Changed development box and my 7270 now has no DSL
This is a fresh checkout.
I only change the model inside "make menuconfig"
The resulting firmware has no ADSL.
The one Maxmuster made DOES have a working ADSL
freetz@freetz:~$ cd ~
freetz@freetz:~$ mv trunk trunk_with_zabbix
freetz@freetz:~$ svn co http://svn.freetz.org/trunk
A    trunk/.build-prerequisites
A    trunk/toolchain
A    trunk/toolchain/.gitignore
A    trunk/toolchain/Config.in.override
A    trunk/toolchain/make
A    trunk/toolchain/make/kernel
A    trunk/toolchain/make/kernel/ccache
A    trunk/toolchain/make/kernel/ccache/ccache.mk
A    trunk/toolchain/make/kernel/binutils
A    trunk/toolchain/make/kernel/binutils/binutils.mk
A    trunk/toolchain/make/kernel/binutils/2.22
A    trunk/toolchain/make/kernel/binutils/2.18
A    trunk/toolchain/make/kernel/binutils/2.18/300-012_check_ldrunpath_length.patch
A    trunk/toolchain/make/kernel/binutils/2.18/010-use_bundled_mkstemps.patch
A    trunk/toolchain/make/kernel/binutils/2.18/100-makeinfo-version.patch
A    trunk/toolchain/make/kernel/binutils/2.18/300-001_ld_makefile_patch.patch
A    trunk/toolchain/make/kernel/binutils/2.18/999-999_missing.patch
A    trunk/toolchain/make/kernel/binutils/2.18/005-no_docs__no_nls.patch
A    trunk/toolchain/make/kernel/gcc
A    trunk/toolchain/make/kernel/gcc/gcc.mk
A    trunk/toolchain/make/kernel/gcc/3.4.6
A    trunk/toolchain/make/kernel/gcc/3.4.6/005-no_docs.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/910-mbsd_multi.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/gcc_ignore_config_cache.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/010-make-j-fixes-pr42980_backport.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/pr15068-fix.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/010-use_bundled_mkstemps.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/collect_arguments.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/pr16276-fix.patch
A    trunk/toolchain/make/kernel/gcc/3.4.6/pr22541-fix-fixincl.patch
A    trunk/toolchain/make/kernel/gcc/4.6.3
A    trunk/toolchain/make/Makefile.in
A    trunk/toolchain/make/kernel-toolchain.mk
A    trunk/toolchain/make/target
A    trunk/toolchain/make/target/libtool-host
A    trunk/toolchain/make/target/libtool-host/libtool-host.mk
A    trunk/toolchain/make/target/libtool-host/patches
A    trunk/toolchain/make/target/uclibc
A    trunk/toolchain/make/target/uclibc/0.9.29
A    trunk/toolchain/make/target/uclibc/0.9.29/102-termios.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/012-getaddrinfo_allow_numeric_service_without_any_hints.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/250-iconv-typo-fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/190-install_tls.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/150-fix-ldso-text-realloc-segfault.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/002-conditional_sched_affinity.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/005-fix_internal_function_definition.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/800-no_libnsl_no_libresolv.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/120-adjtimex.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/516-backport__progname.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/003-hardwired_abspath.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/300-readdir_r-fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/009-fix_getaddrinfo_infinite_loop.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/100-fritzbox_specific_arch_flags.freetz.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/520-move_dl_iterate_phdr.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/008-fix_getaddrinfo_numericserv.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/200-libpthread_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/140-fix-endless-recursion-in-pthread.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/161-mips_pipe_return_value.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/510-gcc_4_3_include_fixed.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/110-compat_macros.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/130-compile_fixes.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/560-utils_static_linking.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/138-pthreads.old-join_np.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/210-trunc.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/700-backport__defeat_compiler_opt.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/006-rm_whitespace.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/001-fix_mmap.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/580-assembler_warnings.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/004-fix_gethostent_r_failure_retval.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/160-mips_syscall_return_value.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/013-ipv6_defines_according_to_kernel_version.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/550-backport_realpath_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/139-pthreads.old-pthread_unlock-unlocked.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/220-libpthread_sysdep_fixes.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/515-backport__progname.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/600-fix_daylight_saving_time_handling.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/141-fix-daemon-to-support-pthread.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/180-fix_kernel_types_with_recent_kernel.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/010-fix_resolv_dnslookup.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/170-NTH_socket_h.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/590-crtn.S_explicit_size.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/530-backport_link_asneeded.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/260-iconv-reversed-endian-fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/010-avm-uclibc.patch
A    trunk/toolchain/make/target/uclibc/0.9.29/570-backport_nonpic_support.patch
A    trunk/toolchain/make/target/uclibc/Config.mod.0.9.28
A    trunk/toolchain/make/target/uclibc/Config.mod.0.9.29
A    trunk/toolchain/make/target/uclibc/Makefile.in
A    trunk/toolchain/make/target/uclibc/uclibc.mk
A    trunk/toolchain/make/target/uclibc/0.9.32.1
A    trunk/toolchain/make/target/uclibc/0.9.32.1/100-fritzbox_specific_arch_flags.freetz.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/200-no_forced_unwind.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/540-pregenerated_locale_data.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/350-use-fputs_unlocked.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/190-nptl_use_arch_default_stack_limit.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/110-compat_macros.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/410-llvm_workaround.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/138-pthreads.old-join_np.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/700-backport__defeat_compiler_opt.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/170-math_finite.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/180-pthread_weak_binding.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/131-inet-fix-__read_etc_hosts_r-segfault.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/660-force_absolute_interp_path.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/013-ipv6_defines_according_to_kernel_version.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/130-ldso-fix-__dl_parse_dynamic_info-segfault.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/139-pthreads.old-pthread_unlock-unlocked.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/120-adjtimex.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/135-fix-pthread.h.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/004-fix-gethostent_r-failure-retval.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/904-pthread_errno_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/300-readdir_r-fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/185-pthread_cleanup_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.32.1/650-IPv6_defines_with_IPv6_disabled.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2
A    trunk/toolchain/make/target/uclibc/0.9.33.2/200-no_forced_unwind.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/100-fritzbox_specific_arch_flags.freetz.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/540-pregenerated_locale_data.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/350-use-fputs_unlocked.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/190-nptl_use_arch_default_stack_limit.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/020-eventfd_proper_implementation.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/110-compat_macros.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/410-llvm_workaround.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/138-pthreads.old-join_np.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/170-math_finite.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/180-pthread_weak_binding.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/131-inet-fix-__read_etc_hosts_r-segfault.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/660-force_absolute_interp_path.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/013-ipv6_defines_according_to_kernel_version.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/139-pthreads.old-pthread_unlock-unlocked.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/120-adjtimex.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/021-eventfd_omit_prototype_if_not_available.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/135-fix-pthread.h.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/004-fix-gethostent_r-failure-retval.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/904-pthread_errno_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/185-pthread_cleanup_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/300-readdir_r-fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/650-IPv6_defines_with_IPv6_disabled.patch
A    trunk/toolchain/make/target/uclibc/0.9.33.2/011-dlsym_rtld_next_fix.patch
A    trunk/toolchain/make/target/uclibc/Config.mod.0.9.32.1
A    trunk/toolchain/make/target/uclibc/Config.mod.0.9.33.2
A    trunk/toolchain/make/target/uclibc/0.9.28
A    trunk/toolchain/make/target/uclibc/0.9.28/100-fritzbox_specific_arch_flags.freetz.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/010-getaddrinfo_allow_numeric_service_without_any_hints.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/520-move_dl_iterate_phdr.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/110-mips_pipe.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/170_update_queue_header.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/510-gcc_4_3_include_fixed.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/160-add_inotify_support.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/560-utils_static_linking.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/120-more_standard_math.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/700-backport__defeat_compiler_opt.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/800-no_libnsl_no_libresolv.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/119-backport_missing_libm_functions.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/200-ipv6_missing_sockopts.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/550-backport_realpath_fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/102-signal_handler_crash_workaround.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/600-fix_daylight_saving_time_handling.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/140-uclibc_do_div_ldso.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/590-crtn.S_explicit_size.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/300-readdir_r-fix.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/010-avm-uclibc-freetz-backport.patch
A    trunk/toolchain/make/target/uclibc/0.9.28/570-backport_nonpic_support.patch
A    trunk/toolchain/make/target/ccache
A    trunk/toolchain/make/target/ccache/ccache.mk
A    trunk/toolchain/make/target/binutils
A    trunk/toolchain/make/target/binutils/binutils.mk
A    trunk/toolchain/make/target/binutils/2.22
A    trunk/toolchain/make/target/binutils/2.22/300-012_check_ldrunpath_length.patch
A    trunk/toolchain/make/target/binutils/2.22/010-use_bundled_mkstemps.patch
A    trunk/toolchain/make/target/binutils/2.22/300-001_ld_makefile_patch.patch
A    trunk/toolchain/make/target/binutils/2.22/005-no_docs__no_nls.patch
A    trunk/toolchain/make/target/gcc
A    trunk/toolchain/make/target/gcc/gcc.mk
A    trunk/toolchain/make/target/gcc/4.6.3
A    trunk/toolchain/make/target/gcc/4.6.3/100-uclibc-conf.patch
A    trunk/toolchain/make/target/gcc/4.6.3/820-libgcc_pic.patch
A    trunk/toolchain/make/target/gcc/4.6.3/005-no_docs.patch
A    trunk/toolchain/make/target/gcc/4.6.3/110-overridable-CXXFLAGS_FOR_TARGET.patch
A    trunk/toolchain/make/target/gcc/4.6.3/010-make-j-fixes.pr42980_backport.install-multi.patch
A    trunk/toolchain/make/target/gcc/4.6.3/000-uClibc_pthread-miscompile-fix.patch
A    trunk/toolchain/make/target/gcc/4.6.3/800-libgcc-dwarf.patch
A    trunk/toolchain/make/target/gcc/4.6.3/010-make-j-fixes.pr42980_backport.multido.patch
A    trunk/toolchain/make/target/gcc/4.6.3/910-mbsd_multi.patch
A    trunk/toolchain/make/target/gcc/4.6.3/302-c99-snprintf.patch
A    trunk/toolchain/make/target/gcc/4.6.3/305-libmudflap-susv3-legacy.patch
A    trunk/toolchain/make/target/gcc/4.6.3/101-libgcc-exclude-rarely-used-functions.patch
A    trunk/toolchain/make/target/gcc/4.6.3/800-libgcc-disable-mips16-float.patch
A    trunk/toolchain/make/target/gcc/4.6.3/010-use_bundled_mkstemps.patch
A    trunk/toolchain/make/target/gcc/4.6.3/020-no_python.patch
A    trunk/toolchain/make/target/gcc/4.6.3/301-missing-execinfo_h.patch
A    trunk/toolchain/make/target/gcc/4.7.2
A    trunk/toolchain/make/target/gcc/4.7.2/100-uclibc-conf.patch
A    trunk/toolchain/make/target/gcc/4.7.2/820-libgcc_pic.patch
A    trunk/toolchain/make/target/gcc/4.7.2/005-no_docs.patch
A    trunk/toolchain/make/target/gcc/4.7.2/010-make-j-fixes.pr42980_backport.multido.patch
A    trunk/toolchain/make/target/gcc/4.7.2/110-overridable-CXXFLAGS_FOR_TARGET.patch
A    trunk/toolchain/make/target/gcc/4.7.2/910-mbsd_multi.patch
A    trunk/toolchain/make/target/gcc/4.7.2/010-make-j-fixes.pr42980_backport.install-multi.patch
A    trunk/toolchain/make/target/gcc/4.7.2/302-c99-snprintf.patch
A    trunk/toolchain/make/target/gcc/4.7.2/305-libmudflap-susv3-legacy.patch
A    trunk/toolchain/make/target/gcc/4.7.2/101-libgcc-exclude-rarely-used-functions.patch
A    trunk/toolchain/make/target/gcc/4.7.2/800-libgcc-disable-mips16-float.patch
A    trunk/toolchain/make/target/gcc/4.7.2/800-libgcc-dwarf.patch
A    trunk/toolchain/make/target/gcc/4.7.2/010-use_bundled_mkstemps.patch
A    trunk/toolchain/make/target/gcc/4.7.2/020-no_python.patch
A    trunk/toolchain/make/target/gcc/4.7.2/301-missing-execinfo_h.patch
A    trunk/toolchain/make/target-toolchain.mk
A    trunk/toolchain/make/download-toolchain.mk
A    trunk/toolchain/make/toolchain-common.in
A    trunk/kernel
A    trunk/kernel/Config.in.modules
A    trunk/kernel/external.files
A    trunk/kernel/external.in
A    trunk/kernel/Config.in.kernel
A    trunk/.defdynamic
A    trunk/include
A    trunk/include/site
A    trunk/include/site/freetz
A    trunk/include/site/mips-linux-uclibc
A    trunk/include/site/mipsel-linux-uclibc
A    trunk/include/make
A    trunk/include/make/010-special-characters-symbolic-names.mk
A    trunk/include/make/020-helper-functions.mk
A    trunk/howtos
A    trunk/howtos/en
A    trunk/howtos/en/HOWTO_recover.txt
A    trunk/howtos/en/HOWTO_integrate_own_files.txt
A    trunk/howtos/en/HOWTO_addons.txt
A    trunk/howtos/de
A    trunk/howtos/de/HOWTO_eigene_dateien.txt
A    trunk/howtos/de/HOWTO_recover.txt
A    trunk/howtos/de/HOWTO_addons.txt
A    trunk/fmake
A    trunk/.defstatic
A    trunk/STARTLEVEL
A    trunk/addon
A    trunk/addon/own-files-0.1
A    trunk/addon/own-files-0.1/root
A    trunk/addon/own-files-0.1/root/lib
A    trunk/addon/own-files-0.1/root/lib/.gitignore
A    trunk/addon/own-files-0.1/root/bin
A    trunk/addon/own-files-0.1/root/bin/.gitignore
A    trunk/addon/own-files-0.1/root/usr
A    trunk/addon/own-files-0.1/root/usr/lib
A    trunk/addon/own-files-0.1/root/usr/lib/.gitignore
A    trunk/addon/own-files-0.1/root/usr/bin
A    trunk/addon/own-files-0.1/root/usr/bin/.gitignore
A    trunk/addon/own-files-0.1/root/usr/sbin
A    trunk/addon/own-files-0.1/root/usr/sbin/.gitignore
A    trunk/addon/own-files-0.1/root/etc
A    trunk/addon/own-files-0.1/root/etc/init.d
A    trunk/addon/own-files-0.1/root/etc/init.d/.gitignore
A    trunk/addon/own-files-0.1/var.tar
A    trunk/addon/own-files-0.1/var.tar/var
A    trunk/addon/own-files-0.1/var.tar/var/tmp
A    trunk/addon/own-files-0.1/var.tar/var/tmp/.gitignore
A    trunk/addon/dynamic.pkg
A    trunk/addon/static.pkg
A    trunk/patches
A    trunk/patches/devices
A    trunk/patches/devices/05_5X
A    trunk/patches/devices/05_5X/120-rc.S-dev.patch
A    trunk/patches/devices/05_5X/130-foncalls.patch!
A    trunk/patches/devices/05_5X/105-S06-logging.sh
A    trunk/patches/devices/05_5X/140-rc.tail.sh-no_exit.patch
A    trunk/patches/devices/05_5X/de
A    trunk/patches/devices/05_5X/de/190-webmenu.patch
A    trunk/patches/devices/05_5X/200-tun-device.sh
A    trunk/patches/devices/05_5X/115-S20-modload.sh
A    trunk/patches/devices/04_XX
A    trunk/patches/devices/04_XX/fon
A    trunk/patches/devices/04_XX/fon/en
A    trunk/patches/devices/04_XX/fon/en/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/fon/en/130-foncalls.patch
A    trunk/patches/devices/04_XX/fon/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/fon/en/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/fon/en/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/fon/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/fon/de
A    trunk/patches/devices/04_XX/fon/de/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/fon/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/fon/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/fon/de/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/fon/de/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/fon/de/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/W501V
A    trunk/patches/devices/04_XX/W501V/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/W501V/200-tk-firmware.sh
A    trunk/patches/devices/04_XX/W501V/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/W501V/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/W501V/de
A    trunk/patches/devices/04_XX/W501V/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/W501V/de/180-tcom.patch
A    trunk/patches/devices/04_XX/W501V/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/W501V/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/W501V/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/W701V
A    trunk/patches/devices/04_XX/W701V/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/W701V/200-tk-firmware.sh
A    trunk/patches/devices/04_XX/W701V/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/W701V/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/W701V/de
A    trunk/patches/devices/04_XX/W701V/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/W701V/de/210-sp2fritz.patch
A    trunk/patches/devices/04_XX/W701V/de/180-tcom.patch
A    trunk/patches/devices/04_XX/W701V/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/W701V/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/W701V/210-copy-modules.sh
A    trunk/patches/devices/04_XX/3020
A    trunk/patches/devices/04_XX/3020/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/3020/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/3020/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/3020/de
A    trunk/patches/devices/04_XX/3020/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/3020/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/W900V
A    trunk/patches/devices/04_XX/W900V/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/W900V/200-tk-firmware.sh
A    trunk/patches/devices/04_XX/W900V/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/W900V/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/W900V/de
A    trunk/patches/devices/04_XX/W900V/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/W900V/de/200-sp2fritz.patch
A    trunk/patches/devices/04_XX/W900V/de/180-tcom.patch
A    trunk/patches/devices/04_XX/W900V/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/W900V/210-copy-modules.sh
A    trunk/patches/devices/04_XX/3030
A    trunk/patches/devices/04_XX/3030/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/3030/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/3030/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/3030/de
A    trunk/patches/devices/04_XX/3030/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/3030/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/5010
A    trunk/patches/devices/04_XX/5010/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/5010/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/5010/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/5010/a-ch
A    trunk/patches/devices/04_XX/5010/a-ch/130-foncalls.patch
A    trunk/patches/devices/04_XX/5010/a-ch/190-webmenu.patch
A    trunk/patches/devices/04_XX/5010/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/3130
A    trunk/patches/devices/04_XX/3130/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/3130/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/3130/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/3130/de
A    trunk/patches/devices/04_XX/3130/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/3130/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/3131
A    trunk/patches/devices/04_XX/3131/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/3131/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/3131/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/3131/de
A    trunk/patches/devices/04_XX/3131/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/3131/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/2170
A    trunk/patches/devices/04_XX/2170/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/2170/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/2170/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/2170/de
A    trunk/patches/devices/04_XX/2170/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/2170/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/5050
A    trunk/patches/devices/04_XX/5050/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/5050/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/5050/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/5050/de
A    trunk/patches/devices/04_XX/5050/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/5050/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/5050/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/5140
A    trunk/patches/devices/04_XX/5140/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/5140/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/5140/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/5140/de
A    trunk/patches/devices/04_XX/5140/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/5140/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/5140/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/5140/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/3170
A    trunk/patches/devices/04_XX/3170/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/3170/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/3170/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/3170/de
A    trunk/patches/devices/04_XX/3170/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/3170/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7112
A    trunk/patches/devices/04_XX/7112/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7112/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7112/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7112/de
A    trunk/patches/devices/04_XX/7112/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7112/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7112/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/7112/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7113
A    trunk/patches/devices/04_XX/7113/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7113/en
A    trunk/patches/devices/04_XX/7113/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/7113/en/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7113/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/7113/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7113/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7113/de
A    trunk/patches/devices/04_XX/7113/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7113/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7113/de/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7113/de/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/7113/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/7140
A    trunk/patches/devices/04_XX/7140/en
A    trunk/patches/devices/04_XX/7140/en/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7140/en/210-notmountable.patch
A    trunk/patches/devices/04_XX/7140/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/7140/en/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7140/en/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7140/en/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7140/en/400_remove_ftpd.patch
A    trunk/patches/devices/04_XX/7140/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/7140/a-ch
A    trunk/patches/devices/04_XX/7140/a-ch/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7140/a-ch/190-webmenu.patch
A    trunk/patches/devices/04_XX/7140/a-ch/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7140/a-ch/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7140/a-ch/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7140/de
A    trunk/patches/devices/04_XX/7140/de/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7140/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7140/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7140/de/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7140/de/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7140/de/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/7050
A    trunk/patches/devices/04_XX/7050/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7050/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7050/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7050/de
A    trunk/patches/devices/04_XX/7050/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7050/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7050/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/5124
A    trunk/patches/devices/04_XX/5124/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/5124/en
A    trunk/patches/devices/04_XX/5124/en/210-notmountable.patch
A    trunk/patches/devices/04_XX/5124/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/5124/en/400_remove_ftpd.patch
A    trunk/patches/devices/04_XX/5124/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/5124/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/5124/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/5124/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/300ip
A    trunk/patches/devices/04_XX/300ip/200-tk-firmware.sh
A    trunk/patches/devices/04_XX/300ip/en
A    trunk/patches/devices/04_XX/300ip/en/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/300ip/en/130-foncalls.patch
A    trunk/patches/devices/04_XX/300ip/en/140-third-phone.patch
A    trunk/patches/devices/04_XX/300ip/en/150-Eumex_to_Fritz.patch
A    trunk/patches/devices/04_XX/300ip/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/300ip/en/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/300ip/en/201-rc.conf-eumex2fon.patch
A    trunk/patches/devices/04_XX/300ip/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/300ip/200-tk-firmware-en
A    trunk/patches/devices/04_XX/300ip/de
A    trunk/patches/devices/04_XX/300ip/de/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/300ip/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/300ip/de/140-third-phone.patch
A    trunk/patches/devices/04_XX/300ip/de/150-Eumex_to_Fritz.patch
A    trunk/patches/devices/04_XX/300ip/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/300ip/de/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/300ip/de/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/300ip/de/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/300ip/200-tk-firmware-de
A    trunk/patches/devices/04_XX/7141
A    trunk/patches/devices/04_XX/7141/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7141/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7141/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7141/de
A    trunk/patches/devices/04_XX/7141/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7141/de/210-notmountable.patch
A    trunk/patches/devices/04_XX/7141/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7141/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/7141/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7141/400_remove_ftpd.patch
A    trunk/patches/devices/04_XX/7150
A    trunk/patches/devices/04_XX/7150/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7150/100-w500v_7150.sh
A    trunk/patches/devices/04_XX/7150/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7150/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7150/de
A    trunk/patches/devices/04_XX/7150/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7150/de/210-notmountable.patch
A    trunk/patches/devices/04_XX/7150/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7150/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/7150/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7150/400_remove_ftpd.patch
A    trunk/patches/devices/04_XX/7170
A    trunk/patches/devices/04_XX/7170/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7170/en
A    trunk/patches/devices/04_XX/7170/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/7170/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/7170/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7170/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7170/a-ch
A    trunk/patches/devices/04_XX/7170/a-ch/190-webmenu.patch
A    trunk/patches/devices/04_XX/7170/de
A    trunk/patches/devices/04_XX/7170/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7170/de/210-notmountable.patch
A    trunk/patches/devices/04_XX/7170/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7170/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/7170/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/7270
A    trunk/patches/devices/04_XX/7270/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7270/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7270/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7270/de
A    trunk/patches/devices/04_XX/7270/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/7270/de/210-notmountable.patch
A    trunk/patches/devices/04_XX/7270/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/7270/de/200-sperre1.patch
A    trunk/patches/devices/04_XX/7270/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/04_XX/wlan
A    trunk/patches/devices/04_XX/wlan/en
A    trunk/patches/devices/04_XX/wlan/en/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/wlan/en/130-foncalls.patch
A    trunk/patches/devices/04_XX/wlan/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/wlan/en/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/wlan/en/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/wlan/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/wlan/de
A    trunk/patches/devices/04_XX/wlan/de/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/wlan/de/130-foncalls.patch
A    trunk/patches/devices/04_XX/wlan/de/190-webmenu.patch
A    trunk/patches/devices/04_XX/wlan/de/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/wlan/de/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/wlan/de/290-replace_websrv-remove_igdd.patch
A    trunk/patches/devices/04_XX/7570
A    trunk/patches/devices/04_XX/7570/120-rc.S-dev.patch
A    trunk/patches/devices/04_XX/7570/en
A    trunk/patches/devices/04_XX/7570/en/130-foncalls.patch
A    trunk/patches/devices/04_XX/7570/en/210-notmountable.patch
A    trunk/patches/devices/04_XX/7570/en/190-webmenu.patch
A    trunk/patches/devices/04_XX/7570/en/200-sperre1.patch
A    trunk/patches/devices/04_XX/7570/110-rc.S-mknod.patch
A    trunk/patches/devices/04_XX/7570/130-rc.S-logging.patch
A    trunk/patches/devices/04_XX/7570/210-install-set_oem.sh
A    trunk/patches/devices/04_XX/7570/140-rc.S-no_avm_exit.patch
A    trunk/patches/devices/05_2X
A    trunk/patches/devices/05_2X/120-rc.S-dev.patch
A    trunk/patches/devices/05_2X/de
A    trunk/patches/devices/05_2X/3270
A    trunk/patches/devices/05_2X/3270/130-foncalls.patch
A    trunk/patches/devices/05_2X/3270/en
A    trunk/patches/devices/05_2X/3270/en/190-webmenu.patch
A    trunk/patches/devices/05_2X/3270/de
A    trunk/patches/devices/05_2X/3270/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/3270/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/3270/200-sperre1.patch
A    trunk/patches/devices/05_2X/7320
A    trunk/patches/devices/05_2X/7320/130-foncalls.patch
A    trunk/patches/devices/05_2X/7320/de
A    trunk/patches/devices/05_2X/7320/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/7320/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/7320/200-sperre1.patch
A    trunk/patches/devices/05_2X/3370
A    trunk/patches/devices/05_2X/3370/130-foncalls.patch
A    trunk/patches/devices/05_2X/3370/de
A    trunk/patches/devices/05_2X/3370/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/3370/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/3370/200-sperre1.patch
A    trunk/patches/devices/05_2X/7240
A    trunk/patches/devices/05_2X/7240/130-foncalls.patch
A    trunk/patches/devices/05_2X/7240/de
A    trunk/patches/devices/05_2X/7240/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/7240/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/7240/200-sperre1.patch
A    trunk/patches/devices/05_2X/7312
A    trunk/patches/devices/05_2X/7312/130-foncalls.patch
A    trunk/patches/devices/05_2X/7312/de
A    trunk/patches/devices/05_2X/7312/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/7312/200-sperre1.patch
A    trunk/patches/devices/05_2X/7330
A    trunk/patches/devices/05_2X/7330/130-foncalls.patch
A    trunk/patches/devices/05_2X/7330/190-webmenu.patch
A    trunk/patches/devices/05_2X/7330/de
A    trunk/patches/devices/05_2X/7330/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/7330/200-sperre1.patch
A    trunk/patches/devices/05_2X/7340
A    trunk/patches/devices/05_2X/7340/130-foncalls.patch
A    trunk/patches/devices/05_2X/7340/en
A    trunk/patches/devices/05_2X/7340/en/190-webmenu.patch
A    trunk/patches/devices/05_2X/7340/200-sperre1.patch
A    trunk/patches/devices/05_2X/115-S20-modload.sh
A    trunk/patches/devices/05_2X/7270
A    trunk/patches/devices/05_2X/7270/130-foncalls.patch
A    trunk/patches/devices/05_2X/7270/190-webmenu.patch
A    trunk/patches/devices/05_2X/7270/de
A    trunk/patches/devices/05_2X/7270/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/7270/200-sperre1.patch
A    trunk/patches/devices/05_2X/7360
A    trunk/patches/devices/05_2X/7360/130-foncalls.patch
A    trunk/patches/devices/05_2X/7360/190-webmenu.patch
A    trunk/patches/devices/05_2X/7360/de
A    trunk/patches/devices/05_2X/7360/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/7360/200-sperre1.patch
A    trunk/patches/devices/05_2X/6840
A    trunk/patches/devices/05_2X/6840/130-foncalls.patch
A    trunk/patches/devices/05_2X/6840/de
A    trunk/patches/devices/05_2X/6840/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/6840/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/6840/200-sperre1.patch
A    trunk/patches/devices/05_2X/en
A    trunk/patches/devices/05_2X/en/210-notmountable.patch
A    trunk/patches/devices/05_2X/7390
A    trunk/patches/devices/05_2X/7390/130-foncalls.patch
A    trunk/patches/devices/05_2X/7390/en
A    trunk/patches/devices/05_2X/7390/en/190-webmenu.patch
A    trunk/patches/devices/05_2X/7390/de
A    trunk/patches/devices/05_2X/7390/de/210-notmountable.patch
A    trunk/patches/devices/05_2X/7390/de/190-webmenu.patch
A    trunk/patches/devices/05_2X/7390/200-sperre1.patch
A    trunk/patches/devices/05_2X/140-rc.tail.sh-no_exit.patch
A    trunk/patches/devices/05_2X/105-S06-logging.sh
A    trunk/patches/devices/05_2X/200-tun-device.sh
A    trunk/patches/cond
A    trunk/patches/cond/intro_bar_middle_alien_7170.patch
A    trunk/patches/cond/mdev_my_uuid.patch
A    trunk/patches/cond/110-system_status.patch
A    trunk/patches/cond/de
A    trunk/patches/cond/de/webmenu-wol-W501V.patch
A    trunk/patches/cond/de/webmenu-wol-3020.patch
A    trunk/patches/cond/de/webmenu-wol-5140.patch
A    trunk/patches/cond/de/webmenu-wol-7330_SL.patch
A    trunk/patches/cond/de/webmenu-wol-7320.patch
A    trunk/patches/cond/de/webmenu-wol-7141.patch
A    trunk/patches/cond/de/480-alarmclock_7112.patch
A    trunk/patches/cond/de/480-alarmclock_7150.patch
A    trunk/patches/cond/de/remove_assistant_7113.patch
A    trunk/patches/cond/de/webmenu-wol-3270_v3.patch
A    trunk/patches/cond/de/webmenu-wol-7270_v1.patch
A    trunk/patches/cond/de/remove_assistant_7170.patch
A    trunk/patches/cond/de/webmenu-wol-7270_v3.patch
A    trunk/patches/cond/de/webmenu-wol-300ip_as_fon.patch
A    trunk/patches/cond/de/webmenu-wol-fon.patch
A    trunk/patches/cond/de/webmenu-wol-7270_v2_labor.patch
A    trunk/patches/cond/de/webmenu-wol-W900V.patch
A    trunk/patches/cond/de/webmenu-wol-7270_v3_labor.patch
A    trunk/patches/cond/de/remove_userman_old.patch
A    trunk/patches/cond/de/webmenu-wol-3131.patch
A    trunk/patches/cond/de/webmenu-wol-7112.patch
A    trunk/patches/cond/de/webmenu-wol-7050.patch
A    trunk/patches/cond/de/webmenu-wol-7312.patch
A    trunk/patches/cond/de/webmenu-wol-7150.patch
A    trunk/patches/cond/de/webmenu-wol-6840.patch
A    trunk/patches/cond/de/webmenu-wol-7390.patch
A    trunk/patches/cond/de/remove_assistant_7141.patch
A    trunk/patches/cond/de/iad2fritz-3331_7170.patch
A    trunk/patches/cond/de/480-alarmclock_7270_v1.patch
A    trunk/patches/cond/de/remove_userman_wlan_old.patch
A    trunk/patches/cond/de/webmenu-wol-7390_05_22.patch
A    trunk/patches/cond/de/webmenu-wol-7330_labor.patch
A    trunk/patches/cond/de/remove-FON3-7170-alien.patch
A    trunk/patches/cond/de/webmenu-wol-W701V.patch
A    trunk/patches/cond/de/remove_assistant.patch
A    trunk/patches/cond/de/webmenu-wol-2170.patch
A    trunk/patches/cond/de/webmenu-wol-7140.patch
A    trunk/patches/cond/de/webmenu-wol-7240.patch
A    trunk/patches/cond/de/webmenu-wol-7360_SL.patch
A    trunk/patches/cond/de/480-alarmclock_7170.patch
A    trunk/patches/cond/de/remove_assistant_7112.patch
A    trunk/patches/cond/de/remove_userman_new.patch
A    trunk/patches/cond/de/sp2fritz_W500V_7150.patch
A    trunk/patches/cond/de/webmenu-wol-3270_v2.patch
A    trunk/patches/cond/de/130-foncalls.patch
A    trunk/patches/cond/de/remove_assistant_7150.patch
A    trunk/patches/cond/de/webmenu-wol-7270_v2.patch
A    trunk/patches/cond/de/webmenu-wol-7360_SL_labor.patch
A    trunk/patches/cond/de/remove_assistant_7270_v1.patch
A    trunk/patches/cond/de/webmenu-wol-2170_vpn.patch
A    trunk/patches/cond/de/install-300ip-as-fon.patch
A    trunk/patches/cond/de/remove_userman_wlan_new.patch
A    trunk/patches/cond/de/sp2fritz-W701V_7170.patch
A    trunk/patches/cond/de/sp2fritz-W900V_7170.patch
A    trunk/patches/cond/de/webmenu-wol-3030.patch
A    trunk/patches/cond/de/webmenu-wol-3130.patch
A    trunk/patches/cond/de/webmenu-wol-5050.patch
A    trunk/patches/cond/de/webmenu-wol-3170.patch
A    trunk/patches/cond/de/webmenu-wol-7113.patch
A    trunk/patches/cond/de/webmenu-wol-7330.patch
A    trunk/patches/cond/de/webmenu-wol-3370.patch
A    trunk/patches/cond/de/webmenu-wol-7170.patch
A    trunk/patches/cond/de/480-alarmclock_7141.patch
A    trunk/patches/cond/de/remove_assistant_7140.patch
A    trunk/patches/cond/de/remove-POTS-7170-alien.patch
A    trunk/patches/cond/de/webmenu-wol-fon_wlan.patch
A    trunk/patches/cond/de/190-webmenu.patch
A    trunk/patches/cond/de/remove_assistant_wop.patch
A    trunk/patches/cond/rc.S-W900V_7170.patch
A    trunk/patches/cond/mdev_wlancfgchanged.patch
A    trunk/patches/cond/install-W701V_7170.patch
A    trunk/patches/cond/install-W900V_7170.patch
A    trunk/patches/cond/install-7141_7170_Annex_A.patch
A    trunk/patches/cond/a-ch
A    trunk/patches/cond/a-ch/remove_userman_wlan_new.patch
A    trunk/patches/cond/a-ch/webmenu-wol-5010.patch
A    trunk/patches/cond/a-ch/webmenu-wol-7140.patch
A    trunk/patches/cond/a-ch/webmenu-wol-7170.patch
A    trunk/patches/cond/a-ch/remove_userman_new.patch
A    trunk/patches/cond/install-3170_7170.patch
A    trunk/patches/cond/install-7112_7170.patch
A    trunk/patches/cond/install-7140_7170.patch
A    trunk/patches/cond/rc.S-no-cdrom-fallback.patch
A    trunk/patches/cond/rc.S-mknod-nophone.patch
A    trunk/patches/cond/mdev_rc.S.patch
A    trunk/patches/cond/rc.S-3170_7170_a_ch.patch
A    trunk/patches/cond/mdev_debug_rc.S.patch
A    trunk/patches/cond/install-3170_7170_a_ch.patch
A    trunk/patches/cond/rc.S-no-cdrom-fallback_5050.patch
A    trunk/patches/cond/install-IAD_3331_7170.patch
A    trunk/patches/cond/install-7570_HN.patch
A    trunk/patches/cond/275-multiple_printers
A    trunk/patches/cond/275-multiple_printers/01-c8d92a2301ba262c61747747a817ab20.patch
A    trunk/patches/cond/275-multiple_printers/02-47c36012e53934dc583c9d568711299d.patch
A    trunk/patches/cond/mdev_post_install_7170.patch
A    trunk/patches/cond/en
A    trunk/patches/cond/en/webmenu-wol-fon.patch
A    trunk/patches/cond/en/webmenu-wol-5124.patch
A    trunk/patches/cond/en/webmenu-wol-7113.patch
A    trunk/patches/cond/en/webmenu-wol-7140.patch
A    trunk/patches/cond/en/webmenu-wol-7330.patch
A    trunk/patches/cond/en/webmenu-wol-7340.patch
A    trunk/patches/cond/en/webmenu-wol-7170.patch
A    trunk/patches/cond/en/webmenu-wol-7360.patch
A    trunk/patches/cond/en/webmenu-wol-7570.patch
A    trunk/patches/cond/en/remove_assistant_7113.patch
A    trunk/patches/cond/en/webmenu-wol-fon_wlan.patch
A    trunk/patches/cond/en/webmenu-wol-3270_v3.patch
A    trunk/patches/cond/en/480-alarmclock_7570.patch
A    trunk/patches/cond/en/7240_7270_rc.S_piglet.patch
A    trunk/patches/cond/en/webmenu-wol-7270_v2.patch
A    trunk/patches/cond/en/webmenu-wol-7270_v3.patch
A    trunk/patches/cond/en/remove_assistant_7570.patch
A    trunk/patches/cond/en/webmenu-wol-7390_05_22.patch
A    trunk/patches/cond/en/install-7240_7270.patch
A    trunk/patches/cond/en/install-300ip-as-fon.patch
A    trunk/patches/cond/mdev_post_install_7270.patch
A    trunk/patches/cond/install-7140_7170_Annex_A.patch
A    trunk/patches/cond/mdev_fstab.patch
A    trunk/patches/cond/rc.S-mknod.patch
A    trunk/patches/cond/rc.S-3170_7170.patch
A    trunk/patches/cond/install-7113_7170.patch
A    trunk/patches/cond/install-7570_W920V.patch
A    trunk/patches/cond/install-7141_7170.patch
A    trunk/patches/cond/rc.S-no-cdrom-fallback_fon_04.49.patch
A    trunk/patches/cond/240-add-dsl-expert-pages
A    trunk/patches/cond/240-add-dsl-expert-pages/b66bb65288407a8256fac6b12375aa20.patch
A    trunk/patches/cond/240-add-dsl-expert-pages/9523ab3710a8b9dab7241b38fe70dfd3.patch
A    trunk/patches/cond/240-add-dsl-expert-pages/3d22178e52b07a6d6313f17d3b359218.patch
A    trunk/patches/cond/rc.S-no-cdrom-fallback_fon.patch
A    trunk/patches/scripts
A    trunk/patches/scripts/260-remove_tr069.sh
A    trunk/patches/scripts/100-7112_7170.sh
A    trunk/patches/scripts/195-webmenu_signed.sh
A    trunk/patches/scripts/100-7113_7170.sh
A    trunk/patches/scripts/220-assistant.sh
A    trunk/patches/scripts/382-enable-gsmvoice.sh
A    trunk/patches/scripts/220-remove-nas.sh
A    trunk/patches/scripts/331-remove-voipd.sh
A    trunk/patches/scripts/480-alarmclock.sh
A    trunk/patches/scripts/320-remove-dsld.sh
A    trunk/patches/scripts/325-remove-showdsldstat.sh
A    trunk/patches/scripts/110-system_status.sh
A    trunk/patches/scripts/101-ctlmgr_wrapper.sh
A    trunk/patches/scripts/550-add_reg_external_in_gui.sh
A    trunk/patches/scripts/560-remove_lsof.sh
A    trunk/patches/scripts/220-help.sh
A    trunk/patches/scripts/191-webmenu_wol.sh
A    trunk/patches/scripts/540-remove_webdav.sh
A    trunk/patches/scripts/197-freetzmount.sh
A    trunk/patches/scripts/100-7570_iad7570.sh
A    trunk/patches/scripts/130-fstab.sh
A    trunk/patches/scripts/330-remove-telephony.sh
A    trunk/patches/scripts/310-remove_kids.sh
A    trunk/patches/scripts/700-set_lang_to_utf8.sh
A    trunk/patches/scripts/100-enforce-urlader-settings.sh
A    trunk/patches/scripts/490-remove-ramzswap.sh
A    trunk/patches/scripts/290-replace_websrv.sh
A    trunk/patches/scripts/401-remove_ftpd.sh
A    trunk/patches/scripts/510-remove_minid.sh
A    trunk/patches/scripts/221-remove_myfritz.sh
A    trunk/patches/scripts/116-usbroot_S46-usb.sh
A    trunk/patches/scripts/250-remove_avm_inetd.sh
A    trunk/patches/scripts/110-inittab.sh
A    trunk/patches/scripts/220-cdrom-iso.sh
A    trunk/patches/scripts/140-remove-uClibc.sh
A    trunk/patches/scripts/380-remove-umtsd.sh
A    trunk/patches/scripts/100-w701v_7170.sh
A    trunk/patches/scripts/108-tffs_nodes.sh
A    trunk/patches/scripts/105-onlinechanged.sh
A    trunk/patches/scripts/580-remove_jffs2.sh
A    trunk/patches/scripts/225-remove_fhem.sh
A    trunk/patches/scripts/360-remove-wlan.sh
A    trunk/patches/scripts/210-enum.sh
A    trunk/patches/scripts/100-3170_7170.sh
A    trunk/patches/scripts/220-chronyd.sh
A    trunk/patches/scripts/210-international.sh
A    trunk/patches/scripts/500-remove-mediasrv.sh
A    trunk/patches/scripts/570-remove_strace.sh
A    trunk/patches/scripts/100-7240_7270.sh
A    trunk/patches/scripts/115-rc.S.sh
A    trunk/patches/scripts/355-remove_dsl_control.sh
A    trunk/patches/scripts/200-vcc.sh
A    trunk/patches/scripts/109-rc.net-multid-wrapper.sh
A    trunk/patches/scripts/420-remove_printserv.sh
A    trunk/patches/scripts/180-printk.sh
A    trunk/patches/scripts/300-remove-samba.sh
A    trunk/patches/scripts/320-remove_capiotcp.sh
A    trunk/patches/scripts/385-remove-ntfs.sh
A    trunk/patches/scripts/345-hide_dsl.sh
A    trunk/patches/scripts/230-openssl.sh
A    trunk/patches/scripts/600-replace_mdev.sh
A    trunk/patches/scripts/610-remove_socat.sh
A    trunk/patches/scripts/100-7270v2_7270v1.sh
A    trunk/patches/scripts/565-remove_more.sh
A    trunk/patches/scripts/530-remove_support.sh
A    trunk/patches/scripts/700-add_bash_to_etc_shells.sh
A    trunk/patches/scripts/100-w900v_7170.sh
A    trunk/patches/scripts/340-remove_dect_update.sh
A    trunk/patches/scripts/120-dev_led.sh
A    trunk/patches/scripts/400-remove-inetdctl.sh
A    trunk/patches/scripts/315-remove-qos.sh
A    trunk/patches/scripts/210-ata.sh
A    trunk/patches/scripts/100-7320_7330.sh
A    trunk/patches/scripts/115-7270_16MB.sh.old
A    trunk/patches/scripts/386-remove_fat.sh
A    trunk/patches/scripts/280-remove_upnp.sh
A    trunk/patches/scripts/100-w920v_7570.sh
A    trunk/patches/scripts/100-7140_7170.sh
A    trunk/patches/scripts/100-7141_7170.sh
A    trunk/patches/scripts/190-webmenu.sh
A    trunk/patches/scripts/510-remove_aha.sh
A    trunk/patches/scripts/198-usbroot.sh
A    trunk/patches/scripts/240-add-dsl-expert-pages.sh
A    trunk/patches/scripts/170-rename_ar7login.sh
A    trunk/patches/scripts/585-remove_isofs.sh
A    trunk/patches/scripts/270-remove_usb_module.sh
A    trunk/patches/scripts/510-remove_aura_usb.sh
A    trunk/patches/scripts/590-remove_libfuse.sh
A    trunk/patches/scripts/999-remove_run_clock.sh
A    trunk/patches/scripts/370-remove_dtrace.sh
A    trunk/patches/scripts/510-remove_avm_vpn.sh
A    trunk/patches/scripts/900-add_options_cfg.sh
A    trunk/patches/scripts/381-modify-umtsd.sh
A    trunk/patches/scripts/100-7270v1_7270v2.sh
A    trunk/patches/scripts/275-multiple_printers.sh
A    trunk/patches/scripts/110-multid-wait.sh
A    trunk/patches/scripts/390-remove_e2fsprogs.sh
A    trunk/patches/scripts/520-remove_dect.sh
A    trunk/patches/scripts/350-add_remove_annex_file.sh
A    trunk/patches/scripts/410-remove_piglet.sh
A    trunk/patches/scripts/460-MAXDEVCOUNT.sh
A    trunk/patches/scripts/100_iad3331_7170.sh
A    trunk/patches/Config.in
A    trunk/CHANGELOG
A    trunk/Config.in.has_avm
A    trunk/README
A    trunk/FIRMWARES
A    trunk/graphics
A    trunk/graphics/tagging
A    trunk/graphics/tagging/cuma.png
A    trunk/graphics/favicon
A    trunk/graphics/favicon/hansolo
A    trunk/graphics/favicon/hansolo/box.ico
A    trunk/graphics/favicon/hansolo/freetz.ico
A    trunk/graphics/favicon/cuma
A    trunk/graphics/favicon/cuma/box.ico
A    trunk/graphics/favicon/cuma/freetz.ico
A    trunk/graphics/favicon/dsl123
A    trunk/graphics/favicon/dsl123/box.ico
A    trunk/graphics/favicon/dsl123/freetz.ico
A    trunk/graphics/favicon/atomphil
A    trunk/graphics/favicon/atomphil/freetz.ico
A    trunk/tools
A    trunk/tools/depmod.pl
A    trunk/tools/external
A    trunk/tools/scriptpatcher.sh
A    trunk/tools/device_table.txt
A    trunk/tools/developer
A    trunk/tools/developer/remove_js_function.awk
A    trunk/tools/developer/kconfig.pygments.patch
A    trunk/tools/developer/create-kconfig-warnings
A    trunk/tools/developer/remove_js_function.sh
A    trunk/tools/developer/mime_map_patterns.trac.patch
A    trunk/tools/developer/generate-ncurses-Config.in.sh
A    trunk/tools/developer/big-makefile
A    trunk/tools/rmtichksum
A    trunk/tools/remove-junk-bytes
A    trunk/tools/freetz_download
A    trunk/tools/freetz_functions
A    trunk/tools/check_uclibc
A    trunk/tools/unpack-kernel
A    trunk/tools/source
A    trunk/tools/source/sstrip-1.0.tar.bz2
A    trunk/tools/source/lzma2eva.tar.bz2
A    trunk/tools/source/find-squashfs.tar.bz2
A    trunk/tools/freetz_mklibs
A    trunk/tools/visualise_make
A    trunk/tools/lib_report
A    trunk/tools/check_prerequisites
A    trunk/tools/images
A    trunk/tools/images/starttelnet_sl.image
A    trunk/tools/images/starttelnet.image
A    trunk/tools/images/uninstall.image
A    trunk/tools/images/README
A    trunk/tools/fwdu
A    trunk/tools/config
A    trunk/tools/config/kconfig-language.txt
A    trunk/tools/config/.gitignore
A    trunk/tools/.gitignore
A    trunk/tools/recover-adam
A    trunk/tools/build_download_toolchains
A    trunk/tools/recover-ds
A    trunk/tools/push_firmware
A    trunk/tools/visualise_make.pl
A    trunk/tools/extract-images
A    trunk/tools/make
A    trunk/tools/make/fakeroot.mk
A    trunk/tools/make/find-squashfs.mk
A    trunk/tools/make/Makefile.in
A    trunk/tools/make/kconfig.mk
A    trunk/tools/make/squashfs3.mk
A    trunk/tools/make/xdelta.mk
A    trunk/tools/make/tichksum
A    trunk/tools/make/tichksum/src
A    trunk/tools/make/tichksum/src/ckmain.c
A    trunk/tools/make/tichksum/src/cksum.c
A    trunk/tools/make/tichksum/src/cksum.h
A    trunk/tools/make/tichksum/src/Makefile
A    trunk/tools/make/tichksum/src/README
A    trunk/tools/make/lzma2eva.mk
A    trunk/tools/make/mklibs.mk
A    trunk/tools/make/patches
A    trunk/tools/make/patches/007-gc_sections.openwrt.mklibs.patch
A    trunk/tools/make/patches/011-remove_multiarch.openwrt.mklibs.patch
A    trunk/tools/make/patches/320-defconfig_create_from_defaults.patch
A    trunk/tools/make/patches/002-disable_symbol_checks.openwrt.mklibs.patch
A    trunk/tools/make/patches/170-read_EINTR_or_EOF.squashfs3.patch
A    trunk/tools/make/patches/220-osx.squashfs3.patch
A    trunk/tools/make/patches/014-missing_stdio.mklibs.patch
A    trunk/tools/make/patches/210-progress_bar-floating_point_exception.squashfs3.patch
A    trunk/tools/make/patches/010-remove_STT_GNU_IFUNC.openwrt.mklibs.patch
A    trunk/tools/make/patches/360-max_item_count_for_choice_dialog.kconfig.patch
A    trunk/tools/make/patches/300-main_makefile.kconfig.patch
A    trunk/tools/make/patches/005-duplicate_syms.openwrt.mklibs.patch
A    trunk/tools/make/patches/190-memcpy_memmove.squashfs3.patch
A    trunk/tools/make/patches/004-libpthread_link.openwrt.mklibs.patch
A    trunk/tools/make/patches/370-save-hidden-prompts-to-file.kconfig.patch
A    trunk/tools/make/patches/009-uclibc_libgcc_pic.a_link.freetz.mklibs.patch
A    trunk/tools/make/patches/200-writer_buffer_leak.squashfs3.patch
A    trunk/tools/make/patches/100-lzma.squashfs3.patch
A    trunk/tools/make/patches/003-no_copy.openwrt.mklibs.patch
A    trunk/tools/make/patches/100-lzma_zlib.lzma.patch
A    trunk/tools/make/patches/150-malloc_size.squashfs3.patch
A    trunk/tools/make/patches/100-fakeroot-doc.fakeroot.patch
A    trunk/tools/make/patches/130-inode_number.squashfs3.patch
A    trunk/tools/make/patches/100-fix_missing_crc32.lzma2eva.patch
A    trunk/tools/make/patches/009-uclibc_libpthread_symbols.openwrt.mklibs.patch
A    trunk/tools/make/patches/100-lzma-and-unsquashfs.squashfs.patch
A    trunk/tools/make/patches/180-no_empty_files_on_read_error_abort_instead.squashfs3.patch
A    trunk/tools/make/patches/100-outbuffer.lzma.patch
A    trunk/tools/make/patches/120-memset-sBlk.squashfs3.patch
A    trunk/tools/make/patches/310-fix_make.kconfig.patch
A    trunk/tools/make/patches/016-use_python2.mklibs.patch
A    trunk/tools/make/patches/008-uclibc_libgcc_link.openwrt.mklibs.patch
A    trunk/tools/make/patches/006-uclibc_init.openwrt.mklibs.patch
A    trunk/tools/make/patches/330-comment_style.kconfig.patch
A    trunk/tools/make/patches/011-comment_warning.mklibs.patch
A    trunk/tools/make/patches/160-queue_race_condition.squashfs3.patch
A    trunk/tools/make/patches/320-unchangable_style.kconfig.patch
A    trunk/tools/make/patches/115-osx.squashfs.patch
A    trunk/tools/make/patches/140-hide_output.squashfs3.patch
A    trunk/tools/make/patches/tar_preserve_directory_permissions.busybox.patch
A    trunk/tools/make/patches/340-fix_randconfig_choice.kconfig.patch
A    trunk/tools/make/patches/350-do_not_select_unmet_direct_dependencies.kconfig.patch
A    trunk/tools/make/patches/110-allow-symlinks.squashfs.patch
A    trunk/tools/make/sfk.mk
A    trunk/tools/make/sstrip.mk
A    trunk/tools/make/tar.mk
A    trunk/tools/make/tichksum.mk
A    trunk/tools/make/Config.busybox
A    trunk/tools/make/busybox-tools.mk
A    trunk/tools/make/python-host.mk
A    trunk/tools/make/squashfs.mk
A    trunk/tools/make/lzma.mk
A    trunk/tools/parse-config
A    trunk/tools/freetz_patch
A    trunk/tools/recover-eva
A    trunk/.version
A    trunk/TODO
A    trunk/.gitignore
A    trunk/fwmod_custom
A    trunk/COPYING
A    trunk/.exclude-dist
A    trunk/Config.in
A    trunk/fwmod
A    trunk/Makefile
A    trunk/make
A    trunk/make/ruby
A    trunk/make/ruby/external.files
A    trunk/make/ruby/external.in
A    trunk/make/ruby/patches
A    trunk/make/ruby/patches/200-fileutils.rb.patch
A    trunk/make/ruby/patches/400-uClibc_stdio.patch
A    trunk/make/ruby/patches/300-http_bufsize.patch
A    trunk/make/ruby/patches/500-fix_crypt.patch
A    trunk/make/ruby/patches/100-Makefile-in.patch
A    trunk/make/ruby/ruby.mk
A    trunk/make/ruby/Config.in
A    trunk/make/ser2net
A    trunk/make/ser2net/files
A    trunk/make/ser2net/files/.language
A    trunk/make/ser2net/files/root
A    trunk/make/ser2net/files/root/usr
A    trunk/make/ser2net/files/root/usr/lib
A    trunk/make/ser2net/files/root/usr/lib/cgi-bin
A    trunk/make/ser2net/files/root/usr/lib/cgi-bin/ser2net.cgi
A    trunk/make/ser2net/files/root/etc
A    trunk/make/ser2net/files/root/etc/default.ser2net
A    trunk/make/ser2net/files/root/etc/default.ser2net/ser2net.cfg
A    trunk/make/ser2net/files/root/etc/default.ser2net/ser2net_conf.def
A    trunk/make/ser2net/files/root/etc/init.d
A    trunk/make/ser2net/files/root/etc/init.d/rc.ser2net
A    trunk/make/ser2net/ser2net.mk
A    trunk/make/ser2net/Config.in
A    trunk/make/pcsc-lite
A    trunk/make/pcsc-lite/external.files
A    trunk/make/pcsc-lite/external.in
A    trunk/make/pcsc-lite/pcsc-lite.mk
A    trunk/make/pcsc-lite/Config.in
A    trunk/make/aiccu
A    trunk/make/aiccu/files
A    trunk/make/aiccu/files/.language
A    trunk/make/aiccu/files/root
A    trunk/make/aiccu/files/root/usr
A    trunk/make/aiccu/files/root/usr/lib
A    trunk/make/aiccu/files/root/usr/lib/cgi-bin
A    trunk/make/aiccu/files/root/usr/lib/cgi-bin/aiccu.cgi
A    trunk/make/aiccu/files/root/etc
A    trunk/make/aiccu/files/root/etc/init.d
A    trunk/make/aiccu/files/root/etc/init.d/rc.aiccu
A    trunk/make/aiccu/files/root/etc/default.aiccu
A    trunk/make/aiccu/files/root/etc/default.aiccu/aiccu.cfg
A    trunk/make/aiccu/files/root/etc/default.aiccu/aiccu_sh.conf
A    trunk/make/aiccu/files/root/etc/default.aiccu/aiccu_conf
A    trunk/make/aiccu/files/root/etc/default.aiccu/aiccu_sh.def
A    trunk/make/aiccu/external.files
A    trunk/make/aiccu/external.services
A    trunk/make/aiccu/external.in
A    trunk/make/aiccu/patches
A    trunk/make/aiccu/patches/120-disable-strip.patch
A    trunk/make/aiccu/patches/100-disable-gnutls.patch
A    trunk/make/aiccu/patches/005-no_libresolv.patch
A    trunk/make/aiccu/patches/200-add_dn_skipname.patch
A    trunk/make/aiccu/patches/110-resolver.patch
A    trunk/make/aiccu/Config.in
A    trunk/make/aiccu/aiccu.mk
A    trunk/make/nfs-utils
A    trunk/make/nfs-utils/patches
A    trunk/make/nfs-utils/patches/005-no_libnsl.patch
A    trunk/make/nfs-utils/patches/200-dont_messup_up_config_cache_with_host_linker_characteristics.patch
A    trunk/make/nfs-utils/patches/300-fix_kernel_bug.patch
A    trunk/make/nfs-utils/patches/001-nfs_utils_uclibc.patch
A    trunk/make/nfs-utils/patches/500-uclibc_libio.h.patch
A    trunk/make/nfs-utils/patches/100_no_libintl.patch
A    trunk/make/nfs-utils/patches/400-dont_mix_flags.patch
A    trunk/make/nfs-utils/Config.in
A    trunk/make/nfs-utils/nfs-utils.mk
A    trunk/make/ndas
A    trunk/make/ndas/patches
A    trunk/make/ndas/patches/class_device_create.patch
A    trunk/make/ndas/Config.in
A    trunk/make/ndas/ndas.mk
A    trunk/make/synce-dccm
A    trunk/make/synce-dccm/files
A    trunk/make/synce-dccm/files/.language
A    trunk/make/synce-dccm/files/root
A    trunk/make/synce-dccm/files/root/usr
A    trunk/make/synce-dccm/files/root/usr/lib
A    trunk/make/synce-dccm/files/root/usr/lib/cgi-bin
A    trunk/make/synce-dccm/files/root/usr/lib/cgi-bin/synce-dccm.cgi
A    trunk/make/synce-dccm/files/root/etc
A    trunk/make/synce-dccm/files/root/etc/init.d
A    trunk/make/synce-dccm/files/root/etc/init.d/rc.synce-dccm
A    trunk/make/synce-dccm/files/root/etc/default.synce-dccm
A    trunk/make/synce-dccm/files/root/etc/default.synce-dccm/synce-dccm.cfg
A    trunk/make/synce-dccm/patches
A    trunk/make/synce-dccm/patches/100-libtool_call_missing_tag.patch
A    trunk/make/synce-dccm/Config.in
A    trunk/make/synce-dccm/synce-dccm.mk
A    trunk/make/authorized-keys
A    trunk/make/authorized-keys/files
A    trunk/make/authorized-keys/files/.language
A    trunk/make/authorized-keys/files/root
A    trunk/make/authorized-keys/files/root/usr
A    trunk/make/authorized-keys/files/root/usr/bin
A    trunk/make/authorized-keys/files/root/usr/bin/authorized_keys_gentmp
A    trunk/make/authorized-keys/files/root/usr/bin/authorized_keys_getuser
A    trunk/make/authorized-keys/files/root/usr/bin/authorized_keys_save
A    trunk/make/authorized-keys/files/root/etc
A    trunk/make/authorized-keys/files/root/etc/init.d
A    trunk/make/authorized-keys/files/root/etc/init.d/rc.authorized-keys
A    trunk/make/authorized-keys/files/root/etc/default.authorized-keys
A    trunk/make/authorized-keys/files/root/etc/default.authorized-keys/id_dsa.def
A    trunk/make/authorized-keys/files/root/etc/default.authorized-keys/authorized_keys.def
A    trunk/make/authorized-keys/files/root/etc/default.authorized-keys/known_hosts.def
A    trunk/make/authorized-keys/files/root/etc/default.authorized-keys/id_rsa.def
A    trunk/make/authorized-keys/Config.in
A    trunk/make/authorized-keys/authorized-keys.mk
A    trunk/make/avahi
A    trunk/make/avahi/external.in.libs
A    trunk/make/avahi/Config.in.libs
A    trunk/make/avahi/Makefile.in
A    trunk/make/avahi/files
A    trunk/make/avahi/files/root
A    trunk/make/avahi/files/root/etc
A    trunk/make/avahi/files/root/etc/config-template.avahi
A    trunk/make/avahi/files/root/etc/config-template.avahi/hosts
A    trunk/make/avahi/files/root/etc/config-template.avahi/services
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/remote_announce.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/samba.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/nfs.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/itunes.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/sftp-ssh.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/ssh.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/services/http.service
A    trunk/make/avahi/files/root/etc/config-template.avahi/avahi-daemon.conf
A    trunk/make/avahi/files/root/etc/init.d
A    trunk/make/avahi/files/root/etc/init.d/rc.avahi
A    trunk/make/avahi/files/root/etc/avahi
A    trunk/make/avahi/files/root/etc/config-template.dbus
A    trunk/make/avahi/files/root/etc/config-template.dbus/system.d
A    trunk/make/avahi/files/root/etc/config-template.dbus/system.d/avahi-dbus.conf
A    trunk/make/avahi/files/root/etc/default.avahi
A    trunk/make/avahi/files/root/etc/default.avahi/avahi.cfg
A    trunk/make/avahi/external.files
A    trunk/make/avahi/external.services
A    trunk/make/avahi/patches
A    trunk/make/avahi/patches/100-pkgconfig.patch
A    trunk/make/avahi/patches/110-nls_cleanups.patch
A    trunk/make/avahi/avahi.mk
A    trunk/make/transmission
A    trunk/make/transmission/transmission.mk
A    trunk/make/transmission/external.files
A    trunk/make/transmission/external.services
A    trunk/make/transmission/external.in
A    trunk/make/transmission/patches
A    trunk/make/transmission/patches/040-IPv6_defines.patch
A    trunk/make/transmission/patches/030-no_in6addr_any_in_libc_without_IPv6_fix.patch
A    trunk/make/transmission/patches/010-low_resource_systems__smaller_buffers.patch
A    trunk/make/transmission/patches/120-finish_dir.patch
A    trunk/make/transmission/patches/020-dont_scrape_paused_torrents_by_default.patch
A    trunk/make/transmission/Config.in
A    trunk/make/matrixtunnel
A    trunk/make/matrixtunnel/matrixtunnel.mk
A    trunk/make/matrixtunnel/Config.in
A    trunk/make/dvbsnoop
A    trunk/make/dvbsnoop/dvbsnoop.mk
A    trunk/make/dvbsnoop/Config.in
A    trunk/make/target-tester
A    trunk/make/target-tester/target-tester.mk
A    trunk/make/target-tester/src
A    trunk/make/target-tester/src/bash_cv_unusable_rtsigs.c
A    trunk/make/target-tester/src/bash_cv_under_sys_siglist.c
A    trunk/make/target-tester/src/realpath_test.c
A    trunk/make/target-tester/src/bash_cv_dup2_broken.c
A    trunk/make/target-tester/src/bash_cv_printf_a_format.c
A    trunk/make/target-tester/src/bash_cv_sys_siglist.c
A    trunk/make/target-tester/src/ac_cv_libnet_endianess.c
A    trunk/make/target-tester/src/bash_cv_opendir_not_robust.c
A    trunk/make/target-tester/src/ac_cv_func_mmap_fixed_mapped.c
A    trunk/make/target-tester/src/bash_cv_func_sigsetjmp.c
A    trunk/make/target-tester/src/gt_cv_int_divbyzero_sigfpe.c
A    trunk/make/target-tester/src/libnet_cv_have_packet_socket.c
A    trunk/make/target-tester/src/bash_cv_pgrp_pipe.c
A    trunk/make/target-tester/src/ac_cv_func_fnmatch_works.c
A    trunk/make/target-tester/src/bash_cv_must_reinstall_sighandlers.c
A    trunk/make/target-tester/src/tst_nl_langinfo.expected_output
A    trunk/make/target-tester/src/tst_nl_langinfo.c
A    trunk/make/target-tester/src/bash_cv_getenv_redef.c
A    trunk/make/target-tester/src/ac_cv_func_vsnprintf_c99.c
A    trunk/make/target-tester/src/zlib_four_byte_unsigned_int.c
A    trunk/make/target-tester/src/ac_cv_lbl_unaligned_fail.c
A    trunk/make/target-tester/src/ac_func-test-generator.sh
A    trunk/make/target-tester/src/excepttest.c
A    trunk/make/target-tester/src/bash_cv_getcwd_malloc.c
A    trunk/make/target-tester/src/bash_cv_ulimit_maxfds.c
A    trunk/make/target-tester/src/ettercap-nsget32.c
A    trunk/make/target-tester/src/target-tester.c
A    trunk/make/target-tester/src/ac_cv_func_printf_unix98.c
A    trunk/make/target-tester/src/Makefile
A    trunk/make/target-tester/Config.in
A    trunk/make/pciutils
A    trunk/make/pciutils/pciutils.mk
A    trunk/make/pciutils/patches
A    trunk/make/pciutils/patches/005-no_libresolv.patch
A    trunk/make/pciutils/Config.in
A    trunk/make/trickle
A    trunk/make/trickle/external.files
A    trunk/make/trickle/trickle.mk
A    trunk/make/trickle/external.in
A    trunk/make/trickle/patches
A    trunk/make/trickle/patches/120-in_addr_t.patch
A    trunk/make/trickle/patches/125-no_libnsl.patch
A    trunk/make/trickle/patches/010-libevent_transitive_pthread.patch
A    trunk/make/trickle/patches/130-ipv6.patch
A    trunk/make/trickle/patches/101-no-strict-aliasing.patch
A    trunk/make/trickle/patches/100-libc_access_via_dlopen.patch
A    trunk/make/trickle/patches/110-sysconf_and_libdir.patch
A    trunk/make/trickle/patches/140-trickle-overload_soname.patch
A    trunk/make/trickle/patches/171_trickle_c__P_option.patch
A    trunk/make/trickle/Config.in
A    trunk/make/usbroot
A    trunk/make/usbroot/files
A    trunk/make/usbroot/files/.language
A    trunk/make/usbroot/files/root
A    trunk/make/usbroot/files/root/oldroot
A    trunk/make/usbroot/files/root/oldroot/.gitignore
A    trunk/make/usbroot/files/root/data
A    trunk/make/usbroot/files/root/data/.gitignore
A    trunk/make/usbroot/files/root/usr
A    trunk/make/usbroot/files/root/usr/lib
A    trunk/make/usbroot/files/root/usr/lib/cgi-bin
A    trunk/make/usbroot/files/root/usr/lib/cgi-bin/usbroot.cgi
A    trunk/make/usbroot/files/root/etc
A    trunk/make/usbroot/files/root/etc/default.usbroot
A    trunk/make/usbroot/files/root/etc/default.usbroot/usbroot.save
A    trunk/make/usbroot/files/root/etc/default.usbroot/usbroot.cfg
A    trunk/make/usbroot/files/root/etc/usbroot_device.table
A    trunk/make/usbroot/files/root/etc/init.d
A    trunk/make/usbroot/files/root/etc/init.d/rc.usbroot
A    trunk/make/usbroot/usbroot.mk
A    trunk/make/usbroot/Config.in
A    trunk/make/imagemagick
A    trunk/make/imagemagick/external.files
A    trunk/make/imagemagick/imagemagick.mk
A    trunk/make/imagemagick/external.in
A    trunk/make/imagemagick/patches
A    trunk/make/imagemagick/patches/010-extra_flags.patch
A    trunk/make/imagemagick/Config.in
A    trunk/make/empty
A    trunk/make/empty/empty.mk
A    trunk/make/empty/Config.in
A    trunk/make/wput
A    trunk/make/wput/external.files
A    trunk/make/wput/wput.mk
A    trunk/make/wput/external.in
A    trunk/make/wput/patches
A    trunk/make/wput/patches/100-socketlib.c.patch
A    trunk/make/wput/patches/102-wput.c.patch
A    trunk/make/wput/Config.in
A    trunk/make/ghostscript-fonts
A    trunk/make/ghostscript-fonts/external.files
A    trunk/make/ghostscript-fonts/ghostscript-fonts.mk
A    trunk/make/ghostscript-fonts/external.in
A    trunk/make/ghostscript-fonts/Config.in
A    trunk/make/mediatomb
A    trunk/make/mediatomb/external.files
A    trunk/make/mediatomb/external.in
A    trunk/make/mediatomb/mediatomb.mk
A    trunk/make/mediatomb/patches
A    trunk/make/mediatomb/patches/200-static_linking.patch
A    trunk/make/mediatomb/patches/050-gcc47x-proper-two-phase-lookup.patch
A    trunk/make/mediatomb/patches/020-ffmpeg-0.11.x.patch
A    trunk/make/mediatomb/patches/300-polarssl_name_collision.patch
A    trunk/make/mediatomb/patches/010-ffmpeg-0.8.x.patch
A    trunk/make/mediatomb/patches/100-SYS_INOTIFY_H_OK.patch
A    trunk/make/mediatomb/Config.in
A    trunk/make/truecrypt
A    trunk/make/truecrypt/external.files
A    trunk/make/truecrypt/external.in
A    trunk/make/truecrypt/patches
A    trunk/make/truecrypt/patches/130-toupper_tolower_nolocale.patch
A    trunk/make/truecrypt/patches/100-Makefile.patch
A    trunk/make/truecrypt/patches/140-missing_locale_include.patch
A    trunk/make/truecrypt/patches/120-cxxabi.patch
A    trunk/make/truecrypt/patches/100-static_linking.patch
A    trunk/make/truecrypt/patches/110-strip.patch
A    trunk/make/truecrypt/patches/115-flags.patch
A    trunk/make/truecrypt/truecrypt.mk
A    trunk/make/truecrypt/Config.in
A    trunk/make/mtr
A    trunk/make/mtr/external.files
A    trunk/make/mtr/external.in
A    trunk/make/mtr/patches
A    trunk/make/mtr/patches/502-fix-res_ninit.patch
A    trunk/make/mtr/patches/501-dns.patch
A    trunk/make/mtr/patches/005-no_libresolv.patch
A    trunk/make/mtr/mtr.mk
A    trunk/make/mtr/Config.in
A    trunk/make/cpmaccfg
A    trunk/make/cpmaccfg/cpmaccfg.mk
A    trunk/make/cpmaccfg/Config.in
A    trunk/make/slang
A    trunk/make/slang/external.in.libs
A    trunk/make/slang/Config.in.libs
A    trunk/make/slang/external.files
A    trunk/make/slang/patches
A    trunk/make/slang/patches/220-modules_omit_files.patch
A    trunk/make/slang/patches/230-uClibc-0.9.28-missing-WCONTINUED.patch
A    trunk/make/slang/patches/110-no_slsh.patch
A    trunk/make/slang/patches/030_hostent_haddr.patch
A    trunk/make/slang/patches/120-no_docs_no_help.patch
A    trunk/make/slang/patches/200-module_install_dir.patch
A    trunk/make/slang/patches/130-no_rpath.patch
A    trunk/make/slang/patches/210-install_module.patch
A    trunk/make/slang/slang.mk
A    trunk/make/hp-utils
A    trunk/make/hp-utils/files
A    trunk/make/hp-utils/files/.language
A    trunk/make/hp-utils/files/root
A    trunk/make/hp-utils/files/root/usr
A    trunk/make/hp-utils/files/root/usr/share
A    trunk/make/hp-utils/files/root/usr/share/images
A    trunk/make/hp-utils/files/root/usr/share/images/clean.png
A    trunk/make/hp-utils/files/root/usr/share/images/align.png
A    trunk/make/hp-utils/files/root/usr/lib
A    trunk/make/hp-utils/files/root/usr/lib/cgi-bin
A    trunk/make/hp-utils/files/root/usr/lib/cgi-bin/hp-utils.cgi
A    trunk/make/hp-utils/files/root/usr/bin
A    trunk/make/hp-utils/files/root/usr/bin/webcfg-hp-utils
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils/style
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils/images
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin/clean.cgi
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin/index.cgi
A    trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin/maint.cgi
A    trunk/make/hp-utils/files/root/etc
A    trunk/make/hp-utils/files/root/etc/init.d
A    trunk/make/hp-utils/files/root/etc/init.d/rc.hp-utils
A    trunk/make/hp-utils/files/root/etc/default.hp-utils
A    trunk/make/hp-utils/files/root/etc/default.hp-utils/hp-utils.cfg
A    trunk/make/hp-utils/files/root/etc/default.hp-utils/hp-utils.inetd
A    trunk/make/hp-utils/files/root/etc/default.hp-utils/httpd-hp-utils_conf
A    trunk/make/hp-utils/patches
A    trunk/make/hp-utils/patches/100-pthread.patch
A    trunk/make/hp-utils/Config.in
A    trunk/make/hp-utils/hp-utils.mk
A    trunk/make/vsftpd
A    trunk/make/vsftpd/files
A    trunk/make/vsftpd/files/.language
A    trunk/make/vsftpd/files/root
A    trunk/make/vsftpd/files/root/usr
A    trunk/make/vsftpd/files/root/usr/lib
A    trunk/make/vsftpd/files/root/usr/lib/cgi-bin
A    trunk/make/vsftpd/files/root/usr/lib/cgi-bin/vsftpd
A    trunk/make/vsftpd/files/root/usr/lib/cgi-bin/vsftpd/vsftpd_log.cgi
A    trunk/make/vsftpd/files/root/usr/lib/cgi-bin/vsftpd.cgi
A    trunk/make/vsftpd/files/root/etc
A    trunk/make/vsftpd/files/root/etc/init.d
A    trunk/make/vsftpd/files/root/etc/init.d/rc.vsftpd
A    trunk/make/vsftpd/files/root/etc/default.vsftpd
A    trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd.cfg
A    trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd.inetd
A    trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd_conf
A    trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd_crt.def
A    trunk/make/vsftpd/files/root/etc/onlinechanged
A    trunk/make/vsftpd/files/root/etc/onlinechanged/vsftpd
A    trunk/make/vsftpd/files/README
A    trunk/make/vsftpd/external.files
A    trunk/make/vsftpd/external.services
A    trunk/make/vsftpd/external.in
A    trunk/make/vsftpd/patches
A    trunk/make/vsftpd/patches/002-find_libs.patch
A    trunk/make/vsftpd/patches/070-config.patch
A    trunk/make/vsftpd/patches/006-enable_ssl.patch
A    trunk/make/vsftpd/patches/090-anonym_root.patch
A    trunk/make/vsftpd/patches/001-destdir.patch
A    trunk/make/vsftpd/patches/003-tunables.patch
A    trunk/make/vsftpd/patches/060-disable_largfiles.patch
A    trunk/make/vsftpd/Config.in
A    trunk/make/vsftpd/vsftpd.mk
A    trunk/make/iodine
A    trunk/make/iodine/files
A    trunk/make/iodine/files/.language
A    trunk/make/iodine/files/root
A    trunk/make/iodine/files/root/usr
A    trunk/make/iodine/files/root/usr/lib
A    trunk/make/iodine/files/root/usr/lib/cgi-bin
A    trunk/make/iodine/files/root/usr/lib/cgi-bin/iodine.cgi
A    trunk/make/iodine/files/root/etc
A    trunk/make/iodine/files/root/etc/init.d
A    trunk/make/iodine/files/root/etc/init.d/rc.iodine
A    trunk/make/iodine/files/root/etc/default.iodine
A    trunk/make/iodine/files/root/etc/default.iodine/iodine.cfg
A    trunk/make/iodine/external.files
A    trunk/make/iodine/external.in
A    trunk/make/iodine/patches
A    trunk/make/iodine/patches/010-iodine-4-users.patch
A    trunk/make/iodine/Config.in
A    trunk/make/iodine/iodine.mk
A    trunk/make/tesseract-deu
A    trunk/make/tesseract-deu/tesseract-deu.mk
A    trunk/make/socat
A    trunk/make/socat/socat.mk
A    trunk/make/socat/external.files
A    trunk/make/socat/external.in
A    trunk/make/socat/Config.in
A    trunk/make/sslh
A    trunk/make/sslh/sslh.mk
A    trunk/make/sslh/files
A    trunk/make/sslh/files/.language
A    trunk/make/sslh/files/root
A    trunk/make/sslh/files/root/usr
A    trunk/make/sslh/files/root/usr/lib
A    trunk/make/sslh/files/root/usr/lib/cgi-bin
A    trunk/make/sslh/files/root/usr/lib/cgi-bin/sslh.cgi
A    trunk/make/sslh/files/root/etc
A    trunk/make/sslh/files/root/etc/init.d
A    trunk/make/sslh/files/root/etc/init.d/rc.sslh
A    trunk/make/sslh/files/root/etc/default.sslh
A    trunk/make/sslh/files/root/etc/default.sslh/default-config.sh
A    trunk/make/sslh/files/root/etc/default.sslh/protocols.def
A    trunk/make/sslh/files/root/etc/default.sslh/sslh.cfg
A    trunk/make/sslh/files/root/etc/default.sslh/sslh.inetd
A    trunk/make/sslh/files/root/etc/default.sslh/sslh_conf
A    trunk/make/sslh/external.files
A    trunk/make/sslh/external.services
A    trunk/make/sslh/external.in
A    trunk/make/sslh/patches
A    trunk/make/sslh/patches/no_open_pipes.patch
A    trunk/make/sslh/Config.in
A    trunk/make/tcp_wrappers
A    trunk/make/tcp_wrappers/tcp_wrappers.mk
A    trunk/make/tcp_wrappers/external.files
A    trunk/make/tcp_wrappers/external.in
A    trunk/make/tcp_wrappers/patches
A    trunk/make/tcp_wrappers/patches/001-debian_patchset.patch
A    trunk/make/tcp_wrappers/Config.in
A    trunk/make/e2fsprogs
A    trunk/make/e2fsprogs/e2fsprogs.mk
A    trunk/make/e2fsprogs/Config.in.libs
A    trunk/make/e2fsprogs/Makefile.in
A    trunk/make/e2fsprogs/files
A    trunk/make/e2fsprogs/files/root
A    trunk/make/e2fsprogs/files/root/usr
A    trunk/make/e2fsprogs/files/root/usr/sbin
A    trunk/make/e2fsprogs/files/root/usr/sbin/mkfs.ext2
A    trunk/make/e2fsprogs/files/root/usr/sbin/mkfs.ext3
A    trunk/make/e2fsprogs/files/root/usr/sbin/fsck.ext2
A    trunk/make/e2fsprogs/files/root/usr/sbin/fsck.ext3
A    trunk/make/e2fsprogs/files/root/usr/sbin/fsck.ext4dev
A    trunk/make/e2fsprogs/files/root/sbin
A    trunk/make/e2fsprogs/files/root/sbin/blkid
A    trunk/make/e2fsprogs/external.files
A    trunk/make/e2fsprogs/external.in
A    trunk/make/e2fsprogs/patches
A    trunk/make/e2fsprogs/patches/060-extra_flags.patch
A    trunk/make/e2fsprogs/patches/110-glibc21.patch
A    trunk/make/e2fsprogs/patches/100-blkid_cache-file.patch
A    trunk/make/e2fsprogs/patches/009-e2defrag-Makefile-fix.patch
A    trunk/make/e2fsprogs/patches/010-pic_instead_of_profile.patch
A    trunk/make/e2fsprogs/patches/103-undef_tls.patch
A    trunk/make/e2fsprogs/patches/210-no_quota.patch
A    trunk/make/e2fsprogs/patches/003-DEFS_fix.patch
A    trunk/make/e2fsprogs/patches/102-use-syscall-function.patch
A    trunk/make/e2fsprogs/patches/001-exit_0_on_corrected_errors.patch
A    trunk/make/e2fsprogs/patches/004-no_inline_funcs.patch
A    trunk/make/e2fsprogs/patches/120-no_unnecessary_iconv_tests.patch
A    trunk/make/e2fsprogs/patches/101-blkid-man3dir.patch
A    trunk/make/e2fsprogs/patches/905-blkid_mtdworkaround.patch
A    trunk/make/usbutils
A    trunk/make/usbutils/usbutils.mk
A    trunk/make/usbutils/Config.in
A    trunk/make/openconnect
A    trunk/make/openconnect/openconnect.mk
A    trunk/make/openconnect/patches
A    trunk/make/openconnect/patches/001-cross-compile.patch
A    trunk/make/openconnect/Config.in
A    trunk/make/js
A    trunk/make/js/external.in.libs
A    trunk/make/js/Config.in.libs
A    trunk/make/js/js.mk
A    trunk/make/js/external.files
A    trunk/make/js/patches
A    trunk/make/js/patches/820-jscpucfg.js.patch
A    trunk/make/js/patches/800-LIBS.js.patch
A    trunk/make/js/patches/005-no_libnsl.js.patch
A    trunk/make/js/patches/810-install_library_only.js.patch
A    trunk/make/js/patches/100-config.cache-proper-dl-values.js.patch
A    trunk/make/js/patches/840-jsautocfg.h.js.patch
A    trunk/make/sg3_utils
A    trunk/make/sg3_utils/sg3_utils.mk
A    trunk/make/sg3_utils/patches
A    trunk/make/sg3_utils/patches/100-unnecessary_include.patch
A    trunk/make/sg3_utils/Config.in
A    trunk/make/umurmur
A    trunk/make/umurmur/files
A    trunk/make/umurmur/files/.language
A    trunk/make/umurmur/files/root
A    trunk/make/umurmur/files/root/usr
A    trunk/make/umurmur/files/root/usr/lib
A    trunk/make/umurmur/files/root/usr/lib/cgi-bin
A    trunk/make/umurmur/files/root/usr/lib/cgi-bin/umurmur.cgi
A    trunk/make/umurmur/files/root/etc
A    trunk/make/umurmur/files/root/etc/default.umurmur
A    trunk/make/umurmur/files/root/etc/default.umurmur/umurmur_crt.def
A    trunk/make/umurmur/files/root/etc/default.umurmur/umurmur_key.def
A    trunk/make/umurmur/files/root/etc/default.umurmur/umurmur.cfg
A    trunk/make/umurmur/files/root/etc/init.d
A    trunk/make/umurmur/files/root/etc/init.d/rc.umurmur
A    trunk/make/umurmur/umurmur.mk
A    trunk/make/umurmur/external.files
A    trunk/make/umurmur/external.services
A    trunk/make/umurmur/external.in
A    trunk/make/umurmur/patches
A    trunk/make/umurmur/patches/100-polarssl_1.2.x.patch
A    trunk/make/umurmur/patches/110-reduced_polarssl_support.patch
A    trunk/make/umurmur/Config.in
A    trunk/make/dns2tcp
A    trunk/make/dns2tcp/files
A    trunk/make/dns2tcp/files/.language
A    trunk/make/dns2tcp/files/root
A    trunk/make/dns2tcp/files/root/usr
A    trunk/make/dns2tcp/files/root/usr/lib
A    trunk/make/dns2tcp/files/root/usr/lib/cgi-bin
A    trunk/make/dns2tcp/files/root/usr/lib/cgi-bin/dns2tcp.cgi
A    trunk/make/dns2tcp/files/root/etc
A    trunk/make/dns2tcp/files/root/etc/default.dns2tcp
A    trunk/make/dns2tcp/files/root/etc/default.dns2tcp/dns2tcp_conf
A    trunk/make/dns2tcp/files/root/etc/default.dns2tcp/dns2tcp.cfg
A    trunk/make/dns2tcp/files/root/etc/init.d
A    trunk/make/dns2tcp/files/root/etc/init.d/rc.dns2tcp
A    trunk/make/dns2tcp/files/README
A    trunk/make/dns2tcp/dns2tcp.mk
A    trunk/make/dns2tcp/external.files
A    trunk/make/dns2tcp/external.services
A    trunk/make/dns2tcp/external.in
A    trunk/make/dns2tcp/Config.in
A    trunk/make/netcat
A    trunk/make/netcat/files
A    trunk/make/netcat/files/root
A    trunk/make/netcat/files/root/usr
A    trunk/make/netcat/files/root/usr/bin
A    trunk/make/netcat/files/root/usr/bin/nc
A    trunk/make/netcat/files/README
A    trunk/make/netcat/external.files
A    trunk/make/netcat/netcat.mk
A    trunk/make/netcat/external.in
A    trunk/make/netcat/Config.in
A    trunk/make/openssh
A    trunk/make/openssh/files
A    trunk/make/openssh/files/.language
A    trunk/make/openssh/files/root
A    trunk/make/openssh/files/root/usr
A    trunk/make/openssh/files/root/usr/lib
A    trunk/make/openssh/files/root/usr/lib/cgi-bin
A    trunk/make/openssh/files/root/usr/lib/cgi-bin/openssh.cgi
A    trunk/make/openssh/files/root/etc
A    trunk/make/openssh/files/root/etc/default.openssh
A    trunk/make/openssh/files/root/etc/default.openssh/rsa_key.def
A    trunk/make/openssh/files/root/etc/default.openssh/dsa_key.def
A    trunk/make/openssh/files/root/etc/default.openssh/openssh.cfg
A    trunk/make/openssh/files/root/etc/init.d
A    trunk/make/openssh/files/root/etc/init.d/rc.openssh
A    trunk/make/openssh/external.files
A    trunk/make/openssh/external.services
A    trunk/make/openssh/openssh.mk
A    trunk/make/openssh/external.in
A    trunk/make/openssh/patches
A    trunk/make/openssh/patches/110-no_ripemd_fix.patch
A    trunk/make/openssh/patches/130-implicit_memset_decl_fix.patch
A    trunk/make/openssh/patches/150-extra_ldflags.patch
A    trunk/make/openssh/patches/100-no_cast_fix.patch
