Changed development box and my 7270 now has no DSL
Can you please show the output of "strace -s 200 -e statfs df"?
root@fritz:/var/mod/root# strace -s 200 -e statfs df
Filesystem           1K-blocks      Used Available Use% Mounted on
statfs("/", {f_type=0x73717368, f_bsize=65536, f_blocks=3659, f_bfree=0, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
/dev/root                12864     12864         0 100% /
statfs("/proc", {f_type="PROC_SUPER_MAGIC", f_bsize=4096, f_blocks=0, f_bfree=0, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
statfs("/var", {f_type=0x1021994, f_bsize=4096, f_blocks=13562, f_bfree=13270, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
tmpfs                    54248      1168     53080   2% /var
statfs("/dev", {f_type=0x1021994, f_bsize=4096, f_blocks=13562, f_bfree=13558, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
dev                      54248        16     54232   0% /dev
statfs("/sys", {f_type="SYSFS_MAGIC", f_bsize=4096, f_blocks=0, f_bfree=0, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
statfs("/dev/pts", {f_type="DEVPTS_SUPER_MAGIC", f_bsize=4096, f_blocks=0, f_bfree=0, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
statfs("/var/media/ftp", {f_type=0x5941ff53, f_bsize=4096, f_blocks=0, f_bfree=112383, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
/var/dev/nand           524288     74756    449532  14% /var/media/ftp
statfs("/proc/bus/usb", {f_type=0x9fa2, f_bsize=4096, f_blocks=0, f_bfree=0, f_bavail=0, f_files=0, f_ffree=0, f_fsid={0, 0}, f_namelen=0}) = 0
I don't know why it should skip /var. Do have usbroot or anything lik
Regards
Oliver
I turned off "remove AVM_E2FSPROG" and now I get even less (/dev/mtdblock5 is missing now).
root@fritz:/var/mod/root# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                13.4M     13.4M         0 100% /
/dev/loop0              274.0K    253.0K      7.0K  97% /var/media/ftp
root@fritz:/var/mod/root# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /var type tmpfs (rw,relatime)
dev on /dev type tmpfs (rw,nosuid,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/loop0 on /var/media/ftp type ext2 (rw,relatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
It was the "replace kernel" that did it....
I guess I always had that turned on......
/dev/root                13.2M     13.2M         0 100% /
tmpfs                    29.2M    956.0K     28.3M   3% /var
dev                      29.2M     68.0K     29.1M   0% /dev
/dev/mtdblock5          768.0K    388.0K    380.0K  51% /data
/dev/mtdblock5 on /data type jffs2 (rw,relatime)
I have a renewed good feeling with the current firmware...
pffff
Is zabbix running now? Do you know how it tries to get the information about free space?
Perhaps the difference has to do with full shmem or ramfs/tmpfs options?
Regards
Oliver
I didn't look at the source of Zabbix on how it's getting the info about free space.
it's working now. I finally can get 1.8 on all my boxes.
Is there any chance that Zabbix can be chosen by default?
I wrote some interesting stuff to monitor the fritzbox.
Yes, they do.I only made some changes to the config..I also need sudo and a /etc/busybox.conf that changes the privileges of ping. Some of the things I did were done by making a fwmod_custom
Zabbix does not run as root. It therefore can't do a ping by default. Full Linux boxes have set the suid flag on ping by default. Ping is not a file, but a symlink to busybox.
Busybox has a solution for this, but it needs a busybox.conf
I have just flashed a new build of the latest trunk and DSL annex A works now.
Thanks MaxMuster and Oliver for looking into this and fixing it!
