7270
DEF error,0 = 1,107783258754,0,all
DEF error,1 = 3,0,0,all
DOUBLE error,0 TO error,1
DEF power,0 = 0,1,0,power
DEF power,1 = 0,1,0,power
DEF internet,0 = 0,9,1,internet
DEF internet,1 = 0,9,1,internet
DEF ab,1 = 0,27,2,festnetz
DEF ab,2 = 0,27,2,festnetz
DEF ab,3 = 0,27,2,festnetz
DEF wlan,0 = 0,28,3,wlan
DEF info,0 = 0,17,4,info
DEF info,1 = 0,17,4,info
DEF info,2 = 0,17,4,info
DEF info,3 = 0,17,4,info
DEF info,4 = 0,17,4,info
DEF rot_eins,0 = 0,35,5,rot1
DEF rot_zwei,0 = 0,36,6,rot2
DEF rot_drei,0 = 0,32,7,rot3
DEF rot_vier,0 = 0,22,8,rot4
DEF rot_fuenf,0 = 0,21,9,rot5
DEF tam,0 = 99,32,10,tam
DEF tam,1 = 99,32,10,tam
DEF pppoe,0 = 99,32,11,dsl
DEF pppoe,1 = 99,32,11,dsl
DEF blockring,0 = 99,32,12,blockring
DEF missedcall,0 = 99,32,13,missedcall
DEF stick_surf,0 = 99,32,14,stick_surf
DEF stick_surf,1 = 99,32,14,stick_surf
DEF stick_surf,2 = 99,32,14,stick_surf
DEF stick_surf,3 = 99,32,14,stick_surf
DEF cpmac,0 = 99,32,15,lan_all
DEF cpmac,1 = 99,32,15,lan_all
DEF cpmac,2 = 99,32,15,lan_all
DEF cpmac,3 = 99,32,15,lan_all
DEF cpmac,4 = 99,32,15,lan_all
DEF usb,0 = 99,32,16,usb
DEF usb,1 = 99,32,16,usb
DEF budget,0 = 99,32,17,budget
DEF adsl,0 = 99,32,18,adsl
DEF adsl,1 = 99,32,18,adsl
DEF ata,0 = 99,32,19,ata
DEF tr69,0 = 99,32,20,tr69
DEF tr69,1 = 99,32,20,tr69
DEF tr69,2 = 99,32,20,tr69
DEF tr69,3 = 99,32,20,tr69
DEF tr69,4 = 99,32,20,tr69
DEF voip_con,0 = 99,32,21,voip_con
DEF voip_con,1 = 99,32,21,voip_con
DEF isdn,0 = 99,32,22,isdn
DEF isdn,1 = 99,32,22,isdn
DEF isdn,2 = 99,32,22,isdn
DEF dect,0 = 99,32,23,dect
DEF null,0 = 99,32,24,null_device
MAP budget,0 TO info,1
MAP ata,0 TO power,1
MAP adsl,0 TO power,0
MAP stick_surf,0 TO info,4
SET power,0 = 1