A    trunk/make/openssh/patches/005-no_libresolv.patch
A    trunk/make/openssh/Config.in
A    trunk/make/mini_fo
A    trunk/make/mini_fo/files
A    trunk/make/mini_fo/files/.language
A    trunk/make/mini_fo/files/root
A    trunk/make/mini_fo/files/root/oldroot
A    trunk/make/mini_fo/files/root/oldroot/.gitignore
A    trunk/make/mini_fo/files/root/sto
A    trunk/make/mini_fo/files/root/sto/.gitignore
A    trunk/make/mini_fo/files/root/usr
A    trunk/make/mini_fo/files/root/usr/lib
A    trunk/make/mini_fo/files/root/usr/lib/cgi-bin
A    trunk/make/mini_fo/files/root/usr/lib/cgi-bin/mini_fo.cgi
A    trunk/make/mini_fo/files/root/etc
A    trunk/make/mini_fo/files/root/etc/default.mini_fo
A    trunk/make/mini_fo/files/root/etc/default.mini_fo/mini_fo.save
A    trunk/make/mini_fo/files/root/etc/init.d
A    trunk/make/mini_fo/files/root/etc/init.d/rc.mini_fo
A    trunk/make/mini_fo/mini_fo.mk
A    trunk/make/mini_fo/Config.in
A    trunk/make/apache
A    trunk/make/apache/external.files
A    trunk/make/apache/apache.mk
A    trunk/make/apache/external.in
A    trunk/make/apache/patches
A    trunk/make/apache/patches/120-shell-bash.patch
A    trunk/make/apache/patches/130-AR.patch
A    trunk/make/apache/patches/110-crosscompile-mipsel.patch
A    trunk/make/apache/patches/100-no_auth_dbm.patch
A    trunk/make/apache/Config.in
A    trunk/make/rush
A    trunk/make/rush/external.files
A    trunk/make/rush/external.services
A    trunk/make/rush/external.in
A    trunk/make/rush/patches
A    trunk/make/rush/patches/dfsg_reduction.patch
A    trunk/make/rush/patches/tcpmux_service.patch
A    trunk/make/rush/rush.mk
A    trunk/make/rush/Config.in
A    trunk/make/hol
A    trunk/make/hol/files
A    trunk/make/hol/files/.language
A    trunk/make/hol/files/root
A    trunk/make/hol/files/root/usr
A    trunk/make/hol/files/root/usr/lib
A    trunk/make/hol/files/root/usr/lib/cgi-bin
A    trunk/make/hol/files/root/usr/lib/cgi-bin/hol.cgi
A    trunk/make/hol/files/root/usr/bin
A    trunk/make/hol/files/root/usr/bin/hol
A    trunk/make/hol/files/root/etc
A    trunk/make/hol/files/root/etc/default.hol
A    trunk/make/hol/files/root/etc/default.hol/hol.cfg
A    trunk/make/hol/files/root/etc/init.d
A    trunk/make/hol/files/root/etc/init.d/rc.hol
A    trunk/make/hol/hol.mk
A    trunk/make/hol/Config.in
A    trunk/make/cryptsetup
A    trunk/make/cryptsetup/external.files
A    trunk/make/cryptsetup/external.in
A    trunk/make/cryptsetup/patches
A    trunk/make/cryptsetup/patches/010-std_gnu99.patch
A    trunk/make/cryptsetup/patches/020-acl_cv_rpath__hardcode_values.patch
A    trunk/make/cryptsetup/patches/040-no_posix_memalign_in_uclibc_0.9.28.patch
A    trunk/make/cryptsetup/patches/030-avoid_largefile_support_warnings.patch
A    trunk/make/cryptsetup/cryptsetup.mk
A    trunk/make/cryptsetup/Config.in
A    trunk/make/classpath
A    trunk/make/classpath/external.files
A    trunk/make/classpath/external.in
A    trunk/make/classpath/patches
A    trunk/make/classpath/patches/100-incomplete_ipv6_test.patch
A    trunk/make/classpath/classpath.mk
A    trunk/make/classpath/Config.in
A    trunk/make/classpath/mini.classlist
A    trunk/make/dtach
A    trunk/make/dtach/external.files
A    trunk/make/dtach/external.in
A    trunk/make/dtach/dtach.mk
A    trunk/make/dtach/Config.in
A    trunk/make/git
A    trunk/make/git/files
A    trunk/make/git/files/.language
A    trunk/make/git/files/root
A    trunk/make/git/files/root/usr
A    trunk/make/git/files/root/usr/lib
A    trunk/make/git/files/root/usr/lib/cgi-bin
A    trunk/make/git/files/root/usr/lib/cgi-bin/git.cgi
A    trunk/make/git/files/root/etc
A    trunk/make/git/files/root/etc/init.d
A    trunk/make/git/files/root/etc/init.d/rc.git
A    trunk/make/git/files/root/etc/default.git
A    trunk/make/git/files/root/etc/default.git/git.cfg
A    trunk/make/git/files/root/etc/default.git/git.inetd
A    trunk/make/git/external.files
A    trunk/make/git/external.services
A    trunk/make/git/external.in
A    trunk/make/git/patches
A    trunk/make/git/patches/060-extra_flags.patch
A    trunk/make/git/patches/015-no_gettext.patch
A    trunk/make/git/patches/010-missing_NO_INSTALL_HARDLINKS.patch
A    trunk/make/git/patches/030-no_rpath.patch
A    trunk/make/git/patches/040-template_dir.patch
A    trunk/make/git/patches/020-allow-without-perl.patch
A    trunk/make/git/patches/050-dont-overwrite-patched-configure.patch
A    trunk/make/git/git.mk
A    trunk/make/git/Config.in
A    trunk/make/openssl
A    trunk/make/openssl/external.in.libs
A    trunk/make/openssl/Config.in.libs
A    trunk/make/openssl/external.files
A    trunk/make/openssl/patches
A    trunk/make/openssl/patches/1.0.1e
A    trunk/make/openssl/patches/1.0.1e/120-makedepend_using_bash.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/190-configure_quiet.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/260-missing_libssl_workaround.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/200-dont-force-large-file.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/120-cisco-dtls-fix.patch
A    trunk/make/openssl/patches/1.0.1e/140-makefile-dirs.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/160-disable_doc_tests.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/230-remove_timestamp_check.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/180-jobserver_unavailable_fix.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/270-no_rpath.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/280-no_private_libs.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/100-hmac-avm.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/150-no_engines.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/110-optimize-for-size.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/250-no_host_LD_LIBRARY_PATH.openssl.patch
A    trunk/make/openssl/patches/1.0.1e/130-perl-path.openssl.patch
A    trunk/make/openssl/patches/0.9.8y
A    trunk/make/openssl/patches/0.9.8y/190-configure_quiet.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/260-missing_libssl_workaround.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/200-dont-force-large-file.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/210-optional-ipv6.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/140-makefile-dirs.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/160-disable_doc_tests.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/230-remove_timestamp_check.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/180-jobserver_unavailable_fix.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/270-no_rpath.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/220-uclibc-susv3-legacy.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/100-hmac-avm.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/150-no_engines.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/110-optimize-for-size.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/250-no_host_LD_LIBRARY_PATH.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/120-makedepend.openssl.patch
A    trunk/make/openssl/patches/0.9.8y/130-perl-path.openssl.patch
A    trunk/make/openssl/openssl.mk
A    trunk/make/pingtunnel
A    trunk/make/pingtunnel/files
A    trunk/make/pingtunnel/files/.language
A    trunk/make/pingtunnel/files/root
A    trunk/make/pingtunnel/files/root/usr
A    trunk/make/pingtunnel/files/root/usr/lib
A    trunk/make/pingtunnel/files/root/usr/lib/cgi-bin
A    trunk/make/pingtunnel/files/root/usr/lib/cgi-bin/pingtunnel.cgi
A    trunk/make/pingtunnel/files/root/etc
A    trunk/make/pingtunnel/files/root/etc/init.d
A    trunk/make/pingtunnel/files/root/etc/init.d/rc.pingtunnel
A    trunk/make/pingtunnel/files/root/etc/default.pingtunnel
A    trunk/make/pingtunnel/files/root/etc/default.pingtunnel/pingtunnel.cfg
A    trunk/make/pingtunnel/external.files
A    trunk/make/pingtunnel/external.services
A    trunk/make/pingtunnel/external.in
A    trunk/make/pingtunnel/patches
A    trunk/make/pingtunnel/patches/000-disable-selinux.patch
A    trunk/make/pingtunnel/pingtunnel.mk
A    trunk/make/pingtunnel/Config.in
A    trunk/make/module-init-tools
A    trunk/make/module-init-tools/patches
A    trunk/make/module-init-tools/patches/100-no_docs.patch
A    trunk/make/module-init-tools/Config.in
A    trunk/make/module-init-tools/module-init-tools.mk
A    trunk/make/sshfs-fuse
A    trunk/make/sshfs-fuse/files
A    trunk/make/sshfs-fuse/files/.language
A    trunk/make/sshfs-fuse/files/root
A    trunk/make/sshfs-fuse/files/root/usr
A    trunk/make/sshfs-fuse/files/root/usr/lib
A    trunk/make/sshfs-fuse/files/root/usr/lib/cgi-bin
A    trunk/make/sshfs-fuse/files/root/usr/lib/cgi-bin/sshfs-fuse.cgi
A    trunk/make/sshfs-fuse/files/root/etc
A    trunk/make/sshfs-fuse/files/root/etc/init.d
A    trunk/make/sshfs-fuse/files/root/etc/init.d/rc.sshfs-fuse
A    trunk/make/sshfs-fuse/files/root/etc/default.sshfs-fuse
A    trunk/make/sshfs-fuse/files/root/etc/default.sshfs-fuse/sshfs-fuse.cfg
A    trunk/make/sshfs-fuse/external.files
A    trunk/make/sshfs-fuse/external.in
A    trunk/make/sshfs-fuse/Config.in
A    trunk/make/sshfs-fuse/sshfs-fuse.mk
A    trunk/make/pptpd
A    trunk/make/pptpd/files
A    trunk/make/pptpd/files/.language
A    trunk/make/pptpd/files/root
A    trunk/make/pptpd/files/root/usr
A    trunk/make/pptpd/files/root/usr/lib
A    trunk/make/pptpd/files/root/usr/lib/cgi-bin
A    trunk/make/pptpd/files/root/usr/lib/cgi-bin/pptpd.cgi
A    trunk/make/pptpd/files/root/etc
A    trunk/make/pptpd/files/root/etc/init.d
A    trunk/make/pptpd/files/root/etc/init.d/rc.pptpd
A    trunk/make/pptpd/files/root/etc/default.pptpd
A    trunk/make/pptpd/files/root/etc/default.pptpd/pptpd_options.def
A    trunk/make/pptpd/files/root/etc/default.pptpd/pptpd.cfg
A    trunk/make/pptpd/files/root/etc/default.pptpd/pptpd_conf.def
A    trunk/make/pptpd/external.files
A    trunk/make/pptpd/external.services
A    trunk/make/pptpd/external.in
A    trunk/make/pptpd/patches
A    trunk/make/pptpd/patches/101-gre_reorder.patch
A    trunk/make/pptpd/patches/102-fix_pppd_version.patch
A    trunk/make/pptpd/patches/100-no_libintlh.patch
A    trunk/make/pptpd/Config.in
A    trunk/make/pptpd/pptpd.mk
A    trunk/make/tiff
A    trunk/make/tiff/external.in.libs
A    trunk/make/tiff/Config.in.libs
A    trunk/make/tiff/external.files
A    trunk/make/tiff/patches
A    trunk/make/tiff/patches/010-no_tests_no_docs.patch
A    trunk/make/tiff/tiff.mk
A    trunk/make/haproxy
A    trunk/make/haproxy/haproxy.mk
A    trunk/make/haproxy/Config.in
A    trunk/make/nfsd-cgi
A    trunk/make/nfsd-cgi/nfsd-cgi.mk
A    trunk/make/nfsd-cgi/files
A    trunk/make/nfsd-cgi/files/.language
A    trunk/make/nfsd-cgi/files/root
A    trunk/make/nfsd-cgi/files/root/usr
A    trunk/make/nfsd-cgi/files/root/usr/lib
A    trunk/make/nfsd-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/nfsd-cgi/files/root/usr/lib/cgi-bin/nfsd.cgi
A    trunk/make/nfsd-cgi/files/root/etc
A    trunk/make/nfsd-cgi/files/root/etc/init.d
A    trunk/make/nfsd-cgi/files/root/etc/init.d/rc.nfsd
A    trunk/make/nfsd-cgi/files/root/etc/default.nfsd
A    trunk/make/nfsd-cgi/files/root/etc/default.nfsd/exports.def
A    trunk/make/nfsd-cgi/files/root/etc/default.nfsd/nfsd.cfg
A    trunk/make/nfsd-cgi/files/root/etc/default.nfsd/hosts_allow.def
A    trunk/make/nfsd-cgi/files/root/etc/default.nfsd/hosts_deny.def
A    trunk/make/nfsd-cgi/files/root/etc/hosts.allow
A    trunk/make/nfsd-cgi/files/root/etc/hosts.deny
A    trunk/make/nfsd-cgi/Config.in
A    trunk/make/nfsroot
A    trunk/make/nfsroot/nfsroot.mk
A    trunk/make/nfsroot/files
A    trunk/make/nfsroot/files/root
A    trunk/make/nfsroot/files/root/etc
A    trunk/make/nfsroot/files/root/etc/init.d
A    trunk/make/nfsroot/files/root/etc/init.d/rc.nfsroot
A    trunk/make/nfsroot/Config.in
A    trunk/make/mdev
A    trunk/make/mdev/mdev.mk
A    trunk/make/mdev/files
A    trunk/make/mdev/files/root
A    trunk/make/mdev/files/root/lib
A    trunk/make/mdev/files/root/lib/mdev
A    trunk/make/mdev/files/root/lib/mdev/interface
A    trunk/make/mdev/files/root/lib/mdev/interface/avmusbwlan
A    trunk/make/mdev/files/root/lib/mdev/interface/storage
A    trunk/make/mdev/files/root/lib/mdev/session
A    trunk/make/mdev/files/root/lib/mdev/session/syslog
A    trunk/make/mdev/files/root/lib/mdev/session/tam
A    trunk/make/mdev/files/root/lib/mdev/session/samba
A    trunk/make/mdev/files/root/lib/mdev/session/ftpd
A    trunk/make/mdev/files/root/lib/mdev/session/usbroot
A    trunk/make/mdev/files/root/lib/mdev/common
A    trunk/make/mdev/files/root/lib/mdev/common/log
A    trunk/make/mdev/files/root/lib/mdev/common/mdevmodule
A    trunk/make/mdev/files/root/lib/mdev/common/mdevprobe
A    trunk/make/mdev/files/root/lib/mdev/common/led
A    trunk/make/mdev/files/root/lib/mdev/common/ar7value
A    trunk/make/mdev/files/root/lib/mdev/common/mdevlog
A    trunk/make/mdev/files/root/lib/mdev/usb
A    trunk/make/mdev/files/root/lib/mdev/usb/avmusbwlan.add
A    trunk/make/mdev/files/root/lib/mdev/usb/usbdev
A    trunk/make/mdev/files/root/lib/mdev/usb/usbcontrol
A    trunk/make/mdev/files/root/lib/mdev/usb/avmusbwlan.remove
A    trunk/make/mdev/files/root/lib/mdev/usb/eventvars
A    trunk/make/mdev/files/root/lib/mdev/block
A    trunk/make/mdev/files/root/lib/mdev/block/vfat.mount
A    trunk/make/mdev/files/root/lib/mdev/block/mount
A    trunk/make/mdev/files/root/lib/mdev/block/ext2.mount
A    trunk/make/mdev/files/root/lib/mdev/block/ext3.mount
A    trunk/make/mdev/files/root/lib/mdev/block/umount
A    trunk/make/mdev/files/root/lib/mdev/block/partition
A    trunk/make/mdev/files/root/lib/mdev/block/disk
A    trunk/make/mdev/files/root/lib/mdev/block/ntfs.mount
A    trunk/make/mdev/files/root/lib/mdev/block/swap.mount
A    trunk/make/mdev/files/root/lib/mdev/block/unrecognized
A    trunk/make/mdev/files/root/lib/mdev/misc
A    trunk/make/mdev/files/root/lib/mdev/misc/mtd
A    trunk/make/mdev/files/root/lib/mdev/misc/bitfile
A    trunk/make/mdev/files/root/bin
A    trunk/make/mdev/files/root/bin/mount.ntfs-3g
A    trunk/make/mdev/files/root/etc
A    trunk/make/mdev/files/root/etc/mdev.conf
A    trunk/make/mdev/files/root/etc/device.table
A    trunk/make/mdev/files/root/etc/modprobe.conf
A    trunk/make/mdev/doc
A    trunk/make/mdev/doc/serial-usb_add.chain
A    trunk/make/mdev/doc/storage_remove.chain
A    trunk/make/mdev/doc/run
A    trunk/make/mdev/doc/run/add-hub_serial_key.mdev
A    trunk/make/mdev/doc/run/remove-hub_serial_key.mdev
A    trunk/make/mdev/doc/serial-usb_remove.chain
A    trunk/make/mdev/doc/storage/01-sda_delete-remove.hotplug
A    trunk/make/mdev/doc/storage/03-modprobe_sd_mod-add.hotplug
A    trunk/make/mdev/doc/storage/01-memory_key-add.hotplug
A    trunk/make/mdev/doc/storage/02-modprobe_modalias-add.hotplug
A    trunk/make/mdev/doc/storage/03-rmmod_usb_storage-remove.hotplug
A    trunk/make/mdev/doc/storage/02-rmmod_sd_mod-remove.hotplug
A    trunk/make/mdev/doc/bluetooth
A    trunk/make/mdev/doc/bluetooth/add_02_rfcomm_module.mdev
A    trunk/make/mdev/doc/bluetooth/add_01_bluetooth-dongle.mdev
A    trunk/make/mdev/doc/serial-usb/add_02_pl2303.mdev
A    trunk/make/mdev/doc/serial-usb/add_02_pl2303_2nd-device.mdev
A    trunk/make/mdev/doc/serial-usb/remove_01_device.mdev
A    trunk/make/mdev/doc/serial-usb/add_01_connect.mdev
A    trunk/make/mdev/doc/serial-usb/add_01_connect_2nd-device.mdev
A    trunk/make/mdev/doc/serial-usb/remove_02_pl2303.mdev
A    trunk/make/mdev/doc/storage_add.chain
A    trunk/make/mdev/doc/bluetooth_add.chain
A    trunk/make/mdev/patches
A    trunk/make/mdev/patches/hardware
A    trunk/make/mdev/patches/hardware/7170_piglet.patch
A    trunk/make/mdev/patches/hardware/7270_piglet.patch
A    trunk/make/mdev/patches/hardware/W701V_piglet.patch
A    trunk/make/mdev/patches/hardware/W900V_piglet.patch
A    trunk/make/mdev/patches/hardware/3130_piglet.patch
A    trunk/make/mdev/patches/hardware/3131_piglet.patch
A    trunk/make/mdev/patches/hardware/2171_piglet.patch
A    trunk/make/mdev/patches/hardware/3170_piglet.patch
A    trunk/make/mdev/patches/hardware/7140_piglet.patch
A    trunk/make/mdev/patches/hardware/7141_piglet.patch
A    trunk/make/mdev/patches/hardware/7150_piglet.patch
A    trunk/make/mdev/patches/hardware/7240_piglet.patch
A    trunk/make/mdev/Config.in
A    trunk/make/html2text
A    trunk/make/html2text/html2text.mk
A    trunk/make/html2text/external.files
A    trunk/make/html2text/external.in
A    trunk/make/html2text/patches
A    trunk/make/html2text/patches/810-fix-deprecated-conversion-warnings.debian.patch
A    trunk/make/html2text/patches/030-auto_ptr-fpermissive.patch
A    trunk/make/html2text/patches/200-close-files-inside-main-loop.debian.patch
A    trunk/make/html2text/patches/010-cross_CXX.patch
A    trunk/make/html2text/patches/400-remove-builtin-http-support.debian.patch
A    trunk/make/html2text/patches/550-skip-numbers-in-html-tag-attributes.debian.patch
A    trunk/make/html2text/patches/040-uClibcxx_no_match_for_equal_operator_workaround.patch
A    trunk/make/html2text/patches/020-CXXFLAGS.patch
A    trunk/make/html2text/patches/401-remove-builtin-http-support.stdin_fix.patch
A    trunk/make/html2text/Config.in
A    trunk/make/microperl
A    trunk/make/microperl/microperl.mk
A    trunk/make/microperl/external.files
A    trunk/make/microperl/external.in
A    trunk/make/microperl/patches
A    trunk/make/microperl/patches/300-fix_moduledir.patch
A    trunk/make/microperl/patches/200-env_enable.patch
A    trunk/make/microperl/patches/100-static_uudmap.patch
A    trunk/make/microperl/Config.in
A    trunk/make/tesseract/external.in.libs
A    trunk/make/tesseract/Config.in.libs
A    trunk/make/tesseract/external.files
A    trunk/make/tesseract/tesseract.mk
A    trunk/make/tesseract/patches
A    trunk/make/tesseract/patches/010-uclibc_fmax.patch
A    trunk/make/tesseract/patches/030-pkgconfig_cleanup.patch
A    trunk/make/tinc
A    trunk/make/tinc/files
A    trunk/make/tinc/files/.language
A    trunk/make/tinc/files/root
A    trunk/make/tinc/files/root/usr
A    trunk/make/tinc/files/root/usr/lib
A    trunk/make/tinc/files/root/usr/lib/cgi-bin
A    trunk/make/tinc/files/root/usr/lib/cgi-bin/tinc.cgi
A    trunk/make/tinc/files/root/etc
A    trunk/make/tinc/files/root/etc/default.tinc
A    trunk/make/tinc/files/root/etc/default.tinc/default-config.sh
A    trunk/make/tinc/files/root/etc/default.tinc/rsa_key_pub.def
A    trunk/make/tinc/files/root/etc/default.tinc/tinc_down.def
A    trunk/make/tinc/files/root/etc/default.tinc/tinc_conf
A    trunk/make/tinc/files/root/etc/default.tinc/server1.def
A    trunk/make/tinc/files/root/etc/default.tinc/server2.def
A    trunk/make/tinc/files/root/etc/default.tinc/server3.def
A    trunk/make/tinc/files/root/etc/default.tinc/rsa_key_priv.def
A    trunk/make/tinc/files/root/etc/default.tinc/tinc.save
A    trunk/make/tinc/files/root/etc/default.tinc/tinc.cfg
A    trunk/make/tinc/files/root/etc/default.tinc/tinc_up.def
A    trunk/make/tinc/files/root/etc/init.d
A    trunk/make/tinc/files/root/etc/init.d/rc.tinc
A    trunk/make/tinc/external.files
A    trunk/make/tinc/tinc.mk
A    trunk/make/tinc/external.services
A    trunk/make/tinc/external.in
A    trunk/make/tinc/Config.in
A    trunk/make/tmux
A    trunk/make/tmux/external.files
A    trunk/make/tmux/tmux.mk
A    trunk/make/tmux/external.in
A    trunk/make/tmux/patches
A    trunk/make/tmux/patches/100-use_var_tmp.patch
A    trunk/make/tmux/patches/120-b64_ntop-conflict.patch
A    trunk/make/tmux/patches/110-no_host_includes.patch
A    trunk/make/tmux/patches/005-no_libresolv.patch
A    trunk/make/tmux/Config.in
A    trunk/make/ppp-cgi
A    trunk/make/ppp-cgi/files
A    trunk/make/ppp-cgi/files/.language
A    trunk/make/ppp-cgi/files/root
A    trunk/make/ppp-cgi/files/root/usr
A    trunk/make/ppp-cgi/files/root/usr/lib
A    trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin/ppp
A    trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin/ppp/ppplog.cgi
A    trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin/ppp.cgi
A    trunk/make/ppp-cgi/files/root/etc
A    trunk/make/ppp-cgi/files/root/etc/default.ppp
A    trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp_dialer
A    trunk/make/ppp-cgi/files/root/etc/default.ppp/peers_options.def
A    trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp_observer
A    trunk/make/ppp-cgi/files/root/etc/default.ppp/peers_chat.def
A    trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp.cfg
A    trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp_logger
A    trunk/make/ppp-cgi/files/root/etc/init.d
A    trunk/make/ppp-cgi/files/root/etc/init.d/rc.ppp
A    trunk/make/ppp-cgi/external.files
A    trunk/make/ppp-cgi/external.services
A    trunk/make/ppp-cgi/ppp-cgi.mk
A    trunk/make/ppp-cgi/external.in
A    trunk/make/ppp-cgi/Config.in
A    trunk/make/ctorrent
A    trunk/make/ctorrent/external.files
A    trunk/make/ctorrent/ctorrent.mk
A    trunk/make/ctorrent/external.in
A    trunk/make/ctorrent/patches
A    trunk/make/ctorrent/patches/100-CVE-2009-1759.patch
A    trunk/make/ctorrent/Config.in
A    trunk/make/radvd
A    trunk/make/radvd/files
A    trunk/make/radvd/files/.language
A    trunk/make/radvd/files/root
A    trunk/make/radvd/files/root/usr
A    trunk/make/radvd/files/root/usr/lib
A    trunk/make/radvd/files/root/usr/lib/cgi-bin
A    trunk/make/radvd/files/root/usr/lib/cgi-bin/radvd.cgi
A    trunk/make/radvd/files/root/etc
A    trunk/make/radvd/files/root/etc/default.radvd
A    trunk/make/radvd/files/root/etc/default.radvd/radvd_conf
A    trunk/make/radvd/files/root/etc/default.radvd/radvd.save
A    trunk/make/radvd/files/root/etc/default.radvd/radvd.cfg
A    trunk/make/radvd/files/root/etc/init.d
A    trunk/make/radvd/files/root/etc/init.d/rc.radvd
A    trunk/make/radvd/external.files
A    trunk/make/radvd/external.services
A    trunk/make/radvd/radvd.mk
A    trunk/make/radvd/external.in
A    trunk/make/radvd/Config.in
A    trunk/make/sqlite
A    trunk/make/sqlite/external.in.libs
A    trunk/make/sqlite/Config.in.libs
A    trunk/make/sqlite/external.files
A    trunk/make/sqlite/patches
A    trunk/make/sqlite/patches/010-pthread_fixes.patch
A    trunk/make/sqlite/sqlite.mk
A    trunk/make/xpdf
A    trunk/make/xpdf/patches
A    trunk/make/xpdf/patches/xpdf-3.02pl4.patch
A    trunk/make/xpdf/patches/xpdf-shared.patch
A    trunk/make/xpdf/patches/xpdf-3.02pl1.patch
A    trunk/make/xpdf/patches/xpdf-3.02pl2.patch
A    trunk/make/xpdf/patches/xpdf-3.02pl3.patch
A    trunk/make/xpdf/xpdf.mk
A    trunk/make/xpdf/Config.in
A    trunk/make/modcgi
A    trunk/make/modcgi/patches
A    trunk/make/modcgi/patches/100-proccgi.patch
A    trunk/make/modcgi/modcgi.mk
A    trunk/make/modcgi/Config.in
A    trunk/make/tor
A    trunk/make/tor/files
A    trunk/make/tor/files/.language
A    trunk/make/tor/files/root
A    trunk/make/tor/files/root/usr
A    trunk/make/tor/files/root/usr/lib
A    trunk/make/tor/files/root/usr/lib/cgi-bin
A    trunk/make/tor/files/root/usr/lib/cgi-bin/tor.cgi
A    trunk/make/tor/files/root/etc
A    trunk/make/tor/files/root/etc/init.d
A    trunk/make/tor/files/root/etc/init.d/rc.tor
A    trunk/make/tor/files/root/etc/default.tor
A    trunk/make/tor/files/root/etc/default.tor/tor.cfg
A    trunk/make/tor/files/root/etc/default.tor/secret_id_key.def
A    trunk/make/tor/files/root/etc/default.tor/tor_conf
A    trunk/make/tor/files/README
A    trunk/make/tor/external.files
A    trunk/make/tor/external.services
A    trunk/make/tor/external.in
A    trunk/make/tor/Config.in
A    trunk/make/tor/tor.mk
A    trunk/make/lftp
A    trunk/make/lftp/external.files
A    trunk/make/lftp/external.in
A    trunk/make/lftp/patches
A    trunk/make/lftp/patches/010-cxx11_workaround.patch
A    trunk/make/lftp/Config.in
A    trunk/make/lftp/lftp.mk
A    trunk/make/httptunnel
A    trunk/make/httptunnel/external.files
A    trunk/make/httptunnel/external.in
A    trunk/make/httptunnel/patches
A    trunk/make/httptunnel/patches/100-fix_stdin-stdout.patch
A    trunk/make/httptunnel/Config.in
A    trunk/make/httptunnel/httptunnel.mk
A    trunk/make/cifsmount
A    trunk/make/cifsmount/files
A    trunk/make/cifsmount/files/root
A    trunk/make/cifsmount/files/root/usr
A    trunk/make/cifsmount/files/root/usr/lib
A    trunk/make/cifsmount/files/root/usr/lib/cgi-bin
A    trunk/make/cifsmount/files/root/usr/lib/cgi-bin/cifsmount.cgi
A    trunk/make/cifsmount/files/root/usr/sbin
A    trunk/make/cifsmount/files/root/usr/sbin/cifsmount
A    trunk/make/cifsmount/files/root/etc
A    trunk/make/cifsmount/files/root/etc/init.d
A    trunk/make/cifsmount/files/root/etc/init.d/rc.cifsmount
A    trunk/make/cifsmount/files/root/etc/default.cifsmount
A    trunk/make/cifsmount/files/root/etc/default.cifsmount/cifsmount.cfg
A    trunk/make/cifsmount/external.files
A    trunk/make/cifsmount/external.services
A    trunk/make/cifsmount/external.in
A    trunk/make/cifsmount/Config.in
A    trunk/make/cifsmount/cifsmount.mk
A    trunk/make/dvbtune
A    trunk/make/dvbtune/patches
A    trunk/make/dvbtune/patches/10-Makefile.patch
A    trunk/make/dvbtune/Config.in
A    trunk/make/dvbtune/dvbtune.mk
A    trunk/make/shellinabox
A    trunk/make/shellinabox/files
A    trunk/make/shellinabox/files/.language
A    trunk/make/shellinabox/files/root
A    trunk/make/shellinabox/files/root/usr
A    trunk/make/shellinabox/files/root/usr/lib
A    trunk/make/shellinabox/files/root/usr/lib/cgi-bin
A    trunk/make/shellinabox/files/root/usr/lib/cgi-bin/shellinabox.cgi
A    trunk/make/shellinabox/files/root/etc
A    trunk/make/shellinabox/files/root/etc/init.d
A    trunk/make/shellinabox/files/root/etc/init.d/rc.shellinabox
A    trunk/make/shellinabox/files/root/etc/default.shellinabox
A    trunk/make/shellinabox/files/root/etc/default.shellinabox/generate_cert.sh
A    trunk/make/shellinabox/files/root/etc/default.shellinabox/shellinabox.cfg
A    trunk/make/shellinabox/external.files
A    trunk/make/shellinabox/external.services
A    trunk/make/shellinabox/external.in
A    trunk/make/shellinabox/patches
A    trunk/make/shellinabox/patches/120_missing_HAVE_UTMPX_H.patch
A    trunk/make/shellinabox/patches/110_fix_missing_getgrouplist.patch
A    trunk/make/shellinabox/patches/140-use_uclibc_daemon_func.patch
A    trunk/make/shellinabox/patches/130_fix_static.patch
A    trunk/make/shellinabox/Config.in
A    trunk/make/shellinabox/shellinabox.mk
A    trunk/make/udpxy
A    trunk/make/udpxy/udpxy.mk
A    trunk/make/udpxy/files
A    trunk/make/udpxy/files/root
A    trunk/make/udpxy/files/root/usr
A    trunk/make/udpxy/files/root/usr/bin
A    trunk/make/udpxy/files/root/usr/bin/udpxrec
A    trunk/make/udpxy/external.files
A    trunk/make/udpxy/external.in
A    trunk/make/udpxy/Config.in
A    trunk/make/ncftp
A    trunk/make/ncftp/ncftp.mk
A    trunk/make/ncftp/external.files
A    trunk/make/ncftp/external.in
A    trunk/make/ncftp/patches
A    trunk/make/ncftp/patches/02-no_host_defines_while_crosscompiling.patch
A    trunk/make/ncftp/patches/01-no_static_libgcc_in_CFLAGS.patch
A    trunk/make/ncftp/Config.in
A    trunk/make/hplip
A    trunk/make/hplip/files
A    trunk/make/hplip/files/root
A    trunk/make/hplip/files/root/etc
A    trunk/make/hplip/files/root/etc/default.sane-backends
A    trunk/make/hplip/files/root/etc/default.sane-backends/dll.d
A    trunk/make/hplip/files/root/etc/default.sane-backends/dll.d/hplip
A    trunk/make/hplip/hplip.mk
A    trunk/make/hplip/external.files
A    trunk/make/hplip/hplip-config-update.py
A    trunk/make/hplip/external.in
A    trunk/make/hplip/patches
A    trunk/make/hplip/patches/100-hplip-minimal.patch
A    trunk/make/hplip/Config.in
A    trunk/make/tcpdump
A    trunk/make/tcpdump/tcpdump.mk
A    trunk/make/tcpdump/external.files
A    trunk/make/tcpdump/external.in
A    trunk/make/tcpdump/patches
A    trunk/make/tcpdump/patches/03-uflag_flushopen.patch
A    trunk/make/tcpdump/patches/01-remove_pcap_debug.patch
A    trunk/make/tcpdump/patches/10-tcpdump_mini.patch
A    trunk/make/tcpdump/patches/02-shared_pcap.patch
A    trunk/make/tcpdump/Config.in
A    trunk/make/bluez-utils
A    trunk/make/bluez-utils/files
A    trunk/make/bluez-utils/files/root
A    trunk/make/bluez-utils/files/root/usr
A    trunk/make/bluez-utils/files/root/usr/lib
A    trunk/make/bluez-utils/files/root/usr/lib/cgi-bin
A    trunk/make/bluez-utils/files/root/usr/lib/cgi-bin/bluez-utils
A    trunk/make/bluez-utils/files/root/usr/lib/cgi-bin/bluez-utils/bluez-utils-help.cgi
A    trunk/make/bluez-utils/files/root/usr/lib/cgi-bin/bluez-utils.cgi
A    trunk/make/bluez-utils/files/root/usr/bin
A    trunk/make/bluez-utils/files/root/usr/bin/bluepin
A    trunk/make/bluez-utils/files/root/etc
A    trunk/make/bluez-utils/files/root/etc/ppp
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils/rfcomm.def
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils/dun.def
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils/linkkeys.def
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils/hcidconf.def
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils/netpandu.def
A    trunk/make/bluez-utils/files/root/etc/default.bluez-utils/bluez-utils.cfg
A    trunk/make/bluez-utils/files/root/etc/hotplug
A    trunk/make/bluez-utils/files/root/etc/hotplug/net.pandu
A    trunk/make/bluez-utils/files/root/etc/bluetooth
A    trunk/make/bluez-utils/files/root/etc/bluetooth/pin
A    trunk/make/bluez-utils/files/root/etc/bluetooth/rfcomm.conf
A    trunk/make/bluez-utils/files/root/etc/bluetooth/hcid.conf
A    trunk/make/bluez-utils/files/root/etc/bluetooth/help.html
A    trunk/make/bluez-utils/files/root/etc/init.d
A    trunk/make/bluez-utils/files/root/etc/init.d/rc.bluez-utils
A    trunk/make/bluez-utils/external.files
A    trunk/make/bluez-utils/external.services
A    trunk/make/bluez-utils/bluez-utils.mk
A    trunk/make/bluez-utils/external.in
A    trunk/make/bluez-utils/Config.in
A    trunk/make/portmap
A    trunk/make/portmap/patches
A    trunk/make/portmap/patches/101-no_pie.patch
A    trunk/make/portmap/portmap.mk
A    trunk/make/portmap/Config.in
A    trunk/make/pptp
A    trunk/make/pptp/files
A    trunk/make/pptp/files/.language
A    trunk/make/pptp/files/root
A    trunk/make/pptp/files/root/usr
A    trunk/make/pptp/files/root/usr/lib
A    trunk/make/pptp/files/root/usr/lib/cgi-bin
A    trunk/make/pptp/files/root/usr/lib/cgi-bin/pptp.cgi
A    trunk/make/pptp/files/root/etc
A    trunk/make/pptp/files/root/etc/init.d
A    trunk/make/pptp/files/root/etc/init.d/rc.pptp
A    trunk/make/pptp/files/root/etc/default.pptp
A    trunk/make/pptp/files/root/etc/default.pptp/pptp.cfg
A    trunk/make/pptp/files/root/etc/default.pptp/pptp_restart
A    trunk/make/pptp/files/root/etc/default.pptp/pptp_options.def
A    trunk/make/pptp/files/root/etc/default.pptp/pptp_peer
A    trunk/make/pptp/external.files
A    trunk/make/pptp/external.services
A    trunk/make/pptp/external.in
A    trunk/make/pptp/patches
A    trunk/make/pptp/patches/100-remove_stropts.patch
A    trunk/make/pptp/pptp.mk
A    trunk/make/pptp/Config.in
A    trunk/make/iptraf
A    trunk/make/iptraf/files
A    trunk/make/iptraf/files/var.tar
A    trunk/make/iptraf/files/var.tar/var
A    trunk/make/iptraf/files/var.tar/var/log
A    trunk/make/iptraf/files/var.tar/var/log/iptraf
A    trunk/make/iptraf/files/var.tar/var/log/iptraf/.gitignore
A    trunk/make/iptraf/files/var.tar/var/run
A    trunk/make/iptraf/files/var.tar/var/run/iptraf
A    trunk/make/iptraf/files/var.tar/var/run/iptraf/.gitignore
A    trunk/make/iptraf/external.files
A    trunk/make/iptraf/external.in
A    trunk/make/iptraf/patches
A    trunk/make/iptraf/patches/008-execl.patch
A    trunk/make/iptraf/patches/005-atheros.patch
A    trunk/make/iptraf/patches/006-src_makefile.patch
A    trunk/make/iptraf/patches/002-ifaces.patch
A    trunk/make/iptraf/patches/007-iptraf_c.patch
A    trunk/make/iptraf/patches/003-exit_menu.patch
A    trunk/make/iptraf/patches/004-includes_fix.patch
A    trunk/make/iptraf/patches/001-cross_compile.patch
A    trunk/make/iptraf/Config.in
A    trunk/make/iptraf/iptraf.mk
A    trunk/make/php
A    trunk/make/php/files
A    trunk/make/php/files/.language
A    trunk/make/php/files/root
A    trunk/make/php/files/root/etc
A    trunk/make/php/files/root/etc/init.d
A    trunk/make/php/files/root/etc/init.d/rc.php
A    trunk/make/php/files/root/etc/default.php
A    trunk/make/php/files/root/etc/default.php/php.cfg
A    trunk/make/php/files/root/etc/default.php/php.ini
A    trunk/make/php/files/root/etc/default.php/php_config.def
A    trunk/make/php/external.files
A    trunk/make/php/external.services
A    trunk/make/php/external.in
A    trunk/make/php/patches
A    trunk/make/php/patches/5.3.22
A    trunk/make/php/patches/5.3.22/500-ttyname_r.patch
A    trunk/make/php/patches/5.3.22/600-strange_iconv_undef.patch
A    trunk/make/php/patches/5.3.22/700-remove_libgd_function.patch
A    trunk/make/php/patches/5.3.22/110-consider-UCLIBC-specifics.patch
A    trunk/make/php/patches/5.3.22/600-iconv_in_libc_workaround.patch
A    trunk/make/php/patches/5.3.22/300-no_ldcxx.patch
A    trunk/make/php/patches/5.4.12
A    trunk/make/php/patches/5.4.12/100-libxml-support-missing-ifdefs.patch
A    trunk/make/php/patches/5.4.12/500-ttyname_r.patch
A    trunk/make/php/patches/5.4.12/600-strange_iconv_undef.patch
A    trunk/make/php/patches/5.4.12/700-remove_libgd_function.patch
A    trunk/make/php/patches/5.4.12/101-missing_openssl_ifdef.patch
A    trunk/make/php/patches/5.4.12/110-consider-UCLIBC-specifics.patch
A    trunk/make/php/patches/5.4.12/600-iconv_in_libc_workaround.patch
A    trunk/make/php/patches/5.4.12/300-no_ldcxx.patch
A    trunk/make/php/Config.in
A    trunk/make/php/php.mk
A    trunk/make/lynx
A    trunk/make/lynx/lynx.mk
A    trunk/make/lynx/external.files
A    trunk/make/lynx/external.in
A    trunk/make/lynx/patches
A    trunk/make/lynx/patches/03_defcfg-userdef.h.patch
A    trunk/make/lynx/patches/01_hostcc-src-makefile.patch
A    trunk/make/lynx/patches/04_no-gzip-param.patch
A    trunk/make/lynx/patches/02_defcfg-lynx.cfg.patch
A    trunk/make/lynx/Config.in
A    trunk/make/minicom
A    trunk/make/minicom/minicom.mk
A    trunk/make/minicom/external.files
A    trunk/make/minicom/external.in
A    trunk/make/minicom/patches
A    trunk/make/minicom/patches/110-change-defaults-to-nomodem.patch
A    trunk/make/minicom/patches/100-iconv_workaround.patch
A    trunk/make/minicom/Config.in
A    trunk/make/nmap
A    trunk/make/nmap/nmap.mk
A    trunk/make/nmap/external.files
A    trunk/make/nmap/external.in
A    trunk/make/nmap/patches
A    trunk/make/nmap/patches/4.68
A    trunk/make/nmap/patches/4.68/300-libm.patch
A    trunk/make/nmap/patches/4.68/500-uclibc++-ctime.patch
A    trunk/make/nmap/patches/4.68/400-chartables.c.patch
A    trunk/make/nmap/patches/4.68/200-libpcap_version_check.patch
A    trunk/make/nmap/patches/4.68/600-uclibc++-output.cc.patch
A    trunk/make/nmap/patches/4.68/100-liblua_includes_version_check.patch
A    trunk/make/nmap/patches/5.51
A    trunk/make/nmap/patches/5.51/210-IPv6_defines.patch
A    trunk/make/nmap/patches/5.51/300-libm.patch
A    trunk/make/nmap/patches/5.51/420-nping_libpcap_libdnet_cleanups.patch
A    trunk/make/nmap/patches/5.51/400-nsock_use_the_same_libpcap_as_nmap.patch
A    trunk/make/nmap/patches/5.51/100-liblua_includes.patch
A    trunk/make/nmap/patches/5.51/410-ncat_static.patch
A    trunk/make/nmap/patches/5.51/200-missing_HAVE_IPV6.patch
A    trunk/make/nmap/Config.in
A    trunk/make/python-imaging-library
A    trunk/make/python-imaging-library/python-imaging-library.mk
A    trunk/make/python-imaging-library/patches
A    trunk/make/python-imaging-library/patches/010-no_host_paths.openwrt.patch
A    trunk/make/python-imaging-library/patches/030-debian_1.1.7-4build1.patch
A    trunk/make/python-imaging-library/patches/020-target_endianess.patch
A    trunk/make/python-imaging-library/patches/040-scripts_shebang.patch
A    trunk/make/python-imaging-library/Config.in
A    trunk/make/dbus
A    trunk/make/dbus/external.in.libs
A    trunk/make/dbus/Config.in.libs
A    trunk/make/dbus/files
A    trunk/make/dbus/files/root
A    trunk/make/dbus/files/root/etc
A    trunk/make/dbus/files/root/etc/default.dbus
A    trunk/make/dbus/files/root/etc/default.dbus/dbus.cfg
A    trunk/make/dbus/files/root/etc/init.d
A    trunk/make/dbus/files/root/etc/init.d/rc.dbus
A    trunk/make/dbus/files/root/etc/dbus-1
A    trunk/make/dbus/dbus.mk
A    trunk/make/dbus/external.files
A    trunk/make/dbus/external.services
A    trunk/make/dbus/patches
A    trunk/make/dbus/patches/100-disable_poll_use_select.patch
A    trunk/make/dbus/patches/010-fix_fd_leaks.upstream-9a9b0e2736378d1a8961fb264d7314e921231e8e.patch
A    trunk/make/igmpproxy
A    trunk/make/igmpproxy/files
A    trunk/make/igmpproxy/files/.language
A    trunk/make/igmpproxy/files/root
A    trunk/make/igmpproxy/files/root/usr
A    trunk/make/igmpproxy/files/root/usr/lib
A    trunk/make/igmpproxy/files/root/usr/lib/cgi-bin
A    trunk/make/igmpproxy/files/root/usr/lib/cgi-bin/igmpproxy.cgi
A    trunk/make/igmpproxy/files/root/etc
A    trunk/make/igmpproxy/files/root/etc/default.igmpproxy
A    trunk/make/igmpproxy/files/root/etc/default.igmpproxy/igmpproxy_config.def
A    trunk/make/igmpproxy/files/root/etc/default.igmpproxy/igmpproxy.config
A    trunk/make/igmpproxy/files/root/etc/default.igmpproxy/igmpproxy.cfg
A    trunk/make/igmpproxy/files/root/etc/init.d
A    trunk/make/igmpproxy/files/root/etc/init.d/rc.igmpproxy
A    trunk/make/igmpproxy/external.files
A    trunk/make/igmpproxy/external.services
A    trunk/make/igmpproxy/igmpproxy.mk
A    trunk/make/igmpproxy/external.in
A    trunk/make/igmpproxy/patches
A    trunk/make/igmpproxy/patches/110-no_warn_for_MRT_DEL_MFC.patch
A    trunk/make/igmpproxy/patches/100-no_warn_for_changing_origins.patch
A    trunk/make/igmpproxy/Config.in
A    trunk/make/downloader
A    trunk/make/downloader/files
A    trunk/make/downloader/files/.language
A    trunk/make/downloader/files/root
A    trunk/make/downloader/files/root/usr
A    trunk/make/downloader/files/root/usr/lib
A    trunk/make/downloader/files/root/usr/lib/cgi-bin
A    trunk/make/downloader/files/root/usr/lib/cgi-bin/downloader.cgi
A    trunk/make/downloader/files/root/usr/lib/cgi-bin/downloader/downremover.cgi
A    trunk/make/downloader/files/root/usr/lib/cgi-bin/downloader/downlog.cgi
A    trunk/make/downloader/files/root/usr/bin
A    trunk/make/downloader/files/root/usr/bin/downremover
A    trunk/make/downloader/files/root/usr/bin/downloader
A    trunk/make/downloader/files/root/etc
A    trunk/make/downloader/files/root/etc/default.downloader
A    trunk/make/downloader/files/root/etc/default.downloader/downloader.cfg
A    trunk/make/downloader/files/root/etc/init.d
A    trunk/make/downloader/files/root/etc/init.d/rc.downloader
A    trunk/make/downloader/files/CHANGELOG
A    trunk/make/downloader/files/README
A    trunk/make/downloader/downloader.mk
A    trunk/make/downloader/Config.in
A    trunk/make/onlinechanged-cgi
A    trunk/make/onlinechanged-cgi/files
A    trunk/make/onlinechanged-cgi/files/.language
A    trunk/make/onlinechanged-cgi/files/root
A    trunk/make/onlinechanged-cgi/files/root/etc
A    trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged
A    trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged/onlinechanged.def
A    trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged/onlinechanged.cfg
A    trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged/onlinechanged-cgi
A    trunk/make/onlinechanged-cgi/files/root/etc/init.d
A    trunk/make/onlinechanged-cgi/files/root/etc/init.d/rc.onlinechanged
A    trunk/make/onlinechanged-cgi/files/root/etc/onlinechanged
A    trunk/make/onlinechanged-cgi/files/root/etc/onlinechanged/onlinechanged-cgi
A    trunk/make/onlinechanged-cgi/onlinechanged-cgi.mk
A    trunk/make/onlinechanged-cgi/Config.in
A    trunk/make/rsync
A    trunk/make/rsync/files
A    trunk/make/rsync/files/.language
A    trunk/make/rsync/files/root
A    trunk/make/rsync/files/root/usr
A    trunk/make/rsync/files/root/usr/lib
A    trunk/make/rsync/files/root/usr/lib/cgi-bin
A    trunk/make/rsync/files/root/usr/lib/cgi-bin/rsync.cgi
A    trunk/make/rsync/files/root/etc
A    trunk/make/rsync/files/root/etc/default.rsync
A    trunk/make/rsync/files/root/etc/default.rsync/shares.def
A    trunk/make/rsync/files/root/etc/default.rsync/rsync_conf
A    trunk/make/rsync/files/root/etc/default.rsync/sharesx.def
A    trunk/make/rsync/files/root/etc/default.rsync/rsync.cfg
A    trunk/make/rsync/files/root/etc/init.d
A    trunk/make/rsync/files/root/etc/init.d/rc.rsync
A    trunk/make/rsync/external.files
A    trunk/make/rsync/external.services
A    trunk/make/rsync/rsync.mk
A    trunk/make/rsync/external.in
A    trunk/make/rsync/Config.in
A    trunk/make/bftpd
A    trunk/make/bftpd/files
A    trunk/make/bftpd/files/.language
A    trunk/make/bftpd/files/root
A    trunk/make/bftpd/files/root/usr
A    trunk/make/bftpd/files/root/usr/lib
A    trunk/make/bftpd/files/root/usr/lib/cgi-bin
A    trunk/make/bftpd/files/root/usr/lib/cgi-bin/bftpd.cgi
A    trunk/make/bftpd/files/root/etc
A    trunk/make/bftpd/files/root/etc/default.bftpd
A    trunk/make/bftpd/files/root/etc/default.bftpd/bftpd.inetd
A    trunk/make/bftpd/files/root/etc/default.bftpd/bftpd_conf
A    trunk/make/bftpd/files/root/etc/default.bftpd/bftpd.cfg
A    trunk/make/bftpd/files/root/etc/init.d
A    trunk/make/bftpd/files/root/etc/init.d/rc.bftpd
A    trunk/make/bftpd/bftpd.mk
A    trunk/make/bftpd/patches
A    trunk/make/bftpd/patches/200-bftpd-cflags.patch
A    trunk/make/bftpd/patches/100-config-path.patch
A    trunk/make/bftpd/Config.in
A    trunk/make/subversion
A    trunk/make/subversion/files
A    trunk/make/subversion/files/.language
A    trunk/make/subversion/files/root
A    trunk/make/subversion/files/root/usr
A    trunk/make/subversion/files/root/usr/lib
A    trunk/make/subversion/files/root/usr/lib/cgi-bin
A    trunk/make/subversion/files/root/usr/lib/cgi-bin/subversion
A    trunk/make/subversion/files/root/usr/lib/cgi-bin/subversion/subversion-log.cgi
A    trunk/make/subversion/files/root/usr/lib/cgi-bin/subversion.cgi
A    trunk/make/subversion/files/root/etc
A    trunk/make/subversion/files/root/etc/default.subversion
A    trunk/make/subversion/files/root/etc/default.subversion/subversion.inetd
A    trunk/make/subversion/files/root/etc/default.subversion/subversion.cfg
A    trunk/make/subversion/files/root/etc/init.d
A    trunk/make/subversion/files/root/etc/init.d/rc.subversion
A    trunk/make/subversion/external.files
A    trunk/make/subversion/external.services
A    trunk/make/subversion/subversion.mk
A    trunk/make/subversion/external.in
A    trunk/make/subversion/patches
A    trunk/make/subversion/patches/010-no_bindings.patch
A    trunk/make/subversion/Config.in
A    trunk/make/tree
A    trunk/make/tree/external.files
A    trunk/make/tree/tree.mk
A    trunk/make/tree/external.in
A    trunk/make/tree/patches
A    trunk/make/tree/patches/100-makefile.patch
A    trunk/make/tree/Config.in
A    trunk/make/ipsec-tools
A    trunk/make/ipsec-tools/files
A    trunk/make/ipsec-tools/files/.language
A    trunk/make/ipsec-tools/files/root
A    trunk/make/ipsec-tools/files/root/usr
A    trunk/make/ipsec-tools/files/root/usr/lib
A    trunk/make/ipsec-tools/files/root/usr/lib/cgi-bin
A    trunk/make/ipsec-tools/files/root/usr/lib/cgi-bin/ipsec-tools.cgi
A    trunk/make/ipsec-tools/files/root/etc
A    trunk/make/ipsec-tools/files/root/etc/default.ipsec-tools
A    trunk/make/ipsec-tools/files/root/etc/default.ipsec-tools/ipsec-tools.cfg
A    trunk/make/ipsec-tools/files/root/etc/default.ipsec-tools/ipsec-tools_conf
A    trunk/make/ipsec-tools/files/root/etc/init.d
A    trunk/make/ipsec-tools/files/root/etc/init.d/rc.ipsec-tools
A    trunk/make/ipsec-tools/ipsec-tools.mk
A    trunk/make/ipsec-tools/patches
A    trunk/make/ipsec-tools/patches/101-no_libfl.patch
A    trunk/make/ipsec-tools/patches/100-build_static.patch
A    trunk/make/ipsec-tools/patches/103-fix_missing_GLOB_TILDE.patch
A    trunk/make/ipsec-tools/patches/102-linux_2.6.19_rtnetlink_changes.patch
A    trunk/make/ipsec-tools/patches/005-no_libresolv.patch
A    trunk/make/ipsec-tools/patches/104-fix_Werror_for_list.h.patch
A    trunk/make/ipsec-tools/Config.in
A    trunk/make/curl
A    trunk/make/curl/external.in.libs
A    trunk/make/curl/Config.in.libs
A    trunk/make/curl/external.files
A    trunk/make/curl/patches
A    trunk/make/curl/patches/200-uclibc-cyassl-pthread.patch
A    trunk/make/curl/patches/130-CPPFLAGS_as_CFLAGS.patch
A    trunk/make/curl/patches/101-cross_compile_writable_argv.patch
A    trunk/make/curl/patches/120-curl-config.patch
A    trunk/make/curl/patches/110-gnu_source__reentrant.patch
A    trunk/make/curl/patches/102-binary_static.patch
A    trunk/make/curl/patches/100-makefile_no_docs.patch
A    trunk/make/curl/curl.mk
A    trunk/make/smstools3
A    trunk/make/smstools3/files
A    trunk/make/smstools3/files/.language
A    trunk/make/smstools3/files/root
A    trunk/make/smstools3/files/root/usr
A    trunk/make/smstools3/files/root/usr/lib
A    trunk/make/smstools3/files/root/usr/lib/cgi-bin
A    trunk/make/smstools3/files/root/usr/lib/cgi-bin/smstools3
A    trunk/make/smstools3/files/root/usr/lib/cgi-bin/smstools3/status.cgi
A    trunk/make/smstools3/files/root/usr/lib/cgi-bin/smstools3.cgi
A    trunk/make/smstools3/files/root/etc
A    trunk/make/smstools3/files/root/etc/init.d
A    trunk/make/smstools3/files/root/etc/init.d/rc.smstools3
A    trunk/make/smstools3/files/root/etc/default.smstools3
A    trunk/make/smstools3/files/root/etc/default.smstools3/smstools3.cfg
A    trunk/make/smstools3/files/root/etc/default.smstools3/smstools3_conf
A    trunk/make/smstools3/external.files
A    trunk/make/smstools3/external.services
A    trunk/make/smstools3/external.in
A    trunk/make/smstools3/patches
A    trunk/make/smstools3/patches/110_smsd_cfg_c.patch
A    trunk/make/smstools3/patches/100_smsd_cfg_h.patch
A    trunk/make/smstools3/Config.in
A    trunk/make/smstools3/smstools3.mk
A    trunk/make/comgt
A    trunk/make/comgt/comgt.mk
A    trunk/make/comgt/files
A    trunk/make/comgt/files/root
A    trunk/make/comgt/files/root/etc
A    trunk/make/comgt/files/root/etc/gcom
A    trunk/make/comgt/files/root/etc/gcom/getstrength.gcom
A    trunk/make/comgt/files/root/etc/gcom/setmode.gcom
A    trunk/make/comgt/files/root/etc/gcom/setpin.gcom
A    trunk/make/comgt/files/root/etc/gcom/getcardinfo.gcom
A    trunk/make/comgt/external.files
A    trunk/make/comgt/external.in
A    trunk/make/comgt/patches
A    trunk/make/comgt/patches/110_comgt_h.patch
A    trunk/make/comgt/patches/100-Makefile.patch
A    trunk/make/comgt/patches/120-scriptfile_path.patch
A    trunk/make/comgt/Config.in
A    trunk/make/ltrace
A    trunk/make/ltrace/ltrace.mk
A    trunk/make/ltrace/external.files
A    trunk/make/ltrace/external.in
A    trunk/make/ltrace/patches
A    trunk/make/ltrace/patches/130-ltrace-mips.patch
A    trunk/make/ltrace/patches/200-susv3-legacy.patch
A    trunk/make/ltrace/patches/300-link_available_libraries_only.patch
A    trunk/make/ltrace/patches/100-add-sysdep.patch
A    trunk/make/ltrace/patches/110-ltrace-compile.patch
A    trunk/make/ltrace/Config.in
A    trunk/make/xmail
A    trunk/make/xmail/xmail.mk
A    trunk/make/xmail/files
A    trunk/make/xmail/files/.language
A    trunk/make/xmail/files/root
A    trunk/make/xmail/files/root/usr
A    trunk/make/xmail/files/root/usr/lib
A    trunk/make/xmail/files/root/usr/lib/cgi-bin
A    trunk/make/xmail/files/root/usr/lib/cgi-bin/xmail.cgi
A    trunk/make/xmail/files/root/etc
A    trunk/make/xmail/files/root/etc/init.d
A    trunk/make/xmail/files/root/etc/init.d/rc.xmail
A    trunk/make/xmail/files/root/etc/default.xmail
A    trunk/make/xmail/files/root/etc/default.xmail/xmail.cfg
A    trunk/make/xmail/files/README
A    trunk/make/xmail/external.files
A    trunk/make/xmail/external.services
A    trunk/make/xmail/external.in
A    trunk/make/xmail/patches
A    trunk/make/xmail/patches/201-ipv6_SysDepCommon.patch
A    trunk/make/xmail/patches/301-Makefile_common.patch
A    trunk/make/xmail/patches/100-compartment.patch
A    trunk/make/xmail/patches/500-MailRoot.patch
A    trunk/make/xmail/patches/400-SSLConfig.patch
A    trunk/make/xmail/patches/500-LMAILSrv.patch
A    trunk/make/xmail/patches/400-SSLBind.patch
A    trunk/make/xmail/patches/302-Makefile_lnx.patch
A    trunk/make/xmail/patches/400-CTRLSvr.patch
A    trunk/make/xmail/patches/300-SysMachine.patch
A    trunk/make/xmail/patches/400-POP3Utils.patch
A    trunk/make/xmail/patches/400-CTRLClient.patch
A    trunk/make/xmail/patches/400-SMTPUtils.patch
A    trunk/make/xmail/patches/400-MiscUtils.patch
A    trunk/make/xmail/patches/400-POP3Svr.patch
A    trunk/make/xmail/patches/400-MailSvr.patch
A    trunk/make/xmail/patches/400-SSLMisc.patch
A    trunk/make/xmail/patches/400-SMTPSvr.patch
A    trunk/make/xmail/patches/400-FINGSvr.patch
A    trunk/make/xmail/patches/200-ipv6_MailSvr.patch
A    trunk/make/xmail/Config.in
A    trunk/make/gnutls
A    trunk/make/gnutls/external.in.libs
A    trunk/make/gnutls/Config.in.libs
A    trunk/make/gnutls/Makefile.in
A    trunk/make/gnutls/gnutls.mk
A    trunk/make/gnutls/external.files
A    trunk/make/gnutls/patches
A    trunk/make/gnutls/patches/010-no_docs_tests.patch
A    trunk/make/gnutls/patches/020-pkgconfig_files.patch
A    trunk/make/bind
A    trunk/make/bind/bind.mk
A    trunk/make/bind/files
A    trunk/make/bind/files/.language
A    trunk/make/bind/files/root
A    trunk/make/bind/files/root/usr
A    trunk/make/bind/files/root/usr/lib
A    trunk/make/bind/files/root/usr/lib/cgi-bin
A    trunk/make/bind/files/root/usr/lib/cgi-bin/bind.cgi
A    trunk/make/bind/files/root/etc
A    trunk/make/bind/files/root/etc/default.bind
A    trunk/make/bind/files/root/etc/default.bind/named_conf.def
A    trunk/make/bind/files/root/etc/default.bind/bind.cfg
A    trunk/make/bind/files/root/etc/init.d
A    trunk/make/bind/files/root/etc/init.d/rc.bind
A    trunk/make/bind/files/root/etc/named.conf
A    trunk/make/bind/files/root/etc/rndc.conf
A    trunk/make/bind/files/root/etc/rndc.key
A    trunk/make/bind/external.files
A    trunk/make/bind/external.services
A    trunk/make/bind/external.in
A    trunk/make/bind/patches
A    trunk/make/bind/patches/010-extra_flags.patch
A    trunk/make/bind/Config.in
A    trunk/make/util-linux-ng
A    trunk/make/util-linux-ng/util-linux-ng.mk
A    trunk/make/util-linux-ng/external.files
A    trunk/make/util-linux-ng/external.in
A    trunk/make/util-linux-ng/patches
A    trunk/make/util-linux-ng/patches/110-no-AI_ADDRCONFIG.patch
A    trunk/make/util-linux-ng/patches/100-program_invocation_short_name.patch
A    trunk/make/util-linux-ng/patches/200-reduce_size.patch
A    trunk/make/util-linux-ng/patches/905-blkid_mtdworkaround.patch
A    trunk/make/util-linux-ng/Config.in
A    trunk/make/mod
A    trunk/make/mod/files
A    trunk/make/mod/files/.language
A    trunk/make/mod/files/root
A    trunk/make/mod/files/root/bin
A    trunk/make/mod/files/root/bin/lang
A    trunk/make/mod/files/root/bin/onlinechanged.sh
A    trunk/make/mod/files/root/usr
A    trunk/make/mod/files/root/usr/share
A    trunk/make/mod/files/root/usr/share/style
A    trunk/make/mod/files/root/usr/share/style/colorscheme-colored.css
A    trunk/make/mod/files/root/usr/share/style/common.css
A    trunk/make/mod/files/root/usr/share/style/mod
A    trunk/make/mod/files/root/usr/share/style/mod/mounted.css
A    trunk/make/mod/files/root/usr/share/style/mod/freetz-conf.css
A    trunk/make/mod/files/root/usr/share/style/mod/daemons.css
A    trunk/make/mod/files/root/usr/share/style/legacy
A    trunk/make/mod/files/root/usr/share/style/legacy/base.css
A    trunk/make/mod/files/root/usr/share/style/newfreetz
A    trunk/make/mod/files/root/usr/share/style/newfreetz/base.css
A    trunk/make/mod/files/root/usr/share/style/newfreetz/colorscheme.css
A    trunk/make/mod/files/root/usr/share/style/phoenix
A    trunk/make/mod/files/root/usr/share/style/phoenix/base.css
A    trunk/make/mod/files/root/usr/share/style/colorscheme-grey.css
A    trunk/make/mod/files/root/usr/share/skin
A    trunk/make/mod/files/root/usr/share/skin/legacy
A    trunk/make/mod/files/root/usr/share/skin/legacy/skin.sh
A    trunk/make/mod/files/root/usr/share/skin/newfreetz
A    trunk/make/mod/files/root/usr/share/skin/newfreetz/skin.sh
A    trunk/make/mod/files/root/usr/share/skin/phoenix
A    trunk/make/mod/files/root/usr/share/skin/phoenix/skin.sh
A    trunk/make/mod/files/root/usr/share/images
A    trunk/make/mod/files/root/usr/share/images/legacy
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_l.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_lb.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_lt.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_b.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_r.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_rb.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_t.png
A    trunk/make/mod/files/root/usr/share/images/legacy/edge_rt.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz
A    trunk/make/mod/files/root/usr/share/images/newfreetz/edge-top-left.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/menu-top-left.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/hg_freetz.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/menu-active.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/edge-bot-left.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/title_right.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/edge-top-right.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/menu-top-right.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/freetz_logo.gif
A    trunk/make/mod/files/root/usr/share/images/newfreetz/edge-bot-right.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/edge-top.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/title_1px.png
A    trunk/make/mod/files/root/usr/share/images/newfreetz/title_left.png
A    trunk/make/mod/files/root/usr/share/images/phoenix
A    trunk/make/mod/files/root/usr/share/images/phoenix/dialog-information.png
A    trunk/make/mod/files/root/usr/share/images/phoenix/dialog-warning.png
A    trunk/make/mod/files/root/usr/share/images/phoenix/dialog-error.png
A    trunk/make/mod/files/root/usr/share/about.txt
A    trunk/make/mod/files/root/usr/www
A    trunk/make/mod/files/root/usr/www/cgi-bin
A    trunk/make/mod/files/root/usr/www/cgi-bin/freetz_status
A    trunk/make/mod/files/root/usr/lib
A    trunk/make/mod/files/root/usr/lib/mod
A    trunk/make/mod/files/root/usr/lib/mod/cgi
A    trunk/make/mod/files/root/usr/lib/mod/cgi/help.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/request.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/error.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/validation.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/page.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/stat_bar.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/width.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/links.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/cache.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/form.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/html.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/menu.sh
A    trunk/make/mod/files/root/usr/lib/mod/cgi/skin.sh
A    trunk/make/mod/files/root/usr/lib/mod/menu-update
A    trunk/make/mod/files/root/usr/lib/mod/service.sh
A    trunk/make/mod/files/root/usr/lib/mod/reg-status
A    trunk/make/mod/files/root/usr/lib/libmodcgi.sh
A    trunk/make/mod/files/root/usr/lib/libmodmount.sh
A    trunk/make/mod/files/root/usr/lib/libmodredir.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/do_download_config.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf.webcfg
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf.webcfg/10-webcfg.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/box_info.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/20-swap.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/80-ipv6.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/60-get_ip.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/50-shutdown.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/70-resolv.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/10-cron.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/30-mount.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/40-external.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/logs.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/modlibcgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/info.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/mounted.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod/webcfg.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/mod.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/avm.cgi
A    trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm
A    trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm/30-websrv.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm/10-telnet.sh
A    trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm/20-multid.sh
A    trunk/make/mod/files/root/usr/lib/mww
A    trunk/make/mod/files/root/usr/lib/mww/cgi
A    trunk/make/mod/files/root/usr/lib/mww/cgi/help.sh
A    trunk/make/mod/files/root/usr/lib/mww/cgi/menu-new.sh
A    trunk/make/mod/files/root/usr/lib/mww/cgi/menu.sh
A    trunk/make/mod/files/root/usr/lib/mww/rudi_auth.cgi
A    trunk/make/mod/files/root/usr/lib/mww/do_external_handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/do_update_handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d
A    trunk/make/mod/files/root/usr/lib/mww/page.d/file
A    trunk/make/mod/files/root/usr/lib/mww/page.d/file/save_body.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/file/handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/file/save.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/file/edit_body.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/file/edit.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/service
A    trunk/make/mod/files/root/usr/lib/mww/page.d/service/list_body.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/service/list.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/service/handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/service/save.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/extra
A    trunk/make/mod/files/root/usr/lib/mww/page.d/extra/list.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/extra/handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/status
A    trunk/make/mod/files/root/usr/lib/mww/page.d/status/handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/conf
A    trunk/make/mod/files/root/usr/lib/mww/page.d/conf/save_body.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/conf/handler.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/conf/save.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/conf/edit_body.sh
A    trunk/make/mod/files/root/usr/lib/mww/page.d/conf/edit.sh
A    trunk/make/mod/files/root/usr/bin
A    trunk/make/mod/files/root/usr/bin/modload
A    trunk/make/mod/files/root/usr/bin/wrapper
A    trunk/make/mod/files/root/usr/bin/wrapper/dsld
A    trunk/make/mod/files/root/usr/bin/wrapper/multid
A    trunk/make/mod/files/root/usr/bin/modunreg
A    trunk/make/mod/files/root/usr/bin/modconf
A    trunk/make/mod/files/root/usr/bin/mvi
A    trunk/make/mod/files/root/usr/bin/kernel_args
A    trunk/make/mod/files/root/usr/bin/nvi
A    trunk/make/mod/files/root/usr/bin/webcfg
A    trunk/make/mod/files/root/usr/bin/modsave
A    trunk/make/mod/files/root/usr/bin/modhosts
A    trunk/make/mod/files/root/usr/bin/modpasswd
A    trunk/make/mod/files/root/usr/bin/modusers
A    trunk/make/mod/files/root/usr/bin/wrap_editors
A    trunk/make/mod/files/root/usr/bin/prepare-downgrade
A    trunk/make/mod/files/root/usr/bin/get_ip
A    trunk/make/mod/files/root/usr/bin/websrv
A    trunk/make/mod/files/root/usr/bin/moduninstall
A    trunk/make/mod/files/root/usr/bin/modreg
A    trunk/make/mod/files/root/usr/mww
A    trunk/make/mod/files/root/usr/mww/style
A    trunk/make/mod/files/root/usr/mww/images
A    trunk/make/mod/files/root/usr/mww/cgi-bin
A    trunk/make/mod/files/root/usr/mww/cgi-bin/file
A    trunk/make/mod/files/root/usr/mww/cgi-bin/passwd_edit.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/update
A    trunk/make/mod/files/root/usr/mww/cgi-bin/update/do_firmware.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/update/external.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/update/do_external.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/update/firmware.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status
A    trunk/make/mod/files/root/usr/mww/cgi-bin/avm
A    trunk/make/mod/files/root/usr/mww/cgi-bin/extra
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/system.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/conf
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/passwd_save.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/freetz.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/service
A    trunk/make/mod/files/root/usr/mww/cgi-bin/passwd.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/skin.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/backup
A    trunk/make/mod/files/root/usr/mww/cgi-bin/backup/do_restore.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/backup/do_backup.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/backup/index.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status.d
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/10-box.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/20-memory.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/00-password.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/50-mount.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/cleanup.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/reboot.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/create-swap.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/fw-attrib.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/branding.sh
A    trunk/make/mod/files/root/usr/mww/cgi-bin/shell
A    trunk/make/mod/files/root/usr/mww/cgi-bin/shell/cmd.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/shell/upload.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/shell/index.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/index.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/about.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/support
A    trunk/make/mod/files/root/usr/mww/cgi-bin/support/do_support.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/support/index.cgi
A    trunk/make/mod/files/root/usr/mww/cgi-bin/page.cgi
A    trunk/make/mod/files/root/etc
A    trunk/make/mod/files/root/etc/default.webcfg
A    trunk/make/mod/files/root/etc/default.webcfg/webcfg_conf
A    trunk/make/mod/files/root/etc/profile
A    trunk/make/mod/files/root/etc/default.mod
A    trunk/make/mod/files/root/etc/default.mod/dtrace.def
A    trunk/make/mod/files/root/etc/default.mod/rc_external.def
A    trunk/make/mod/files/root/etc/default.mod/crontab.def
A    trunk/make/mod/files/root/etc/default.mod/modules.def
A    trunk/make/mod/files/root/etc/default.mod/udev_first.def
A    trunk/make/mod/files/root/etc/default.mod/shutdown.def
A    trunk/make/mod/files/root/etc/default.mod/udev_final.def
A    trunk/make/mod/files/root/etc/default.mod/rc_custom.def
A    trunk/make/mod/files/root/etc/default.mod/_profile.def
A    trunk/make/mod/files/root/etc/default.mod/hosts.def
A    trunk/make/mod/files/root/etc/default.mod/mod.cfg
A    trunk/make/mod/files/root/etc/cron.d
A    trunk/make/mod/files/root/etc/cron.d/.gitignore
A    trunk/make/mod/files/root/etc/motd
A    trunk/make/mod/files/root/etc/mtab
A    trunk/make/mod/files/root/etc/services
A    trunk/make/mod/files/root/etc/udev
A    trunk/make/mod/files/root/etc/udev/rules.d
A    trunk/make/mod/files/root/etc/udev/rules.d/00-custom.rules
A    trunk/make/mod/files/root/etc/udev/rules.d/99-custom.rules
A    trunk/make/mod/files/root/etc/inittab.shutdown
A    trunk/make/mod/files/root/etc/device.table
A    trunk/make/mod/files/root/etc/init.d
A    trunk/make/mod/files/root/etc/init.d/rc.ftpd
A    trunk/make/mod/files/root/etc/init.d/rc.webcfg
A    trunk/make/mod/files/root/etc/init.d/rc.multid
A    trunk/make/mod/files/root/etc/init.d/rc.mod
A    trunk/make/mod/files/root/etc/init.d/rc.telnetd
A    trunk/make/mod/files/root/etc/init.d/rc.external
A    trunk/make/mod/files/root/etc/init.d/rc.crond
A    trunk/make/mod/files/root/etc/init.d/rc.smbd
A    trunk/make/mod/files/root/etc/init.d/rc.dsld
A    trunk/make/mod/files/root/etc/init.d/modlibrc
A    trunk/make/mod/files/root/etc/init.d/rc.websrv
A    trunk/make/mod/files/root/etc/init.d/rc.swap
A    trunk/make/mod/files/root/etc/default.avm
A    trunk/make/mod/files/root/etc/default.avm/avm.cfg
A    trunk/make/mod/files/root/etc/modprobe.conf
A    trunk/make/mod/files/root/etc/resolv.conf
A    trunk/make/mod/files/root/sbin
A    trunk/make/mod/files/root/sbin/ar7login
A    trunk/make/mod/files/root/sys
A    trunk/make/mod/files/root/sys/.gitignore
A    trunk/make/mod/mod.mk
A    trunk/make/mod/Config.in
A    trunk/make/inotify-tools
A    trunk/make/inotify-tools/files
A    trunk/make/inotify-tools/files/.language
A    trunk/make/inotify-tools/files/root
A    trunk/make/inotify-tools/files/root/usr
A    trunk/make/inotify-tools/files/root/usr/lib
A    trunk/make/inotify-tools/files/root/usr/lib/cgi-bin
A    trunk/make/inotify-tools/files/root/usr/lib/cgi-bin/inotify-tools
A    trunk/make/inotify-tools/files/root/usr/lib/cgi-bin/inotify-tools/inotify-tools_log.cgi
A    trunk/make/inotify-tools/files/root/usr/lib/cgi-bin/inotify-tools.cgi
A    trunk/make/inotify-tools/files/root/etc
A    trunk/make/inotify-tools/files/root/etc/default.inotify-tools
A    trunk/make/inotify-tools/files/root/etc/default.inotify-tools/inotify-tools.cfg
A    trunk/make/inotify-tools/files/root/etc/init.d
A    trunk/make/inotify-tools/files/root/etc/init.d/rc.inotify-tools
A    trunk/make/inotify-tools/external.files
A    trunk/make/inotify-tools/external.services
A    trunk/make/inotify-tools/inotify-tools.mk
A    trunk/make/inotify-tools/external.in
A    trunk/make/inotify-tools/patches
A    trunk/make/inotify-tools/patches/100-inotifytools-lfs.patch
A    trunk/make/inotify-tools/Config.in
A    trunk/make/fortune
A    trunk/make/fortune/files
A    trunk/make/fortune/files/.language
A    trunk/make/fortune/files/root
A    trunk/make/fortune/files/root/usr
A    trunk/make/fortune/files/root/usr/lib
A    trunk/make/fortune/files/root/usr/lib/cgi-bin
A    trunk/make/fortune/files/root/usr/lib/cgi-bin/fortune.cgi
A    trunk/make/fortune/files/root/usr/bin
A    trunk/make/fortune/files/root/usr/bin/fortune
A    trunk/make/fortune/files/root/etc
A    trunk/make/fortune/files/root/etc/default.fortune
A    trunk/make/fortune/files/root/etc/default.fortune/fortune.cfg
A    trunk/make/fortune/files/root/etc/init.d
A    trunk/make/fortune/files/root/etc/init.d/rc.fortune
A    trunk/make/fortune/patches
A    trunk/make/fortune/patches/100-fortunedir.patch
A    trunk/make/fortune/fortune.mk
A    trunk/make/fortune/Config.in
A    trunk/make/nhipt
A    trunk/make/nhipt/files
A    trunk/make/nhipt/files/root
A    trunk/make/nhipt/files/root/usr
A    trunk/make/nhipt/files/root/usr/lib
A    trunk/make/nhipt/files/root/usr/lib/cgi-bin
A    trunk/make/nhipt/files/root/usr/lib/cgi-bin/nhipt.cgi
A    trunk/make/nhipt/files/root/usr/ipt
A    trunk/make/nhipt/files/root/usr/ipt/cgi-bin
A    trunk/make/nhipt/files/root/usr/ipt/cgi-bin/nhipt.cgi
A    trunk/make/nhipt/files/root/usr/ipt/cgi-bin/index.cgi
A    trunk/make/nhipt/files/root/etc
A    trunk/make/nhipt/files/root/etc/default.nhipt
A    trunk/make/nhipt/files/root/etc/default.nhipt/nhipt.cfg
A    trunk/make/nhipt/files/root/etc/init.d
A    trunk/make/nhipt/files/root/etc/init.d/rc.nhipt
A    trunk/make/nhipt/nhipt.mk
A    trunk/make/nhipt/Config.in
A    trunk/make/usbip
A    trunk/make/usbip/files
A    trunk/make/usbip/files/.language
A    trunk/make/usbip/files/root
A    trunk/make/usbip/files/root/usr
A    trunk/make/usbip/files/root/usr/lib
A    trunk/make/usbip/files/root/usr/lib/cgi-bin
A    trunk/make/usbip/files/root/usr/lib/cgi-bin/usbip.cgi
A    trunk/make/usbip/files/root/etc
A    trunk/make/usbip/files/root/etc/default.usbip
A    trunk/make/usbip/files/root/etc/default.usbip/usbip.cfg
A    trunk/make/usbip/files/root/etc/init.d
A    trunk/make/usbip/files/root/etc/init.d/rc.usbip
A    trunk/make/usbip/external.files
A    trunk/make/usbip/external.services
A    trunk/make/usbip/external.in
A    trunk/make/usbip/patches
A    trunk/make/usbip/patches/101-usbids_file.patch
A    trunk/make/usbip/patches/200-compat_2.6.13.patch
A    trunk/make/usbip/patches/100-cross_compile.patch
A    trunk/make/usbip/usbip.mk
A    trunk/make/usbip/Config.in
A    trunk/make/callmonitor
A    trunk/make/callmonitor/patches
A    trunk/make/callmonitor/callmonitor.mk
A    trunk/make/callmonitor/Config.in
A    trunk/make/samba
A    trunk/make/samba/samba30.mk.in
A    trunk/make/samba/files
A    trunk/make/samba/files/.language
A    trunk/make/samba/files/root
A    trunk/make/samba/files/root/usr
A    trunk/make/samba/files/root/usr/lib
A    trunk/make/samba/files/root/usr/lib/cgi-bin
A    trunk/make/samba/files/root/usr/lib/cgi-bin/samba.cgi
A    trunk/make/samba/files/root/etc
A    trunk/make/samba/files/root/etc/samba_control
A    trunk/make/samba/files/root/etc/init.d
A    trunk/make/samba/files/root/etc/init.d/rc.nmbd
A    trunk/make/samba/files/root/etc/init.d/rc.samba
A    trunk/make/samba/files/root/etc/init.d/rc.smbd
A    trunk/make/samba/files/root/etc/default.samba
A    trunk/make/samba/files/root/etc/default.samba/samba.save
A    trunk/make/samba/files/root/etc/default.samba/samba.cfg
A    trunk/make/samba/files/root/etc/default.samba/shares.def
A    trunk/make/samba/files/root/etc/default.samba/smbd.inetd
A    trunk/make/samba/files/root/etc/default.samba/samba_conf
A    trunk/make/samba/files/root/etc/default.samba/sharesx.def
A    trunk/make/samba/external.files
A    trunk/make/samba/external.services
A    trunk/make/samba/external.in
A    trunk/make/samba/patches
A    trunk/make/samba/patches/3.6.12
A    trunk/make/samba/patches/3.6.12/520-gnu_ld_version.patch
A    trunk/make/samba/patches/3.6.12/260-remove_samr.patch
A    trunk/make/samba/patches/3.6.12/100-configure_getaddrinfo.patch
A    trunk/make/samba/patches/3.6.12/110-multicall.patch
A    trunk/make/samba/patches/3.6.12/240-remove_dfs_api.patch
A    trunk/make/samba/patches/3.6.12/111-build-required-binaries-only.patch
A    trunk/make/samba/patches/3.6.12/250-remove_domain_logon.patch
A    trunk/make/samba/patches/3.6.12/200-remove_printer_support.patch
A    trunk/make/samba/patches/3.6.12/210-remove_ad_support.patch
A    trunk/make/samba/patches/3.6.12/330-librpc_default_print.patch
A    trunk/make/samba/patches/3.6.12/300-assert_debug_level.patch
A    trunk/make/samba/patches/3.6.12/320-debug_level_checks.patch
A    trunk/make/samba/patches/3.6.12/500-extra_FLAGS.patch
A    trunk/make/samba/patches/3.6.12/220-remove_services.patch
A    trunk/make/samba/patches/3.6.12/270-remove_registry_backend.patch
A    trunk/make/samba/patches/3.6.12/290-remove_lsa.patch
A    trunk/make/samba/patches/3.6.12/530-LINUX_LFS_SUPPORT.patch
A    trunk/make/samba/patches/3.6.12/101-config.cache-proper-dl-values.patch
A    trunk/make/samba/patches/3.6.12/230-remove_winreg_support.patch
A    trunk/make/samba/patches/3.6.12/112-avm_smbpasswd.patch
A    trunk/make/samba/patches/3.6.12/540-iconv-hardcoded-charsets.patch
A    trunk/make/samba/patches/3.6.12/280-strip_srvsvc.patch
A    trunk/make/samba/patches/3.6.12/120-add_missing_ifdef.patch
A    trunk/make/samba/patches/3.6.12/510-verbose_compiling.patch.disabled
A    trunk/make/samba/patches/3.6.12/310-remove_error_strings.patch
A    trunk/make/samba/patches/3.6.12/550-no_libresolb.patch
A    trunk/make/samba/patches/3.0.37
A    trunk/make/samba/patches/3.0.37/110-multicall.patch
A    trunk/make/samba/patches/3.0.37/110-samba_avm.patch
A    trunk/make/samba/patches/3.0.37/111-build-required-binaries-only.patch
A    trunk/make/samba/patches/3.0.37/100-skip_configure_tests.patch
A    trunk/make/samba/patches/3.0.37/150-fix_ls.patch
A    trunk/make/samba/patches/3.0.37/300-fix_oplocks_define.patch
A    trunk/make/samba/patches/3.0.37/160-fix_log.patch
A    trunk/make/samba/patches/3.0.37/004-samba-3.0.37-CVE-2012-1182.patch
A    trunk/make/samba/patches/3.0.37/500-extra_FLAGS.patch
A    trunk/make/samba/patches/3.0.37/002-samba-3.0.37-CVE-2010-3069.patch
A    trunk/make/samba/patches/3.0.37/550-no_libresolv.patch
A    trunk/make/samba/patches/3.0.37/530-LINUX_LFS_SUPPORT.patch
A    trunk/make/samba/patches/3.0.37/001-s3-schannel-client-Push-the-domain-and-netbios-name.patch
A    trunk/make/samba/patches/3.0.37/112-avm_smbpasswd.patch
A    trunk/make/samba/patches/3.0.37/003-samba-3.0-CVE-2012-0870-1.patch
A    trunk/make/samba/patches/3.0.37/540-iconv-hardcoded-charsets.patch
A    trunk/make/samba/patches/3.0.37/003-samba-3.0-CVE-2012-0870-2.patch
A    trunk/make/samba/samba36.mk.in
A    trunk/make/samba/samba.mk
A    trunk/make/samba/Config.in
A    trunk/make/davfs2
A    trunk/make/davfs2/files
A    trunk/make/davfs2/files/.language
A    trunk/make/davfs2/files/root
A    trunk/make/davfs2/files/root/usr
A    trunk/make/davfs2/files/root/usr/lib
A    trunk/make/davfs2/files/root/usr/lib/cgi-bin
A    trunk/make/davfs2/files/root/usr/lib/cgi-bin/davfs2.cgi
A    trunk/make/davfs2/files/root/etc
A    trunk/make/davfs2/files/root/etc/davfs2
A    trunk/make/davfs2/files/root/etc/init.d
A    trunk/make/davfs2/files/root/etc/init.d/rc.davfs2
A    trunk/make/davfs2/files/root/etc/default.davfs2
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_0_conf
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt0.def
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_1_conf
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt1.def
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2.cfg
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_2_conf
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt2.def
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_3_conf
A    trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt3.def
A    trunk/make/davfs2/external.files
A    trunk/make/davfs2/external.services
A    trunk/make/davfs2/external.in
A    trunk/make/davfs2/patches
A    trunk/make/davfs2/patches/040-no_user_specific_cache_dir.patch
A    trunk/make/davfs2/patches/060-rpmatch.patch
A    trunk/make/davfs2/patches/030-no_fstab_check.patch
A    trunk/make/davfs2/patches/010-cache_size.patch
A    trunk/make/davfs2/patches/070-no_libintl.patch
A    trunk/make/davfs2/patches/020-canonicalize.patch
A    trunk/make/davfs2/patches/050-reduce_debug_output.patch
A    trunk/make/davfs2/Config.in
A    trunk/make/davfs2/davfs2.mk
A    trunk/make/squid
A    trunk/make/squid/files
A    trunk/make/squid/files/.language
A    trunk/make/squid/files/root
A    trunk/make/squid/files/root/usr
A    trunk/make/squid/files/root/usr/lib
A    trunk/make/squid/files/root/usr/lib/cgi-bin
A    trunk/make/squid/files/root/usr/lib/cgi-bin/squid
A    trunk/make/squid/files/root/usr/lib/cgi-bin/squid/squid_log.cgi
A    trunk/make/squid/files/root/usr/lib/cgi-bin/squid.cgi
A    trunk/make/squid/files/root/etc
A    trunk/make/squid/files/root/etc/init.d
A    trunk/make/squid/files/root/etc/init.d/rc.squid
A    trunk/make/squid/files/root/etc/default.squid
A    trunk/make/squid/files/root/etc/default.squid/squid.cfg
A    trunk/make/squid/files/root/etc/default.squid/squid_conf
A    trunk/make/squid/external.files
A    trunk/make/squid/external.services
A    trunk/make/squid/external.in
A    trunk/make/squid/patches
A    trunk/make/squid/patches/120-x_funs.patch
A    trunk/make/squid/patches/130_configure_cflags.patch
A    trunk/make/squid/patches/005-no_libnsl_no_libresolv.patch
A    trunk/make/squid/patches/110-cross_compile.patch
A    trunk/make/squid/Config.in
A    trunk/make/squid/squid.mk
A    trunk/make/avm-firewall
A    trunk/make/avm-firewall/files
A    trunk/make/avm-firewall/files/.language
A    trunk/make/avm-firewall/files/root
A    trunk/make/avm-firewall/files/root/usr
A    trunk/make/avm-firewall/files/root/usr/share
A    trunk/make/avm-firewall/files/root/usr/share/images
A    trunk/make/avm-firewall/files/root/usr/share/images/reject.gif
A    trunk/make/avm-firewall/files/root/usr/share/images/clone.png
A    trunk/make/avm-firewall/files/root/usr/share/images/deny.gif
A    trunk/make/avm-firewall/files/root/usr/share/images/blink!.gif
A    trunk/make/avm-firewall/files/root/usr/share/images/permit.gif
A    trunk/make/avm-firewall/files/root/usr/share/images/log.gif
A    trunk/make/avm-firewall/files/root/usr/share/images/nat.gif
A    trunk/make/avm-firewall/files/root/usr/share/images/del.png
A    trunk/make/avm-firewall/files/root/usr/share/images/up.png
A    trunk/make/avm-firewall/files/root/usr/share/images/down.png
A    trunk/make/avm-firewall/files/root/usr/lib
A    trunk/make/avm-firewall/files/root/usr/lib/cgi-bin
A    trunk/make/avm-firewall/files/root/usr/lib/cgi-bin/avm-firewall.cgi
A    trunk/make/avm-firewall/files/root/etc
A    trunk/make/avm-firewall/files/root/etc/init.d
A    trunk/make/avm-firewall/files/root/etc/init.d/rc.avm-firewall
A    trunk/make/avm-firewall/files/root/etc/default.avm-firewall
A    trunk/make/avm-firewall/files/root/etc/default.avm-firewall/avm-firewall.save
A    trunk/make/avm-firewall/files/root/etc/default.avm-firewall/avm-firewall.cfg
A    trunk/make/avm-firewall/Config.in
A    trunk/make/avm-firewall/avm-firewall.mk
A    trunk/make/madplay
A    trunk/make/madplay/external.files
A    trunk/make/madplay/external.in
A    trunk/make/madplay/patches
A    trunk/make/madplay/patches/110-libtool_call_missing_tag.patch
A    trunk/make/madplay/patches/100-configure_arch.patch
A    trunk/make/madplay/Config.in
A    trunk/make/madplay/madplay.mk
A    trunk/make/ruby-fcgi
A    trunk/make/ruby-fcgi/files
A    trunk/make/ruby-fcgi/files/root
A    trunk/make/ruby-fcgi/files/root/usr
A    trunk/make/ruby-fcgi/files/root/usr/bin
A    trunk/make/ruby-fcgi/files/root/usr/bin/ruby-cgi
A    trunk/make/ruby-fcgi/files/README
A    trunk/make/ruby-fcgi/Config.in
A    trunk/make/ruby-fcgi/ruby-fcgi.mk
A    trunk/make/dnsd-cgi
A    trunk/make/dnsd-cgi/files
A    trunk/make/dnsd-cgi/files/.language
A    trunk/make/dnsd-cgi/files/root
A    trunk/make/dnsd-cgi/files/root/usr
A    trunk/make/dnsd-cgi/files/root/usr/lib
A    trunk/make/dnsd-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/dnsd-cgi/files/root/usr/lib/cgi-bin/dnsd.cgi
A    trunk/make/dnsd-cgi/files/root/etc
A    trunk/make/dnsd-cgi/files/root/etc/init.d
A    trunk/make/dnsd-cgi/files/root/etc/init.d/rc.dnsd
A    trunk/make/dnsd-cgi/files/root/etc/default.dnsd
A    trunk/make/dnsd-cgi/files/root/etc/default.dnsd/dnsd.cfg
A    trunk/make/dnsd-cgi/files/root/etc/default.dnsd/dnsd_conf.def
A    trunk/make/dnsd-cgi/Config.in
A    trunk/make/dnsd-cgi/dnsd-cgi.mk
A    trunk/make/pyload
A    trunk/make/pyload/files
A    trunk/make/pyload/files/.language
A    trunk/make/pyload/files/root
A    trunk/make/pyload/files/root/opt
A    trunk/make/pyload/files/root/opt/pyLoad
A    trunk/make/pyload/files/root/opt/pyLoad/module
A    trunk/make/pyload/files/root/opt/pyLoad/module/config
A    trunk/make/pyload/files/root/opt/pyLoad/module/config/configdir
A    trunk/make/pyload/files/root/usr
A    trunk/make/pyload/files/root/usr/lib
A    trunk/make/pyload/files/root/usr/lib/cgi-bin
A    trunk/make/pyload/files/root/usr/lib/cgi-bin/pyload.cgi
A    trunk/make/pyload/files/root/usr/mww
A    trunk/make/pyload/files/root/usr/mww/cgi-bin
A    trunk/make/pyload/files/root/usr/mww/cgi-bin/pyload
A    trunk/make/pyload/files/root/etc
A    trunk/make/pyload/files/root/etc/init.d
A    trunk/make/pyload/files/root/etc/init.d/rc.pyload
A    trunk/make/pyload/files/root/etc/default.pyload
A    trunk/make/pyload/files/root/etc/default.pyload/pyload.cfg
A    trunk/make/pyload/external.files
A    trunk/make/pyload/external.services
A    trunk/make/pyload/external.in
A    trunk/make/pyload/patches
A    trunk/make/pyload/patches/020-allow_hyphen_in_configdir.patch
A    trunk/make/pyload/patches/005-fix_typos.patch
A    trunk/make/pyload/patches/010-no_nls.patch
A    trunk/make/pyload/patches/030-no_changedir.patch
A    trunk/make/pyload/Config.in
A    trunk/make/pyload/pyload.mk
A    trunk/make/siproxd
A    trunk/make/siproxd/files
A    trunk/make/siproxd/files/.language
A    trunk/make/siproxd/files/root
A    trunk/make/siproxd/files/root/usr
A    trunk/make/siproxd/files/root/usr/lib
A    trunk/make/siproxd/files/root/usr/lib/cgi-bin
A    trunk/make/siproxd/files/root/usr/lib/cgi-bin/siproxd.cgi
A    trunk/make/siproxd/files/root/etc
A    trunk/make/siproxd/files/root/etc/init.d
A    trunk/make/siproxd/files/root/etc/init.d/rc.siproxd
A    trunk/make/siproxd/files/root/etc/default.siproxd
A    trunk/make/siproxd/files/root/etc/default.siproxd/siproxdpwd_conf.def
A    trunk/make/siproxd/files/root/etc/default.siproxd/siproxd.cfg
A    trunk/make/siproxd/files/root/etc/default.siproxd/siproxdreg_conf.def
A    trunk/make/siproxd/files/root/etc/default.siproxd/siproxd_conf.def
A    trunk/make/siproxd/files/root/etc/onlinechanged
A    trunk/make/siproxd/files/root/etc/onlinechanged/siproxd
