node-test.c: In function 'g_node_test':
node-test.c:99: warning: reading through null pointer (argument 5)
node-test.c:103: warning: reading through null pointer (argument 5)
node-test.c:111: warning: reading through null pointer (argument 5)
node-test.c:121: warning: reading through null pointer (argument 5)
node-test.c:122: warning: reading through null pointer (argument 5)
node-test.c:123: warning: reading through null pointer (argument 5)
node-test.c:124: warning: reading through null pointer (argument 5)
node-test.c:125: warning: reading through null pointer (argument 5)
node-test.c:126: warning: reading through null pointer (argument 5)
node-test.c:127: warning: reading through null pointer (argument 5)
node-test.c:128: warning: reading through null pointer (argument 5)
node-test.c:129: warning: reading through null pointer (argument 5)
node-test.c:130: warning: reading through null pointer (argument 5)
node-test.c:131: warning: reading through null pointer (argument 5)
node-test.c:136: warning: reading through null pointer (argument 5)
node-test.c:140: warning: reading through null pointer (argument 5)
node-test.c:195: warning: reading through null pointer (argument 5)
node-test.c:196: warning: reading through null pointer (argument 5)
/home/deepzone/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -DHAVE_CO NFIG_H -I. -I. -I.. -I.. -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -D_REENTRANT -c strfunc-test .c
/home/deepzone/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -DHAVE_CO NFIG_H -I. -I. -I.. -I.. -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -D_REENTRANT -c tree-test.c
/home/deepzone/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -DHAVE_CO NFIG_H -I. -I. -I.. -I.. -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -D_REENTRANT -c type-test.c
/bin/sh ../libtool --mode=link /home/deepzone/freetz-1.1/toolchain/target/bin/mi psel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LA RGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -D_REENTRANT -o array-test arra y-test.o ../libglib.la
../libtool: line 341: echo: write error: Cannot allocate memory
../libtool: line 341: /bin/sed: Cannot allocate memory
../libtool: fork: Cannot allocate memory
make[3]: *** [type-test.o] Error 255
make[3]: *** Waiting for unfinished jobs....
mkdir .libs
/home/deepzone/freetz-1.1/toolchain/target/bin/mipsel-linux-uclibc-gcc -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_ BITS=64 -Wall -D_REENTRANT -o .libs/array-test array-test.o ../.libs/libglib.so
creating array-test
make[3]: Leaving directory `/home/deepzone/freetz-1.1/source/glib-1.2.10/tests'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/deepzone/freetz-1.1/source/glib-1.2.10'
make[1]: *** [all-recursive-am] Error 2
make[1]: Leaving directory `/home/deepzone/freetz-1.1/source/glib-1.2.10'
make: *** [source/glib-1.2.10/.libs/libglib-1.2.so.0.0.10] Error 2
