root@fritz:/var/mod/root# dmesg
Linux version 2.6.32.21 (gcc version 4.4.7 (GCC) ) #1 Mon Jun 18 15:06:22 CEST 2012
bootconsole [early0] enabled
CPU revision is: 00019068 (MIPS 4KEc)
[memsize] memsize=0x4000000
[ur8_pci_init]
ur8_clk_get_pll_factor: 300000000
ur8_get_pci_clock 33333333
[pci] default: 33 MHz
[setup_pci_master]
[setup_pci_slave]
Exposing 67108864 memory over PCI
Setup Complete, Enabling PCI Interface
PCI Interface Running
registering PCI controller with io_map_base unset
PCI controller initialized
TI UR8 (7270), ID: 0x0030, Revision: 0x10
Determined physical RAM map:
memory: 00100000 @ 14000000 (bootloader)
memory: 03e60000 @ 14100000 (usable)
memory: 000a0000 @ 17f60000 (reserved)
memory: 00000000 @ 18000000 (usable)
Wasting 8192 bytes for tracking 256 unused pages
Zone PFN ranges:
Normal 0x00014000 -> 0x00018000
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0x00014000 -> 0x00018000
On node 0 totalpages: 16384
free_area_init_node: node 0, pgdat 94493310, node_mem_map 95000000
Normal zone: 128 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 16256 pages, LIFO batch:3
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line:
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[trap_init] rollback = 1
[trap_init] cpu_has_ejtag
[trap_init] cpu_has_divec
[trap_init] cpu_has_mcheck
[trap_init] cpu_has_4kex
[per_cpu_trap_init] ebase before writing 0x80000000, new ebase 0x80000000
Primary instruction cache 16kB, VIPT, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 16 bytes
Memory: 58952k/63872k available (2744k kernel code, 4852k reserved, 917k data, 152k init, 0k highmem)
Hierarchical RCU implementation.
NR_IRQS:256
[arch_init_irq]
[uart_avm_post_setup_ports] setup membase=0xa8610e00 for uart0
[uart_avm_set_termios] old_dll=98, old_dlh=0
[uart_avm_set_termios] baudrate=38400, quot=98, dll=98, dlh=0
console [ttyS0] enabled, bootconsole disabled
Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Mount-cache hash table entries: 512
NET: Registered protocol family 16
[cpmac] Version: 1.108.1.78 - Revision 811:1364 - Fr 1.07.2011 14:42:22
cpmac: compiled with sizeof(struct sk_buff) = 176
MUSB UR8 pdev active!
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
pci 0000:00:0e.0: reg 10 32bit mmio: [0x000000-0x00ffff]
Master and Slave Enabled
NET: Registered protocol family 8
NET: Registered protocol family 20
musb_hdrc: version 6.0, cppi-dma, host, debug=0
musb_hdrc: ConfigData=0x06 (UTMI-8, dyn FIFOs, SoftConn)
musb_hdrc: MHDRC RTL version 1.500
musb_hdrc: setup fifo_mode 2
musb_hdrc: 8/9 max ep, 3648/4096 memory
musb_core_init 1505: musb_hdrc: hw_ep 0shared, max 64
musb_core_init 1505: musb_hdrc: hw_ep 1tx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 1rx, max 512
musb_core_init 1505: musb_hdrc: hw_ep 2tx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 2rx, max 512
musb_core_init 1505: musb_hdrc: hw_ep 3tx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 3rx, max 512
musb_core_init 1513: musb_hdrc: hw_ep 4rx, max 512
musb_hdrc: USB Host mode controller at a3400000 using DMA, IRQ 39
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[loadcontrol]module musb_hdrc registered
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.32.21 musb-hcd
usb usb1: SerialNumber: musb_hdrc
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
[simple_profiling] 0 entries 50 min
squashfs: version 3.4 (2008/08/26) Phillip Lougher
msgmni has been set to 115
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 254)
io scheduler noop registered (default)
[avm_membench_init]
avm_net_trace: Up and running.