A    trunk/make/siproxd/files/README
A    trunk/make/siproxd/external.files
A    trunk/make/siproxd/external.services
A    trunk/make/siproxd/external.in
A    trunk/make/siproxd/patches
A    trunk/make/siproxd/patches/025-reduce_buffer_sizes.patch
A    trunk/make/siproxd/patches/010-no-strict-aliasing.patch
A    trunk/make/siproxd/patches/030-daemonize_as_cmdline_parameter_only.patch
A    trunk/make/siproxd/patches/020-plugin_dir_trailing_slash.patch
A    trunk/make/siproxd/patches/005-no_libresolv.patch
A    trunk/make/siproxd/Config.in
A    trunk/make/siproxd/siproxd.mk
A    trunk/make/ifstat
A    trunk/make/ifstat/ifstat.mk
A    trunk/make/ifstat/external.files
A    trunk/make/ifstat/external.in
A    trunk/make/ifstat/Config.in
A    trunk/make/httpry
A    trunk/make/httpry/httpry.mk
A    trunk/make/httpry/files
A    trunk/make/httpry/files/.language
A    trunk/make/httpry/files/root
A    trunk/make/httpry/files/root/usr
A    trunk/make/httpry/files/root/usr/lib
A    trunk/make/httpry/files/root/usr/lib/cgi-bin
A    trunk/make/httpry/files/root/usr/lib/cgi-bin/httpry
A    trunk/make/httpry/files/root/usr/lib/cgi-bin/httpry/httpry_log.cgi
A    trunk/make/httpry/files/root/usr/lib/cgi-bin/httpry.cgi
A    trunk/make/httpry/files/root/etc
A    trunk/make/httpry/files/root/etc/init.d
A    trunk/make/httpry/files/root/etc/init.d/rc.httpry
A    trunk/make/httpry/files/root/etc/default.httpry
A    trunk/make/httpry/files/root/etc/default.httpry/httpry.cfg
A    trunk/make/httpry/external.files
A    trunk/make/httpry/external.services
A    trunk/make/httpry/external.in
A    trunk/make/httpry/Config.in
A    trunk/make/gocr
A    trunk/make/gocr/gocr.mk
A    trunk/make/gocr/external.files
A    trunk/make/gocr/external.in
A    trunk/make/gocr/patches
A    trunk/make/gocr/patches/01-netpbm_include_path.patch
A    trunk/make/gocr/Config.in
A    trunk/make/dante
A    trunk/make/dante/dante.mk
A    trunk/make/dante/patches
A    trunk/make/dante/patches/017-cppcheck.patch
A    trunk/make/dante/patches/011-linux-eccentricities.patch
A    trunk/make/dante/patches/013-c-warnings.patch
A    trunk/make/dante/patches/130-GNU_SOURCE.patch
A    trunk/make/dante/patches/140-freeifaddrs_AF_NETLINK-fix.patch
A    trunk/make/dante/patches/141-disable-AF_NETLINK.patch
A    trunk/make/dante/patches/003-CFLAGS.patch
A    trunk/make/dante/patches/007-rconnect.patch
A    trunk/make/dante/patches/120-ifaddrs_compat.patch
A    trunk/make/dante/patches/110-cross_compile.patch
A    trunk/make/dante/Config.in
A    trunk/make/gdb
A    trunk/make/gdb/gdb.mk
A    trunk/make/gdb/external.files
A    trunk/make/gdb/external.in
A    trunk/make/gdb/patches
A    trunk/make/gdb/patches/7.3.1
A    trunk/make/gdb/patches/7.3.1/010-no_testsuite.patch
A    trunk/make/gdb/patches/7.3.1/600-fix-compile-flag-mismatch.patch
A    trunk/make/gdb/patches/6.8
A    trunk/make/gdb/patches/6.8/010-no_testsuite.patch
A    trunk/make/gdb/patches/6.8/600-fix-compile-flag-mismatch.patch
A    trunk/make/gdb/Config.in
A    trunk/make/mc
A    trunk/make/mc/external.files
A    trunk/make/mc/mc.mk
A    trunk/make/mc/external.in
A    trunk/make/mc/patches
A    trunk/make/mc/patches/030-bash_inputrc.patch
A    trunk/make/mc/patches/020-noman_nolang.patch
A    trunk/make/mc/patches/040-ash_as_subshell_additional.patch
A    trunk/make/mc/patches/020-nomacro_examples.patch
A    trunk/make/mc/patches/010-rpath.patch
A    trunk/make/mc/patches/015-drop_dependency_on_gmodule.patch
A    trunk/make/mc/patches/005-strverscmp_fix.patch
A    trunk/make/mc/patches/040-ash_as_subshell.patch
A    trunk/make/mc/Config.in
A    trunk/make/iptables-cgi
A    trunk/make/iptables-cgi/files
A    trunk/make/iptables-cgi/files/.language
A    trunk/make/iptables-cgi/files/root
A    trunk/make/iptables-cgi/files/root/usr
A    trunk/make/iptables-cgi/files/root/usr/share
A    trunk/make/iptables-cgi/files/root/usr/share/images
A    trunk/make/iptables-cgi/files/root/usr/share/images/REJECT.gif
A    trunk/make/iptables-cgi/files/root/usr/share/images/ACCEPT.gif
A    trunk/make/iptables-cgi/files/root/usr/share/images/LOG.gif
A    trunk/make/iptables-cgi/files/root/usr/share/images/DROP.gif
A    trunk/make/iptables-cgi/files/root/usr/share/images/MASQUERADE.gif
A    trunk/make/iptables-cgi/files/root/usr/share/images/SPORT.gif
A    trunk/make/iptables-cgi/files/root/usr/share/images/DPORT.gif
A    trunk/make/iptables-cgi/files/root/usr/lib
A    trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables
A    trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables/controller.cgi
A    trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables/editor.cgi
A    trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables.cgi
A    trunk/make/iptables-cgi/files/root/etc
A    trunk/make/iptables-cgi/files/root/etc/init.d
A    trunk/make/iptables-cgi/files/root/etc/init.d/rc.iptables
A    trunk/make/iptables-cgi/files/root/etc/default.iptables
A    trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables.def
A    trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables.save
A    trunk/make/iptables-cgi/files/root/etc/default.iptables/services.def
A    trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables.cfg
A    trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables_services
A    trunk/make/iptables-cgi/files/iptables_services
A    trunk/make/iptables-cgi/files/README
A    trunk/make/iptables-cgi/iptables-cgi.mk
A    trunk/make/iptables-cgi/Config.in
A    trunk/make/dtmfbox-cgi
A    trunk/make/dtmfbox-cgi/files
A    trunk/make/dtmfbox-cgi/files/root
A    trunk/make/dtmfbox-cgi/files/root/usr
A    trunk/make/dtmfbox-cgi/files/root/usr/bin
A    trunk/make/dtmfbox-cgi/files/root/usr/bin/webcfg-dtmfbox-cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/dtmfbox.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_cfg.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_cmd.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_status.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_main.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_webphone.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_help.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_scriptedit.cgi
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/dtmfbox_style.css
A    trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/index.html
A    trunk/make/dtmfbox-cgi/files/root/etc
A    trunk/make/dtmfbox-cgi/files/root/etc/init.d
A    trunk/make/dtmfbox-cgi/files/root/etc/init.d/rc.dtmfbox-cgi
A    trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi
A    trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi/dtmfbox-cgi.cfg
A    trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi/dtmfbox-cgi.inetd
A    trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi/httpd-dtmfbox-cgi_conf
A    trunk/make/dtmfbox-cgi/dtmfbox-cgi.mk
A    trunk/make/dtmfbox-cgi/Config.in
A    trunk/make/tesseract-eng
A    trunk/make/tesseract-eng/tesseract-eng.mk
A    trunk/make/fstyp
A    trunk/make/fstyp/patches
A    trunk/make/fstyp/patches/400-update_config_sub.patch
A    trunk/make/fstyp/patches/300-ext3.patch
A    trunk/make/fstyp/patches/200-fat_pattern.patch
A    trunk/make/fstyp/patches/500-squashfs_jffs2_pattern.patch
A    trunk/make/fstyp/patches/600-unknown_filesystem.patch
A    trunk/make/fstyp/patches/350-ext4.patch
A    trunk/make/fstyp/patches/100-includedir.patch
A    trunk/make/fstyp/Config.in
A    trunk/make/fstyp/fstyp.mk
A    trunk/make/hd-idle
A    trunk/make/hd-idle/files
A    trunk/make/hd-idle/files/.language
A    trunk/make/hd-idle/files/root
A    trunk/make/hd-idle/files/root/usr
A    trunk/make/hd-idle/files/root/usr/lib
A    trunk/make/hd-idle/files/root/usr/lib/cgi-bin
A    trunk/make/hd-idle/files/root/usr/lib/cgi-bin/hd-idle.cgi
A    trunk/make/hd-idle/files/root/etc
A    trunk/make/hd-idle/files/root/etc/init.d
A    trunk/make/hd-idle/files/root/etc/init.d/rc.hd-idle
A    trunk/make/hd-idle/files/root/etc/default.hd-idle
A    trunk/make/hd-idle/files/root/etc/default.hd-idle/hd-idle.cfg
A    trunk/make/hd-idle/patches
A    trunk/make/hd-idle/patches/100-unnecessary_include.patch
A    trunk/make/hd-idle/Config.in
A    trunk/make/hd-idle/hd-idle.mk
A    trunk/make/espeak
A    trunk/make/espeak/files
A    trunk/make/espeak/files/root
A    trunk/make/espeak/files/root/usr
A    trunk/make/espeak/files/root/usr/share
A    trunk/make/espeak/files/root/usr/share/espeak-data
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/default
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/croak
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m3
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m4
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m5
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/whisper
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m6
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f1
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f2
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f3
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f4
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/fast
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m1
A    trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m2
A    trunk/make/espeak/files/root/usr/share/espeak-data/de_dict
A    trunk/make/espeak/files/root/usr/share/espeak-data/phontab
A    trunk/make/espeak/files/root/usr/share/espeak-data/phonindex
A    trunk/make/espeak/files/root/usr/share/espeak-data/phondata
A    trunk/make/espeak/external.files
A    trunk/make/espeak/external.in
A    trunk/make/espeak/patches
A    trunk/make/espeak/patches/100-mipsel.patch
A    trunk/make/espeak/Config.in
A    trunk/make/espeak/espeak.mk
A    trunk/make/jamvm
A    trunk/make/jamvm/jamvm.mk
A    trunk/make/jamvm/external.files
A    trunk/make/jamvm/external.in
A    trunk/make/jamvm/patches
A    trunk/make/jamvm/patches/010-allow_mips.patch
A    trunk/make/jamvm/patches/001-heap_size.patch
A    trunk/make/jamvm/Config.in
A    trunk/make/Config.in
A    trunk/make/streamripper
A    trunk/make/streamripper/files
A    trunk/make/streamripper/files/.language
A    trunk/make/streamripper/files/root
A    trunk/make/streamripper/files/root/usr
A    trunk/make/streamripper/files/root/usr/lib
A    trunk/make/streamripper/files/root/usr/lib/cgi-bin
A    trunk/make/streamripper/files/root/usr/lib/cgi-bin/streamripper
A    trunk/make/streamripper/files/root/usr/lib/cgi-bin/streamripper/log.cgi
A    trunk/make/streamripper/files/root/usr/lib/cgi-bin/streamripper.cgi
A    trunk/make/streamripper/files/root/etc
A    trunk/make/streamripper/files/root/etc/default.streamripper
A    trunk/make/streamripper/files/root/etc/default.streamripper/filter.def
A    trunk/make/streamripper/files/root/etc/default.streamripper/streamripper.cfg
A    trunk/make/streamripper/files/root/etc/init.d
A    trunk/make/streamripper/files/root/etc/init.d/rc.streamripper
A    trunk/make/streamripper/external.files
A    trunk/make/streamripper/streamripper.mk
A    trunk/make/streamripper/external.services
A    trunk/make/streamripper/external.in
A    trunk/make/streamripper/patches
A    trunk/make/streamripper/patches/200-prototypes.patch
A    trunk/make/streamripper/patches/100-cross_compile.patch
A    trunk/make/streamripper/Config.in
A    trunk/make/sundtek
A    trunk/make/sundtek/files
A    trunk/make/sundtek/files/.language
A    trunk/make/sundtek/files/root
A    trunk/make/sundtek/files/root/usr
A    trunk/make/sundtek/files/root/usr/lib
A    trunk/make/sundtek/files/root/usr/lib/cgi-bin
A    trunk/make/sundtek/files/root/usr/lib/cgi-bin/sundtek.cgi
A    trunk/make/sundtek/files/root/etc
A    trunk/make/sundtek/files/root/etc/default.sundtek
A    trunk/make/sundtek/files/root/etc/default.sundtek/sundtek.cfg
A    trunk/make/sundtek/files/root/etc/init.d
A    trunk/make/sundtek/files/root/etc/init.d/rc.sundtek
A    trunk/make/sundtek/sundtek.mk
A    trunk/make/sundtek/Config.in
A    trunk/make/lighttpd
A    trunk/make/lighttpd/files
A    trunk/make/lighttpd/files/.language
A    trunk/make/lighttpd/files/root
A    trunk/make/lighttpd/files/root/usr
A    trunk/make/lighttpd/files/root/usr/lib
A    trunk/make/lighttpd/files/root/usr/lib/cgi-bin
A    trunk/make/lighttpd/files/root/usr/lib/cgi-bin/lighttpd
A    trunk/make/lighttpd/files/root/usr/lib/cgi-bin/lighttpd/lighttpd-log.cgi
A    trunk/make/lighttpd/files/root/usr/lib/cgi-bin/lighttpd.cgi
A    trunk/make/lighttpd/files/root/usr/bin
A    trunk/make/lighttpd/files/root/usr/bin/lighttpd_usersave
A    trunk/make/lighttpd/files/root/etc
A    trunk/make/lighttpd/files/root/etc/default.lighttpd
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_ca.def
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_add.def
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_conf
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_crt.def
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_user.def
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_rights.def
A    trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd.cfg
A    trunk/make/lighttpd/files/root/etc/init.d
A    trunk/make/lighttpd/files/root/etc/init.d/rc.lighttpd
A    trunk/make/lighttpd/files/README
A    trunk/make/lighttpd/external.files
A    trunk/make/lighttpd/external.services
A    trunk/make/lighttpd/lighttpd.mk
A    trunk/make/lighttpd/external.in
A    trunk/make/lighttpd/patches
A    trunk/make/lighttpd/patches/020-missing_includes__missing_wrong_ifdefs.patch
A    trunk/make/lighttpd/patches/015-proper-ERR_error_string_usage.patch
A    trunk/make/lighttpd/patches/200-openssl-alternative.patch
A    trunk/make/lighttpd/patches/010-uuid_pic.patch
A    trunk/make/lighttpd/patches/300-pthread_main_binary.patch
A    trunk/make/lighttpd/Config.in
A    trunk/make/screen
A    trunk/make/screen/files
A    trunk/make/screen/files/root
A    trunk/make/screen/files/root/usr
A    trunk/make/screen/files/root/usr/bin
A    trunk/make/screen/files/root/usr/bin/screen
A    trunk/make/screen/files/README
A    trunk/make/screen/external.files
A    trunk/make/screen/screen.mk
A    trunk/make/screen/external.in
A    trunk/make/screen/patches
A    trunk/make/screen/patches/100-cross_compile_fix.patch
A    trunk/make/screen/patches/102-encoding.c.patch
A    trunk/make/screen/Config.in
A    trunk/make/vnstat-cgi
A    trunk/make/vnstat-cgi/files
A    trunk/make/vnstat-cgi/files/.language
A    trunk/make/vnstat-cgi/files/root
A    trunk/make/vnstat-cgi/files/root/usr
A    trunk/make/vnstat-cgi/files/root/usr/lib
A    trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat
A    trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat/stats.cgi
A    trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat/index.cgi
A    trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat.cgi
A    trunk/make/vnstat-cgi/files/root/usr/bin
A    trunk/make/vnstat-cgi/files/root/usr/bin/webcfg-vns
A    trunk/make/vnstat-cgi/files/root/usr/mww
A    trunk/make/vnstat-cgi/files/root/usr/mww/vnspix
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns/style
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns/images
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns/vnspix
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns/cgi-bin
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns/cgi-bin/index.cgi
A    trunk/make/vnstat-cgi/files/root/usr/mww-vns/favicon.ico
A    trunk/make/vnstat-cgi/files/root/etc
A    trunk/make/vnstat-cgi/files/root/etc/default.vnstat
A    trunk/make/vnstat-cgi/files/root/etc/default.vnstat/vnstat_conf.def
A    trunk/make/vnstat-cgi/files/root/etc/default.vnstat/webcfg-vns.inetd
A    trunk/make/vnstat-cgi/files/root/etc/default.vnstat/httpd-vns_conf
A    trunk/make/vnstat-cgi/files/root/etc/default.vnstat/vnstat.cfg
A    trunk/make/vnstat-cgi/files/root/etc/init.d
A    trunk/make/vnstat-cgi/files/root/etc/init.d/rc.vnstat
A    trunk/make/vnstat-cgi/external.services
A    trunk/make/vnstat-cgi/vnstat-cgi.mk
A    trunk/make/vnstat-cgi/Config.in
A    trunk/make/nagios
A    trunk/make/nagios/files
A    trunk/make/nagios/files/root
A    trunk/make/nagios/files/root/etc
A    trunk/make/nagios/files/root/etc/default.nagios
A    trunk/make/nagios/files/root/etc/default.nagios/commands.cfg
A    trunk/make/nagios/files/root/etc/default.nagios/cgi.cfg
A    trunk/make/nagios/files/root/etc/default.nagios/resource.cfg
A    trunk/make/nagios/files/root/etc/default.nagios/localhost.cfg
A    trunk/make/nagios/files/root/etc/default.nagios/nagios.cfg
A    trunk/make/nagios/nagios.mk
A    trunk/make/nagios/Config.in
A    trunk/make/python
A    trunk/make/python/external.in.libs
A    trunk/make/python/python-module-macros.mk.in
A    trunk/make/python/Config.in.libs
A    trunk/make/python/files
A    trunk/make/python/files/root
A    trunk/make/python/files/root/usr
A    trunk/make/python/files/root/usr/bin
A    trunk/make/python/files/root/usr/bin/python2.7
A    trunk/make/python/external.files
A    trunk/make/python/patches
A    trunk/make/python/patches/040-dont-import-cross-compiled-modules.openwrt.patch
A    trunk/make/python/patches/330-compileall-hostpython.patch
A    trunk/make/python/patches/350-readline-termcap.patch
A    trunk/make/python/patches/320-regen.patch
A    trunk/make/python/patches/080-distutils-dont_adjust_files.openwrt.patch
A    trunk/make/python/patches/110-zlib-as-builtin-module.openwrt.patch
A    trunk/make/python/patches/150-no-sqlite-rpath.openwrt.patch
A    trunk/make/python/patches/370-no-libdb-rpath.freetz.patch
A    trunk/make/python/patches/030-fixup-include-dirs.openwrt.patch
A    trunk/make/python/patches/000-cross-compile.openwrt.patch
A    trunk/make/python/patches/140-verbose-sharedmods.openwrt.patch
A    trunk/make/python/patches/310-disable_epoll.freetz.patch
A    trunk/make/python/patches/360-detect_modules-CROSS_TOOLCHAIN_SYSROOT.freetz.patch
A    trunk/make/python/patches/130-readline-setup.openwrt.patch
A    trunk/make/python/patches/300-dlopen_DYNLOADFILE_fix.freetz.patch
A    trunk/make/python/python.mk
A    trunk/make/python/python-filelists.mk.in
A    trunk/make/Makefile.in
A    trunk/make/checkmaild
A    trunk/make/checkmaild/files
A    trunk/make/checkmaild/files/.language
A    trunk/make/checkmaild/files/root
A    trunk/make/checkmaild/files/root/usr
A    trunk/make/checkmaild/files/root/usr/lib
A    trunk/make/checkmaild/files/root/usr/lib/cgi-bin
A    trunk/make/checkmaild/files/root/usr/lib/cgi-bin/checkmaild.cgi
A    trunk/make/checkmaild/files/root/etc
A    trunk/make/checkmaild/files/root/etc/init.d
A    trunk/make/checkmaild/files/root/etc/init.d/rc.checkmaild
A    trunk/make/checkmaild/files/root/etc/default.checkmaild
A    trunk/make/checkmaild/files/root/etc/default.checkmaild/mailactions.def
A    trunk/make/checkmaild/files/root/etc/default.checkmaild/checkmaild.cfg
A    trunk/make/checkmaild/files/root/etc/default.checkmaild/mailactions-phone.example
A    trunk/make/checkmaild/files/root/etc/default.checkmaild/mailactions.default
A    trunk/make/checkmaild/files/root/etc/default.checkmaild/checkmaild_conf
A    trunk/make/checkmaild/external.files
A    trunk/make/checkmaild/external.services
A    trunk/make/checkmaild/external.in
A    trunk/make/checkmaild/Config.in
A    trunk/make/checkmaild/checkmaild.mk
A    trunk/make/netpbm
A    trunk/make/netpbm/external.in.libs
A    trunk/make/netpbm/Config.in.libs
A    trunk/make/netpbm/external.files
A    trunk/make/netpbm/patches
A    trunk/make/netpbm/patches/00-no_xml2-config_libpng-config_calls.patch
A    trunk/make/netpbm/patches/01-Makefile.config.patch
A    trunk/make/netpbm/netpbm.mk
A    trunk/make/openvpn
A    trunk/make/openvpn/files
A    trunk/make/openvpn/files/.language
A    trunk/make/openvpn/files/root
A    trunk/make/openvpn/files/root/usr
A    trunk/make/openvpn/files/root/usr/lib
A    trunk/make/openvpn/files/root/usr/lib/cgi-bin
A    trunk/make/openvpn/files/root/usr/lib/cgi-bin/openvpn
A    trunk/make/openvpn/files/root/usr/lib/cgi-bin/openvpn/openvpn_clients.cgi
A    trunk/make/openvpn/files/root/usr/lib/cgi-bin/openvpn.cgi
A    trunk/make/openvpn/files/root/etc
A    trunk/make/openvpn/files/root/etc/init.d
A    trunk/make/openvpn/files/root/etc/init.d/rc.openvpn
A    trunk/make/openvpn/files/root/etc/default.openvpn
A    trunk/make/openvpn/files/root/etc/default.openvpn/openvpn.save
A    trunk/make/openvpn/files/root/etc/default.openvpn/openvpn.cfg
A    trunk/make/openvpn/files/root/etc/default.openvpn/ca_crt.def
A    trunk/make/openvpn/files/root/etc/default.openvpn/dh_pem.def
A    trunk/make/openvpn/files/root/etc/default.openvpn/openvpn_conf
A    trunk/make/openvpn/files/root/etc/default.openvpn/static_key.def
A    trunk/make/openvpn/files/root/etc/default.openvpn/box_crt.def
A    trunk/make/openvpn/files/root/etc/default.openvpn/box_key.def
A    trunk/make/openvpn/files/root/etc/default.openvpn/crl_pem.def
A    trunk/make/openvpn/files/root/etc/default.openvpn/openvpn_dynamic_conf
A    trunk/make/openvpn/files/README
A    trunk/make/openvpn/external.files
A    trunk/make/openvpn/external.services
A    trunk/make/openvpn/external.in
A    trunk/make/openvpn/patches
A    trunk/make/openvpn/patches/2.3.0
A    trunk/make/openvpn/patches/2.3.0/010-tcp_disconnect_fix.upstream.patch
A    trunk/make/openvpn/patches/2.3.0/200-no_in6addr_any_in_libc_without_IPv6_fix.patch
A    trunk/make/openvpn/patches/2.3.0/220-polarssl-1.2.x-support.patch
A    trunk/make/openvpn/patches/2.3.0/210-disable_epoll_poll_use_select.patch
A    trunk/make/openvpn/patches/2.2.2
A    trunk/make/openvpn/patches/2.2.2/200-no_in6addr_any_in_libc_without_IPv6_fix.patch
A    trunk/make/openvpn/patches/2.2.2/101-ipv6_payload_support.patch
A    trunk/make/openvpn/patches/2.2.2/100-ipv6_support.patch
A    trunk/make/openvpn/patches/2.2.2/210-disable_epoll_poll_use_select.patch
A    trunk/make/openvpn/Config.in
A    trunk/make/openvpn/openvpn.mk
A    trunk/make/tinyproxy
A    trunk/make/tinyproxy/files
A    trunk/make/tinyproxy/files/.language
A    trunk/make/tinyproxy/files/root
A    trunk/make/tinyproxy/files/root/usr
A    trunk/make/tinyproxy/files/root/usr/mww_tinyproxy
A    trunk/make/tinyproxy/files/root/usr/mww_tinyproxy/cgi-bin
A    trunk/make/tinyproxy/files/root/usr/mww_tinyproxy/cgi-bin/proxy.cgi
A    trunk/make/tinyproxy/files/root/usr/lib
A    trunk/make/tinyproxy/files/root/usr/lib/cgi-bin
A    trunk/make/tinyproxy/files/root/usr/lib/cgi-bin/tinyproxy.cgi
A    trunk/make/tinyproxy/files/root/etc
A    trunk/make/tinyproxy/files/root/etc/init.d
A    trunk/make/tinyproxy/files/root/etc/init.d/rc.tinyproxy
A    trunk/make/tinyproxy/files/root/etc/default.tinyproxy
A    trunk/make/tinyproxy/files/root/etc/default.tinyproxy/tinyproxy.cfg
A    trunk/make/tinyproxy/files/root/etc/default.tinyproxy/tinyproxy_conf
A    trunk/make/tinyproxy/files/README
A    trunk/make/tinyproxy/external.files
A    trunk/make/tinyproxy/external.services
A    trunk/make/tinyproxy/external.in
A    trunk/make/tinyproxy/patches
A    trunk/make/tinyproxy/patches/130-fix_tmp_to_var_tmp.patch
A    trunk/make/tinyproxy/patches/120-fix_INET6.patch
A    trunk/make/tinyproxy/patches/020-config_and_pid-path.patch
A    trunk/make/tinyproxy/patches/030-no_libnsl_no_libresolv.patch
A    trunk/make/tinyproxy/patches/010-no-docs-and-tests.patch
A    trunk/make/tinyproxy/Config.in
A    trunk/make/tinyproxy/tinyproxy.mk
A    trunk/make/dvbstream
A    trunk/make/dvbstream/patches
A    trunk/make/dvbstream/patches/10-Makefile.patch
A    trunk/make/dvbstream/Config.in
A    trunk/make/dvbstream/dvbstream.mk
A    trunk/make/unrar
A    trunk/make/unrar/external.files
A    trunk/make/unrar/external.in
A    trunk/make/unrar/patches
A    trunk/make/unrar/patches/01-disable_exceptions.patch
A    trunk/make/unrar/patches/02-disable_strip.patch
A    trunk/make/unrar/Config.in
A    trunk/make/unrar/unrar.mk
A    trunk/make/irssi
A    trunk/make/irssi/irssi.mk
A    trunk/make/irssi/external.files
A    trunk/make/irssi/external.in
A    trunk/make/irssi/Config.in
A    trunk/make/iputils
A    trunk/make/iputils/iputils.mk
A    trunk/make/iputils/Config.in
A    trunk/make/spawn-fcgi
A    trunk/make/spawn-fcgi/external.files
A    trunk/make/spawn-fcgi/spawn-fcgi.mk
A    trunk/make/spawn-fcgi/external.in
A    trunk/make/spawn-fcgi/Config.in
A    trunk/make/synce-serial
A    trunk/make/synce-serial/synce-serial.mk
A    trunk/make/synce-serial/patches
A    trunk/make/synce-serial/patches/100-scripts_location.patch
A    trunk/make/synce-serial/Config.in
A    trunk/make/unfs3
A    trunk/make/unfs3/files
A    trunk/make/unfs3/files/.language
A    trunk/make/unfs3/files/root
A    trunk/make/unfs3/files/root/usr
A    trunk/make/unfs3/files/root/usr/lib
A    trunk/make/unfs3/files/root/usr/lib/cgi-bin
A    trunk/make/unfs3/files/root/usr/lib/cgi-bin/unfs3.cgi
A    trunk/make/unfs3/files/root/etc
A    trunk/make/unfs3/files/root/etc/default.unfs3
A    trunk/make/unfs3/files/root/etc/default.unfs3/exports.def
A    trunk/make/unfs3/files/root/etc/default.unfs3/hosts_allow.def
A    trunk/make/unfs3/files/root/etc/default.unfs3/hosts_deny.def
A    trunk/make/unfs3/files/root/etc/default.unfs3/unfs3.cfg
A    trunk/make/unfs3/files/root/etc/init.d
A    trunk/make/unfs3/files/root/etc/init.d/rc.unfs3
A    trunk/make/unfs3/files/root/etc/hosts.allow
A    trunk/make/unfs3/files/root/etc/hosts.deny
A    trunk/make/unfs3/unfs3.mk
A    trunk/make/unfs3/patches
A    trunk/make/unfs3/patches/100-noyywrap.patch
A    trunk/make/unfs3/Config.in
A    trunk/make/nano-shell
A    trunk/make/nano-shell/files
A    trunk/make/nano-shell/files/root
A    trunk/make/nano-shell/files/root/usr
A    trunk/make/nano-shell/files/root/usr/www
A    trunk/make/nano-shell/files/root/usr/www/all
A    trunk/make/nano-shell/files/root/usr/www/all/cgi-bin
A    trunk/make/nano-shell/files/root/usr/www/all/cgi-bin/shell.cgi
A    trunk/make/nano-shell/files/root/usr/bin
A    trunk/make/nano-shell/files/root/usr/bin/shell.cgi
A    trunk/make/nano-shell/files/root/usr/mww
A    trunk/make/nano-shell/files/root/usr/mww/cgi-bin
A    trunk/make/nano-shell/files/root/usr/mww/cgi-bin/shell.cgi
A    trunk/make/nano-shell/files/README
A    trunk/make/nano-shell/nano-shell.mk
A    trunk/make/nano-shell/Config.in
A    trunk/make/ccid
A    trunk/make/ccid/ccid.mk
A    trunk/make/ccid/Config.in
A    trunk/make/fuse
A    trunk/make/fuse/external.in.libs
A    trunk/make/fuse/Config.in.libs
A    trunk/make/fuse/external.files
A    trunk/make/fuse/patches
A    trunk/make/fuse/patches/140-no_bb_mount.patch
A    trunk/make/fuse/patches/102-no_depmod.patch
A    trunk/make/fuse/patches/112-no_break_on_mknod.patch
A    trunk/make/fuse/fuse.mk
A    trunk/make/netatalk
A    trunk/make/netatalk/files
A    trunk/make/netatalk/files/.language
A    trunk/make/netatalk/files/root
A    trunk/make/netatalk/files/root/usr
A    trunk/make/netatalk/files/root/usr/lib
A    trunk/make/netatalk/files/root/usr/lib/cgi-bin
A    trunk/make/netatalk/files/root/usr/lib/cgi-bin/netatalk.cgi
A    trunk/make/netatalk/files/root/etc
A    trunk/make/netatalk/files/root/etc/init.d
A    trunk/make/netatalk/files/root/etc/init.d/rc.netatalk
A    trunk/make/netatalk/files/root/etc/init.d/rc.cnid_metad
A    trunk/make/netatalk/files/root/etc/init.d/rc.afpd
A    trunk/make/netatalk/files/root/etc/default.netatalk
A    trunk/make/netatalk/files/root/etc/default.netatalk/netatalk.cfg
A    trunk/make/netatalk/files/root/etc/default.netatalk/afpd_conf_conf
A    trunk/make/netatalk/files/root/etc/default.netatalk/applevolumes_default_conf
A    trunk/make/netatalk/files/root/etc/default.netatalk/afpd_conf.def
A    trunk/make/netatalk/files/root/etc/default.netatalk/applevolumes_default.def
A    trunk/make/netatalk/external.files
A    trunk/make/netatalk/external.services
A    trunk/make/netatalk/external.in
A    trunk/make/netatalk/patches
A    trunk/make/netatalk/patches/010-AI_NUMERICSERV.patch
A    trunk/make/netatalk/patches/030-configure_no_export.patch
A    trunk/make/netatalk/netatalk.mk
A    trunk/make/netatalk/Config.in
A    trunk/make/iptables/patches
A    trunk/make/iptables/patches/006-iprange-typesh.patch
A    trunk/make/iptables/patches/007_add_IPT_ALIGN.patch
A    trunk/make/iptables/patches/010_no_ipv6_if_disabled.patch
A    trunk/make/iptables/patches/004-multiport_v1.patch
A    trunk/make/iptables/patches/2.6.13.1
A    trunk/make/iptables/patches/009_switch_XML_SAVE_RESTORE.patch
A    trunk/make/iptables/patches/001-ipp2p-0.8.2.patch
A    trunk/make/iptables/patches/008_fix_exit_error.patch
A    trunk/make/iptables/patches/2.6.19.2
A    trunk/make/iptables/patches/2.6.19.2/define_PROC_SUPER_MAGIC.patch
A    trunk/make/iptables/patches/2.6.19.2/layer7_2.19.patch
A    trunk/make/iptables/patches/2.6.28
A    trunk/make/iptables/patches/2.6.28/layer7_2.22.patch
A    trunk/make/iptables/iptables.mk
A    trunk/make/iptables/Config.in
A    trunk/make/iptables/standard-modules.in
A    trunk/make/inetd
A    trunk/make/inetd/files
A    trunk/make/inetd/files/.language
A    trunk/make/inetd/files/root
A    trunk/make/inetd/files/root/bin
A    trunk/make/inetd/files/root/bin/inetdctl
A    trunk/make/inetd/files/root/bin/inetdsamba
A    trunk/make/inetd/files/root/bin/inetdftp
A    trunk/make/inetd/files/root/usr
A    trunk/make/inetd/files/root/usr/lib
A    trunk/make/inetd/files/root/usr/lib/cgi-bin
A    trunk/make/inetd/files/root/usr/lib/cgi-bin/inetd.cgi
A    trunk/make/inetd/files/root/etc
A    trunk/make/inetd/files/root/etc/default.ftpd
A    trunk/make/inetd/files/root/etc/default.ftpd/ftpd.inetd
A    trunk/make/inetd/files/root/etc/default.webcfg
A    trunk/make/inetd/files/root/etc/default.webcfg/webcfg.inetd
A    trunk/make/inetd/files/root/etc/default.telnetd
A    trunk/make/inetd/files/root/etc/default.telnetd/telnetd.inetd
A    trunk/make/inetd/files/root/etc/init.d
A    trunk/make/inetd/files/root/etc/init.d/rc.inetd
A    trunk/make/inetd/files/root/etc/init.d/modlibinetd
A    trunk/make/inetd/files/root/etc/default.inetd
A    trunk/make/inetd/files/root/etc/default.inetd/inetd.save
A    trunk/make/inetd/files/root/etc/default.inetd/inetd.cfg
A    trunk/make/inetd/files/root/etc/default.inetd/inetd_conf.def
A    trunk/make/inetd/files/root/etc/default.inetd/inetd_user.def
A    trunk/make/inetd/files/root/etc/inetd.conf
A    trunk/make/inetd/files/root/etc/default.smbd
A    trunk/make/inetd/files/root/etc/default.smbd/smbd-139.inetd
A    trunk/make/inetd/files/root/etc/default.smbd/smbd-445.inetd
A    trunk/make/inetd/files/root/etc/default.websrv
A    trunk/make/inetd/files/root/etc/default.websrv/websrv.inetd
A    trunk/make/inetd/inetd.mk
A    trunk/make/inetd/Config.in
A    trunk/make/apache2
A    trunk/make/apache2/external.files
A    trunk/make/apache2/external.in
A    trunk/make/apache2/patches
A    trunk/make/apache2/patches/040-always-check-for-openssl.patch
A    trunk/make/apache2/patches/030-apr-util-check.patch
A    trunk/make/apache2/patches/100-hostmake.patch
A    trunk/make/apache2/patches/200-apxs-cross-compile-hacks.patch
A    trunk/make/apache2/apache2.mk
A    trunk/make/apache2/Config.in
A    trunk/make/dtmfbox/files
A    trunk/make/dtmfbox/files/root
A    trunk/make/dtmfbox/files/root/etc
A    trunk/make/dtmfbox/files/root/etc/init.d
A    trunk/make/dtmfbox/files/root/etc/init.d/rc.dtmfbox
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg/dtmfbox.cfg
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg/menu.cfg
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg/script.cfg
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_cbct.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_reverse.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/espeak.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_radio.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_weather.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/callthrough.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/am_setup.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/funcs.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_anticallcenter.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_ctrl5.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_am.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/am_funcs.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_checkmaild.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_fb.sh
A    trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/am_admin.sh
A    trunk/make/dtmfbox/files/README
A    trunk/make/dtmfbox/external.files
A    trunk/make/dtmfbox/external.in
A    trunk/make/dtmfbox/patches
A    trunk/make/dtmfbox/patches/020-check_for_null_ptr.patch
A    trunk/make/dtmfbox/patches/060-extra_flags.patch
A    trunk/make/dtmfbox/patches/010-no_host_paths.patch
A    trunk/make/dtmfbox/patches/030-plugin_execute_cmd-fixes.patch
A    trunk/make/dtmfbox/dtmfbox.mk
A    trunk/make/dtmfbox/Config.in
A    trunk/make/quagga
A    trunk/make/quagga/files
A    trunk/make/quagga/files/.language
A    trunk/make/quagga/files/root
A    trunk/make/quagga/files/root/usr
A    trunk/make/quagga/files/root/usr/lib
A    trunk/make/quagga/files/root/usr/lib/cgi-bin
A    trunk/make/quagga/files/root/usr/lib/cgi-bin/quagga.cgi
A    trunk/make/quagga/files/root/etc
A    trunk/make/quagga/files/root/etc/init.d
A    trunk/make/quagga/files/root/etc/init.d/quagga
A    trunk/make/quagga/files/root/etc/init.d/rc.quagga
A    trunk/make/quagga/files/root/etc/default.quagga
A    trunk/make/quagga/files/root/etc/default.quagga/ripd_conf.def
A    trunk/make/quagga/files/root/etc/default.quagga/ospf6d_conf.def
A    trunk/make/quagga/files/root/etc/default.quagga/quagga.cfg
A    trunk/make/quagga/files/root/etc/default.quagga/ripngd_conf.def
A    trunk/make/quagga/files/root/etc/default.quagga/zebra_conf.def
A    trunk/make/quagga/files/root/etc/default.quagga/isisd_conf.def
A    trunk/make/quagga/files/root/etc/default.quagga/ospfd_conf.def
A    trunk/make/quagga/files/root/etc/default.quagga/bgpd_conf.def
A    trunk/make/quagga/files/README
A    trunk/make/quagga/patches
A    trunk/make/quagga/patches/011-fix-cpp.patch
A    trunk/make/quagga/patches/100-quagga_multipath_caching_policy.patch
A    trunk/make/quagga/patches/101-incorrect_func_pow_test.patch
A    trunk/make/quagga/patches/120-fix-ipv6.patch
A    trunk/make/quagga/patches/010-fix-ipctl-forwarding.patch
A    trunk/make/quagga/patches/110-holdtimer-set.patch
A    trunk/make/quagga/Config.in
A    trunk/make/quagga/quagga.mk
A    trunk/make/xrelayd
A    trunk/make/xrelayd/files
A    trunk/make/xrelayd/files/.language
A    trunk/make/xrelayd/files/root
A    trunk/make/xrelayd/files/root/usr
A    trunk/make/xrelayd/files/root/usr/lib
A    trunk/make/xrelayd/files/root/usr/lib/cgi-bin
A    trunk/make/xrelayd/files/root/usr/lib/cgi-bin/xrelayd.cgi
A    trunk/make/xrelayd/files/root/etc
A    trunk/make/xrelayd/files/root/etc/init.d
A    trunk/make/xrelayd/files/root/etc/init.d/rc.xrelayd
A    trunk/make/xrelayd/files/root/etc/default.xrelayd
A    trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd_svcs.def
A    trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd_certchain.def
A    trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd.cfg
A    trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd_key.def
A    trunk/make/xrelayd/patches
A    trunk/make/xrelayd/patches/020-polarssl-0.x.x-to-1.x.x.patch
A    trunk/make/xrelayd/patches/030-polarssl-1.2.x.patch
A    trunk/make/xrelayd/patches/010-use-polarssl.patch
A    trunk/make/xrelayd/patches/040-make-genstuff-optional.patch
A    trunk/make/xrelayd/Config.in
A    trunk/make/xrelayd/xrelayd.mk
A    trunk/make/htop
A    trunk/make/htop/htop.mk
A    trunk/make/htop/external.files
A    trunk/make/htop/external.in
A    trunk/make/htop/patches
A    trunk/make/htop/patches/010-ioprio_support.patch
A    trunk/make/htop/Config.in
A    trunk/make/haserl
A    trunk/make/haserl/haserl.mk
A    trunk/make/haserl/patches
A    trunk/make/haserl/patches/100-lualib_inc.patch
A    trunk/make/haserl/Config.in
A    trunk/make/xsltproc
A    trunk/make/xsltproc/external.in.libs
A    trunk/make/xsltproc/Config.in.libs
A    trunk/make/xsltproc/external.files
A    trunk/make/xsltproc/xsltproc.mk
A    trunk/make/xsltproc/patches
A    trunk/make/xsltproc/patches/100-no_docs_mans_tests.patch
A    trunk/make/virtualip-cgi
A    trunk/make/virtualip-cgi/files
A    trunk/make/virtualip-cgi/files/.language
A    trunk/make/virtualip-cgi/files/root
A    trunk/make/virtualip-cgi/files/root/usr
A    trunk/make/virtualip-cgi/files/root/usr/lib
A    trunk/make/virtualip-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/virtualip-cgi/files/root/usr/lib/cgi-bin/virtualip.cgi
A    trunk/make/virtualip-cgi/files/root/etc
A    trunk/make/virtualip-cgi/files/root/etc/default.virtualip
A    trunk/make/virtualip-cgi/files/root/etc/default.virtualip/virtualip.cfg
A    trunk/make/virtualip-cgi/files/root/etc/init.d
A    trunk/make/virtualip-cgi/files/root/etc/init.d/rc.virtualip
A    trunk/make/virtualip-cgi/files/README
A    trunk/make/virtualip-cgi/virtualip-cgi.mk
A    trunk/make/virtualip-cgi/Config.in
A    trunk/make/vnstat
A    trunk/make/vnstat/external.files
A    trunk/make/vnstat/vnstat.mk
A    trunk/make/vnstat/external.in
A    trunk/make/vnstat/Config.in
A    trunk/make/phpxmail
A    trunk/make/phpxmail/files
A    trunk/make/phpxmail/files/.language
A    trunk/make/phpxmail/files/root
A    trunk/make/phpxmail/files/root/usr
A    trunk/make/phpxmail/files/root/usr/lib
A    trunk/make/phpxmail/files/root/usr/lib/cgi-bin
A    trunk/make/phpxmail/files/root/usr/lib/cgi-bin/phpxmail.cgi
A    trunk/make/phpxmail/files/root/usr/mww
A    trunk/make/phpxmail/files/root/usr/mww/phpxmail
A    trunk/make/phpxmail/files/root/usr/mww/phpxmail/servers.php
A    trunk/make/phpxmail/files/root/usr/mww/phpxmail/config.php
A    trunk/make/phpxmail/files/root/etc
A    trunk/make/phpxmail/files/root/etc/default.phpxmail
A    trunk/make/phpxmail/files/root/etc/default.phpxmail/phpxmail.save
A    trunk/make/phpxmail/files/root/etc/default.phpxmail/phpxmail.cfg
A    trunk/make/phpxmail/files/root/etc/init.d
A    trunk/make/phpxmail/files/root/etc/init.d/rc.phpxmail
A    trunk/make/phpxmail/patches
A    trunk/make/phpxmail/patches/100-modsave.patch
A    trunk/make/phpxmail/phpxmail.mk
A    trunk/make/phpxmail/Config.in
A    trunk/make/oidentd
A    trunk/make/oidentd/files
A    trunk/make/oidentd/files/.language
A    trunk/make/oidentd/files/root
A    trunk/make/oidentd/files/root/usr
A    trunk/make/oidentd/files/root/usr/lib
A    trunk/make/oidentd/files/root/usr/lib/cgi-bin
A    trunk/make/oidentd/files/root/usr/lib/cgi-bin/oidentd.cgi
A    trunk/make/oidentd/files/root/etc
A    trunk/make/oidentd/files/root/etc/init.d
A    trunk/make/oidentd/files/root/etc/init.d/rc.oidentd
A    trunk/make/oidentd/files/root/etc/default.oidentd
A    trunk/make/oidentd/files/root/etc/default.oidentd/oidentd.cfg
A    trunk/make/oidentd/files/root/etc/default.oidentd/oidentd.inetd
A    trunk/make/oidentd/files/root/etc/default.oidentd/oidentd_conf.def
A    trunk/make/oidentd/external.files
A    trunk/make/oidentd/external.services
A    trunk/make/oidentd/external.in
A    trunk/make/oidentd/patches
A    trunk/make/oidentd/patches/010-inline_std_gnu99.patch
A    trunk/make/oidentd/Config.in
A    trunk/make/oidentd/oidentd.mk
A    trunk/make/stunnel
A    trunk/make/stunnel/files
A    trunk/make/stunnel/files/.language
A    trunk/make/stunnel/files/root
A    trunk/make/stunnel/files/root/usr
A    trunk/make/stunnel/files/root/usr/lib
A    trunk/make/stunnel/files/root/usr/lib/cgi-bin
A    trunk/make/stunnel/files/root/usr/lib/cgi-bin/stunnel.cgi
A    trunk/make/stunnel/files/root/etc
A    trunk/make/stunnel/files/root/etc/init.d
A    trunk/make/stunnel/files/root/etc/init.d/rc.stunnel
A    trunk/make/stunnel/files/root/etc/default.stunnel
A    trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_svcs.def
A    trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_certchain.def
A    trunk/make/stunnel/files/root/etc/default.stunnel/stunnel.cfg
A    trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_conf
A    trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_key.def
A    trunk/make/stunnel/external.files
A    trunk/make/stunnel/external.services
A    trunk/make/stunnel/external.in
A    trunk/make/stunnel/patches
A    trunk/make/stunnel/patches/400-openssl-alternative.patch.TODO
A    trunk/make/stunnel/patches/300-ocsp-missing-ifdef.patch
A    trunk/make/stunnel/patches/100-kerberos_include.patch
A    trunk/make/stunnel/patches/450-cross_compilation.patch
A    trunk/make/stunnel/patches/200-default-values.patch
A    trunk/make/stunnel/Config.in
A    trunk/make/stunnel/stunnel.mk
A    trunk/make/libs
A    trunk/make/libs/mpc
A    trunk/make/libs/mpc/Makefile.in
A    trunk/make/libs/mpc/external.files
A    trunk/make/libs/mpc/mpc.mk
A    trunk/make/libs/mpc/external.in
A    trunk/make/libs/mpc/patches
A    trunk/make/libs/mpc/patches/100-no_docs_no_tests.mpc.patch
A    trunk/make/libs/mpc/Config.in
A    trunk/make/libs/protobuf-c
A    trunk/make/libs/protobuf-c/Makefile.in
A    trunk/make/libs/protobuf-c/external.files
A    trunk/make/libs/protobuf-c/protobuf-c.mk
A    trunk/make/libs/protobuf-c/external.in
A    trunk/make/libs/protobuf-c/Config.in
A    trunk/make/libs/uclibcxx
A    trunk/make/libs/uclibcxx/Makefile.in
A    trunk/make/libs/uclibcxx/external.files
A    trunk/make/libs/uclibcxx/external.in
A    trunk/make/libs/uclibcxx/patches
A    trunk/make/libs/uclibcxx/patches/010-fpos_not_equal_fix.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/050-gcc47x-proper-two-phase-lookup.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/040-iostream_wchar_support.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/400-eabi_fix.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/020-avoid_not_equal.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/900-dependent_exception.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/009-compile_fixes.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/010-bitset_fix.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/030-istream_long_long_support.uclibcxx.patch
A    trunk/make/libs/uclibcxx/patches/300-wrapper.uclibcxx.patch
A    trunk/make/libs/uclibcxx/Config.in
A    trunk/make/libs/uclibcxx/Config.uclibc++
A    trunk/make/libs/uclibcxx/uclibc++.mk
A    trunk/make/libs/popt
A    trunk/make/libs/popt/Makefile.in
A    trunk/make/libs/popt/external.files
A    trunk/make/libs/popt/external.in
A    trunk/make/libs/popt/patches
A    trunk/make/libs/popt/patches/110-Makefile.popt.patch
A    trunk/make/libs/popt/patches/120-gnu_glob.popt.patch
A    trunk/make/libs/popt/patches/100-configure.popt.patch
A    trunk/make/libs/popt/popt.mk
A    trunk/make/libs/popt/Config.in
A    trunk/make/libs/libexif
A    trunk/make/libs/libexif/Makefile.in
A    trunk/make/libs/libexif/external.files
A    trunk/make/libs/libexif/external.in
A    trunk/make/libs/libexif/patches
A    trunk/make/libs/libexif/patches/100-no_docs.libexif.patch
A    trunk/make/libs/libexif/libexif.mk
A    trunk/make/libs/libexif/Config.in
A    trunk/make/libs/apr
A    trunk/make/libs/apr/Makefile.in
A    trunk/make/libs/apr/external.files
A    trunk/make/libs/apr/external.in
A    trunk/make/libs/apr/patches
A    trunk/make/libs/apr/patches/010-uuid_pic.apr.patch
A    trunk/make/libs/apr/apr.mk
A    trunk/make/libs/apr/Config.in
A    trunk/make/libs/ncurses
A    trunk/make/libs/ncurses/Makefile.in
A    trunk/make/libs/ncurses/external.files
A    trunk/make/libs/ncurses/external.in
A    trunk/make/libs/ncurses/patches
A    trunk/make/libs/ncurses/patches/100-PKG_CONFIG_LIBDIR_contains_DESTDIR.ncurses.patch
A    trunk/make/libs/ncurses/patches/005-emdebian-wchar.ncurses.patch
A    trunk/make/libs/ncurses/patches/130-terminfo-rxvt-unicode.ncurses.patch
A    trunk/make/libs/ncurses/patches/120-terminfo-konsole.ncurses.patch
A    trunk/make/libs/ncurses/patches/110-terminfo-kbs.ncurses.patch
A    trunk/make/libs/ncurses/ncurses.mk
A    trunk/make/libs/ncurses/Config.in
A    trunk/make/libs/ncurses/ncurses-Config.in
A    trunk/make/libs/freetype
A    trunk/make/libs/freetype/Makefile.in
A    trunk/make/libs/freetype/external.files
A    trunk/make/libs/freetype/external.in
A    trunk/make/libs/freetype/freetype.mk
A    trunk/make/libs/freetype/Config.in
A    trunk/make/libs/libosip2
A    trunk/make/libs/libosip2/Makefile.in
A    trunk/make/libs/libosip2/external.files
A    trunk/make/libs/libosip2/external.in
A    trunk/make/libs/libosip2/patches
A    trunk/make/libs/libosip2/patches/010-multiple_CFLAGS.libosip2.patch
A    trunk/make/libs/libosip2/libosip2.mk
A    trunk/make/libs/libosip2/Config.in
A    trunk/make/libs/wxWidgets
A    trunk/make/libs/wxWidgets/Makefile.in
A    trunk/make/libs/wxWidgets/external.files
A    trunk/make/libs/wxWidgets/external.in
A    trunk/make/libs/wxWidgets/patches
A    trunk/make/libs/wxWidgets/patches/101-no_optimize_flags.wxWidgets.patch
A    trunk/make/libs/wxWidgets/patches/100-wx-config-DESTDIR.wxWidgets.patch
A    trunk/make/libs/wxWidgets/patches/110-build_static_lib_along_with_shared.wxWidgets.patch
A    trunk/make/libs/wxWidgets/Config.in
A    trunk/make/libs/wxWidgets/wxWidgets.mk
A    trunk/make/libs/jpeg
A    trunk/make/libs/jpeg/Makefile.in
A    trunk/make/libs/jpeg/external.files
A    trunk/make/libs/jpeg/external.in
A    trunk/make/libs/jpeg/patches
A    trunk/make/libs/jpeg/patches/100-config_guess.jpeg.patch
A    trunk/make/libs/jpeg/Config.in
A    trunk/make/libs/jpeg/jpeg.mk
A    trunk/make/libs/opus
A    trunk/make/libs/opus/Makefile.in
A    trunk/make/libs/opus/external.files
A    trunk/make/libs/opus/external.in
A    trunk/make/libs/opus/Config.in
A    trunk/make/libs/opus/opus.mk
A    trunk/make/libs/sysfsutils
A    trunk/make/libs/sysfsutils/Makefile.in
A    trunk/make/libs/sysfsutils/external.files
A    trunk/make/libs/sysfsutils/external.in
A    trunk/make/libs/sysfsutils/Config.in
A    trunk/make/libs/sysfsutils/sysfsutils.mk
A    trunk/make/libs/libmad
A    trunk/make/libs/libmad/Makefile.in
A    trunk/make/libs/libmad/external.files
A    trunk/make/libs/libmad/external.in
A    trunk/make/libs/libmad/patches
A    trunk/make/libs/libmad/patches/100-configure.libmad.patch
A    trunk/make/libs/libmad/patches/001-mips_removal_h_constraint.libmad.patch
A    trunk/make/libs/libmad/Config.in
A    trunk/make/libs/libmad/libmad.mk
A    trunk/make/libs/libdaemon
A    trunk/make/libs/libdaemon/libdaemon.mk
A    trunk/make/libs/libdaemon/Makefile.in
A    trunk/make/libs/libdaemon/external.files
A    trunk/make/libs/libdaemon/external.in
A    trunk/make/libs/libdaemon/Config.in
A    trunk/make/libs/neon
A    trunk/make/libs/neon/Makefile.in
A    trunk/make/libs/neon/external.files
A    trunk/make/libs/neon/neon.mk
A    trunk/make/libs/neon/external.in
A    trunk/make/libs/neon/patches
A    trunk/make/libs/neon/patches/110-no_libintl.neon.patch
A    trunk/make/libs/neon/patches/120-dont-cache-openssl-version-dependent-values.neon.patch
A    trunk/make/libs/neon/patches/100-no_docs.neon.patch
A    trunk/make/libs/neon/Config.in
A    trunk/make/libs/libgcrypt
A    trunk/make/libs/libgcrypt/Makefile.in
A    trunk/make/libs/libgcrypt/external.files
A    trunk/make/libs/libgcrypt/libgcrypt.mk
A    trunk/make/libs/libgcrypt/external.in
A    trunk/make/libs/libgcrypt/patches
A    trunk/make/libs/libgcrypt/patches/002-no_docs_tests.libgcrypt.patch
A    trunk/make/libs/libgcrypt/Config.in
A    trunk/make/libs/polarssl
A    trunk/make/libs/polarssl/Makefile.in
A    trunk/make/libs/polarssl/external.files
A    trunk/make/libs/polarssl/polarssl.mk
A    trunk/make/libs/polarssl/external.in
A    trunk/make/libs/polarssl/patches
A    trunk/make/libs/polarssl/patches/100-shared.polarssl.patch
A    trunk/make/libs/polarssl/patches/200-x509write.polarssl.patch
A    trunk/make/libs/polarssl/patches/300-blowfish-openssl-compat.polarssl.patch
A    trunk/make/libs/polarssl/patches/020-reduce_size.polarssl.patch
A    trunk/make/libs/polarssl/Config.in
A    trunk/make/libs/zlib
A    trunk/make/libs/zlib/Makefile.in
A    trunk/make/libs/zlib/external.files
A    trunk/make/libs/zlib/zlib.mk
A    trunk/make/libs/zlib/external.in
A    trunk/make/libs/zlib/patches
A    trunk/make/libs/zlib/patches/120-four_byte_unsigned_int.zlib.patch
A    trunk/make/libs/zlib/patches/110-configure_no_exit.zlib.patch
A    trunk/make/libs/zlib/Config.in
A    trunk/make/libs/uclibc/Config.in
A    trunk/make/libs/pkcs11
A    trunk/make/libs/pkcs11/pkcs11.mk
A    trunk/make/libs/lzo
A    trunk/make/libs/lzo/Makefile.in
A    trunk/make/libs/lzo/external.files
A    trunk/make/libs/lzo/external.in
A    trunk/make/libs/lzo/Config.in
A    trunk/make/libs/lzo/lzo.mk
A    trunk/make/libs/libsynce
A    trunk/make/libs/libsynce/Makefile.in
A    trunk/make/libs/libsynce/external.files
A    trunk/make/libs/libsynce/external.in
A    trunk/make/libs/libsynce/Config.in
A    trunk/make/libs/libsynce/libsynce.mk
A    trunk/make/libs/bluez-libs
A    trunk/make/libs/bluez-libs/Makefile.in
A    trunk/make/libs/bluez-libs/external.files
A    trunk/make/libs/bluez-libs/external.in
A    trunk/make/libs/bluez-libs/Config.in
A    trunk/make/libs/bluez-libs/bluez-libs.mk
A    trunk/make/libs/libevent
A    trunk/make/libs/libevent/Makefile.in
A    trunk/make/libs/libevent/external.files
A    trunk/make/libs/libevent/external.in
A    trunk/make/libs/libevent/patches
A    trunk/make/libs/libevent/patches/upstream-b7577868a8975fa17d77cf438141884bf081a6b2.libevent.patch
A    trunk/make/libs/libevent/patches/010-no_unnecessary_libs_sample_test_pyscripts.libevent.patch
A    trunk/make/libs/libevent/patches/020-openssl_test_fix.libevent.patch
A    trunk/make/libs/libevent/Config.in
A    trunk/make/libs/libevent/libevent.mk
A    trunk/make/libs/libxml2
A    trunk/make/libs/libxml2/libxml2.mk
A    trunk/make/libs/libxml2/Makefile.in
A    trunk/make/libs/libxml2/external.files
A    trunk/make/libs/libxml2/external.in
A    trunk/make/libs/libxml2/patches
A    trunk/make/libs/libxml2/patches/100-no_docs_examples_tests.libxml2.patch
A    trunk/make/libs/libxml2/patches/110-pthread_fixes.libxml2.patch
A    trunk/make/libs/libxml2/Config.in
A    trunk/make/libs/attr
A    trunk/make/libs/attr/attr.mk
A    trunk/make/libs/attr/Makefile.in
A    trunk/make/libs/attr/external.files
A    trunk/make/libs/attr/external.in
A    trunk/make/libs/attr/patches
A    trunk/make/libs/attr/patches/10-allow-DESTDIR.attr.patch
A    trunk/make/libs/attr/patches/05-eliminate_a_memory_leak.attr.patch
A    trunk/make/libs/attr/patches/03-pull_in_string.h.attr.patch
A    trunk/make/libs/attr/patches/07-fix_thinko_in_restore.attr.patch
A    trunk/make/libs/attr/patches/02-fix_memory_leak_in_attr_copy_action.attr.patch
A    trunk/make/libs/attr/patches/06-eliminate_a_double_free.attr.patch
A    trunk/make/libs/attr/Config.in
A    trunk/make/libs/libctlmgr
A    trunk/make/libs/libctlmgr/Makefile.in
A    trunk/make/libs/libctlmgr/libctlmgr.mk
A    trunk/make/libs/libctlmgr/src
A    trunk/make/libs/libctlmgr/src/libctlmgr.c
A    trunk/make/libs/libctlmgr/src/Makefile
A    trunk/make/libs/libctlmgr/Config.in
A    trunk/make/libs/libdnet
A    trunk/make/libs/libdnet/Makefile.in
A    trunk/make/libs/libdnet/external.files
A    trunk/make/libs/libdnet/external.in
A    trunk/make/libs/libdnet/libdnet.mk
A    trunk/make/libs/libdnet/patches
A    trunk/make/libs/libdnet/patches/040-socklen_t.nmap_backport.libdnet.patch
A    trunk/make/libs/libdnet/patches/040-missing_part_of_r654.nmap_backport.libdnet.patch
A    trunk/make/libs/libdnet/patches/010-missing_tags.libdnet.patch
A    trunk/make/libs/libdnet/patches/030-no_man_python_test.libdnet.patch
A    trunk/make/libs/libdnet/patches/050-install_sctp_h.libdnet.patch
A    trunk/make/libs/libdnet/patches/020-dnet-config.libdnet.patch
A    trunk/make/libs/libdnet/patches/050-name_collision_sctp_h.libdnet.patch
A    trunk/make/libs/libdnet/Config.in
A    trunk/make/libs/gmp
A    trunk/make/libs/gmp/Makefile.in
A    trunk/make/libs/gmp/external.files
A    trunk/make/libs/gmp/external.in
A    trunk/make/libs/gmp/patches
A    trunk/make/libs/gmp/patches/100-no_tests_no_demos_no_docs.gmp.patch
A    trunk/make/libs/gmp/patches/010-dont_test_for_cxx_if_no_cxx_requested.gmp.patch
A    trunk/make/libs/gmp/gmp.mk
A    trunk/make/libs/gmp/Config.in
A    trunk/make/libs/gettext
A    trunk/make/libs/gettext/Makefile.in
A    trunk/make/libs/gettext/external.files
A    trunk/make/libs/gettext/external.in
A    trunk/make/libs/gettext/Config.in
A    trunk/make/libs/gettext/gettext.mk
A    trunk/make/libs/matrixssl
A    trunk/make/libs/matrixssl/Makefile.in
A    trunk/make/libs/matrixssl/external.files
A    trunk/make/libs/matrixssl/external.in
A    trunk/make/libs/matrixssl/Config.in
A    trunk/make/libs/matrixssl/matrixssl.mk
A    trunk/make/libs/pcre
A    trunk/make/libs/pcre/pcre.mk
A    trunk/make/libs/pcre/Makefile.in
A    trunk/make/libs/pcre/external.files
A    trunk/make/libs/pcre/external.in
A    trunk/make/libs/pcre/patches
A    trunk/make/libs/pcre/patches/100-no_docs_no_man.pcre.patch
A    trunk/make/libs/pcre/patches/110-unnecessary-tests.pcre.patch
A    trunk/make/libs/pcre/patches/750-pcre_config_cross.pcre.patch
A    trunk/make/libs/pcre/Config.in
A    trunk/make/libs/gd
A    trunk/make/libs/gd/gd.mk
A    trunk/make/libs/gd/Makefile.in
A    trunk/make/libs/gd/external.files
A    trunk/make/libs/gd/external.in
A    trunk/make/libs/gd/patches
A    trunk/make/libs/gd/patches/0004_fix_fprint_string_formatting.debian.gd.patch
A    trunk/make/libs/gd/patches/0010-additional_attributes.php.gd.patch
A    trunk/make/libs/gd/patches/0003_fix_support_large_images.debian.gd.patch
A    trunk/make/libs/gd/patches/0002_CVE-2009-3546.debian.gd.patch
A    trunk/make/libs/gd/patches/0001_fix_leak_in_gdImageCopyResized.debian.gd.patch
A    trunk/make/libs/gd/Config.in
A    trunk/make/libs/pjproject
A    trunk/make/libs/pjproject/Makefile.in
A    trunk/make/libs/pjproject/pjproject.mk
A    trunk/make/libs/pjproject/patches
A    trunk/make/libs/pjproject/patches/120-no_uuid.pjproject.patch
A    trunk/make/libs/pjproject/patches/100-stat_wav.pjproject.patch
A    trunk/make/libs/pjproject/patches/101-no-test.pjproject.patch
A    trunk/make/libs/pjproject/Config.in
A    trunk/make/libs/libusb1
A    trunk/make/libs/libusb1/Makefile.in
A    trunk/make/libs/libusb1/external.files
A    trunk/make/libs/libusb1/external.in
A    trunk/make/libs/libusb1/libusb1.mk
A    trunk/make/libs/libusb1/Config.in
A    trunk/make/libs/taglib
A    trunk/make/libs/taglib/Makefile.in
A    trunk/make/libs/taglib/external.files
A    trunk/make/libs/taglib/external.in
A    trunk/make/libs/taglib/patches
A    trunk/make/libs/taglib/patches/030-no-debug-warnings.taglib.patch
A    trunk/make/libs/taglib/patches/010-missing_not_equal_operator.taglib.patch
A    trunk/make/libs/taglib/patches/020-missing_libm.taglib.patch
A    trunk/make/libs/taglib/patches/100-no_libdir.uclibcxx.patch
A    trunk/make/libs/taglib/taglib.mk
A    trunk/make/libs/taglib/Config.in
A    trunk/make/libs/libid3tag
A    trunk/make/libs/libid3tag/Makefile.in
A    trunk/make/libs/libid3tag/external.files
A    trunk/make/libs/libid3tag/external.in
A    trunk/make/libs/libid3tag/patches
A    trunk/make/libs/libid3tag/patches/100-makefile.libid3tag.patch
A    trunk/make/libs/libid3tag/patches/100-configure_cflags.libid3tag.patch
A    trunk/make/libs/libid3tag/libid3tag.mk
A    trunk/make/libs/libid3tag/Config.in
A    trunk/make/libs/libavmhmac
A    trunk/make/libs/libavmhmac/Makefile.in
A    trunk/make/libs/libavmhmac/libavmhmac.mk
A    trunk/make/libs/libavmhmac/Config.in
A    trunk/make/libs/libtool
A    trunk/make/libs/libtool/Makefile.in
A    trunk/make/libs/libtool/external.files
A    trunk/make/libs/libtool/external.in
A    trunk/make/libs/libtool/patches
A    trunk/make/libs/libtool/patches/001-force_dlopen_deplibs.libtool.patch
A    trunk/make/libs/libtool/patches/100-libdir_path.libtool.patch
A    trunk/make/libs/libtool/patches/130-no_recheck.libtool.patch
A    trunk/make/libs/libtool/patches/200-package-specific-dlerror-test.libtool.patch
A    trunk/make/libs/libtool/patches/110-no_rpath.libtool.patch
A    trunk/make/libs/libtool/patches/120-libdir_search.libtool.patch
A    trunk/make/libs/libtool/Config.in
A    trunk/make/libs/libtool/libtool.mk
A    trunk/make/libs/libftdi
A    trunk/make/libs/libftdi/Makefile.in
A    trunk/make/libs/libftdi/external.files
A    trunk/make/libs/libftdi/libftdi.mk
A    trunk/make/libs/libftdi/external.in
A    trunk/make/libs/libftdi/patches
A    trunk/make/libs/libftdi/patches/100-no_docs.libftdi.patch
A    trunk/make/libs/libftdi/Config.in
A    trunk/make/libs/linux-atm
A    trunk/make/libs/linux-atm/Makefile.in
A    trunk/make/libs/linux-atm/external.files
A    trunk/make/libs/linux-atm/linux-atm.mk
A    trunk/make/libs/linux-atm/external.in
A    trunk/make/libs/linux-atm/patches
A    trunk/make/libs/linux-atm/patches/100-build_lib_only.linux-atm.patch
A    trunk/make/libs/linux-atm/patches/005-no_libresolv.linux-atm.patch
A    trunk/make/libs/linux-atm/Config.in
A    trunk/make/libs/expat
A    trunk/make/libs/expat/Makefile.in
A    trunk/make/libs/expat/external.files
A    trunk/make/libs/expat/expat.mk
A    trunk/make/libs/expat/external.in
A    trunk/make/libs/expat/patches
A    trunk/make/libs/expat/patches/560-901_CVE_2009_3560.expat.patch
A    trunk/make/libs/expat/patches/551-936_CVE_2009_2625.expat.patch
A    trunk/make/libs/expat/patches/302-191_install_expat_config_h.expat.patch
A    trunk/make/libs/expat/Config.in
A    trunk/make/libs/db
A    trunk/make/libs/db/Makefile.in
A    trunk/make/libs/db/external.files
A    trunk/make/libs/db/external.in
A    trunk/make/libs/db/patches
A    trunk/make/libs/db/patches/100-no_docs.db.patch
A    trunk/make/libs/db/Config.in
A    trunk/make/libs/db/db.mk
A    trunk/make/libs/libart_lgpl
A    trunk/make/libs/libart_lgpl/libart_lgpl.mk
A    trunk/make/libs/libart_lgpl/Makefile.in
A    trunk/make/libs/libart_lgpl/external.files
A    trunk/make/libs/libart_lgpl/external.in
A    trunk/make/libs/libart_lgpl/Config.in
A    trunk/make/libs/libgpg-error
A    trunk/make/libs/libgpg-error/libgpg-error.mk
A    trunk/make/libs/libgpg-error/Makefile.in
A    trunk/make/libs/libgpg-error/external.files
A    trunk/make/libs/libgpg-error/external.in
A    trunk/make/libs/libgpg-error/patches
A    trunk/make/libs/libgpg-error/patches/110-gnu_source__reentrant.libgpg-error.patch
A    trunk/make/libs/libgpg-error/patches/100-libtool.libgpg-error.patch
A    trunk/make/libs/libgpg-error/Config.in
A    trunk/make/libs/libvorbis
A    trunk/make/libs/libvorbis/libvorbis.mk
A    trunk/make/libs/libvorbis/Makefile.in
A    trunk/make/libs/libvorbis/external.files
A    trunk/make/libs/libvorbis/external.in
A    trunk/make/libs/libvorbis/patches
A    trunk/make/libs/libvorbis/patches/100-no_docs.libvorbis.patch
A    trunk/make/libs/libvorbis/patches/200-remove51.libvorbis.patch
A    trunk/make/libs/libvorbis/Config.in
A    trunk/make/libs/libconfig
A    trunk/make/libs/libconfig/Makefile.in
A    trunk/make/libs/libconfig/libconfig.mk
A    trunk/make/libs/libconfig/external.files
A    trunk/make/libs/libconfig/external.in
A    trunk/make/libs/libconfig/patches
A    trunk/make/libs/libconfig/patches/010-nodocs-notests.libconfig.patch
A    trunk/make/libs/libconfig/Config.in
A    trunk/make/libs/apr-util
A    trunk/make/libs/apr-util/Makefile.in
A    trunk/make/libs/apr-util/apr-util.mk
A    trunk/make/libs/apr-util/external.files
A    trunk/make/libs/apr-util/external.in
A    trunk/make/libs/apr-util/patches
A    trunk/make/libs/apr-util/patches/100-apu-config.apr-util.patch
A    trunk/make/libs/apr-util/Config.in
A    trunk/make/libs/glib2
A    trunk/make/libs/glib2/Makefile.in
A    trunk/make/libs/glib2/external.files
A    trunk/make/libs/glib2/glib2.mk
A    trunk/make/libs/glib2/external.in
A    trunk/make/libs/glib2/patches
A    trunk/make/libs/glib2/patches/030-no_in6addr_vars_in_libc_without_IPv6.glib2.patch
A    trunk/make/libs/glib2/patches/120-unnecessary-GLIB_COMPILES.glib2.patch
A    trunk/make/libs/glib2/patches/200-no_nls.glib2.patch
A    trunk/make/libs/glib2/patches/300-configure-tests-unconditional-includes.glib2.patch
A    trunk/make/libs/glib2/patches/010-pkgconfig-no-privates.glib2.patch
A    trunk/make/libs/glib2/patches/110-drop-DBUS-dependency.glib2.patch
A    trunk/make/libs/glib2/patches/020-no-tests-no-docs.glib2.patch
A    trunk/make/libs/glib2/patches/100-drop-PYTHON-dependency.glib2.patch
A    trunk/make/libs/glib2/patches/320-drop-libelf-dependency.glib2.patch
A    trunk/make/libs/glib2/patches/310-fix-ac_cv_alignof-tests.glib2.patch
A    trunk/make/libs/glib2/patches/050-configure_generated_libtool_call.glib2.patch
A    trunk/make/libs/glib2/Config.in
A    trunk/make/libs/libcapi
A    trunk/make/libs/libcapi/Makefile.in
A    trunk/make/libs/libcapi/external.files
A    trunk/make/libs/libcapi/external.in
A    trunk/make/libs/libcapi/libcapi.mk
A    trunk/make/libs/libcapi/Config.in
A    trunk/make/libs/libogg
A    trunk/make/libs/libogg/Makefile.in
A    trunk/make/libs/libogg/external.files
A    trunk/make/libs/libogg/external.in
A    trunk/make/libs/libogg/patches
A    trunk/make/libs/libogg/patches/100-no_docs.libogg.patch
A    trunk/make/libs/libogg/patches/110-no_opt_cflags.libogg.patch
A    trunk/make/libs/libogg/libogg.mk
A    trunk/make/libs/libogg/Config.in
A    trunk/make/libs/liboping
A    trunk/make/libs/liboping/Makefile.in
A    trunk/make/libs/liboping/external.files
A    trunk/make/libs/liboping/external.in
A    trunk/make/libs/liboping/patches
A    trunk/make/libs/liboping/patches/110-IPv6_defines.liboping.patch
A    trunk/make/libs/liboping/patches/100-no-Werror.liboping.patch
A    trunk/make/libs/liboping/patches/120-IPv6_structs.liboping.patch
A    trunk/make/libs/liboping/liboping.mk
A    trunk/make/libs/liboping/Config.in
A    trunk/make/libs/libstdcxx
A    trunk/make/libs/libstdcxx/libstdc++.mk
A    trunk/make/libs/libstdcxx/Makefile.in
A    trunk/make/libs/libstdcxx/external.files
A    trunk/make/libs/libstdcxx/external.in
A    trunk/make/libs/libstdcxx/Config.in
A    trunk/make/libs/mpfr
A    trunk/make/libs/mpfr/Makefile.in
A    trunk/make/libs/mpfr/external.files
A    trunk/make/libs/mpfr/external.in
A    trunk/make/libs/mpfr/patches
A    trunk/make/libs/mpfr/patches/002-patch02_strtofr-ternary-value.mpfr.patch
A    trunk/make/libs/mpfr/patches/100-no_docs_no_tests.mpfr.patch
A    trunk/make/libs/mpfr/patches/001-patch01_get_decimal64.mpfr.patch
A    trunk/make/libs/mpfr/patches/003-patch03-gmp51-compat.mpfr.patch
A    trunk/make/libs/mpfr/Config.in
A    trunk/make/libs/mpfr/mpfr.mk
A    trunk/make/libs/libpcap
A    trunk/make/libs/libpcap/libpcap.mk
A    trunk/make/libs/libpcap/Makefile.in
A    trunk/make/libs/libpcap/external.files
A    trunk/make/libs/libpcap/external.in
A    trunk/make/libs/libpcap/patches
A    trunk/make/libs/libpcap/patches/100-reduce_buffer_size.libpcap.patch
A    trunk/make/libs/libpcap/patches/100-shared-lib.libpcap.patch
A    trunk/make/libs/libpcap/patches/103-flex_workaround.libpcap.patch
A    trunk/make/libs/libpcap/patches/108-no_usb.libpcap.patch
A    trunk/make/libs/libpcap/patches/107-no_man.libpcap.patch
A    trunk/make/libs/libpcap/patches/105-protocol_api.libpcap.patch
A    trunk/make/libs/libpcap/patches/106-fix_pcap-config.libpcap.patch
A    trunk/make/libs/libpcap/patches/104-space_optimization.libpcap.patch
A    trunk/make/libs/libpcap/Config.in
A    trunk/make/libs/libnet
A    trunk/make/libs/libnet/Makefile.in
A    trunk/make/libs/libnet/external.files
A    trunk/make/libs/libnet/libnet.mk
A    trunk/make/libs/libnet/external.in
A    trunk/make/libs/libnet/patches
A    trunk/make/libs/libnet/patches/100-cross-compilation.libnet.patch
A    trunk/make/libs/libnet/Config.in
A    trunk/make/libs/openobex
A    trunk/make/libs/openobex/Makefile.in
A    trunk/make/libs/openobex/external.files
A    trunk/make/libs/openobex/openobex.mk
A    trunk/make/libs/openobex/external.in
A    trunk/make/libs/openobex/patches
A    trunk/make/libs/openobex/patches/100-makefile_no_usb.openobex.patch
A    trunk/make/libs/openobex/Config.in
A    trunk/make/libs/libusb/Makefile.in
A    trunk/make/libs/libusb/external.files
A    trunk/make/libs/libusb/libusb.mk
A    trunk/make/libs/libusb/external.in
A    trunk/make/libs/libusb/patches
A    trunk/make/libs/libusb/patches/100-fix_dirs.libusb.patch
A    trunk/make/libs/libusb/patches/01-no_libusbpp.libusb.patch
A    trunk/make/libs/libusb/Config.in
A    trunk/make/libs/readline
A    trunk/make/libs/readline/Makefile.in
A    trunk/make/libs/readline/external.files
A    trunk/make/libs/readline/external.in
A    trunk/make/libs/readline/patches
A    trunk/make/libs/readline/patches/120-curses-link.readline.patch
A    trunk/make/libs/readline/patches/110-no_old_libs.readline.patch
A    trunk/make/libs/readline/patches/001-no_doc__no_examples.readline.patch
A    trunk/make/libs/readline/patches/001-no_rpath.readline.patch
A    trunk/make/libs/readline/patches/101-readline62-001.readline.patch
A    trunk/make/libs/readline/patches/102-readline62-002.readline.patch
A    trunk/make/libs/readline/patches/103-readline62-003.readline.patch
A    trunk/make/libs/readline/patches/104-readline62-004.readline.patch
A    trunk/make/libs/readline/readline.mk
A    trunk/make/libs/readline/Config.in
A    trunk/make/libs/devmapper
A    trunk/make/libs/devmapper/Makefile.in
A    trunk/make/libs/devmapper/external.files
A    trunk/make/libs/devmapper/external.in
A    trunk/make/libs/devmapper/devmapper.mk
A    trunk/make/libs/devmapper/Config.in
A    trunk/make/libs/libmultid
A    trunk/make/libs/libmultid/Makefile.in
A    trunk/make/libs/libmultid/src
A    trunk/make/libs/libmultid/src/libmultid.c
A    trunk/make/libs/libmultid/src/Makefile
A    trunk/make/libs/libmultid/Config.in
A    trunk/make/libs/libmultid/libmultid.mk
A    trunk/make/libs/external.in
A    trunk/make/libs/libffi
A    trunk/make/libs/libffi/libffi.mk
A    trunk/make/libs/libffi/Makefile.in
A    trunk/make/libs/libffi/external.files
A    trunk/make/libs/libffi/external.in
A    trunk/make/libs/libffi/patches
A    trunk/make/libs/libffi/patches/010-no-tests-no-docs.libffi.patch
A    trunk/make/libs/libffi/patches/020-includedir.libffi.patch
A    trunk/make/libs/libffi/Config.in
A    trunk/make/libs/libelf
A    trunk/make/libs/libelf/Makefile.in
A    trunk/make/libs/libelf/external.files
A    trunk/make/libs/libelf/libelf.mk
A    trunk/make/libs/libelf/external.in
A    trunk/make/libs/libelf/patches
A    trunk/make/libs/libelf/patches/100-configure.libelf.patch
A    trunk/make/libs/libelf/Config.in
A    trunk/make/libs/cyassl
A    trunk/make/libs/cyassl/Makefile.in
A    trunk/make/libs/cyassl/external.files
A    trunk/make/libs/cyassl/cyassl.mk
A    trunk/make/libs/cyassl/external.in
A    trunk/make/libs/cyassl/patches
A    trunk/make/libs/cyassl/patches/030-export_compile_time_defines.cyassl.patch
A    trunk/make/libs/cyassl/patches/020-missing-pthread-dependency.cyassl.patch
A    trunk/make/libs/cyassl/patches/010-mark_unsupported_features.cyassl.patch
A    trunk/make/libs/cyassl/Config.in
A    trunk/make/libs/yaml
A    trunk/make/libs/yaml/Makefile.in
A    trunk/make/libs/yaml/external.files
A    trunk/make/libs/yaml/external.in
A    trunk/make/libs/yaml/yaml.mk
A    trunk/make/libs/yaml/Config.in
A    trunk/make/libs/libiconv
A    trunk/make/libs/libiconv/Makefile.in
A    trunk/make/libs/libiconv/external.files
A    trunk/make/libs/libiconv/external.in
A    trunk/make/libs/libiconv/patches
A    trunk/make/libs/libiconv/patches/100-strip_charsets.libiconv.patch
A    trunk/make/libs/libiconv/Config.in
A    trunk/make/libs/libiconv/libiconv.mk
A    trunk/make/libs/flac
A    trunk/make/libs/flac/Makefile.in
A    trunk/make/libs/flac/external.files
A    trunk/make/libs/flac/external.in
A    trunk/make/libs/flac/patches
A    trunk/make/libs/flac/patches/200-CFLAGS.flac.patch
A    trunk/make/libs/flac/patches/100-no-docs-and-examples.flac.patch
A    trunk/make/libs/flac/Config.in
A    trunk/make/libs/flac/flac.mk
A    trunk/make/libs/libgcc_s
A    trunk/make/libs/libgcc_s/Makefile.in
A    trunk/make/libs/libgcc_s/Config.in
A    trunk/make/libs/libgcc_s/libgcc_s.mk
A    trunk/make/libs/openjpeg
A    trunk/make/libs/openjpeg/Makefile.in
A    trunk/make/libs/openjpeg/external.files
A    trunk/make/libs/openjpeg/external.in
A    trunk/make/libs/openjpeg/patches
A    trunk/make/libs/openjpeg/patches/100-freetz_cflags.openjpeg.patch
A    trunk/make/libs/openjpeg/Config.in
A    trunk/make/libs/openjpeg/openjpeg.mk
A    trunk/make/libs/Config.in
A    trunk/make/libs/libpng
A    trunk/make/libs/libpng/libpng.mk
A    trunk/make/libs/libpng/Makefile.in
A    trunk/make/libs/libpng/external.files
A    trunk/make/libs/libpng/external.in
A    trunk/make/libs/libpng/Config.in
A    trunk/make/libs/libtasn1
A    trunk/make/libs/libtasn1/Makefile.in
A    trunk/make/libs/libtasn1/external.files
A    trunk/make/libs/libtasn1/libtasn1.mk
A    trunk/make/libs/libtasn1/external.in
A    trunk/make/libs/libtasn1/patches
A    trunk/make/libs/libtasn1/patches/100-lib_only.libtasn1.patch
A    trunk/make/libs/libtasn1/Config.in
A    trunk/make/libs/leptonica
A    trunk/make/libs/leptonica/Makefile.in
A    trunk/make/libs/leptonica/external.files
A    trunk/make/libs/leptonica/leptonica.mk
A    trunk/make/libs/leptonica/external.in
A    trunk/make/libs/leptonica/patches
A    trunk/make/libs/leptonica/patches/030-no_demo_code_in_lib.leptonica.patch
A    trunk/make/libs/leptonica/patches/020-no_xtractprotos.leptonica.patch
A    trunk/make/libs/leptonica/patches/010-enforce-libpng12.leptonica.patch
A    trunk/make/libs/leptonica/Config.in
A    trunk/make/htpdate
A    trunk/make/htpdate/htpdate.mk
A    trunk/make/htpdate/files
A    trunk/make/htpdate/files/.language
A    trunk/make/htpdate/files/root
A    trunk/make/htpdate/files/root/usr
A    trunk/make/htpdate/files/root/usr/lib
A    trunk/make/htpdate/files/root/usr/lib/cgi-bin
A    trunk/make/htpdate/files/root/usr/lib/cgi-bin/htpdate.cgi
A    trunk/make/htpdate/files/root/etc
A    trunk/make/htpdate/files/root/etc/init.d
A    trunk/make/htpdate/files/root/etc/init.d/rc.htpdate
A    trunk/make/htpdate/files/root/etc/default.htpdate
A    trunk/make/htpdate/files/root/etc/default.htpdate/htpdate.save
A    trunk/make/htpdate/files/root/etc/default.htpdate/htpdate.cfg
A    trunk/make/htpdate/files/root/etc/onlinechanged
A    trunk/make/htpdate/files/root/etc/onlinechanged/10-htpdate
A    trunk/make/htpdate/patches
A    trunk/make/htpdate/patches/100_htpdate_c.patch
A    trunk/make/htpdate/Config.in
A    trunk/make/br2684ctl
A    trunk/make/br2684ctl/br2684ctl.mk
A    trunk/make/br2684ctl/patches
A    trunk/make/br2684ctl/patches/101-routed_support.patch
A    trunk/make/br2684ctl/patches/100-debian.patch
A    trunk/make/br2684ctl/Config.in
A    trunk/make/README.Makefiles
A    trunk/make/vtun
A    trunk/make/vtun/files
A    trunk/make/vtun/files/.language
A    trunk/make/vtun/files/root
A    trunk/make/vtun/files/root/usr
A    trunk/make/vtun/files/root/usr/lib
A    trunk/make/vtun/files/root/usr/lib/cgi-bin
A    trunk/make/vtun/files/root/usr/lib/cgi-bin/vtun.cgi
A    trunk/make/vtun/files/root/etc
A    trunk/make/vtun/files/root/etc/default.vtun
A    trunk/make/vtun/files/root/etc/default.vtun/vtun.cfg
A    trunk/make/vtun/files/root/etc/init.d
A    trunk/make/vtun/files/root/etc/init.d/rc.vtun
A    trunk/make/vtun/vtun.mk
A    trunk/make/vtun/external.files
A    trunk/make/vtun/external.services
A    trunk/make/vtun/external.in
A    trunk/make/vtun/patches
A    trunk/make/vtun/patches/110-debian_sslauth.patch
A    trunk/make/vtun/patches/111-debian_ipv6.patch
A    trunk/make/vtun/patches/100-extra_ldflags.patch
A    trunk/make/vtun/Config.in
A    trunk/make/linux
A    trunk/make/linux/Config.ur8.7270_04.86
A    trunk/make/linux/Config.ohio.04.67
A    trunk/make/linux/Config.ohio.04.76
A    trunk/make/linux/Config.iks.7390_05.21
A    trunk/make/linux/Config.ohio.04.87
A    trunk/make/linux/Makefile.in
A    trunk/make/linux/Config.iks.7390_05.50
A    trunk/make/linux/Config.ohio.7140_04.33
A    trunk/make/linux/kernel.mk
A    trunk/make/linux/patches
A    trunk/make/linux/patches/2.6.13.1
A    trunk/make/linux/patches/2.6.13.1/320-ipp2p_0.8.2.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.ipv6_multicast.patch
A    trunk/make/linux/patches/2.6.13.1/04.87
A    trunk/make/linux/patches/2.6.13.1/04.87/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.87/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/500-unionfs.patch
A    trunk/make/linux/patches/2.6.13.1/310-autofs4-2.6.13-v5-update-20081027.patch
A    trunk/make/linux/patches/2.6.13.1/9999-missing_skb_truesize_increment.patch
A    trunk/make/linux/patches/2.6.13.1/209-mini_fo.patch
A    trunk/make/linux/patches/2.6.13.1/004-extra_optimization.patch
A    trunk/make/linux/patches/2.6.13.1/300-mppe-mppc-1.3.patch
A    trunk/make/linux/patches/2.6.13.1/800-nfsd_custom_port.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.congestion_BIC_b.patch
A    trunk/make/linux/patches/2.6.13.1/100-evaloader.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.tcp_clamp_window.patch
A    trunk/make/linux/patches/2.6.13.1/350-kernel-2.6.13-2.6.16-layer7-2.2.patch
A    trunk/make/linux/patches/2.6.13.1/04.30
A    trunk/make/linux/patches/2.6.13.1/04.30/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/101-depmod.patch
A    trunk/make/linux/patches/2.6.13.1/04.33
A    trunk/make/linux/patches/2.6.13.1/04.33/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/04.70
A    trunk/make/linux/patches/2.6.13.1/04.70/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.70/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/520-lib-lzo.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.14.x-branch.unlink_expect_leak.patch
A    trunk/make/linux/patches/2.6.13.1/110-unistd_h_inotify.patch
A    trunk/make/linux/patches/2.6.13.1/700-cifs-1.45.patch
A    trunk/make/linux/patches/2.6.13.1/r7203
A    trunk/make/linux/patches/2.6.13.1/r7203/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/04.57
A    trunk/make/linux/patches/2.6.13.1/04.57/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.57/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/04.76
A    trunk/make/linux/patches/2.6.13.1/04.76/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.76/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/012-mips_cpu_tlb.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.default_congestion.patch
A    trunk/make/linux/patches/2.6.13.1/210-jff2nfsexport-2.6.13.1.patch
A    trunk/make/linux/patches/2.6.13.1/400-ftdi-smartmouse.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.14.x-branch.dont_increase_master_refcount_on_expectations.patch
A    trunk/make/linux/patches/2.6.13.1/201-ip_conntrack_rtsp_2.6.13.1.patch
A    trunk/make/linux/patches/2.6.13.1/360-netfilter-ipv6-Backport-ip6t_REJECT-from-2.6.14.patch
A    trunk/make/linux/patches/2.6.13.1/011-mips_boot.patch
A    trunk/make/linux/patches/2.6.13.1/900-mute_printk_speedup.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.DHCP_MASQUERADE.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.congestion_BIC.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.wrong_BUG_ON.patch
A    trunk/make/linux/patches/2.6.13.1/120-capi-missing-compiler-includes.patch
A    trunk/make/linux/patches/2.6.13.1/999-ip_tables_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.request_key_auth-memleak.patch
A    trunk/make/linux/patches/2.6.13.1/102-squashfs3.3_lzma.patch
A    trunk/make/linux/patches/2.6.13.1/04.40
A    trunk/make/linux/patches/2.6.13.1/04.40/makefile.lib.patch
A    trunk/make/linux/patches/2.6.13.1/04.40/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/710-scall32.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.MPOL_F_VERIFY.patch
A    trunk/make/linux/patches/2.6.13.1/200-ip_conntrack.patch
A    trunk/make/linux/patches/2.6.13.1/04.80
A    trunk/make/linux/patches/2.6.13.1/04.80/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.80/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.putname_memleak.patch
A    trunk/make/linux/patches/2.6.13.1/130-Add-missing-linux-compiler.h-include-to-blkpg.h.patch
A    trunk/make/linux/patches/2.6.13.1/04.49
A    trunk/make/linux/patches/2.6.13.1/04.49/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.49/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.13.1/04.67
A    trunk/make/linux/patches/2.6.13.1/04.67/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.13.1/04.67/600-cpmac-ioctl.patch
A    trunk/make/linux/patches/2.6.32
A    trunk/make/linux/patches/2.6.32/7330_05.20
A    trunk/make/linux/patches/2.6.32/7330_05.20/003-pppoatm.c.patch
A    trunk/make/linux/patches/2.6.32/7330_05.20/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.32/7330_05.20/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.32/7330_05.20/690-no_system-load-1_messages.patch
A    trunk/make/linux/patches/2.6.32/7330_05.20/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.32/300-skbuff-nf_conntrack.patch
A    trunk/make/linux/patches/2.6.32/230-cifs_revert_slow_work.patch
A    trunk/make/linux/patches/2.6.32/022-mips_use_generic_thread_info_allocator.patch
A    trunk/make/linux/patches/2.6.32/3370_05.21
A    trunk/make/linux/patches/2.6.32/3370_05.21/003-pppoatm.c.patch
A    trunk/make/linux/patches/2.6.32/3370_05.21/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.32/3370_05.21/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.32/3370_05.21/690-no_system-load-1_messages.patch
A    trunk/make/linux/patches/2.6.32/3370_05.21/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.32/400-ftdi-smartmouse.patch
A    trunk/make/linux/patches/2.6.32/7360_05.20
A    trunk/make/linux/patches/2.6.32/7360_05.20/003-pppoatm.c.patch
A    trunk/make/linux/patches/2.6.32/7360_05.20/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.32/7360_05.20/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.32/7360_05.20/690-no_system-load-1_messages.patch
A    trunk/make/linux/patches/2.6.32/7360_05.20/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.32/7270_05.21
A    trunk/make/linux/patches/2.6.32/7270_05.21/003-pppoatm.c.patch
A    trunk/make/linux/patches/2.6.32/7270_05.21/500-fix_7270v1_hw_config.patch
A    trunk/make/linux/patches/2.6.32/7270_05.21/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.32/7270_05.21/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.32/7270_05.21/690-no_system-load-1_messages.patch
A    trunk/make/linux/patches/2.6.32/7270_05.21/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.32/009-jffs-fix-min-max-confusion.patch
A    trunk/make/linux/patches/2.6.32/7270_05.50
A    trunk/make/linux/patches/2.6.32/7270_05.50/500-fix_7270v1_hw_config.patch
A    trunk/make/linux/patches/2.6.32/7270_05.50/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.32/7270_05.50/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.32/7270_05.50/690-no_system-load-1_messages.patch
A    trunk/make/linux/patches/2.6.32/7270_05.50/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.32/012-extra_optimization.patch
A    trunk/make/linux/patches/2.6.32/023-mips-fix-kexec.patch
A    trunk/make/linux/patches/2.6.32/300-mppe-mppc.patch
A    trunk/make/linux/patches/2.6.32/120-capi-missing-compiler-includes.patch
A    trunk/make/linux/patches/2.6.32/100-evaloader.patch
A    trunk/make/linux/patches/2.6.32/010-shell_bash.patch
A    trunk/make/linux/patches/2.6.32/540-export_scsi_headers.patch
A    trunk/make/linux/patches/2.6.32/401-ftdi-working.patch
A    trunk/make/linux/patches/2.6.32/115-netfilter_recent_reap.patch
A    trunk/make/linux/patches/2.6.32/710-scall32.patch
A    trunk/make/linux/patches/2.6.32/199-remove_double_hash_conntrack.patch
A    trunk/make/linux/patches/2.6.32/002-usb_musb_kconfig.patch
A    trunk/make/linux/patches/2.6.32/001-drivers_dsl_kconfig.patch
A    trunk/make/linux/patches/2.6.32/100-netfilter_layer7_2.21.patch
A    trunk/make/linux/patches/2.6.32/530-scsi_user_space.patch
A    trunk/make/linux/patches/2.6.32/203-slab_maxsize.patch.dont-use
A    trunk/make/linux/patches/2.6.19.2
A    trunk/make/linux/patches/2.6.19.2/350-kernel-2.6.18-2.6.19-layer7-2.9.patch
A    trunk/make/linux/patches/2.6.19.2/752-usb-ehci--fix-isochronous-URB-leak.patch
A    trunk/make/linux/patches/2.6.19.2/001-fix_mixed_rules.patch
A    trunk/make/linux/patches/2.6.19.2/770-revert--endpoint-attributes-track-altsetting-changes.patch
A    trunk/make/linux/patches/2.6.19.2/9999-missing_skb_truesize_increment.patch
A    trunk/make/linux/patches/2.6.19.2/209-mini_fo.patch
A    trunk/make/linux/patches/2.6.19.2/900-mute_dma_busy__caused_by_dvb_device.patch
A    trunk/make/linux/patches/2.6.19.2/998-fix-unifdef.patch
A    trunk/make/linux/patches/2.6.19.2/757-fix-device_add-error-path.patch
A    trunk/make/linux/patches/2.6.19.2/7270_04.86
A    trunk/make/linux/patches/2.6.19.2/7270_04.86/110-hwrev_list.patch
A    trunk/make/linux/patches/2.6.19.2/7270_04.86/200-7570_mtd.patch
A    trunk/make/linux/patches/2.6.19.2/7270_04.86/120-remove_fusiv.patch
A    trunk/make/linux/patches/2.6.19.2/100-evaloader.patch
A    trunk/make/linux/patches/2.6.19.2/130-revert_skbuff_changes.patch
A    trunk/make/linux/patches/2.6.19.2/99999-enable_syslog.patch
A    trunk/make/linux/patches/2.6.19.2/310-autofs.patch
A    trunk/make/linux/patches/2.6.19.2/762-debug-device_register.patch!
