cpu-probe: Manufacturer MIPS
mips-config1: JTAG pressent
mips-config1: TLB size 16
mips-config3: Vectored interrupts implmented
CPU revision is: 00019068
[mips_clock] default 360000000 MHz
[ur8_clk_set_emif] SDRAM Refresh 0x3a8 Timing 0x2214717 Bank 0x21 Async 0xc42c301
[ur8_pci_init]
[pci] default: 33 MHz
[setup_pci_master]
[setup_pci_slave]
Exposing 67108864 memory over PCI
Setup Complete, Enabling PCI Interface
PCI Interface Running
PCI controller initialized
[ur8_vbus_set_prio] instance vbus_nwss_dma level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_sar_pdsp level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_buffer_manager level 2 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_usb level 5 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_vlynq level 7 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_pci level 5 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_c55 level 3 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_tdm level 0 escalator disabled (count 255, floor 7)
[ur8_vbus_set_prio] instance vbus_mips level 3 escalator disabled (count 255, floor 7)
Determined physical RAM map:
memory: 03fc0000 @ 14000000 (usable)
memory: 00040000 @ 17fc0000 (reserved)
[init_bootmem]
[free_bootmem]
[reserve_bootmem]
On node 0 totalpages: 98240
[mem_map-hack]: reduce size from 3145728 524288 Bytes
[mem_map-hack]: move map base from 0x94329000 to 0x940a9000
DMA zone: 767 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 97473 pages, LIFO batch:31
Normal zone: 0 pages used for memmap
[request_resource] Kernel code: start 0x14000000 < root->start 0x17fc0000
[request_resource] Kernel data: start 0x14208b30 < root->start 0x17fc0000
Built 1 zonelists. Total pages: 97473
Kernel command line: console=ttyS0,38400n8r
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 2048 (order: 11, 8192 bytes)
CPU frequency 360.00 MHz
Using 180.000 MHz high precision timer.
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[free_all_bootmem]
Memory: 61056k/65280k available (2082k kernel code, 4140k reserved, 641k data, 140k init, 0k highmem)
Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Mount-cache hash table entries: 512
Checking for 'wait' instruction... available.
NET: Registered protocol family 16
[ur8_mtd_init]
[ur8_mtd_init] flashsize = 0x01000000 Byte 16 MBytes
[ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
[ur8_mtd_init] mtd[1] = 0x90020000,0x90F80000
[ur8_mtd_init] mtd[2] = 0x90000000,0x90020000
[ur8_mtd_init] mtd[3] = 0x90F80000,0x90FC0000
[ur8_mtd_init] mtd[4] = 0x90FC0000,0x91000000
[ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
Master and Slave Enabled
pktsched: using high resolution timer
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
squashfs: version 3.2 (2007/01/02) Phillip Lougher
Installing knfsd (copyright (C) 1996 [email protected]).
fuse init (API version 7.8)
io scheduler noop registered (default)
avm_net_trace: Up and running.
[avm] configured: watchdog event debug enable direct gpio
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Dec 9 2009 14:06:26)
Serial: 8250/16550 driver $Revision: 1.3 $ 1 ports,
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0000 ProdID=0000 Rev= 2.06
S: Manufacturer=Linux 2.6.19.2 musb-hcd
S: Product=MUSB HDRC host driver
S: SerialNumber=musb_hdrc
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=256ms
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=067b ProdID=2303 Rev= 3.00
S: Manufacturer=Prolific Technology Inc.
S: Product=USB-Serial Controller
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303
E: Ad=81(I) Atr=03(Int.) MxPS= 10 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
was haltet Ihr davon, und vor allem was muss ich bei freetz auswählen?
rrdtool dump ???
Serial: 8250/16550 driver $Revision: 1.3 $ 1 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 15) is a UR8_UART
T: Bus=01 Lev=02 Prnt=02 Port=02 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
Stopping rrdstats...done.
DigiTemp v3.5.0 Copyright 1996-2007 by Brian C. Lane
GNU Public License v2.0 - http://www.digitemp.com
Turning off all DS2409 Couplers
Searching the 1-Wire LAN
Das hatte ich mir fast gedacht.ttyS0 ist die serielle Schnittstelle in der Box
Das verstehe ich leider nicht. Was meinst du?(da kommen div., nützliche Debugausgaben beim booten raus, siehe /proc/cmdline)
Du musst einfach nur das Modul pl2303 laden (muss natürlich bei menuconfig angewählt werden) und schon kannst Du auf´s digitemp via /dev/ttyUSB0
ftdi_sio
fuse
nls_cp437
nls_iso8859_1
pl2303
usbserial
/var/tmp/flash/rrdstats # digitemp -s /dev/ttyUSB1 -i
owAcquire: failed to open device: No such device
Error 23: Failed to acquire a necessary system resource
modeprobe pl2303
USB-Gerät 002, Klasse 'USB 1.1 (full-speed) bulk', angesteckt
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbcore: registered new interface driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver
led_modul_Fritz_Box_7240: module license '
(C) Copyright 2008 by AVM
' taintskernel.
Was meinst Du mit "kann ich nicht laden"? Was genau gibst Du in der Konsole ein? Welche Fehlermeldung kommt? Normal ist, dass danach gar keine Meldung kommt - zumindest bei mir.Kernelmodul kann ich komischerweise nicht über die Console laden (modeprobe pl2303).
pl2303
ftdi_sio
hfsplus
root@fb1 /var/mod/root $ dmesg | grep usb
usbcore: registered new driver usbfs
usbcore: registered new driver hub
usbcore: registered new driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for Generic
usbcore: registered new driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core v2.0
drivers/usb/serial/usb-serial.c: USB Serial support registered for PL-2303
usbcore: registered new driver pl2303
drivers/usb/serial/pl2303.c: Prolific PL2303 USB to serial adaptor driver v0.12
drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new driver ftdi_sio
drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
[setup_irq]: irq 9 irqaction->handler 0xc0192490 (ahci_irq+0x0/0x880 [usbahcicore] )
usb 1-1: new full speed USB device using ahci and address 2
usb 1-1.1: new full speed USB device using ahci and address 3
usb 1-1.2: new full speed USB device using ahci and address 4
usb 1-1.2: PL-2303 converter now attached to ttyUSB0
usb 1-1.4: new full speed USB device using ahci and address 5
usb-storage: device found at 3
usb-storage: waiting for device to settle before scanning
usb-storage: device found at 5
usbcore: registered new driver usb-storage
usb-storage: device scan complete
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=13744 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
root@fb1 /var/mod/root $ dmesg | grep tty
Calling initcall 0x9421ab38: tty_class_init+0x0/0x34()
Calling initcall 0x9421ab6c: tty_init+0x0/0x184()
ttyS0 at MMIO 0x0 (irq = 15) is a OHIO_UART
/var/mod/root # dmesg | grep usb
/var/mod/root # dmesg | grep tty
