<html><body>
<pre id="cmd_output">
13:00:02.375 dtmfbox.c PJSIP 0.5.10.2-trunk
13:00:02.404 pjlib select() I/O Queue created (0x4f7a54)
13:00:02.405 sip_endpoint.c Module "mod-msg-print" registered
13:00:02.407 capi_ctrl.c Init CAPI...
13:00:02.416 capi_ctrl.c CAPI initialized!
13:00:02.417 voip_ctrl.c Init VOIP...
13:00:02.418 voip_ctrl.c Resolve IP from stun.1und1.de:3478 ...
13:00:02.560 voip_ctrl.c Use IP: 87.169.57.224
13:00:02.562 udp0x51ae0c SIP UDP transport started, published address is 87.169.57.224:5061
13:00:02.563 voip_ctrl.c UDP server listening on port 5061
13:00:02.568 sip_endpoint.c Module "mod-tsx-layer" registered
13:00:02.568 sip_endpoint.c Module "mod-stateful-util" registered
13:00:02.573 sip_endpoint.c Module "mod-ua" registered
13:00:02.574 voip_ctrl.c VOIP callbacks initialized
13:00:02.576 sip_endpoint.c Module "mod-invite" registered
13:00:02.577 sip_endpoint.c Module "dtmfbox" registered
13:00:02.594 pjlib select() I/O Queue created (0x541154)
13:00:02.604 voip_ctrl.c RTP/RTCP: 87.169.57.224:4000-4001
13:00:02.607 voip_ctrl.c RTP/RTCP: 87.169.57.224:4002-4003
13:00:02.609 voip_ctrl.c RTP/RTCP: 87.169.57.224:4004-4005
13:00:02.613 voip_ctrl.c RTP/RTCP: 87.169.57.224:4006-4007
13:00:02.616 voip_ctrl.c RTP/RTCP: 87.169.57.224:4008-4009
13:00:02.619 voip_ctrl.c RTP/RTCP: 87.169.57.224:4010-4011
13:00:02.622 voip_ctrl.c RTP/RTCP: 87.169.57.224:4012-4013
13:00:02.625 voip_ctrl.c RTP/RTCP: 87.169.57.224:4014-4015
13:00:02.626 voip_ctrl.c RTP/RTCP transport running from port 4000 to 4015
13:00:04.893 voip_ctrl.c VOIP initialized!
13:00:04.901 voip_ctrl.c Start VOIP listen loop...
13:00:04.946 voip_auth.c SIP-Message (REGISTER):
REGISTER sip:sip.1und1.de SIP/2.0
Via: SIP/2.0/UDP 87.169.57.224:5061;rport;branch=z9hG4bKPj098a0000000375cb6c55
Max-Forwards: 70
[email protected]>;tag=098a0000000275cb6c55
To: <sip:
[email protected]>
Call-ID: 098a0000000175cb6c55
CSeq: 57259 REGISTER
User-Agent: dtmfbox v0.3.7
Contact: <sip:
[email protected]:5061>;expires=3600
Expires: 3600
Content-Length: 0
13:00:04.948 capi_ctrl.c (ISDN/ANALOG): Listen to CAPI controller 1...
13:00:04.950 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
13:00:05.005 sip_auth_clien Unable to set auth for tdta0x56fc24: can not find credential for 87.169.57.224/Digest
13:00:05.006 voip_auth.c ERR: SIP registration error (sip.1und1.de), status=12!
13:00:05.007 voip_auth.c sip.1und1.de: (401) - Unauthorized
</pre>
<script>window.defaultStatus = "OK"</script>
</body></html>