A    trunk/make/linux/patches/2.6.19.2/761-debug-device_add.patch!
A    trunk/make/linux/patches/2.6.19.2/753-V4L-DVB-9605--usb-urb_fix-memory-leak.patch
A    trunk/make/linux/patches/2.6.19.2/500-compcache-0.5.4-ramzswap-xvmalloc.patch
A    trunk/make/linux/patches/2.6.19.2/520-lib-lzo.patch
A    trunk/make/linux/patches/2.6.19.2/758-driver_core--dont-fail-attaching-device-if-cannot-be-bound.patch
A    trunk/make/linux/patches/2.6.19.2/751-as1352--fix-isochronous-usbfs-input.patch
A    trunk/make/linux/patches/2.6.19.2/760-debug-cpmac.patch
A    trunk/make/linux/patches/2.6.19.2/400-ftdi-smartmouse.patch
A    trunk/make/linux/patches/2.6.19.2/763-debug-usb_create_ep_files.patch!
A    trunk/make/linux/patches/2.6.19.2/754-Fix-memory-leak-on-Tx-data-path.patch
A    trunk/make/linux/patches/2.6.19.2/510-compcache-0.5.4-swap_notifier_generic.patch
A    trunk/make/linux/patches/2.6.19.2/290-revert_ppp_generic.patch
A    trunk/make/linux/patches/2.6.19.2/320-kernel-2.6.19-ipp2p-0.82.patch
A    trunk/make/linux/patches/2.6.19.2/300-mppe-mppc.patch
A    trunk/make/linux/patches/2.6.19.2/120-capi-missing-compiler-includes.patch
A    trunk/make/linux/patches/2.6.19.2/210-jff2nfsexport.patch
A    trunk/make/linux/patches/2.6.19.2/110-missing_limits_header.patch
A    trunk/make/linux/patches/2.6.19.2/755-fix-cleanup-when-failing-device_add.patch
A    trunk/make/linux/patches/2.6.19.2/102-squashfs3.3_lzma.patch
A    trunk/make/linux/patches/2.6.19.2/756-dont_add-del_interfaces__register-unregister_them.patch
A    trunk/make/linux/patches/2.6.19.2/710-scall32.patch
A    trunk/make/linux/patches/2.6.19.2/764-debug-usb_create_sysfs_intf_files.patch!
A    trunk/make/linux/patches/2.6.19.2/200-ip_conntrack.patch
A    trunk/make/linux/patches/2.6.19.2/201-ip_conntrack_rtsp.2.6.19.2.patch
A    trunk/make/linux/patches/2.6.19.2/530-scsi_user_space.patch
A    trunk/make/linux/patches/2.6.19.2/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/patches/2.6.28
A    trunk/make/linux/patches/2.6.28/001-fix_mixed_rules.patch
A    trunk/make/linux/patches/2.6.28/006-gcc4_inline_fix.patch
A    trunk/make/linux/patches/2.6.28/209-mini_fo.patch
A    trunk/make/linux/patches/2.6.28/350-kernel-2.6.25-2.6.28-layer7-2.22.patch
A    trunk/make/linux/patches/2.6.28/215-mini_fo_2.6.30.patch
A    trunk/make/linux/patches/2.6.28/7390_05.50
A    trunk/make/linux/patches/2.6.28/7390_05.50/150-expand-module_alloc_size_list.patch
A    trunk/make/linux/patches/2.6.28/7390_05.50/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.28/7390_05.50/004-extra_optimization.patch
A    trunk/make/linux/patches/2.6.28/7390_05.50/120-missing_fusiv_optimization.patch
A    trunk/make/linux/patches/2.6.28/216-mini_fo_locking.patch
A    trunk/make/linux/patches/2.6.28/310-autofs4-2.6.28-v5-update-20090903.patch
A    trunk/make/linux/patches/2.6.28/213-mini_fo_2.6.27_fixes.patch
A    trunk/make/linux/patches/2.6.28/100-evaloader.patch
A    trunk/make/linux/patches/2.6.28/401-ftdi-working.patch
A    trunk/make/linux/patches/2.6.28/402-ftdi-bump-to-1-5-0.patch
A    trunk/make/linux/patches/2.6.28/550-fix_swapfile_on_fat.patch
A    trunk/make/linux/patches/2.6.28/200-AVM_fixes.patch
A    trunk/make/linux/patches/2.6.28/300-skbuff-nf_conntrack.patch
A    trunk/make/linux/patches/2.6.28/400-ftdi-smartmouse.patch
A    trunk/make/linux/patches/2.6.28/027-mips-freestanding.patch
A    trunk/make/linux/patches/2.6.28/028-slab_maxsize.patch.dont-use
A    trunk/make/linux/patches/2.6.28/210-mini_fo_2.6.25_fixes.patch
A    trunk/make/linux/patches/2.6.28/7390_05.21
A    trunk/make/linux/patches/2.6.28/7390_05.21/200-no_avm_extras.patch
A    trunk/make/linux/patches/2.6.28/7390_05.21/004-extra_optimization.patch
A    trunk/make/linux/patches/2.6.28/7390_05.21/120-missing_fusiv_optimization.patch
A    trunk/make/linux/patches/2.6.28/290-revert_ppp_generic.patch
A    trunk/make/linux/patches/2.6.28/011-mips_boot.patch
A    trunk/make/linux/patches/2.6.28/212-mini_fo_2.6.26_fixes.patch
A    trunk/make/linux/patches/2.6.28/300-mppe-mppc.patch
A    trunk/make/linux/patches/2.6.28/690-no_system-load-1_messages.patch
A    trunk/make/linux/patches/2.6.28/120-capi-missing-compiler-includes.patch
A    trunk/make/linux/patches/2.6.28/010-shell_bash.patch
A    trunk/make/linux/patches/2.6.28/540-export_scsi_headers.patch
A    trunk/make/linux/patches/2.6.28/024-mips_disable_fpu.patch
A    trunk/make/linux/patches/2.6.28/710-scall32.patch
A    trunk/make/linux/patches/2.6.28/217-mini_fo_dentry_check.patch
A    trunk/make/linux/patches/2.6.28/211-mini_fo_2.6.25_dentry_open_war.patch
A    trunk/make/linux/patches/2.6.28/300-fix_byteorder_header.patch
A    trunk/make/linux/patches/2.6.28/025-mips_fix_loading_of_modules_with_unresolved_weak_sy.patch
A    trunk/make/linux/patches/2.6.28/530-scsi_user_space.patch
A    trunk/make/linux/patches/2.6.28/531-scsi_user_space.patch
A    trunk/make/linux/patches/2.6.28/999-cpmac_debug_sk_buff.patch
A    trunk/make/linux/Config.ohio.5140_04.67
A    trunk/make/linux/Config.ar7.04.30
A    trunk/make/linux/Config.ar7.04.40
A    trunk/make/linux/Config.ar7.04.33
A    trunk/make/linux/Config.vr9.3370_05.21
A    trunk/make/linux/Config.ur8.7270_05.21
A    trunk/make/linux/Config.vr9.7360_05.20
A    trunk/make/linux/Config.ur8.7270_05.50
A    trunk/make/linux/Config.ohio.04.33
A    trunk/make/linux/Config.ohio.04.70
A    trunk/make/linux/Config.ohio.04.80
A    trunk/make/linux/Config.ar7.04.49
A    trunk/make/linux/Config.ohio.04.57
A    trunk/make/linux/Config.ar9.7330_05.20
A    trunk/make/linux/Config.ohio.r7203
A    trunk/make/dosfstools
A    trunk/make/dosfstools/external.files
A    trunk/make/dosfstools/dosfstools.mk
A    trunk/make/dosfstools/external.in
A    trunk/make/dosfstools/patches
A    trunk/make/dosfstools/patches/100-fix_missing_blksszget.patch
A    trunk/make/dosfstools/patches/110-consider-freetz-LFS-flags.patch
A    trunk/make/dosfstools/Config.in
A    trunk/make/inadyn-mt
A    trunk/make/inadyn-mt/files
A    trunk/make/inadyn-mt/files/.language
A    trunk/make/inadyn-mt/files/root
A    trunk/make/inadyn-mt/files/root/usr
A    trunk/make/inadyn-mt/files/root/usr/lib
A    trunk/make/inadyn-mt/files/root/usr/lib/cgi-bin
A    trunk/make/inadyn-mt/files/root/usr/lib/cgi-bin/inadyn-mt.cgi
A    trunk/make/inadyn-mt/files/root/etc
A    trunk/make/inadyn-mt/files/root/etc/default.inadyn-mt
A    trunk/make/inadyn-mt/files/root/etc/default.inadyn-mt/inadyn-mt.cfg
A    trunk/make/inadyn-mt/files/root/etc/init.d
A    trunk/make/inadyn-mt/files/root/etc/init.d/rc.inadyn-mt
A    trunk/make/inadyn-mt/inadyn-mt.mk
A    trunk/make/inadyn-mt/patches
A    trunk/make/inadyn-mt/patches/200-multiservices.patch
A    trunk/make/inadyn-mt/Config.in
A    trunk/make/autofs
A    trunk/make/autofs/files
A    trunk/make/autofs/files/.language
A    trunk/make/autofs/files/root
A    trunk/make/autofs/files/root/usr
A    trunk/make/autofs/files/root/usr/lib
A    trunk/make/autofs/files/root/usr/lib/cgi-bin
A    trunk/make/autofs/files/root/usr/lib/cgi-bin/autofs.cgi
A    trunk/make/autofs/files/root/etc
A    trunk/make/autofs/files/root/etc/auto.master
A    trunk/make/autofs/files/root/etc/default.autofs
A    trunk/make/autofs/files/root/etc/default.autofs/autofs.cfg
A    trunk/make/autofs/files/root/etc/default.autofs/auto_conf.def
A    trunk/make/autofs/files/root/etc/init.d
A    trunk/make/autofs/files/root/etc/init.d/rc.autofs
A    trunk/make/autofs/external.files
A    trunk/make/autofs/external.services
A    trunk/make/autofs/autofs.mk
A    trunk/make/autofs/external.in
A    trunk/make/autofs/patches
A    trunk/make/autofs/patches/004_autofs-5.0.5-special-case-cifs-escapes.patch
A    trunk/make/autofs/patches/033_autofs-5.0.5-fix-random-selection-for-host-on-different-network.patch
A    trunk/make/autofs/patches/056_autofs-5.0.5-fix-direct-map-not-updating-on-reread.patch
A    trunk/make/autofs/patches/014_autofs-5.0.5-check-for-path-mount-location-in-generic-module.patch
A    trunk/make/autofs/patches/039_autofs-5.0.5-dont-check-null-cache-on-expire.patch
A    trunk/make/autofs/patches/003_autofs-5.0.4-add-mount-wait-parameter.patch
A    trunk/make/autofs/patches/005_autofs-5.0.5-fix-libxml2-workaround-configure.patch
A    trunk/make/autofs/patches/057_autofs-5.0.5-add-external-bind-method.patch
A    trunk/make/autofs/patches/021_autofs-5.0.5-fix-disable-timeout.patch
A    trunk/make/autofs/patches/046_autofs-5.0.5-remove-extra-read-master-map-call.patch
A    trunk/make/autofs/patches/060_autofs-5.0.5-fix-submount-shutdown-wait.patch
A    trunk/make/autofs/patches/038_autofs-5.0.5-fix-parse_sun-module-init.patch
A    trunk/make/autofs/patches/008_autofs-5.0.5-fix-stale-init-for-file-map-instance.patch
A    trunk/make/autofs/patches/035_autofs-5.0.5-dont-hold-lock-for-simple-mounts.patch
A    trunk/make/autofs/patches/028_autofs-5.0.5-add-locality-as-valid-ldap-master-map-attribute-fix.patch
A    trunk/make/autofs/patches/051_autofs-5.0.5-make-verbose-mode-a-little-less-verbose.patch
A    trunk/make/autofs/patches/017_autofs-5.0.5-fix-memory-leak-on-reload.patch
A    trunk/make/autofs/patches/013_autofs-5.0.5-fix-pidof-init-script-usage.patch
A    trunk/make/autofs/patches/016_autofs-5.0.5-fix-rpc-large-export-list.patch
A    trunk/make/autofs/patches/002_autofs-5.0.5-refactor-ldap-sasl-bind.patch
A    trunk/make/autofs/patches/150-uclibc-0_9_28-compat.patch
A    trunk/make/autofs/patches/025_autofs-5.0.5-fix-get-qdn-fail.patch
A    trunk/make/autofs/patches/032_autofs-5.0.5-add-autofs_ldap_auth_conf-man-page.patch
A    trunk/make/autofs/patches/140-conf.patch
A    trunk/make/autofs/patches/009_autofs-5.0.5-fix-ext4-fsck-at-mount.patch
A    trunk/make/autofs/patches/007_autofs-5.0.5-fix-backwards-ifndef-INET6.patch
A    trunk/make/autofs/patches/043_autofs-5.0.5-check-each-dc-server.patch
A    trunk/make/autofs/patches/022_autofs-5.0.5-fix-strdup-return-value-check.patch
A    trunk/make/autofs/patches/011_autofs-5.0.5-make-documentation-for-set-log-priority-clearer.patch
A    trunk/make/autofs/patches/018_autofs-5.0.5-update-kernel-patches-2.6.18-and-2.6.19.patch
A    trunk/make/autofs/patches/012_autofs-5.0.5-fix-timeout-in-connect_nb.patch
A    trunk/make/autofs/patches/045_autofs-5.0.5-remove-state-machine-timed-wait.patch
A    trunk/make/autofs/patches/006_autofs-5.0.5-more-code-analysis-corrections.patch
A    trunk/make/autofs/patches/058_autofs-5.0.5-fix-add-simple-bind-auth.patch
A    trunk/make/autofs/patches/037_autofs-5.0.5-fix-wildcard-map-entry-match.patch
A    trunk/make/autofs/patches/026_autofs-5.0.5-fix-ampersand-escape-in-auto-smb.patch
A    trunk/make/autofs/patches/034_autofs-5.0.5-make-redhat-init-script-more-lsb-compliant.patch
A    trunk/make/autofs/patches/020_autofs-5.0.5-fix-random-selection-option.patch
A    trunk/make/autofs/patches/027_autofs-5.0.5-add-locality-as-valid-ldap-master-map-attribute.patch
A    trunk/make/autofs/patches/042_autofs-5.0.5-mapent-becomes-negative-during-lookup.patch
A    trunk/make/autofs/patches/031_autofs-5.0.5-fix-master-map-source-server-unavialable-handling.patch
A    trunk/make/autofs/patches/015_autofs-5.0.5-dont-fail-mount-on-access-fail.patch
A    trunk/make/autofs/patches/044_autofs-5.0.5-fix-negative-cache-included-map-lookup.patch
A    trunk/make/autofs/patches/048_autofs-5.0.5-fix-error-handing-in-do_mount_indirect.patch
A    trunk/make/autofs/patches/024_autofs-5.0.5-add-sasl-mutex-callbacks.patch
A    trunk/make/autofs/patches/110-fix_cross_compilation.patch
A    trunk/make/autofs/patches/059_autofs-5.0.5-add-dump-maps-option.patch
A    trunk/make/autofs/patches/120-fix_nfs_header_dir.patch
A    trunk/make/autofs/patches/047_autofs-5.0.5-fix-fix-cache_init-on-source-re-read.patch
A    trunk/make/autofs/patches/052_autofs-5.0.5-remove-ERR_remove_state-openssl-call.patch
A    trunk/make/autofs/patches/041_autofs-5.0.5-fix-cache_init-on-source-re-read.patch
A    trunk/make/autofs/patches/029_autofs-5.0.5-make-nfs4-default-for-redhat-replicated-selection.patch
A    trunk/make/autofs/patches/036_autofs-5.0.5-fix-remount-locking.patch
A    trunk/make/autofs/patches/040_autofs-5.0.5-fix-null-cache-race.patch
A    trunk/make/autofs/patches/055_autofs-5.0.4-always-read-file-maps-mount-lookup-map-read-fix.patch
A    trunk/make/autofs/patches/130-remove_ypclnt_header.patch
A    trunk/make/autofs/patches/019_autofs-5.0.5-dont-connect-at-ldap-lookup-module-init.patch
A    trunk/make/autofs/patches/053_autofs-5.0.5-fix-restart.patch
A    trunk/make/autofs/patches/049_autofs-5.0.5-expire-thread-use-pending-mutex.patch
A    trunk/make/autofs/patches/030_autofs-5.0.5-add-simple-bind-auth.patch
A    trunk/make/autofs/patches/001_autofs-5.0.5-fix-included-map-read-fail-handling.patch
A    trunk/make/autofs/patches/050_autofs-5.0.5-include-krb5-library.patch
A    trunk/make/autofs/patches/054_autofs-5.0.5-fix-status-privilege-error.patch
A    trunk/make/autofs/patches/010_autofs-5.0.5-dont-use-master_lex_destroy-to-clear-parse-buffer.patch
A    trunk/make/autofs/patches/023_autofs-5.0.5-fix-reconnect-get-base-dn.patch
A    trunk/make/autofs/Config.in
A    trunk/make/spindown-cgi
A    trunk/make/spindown-cgi/files
A    trunk/make/spindown-cgi/files/.language
A    trunk/make/spindown-cgi/files/root
A    trunk/make/spindown-cgi/files/root/usr
A    trunk/make/spindown-cgi/files/root/usr/lib
A    trunk/make/spindown-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/spindown-cgi/files/root/usr/lib/cgi-bin/spindown.cgi
A    trunk/make/spindown-cgi/files/root/usr/bin
A    trunk/make/spindown-cgi/files/root/usr/bin/spindown
A    trunk/make/spindown-cgi/files/root/etc
A    trunk/make/spindown-cgi/files/root/etc/default.spindown
A    trunk/make/spindown-cgi/files/root/etc/default.spindown/spindown.cfg
A    trunk/make/spindown-cgi/files/root/etc/init.d
A    trunk/make/spindown-cgi/files/root/etc/init.d/rc.spindown
A    trunk/make/spindown-cgi/files/README
A    trunk/make/spindown-cgi/spindown-cgi.mk
A    trunk/make/spindown-cgi/Config.in
A    trunk/make/rcapid
A    trunk/make/rcapid/files
A    trunk/make/rcapid/files/.language
A    trunk/make/rcapid/files/root
A    trunk/make/rcapid/files/root/usr
A    trunk/make/rcapid/files/root/usr/lib
A    trunk/make/rcapid/files/root/usr/lib/cgi-bin
A    trunk/make/rcapid/files/root/usr/lib/cgi-bin/rcapid.cgi
A    trunk/make/rcapid/files/root/etc
A    trunk/make/rcapid/files/root/etc/default.rcapid
A    trunk/make/rcapid/files/root/etc/default.rcapid/rcapid.cfg
A    trunk/make/rcapid/files/root/etc/default.rcapid/rcapid.inetd
A    trunk/make/rcapid/files/root/etc/init.d
A    trunk/make/rcapid/files/root/etc/init.d/rc.rcapid
A    trunk/make/rcapid/files/README
A    trunk/make/rcapid/patches
A    trunk/make/rcapid/patches/100-makefile.in.patch
A    trunk/make/rcapid/rcapid.mk
A    trunk/make/rcapid/Config.in
A    trunk/make/slurm
A    trunk/make/slurm/external.files
A    trunk/make/slurm/external.in
A    trunk/make/slurm/patches
A    trunk/make/slurm/patches/001-no_host_curses.patch
A    trunk/make/slurm/slurm.mk
A    trunk/make/slurm/Config.in
A    trunk/make/ldd
A    trunk/make/ldd/external.files
A    trunk/make/ldd/external.in
A    trunk/make/ldd/patches
A    trunk/make/ldd/patches/030-null-check.upstream.patch
A    trunk/make/ldd/patches/010-open_3rd_param.upstream.patch
A    trunk/make/ldd/patches/020-lib_segfault.upstream.patch
A    trunk/make/ldd/ldd.mk
A    trunk/make/ldd/Config.in
A    trunk/make/gw6
A    trunk/make/gw6/files
A    trunk/make/gw6/files/.language
A    trunk/make/gw6/files/root
A    trunk/make/gw6/files/root/usr
A    trunk/make/gw6/files/root/usr/share
A    trunk/make/gw6/files/root/usr/share/gw6
A    trunk/make/gw6/files/root/usr/share/gw6/template
A    trunk/make/gw6/files/root/usr/share/gw6/template/linux.sh
A    trunk/make/gw6/files/root/usr/lib
A    trunk/make/gw6/files/root/usr/lib/cgi-bin
A    trunk/make/gw6/files/root/usr/lib/cgi-bin/gw6.cgi
A    trunk/make/gw6/files/root/etc
A    trunk/make/gw6/files/root/etc/init.d
A    trunk/make/gw6/files/root/etc/init.d/rc.gw6
A    trunk/make/gw6/files/root/etc/default.gw6
A    trunk/make/gw6/files/root/etc/default.gw6/gw6.cfg
A    trunk/make/gw6/files/root/etc/default.gw6/gw6_conf
A    trunk/make/gw6/external.files
A    trunk/make/gw6/external.services
A    trunk/make/gw6/external.in
A    trunk/make/gw6/patches
A    trunk/make/gw6/patches/020-build_system.patch
A    trunk/make/gw6/patches/010-no_tests.patch
A    trunk/make/gw6/patches/040-fix_out_of_bounds_access.patch
A    trunk/make/gw6/patches/030-missing_includes.patch
A    trunk/make/gw6/gw6.mk
A    trunk/make/gw6/Config.in
A    trunk/make/pppd
A    trunk/make/pppd/files
A    trunk/make/pppd/files/root
A    trunk/make/pppd/files/root/etc
A    trunk/make/pppd/files/root/etc/ppp
A    trunk/make/pppd/files/root/etc/init.d
A    trunk/make/pppd/files/root/etc/init.d/rc.pppd
A    trunk/make/pppd/files/root/etc/default.pppd
A    trunk/make/pppd/files/root/etc/default.pppd/chap_secrets.def
A    trunk/make/pppd/files/root/etc/default.pppd/pppd_ip-down
A    trunk/make/pppd/files/root/etc/default.pppd/pap_secrets.def
A    trunk/make/pppd/files/root/etc/default.pppd/pppd_options.def
A    trunk/make/pppd/files/root/etc/default.pppd/pppd_ip-up
A    trunk/make/pppd/files/README
A    trunk/make/pppd/external.files
A    trunk/make/pppd/external.in
A    trunk/make/pppd/patches
A    trunk/make/pppd/patches/206-radius_config.patch
A    trunk/make/pppd/patches/204-opt_flags.patch
A    trunk/make/pppd/patches/100-debian_close_dev_ppp.patch
A    trunk/make/pppd/patches/113-debian_ipv6_accept_remote.patch
A    trunk/make/pppd/patches/101-debian_ip-up_option.patch
A    trunk/make/pppd/patches/209-compensate_time_change.patch
A    trunk/make/pppd/patches/105-debian_pppoatm_cleanup.patch
A    trunk/make/pppd/patches/208-no_exponential_timeout.patch
A    trunk/make/pppd/patches/203-no_strip.patch
A    trunk/make/pppd/patches/201-mppe_mppc_1.1.patch
A    trunk/make/pppd/patches/107-debian_stripMSdomain.patch
A    trunk/make/pppd/patches/109-debian_demand.patch
A    trunk/make/pppd/patches/104-debian_fix_linkpidfile.patch
A    trunk/make/pppd/patches/111-debian_fix_null_pppdb.patch
A    trunk/make/pppd/patches/210-lcp_mtu_max.patch
A    trunk/make/pppd/patches/112-debian_dont_exit_pado_timeout.patch
A    trunk/make/pppd/patches/102-debian_readable_connerrs.patch
A    trunk/make/pppd/patches/108-debian_defaultroute.patch
A    trunk/make/pppd/patches/200-makefile.patch
A    trunk/make/pppd/patches/202-no_atm.patch
A    trunk/make/pppd/patches/300-filter-pcap-includes-lib.patch
A    trunk/make/pppd/patches/110-debian_adaptive_echos.patch
A    trunk/make/pppd/patches/099-debian_git_20100307.patch
A    trunk/make/pppd/pppd.mk
A    trunk/make/pppd/Config.in
A    trunk/make/ffmpeg
A    trunk/make/ffmpeg/external.in.libs
A    trunk/make/ffmpeg/Config.in.libs
A    trunk/make/ffmpeg/Makefile.in
A    trunk/make/ffmpeg/external.files
A    trunk/make/ffmpeg/patches
A    trunk/make/ffmpeg/patches/120-IPv6_defines.patch
A    trunk/make/ffmpeg/patches/110-quiet.patch
A    trunk/make/ffmpeg/ffmpeg.mk
A    trunk/make/dnsmasq
A    trunk/make/dnsmasq/files
A    trunk/make/dnsmasq/files/.language
A    trunk/make/dnsmasq/files/root
A    trunk/make/dnsmasq/files/root/usr
A    trunk/make/dnsmasq/files/root/usr/lib
A    trunk/make/dnsmasq/files/root/usr/lib/cgi-bin
A    trunk/make/dnsmasq/files/root/usr/lib/cgi-bin/dnsmasq.cgi
A    trunk/make/dnsmasq/files/root/etc
A    trunk/make/dnsmasq/files/root/etc/init.d
A    trunk/make/dnsmasq/files/root/etc/init.d/rc.dnsmasq
A    trunk/make/dnsmasq/files/root/etc/default.dnsmasq
A    trunk/make/dnsmasq/files/root/etc/default.dnsmasq/dnsmasq.cfg
A    trunk/make/dnsmasq/files/root/etc/default.dnsmasq/dnsmasq_extra.def
A    trunk/make/dnsmasq/files/root/etc/default.dnsmasq/dnsmasq_conf
A    trunk/make/dnsmasq/patches
A    trunk/make/dnsmasq/patches/120-tftp-dir-check.patch
A    trunk/make/dnsmasq/patches/100-multid-leases.patch
A    trunk/make/dnsmasq/patches/110-largefile.patch
A    trunk/make/dnsmasq/patches/020-do-fork.patch
A    trunk/make/dnsmasq/Config.in
A    trunk/make/dnsmasq/dnsmasq.mk
A    trunk/make/vpnc
A    trunk/make/vpnc/files
A    trunk/make/vpnc/files/root
A    trunk/make/vpnc/files/root/usr
A    trunk/make/vpnc/files/root/usr/lib
A    trunk/make/vpnc/files/root/usr/lib/cgi-bin
A    trunk/make/vpnc/files/root/usr/lib/cgi-bin/vpnc.cgi
A    trunk/make/vpnc/files/root/etc
A    trunk/make/vpnc/files/root/etc/init.d
A    trunk/make/vpnc/files/root/etc/init.d/rc.vpnc
A    trunk/make/vpnc/files/root/etc/default.vpnc
A    trunk/make/vpnc/files/root/etc/default.vpnc/vpnc.cfg
A    trunk/make/vpnc/files/root/etc/default.vpnc/vpnc-script
A    trunk/make/vpnc/files/root/etc/default.vpnc/vpnc_conf
A    trunk/make/vpnc/patches
A    trunk/make/vpnc/patches/01-cross.patch
A    trunk/make/vpnc/Config.in
A    trunk/make/vpnc/vpnc.mk
A    trunk/make/wget
A    trunk/make/wget/external.files
A    trunk/make/wget/external.in
A    trunk/make/wget/patches
A    trunk/make/wget/patches/010-openssl_zlib_dependency_fix.patch
A    trunk/make/wget/patches/200-no_compile_link_strings.patch
A    trunk/make/wget/patches/101-drop-libuuid-dependency.patch
A    trunk/make/wget/patches/020-consider-with-zlib.patch
A    trunk/make/wget/patches/030-static_linking_workaround.patch
A    trunk/make/wget/patches/102-drop-libpcre-dependency.patch
A    trunk/make/wget/Config.in
A    trunk/make/wget/wget.mk
A    trunk/make/rtmpdump
A    trunk/make/rtmpdump/external.files
A    trunk/make/rtmpdump/external.in
A    trunk/make/rtmpdump/Config.in
A    trunk/make/rtmpdump/rtmpdump.mk
A    trunk/make/bittwist
A    trunk/make/bittwist/bittwist.mk
A    trunk/make/bittwist/external.files
A    trunk/make/bittwist/external.in
A    trunk/make/bittwist/patches
A    trunk/make/bittwist/patches/100_ifaddrs_SIOCGIFHWADDR.patch
A    trunk/make/bittwist/patches/120-uClibc-0.9.28-conflicting-inet_aton-prototype.patch
A    trunk/make/bittwist/patches/110-Makefile.patch
A    trunk/make/bittwist/Config.in
A    trunk/make/opendd
A    trunk/make/opendd/opendd.mk
A    trunk/make/opendd/files
A    trunk/make/opendd/files/.language
A    trunk/make/opendd/files/root
A    trunk/make/opendd/files/root/usr
A    trunk/make/opendd/files/root/usr/lib
A    trunk/make/opendd/files/root/usr/lib/cgi-bin
A    trunk/make/opendd/files/root/usr/lib/cgi-bin/opendd.cgi
A    trunk/make/opendd/files/root/etc
A    trunk/make/opendd/files/root/etc/init.d
A    trunk/make/opendd/files/root/etc/init.d/rc.opendd
A    trunk/make/opendd/files/root/etc/default.opendd
A    trunk/make/opendd/files/root/etc/default.opendd/opendd.save
A    trunk/make/opendd/files/root/etc/default.opendd/opendd.cfg
A    trunk/make/opendd/files/root/etc/default.opendd/opendd_pem.def
A    trunk/make/opendd/files/root/etc/default.opendd/opendd_conf
A    trunk/make/opendd/files/root/etc/onlinechanged
A    trunk/make/opendd/files/root/etc/onlinechanged/20-opendd
A    trunk/make/opendd/external.files
A    trunk/make/opendd/external.services
A    trunk/make/opendd/external.in
A    trunk/make/opendd/patches
A    trunk/make/opendd/patches/150_opendd_h.patch
A    trunk/make/opendd/patches/130_setproctitle_c.patch
A    trunk/make/opendd/patches/170_smtpserverport.patch
A    trunk/make/opendd/patches/200_add-sender.patch
A    trunk/make/opendd/patches/120_setproctitle_h.patch
A    trunk/make/opendd/patches/100_Makefile.patch
A    trunk/make/opendd/patches/160_get_ip.patch
A    trunk/make/opendd/patches/140_opendd_c.patch
A    trunk/make/opendd/patches/110_util_c.patch
A    trunk/make/opendd/Config.in
A    trunk/make/deco
A    trunk/make/deco/deco.mk
A    trunk/make/deco/files
A    trunk/make/deco/files/root
A    trunk/make/deco/files/root/usr
A    trunk/make/deco/files/root/usr/lib
A    trunk/make/deco/files/root/usr/lib/deco
A    trunk/make/deco/files/root/usr/lib/deco/profile
A    trunk/make/deco/files/root/usr/lib/deco/menu
A    trunk/make/deco/external.files
A    trunk/make/deco/external.in
A    trunk/make/deco/patches
A    trunk/make/deco/patches/100-tty.c.patch
A    trunk/make/deco/Config.in
A    trunk/make/ntfs
A    trunk/make/ntfs/external.in.libs
A    trunk/make/ntfs/ntfs.mk
A    trunk/make/ntfs/Config.in.libs
A    trunk/make/ntfs/external.files
A    trunk/make/ntfs/patches
A    trunk/make/ntfs/patches/300-dont_messup_up_config_cache_with_host_linker_characteristics.patch
A    trunk/make/ntfs/patches/100-no_libintlh.patch
A    trunk/make/mini-snmpd
A    trunk/make/mini-snmpd/mini-snmpd.mk
A    trunk/make/mini-snmpd/external.files
A    trunk/make/mini-snmpd/external.in
A    trunk/make/mini-snmpd/patches
A    trunk/make/mini-snmpd/patches/100-cross_compile.patch
A    trunk/make/mini-snmpd/Config.in
A    trunk/make/python-pyopenssl
A    trunk/make/python-pyopenssl/python-pyopenssl.mk
A    trunk/make/python-pyopenssl/patches
A    trunk/make/python-pyopenssl/patches/010-no_tests.patch
A    trunk/make/python-pyopenssl/Config.in
A    trunk/make/iftop
A    trunk/make/iftop/external.files
A    trunk/make/iftop/external.in
A    trunk/make/iftop/iftop.mk
A    trunk/make/iftop/patches
A    trunk/make/iftop/patches/110_cfgfile_c.patch
A    trunk/make/iftop/patches/130_ui_c.patch
A    trunk/make/iftop/patches/100_ether_h.patch
A    trunk/make/iftop/patches/120_options_c.patch
A    trunk/make/iftop/Config.in
A    trunk/make/smartmontools
A    trunk/make/smartmontools/files
A    trunk/make/smartmontools/files/.language
A    trunk/make/smartmontools/files/root
A    trunk/make/smartmontools/files/root/usr
A    trunk/make/smartmontools/files/root/usr/lib
A    trunk/make/smartmontools/files/root/usr/lib/cgi-bin
A    trunk/make/smartmontools/files/root/usr/lib/cgi-bin/smartmontools
A    trunk/make/smartmontools/files/root/usr/lib/cgi-bin/smartmontools/status.cgi
A    trunk/make/smartmontools/files/root/etc
A    trunk/make/smartmontools/files/root/etc/init.d
A    trunk/make/smartmontools/files/root/etc/init.d/rc.smartmontools
A    trunk/make/smartmontools/external.files
A    trunk/make/smartmontools/external.services
A    trunk/make/smartmontools/external.in
A    trunk/make/smartmontools/smartmontools.mk
A    trunk/make/smartmontools/Config.in
A    trunk/make/strace
A    trunk/make/strace/external.files
A    trunk/make/strace/external.in
A    trunk/make/strace/patches
A    trunk/make/strace/patches/030-lseek.patch
A    trunk/make/strace/patches/100-add-TRACE_IPC-to-sys_ipc.patch
A    trunk/make/strace/patches/010-disabled-largefile-syscalls.patch
A    trunk/make/strace/patches/040-missing_HAVE_LONG_LONG_OFF_T.patch
A    trunk/make/strace/patches/099-Fix-MIPS-syscall-entries.patch
A    trunk/make/strace/patches/050-no__long_long_off_t__long_long_rlim_t.patch
A    trunk/make/strace/patches/020-statfs64.patch
A    trunk/make/strace/patches/060-BLKTRACESTOP.patch
A    trunk/make/strace/strace.mk
A    trunk/make/strace/Config.in
A    trunk/make/debootstrap
A    trunk/make/debootstrap/files
A    trunk/make/debootstrap/files/root
A    trunk/make/debootstrap/files/root/usr
A    trunk/make/debootstrap/files/root/usr/share
A    trunk/make/debootstrap/files/root/usr/share/debootstrap
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/devices.tar.gz
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/sid
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/squeeze
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/etch
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/lenny
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/natty
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/lucid
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/maverick
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/etch-m68k
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/karmic
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/hardy
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/jaunty
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/stable
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/wheezy
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/gutsy
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/testing
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/unstable
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/intrepid
A    trunk/make/debootstrap/files/root/usr/share/debootstrap/functions
A    trunk/make/debootstrap/files/root/usr/sbin
A    trunk/make/debootstrap/files/root/usr/sbin/debootstrap
A    trunk/make/debootstrap/files/README
A    trunk/make/debootstrap/patches
A    trunk/make/debootstrap/src
A    trunk/make/debootstrap/src/pkgdetails.c
A    trunk/make/debootstrap/src/Makefile
A    trunk/make/debootstrap/Config.in
A    trunk/make/debootstrap/debootstrap.mk
A    trunk/make/tcpproxy
A    trunk/make/tcpproxy/external.files
A    trunk/make/tcpproxy/external.in
A    trunk/make/tcpproxy/Config.in
A    trunk/make/tcpproxy/tcpproxy.mk
A    trunk/make/collectd
A    trunk/make/collectd/collectd.mk
A    trunk/make/collectd/files
A    trunk/make/collectd/files/.language
A    trunk/make/collectd/files/root
A    trunk/make/collectd/files/root/usr
A    trunk/make/collectd/files/root/usr/share
A    trunk/make/collectd/files/root/usr/share/collectd
A    trunk/make/collectd/files/root/usr/share/collectd/generate_graphs
A    trunk/make/collectd/files/root/usr/lib
A    trunk/make/collectd/files/root/usr/lib/cgi-bin
A    trunk/make/collectd/files/root/usr/lib/cgi-bin/collectd
A    trunk/make/collectd/files/root/usr/lib/cgi-bin/collectd/view.cgi
A    trunk/make/collectd/files/root/usr/lib/cgi-bin/collectd.cgi
A    trunk/make/collectd/files/root/usr/mww
A    trunk/make/collectd/files/root/usr/mww/graph
A    trunk/make/collectd/files/root/etc
A    trunk/make/collectd/files/root/etc/init.d
A    trunk/make/collectd/files/root/etc/init.d/rc.collectd
A    trunk/make/collectd/files/root/etc/default.collectd
A    trunk/make/collectd/files/root/etc/default.collectd/collectd.cfg
A    trunk/make/collectd/files/root/etc/default.collectd/collectd_conf.def
A    trunk/make/collectd/external.files
A    trunk/make/collectd/external.services
A    trunk/make/collectd/external.in
A    trunk/make/collectd/patches
A    trunk/make/collectd/patches/300-allow-plugin-symlinks.patch
A    trunk/make/collectd/patches/200-fritzbox-plugin-buildsystem.patch
A    trunk/make/collectd/patches/100-system_libltdl.patch
A    trunk/make/collectd/patches/210-fritzbox-plugin-src.patch
A    trunk/make/collectd/patches/130-PLUGINDIR.patch
A    trunk/make/collectd/patches/110-unnecessary_tests.patch
A    trunk/make/collectd/patches/120-wrong-dependencies.patch
A    trunk/make/collectd/Config.in
A    trunk/make/mcabber
A    trunk/make/mcabber/mcabber.mk
A    trunk/make/mcabber/files
A    trunk/make/mcabber/files/.language
A    trunk/make/mcabber/files/root
A    trunk/make/mcabber/files/root/usr
A    trunk/make/mcabber/files/root/usr/lib
A    trunk/make/mcabber/files/root/usr/lib/cgi-bin
A    trunk/make/mcabber/files/root/usr/lib/cgi-bin/mcabber.cgi
A    trunk/make/mcabber/files/root/etc
A    trunk/make/mcabber/files/root/etc/init.d
A    trunk/make/mcabber/files/root/etc/init.d/rc.mcabber
A    trunk/make/mcabber/files/root/etc/default.mcabber
A    trunk/make/mcabber/files/root/etc/default.mcabber/mcabber_conf
A    trunk/make/mcabber/files/root/etc/default.mcabber/mcabber.save
A    trunk/make/mcabber/files/root/etc/default.mcabber/mcabber.cfg
A    trunk/make/mcabber/patches
A    trunk/make/mcabber/patches/100-libm.patch
A    trunk/make/mcabber/patches/200-ldl.patch
A    trunk/make/mcabber/Config.in
A    trunk/make/dropbear
A    trunk/make/dropbear/files
A    trunk/make/dropbear/files/.language
A    trunk/make/dropbear/files/root
A    trunk/make/dropbear/files/root/usr
A    trunk/make/dropbear/files/root/usr/lib
A    trunk/make/dropbear/files/root/usr/lib/cgi-bin
A    trunk/make/dropbear/files/root/usr/lib/cgi-bin/dropbear.cgi
A    trunk/make/dropbear/files/root/usr/bin
A    trunk/make/dropbear/files/root/usr/bin/scp
A    trunk/make/dropbear/files/root/usr/bin/dropbearkey
A    trunk/make/dropbear/files/root/usr/bin/ssh
A    trunk/make/dropbear/files/root/usr/sbin
A    trunk/make/dropbear/files/root/usr/sbin/dropbear
A    trunk/make/dropbear/files/root/etc
A    trunk/make/dropbear/files/root/etc/default.dropbear
A    trunk/make/dropbear/files/root/etc/default.dropbear/dropbear.inetd
A    trunk/make/dropbear/files/root/etc/default.dropbear/dropbear.cfg
A    trunk/make/dropbear/files/root/etc/init.d
A    trunk/make/dropbear/files/root/etc/init.d/rc.dropbear
A    trunk/make/dropbear/external.files
A    trunk/make/dropbear/dropbear.mk
A    trunk/make/dropbear/external.services
A    trunk/make/dropbear/external.in
A    trunk/make/dropbear/patches
A    trunk/make/dropbear/patches/100-root-login-only.patch
A    trunk/make/dropbear/patches/140-disable_assert.patch
A    trunk/make/dropbear/patches/130-standalone.patch
A    trunk/make/dropbear/patches/111_configure_hostlookup.patch
A    trunk/make/dropbear/patches/200-lcrypt_bsdfix.patch
A    trunk/make/dropbear/patches/250-login-limits.patch
A    trunk/make/dropbear/patches/210-pidfile.patch
A    trunk/make/dropbear/patches/300-extra-FLAGS.patch
A    trunk/make/dropbear/patches/003-uninit-defect.patch
A    trunk/make/dropbear/patches/001-charo-io.patch
A    trunk/make/dropbear/patches/110-options.h.patch
A    trunk/make/dropbear/Config.in
A    trunk/make/sane-backends
A    trunk/make/sane-backends/config-update.pl
A    trunk/make/sane-backends/files
A    trunk/make/sane-backends/files/.language
A    trunk/make/sane-backends/files/root
A    trunk/make/sane-backends/files/root/usr
A    trunk/make/sane-backends/files/root/usr/lib
A    trunk/make/sane-backends/files/root/usr/lib/cgi-bin
A    trunk/make/sane-backends/files/root/usr/lib/cgi-bin/sane-backends.cgi
A    trunk/make/sane-backends/files/root/etc
A    trunk/make/sane-backends/files/root/etc/default.sane-backends
A    trunk/make/sane-backends/files/root/etc/default.sane-backends/saned_conf
A    trunk/make/sane-backends/files/root/etc/default.sane-backends/sane-backends.inetd
A    trunk/make/sane-backends/files/root/etc/default.sane-backends/sane-backends.save
A    trunk/make/sane-backends/files/root/etc/default.sane-backends/sane-backends.cfg
A    trunk/make/sane-backends/files/root/etc/init.d
A    trunk/make/sane-backends/files/root/etc/init.d/rc.sane-backends
A    trunk/make/sane-backends/files/TODO
A    trunk/make/sane-backends/files/README
A    trunk/make/sane-backends/external.files
A    trunk/make/sane-backends/sane-backends.in
A    trunk/make/sane-backends/external.services
A    trunk/make/sane-backends/sane-backends.mk
A    trunk/make/sane-backends/external.in
A    trunk/make/sane-backends/patches
A    trunk/make/sane-backends/patches/011-no_host_cups.patch
A    trunk/make/sane-backends/patches/300-libtool_sys_lib_search_path_spec.patch
A    trunk/make/sane-backends/patches/100-no_docs_and_translations.patch
A    trunk/make/sane-backends/patches/401-debian_missing_pthreads.patch
A    trunk/make/sane-backends/patches/201-backends_lib_path.patch
A    trunk/make/sane-backends/patches/010-dont-add-host-include-path.patch
A    trunk/make/sane-backends/patches/403-debian_libsane_deps.patch
A    trunk/make/sane-backends/patches/020-non-i386-qcam.patch
A    trunk/make/sane-backends/patches/200-config_path.patch
A    trunk/make/sane-backends/patches/402-debian_frontends_libs.patch
A    trunk/make/sane-backends/Config.in
A    trunk/make/sispmctl
A    trunk/make/sispmctl/files
A    trunk/make/sispmctl/files/.language
A    trunk/make/sispmctl/files/root
A    trunk/make/sispmctl/files/root/usr
A    trunk/make/sispmctl/files/root/usr/lib
A    trunk/make/sispmctl/files/root/usr/lib/cgi-bin
A    trunk/make/sispmctl/files/root/usr/lib/cgi-bin/sispmctl.cgi
A    trunk/make/sispmctl/files/root/etc
A    trunk/make/sispmctl/files/root/etc/default.sispmctl
A    trunk/make/sispmctl/files/root/etc/default.sispmctl/sispmctl.cfg
A    trunk/make/sispmctl/files/root/etc/init.d
A    trunk/make/sispmctl/files/root/etc/init.d/rc.sispmctl
A    trunk/make/sispmctl/files/README
A    trunk/make/sispmctl/external.files
A    trunk/make/sispmctl/external.services
A    trunk/make/sispmctl/sispmctl.mk
A    trunk/make/sispmctl/external.in
A    trunk/make/sispmctl/Config.in
A    trunk/make/wol-cgi
A    trunk/make/wol-cgi/files
A    trunk/make/wol-cgi/files/.language
A    trunk/make/wol-cgi/files/root
A    trunk/make/wol-cgi/files/root/usr
A    trunk/make/wol-cgi/files/root/usr/www
A    trunk/make/wol-cgi/files/root/usr/www/cgi-bin
A    trunk/make/wol-cgi/files/root/usr/www/cgi-bin/freetz_wol
A    trunk/make/wol-cgi/files/root/usr/lib
A    trunk/make/wol-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/wol-cgi/files/root/usr/lib/cgi-bin/wol.cgi
A    trunk/make/wol-cgi/files/root/usr/bin
A    trunk/make/wol-cgi/files/root/usr/bin/freetz_wol
A    trunk/make/wol-cgi/files/root/usr/bin/webcfg-wol
A    trunk/make/wol-cgi/files/root/usr/mww-wol
A    trunk/make/wol-cgi/files/root/usr/mww-wol/style
A    trunk/make/wol-cgi/files/root/usr/mww-wol/images
A    trunk/make/wol-cgi/files/root/usr/mww-wol/cgi-bin
A    trunk/make/wol-cgi/files/root/usr/mww-wol/cgi-bin/index.cgi
A    trunk/make/wol-cgi/files/root/usr/mww-wol/cgi-bin/wake.cgi
A    trunk/make/wol-cgi/files/root/etc
A    trunk/make/wol-cgi/files/root/etc/default.wol
A    trunk/make/wol-cgi/files/root/etc/default.wol/wol.cfg
A    trunk/make/wol-cgi/files/root/etc/default.wol/wol.inetd
A    trunk/make/wol-cgi/files/root/etc/default.wol/httpd-wol_conf
A    trunk/make/wol-cgi/files/root/etc/init.d
A    trunk/make/wol-cgi/files/root/etc/init.d/rc.wol
A    trunk/make/wol-cgi/wol-cgi.mk
A    trunk/make/wol-cgi/Config.in
A    trunk/make/digitemp
A    trunk/make/digitemp/external.files
A    trunk/make/digitemp/external.in
A    trunk/make/digitemp/patches
A    trunk/make/digitemp/patches/200-linebuf.patch
A    trunk/make/digitemp/patches/100-cflags.patch
A    trunk/make/digitemp/digitemp.mk
A    trunk/make/digitemp/Config.in
A    trunk/make/polipo
A    trunk/make/polipo/files
A    trunk/make/polipo/files/.language
A    trunk/make/polipo/files/root
A    trunk/make/polipo/files/root/usr
A    trunk/make/polipo/files/root/usr/lib
A    trunk/make/polipo/files/root/usr/lib/cgi-bin
A    trunk/make/polipo/files/root/usr/lib/cgi-bin/polipo.cgi
A    trunk/make/polipo/files/root/etc
A    trunk/make/polipo/files/root/etc/default.polipo
A    trunk/make/polipo/files/root/etc/default.polipo/polipo.cfg
A    trunk/make/polipo/files/root/etc/default.polipo/polipo_conf
A    trunk/make/polipo/files/root/etc/init.d
A    trunk/make/polipo/files/root/etc/init.d/rc.polipo
A    trunk/make/polipo/external.files
A    trunk/make/polipo/external.services
A    trunk/make/polipo/external.in
A    trunk/make/polipo/polipo.mk
A    trunk/make/polipo/Config.in
A    trunk/make/ripmime
A    trunk/make/ripmime/external.files
A    trunk/make/ripmime/external.in
A    trunk/make/ripmime/ripmime.mk
A    trunk/make/ripmime/Config.in
A    trunk/make/lsof
A    trunk/make/lsof/external.files
A    trunk/make/lsof/external.in
A    trunk/make/lsof/patches
A    trunk/make/lsof/patches/030-LFS_controlled_by_freetz.patch
A    trunk/make/lsof/patches/040-crosscompiling-strftime-test.patch
A    trunk/make/lsof/patches/005-IPv6.patch
A    trunk/make/lsof/patches/010-configure_quiet.patch
A    trunk/make/lsof/patches/001-AR_RANLIB.patch
A    trunk/make/lsof/patches/020-remove-susvlegacy-funcs.patch
A    trunk/make/lsof/patches/002-noportmap.patch
A    trunk/make/lsof/lsof.mk
A    trunk/make/lsof/Config.in
A    trunk/make/gnu-make
A    trunk/make/gnu-make/external.files
A    trunk/make/gnu-make/external.in
A    trunk/make/gnu-make/Config.in
A    trunk/make/gnu-make/gnu-make.mk
A    trunk/make/noip
A    trunk/make/noip/files
A    trunk/make/noip/files/root
A    trunk/make/noip/files/root/var
A    trunk/make/noip/files/root/var/tmp
A    trunk/make/noip/files/root/var/tmp/noip.update
A    trunk/make/noip/patches
A    trunk/make/noip/patches/201-noip2c.patch
A    trunk/make/noip/patches/101-makefile.patch
A    trunk/make/noip/Config.in
A    trunk/make/noip/noip.mk
A    trunk/make/sablevm-sdk
A    trunk/make/sablevm-sdk/files
A    trunk/make/sablevm-sdk/files/root
A    trunk/make/sablevm-sdk/files/root/usr
A    trunk/make/sablevm-sdk/files/root/usr/share
A    trunk/make/sablevm-sdk/files/root/usr/share/sablevm-classpath
A    trunk/make/sablevm-sdk/files/root/usr/share/sablevm-classpath/.gitignore
A    trunk/make/sablevm-sdk/files/root/usr/lib
A    trunk/make/sablevm-sdk/files/root/usr/lib/security
A    trunk/make/sablevm-sdk/files/root/usr/lib/security/classpath.security
A    trunk/make/sablevm-sdk/files/root/usr/lib/sablevm-classpath
A    trunk/make/sablevm-sdk/files/root/usr/lib/sablevm-classpath/.gitignore
A    trunk/make/sablevm-sdk/external.files
A    trunk/make/sablevm-sdk/external.in
A    trunk/make/sablevm-sdk/patches
A    trunk/make/sablevm-sdk/patches/001-heap_size.patch
A    trunk/make/sablevm-sdk/patches/020-missing_popt_dependency.patch
A    trunk/make/sablevm-sdk/patches/010-link_binary_against_pthread.patch
A    trunk/make/sablevm-sdk/Config.in
A    trunk/make/sablevm-sdk/example
A    trunk/make/sablevm-sdk/example/HelloWorld.class
A    trunk/make/sablevm-sdk/example/HelloWorld.java
A    trunk/make/sablevm-sdk/mini.classlist
A    trunk/make/sablevm-sdk/sablevm-sdk.mk
A    trunk/make/bip
A    trunk/make/bip/bip.mk
A    trunk/make/bip/files
A    trunk/make/bip/files/.language
A    trunk/make/bip/files/root
A    trunk/make/bip/files/root/usr
A    trunk/make/bip/files/root/usr/lib
A    trunk/make/bip/files/root/usr/lib/cgi-bin
A    trunk/make/bip/files/root/usr/lib/cgi-bin/bip.cgi
A    trunk/make/bip/files/root/etc
A    trunk/make/bip/files/root/etc/init.d
A    trunk/make/bip/files/root/etc/init.d/rc.bip
A    trunk/make/bip/files/root/etc/default.bip
A    trunk/make/bip/files/root/etc/default.bip/bip_conf
A    trunk/make/bip/files/root/etc/default.bip/bip.cfg
A    trunk/make/bip/files/root/etc/default.bip/bip_user_conf.def
A    trunk/make/bip/files/root/etc/default.bip/bip_user.conf
A    trunk/make/bip/external.files
A    trunk/make/bip/external.services
A    trunk/make/bip/external.in
A    trunk/make/bip/patches
A    trunk/make/bip/patches/010-remove-unnecessary-conflicting-declaration.patch
A    trunk/make/bip/patches/110-no_libintl.patch
A    trunk/make/bip/patches/100-freenode-quiet.patch
A    trunk/make/bip/Config.in
A    trunk/make/owfs
A    trunk/make/owfs/external.files
A    trunk/make/owfs/owfs.mk
A    trunk/make/owfs/external.in
A    trunk/make/owfs/patches
A    trunk/make/owfs/patches/120-invalid-tags-ltmain.patch
A    trunk/make/owfs/patches/110-rpath-in-extralibs-flags.patch
A    trunk/make/owfs/patches/100-owphp-irritating-warning.patch
A    trunk/make/owfs/Config.in
A    trunk/make/bird
A    trunk/make/bird/files
A    trunk/make/bird/files/.language
A    trunk/make/bird/files/root
A    trunk/make/bird/files/root/usr
A    trunk/make/bird/files/root/usr/lib
A    trunk/make/bird/files/root/usr/lib/cgi-bin
A    trunk/make/bird/files/root/usr/lib/cgi-bin/bird.cgi
A    trunk/make/bird/files/root/etc
A    trunk/make/bird/files/root/etc/default.bird
A    trunk/make/bird/files/root/etc/default.bird/bird_conf.def
A    trunk/make/bird/files/root/etc/default.bird/bird.cfg
A    trunk/make/bird/files/root/etc/init.d
A    trunk/make/bird/files/root/etc/init.d/rc.bird
A    trunk/make/bird/files/README
A    trunk/make/bird/external.files
A    trunk/make/bird/external.services
A    trunk/make/bird/bird.mk
A    trunk/make/bird/external.in
A    trunk/make/bird/patches
A    trunk/make/bird/patches/003_birdc-fix-buffer-overflow.patch
A    trunk/make/bird/patches/102_rules_in.patch
A    trunk/make/bird/patches/002_netlink.patch
A    trunk/make/bird/patches/101_disable-default-debug.patch
A    trunk/make/bird/patches/100_fix-debugging-paths.patch
A    trunk/make/bird/patches/004_birdc-include-more-headers.patch
A    trunk/make/bird/Config.in
A    trunk/make/privoxy
A    trunk/make/privoxy/files
A    trunk/make/privoxy/files/.language
A    trunk/make/privoxy/files/root
A    trunk/make/privoxy/files/root/usr
A    trunk/make/privoxy/files/root/usr/lib
A    trunk/make/privoxy/files/root/usr/lib/cgi-bin
A    trunk/make/privoxy/files/root/usr/lib/cgi-bin/privoxy.cgi
A    trunk/make/privoxy/files/root/etc
A    trunk/make/privoxy/files/root/etc/default.privoxy
A    trunk/make/privoxy/files/root/etc/default.privoxy/filter.def
A    trunk/make/privoxy/files/root/etc/default.privoxy/privoxy_conf
A    trunk/make/privoxy/files/root/etc/default.privoxy/action.def
A    trunk/make/privoxy/files/root/etc/default.privoxy/privoxy.save
A    trunk/make/privoxy/files/root/etc/default.privoxy/privoxy_loadeasylist
A    trunk/make/privoxy/files/root/etc/default.privoxy/privoxy.cfg
A    trunk/make/privoxy/files/root/etc/init.d
A    trunk/make/privoxy/files/root/etc/init.d/rc.privoxy
A    trunk/make/privoxy/files/README
A    trunk/make/privoxy/external.files
A    trunk/make/privoxy/external.services
A    trunk/make/privoxy/privoxy.mk
A    trunk/make/privoxy/external.in
A    trunk/make/privoxy/patches
A    trunk/make/privoxy/patches/100-missing_strptime_prototype.patch
A    trunk/make/privoxy/patches/110-dont_link_libnsl.patch
A    trunk/make/privoxy/Config.in
A    trunk/make/lua
A    trunk/make/lua/external.in.libs
A    trunk/make/lua/Config.in.libs
A    trunk/make/lua/external.files
A    trunk/make/lua/lua.mk
A    trunk/make/lua/patches
A    trunk/make/lua/patches/130-optimization_flags.patch
A    trunk/make/lua/patches/020-shared-liblua_LUA_API.patch
A    trunk/make/lua/patches/030-archindependent-bytecode.patch
A    trunk/make/lua/patches/200-lua-path.patch
A    trunk/make/lua/patches/020-shared-liblua.patch
A    trunk/make/lua/patches/100-noreadline.patch
A    trunk/make/netsnmp
A    trunk/make/netsnmp/files
A    trunk/make/netsnmp/files/.language
A    trunk/make/netsnmp/files/root
A    trunk/make/netsnmp/files/root/usr
A    trunk/make/netsnmp/files/root/usr/lib
A    trunk/make/netsnmp/files/root/usr/lib/cgi-bin
A    trunk/make/netsnmp/files/root/usr/lib/cgi-bin/netsnmp.cgi
A    trunk/make/netsnmp/files/root/etc
A    trunk/make/netsnmp/files/root/etc/init.d
A    trunk/make/netsnmp/files/root/etc/init.d/rc.netsnmp
A    trunk/make/netsnmp/files/root/etc/default.netsnmp
A    trunk/make/netsnmp/files/root/etc/default.netsnmp/netsnmp.cfg
A    trunk/make/netsnmp/files/root/etc/default.netsnmp/snmpd_conf.def
A    trunk/make/netsnmp/files/README
A    trunk/make/netsnmp/patches
A    trunk/make/netsnmp/patches/140-no_ldconfig.patch
A    trunk/make/netsnmp/patches/750-ieee802dot11.patch
A    trunk/make/netsnmp/patches/050-no_SIOCMIIPHY_syscall.patch
A    trunk/make/netsnmp/patches/120-debian-searchdirs.patch
A    trunk/make/netsnmp/patches/200-openssl_test_fix.patch
A    trunk/make/netsnmp/patches/100-debian-statistics.patch
A    trunk/make/netsnmp/patches/300-fix_ASN_INT64.patch
A    trunk/make/netsnmp/patches/010-disable_inline.patch
A    trunk/make/netsnmp/patches/110-debian-makefiles.patch
A    trunk/make/netsnmp/patches/130-debian-extramibs.patch
A    trunk/make/netsnmp/patches/150-ldflags.patch
A    trunk/make/netsnmp/Config.in
A    trunk/make/netsnmp/netsnmp.mk
A    trunk/make/syslogd-cgi
A    trunk/make/syslogd-cgi/files
A    trunk/make/syslogd-cgi/files/.language
A    trunk/make/syslogd-cgi/files/root
A    trunk/make/syslogd-cgi/files/root/usr
A    trunk/make/syslogd-cgi/files/root/usr/lib
A    trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin/syslogd
A    trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin/syslogd/log.cgi
A    trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin/syslogd.cgi
A    trunk/make/syslogd-cgi/files/root/etc
A    trunk/make/syslogd-cgi/files/root/etc/init.d
A    trunk/make/syslogd-cgi/files/root/etc/init.d/rc.syslogd
A    trunk/make/syslogd-cgi/files/root/etc/default.syslogd
A    trunk/make/syslogd-cgi/files/root/etc/default.syslogd/syslogd.cfg
A    trunk/make/syslogd-cgi/Config.in
A    trunk/make/syslogd-cgi/syslogd-cgi.mk
A    trunk/make/rrdtool
A    trunk/make/rrdtool/external.in.libs
A    trunk/make/rrdtool/Config.in.libs
A    trunk/make/rrdtool/Makefile.in
A    trunk/make/rrdtool/files
A    trunk/make/rrdtool/files/root
A    trunk/make/rrdtool/files/root/usr
A    trunk/make/rrdtool/files/root/usr/share
A    trunk/make/rrdtool/files/root/usr/share/rrdtool
A    trunk/make/rrdtool/files/root/usr/share/rrdtool/fonts
A    trunk/make/rrdtool/files/root/usr/share/rrdtool/fonts/DejaVuSansMono-Roman.ttf
A    trunk/make/rrdtool/files/README
A    trunk/make/rrdtool/external.files
A    trunk/make/rrdtool/patches
A    trunk/make/rrdtool/patches/010-dont-add-host-include-paths.patch
A    trunk/make/rrdtool/rrdtool.mk
A    trunk/make/nc6
A    trunk/make/nc6/external.files
A    trunk/make/nc6/external.in
A    trunk/make/nc6/Config.in
A    trunk/make/nc6/nc6.mk
A    trunk/make/inadyn-opendns
A    trunk/make/inadyn-opendns/files
A    trunk/make/inadyn-opendns/files/.language
A    trunk/make/inadyn-opendns/files/root
A    trunk/make/inadyn-opendns/files/root/usr
A    trunk/make/inadyn-opendns/files/root/usr/lib
A    trunk/make/inadyn-opendns/files/root/usr/lib/cgi-bin
A    trunk/make/inadyn-opendns/files/root/usr/lib/cgi-bin/inadyn-opendns.cgi
A    trunk/make/inadyn-opendns/files/root/etc
A    trunk/make/inadyn-opendns/files/root/etc/init.d
A    trunk/make/inadyn-opendns/files/root/etc/init.d/rc.inadyn-opendns
A    trunk/make/inadyn-opendns/files/root/etc/default.inadyn-opendns
A    trunk/make/inadyn-opendns/files/root/etc/default.inadyn-opendns/inadyn-opendns.cfg
A    trunk/make/inadyn-opendns/files/root/etc/default.inadyn-opendns/inadyn-opendns_conf
A    trunk/make/inadyn-opendns/patches
A    trunk/make/inadyn-opendns/patches/100-makefile.patch
A    trunk/make/inadyn-opendns/Config.in
A    trunk/make/inadyn-opendns/inadyn-opendns.mk
A    trunk/make/external.in
A    trunk/make/openntpd
A    trunk/make/openntpd/files
A    trunk/make/openntpd/files/.language
A    trunk/make/openntpd/files/root
A    trunk/make/openntpd/files/root/usr
A    trunk/make/openntpd/files/root/usr/lib
A    trunk/make/openntpd/files/root/usr/lib/cgi-bin
A    trunk/make/openntpd/files/root/usr/lib/cgi-bin/openntpd.cgi
A    trunk/make/openntpd/files/root/etc
A    trunk/make/openntpd/files/root/etc/init.d
A    trunk/make/openntpd/files/root/etc/init.d/rc.openntpd
A    trunk/make/openntpd/files/root/etc/default.openntpd
A    trunk/make/openntpd/files/root/etc/default.openntpd/openntpd.cfg
A    trunk/make/openntpd/files/root/etc/default.openntpd/openntpd_conf.def
A    trunk/make/openntpd/files/README.extension
A    trunk/make/openntpd/patches
A    trunk/make/openntpd/patches/110-TIK_extension.patch
A    trunk/make/openntpd/patches/101-adjtimex_linux.patch
A    trunk/make/openntpd/patches/102-save_freq_drift.patch
A    trunk/make/openntpd/patches/010-ar_fix.patch
A    trunk/make/openntpd/patches/011-missing_prototypes_fix.patch
A    trunk/make/openntpd/patches/200-warn-unsupp-servers.debian.patch
A    trunk/make/openntpd/Config.in
A    trunk/make/openntpd/openntpd.mk
A    trunk/make/smusbutil
A    trunk/make/smusbutil/patches
A    trunk/make/smusbutil/patches/more_devices.patch
A    trunk/make/smusbutil/patches/make_variables.patch
A    trunk/make/smusbutil/Config.in
A    trunk/make/smusbutil/smusbutil.mk
A    trunk/make/transmission-cgi
A    trunk/make/transmission-cgi/transmission-cgi.mk
A    trunk/make/transmission-cgi/files
A    trunk/make/transmission-cgi/files/.language
A    trunk/make/transmission-cgi/files/root
A    trunk/make/transmission-cgi/files/root/usr
A    trunk/make/transmission-cgi/files/root/usr/lib
A    trunk/make/transmission-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/transmission-cgi/files/root/usr/lib/cgi-bin/transmission.cgi
A    trunk/make/transmission-cgi/files/root/etc
A    trunk/make/transmission-cgi/files/root/etc/init.d
A    trunk/make/transmission-cgi/files/root/etc/init.d/rc.transmission
A    trunk/make/transmission-cgi/files/root/etc/default.transmission
A    trunk/make/transmission-cgi/files/root/etc/default.transmission/transmission.cfg
A    trunk/make/transmission-cgi/Config.in
A    trunk/make/bridge-utils
A    trunk/make/bridge-utils/bridge-utils.mk
A    trunk/make/bridge-utils/patches
A    trunk/make/bridge-utils/patches/100-Makefile.patch
A    trunk/make/bridge-utils/Config.in
A    trunk/make/nano
A    trunk/make/nano/nano.mk
A    trunk/make/nano/files
A    trunk/make/nano/files/.language
A    trunk/make/nano/files/root
A    trunk/make/nano/files/root/usr
A    trunk/make/nano/files/root/usr/bin
A    trunk/make/nano/files/root/usr/bin/mnano
A    trunk/make/nano/files/root/usr/bin/nnano
A    trunk/make/nano/files/root/etc
A    trunk/make/nano/files/root/etc/nanorc
A    trunk/make/nano/files/root/etc/init.d
A    trunk/make/nano/files/root/etc/init.d/rc.nano
A    trunk/make/nano/files/root/etc/.nanorc
A    trunk/make/nano/files/root/etc/default.nano
A    trunk/make/nano/files/root/etc/default.nano/nanorc.options-fancy
A    trunk/make/nano/files/root/etc/default.nano/nanorc.options-tiny
A    trunk/make/nano/files/root/etc/default.nano/nanorc.def
A    trunk/make/nano/files/README
A    trunk/make/nano/external.files
A    trunk/make/nano/external.in
A    trunk/make/nano/patches
A    trunk/make/nano/patches/100_no_libintl.patch
A    trunk/make/nano/patches/200_force-GNU-wordbounds.patch
A    trunk/make/nano/patches/300_fix-segfault-on-file-overwrite.patch
A    trunk/make/nano/Config.in
A    trunk/make/minidlna
A    trunk/make/minidlna/minidlna.mk
A    trunk/make/minidlna/files
A    trunk/make/minidlna/files/.language
A    trunk/make/minidlna/files/root
A    trunk/make/minidlna/files/root/usr
A    trunk/make/minidlna/files/root/usr/lib
A    trunk/make/minidlna/files/root/usr/lib/cgi-bin
A    trunk/make/minidlna/files/root/usr/lib/cgi-bin/minidlna.cgi
A    trunk/make/minidlna/files/root/etc
A    trunk/make/minidlna/files/root/etc/init.d
A    trunk/make/minidlna/files/root/etc/init.d/rc.minidlna
A    trunk/make/minidlna/files/root/etc/default.minidlna
A    trunk/make/minidlna/files/root/etc/default.minidlna/minidlna_conf
A    trunk/make/minidlna/files/root/etc/default.minidlna/minidlna.cfg
A    trunk/make/minidlna/external.files
A    trunk/make/minidlna/external.services
A    trunk/make/minidlna/external.in
A    trunk/make/minidlna/patches
A    trunk/make/minidlna/patches/120-ignore_own_pid.patch
A    trunk/make/minidlna/patches/110-include-fixes.patch
A    trunk/make/minidlna/patches/100-cross_compile.patch
A    trunk/make/minidlna/Config.in
A    trunk/make/busybox
A    trunk/make/busybox/busybox.mk
A    trunk/make/busybox/Makefile.in
A    trunk/make/busybox/generate.sh
A    trunk/make/busybox/Config.in.busybox
A    trunk/make/busybox/patches
A    trunk/make/busybox/patches/604-httpdstar.patch
A    trunk/make/busybox/patches/130-scripts_bash.patch
A    trunk/make/busybox/patches/470-insmod_search.patch
A    trunk/make/busybox/patches/000-busybox-1.21.0-platform.patch
A    trunk/make/busybox/patches/711-revert_crtscts_fix.patch
A    trunk/make/busybox/patches/480-copy_file_dev_node_fix.patch
A    trunk/make/busybox/patches/101-init_avoid_loop_opening_tty.patch
A    trunk/make/busybox/patches/110-wget_getopt_fix.patch
A    trunk/make/busybox/patches/000-busybox-1.21.0-mdev.patch
A    trunk/make/busybox/patches/220-httpd-pidfile.patch
A    trunk/make/busybox/patches/602-telnetd_intr.patch
A    trunk/make/busybox/patches/110-busybox-nolock-as-default.patch
A    trunk/make/busybox/patches/320-mdev_scan_file.patch
A    trunk/make/busybox/patches/440-httpd_chdir.patch
A    trunk/make/busybox/patches/000-busybox-1.21.0-xz.patch
A    trunk/make/busybox/patches/720-stun-ip.patch
A    trunk/make/busybox/patches/503-id_getgrouplist.patch
A    trunk/make/busybox/patches/712-revert_read_sighandler.patch
A    trunk/make/busybox/patches/100-autoconf.patch
A    trunk/make/busybox/patches/450-httpd_REDIRECT_STATUS.patch
A    trunk/make/busybox/patches/350-httpd_redir.patch
A    trunk/make/busybox/patches/605-blkid_mtdworkaround.patch
A    trunk/make/busybox/patches/620-findfs.patch
A    trunk/make/busybox/patches/210-telnet-close-on-exit.patch
A    trunk/make/busybox/patches/615-blkid_bogus_device_handling.patch
A    trunk/make/busybox/busybox.rebuild-subopts.mk.in
A    trunk/make/vim
A    trunk/make/vim/vim.mk
A    trunk/make/vim/files
A    trunk/make/vim/files/root
A    trunk/make/vim/files/root/usr
A    trunk/make/vim/files/root/usr/share
A    trunk/make/vim/files/root/usr/share/vim
A    trunk/make/vim/files/root/usr/share/vim/vimrc
A    trunk/make/vim/files/root/etc
A    trunk/make/vim/files/root/etc/vimrc
A    trunk/make/vim/external.files
A    trunk/make/vim/external.in
A    trunk/make/vim/patches
A    trunk/make/vim/patches/100-cross_compile.patch
A    trunk/make/vim/Config.in
A    trunk/make/python-pycurl
A    trunk/make/python-pycurl/python-pycurl.mk
A    trunk/make/python-pycurl/patches
A    trunk/make/python-pycurl/patches/020-dont_install_data_files.patch
A    trunk/make/python-pycurl/patches/010-no_static.openwrt.patch
A    trunk/make/python-pycurl/Config.in
A    trunk/make/fowsr
A    trunk/make/fowsr/external.files
A    trunk/make/fowsr/fowsr.mk
A    trunk/make/fowsr/external.in
A    trunk/make/fowsr/Config.in
A    trunk/make/bfusb
A    trunk/make/bfusb/bfusb.mk
A    trunk/make/bfusb/Config.in
A    trunk/make/wol
A    trunk/make/wol/external.files
A    trunk/make/wol/external.in
A    trunk/make/wol/wol.mk
A    trunk/make/wol/Config.in
A    trunk/make/cpmaccfg-cgi
A    trunk/make/cpmaccfg-cgi/files
A    trunk/make/cpmaccfg-cgi/files/root
A    trunk/make/cpmaccfg-cgi/files/root/usr
A    trunk/make/cpmaccfg-cgi/files/root/usr/share
A    trunk/make/cpmaccfg-cgi/files/root/usr/share/images
A    trunk/make/cpmaccfg-cgi/files/root/usr/share/images/avm-hinten.jpg
A    trunk/make/cpmaccfg-cgi/files/root/usr/lib
A    trunk/make/cpmaccfg-cgi/files/root/usr/lib/cgi-bin
A    trunk/make/cpmaccfg-cgi/files/root/usr/lib/cgi-bin/cpmaccfg.cgi
A    trunk/make/cpmaccfg-cgi/files/root/etc
A    trunk/make/cpmaccfg-cgi/files/root/etc/init.d
A    trunk/make/cpmaccfg-cgi/files/root/etc/init.d/rc.cpmaccfg
A    trunk/make/cpmaccfg-cgi/files/root/etc/default.cpmaccfg
A    trunk/make/cpmaccfg-cgi/files/root/etc/default.cpmaccfg/cpmaccfg.save
A    trunk/make/cpmaccfg-cgi/files/root/etc/default.cpmaccfg/cpmaccfg.cfg
A    trunk/make/cpmaccfg-cgi/files/README
A    trunk/make/cpmaccfg-cgi/cpmaccfg-cgi.mk
A    trunk/make/cpmaccfg-cgi/Config.in
A    trunk/make/knock
A    trunk/make/knock/files
A    trunk/make/knock/files/.language
A    trunk/make/knock/files/root
A    trunk/make/knock/files/root/usr
A    trunk/make/knock/files/root/usr/share
A    trunk/make/knock/files/root/usr/share/doc
A    trunk/make/knock/files/root/usr/share/doc/knock
A    trunk/make/knock/files/root/usr/share/doc/knock/knockd.conf
A    trunk/make/knock/files/root/usr/lib
A    trunk/make/knock/files/root/usr/lib/cgi-bin
A    trunk/make/knock/files/root/usr/lib/cgi-bin/knock.cgi
A    trunk/make/knock/files/root/etc
A    trunk/make/knock/files/root/etc/init.d
A    trunk/make/knock/files/root/etc/init.d/rc.knock
A    trunk/make/knock/files/root/etc/default.knock
A    trunk/make/knock/files/root/etc/default.knock/knock.cfg
A    trunk/make/knock/files/root/etc/default.knock/knockd_conf.def
A    trunk/make/knock/files/root/etc/onlinechanged
A    trunk/make/knock/files/root/etc/onlinechanged/knock
A    trunk/make/knock/external.files
A    trunk/make/knock/external.services
A    trunk/make/knock/external.in
A    trunk/make/knock/patches
A    trunk/make/knock/patches/100-debian-reap_child_procs.patch
A    trunk/make/knock/patches/101-smaller_snaplen.patch
A    trunk/make/knock/Config.in
A    trunk/make/knock/knock.mk
A    trunk/make/.gitignore
A    trunk/make/ngircd
A    trunk/make/ngircd/files
A    trunk/make/ngircd/files/.language
A    trunk/make/ngircd/files/root
A    trunk/make/ngircd/files/root/usr
A    trunk/make/ngircd/files/root/usr/lib
A    trunk/make/ngircd/files/root/usr/lib/cgi-bin
A    trunk/make/ngircd/files/root/usr/lib/cgi-bin/ngircd.cgi
A    trunk/make/ngircd/files/root/etc
A    trunk/make/ngircd/files/root/etc/init.d
A    trunk/make/ngircd/files/root/etc/init.d/rc.ngircd
A    trunk/make/ngircd/files/root/etc/default.ngircd
A    trunk/make/ngircd/files/root/etc/default.ngircd/ngircd.cfg
A    trunk/make/ngircd/files/root/etc/default.ngircd/ngircd_conf.def
A    trunk/make/ngircd/external.files
A    trunk/make/ngircd/external.services
A    trunk/make/ngircd/external.in
A    trunk/make/ngircd/patches
A    trunk/make/ngircd/patches/100_static_crypto.patch
A    trunk/make/ngircd/Config.in
A    trunk/make/ngircd/ngircd.mk
A    trunk/make/rrdstats
A    trunk/make/rrdstats/files
A    trunk/make/rrdstats/files/.language
A    trunk/make/rrdstats/files/root
A    trunk/make/rrdstats/files/root/usr
A    trunk/make/rrdstats/files/root/usr/mww-rrd
A    trunk/make/rrdstats/files/root/usr/mww-rrd/style
A    trunk/make/rrdstats/files/root/usr/mww-rrd/images
A    trunk/make/rrdstats/files/root/usr/mww-rrd/cgi-bin
A    trunk/make/rrdstats/files/root/usr/mww-rrd/cgi-bin/index.cgi
A    trunk/make/rrdstats/files/root/usr/mww-rrd/statpix
A    trunk/make/rrdstats/files/root/usr/mww-rrd/favicon.ico
A    trunk/make/rrdstats/files/root/usr/lib
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/stats.cgi
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/rrddt.cgi
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/index-stats.cgi
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/index-rrddt.cgi
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/main.cgi
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/dt-init.cgi
A    trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats.cgi
A    trunk/make/rrdstats/files/root/usr/bin
A    trunk/make/rrdstats/files/root/usr/bin/webcfg-rrd
A    trunk/make/rrdstats/files/root/usr/bin/rrdstats
A    trunk/make/rrdstats/files/root/usr/bin/webcfg-one
A    trunk/make/rrdstats/files/root/usr/mww-one
A    trunk/make/rrdstats/files/root/usr/mww-one/style
A    trunk/make/rrdstats/files/root/usr/mww-one/images
A    trunk/make/rrdstats/files/root/usr/mww-one/cgi-bin
A    trunk/make/rrdstats/files/root/usr/mww-one/cgi-bin/index.cgi
A    trunk/make/rrdstats/files/root/usr/mww-one/statpix
A    trunk/make/rrdstats/files/root/usr/mww-one/favicon.ico
A    trunk/make/rrdstats/files/root/usr/mww/statpix
A    trunk/make/rrdstats/files/root/etc
A    trunk/make/rrdstats/files/root/etc/init.d
A    trunk/make/rrdstats/files/root/etc/init.d/rc.rrdstats
A    trunk/make/rrdstats/files/root/etc/default.rrdstats
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/rrdstats.cfg
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/webcfg-rrd.inetd
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-conf.def
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/httpd-one_conf
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-alert.def
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-alias.def
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/httpd-rrd_conf
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-group.def
A    trunk/make/rrdstats/files/root/etc/default.rrdstats/webcfg-one.inetd
A    trunk/make/rrdstats/external.services
A    trunk/make/rrdstats/Config.in
A    trunk/make/rrdstats/rrdstats.mk
A    trunk/make/obexftp
A    trunk/make/obexftp/external.files
A    trunk/make/obexftp/external.in
A    trunk/make/obexftp/Config.in
A    trunk/make/obexftp/obexftp.mk
A    trunk/make/python-pycrypto
A    trunk/make/python-pycrypto/patches
A    trunk/make/python-pycrypto/patches/010-no_host_paths.openwrt.patch
A    trunk/make/python-pycrypto/patches/030-honor_freetz_compiler_flags.patch
A    trunk/make/python-pycrypto/patches/020-target_endianess.patch
A    trunk/make/python-pycrypto/patches/040-no_tests.patch
A    trunk/make/python-pycrypto/Config.in
A    trunk/make/python-pycrypto/python-pycrypto.mk
A    trunk/make/bash
A    trunk/make/bash/bash.mk
A    trunk/make/bash/external.files
A    trunk/make/bash/external.in
A    trunk/make/bash/patches
A    trunk/make/bash/patches/bash32-050.patch
A    trunk/make/bash/patches/bash32-051.patch
A    trunk/make/bash/patches/bash32-049.patch
A    trunk/make/bash/Config.in
 U   trunk
Checked out revision 10273.
freetz@freetz:~$ cd trunk
freetz@freetz:~/trunk$ make menuconfig
tools/freetz_download dl kconfig-v3.8.tar.xz git_archive@git://repo.or.cz/linux-2.6.git,scripts/basic,scripts/kconfig,scripts/Kbuild.include,scripts/Makefile.build,scripts/Makefile.host,scripts/Makefile.lib
--2013-03-18 15:48:47--  http://freetz.magenbrot.net/kconfig-v3.8.tar.xz
Resolving freetz.magenbrot.net (freetz.magenbrot.net)... 85.25.156.176
Connecting to freetz.magenbrot.net (freetz.magenbrot.net)|85.25.156.176|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 129520 (126K) [application/x-tar]
Saving to: `dl/kconfig-v3.8.tar.xz'
100%[=========================================================================================================================>] 129,520     83.7K/s   in 1.5s
2013-03-18 15:48:49 (83.7 KB/s) - `dl/kconfig-v3.8.tar.xz' saved [129520/129520]
Download succeeded - "http://freetz.magenbrot.net/kconfig-v3.8.tar.xz"  ->  saved to folder "dl"
tar -C /home/freetz/trunk/source/host-tools  -xf dl/kconfig-v3.8.tar.xz
for i in tools/make/patches/*.kconfig.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/kconfig-v3.8 $i; \
        done;
    applying patch file tools/make/patches/300-main_makefile.kconfig.patch
    patching file Makefile
    applying patch file tools/make/patches/310-fix_make.kconfig.patch
    patching file scripts/kconfig/Makefile
    applying patch file tools/make/patches/320-unchangable_style.kconfig.patch
    patching file scripts/kconfig/mconf.c
    applying patch file tools/make/patches/330-comment_style.kconfig.patch
    applying patch file tools/make/patches/340-fix_randconfig_choice.kconfig.patch
    patching file scripts/kconfig/confdata.c
    applying patch file tools/make/patches/350-do_not_select_unmet_direct_dependencies.kconfig.patch
    patching file scripts/kconfig/symbol.c
    applying patch file tools/make/patches/360-max_item_count_for_choice_dialog.kconfig.patch
    applying patch file tools/make/patches/370-save-hidden-prompts-to-file.kconfig.patch
    patching file scripts/kconfig/menu.c
touch /home/freetz/trunk/source/host-tools/kconfig-v3.8/.unpacked
make -j -C /home/freetz/trunk/source/host-tools/kconfig-v3.8 menuconfig
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/kconfig-v3.8'
make[2]: Entering directory `/home/freetz/trunk/source/host-tools/kconfig-v3.8'
  HOSTCC  scripts/basic/fixdep
make[2]: Leaving directory `/home/freetz/trunk/source/host-tools/kconfig-v3.8'
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/mconf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/lxdialog/checklist.o
  HOSTCC  scripts/kconfig/lxdialog/inputbox.o
  HOSTCC  scripts/kconfig/lxdialog/menubox.o
  HOSTCC  scripts/kconfig/lxdialog/textbox.o
  HOSTCC  scripts/kconfig/lxdialog/util.o
  HOSTCC  scripts/kconfig/lxdialog/yesno.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/mconf
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/kconfig-v3.8'
cp /home/freetz/trunk/source/host-tools/kconfig-v3.8/scripts/kconfig/mconf tools/config/mconf
# configuration written to .config
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
--2013-03-18 15:49:08--  ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270_v3/firmware/english/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image
           => `dl/fw/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image'
Resolving ftp.avm.de (ftp.avm.de)... 212.42.244.90
Connecting to ftp.avm.de (ftp.avm.de)|212.42.244.90|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done.    ==> PWD ... done.
==> TYPE I ... done.  ==> CWD (1) /fritz.box/fritzbox.fon_wlan_7270_v3/firmware/english ... done.
==> SIZE FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image ... 15697920
==> PASV ... done.    ==> RETR FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image ... done.
Length: 15697920 (15M) (unauthoritative)
100%[=========================================================================================================================>] 15,697,920   262K/s   in 36s
2013-03-18 15:49:45 (424 KB/s) - `dl/fw/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image' saved [15697920]
Download succeeded - "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270_v3/firmware/english/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image"  ->  saved to folder "dl/fw"
MD5 verified for dl/fw/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image: 0f2406d342e7ce0ce987296bca46cfe6
tools/freetz_download dl busybox-1.21.0.tar.bz2 http://www.busybox.net/downloads d613f2e4b580305c1de8691f7b84285e
--2013-03-18 15:49:45--  http://www.busybox.net/downloads/busybox-1.21.0.tar.bz2
Resolving www.busybox.net (www.busybox.net)... 140.211.167.224
Connecting to www.busybox.net (www.busybox.net)|140.211.167.224|:80... connected.
