<4>s=rxgains2gelnagaina1=0
<4>s=rxgains2gtrisoa1=0
<4>s=rxgains2gtrelnabypa1=0
<4>s=rxgains5gelnagaina1=3
<4>s=rxgains5gtrisoa1=6
<4>s=rxgains5gtrelnabypa1=1
<4>s=maxp5ga1=64,64,64,64
<4>s=pa5ga1=0xff55,0x1688,0xfd3c,0xff53,0x1668,0xfd37,0xff4e,0x153c,0xfd47,0xff55,0x156a,0xfd50
<4>s=maxp2ga2=66
<4>s=pa2ga2=0xff25,0x18a6,0xfce2
<4>s=rxgains5gmelnagaina2=7
<4>s=rxgains5gmtrisoa2=15
<4>s=rxgains5gmtrelnabypa2=1
<4>s=rxgains5ghelnagaina2=7
<4>s=rxgains5ghtrisoa2=15
<4>s=rxgains5ghtrelnabypa2=1
<4>s=rxgains2gelnagaina2=0
<4>s=rxgains2gtrisoa2=0
<4>s=rxgains2gtrelnabypa2=0
<4>s=rxgains5gelnagaina2=3
<4>s=rxgains5gtrisoa2=6
<4>s=rxgains5gtrelnabypa2=1
<4>s=maxp5ga2=64,64,64,64
<4>s=pa5ga2=0xff21,0x1570,0xfd23,0xff4a,0x16da,0xfd2d,0xff4c,0x1697,0xfd35,0xff41,0x1519,0xfd46
<4>s=devid=0x43a2
<4>s=watchdog=60000
<4>s=ledbh10=0x88
<4>HTAVAIL is set, so not updating BBPLL Frequency
<4>wl1: wlc_attach: Overriding device id: 0x43a2 instead of 0x4360
<4>Overriding device id = 0x43a2
<4>wlc_bmac_attach, deviceid 0x43a2 nbands 1
<4>wl1: wlc_bmac_attach: chiprev 3 corerev 42 cccap 0x58680001 maccap 0x30518c05 band 5G, phy_type 11 phy_rev 1
<4>wl1: wlc_stf_txcore_shmem_write: No clock
<4>wl1: wlc_ampdu_tx_set: AGG Mode = MAC+AQM txmaxpkts 1024
<4>wl1: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.23.cpe4.12L06B.1 (Compiled in . at 14:40:49 on Oct 22 2014)
<4>dgasp: kerSysRegisterDyingGaspHandler: wl1 registered
<7>Endpoint: endpoint_init entry
<7>Endpoint: endpoint_init COMPLETED
<6>Broadcom 802.1Q VLAN Interface, v0.1