[loadcontrol] set auto - scale=1
[avm] configured: watchdog event debug enable direct gpio
AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jun 18 2012 15:02:07)
[simple-profiling]: no performance counters implemented
[avm]: AVM Simple Profiling enabled.
Serial: SERIAL_AVM_8250 driver
[uart_avm_request_port] request port 0
ttyS0 at MMIO 0x0 (irq = 15) is a PORT_16550A
physmap platform flash device: 01000001 at 10000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
Don't use write buffer on ST flash M29W128G
physmap-flash.0: CFI does not contain boot bank location. Assuming top.
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
6 find_squashfs partitions found on MTD device physmap-flash.0
Creating 6 MTD partitions on "physmap-flash.0":
0x000000160300-0x000000f80000 : "rootfs"
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
0x000000020000-0x000000160300 : "kernel"
mtd: partition "kernel" doesn't end on an erase block -- force read-only
0x000000000000-0x000000020000 : "urlader"
0x000000f80000-0x000000fc0000 : "tffs (1)"
0x000000fc0000-0x000001000000 : "tffs (2)"
0x000000ec0000-0x000000f80000 : "jffs2"
Generic platform RAM MTD, (c) 2004 Simtec Electronics
[dectsync] inactive
prefetch_code: 9426b650: len=1832
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
CAPI Subsystem Rev 1.1.2.8
TCP cubic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 10
NET: Registered protocol family 17
PCI_STATUS_SET: 60000
PCI_STATUS_CLR: 60000
PCI_HOST_INT_EN: 0
PCI_HOST_INT_CLR: 0
PCI_BE_INT_En: 0
PCI_BE_INT_CLR: 0
[pci_int_init] done
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
[squashfs] use lzma compression
VFS: Mounted root (squashfs filesystem) readonly on device 31:0.
Freeing bootloader memory: 1024k freed
Freeing unused kernel memory: 152k freed
[uart_avm_startup] Setup IRQ 15
TFFS Name Table G
led_modul_Fritz_Box_7270plus: module license '
(C) Copyright 2008 by AVM
' taints kernel.
Disabling lock debugging due to kernel taint
[led_gpio_bit_driver_init] gpio 1 name power
[led_gpio_bit_driver_init] gpio 9 name internet
[led_gpio_bit_driver_init] gpio 27 name festnetz
[led_gpio_bit_driver_init] gpio 28 name wlan
[led_gpio_bit_driver_init] gpio 17 name dual1
[led_gpio_bit_driver_init] gpio 35 name dual2
[button_init] name button_wlan gpio 25 active low
[button_init] name button_dect gpio 23 active low
[button_init] name button_both gpio 0 active high
AVM_WATCHDOG: System Init UEberwachung 480 Sekunden
[avm_debug]standard kernel-messages
[piglet]use gpio-settings for 145
patch_dectfw: c0b70000, totallen = 68523(10bab)
patch_dectfw: patch_adress: f103a max_len: 26 with Version 2 Len: 17
dect_loader: fast-bootmode
dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_488.hex' successfull
[piglet]bitfile '/lib/modules/bitfile.bit'
[piglet] clock from pll3(384000000)
[piglet] bitfile 169293 bytes done
[piglet]TDM: FS: 8000 Hz CLK:2048010 Hz
JFFS2 version 2.2 (NAND) (ZLIB) (RTIME) (c) 2001-2006 Red Hat, Inc.