Length: 2200841 (2.1M) [application/x-bzip2]
Saving to: `dl/busybox-1.21.0.tar.bz2'
100%[=========================================================================================================================>] 2,200,841    280K/s   in 11s
2013-03-18 15:49:57 (202 KB/s) - `dl/busybox-1.21.0.tar.bz2' saved [2200841/2200841]
Download succeeded - "http://www.busybox.net/downloads/busybox-1.21.0.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/busybox-1.21.0.tar.bz2: d613f2e4b580305c1de8691f7b84285e
tar -C /home/freetz/trunk/source/host-tools  -xf dl/busybox-1.21.0.tar.bz2
shopt -s nullglob; for i in tools/make/patches/*.busybox.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/busybox-1.21.0 $i; \
        done
    applying patch file tools/make/patches/tar_preserve_directory_permissions.busybox.patch
    patching file archival/libarchive/data_extract_all.c
touch /home/freetz/trunk/source/host-tools/busybox-1.21.0/.unpacked
cp tools/make/Config.busybox /home/freetz/trunk/source/host-tools/busybox-1.21.0/.config
make -j2 -C /home/freetz/trunk/source/host-tools/busybox-1.21.0 oldconfig
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/busybox-1.21.0'
  GEN     include/applets.h
  HOSTCC  scripts/basic/split-include
scripts/basic/split-include.c: In function âmainâ:
scripts/basic/split-include.c:134:11: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  scripts/basic/docproc
  GEN     include/usage.h
  GEN     findutils/Kbuild
  GEN     findutils/Config.in
  GEN     archival/Kbuild
  GEN     archival/Config.in
  GEN     archival/libarchive/Kbuild
  GEN     libpwdgrp/Kbuild
  GEN     applets/Kbuild
  GEN     coreutils/Kbuild
  GEN     coreutils/Config.in
  GEN     coreutils/libcoreutils/Kbuild
  GEN     miscutils/Kbuild
  GEN     miscutils/Config.in
  GEN     console-tools/Kbuild
  GEN     console-tools/Config.in
  GEN     sysklogd/Kbuild
  GEN     sysklogd/Config.in
  GEN     selinux/Kbuild
  GEN     selinux/Config.in
  GEN     editors/Kbuild
  GEN     editors/Config.in
  GEN     loginutils/Kbuild
  GEN     loginutils/Config.in
  GEN     procps/Kbuild
  GEN     procps/Config.in
  GEN     networking/Kbuild
  GEN     networking/Config.in
  GEN     networking/udhcp/Kbuild
  GEN     networking/udhcp/Config.in
  GEN     networking/libiproute/Kbuild
  GEN     libbb/Kbuild
  GEN     libbb/Config.in
  GEN     printutils/Kbuild
  GEN     printutils/Config.in
  GEN     modutils/Kbuild
  GEN     modutils/Config.in
  GEN     shell/Kbuild
  GEN     shell/Config.in
  GEN     init/Kbuild
  GEN     init/Config.in
  GEN     e2fsprogs/Kbuild
  GEN     e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/uuid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/blkid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/e2p/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/ext2fs/Kbuild
  GEN     runit/Kbuild
  GEN     runit/Config.in
  GEN     mailutils/Kbuild
  GEN     mailutils/Config.in
  GEN     scripts/Kbuild
  GEN     debianutils/Kbuild
  GEN     debianutils/Config.in
  GEN     util-linux/Kbuild
  GEN     util-linux/Config.in
  GEN     util-linux/volume_id/Kbuild
scripts/kconfig/conf.c: In function âconf_choiceâ:
scripts/kconfig/conf.c:354:9: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
scripts/kconfig/conf.c: In function âconf_askvalueâ:
scripts/kconfig/conf.c:106:8: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  scripts/kconfig/kxgettext.o
  SHIPPED scripts/kconfig/lex.zconf.c
scripts/kconfig/mconf.c: In function âshow_textboxâ:
scripts/kconfig/mconf.c:847:7: warning: ignoring return value of âwriteâ, declared with attribute warn_unused_result [-Wunused-result]
scripts/kconfig/mconf.c: In function âexec_confâ:
scripts/kconfig/mconf.c:481:6: warning: ignoring return value of âpipeâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -o Config.in
# using defaults found in .config
* Busybox Configuration
* Busybox Settings
* General Configuration
Enable options for full-blown desktop systems (DESKTOP) [N/y/?] n
Provide compatible behavior for rare corner cases (bigger code) (EXTRA_COMPAT) [N/y/?] n
Enable obsolete features removed before SUSv3 (INCLUDE_SUSv2) [Y/n/?] y
Avoid using GCC-specific code constructs (USE_PORTABLE_CODE) [N/y/?] n
Enable Linux-specific applets and features (PLATFORM_LINUX) [Y/?] y
Buffer allocation policy
> 1. Allocate with Malloc (FEATURE_BUFFERS_USE_MALLOC)
  2. Allocate on the Stack (FEATURE_BUFFERS_GO_ON_STACK)
  3. Allocate in the .bss section (FEATURE_BUFFERS_GO_IN_BSS)
choice[1-3?]: 1
Show applet usage messages (SHOW_USAGE) [Y/n/?] y
  Show verbose applet usage messages (FEATURE_VERBOSE_USAGE) [N/y/?] n
  Store applet usage messages in compressed form (FEATURE_COMPRESS_USAGE) [Y/n/?] y
Support --install [-s] to install applet links at runtime (FEATURE_INSTALLER) [N/y/?] n
Don't use /usr (INSTALL_NO_USR) [N/y/?] n
Enable locale support (system needs locale for this to work) (LOCALE_SUPPORT) [N/y/?] n
Support Unicode (UNICODE_SUPPORT) [N/y/?] n
Support for --long-options (LONG_OPTS) [Y/n/?] y
Use the devpts filesystem for Unix98 PTYs (FEATURE_DEVPTS) [Y/n/?] y
Clean up all memory before exiting (usually not needed) (FEATURE_CLEAN_UP) [N/y/?] n
Support utmp file (FEATURE_UTMP) [N/y/?] n
Support writing pidfiles (FEATURE_PIDFILE) [N/y/?] n
Support for SUID/SGID handling (FEATURE_SUID) [N/y/?] n
Support NSA Security Enhanced Linux (SELINUX) [N/y/?] n
exec prefers applets (FEATURE_PREFER_APPLETS) [N/y/?] n
Path to BusyBox executable (BUSYBOX_EXEC_PATH) [/proc/self/exe] /proc/self/exe
* Build Options
Build BusyBox as a static binary (no shared libs) (STATIC) [N/y/?] n
  Build BusyBox as a position independent executable (PIE) [N/y/?] n
Force NOMMU build (NOMMU) [N/y/?] n
Build shared libbusybox (BUILD_LIBBUSYBOX) [N/y/?] n
Build with Large File Support (for accessing files > 2 GB) (LFS) [Y/n/?] y
Cross Compiler prefix (CROSS_COMPILER_PREFIX) []
Path to sysroot (SYSROOT) []
Additional CFLAGS (EXTRA_CFLAGS) []
Additional LDFLAGS (EXTRA_LDFLAGS) []
Additional LDLIBS (EXTRA_LDLIBS) []
* Debugging Options
Build BusyBox with extra Debugging symbols (DEBUG) [N/y/?] n
Abort compilation on any warning (WERROR) [N/y/?] n
Additional debugging library
> 1. None (NO_DEBUG_LIB)
  2. Dmalloc (DMALLOC)
  3. Electric-fence (EFENCE)
choice[1-3?]: 1
* Installation Options ("make install" behavior)
What kind of applet links to install
> 1. as soft-links (INSTALL_APPLET_SYMLINKS)
  2. as hard-links (INSTALL_APPLET_HARDLINKS)
  3. as script wrappers (INSTALL_APPLET_SCRIPT_WRAPPERS)
  4. not installed (INSTALL_APPLET_DONT)
choice[1-4?]: 1
BusyBox installation prefix (PREFIX) [./_install] ./_install
* Busybox Library Tuning
Enable systemd support (FEATURE_SYSTEMD) [N/y/?] n
Support RTMIN[+n] and RTMAX[-n] signal names (FEATURE_RTMINMAX) [N/y/?] n
Minimum password length (PASSWORD_MINLEN) [6] 6
MD5: Trade bytes for speed (0:fast, 3:slow) (MD5_SMALL) [1] 1
SHA3: Trade bytes for speed (0:fast, 1:slow) (SHA3_SMALL) [1] 1
Faster /proc scanning code (+100 bytes) (FEATURE_FAST_TOP) [N/y/?] n
Support for /etc/networks (FEATURE_ETC_NETWORKS) [N/y/?] n
Command line editing (FEATURE_EDITING) [N/y/?] n
Non-POSIX, but safer, copying to special nodes (FEATURE_NON_POSIX_CP) [Y/n/?] y
Give more precise messages when copy fails (cp, mv etc) (FEATURE_VERBOSE_CP_MESSAGE) [N/y/?] n
Copy buffer size, in kilobytes (FEATURE_COPYBUF_KB) [4] 4
Skip rootfs in mount table (FEATURE_SKIP_ROOTFS) [N/y/?] n
Use clock_gettime(CLOCK_MONOTONIC) syscall (MONOTONIC_SYSCALL) [Y/n/?] y
Use ioctl names rather than hex values in error messages (IOCTL_HEX2STR_ERROR) [Y/n/?] y
Support infiniband HW (FEATURE_HWIB) [Y/n/?] y
* Applets
* Archival Utilities
Make tar, rpm, modprobe etc understand .xz data (FEATURE_SEAMLESS_XZ) [Y/n/?] y
Make tar, rpm, modprobe etc understand .lzma data (FEATURE_SEAMLESS_LZMA) [Y/n/?] y
Make tar, rpm, modprobe etc understand .bz2 data (FEATURE_SEAMLESS_BZ2) [Y/n/?] y
Make tar, rpm, modprobe etc understand .gz data (FEATURE_SEAMLESS_GZ) [Y/n/?] y
tar, rpm, modprobe etc understand .Z data (FEATURE_SEAMLESS_Z) [Y/n/?] y
ar (AR) [N/y/?] n
bunzip2 (BUNZIP2) [Y/n/?] y
bzip2 (BZIP2) [N/y/?] n
cpio (CPIO) [N/y/?] n
dpkg (DPKG) [N/y/?] n
dpkg_deb (DPKG_DEB) [N/y/?] n
gunzip (GUNZIP) [Y/n/?] y
gzip (GZIP) [N/y/?] n
lzop (LZOP) [N/y/?] n
rpm2cpio (RPM2CPIO) [N/y/?] n
rpm (RPM) [N/y/?] n
tar (TAR) [Y/n/?] y
  Enable archive creation (FEATURE_TAR_CREATE) [Y/n/?] y
  Autodetect compressed tarballs (FEATURE_TAR_AUTODETECT) [Y/n/?] y
  Enable -X (exclude from) and -T (include from) options) (FEATURE_TAR_FROM) [Y/n/?] y
  Support for old tar header format (FEATURE_TAR_OLDGNU_COMPATIBILITY) [Y/n/?] y
  Enable untarring of tarballs with checksums produced by buggy Sun tar (FEATURE_TAR_OLDSUN_COMPATIBILITY) [N/y/?] n
  Support for GNU tar extensions (long filenames) (FEATURE_TAR_GNU_EXTENSIONS) [Y/n/?] y
  Enable long options (FEATURE_TAR_LONG_OPTIONS) [Y/n/?] y
    Support for writing to an external program (FEATURE_TAR_TO_COMMAND) [N/y/?] n
  Enable use of user and group names (FEATURE_TAR_UNAME_GNAME) [Y/n/?] y
  Enable -m (do not preserve time) option (FEATURE_TAR_NOPRESERVE_TIME) [N/y/?] n
uncompress (UNCOMPRESS) [Y/n/?] y
unlzma (UNLZMA) [Y/n/?] y
  Optimize unlzma for speed (FEATURE_LZMA_FAST) [Y/n/?] y
  Provide lzma alias which supports only unpacking (LZMA) [N/y/?] n
unxz (UNXZ) [Y/n/?] y
  Provide xz alias which supports only unpacking (XZ) [N/y/?] n
unzip (UNZIP) [Y/n/?] y
* Coreutils
basename (BASENAME) [N/y/?] n
cat (CAT) [N/y/?] n
date (DATE) [N/y/?] n
hostid (HOSTID) [N/y/?] n
id (ID) [N/y/?] n
groups (GROUPS) [N/y/?] n
test (TEST) [N/y/?] n
touch (TOUCH) [N/y/?] n
tr (TR) [N/y/?] n
base64 (BASE64) [N/y/?] n
cal (CAL) [N/y/?] n
catv (CATV) [N/y/?] n
chgrp (CHGRP) [N/y/?] n
chmod (CHMOD) [N/y/?] n
chown (CHOWN) [N/y/?] n
chroot (CHROOT) [N/y/?] n
cksum (CKSUM) [N/y/?] n
comm (COMM) [N/y/?] n
cp (CP) [N/y/?] n
cut (CUT) [N/y/?] n
dd (DD) [N/y/?] n
df (DF) [N/y/?] n
dirname (DIRNAME) [N/y/?] n
dos2unix/unix2dos (DOS2UNIX) [N/y/?] n
du (default blocksize of 512 bytes) (DU) [N/y/?] n
echo (basic SuSv3 version taking no options) (ECHO) [N/y/?] n
env (ENV) [N/y/?] n
expand (EXPAND) [N/y/?] n
expr (EXPR) [N/y/?] n
false (FALSE) [N/y/?] n
fold (FOLD) [N/y/?] n
fsync (FSYNC) [N/y/?] n
head (HEAD) [N/y/?] n
install (INSTALL) [N/y/?] n
ln (LN) [N/y/?] n
logname (LOGNAME) [N/y/?] n
ls (LS) [N/y/?] n
md5sum (MD5SUM) [Y/n/?] y
mkdir (MKDIR) [N/y/?] n
mkfifo (MKFIFO) [N/y/?] n
mknod (MKNOD) [N/y/?] n
mv (MV) [N/y/?] n
nice (NICE) [N/y/?] n
nohup (NOHUP) [N/y/?] n
od (OD) [N/y/?] n
printenv (PRINTENV) [N/y/?] n
printf (PRINTF) [N/y/?] n
pwd (PWD) [N/y/?] n
readlink (READLINK) [N/y/?] n
realpath (REALPATH) [N/y/?] n
rm (RM) [N/y/?] n
rmdir (RMDIR) [N/y/?] n
seq (SEQ) [N/y/?] n
sha1sum (SHA1SUM) [N/y/?] n
sha256sum (SHA256SUM) [N/y/?] n
sha512sum (SHA512SUM) [N/y/?] n
sha3sum (SHA3SUM) [N/y/?] n
sleep (SLEEP) [N/y/?] n
sort (SORT) [N/y/?] n
split (SPLIT) [N/y/?] n
stat (STAT) [N/y/?] n
stty (STTY) [N/y/?] n
sum (SUM) [N/y/?] n
sync (SYNC) [N/y/?] n
tac (TAC) [N/y/?] n
tail (TAIL) [N/y/?] n
tee (TEE) [N/y/?] n
true (TRUE) [N/y/?] n
tty (TTY) [N/y/?] n
uname (UNAME) [N/y/?] n
unexpand (UNEXPAND) [N/y/?] n
uniq (UNIQ) [N/y/?] n
usleep (USLEEP) [N/y/?] n
uudecode (UUDECODE) [N/y/?] n
uuencode (UUENCODE) [N/y/?] n
wc (WC) [N/y/?] n
whoami (WHOAMI) [N/y/?] n
yes (YES) [N/y/?] n
* Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
Enable -c, -s and -w options (FEATURE_MD5_SHA1_SUM_CHECK) [Y/n/?] y
* Console Utilities
chvt (CHVT) [N/y/?] n
fgconsole (FGCONSOLE) [N/y/?] n
clear (CLEAR) [N/y/?] n
deallocvt (DEALLOCVT) [N/y/?] n
dumpkmap (DUMPKMAP) [N/y/?] n
kbd_mode (KBD_MODE) [N/y/?] n
loadfont (LOADFONT) [N/y/?] n
loadkmap (LOADKMAP) [N/y/?] n
openvt (OPENVT) [N/y/?] n
reset (RESET) [N/y/?] n
resize (RESIZE) [N/y/?] n
setconsole (SETCONSOLE) [N/y/?] n
setfont (SETFONT) [N/y/?] n
setkeycodes (SETKEYCODES) [N/y/?] n
setlogcons (SETLOGCONS) [N/y/?] n
showkey (SHOWKEY) [N/y/?] n
* Debian Utilities
mktemp (MKTEMP) [N/y/?] n
pipe_progress (PIPE_PROGRESS) [N/y/?] n
run-parts (RUN_PARTS) [N/y/?] n
start-stop-daemon (START_STOP_DAEMON) [N/y/?] n
which (WHICH) [N/y/?] n
* Editors
patch (PATCH) [N/y/?] n
vi (VI) [N/y/?] n
awk (AWK) [N/y/?] n
cmp (CMP) [N/y/?] n
diff (DIFF) [N/y/?] n
ed (ED) [N/y/?] n
sed (SED) [N/y/?] n
* Finding Utilities
find (FIND) [N/y/?] n
grep (GREP) [N/y/?] n
xargs (XARGS) [N/y/?] n
* Init Utilities
bootchartd (BOOTCHARTD) [N/y/?] n
poweroff, halt, and reboot (HALT) [N/y/?] n
init (INIT) [N/y/?] n
mesg (MESG) [N/y/?] n
* Login/Password Management Utilities
add-shell (ADD_SHELL) [N/y/?] n
remove-shell (REMOVE_SHELL) [N/y/?] n
Support for shadow passwords (FEATURE_SHADOWPASSWDS) [N/y/?] n
Use internal password and group functions rather than system functions (USE_BB_PWD_GRP) [N/y/?] n
Use internal crypt functions (USE_BB_CRYPT) [Y/n/?] y
  Enable SHA256/512 crypt functions (USE_BB_CRYPT_SHA) [N/y/?] n
adduser (ADDUSER) [N/y/?] n
addgroup (ADDGROUP) [N/y/?] n
deluser (DELUSER) [N/y/?] n
delgroup (DELGROUP) [N/y/?] n
getty (GETTY) [N/y/?] n
login (LOGIN) [N/y/?] n
passwd (PASSWD) [N/y/?] n
cryptpw (CRYPTPW) [N/y/?] n
chpasswd (CHPASSWD) [N/y/?] n
su (SU) [N/y/?] n
sulogin (SULOGIN) [N/y/?] n
vlock (VLOCK) [N/y/?] n
* Linux Ext2 FS Progs
chattr (CHATTR) [N/y/?] n
fsck (FSCK) [N/y/?] n
lsattr (LSATTR) [N/y/?] n
tune2fs (TUNE2FS) [N/y/?] n
* Linux Module Utilities
modinfo (MODINFO) [N/y/?] n
Simplified modutils (MODPROBE_SMALL) [N/y/?] n
  insmod (INSMOD) [N/y/?] n
  rmmod (RMMOD) [N/y/?] n
  lsmod (LSMOD) [N/y/?] n
  modprobe (MODPROBE) [N/y/?] n
  depmod (DEPMOD) [N/y/?] n
* Options common to multiple modutils
* Linux System Utilities
blockdev (BLOCKDEV) [N/y/?] n
mdev (MDEV) [N/y/?] n
rev (REV) [N/y/?] n
acpid (ACPID) [N/y/?] n
blkid (BLKID) [N/y/?] n
dmesg (DMESG) [N/y/?] n
fbset (FBSET) [N/y/?] n
fdflush (FDFLUSH) [N/y/?] n
fdformat (FDFORMAT) [N/y/?] n
fdisk (FDISK) [N/y/?] n
findfs (FINDFS) [N/y/?] n
flock (FLOCK) [N/y/?] n
freeramdisk (FREERAMDISK) [N/y/?] n
fsck_minix (FSCK_MINIX) [N/y/?] n
mkfs_ext2 (MKFS_EXT2) [N/y/?] n
mkfs_minix (MKFS_MINIX) [N/y/?] n
mkfs_reiser (MKFS_REISER) [N/y/?] n
mkfs_vfat (MKFS_VFAT) [N/y/?] n
getopt (GETOPT) [N/y/?] n
hexdump (HEXDUMP) [N/y/?] n
hwclock (HWCLOCK) [N/y/?] n
ipcrm (IPCRM) [N/y/?] n
ipcs (IPCS) [N/y/?] n
losetup (LOSETUP) [N/y/?] n
lspci (LSPCI) [N/y/?] n
lsusb (LSUSB) [N/y/?] n
mkswap (MKSWAP) [N/y/?] n
more (MORE) [N/y/?] n
mount (MOUNT) [N/y/?] n
pivot_root (PIVOT_ROOT) [N/y/?] n
rdate (RDATE) [N/y/?] n
rdev (RDEV) [N/y/?] n
readprofile (READPROFILE) [N/y/?] n
rtcwake (RTCWAKE) [N/y/?] n
script (SCRIPT) [N/y/?] n
scriptreplay (SCRIPTREPLAY) [N/y/?] n
setarch (SETARCH) [N/y/?] n
swaponoff (SWAPONOFF) [N/y/?] n
switch_root (SWITCH_ROOT) [N/y/?] n
umount (UMOUNT) [N/y/?] n
* Miscellaneous Utilities
conspy (CONSPY) [N/y/?] n
less (LESS) [N/y/?] n
nandwrite (NANDWRITE) [N/y/?] n
nanddump (NANDDUMP) [N/y/?] n
setserial (SETSERIAL) [N/y/?] n
ubiattach (UBIATTACH) [N/y/?] n
ubidetach (UBIDETACH) [N/y/?] n
ubimkvol (UBIMKVOL) [N/y/?] n
ubirmvol (UBIRMVOL) [N/y/?] n
ubirsvol (UBIRSVOL) [N/y/?] n
ubiupdatevol (UBIUPDATEVOL) [N/y/?] n
adjtimex (ADJTIMEX) [N/y/?] n
bbconfig (BBCONFIG) [N/y/?] n
beep (BEEP) [N/y/?] n
chat (CHAT) [N/y/?] n
chrt (CHRT) [N/y/?] n
crond (CROND) [N/y/?] n
crontab (CRONTAB) [N/y/?] n
dc (DC) [N/y/?] n
devfsd (obsolete) (DEVFSD) [N/y/?] n
Use devfs names for all devices (obsolete) (FEATURE_DEVFS) [N/y/?] n
devmem (DEVMEM) [N/y/?] n
eject (EJECT) [N/y/?] n
fbsplash (FBSPLASH) [N/y/?] n
flashcp (FLASHCP) [N/y/?] n
flash_lock (FLASH_LOCK) [N/y/?] n
flash_unlock (FLASH_UNLOCK) [N/y/?] n
flash_eraseall (FLASH_ERASEALL) [N/y/?] n
ionice (IONICE) [N/y/?] n
inotifyd (INOTIFYD) [N/y/?] n
hdparm (HDPARM) [N/y/?] n
makedevs (MAKEDEVS) [Y/n/?] y
  Choose makedevs behaviour
    1. leaf (FEATURE_MAKEDEVS_LEAF)
  > 2. table (FEATURE_MAKEDEVS_TABLE)
  choice[1-2]: 2
man (MAN) [N/y/?] n
microcom (MICROCOM) [N/y/?] n
mountpoint (MOUNTPOINT) [N/y/?] n
mt (MT) [N/y/?] n
raidautorun (RAIDAUTORUN) [N/y/?] n
readahead (READAHEAD) [N/y/?] n
rfkill (RFKILL) [N/y/?] n
rx (RX) [N/y/?] n
setsid (SETSID) [N/y/?] n
strings (STRINGS) [N/y/?] n
taskset (TASKSET) [N/y/?] n
time (TIME) [N/y/?] n
timeout (TIMEOUT) [N/y/?] n
ttysize (TTYSIZE) [N/y/?] n
volname (VOLNAME) [N/y/?] n
watchdog (WATCHDOG) [N/y/?] n
* Networking Utilities
nameif (NAMEIF) [N/y/?] n
nbd-client (NBDCLIENT) [N/y/?] n
nc (NC) [N/y/?] n
ping (PING) [N/y/?] n
whois (WHOIS) [N/y/?] n
Enable IPv6 support (FEATURE_IPV6) [N/y/?] n
Enable Unix domain socket support (usually not needed) (FEATURE_UNIX_LOCAL) [N/y/?] n
Verbose resolution errors (VERBOSE_RESOLUTION_ERRORS) [N/y/?] n
arp (ARP) [N/y/?] n
arping (ARPING) [N/y/?] n
brctl (BRCTL) [N/y/?] n
dnsd (DNSD) [N/y/?] n
ether-wake (ETHER_WAKE) [N/y/?] n
fakeidentd (FAKEIDENTD) [N/y/?] n
ftpd (FTPD) [N/y/?] n
ftpget (FTPGET) [N/y/?] n
ftpput (FTPPUT) [N/y/?] n
hostname (HOSTNAME) [N/y/?] n
httpd (HTTPD) [N/y/?] n
ifconfig (IFCONFIG) [N/y/?] n
ifenslave (IFENSLAVE) [N/y/?] n
ifplugd (IFPLUGD) [N/y/?] n
ifupdown (IFUPDOWN) [N/y/?] n
inetd (INETD) [N/y/?] n
ip (IP) [N/y/?] n
ipcalc (IPCALC) [N/y/?] n
netstat (NETSTAT) [N/y/?] n
nslookup (NSLOOKUP) [N/y/?] n
ntpd (NTPD) [N/y/?] n
pscan (PSCAN) [N/y/?] n
route (ROUTE) [N/y/?] n
slattach (SLATTACH) [N/y/?] n
tcpsvd (TCPSVD) [N/y/?] n
telnet (TELNET) [N/y/?] n
telnetd (TELNETD) [N/y/?] n
tftp (TFTP) [N/y/?] n
tftpd (TFTPD) [N/y/?] n
traceroute (TRACEROUTE) [N/y/?] n
tunctl (TUNCTL) [N/y/?] n
udhcp server (udhcpd) (UDHCPD) [N/y/?] n
udhcp client (udhcpc) (UDHCPC) [N/y/?] n
udpsvd (UDPSVD) [N/y/?] n
vconfig (VCONFIG) [N/y/?] n
wget (WGET) [N/y/?] n
zcip (ZCIP) [N/y/?] n
* Print Utilities
lpd (LPD) [N/y/?] n
lpr (LPR) [N/y/?] n
lpq (LPQ) [N/y/?] n
* Mail Utilities
makemime (MAKEMIME) [N/y/?] n
popmaildir (POPMAILDIR) [N/y/?] n
reformime (REFORMIME) [N/y/?] n
sendmail (SENDMAIL) [N/y/?] n
* Process Utilities
iostat (IOSTAT) [N/y/?] n
lsof (LSOF) [N/y/?] n
mpstat (MPSTAT) [N/y/?] n
nmeter (NMETER) [N/y/?] n
pmap (PMAP) [N/y/?] n
powertop (POWERTOP) [N/y/?] n
pstree (PSTREE) [N/y/?] n
pwdx (PWDX) [N/y/?] n
smemcap (SMEMCAP) [N/y/?] n
top (TOP) [N/y/?] n
uptime (UPTIME) [N/y/?] n
free (FREE) [N/y/?] n
fuser (FUSER) [N/y/?] n
kill (KILL) [N/y/?] n
pgrep (PGREP) [N/y/?] n
pidof (PIDOF) [N/y/?] n
pkill (PKILL) [N/y/?] n
ps (PS) [N/y/?] n
renice (RENICE) [N/y/?] n
sysctl (BB_SYSCTL) [N/y/?] n
watch (WATCH) [N/y/?] n
* Runit Utilities
runsv (RUNSV) [N/y/?] n
runsvdir (RUNSVDIR) [N/y/?] n
sv (SV) [N/y/?] n
svlogd (SVLOGD) [N/y/?] n
chpst (CHPST) [N/y/?] n
setuidgid (SETUIDGID) [N/y/?] n
envuidgid (ENVUIDGID) [N/y/?] n
envdir (ENVDIR) [N/y/?] n
softlimit (SOFTLIMIT) [N/y/?] n
* Shells
ash (ASH) [Y/n/?] y
  bash-compatible extensions (ASH_BASH_COMPAT) [N/y/?] n
  Idle timeout variable (ASH_IDLE_TIMEOUT) [N/y/?] n
  Job control (ASH_JOB_CONTROL) [N/y/?] n
  Alias support (ASH_ALIAS) [N/y/?] n
  Builtin getopt to parse positional parameters (ASH_GETOPTS) [N/y/?] n
  Builtin version of 'echo' (ASH_BUILTIN_ECHO) [N/y/?] n
  Builtin version of 'printf' (ASH_BUILTIN_PRINTF) [N/y/?] n
  Builtin version of 'test' (ASH_BUILTIN_TEST) [N/y/?] n
  'command' command to override shell builtins (ASH_CMDCMD) [N/y/?] n
  Check for new mail on interactive shells (ASH_MAIL) [N/y/?] n
  Optimize for size instead of speed (ASH_OPTIMIZE_FOR_SIZE) [N/y/?] n
  Pseudorandom generator and $RANDOM variable (ASH_RANDOM_SUPPORT) [N/y/?] n
  Expand prompt string (ASH_EXPAND_PRMT) [N/y/?] n
cttyhack (CTTYHACK) [N/y/?] n
hush (HUSH) [N/y/?] n
msh (deprecated: aliased to hush) (MSH) [N/y/?] n
Choose which shell is aliased to 'sh' name
  1. ash (FEATURE_SH_IS_ASH)
> 2. none (FEATURE_SH_IS_NONE)
choice[1-2?]: 2
Choose which shell is aliased to 'bash' name
  1. ash (FEATURE_BASH_IS_ASH)
> 2. none (FEATURE_BASH_IS_NONE)
choice[1-2?]: 2
POSIX math support (SH_MATH_SUPPORT) [N/y/?] n
Hide message on interactive shell startup (FEATURE_SH_EXTRA_QUIET) [N/y/?] n
Use $HISTFILESIZE (FEATURE_SH_HISTFILESIZE) [N/y/?] n
* System Logging Utilities
syslogd (SYSLOGD) [N/y/?] n
klogd (KLOGD) [N/y/?] n
logger (LOGGER) [N/y/?] n
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/busybox-1.21.0'
touch /home/freetz/trunk/source/host-tools/busybox-1.21.0/.configured
  SPLIT   include/autoconf.h -> include/config/*
  HOSTCC  applets/usage
  GEN     include/bbconfigopts.h
applets/usage.c: In function âmainâ:
applets/usage.c:52:8: warning: ignoring return value of âwriteâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  applets/applet_tables
applets/applet_tables.c: In function âmainâ:
applets/applet_tables.c:144:9: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
  GEN     include/usage_compressed.h
  GEN     include/applet_tables.h
  HOSTCC  applets/usage_pod
  CC      applets/applets.o
applets/usage_pod.c: In function âmainâ:
applets/usage_pod.c:74:3: warning: format not a string literal and no format arguments [-Wformat-security]
  LD      applets/built-in.o
  DOC     busybox.pod
  DOC     BusyBox.txt
  DOC     busybox.1
  DOC     BusyBox.html
  LD      archival/built-in.o
  CC      archival/bbunzip.o
  LD      archival/libarchive/built-in.o
  CC      archival/libarchive/data_align.o
  CC      archival/libarchive/data_extract_all.o
  CC      archival/tar.o
archival/libarchive/data_extract_all.c: In function âdata_extract_allâ:
archival/libarchive/data_extract_all.c:177:9: warning: ignoring return value of âchownâ, declared with attribute warn_unused_result [-Wunused-result]
  CC      archival/libarchive/data_extract_to_stdout.o
  CC      archival/libarchive/data_skip.o
  CC      archival/unzip.o
  CC      archival/libarchive/decompress_bunzip2.o
  AR      archival/lib.a
  LD      console-tools/built-in.o
  AR      console-tools/lib.a
  LD      coreutils/built-in.o
  CC      coreutils/echo.o
  CC      archival/libarchive/decompress_gunzip.o
  CC      coreutils/md5_sha1_sum.o
  CC      coreutils/test.o
  CC      archival/libarchive/decompress_uncompress.o
  CC      coreutils/test_ptr_hack.o
  AR      coreutils/lib.a
  LD      coreutils/libcoreutils/built-in.o
  AR      coreutils/libcoreutils/lib.a
  CC      archival/libarchive/decompress_unlzma.o
  LD      debianutils/built-in.o
  AR      debianutils/lib.a
  LD      e2fsprogs/built-in.o
  AR      e2fsprogs/lib.a
  LD      editors/built-in.o
  AR      editors/lib.a
  LD      findutils/built-in.o
  AR      findutils/lib.a
  LD      init/built-in.o
  AR      init/lib.a
  CC      archival/libarchive/decompress_unxz.o
  LD      libbb/built-in.o
  CC      libbb/appletlib.o
libbb/appletlib.c: In function âbusybox_mainâ:
libbb/appletlib.c:691:7: warning: variable âuse_symbolic_linksâ set but not used [-Wunused-but-set-variable]
  CC      libbb/ask_confirmation.o
  CC      libbb/bb_askpass.o
  CC      libbb/bb_bswap_64.o
  CC      archival/libarchive/filter_accept_all.o
  CC      libbb/bb_do_delay.o
  CC      archival/libarchive/filter_accept_list.o
  CC      libbb/bb_pwd.o
  CC      archival/libarchive/filter_accept_reject_list.o
  CC      libbb/bb_qsort.o
  CC      archival/libarchive/find_list_entry.o
  CC      libbb/bb_strtonum.o
  CC      archival/libarchive/get_header_tar.o
  CC      libbb/change_identity.o
  CC      archival/libarchive/header_list.o
  CC      libbb/chomp.o
  CC      archival/libarchive/header_skip.o
  CC      libbb/compare_string_array.o
  CC      archival/libarchive/header_verbose_list.o
  CC      libbb/concat_path_file.o
  CC      archival/libarchive/init_handle.o
  CC      libbb/concat_subpath_file.o
  CC      archival/libarchive/open_transformer.o
  CC      libbb/copy_file.o
  CC      archival/libarchive/seek_by_jump.o
  CC      libbb/copyfd.o
  CC      archival/libarchive/seek_by_read.o
  CC      libbb/crc32.o
  AR      archival/libarchive/lib.a
  LD      libpwdgrp/built-in.o
  CC      libpwdgrp/uidgid_get.o
  CC      libbb/create_icmp6_socket.o
  CC      libbb/create_icmp_socket.o
  AR      libpwdgrp/lib.a
  LD      loginutils/built-in.o
  AR      loginutils/lib.a
  LD      mailutils/built-in.o
  AR      mailutils/lib.a
  CC      libbb/default_error_retval.o
  LD      miscutils/built-in.o
  CC      miscutils/makedevs.o
  CC      libbb/device_open.o
  AR      miscutils/lib.a
  CC      libbb/dump.o
  LD      modutils/built-in.o
  AR      modutils/lib.a
  LD      networking/built-in.o
  AR      networking/lib.a
  LD      networking/libiproute/built-in.o
  AR      networking/libiproute/lib.a
  LD      networking/udhcp/built-in.o
  AR      networking/udhcp/lib.a
  LD      printutils/built-in.o
  AR      printutils/lib.a
  LD      procps/built-in.o
  CC      procps/kill.o
  CC      libbb/execable.o
  AR      procps/lib.a
  CC      libbb/fclose_nonstdin.o
  LD      runit/built-in.o
  AR      runit/lib.a
  LD      selinux/built-in.o
  AR      selinux/lib.a
  CC      libbb/fflush_stdout_and_exit.o
  LD      shell/built-in.o
  CC      shell/ash.o
  CC      libbb/fgets_str.o
  CC      libbb/find_pid_by_name.o
  CC      libbb/find_root_device.o
  CC      libbb/full_write.o
  CC      libbb/get_console.o
  CC      libbb/get_last_path_component.o
  CC      libbb/get_line_from_file.o
  CC      libbb/get_shell_name.o
  CC      libbb/get_volsize.o
  CC      libbb/getopt32.o
  CC      libbb/getpty.o
  CC      libbb/hash_md5_sha.o
  CC      libbb/herror_msg.o
  CC      shell/ash_ptr_hack.o
  CC      libbb/human_readable.o
  CC      shell/shell_common.o
  CC      libbb/inet_common.o
  AR      shell/lib.a
  LD      sysklogd/built-in.o
  AR      sysklogd/lib.a
  CC      libbb/info_msg.o
  LD      util-linux/built-in.o
  AR      util-linux/lib.a
  LD      util-linux/volume_id/built-in.o
  AR      util-linux/volume_id/lib.a
  CC      libbb/inode_hash.o
  CC      libbb/isdirectory.o
  CC      libbb/kernel_version.o
  CC      libbb/last_char_is.o
  CC      libbb/lineedit.o
  CC      libbb/lineedit_ptr_hack.o
  CC      libbb/llist.o
  CC      libbb/login.o
  CC      libbb/make_directory.o
  CC      libbb/makedev.o
  CC      libbb/match_fstype.o
  CC      libbb/messages.o
  CC      libbb/missing_syscalls.o
  CC      libbb/mode_string.o
  CC      libbb/parse_config.o
  CC      libbb/parse_mode.o
  CC      libbb/percent_decode.o
  CC      libbb/perror_msg.o
  CC      libbb/perror_nomsg.o
  CC      libbb/perror_nomsg_and_die.o
  CC      libbb/pidfile.o
  CC      libbb/platform.o
  CC      libbb/print_flags.o
  CC      libbb/printable.o
  CC      libbb/printable_string.o
  CC      libbb/process_escape_sequence.o
  CC      libbb/procps.o
  CC      libbb/progress.o
  CC      libbb/ptr_to_globals.o
  CC      libbb/read.o
  CC      libbb/read_key.o
  CC      libbb/read_printf.o
  CC      libbb/recursive_action.o
  CC      libbb/remove_file.o
  CC      libbb/run_shell.o
  CC      libbb/safe_gethostname.o
  CC      libbb/safe_poll.o
  CC      libbb/safe_strncpy.o
  CC      libbb/safe_write.o
  CC      libbb/setup_environment.o
  CC      libbb/signals.o
  CC      libbb/simplify_path.o
  CC      libbb/single_argv.o
  CC      libbb/skip_whitespace.o
  CC      libbb/speed_table.o
  CC      libbb/str_tolower.o
  CC      libbb/strrstr.o
  CC      libbb/time.o
  CC      libbb/trim.o
  CC      libbb/u_signal_names.o
  CC      libbb/uuencode.o
  CC      libbb/vdprintf.o
  CC      libbb/verror_msg.o
  CC      libbb/vfork_daemon_rexec.o
  CC      libbb/warn_ignoring_args.o
  CC      libbb/wfopen.o
  CC      libbb/wfopen_input.o
  CC      libbb/write.o
  CC      libbb/xatonum.o
  CC      libbb/xconnect.o
  CC      libbb/xfunc_die.o
  CC      libbb/xfuncs.o
  CC      libbb/xfuncs_printf.o
libbb/xfuncs_printf.c: In function âgenerate_uuidâ:
libbb/xfuncs_printf.c:593:7: warning: ignoring return value of âreadâ, declared with attribute warn_unused_result [-Wunused-result]
  CC      libbb/xgetcwd.o
  CC      libbb/xgethostbyname.o
  CC      libbb/xreadlink.o
  CC      libbb/xrealloc_vector.o
  AR      libbb/lib.a
  LINK    busybox_unstripped
Trying libraries: crypt m
 Library crypt is not needed, excluding it
 Library m is not needed, excluding it
Final link with: <none>
cp /home/freetz/trunk/source/host-tools/busybox-1.21.0/busybox tools/busybox
find tools -lname busybox -delete
for i in $(tools/busybox --list); do \
                ln -fs busybox tools/$i; \
        done
tools/freetz_download dl fakeroot_1.18.4.orig.tar.bz2 http://ftp.debian.org/debian/pool/main/f/fakeroot 706171d8d520b1ca1576ac73f2ceb4f3
--2013-03-18 15:50:16--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.18.4.orig.tar.bz2
Resolving ftp.debian.org (ftp.debian.org)... 130.89.148.12, 2001:610:1908:b000::148:12
Connecting to ftp.debian.org (ftp.debian.org)|130.89.148.12|:80... connected.
Length: 309298 (302K) [application/x-bzip2]
Saving to: `dl/fakeroot_1.18.4.orig.tar.bz2'
100%[=========================================================================================================================>] 309,298      101K/s   in 3.0s
2013-03-18 15:50:19 (101 KB/s) - `dl/fakeroot_1.18.4.orig.tar.bz2' saved [309298/309298]
Download succeeded - "http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.18.4.orig.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/fakeroot_1.18.4.orig.tar.bz2: 706171d8d520b1ca1576ac73f2ceb4f3
tar -C /home/freetz/trunk/source/host-tools  -xf dl/fakeroot_1.18.4.orig.tar.bz2
sed -i "s,getopt --version,getopt --version 2>/dev/null," \
                /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/scripts/fakeroot.in
for i in tools/make/patches/*.fakeroot.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/fakeroot-1.18.4 $i; \
        done
    applying patch file tools/make/patches/100-fakeroot-doc.fakeroot.patch
    patching file Makefile.am
    patching file Makefile.in
touch /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/.unpacked
(mkdir -p /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch; cd /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch; rm -f config.cache; \
                CFLAGS="-O3 -Wall" \
                CC="gcc" \
                ../../configure \
                --prefix=/home/freetz/trunk/tools/build \
                --enable-shared \
                --disable-nls \
configure: WARNING: unrecognized options: --disable-nls
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make sets $(MAKE)... (cached) yes
checking how to print strings... printf
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 3458764513820540925
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking which IPC method to use... (cached) sysv
checking which database format to use... (cached) inode
checking for dlopen in -ldl... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for unistd.h... (cached) yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking sys/feature_tests.h usability... no
checking sys/feature_tests.h presence... no
checking for sys/feature_tests.h... no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for stdint.h... (cached) yes
checking for inttypes.h... (cached) yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking sys/sysmacros.h usability... yes
checking sys/sysmacros.h presence... yes
checking for sys/sysmacros.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/acl.h usability... no
checking sys/acl.h presence... no
checking for sys/acl.h... no
checking fts.h usability... yes
checking fts.h presence... yes
checking for fts.h... yes
checking for an ANSI C-conforming const... yes
checking for mode_t... yes
checking for off_t... yes
checking for size_t... yes
checking for return value and second and third argument of readlink... ssize_t, char, size_t
checking for first argument of setgroups... size_t
checking for union semun... no
checking for type of arg of __xmknod... needs *
checking for type of arg of __xmknodat... needs *
checking for type of arg of initgroups... gid_t
checking for type of arg of setreuid... gid_t
checking for type of arg of setregid... gid_t
checking for type of second arg to stat... struct stat *
checking for d_off in struct dirent... yes
checking for d_type in struct dirent... yes
checking for acl_t struct... no
checking for fchmodat... yes
checking for fchownat... yes
checking for fstatat... yes
checking for mkdirat... yes
checking for mknodat... yes
checking for openat... yes
checking for renameat... yes
checking for unlinkat... yes
checking for lchmod... no
checking for fgetattrlist... no
checking for __xstat... yes
checking for __fxstat... yes
checking for __lxstat... yes
checking for __fxstatat... yes
checking for __xstat64... yes
checking for __fxstat64... yes
checking for __lxstat64... yes
checking for __fxstatat64... yes
checking for __xmknod... yes
checking for __xmknodat... yes
created fakerootconfig.h
checking for strdup... yes
checking for strstr... yes
checking for getresuid... yes
checking for setresuid... yes
checking for getresgid... yes
checking for setresgid... yes
checking for setfsuid... yes
checking for setfsgid... yes
checking for fts_read... yes
checking for fts_children... yes
checking whether setenv is declared... yes
checking whether unsetenv is declared... yes
checking for setenv... yes
checking for MacOS X/Darwin... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating scripts/Makefile
config.status: creating doc/Makefile
config.status: creating doc/de/Makefile
config.status: creating doc/es/Makefile
config.status: creating doc/fr/Makefile
config.status: creating doc/nl/Makefile
config.status: creating doc/sv/Makefile
config.status: creating test/Makefile
config.status: creating test/defs
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
touch /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/.configured
make -j2 -C /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch install
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch'
Making install in scripts
make[2]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
sed -e 's,[@]prefix[@],/home/freetz/trunk/tools/build,g' -e 's,[@]bindir[@],/home/freetz/trunk/tools/build/bin,g' -e 's,[@]libdir[@],/home/freetz/trunk/tools/build/lib,g' -e 's,[@]fakeroot_transformed[@],'`echo fakeroot | sed -e 's,x,x,'`',g' -e 's,[@]faked_transformed[@],'`echo faked | sed -e 's,x,x,'`',g' -e 's,[@]signal[@],TERM,g' -e 's,[@]SHELL[@],/bin/bash,g' -e 's,[@]VERSION[@],1.18.4,g' -e 's,[@]DLSUFFIX[@],.so,g' -e 's,[@]LDLIBPATHVAR[@],LD_LIBRARY_PATH,g' -e 's,[@]LDPRELOADVAR[@],LD_PRELOAD,g' -e 's,[@]LDPRELOADABS[@],0,g' -e 's,[@]LDEXTRAVAR[@],,g' -e 's,[@]MACOSX_FALSE[@],,g' -e 's,[@]MACOSX_TRUE[@],#,g' < ../../../scripts/fakeroot.in > fakeroot
chmod +x fakeroot
make[3]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
make[3]: Nothing to be done for `install-data-am'.
test -z "/home/freetz/trunk/tools/build/bin" || /bin/mkdir -p "/home/freetz/trunk/tools/build/bin"
 /usr/bin/install -c fakeroot '/home/freetz/trunk/tools/build/bin'
make[3]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
make[2]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
Making install in test
make[2]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[3]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[2]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[2]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch'
awk -f ../../wrapawk < ../../wrapfunc.inp
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c -o communicate.lo ../../communicate.c
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT libfakeroot_inode64.lo -MD -MP -MF .deps/libfakeroot_inode64.Tpo -c -o libfakeroot_inode64.lo ../../libfakeroot_inode64.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c  -fPIC -DPIC -o .libs/communicate.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_inode64.lo -MD -MP -MF .deps/libfakeroot_inode64.Tpo -c ../../libfakeroot_inode64.c  -fPIC -DPIC -o .libs/libfakeroot_inode64.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_inode64.lo -MD -MP -MF .deps/libfakeroot_inode64.Tpo -c ../../libfakeroot_inode64.c -o libfakeroot_inode64.o >/dev/null 2>&1
../../communicate.c: In function 'send_get_fakem':
../../communicate.c:540:7: warning: variable 'l' set but not used [-Wunused-but-set-variable]
mv -f .deps/libfakeroot_inode64.Tpo .deps/libfakeroot_inode64.Plo
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT libfakeroot_unix2003.lo -MD -MP -MF .deps/libfakeroot_unix2003.Tpo -c -o libfakeroot_unix2003.lo ../../libfakeroot_unix2003.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_unix2003.lo -MD -MP -MF .deps/libfakeroot_unix2003.Tpo -c ../../libfakeroot_unix2003.c  -fPIC -DPIC -o .libs/libfakeroot_unix2003.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_unix2003.lo -MD -MP -MF .deps/libfakeroot_unix2003.Tpo -c ../../libfakeroot_unix2003.c -o libfakeroot_unix2003.o >/dev/null 2>&1
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c -o communicate.o >/dev/null 2>&1
mv -f .deps/libfakeroot_unix2003.Tpo .deps/libfakeroot_unix2003.Plo
gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT faked.o -MD -MP -MF .deps/faked.Tpo -c -o faked.o ../../faked.c
../../faked.c: In function âsave_databaseâ:
../../faked.c:524:13: warning: format â%llxâ expects argument of type âlong long unsigned intâ, but argument 3 has type âfake_dev_tâ [-Wformat]
../../faked.c:524:13: warning: format â%lluâ expects argument of type âlong long unsigned intâ, but argument 4 has type âfake_ino_tâ [-Wformat]
../../faked.c:524:13: warning: format â%lloâ expects argument of type âlong long unsigned intâ, but argument 5 has type âlong unsigned intâ [-Wformat]
../../faked.c:524:13: warning: format â%lluâ expects argument of type âlong long unsigned intâ, but argument 6 has type âlong unsigned intâ [-Wformat]
../../faked.c:524:13: warning: format â%lluâ expects argument of type âlong long unsigned intâ, but argument 7 has type âlong unsigned intâ [-Wformat]
../../faked.c:524:13: warning: format â%lluâ expects argument of type âlong long unsigned intâ, but argument 8 has type âlong unsigned intâ [-Wformat]
../../faked.c:524:13: warning: format â%lluâ expects argument of type âlong long unsigned intâ, but argument 9 has type âfake_dev_tâ [-Wformat]
../../faked.c: In function âload_databaseâ:
../../faked.c:563:13: warning: format â%llxâ expects argument of type âlong long unsigned int *â, but argument 2 has type âuint64_t *â [-Wformat]
../../faked.c:563:13: warning: format â%lluâ expects argument of type âlong long unsigned int *â, but argument 3 has type âuint64_t *â [-Wformat]
../../faked.c:563:13: warning: format â%lloâ expects argument of type âlong long unsigned int *â, but argument 4 has type âuint64_t *â [-Wformat]
../../faked.c:563:13: warning: format â%lluâ expects argument of type âlong long unsigned int *â, but argument 5 has type âuint64_t *â [-Wformat]
../../faked.c:563:13: warning: format â%lluâ expects argument of type âlong long unsigned int *â, but argument 6 has type âuint64_t *â [-Wformat]
../../faked.c:563:13: warning: format â%lluâ expects argument of type âlong long unsigned int *â, but argument 7 has type âuint64_t *â [-Wformat]
../../faked.c:563:13: warning: format â%lluâ expects argument of type âlong long unsigned int *â, but argument 8 has type âuint64_t *â [-Wformat]
../../faked.c: In function âdebug_statâ:
../../faked.c:596:4: warning: format â%llxâ expects argument of type âlong long unsigned intâ, but argument 3 has type âfake_dev_tâ [-Wformat]
../../faked.c:596:4: warning: format â%lliâ expects argument of type âlong long intâ, but argument 4 has type âfake_ino_tâ [-Wformat]
../../faked.c:596:4: warning: format â%lliâ expects argument of type âlong long intâ, but argument 9 has type âfake_dev_tâ [-Wformat]
../../faked.c: In function âprocess_chmodâ:
../../faked.c:694:9: warning: suggest parentheses around operand of â!â or change â&â to â&&â or â!â to â~â [-Wparentheses]
mv -f .deps/communicate.Tpo .deps/communicate.Plo
gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT simple.o -MD -MP -MF .deps/simple.Tpo -c -o simple.o ../../simple.c
mv -f .deps/simple.Tpo .deps/simple.Po
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c -o libfakeroot.lo ../../libfakeroot.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c  -fPIC -DPIC -o .libs/libfakeroot.o
../../libfakeroot.c: In function 'fts_read':
../../libfakeroot.c:1583:5: warning: passing argument 1 of 'send_get_stat64' from incompatible pointer type [enabled by default]
../../communicate.h:191:13: note: expected 'struct stat64 *' but argument is of type 'struct stat *'
../../libfakeroot.c: In function 'fts_children':
../../libfakeroot.c:1606:7: warning: passing argument 1 of 'send_get_stat64' from incompatible pointer type [enabled by default]
mv -f .deps/faked.Tpo .deps/faked.Po
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o libcommunicate.la  communicate.lo  -ldl
libtool: link: ar cru .libs/libcommunicate.a .libs/communicate.o
libtool: link: ranlib .libs/libcommunicate.a
libtool: link: ( cd ".libs" && rm -f "libcommunicate.la" && ln -s "../libcommunicate.la" "libcommunicate.la" )
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o libmacosx.la  libfakeroot_inode64.lo libfakeroot_unix2003.lo  -ldl
libtool: link: ar cru .libs/libmacosx.a .libs/libfakeroot_inode64.o .libs/libfakeroot_unix2003.o
libtool: link: ranlib .libs/libmacosx.a
libtool: link: ( cd ".libs" && rm -f "libmacosx.la" && ln -s "../libmacosx.la" "libmacosx.la" )
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o faked faked.o libcommunicate.la -ldl
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c -o libfakeroot.o >/dev/null 2>&1
libtool: link: gcc -O3 -Wall -o faked faked.o  ./.libs/libcommunicate.a -ldl
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o simple simple.o  -ldl
libtool: link: gcc -O3 -Wall -o simple simple.o  -ldl
mv -f .deps/libfakeroot.Tpo .deps/libfakeroot.Plo
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall -release 0  -o libfakeroot.la -rpath /home/freetz/trunk/tools/build/lib libfakeroot.lo libcommunicate.la  -ldl
libtool: link: gcc -shared  -fPIC -DPIC  .libs/libfakeroot.o  -Wl,--whole-archive ./.libs/libcommunicate.a -Wl,--no-whole-archive  -ldl  -O3   -Wl,-soname -Wl,libfakeroot-0.so -o .libs/libfakeroot-0.so
libtool: link: (cd ".libs" && rm -f "libfakeroot.so" && ln -s "libfakeroot-0.so" "libfakeroot.so")
libtool: link: (cd .libs/libfakeroot.lax/libcommunicate.a && ar x "/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch/./.libs/libcommunicate.a")
libtool: link: ar cru .libs/libfakeroot.a  libfakeroot.o  .libs/libfakeroot.lax/libcommunicate.a/communicate.o
libtool: link: ranlib .libs/libfakeroot.a
libtool: link: rm -fr .libs/libfakeroot.lax
libtool: link: ( cd ".libs" && rm -f "libfakeroot.la" && ln -s "../libfakeroot.la" "libfakeroot.la" )
make[3]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch'
test -z "/home/freetz/trunk/tools/build/lib" || /bin/mkdir -p "/home/freetz/trunk/tools/build/lib"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   libfakeroot.la '/home/freetz/trunk/tools/build/lib'
libtool: install: /usr/bin/install -c .libs/libfakeroot-0.so /home/freetz/trunk/tools/build/lib/libfakeroot-0.so
libtool: install: (cd /home/freetz/trunk/tools/build/lib && { ln -s -f libfakeroot-0.so libfakeroot.so || { rm -f libfakeroot.so && ln -s libfakeroot-0.so libfakeroot.so; }; })
libtool: install: /usr/bin/install -c .libs/libfakeroot.lai /home/freetz/trunk/tools/build/lib/libfakeroot.la
libtool: install: /usr/bin/install -c .libs/libfakeroot.a /home/freetz/trunk/tools/build/lib/libfakeroot.a
libtool: install: chmod 644 /home/freetz/trunk/tools/build/lib/libfakeroot.a
libtool: install: ranlib /home/freetz/trunk/tools/build/lib/libfakeroot.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/sbin" ldconfig -n /home/freetz/trunk/tools/build/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
  /bin/bash ./libtool   --mode=install /usr/bin/install -c faked '/home/freetz/trunk/tools/build/bin'
libtool: install: /usr/bin/install -c faked /home/freetz/trunk/tools/build/bin/faked
make[3]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch'
make[2]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch'
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/arch'
sed -i -e 's,^PATHS=.*,PATHS=/home/freetz/trunk/tools/build/lib:/home/freetz/trunk/tools/build/lib32,g' /home/freetz/trunk/tools/build/bin/fakeroot
(mkdir -p /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch; cd /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch; rm -f config.cache; \
                CFLAGS="-m32 -O3 -Wall" \
                CC="gcc" \
                ../../configure \
                --enable-shared \
                --disable-nls \
checking whether the gcc linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes
checking for return value and second and third argument of readlink... int, char, size_t
touch /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch/.configured
make -j2 -C /home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch libdir="/home/freetz/trunk/tools/build/lib32" install-libLTLIBRARIES
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch'
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -m32 -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c -o communicate.lo ../../communicate.c
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -m32 -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c -o libfakeroot.lo ../../libfakeroot.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c  -fPIC -DPIC -o .libs/communicate.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c  -fPIC -DPIC -o .libs/libfakeroot.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c -o communicate.o >/dev/null 2>&1
/bin/bash ./libtool --tag=CC   --mode=link gcc  -m32 -O3 -Wall   -o libcommunicate.la  communicate.lo  -ldl
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c -o libfakeroot.o >/dev/null 2>&1
/bin/bash ./libtool --tag=CC   --mode=link gcc  -m32 -O3 -Wall -release 0  -o libfakeroot.la -rpath /home/freetz/trunk/tools/build/lib32 libfakeroot.lo libcommunicate.la  -ldl
libtool: link: gcc -shared  -fPIC -DPIC  .libs/libfakeroot.o  -Wl,--whole-archive ./.libs/libcommunicate.a -Wl,--no-whole-archive  -ldl  -m32 -O3   -Wl,-soname -Wl,libfakeroot-0.so -o .libs/libfakeroot-0.so
libtool: link: (cd .libs/libfakeroot.lax/libcommunicate.a && ar x "/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch/./.libs/libcommunicate.a")
test -z "/home/freetz/trunk/tools/build/lib32" || /bin/mkdir -p "/home/freetz/trunk/tools/build/lib32"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   libfakeroot.la '/home/freetz/trunk/tools/build/lib32'
libtool: install: /usr/bin/install -c .libs/libfakeroot-0.so /home/freetz/trunk/tools/build/lib32/libfakeroot-0.so
libtool: install: (cd /home/freetz/trunk/tools/build/lib32 && { ln -s -f libfakeroot-0.so libfakeroot.so || { rm -f libfakeroot.so && ln -s libfakeroot-0.so libfakeroot.so; }; })
libtool: install: /usr/bin/install -c .libs/libfakeroot.lai /home/freetz/trunk/tools/build/lib32/libfakeroot.la
libtool: install: /usr/bin/install -c .libs/libfakeroot.a /home/freetz/trunk/tools/build/lib32/libfakeroot.a
libtool: install: chmod 644 /home/freetz/trunk/tools/build/lib32/libfakeroot.a
libtool: install: ranlib /home/freetz/trunk/tools/build/lib32/libfakeroot.a
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/sbin" ldconfig -n /home/freetz/trunk/tools/build/lib32
     during execution
     during linking
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/fakeroot-1.18.4/build/biarch'
tar -C /home/freetz/trunk/source/host-tools  -xf tools/source/find-squashfs.tar.bz2
touch /home/freetz/trunk/source/host-tools/find-squashfs/.unpacked
make -j2 CC="gcc" LD="ld -static" \
                -C /home/freetz/trunk/source/host-tools/find-squashfs
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/find-squashfs'
gcc -W -Wall -O2   -c -o find-squashfs.o find-squashfs.c
gcc -o find-squashfs find-squashfs.o
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/find-squashfs'
cp /home/freetz/trunk/source/host-tools/find-squashfs/find-squashfs tools/find-squashfs
tar -C /home/freetz/trunk/source/host-tools  -xf tools/source/sstrip-1.0.tar.bz2
touch /home/freetz/trunk/source/host-tools/sstrip-1.0/.unpacked
make -j2 -C /home/freetz/trunk/source/host-tools/sstrip-1.0 \
                CC="gcc" \
                CFLAGS="-Wall -O2" \
                all
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/sstrip-1.0'
gcc -Wall -O2    sstrip.c   -o sstrip
sstrip.c: In function âmainâ:
sstrip.c:367:1: warning: âp.phdrs32â may be used uninitialized in this function [-Wuninitialized]
sstrip.c:430:4: note: âp.phdrs32â was declared here
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/sstrip-1.0'
cp /home/freetz/trunk/source/host-tools/sstrip-1.0/sstrip tools/sstrip
make -j2 -C /home/freetz/trunk/source/host-tools/kconfig-v3.8 config
cp /home/freetz/trunk/source/host-tools/kconfig-v3.8/scripts/kconfig/conf tools/config/conf
tools/freetz_download dl lzma443.tar.bz2 @SF/sevenzip c4e1b467184c7cffd4371c74df2baf0f
--2013-03-18 15:50:35--  http://downloads.sourceforge.net/sevenzip/lzma443.tar.bz2
Resolving downloads.sourceforge.net (downloads.sourceforge.net)... 216.34.181.59
Connecting to downloads.sourceforge.net (downloads.sourceforge.net)|216.34.181.59|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: http://downloads.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2 [following]
--2013-03-18 15:50:35--  http://downloads.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2
Reusing existing connection to downloads.sourceforge.net:80.
HTTP request sent, awaiting response... 302 Found
Location: http://netcologne.dl.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2 [following]
--2013-03-18 15:50:35--  http://netcologne.dl.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2
Resolving netcologne.dl.sourceforge.net (netcologne.dl.sourceforge.net)... 78.35.24.46, 2001:4dd0:1234:6::5f
Connecting to netcologne.dl.sourceforge.net (netcologne.dl.sourceforge.net)|78.35.24.46|:80... connected.
Length: 178493 (174K) [application/x-bzip2]
Saving to: `dl/lzma443.tar.bz2'
100%[=========================================================================================================================>] 178,493      537K/s   in 0.3s
2013-03-18 15:50:36 (537 KB/s) - `dl/lzma443.tar.bz2' saved [178493/178493]
Download succeeded - "http://downloads.sourceforge.net/sevenzip/lzma443.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/lzma443.tar.bz2: c4e1b467184c7cffd4371c74df2baf0f
mkdir -p /home/freetz/trunk/source/host-tools/lzma443
tar -C /home/freetz/trunk/source/host-tools/lzma443  -xf dl/lzma443.tar.bz2
for i in tools/make/patches/*.lzma.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/lzma443 $i; \
        done
    applying patch file tools/make/patches/100-lzma_zlib.lzma.patch
    patching file C/7zip/Compress/LZMA/LZMADecoder.cpp
    patching file C/7zip/Compress/LZMA/LZMADecoder.h
    patching file C/7zip/Compress/LZMA_Lib/makefile
    patching file C/7zip/Compress/LZMA_Lib/ZLib.cpp
    applying patch file tools/make/patches/100-outbuffer.lzma.patch
    patching file C/7zip/Common/OutBuffer.cpp
touch /home/freetz/trunk/source/host-tools/lzma443/.unpacked
make -j2 -C /home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib'
g++ -O3 -Wall -c  -I ../../../ ZLib.cpp
g++ -O3 -Wall -c  -I ../../../ ../LZMA/LZMADecoder.cpp
../LZMA/LZMADecoder.cpp: In member function âvirtual LONG NCompress::NLZMA::CDecoder::SetOutStreamSize(const UInt64*)â:
../LZMA/LZMADecoder.cpp:317:42: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
g++ -O3 -Wall -c  -I ../../../ ../LZMA/LZMAEncoder.cpp
../LZMA/LZMAEncoder.cpp: In member function âLONG NCompress::NLZMA::CEncoder::GetOptimumFast(UInt32, UInt32&, UInt32&)â:
../LZMA/LZMAEncoder.cpp:1207:68: warning: suggest parentheses around â&&â within â||â [-Wparentheses]
../LZMA/LZMAEncoder.cpp:1208:69: warning: suggest parentheses around â&&â within â||â [-Wparentheses]
../LZMA/LZMAEncoder.cpp:1223:82: warning: suggest parentheses around â&&â within â||â [-Wparentheses]
../LZMA/LZMAEncoder.cpp:1225:97: warning: suggest parentheses around â&&â within â||â [-Wparentheses]
g++ -O3 -Wall -c  -I ../../../ ../LZ/LZInWindow.cpp
g++ -O3 -Wall -c  -I ../../../ ../LZ/LZOutWindow.cpp
g++ -O3 -Wall -c  -I ../../../ ../RangeCoder/RangeCoderBit.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/InBuffer.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/OutBuffer.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/FileStreams.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/Alloc.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/C_FileIO.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/CommandLineParser.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/CRC.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/StreamUtils.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/String.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/StringConvert.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/StringToInt.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/Vector.cpp
ar r liblzma.a ZLib.o LZMADecoder.o LZMAEncoder.o LZInWindow.o LZOutWindow.o RangeCoderBit.o InBuffer.o OutBuffer.o FileStreams.o Alloc.o C_FileIO.o CommandLineParser.o CRC.o StreamUtils.o String.o StringConvert.o StringToInt.o Vector.o
ar: creating liblzma.a
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib'
touch -c /home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib/liblzma.a
cp -f /home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib/liblzma.a /home/freetz/trunk/source/host-tools/lzma443/liblzma.a
make -j2 -f makefile.gcc -C /home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone'
g++ -O2 -Wall -c -I ../../../ LzmaAlone.cpp
g++ -O2 -Wall -c -I ../../../ LzmaBench.cpp
LzmaBench.cpp: In function âvoid ThrowError(FILE*, LONG, const char*)â:
LzmaBench.cpp:366:17: warning: format not a string literal and no format arguments [-Wformat-security]
LzmaAlone.cpp: In function âint main2(int, const char**)â:
LzmaAlone.cpp:371:76: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
LzmaAlone.cpp:447:36: warning: format not a string literal and no format arguments [-Wformat-security]
LzmaAlone.cpp:473:33: warning: format not a string literal and no format arguments [-Wformat-security]
LzmaAlone.cpp:478:33: warning: format not a string literal and no format arguments [-Wformat-security]
LzmaAlone.cpp:492:35: warning: format not a string literal and no format arguments [-Wformat-security]
LzmaAlone.cpp:497:35: warning: format not a string literal and no format arguments [-Wformat-security]
g++ -O2 -Wall -c -I ../../../ LzmaRam.cpp
gcc -O2 -Wall -c -I ../../../ LzmaRamDecode.c
gcc -O2 -Wall -c -I ../../../ ../LZMA_C/LzmaDecode.c
gcc -O2 -Wall -c -I ../../../ ../Branch/BranchX86.c
g++ -O2 -Wall -c -I ../../../ ../LZMA/LZMADecoder.cpp
g++ -O2 -Wall -c -I ../../../ ../LZMA/LZMAEncoder.cpp
g++ -O2 -Wall -c -I ../../../ ../LZ/LZInWindow.cpp
g++ -O2 -Wall -c -I ../../../ ../LZ/LZOutWindow.cpp
g++ -O2 -Wall -c -I ../../../ ../RangeCoder/RangeCoderBit.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/InBuffer.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/OutBuffer.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/FileStreams.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/StreamUtils.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/Alloc.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/C_FileIO.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/CommandLineParser.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/CRC.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/String.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/StringConvert.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/StringToInt.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/Vector.cpp
g++ -O2 -Wall -o lzma  LzmaAlone.o LzmaBench.o LzmaRam.o LzmaRamDecode.o LzmaDecode.o BranchX86.o LZMADecoder.o LZMAEncoder.o LZInWindow.o LZOutWindow.o RangeCoderBit.o InBuffer.o OutBuffer.o FileStreams.o StreamUtils.o Alloc.o C_FileIO.o CommandLineParser.o CRC.o String.o StringConvert.o StringToInt.o Vector.o  -lm
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone'
cp /home/freetz/trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone/lzma tools/lzma
tar -C /home/freetz/trunk/source/host-tools  -xf tools/source/lzma2eva.tar.bz2
for i in tools/make/patches/*.lzma2eva.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/lzma2eva $i; \
        done
    applying patch file tools/make/patches/100-fix_missing_crc32.lzma2eva.patch
touch /home/freetz/trunk/source/host-tools/lzma2eva/.unpacked
make -j2 CC="gcc" LD="ld" -C /home/freetz/trunk/source/host-tools/lzma2eva
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/lzma2eva'
gcc -o lzma2eva lzma2eva.c -lz
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/lzma2eva'
cp /home/freetz/trunk/source/host-tools/lzma2eva/lzma2eva tools/lzma2eva
tools/freetz_download dl sfk165.zip @SF/swissfileknife/1-swissfileknife/1.6.5 8694d73033dde496c023258f08daa918
--2013-03-18 15:50:43--  http://downloads.sourceforge.net/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip
Location: http://switch.dl.sourceforge.net/project/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip [following]
--2013-03-18 15:50:44--  http://switch.dl.sourceforge.net/project/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip
Resolving switch.dl.sourceforge.net (switch.dl.sourceforge.net)... 130.59.138.21, 2001:620:0:1b::21
Connecting to switch.dl.sourceforge.net (switch.dl.sourceforge.net)|130.59.138.21|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2817916 (2.7M) [application/zip]
Saving to: `dl/sfk165.zip'
100%[=========================================================================================================================>] 2,817,916    512K/s   in 5.4s
2013-03-18 15:50:49 (505 KB/s) - `dl/sfk165.zip' saved [2817916/2817916]
Download succeeded - "http://downloads.sourceforge.net/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip"  ->  saved to folder "dl"
MD5 verified for dl/sfk165.zip: 8694d73033dde496c023258f08daa918
unzip -d /home/freetz/trunk/source/host-tools dl/sfk165.zip
Archive:  dl/sfk165.zip
   creating: /home/freetz/trunk/source/host-tools/sfk165/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/bsd-license.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/do-compile-unix.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/do-compile-win.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/do-prep-linux-bin.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/do-view-all-win.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/do-view-readme-win.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/inst.cpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/macbin/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/macbin/readme.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/macbin/sfk-mac-i686.exe
  inflating: /home/freetz/trunk/source/host-tools/sfk165/macbin/sfk-mac-ppc.exe
  inflating: /home/freetz/trunk/source/host-tools/sfk165/memdeb.cpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/mtk/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/mtk/mtktrace.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/mtk/mtktrace.hpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/mtk/readme.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/patch.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/readme.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/scripts/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/01-sfk-selftest-win.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/02-conv-win-to-ux.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/03-sfk-selftest-ux.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/10-sfk-selftest-db.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/10-sfk-selftest-db.txt2
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/11-sub-test-win.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/12-sub-test-ux.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/13-sfk-selftest-ux-pre.bat
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/14-sfk-selftest-ux-fix.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/15-sfk-selftest-ux-fix.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/50-patch-all-ux.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/50-patch-all-win.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/scripts/readme.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/sfk.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/sfk.exe
  inflating: /home/freetz/trunk/source/host-tools/sfk165/sfkbase.hpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/sfknet.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/sfknet.hpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/BaseLib/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/BaseLib/Trace/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/BaseLib/Trace/include/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/BaseLib/Trace/include/Trace.hpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarBottle.hpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarDriver.hpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarGlass.hpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarMug.hpp
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/ExtremelyLongHeaderFileNameForRatherSeldomUsedClass.hpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarBottle.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarDriver.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarGlass.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarMug.cpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/DB/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/DB/include/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/DB/include/DBController.hpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/DB/source/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/DB/source/DBController.cpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/include/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/include/FooGUI.hpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/source/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/source/FooGUI.cpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/01-native-tab-crlf.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/02-crlf.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/03-native-tab-lf.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/04-lf.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/05-split-text.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/06-binary.jpg
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/07-filter-src.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/08-head-tail.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/09 blank file name.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/10-dir-list.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/11-wide-line.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/12-foo-jam.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/13-eof-null.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/14-all-codes.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/15-float-text.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/16-short-words.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/17 blank dir/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/17 blank dir/tree with blank/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/17 blank dir/tree with blank/file name.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/18-ziptest.zip
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/19-jartest.jar
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/20-tab-data-line.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/21-patch-bin.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/22-umlauts-???????-name.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/23-filt-patterns.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/24-line-blocks.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/25-nested-zip.zip
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/26-flat-tar.tar
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/27-pack-text1.txt.gz
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/28-pack-text2.txt.bz2
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/29-pack-tape1.tar.gz
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/30-pack-tape2.tar.bz2
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/31-nested-arc.tar.gz
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/32-pack-tape3.tgz
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/33-nested-any.zip
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/Formats/34-csv-data-lines.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/.myscm/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/.myscm/root.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/.myscm.bak/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/.myscm.bak/root.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/01-make-all.sh
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/base/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/base/Tools.cpp
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/base/Tools.hpp
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/login/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/login/Screen.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/config.h
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/config.h.bak
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/myscm-use.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/save/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/save/config.h
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/save2/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/save2/config.h
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/save3/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/save3/config.h
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tmp/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tmp/trash1.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tmp/trash2.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tmp/trash3.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/.myscm/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/.myscm/sub1.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/.myscm/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/.myscm/sub2.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/Tools.hpp
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/Tools.hpp.bak
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/new.myscm/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/new.myscm/sub1.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/org.myscm/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/org.myscm/sub1.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/.myscm/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/.myscm/sub3.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/other1.myscm
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/other1.myscm.bak
   creating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/.myscm
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/.myscm-file.txt
 extracting: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/Tools.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/Tools.cpp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/Tools.tmp
  inflating: /home/freetz/trunk/source/host-tools/sfk165/testfiles/readme.txt
   creating: /home/freetz/trunk/source/host-tools/sfk165/uxbin/
  inflating: /home/freetz/trunk/source/host-tools/sfk165/uxbin/readme.txt
  inflating: /home/freetz/trunk/source/host-tools/sfk165/uxbin/sfk-linux-lib5.exe
  inflating: /home/freetz/trunk/source/host-tools/sfk165/uxbin/sfk-linux.exe
  inflating: /home/freetz/trunk/source/host-tools/sfk165/zz-bookmarks.1.dvbm
touch /home/freetz/trunk/source/host-tools/sfk165/.unpacked
g++ -s /home/freetz/trunk/source/host-tools/sfk165/sfk.cpp /home/freetz/trunk/source/host-tools/sfk165/sfknet.cpp /home/freetz/trunk/source/host-tools/sfk165/patch.cpp /home/freetz/trunk/source/host-tools/sfk165/inst.cpp -o /home/freetz/trunk/source/host-tools/sfk165/sfk
/home/freetz/trunk/source/host-tools/sfk165/sfk.cpp: In function âunsigned char matchstr(char*, char*, int, int&, int&)â:
/home/freetz/trunk/source/host-tools/sfk165/sfk.cpp:8075:86: warning: format â%dâ expects argument of type âintâ, but argument 3 has type âlong intâ [-Wformat]
/home/freetz/trunk/source/host-tools/sfk165/sfk.cpp:8080:90: warning: format â%dâ expects argument of type âintâ, but argument 3 has type âlong intâ [-Wformat]
/home/freetz/trunk/source/host-tools/sfk165/sfk.cpp:8180:102: warning: format â%dâ expects argument of type âintâ, but argument 4 has type âlong intâ [-Wformat]
/home/freetz/trunk/source/host-tools/sfk165/sfk.cpp: In function âint prtFile(char*, char*, Coi*, char*, int, const char*, ...)â:
/home/freetz/trunk/source/host-tools/sfk165/sfk.cpp:17655:103: warning: format â%uâ expects argument of type âunsigned intâ, but argument 3 has type âsize_t {aka long unsigned int}â [-Wformat]
cp /home/freetz/trunk/source/host-tools/sfk165/sfk tools/sfk
tools/freetz_download dl squashfs2.2-r2.tar.gz @SF/squashfs a8d09a217240127ae4d339e8368d2de1
--2013-03-18 15:50:53--  http://downloads.sourceforge.net/squashfs/squashfs2.2-r2.tar.gz
Location: http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz [following]
--2013-03-18 15:50:54--  http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz
Location: http://kent.dl.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz [following]
--2013-03-18 15:50:54--  http://kent.dl.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz
Resolving kent.dl.sourceforge.net (kent.dl.sourceforge.net)... 212.219.56.185
Connecting to kent.dl.sourceforge.net (kent.dl.sourceforge.net)|212.219.56.185|:80... connected.
Length: 234231 (229K) [application/x-gzip]
Saving to: `dl/squashfs2.2-r2.tar.gz'
100%[=========================================================================================================================>] 234,231      470K/s   in 0.5s
2013-03-18 15:50:54 (470 KB/s) - `dl/squashfs2.2-r2.tar.gz' saved [234231/234231]
Download succeeded - "http://downloads.sourceforge.net/squashfs/squashfs2.2-r2.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/squashfs2.2-r2.tar.gz: a8d09a217240127ae4d339e8368d2de1
tar -C /home/freetz/trunk/source/host-tools  -xf dl/squashfs2.2-r2.tar.gz
for i in tools/make/patches/*.squashfs.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/squashfs2.2-r2 $i; \
        done
    applying patch file tools/make/patches/100-lzma-and-unsquashfs.squashfs.patch
    patching file squashfs-tools/Makefile
    patching file squashfs-tools/squashfs_fs.h
    patching file squashfs-tools/unsquashfs.c
    applying patch file tools/make/patches/110-allow-symlinks.squashfs.patch
    patching file squashfs-tools/mksquashfs.c
    applying patch file tools/make/patches/115-osx.squashfs.patch
    patching file squashfs-tools/read_fs.c
touch /home/freetz/trunk/source/host-tools/squashfs2.2-r2/.unpacked
make -j2 CC="gcc" CXX="g++" LZMA_DIR="/home/freetz/trunk/source/host-tools/lzma443" \
                -C /home/freetz/trunk/source/host-tools/squashfs2.2-r2/squashfs-tools mksquashfs-lzma unsquashfs-lzma
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/squashfs2.2-r2/squashfs-tools'
sed -e 's/#define SQUASHFS_MINOR\t\t\t1/#define SQUASHFS_MINOR\t\t\t76/g' squashfs_fs.h > squashfs_fs-lzma.h
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o read_fs.o read_fs.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o sort.o sort.c
sed -e 's/squashfs_fs\.h/squashfs_fs-lzma.h/g' unsquashfs.c > unsquashfs-lzma.c
sed -e 's/squashfs_fs\.h/squashfs_fs-lzma.h/g' mksquashfs.c > mksquashfs-lzma.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o unsquashfs-lzma.o unsquashfs-lzma.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o mksquashfs-lzma.o mksquashfs-lzma.c
mksquashfs-lzma.c: In function âdir_scanâ:
mksquashfs-lzma.c:1456:6: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
g++ unsquashfs-lzma.o -L/home/freetz/trunk/source/host-tools/lzma443 -llzma -o unsquashfs-lzma
g++ mksquashfs-lzma.o read_fs.o sort.o -L/home/freetz/trunk/source/host-tools/lzma443 -llzma -o mksquashfs-lzma
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/squashfs2.2-r2/squashfs-tools'
touch -c /home/freetz/trunk/source/host-tools/squashfs2.2-r2/squashfs-tools/mksquashfs-lzma
cp /home/freetz/trunk/source/host-tools/squashfs2.2-r2/squashfs-tools/mksquashfs-lzma tools/mksquashfs-lzma
strip tools/mksquashfs-lzma
cp /home/freetz/trunk/source/host-tools/squashfs2.2-r2/squashfs-tools/unsquashfs-lzma tools/unsquashfs-lzma
strip tools/unsquashfs-lzma
tools/freetz_download dl squashfs3.4.tar.gz @SF/squashfs 2a4d2995ad5aa6840c95a95ffa6b1da6
--2013-03-18 15:50:55--  http://downloads.sourceforge.net/squashfs/squashfs3.4.tar.gz
Location: http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz [following]
--2013-03-18 15:50:56--  http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz
Location: http://garr.dl.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz [following]
--2013-03-18 15:50:56--  http://garr.dl.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz
Resolving garr.dl.sourceforge.net (garr.dl.sourceforge.net)... 193.206.140.34, 2001:760:ffff:b0::34
Connecting to garr.dl.sourceforge.net (garr.dl.sourceforge.net)|193.206.140.34|:80... connected.
Length: 352660 (344K) [application/x-gzip]
Saving to: `dl/squashfs3.4.tar.gz'
100%[=========================================================================================================================>] 352,660      333K/s   in 1.0s
2013-03-18 15:50:57 (333 KB/s) - `dl/squashfs3.4.tar.gz' saved [352660/352660]
Download succeeded - "http://downloads.sourceforge.net/squashfs/squashfs3.4.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/squashfs3.4.tar.gz: 2a4d2995ad5aa6840c95a95ffa6b1da6
tar -C /home/freetz/trunk/source/host-tools  -xf dl/squashfs3.4.tar.gz
for i in tools/make/patches/*.squashfs3.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/host-tools/squashfs3.4 $i; \
        done
    applying patch file tools/make/patches/100-lzma.squashfs3.patch
    applying patch file tools/make/patches/120-memset-sBlk.squashfs3.patch
    applying patch file tools/make/patches/130-inode_number.squashfs3.patch
    applying patch file tools/make/patches/140-hide_output.squashfs3.patch
    applying patch file tools/make/patches/150-malloc_size.squashfs3.patch
    applying patch file tools/make/patches/160-queue_race_condition.squashfs3.patch
    applying patch file tools/make/patches/170-read_EINTR_or_EOF.squashfs3.patch
    applying patch file tools/make/patches/180-no_empty_files_on_read_error_abort_instead.squashfs3.patch
    applying patch file tools/make/patches/190-memcpy_memmove.squashfs3.patch
    applying patch file tools/make/patches/200-writer_buffer_leak.squashfs3.patch
    applying patch file tools/make/patches/210-progress_bar-floating_point_exception.squashfs3.patch
    applying patch file tools/make/patches/220-osx.squashfs3.patch
touch /home/freetz/trunk/source/host-tools/squashfs3.4/.unpacked
                -C /home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools all
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools'
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o mksquashfs.o mksquashfs.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o read_fs.o read_fs.c
mksquashfs.c: In function âdir_scan2â:
mksquashfs.c:3033:6: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
mksquashfs.c:3087:7: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
mksquashfs.c: In function âwrite_file_blocks_dupâ:
mksquashfs.c:2572:13: warning: ignoring return value of âftruncateâ, declared with attribute warn_unused_result [-Wunused-result]
mksquashfs.c:2600:12: warning: ignoring return value of âftruncateâ, declared with attribute warn_unused_result [-Wunused-result]
mksquashfs.c: In function âwrite_file_blocksâ:
mksquashfs.c:2476:12: warning: ignoring return value of âftruncateâ, declared with attribute warn_unused_result [-Wunused-result]
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o sort.o sort.c
sort.c: In function âsort_files_and_writeâ:
sort.c:238:5: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
sort.c:245:5: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o unsquashfs.o unsquashfs.c
sed -e 's/#define SQUASHFS_MINOR\t\t\t0/#define SQUASHFS_MINOR\t\t\t76/g' squashfs_fs.h > squashfs_fs-lzma.h
gcc unsquashfs.o -lz -lpthread -lm -o unsquashfs3
gcc mksquashfs.o read_fs.o sort.o -lz -lpthread -lm -o mksquashfs3
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o mksquashfs-lzma.o mksquashfs-lzma.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o unsquashfs-lzma.o unsquashfs-lzma.c
mksquashfs-lzma.c: In function âdir_scan2â:
mksquashfs-lzma.c:3033:6: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
mksquashfs-lzma.c:3087:7: warning: format â%lldâ expects argument of type âlong long intâ, but argument 3 has type â__off_tâ [-Wformat]
mksquashfs-lzma.c: In function âwrite_file_blocks_dupâ:
mksquashfs-lzma.c:2572:13: warning: ignoring return value of âftruncateâ, declared with attribute warn_unused_result [-Wunused-result]
mksquashfs-lzma.c:2600:12: warning: ignoring return value of âftruncateâ, declared with attribute warn_unused_result [-Wunused-result]
mksquashfs-lzma.c: In function âwrite_file_blocksâ:
mksquashfs-lzma.c:2476:12: warning: ignoring return value of âftruncateâ, declared with attribute warn_unused_result [-Wunused-result]
g++ unsquashfs-lzma.o -L/home/freetz/trunk/source/host-tools/lzma443 -llzma -lpthread -lm -o unsquashfs3-lzma
g++ mksquashfs-lzma.o read_fs.o sort.o -L/home/freetz/trunk/source/host-tools/lzma443 -llzma -lpthread -lm -o mksquashfs3-lzma
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools'
touch -c /home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools/mksquashfs3
cp /home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools/mksquashfs3 tools/mksquashfs3
strip tools/mksquashfs3
cp /home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools/unsquashfs3 tools/unsquashfs3
strip tools/unsquashfs3
cp /home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools/mksquashfs3-lzma tools/mksquashfs3-lzma
strip tools/mksquashfs3-lzma
cp /home/freetz/trunk/source/host-tools/squashfs3.4/squashfs-tools/unsquashfs3-lzma tools/unsquashfs3-lzma
strip tools/unsquashfs3-lzma
rm -f -r /home/freetz/trunk/source/host-tools/TI-chksum-0.2
mkdir -p /home/freetz/trunk/source/host-tools/TI-chksum-0.2
tar cC tools/make/tichksum/src . | tar xC /home/freetz/trunk/source/host-tools/TI-chksum-0.2  --exclude=.svn
touch /home/freetz/trunk/source/host-tools/TI-chksum-0.2/.unpacked
make -j2 CC="gcc" LD="ld" \
                -C /home/freetz/trunk/source/host-tools/TI-chksum-0.2
make[1]: Entering directory `/home/freetz/trunk/source/host-tools/TI-chksum-0.2'
gcc -W -Wall -O2   -c -o ckmain.o ckmain.c
gcc -W -Wall -O2   -c -o cksum.o cksum.c
cksum.c: In function âcs_is_taggedâ:
cksum.c:102:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing]
cksum.c: In function âcs_get_sumâ:
cksum.c:193:8: warning: ignoring return value of âfreadâ, declared with attribute warn_unused_result [-Wunused-result]
cksum.c:194:8: warning: ignoring return value of âfreadâ, declared with attribute warn_unused_result [-Wunused-result]
cksum.c: In function âcs_read_sumâ:
cksum.c:112:8: warning: ignoring return value of âfreadâ, declared with attribute warn_unused_result [-Wunused-result]
cksum.c:101:8: warning: ignoring return value of âfreadâ, declared with attribute warn_unused_result [-Wunused-result]
gcc -o tichksum ckmain.o cksum.o
make[1]: Leaving directory `/home/freetz/trunk/source/host-tools/TI-chksum-0.2'
cp /home/freetz/trunk/source/host-tools/TI-chksum-0.2/tichksum tools/tichksum
--2013-03-18 15:51:03--  http://freetz.wirsind.info/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma
Resolving freetz.wirsind.info (freetz.wirsind.info)... 87.98.242.177
Connecting to freetz.wirsind.info (freetz.wirsind.info)|87.98.242.177|:80... connected.
