17:29:13.575 dtmfbox.c PJSIP 0.7.0-trunk
17:29:13.605 pjlib select() I/O Queue created (0x4f8654)
17:29:13.606 sip_endpoint.c Module "mod-msg-print" registered
17:29:13.607 capi_ctrl.c Init CAPI...
17:29:13.616 capi_ctrl.c CAPI initialized!
17:29:13.617 voip_ctrl.c Init VOIP...
17:29:13.618 voip_ctrl.c Resolve IP from stun.1und1.de:3478 ...
17:29:13.759 voip_ctrl.c Use IP: 87.169.31.169
17:29:13.761 udp0x51ba0c SIP UDP transport started, published address is 87.169.31.169:5061
17:29:13.762 voip_ctrl.c UDP server listening on port 5061
17:29:13.767 sip_endpoint.c Module "mod-tsx-layer" registered
17:29:13.768 sip_endpoint.c Module "mod-stateful-util" registered
17:29:13.773 sip_endpoint.c Module "mod-ua" registered
17:29:13.774 voip_ctrl.c VOIP callbacks initialized
17:29:13.775 sip_endpoint.c Module "mod-invite" registered
17:29:13.776 sip_endpoint.c Module "dtmfbox" registered
17:29:13.794 pjlib select() I/O Queue created (0x541d54)
17:29:13.949 voip_ctrl.c RTP/RTCP: 87.169.31.169:61262-61263
17:29:14.095 voip_ctrl.c RTP/RTCP: 87.169.31.169:61264-61265
17:29:14.240 voip_ctrl.c RTP/RTCP: 87.169.31.169:61266-61267
17:29:14.386 voip_ctrl.c RTP/RTCP: 87.169.31.169:61268-61269
17:29:14.534 voip_ctrl.c RTP/RTCP: 87.169.31.169:61270-61271
17:29:14.679 voip_ctrl.c RTP/RTCP: 87.169.31.169:61272-61273
17:29:14.823 voip_ctrl.c RTP/RTCP: 87.169.31.169:61274-61275
17:29:14.968 voip_ctrl.c RTP/RTCP: 87.169.31.169:61276-61277
17:29:14.969 voip_ctrl.c RTP/RTCP transport running from port 4000 to 4015
17:29:16.590 voip_ctrl.c VOIP initialized!
17:29:16.598 voip_auth.c SIP (TX-REGISTER):
REGISTER sip:212.227.15.197 SIP/2.0
Via: SIP/2.0/UDP 87.169.31.169:5061;rport;branch=z9hG4bKPj0a410000000375cb6c55
Max-Forwards: 70
[email protected]>;tag=0a410000000275cb6c55
To: <sip:
[email protected]>
Call-ID: 0a410000000175cb6c55
CSeq: 36773 REGISTER
User-Agent: dtmfbox v0.3.8
Contact: <sip:
[email protected]>;expires=3600
Expires: 3600
Content-Length: 0
17:29:16.600 capi_ctrl.c Listen to CAPI incoming controller 1...
17:29:16.602 capi_ctrl.c Listen to CAPI internal controller 3...
17:29:16.605 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
17:29:16.606 capi_ctrl.c (CNF, CTRL 3, PLCI: 0) - CAPI_LISTEN
17:29:16.607 voip_ctrl.c Start VOIP listen loop...
17:29:16.718 voip_auth.c SIP (RX-REGISTER):
SIP/2.0 200 OK
Via: SIP/2.0/UDP 87.169.31.169:5061;rport=5061;branch=z9hG4bKPj0a410000000475cb6c55
To: <sip:
[email protected]>;tag=a6a1c5f60faecf035a1ae5b6e96e979a-9149
CSeq: 36774 REGISTER
Contact: <sip:
[email protected];uniq=CAB8543514A0F46EAE7B3F0EC2C75>;expires=28761, <sip:
[email protected]>;expires=28593
Server: UI OpenSer
Content-Length: 0
17:29:16.719 voip_auth.c SIP registration successful (212.227.15.197), status=14
17:29:16.720 voip_auth.c Next registration in 28593 sec
17:29:24.204 voip_funcs.c Call: sip:
[email protected] -> sip:8xxxx7
17:29:24.205 voip_funcs.c Create UAC dialog
17:29:24.206 voip_funcs.c Create SDP
17:29:24.208 voip_funcs.c Create INVITE
17:29:24.505 sip_resolve.c Failed to resolve '8xxxxx7'. Err=70018 (gethostbyname() has returned error (PJ_ERESOLVE))
17:29:24.506 tsx0x574064 Failed to send Request msg INVITE/cseq=1250654575 (tdta0x57305c)! err=70018 (gethostbyname() has returned error (PJ_ERESOLVE))
17:29:24.507 voip_events.c Call DISCONNECTED [port=0, reason=503 (Service Unavailable)]
17:29:24.508 voip_events.c Hangup [0]
17:29:24.557 script_funcs.c Run script: /var/media/ftp/USBDISK2-0-Partition-0-1/dtmfbox-0.3.8-usb/script/script_main.sh DISCONNECT VOIP OUTGOING 0 -1 "496xxxxxxxx7" "8xxxx7" &
17:29:24.773 voip_funcs.c ERR: (70018) Unable to send invite request!
17:29:24.774 script_funcs.c VoIP call ( -> )
17:30:34.403 capi_funcs.c (CTRL 1, MSN: 8xxxx7 - No:
[email protected]) - CONNECT_REQ
17:30:34.405 script_funcs.c CAPI call (812847 ->
[email protected])
17:30:34.407 capi_ctrl.c (CNF, CTRL 1, PLCI: 4353) - CAPI_CONNECT
17:30:34.611 capi_ctrl.c (IND, CTRL 1, PLCI: 4353) - CAPI_INFO
17:30:34.613 capi_ctrl.c (IND, CTRL 1, PLCI: 4353) - CAPI_DISCONNECT
17:30:34.701 script_funcs.c Run script: /var/media/ftp/USBDISK2-0-Partition-0-1/dtmfbox-0.3.8-usb/script/script_main.sh DISCONNECT ISDN OUTGOING 0 -1 "8xxxx7" "
[email protected]" &
</pre>