[4294938616]system-load 6 22 tasks:20 % curr:rc.S(1 %) max:init(12 %, pid:1), readytorun: 1, pgfault 1400/s (max 1 avg 1.0)
loop: module loaded
[pcmlink]svn: 1385
driver params overwritten io_addr=0x0 irq_num=0
[pcmlink]c55: simple checksum: 18EF96A
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
dect_uicp_from_dect, ignore 8 bytes, dect_manager not up: %B
ramzswap: /dev/ramzswap0 initialized: disksize_kb=8192
Adding 8184k swap on /dev/ramzswap0. Priority:-1 extents:1 across:8184k SS
dect_uicp_from_dect, ignore 16 bytes, dect_manager not up: %B
[4294939616]system-load 9 62 tasks:10 % curr:configd(0 %) max:udevd(1 %, pid:411), readytorun: 4, pgfault 4513/s (max 2 avg 1.0)
[dsl_ur8] DDC_cpsarChOpen done:0: Ch=15, Dir=TX
[dsl_ur8] DDC_cpsarChOpen done:0: Ch=15, Dir=RX
[dsl_ur8] driver version: 3.02.02.00
[dsl_ur8] before enabling Saras Digital Control: ADSLSS_PRCR(0xA1000500)=0x00000000!
[dsl_ur8] after enabling Saras Digital Control: ADSLSS_PRCR(0xA1000500)=0x000007FF!
[dsl_ur8] datapump path (/lib/modules/dsp_ur8/ur8-A-dsl.bin)
[dsl_ur8] DSP binary filesize = 433398 bytes
[dsl_ur8] shim_osLoadFWImage: Completed
[dsl_ur8] DSP image page address: (96500000)
[dsl_ur8] PM2EMIF=06500000 DM2EMIF=06500000 at DSLSS Start Time. PM2EMIF changes when DSL DP runs
[dsl_ur8] dslhal_support_hostDspCodeDownload: Done. Datapump version: 01.52.51.32
[dsl_ur8] dsl serial number successfully set to "465249545a21426f78466f6e574c414e37323730094243303534333439304442"
[dsl_ur8] AVM Fw Version successfully set into EOC Stuct 74.05.06
[dsl_ur8] DDC_dsl_init: Done
[dsl_ur8] DDC_atm_init: Done priv = 96dbbc00
[dsl_ur8] DDA_atm_irq_request: SAR Interrupt registered
[dsl_ur8] AVM Datapump
[dsl_ur8] DDA_atm_irq_request: DSL Interrupt registered
[dsl_ur8] Powermanagment (States => 1,10) supported!
[dsl_ur8] Loading Linux DSL Driver done
kdsldmod: init start (Sep 8 2011 17:19:05) sizeof(struct sk_buff)=176
kdsldmod: init done
[dsl_ur8] ioctl set inventory invoked
[dsl_ur8] dsl serial number successfully set to "424330353433343930444242204621426f78373237302037342e30352e303600"
eth: port 0 status 2 throttle 0
eth: port 1 status 1 throttle 1
[cpmac] [adm_power_config] tried to set a mode 1 that is not possible for this port 1.
[avm_power] : ethernet switch failed
eth: port 2 status 1 throttle 1
[cpmac] [adm_power_config] tried to set a mode 1 that is not possible for this port 2.
[4294940658]system-load 100 % 38 tasks:11 % curr:ctlmgr(9 %) max:ctlmgr(9 %, pid:695), readytorun: 3, pgfault 1277/s (max 2 avg 1.0)
eth: port 3 status 1 throttle 1
[cpmac] [adm_power_config] tried to set a mode 1 that is not possible for this port 3.