Length: 5192957 (5.0M) [application/octet-stream]
Saving to: `dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma'
100%[=========================================================================================================================>] 5,192,957    505K/s   in 12s
2013-03-18 15:51:16 (414 KB/s) - `dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma' saved [5192957/5192957]
Download succeeded - "http://freetz.wirsind.info/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma"  ->  saved to folder "dl"
MD5 verified for dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma: b17b7f26931ad8f263953a2dfc1d08b7
mkdir -p toolchain/build
rm -f -r toolchain/build/mipsel_gcc-4.6.3
tools/busybox tar  -xf dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma -C toolchain/build
---> kernel:  downloading...tools/freetz_download dl/fw ""7270_05.21"-release_kernel.tar.xz" "" "e396bbfcbd88c09cfcc652f94b7f8a57"
--2013-03-18 15:51:16--  http://freetz.wirsind.info/7270_05.21-release_kernel.tar.xz
Length: 58215296 (56M) [application/octet-stream]
Saving to: `dl/fw/7270_05.21-release_kernel.tar.xz'
100%[=========================================================================================================================>] 58,215,296   569K/s   in 1m 55s
2013-03-18 15:53:12 (493 KB/s) - `dl/fw/7270_05.21-release_kernel.tar.xz' saved [58215296/58215296]
Download succeeded - "http://freetz.wirsind.info/7270_05.21-release_kernel.tar.xz"  ->  saved to folder "dl/fw"
MD5 verified for dl/fw/7270_05.21-release_kernel.tar.xz: e396bbfcbd88c09cfcc652f94b7f8a57
rm -f -r source/kernel/ref-ur8-7270_05.21
mkdir -p source/kernel/ref-ur8-7270_05.21
checking structure...  unpacking...  preparing...     applying patch file make/linux/patches/2.6.32/001-drivers_dsl_kconfig.patch
    patching file linux-2.6.32/drivers/dsl/Kconfig
    patching file linux-2.6.32/drivers/dsl/Makefile.26
    patching file linux-2.6.32/drivers/Kconfig
    applying patch file make/linux/patches/2.6.32/002-usb_musb_kconfig.patch
    patching file linux-2.6.32/drivers/usb/Kconfig
    applying patch file make/linux/patches/2.6.32/009-jffs-fix-min-max-confusion.patch
    patching file linux-2.6.32/fs/jffs2/summary.c
    applying patch file make/linux/patches/2.6.32/010-shell_bash.patch
    patching file linux-2.6.32/Makefile
    applying patch file make/linux/patches/2.6.32/012-extra_optimization.patch
    applying patch file make/linux/patches/2.6.32/022-mips_use_generic_thread_info_allocator.patch
    patching file linux-2.6.32/arch/mips/include/asm/thread_info.h
    applying patch file make/linux/patches/2.6.32/023-mips-fix-kexec.patch
    patching file linux-2.6.32/arch/mips/kernel/machine_kexec.c
    applying patch file make/linux/patches/2.6.32/100-evaloader.patch
    patching file linux-2.6.32/arch/mips/Makefile
    applying patch file make/linux/patches/2.6.32/100-netfilter_layer7_2.21.patch
    patching file linux-2.6.32/net/netfilter/regexp/regexp.c
    patching file linux-2.6.32/net/netfilter/regexp/regexp.h
    patching file linux-2.6.32/net/netfilter/regexp/regmagic.h
    patching file linux-2.6.32/net/netfilter/regexp/regsub.c
    applying patch file make/linux/patches/2.6.32/115-netfilter_recent_reap.patch
    patching file linux-2.6.32/include/linux/netfilter/xt_recent.h
    patching file linux-2.6.32/net/netfilter/xt_recent.c
    applying patch file make/linux/patches/2.6.32/120-capi-missing-compiler-includes.patch
    patching file linux-2.6.32/include/linux/capi.h
    patching file linux-2.6.32/include/linux/kernelcapi.h
    applying patch file make/linux/patches/2.6.32/199-remove_double_hash_conntrack.patch
    patching file linux-2.6.32/net/netfilter/nf_conntrack_core.c
    applying patch file make/linux/patches/2.6.32/230-cifs_revert_slow_work.patch
    patching file linux-2.6.32/fs/cifs/cifsfs.c
    patching file linux-2.6.32/fs/cifs/cifsglob.h
    patching file linux-2.6.32/fs/cifs/cifsproto.h
    patching file linux-2.6.32/fs/cifs/cifssmb.c
    patching file linux-2.6.32/fs/cifs/connect.c
    patching file linux-2.6.32/fs/cifs/dir.c
    patching file linux-2.6.32/fs/cifs/Kconfig
    patching file linux-2.6.32/fs/cifs/misc.c
    patching file linux-2.6.32/fs/cifs/transport.c
    patching file linux-2.6.32/fs/cifs/file.c
    applying patch file make/linux/patches/2.6.32/300-mppe-mppc.patch
    patching file linux-2.6.32/crypto/api.c
    patching file linux-2.6.32/drivers/net/Kconfig
    patching file linux-2.6.32/drivers/net/Makefile
    patching file linux-2.6.32/drivers/net/ppp_mppe_mppc.c
    patching file linux-2.6.32/include/linux/crypto.h
    patching file linux-2.6.32/include/linux/ppp-comp.h
    patching file linux-2.6.32/drivers/net/ppp_generic.c
    applying patch file make/linux/patches/2.6.32/300-skbuff-nf_conntrack.patch
    patching file linux-2.6.32/include/linux/skbuff.h
    patching file linux-2.6.32/net/core/skbuff.c
    applying patch file make/linux/patches/2.6.32/400-ftdi-smartmouse.patch
    patching file linux-2.6.32/drivers/usb/serial/ftdi_sio_ids.h
    patching file linux-2.6.32/drivers/usb/serial/ftdi_sio.c
    applying patch file make/linux/patches/2.6.32/401-ftdi-working.patch
    applying patch file make/linux/patches/2.6.32/530-scsi_user_space.patch
    patching file linux-2.6.32/include/scsi/scsi.h
    patching file linux-2.6.32/include/scsi/scsi_netlink.h
    applying patch file make/linux/patches/2.6.32/540-export_scsi_headers.patch
    patching file linux-2.6.32/include/scsi/Kbuild
    applying patch file make/linux/patches/2.6.32/710-scall32.patch
    patching file linux-2.6.32/arch/mips/kernel/scall32-o32.S
#Version specific patches
    applying patch file make/linux/patches/2.6.32/7270_05.21/003-pppoatm.c.patch
    patching file linux-2.6.32/net/atm/pppoatm.c
    applying patch file make/linux/patches/2.6.32/7270_05.21/110-hwrev_list.patch
    patching file linux-2.6.32/drivers/net/avm_cpmac/Makefile
    applying patch file make/linux/patches/2.6.32/7270_05.21/200-no_avm_extras.patch
    patching file linux-2.6.32/drivers/block/compcache/Makefile
    patching file linux-2.6.32/drivers/rtc/Makefile
    applying patch file make/linux/patches/2.6.32/7270_05.21/500-fix_7270v1_hw_config.patch
    patching file linux-2.6.32/arch/mips/ur8/avm_hw_config.c
    patching file linux-2.6.32/arch/mips/include/asm/avm_cache.h
    patching file linux-2.6.32/drivers/net/avm_cpmac/cpmac_product_conf.c
    applying patch file make/linux/patches/2.6.32/7270_05.21/690-no_system-load-1_messages.patch
    patching file linux-2.6.32/arch/mips/kernel/process.c
    applying patch file make/linux/patches/2.6.32/7270_05.21/999-cpmac_debug_sk_buff.patch
    patching file linux-2.6.32/drivers/net/avm_cpmac/cpphy_entry.c
 Linking  source/kernel/ref-ur8-7270_05.21/linux-2.6.32/include/linux/new_capi_debug.h
 Linking  source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/dsl/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/kernel/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/kvm/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/lib/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/mm/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/oprofile/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/platforms/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/sysdev/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/xmon/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/x86/vdso/vdso32-syms.lds/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/x86/vdso/vdso-syms.lds/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/infiniband/hw/amso1100/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/infiniband/ulp/srp/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/mei/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/mtd/nand/avm_nand/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/scsi/cxgb3i/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/scsi/osd/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/usb/host/whci/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/firmware/dummy/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fs/exofs/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fusiv_src/kernel/drivers/bmedriver/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fusiv_src/kernel/drivers/policyVlan/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fusiv_src/kernel/drivers/voice/ipvoice/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/source
ln -s linux-2.6.32 source/kernel/ref-ur8-7270_05.21/linux
touch source/kernel/ref-ur8-7270_05.21/.unpacked
if [ ! -e source/.echo_item_start ]; then       echo -n "---> "; case "" in BIN)        echo -n "package/: " ;; LIB)    echo -n "library/: " ;; TOOL)   echo -n "tool/: " ;; *)    echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n " configuring... ";
 configuring... cp make/linux/Config.ur8.7270_05.21 source/kernel/ref-ur8-7270_05.21/linux-2.6.32/.config
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ur8-7270_05.21/linux-2.6.32 CROSS_COMPILE="mipsel-unknown-linux-gnu-" KERNEL_MAKE_PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" ARCH="mips" INSTALL_HDR_PATH=/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32 INSTALL_MOD_PATH="/home/freetz/trunk/source/kernel/ref-ur8-7270_05.21" oldconfig
building... make[1]: Entering directory `/home/freetz/trunk/source/kernel/ref-ur8-7270_05.21/linux-2.6.32'
Makefile:197: use: CROSS_COMPILE=mipsel-unknown-linux-gnu-
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/docproc
  HOSTCC  scripts/basic/hash
  HOSTCC  scripts/kconfig/conf.o
scripts/kconfig/conf.c: In function âconf_symâ:
scripts/kconfig/conf.c:162:6: warning: variable âtypeâ set but not used [-Wunused-but-set-variable]
scripts/kconfig/conf.c: In function âconf_choiceâ:
scripts/kconfig/conf.c:234:6: warning: variable âtypeâ set but not used [-Wunused-but-set-variable]
  HOSTCC  scripts/kconfig/kxgettext.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/lex.zconf.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -o arch/mips/Kconfig
fusiv_src/kernel/Kconfig:79:warning: defaults for choice values not supported
# configuration written to .config
make[1]: Leaving directory `/home/freetz/trunk/source/kernel/ref-ur8-7270_05.21/linux-2.6.32'
touch source/kernel/ref-ur8-7270_05.21/.configured
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ur8-7270_05.21/linux-2.6.32 CROSS_COMPILE="mipsel-unknown-linux-gnu-" KERNEL_MAKE_PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" ARCH="mips" INSTALL_HDR_PATH=/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32 INSTALL_MOD_PATH="/home/freetz/trunk/source/kernel/ref-ur8-7270_05.21" prepare
/home/freetz/trunk/source/kernel/ref-ur8-7270_05.21/linux-2.6.32/Makefile:197: use: CROSS_COMPILE=mipsel-unknown-linux-gnu-
scripts/kconfig/conf -s arch/mips/Kconfig
  CHK     include/linux/version.h
  UPD     include/linux/version.h
  CHK     include/linux/utsrelease.h
  UPD     include/linux/utsrelease.h
  SYMLINK include/asm -> include/asm-mips
  CC      kernel/bounds.s
  GEN     include/linux/bounds.h
  CC      arch/mips/kernel/asm-offsets.s
  GEN     include/asm/asm-offsets.h
  CALL    scripts/checksyscalls.sh
<stdin>:1655:2: warning: #warning syscall shmget not implemented [-Wcpp]
<stdin>:1659:2: warning: #warning syscall shmat not implemented [-Wcpp]
<stdin>:1663:2: warning: #warning syscall shmctl not implemented [-Wcpp]
<stdin>:1791:2: warning: #warning syscall semget not implemented [-Wcpp]
<stdin>:1795:2: warning: #warning syscall semop not implemented [-Wcpp]
<stdin>:1799:2: warning: #warning syscall semctl not implemented [-Wcpp]
<stdin>:1803:2: warning: #warning syscall shmdt not implemented [-Wcpp]
<stdin>:1807:2: warning: #warning syscall msgget not implemented [-Wcpp]
<stdin>:1811:2: warning: #warning syscall msgsnd not implemented [-Wcpp]
<stdin>:1815:2: warning: #warning syscall msgrcv not implemented [-Wcpp]
<stdin>:1819:2: warning: #warning syscall msgctl not implemented [-Wcpp]
<stdin>:2251:2: warning: #warning syscall reserved177 not implemented [-Wcpp]
<stdin>:2315:2: warning: #warning syscall reserved193 not implemented [-Wcpp]
<stdin>:2399:2: warning: #warning syscall semtimedop not implemented [-Wcpp]
<stdin>:2843:2: warning: #warning syscall shmget not implemented [-Wcpp]
<stdin>:2847:2: warning: #warning syscall shmat not implemented [-Wcpp]
<stdin>:2851:2: warning: #warning syscall shmctl not implemented [-Wcpp]
<stdin>:2979:2: warning: #warning syscall semget not implemented [-Wcpp]
<stdin>:2983:2: warning: #warning syscall semop not implemented [-Wcpp]
<stdin>:2987:2: warning: #warning syscall semctl not implemented [-Wcpp]
<stdin>:2991:2: warning: #warning syscall shmdt not implemented [-Wcpp]
<stdin>:2995:2: warning: #warning syscall msgget not implemented [-Wcpp]
<stdin>:2999:2: warning: #warning syscall msgsnd not implemented [-Wcpp]
<stdin>:3003:2: warning: #warning syscall msgrcv not implemented [-Wcpp]
<stdin>:3007:2: warning: #warning syscall msgctl not implemented [-Wcpp]
<stdin>:3439:2: warning: #warning syscall reserved177 not implemented [-Wcpp]
<stdin>:3503:2: warning: #warning syscall reserved193 not implemented [-Wcpp]
<stdin>:3591:2: warning: #warning syscall semtimedop not implemented [-Wcpp]
touch source/kernel/ref-ur8-7270_05.21/.prepared
--2013-03-18 15:53:30--  http://freetz.3dfxatwork.de/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma
Resolving freetz.3dfxatwork.de (freetz.3dfxatwork.de)... 85.214.81.232, 2a01:238:4362:b900:fc60:1b77:4435:1ba9
Connecting to freetz.3dfxatwork.de (freetz.3dfxatwork.de)|85.214.81.232|:80... connected.
Length: 8924371 (8.5M) [application/x-tar]
Saving to: `dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma'
100%[=========================================================================================================================>] 8,924,371    529K/s   in 16s
2013-03-18 15:53:46 (557 KB/s) - `dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma' saved [8924371/8924371]
Download succeeded - "http://freetz.3dfxatwork.de/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma"  ->  saved to folder "dl"
MD5 verified for dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma: bc1fa16bb96c2460207059539c9bee00
rm -f -r toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1
tools/busybox tar  -xf dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma -C toolchain/build
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ur8-7270_05.21/linux-2.6.32 CROSS_COMPILE="mipsel-unknown-linux-gnu-" KERNEL_MAKE_PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" ARCH="mips" INSTALL_HDR_PATH=/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32 INSTALL_MOD_PATH="/home/freetz/trunk/source/kernel/ref-ur8-7270_05.21" headers_install
  HOSTCC  scripts/unifdef
  INSTALL include/asm-generic (34 files)
  INSTALL include/drm (12 files)
  INSTALL include/linux/byteorder (2 files)
  INSTALL include/linux/can (4 files)
  INSTALL include/mtd (5 files)
  INSTALL include/linux/dvb (8 files)
  INSTALL include/rdma (1 file)
  INSTALL include/scsi (6 files)
  INSTALL include/linux/hdlc (1 file)
  INSTALL include/linux/isdn (1 file)
  INSTALL include/sound (9 files)
  INSTALL include/linux/netfilter (58 files)
  INSTALL include/video (3 files)
  INSTALL include/xen (1 file)
  INSTALL include (0 file)
  INSTALL include/linux/netfilter_arp (2 files)
  INSTALL include/linux/netfilter_bridge (16 files)
  INSTALL include/linux/netfilter_ipv4 (14 files)
  INSTALL include/linux/netfilter_ipv6 (11 files)
  INSTALL include/linux/nfsd (6 files)
  INSTALL include/linux/raid (2 files)
  INSTALL include/linux/spi (1 file)
  INSTALL include/linux/sunrpc (1 file)
  INSTALL include/linux/tc_act (6 files)
  INSTALL include/linux/tc_ematch (4 files)
  INSTALL include/linux/usb (8 files)
  INSTALL include/linux/wimax (1 file)
  INSTALL include/linux (353 files)
  INSTALL include/asm (33 files)
find "/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32" \( -name "..install.cmd" -o -name ".install" \) -exec rm -f \{\} \+
touch /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32/include/linux/version.h
touch -c /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libc.a
for i in ld-uClibc-0.9.32.1.so ld-uClibc.so.0 libc.so libc.so.0 libcrypt-0.9.32.1.so libcrypt.so libcrypt.so.0 libdl-0.9.32.1.so libdl.so libdl.so.0 libm-0.9.32.1.so libm.so libm.so.0 libpthread-0.9.32.1.so libpthread.so libpthread.so.0 librt-0.9.32.1.so librt.so librt.so.0 libthread_db-0.9.32.1.so libthread_db.so libthread_db.so.1 libuClibc-0.9.32.1.so libutil-0.9.32.1.so libutil.so libutil.so.0; do \
                cp -a /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/lib/$i packages/target-mipsel_uClibc-0.9.32.1/root/lib/$i; \
        done
ln -sf libuClibc-0.9.32.1.so packages/target-mipsel_uClibc-0.9.32.1/root/lib/libc.so
touch -c packages/target-mipsel_uClibc-0.9.32.1/root/lib/libc.so.0
if [ ! -e source/.echo_item_start ]; then       echo -n "---> "; case "LIB" in BIN)     echo -n "package/uclibcxx: " ;; LIB)    echo -n "library/uclibcxx: " ;; TOOL)      echo -n "tool/uclibcxx: " ;; *) echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
downloading...
--2013-03-18 15:53:50--  http://git.uclibc.org/uClibc++/snapshot/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2
Resolving git.uclibc.org (git.uclibc.org)... 140.211.167.224
Connecting to git.uclibc.org (git.uclibc.org)|140.211.167.224|:80... connected.
Length: 257792 (252K) [application/x-bzip2]
Saving to: `dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2'
100%[=========================================================================================================================>] 257,792      236K/s   in 1.1s
2013-03-18 15:53:52 (236 KB/s) - `dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2' saved [257792/257792]
Download succeeded - "http://git.uclibc.org/uClibc++/snapshot/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2: 838aa335ef7f2fcf7191e82d375d0178
preparing... tools/bunzip2 -c dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2 | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/libs/uclibcxx/patches/*.uclibcxx.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30 $i; done
    applying patch file make/libs/uclibcxx/patches/009-compile_fixes.uclibcxx.patch
    patching file include/associative_base
    patching file include/string
    patching file src/string.cpp
    applying patch file make/libs/uclibcxx/patches/010-bitset_fix.uclibcxx.patch
    patching file include/bitset
    applying patch file make/libs/uclibcxx/patches/010-fpos_not_equal_fix.uclibcxx.patch
    patching file include/ios
    applying patch file make/libs/uclibcxx/patches/020-avoid_not_equal.uclibcxx.patch
    patching file include/algorithm
    patching file include/set
    applying patch file make/libs/uclibcxx/patches/030-istream_long_long_support.uclibcxx.patch
    patching file include/istream
    patching file include/istream_helpers
    applying patch file make/libs/uclibcxx/patches/040-iostream_wchar_support.uclibcxx.patch
    patching file include/ostream
    applying patch file make/libs/uclibcxx/patches/050-gcc47x-proper-two-phase-lookup.uclibcxx.patch
    patching file include/fstream
    applying patch file make/libs/uclibcxx/patches/300-wrapper.uclibcxx.patch
    patching file bin/Makefile
    applying patch file make/libs/uclibcxx/patches/400-eabi_fix.uclibcxx.patch
    patching file include/typeinfo
    patching file include/unwind-cxx.h
    applying patch file make/libs/uclibcxx/patches/900-dependent_exception.uclibcxx.patch
    patching file src/eh_alloc.cpp
cp make/libs/uclibcxx/Config.uclibc++ source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/.config
sed -i -r -e 's%^(# )?(UCLIBCXX_HAS_LFS)[ =].*%\2=y%g' -e 's%^(# )?(UCLIBCXX_HAS_WCHAR)[ =].*%# \2 is not set%g' -e 's%^(# )?(UCLIBCXX_SUPPORT_WCIN)[ =].*%# \2 is not set%g' -e 's%^(# )?(UCLIBCXX_SUPPORT_WCOUT)[ =].*%# \2 is not set%g' -e 's%^(# )?(UCLIBCXX_SUPPORT_WCERR)[ =].*%# \2 is not set%g' source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/.config
touch source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/.configured
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30 \
                CPU_CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" \
                CROSS="mipsel-linux-uclibc-" \
                all
make[1]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30'
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/extra/config'
make[2]: warning: jobserver unavailable: using -j1.  Add `+' to parent make rule.
cp zconf.tab.h_shipped zconf.tab.h
gcc -O2 -Wall -I. -c conf.c -o conf.o
conf.c: In function âconf_stringâ:
conf.c:163:20: warning: variable âhelpâ set but not used [-Wunused-but-set-variable]
conf.c:197:6: warning: variable âtypeâ set but not used [-Wunused-but-set-variable]
conf.c:272:6: warning: variable âtypeâ set but not used [-Wunused-but-set-variable]
conf.c:349:9: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
conf.c: In function âconf_askvalueâ:
conf.c:93:8: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
cp zconf.tab.c_shipped zconf.tab.c
cp lex.zconf.c_shipped lex.zconf.c
gcc -O2 -Wall -I. -c zconf.tab.c -o zconf.tab.o
lex.zconf.c:2969:16: warning: âinputâ defined but not used [-Wunused-function]
gcc  conf.o zconf.tab.o -o conf
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/extra/config'
# using defaults found in .config
* uClibc++ Configuration
* Target Features and Options
Enable floating point number support (UCLIBCXX_HAS_FLOATS) [Y/n/?] y
  Math operations with long double (UCLIBCXX_HAS_LONG_DOUBLE) [N/y/?] n
Toolchain supports Thread-Local Storage (UCLIBCXX_HAS_TLS) [N/y/?] n
Compiler Warnings (WARNINGS) []
Extra Library Link Flags (BUILD_EXTRA_LIBRARIES) []
* String and I/O Stream Support
Wide Character Support (Not Currently Supported) (UCLIBCXX_HAS_WCHAR) [N/y/?] n
I/O stream buffer size (UCLIBCXX_IOSTREAM_BUFSIZE) [32] 32
Large File Support (UCLIBCXX_HAS_LFS) [Y/n/?] y
Enable support for standard streams like cin and cout (UCLIBCXX_SUPPORT_CDIR) [Y/n/?] y
  Enable cin (UCLIBCXX_SUPPORT_CIN) [Y/n/?] y
  Enable cout (UCLIBCXX_SUPPORT_COUT) [Y/n/?] y
  Enable cerr (UCLIBCXX_SUPPORT_CERR) [Y/n/?] y
  Enable clog (UCLIBCXX_SUPPORT_CLOG) [N/y/?] n
* STL and Code Expansion
STL buffer size (UCLIBCXX_STL_BUFFER_SIZE) [32] 32
Template code expansion (UCLIBCXX_CODE_EXPANSION) [Y/n/?] y
  Expand constructors and destructors (UCLIBCXX_EXPAND_CONSTRUCTORS_DESTRUCTORS) [N/y/?] n
  Expand std::basic_string for <char> (UCLIBCXX_EXPAND_STRING_CHAR) [Y/n/?] y
  Expand std::vector for basic data types (UCLIBCXX_EXPAND_VECTOR_BASIC) [Y/n/?] y
  Expand ios core code for char (UCLIBCXX_EXPAND_IOS_CHAR) [N/y/?] n
  Expand std::streambuf for char (UCLIBCXX_EXPAND_STREAMBUF_CHAR) [N/y/?] n
  Expand std::istream for <char> (UCLIBCXX_EXPAND_ISTREAM_CHAR) [Y/n/?] y
  Expand std::ostream for <char> (UCLIBCXX_EXPAND_OSTREAM_CHAR) [Y/n/?] y
  Expand std::fstream for <char> (UCLIBCXX_EXPAND_FSTREAM_CHAR) [Y/n/?] y
  Expand std::sstream for <char> (UCLIBCXX_EXPAND_SSTREAM_CHAR) [N/y/?] n
* Library Installation Options
uClibc++ runtime prefix directory (UCLIBCXX_RUNTIME_PREFIX) []
uClibc++ header file subdirectory (UCLIBCXX_RUNTIME_INCLUDE_SUBDIR) [/include/uClibc++] /include/uClibc++
uClibc++ library subdirectory (UCLIBCXX_RUNTIME_LIB_SUBDIR) [/lib] /lib
uClibc++ application file subdirectory (UCLIBCXX_RUNTIME_BIN_SUBDIR) [/bin] /bin
Exception and RTTI support (UCLIBCXX_EXCEPTION_SUPPORT) [Y/n/?] y
  Import libsupc++.a (IMPORT_LIBSUP) [Y/n/?] y
  Import libgcc_eh.a (IMPORT_LIBGCC_EH) [N/y/?] n
Build static library (BUILD_STATIC_LIB) [Y/n/?] y
  Build only static library (BUILD_ONLY_STATIC_LIB) [N/y/?] n
Build uClibc++ with debugging symbols (DODEBUG) [N/y/?] n
for dir in bin include src ; do \
                make -C $dir all; \
        done
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/bin'
echo "#!/bin/sh" > g++-uc
echo "" >> g++-uc
echo 'WRAPPER_INCLUDEDIR="${WRAPPER_INCLUDEDIR:=-I/include/uClibc++/}"' >> g++-uc
echo 'WRAPPER_LIBDIR="${WRAPPER_LIBDIR:=-L/lib/}"' >> g++-uc
echo "" >> g++-uc
echo "WRAPPER_LIBS=\" -L/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/ -lc -lgcc -Wl,--as-needed -lgcc_s -Wl,--no-as-needed\"" >> g++-uc
echo "" >> g++-uc
echo 'WRAPPER_INCLIB=$(echo " $@ " | sed -ne "s/.* -\([cES]\|MF\) .*/NO/p;t;aYES")' >> g++-uc
echo 'WRAPPER_STATIC=$(echo " $@ " | sed -ne "s/.* -static .*/YES/p;t;aNO")' >> g++-uc
echo 'if [ "$WRAPPER_STATIC" = "YES" ]' >> g++-uc
echo 'then' >> g++-uc
echo "  WRAPPER_LIBS=\"-Wl,--start-group  -L/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/ -lc -lgcc -lgcc_eh -Wl,--end-group\"" >> g++-uc
echo 'fi' >> g++-uc
echo 'if [ "$WRAPPER_INCLIB" = "YES" ]' >> g++-uc
echo '  exec mipsel-linux-uclibc-g++ -fno-builtin -nostdinc++ -DGCC_HASCLASSVISIBILITY  $WRAPPER_INCLUDEDIR "$@" -nodefaultlibs $WRAPPER_LIBDIR -luClibc++ $WRAPPER_LIBS' >> g++-uc
echo 'fi' >> g++-uc
echo "" >> g++-uc
echo 'exec mipsel-linux-uclibc-g++ -fno-builtin -nostdinc++ -DGCC_HASCLASSVISIBILITY  $WRAPPER_INCLUDEDIR "$@"' >> g++-uc
chmod 755 g++-uc
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/bin'
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/include'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/include'
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src'
make -C abi/libsupc all
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o algorithm.o -c algorithm.cpp
make[3]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src/abi/libsupc'
mipsel-linux-uclibc-ar x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/../../../../mipsel-linux-uclibc/lib/libsupc++.a
rm -f -f new_op*.o del_op*.o pure.o new_handler.o eh_alloc.o eh_globals.o
make[3]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src/abi/libsupc'
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o associative_base.o -c associative_base.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment algorithm.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o bitset.o -c bitset.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment associative_base.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o char_traits.o -c char_traits.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment bitset.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o complex.o -c complex.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment char_traits.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_op.o -c del_op.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_op.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_opnt.o -c del_opnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_opnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_opv.o -c del_opv.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_opv.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_opvnt.o -c del_opvnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_opvnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o deque.o -c deque.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment complex.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o eh_alloc.o -c eh_alloc.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment deque.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o eh_globals.o -c eh_globals.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment eh_alloc.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o exception.o -c exception.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment exception.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o fstream.o -c fstream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment eh_globals.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o func_exception.o -c func_exception.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment func_exception.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o iomanip.o -c iomanip.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment iomanip.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o ios.o -c ios.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment fstream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o iostream.o -c iostream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment ios.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o istream.o -c istream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment iostream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o iterator.o -c iterator.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment iterator.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o limits.o -c limits.cpp
In file included from limits.cpp:20:0:
../include/limits:24:2: warning: #warning is a GCC extension [enabled by default]
../include/limits:24:2: warning: #warning limits header is nowhere complete or accurate [-Wcpp]
mipsel-linux-uclibc-strip -x -R .note -R .comment limits.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o list.o -c list.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment list.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o locale.o -c locale.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment locale.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o map.o -c map.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment map.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_handler.o -c new_handler.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_handler.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_op.o -c new_op.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_op.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_opnt.o -c new_opnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment istream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_opv.o -c new_opv.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_opnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_opvnt.o -c new_opvnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_opv.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o numeric.o -c numeric.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_opvnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o ostream.o -c ostream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment numeric.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o queue.o -c queue.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment queue.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o set.o -c set.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment set.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o sstream.o -c sstream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment ostream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o stack.o -c stack.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment stack.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o stdexcept.o -c stdexcept.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment stdexcept.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o streambuf.o -c streambuf.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment sstream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o string.o -c string.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment streambuf.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o utility.o -c utility.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment utility.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o valarray.o -c valarray.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment valarray.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o vector.o -c vector.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment vector.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o abi/abi.o -c abi/abi.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment abi/abi.o
mipsel-linux-uclibc-strip -x -R .note -R .comment string.o
mipsel-linux-uclibc-ar rcs libuClibc++.a algorithm.o associative_base.o bitset.o char_traits.o complex.o del_op.o del_opnt.o del_opv.o del_opvnt.o deque.o eh_alloc.o eh_globals.o exception.o fstream.o func_exception.o iomanip.o ios.o iostream.o istream.o iterator.o limits.o list.o locale.o map.o new_handler.o new_op.o new_opnt.o new_opv.o new_opvnt.o numeric.o ostream.o queue.o set.o sstream.o stack.o stdexcept.o streambuf.o string.o utility.o valarray.o vector.o abi/abi.o  abi/libsupc/array_type_info.o abi/libsupc/atexit_arm.o abi/libsupc/bad_alloc.o abi/libsupc/bad_cast.o abi/libsupc/bad_typeid.o abi/libsupc/class_type_info.o abi/libsupc/cp-demangle.o abi/libsupc/dyncast.o abi/libsupc/eh_arm.o abi/libsupc/eh_aux_runtime.o abi/libsupc/eh_call.o abi/libsupc/eh_catch.o abi/libsupc/eh_exception.o abi/libsupc/eh_personality.o abi/libsupc/eh_ptr.o abi/libsupc/eh_term_handler.o abi/libsupc/eh_terminate.o abi/libsupc/eh_throw.o abi/libsupc/eh_type.o abi/libsupc/eh_unex_handler.o abi/libsupc/enum_type_info.o abi/libsupc/function_type_info.o abi/libsupc/fundamental_type_info.o abi/libsupc/guard_error.o abi/libsupc/guard.o abi/libsupc/hash_bytes.o abi/libsupc/nested_exception.o abi/libsupc/pbase_type_info.o abi/libsupc/pmem_type_info.o abi/libsupc/pointer_type_info.o abi/libsupc/si_class_type_info.o abi/libsupc/tinfo2.o abi/libsupc/tinfo.o abi/libsupc/vec.o abi/libsupc/vmi_class_type_info.o abi/libsupc/vterminate.o
mipsel-linux-uclibc-gcc -Wl,--warn-common -Wl,--warn-once -Wl,-z,combreloc -Wl,-z,defs -nodefaultlibs -shared -Wl,-soname,libuClibc++.so.0 `echo ""` -Wl,-s -o libuClibc++-0.2.3.so algorithm.o associative_base.o bitset.o char_traits.o complex.o del_op.o del_opnt.o del_opv.o del_opvnt.o deque.o eh_alloc.o eh_globals.o exception.o fstream.o func_exception.o iomanip.o ios.o iostream.o istream.o iterator.o limits.o list.o locale.o map.o new_handler.o new_op.o new_opnt.o new_opv.o new_opvnt.o numeric.o ostream.o queue.o set.o sstream.o stack.o stdexcept.o streambuf.o string.o utility.o valarray.o vector.o abi/abi.o abi/libsupc/array_type_info.o abi/libsupc/atexit_arm.o abi/libsupc/bad_alloc.o abi/libsupc/bad_cast.o abi/libsupc/bad_typeid.o abi/libsupc/class_type_info.o abi/libsupc/cp-demangle.o abi/libsupc/dyncast.o abi/libsupc/eh_arm.o abi/libsupc/eh_aux_runtime.o abi/libsupc/eh_call.o abi/libsupc/eh_catch.o abi/libsupc/eh_exception.o abi/libsupc/eh_personality.o abi/libsupc/eh_ptr.o abi/libsupc/eh_term_handler.o abi/libsupc/eh_terminate.o abi/libsupc/eh_throw.o abi/libsupc/eh_type.o abi/libsupc/eh_unex_handler.o abi/libsupc/enum_type_info.o abi/libsupc/function_type_info.o abi/libsupc/fundamental_type_info.o abi/libsupc/guard_error.o abi/libsupc/guard.o abi/libsupc/hash_bytes.o abi/libsupc/nested_exception.o abi/libsupc/pbase_type_info.o abi/libsupc/pmem_type_info.o abi/libsupc/pointer_type_info.o abi/libsupc/si_class_type_info.o abi/libsupc/tinfo2.o abi/libsupc/tinfo.o abi/libsupc/vec.o abi/libsupc/vmi_class_type_info.o abi/libsupc/vterminate.o   -L/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/ -lc -lgcc -Wl,--as-needed -lgcc_s -Wl,--no-as-needed
mipsel-linux-uclibc-ranlib libuClibc++.a
ln -s -f libuClibc++-0.2.3.so libuClibc++.so.0
ln -s -f libuClibc++.so.0 libuClibc++.so
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src'
make[1]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30'
                DESTDIR="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr" \
                install
                make -C $dir install; \
        done
install -d /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/
install -m 755 g++-uc /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/
install -d /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include/uClibc++/
install -m 644 algorithm associative_base basic_definitions bitset cassert cctype cerrno cfloat char_traits climits clocale cmath complex csetjmp csignal cstdarg cstddef cstdio cstdlib cstring ctime cwchar cwctype deque exception fstream func_exception functional iomanip ios iosfwd iostream istream istream_helpers iterator iterator_base limits list locale map memory new numeric ostream ostream_helpers queue set sstream stack stdexcept streambuf string string_iostream support system_configuration.h typeinfo type_traits unwind-cxx.h utility valarray vector /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include/uClibc++/
install -d /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/
install -m 755 libuClibc++-0.2.3.so \
cp -fa libuClibc++.so.0 libuClibc++.so /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/
install -m 644 libuClibc++.a /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/
sed -i -e 's|-I/include/uClibc++|-I/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include/uClibc++|g' /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/g++-uc
sed -i -e 's|-L/lib/|-L/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/|g' /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/g++-uc
mv      /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/g++-uc \
                /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/mipsel-linux-uclibc-g++-uc
ln -sf mipsel-linux-uclibc-g++-uc /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/mipsel-linux-g++-uc
if [ ! -e source/.echo_item_start ]; then       echo -n "---> "; case "LIB" in BIN)     echo -n "package/libtool: " ;; LIB)     echo -n "library/libtool: " ;; TOOL)       echo -n "tool/libtool: " ;; *)  echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
downloading...
--2013-03-18 15:54:01--  http://ftpmirror.gnu.org/libtool/libtool-1.5.26.tar.gz
Resolving ftpmirror.gnu.org (ftpmirror.gnu.org)... 140.186.70.73
Connecting to ftpmirror.gnu.org (ftpmirror.gnu.org)|140.186.70.73|:80... connected.
HTTP request sent, awaiting response... 302 Found
Location: http://gnu.xl-mirror.nl/libtool/libtool-1.5.26.tar.gz [following]
--2013-03-18 15:54:01--  http://gnu.xl-mirror.nl/libtool/libtool-1.5.26.tar.gz
Resolving gnu.xl-mirror.nl (gnu.xl-mirror.nl)... 91.217.235.93
Connecting to gnu.xl-mirror.nl (gnu.xl-mirror.nl)|91.217.235.93|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2961939 (2.8M) [application/x-gzip]
Saving to: `dl/libtool-1.5.26.tar.gz'
100%[=========================================================================================================================>] 2,961,939    576K/s   in 5.0s
2013-03-18 15:54:06 (584 KB/s) - `dl/libtool-1.5.26.tar.gz' saved [2961939/2961939]
Download succeeded - "http://ftpmirror.gnu.org/libtool/libtool-1.5.26.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/libtool-1.5.26.tar.gz: aa9c5107f3ec9ef4200eb6556f3b3c29
rm -f -r /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26
mkdir -p /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26
tar -C /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1  -xf dl/libtool-1.5.26.tar.gz
for i in toolchain/make/target/libtool-host/patches/*.patch; do \
                tools/freetz_patch /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26 $i; \
        done
    applying patch file toolchain/make/target/libtool-host/patches/001-force_dlopen_deplibs.libtool.patch
    patching file ltdl.m4
    patching file libltdl/acinclude.m4
    patching file libltdl/configure
    applying patch file toolchain/make/target/libtool-host/patches/100-libdir_path.libtool.patch
    patching file Makefile.in
    patching file ltmain.in
    patching file Makefile.am
    applying patch file toolchain/make/target/libtool-host/patches/110-no_rpath.libtool.patch
    patching file acinclude.m4
    patching file cdemo/acinclude.m4
    patching file cdemo/configure
    patching file configure
    patching file demo/acinclude.m4
    patching file demo/configure
    patching file depdemo/acinclude.m4
    patching file depdemo/configure
    patching file f77demo/acinclude.m4
    patching file f77demo/configure
    patching file libtool.m4
    patching file mdemo/acinclude.m4
    patching file mdemo/configure
    patching file mdemo2/acinclude.m4
    patching file mdemo2/configure
    patching file pdemo/acinclude.m4
    patching file pdemo/configure
    patching file tagdemo/acinclude.m4
    patching file tagdemo/configure
    applying patch file toolchain/make/target/libtool-host/patches/120-libdir_search.libtool.patch
    applying patch file toolchain/make/target/libtool-host/patches/130-no_recheck.libtool.patch
    patching file libltdl/Makefile.am
    patching file libltdl/Makefile.in
    applying patch file toolchain/make/target/libtool-host/patches/200-package-specific-dlerror-test.libtool.patch
for i in $(find /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26 -type f \( \( -name "*.m4" -o -name "*.am" \) -a ! -name "aclocal.m4" \)); do \
                touch -t 200001010000.00 $i; \
        done; \
        touch /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/.unpacked
(cd /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26; rm -rf config.cache; \
                CC=/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc \
                CXX=/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper \
                PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" \
                ./configure \
                --build=x86_64-pc-linux-gnu \
                --host=mipsel-linux-uclibc \
                --target=mipsel-linux-uclibc \
                --prefix=/usr \
                --disable-ltdl-install \
                --enable-shared \
                --enable-static \
                --disable-nls \
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for mipsel-linux-uclibc-strip... mipsel-linux-uclibc-strip
checking for mipsel-linux-uclibc-gcc... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... yes
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc accepts -g... yes
checking for /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... none
checking for a sed that does not truncate output... /bin/sed
checking build system type... x86_64-pc-linux-gnu
checking host system type... mipsel-unknown-linux-uclibc
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking if the linker (/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld... yes
checking for BSD-compatible nm... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-nm -B
checking whether ln -s works... yes
checking whether we are using the GNU C++ compiler... yes
checking whether /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper accepts -g... yes
checking dependency style of /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper... none
checking for mipsel-linux-uclibc-g77... no
checking for mipsel-linux-uclibc-xlf... no
checking for mipsel-linux-uclibc-f77... no
checking for mipsel-linux-uclibc-frt... no
checking for mipsel-linux-uclibc-pgf77... no
checking for mipsel-linux-uclibc-cf77... no
checking for mipsel-linux-uclibc-fort77... no
checking for mipsel-linux-uclibc-fl32... no
checking for mipsel-linux-uclibc-af77... no
checking for mipsel-linux-uclibc-xlf90... no
checking for mipsel-linux-uclibc-f90... no
checking for mipsel-linux-uclibc-pgf90... no
checking for mipsel-linux-uclibc-pghpf... no
checking for mipsel-linux-uclibc-epcf90... no
checking for mipsel-linux-uclibc-gfortran... no
checking for mipsel-linux-uclibc-g95... no
checking for mipsel-linux-uclibc-xlf95... no
checking for mipsel-linux-uclibc-f95... no
checking for mipsel-linux-uclibc-fort... no
checking for mipsel-linux-uclibc-ifort... no
checking for mipsel-linux-uclibc-ifc... no
checking for mipsel-linux-uclibc-efc... no
checking for mipsel-linux-uclibc-pgf95... no
checking for mipsel-linux-uclibc-lf95... no
checking for mipsel-linux-uclibc-ftn... no
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking for mipsel-linux-uclibc-gcj... no
checking for gcj... no
checking for mipsel-linux-uclibc-windres... no
checking for windres... no
checking for /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld option to reload object files... -r
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper -E
checking the maximum length of command line arguments... 3458764513820540925
checking command to parse /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-nm -B output from /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc object... ok
checking for objdir... .libs
checking for mipsel-linux-uclibc-ar... mipsel-linux-uclibc-ar
checking for mipsel-linux-uclibc-ranlib... mipsel-linux-uclibc-ranlib
checking for mipsel-linux-uclibc-strip... (cached) mipsel-linux-uclibc-strip
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc supports -fno-rtti -fno-exceptions... no
checking for /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc option to produce PIC... -fPIC
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc PIC flag -fPIC works... yes
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc static flag -static works... yes
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc supports -c -o file.o... yes
checking whether the /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc linker (/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... cross
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking whether the /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper linker (/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking for /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper option to produce PIC... -fPIC
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper PIC flag -fPIC works... yes
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper static flag -static works... yes
checking if /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
appending configuration tag "GCJ" to libtool
configure: creating ./config.status
config.status: creating Makefile
config.status: creating doc/Makefile
config.status: creating tests/Makefile
config.status: executing depfiles commands
=== configuring in libltdl (/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl)
configure: running /bin/bash ./configure '--prefix=/usr'  '--build=x86_64-pc-linux-gnu' '--host=mipsel-linux-uclibc' '--target=mipsel-linux-uclibc' '--disable-ltdl-install' '--enable-shared' '--enable-static' '--disable-nls' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=mipsel-linux-uclibc' 'target_alias=mipsel-linux-uclibc' 'CC=/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc' 'CFLAGS=-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64' 'CXX=/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper' --cache-file=/dev/null --srcdir=.
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking which extension is used for loadable modules... .so
checking which variable specifies run-time library path... LD_LIBRARY_PATH
checking for the default library search path... /lib /usr/lib /usr/local/lib /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /lib32 /usr/lib32
checking whether libtool supports -dlopen/-dlpreopen... yes
checking for dlerror... yes
checking for _ prefix in compiled symbols... no
checking whether deplibs are loaded by dlopen... yes
checking argz.h usability... no
checking argz.h presence... no
checking for argz.h... no
checking for error_t... no
checking for argz_append... no
checking for argz_create_sep... no
checking for argz_insert... no
checking for argz_next... no
checking for argz_stringify... no
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for memory.h... (cached) yes
checking for stdlib.h... (cached) yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for unistd.h... (cached) yes
checking dl.h usability... no
checking dl.h presence... no
checking for dl.h... no
checking sys/dl.h usability... no
checking sys/dl.h presence... no
checking for sys/dl.h... no
checking dld.h usability... no
checking dld.h presence... no
checking for dld.h... no
checking mach-o/dyld.h usability... no
checking mach-o/dyld.h presence... no
checking for mach-o/dyld.h... no
checking for string.h... (cached) yes
checking for strchr... yes
checking for strrchr... yes
checking for memcpy... yes
checking for memmove... yes
checking for strcmp... yes
checking for closedir... yes
checking for opendir... yes
checking for readdir... yes
config.status: creating config.h
touch /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/.configured
                make -j2 -C /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26 \
                GLOBAL_LIBDIR=/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib \
                all
make[1]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
Making all in .
make[2]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
rm -f ltmain.shT
CONFIG_FILES=libtoolize CONFIG_HEADERS= /bin/bash ./config.status
date=`/bin/bash ./mkstamp < ./ChangeLog` && \
        sed -e 's/@''PACKAGE@/libtool/' -e 's/@''VERSION@/1.5.26/' \
                -e 's#@''GLOBAL_LIBDIR@#/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib#' \
            -e "s%@""TIMESTAMP@%$date%" ./ltmain.in > ltmain.shT
mv -f ltmain.shT ltmain.sh || \
        (rm -f ltmain.sh && cp ltmain.shT ltmain.sh && rm -f ltmain.shT)
cp ltmain.sh ./libltdl/
chmod +x libtool
config.status: creating libtoolize
chmod +x libtoolize
make[2]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
Making all in libltdl
make[2]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
make  all-am
make[3]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
make[2]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
Making all in doc
make[2]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
Updating ./version.texi
make[2]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
Making all in tests
make[2]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
make[2]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
make[1]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
touch -c /home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libtool
make -j2 DESTDIR="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr" \
                MAKEINFO=true \
                install
Making install in .
make[3]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
test -z "/usr/bin" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/bin"
test -z "/usr/share/aclocal" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/aclocal"
 /usr/bin/install -c 'libtool' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/bin/libtool'
 /usr/bin/install -c -m 644 'libtool.m4' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/aclocal/libtool.m4'
 /usr/bin/install -c 'libtoolize' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/bin/libtoolize'
 /usr/bin/install -c -m 644 'ltdl.m4' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/aclocal/ltdl.m4'
test -z "/usr/share/libtool/libltdl" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl"
test -z "/usr/share/libtool" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool"
 /usr/bin/install -c -m 644 'libltdl/COPYING.LIB' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/COPYING.LIB'
 /usr/bin/install -c -m 644 'config.guess' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.guess'
 /usr/bin/install -c -m 644 'libltdl/README' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/README'
 /usr/bin/install -c -m 644 'config.sub' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.sub'
 /usr/bin/install -c -m 644 'libltdl/configure.ac' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/configure.ac'
 /usr/bin/install -c -m 644 'install-sh' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/install-sh'
 /usr/bin/install -c -m 644 'libltdl/Makefile.am' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/Makefile.am'
 /usr/bin/install -c -m 644 'ltmain.sh' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/ltmain.sh'
 /usr/bin/install -c -m 644 'libltdl/ltdl.c' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/ltdl.c'
 /usr/bin/install -c -m 644 'libltdl/ltdl.h' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/ltdl.h'
 /usr/bin/install -c -m 644 'libltdl/config.guess' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.guess'
 /usr/bin/install -c -m 644 'libltdl/config.sub' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.sub'
 /usr/bin/install -c -m 644 'libltdl/install-sh' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/install-sh'
 /usr/bin/install -c -m 644 'libltdl/missing' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/missing'
 /usr/bin/install -c -m 644 'libltdl/ltmain.sh' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/ltmain.sh'
 /usr/bin/install -c -m 644 'libltdl/acinclude.m4' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/acinclude.m4'
 /usr/bin/install -c -m 644 'libltdl/aclocal.m4' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/aclocal.m4'
 /usr/bin/install -c -m 644 'libltdl/Makefile.in' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/Makefile.in'
 /usr/bin/install -c -m 644 'libltdl/configure' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/configure'
 /usr/bin/install -c -m 644 'libltdl/config-h.in' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config-h.in'
make  install-data-hook
make[4]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.guess
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.sub
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/install-sh
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.guess
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.sub
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/install-sh
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/configure
chmod +x /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/missing
make[4]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
make[3]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
Making install in libltdl
test -z "/usr/lib" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/lib"
test -z "/usr/include" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/include"
Making install in doc
restore=: && backupdir=".am$$" && \
        am__cwd=`pwd` && cd . && \
        rm -rf $backupdir && mkdir $backupdir && \
        if (true --version) >/dev/null 2>&1; then \
          for f in libtool.info libtool.info-[0-9] libtool.info-[0-9][0-9] libtool.i[0-9] libtool.i[0-9][0-9]; do \
            if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
          done; \
        else :; fi && \
        cd "$am__cwd"; \
        if true   -I . \
         -o libtool.info libtool.texi; \
        then \
          rc=0; \
          cd .; \
        else \
          rc=$?; \
          cd . && \
          $restore $backupdir/* `echo "./libtool.info" | sed 's|[^/]*$||'`; \
        fi; \
        rm -rf $backupdir; exit $rc
make[3]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
make[3]: Nothing to be done for `install-exec-am'.
          done; \
        else :; fi && \
        cd "$am__cwd"; \
        if true   -I . \
        then \
          rc=0; \
          cd .; \
        else \
          rc=$?; \
          cd . && \
        fi; \
test -z "/usr/share/info" || /bin/mkdir -p "/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info"
 install-info --info-dir='/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info' '/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info/libtool.info'
This is not dpkg install-info anymore, but GNU install-info
See the man page for ginstall-info for command line arguments
install-info: No such file or directory for /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info/libtool.info
make[3]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
Making install in tests
make[3]: Entering directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `/home/freetz/trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
rm -f -r /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/info /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/man /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/doc /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/locale /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/info /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/man /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/doc /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/locale /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/info /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/man /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/doc /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/locale /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/info /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/man /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/doc /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/locale
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/root/usr/lib/freetz/root
if test -d make/libs/libctlmgr/files; then tar -c -C make/libs/libctlmgr/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/root/usr/lib/freetz ; fi
---> library/libctlmgr: preparing... mkdir -p source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6
cp -a make/libs/libctlmgr/src/libctlmgr.c make/libs/libctlmgr/src/Makefile source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6 \
                CC="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" \
                LIB_VERSION="0.6" \
                all
building... make[1]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6'
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fPIC -D_GNU_SOURCE  -c -o libctlmgr.o libctlmgr.c
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -shared -ldl -o libctlmgr.so.0.6 libctlmgr.o
ln -sf libctlmgr.so.0.6 libctlmgr.so
make[1]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6'
chmod 755 source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6/libctlmgr.so.0.6; mkdir -p packages/target-mipsel_uClibc-0.9.32.1/root/lib/; cp -a source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6/libctlmgr.so* packages/target-mipsel_uClibc-0.9.32.1/root/lib/; /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/root/lib/libctlmgr.so.0.6;
done.
chmod 755 /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libgcc_s.so.1; mkdir -p packages/target-mipsel_uClibc-0.9.32.1/root/lib/; cp -a /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libgcc_s.so* packages/target-mipsel_uClibc-0.9.32.1/root/lib/; /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/root/lib/libgcc_s.so.1;
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/busybox/root
if test -d make/busybox/files; then tar -c -C make/busybox/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/busybox ; fi
---> package/busybox: preparing... tools/bunzip2 -c dl/busybox-1.21.0.tar.bz2 | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/busybox/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0 $i; done
    applying patch file make/busybox/patches/000-busybox-1.21.0-mdev.patch
    patching file util-linux/mdev.c
    applying patch file make/busybox/patches/000-busybox-1.21.0-platform.patch
    patching file archival/libarchive/decompress_unxz.c
    patching file include/platform.h
    applying patch file make/busybox/patches/000-busybox-1.21.0-xz.patch
    applying patch file make/busybox/patches/100-autoconf.patch
    patching file applets/Kbuild.src
    applying patch file make/busybox/patches/101-init_avoid_loop_opening_tty.patch
    patching file init/init.c
    applying patch file make/busybox/patches/110-busybox-nolock-as-default.patch
    patching file util-linux/mount.c
    applying patch file make/busybox/patches/110-wget_getopt_fix.patch
    patching file networking/wget.c
    applying patch file make/busybox/patches/130-scripts_bash.patch
    patching file scripts/trylink
    patching file scripts/gen_build_files.sh
    applying patch file make/busybox/patches/210-telnet-close-on-exit.patch
    patching file networking/telnetd.c
    applying patch file make/busybox/patches/220-httpd-pidfile.patch
    patching file networking/httpd.c
    applying patch file make/busybox/patches/320-mdev_scan_file.patch
    applying patch file make/busybox/patches/350-httpd_redir.patch
    applying patch file make/busybox/patches/440-httpd_chdir.patch
    applying patch file make/busybox/patches/450-httpd_REDIRECT_STATUS.patch
    applying patch file make/busybox/patches/470-insmod_search.patch
    patching file modutils/insmod.c
    patching file modutils/Config.src
    applying patch file make/busybox/patches/480-copy_file_dev_node_fix.patch
    patching file libbb/copy_file.c
    applying patch file make/busybox/patches/503-id_getgrouplist.patch
    patching file coreutils/id.c
    applying patch file make/busybox/patches/602-telnetd_intr.patch
    applying patch file make/busybox/patches/604-httpdstar.patch
    patching file libbb/appletlib.c
    applying patch file make/busybox/patches/605-blkid_mtdworkaround.patch
    patching file util-linux/volume_id/get_devname.c
    applying patch file make/busybox/patches/615-blkid_bogus_device_handling.patch
    patching file util-linux/blkid.c
    applying patch file make/busybox/patches/620-findfs.patch
    patching file util-linux/findfs.c
    patching file include/volume_id.h
    applying patch file make/busybox/patches/711-revert_crtscts_fix.patch
    applying patch file make/busybox/patches/712-revert_read_sighandler.patch
    patching file shell/shell_common.c
    applying patch file make/busybox/patches/720-stun-ip.patch
    patching file networking/stun-ip.c
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0 \
                CC="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CROSS_COMPILE="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-" EXTRA_CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" ARCH="mips"
building... make[1]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0'
  GEN     include/applets.h
  GEN     include/usage.h
  GEN     findutils/Kbuild
  GEN     findutils/Config.in
  GEN     archival/Kbuild
  GEN     archival/Config.in
  GEN     archival/libarchive/Kbuild
  GEN     libpwdgrp/Kbuild
  GEN     applets/Kbuild
  GEN     coreutils/Kbuild
  GEN     coreutils/Config.in
  GEN     coreutils/libcoreutils/Kbuild
  GEN     miscutils/Kbuild
  GEN     miscutils/Config.in
  GEN     console-tools/Kbuild
  GEN     console-tools/Config.in
  GEN     sysklogd/Kbuild
  GEN     sysklogd/Config.in
  GEN     selinux/Kbuild
  GEN     selinux/Config.in
  GEN     editors/Kbuild
  GEN     editors/Config.in
  GEN     loginutils/Kbuild
  GEN     loginutils/Config.in
  GEN     procps/Kbuild
  GEN     procps/Config.in
  GEN     networking/Kbuild
  GEN     networking/Config.in
  GEN     networking/udhcp/Kbuild
  GEN     networking/udhcp/Config.in
  GEN     networking/libiproute/Kbuild
  GEN     libbb/Kbuild
  GEN     libbb/Config.in
  GEN     printutils/Kbuild
  GEN     printutils/Config.in
  GEN     modutils/Kbuild
  GEN     modutils/Config.in
  GEN     shell/Kbuild
  GEN     shell/Config.in
  GEN     init/Kbuild
  GEN     init/Config.in
  GEN     e2fsprogs/Kbuild
  GEN     e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/uuid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/blkid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/e2p/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/ext2fs/Kbuild
  GEN     runit/Kbuild
  GEN     runit/Config.in
  GEN     mailutils/Kbuild
  GEN     mailutils/Config.in
  GEN     scripts/Kbuild
  GEN     debianutils/Kbuild
  GEN     debianutils/Config.in
  GEN     util-linux/Kbuild
  GEN     util-linux/Config.in
  GEN     util-linux/volume_id/Kbuild
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/split-include
scripts/basic/split-include.c: In function âmainâ:
scripts/basic/split-include.c:134:11: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  scripts/basic/docproc
  HOSTCC  scripts/kconfig/conf.o
scripts/kconfig/conf.c: In function âconf_choiceâ:
scripts/kconfig/conf.c:354:9: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
scripts/kconfig/conf.c: In function âconf_askvalueâ:
scripts/kconfig/conf.c:106:8: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  scripts/kconfig/kxgettext.o
  HOSTCC  scripts/kconfig/mconf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/lex.zconf.c
  SHIPPED scripts/kconfig/zconf.hash.c
scripts/kconfig/mconf.c: In function âshow_textboxâ:
scripts/kconfig/mconf.c:847:7: warning: ignoring return value of âwriteâ, declared with attribute warn_unused_result [-Wunused-result]
scripts/kconfig/mconf.c: In function âexec_confâ:
scripts/kconfig/mconf.c:481:6: warning: ignoring return value of âpipeâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -s Config.in
# using defaults found in .config
.config:655:warning: trying to reassign symbol LOCALE_SUPPORT
  SPLIT   include/autoconf.h -> include/config/*
  HOSTCC  applets/usage
  GEN     include/bbconfigopts.h
applets/usage.c: In function âmainâ:
applets/usage.c:52:8: warning: ignoring return value of âwriteâ, declared with attribute warn_unused_result [-Wunused-result]
  HOSTCC  applets/applet_tables
applets/applet_tables.c: In function âmainâ:
applets/applet_tables.c:144:9: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
  GEN     include/usage_compressed.h
  GEN     include/applet_tables.h
  HOSTCC  applets/usage_pod
applets/usage_pod.c: In function âmainâ:
applets/usage_pod.c:74:3: warning: format not a string literal and no format arguments [-Wformat-security]
  CC      applets/applets.o
  LD      applets/built-in.o
  DOC     busybox.pod
  DOC     BusyBox.txt
  DOC     busybox.1
  DOC     BusyBox.html
  LD      archival/built-in.o
  CC      archival/bbunzip.o
  LD      archival/libarchive/built-in.o
  CC      archival/libarchive/data_align.o
  CC      archival/libarchive/data_extract_all.o
  CC      archival/gzip.o
  CC      archival/libarchive/data_extract_to_stdout.o
  CC      archival/libarchive/data_skip.o
  CC      archival/libarchive/decompress_gunzip.o
  CC      archival/tar.o
  CC      archival/libarchive/filter_accept_all.o
  CC      archival/libarchive/filter_accept_list.o
  CC      archival/libarchive/filter_accept_reject_list.o
  AR      archival/lib.a
  LD      console-tools/built-in.o
  AR      console-tools/lib.a
  LD      coreutils/built-in.o
  CC      coreutils/basename.o
  CC      archival/libarchive/find_list_entry.o
  CC      coreutils/cat.o
  CC      archival/libarchive/get_header_tar.o
  CC      coreutils/chmod.o
  CC      coreutils/chown.o
  CC      archival/libarchive/header_list.o
  CC      coreutils/cp.o
  CC      archival/libarchive/header_skip.o
  CC      archival/libarchive/header_verbose_list.o
  CC      coreutils/cut.o
  CC      archival/libarchive/init_handle.o
  CC      archival/libarchive/open_transformer.o
  CC      coreutils/date.o
  CC      archival/libarchive/seek_by_jump.o
  CC      coreutils/dd.o
  CC      archival/libarchive/seek_by_read.o
  AR      archival/libarchive/lib.a
  LD      coreutils/libcoreutils/built-in.o
  CC      coreutils/libcoreutils/cp_mv_stat.o
  CC      coreutils/df.o
  CC      coreutils/libcoreutils/getopt_mk_fifo_nod.o
  CC      coreutils/dirname.o
  AR      coreutils/libcoreutils/lib.a
  LD      debianutils/built-in.o
  CC      debianutils/which.o
  CC      coreutils/du.o
  AR      debianutils/lib.a
  LD      e2fsprogs/built-in.o
  AR      e2fsprogs/lib.a
  CC      coreutils/echo.o
  LD      editors/built-in.o
  CC      editors/awk.o
  CC      coreutils/env.o
  CC      coreutils/expr.o
  CC      coreutils/false.o
  CC      coreutils/head.o
  CC      coreutils/id.o
  CC      coreutils/ln.o
  CC      coreutils/ls.o
  CC      coreutils/mkdir.o
  CC      editors/sed.o
  CC      coreutils/mkfifo.o
  CC      coreutils/mknod.o
  CC      coreutils/mv.o
  CC      coreutils/nohup.o
  CC      coreutils/printf.o
  CC      editors/vi.o
  CC      coreutils/pwd.o
  CC      coreutils/realpath.o
  CC      coreutils/rm.o
  CC      coreutils/rmdir.o
  CC      coreutils/sleep.o
  CC      coreutils/sort.o
  CC      coreutils/stat.o
  CC      coreutils/stty.o
  CC      coreutils/sync.o
  CC      coreutils/tail.o
  AR      editors/lib.a
  LD      findutils/built-in.o
  CC      findutils/find.o
  CC      coreutils/tee.o
  CC      coreutils/test.o
  CC      findutils/grep.o
  CC      coreutils/test_ptr_hack.o
  CC      coreutils/touch.o
  CC      coreutils/tr.o
  CC      findutils/xargs.o
  CC      coreutils/true.o
  CC      coreutils/tty.o
  AR      findutils/lib.a
  LD      init/built-in.o
  CC      coreutils/uname.o
  CC      init/halt.o
  CC      coreutils/uudecode.o
  CC      init/init.o
  CC      coreutils/wc.o
  CC      coreutils/yes.o
  AR      init/lib.a
  LD      libbb/built-in.o
  CC      libbb/appletlib.o
  AR      coreutils/lib.a
  LD      libpwdgrp/built-in.o
  CC      libpwdgrp/uidgid_get.o
libbb/appletlib.c: In function 'busybox_main':
libbb/appletlib.c:693:7: warning: variable 'use_symbolic_links' set but not used [-Wunused-but-set-variable]
  AR      libpwdgrp/lib.a
  LD      loginutils/built-in.o
  CC      libbb/ask_confirmation.o
  CC      loginutils/addgroup.o
  CC      libbb/bb_askpass.o
  CC      loginutils/adduser.o
  CC      libbb/bb_bswap_64.o
  CC      loginutils/cryptpw.o
  CC      libbb/bb_do_delay.o
  CC      loginutils/deluser.o
  CC      libbb/bb_pwd.o
  CC      loginutils/login.o
  CC      libbb/bb_qsort.o
  CC      libbb/bb_strtonum.o
  CC      loginutils/passwd.o
  CC      libbb/change_identity.o
  AR      loginutils/lib.a
  LD      mailutils/built-in.o
  AR      mailutils/lib.a
  CC      libbb/chomp.o
  LD      miscutils/built-in.o
  CC      miscutils/crond.o
  CC      libbb/compare_string_array.o
  CC      libbb/concat_path_file.o
  CC      libbb/concat_subpath_file.o
  CC      miscutils/crontab.o
  CC      libbb/copy_file.o
  CC      miscutils/makedevs.o
  CC      libbb/copyfd.o
  AR      miscutils/lib.a
  LD      modutils/built-in.o
  CC      modutils/insmod.o
  CC      libbb/correct_password.o
modutils/insmod.c: In function 'check_module_name_match':
modutils/insmod.c:23:81: warning: unused parameter 'statbuf' [-Wunused-parameter]
modutils/insmod.c:24:28: warning: unused parameter 'depth' [-Wunused-parameter]
modutils/insmod.c: In function 'find_module':
modutils/insmod.c:45:31: warning: variable 'k_version' set but not used [-Wunused-but-set-variable]
  CC      modutils/lsmod.o
  CC      libbb/crc32.o
  CC      modutils/modprobe.o
  CC      libbb/create_icmp6_socket.o
  CC      libbb/create_icmp_socket.o
  CC      libbb/default_error_retval.o
  CC      modutils/modutils.o
  CC      libbb/device_open.o
  CC      libbb/dump.o
  CC      modutils/rmmod.o
  AR      modutils/lib.a
  LD      networking/built-in.o
  CC      networking/ether-wake.o
  CC      networking/hostname.o
  CC      networking/httpd.o
  CC      libbb/execable.o
  CC      libbb/fclose_nonstdin.o
  CC      libbb/fflush_stdout_and_exit.o
  CC      libbb/fgets_str.o
  CC      libbb/find_mount_point.o
  CC      libbb/find_pid_by_name.o
  CC      libbb/find_root_device.o
  CC      networking/ifconfig.o
  CC      libbb/full_write.o
  CC      networking/ifupdown.o
  CC      libbb/get_console.o
  CC      libbb/get_last_path_component.o
  CC      libbb/get_line_from_file.o
  CC      libbb/get_shell_name.o
  CC      libbb/get_volsize.o
  CC      networking/inetd.o
  CC      libbb/getopt32.o
  CC      libbb/getpty.o
  CC      libbb/hash_md5_sha.o
  CC      networking/interface.o
  CC      libbb/herror_msg.o
  CC      libbb/human_readable.o
  CC      networking/netstat.o
  CC      libbb/inet_cksum.o
  CC      libbb/inet_common.o
  CC      networking/ping.o
  CC      libbb/info_msg.o
  CC      libbb/inode_hash.o
  CC      networking/route.o
  CC      libbb/isdirectory.o
  CC      libbb/kernel_version.o
  CC      libbb/last_char_is.o
  CC      networking/stun-ip.o
  CC      libbb/lineedit.o
  CC      networking/telnetd.o
  CC      networking/vconfig.o
  CC      networking/whois.o
  AR      networking/lib.a
  LD      networking/libiproute/built-in.o
  AR      networking/libiproute/lib.a
  CC      libbb/lineedit_ptr_hack.o
  LD      networking/udhcp/built-in.o
  CC      libbb/llist.o
  AR      networking/udhcp/lib.a
  LD      printutils/built-in.o
  AR      printutils/lib.a
  LD      procps/built-in.o
  CC      procps/free.o
  CC      libbb/login.o
  CC      procps/kill.o
  CC      libbb/loop.o
  CC      procps/pidof.o
  CC      libbb/make_directory.o
  CC      procps/ps.o
procps/ps.c: In function 'ps_main':
procps/ps.c:748:14: warning: 'uptime' may be used uninitialized in this function [-Wuninitialized]
  CC      libbb/makedev.o
  CC      procps/sysctl.o
  CC      libbb/match_fstype.o
  CC      libbb/messages.o
  CC      procps/top.o
  CC      libbb/missing_syscalls.o
procps/top.c: In function 'handle_input':
procps/top.c:921:16: warning: variable 'pfd' set but not used [-Wunused-but-set-variable]
  CC      libbb/mode_string.o
  CC      libbb/obscure.o
  CC      libbb/parse_config.o
  CC      procps/uptime.o
  AR      procps/lib.a
  CC      libbb/parse_mode.o
  LD      runit/built-in.o
  AR      runit/lib.a
  LD      selinux/built-in.o
  AR      selinux/lib.a
  LD      shell/built-in.o
  CC      shell/ash.o
  CC      libbb/percent_decode.o
  CC      libbb/perror_msg.o
  CC      libbb/perror_nomsg.o
  CC      libbb/perror_nomsg_and_die.o
  CC      libbb/pidfile.o
  CC      libbb/platform.o
  CC      libbb/print_flags.o
  CC      libbb/printable.o
  CC      libbb/printable_string.o
  CC      libbb/process_escape_sequence.o
  CC      libbb/procps.o
  CC      libbb/progress.o
  CC      libbb/ptr_to_globals.o
  CC      libbb/pw_encrypt.o
  CC      libbb/read.o
  CC      libbb/read_key.o
  CC      libbb/read_printf.o
  CC      libbb/recursive_action.o
  CC      libbb/remove_file.o
  CC      libbb/run_shell.o
  CC      libbb/safe_gethostname.o
  CC      libbb/safe_poll.o
  CC      libbb/safe_strncpy.o
  CC      libbb/safe_write.o
  CC      libbb/setup_environment.o
  CC      libbb/signals.o
  CC      libbb/simplify_path.o
  CC      libbb/single_argv.o
  CC      libbb/skip_whitespace.o
  CC      libbb/speed_table.o
  CC      libbb/str_tolower.o
  CC      libbb/strrstr.o
  CC      libbb/time.o
  CC      libbb/trim.o
  CC      libbb/u_signal_names.o
  CC      shell/ash_ptr_hack.o
  CC      shell/math.o
  CC      libbb/update_passwd.o
  CC      libbb/uuencode.o
  CC      shell/shell_common.o
  CC      libbb/vdprintf.o
  CC      libbb/verror_msg.o
  AR      shell/lib.a
  LD      sysklogd/built-in.o
  CC      sysklogd/klogd.o
  CC      libbb/vfork_daemon_rexec.o
  CC      sysklogd/logread.o
  CC      libbb/warn_ignoring_args.o
  CC      libbb/wfopen.o
  CC      sysklogd/syslogd_and_logger.o
  CC      libbb/wfopen_input.o
  CC      libbb/write.o
  CC      libbb/xatonum.o
  AR      sysklogd/lib.a
  LD      util-linux/built-in.o
  CC      util-linux/blkid.o
  CC      util-linux/dmesg.o
  CC      libbb/xconnect.o
  CC      util-linux/getopt.o
  CC      util-linux/mkswap.o
  CC      libbb/xfunc_die.o
  CC      libbb/xfuncs.o
  CC      util-linux/mount.o
  CC      libbb/xfuncs_printf.o
  CC      libbb/xgetcwd.o
  CC      libbb/xgethostbyname.o
  CC      util-linux/pivot_root.o
  CC      libbb/xreadlink.o
  CC      util-linux/swaponoff.o
  CC      libbb/xrealloc_vector.o
  CC      util-linux/umount.o
  CC      libbb/xregcomp.o
  AR      util-linux/lib.a
  AR      libbb/lib.a
  LD      util-linux/volume_id/built-in.o
  CC      util-linux/volume_id/ext.o
  CC      util-linux/volume_id/fat.o
  CC      util-linux/volume_id/get_devname.o
  CC      util-linux/volume_id/ntfs.o
  CC      util-linux/volume_id/util.o
  CC      util-linux/volume_id/volume_id.o
  AR      util-linux/volume_id/lib.a
  LINK    busybox_unstripped
Trying libraries: crypt m
 Library crypt is not needed, excluding it
 Library m is not needed, excluding it
Final link with: <none>
make[1]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0'
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/busybox/; cp source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0/busybox packages/target-mipsel_uClibc-0.9.32.1/busybox/busybox; /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/busybox/busybox;
                CC="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CROSS_COMPILE="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-" EXTRA_CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" ARCH="mips" \
                busybox.links
touch -c source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0/busybox.links
cp source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0/busybox.links packages/target-mipsel_uClibc-0.9.32.1/busybox/busybox.links
done.
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root
if test -d make/haserl/files; then tar -c -C make/haserl/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29 ; fi
if [ ! -e source/.echo_item_start ]; then       echo -n "---> "; case "BIN" in BIN)     echo -n "package/haserl: " ;; LIB)      echo -n "library/haserl: " ;; TOOL)echo -n "tool/haserl: " ;; *)   echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
---> package/haserl: downloading...
--2013-03-18 15:55:04--  http://downloads.sourceforge.net/haserl/haserl-0.9.29.tar.gz
Resolving downloads.sourceforge.net (downloads.sourceforge.net)... 216.34.181.59
Connecting to downloads.sourceforge.net (downloads.sourceforge.net)|216.34.181.59|:80... connected.
HTTP request sent, awaiting response... 301 Moved Permanently
Location: http://downloads.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz [following]
--2013-03-18 15:55:05--  http://downloads.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz
Reusing existing connection to downloads.sourceforge.net:80.
Location: http://garr.dl.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz [following]
--2013-03-18 15:55:05--  http://garr.dl.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz
Resolving garr.dl.sourceforge.net (garr.dl.sourceforge.net)... 193.206.140.34, 2001:760:ffff:b0::34
Connecting to garr.dl.sourceforge.net (garr.dl.sourceforge.net)|193.206.140.34|:80... connected.
Length: 135230 (132K) [application/x-gzip]
Saving to: `dl/haserl-0.9.29.tar.gz'
100%[=========================================================================================================================>] 135,230      403K/s   in 0.3s
2013-03-18 15:55:06 (403 KB/s) - `dl/haserl-0.9.29.tar.gz' saved [135230/135230]
Download succeeded - "http://downloads.sourceforge.net/haserl/haserl-0.9.29.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/haserl-0.9.29.tar.gz: 4cac9409530200b4a7a82a48ec174800
preparing... tools/gunzip -c dl/haserl-0.9.29.tar.gz | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/haserl/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29 $i; done
    applying patch file make/haserl/patches/100-lualib_inc.patch
    patching file src/Makefile.in
    patching file src/haserl_lualib.inc
configuring... (conf_cmd() { ./configure  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; cd source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29;   rm -f config.{cache,status};    PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" CC="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CXX="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper" CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/pkgconfig" GLOBAL_LIBDIR=/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib  FREETZ_TARGET_LFS="y" CONFIG_SITE=/home/freetz/trunk/include/site/mipsel-linux-uclibc conf_cmd   --cache-file=/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/config.cache --target=mipsel-linux --host=mipsel-linux --build=x86_64-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls      )
configure: WARNING: unrecognized options: --with-gnu-ld, --disable-nls
configure: loading site script /home/freetz/trunk/include/site/mipsel-linux-uclibc
configure: creating cache /home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/config.cache
checking for mipsel-linux-strip... mipsel-linux-strip
checking for mipsel-linux-gcc... /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
checking dependency style of /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... gcc3
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for size_t... yes
checking for working memcmp... (cached) yes
checking for memset... yes
checking for putenv... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strncasecmp... yes
checking for strstr... yes
configure: updating cache /home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/config.cache
config.status: creating src/Makefile
config.status: creating src/config.h
** Configuration summary for haserl 0.9.29:
        Building haserl with with lua disabled
        Building haserl with with bash-extensions disabled
        libs:
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29
building... make[1]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
Making all in src
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
make  all-am
make[3]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT common.o -MD -MP -MF .deps/common.Tpo -c -o common.o common.c
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT sliding_buffer.o -MD -MP -MF .deps/sliding_buffer.Tpo -c -o sliding_buffer.o sliding_buffer.c
mv -f .deps/sliding_buffer.Tpo .deps/sliding_buffer.Po
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT h_error.o -MD -MP -MF .deps/h_error.Tpo -c -o h_error.o h_error.c
mv -f .deps/common.Tpo .deps/common.Po
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT h_script.o -MD -MP -MF .deps/h_script.Tpo -c -o h_script.o h_script.c
mv -f .deps/h_error.Tpo .deps/h_error.Po
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT rfc2388.o -MD -MP -MF .deps/rfc2388.Tpo -c -o rfc2388.o rfc2388.c
mv -f .deps/h_script.Tpo .deps/h_script.Po
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT h_bash.o -MD -MP -MF .deps/h_bash.Tpo -c -o h_bash.o h_bash.c
mv -f .deps/rfc2388.Tpo .deps/rfc2388.Po
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT haserl.o -MD -MP -MF .deps/haserl.Tpo -c -o haserl.o haserl.c
mv -f .deps/h_bash.Tpo .deps/h_bash.Po
haserl.c: In function 'main':
haserl.c:695:7: warning: variable 'retval' set but not used [-Wunused-but-set-variable]
mv -f .deps/haserl.Tpo .deps/haserl.Po
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc  -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall   -o haserl common.o sliding_buffer.o h_error.o h_script.o rfc2388.o h_bash.o  haserl.o
make[3]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
Making all in doc
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/doc'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/doc'
make[2]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
make[1]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root/usr/bin/; cp source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src/haserl packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root/usr/bin/haserl; /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root/usr/bin/haserl;
done.
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/inetd-0.2/root
if test -d make/inetd/files; then tar -c -C make/inetd/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/inetd-0.2 ; fi
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/mod-1.0/root
if test -d make/mod/files; then tar -c -C make/mod/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/mod-1.0 ; fi
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root
if test -d make/modcgi/files; then tar -c -C make/modcgi/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3 ; fi
if [ ! -e source/.echo_item_start ]; then       echo -n "---> "; case "BIN" in BIN)     echo -n "package/modcgi: " ;; LIB)      echo -n "library/modcgi: " ;; TOOL)echo -n "tool/modcgi: " ;; *)   echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
---> package/modcgi: downloading...
--2013-03-18 15:55:11--  http://freetz.magenbrot.net/modcgi-0.3.tar.bz2
Resolving freetz.magenbrot.net (freetz.magenbrot.net)... 85.25.156.176
Connecting to freetz.magenbrot.net (freetz.magenbrot.net)|85.25.156.176|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 2343 (2.3K) [application/x-bzip2]
Saving to: `dl/modcgi-0.3.tar.bz2'
100%[=========================================================================================================================>] 2,343       --.-K/s   in 0s
2013-03-18 15:55:11 (5.69 MB/s) - `dl/modcgi-0.3.tar.bz2' saved [2343/2343]
Download succeeded - "http://freetz.magenbrot.net/modcgi-0.3.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/modcgi-0.3.tar.bz2: 5323ce1a98492bd78d2fbe097268fe83
preparing... tools/bunzip2 -c dl/modcgi-0.3.tar.bz2 | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/modcgi/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3 $i; done
    applying patch file make/modcgi/patches/100-proccgi.patch
    patching file proccgi/proccgi.c
cmd() { PATH="/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };  if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3 \
building... make[1]: Entering directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3'
cp proccgi/proccgi.c proccgi.c ; \
        mv proccgi.c modcgi.c
/home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -o modcgi modcgi.c
make[1]: Leaving directory `/home/freetz/trunk/source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3'
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root/usr/bin/; cp source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/modcgi packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root/usr/bin/modcgi; /home/freetz/trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root/usr/bin/modcgi;
done.
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/syslogd-cgi-0.2.3/root
if test -d make/syslogd-cgi/files; then tar -c -C make/syslogd-cgi/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/syslogd-cgi-0.2.3 ; fi
STEP 1: UNPACK
unpacking firmware image
Skipping 0 Bytes garbage...splitting kernel image
unpacking filesystem image
    3446 inodes (3881 blocks) to write
    created 2707 files
    created 198 directories
    created 652 symlinks
    created 87 devices
    created 0 fifos
unpacking var.tar
done.
detected firmware 7270 v3 74.05.23 rev22845 (26.07.2012 12:13:40)
STEP 2: MODIFY
applying symlinks, deleting additional webinterfaces in: usr/www usr/www.nas usr/www.myfritz
applying patches
  applying patches: 7270_v3-en (05_2X)
    applying patch file ./patches/devices/05_2X/105-S06-logging.sh
    applying patch file ./patches/devices/05_2X/115-S20-modload.sh
    applying patch file ./patches/devices/05_2X/200-tun-device.sh
    patching build/modified/filesystem/etc/udev/rules.d/50-udev-default.rules
    applying patch file ./patches/devices/05_2X/120-rc.S-dev.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/devices/05_2X/140-rc.tail.sh-no_exit.patch
    patching file etc/init.d/rc.tail.sh
    applying patch file ./patches/devices/05_2X/en/210-notmountable.patch
    patching file usr/www/all/html/de/home/home.js
    applying patch file ./patches/devices/05_2X/7270/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/devices/05_2X/7270/190-webmenu.patch
    patching file usr/www/all/templates/menu_page_end.html
    patching file usr/www/all/menus/menu_freetz.lua
    patching file usr/www/all/templates/menu_page_head.html
    applying patch file ./patches/devices/05_2X/7270/200-sperre1.patch
    patching file usr/www/all/html/de/fon/sperre1.js
  creating symlinks /tmp, /mod and /home
  creating /mnt and /opt
  setting freetz-version 'freetz-devel'
    applying patch file ./patches/scripts/100-3170_7170.sh
    applying patch file ./patches/scripts/100-7112_7170.sh
    applying patch file ./patches/scripts/100-7113_7170.sh
    applying patch file ./patches/scripts/100-7140_7170.sh
    applying patch file ./patches/scripts/100-7141_7170.sh
    applying patch file ./patches/scripts/100-7240_7270.sh
    applying patch file ./patches/scripts/100-7270v1_7270v2.sh
    applying patch file ./patches/scripts/100-7270v2_7270v1.sh
    applying patch file ./patches/scripts/100-7320_7330.sh
    applying patch file ./patches/scripts/100-7570_iad7570.sh
    applying patch file ./patches/scripts/100-enforce-urlader-settings.sh
    applying patch file ./patches/scripts/100_iad3331_7170.sh
    applying patch file ./patches/scripts/100-w701v_7170.sh
    applying patch file ./patches/scripts/100-w900v_7170.sh
    applying patch file ./patches/scripts/100-w920v_7570.sh
    applying patch file ./patches/scripts/101-ctlmgr_wrapper.sh
    applying patch file ./patches/scripts/105-onlinechanged.sh
  patching /bin/onlinechanged
    applying patch file ./patches/scripts/108-tffs_nodes.sh
  applying tffs_nodes patch
    patching build/modified/filesystem/etc/init.d/S08-tffs
    applying patch file ./patches/scripts/109-rc.net-multid-wrapper.sh
  replacing multid by a wrapper
    patching build/modified/filesystem/etc/init.d/rc.net
    applying patch file ./patches/scripts/110-inittab.sh
    applying patch file ./patches/scripts/110-multid-wait.sh
  applying multid-wait patch
    applying patch file ./patches/scripts/110-system_status.sh
    applying patch file ./patches/scripts/115-rc.S.sh
    applying patch file ./patches/scripts/116-usbroot_S46-usb.sh
    applying patch file ./patches/scripts/120-dev_led.sh
  applying /dev/led patch
    patching build/modified/filesystem/bin/update_led_on
    patching build/modified/filesystem/bin/update_led_off
    applying patch file ./patches/scripts/130-fstab.sh
    applying patch file ./patches/scripts/140-remove-uClibc.sh
  removing uClibc-0.9.32 files
    rm -rf build/modified/filesystem/lib/*0.9.32*
  removing uClibc links
    rm -rf build/modified/filesystem/lib/ld-linux.so*
    rm -rf build/modified/filesystem/lib/ld-uClibc.so*
    rm -rf build/modified/filesystem/lib/ld.so*
    rm -rf build/modified/filesystem/lib/libc.so*
    rm -rf build/modified/filesystem/lib/libcrypt.so*
    rm -rf build/modified/filesystem/lib/libdl.so*
    rm -rf build/modified/filesystem/lib/libld-uClibc*
    rm -rf build/modified/filesystem/lib/libm.so*
    rm -rf build/modified/filesystem/lib/libnsl.so*
    rm -rf build/modified/filesystem/lib/libpthread.so*
    rm -rf build/modified/filesystem/lib/libthread_db.so*
    rm -rf build/modified/filesystem/lib/libresolv.so*
    rm -rf build/modified/filesystem/lib/librt.so*
    rm -rf build/modified/filesystem/lib/libubacktrace.so*
    rm -rf build/modified/filesystem/lib/libutil.so*
  linking ld.so.1
    applying patch file ./patches/scripts/170-rename_ar7login.sh
  renaming ar7login to make way for wrapper script
    applying patch file ./patches/scripts/180-printk.sh
  applying printk patch
    patching build/modified/filesystem/etc/init.d/S11-piglet
    applying patch file ./patches/scripts/190-webmenu.sh
  applying webmenu patch
    patching build/modified/filesystem/usr/www/all/html/de/menus/menu2.html
    applying patch file ./patches/scripts/191-webmenu_wol.sh
    applying patch file ./patches/scripts/195-webmenu_signed.sh
    applying patch file ./patches/scripts/197-freetzmount.sh
  applying FREETZMOUNT patch
    patching build/modified/filesystem/etc/hotplug/storage
    patching build/modified/filesystem/etc/hotplug/udev-mount-sd
    patching run_mount script
    patching /etc/hotplug/storage
    applying patch file ./patches/scripts/198-usbroot.sh
    applying patch file ./patches/scripts/200-vcc.sh
    applying patch file ./patches/scripts/210-ata.sh
    applying patch file ./patches/scripts/210-enum.sh
    applying patch file ./patches/scripts/210-international.sh
    applying patch file ./patches/scripts/220-assistant.sh
    applying patch file ./patches/scripts/220-cdrom-iso.sh
    applying patch file ./patches/scripts/220-chronyd.sh
    applying patch file ./patches/scripts/220-help.sh
    applying patch file ./patches/scripts/220-remove-nas.sh
    applying patch file ./patches/scripts/221-remove_myfritz.sh
    applying patch file ./patches/scripts/225-remove_fhem.sh
    applying patch file ./patches/scripts/230-openssl.sh
    applying patch file ./patches/scripts/240-add-dsl-expert-pages.sh
    applying patch file ./patches/scripts/250-remove_avm_inetd.sh
  removing AVM inetd
    rm -rf build/modified/filesystem/bin/inetdctl
    rm -rf build/modified/filesystem/etc/inetd.conf
    rm -rf build/modified/filesystem/etc/init.d/S75-inetd
    applying patch file ./patches/scripts/260-remove_tr069.sh
    applying patch file ./patches/scripts/270-remove_usb_module.sh
    applying patch file ./patches/scripts/275-multiple_printers.sh
    applying patch file ./patches/scripts/280-remove_upnp.sh
    applying patch file ./patches/scripts/290-replace_websrv.sh
    applying patch file ./patches/scripts/300-remove-samba.sh
    applying patch file ./patches/scripts/310-remove_kids.sh
    applying patch file ./patches/scripts/315-remove-qos.sh
    applying patch file ./patches/scripts/320-remove_capiotcp.sh
    applying patch file ./patches/scripts/320-remove-dsld.sh
    applying patch file ./patches/scripts/325-remove-showdsldstat.sh
    applying patch file ./patches/scripts/330-remove-telephony.sh
    applying patch file ./patches/scripts/331-remove-voipd.sh
    applying patch file ./patches/scripts/340-remove_dect_update.sh
    applying patch file ./patches/scripts/345-hide_dsl.sh
    applying patch file ./patches/scripts/350-add_remove_annex_file.sh
    applying patch file ./patches/scripts/355-remove_dsl_control.sh
    applying patch file ./patches/scripts/360-remove-wlan.sh
    applying patch file ./patches/scripts/370-remove_dtrace.sh
  removing dtrace file
    rm -rf build/modified/filesystem/usr/bin/dtrace
    applying patch file ./patches/scripts/380-remove-umtsd.sh
    applying patch file ./patches/scripts/381-modify-umtsd.sh
    applying patch file ./patches/scripts/382-enable-gsmvoice.sh
    applying patch file ./patches/scripts/385-remove-ntfs.sh
    applying patch file ./patches/scripts/386-remove_fat.sh
    applying patch file ./patches/scripts/390-remove_e2fsprogs.sh
  remove AVM's e2fsprogs binaries
    rm -rf build/modified/filesystem/sbin/blkid
    rm -rf build/modified/filesystem/usr/sbin/blkid
    rm -rf build/modified/filesystem/usr/sbin/e2fsck
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext4
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext3
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext2
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext4dev
    rm -rf build/modified/filesystem/sbin/mkfs
    rm -rf build/modified/filesystem/sbin/mkswap
  remove AVM's e2fsprogs libraries
    rm -rf build/modified/filesystem/usr/lib/libblkid*
    rm -rf build/modified/filesystem/usr/lib/libcom_err*
    rm -rf build/modified/filesystem/usr/lib/libe2p*
    rm -rf build/modified/filesystem/usr/lib/libext2fs*
    rm -rf build/modified/filesystem/usr/lib/libuuid*
    applying patch file ./patches/scripts/400-remove-inetdctl.sh
    applying patch file ./patches/scripts/401-remove_ftpd.sh
  remove banner from AVM ftpd
    applying patch file ./patches/scripts/410-remove_piglet.sh
    applying patch file ./patches/scripts/420-remove_printserv.sh
    applying patch file ./patches/scripts/460-MAXDEVCOUNT.sh
    applying patch file ./patches/scripts/480-alarmclock.sh
    applying patch file ./patches/scripts/490-remove-ramzswap.sh
    applying patch file ./patches/scripts/500-remove-mediasrv.sh
    applying patch file ./patches/scripts/510-remove_aha.sh
    applying patch file ./patches/scripts/510-remove_aura_usb.sh
    applying patch file ./patches/scripts/510-remove_avm_vpn.sh
    applying patch file ./patches/scripts/510-remove_minid.sh
    applying patch file ./patches/scripts/520-remove_dect.sh
    applying patch file ./patches/scripts/530-remove_support.sh
    applying patch file ./patches/scripts/540-remove_webdav.sh
    applying patch file ./patches/scripts/550-add_reg_external_in_gui.sh
    applying patch file ./patches/scripts/560-remove_lsof.sh
    applying patch file ./patches/scripts/565-remove_more.sh
  removing more
    rm -rf build/modified/filesystem/bin/more
    applying patch file ./patches/scripts/570-remove_strace.sh
    applying patch file ./patches/scripts/580-remove_jffs2.sh
    applying patch file ./patches/scripts/585-remove_isofs.sh
    applying patch file ./patches/scripts/590-remove_libfuse.sh
    applying patch file ./patches/scripts/600-replace_mdev.sh
    applying patch file ./patches/scripts/610-remove_socat.sh
    applying patch file ./patches/scripts/700-add_bash_to_etc_shells.sh
    applying patch file ./patches/scripts/700-set_lang_to_utf8.sh
    applying patch file ./patches/scripts/900-add_options_cfg.sh
  creating options.cfg
    by symlinking it to .config
    applying patch file ./patches/scripts/999-remove_run_clock.sh
  removing oem: none
installing mod base
  installing libs
  ld_uClibc ....................   10.30 Kb
  libcrypt .....................    6.98 Kb
  libctlmgr ....................    1.83 Kb
  libdl ........................    4.30 Kb
  libgcc_s .....................   20.58 Kb
  libm .........................   31.64 Kb
  libpthread ...................   21.59 Kb
  librt ........................    2.43 Kb
  libuClibc ....................  194.41 Kb
installing busybox
  replacing busybox
  installing symlinks
installing packages
  syslogd-cgi-0.2.3 ............    3.13 Kb
  inetd-0.2 ....................    2.98 Kb
  haserl-0.9.29 ................    8.88 Kb
  mod-1.0 ......................   98.54 Kb
  modcgi-0.3 ...................    3.44 Kb
invoking custom script
processing mod base options
  setting colored style as default
  patching security level
  rc.external was not integrated into image
  integrating stripped .config file into image
stripping leftover unstripped binaries
    build/modified/filesystem/bin/wlancfgconv
    build/modified/filesystem/bin/wlancfgctl
    build/modified/filesystem/usr/share/ctlmgr/libwlan.so
    build/modified/filesystem/usr/share/ctlmgr/libctlwebdav.so
    build/modified/filesystem/usr/share/ctlmgr/libplcctlmgr.so
    build/modified/filesystem/usr/sbin/athstatsclr
    build/modified/filesystem/usr/sbin/dsl_monitor
    build/modified/filesystem/usr/sbin/80211stats
    build/modified/filesystem/usr/bin/bspatch
    build/modified/filesystem/lib/libwcfg.so
    build/modified/filesystem/lib/libuClibc-0.9.32.1.so
    build/modified/filesystem/lib/libz.so.1.2.3
    build/modified/filesystem/lib/libdl-0.9.32.1.so
    build/modified/filesystem/lib/librt-0.9.32.1.so
    build/modified/filesystem/lib/libm-0.9.32.1.so
    build/modified/filesystem/lib/libpthread-0.9.32.1.so
    build/modified/filesystem/lib/libwlanparams.so
    build/modified/filesystem/lib/ld-uClibc-0.9.32.1.so
    build/modified/filesystem/lib/libcrypt-0.9.32.1.so
    build/modified/filesystem/lib/libtiinterpreter.so.0.0.0
done.
STEP 3: PACK
  checking for left over Subversion directories
  integrate freetz info file into image
packing var.tar
creating filesystem image
  SquashFS block size: 65536 (64 kB)
merging kernel image
  kernel image size: 14588928 (max: 16121856, free: 1532928)
  Aproximately free time for the answering machine: 597s (9min 57s)
packing images/7270_v3_05.23-freetz-devel.en_20130318-155517.image
done.
FINISHED
Here an built-log of a complete new checkout:
joerg@joerg-desktop:/run/shm/tmp/freetz-trunk$ cd ..
joerg@joerg-desktop:/run/shm/tmp$ rm -rf freetz-trunk/
joerg@joerg-desktop:/run/shm/tmp$ umask 022
joerg@joerg-desktop:/run/shm/tmp$ svn co http://svn.freetz.org/trunk freetz-trunk
A    freetz-trunk/.build-prerequisites
A    freetz-trunk/kernel
A    freetz-trunk/kernel/Config.in.modules
A    freetz-trunk/kernel/external.files
A    freetz-trunk/kernel/external.in
A    freetz-trunk/kernel/Config.in.kernel
A    freetz-trunk/toolchain
A    freetz-trunk/toolchain/.gitignore
A    freetz-trunk/toolchain/Config.in.override
A    freetz-trunk/toolchain/make
A    freetz-trunk/toolchain/make/kernel
A    freetz-trunk/toolchain/make/kernel/ccache
A    freetz-trunk/toolchain/make/kernel/ccache/ccache.mk
A    freetz-trunk/toolchain/make/kernel/binutils
A    freetz-trunk/toolchain/make/kernel/binutils/binutils.mk
A    freetz-trunk/toolchain/make/kernel/binutils/2.22
A    freetz-trunk/toolchain/make/kernel/binutils/2.18
A    freetz-trunk/toolchain/make/kernel/binutils/2.18/300-012_check_ldrunpath_length.patch
A    freetz-trunk/toolchain/make/kernel/binutils/2.18/010-use_bundled_mkstemps.patch
A    freetz-trunk/toolchain/make/kernel/binutils/2.18/100-makeinfo-version.patch
A    freetz-trunk/toolchain/make/kernel/binutils/2.18/300-001_ld_makefile_patch.patch
A    freetz-trunk/toolchain/make/kernel/binutils/2.18/999-999_missing.patch
A    freetz-trunk/toolchain/make/kernel/binutils/2.18/005-no_docs__no_nls.patch
A    freetz-trunk/toolchain/make/kernel/gcc
A    freetz-trunk/toolchain/make/kernel/gcc/gcc.mk
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/005-no_docs.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/910-mbsd_multi.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/gcc_ignore_config_cache.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/010-make-j-fixes-pr42980_backport.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/pr15068-fix.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/010-use_bundled_mkstemps.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/collect_arguments.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/pr16276-fix.patch
A    freetz-trunk/toolchain/make/kernel/gcc/3.4.6/pr22541-fix-fixincl.patch
A    freetz-trunk/toolchain/make/kernel/gcc/4.6.3
A    freetz-trunk/toolchain/make/Makefile.in
A    freetz-trunk/toolchain/make/kernel-toolchain.mk
A    freetz-trunk/toolchain/make/target
A    freetz-trunk/toolchain/make/target/libtool-host
A    freetz-trunk/toolchain/make/target/libtool-host/libtool-host.mk
A    freetz-trunk/toolchain/make/target/libtool-host/patches
A    freetz-trunk/toolchain/make/target/uclibc
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/102-termios.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/012-getaddrinfo_allow_numeric_service_without_any_hints.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/250-iconv-typo-fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/190-install_tls.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/150-fix-ldso-text-realloc-segfault.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/002-conditional_sched_affinity.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/005-fix_internal_function_definition.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/800-no_libnsl_no_libresolv.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/120-adjtimex.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/516-backport__progname.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/003-hardwired_abspath.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/300-readdir_r-fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/009-fix_getaddrinfo_infinite_loop.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/100-fritzbox_specific_arch_flags.freetz.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/520-move_dl_iterate_phdr.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/008-fix_getaddrinfo_numericserv.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/200-libpthread_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/140-fix-endless-recursion-in-pthread.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/161-mips_pipe_return_value.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/510-gcc_4_3_include_fixed.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/110-compat_macros.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/130-compile_fixes.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/560-utils_static_linking.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/138-pthreads.old-join_np.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/210-trunc.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/700-backport__defeat_compiler_opt.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/006-rm_whitespace.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/001-fix_mmap.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/580-assembler_warnings.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/004-fix_gethostent_r_failure_retval.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/160-mips_syscall_return_value.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/013-ipv6_defines_according_to_kernel_version.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/550-backport_realpath_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/139-pthreads.old-pthread_unlock-unlocked.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/220-libpthread_sysdep_fixes.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/515-backport__progname.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/600-fix_daylight_saving_time_handling.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/141-fix-daemon-to-support-pthread.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/180-fix_kernel_types_with_recent_kernel.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/010-fix_resolv_dnslookup.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/170-NTH_socket_h.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/590-crtn.S_explicit_size.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/530-backport_link_asneeded.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/260-iconv-reversed-endian-fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/010-avm-uclibc.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.29/570-backport_nonpic_support.patch
A    freetz-trunk/toolchain/make/target/uclibc/Config.mod.0.9.28
A    freetz-trunk/toolchain/make/target/uclibc/Config.mod.0.9.29
A    freetz-trunk/toolchain/make/target/uclibc/Makefile.in
A    freetz-trunk/toolchain/make/target/uclibc/uclibc.mk
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/100-fritzbox_specific_arch_flags.freetz.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/200-no_forced_unwind.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/540-pregenerated_locale_data.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/350-use-fputs_unlocked.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/190-nptl_use_arch_default_stack_limit.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/110-compat_macros.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/410-llvm_workaround.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/138-pthreads.old-join_np.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/700-backport__defeat_compiler_opt.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/170-math_finite.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/180-pthread_weak_binding.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/131-inet-fix-__read_etc_hosts_r-segfault.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/660-force_absolute_interp_path.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/013-ipv6_defines_according_to_kernel_version.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/130-ldso-fix-__dl_parse_dynamic_info-segfault.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/139-pthreads.old-pthread_unlock-unlocked.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/120-adjtimex.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/135-fix-pthread.h.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/004-fix-gethostent_r-failure-retval.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/904-pthread_errno_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/300-readdir_r-fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/185-pthread_cleanup_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.32.1/650-IPv6_defines_with_IPv6_disabled.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/200-no_forced_unwind.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/100-fritzbox_specific_arch_flags.freetz.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/540-pregenerated_locale_data.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/350-use-fputs_unlocked.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/190-nptl_use_arch_default_stack_limit.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/020-eventfd_proper_implementation.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/110-compat_macros.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/410-llvm_workaround.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/138-pthreads.old-join_np.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/170-math_finite.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/180-pthread_weak_binding.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/131-inet-fix-__read_etc_hosts_r-segfault.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/660-force_absolute_interp_path.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/013-ipv6_defines_according_to_kernel_version.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/139-pthreads.old-pthread_unlock-unlocked.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/120-adjtimex.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/021-eventfd_omit_prototype_if_not_available.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/135-fix-pthread.h.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/004-fix-gethostent_r-failure-retval.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/904-pthread_errno_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/185-pthread_cleanup_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/300-readdir_r-fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/650-IPv6_defines_with_IPv6_disabled.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.33.2/011-dlsym_rtld_next_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/Config.mod.0.9.32.1
A    freetz-trunk/toolchain/make/target/uclibc/Config.mod.0.9.33.2
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/100-fritzbox_specific_arch_flags.freetz.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/010-getaddrinfo_allow_numeric_service_without_any_hints.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/520-move_dl_iterate_phdr.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/110-mips_pipe.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/170_update_queue_header.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/510-gcc_4_3_include_fixed.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/160-add_inotify_support.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/560-utils_static_linking.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/120-more_standard_math.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/700-backport__defeat_compiler_opt.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/800-no_libnsl_no_libresolv.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/119-backport_missing_libm_functions.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/200-ipv6_missing_sockopts.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/550-backport_realpath_fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/102-signal_handler_crash_workaround.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/600-fix_daylight_saving_time_handling.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/140-uclibc_do_div_ldso.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/590-crtn.S_explicit_size.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/300-readdir_r-fix.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/010-avm-uclibc-freetz-backport.patch
A    freetz-trunk/toolchain/make/target/uclibc/0.9.28/570-backport_nonpic_support.patch
A    freetz-trunk/toolchain/make/target/ccache
A    freetz-trunk/toolchain/make/target/ccache/ccache.mk
A    freetz-trunk/toolchain/make/target/binutils
A    freetz-trunk/toolchain/make/target/binutils/binutils.mk
A    freetz-trunk/toolchain/make/target/binutils/2.22
A    freetz-trunk/toolchain/make/target/binutils/2.22/300-012_check_ldrunpath_length.patch
A    freetz-trunk/toolchain/make/target/binutils/2.22/010-use_bundled_mkstemps.patch
A    freetz-trunk/toolchain/make/target/binutils/2.22/300-001_ld_makefile_patch.patch
A    freetz-trunk/toolchain/make/target/binutils/2.22/005-no_docs__no_nls.patch
A    freetz-trunk/toolchain/make/target/gcc
A    freetz-trunk/toolchain/make/target/gcc/gcc.mk
A    freetz-trunk/toolchain/make/target/gcc/4.6.3
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/100-uclibc-conf.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/820-libgcc_pic.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/110-overridable-CXXFLAGS_FOR_TARGET.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/005-no_docs.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/010-make-j-fixes.pr42980_backport.install-multi.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/000-uClibc_pthread-miscompile-fix.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/800-libgcc-dwarf.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/910-mbsd_multi.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/010-make-j-fixes.pr42980_backport.multido.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/305-libmudflap-susv3-legacy.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/302-c99-snprintf.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/800-libgcc-disable-mips16-float.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/101-libgcc-exclude-rarely-used-functions.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/010-use_bundled_mkstemps.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/020-no_python.patch
A    freetz-trunk/toolchain/make/target/gcc/4.6.3/301-missing-execinfo_h.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/100-uclibc-conf.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/820-libgcc_pic.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/005-no_docs.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/010-make-j-fixes.pr42980_backport.multido.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/110-overridable-CXXFLAGS_FOR_TARGET.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/910-mbsd_multi.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/010-make-j-fixes.pr42980_backport.install-multi.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/302-c99-snprintf.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/305-libmudflap-susv3-legacy.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/101-libgcc-exclude-rarely-used-functions.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/800-libgcc-disable-mips16-float.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/800-libgcc-dwarf.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/010-use_bundled_mkstemps.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/020-no_python.patch
A    freetz-trunk/toolchain/make/target/gcc/4.7.2/301-missing-execinfo_h.patch
A    freetz-trunk/toolchain/make/target-toolchain.mk
A    freetz-trunk/toolchain/make/download-toolchain.mk
A    freetz-trunk/toolchain/make/toolchain-common.in
A    freetz-trunk/.defdynamic
A    freetz-trunk/fmake
A    freetz-trunk/howtos
A    freetz-trunk/howtos/en
A    freetz-trunk/howtos/en/HOWTO_recover.txt
A    freetz-trunk/howtos/en/HOWTO_integrate_own_files.txt
A    freetz-trunk/howtos/en/HOWTO_addons.txt
A    freetz-trunk/howtos/de
A    freetz-trunk/howtos/de/HOWTO_eigene_dateien.txt
A    freetz-trunk/howtos/de/HOWTO_recover.txt
A    freetz-trunk/howtos/de/HOWTO_addons.txt
A    freetz-trunk/include
A    freetz-trunk/include/site
A    freetz-trunk/include/site/freetz
A    freetz-trunk/include/site/mips-linux-uclibc
A    freetz-trunk/include/site/mipsel-linux-uclibc
A    freetz-trunk/include/make
A    freetz-trunk/include/make/010-special-characters-symbolic-names.mk
A    freetz-trunk/include/make/020-helper-functions.mk
A    freetz-trunk/.defstatic
A    freetz-trunk/addon
A    freetz-trunk/addon/own-files-0.1
A    freetz-trunk/addon/own-files-0.1/root
A    freetz-trunk/addon/own-files-0.1/root/lib
A    freetz-trunk/addon/own-files-0.1/root/lib/.gitignore
A    freetz-trunk/addon/own-files-0.1/root/bin
A    freetz-trunk/addon/own-files-0.1/root/bin/.gitignore
A    freetz-trunk/addon/own-files-0.1/root/usr
A    freetz-trunk/addon/own-files-0.1/root/usr/lib
A    freetz-trunk/addon/own-files-0.1/root/usr/lib/.gitignore
A    freetz-trunk/addon/own-files-0.1/root/usr/bin
A    freetz-trunk/addon/own-files-0.1/root/usr/bin/.gitignore
A    freetz-trunk/addon/own-files-0.1/root/usr/sbin
A    freetz-trunk/addon/own-files-0.1/root/usr/sbin/.gitignore
A    freetz-trunk/addon/own-files-0.1/root/etc
A    freetz-trunk/addon/own-files-0.1/root/etc/init.d
A    freetz-trunk/addon/own-files-0.1/root/etc/init.d/.gitignore
A    freetz-trunk/addon/own-files-0.1/var.tar
A    freetz-trunk/addon/own-files-0.1/var.tar/var
A    freetz-trunk/addon/own-files-0.1/var.tar/var/tmp
A    freetz-trunk/addon/own-files-0.1/var.tar/var/tmp/.gitignore
A    freetz-trunk/addon/dynamic.pkg
A    freetz-trunk/addon/static.pkg
A    freetz-trunk/STARTLEVEL
A    freetz-trunk/Config.in.has_avm
A    freetz-trunk/CHANGELOG
A    freetz-trunk/patches
A    freetz-trunk/patches/devices
A    freetz-trunk/patches/devices/05_5X
A    freetz-trunk/patches/devices/05_5X/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/05_5X/130-foncalls.patch!
A    freetz-trunk/patches/devices/05_5X/105-S06-logging.sh
A    freetz-trunk/patches/devices/05_5X/140-rc.tail.sh-no_exit.patch
A    freetz-trunk/patches/devices/05_5X/de
A    freetz-trunk/patches/devices/05_5X/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_5X/200-tun-device.sh
A    freetz-trunk/patches/devices/05_5X/115-S20-modload.sh
A    freetz-trunk/patches/devices/04_XX
A    freetz-trunk/patches/devices/04_XX/fon
A    freetz-trunk/patches/devices/04_XX/fon/en
A    freetz-trunk/patches/devices/04_XX/fon/en/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/fon/en/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/fon/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/fon/en/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/fon/en/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/fon/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/fon/de
A    freetz-trunk/patches/devices/04_XX/fon/de/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/fon/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/fon/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/fon/de/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/fon/de/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/fon/de/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/W501V
A    freetz-trunk/patches/devices/04_XX/W501V/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/W501V/200-tk-firmware.sh
A    freetz-trunk/patches/devices/04_XX/W501V/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/W501V/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/W501V/de
A    freetz-trunk/patches/devices/04_XX/W501V/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/W501V/de/180-tcom.patch
A    freetz-trunk/patches/devices/04_XX/W501V/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/W501V/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/W501V/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/W701V
A    freetz-trunk/patches/devices/04_XX/W701V/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/W701V/200-tk-firmware.sh
A    freetz-trunk/patches/devices/04_XX/W701V/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/W701V/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/W701V/de
A    freetz-trunk/patches/devices/04_XX/W701V/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/W701V/de/210-sp2fritz.patch
A    freetz-trunk/patches/devices/04_XX/W701V/de/180-tcom.patch
A    freetz-trunk/patches/devices/04_XX/W701V/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/W701V/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/W701V/210-copy-modules.sh
A    freetz-trunk/patches/devices/04_XX/3020
A    freetz-trunk/patches/devices/04_XX/3020/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/3020/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/3020/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/3020/de
A    freetz-trunk/patches/devices/04_XX/3020/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/3020/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/W900V
A    freetz-trunk/patches/devices/04_XX/W900V/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/W900V/200-tk-firmware.sh
A    freetz-trunk/patches/devices/04_XX/W900V/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/W900V/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/W900V/de
A    freetz-trunk/patches/devices/04_XX/W900V/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/W900V/de/200-sp2fritz.patch
A    freetz-trunk/patches/devices/04_XX/W900V/de/180-tcom.patch
A    freetz-trunk/patches/devices/04_XX/W900V/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/W900V/210-copy-modules.sh
A    freetz-trunk/patches/devices/04_XX/3030
A    freetz-trunk/patches/devices/04_XX/3030/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/3030/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/3030/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/3030/de
A    freetz-trunk/patches/devices/04_XX/3030/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/3030/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/5010
A    freetz-trunk/patches/devices/04_XX/5010/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/5010/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/5010/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/5010/a-ch
A    freetz-trunk/patches/devices/04_XX/5010/a-ch/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/5010/a-ch/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/5010/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/3130
A    freetz-trunk/patches/devices/04_XX/3130/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/3130/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/3130/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/3130/de
A    freetz-trunk/patches/devices/04_XX/3130/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/3130/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/3131
A    freetz-trunk/patches/devices/04_XX/3131/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/3131/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/3131/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/3131/de
A    freetz-trunk/patches/devices/04_XX/3131/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/3131/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/2170
A    freetz-trunk/patches/devices/04_XX/2170/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/2170/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/2170/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/2170/de
A    freetz-trunk/patches/devices/04_XX/2170/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/2170/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/5050
A    freetz-trunk/patches/devices/04_XX/5050/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/5050/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/5050/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/5050/de
A    freetz-trunk/patches/devices/04_XX/5050/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/5050/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/5050/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/5140
A    freetz-trunk/patches/devices/04_XX/5140/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/5140/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/5140/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/5140/de
A    freetz-trunk/patches/devices/04_XX/5140/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/5140/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/5140/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/5140/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/3170
A    freetz-trunk/patches/devices/04_XX/3170/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/3170/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/3170/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/3170/de
A    freetz-trunk/patches/devices/04_XX/3170/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/3170/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7112
A    freetz-trunk/patches/devices/04_XX/7112/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7112/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7112/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7112/de
A    freetz-trunk/patches/devices/04_XX/7112/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7112/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7112/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7112/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7113
A    freetz-trunk/patches/devices/04_XX/7113/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7113/en
A    freetz-trunk/patches/devices/04_XX/7113/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7113/en/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7113/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7113/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7113/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7113/de
A    freetz-trunk/patches/devices/04_XX/7113/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7113/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7113/de/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7113/de/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/7113/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7140
A    freetz-trunk/patches/devices/04_XX/7140/en
A    freetz-trunk/patches/devices/04_XX/7140/en/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/400_remove_ftpd.patch
A    freetz-trunk/patches/devices/04_XX/7140/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7140/a-ch
A    freetz-trunk/patches/devices/04_XX/7140/a-ch/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7140/a-ch/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7140/a-ch/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7140/a-ch/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7140/a-ch/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7140/de
A    freetz-trunk/patches/devices/04_XX/7140/de/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7140/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7140/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7140/de/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7140/de/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7140/de/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/7050
A    freetz-trunk/patches/devices/04_XX/7050/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7050/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7050/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7050/de
A    freetz-trunk/patches/devices/04_XX/7050/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7050/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7050/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/5124
A    freetz-trunk/patches/devices/04_XX/5124/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/5124/en
A    freetz-trunk/patches/devices/04_XX/5124/en/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/5124/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/5124/en/400_remove_ftpd.patch
A    freetz-trunk/patches/devices/04_XX/5124/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/5124/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/5124/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/5124/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/300ip
A    freetz-trunk/patches/devices/04_XX/300ip/200-tk-firmware.sh
A    freetz-trunk/patches/devices/04_XX/300ip/en
A    freetz-trunk/patches/devices/04_XX/300ip/en/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/140-third-phone.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/150-Eumex_to_Fritz.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/201-rc.conf-eumex2fon.patch
A    freetz-trunk/patches/devices/04_XX/300ip/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/300ip/200-tk-firmware-en
A    freetz-trunk/patches/devices/04_XX/300ip/de
A    freetz-trunk/patches/devices/04_XX/300ip/de/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/140-third-phone.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/150-Eumex_to_Fritz.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/300ip/de/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/300ip/200-tk-firmware-de
A    freetz-trunk/patches/devices/04_XX/7141
A    freetz-trunk/patches/devices/04_XX/7141/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7141/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7141/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7141/de
A    freetz-trunk/patches/devices/04_XX/7141/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7141/de/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/7141/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7141/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7141/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7141/400_remove_ftpd.patch
A    freetz-trunk/patches/devices/04_XX/7150
A    freetz-trunk/patches/devices/04_XX/7150/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7150/100-w500v_7150.sh
A    freetz-trunk/patches/devices/04_XX/7150/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7150/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7150/de
A    freetz-trunk/patches/devices/04_XX/7150/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7150/de/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/7150/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7150/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7150/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7150/400_remove_ftpd.patch
A    freetz-trunk/patches/devices/04_XX/7170
A    freetz-trunk/patches/devices/04_XX/7170/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7170/en
A    freetz-trunk/patches/devices/04_XX/7170/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7170/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7170/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7170/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7170/a-ch
A    freetz-trunk/patches/devices/04_XX/7170/a-ch/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7170/de
A    freetz-trunk/patches/devices/04_XX/7170/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7170/de/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/7170/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7170/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7170/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/7270
A    freetz-trunk/patches/devices/04_XX/7270/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7270/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7270/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7270/de
A    freetz-trunk/patches/devices/04_XX/7270/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7270/de/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/7270/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7270/de/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7270/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/04_XX/wlan
A    freetz-trunk/patches/devices/04_XX/wlan/en
A    freetz-trunk/patches/devices/04_XX/wlan/en/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/wlan/en/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/wlan/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/wlan/en/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/wlan/en/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/wlan/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/wlan/de
A    freetz-trunk/patches/devices/04_XX/wlan/de/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/wlan/de/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/wlan/de/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/wlan/de/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/wlan/de/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/wlan/de/290-replace_websrv-remove_igdd.patch
A    freetz-trunk/patches/devices/04_XX/7570
A    freetz-trunk/patches/devices/04_XX/7570/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/04_XX/7570/en
A    freetz-trunk/patches/devices/04_XX/7570/en/130-foncalls.patch
A    freetz-trunk/patches/devices/04_XX/7570/en/210-notmountable.patch
A    freetz-trunk/patches/devices/04_XX/7570/en/190-webmenu.patch
A    freetz-trunk/patches/devices/04_XX/7570/en/200-sperre1.patch
A    freetz-trunk/patches/devices/04_XX/7570/110-rc.S-mknod.patch
A    freetz-trunk/patches/devices/04_XX/7570/130-rc.S-logging.patch
A    freetz-trunk/patches/devices/04_XX/7570/210-install-set_oem.sh
A    freetz-trunk/patches/devices/04_XX/7570/140-rc.S-no_avm_exit.patch
A    freetz-trunk/patches/devices/05_2X
A    freetz-trunk/patches/devices/05_2X/120-rc.S-dev.patch
A    freetz-trunk/patches/devices/05_2X/de
A    freetz-trunk/patches/devices/05_2X/3270
A    freetz-trunk/patches/devices/05_2X/3270/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/3270/en
A    freetz-trunk/patches/devices/05_2X/3270/en/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/3270/de
A    freetz-trunk/patches/devices/05_2X/3270/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/3270/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/3270/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/7320
A    freetz-trunk/patches/devices/05_2X/7320/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7320/de
A    freetz-trunk/patches/devices/05_2X/7320/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7320/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7320/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/3370
A    freetz-trunk/patches/devices/05_2X/3370/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/3370/de
A    freetz-trunk/patches/devices/05_2X/3370/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/3370/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/3370/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/7240
A    freetz-trunk/patches/devices/05_2X/7240/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7240/de
A    freetz-trunk/patches/devices/05_2X/7240/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7240/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7240/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/7312
A    freetz-trunk/patches/devices/05_2X/7312/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7312/de
A    freetz-trunk/patches/devices/05_2X/7312/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7312/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/7330
A    freetz-trunk/patches/devices/05_2X/7330/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7330/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7330/de
A    freetz-trunk/patches/devices/05_2X/7330/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7330/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/7340
A    freetz-trunk/patches/devices/05_2X/7340/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7340/en
A    freetz-trunk/patches/devices/05_2X/7340/en/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7340/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/115-S20-modload.sh
A    freetz-trunk/patches/devices/05_2X/7270
A    freetz-trunk/patches/devices/05_2X/7270/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7270/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7270/de
A    freetz-trunk/patches/devices/05_2X/7270/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7270/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/7360
A    freetz-trunk/patches/devices/05_2X/7360/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7360/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7360/de
A    freetz-trunk/patches/devices/05_2X/7360/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7360/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/6840
A    freetz-trunk/patches/devices/05_2X/6840/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/6840/de
A    freetz-trunk/patches/devices/05_2X/6840/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/6840/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/6840/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/en
A    freetz-trunk/patches/devices/05_2X/en/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7390
A    freetz-trunk/patches/devices/05_2X/7390/130-foncalls.patch
A    freetz-trunk/patches/devices/05_2X/7390/en
A    freetz-trunk/patches/devices/05_2X/7390/en/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7390/de
A    freetz-trunk/patches/devices/05_2X/7390/de/210-notmountable.patch
A    freetz-trunk/patches/devices/05_2X/7390/de/190-webmenu.patch
A    freetz-trunk/patches/devices/05_2X/7390/200-sperre1.patch
A    freetz-trunk/patches/devices/05_2X/140-rc.tail.sh-no_exit.patch
A    freetz-trunk/patches/devices/05_2X/105-S06-logging.sh
A    freetz-trunk/patches/devices/05_2X/200-tun-device.sh
A    freetz-trunk/patches/cond
A    freetz-trunk/patches/cond/intro_bar_middle_alien_7170.patch
A    freetz-trunk/patches/cond/mdev_my_uuid.patch
A    freetz-trunk/patches/cond/110-system_status.patch
A    freetz-trunk/patches/cond/de
A    freetz-trunk/patches/cond/de/webmenu-wol-W501V.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3020.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-5140.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7330_SL.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7320.patch
A    freetz-trunk/patches/cond/de/480-alarmclock_7112.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7141.patch
A    freetz-trunk/patches/cond/de/480-alarmclock_7150.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7113.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3270_v3.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7170.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7270_v1.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7270_v3.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-300ip_as_fon.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-fon.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7270_v2_labor.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-W900V.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7270_v3_labor.patch
A    freetz-trunk/patches/cond/de/remove_userman_old.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3131.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7112.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7050.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7312.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7150.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-6840.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7390.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7141.patch
A    freetz-trunk/patches/cond/de/iad2fritz-3331_7170.patch
A    freetz-trunk/patches/cond/de/480-alarmclock_7270_v1.patch
A    freetz-trunk/patches/cond/de/remove_userman_wlan_old.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7390_05_22.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7330_labor.patch
A    freetz-trunk/patches/cond/de/remove-FON3-7170-alien.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-W701V.patch
A    freetz-trunk/patches/cond/de/remove_assistant.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-2170.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7140.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7240.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7360_SL.patch
A    freetz-trunk/patches/cond/de/480-alarmclock_7170.patch
A    freetz-trunk/patches/cond/de/sp2fritz_W500V_7150.patch
A    freetz-trunk/patches/cond/de/remove_userman_new.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7112.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3270_v2.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7150.patch
A    freetz-trunk/patches/cond/de/130-foncalls.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7270_v2.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-2170_vpn.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7270_v1.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7360_SL_labor.patch
A    freetz-trunk/patches/cond/de/install-300ip-as-fon.patch
A    freetz-trunk/patches/cond/de/remove_userman_wlan_new.patch
A    freetz-trunk/patches/cond/de/sp2fritz-W701V_7170.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3030.patch
A    freetz-trunk/patches/cond/de/sp2fritz-W900V_7170.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3130.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-5050.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3170.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7113.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-3370.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7330.patch
A    freetz-trunk/patches/cond/de/480-alarmclock_7141.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-7170.patch
A    freetz-trunk/patches/cond/de/remove_assistant_7140.patch
A    freetz-trunk/patches/cond/de/remove-POTS-7170-alien.patch
A    freetz-trunk/patches/cond/de/webmenu-wol-fon_wlan.patch
A    freetz-trunk/patches/cond/de/190-webmenu.patch
A    freetz-trunk/patches/cond/de/remove_assistant_wop.patch
A    freetz-trunk/patches/cond/rc.S-W900V_7170.patch
A    freetz-trunk/patches/cond/mdev_wlancfgchanged.patch
A    freetz-trunk/patches/cond/install-W701V_7170.patch
A    freetz-trunk/patches/cond/install-W900V_7170.patch
A    freetz-trunk/patches/cond/install-7141_7170_Annex_A.patch
A    freetz-trunk/patches/cond/a-ch
A    freetz-trunk/patches/cond/a-ch/remove_userman_wlan_new.patch
A    freetz-trunk/patches/cond/a-ch/webmenu-wol-5010.patch
A    freetz-trunk/patches/cond/a-ch/webmenu-wol-7140.patch
A    freetz-trunk/patches/cond/a-ch/webmenu-wol-7170.patch
A    freetz-trunk/patches/cond/a-ch/remove_userman_new.patch
A    freetz-trunk/patches/cond/install-3170_7170.patch
A    freetz-trunk/patches/cond/install-7112_7170.patch
A    freetz-trunk/patches/cond/install-7140_7170.patch
A    freetz-trunk/patches/cond/rc.S-no-cdrom-fallback.patch
A    freetz-trunk/patches/cond/rc.S-mknod-nophone.patch
A    freetz-trunk/patches/cond/mdev_rc.S.patch
A    freetz-trunk/patches/cond/rc.S-3170_7170_a_ch.patch
A    freetz-trunk/patches/cond/install-3170_7170_a_ch.patch
A    freetz-trunk/patches/cond/mdev_debug_rc.S.patch
A    freetz-trunk/patches/cond/rc.S-no-cdrom-fallback_5050.patch
A    freetz-trunk/patches/cond/install-IAD_3331_7170.patch
A    freetz-trunk/patches/cond/install-7570_HN.patch
A    freetz-trunk/patches/cond/275-multiple_printers
A    freetz-trunk/patches/cond/275-multiple_printers/01-c8d92a2301ba262c61747747a817ab20.patch
A    freetz-trunk/patches/cond/275-multiple_printers/02-47c36012e53934dc583c9d568711299d.patch
A    freetz-trunk/patches/cond/en
A    freetz-trunk/patches/cond/en/webmenu-wol-fon.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-5124.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7113.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7140.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7330.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7340.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7170.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7360.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7570.patch
A    freetz-trunk/patches/cond/en/remove_assistant_7113.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-fon_wlan.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-3270_v3.patch
A    freetz-trunk/patches/cond/en/480-alarmclock_7570.patch
A    freetz-trunk/patches/cond/en/7240_7270_rc.S_piglet.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7270_v2.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7270_v3.patch
A    freetz-trunk/patches/cond/en/remove_assistant_7570.patch
A    freetz-trunk/patches/cond/en/webmenu-wol-7390_05_22.patch
A    freetz-trunk/patches/cond/en/install-7240_7270.patch
A    freetz-trunk/patches/cond/en/install-300ip-as-fon.patch
A    freetz-trunk/patches/cond/mdev_post_install_7170.patch
A    freetz-trunk/patches/cond/mdev_post_install_7270.patch
A    freetz-trunk/patches/cond/install-7140_7170_Annex_A.patch
A    freetz-trunk/patches/cond/mdev_fstab.patch
A    freetz-trunk/patches/cond/rc.S-3170_7170.patch
A    freetz-trunk/patches/cond/rc.S-mknod.patch
A    freetz-trunk/patches/cond/install-7570_W920V.patch
A    freetz-trunk/patches/cond/install-7113_7170.patch
A    freetz-trunk/patches/cond/install-7141_7170.patch
A    freetz-trunk/patches/cond/rc.S-no-cdrom-fallback_fon_04.49.patch
A    freetz-trunk/patches/cond/240-add-dsl-expert-pages
A    freetz-trunk/patches/cond/240-add-dsl-expert-pages/b66bb65288407a8256fac6b12375aa20.patch
A    freetz-trunk/patches/cond/240-add-dsl-expert-pages/9523ab3710a8b9dab7241b38fe70dfd3.patch
A    freetz-trunk/patches/cond/240-add-dsl-expert-pages/3d22178e52b07a6d6313f17d3b359218.patch
A    freetz-trunk/patches/cond/rc.S-no-cdrom-fallback_fon.patch
A    freetz-trunk/patches/scripts
A    freetz-trunk/patches/scripts/100-7112_7170.sh
A    freetz-trunk/patches/scripts/260-remove_tr069.sh
A    freetz-trunk/patches/scripts/100-7113_7170.sh
A    freetz-trunk/patches/scripts/195-webmenu_signed.sh
A    freetz-trunk/patches/scripts/382-enable-gsmvoice.sh
A    freetz-trunk/patches/scripts/220-assistant.sh
A    freetz-trunk/patches/scripts/220-remove-nas.sh
A    freetz-trunk/patches/scripts/331-remove-voipd.sh
A    freetz-trunk/patches/scripts/480-alarmclock.sh
A    freetz-trunk/patches/scripts/320-remove-dsld.sh
A    freetz-trunk/patches/scripts/325-remove-showdsldstat.sh
A    freetz-trunk/patches/scripts/110-system_status.sh
A    freetz-trunk/patches/scripts/101-ctlmgr_wrapper.sh
A    freetz-trunk/patches/scripts/560-remove_lsof.sh
A    freetz-trunk/patches/scripts/550-add_reg_external_in_gui.sh
A    freetz-trunk/patches/scripts/220-help.sh
A    freetz-trunk/patches/scripts/191-webmenu_wol.sh
A    freetz-trunk/patches/scripts/540-remove_webdav.sh
A    freetz-trunk/patches/scripts/197-freetzmount.sh
A    freetz-trunk/patches/scripts/100-7570_iad7570.sh
A    freetz-trunk/patches/scripts/130-fstab.sh
A    freetz-trunk/patches/scripts/330-remove-telephony.sh
A    freetz-trunk/patches/scripts/310-remove_kids.sh
A    freetz-trunk/patches/scripts/700-set_lang_to_utf8.sh
A    freetz-trunk/patches/scripts/100-enforce-urlader-settings.sh
A    freetz-trunk/patches/scripts/490-remove-ramzswap.sh
A    freetz-trunk/patches/scripts/290-replace_websrv.sh
A    freetz-trunk/patches/scripts/401-remove_ftpd.sh
A    freetz-trunk/patches/scripts/510-remove_minid.sh
A    freetz-trunk/patches/scripts/221-remove_myfritz.sh
A    freetz-trunk/patches/scripts/116-usbroot_S46-usb.sh
A    freetz-trunk/patches/scripts/250-remove_avm_inetd.sh
A    freetz-trunk/patches/scripts/110-inittab.sh
A    freetz-trunk/patches/scripts/220-cdrom-iso.sh
A    freetz-trunk/patches/scripts/140-remove-uClibc.sh
A    freetz-trunk/patches/scripts/380-remove-umtsd.sh
A    freetz-trunk/patches/scripts/108-tffs_nodes.sh
A    freetz-trunk/patches/scripts/100-w701v_7170.sh
A    freetz-trunk/patches/scripts/580-remove_jffs2.sh
A    freetz-trunk/patches/scripts/105-onlinechanged.sh
A    freetz-trunk/patches/scripts/360-remove-wlan.sh
A    freetz-trunk/patches/scripts/225-remove_fhem.sh
A    freetz-trunk/patches/scripts/210-enum.sh
A    freetz-trunk/patches/scripts/100-3170_7170.sh
A    freetz-trunk/patches/scripts/570-remove_strace.sh
A    freetz-trunk/patches/scripts/500-remove-mediasrv.sh
A    freetz-trunk/patches/scripts/210-international.sh
A    freetz-trunk/patches/scripts/220-chronyd.sh
A    freetz-trunk/patches/scripts/355-remove_dsl_control.sh
A    freetz-trunk/patches/scripts/115-rc.S.sh
A    freetz-trunk/patches/scripts/100-7240_7270.sh
A    freetz-trunk/patches/scripts/109-rc.net-multid-wrapper.sh
A    freetz-trunk/patches/scripts/200-vcc.sh
A    freetz-trunk/patches/scripts/420-remove_printserv.sh
A    freetz-trunk/patches/scripts/180-printk.sh
A    freetz-trunk/patches/scripts/300-remove-samba.sh
A    freetz-trunk/patches/scripts/320-remove_capiotcp.sh
A    freetz-trunk/patches/scripts/385-remove-ntfs.sh
A    freetz-trunk/patches/scripts/345-hide_dsl.sh
A    freetz-trunk/patches/scripts/230-openssl.sh
A    freetz-trunk/patches/scripts/600-replace_mdev.sh
A    freetz-trunk/patches/scripts/610-remove_socat.sh
A    freetz-trunk/patches/scripts/100-7270v2_7270v1.sh
A    freetz-trunk/patches/scripts/565-remove_more.sh
A    freetz-trunk/patches/scripts/530-remove_support.sh
A    freetz-trunk/patches/scripts/700-add_bash_to_etc_shells.sh
A    freetz-trunk/patches/scripts/100-w900v_7170.sh
A    freetz-trunk/patches/scripts/340-remove_dect_update.sh
A    freetz-trunk/patches/scripts/120-dev_led.sh
A    freetz-trunk/patches/scripts/400-remove-inetdctl.sh
A    freetz-trunk/patches/scripts/315-remove-qos.sh
A    freetz-trunk/patches/scripts/210-ata.sh
A    freetz-trunk/patches/scripts/100-7320_7330.sh
A    freetz-trunk/patches/scripts/115-7270_16MB.sh.old
A    freetz-trunk/patches/scripts/386-remove_fat.sh
A    freetz-trunk/patches/scripts/280-remove_upnp.sh
A    freetz-trunk/patches/scripts/100-w920v_7570.sh
A    freetz-trunk/patches/scripts/100-7140_7170.sh
A    freetz-trunk/patches/scripts/100-7141_7170.sh
A    freetz-trunk/patches/scripts/190-webmenu.sh
A    freetz-trunk/patches/scripts/510-remove_aha.sh
A    freetz-trunk/patches/scripts/198-usbroot.sh
A    freetz-trunk/patches/scripts/240-add-dsl-expert-pages.sh
A    freetz-trunk/patches/scripts/170-rename_ar7login.sh
A    freetz-trunk/patches/scripts/585-remove_isofs.sh
A    freetz-trunk/patches/scripts/270-remove_usb_module.sh
A    freetz-trunk/patches/scripts/510-remove_aura_usb.sh
A    freetz-trunk/patches/scripts/590-remove_libfuse.sh
A    freetz-trunk/patches/scripts/999-remove_run_clock.sh
A    freetz-trunk/patches/scripts/370-remove_dtrace.sh
A    freetz-trunk/patches/scripts/510-remove_avm_vpn.sh
A    freetz-trunk/patches/scripts/900-add_options_cfg.sh
A    freetz-trunk/patches/scripts/381-modify-umtsd.sh
A    freetz-trunk/patches/scripts/100-7270v1_7270v2.sh
A    freetz-trunk/patches/scripts/275-multiple_printers.sh
A    freetz-trunk/patches/scripts/110-multid-wait.sh
A    freetz-trunk/patches/scripts/390-remove_e2fsprogs.sh
A    freetz-trunk/patches/scripts/520-remove_dect.sh
A    freetz-trunk/patches/scripts/350-add_remove_annex_file.sh
A    freetz-trunk/patches/scripts/410-remove_piglet.sh
A    freetz-trunk/patches/scripts/460-MAXDEVCOUNT.sh
A    freetz-trunk/patches/scripts/100_iad3331_7170.sh
A    freetz-trunk/patches/Config.in
A    freetz-trunk/README
A    freetz-trunk/FIRMWARES
A    freetz-trunk/graphics
A    freetz-trunk/graphics/tagging
A    freetz-trunk/graphics/tagging/cuma.png
A    freetz-trunk/graphics/favicon
A    freetz-trunk/graphics/favicon/hansolo
A    freetz-trunk/graphics/favicon/hansolo/box.ico
A    freetz-trunk/graphics/favicon/hansolo/freetz.ico
A    freetz-trunk/graphics/favicon/cuma
A    freetz-trunk/graphics/favicon/cuma/box.ico
A    freetz-trunk/graphics/favicon/cuma/freetz.ico
A    freetz-trunk/graphics/favicon/dsl123
A    freetz-trunk/graphics/favicon/dsl123/box.ico
A    freetz-trunk/graphics/favicon/dsl123/freetz.ico
A    freetz-trunk/graphics/favicon/atomphil
A    freetz-trunk/graphics/favicon/atomphil/freetz.ico
A    freetz-trunk/tools
A    freetz-trunk/tools/depmod.pl
A    freetz-trunk/tools/external
A    freetz-trunk/tools/scriptpatcher.sh
A    freetz-trunk/tools/device_table.txt
A    freetz-trunk/tools/developer
A    freetz-trunk/tools/developer/remove_js_function.awk
A    freetz-trunk/tools/developer/kconfig.pygments.patch
A    freetz-trunk/tools/developer/create-kconfig-warnings
A    freetz-trunk/tools/developer/remove_js_function.sh
A    freetz-trunk/tools/developer/mime_map_patterns.trac.patch
A    freetz-trunk/tools/developer/generate-ncurses-Config.in.sh
A    freetz-trunk/tools/developer/big-makefile
A    freetz-trunk/tools/rmtichksum
A    freetz-trunk/tools/remove-junk-bytes
A    freetz-trunk/tools/freetz_download
A    freetz-trunk/tools/freetz_functions
A    freetz-trunk/tools/check_uclibc
A    freetz-trunk/tools/unpack-kernel
A    freetz-trunk/tools/source
A    freetz-trunk/tools/source/sstrip-1.0.tar.bz2
A    freetz-trunk/tools/source/lzma2eva.tar.bz2
A    freetz-trunk/tools/source/find-squashfs.tar.bz2
A    freetz-trunk/tools/freetz_mklibs
A    freetz-trunk/tools/visualise_make
A    freetz-trunk/tools/lib_report
A    freetz-trunk/tools/check_prerequisites
A    freetz-trunk/tools/images
A    freetz-trunk/tools/images/starttelnet_sl.image
A    freetz-trunk/tools/images/starttelnet.image
A    freetz-trunk/tools/images/uninstall.image
A    freetz-trunk/tools/images/README
A    freetz-trunk/tools/fwdu
A    freetz-trunk/tools/config
A    freetz-trunk/tools/config/kconfig-language.txt
A    freetz-trunk/tools/config/.gitignore
A    freetz-trunk/tools/.gitignore
A    freetz-trunk/tools/recover-adam
A    freetz-trunk/tools/build_download_toolchains
A    freetz-trunk/tools/recover-ds
A    freetz-trunk/tools/push_firmware
A    freetz-trunk/tools/visualise_make.pl
A    freetz-trunk/tools/extract-images
A    freetz-trunk/tools/make
A    freetz-trunk/tools/make/fakeroot.mk
A    freetz-trunk/tools/make/find-squashfs.mk
A    freetz-trunk/tools/make/Makefile.in
A    freetz-trunk/tools/make/kconfig.mk
A    freetz-trunk/tools/make/squashfs3.mk
A    freetz-trunk/tools/make/xdelta.mk
A    freetz-trunk/tools/make/tichksum
A    freetz-trunk/tools/make/tichksum/src
A    freetz-trunk/tools/make/tichksum/src/ckmain.c
A    freetz-trunk/tools/make/tichksum/src/cksum.c
A    freetz-trunk/tools/make/tichksum/src/cksum.h
A    freetz-trunk/tools/make/tichksum/src/Makefile
A    freetz-trunk/tools/make/tichksum/src/README
A    freetz-trunk/tools/make/lzma2eva.mk
A    freetz-trunk/tools/make/mklibs.mk
A    freetz-trunk/tools/make/patches
A    freetz-trunk/tools/make/patches/007-gc_sections.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/011-remove_multiarch.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/320-defconfig_create_from_defaults.patch
A    freetz-trunk/tools/make/patches/002-disable_symbol_checks.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/170-read_EINTR_or_EOF.squashfs3.patch
A    freetz-trunk/tools/make/patches/220-osx.squashfs3.patch
A    freetz-trunk/tools/make/patches/014-missing_stdio.mklibs.patch
A    freetz-trunk/tools/make/patches/210-progress_bar-floating_point_exception.squashfs3.patch
A    freetz-trunk/tools/make/patches/010-remove_STT_GNU_IFUNC.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/360-max_item_count_for_choice_dialog.kconfig.patch
A    freetz-trunk/tools/make/patches/300-main_makefile.kconfig.patch
A    freetz-trunk/tools/make/patches/005-duplicate_syms.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/190-memcpy_memmove.squashfs3.patch
A    freetz-trunk/tools/make/patches/004-libpthread_link.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/370-save-hidden-prompts-to-file.kconfig.patch
A    freetz-trunk/tools/make/patches/009-uclibc_libgcc_pic.a_link.freetz.mklibs.patch
A    freetz-trunk/tools/make/patches/200-writer_buffer_leak.squashfs3.patch
A    freetz-trunk/tools/make/patches/100-lzma.squashfs3.patch
A    freetz-trunk/tools/make/patches/003-no_copy.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/100-lzma_zlib.lzma.patch
A    freetz-trunk/tools/make/patches/150-malloc_size.squashfs3.patch
A    freetz-trunk/tools/make/patches/100-fakeroot-doc.fakeroot.patch
A    freetz-trunk/tools/make/patches/130-inode_number.squashfs3.patch
A    freetz-trunk/tools/make/patches/100-fix_missing_crc32.lzma2eva.patch
A    freetz-trunk/tools/make/patches/009-uclibc_libpthread_symbols.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/100-lzma-and-unsquashfs.squashfs.patch
A    freetz-trunk/tools/make/patches/180-no_empty_files_on_read_error_abort_instead.squashfs3.patch
A    freetz-trunk/tools/make/patches/100-outbuffer.lzma.patch
A    freetz-trunk/tools/make/patches/120-memset-sBlk.squashfs3.patch
A    freetz-trunk/tools/make/patches/310-fix_make.kconfig.patch
A    freetz-trunk/tools/make/patches/016-use_python2.mklibs.patch
A    freetz-trunk/tools/make/patches/008-uclibc_libgcc_link.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/006-uclibc_init.openwrt.mklibs.patch
A    freetz-trunk/tools/make/patches/330-comment_style.kconfig.patch
A    freetz-trunk/tools/make/patches/011-comment_warning.mklibs.patch
A    freetz-trunk/tools/make/patches/160-queue_race_condition.squashfs3.patch
A    freetz-trunk/tools/make/patches/320-unchangable_style.kconfig.patch
A    freetz-trunk/tools/make/patches/115-osx.squashfs.patch
A    freetz-trunk/tools/make/patches/140-hide_output.squashfs3.patch
A    freetz-trunk/tools/make/patches/tar_preserve_directory_permissions.busybox.patch
A    freetz-trunk/tools/make/patches/340-fix_randconfig_choice.kconfig.patch
A    freetz-trunk/tools/make/patches/350-do_not_select_unmet_direct_dependencies.kconfig.patch
A    freetz-trunk/tools/make/patches/110-allow-symlinks.squashfs.patch
A    freetz-trunk/tools/make/sfk.mk
A    freetz-trunk/tools/make/sstrip.mk
A    freetz-trunk/tools/make/tar.mk
A    freetz-trunk/tools/make/tichksum.mk
A    freetz-trunk/tools/make/Config.busybox
A    freetz-trunk/tools/make/busybox-tools.mk
A    freetz-trunk/tools/make/python-host.mk
A    freetz-trunk/tools/make/squashfs.mk
A    freetz-trunk/tools/make/lzma.mk
A    freetz-trunk/tools/parse-config
A    freetz-trunk/tools/freetz_patch
A    freetz-trunk/tools/recover-eva
A    freetz-trunk/.version
A    freetz-trunk/TODO
A    freetz-trunk/.gitignore
A    freetz-trunk/fwmod_custom
A    freetz-trunk/COPYING
A    freetz-trunk/.exclude-dist
A    freetz-trunk/Makefile
A    freetz-trunk/make
A    freetz-trunk/make/ruby
A    freetz-trunk/make/ruby/external.files
A    freetz-trunk/make/ruby/external.in
A    freetz-trunk/make/ruby/patches
A    freetz-trunk/make/ruby/patches/200-fileutils.rb.patch
A    freetz-trunk/make/ruby/patches/400-uClibc_stdio.patch
A    freetz-trunk/make/ruby/patches/300-http_bufsize.patch
A    freetz-trunk/make/ruby/patches/500-fix_crypt.patch
A    freetz-trunk/make/ruby/patches/100-Makefile-in.patch
A    freetz-trunk/make/ruby/ruby.mk
A    freetz-trunk/make/ruby/Config.in
A    freetz-trunk/make/ser2net
A    freetz-trunk/make/ser2net/files
A    freetz-trunk/make/ser2net/files/.language
A    freetz-trunk/make/ser2net/files/root
A    freetz-trunk/make/ser2net/files/root/usr
A    freetz-trunk/make/ser2net/files/root/usr/lib
A    freetz-trunk/make/ser2net/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/ser2net/files/root/usr/lib/cgi-bin/ser2net.cgi
A    freetz-trunk/make/ser2net/files/root/etc
A    freetz-trunk/make/ser2net/files/root/etc/default.ser2net
A    freetz-trunk/make/ser2net/files/root/etc/default.ser2net/ser2net.cfg
A    freetz-trunk/make/ser2net/files/root/etc/default.ser2net/ser2net_conf.def
A    freetz-trunk/make/ser2net/files/root/etc/init.d
A    freetz-trunk/make/ser2net/files/root/etc/init.d/rc.ser2net
A    freetz-trunk/make/ser2net/ser2net.mk
A    freetz-trunk/make/ser2net/Config.in
A    freetz-trunk/make/pcsc-lite
A    freetz-trunk/make/pcsc-lite/external.files
A    freetz-trunk/make/pcsc-lite/external.in
A    freetz-trunk/make/pcsc-lite/pcsc-lite.mk
A    freetz-trunk/make/pcsc-lite/Config.in
A    freetz-trunk/make/aiccu
A    freetz-trunk/make/aiccu/files
A    freetz-trunk/make/aiccu/files/.language
A    freetz-trunk/make/aiccu/files/root
A    freetz-trunk/make/aiccu/files/root/usr
A    freetz-trunk/make/aiccu/files/root/usr/lib
A    freetz-trunk/make/aiccu/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/aiccu/files/root/usr/lib/cgi-bin/aiccu.cgi
A    freetz-trunk/make/aiccu/files/root/etc
A    freetz-trunk/make/aiccu/files/root/etc/init.d
A    freetz-trunk/make/aiccu/files/root/etc/init.d/rc.aiccu
A    freetz-trunk/make/aiccu/files/root/etc/default.aiccu
A    freetz-trunk/make/aiccu/files/root/etc/default.aiccu/aiccu.cfg
A    freetz-trunk/make/aiccu/files/root/etc/default.aiccu/aiccu_sh.conf
A    freetz-trunk/make/aiccu/files/root/etc/default.aiccu/aiccu_conf
A    freetz-trunk/make/aiccu/files/root/etc/default.aiccu/aiccu_sh.def
A    freetz-trunk/make/aiccu/external.files
A    freetz-trunk/make/aiccu/external.services
A    freetz-trunk/make/aiccu/external.in
A    freetz-trunk/make/aiccu/patches
A    freetz-trunk/make/aiccu/patches/120-disable-strip.patch
A    freetz-trunk/make/aiccu/patches/100-disable-gnutls.patch
A    freetz-trunk/make/aiccu/patches/005-no_libresolv.patch
A    freetz-trunk/make/aiccu/patches/200-add_dn_skipname.patch
A    freetz-trunk/make/aiccu/patches/110-resolver.patch
A    freetz-trunk/make/aiccu/Config.in
A    freetz-trunk/make/aiccu/aiccu.mk
A    freetz-trunk/make/nfs-utils
A    freetz-trunk/make/nfs-utils/patches
A    freetz-trunk/make/nfs-utils/patches/005-no_libnsl.patch
A    freetz-trunk/make/nfs-utils/patches/200-dont_messup_up_config_cache_with_host_linker_characteristics.patch
A    freetz-trunk/make/nfs-utils/patches/300-fix_kernel_bug.patch
A    freetz-trunk/make/nfs-utils/patches/001-nfs_utils_uclibc.patch
A    freetz-trunk/make/nfs-utils/patches/500-uclibc_libio.h.patch
A    freetz-trunk/make/nfs-utils/patches/100_no_libintl.patch
A    freetz-trunk/make/nfs-utils/patches/400-dont_mix_flags.patch
A    freetz-trunk/make/nfs-utils/Config.in
A    freetz-trunk/make/nfs-utils/nfs-utils.mk
A    freetz-trunk/make/ndas
A    freetz-trunk/make/ndas/patches
A    freetz-trunk/make/ndas/patches/class_device_create.patch
A    freetz-trunk/make/ndas/Config.in
A    freetz-trunk/make/ndas/ndas.mk
A    freetz-trunk/make/synce-dccm
A    freetz-trunk/make/synce-dccm/files
A    freetz-trunk/make/synce-dccm/files/.language
A    freetz-trunk/make/synce-dccm/files/root
A    freetz-trunk/make/synce-dccm/files/root/usr
A    freetz-trunk/make/synce-dccm/files/root/usr/lib
A    freetz-trunk/make/synce-dccm/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/synce-dccm/files/root/usr/lib/cgi-bin/synce-dccm.cgi
A    freetz-trunk/make/synce-dccm/files/root/etc
A    freetz-trunk/make/synce-dccm/files/root/etc/init.d
A    freetz-trunk/make/synce-dccm/files/root/etc/init.d/rc.synce-dccm
A    freetz-trunk/make/synce-dccm/files/root/etc/default.synce-dccm
A    freetz-trunk/make/synce-dccm/files/root/etc/default.synce-dccm/synce-dccm.cfg
A    freetz-trunk/make/synce-dccm/patches
A    freetz-trunk/make/synce-dccm/patches/100-libtool_call_missing_tag.patch
A    freetz-trunk/make/synce-dccm/Config.in
A    freetz-trunk/make/synce-dccm/synce-dccm.mk
A    freetz-trunk/make/authorized-keys
A    freetz-trunk/make/authorized-keys/files
A    freetz-trunk/make/authorized-keys/files/.language
A    freetz-trunk/make/authorized-keys/files/root
A    freetz-trunk/make/authorized-keys/files/root/usr
A    freetz-trunk/make/authorized-keys/files/root/usr/bin
A    freetz-trunk/make/authorized-keys/files/root/usr/bin/authorized_keys_gentmp
A    freetz-trunk/make/authorized-keys/files/root/usr/bin/authorized_keys_getuser
A    freetz-trunk/make/authorized-keys/files/root/usr/bin/authorized_keys_save
A    freetz-trunk/make/authorized-keys/files/root/etc
A    freetz-trunk/make/authorized-keys/files/root/etc/init.d
A    freetz-trunk/make/authorized-keys/files/root/etc/init.d/rc.authorized-keys
A    freetz-trunk/make/authorized-keys/files/root/etc/default.authorized-keys
A    freetz-trunk/make/authorized-keys/files/root/etc/default.authorized-keys/id_dsa.def
A    freetz-trunk/make/authorized-keys/files/root/etc/default.authorized-keys/authorized_keys.def
A    freetz-trunk/make/authorized-keys/files/root/etc/default.authorized-keys/known_hosts.def
A    freetz-trunk/make/authorized-keys/files/root/etc/default.authorized-keys/id_rsa.def
A    freetz-trunk/make/authorized-keys/Config.in
A    freetz-trunk/make/authorized-keys/authorized-keys.mk
A    freetz-trunk/make/avahi
A    freetz-trunk/make/avahi/external.in.libs
A    freetz-trunk/make/avahi/Config.in.libs
A    freetz-trunk/make/avahi/Makefile.in
A    freetz-trunk/make/avahi/files
A    freetz-trunk/make/avahi/files/root
A    freetz-trunk/make/avahi/files/root/etc
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/hosts
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/remote_announce.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/samba.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/nfs.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/itunes.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/sftp-ssh.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/ssh.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/services/http.service
A    freetz-trunk/make/avahi/files/root/etc/config-template.avahi/avahi-daemon.conf
A    freetz-trunk/make/avahi/files/root/etc/init.d
A    freetz-trunk/make/avahi/files/root/etc/init.d/rc.avahi
A    freetz-trunk/make/avahi/files/root/etc/avahi
A    freetz-trunk/make/avahi/files/root/etc/config-template.dbus
A    freetz-trunk/make/avahi/files/root/etc/config-template.dbus/system.d
A    freetz-trunk/make/avahi/files/root/etc/config-template.dbus/system.d/avahi-dbus.conf
A    freetz-trunk/make/avahi/files/root/etc/default.avahi
A    freetz-trunk/make/avahi/files/root/etc/default.avahi/avahi.cfg
A    freetz-trunk/make/avahi/external.files
A    freetz-trunk/make/avahi/external.services
A    freetz-trunk/make/avahi/patches
A    freetz-trunk/make/avahi/patches/100-pkgconfig.patch
A    freetz-trunk/make/avahi/patches/110-nls_cleanups.patch
A    freetz-trunk/make/avahi/avahi.mk
A    freetz-trunk/make/transmission
A    freetz-trunk/make/transmission/transmission.mk
A    freetz-trunk/make/transmission/external.files
A    freetz-trunk/make/transmission/external.services
A    freetz-trunk/make/transmission/external.in
A    freetz-trunk/make/transmission/patches
A    freetz-trunk/make/transmission/patches/040-IPv6_defines.patch
A    freetz-trunk/make/transmission/patches/030-no_in6addr_any_in_libc_without_IPv6_fix.patch
A    freetz-trunk/make/transmission/patches/010-low_resource_systems__smaller_buffers.patch
A    freetz-trunk/make/transmission/patches/120-finish_dir.patch
A    freetz-trunk/make/transmission/patches/020-dont_scrape_paused_torrents_by_default.patch
A    freetz-trunk/make/transmission/Config.in
A    freetz-trunk/make/matrixtunnel
A    freetz-trunk/make/matrixtunnel/matrixtunnel.mk
A    freetz-trunk/make/matrixtunnel/Config.in
A    freetz-trunk/make/dvbsnoop
A    freetz-trunk/make/dvbsnoop/dvbsnoop.mk
A    freetz-trunk/make/dvbsnoop/Config.in
A    freetz-trunk/make/target-tester
A    freetz-trunk/make/target-tester/target-tester.mk
A    freetz-trunk/make/target-tester/src
A    freetz-trunk/make/target-tester/src/bash_cv_unusable_rtsigs.c
A    freetz-trunk/make/target-tester/src/bash_cv_under_sys_siglist.c
A    freetz-trunk/make/target-tester/src/realpath_test.c
A    freetz-trunk/make/target-tester/src/bash_cv_dup2_broken.c
A    freetz-trunk/make/target-tester/src/bash_cv_printf_a_format.c
A    freetz-trunk/make/target-tester/src/bash_cv_sys_siglist.c
A    freetz-trunk/make/target-tester/src/ac_cv_libnet_endianess.c
A    freetz-trunk/make/target-tester/src/bash_cv_opendir_not_robust.c
A    freetz-trunk/make/target-tester/src/ac_cv_func_mmap_fixed_mapped.c
A    freetz-trunk/make/target-tester/src/bash_cv_func_sigsetjmp.c
A    freetz-trunk/make/target-tester/src/gt_cv_int_divbyzero_sigfpe.c
A    freetz-trunk/make/target-tester/src/libnet_cv_have_packet_socket.c
A    freetz-trunk/make/target-tester/src/bash_cv_pgrp_pipe.c
A    freetz-trunk/make/target-tester/src/ac_cv_func_fnmatch_works.c
A    freetz-trunk/make/target-tester/src/bash_cv_must_reinstall_sighandlers.c
A    freetz-trunk/make/target-tester/src/tst_nl_langinfo.expected_output
A    freetz-trunk/make/target-tester/src/tst_nl_langinfo.c
A    freetz-trunk/make/target-tester/src/bash_cv_getenv_redef.c
A    freetz-trunk/make/target-tester/src/ac_cv_func_vsnprintf_c99.c
A    freetz-trunk/make/target-tester/src/zlib_four_byte_unsigned_int.c
A    freetz-trunk/make/target-tester/src/ac_cv_lbl_unaligned_fail.c
A    freetz-trunk/make/target-tester/src/ac_func-test-generator.sh
A    freetz-trunk/make/target-tester/src/excepttest.c
A    freetz-trunk/make/target-tester/src/bash_cv_getcwd_malloc.c
A    freetz-trunk/make/target-tester/src/bash_cv_ulimit_maxfds.c
A    freetz-trunk/make/target-tester/src/ettercap-nsget32.c
A    freetz-trunk/make/target-tester/src/target-tester.c
A    freetz-trunk/make/target-tester/src/ac_cv_func_printf_unix98.c
A    freetz-trunk/make/target-tester/src/Makefile
A    freetz-trunk/make/target-tester/Config.in
A    freetz-trunk/make/pciutils
A    freetz-trunk/make/pciutils/pciutils.mk
A    freetz-trunk/make/pciutils/patches
A    freetz-trunk/make/pciutils/patches/005-no_libresolv.patch
A    freetz-trunk/make/pciutils/Config.in
A    freetz-trunk/make/trickle
A    freetz-trunk/make/trickle/external.files
A    freetz-trunk/make/trickle/trickle.mk
A    freetz-trunk/make/trickle/external.in
A    freetz-trunk/make/trickle/patches
A    freetz-trunk/make/trickle/patches/120-in_addr_t.patch
A    freetz-trunk/make/trickle/patches/125-no_libnsl.patch
A    freetz-trunk/make/trickle/patches/010-libevent_transitive_pthread.patch
A    freetz-trunk/make/trickle/patches/130-ipv6.patch
A    freetz-trunk/make/trickle/patches/101-no-strict-aliasing.patch
A    freetz-trunk/make/trickle/patches/100-libc_access_via_dlopen.patch
A    freetz-trunk/make/trickle/patches/110-sysconf_and_libdir.patch
A    freetz-trunk/make/trickle/patches/140-trickle-overload_soname.patch
A    freetz-trunk/make/trickle/patches/171_trickle_c__P_option.patch
A    freetz-trunk/make/trickle/Config.in
A    freetz-trunk/make/usbroot
A    freetz-trunk/make/usbroot/files
A    freetz-trunk/make/usbroot/files/.language
A    freetz-trunk/make/usbroot/files/root
A    freetz-trunk/make/usbroot/files/root/oldroot
A    freetz-trunk/make/usbroot/files/root/oldroot/.gitignore
A    freetz-trunk/make/usbroot/files/root/data
A    freetz-trunk/make/usbroot/files/root/data/.gitignore
A    freetz-trunk/make/usbroot/files/root/usr
A    freetz-trunk/make/usbroot/files/root/usr/lib
A    freetz-trunk/make/usbroot/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/usbroot/files/root/usr/lib/cgi-bin/usbroot.cgi
A    freetz-trunk/make/usbroot/files/root/etc
A    freetz-trunk/make/usbroot/files/root/etc/default.usbroot
A    freetz-trunk/make/usbroot/files/root/etc/default.usbroot/usbroot.save
A    freetz-trunk/make/usbroot/files/root/etc/default.usbroot/usbroot.cfg
A    freetz-trunk/make/usbroot/files/root/etc/usbroot_device.table
A    freetz-trunk/make/usbroot/files/root/etc/init.d
A    freetz-trunk/make/usbroot/files/root/etc/init.d/rc.usbroot
A    freetz-trunk/make/usbroot/usbroot.mk
A    freetz-trunk/make/usbroot/Config.in
A    freetz-trunk/make/empty
A    freetz-trunk/make/empty/empty.mk
A    freetz-trunk/make/empty/Config.in
A    freetz-trunk/make/imagemagick
A    freetz-trunk/make/imagemagick/external.files
A    freetz-trunk/make/imagemagick/imagemagick.mk
A    freetz-trunk/make/imagemagick/external.in
A    freetz-trunk/make/imagemagick/patches
A    freetz-trunk/make/imagemagick/patches/010-extra_flags.patch
A    freetz-trunk/make/imagemagick/Config.in
A    freetz-trunk/make/wput
A    freetz-trunk/make/wput/external.files
A    freetz-trunk/make/wput/wput.mk
A    freetz-trunk/make/wput/external.in
A    freetz-trunk/make/wput/patches
A    freetz-trunk/make/wput/patches/100-socketlib.c.patch
A    freetz-trunk/make/wput/patches/102-wput.c.patch
A    freetz-trunk/make/wput/Config.in
A    freetz-trunk/make/ghostscript-fonts
A    freetz-trunk/make/ghostscript-fonts/external.files
A    freetz-trunk/make/ghostscript-fonts/ghostscript-fonts.mk
A    freetz-trunk/make/ghostscript-fonts/external.in
A    freetz-trunk/make/ghostscript-fonts/Config.in
A    freetz-trunk/make/truecrypt
A    freetz-trunk/make/truecrypt/external.files
A    freetz-trunk/make/truecrypt/external.in
A    freetz-trunk/make/truecrypt/patches
A    freetz-trunk/make/truecrypt/patches/130-toupper_tolower_nolocale.patch
A    freetz-trunk/make/truecrypt/patches/100-Makefile.patch
A    freetz-trunk/make/truecrypt/patches/140-missing_locale_include.patch
A    freetz-trunk/make/truecrypt/patches/120-cxxabi.patch
A    freetz-trunk/make/truecrypt/patches/100-static_linking.patch
A    freetz-trunk/make/truecrypt/patches/110-strip.patch
A    freetz-trunk/make/truecrypt/patches/115-flags.patch
A    freetz-trunk/make/truecrypt/truecrypt.mk
A    freetz-trunk/make/truecrypt/Config.in
A    freetz-trunk/make/mediatomb
A    freetz-trunk/make/mediatomb/external.files
A    freetz-trunk/make/mediatomb/external.in
A    freetz-trunk/make/mediatomb/mediatomb.mk
A    freetz-trunk/make/mediatomb/patches
A    freetz-trunk/make/mediatomb/patches/200-static_linking.patch
A    freetz-trunk/make/mediatomb/patches/050-gcc47x-proper-two-phase-lookup.patch
A    freetz-trunk/make/mediatomb/patches/020-ffmpeg-0.11.x.patch
A    freetz-trunk/make/mediatomb/patches/300-polarssl_name_collision.patch
A    freetz-trunk/make/mediatomb/patches/010-ffmpeg-0.8.x.patch
A    freetz-trunk/make/mediatomb/patches/100-SYS_INOTIFY_H_OK.patch
A    freetz-trunk/make/mediatomb/Config.in
A    freetz-trunk/make/mtr
A    freetz-trunk/make/mtr/external.files
A    freetz-trunk/make/mtr/external.in
A    freetz-trunk/make/mtr/patches
A    freetz-trunk/make/mtr/patches/502-fix-res_ninit.patch
A    freetz-trunk/make/mtr/patches/501-dns.patch
A    freetz-trunk/make/mtr/patches/005-no_libresolv.patch
A    freetz-trunk/make/mtr/mtr.mk
A    freetz-trunk/make/mtr/Config.in
A    freetz-trunk/make/cpmaccfg
A    freetz-trunk/make/cpmaccfg/cpmaccfg.mk
A    freetz-trunk/make/cpmaccfg/Config.in
A    freetz-trunk/make/slang
A    freetz-trunk/make/slang/external.in.libs
A    freetz-trunk/make/slang/Config.in.libs
A    freetz-trunk/make/slang/external.files
A    freetz-trunk/make/slang/patches
A    freetz-trunk/make/slang/patches/220-modules_omit_files.patch
A    freetz-trunk/make/slang/patches/230-uClibc-0.9.28-missing-WCONTINUED.patch
A    freetz-trunk/make/slang/patches/110-no_slsh.patch
A    freetz-trunk/make/slang/patches/030_hostent_haddr.patch
A    freetz-trunk/make/slang/patches/120-no_docs_no_help.patch
A    freetz-trunk/make/slang/patches/200-module_install_dir.patch
A    freetz-trunk/make/slang/patches/130-no_rpath.patch
A    freetz-trunk/make/slang/patches/210-install_module.patch
A    freetz-trunk/make/slang/slang.mk
A    freetz-trunk/make/hp-utils
A    freetz-trunk/make/hp-utils/files
A    freetz-trunk/make/hp-utils/files/.language
A    freetz-trunk/make/hp-utils/files/root
A    freetz-trunk/make/hp-utils/files/root/usr
A    freetz-trunk/make/hp-utils/files/root/usr/share
A    freetz-trunk/make/hp-utils/files/root/usr/share/images
A    freetz-trunk/make/hp-utils/files/root/usr/share/images/clean.png
A    freetz-trunk/make/hp-utils/files/root/usr/share/images/align.png
A    freetz-trunk/make/hp-utils/files/root/usr/lib
A    freetz-trunk/make/hp-utils/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/hp-utils/files/root/usr/lib/cgi-bin/hp-utils.cgi
A    freetz-trunk/make/hp-utils/files/root/usr/bin
A    freetz-trunk/make/hp-utils/files/root/usr/bin/webcfg-hp-utils
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils/style
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils/images
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin/clean.cgi
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin/index.cgi
A    freetz-trunk/make/hp-utils/files/root/usr/mww-hp-utils/cgi-bin/maint.cgi
A    freetz-trunk/make/hp-utils/files/root/etc
A    freetz-trunk/make/hp-utils/files/root/etc/init.d
A    freetz-trunk/make/hp-utils/files/root/etc/init.d/rc.hp-utils
A    freetz-trunk/make/hp-utils/files/root/etc/default.hp-utils
A    freetz-trunk/make/hp-utils/files/root/etc/default.hp-utils/hp-utils.cfg
A    freetz-trunk/make/hp-utils/files/root/etc/default.hp-utils/hp-utils.inetd
A    freetz-trunk/make/hp-utils/files/root/etc/default.hp-utils/httpd-hp-utils_conf
A    freetz-trunk/make/hp-utils/patches
A    freetz-trunk/make/hp-utils/patches/100-pthread.patch
A    freetz-trunk/make/hp-utils/Config.in
A    freetz-trunk/make/hp-utils/hp-utils.mk
A    freetz-trunk/make/vsftpd
A    freetz-trunk/make/vsftpd/files
A    freetz-trunk/make/vsftpd/files/.language
A    freetz-trunk/make/vsftpd/files/root
A    freetz-trunk/make/vsftpd/files/root/usr
A    freetz-trunk/make/vsftpd/files/root/usr/lib
A    freetz-trunk/make/vsftpd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/vsftpd/files/root/usr/lib/cgi-bin/vsftpd
A    freetz-trunk/make/vsftpd/files/root/usr/lib/cgi-bin/vsftpd/vsftpd_log.cgi
A    freetz-trunk/make/vsftpd/files/root/usr/lib/cgi-bin/vsftpd.cgi
A    freetz-trunk/make/vsftpd/files/root/etc
A    freetz-trunk/make/vsftpd/files/root/etc/init.d
A    freetz-trunk/make/vsftpd/files/root/etc/init.d/rc.vsftpd
A    freetz-trunk/make/vsftpd/files/root/etc/default.vsftpd
A    freetz-trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd.cfg
A    freetz-trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd.inetd
A    freetz-trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd_conf
A    freetz-trunk/make/vsftpd/files/root/etc/default.vsftpd/vsftpd_crt.def
A    freetz-trunk/make/vsftpd/files/root/etc/onlinechanged
A    freetz-trunk/make/vsftpd/files/root/etc/onlinechanged/vsftpd
A    freetz-trunk/make/vsftpd/files/README
A    freetz-trunk/make/vsftpd/external.files
A    freetz-trunk/make/vsftpd/external.services
A    freetz-trunk/make/vsftpd/external.in
A    freetz-trunk/make/vsftpd/patches
A    freetz-trunk/make/vsftpd/patches/002-find_libs.patch
A    freetz-trunk/make/vsftpd/patches/070-config.patch
A    freetz-trunk/make/vsftpd/patches/006-enable_ssl.patch
A    freetz-trunk/make/vsftpd/patches/090-anonym_root.patch
A    freetz-trunk/make/vsftpd/patches/001-destdir.patch
A    freetz-trunk/make/vsftpd/patches/003-tunables.patch
A    freetz-trunk/make/vsftpd/patches/060-disable_largfiles.patch
A    freetz-trunk/make/vsftpd/Config.in
A    freetz-trunk/make/vsftpd/vsftpd.mk
A    freetz-trunk/make/iodine
A    freetz-trunk/make/iodine/files
A    freetz-trunk/make/iodine/files/.language
A    freetz-trunk/make/iodine/files/root
A    freetz-trunk/make/iodine/files/root/usr
A    freetz-trunk/make/iodine/files/root/usr/lib
A    freetz-trunk/make/iodine/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/iodine/files/root/usr/lib/cgi-bin/iodine.cgi
A    freetz-trunk/make/iodine/files/root/etc
A    freetz-trunk/make/iodine/files/root/etc/init.d
A    freetz-trunk/make/iodine/files/root/etc/init.d/rc.iodine
A    freetz-trunk/make/iodine/files/root/etc/default.iodine
A    freetz-trunk/make/iodine/files/root/etc/default.iodine/iodine.cfg
A    freetz-trunk/make/iodine/external.files
A    freetz-trunk/make/iodine/external.in
A    freetz-trunk/make/iodine/patches
A    freetz-trunk/make/iodine/patches/010-iodine-4-users.patch
A    freetz-trunk/make/iodine/Config.in
A    freetz-trunk/make/iodine/iodine.mk
A    freetz-trunk/make/tesseract-deu
A    freetz-trunk/make/tesseract-deu/tesseract-deu.mk
A    freetz-trunk/make/tcp_wrappers
A    freetz-trunk/make/tcp_wrappers/tcp_wrappers.mk
A    freetz-trunk/make/tcp_wrappers/external.files
A    freetz-trunk/make/tcp_wrappers/external.in
A    freetz-trunk/make/tcp_wrappers/patches
A    freetz-trunk/make/tcp_wrappers/patches/001-debian_patchset.patch
A    freetz-trunk/make/tcp_wrappers/Config.in
A    freetz-trunk/make/sslh
A    freetz-trunk/make/sslh/sslh.mk
A    freetz-trunk/make/sslh/files
A    freetz-trunk/make/sslh/files/.language
A    freetz-trunk/make/sslh/files/root
A    freetz-trunk/make/sslh/files/root/usr
A    freetz-trunk/make/sslh/files/root/usr/lib
A    freetz-trunk/make/sslh/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/sslh/files/root/usr/lib/cgi-bin/sslh.cgi
A    freetz-trunk/make/sslh/files/root/etc
A    freetz-trunk/make/sslh/files/root/etc/init.d
A    freetz-trunk/make/sslh/files/root/etc/init.d/rc.sslh
A    freetz-trunk/make/sslh/files/root/etc/default.sslh
A    freetz-trunk/make/sslh/files/root/etc/default.sslh/default-config.sh
A    freetz-trunk/make/sslh/files/root/etc/default.sslh/protocols.def
A    freetz-trunk/make/sslh/files/root/etc/default.sslh/sslh.cfg
A    freetz-trunk/make/sslh/files/root/etc/default.sslh/sslh.inetd
A    freetz-trunk/make/sslh/files/root/etc/default.sslh/sslh_conf
A    freetz-trunk/make/sslh/external.files
A    freetz-trunk/make/sslh/external.services
A    freetz-trunk/make/sslh/external.in
A    freetz-trunk/make/sslh/patches
A    freetz-trunk/make/sslh/patches/no_open_pipes.patch
A    freetz-trunk/make/sslh/Config.in
A    freetz-trunk/make/socat
A    freetz-trunk/make/socat/socat.mk
A    freetz-trunk/make/socat/external.files
A    freetz-trunk/make/socat/external.in
A    freetz-trunk/make/socat/Config.in
A    freetz-trunk/make/e2fsprogs
A    freetz-trunk/make/e2fsprogs/e2fsprogs.mk
A    freetz-trunk/make/e2fsprogs/Config.in.libs
A    freetz-trunk/make/e2fsprogs/Makefile.in
A    freetz-trunk/make/e2fsprogs/files
A    freetz-trunk/make/e2fsprogs/files/root
A    freetz-trunk/make/e2fsprogs/files/root/usr
A    freetz-trunk/make/e2fsprogs/files/root/usr/sbin
A    freetz-trunk/make/e2fsprogs/files/root/usr/sbin/mkfs.ext2
A    freetz-trunk/make/e2fsprogs/files/root/usr/sbin/mkfs.ext3
A    freetz-trunk/make/e2fsprogs/files/root/usr/sbin/fsck.ext2
A    freetz-trunk/make/e2fsprogs/files/root/usr/sbin/fsck.ext3
A    freetz-trunk/make/e2fsprogs/files/root/usr/sbin/fsck.ext4dev
A    freetz-trunk/make/e2fsprogs/files/root/sbin
A    freetz-trunk/make/e2fsprogs/files/root/sbin/blkid
A    freetz-trunk/make/e2fsprogs/external.files
A    freetz-trunk/make/e2fsprogs/external.in
A    freetz-trunk/make/e2fsprogs/patches
A    freetz-trunk/make/e2fsprogs/patches/060-extra_flags.patch
A    freetz-trunk/make/e2fsprogs/patches/110-glibc21.patch
A    freetz-trunk/make/e2fsprogs/patches/100-blkid_cache-file.patch
A    freetz-trunk/make/e2fsprogs/patches/009-e2defrag-Makefile-fix.patch
A    freetz-trunk/make/e2fsprogs/patches/010-pic_instead_of_profile.patch
A    freetz-trunk/make/e2fsprogs/patches/103-undef_tls.patch
A    freetz-trunk/make/e2fsprogs/patches/210-no_quota.patch
A    freetz-trunk/make/e2fsprogs/patches/003-DEFS_fix.patch
A    freetz-trunk/make/e2fsprogs/patches/102-use-syscall-function.patch
A    freetz-trunk/make/e2fsprogs/patches/001-exit_0_on_corrected_errors.patch
A    freetz-trunk/make/e2fsprogs/patches/004-no_inline_funcs.patch
A    freetz-trunk/make/e2fsprogs/patches/120-no_unnecessary_iconv_tests.patch
A    freetz-trunk/make/e2fsprogs/patches/101-blkid-man3dir.patch
A    freetz-trunk/make/e2fsprogs/patches/905-blkid_mtdworkaround.patch
A    freetz-trunk/make/usbutils
A    freetz-trunk/make/usbutils/usbutils.mk
A    freetz-trunk/make/usbutils/Config.in
A    freetz-trunk/make/openconnect
A    freetz-trunk/make/openconnect/openconnect.mk
A    freetz-trunk/make/openconnect/patches
A    freetz-trunk/make/openconnect/patches/001-cross-compile.patch
A    freetz-trunk/make/openconnect/Config.in
A    freetz-trunk/make/js
A    freetz-trunk/make/js/external.in.libs
A    freetz-trunk/make/js/Config.in.libs
A    freetz-trunk/make/js/js.mk
A    freetz-trunk/make/js/external.files
A    freetz-trunk/make/js/patches
A    freetz-trunk/make/js/patches/820-jscpucfg.js.patch
A    freetz-trunk/make/js/patches/800-LIBS.js.patch
A    freetz-trunk/make/js/patches/005-no_libnsl.js.patch
A    freetz-trunk/make/js/patches/810-install_library_only.js.patch
A    freetz-trunk/make/js/patches/100-config.cache-proper-dl-values.js.patch
A    freetz-trunk/make/js/patches/840-jsautocfg.h.js.patch
A    freetz-trunk/make/sg3_utils
A    freetz-trunk/make/sg3_utils/sg3_utils.mk
A    freetz-trunk/make/sg3_utils/patches
A    freetz-trunk/make/sg3_utils/patches/100-unnecessary_include.patch
A    freetz-trunk/make/sg3_utils/Config.in
A    freetz-trunk/make/umurmur
A    freetz-trunk/make/umurmur/files
A    freetz-trunk/make/umurmur/files/.language
A    freetz-trunk/make/umurmur/files/root
A    freetz-trunk/make/umurmur/files/root/usr
A    freetz-trunk/make/umurmur/files/root/usr/lib
A    freetz-trunk/make/umurmur/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/umurmur/files/root/usr/lib/cgi-bin/umurmur.cgi
A    freetz-trunk/make/umurmur/files/root/etc
A    freetz-trunk/make/umurmur/files/root/etc/default.umurmur
A    freetz-trunk/make/umurmur/files/root/etc/default.umurmur/umurmur_crt.def
A    freetz-trunk/make/umurmur/files/root/etc/default.umurmur/umurmur_key.def
A    freetz-trunk/make/umurmur/files/root/etc/default.umurmur/umurmur.cfg
A    freetz-trunk/make/umurmur/files/root/etc/init.d
A    freetz-trunk/make/umurmur/files/root/etc/init.d/rc.umurmur
A    freetz-trunk/make/umurmur/umurmur.mk
A    freetz-trunk/make/umurmur/external.files
A    freetz-trunk/make/umurmur/external.services
A    freetz-trunk/make/umurmur/external.in
A    freetz-trunk/make/umurmur/patches
A    freetz-trunk/make/umurmur/patches/100-polarssl_1.2.x.patch
A    freetz-trunk/make/umurmur/patches/110-reduced_polarssl_support.patch
A    freetz-trunk/make/umurmur/Config.in
A    freetz-trunk/make/dns2tcp
A    freetz-trunk/make/dns2tcp/files
A    freetz-trunk/make/dns2tcp/files/.language
A    freetz-trunk/make/dns2tcp/files/root
A    freetz-trunk/make/dns2tcp/files/root/usr
A    freetz-trunk/make/dns2tcp/files/root/usr/lib
A    freetz-trunk/make/dns2tcp/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/dns2tcp/files/root/usr/lib/cgi-bin/dns2tcp.cgi
A    freetz-trunk/make/dns2tcp/files/root/etc
A    freetz-trunk/make/dns2tcp/files/root/etc/default.dns2tcp
A    freetz-trunk/make/dns2tcp/files/root/etc/default.dns2tcp/dns2tcp_conf
A    freetz-trunk/make/dns2tcp/files/root/etc/default.dns2tcp/dns2tcp.cfg
A    freetz-trunk/make/dns2tcp/files/root/etc/init.d
A    freetz-trunk/make/dns2tcp/files/root/etc/init.d/rc.dns2tcp
A    freetz-trunk/make/dns2tcp/files/README
A    freetz-trunk/make/dns2tcp/dns2tcp.mk
A    freetz-trunk/make/dns2tcp/external.files
A    freetz-trunk/make/dns2tcp/external.services
A    freetz-trunk/make/dns2tcp/external.in
A    freetz-trunk/make/dns2tcp/Config.in
A    freetz-trunk/make/netcat
A    freetz-trunk/make/netcat/files
A    freetz-trunk/make/netcat/files/root
A    freetz-trunk/make/netcat/files/root/usr
A    freetz-trunk/make/netcat/files/root/usr/bin
A    freetz-trunk/make/netcat/files/root/usr/bin/nc
A    freetz-trunk/make/netcat/files/README
A    freetz-trunk/make/netcat/external.files
A    freetz-trunk/make/netcat/netcat.mk
A    freetz-trunk/make/netcat/external.in
A    freetz-trunk/make/netcat/Config.in
A    freetz-trunk/make/openssh
A    freetz-trunk/make/openssh/files
A    freetz-trunk/make/openssh/files/.language
A    freetz-trunk/make/openssh/files/root
A    freetz-trunk/make/openssh/files/root/usr
A    freetz-trunk/make/openssh/files/root/usr/lib
A    freetz-trunk/make/openssh/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/openssh/files/root/usr/lib/cgi-bin/openssh.cgi
A    freetz-trunk/make/openssh/files/root/etc
A    freetz-trunk/make/openssh/files/root/etc/default.openssh
A    freetz-trunk/make/openssh/files/root/etc/default.openssh/rsa_key.def
A    freetz-trunk/make/openssh/files/root/etc/default.openssh/dsa_key.def
A    freetz-trunk/make/openssh/files/root/etc/default.openssh/openssh.cfg
A    freetz-trunk/make/openssh/files/root/etc/init.d
A    freetz-trunk/make/openssh/files/root/etc/init.d/rc.openssh
A    freetz-trunk/make/openssh/external.files
A    freetz-trunk/make/openssh/external.services
A    freetz-trunk/make/openssh/openssh.mk
A    freetz-trunk/make/openssh/external.in
A    freetz-trunk/make/openssh/patches
A    freetz-trunk/make/openssh/patches/110-no_ripemd_fix.patch
A    freetz-trunk/make/openssh/patches/130-implicit_memset_decl_fix.patch
A    freetz-trunk/make/openssh/patches/150-extra_ldflags.patch
A    freetz-trunk/make/openssh/patches/100-no_cast_fix.patch
A    freetz-trunk/make/openssh/patches/005-no_libresolv.patch
A    freetz-trunk/make/openssh/Config.in
A    freetz-trunk/make/mini_fo
A    freetz-trunk/make/mini_fo/files
A    freetz-trunk/make/mini_fo/files/.language
A    freetz-trunk/make/mini_fo/files/root
A    freetz-trunk/make/mini_fo/files/root/oldroot
A    freetz-trunk/make/mini_fo/files/root/oldroot/.gitignore
A    freetz-trunk/make/mini_fo/files/root/sto
A    freetz-trunk/make/mini_fo/files/root/sto/.gitignore
A    freetz-trunk/make/mini_fo/files/root/usr
A    freetz-trunk/make/mini_fo/files/root/usr/lib
A    freetz-trunk/make/mini_fo/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/mini_fo/files/root/usr/lib/cgi-bin/mini_fo.cgi
A    freetz-trunk/make/mini_fo/files/root/etc
A    freetz-trunk/make/mini_fo/files/root/etc/default.mini_fo
A    freetz-trunk/make/mini_fo/files/root/etc/default.mini_fo/mini_fo.save
A    freetz-trunk/make/mini_fo/files/root/etc/init.d
A    freetz-trunk/make/mini_fo/files/root/etc/init.d/rc.mini_fo
A    freetz-trunk/make/mini_fo/mini_fo.mk
A    freetz-trunk/make/mini_fo/Config.in
A    freetz-trunk/make/apache
A    freetz-trunk/make/apache/external.files
A    freetz-trunk/make/apache/apache.mk
A    freetz-trunk/make/apache/external.in
A    freetz-trunk/make/apache/patches
A    freetz-trunk/make/apache/patches/120-shell-bash.patch
A    freetz-trunk/make/apache/patches/130-AR.patch