[dsl_ur8] hwrev=145 is_ATA_Ld_Hw=0
[dsl_ur8] from ATA to DSL Mode
[dsl_ur8] DSP in QUIET Mode. State Machine is being restarted
ADDRCONF(NETDEV_UP): cpmac0: link is not ready
[dsl_ur8] SARAS PWDREG = 0x0000
ADDRCONF(NETDEV_UP): eth0: link is not ready
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
[4294941733]system-load 100 % 55 tasks:33 % curr:capi_oslib/0(0 %) max:ctlmgr(16 %, pid:695), readytorun: 4, pgfault 6933/s (max 2 avg 1.0)
ADDRCONF(NETDEV_CHANGE): cpmac0: link becomes ready
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
lan: port 1(eth0) entering forwarding state
[4294942762]system-load 100 % 59 tasks:20 % curr:wlancfgctl(0 %) max:telefon(5 %, pid:1461), readytorun: 1, pgfault 6125/s (max 2 avg 1.0)
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (427070 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=2443 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=3383 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=3483 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=3583 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=6503 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=6909 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=67109081 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=7426 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=80 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=8926 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=11676 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=11676 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=11676 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=11949 mW
SysRq : Changing Loglevel
Loglevel set to 4
[dsl_ur8] DSL in Sync
[dsl_ur8] dslhal_support_processMailBox: Received DSP_ATM_TC_SYNC at 4294943444
[dsl_ur8] ATM TC in Sync
[dsl_ur8] activating vpi=0 vci=35
[dsl_ur8] DDC_cpsarChOpen done:0: Ch=0, Dir=RX
[dsl_ur8] DDC_cpsarChOpen done:0: Ch=0, Dir=TX
[dsl_ur8] Successfully opened vpi=0 vci=35 chan=0
kdsld_token_thread: start
sch_llq: Sep 7 2011 16:59:01
[4294943783]system-load 100 % 70 tasks:33 % curr:luacgi(20 %) max:luacgi(20 %, pid:2040), readytorun: 3, pgfault 6250/s (max 1 avg 1.0)
rtc-avm rtc-avm.0: rtc core: registered avm as rtc0
[avm-rtc]: avm_rtc_probe: register: ret=0x967fb000
[avm-rtc]: avm_rtc_probe: success
[4294944937]system-load 6 65 tasks:20 % curr:luacgi(11 %) max:luacgi(11 %, pid:2663), readytorun: 1, pgfault 4421/s (max 1 avg 1.0)
/proc/tffs: info request: success
[4294947235]system-load 1 70 tasks:3 % curr:rc.telnetd(0 %) max:ctlmgr(1 %, pid:695), readytorun: 2, pgfault 871/s (max 1 avg 1.0)
[4294956048]system-load 2 73 tasks:1 % curr:modhosts(0 %) max:CPMAC workqueue(0 %, pid:7), readytorun: 2, pgfault 1098/s (max 1 avg 1.0)
[4294960697]system-load 4 66 tasks:4 % curr:luacgi(2 %) max:luacgi(2 %, pid:4191), readytorun: 1, pgfault 732/s (max 1 avg 1.0)
[4294962984]system-load 1 66 tasks:9 % curr:ctlmgr(2 %) max:luacgi(5 %, pid:4193), readytorun: 2, pgfault 64/s (max 1 avg 1.0)
[4294964617]system-load 1 66 tasks:8 % curr:dropbear(6 %) max:dropbear(6 %, pid:4195), readytorun: 2, pgfault 32/s (max 1 avg 1.0)
root@fritz:/var/mod/root# lsmod
Module Size Used by Tainted: P
rtc_avm 5216 0
rtc_core 15149 1 rtc_avm
sch_sfq 5489 4
sch_llq 8309 1
sch_tbf 4386 1
kdsldmod 1015553 4
dsl_ur8 183779 1
ramzswap 17338 1
lzo_compress 1882 1 ramzswap
lzo_decompress 2047 1 ramzswap
dect_io 11542 0
avm_dect 235989 1 dect_io
capi_codec 411701 0
isdn_fbox_fon5 769369 5
pcmlink 336297 3 avm_dect,capi_codec,isdn_fbox_fon5
loop 13569 2
jffs2 101490 1
Piglet_noemif 42466 0
led_modul_Fritz_Box_7270plus 62648 2
root@fritz:/var/mod/root# ps
PID USER VSZ STAT COMMAND
1 root 1160 S init
2 root 0 SW [kthreadd]
3 root 0 SW [ksoftirqd/0]
4 root 0 SW [events/0]
5 root 0 SW [khelper]
6 root 0 SW [async/mgr]
7 root 0 SW [CPMAC workqueue]
8 root 0 SW [sync_supers]
9 root 0 SW [bdi-default]
10 root 0 SW [kblockd/0]
11 root 0 SW [khubd]
12 root 0 SW [kswapd0]
13 root 0 SW [aio/0]
14 root 0 SW [crypto/0]
18 root 0 SW [pm_info]
19 root 0 SWN [avmdebug]
20 root 0 SW [mtdblockd]
21 root 0 SW [tffsd_mtd_0]
75 root 0 SW [cleanup_timer_f]
177 root 0 SWN [jffs2_gcd_mtd5]
197 root 0 SW< [loop0]
208 root 0 SW [capi_oslib]
209 root 0 SW [capi_oslib/0]
210 root 0 SW [capitransp]
212 root 0 SW [flush-7:0]
214 root 0 SW< [avm_dect_thread]
215 root 0 SW [ksock tcp worke]
216 root 0 SW [ksock tcp serve]
411 root 1056 S < /sbin/udevd --daemon
522 root 1060 S < /sbin/udevd --daemon
592 root 3840 S /bin/configd
687 root 0 SWN [dectuart_route]
695 root 10768 S /usr/bin/avm/ctlmgr
700 root 4280 S upnpd
723 root 4412 S multid -t -d
735 root 10768 S /usr/bin/avm/ctlmgr
736 root 10768 S /usr/bin/avm/ctlmgr
737 root 10768 S /usr/bin/avm/ctlmgr
958 root 4412 S multid -t -d
1200 root 4280 S upnpd
1201 root 4280 S upnpd
1202 root 4280 S upnpd
1449 root 4940 S dsld -i -n
1461 root 5012 S telefon a127.0.0.1
1466 root 4696 S < voipd
1472 root 3628 S pbd
1473 root 3628 S pbd
1477 root 3628 S pbd
1478 root 3628 S pbd
1496 root 5012 S telefon a127.0.0.1
1497 root 5012 S telefon a127.0.0.1
2002 root 824 S /bin/run_clock -c /dev/tffs -d
2199 root 0 SWN [kdsld_token]
2228 root 1152 S {busybox} inetd
2411 zabbix 1720 S N zabbix_agentd -c /mod/etc/zabbix_agentd.conf
2412 zabbix 1720 S N zabbix_agentd -c /mod/etc/zabbix_agentd.conf
2413 zabbix 1720 S N zabbix_agentd -c /mod/etc/zabbix_agentd.conf
2414 zabbix 1720 S N zabbix_agentd -c /mod/etc/zabbix_agentd.conf
2415 zabbix 1720 S N zabbix_agentd -c /mod/etc/zabbix_agentd.conf
2416 zabbix 1720 S N zabbix_agentd -c /mod/etc/zabbix_agentd.conf
2534 root 1056 S < /sbin/udevd --daemon
2630 root 1180 S /sbin/chronyd -f /var/tmp/chrony.conf
2634 root 1160 S init
3073 root 1136 S dropbear -p 22 -R
4186 root 1152 S {busybox} httpd-webcfg -P /var/run/webcfg.pid -p 61080 -c /mod/etc/webcf
4195 root 1200 S dropbear -p 22 -R
4198 root 1168 S -sh
4230 root 1156 R {busybox} ps
root@fritz:/var/mod/root# ls /proc/avalanche/
avsar_PMDTestus avsar_feature_bits avsar_rxsnr1
avsar_QLNpsds avsar_modem_stats avsar_rxsnr2
avsar_SNRpsds avsar_modem_training avsar_rxsnr3
avsar_bit_allocation_table avsar_oam_ping avsar_sarhal_stats
avsar_channels avsar_private avsar_ver
avsar_define_bits avsar_pvc_table base_psp_version
avsar_dsl_modulation_schemes avsar_qos_enable clear_eoc_stats
avsar_dsllabor avsar_rxsnr0 dsllabor