A    freetz-trunk/make/apache/patches/110-crosscompile-mipsel.patch
A    freetz-trunk/make/apache/patches/100-no_auth_dbm.patch
A    freetz-trunk/make/apache/Config.in
A    freetz-trunk/make/rush
A    freetz-trunk/make/rush/external.files
A    freetz-trunk/make/rush/external.services
A    freetz-trunk/make/rush/external.in
A    freetz-trunk/make/rush/patches
A    freetz-trunk/make/rush/patches/dfsg_reduction.patch
A    freetz-trunk/make/rush/patches/tcpmux_service.patch
A    freetz-trunk/make/rush/rush.mk
A    freetz-trunk/make/rush/Config.in
A    freetz-trunk/make/hol
A    freetz-trunk/make/hol/files
A    freetz-trunk/make/hol/files/.language
A    freetz-trunk/make/hol/files/root
A    freetz-trunk/make/hol/files/root/usr
A    freetz-trunk/make/hol/files/root/usr/lib
A    freetz-trunk/make/hol/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/hol/files/root/usr/lib/cgi-bin/hol.cgi
A    freetz-trunk/make/hol/files/root/usr/bin
A    freetz-trunk/make/hol/files/root/usr/bin/hol
A    freetz-trunk/make/hol/files/root/etc
A    freetz-trunk/make/hol/files/root/etc/default.hol
A    freetz-trunk/make/hol/files/root/etc/default.hol/hol.cfg
A    freetz-trunk/make/hol/files/root/etc/init.d
A    freetz-trunk/make/hol/files/root/etc/init.d/rc.hol
A    freetz-trunk/make/hol/hol.mk
A    freetz-trunk/make/hol/Config.in
A    freetz-trunk/make/cryptsetup
A    freetz-trunk/make/cryptsetup/external.files
A    freetz-trunk/make/cryptsetup/external.in
A    freetz-trunk/make/cryptsetup/patches
A    freetz-trunk/make/cryptsetup/patches/010-std_gnu99.patch
A    freetz-trunk/make/cryptsetup/patches/020-acl_cv_rpath__hardcode_values.patch
A    freetz-trunk/make/cryptsetup/patches/040-no_posix_memalign_in_uclibc_0.9.28.patch
A    freetz-trunk/make/cryptsetup/patches/030-avoid_largefile_support_warnings.patch
A    freetz-trunk/make/cryptsetup/cryptsetup.mk
A    freetz-trunk/make/cryptsetup/Config.in
A    freetz-trunk/make/classpath
A    freetz-trunk/make/classpath/external.files
A    freetz-trunk/make/classpath/external.in
A    freetz-trunk/make/classpath/patches
A    freetz-trunk/make/classpath/patches/100-incomplete_ipv6_test.patch
A    freetz-trunk/make/classpath/classpath.mk
A    freetz-trunk/make/classpath/Config.in
A    freetz-trunk/make/classpath/mini.classlist
A    freetz-trunk/make/dtach
A    freetz-trunk/make/dtach/external.files
A    freetz-trunk/make/dtach/external.in
A    freetz-trunk/make/dtach/dtach.mk
A    freetz-trunk/make/dtach/Config.in
A    freetz-trunk/make/git
A    freetz-trunk/make/git/files
A    freetz-trunk/make/git/files/.language
A    freetz-trunk/make/git/files/root
A    freetz-trunk/make/git/files/root/usr
A    freetz-trunk/make/git/files/root/usr/lib
A    freetz-trunk/make/git/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/git/files/root/usr/lib/cgi-bin/git.cgi
A    freetz-trunk/make/git/files/root/etc
A    freetz-trunk/make/git/files/root/etc/init.d
A    freetz-trunk/make/git/files/root/etc/init.d/rc.git
A    freetz-trunk/make/git/files/root/etc/default.git
A    freetz-trunk/make/git/files/root/etc/default.git/git.cfg
A    freetz-trunk/make/git/files/root/etc/default.git/git.inetd
A    freetz-trunk/make/git/external.files
A    freetz-trunk/make/git/external.services
A    freetz-trunk/make/git/external.in
A    freetz-trunk/make/git/patches
A    freetz-trunk/make/git/patches/060-extra_flags.patch
A    freetz-trunk/make/git/patches/015-no_gettext.patch
A    freetz-trunk/make/git/patches/010-missing_NO_INSTALL_HARDLINKS.patch
A    freetz-trunk/make/git/patches/030-no_rpath.patch
A    freetz-trunk/make/git/patches/040-template_dir.patch
A    freetz-trunk/make/git/patches/020-allow-without-perl.patch
A    freetz-trunk/make/git/patches/050-dont-overwrite-patched-configure.patch
A    freetz-trunk/make/git/git.mk
A    freetz-trunk/make/git/Config.in
A    freetz-trunk/make/openssl
A    freetz-trunk/make/openssl/external.in.libs
A    freetz-trunk/make/openssl/Config.in.libs
A    freetz-trunk/make/openssl/external.files
A    freetz-trunk/make/openssl/patches
A    freetz-trunk/make/openssl/patches/1.0.1e
A    freetz-trunk/make/openssl/patches/1.0.1e/120-makedepend_using_bash.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/190-configure_quiet.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/260-missing_libssl_workaround.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/200-dont-force-large-file.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/120-cisco-dtls-fix.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/140-makefile-dirs.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/160-disable_doc_tests.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/230-remove_timestamp_check.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/180-jobserver_unavailable_fix.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/270-no_rpath.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/280-no_private_libs.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/100-hmac-avm.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/150-no_engines.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/110-optimize-for-size.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/250-no_host_LD_LIBRARY_PATH.openssl.patch
A    freetz-trunk/make/openssl/patches/1.0.1e/130-perl-path.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y
A    freetz-trunk/make/openssl/patches/0.9.8y/190-configure_quiet.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/260-missing_libssl_workaround.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/200-dont-force-large-file.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/210-optional-ipv6.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/140-makefile-dirs.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/160-disable_doc_tests.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/230-remove_timestamp_check.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/180-jobserver_unavailable_fix.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/270-no_rpath.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/220-uclibc-susv3-legacy.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/100-hmac-avm.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/150-no_engines.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/110-optimize-for-size.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/250-no_host_LD_LIBRARY_PATH.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/120-makedepend.openssl.patch
A    freetz-trunk/make/openssl/patches/0.9.8y/130-perl-path.openssl.patch
A    freetz-trunk/make/openssl/openssl.mk
A    freetz-trunk/make/pingtunnel
A    freetz-trunk/make/pingtunnel/files
A    freetz-trunk/make/pingtunnel/files/.language
A    freetz-trunk/make/pingtunnel/files/root
A    freetz-trunk/make/pingtunnel/files/root/usr
A    freetz-trunk/make/pingtunnel/files/root/usr/lib
A    freetz-trunk/make/pingtunnel/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/pingtunnel/files/root/usr/lib/cgi-bin/pingtunnel.cgi
A    freetz-trunk/make/pingtunnel/files/root/etc
A    freetz-trunk/make/pingtunnel/files/root/etc/init.d
A    freetz-trunk/make/pingtunnel/files/root/etc/init.d/rc.pingtunnel
A    freetz-trunk/make/pingtunnel/files/root/etc/default.pingtunnel
A    freetz-trunk/make/pingtunnel/files/root/etc/default.pingtunnel/pingtunnel.cfg
A    freetz-trunk/make/pingtunnel/external.files
A    freetz-trunk/make/pingtunnel/external.services
A    freetz-trunk/make/pingtunnel/external.in
A    freetz-trunk/make/pingtunnel/patches
A    freetz-trunk/make/pingtunnel/patches/000-disable-selinux.patch
A    freetz-trunk/make/pingtunnel/pingtunnel.mk
A    freetz-trunk/make/pingtunnel/Config.in
A    freetz-trunk/make/module-init-tools
A    freetz-trunk/make/module-init-tools/patches
A    freetz-trunk/make/module-init-tools/patches/100-no_docs.patch
A    freetz-trunk/make/module-init-tools/Config.in
A    freetz-trunk/make/module-init-tools/module-init-tools.mk
A    freetz-trunk/make/sshfs-fuse
A    freetz-trunk/make/sshfs-fuse/files
A    freetz-trunk/make/sshfs-fuse/files/.language
A    freetz-trunk/make/sshfs-fuse/files/root
A    freetz-trunk/make/sshfs-fuse/files/root/usr
A    freetz-trunk/make/sshfs-fuse/files/root/usr/lib
A    freetz-trunk/make/sshfs-fuse/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/sshfs-fuse/files/root/usr/lib/cgi-bin/sshfs-fuse.cgi
A    freetz-trunk/make/sshfs-fuse/files/root/etc
A    freetz-trunk/make/sshfs-fuse/files/root/etc/init.d
A    freetz-trunk/make/sshfs-fuse/files/root/etc/init.d/rc.sshfs-fuse
A    freetz-trunk/make/sshfs-fuse/files/root/etc/default.sshfs-fuse
A    freetz-trunk/make/sshfs-fuse/files/root/etc/default.sshfs-fuse/sshfs-fuse.cfg
A    freetz-trunk/make/sshfs-fuse/external.files
A    freetz-trunk/make/sshfs-fuse/external.in
A    freetz-trunk/make/sshfs-fuse/Config.in
A    freetz-trunk/make/sshfs-fuse/sshfs-fuse.mk
A    freetz-trunk/make/pptpd
A    freetz-trunk/make/pptpd/files
A    freetz-trunk/make/pptpd/files/.language
A    freetz-trunk/make/pptpd/files/root
A    freetz-trunk/make/pptpd/files/root/usr
A    freetz-trunk/make/pptpd/files/root/usr/lib
A    freetz-trunk/make/pptpd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/pptpd/files/root/usr/lib/cgi-bin/pptpd.cgi
A    freetz-trunk/make/pptpd/files/root/etc
A    freetz-trunk/make/pptpd/files/root/etc/init.d
A    freetz-trunk/make/pptpd/files/root/etc/init.d/rc.pptpd
A    freetz-trunk/make/pptpd/files/root/etc/default.pptpd
A    freetz-trunk/make/pptpd/files/root/etc/default.pptpd/pptpd_options.def
A    freetz-trunk/make/pptpd/files/root/etc/default.pptpd/pptpd.cfg
A    freetz-trunk/make/pptpd/files/root/etc/default.pptpd/pptpd_conf.def
A    freetz-trunk/make/pptpd/external.files
A    freetz-trunk/make/pptpd/external.services
A    freetz-trunk/make/pptpd/external.in
A    freetz-trunk/make/pptpd/patches
A    freetz-trunk/make/pptpd/patches/101-gre_reorder.patch
A    freetz-trunk/make/pptpd/patches/102-fix_pppd_version.patch
A    freetz-trunk/make/pptpd/patches/100-no_libintlh.patch
A    freetz-trunk/make/pptpd/Config.in
A    freetz-trunk/make/pptpd/pptpd.mk
A    freetz-trunk/make/tiff
A    freetz-trunk/make/tiff/external.in.libs
A    freetz-trunk/make/tiff/Config.in.libs
A    freetz-trunk/make/tiff/external.files
A    freetz-trunk/make/tiff/patches
A    freetz-trunk/make/tiff/patches/010-no_tests_no_docs.patch
A    freetz-trunk/make/tiff/tiff.mk
A    freetz-trunk/make/haproxy
A    freetz-trunk/make/haproxy/haproxy.mk
A    freetz-trunk/make/haproxy/Config.in
A    freetz-trunk/make/nfsd-cgi
A    freetz-trunk/make/nfsd-cgi/nfsd-cgi.mk
A    freetz-trunk/make/nfsd-cgi/files
A    freetz-trunk/make/nfsd-cgi/files/.language
A    freetz-trunk/make/nfsd-cgi/files/root
A    freetz-trunk/make/nfsd-cgi/files/root/usr
A    freetz-trunk/make/nfsd-cgi/files/root/usr/lib
A    freetz-trunk/make/nfsd-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/nfsd-cgi/files/root/usr/lib/cgi-bin/nfsd.cgi
A    freetz-trunk/make/nfsd-cgi/files/root/etc
A    freetz-trunk/make/nfsd-cgi/files/root/etc/init.d
A    freetz-trunk/make/nfsd-cgi/files/root/etc/init.d/rc.nfsd
A    freetz-trunk/make/nfsd-cgi/files/root/etc/default.nfsd
A    freetz-trunk/make/nfsd-cgi/files/root/etc/default.nfsd/exports.def
A    freetz-trunk/make/nfsd-cgi/files/root/etc/default.nfsd/nfsd.cfg
A    freetz-trunk/make/nfsd-cgi/files/root/etc/default.nfsd/hosts_allow.def
A    freetz-trunk/make/nfsd-cgi/files/root/etc/default.nfsd/hosts_deny.def
A    freetz-trunk/make/nfsd-cgi/files/root/etc/hosts.allow
A    freetz-trunk/make/nfsd-cgi/files/root/etc/hosts.deny
A    freetz-trunk/make/nfsd-cgi/Config.in
A    freetz-trunk/make/nfsroot
A    freetz-trunk/make/nfsroot/nfsroot.mk
A    freetz-trunk/make/nfsroot/files
A    freetz-trunk/make/nfsroot/files/root
A    freetz-trunk/make/nfsroot/files/root/etc
A    freetz-trunk/make/nfsroot/files/root/etc/init.d
A    freetz-trunk/make/nfsroot/files/root/etc/init.d/rc.nfsroot
A    freetz-trunk/make/nfsroot/Config.in
A    freetz-trunk/make/mdev
A    freetz-trunk/make/mdev/mdev.mk
A    freetz-trunk/make/mdev/files
A    freetz-trunk/make/mdev/files/root
A    freetz-trunk/make/mdev/files/root/lib
A    freetz-trunk/make/mdev/files/root/lib/mdev
A    freetz-trunk/make/mdev/files/root/lib/mdev/interface
A    freetz-trunk/make/mdev/files/root/lib/mdev/interface/avmusbwlan
A    freetz-trunk/make/mdev/files/root/lib/mdev/interface/storage
A    freetz-trunk/make/mdev/files/root/lib/mdev/session
A    freetz-trunk/make/mdev/files/root/lib/mdev/session/syslog
A    freetz-trunk/make/mdev/files/root/lib/mdev/session/tam
A    freetz-trunk/make/mdev/files/root/lib/mdev/session/samba
A    freetz-trunk/make/mdev/files/root/lib/mdev/session/ftpd
A    freetz-trunk/make/mdev/files/root/lib/mdev/session/usbroot
A    freetz-trunk/make/mdev/files/root/lib/mdev/common
A    freetz-trunk/make/mdev/files/root/lib/mdev/common/log
A    freetz-trunk/make/mdev/files/root/lib/mdev/common/mdevmodule
A    freetz-trunk/make/mdev/files/root/lib/mdev/common/mdevprobe
A    freetz-trunk/make/mdev/files/root/lib/mdev/common/led
A    freetz-trunk/make/mdev/files/root/lib/mdev/common/ar7value
A    freetz-trunk/make/mdev/files/root/lib/mdev/common/mdevlog
A    freetz-trunk/make/mdev/files/root/lib/mdev/usb
A    freetz-trunk/make/mdev/files/root/lib/mdev/usb/avmusbwlan.add
A    freetz-trunk/make/mdev/files/root/lib/mdev/usb/usbdev
A    freetz-trunk/make/mdev/files/root/lib/mdev/usb/usbcontrol
A    freetz-trunk/make/mdev/files/root/lib/mdev/usb/avmusbwlan.remove
A    freetz-trunk/make/mdev/files/root/lib/mdev/usb/eventvars
A    freetz-trunk/make/mdev/files/root/lib/mdev/block
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/vfat.mount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/mount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/ext2.mount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/ext3.mount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/umount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/partition
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/disk
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/ntfs.mount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/swap.mount
A    freetz-trunk/make/mdev/files/root/lib/mdev/block/unrecognized
A    freetz-trunk/make/mdev/files/root/lib/mdev/misc
A    freetz-trunk/make/mdev/files/root/lib/mdev/misc/mtd
A    freetz-trunk/make/mdev/files/root/lib/mdev/misc/bitfile
A    freetz-trunk/make/mdev/files/root/bin
A    freetz-trunk/make/mdev/files/root/bin/mount.ntfs-3g
A    freetz-trunk/make/mdev/files/root/etc
A    freetz-trunk/make/mdev/files/root/etc/mdev.conf
A    freetz-trunk/make/mdev/files/root/etc/device.table
A    freetz-trunk/make/mdev/files/root/etc/modprobe.conf
A    freetz-trunk/make/mdev/doc
A    freetz-trunk/make/mdev/doc/serial-usb_add.chain
A    freetz-trunk/make/mdev/doc/storage_remove.chain
A    freetz-trunk/make/mdev/doc/run
A    freetz-trunk/make/mdev/doc/run/add-hub_serial_key.mdev
A    freetz-trunk/make/mdev/doc/run/remove-hub_serial_key.mdev
A    freetz-trunk/make/mdev/doc/serial-usb_remove.chain
A    freetz-trunk/make/mdev/doc/storage/01-sda_delete-remove.hotplug
A    freetz-trunk/make/mdev/doc/storage/03-modprobe_sd_mod-add.hotplug
A    freetz-trunk/make/mdev/doc/storage/01-memory_key-add.hotplug
A    freetz-trunk/make/mdev/doc/storage/02-modprobe_modalias-add.hotplug
A    freetz-trunk/make/mdev/doc/storage/03-rmmod_usb_storage-remove.hotplug
A    freetz-trunk/make/mdev/doc/storage/02-rmmod_sd_mod-remove.hotplug
A    freetz-trunk/make/mdev/doc/bluetooth
A    freetz-trunk/make/mdev/doc/bluetooth/add_02_rfcomm_module.mdev
A    freetz-trunk/make/mdev/doc/bluetooth/add_01_bluetooth-dongle.mdev
A    freetz-trunk/make/mdev/doc/serial-usb/add_02_pl2303.mdev
A    freetz-trunk/make/mdev/doc/serial-usb/add_02_pl2303_2nd-device.mdev
A    freetz-trunk/make/mdev/doc/serial-usb/remove_01_device.mdev
A    freetz-trunk/make/mdev/doc/serial-usb/add_01_connect.mdev
A    freetz-trunk/make/mdev/doc/serial-usb/add_01_connect_2nd-device.mdev
A    freetz-trunk/make/mdev/doc/serial-usb/remove_02_pl2303.mdev
A    freetz-trunk/make/mdev/doc/storage_add.chain
A    freetz-trunk/make/mdev/doc/bluetooth_add.chain
A    freetz-trunk/make/mdev/patches
A    freetz-trunk/make/mdev/patches/hardware
A    freetz-trunk/make/mdev/patches/hardware/7170_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/7270_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/W701V_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/W900V_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/3130_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/3131_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/2171_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/3170_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/7140_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/7141_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/7150_piglet.patch
A    freetz-trunk/make/mdev/patches/hardware/7240_piglet.patch
A    freetz-trunk/make/mdev/Config.in
A    freetz-trunk/make/html2text
A    freetz-trunk/make/html2text/html2text.mk
A    freetz-trunk/make/html2text/external.files
A    freetz-trunk/make/html2text/external.in
A    freetz-trunk/make/html2text/patches
A    freetz-trunk/make/html2text/patches/810-fix-deprecated-conversion-warnings.debian.patch
A    freetz-trunk/make/html2text/patches/030-auto_ptr-fpermissive.patch
A    freetz-trunk/make/html2text/patches/200-close-files-inside-main-loop.debian.patch
A    freetz-trunk/make/html2text/patches/010-cross_CXX.patch
A    freetz-trunk/make/html2text/patches/400-remove-builtin-http-support.debian.patch
A    freetz-trunk/make/html2text/patches/550-skip-numbers-in-html-tag-attributes.debian.patch
A    freetz-trunk/make/html2text/patches/040-uClibcxx_no_match_for_equal_operator_workaround.patch
A    freetz-trunk/make/html2text/patches/020-CXXFLAGS.patch
A    freetz-trunk/make/html2text/patches/401-remove-builtin-http-support.stdin_fix.patch
A    freetz-trunk/make/html2text/Config.in
A    freetz-trunk/make/microperl
A    freetz-trunk/make/microperl/microperl.mk
A    freetz-trunk/make/microperl/external.files
A    freetz-trunk/make/microperl/external.in
A    freetz-trunk/make/microperl/patches
A    freetz-trunk/make/microperl/patches/300-fix_moduledir.patch
A    freetz-trunk/make/microperl/patches/200-env_enable.patch
A    freetz-trunk/make/microperl/patches/100-static_uudmap.patch
A    freetz-trunk/make/microperl/Config.in
A    freetz-trunk/make/tesseract/external.in.libs
A    freetz-trunk/make/tesseract/Config.in.libs
A    freetz-trunk/make/tesseract/external.files
A    freetz-trunk/make/tesseract/tesseract.mk
A    freetz-trunk/make/tesseract/patches
A    freetz-trunk/make/tesseract/patches/010-uclibc_fmax.patch
A    freetz-trunk/make/tesseract/patches/030-pkgconfig_cleanup.patch
A    freetz-trunk/make/tinc
A    freetz-trunk/make/tinc/files
A    freetz-trunk/make/tinc/files/.language
A    freetz-trunk/make/tinc/files/root
A    freetz-trunk/make/tinc/files/root/usr
A    freetz-trunk/make/tinc/files/root/usr/lib
A    freetz-trunk/make/tinc/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/tinc/files/root/usr/lib/cgi-bin/tinc.cgi
A    freetz-trunk/make/tinc/files/root/etc
A    freetz-trunk/make/tinc/files/root/etc/default.tinc
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/default-config.sh
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/rsa_key_pub.def
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/tinc_down.def
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/tinc_conf
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/server1.def
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/server2.def
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/server3.def
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/rsa_key_priv.def
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/tinc.save
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/tinc.cfg
A    freetz-trunk/make/tinc/files/root/etc/default.tinc/tinc_up.def
A    freetz-trunk/make/tinc/files/root/etc/init.d
A    freetz-trunk/make/tinc/files/root/etc/init.d/rc.tinc
A    freetz-trunk/make/tinc/external.files
A    freetz-trunk/make/tinc/tinc.mk
A    freetz-trunk/make/tinc/external.services
A    freetz-trunk/make/tinc/external.in
A    freetz-trunk/make/tinc/Config.in
A    freetz-trunk/make/tmux
A    freetz-trunk/make/tmux/external.files
A    freetz-trunk/make/tmux/tmux.mk
A    freetz-trunk/make/tmux/external.in
A    freetz-trunk/make/tmux/patches
A    freetz-trunk/make/tmux/patches/100-use_var_tmp.patch
A    freetz-trunk/make/tmux/patches/120-b64_ntop-conflict.patch
A    freetz-trunk/make/tmux/patches/110-no_host_includes.patch
A    freetz-trunk/make/tmux/patches/005-no_libresolv.patch
A    freetz-trunk/make/tmux/Config.in
A    freetz-trunk/make/ppp-cgi
A    freetz-trunk/make/ppp-cgi/files
A    freetz-trunk/make/ppp-cgi/files/.language
A    freetz-trunk/make/ppp-cgi/files/root
A    freetz-trunk/make/ppp-cgi/files/root/usr
A    freetz-trunk/make/ppp-cgi/files/root/usr/lib
A    freetz-trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin/ppp
A    freetz-trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin/ppp/ppplog.cgi
A    freetz-trunk/make/ppp-cgi/files/root/usr/lib/cgi-bin/ppp.cgi
A    freetz-trunk/make/ppp-cgi/files/root/etc
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp_dialer
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp/peers_options.def
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp_observer
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp/peers_chat.def
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp.cfg
A    freetz-trunk/make/ppp-cgi/files/root/etc/default.ppp/ppp_logger
A    freetz-trunk/make/ppp-cgi/files/root/etc/init.d
A    freetz-trunk/make/ppp-cgi/files/root/etc/init.d/rc.ppp
A    freetz-trunk/make/ppp-cgi/external.files
A    freetz-trunk/make/ppp-cgi/external.services
A    freetz-trunk/make/ppp-cgi/ppp-cgi.mk
A    freetz-trunk/make/ppp-cgi/external.in
A    freetz-trunk/make/ppp-cgi/Config.in
A    freetz-trunk/make/radvd
A    freetz-trunk/make/radvd/files
A    freetz-trunk/make/radvd/files/.language
A    freetz-trunk/make/radvd/files/root
A    freetz-trunk/make/radvd/files/root/usr
A    freetz-trunk/make/radvd/files/root/usr/lib
A    freetz-trunk/make/radvd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/radvd/files/root/usr/lib/cgi-bin/radvd.cgi
A    freetz-trunk/make/radvd/files/root/etc
A    freetz-trunk/make/radvd/files/root/etc/default.radvd
A    freetz-trunk/make/radvd/files/root/etc/default.radvd/radvd_conf
A    freetz-trunk/make/radvd/files/root/etc/default.radvd/radvd.save
A    freetz-trunk/make/radvd/files/root/etc/default.radvd/radvd.cfg
A    freetz-trunk/make/radvd/files/root/etc/init.d
A    freetz-trunk/make/radvd/files/root/etc/init.d/rc.radvd
A    freetz-trunk/make/radvd/external.files
A    freetz-trunk/make/radvd/external.services
A    freetz-trunk/make/radvd/radvd.mk
A    freetz-trunk/make/radvd/external.in
A    freetz-trunk/make/radvd/Config.in
A    freetz-trunk/make/ctorrent
A    freetz-trunk/make/ctorrent/external.files
A    freetz-trunk/make/ctorrent/ctorrent.mk
A    freetz-trunk/make/ctorrent/external.in
A    freetz-trunk/make/ctorrent/patches
A    freetz-trunk/make/ctorrent/patches/100-CVE-2009-1759.patch
A    freetz-trunk/make/ctorrent/Config.in
A    freetz-trunk/make/xpdf
A    freetz-trunk/make/xpdf/patches
A    freetz-trunk/make/xpdf/patches/xpdf-3.02pl4.patch
A    freetz-trunk/make/xpdf/patches/xpdf-shared.patch
A    freetz-trunk/make/xpdf/patches/xpdf-3.02pl1.patch
A    freetz-trunk/make/xpdf/patches/xpdf-3.02pl2.patch
A    freetz-trunk/make/xpdf/patches/xpdf-3.02pl3.patch
A    freetz-trunk/make/xpdf/xpdf.mk
A    freetz-trunk/make/xpdf/Config.in
A    freetz-trunk/make/sqlite
A    freetz-trunk/make/sqlite/external.in.libs
A    freetz-trunk/make/sqlite/Config.in.libs
A    freetz-trunk/make/sqlite/external.files
A    freetz-trunk/make/sqlite/patches
A    freetz-trunk/make/sqlite/patches/010-pthread_fixes.patch
A    freetz-trunk/make/sqlite/sqlite.mk
A    freetz-trunk/make/modcgi
A    freetz-trunk/make/modcgi/patches
A    freetz-trunk/make/modcgi/patches/100-proccgi.patch
A    freetz-trunk/make/modcgi/modcgi.mk
A    freetz-trunk/make/modcgi/Config.in
A    freetz-trunk/make/tor
A    freetz-trunk/make/tor/files
A    freetz-trunk/make/tor/files/.language
A    freetz-trunk/make/tor/files/root
A    freetz-trunk/make/tor/files/root/usr
A    freetz-trunk/make/tor/files/root/usr/lib
A    freetz-trunk/make/tor/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/tor/files/root/usr/lib/cgi-bin/tor.cgi
A    freetz-trunk/make/tor/files/root/etc
A    freetz-trunk/make/tor/files/root/etc/init.d
A    freetz-trunk/make/tor/files/root/etc/init.d/rc.tor
A    freetz-trunk/make/tor/files/root/etc/default.tor
A    freetz-trunk/make/tor/files/root/etc/default.tor/tor.cfg
A    freetz-trunk/make/tor/files/root/etc/default.tor/secret_id_key.def
A    freetz-trunk/make/tor/files/root/etc/default.tor/tor_conf
A    freetz-trunk/make/tor/files/README
A    freetz-trunk/make/tor/external.files
A    freetz-trunk/make/tor/external.services
A    freetz-trunk/make/tor/external.in
A    freetz-trunk/make/tor/Config.in
A    freetz-trunk/make/tor/tor.mk
A    freetz-trunk/make/httptunnel
A    freetz-trunk/make/httptunnel/external.files
A    freetz-trunk/make/httptunnel/external.in
A    freetz-trunk/make/httptunnel/patches
A    freetz-trunk/make/httptunnel/patches/100-fix_stdin-stdout.patch
A    freetz-trunk/make/httptunnel/Config.in
A    freetz-trunk/make/httptunnel/httptunnel.mk
A    freetz-trunk/make/lftp
A    freetz-trunk/make/lftp/external.files
A    freetz-trunk/make/lftp/external.in
A    freetz-trunk/make/lftp/patches
A    freetz-trunk/make/lftp/patches/010-cxx11_workaround.patch
A    freetz-trunk/make/lftp/Config.in
A    freetz-trunk/make/lftp/lftp.mk
A    freetz-trunk/make/dvbtune
A    freetz-trunk/make/dvbtune/patches
A    freetz-trunk/make/dvbtune/patches/10-Makefile.patch
A    freetz-trunk/make/dvbtune/Config.in
A    freetz-trunk/make/dvbtune/dvbtune.mk
A    freetz-trunk/make/cifsmount
A    freetz-trunk/make/cifsmount/files
A    freetz-trunk/make/cifsmount/files/root
A    freetz-trunk/make/cifsmount/files/root/usr
A    freetz-trunk/make/cifsmount/files/root/usr/lib
A    freetz-trunk/make/cifsmount/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/cifsmount/files/root/usr/lib/cgi-bin/cifsmount.cgi
A    freetz-trunk/make/cifsmount/files/root/usr/sbin
A    freetz-trunk/make/cifsmount/files/root/usr/sbin/cifsmount
A    freetz-trunk/make/cifsmount/files/root/etc
A    freetz-trunk/make/cifsmount/files/root/etc/init.d
A    freetz-trunk/make/cifsmount/files/root/etc/init.d/rc.cifsmount
A    freetz-trunk/make/cifsmount/files/root/etc/default.cifsmount
A    freetz-trunk/make/cifsmount/files/root/etc/default.cifsmount/cifsmount.cfg
A    freetz-trunk/make/cifsmount/external.files
A    freetz-trunk/make/cifsmount/external.services
A    freetz-trunk/make/cifsmount/external.in
A    freetz-trunk/make/cifsmount/Config.in
A    freetz-trunk/make/cifsmount/cifsmount.mk
A    freetz-trunk/make/shellinabox
A    freetz-trunk/make/shellinabox/files
A    freetz-trunk/make/shellinabox/files/.language
A    freetz-trunk/make/shellinabox/files/root
A    freetz-trunk/make/shellinabox/files/root/usr
A    freetz-trunk/make/shellinabox/files/root/usr/lib
A    freetz-trunk/make/shellinabox/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/shellinabox/files/root/usr/lib/cgi-bin/shellinabox.cgi
A    freetz-trunk/make/shellinabox/files/root/etc
A    freetz-trunk/make/shellinabox/files/root/etc/init.d
A    freetz-trunk/make/shellinabox/files/root/etc/init.d/rc.shellinabox
A    freetz-trunk/make/shellinabox/files/root/etc/default.shellinabox
A    freetz-trunk/make/shellinabox/files/root/etc/default.shellinabox/generate_cert.sh
A    freetz-trunk/make/shellinabox/files/root/etc/default.shellinabox/shellinabox.cfg
A    freetz-trunk/make/shellinabox/external.files
A    freetz-trunk/make/shellinabox/external.services
A    freetz-trunk/make/shellinabox/external.in
A    freetz-trunk/make/shellinabox/patches
A    freetz-trunk/make/shellinabox/patches/120_missing_HAVE_UTMPX_H.patch
A    freetz-trunk/make/shellinabox/patches/110_fix_missing_getgrouplist.patch
A    freetz-trunk/make/shellinabox/patches/140-use_uclibc_daemon_func.patch
A    freetz-trunk/make/shellinabox/patches/130_fix_static.patch
A    freetz-trunk/make/shellinabox/Config.in
A    freetz-trunk/make/shellinabox/shellinabox.mk
A    freetz-trunk/make/udpxy
A    freetz-trunk/make/udpxy/udpxy.mk
A    freetz-trunk/make/udpxy/files
A    freetz-trunk/make/udpxy/files/root
A    freetz-trunk/make/udpxy/files/root/usr
A    freetz-trunk/make/udpxy/files/root/usr/bin
A    freetz-trunk/make/udpxy/files/root/usr/bin/udpxrec
A    freetz-trunk/make/udpxy/external.files
A    freetz-trunk/make/udpxy/external.in
A    freetz-trunk/make/udpxy/Config.in
A    freetz-trunk/make/ncftp
A    freetz-trunk/make/ncftp/ncftp.mk
A    freetz-trunk/make/ncftp/external.files
A    freetz-trunk/make/ncftp/external.in
A    freetz-trunk/make/ncftp/patches
A    freetz-trunk/make/ncftp/patches/02-no_host_defines_while_crosscompiling.patch
A    freetz-trunk/make/ncftp/patches/01-no_static_libgcc_in_CFLAGS.patch
A    freetz-trunk/make/ncftp/Config.in
A    freetz-trunk/make/tcpdump
A    freetz-trunk/make/tcpdump/tcpdump.mk
A    freetz-trunk/make/tcpdump/external.files
A    freetz-trunk/make/tcpdump/external.in
A    freetz-trunk/make/tcpdump/patches
A    freetz-trunk/make/tcpdump/patches/03-uflag_flushopen.patch
A    freetz-trunk/make/tcpdump/patches/01-remove_pcap_debug.patch
A    freetz-trunk/make/tcpdump/patches/10-tcpdump_mini.patch
A    freetz-trunk/make/tcpdump/patches/02-shared_pcap.patch
A    freetz-trunk/make/tcpdump/Config.in
A    freetz-trunk/make/hplip
A    freetz-trunk/make/hplip/files
A    freetz-trunk/make/hplip/files/root
A    freetz-trunk/make/hplip/files/root/etc
A    freetz-trunk/make/hplip/files/root/etc/default.sane-backends
A    freetz-trunk/make/hplip/files/root/etc/default.sane-backends/dll.d
A    freetz-trunk/make/hplip/files/root/etc/default.sane-backends/dll.d/hplip
A    freetz-trunk/make/hplip/hplip.mk
A    freetz-trunk/make/hplip/external.files
A    freetz-trunk/make/hplip/hplip-config-update.py
A    freetz-trunk/make/hplip/external.in
A    freetz-trunk/make/hplip/patches
A    freetz-trunk/make/hplip/patches/100-hplip-minimal.patch
A    freetz-trunk/make/hplip/Config.in
A    freetz-trunk/make/bluez-utils
A    freetz-trunk/make/bluez-utils/files
A    freetz-trunk/make/bluez-utils/files/root
A    freetz-trunk/make/bluez-utils/files/root/usr
A    freetz-trunk/make/bluez-utils/files/root/usr/lib
A    freetz-trunk/make/bluez-utils/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/bluez-utils/files/root/usr/lib/cgi-bin/bluez-utils
A    freetz-trunk/make/bluez-utils/files/root/usr/lib/cgi-bin/bluez-utils/bluez-utils-help.cgi
A    freetz-trunk/make/bluez-utils/files/root/usr/lib/cgi-bin/bluez-utils.cgi
A    freetz-trunk/make/bluez-utils/files/root/usr/bin
A    freetz-trunk/make/bluez-utils/files/root/usr/bin/bluepin
A    freetz-trunk/make/bluez-utils/files/root/etc
A    freetz-trunk/make/bluez-utils/files/root/etc/ppp
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils/rfcomm.def
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils/dun.def
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils/linkkeys.def
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils/hcidconf.def
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils/netpandu.def
A    freetz-trunk/make/bluez-utils/files/root/etc/default.bluez-utils/bluez-utils.cfg
A    freetz-trunk/make/bluez-utils/files/root/etc/hotplug
A    freetz-trunk/make/bluez-utils/files/root/etc/hotplug/net.pandu
A    freetz-trunk/make/bluez-utils/files/root/etc/bluetooth
A    freetz-trunk/make/bluez-utils/files/root/etc/bluetooth/pin
A    freetz-trunk/make/bluez-utils/files/root/etc/bluetooth/rfcomm.conf
A    freetz-trunk/make/bluez-utils/files/root/etc/bluetooth/hcid.conf
A    freetz-trunk/make/bluez-utils/files/root/etc/bluetooth/help.html
A    freetz-trunk/make/bluez-utils/files/root/etc/init.d
A    freetz-trunk/make/bluez-utils/files/root/etc/init.d/rc.bluez-utils
A    freetz-trunk/make/bluez-utils/external.files
A    freetz-trunk/make/bluez-utils/external.services
A    freetz-trunk/make/bluez-utils/bluez-utils.mk
A    freetz-trunk/make/bluez-utils/external.in
A    freetz-trunk/make/bluez-utils/Config.in
A    freetz-trunk/make/portmap
A    freetz-trunk/make/portmap/patches
A    freetz-trunk/make/portmap/patches/101-no_pie.patch
A    freetz-trunk/make/portmap/portmap.mk
A    freetz-trunk/make/portmap/Config.in
A    freetz-trunk/make/pptp/files
A    freetz-trunk/make/pptp/files/.language
A    freetz-trunk/make/pptp/files/root
A    freetz-trunk/make/pptp/files/root/usr
A    freetz-trunk/make/pptp/files/root/usr/lib
A    freetz-trunk/make/pptp/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/pptp/files/root/usr/lib/cgi-bin/pptp.cgi
A    freetz-trunk/make/pptp/files/root/etc
A    freetz-trunk/make/pptp/files/root/etc/init.d
A    freetz-trunk/make/pptp/files/root/etc/init.d/rc.pptp
A    freetz-trunk/make/pptp/files/root/etc/default.pptp
A    freetz-trunk/make/pptp/files/root/etc/default.pptp/pptp.cfg
A    freetz-trunk/make/pptp/files/root/etc/default.pptp/pptp_restart
A    freetz-trunk/make/pptp/files/root/etc/default.pptp/pptp_options.def
A    freetz-trunk/make/pptp/files/root/etc/default.pptp/pptp_peer
A    freetz-trunk/make/pptp/external.files
A    freetz-trunk/make/pptp/external.services
A    freetz-trunk/make/pptp/external.in
A    freetz-trunk/make/pptp/patches
A    freetz-trunk/make/pptp/patches/100-remove_stropts.patch
A    freetz-trunk/make/pptp/pptp.mk
A    freetz-trunk/make/pptp/Config.in
A    freetz-trunk/make/iptraf
A    freetz-trunk/make/iptraf/files
A    freetz-trunk/make/iptraf/files/var.tar
A    freetz-trunk/make/iptraf/files/var.tar/var
A    freetz-trunk/make/iptraf/files/var.tar/var/log
A    freetz-trunk/make/iptraf/files/var.tar/var/log/iptraf
A    freetz-trunk/make/iptraf/files/var.tar/var/log/iptraf/.gitignore
A    freetz-trunk/make/iptraf/files/var.tar/var/run
A    freetz-trunk/make/iptraf/files/var.tar/var/run/iptraf
A    freetz-trunk/make/iptraf/files/var.tar/var/run/iptraf/.gitignore
A    freetz-trunk/make/iptraf/external.files
A    freetz-trunk/make/iptraf/external.in
A    freetz-trunk/make/iptraf/patches
A    freetz-trunk/make/iptraf/patches/008-execl.patch
A    freetz-trunk/make/iptraf/patches/005-atheros.patch
A    freetz-trunk/make/iptraf/patches/006-src_makefile.patch
A    freetz-trunk/make/iptraf/patches/002-ifaces.patch
A    freetz-trunk/make/iptraf/patches/007-iptraf_c.patch
A    freetz-trunk/make/iptraf/patches/003-exit_menu.patch
A    freetz-trunk/make/iptraf/patches/004-includes_fix.patch
A    freetz-trunk/make/iptraf/patches/001-cross_compile.patch
A    freetz-trunk/make/iptraf/Config.in
A    freetz-trunk/make/iptraf/iptraf.mk
A    freetz-trunk/make/php
A    freetz-trunk/make/php/files
A    freetz-trunk/make/php/files/.language
A    freetz-trunk/make/php/files/root
A    freetz-trunk/make/php/files/root/etc
A    freetz-trunk/make/php/files/root/etc/init.d
A    freetz-trunk/make/php/files/root/etc/init.d/rc.php
A    freetz-trunk/make/php/files/root/etc/default.php
A    freetz-trunk/make/php/files/root/etc/default.php/php.cfg
A    freetz-trunk/make/php/files/root/etc/default.php/php.ini
A    freetz-trunk/make/php/files/root/etc/default.php/php_config.def
A    freetz-trunk/make/php/external.files
A    freetz-trunk/make/php/external.services
A    freetz-trunk/make/php/external.in
A    freetz-trunk/make/php/patches
A    freetz-trunk/make/php/patches/5.3.22
A    freetz-trunk/make/php/patches/5.3.22/500-ttyname_r.patch
A    freetz-trunk/make/php/patches/5.3.22/600-strange_iconv_undef.patch
A    freetz-trunk/make/php/patches/5.3.22/700-remove_libgd_function.patch
A    freetz-trunk/make/php/patches/5.3.22/110-consider-UCLIBC-specifics.patch
A    freetz-trunk/make/php/patches/5.3.22/600-iconv_in_libc_workaround.patch
A    freetz-trunk/make/php/patches/5.3.22/300-no_ldcxx.patch
A    freetz-trunk/make/php/patches/5.4.12
A    freetz-trunk/make/php/patches/5.4.12/100-libxml-support-missing-ifdefs.patch
A    freetz-trunk/make/php/patches/5.4.12/500-ttyname_r.patch
A    freetz-trunk/make/php/patches/5.4.12/600-strange_iconv_undef.patch
A    freetz-trunk/make/php/patches/5.4.12/700-remove_libgd_function.patch
A    freetz-trunk/make/php/patches/5.4.12/101-missing_openssl_ifdef.patch
A    freetz-trunk/make/php/patches/5.4.12/110-consider-UCLIBC-specifics.patch
A    freetz-trunk/make/php/patches/5.4.12/600-iconv_in_libc_workaround.patch
A    freetz-trunk/make/php/patches/5.4.12/300-no_ldcxx.patch
A    freetz-trunk/make/php/Config.in
A    freetz-trunk/make/php/php.mk
A    freetz-trunk/make/lynx
A    freetz-trunk/make/lynx/lynx.mk
A    freetz-trunk/make/lynx/external.files
A    freetz-trunk/make/lynx/external.in
A    freetz-trunk/make/lynx/patches
A    freetz-trunk/make/lynx/patches/03_defcfg-userdef.h.patch
A    freetz-trunk/make/lynx/patches/01_hostcc-src-makefile.patch
A    freetz-trunk/make/lynx/patches/04_no-gzip-param.patch
A    freetz-trunk/make/lynx/patches/02_defcfg-lynx.cfg.patch
A    freetz-trunk/make/lynx/Config.in
A    freetz-trunk/make/nmap
A    freetz-trunk/make/nmap/nmap.mk
A    freetz-trunk/make/nmap/external.files
A    freetz-trunk/make/nmap/external.in
A    freetz-trunk/make/nmap/patches
A    freetz-trunk/make/nmap/patches/4.68
A    freetz-trunk/make/nmap/patches/4.68/300-libm.patch
A    freetz-trunk/make/nmap/patches/4.68/500-uclibc++-ctime.patch
A    freetz-trunk/make/nmap/patches/4.68/400-chartables.c.patch
A    freetz-trunk/make/nmap/patches/4.68/200-libpcap_version_check.patch
A    freetz-trunk/make/nmap/patches/4.68/600-uclibc++-output.cc.patch
A    freetz-trunk/make/nmap/patches/4.68/100-liblua_includes_version_check.patch
A    freetz-trunk/make/nmap/patches/5.51
A    freetz-trunk/make/nmap/patches/5.51/210-IPv6_defines.patch
A    freetz-trunk/make/nmap/patches/5.51/300-libm.patch
A    freetz-trunk/make/nmap/patches/5.51/420-nping_libpcap_libdnet_cleanups.patch
A    freetz-trunk/make/nmap/patches/5.51/400-nsock_use_the_same_libpcap_as_nmap.patch
A    freetz-trunk/make/nmap/patches/5.51/100-liblua_includes.patch
A    freetz-trunk/make/nmap/patches/5.51/410-ncat_static.patch
A    freetz-trunk/make/nmap/patches/5.51/200-missing_HAVE_IPV6.patch
A    freetz-trunk/make/nmap/Config.in
A    freetz-trunk/make/minicom
A    freetz-trunk/make/minicom/minicom.mk
A    freetz-trunk/make/minicom/external.files
A    freetz-trunk/make/minicom/external.in
A    freetz-trunk/make/minicom/patches
A    freetz-trunk/make/minicom/patches/110-change-defaults-to-nomodem.patch
A    freetz-trunk/make/minicom/patches/100-iconv_workaround.patch
A    freetz-trunk/make/minicom/Config.in
A    freetz-trunk/make/python-imaging-library
A    freetz-trunk/make/python-imaging-library/python-imaging-library.mk
A    freetz-trunk/make/python-imaging-library/patches
A    freetz-trunk/make/python-imaging-library/patches/010-no_host_paths.openwrt.patch
A    freetz-trunk/make/python-imaging-library/patches/030-debian_1.1.7-4build1.patch
A    freetz-trunk/make/python-imaging-library/patches/020-target_endianess.patch
A    freetz-trunk/make/python-imaging-library/patches/040-scripts_shebang.patch
A    freetz-trunk/make/python-imaging-library/Config.in
A    freetz-trunk/make/dbus
A    freetz-trunk/make/dbus/external.in.libs
A    freetz-trunk/make/dbus/Config.in.libs
A    freetz-trunk/make/dbus/files
A    freetz-trunk/make/dbus/files/root
A    freetz-trunk/make/dbus/files/root/etc
A    freetz-trunk/make/dbus/files/root/etc/default.dbus
A    freetz-trunk/make/dbus/files/root/etc/default.dbus/dbus.cfg
A    freetz-trunk/make/dbus/files/root/etc/init.d
A    freetz-trunk/make/dbus/files/root/etc/init.d/rc.dbus
A    freetz-trunk/make/dbus/files/root/etc/dbus-1
A    freetz-trunk/make/dbus/dbus.mk
A    freetz-trunk/make/dbus/external.files
A    freetz-trunk/make/dbus/external.services
A    freetz-trunk/make/dbus/patches
A    freetz-trunk/make/dbus/patches/100-disable_poll_use_select.patch
A    freetz-trunk/make/dbus/patches/010-fix_fd_leaks.upstream-9a9b0e2736378d1a8961fb264d7314e921231e8e.patch
A    freetz-trunk/make/rsync
A    freetz-trunk/make/rsync/files
A    freetz-trunk/make/rsync/files/.language
A    freetz-trunk/make/rsync/files/root
A    freetz-trunk/make/rsync/files/root/usr
A    freetz-trunk/make/rsync/files/root/usr/lib
A    freetz-trunk/make/rsync/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/rsync/files/root/usr/lib/cgi-bin/rsync.cgi
A    freetz-trunk/make/rsync/files/root/etc
A    freetz-trunk/make/rsync/files/root/etc/default.rsync
A    freetz-trunk/make/rsync/files/root/etc/default.rsync/shares.def
A    freetz-trunk/make/rsync/files/root/etc/default.rsync/rsync_conf
A    freetz-trunk/make/rsync/files/root/etc/default.rsync/sharesx.def
A    freetz-trunk/make/rsync/files/root/etc/default.rsync/rsync.cfg
A    freetz-trunk/make/rsync/files/root/etc/init.d
A    freetz-trunk/make/rsync/files/root/etc/init.d/rc.rsync
A    freetz-trunk/make/rsync/external.files
A    freetz-trunk/make/rsync/external.services
A    freetz-trunk/make/rsync/rsync.mk
A    freetz-trunk/make/rsync/external.in
A    freetz-trunk/make/rsync/Config.in
A    freetz-trunk/make/onlinechanged-cgi
A    freetz-trunk/make/onlinechanged-cgi/files
A    freetz-trunk/make/onlinechanged-cgi/files/.language
A    freetz-trunk/make/onlinechanged-cgi/files/root
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged/onlinechanged.def
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged/onlinechanged.cfg
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/default.onlinechanged/onlinechanged-cgi
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/init.d
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/init.d/rc.onlinechanged
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/onlinechanged
A    freetz-trunk/make/onlinechanged-cgi/files/root/etc/onlinechanged/onlinechanged-cgi
A    freetz-trunk/make/onlinechanged-cgi/onlinechanged-cgi.mk
A    freetz-trunk/make/onlinechanged-cgi/Config.in
A    freetz-trunk/make/downloader
A    freetz-trunk/make/downloader/files
A    freetz-trunk/make/downloader/files/.language
A    freetz-trunk/make/downloader/files/root
A    freetz-trunk/make/downloader/files/root/usr
A    freetz-trunk/make/downloader/files/root/usr/lib
A    freetz-trunk/make/downloader/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/downloader/files/root/usr/lib/cgi-bin/downloader.cgi
A    freetz-trunk/make/downloader/files/root/usr/lib/cgi-bin/downloader/downremover.cgi
A    freetz-trunk/make/downloader/files/root/usr/lib/cgi-bin/downloader/downlog.cgi
A    freetz-trunk/make/downloader/files/root/usr/bin
A    freetz-trunk/make/downloader/files/root/usr/bin/downremover
A    freetz-trunk/make/downloader/files/root/usr/bin/downloader
A    freetz-trunk/make/downloader/files/root/etc
A    freetz-trunk/make/downloader/files/root/etc/default.downloader
A    freetz-trunk/make/downloader/files/root/etc/default.downloader/downloader.cfg
A    freetz-trunk/make/downloader/files/root/etc/init.d
A    freetz-trunk/make/downloader/files/root/etc/init.d/rc.downloader
A    freetz-trunk/make/downloader/files/CHANGELOG
A    freetz-trunk/make/downloader/files/README
A    freetz-trunk/make/downloader/downloader.mk
A    freetz-trunk/make/downloader/Config.in
A    freetz-trunk/make/igmpproxy
A    freetz-trunk/make/igmpproxy/files
A    freetz-trunk/make/igmpproxy/files/.language
A    freetz-trunk/make/igmpproxy/files/root
A    freetz-trunk/make/igmpproxy/files/root/usr
A    freetz-trunk/make/igmpproxy/files/root/usr/lib
A    freetz-trunk/make/igmpproxy/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/igmpproxy/files/root/usr/lib/cgi-bin/igmpproxy.cgi
A    freetz-trunk/make/igmpproxy/files/root/etc
A    freetz-trunk/make/igmpproxy/files/root/etc/default.igmpproxy
A    freetz-trunk/make/igmpproxy/files/root/etc/default.igmpproxy/igmpproxy_config.def
A    freetz-trunk/make/igmpproxy/files/root/etc/default.igmpproxy/igmpproxy.config
A    freetz-trunk/make/igmpproxy/files/root/etc/default.igmpproxy/igmpproxy.cfg
A    freetz-trunk/make/igmpproxy/files/root/etc/init.d
A    freetz-trunk/make/igmpproxy/files/root/etc/init.d/rc.igmpproxy
A    freetz-trunk/make/igmpproxy/external.files
A    freetz-trunk/make/igmpproxy/external.services
A    freetz-trunk/make/igmpproxy/igmpproxy.mk
A    freetz-trunk/make/igmpproxy/external.in
A    freetz-trunk/make/igmpproxy/patches
A    freetz-trunk/make/igmpproxy/patches/110-no_warn_for_MRT_DEL_MFC.patch
A    freetz-trunk/make/igmpproxy/patches/100-no_warn_for_changing_origins.patch
A    freetz-trunk/make/igmpproxy/Config.in
A    freetz-trunk/make/tree
A    freetz-trunk/make/tree/external.files
A    freetz-trunk/make/tree/tree.mk
A    freetz-trunk/make/tree/external.in
A    freetz-trunk/make/tree/patches
A    freetz-trunk/make/tree/patches/100-makefile.patch
A    freetz-trunk/make/tree/Config.in
A    freetz-trunk/make/subversion
A    freetz-trunk/make/subversion/files
A    freetz-trunk/make/subversion/files/.language
A    freetz-trunk/make/subversion/files/root
A    freetz-trunk/make/subversion/files/root/usr
A    freetz-trunk/make/subversion/files/root/usr/lib
A    freetz-trunk/make/subversion/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/subversion/files/root/usr/lib/cgi-bin/subversion
A    freetz-trunk/make/subversion/files/root/usr/lib/cgi-bin/subversion/subversion-log.cgi
A    freetz-trunk/make/subversion/files/root/usr/lib/cgi-bin/subversion.cgi
A    freetz-trunk/make/subversion/files/root/etc
A    freetz-trunk/make/subversion/files/root/etc/default.subversion
A    freetz-trunk/make/subversion/files/root/etc/default.subversion/subversion.inetd
A    freetz-trunk/make/subversion/files/root/etc/default.subversion/subversion.cfg
A    freetz-trunk/make/subversion/files/root/etc/init.d
A    freetz-trunk/make/subversion/files/root/etc/init.d/rc.subversion
A    freetz-trunk/make/subversion/external.files
A    freetz-trunk/make/subversion/external.services
A    freetz-trunk/make/subversion/subversion.mk
A    freetz-trunk/make/subversion/external.in
A    freetz-trunk/make/subversion/patches
A    freetz-trunk/make/subversion/patches/010-no_bindings.patch
A    freetz-trunk/make/subversion/Config.in
A    freetz-trunk/make/bftpd
A    freetz-trunk/make/bftpd/files
A    freetz-trunk/make/bftpd/files/.language
A    freetz-trunk/make/bftpd/files/root
A    freetz-trunk/make/bftpd/files/root/usr
A    freetz-trunk/make/bftpd/files/root/usr/lib
A    freetz-trunk/make/bftpd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/bftpd/files/root/usr/lib/cgi-bin/bftpd.cgi
A    freetz-trunk/make/bftpd/files/root/etc
A    freetz-trunk/make/bftpd/files/root/etc/default.bftpd
A    freetz-trunk/make/bftpd/files/root/etc/default.bftpd/bftpd.inetd
A    freetz-trunk/make/bftpd/files/root/etc/default.bftpd/bftpd_conf
A    freetz-trunk/make/bftpd/files/root/etc/default.bftpd/bftpd.cfg
A    freetz-trunk/make/bftpd/files/root/etc/init.d
A    freetz-trunk/make/bftpd/files/root/etc/init.d/rc.bftpd
A    freetz-trunk/make/bftpd/bftpd.mk
A    freetz-trunk/make/bftpd/patches
A    freetz-trunk/make/bftpd/patches/200-bftpd-cflags.patch
A    freetz-trunk/make/bftpd/patches/100-config-path.patch
A    freetz-trunk/make/bftpd/Config.in
A    freetz-trunk/make/ipsec-tools
A    freetz-trunk/make/ipsec-tools/files
A    freetz-trunk/make/ipsec-tools/files/.language
A    freetz-trunk/make/ipsec-tools/files/root
A    freetz-trunk/make/ipsec-tools/files/root/usr
A    freetz-trunk/make/ipsec-tools/files/root/usr/lib
A    freetz-trunk/make/ipsec-tools/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/ipsec-tools/files/root/usr/lib/cgi-bin/ipsec-tools.cgi
A    freetz-trunk/make/ipsec-tools/files/root/etc
A    freetz-trunk/make/ipsec-tools/files/root/etc/default.ipsec-tools
A    freetz-trunk/make/ipsec-tools/files/root/etc/default.ipsec-tools/ipsec-tools.cfg
A    freetz-trunk/make/ipsec-tools/files/root/etc/default.ipsec-tools/ipsec-tools_conf
A    freetz-trunk/make/ipsec-tools/files/root/etc/init.d
A    freetz-trunk/make/ipsec-tools/files/root/etc/init.d/rc.ipsec-tools
A    freetz-trunk/make/ipsec-tools/ipsec-tools.mk
A    freetz-trunk/make/ipsec-tools/patches
A    freetz-trunk/make/ipsec-tools/patches/101-no_libfl.patch
A    freetz-trunk/make/ipsec-tools/patches/100-build_static.patch
A    freetz-trunk/make/ipsec-tools/patches/103-fix_missing_GLOB_TILDE.patch
A    freetz-trunk/make/ipsec-tools/patches/102-linux_2.6.19_rtnetlink_changes.patch
A    freetz-trunk/make/ipsec-tools/patches/005-no_libresolv.patch
A    freetz-trunk/make/ipsec-tools/patches/104-fix_Werror_for_list.h.patch
A    freetz-trunk/make/ipsec-tools/Config.in
A    freetz-trunk/make/curl
A    freetz-trunk/make/curl/external.in.libs
A    freetz-trunk/make/curl/Config.in.libs
A    freetz-trunk/make/curl/external.files
A    freetz-trunk/make/curl/patches
A    freetz-trunk/make/curl/patches/200-uclibc-cyassl-pthread.patch
A    freetz-trunk/make/curl/patches/130-CPPFLAGS_as_CFLAGS.patch
A    freetz-trunk/make/curl/patches/101-cross_compile_writable_argv.patch
A    freetz-trunk/make/curl/patches/120-curl-config.patch
A    freetz-trunk/make/curl/patches/110-gnu_source__reentrant.patch
A    freetz-trunk/make/curl/patches/102-binary_static.patch
A    freetz-trunk/make/curl/patches/100-makefile_no_docs.patch
A    freetz-trunk/make/curl/curl.mk
A    freetz-trunk/make/smstools3
A    freetz-trunk/make/smstools3/files
A    freetz-trunk/make/smstools3/files/.language
A    freetz-trunk/make/smstools3/files/root
A    freetz-trunk/make/smstools3/files/root/usr
A    freetz-trunk/make/smstools3/files/root/usr/lib
A    freetz-trunk/make/smstools3/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/smstools3/files/root/usr/lib/cgi-bin/smstools3
A    freetz-trunk/make/smstools3/files/root/usr/lib/cgi-bin/smstools3/status.cgi
A    freetz-trunk/make/smstools3/files/root/usr/lib/cgi-bin/smstools3.cgi
A    freetz-trunk/make/smstools3/files/root/etc
A    freetz-trunk/make/smstools3/files/root/etc/init.d
A    freetz-trunk/make/smstools3/files/root/etc/init.d/rc.smstools3
A    freetz-trunk/make/smstools3/files/root/etc/default.smstools3
A    freetz-trunk/make/smstools3/files/root/etc/default.smstools3/smstools3.cfg
A    freetz-trunk/make/smstools3/files/root/etc/default.smstools3/smstools3_conf
A    freetz-trunk/make/smstools3/external.files
A    freetz-trunk/make/smstools3/external.services
A    freetz-trunk/make/smstools3/external.in
A    freetz-trunk/make/smstools3/patches
A    freetz-trunk/make/smstools3/patches/110_smsd_cfg_c.patch
A    freetz-trunk/make/smstools3/patches/100_smsd_cfg_h.patch
A    freetz-trunk/make/smstools3/Config.in
A    freetz-trunk/make/smstools3/smstools3.mk
A    freetz-trunk/make/comgt
A    freetz-trunk/make/comgt/comgt.mk
A    freetz-trunk/make/comgt/files
A    freetz-trunk/make/comgt/files/root
A    freetz-trunk/make/comgt/files/root/etc
A    freetz-trunk/make/comgt/files/root/etc/gcom
A    freetz-trunk/make/comgt/files/root/etc/gcom/getstrength.gcom
A    freetz-trunk/make/comgt/files/root/etc/gcom/setmode.gcom
A    freetz-trunk/make/comgt/files/root/etc/gcom/setpin.gcom
A    freetz-trunk/make/comgt/files/root/etc/gcom/getcardinfo.gcom
A    freetz-trunk/make/comgt/external.files
A    freetz-trunk/make/comgt/external.in
A    freetz-trunk/make/comgt/patches
A    freetz-trunk/make/comgt/patches/110_comgt_h.patch
A    freetz-trunk/make/comgt/patches/100-Makefile.patch
A    freetz-trunk/make/comgt/patches/120-scriptfile_path.patch
A    freetz-trunk/make/comgt/Config.in
A    freetz-trunk/make/xmail
A    freetz-trunk/make/xmail/xmail.mk
A    freetz-trunk/make/xmail/files
A    freetz-trunk/make/xmail/files/.language
A    freetz-trunk/make/xmail/files/root
A    freetz-trunk/make/xmail/files/root/usr
A    freetz-trunk/make/xmail/files/root/usr/lib
A    freetz-trunk/make/xmail/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/xmail/files/root/usr/lib/cgi-bin/xmail.cgi
A    freetz-trunk/make/xmail/files/root/etc
A    freetz-trunk/make/xmail/files/root/etc/init.d
A    freetz-trunk/make/xmail/files/root/etc/init.d/rc.xmail
A    freetz-trunk/make/xmail/files/root/etc/default.xmail
A    freetz-trunk/make/xmail/files/root/etc/default.xmail/xmail.cfg
A    freetz-trunk/make/xmail/files/README
A    freetz-trunk/make/xmail/external.files
A    freetz-trunk/make/xmail/external.services
A    freetz-trunk/make/xmail/external.in
A    freetz-trunk/make/xmail/patches
A    freetz-trunk/make/xmail/patches/201-ipv6_SysDepCommon.patch
A    freetz-trunk/make/xmail/patches/301-Makefile_common.patch
A    freetz-trunk/make/xmail/patches/100-compartment.patch
A    freetz-trunk/make/xmail/patches/500-MailRoot.patch
A    freetz-trunk/make/xmail/patches/400-SSLConfig.patch
A    freetz-trunk/make/xmail/patches/500-LMAILSrv.patch
A    freetz-trunk/make/xmail/patches/400-SSLBind.patch
A    freetz-trunk/make/xmail/patches/302-Makefile_lnx.patch
A    freetz-trunk/make/xmail/patches/400-CTRLSvr.patch
A    freetz-trunk/make/xmail/patches/300-SysMachine.patch
A    freetz-trunk/make/xmail/patches/400-POP3Utils.patch
A    freetz-trunk/make/xmail/patches/400-CTRLClient.patch
A    freetz-trunk/make/xmail/patches/400-SMTPUtils.patch
A    freetz-trunk/make/xmail/patches/400-MiscUtils.patch
A    freetz-trunk/make/xmail/patches/400-POP3Svr.patch
A    freetz-trunk/make/xmail/patches/400-MailSvr.patch
A    freetz-trunk/make/xmail/patches/400-SSLMisc.patch
A    freetz-trunk/make/xmail/patches/400-SMTPSvr.patch
A    freetz-trunk/make/xmail/patches/400-FINGSvr.patch
A    freetz-trunk/make/xmail/patches/200-ipv6_MailSvr.patch
A    freetz-trunk/make/xmail/Config.in
A    freetz-trunk/make/ltrace
A    freetz-trunk/make/ltrace/ltrace.mk
A    freetz-trunk/make/ltrace/external.files
A    freetz-trunk/make/ltrace/external.in
A    freetz-trunk/make/ltrace/patches
A    freetz-trunk/make/ltrace/patches/130-ltrace-mips.patch
A    freetz-trunk/make/ltrace/patches/200-susv3-legacy.patch
A    freetz-trunk/make/ltrace/patches/300-link_available_libraries_only.patch
A    freetz-trunk/make/ltrace/patches/100-add-sysdep.patch
A    freetz-trunk/make/ltrace/patches/110-ltrace-compile.patch
A    freetz-trunk/make/ltrace/Config.in
A    freetz-trunk/make/util-linux-ng
A    freetz-trunk/make/util-linux-ng/util-linux-ng.mk
A    freetz-trunk/make/util-linux-ng/external.files
A    freetz-trunk/make/util-linux-ng/external.in
A    freetz-trunk/make/util-linux-ng/patches
A    freetz-trunk/make/util-linux-ng/patches/110-no-AI_ADDRCONFIG.patch
A    freetz-trunk/make/util-linux-ng/patches/100-program_invocation_short_name.patch
A    freetz-trunk/make/util-linux-ng/patches/200-reduce_size.patch
A    freetz-trunk/make/util-linux-ng/patches/905-blkid_mtdworkaround.patch
A    freetz-trunk/make/util-linux-ng/Config.in
A    freetz-trunk/make/bind
A    freetz-trunk/make/bind/bind.mk
A    freetz-trunk/make/bind/files
A    freetz-trunk/make/bind/files/.language
A    freetz-trunk/make/bind/files/root
A    freetz-trunk/make/bind/files/root/usr
A    freetz-trunk/make/bind/files/root/usr/lib
A    freetz-trunk/make/bind/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/bind/files/root/usr/lib/cgi-bin/bind.cgi
A    freetz-trunk/make/bind/files/root/etc
A    freetz-trunk/make/bind/files/root/etc/default.bind
A    freetz-trunk/make/bind/files/root/etc/default.bind/named_conf.def
A    freetz-trunk/make/bind/files/root/etc/default.bind/bind.cfg
A    freetz-trunk/make/bind/files/root/etc/init.d
A    freetz-trunk/make/bind/files/root/etc/init.d/rc.bind
A    freetz-trunk/make/bind/files/root/etc/named.conf
A    freetz-trunk/make/bind/files/root/etc/rndc.conf
A    freetz-trunk/make/bind/files/root/etc/rndc.key
A    freetz-trunk/make/bind/external.files
A    freetz-trunk/make/bind/external.services
A    freetz-trunk/make/bind/external.in
A    freetz-trunk/make/bind/patches
A    freetz-trunk/make/bind/patches/010-extra_flags.patch
A    freetz-trunk/make/bind/Config.in
A    freetz-trunk/make/gnutls
A    freetz-trunk/make/gnutls/external.in.libs
A    freetz-trunk/make/gnutls/Config.in.libs
A    freetz-trunk/make/gnutls/Makefile.in
A    freetz-trunk/make/gnutls/gnutls.mk
A    freetz-trunk/make/gnutls/external.files
A    freetz-trunk/make/gnutls/patches
A    freetz-trunk/make/gnutls/patches/010-no_docs_tests.patch
A    freetz-trunk/make/gnutls/patches/020-pkgconfig_files.patch
A    freetz-trunk/make/inotify-tools
A    freetz-trunk/make/inotify-tools/files
A    freetz-trunk/make/inotify-tools/files/.language
A    freetz-trunk/make/inotify-tools/files/root
A    freetz-trunk/make/inotify-tools/files/root/usr
A    freetz-trunk/make/inotify-tools/files/root/usr/lib
A    freetz-trunk/make/inotify-tools/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/inotify-tools/files/root/usr/lib/cgi-bin/inotify-tools
A    freetz-trunk/make/inotify-tools/files/root/usr/lib/cgi-bin/inotify-tools/inotify-tools_log.cgi
A    freetz-trunk/make/inotify-tools/files/root/usr/lib/cgi-bin/inotify-tools.cgi
A    freetz-trunk/make/inotify-tools/files/root/etc
A    freetz-trunk/make/inotify-tools/files/root/etc/default.inotify-tools
A    freetz-trunk/make/inotify-tools/files/root/etc/default.inotify-tools/inotify-tools.cfg
A    freetz-trunk/make/inotify-tools/files/root/etc/init.d
A    freetz-trunk/make/inotify-tools/files/root/etc/init.d/rc.inotify-tools
A    freetz-trunk/make/inotify-tools/external.files
A    freetz-trunk/make/inotify-tools/external.services
A    freetz-trunk/make/inotify-tools/inotify-tools.mk
A    freetz-trunk/make/inotify-tools/external.in
A    freetz-trunk/make/inotify-tools/patches
A    freetz-trunk/make/inotify-tools/patches/100-inotifytools-lfs.patch
A    freetz-trunk/make/inotify-tools/Config.in
A    freetz-trunk/make/mod/files
A    freetz-trunk/make/mod/files/.language
A    freetz-trunk/make/mod/files/root
A    freetz-trunk/make/mod/files/root/bin
A    freetz-trunk/make/mod/files/root/bin/lang
A    freetz-trunk/make/mod/files/root/bin/onlinechanged.sh
A    freetz-trunk/make/mod/files/root/usr
A    freetz-trunk/make/mod/files/root/usr/share
A    freetz-trunk/make/mod/files/root/usr/share/style
A    freetz-trunk/make/mod/files/root/usr/share/style/colorscheme-colored.css
A    freetz-trunk/make/mod/files/root/usr/share/style/common.css
A    freetz-trunk/make/mod/files/root/usr/share/style/mod
A    freetz-trunk/make/mod/files/root/usr/share/style/mod/mounted.css
A    freetz-trunk/make/mod/files/root/usr/share/style/mod/freetz-conf.css
A    freetz-trunk/make/mod/files/root/usr/share/style/mod/daemons.css
A    freetz-trunk/make/mod/files/root/usr/share/style/legacy
A    freetz-trunk/make/mod/files/root/usr/share/style/legacy/base.css
A    freetz-trunk/make/mod/files/root/usr/share/style/newfreetz
A    freetz-trunk/make/mod/files/root/usr/share/style/newfreetz/base.css
A    freetz-trunk/make/mod/files/root/usr/share/style/newfreetz/colorscheme.css
A    freetz-trunk/make/mod/files/root/usr/share/style/phoenix
A    freetz-trunk/make/mod/files/root/usr/share/style/phoenix/base.css
A    freetz-trunk/make/mod/files/root/usr/share/style/colorscheme-grey.css
A    freetz-trunk/make/mod/files/root/usr/share/skin
A    freetz-trunk/make/mod/files/root/usr/share/skin/legacy
A    freetz-trunk/make/mod/files/root/usr/share/skin/legacy/skin.sh
A    freetz-trunk/make/mod/files/root/usr/share/skin/newfreetz
A    freetz-trunk/make/mod/files/root/usr/share/skin/newfreetz/skin.sh
A    freetz-trunk/make/mod/files/root/usr/share/skin/phoenix
A    freetz-trunk/make/mod/files/root/usr/share/skin/phoenix/skin.sh
A    freetz-trunk/make/mod/files/root/usr/share/images
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_l.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_lb.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_lt.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_b.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_r.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_rb.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_t.png
A    freetz-trunk/make/mod/files/root/usr/share/images/legacy/edge_rt.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/edge-top-left.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/menu-top-left.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/hg_freetz.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/menu-active.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/edge-bot-left.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/title_right.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/edge-top-right.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/menu-top-right.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/freetz_logo.gif
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/edge-bot-right.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/edge-top.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/title_1px.png
A    freetz-trunk/make/mod/files/root/usr/share/images/newfreetz/title_left.png
A    freetz-trunk/make/mod/files/root/usr/share/images/phoenix
A    freetz-trunk/make/mod/files/root/usr/share/images/phoenix/dialog-information.png
A    freetz-trunk/make/mod/files/root/usr/share/images/phoenix/dialog-warning.png
A    freetz-trunk/make/mod/files/root/usr/share/images/phoenix/dialog-error.png
A    freetz-trunk/make/mod/files/root/usr/share/about.txt
A    freetz-trunk/make/mod/files/root/usr/www
A    freetz-trunk/make/mod/files/root/usr/www/cgi-bin
A    freetz-trunk/make/mod/files/root/usr/www/cgi-bin/freetz_status
A    freetz-trunk/make/mod/files/root/usr/lib
A    freetz-trunk/make/mod/files/root/usr/lib/mod
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/help.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/request.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/error.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/validation.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/page.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/stat_bar.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/width.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/links.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/cache.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/form.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/html.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/menu.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/cgi/skin.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/menu-update
A    freetz-trunk/make/mod/files/root/usr/lib/mod/service.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mod/reg-status
A    freetz-trunk/make/mod/files/root/usr/lib/libmodcgi.sh
A    freetz-trunk/make/mod/files/root/usr/lib/libmodmount.sh
A    freetz-trunk/make/mod/files/root/usr/lib/libmodredir.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/do_download_config.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf.webcfg
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf.webcfg/10-webcfg.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/box_info.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/20-swap.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/80-ipv6.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/60-get_ip.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/50-shutdown.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/70-resolv.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/10-cron.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/30-mount.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/conf/40-external.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/logs.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/modlibcgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/info.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/mounted.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod/webcfg.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/mod.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/avm.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm/30-websrv.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm/10-telnet.sh
A    freetz-trunk/make/mod/files/root/usr/lib/cgi-bin/conf.avm/20-multid.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww
A    freetz-trunk/make/mod/files/root/usr/lib/mww/cgi
A    freetz-trunk/make/mod/files/root/usr/lib/mww/cgi/help.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/cgi/menu-new.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/cgi/menu.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/rudi_auth.cgi
A    freetz-trunk/make/mod/files/root/usr/lib/mww/do_external_handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/do_update_handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/file
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/file/save_body.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/file/handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/file/save.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/file/edit_body.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/file/edit.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/service
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/service/list_body.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/service/list.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/service/handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/service/save.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/extra
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/extra/list.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/extra/handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/status
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/status/handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/conf
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/conf/save_body.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/conf/handler.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/conf/save.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/conf/edit_body.sh
A    freetz-trunk/make/mod/files/root/usr/lib/mww/page.d/conf/edit.sh
A    freetz-trunk/make/mod/files/root/usr/bin
A    freetz-trunk/make/mod/files/root/usr/bin/modload
A    freetz-trunk/make/mod/files/root/usr/bin/wrapper
A    freetz-trunk/make/mod/files/root/usr/bin/wrapper/dsld
A    freetz-trunk/make/mod/files/root/usr/bin/wrapper/multid
A    freetz-trunk/make/mod/files/root/usr/bin/modunreg
A    freetz-trunk/make/mod/files/root/usr/bin/modconf
A    freetz-trunk/make/mod/files/root/usr/bin/mvi
A    freetz-trunk/make/mod/files/root/usr/bin/kernel_args
A    freetz-trunk/make/mod/files/root/usr/bin/nvi
A    freetz-trunk/make/mod/files/root/usr/bin/webcfg
A    freetz-trunk/make/mod/files/root/usr/bin/modsave
A    freetz-trunk/make/mod/files/root/usr/bin/modhosts
A    freetz-trunk/make/mod/files/root/usr/bin/modpasswd
A    freetz-trunk/make/mod/files/root/usr/bin/modusers
A    freetz-trunk/make/mod/files/root/usr/bin/wrap_editors
A    freetz-trunk/make/mod/files/root/usr/bin/prepare-downgrade
A    freetz-trunk/make/mod/files/root/usr/bin/get_ip
A    freetz-trunk/make/mod/files/root/usr/bin/websrv
A    freetz-trunk/make/mod/files/root/usr/bin/moduninstall
A    freetz-trunk/make/mod/files/root/usr/bin/modreg
A    freetz-trunk/make/mod/files/root/usr/mww
A    freetz-trunk/make/mod/files/root/usr/mww/style
A    freetz-trunk/make/mod/files/root/usr/mww/images
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/file
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/passwd_edit.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/update
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/update/do_firmware.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/update/external.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/update/do_external.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/update/firmware.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/avm
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/extra
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/system.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/conf
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/passwd_save.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/freetz.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/service
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/passwd.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/skin.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/backup
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/backup/do_restore.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/backup/do_backup.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/backup/index.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status.d
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/10-box.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/20-memory.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/00-password.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/status.d/50-mount.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/cleanup.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/reboot.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/create-swap.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/fw-attrib.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/exec.d/branding.sh
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/shell
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/shell/cmd.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/shell/upload.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/shell/index.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/index.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/about.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/support
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/support/do_support.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/support/index.cgi
A    freetz-trunk/make/mod/files/root/usr/mww/cgi-bin/page.cgi
A    freetz-trunk/make/mod/files/root/etc
A    freetz-trunk/make/mod/files/root/etc/default.webcfg
A    freetz-trunk/make/mod/files/root/etc/default.webcfg/webcfg_conf
A    freetz-trunk/make/mod/files/root/etc/profile
A    freetz-trunk/make/mod/files/root/etc/default.mod
A    freetz-trunk/make/mod/files/root/etc/default.mod/dtrace.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/rc_external.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/crontab.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/modules.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/udev_first.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/shutdown.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/udev_final.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/rc_custom.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/_profile.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/hosts.def
A    freetz-trunk/make/mod/files/root/etc/default.mod/mod.cfg
A    freetz-trunk/make/mod/files/root/etc/cron.d
A    freetz-trunk/make/mod/files/root/etc/cron.d/.gitignore
A    freetz-trunk/make/mod/files/root/etc/motd
A    freetz-trunk/make/mod/files/root/etc/mtab
A    freetz-trunk/make/mod/files/root/etc/services
A    freetz-trunk/make/mod/files/root/etc/udev
A    freetz-trunk/make/mod/files/root/etc/udev/rules.d
A    freetz-trunk/make/mod/files/root/etc/udev/rules.d/00-custom.rules
A    freetz-trunk/make/mod/files/root/etc/udev/rules.d/99-custom.rules
A    freetz-trunk/make/mod/files/root/etc/inittab.shutdown
A    freetz-trunk/make/mod/files/root/etc/device.table
A    freetz-trunk/make/mod/files/root/etc/init.d
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.ftpd
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.webcfg
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.multid
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.mod
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.telnetd
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.external
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.crond
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.smbd
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.dsld
A    freetz-trunk/make/mod/files/root/etc/init.d/modlibrc
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.websrv
A    freetz-trunk/make/mod/files/root/etc/init.d/rc.swap
A    freetz-trunk/make/mod/files/root/etc/default.avm
A    freetz-trunk/make/mod/files/root/etc/default.avm/avm.cfg
A    freetz-trunk/make/mod/files/root/etc/modprobe.conf
A    freetz-trunk/make/mod/files/root/etc/resolv.conf
A    freetz-trunk/make/mod/files/root/sbin
A    freetz-trunk/make/mod/files/root/sbin/ar7login
A    freetz-trunk/make/mod/files/root/sys
A    freetz-trunk/make/mod/files/root/sys/.gitignore
A    freetz-trunk/make/mod/mod.mk
A    freetz-trunk/make/mod/Config.in
A    freetz-trunk/make/usbip
A    freetz-trunk/make/usbip/files
A    freetz-trunk/make/usbip/files/.language
A    freetz-trunk/make/usbip/files/root
A    freetz-trunk/make/usbip/files/root/usr
A    freetz-trunk/make/usbip/files/root/usr/lib
A    freetz-trunk/make/usbip/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/usbip/files/root/usr/lib/cgi-bin/usbip.cgi
A    freetz-trunk/make/usbip/files/root/etc
A    freetz-trunk/make/usbip/files/root/etc/default.usbip
A    freetz-trunk/make/usbip/files/root/etc/default.usbip/usbip.cfg
A    freetz-trunk/make/usbip/files/root/etc/init.d
A    freetz-trunk/make/usbip/files/root/etc/init.d/rc.usbip
A    freetz-trunk/make/usbip/external.files
A    freetz-trunk/make/usbip/external.services
A    freetz-trunk/make/usbip/external.in
A    freetz-trunk/make/usbip/patches
A    freetz-trunk/make/usbip/patches/101-usbids_file.patch
A    freetz-trunk/make/usbip/patches/200-compat_2.6.13.patch
A    freetz-trunk/make/usbip/patches/100-cross_compile.patch
A    freetz-trunk/make/usbip/usbip.mk
A    freetz-trunk/make/usbip/Config.in
A    freetz-trunk/make/nhipt
A    freetz-trunk/make/nhipt/files
A    freetz-trunk/make/nhipt/files/root
A    freetz-trunk/make/nhipt/files/root/usr
A    freetz-trunk/make/nhipt/files/root/usr/lib
A    freetz-trunk/make/nhipt/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/nhipt/files/root/usr/lib/cgi-bin/nhipt.cgi
A    freetz-trunk/make/nhipt/files/root/usr/ipt
A    freetz-trunk/make/nhipt/files/root/usr/ipt/cgi-bin
A    freetz-trunk/make/nhipt/files/root/usr/ipt/cgi-bin/nhipt.cgi
A    freetz-trunk/make/nhipt/files/root/usr/ipt/cgi-bin/index.cgi
A    freetz-trunk/make/nhipt/files/root/etc
A    freetz-trunk/make/nhipt/files/root/etc/default.nhipt
A    freetz-trunk/make/nhipt/files/root/etc/default.nhipt/nhipt.cfg
A    freetz-trunk/make/nhipt/files/root/etc/init.d
A    freetz-trunk/make/nhipt/files/root/etc/init.d/rc.nhipt
A    freetz-trunk/make/nhipt/nhipt.mk
A    freetz-trunk/make/nhipt/Config.in
A    freetz-trunk/make/fortune
A    freetz-trunk/make/fortune/files
A    freetz-trunk/make/fortune/files/.language
A    freetz-trunk/make/fortune/files/root
A    freetz-trunk/make/fortune/files/root/usr
A    freetz-trunk/make/fortune/files/root/usr/lib
A    freetz-trunk/make/fortune/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/fortune/files/root/usr/lib/cgi-bin/fortune.cgi
A    freetz-trunk/make/fortune/files/root/usr/bin
A    freetz-trunk/make/fortune/files/root/usr/bin/fortune
A    freetz-trunk/make/fortune/files/root/etc
A    freetz-trunk/make/fortune/files/root/etc/default.fortune
A    freetz-trunk/make/fortune/files/root/etc/default.fortune/fortune.cfg
A    freetz-trunk/make/fortune/files/root/etc/init.d
A    freetz-trunk/make/fortune/files/root/etc/init.d/rc.fortune
A    freetz-trunk/make/fortune/patches
A    freetz-trunk/make/fortune/patches/100-fortunedir.patch
A    freetz-trunk/make/fortune/fortune.mk
A    freetz-trunk/make/fortune/Config.in
A    freetz-trunk/make/samba
A    freetz-trunk/make/samba/samba30.mk.in
A    freetz-trunk/make/samba/files
A    freetz-trunk/make/samba/files/.language
A    freetz-trunk/make/samba/files/root
A    freetz-trunk/make/samba/files/root/usr
A    freetz-trunk/make/samba/files/root/usr/lib
A    freetz-trunk/make/samba/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/samba/files/root/usr/lib/cgi-bin/samba.cgi
A    freetz-trunk/make/samba/files/root/etc
A    freetz-trunk/make/samba/files/root/etc/samba_control
A    freetz-trunk/make/samba/files/root/etc/init.d
A    freetz-trunk/make/samba/files/root/etc/init.d/rc.nmbd
A    freetz-trunk/make/samba/files/root/etc/init.d/rc.samba
A    freetz-trunk/make/samba/files/root/etc/init.d/rc.smbd
A    freetz-trunk/make/samba/files/root/etc/default.samba
A    freetz-trunk/make/samba/files/root/etc/default.samba/samba.save
A    freetz-trunk/make/samba/files/root/etc/default.samba/samba.cfg
A    freetz-trunk/make/samba/files/root/etc/default.samba/shares.def
A    freetz-trunk/make/samba/files/root/etc/default.samba/smbd.inetd
A    freetz-trunk/make/samba/files/root/etc/default.samba/samba_conf
A    freetz-trunk/make/samba/files/root/etc/default.samba/sharesx.def
A    freetz-trunk/make/samba/external.files
A    freetz-trunk/make/samba/external.services
A    freetz-trunk/make/samba/external.in
A    freetz-trunk/make/samba/patches
A    freetz-trunk/make/samba/patches/3.6.12
A    freetz-trunk/make/samba/patches/3.6.12/520-gnu_ld_version.patch
A    freetz-trunk/make/samba/patches/3.6.12/260-remove_samr.patch
A    freetz-trunk/make/samba/patches/3.6.12/100-configure_getaddrinfo.patch
A    freetz-trunk/make/samba/patches/3.6.12/110-multicall.patch
A    freetz-trunk/make/samba/patches/3.6.12/240-remove_dfs_api.patch
A    freetz-trunk/make/samba/patches/3.6.12/111-build-required-binaries-only.patch
A    freetz-trunk/make/samba/patches/3.6.12/250-remove_domain_logon.patch
A    freetz-trunk/make/samba/patches/3.6.12/200-remove_printer_support.patch
A    freetz-trunk/make/samba/patches/3.6.12/210-remove_ad_support.patch
A    freetz-trunk/make/samba/patches/3.6.12/330-librpc_default_print.patch
A    freetz-trunk/make/samba/patches/3.6.12/300-assert_debug_level.patch
A    freetz-trunk/make/samba/patches/3.6.12/320-debug_level_checks.patch
A    freetz-trunk/make/samba/patches/3.6.12/500-extra_FLAGS.patch
A    freetz-trunk/make/samba/patches/3.6.12/220-remove_services.patch
A    freetz-trunk/make/samba/patches/3.6.12/270-remove_registry_backend.patch
A    freetz-trunk/make/samba/patches/3.6.12/290-remove_lsa.patch
A    freetz-trunk/make/samba/patches/3.6.12/530-LINUX_LFS_SUPPORT.patch
A    freetz-trunk/make/samba/patches/3.6.12/101-config.cache-proper-dl-values.patch
A    freetz-trunk/make/samba/patches/3.6.12/230-remove_winreg_support.patch
A    freetz-trunk/make/samba/patches/3.6.12/112-avm_smbpasswd.patch
A    freetz-trunk/make/samba/patches/3.6.12/540-iconv-hardcoded-charsets.patch
A    freetz-trunk/make/samba/patches/3.6.12/280-strip_srvsvc.patch
A    freetz-trunk/make/samba/patches/3.6.12/120-add_missing_ifdef.patch
A    freetz-trunk/make/samba/patches/3.6.12/510-verbose_compiling.patch.disabled
A    freetz-trunk/make/samba/patches/3.6.12/310-remove_error_strings.patch
A    freetz-trunk/make/samba/patches/3.6.12/550-no_libresolb.patch
A    freetz-trunk/make/samba/patches/3.0.37
A    freetz-trunk/make/samba/patches/3.0.37/110-multicall.patch
A    freetz-trunk/make/samba/patches/3.0.37/110-samba_avm.patch
A    freetz-trunk/make/samba/patches/3.0.37/111-build-required-binaries-only.patch
A    freetz-trunk/make/samba/patches/3.0.37/100-skip_configure_tests.patch
A    freetz-trunk/make/samba/patches/3.0.37/150-fix_ls.patch
A    freetz-trunk/make/samba/patches/3.0.37/300-fix_oplocks_define.patch
A    freetz-trunk/make/samba/patches/3.0.37/160-fix_log.patch
A    freetz-trunk/make/samba/patches/3.0.37/004-samba-3.0.37-CVE-2012-1182.patch
A    freetz-trunk/make/samba/patches/3.0.37/500-extra_FLAGS.patch
A    freetz-trunk/make/samba/patches/3.0.37/002-samba-3.0.37-CVE-2010-3069.patch
A    freetz-trunk/make/samba/patches/3.0.37/550-no_libresolv.patch
A    freetz-trunk/make/samba/patches/3.0.37/530-LINUX_LFS_SUPPORT.patch
A    freetz-trunk/make/samba/patches/3.0.37/001-s3-schannel-client-Push-the-domain-and-netbios-name.patch
A    freetz-trunk/make/samba/patches/3.0.37/112-avm_smbpasswd.patch
A    freetz-trunk/make/samba/patches/3.0.37/003-samba-3.0-CVE-2012-0870-1.patch
A    freetz-trunk/make/samba/patches/3.0.37/540-iconv-hardcoded-charsets.patch
A    freetz-trunk/make/samba/patches/3.0.37/003-samba-3.0-CVE-2012-0870-2.patch
A    freetz-trunk/make/samba/samba36.mk.in
A    freetz-trunk/make/samba/samba.mk
A    freetz-trunk/make/samba/Config.in
A    freetz-trunk/make/callmonitor
A    freetz-trunk/make/callmonitor/patches
A    freetz-trunk/make/callmonitor/callmonitor.mk
A    freetz-trunk/make/callmonitor/Config.in
A    freetz-trunk/make/squid
A    freetz-trunk/make/squid/files
A    freetz-trunk/make/squid/files/.language
A    freetz-trunk/make/squid/files/root
A    freetz-trunk/make/squid/files/root/usr
A    freetz-trunk/make/squid/files/root/usr/lib
A    freetz-trunk/make/squid/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/squid/files/root/usr/lib/cgi-bin/squid
A    freetz-trunk/make/squid/files/root/usr/lib/cgi-bin/squid/squid_log.cgi
A    freetz-trunk/make/squid/files/root/usr/lib/cgi-bin/squid.cgi
A    freetz-trunk/make/squid/files/root/etc
A    freetz-trunk/make/squid/files/root/etc/init.d
A    freetz-trunk/make/squid/files/root/etc/init.d/rc.squid
A    freetz-trunk/make/squid/files/root/etc/default.squid
A    freetz-trunk/make/squid/files/root/etc/default.squid/squid.cfg
A    freetz-trunk/make/squid/files/root/etc/default.squid/squid_conf
A    freetz-trunk/make/squid/external.files
A    freetz-trunk/make/squid/external.services
A    freetz-trunk/make/squid/external.in
A    freetz-trunk/make/squid/patches
A    freetz-trunk/make/squid/patches/120-x_funs.patch
A    freetz-trunk/make/squid/patches/130_configure_cflags.patch
A    freetz-trunk/make/squid/patches/005-no_libnsl_no_libresolv.patch
A    freetz-trunk/make/squid/patches/110-cross_compile.patch
A    freetz-trunk/make/squid/Config.in
A    freetz-trunk/make/squid/squid.mk
A    freetz-trunk/make/davfs2
A    freetz-trunk/make/davfs2/files
A    freetz-trunk/make/davfs2/files/.language
A    freetz-trunk/make/davfs2/files/root
A    freetz-trunk/make/davfs2/files/root/usr
A    freetz-trunk/make/davfs2/files/root/usr/lib
A    freetz-trunk/make/davfs2/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/davfs2/files/root/usr/lib/cgi-bin/davfs2.cgi
A    freetz-trunk/make/davfs2/files/root/etc
A    freetz-trunk/make/davfs2/files/root/etc/davfs2
A    freetz-trunk/make/davfs2/files/root/etc/init.d
A    freetz-trunk/make/davfs2/files/root/etc/init.d/rc.davfs2
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_0_conf
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt0.def
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_1_conf
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt1.def
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2.cfg
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_2_conf
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt2.def
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_secrets_3_conf
A    freetz-trunk/make/davfs2/files/root/etc/default.davfs2/davfs2_servercrt3.def
A    freetz-trunk/make/davfs2/external.files
A    freetz-trunk/make/davfs2/external.services
A    freetz-trunk/make/davfs2/external.in
A    freetz-trunk/make/davfs2/patches
A    freetz-trunk/make/davfs2/patches/040-no_user_specific_cache_dir.patch
A    freetz-trunk/make/davfs2/patches/060-rpmatch.patch
A    freetz-trunk/make/davfs2/patches/030-no_fstab_check.patch
A    freetz-trunk/make/davfs2/patches/010-cache_size.patch
A    freetz-trunk/make/davfs2/patches/070-no_libintl.patch
A    freetz-trunk/make/davfs2/patches/020-canonicalize.patch
A    freetz-trunk/make/davfs2/patches/050-reduce_debug_output.patch
A    freetz-trunk/make/davfs2/Config.in
A    freetz-trunk/make/davfs2/davfs2.mk
A    freetz-trunk/make/avm-firewall
A    freetz-trunk/make/avm-firewall/files
A    freetz-trunk/make/avm-firewall/files/.language
A    freetz-trunk/make/avm-firewall/files/root
A    freetz-trunk/make/avm-firewall/files/root/usr
A    freetz-trunk/make/avm-firewall/files/root/usr/share
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/reject.gif
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/clone.png
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/deny.gif
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/blink!.gif
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/permit.gif
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/log.gif
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/nat.gif
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/del.png
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/up.png
A    freetz-trunk/make/avm-firewall/files/root/usr/share/images/down.png
A    freetz-trunk/make/avm-firewall/files/root/usr/lib
A    freetz-trunk/make/avm-firewall/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/avm-firewall/files/root/usr/lib/cgi-bin/avm-firewall.cgi
A    freetz-trunk/make/avm-firewall/files/root/etc
A    freetz-trunk/make/avm-firewall/files/root/etc/init.d
A    freetz-trunk/make/avm-firewall/files/root/etc/init.d/rc.avm-firewall
A    freetz-trunk/make/avm-firewall/files/root/etc/default.avm-firewall
A    freetz-trunk/make/avm-firewall/files/root/etc/default.avm-firewall/avm-firewall.save
A    freetz-trunk/make/avm-firewall/files/root/etc/default.avm-firewall/avm-firewall.cfg
A    freetz-trunk/make/avm-firewall/Config.in
A    freetz-trunk/make/avm-firewall/avm-firewall.mk
A    freetz-trunk/make/ruby-fcgi
A    freetz-trunk/make/ruby-fcgi/files
A    freetz-trunk/make/ruby-fcgi/files/root
A    freetz-trunk/make/ruby-fcgi/files/root/usr
A    freetz-trunk/make/ruby-fcgi/files/root/usr/bin
A    freetz-trunk/make/ruby-fcgi/files/root/usr/bin/ruby-cgi
A    freetz-trunk/make/ruby-fcgi/files/README
A    freetz-trunk/make/ruby-fcgi/Config.in
A    freetz-trunk/make/ruby-fcgi/ruby-fcgi.mk
A    freetz-trunk/make/madplay
A    freetz-trunk/make/madplay/external.files
A    freetz-trunk/make/madplay/external.in
A    freetz-trunk/make/madplay/patches
A    freetz-trunk/make/madplay/patches/110-libtool_call_missing_tag.patch
A    freetz-trunk/make/madplay/patches/100-configure_arch.patch
A    freetz-trunk/make/madplay/Config.in
A    freetz-trunk/make/madplay/madplay.mk
A    freetz-trunk/make/siproxd
A    freetz-trunk/make/siproxd/files
A    freetz-trunk/make/siproxd/files/.language
A    freetz-trunk/make/siproxd/files/root
A    freetz-trunk/make/siproxd/files/root/usr
A    freetz-trunk/make/siproxd/files/root/usr/lib
A    freetz-trunk/make/siproxd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/siproxd/files/root/usr/lib/cgi-bin/siproxd.cgi
A    freetz-trunk/make/siproxd/files/root/etc
A    freetz-trunk/make/siproxd/files/root/etc/init.d
A    freetz-trunk/make/siproxd/files/root/etc/init.d/rc.siproxd
A    freetz-trunk/make/siproxd/files/root/etc/default.siproxd
A    freetz-trunk/make/siproxd/files/root/etc/default.siproxd/siproxdpwd_conf.def
A    freetz-trunk/make/siproxd/files/root/etc/default.siproxd/siproxd.cfg
A    freetz-trunk/make/siproxd/files/root/etc/default.siproxd/siproxdreg_conf.def
A    freetz-trunk/make/siproxd/files/root/etc/default.siproxd/siproxd_conf.def
A    freetz-trunk/make/siproxd/files/root/etc/onlinechanged
A    freetz-trunk/make/siproxd/files/root/etc/onlinechanged/siproxd
A    freetz-trunk/make/siproxd/files/README
A    freetz-trunk/make/siproxd/external.files
A    freetz-trunk/make/siproxd/external.services
A    freetz-trunk/make/siproxd/external.in
A    freetz-trunk/make/siproxd/patches
A    freetz-trunk/make/siproxd/patches/025-reduce_buffer_sizes.patch
A    freetz-trunk/make/siproxd/patches/010-no-strict-aliasing.patch
A    freetz-trunk/make/siproxd/patches/030-daemonize_as_cmdline_parameter_only.patch
A    freetz-trunk/make/siproxd/patches/020-plugin_dir_trailing_slash.patch
A    freetz-trunk/make/siproxd/patches/005-no_libresolv.patch
A    freetz-trunk/make/siproxd/Config.in
A    freetz-trunk/make/siproxd/siproxd.mk
A    freetz-trunk/make/pyload
A    freetz-trunk/make/pyload/files
A    freetz-trunk/make/pyload/files/.language
A    freetz-trunk/make/pyload/files/root
A    freetz-trunk/make/pyload/files/root/opt
A    freetz-trunk/make/pyload/files/root/opt/pyLoad
A    freetz-trunk/make/pyload/files/root/opt/pyLoad/module
A    freetz-trunk/make/pyload/files/root/opt/pyLoad/module/config
A    freetz-trunk/make/pyload/files/root/opt/pyLoad/module/config/configdir
A    freetz-trunk/make/pyload/files/root/usr
A    freetz-trunk/make/pyload/files/root/usr/lib
A    freetz-trunk/make/pyload/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/pyload/files/root/usr/lib/cgi-bin/pyload.cgi
A    freetz-trunk/make/pyload/files/root/usr/mww
A    freetz-trunk/make/pyload/files/root/usr/mww/cgi-bin
A    freetz-trunk/make/pyload/files/root/usr/mww/cgi-bin/pyload
A    freetz-trunk/make/pyload/files/root/etc
A    freetz-trunk/make/pyload/files/root/etc/init.d
A    freetz-trunk/make/pyload/files/root/etc/init.d/rc.pyload
A    freetz-trunk/make/pyload/files/root/etc/default.pyload
A    freetz-trunk/make/pyload/files/root/etc/default.pyload/pyload.cfg
A    freetz-trunk/make/pyload/external.files
A    freetz-trunk/make/pyload/external.services
A    freetz-trunk/make/pyload/external.in
A    freetz-trunk/make/pyload/patches
A    freetz-trunk/make/pyload/patches/020-allow_hyphen_in_configdir.patch
A    freetz-trunk/make/pyload/patches/005-fix_typos.patch
A    freetz-trunk/make/pyload/patches/010-no_nls.patch
A    freetz-trunk/make/pyload/patches/030-no_changedir.patch
A    freetz-trunk/make/pyload/Config.in
A    freetz-trunk/make/pyload/pyload.mk
A    freetz-trunk/make/dnsd-cgi
A    freetz-trunk/make/dnsd-cgi/files
A    freetz-trunk/make/dnsd-cgi/files/.language
A    freetz-trunk/make/dnsd-cgi/files/root
A    freetz-trunk/make/dnsd-cgi/files/root/usr
A    freetz-trunk/make/dnsd-cgi/files/root/usr/lib
A    freetz-trunk/make/dnsd-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/dnsd-cgi/files/root/usr/lib/cgi-bin/dnsd.cgi
A    freetz-trunk/make/dnsd-cgi/files/root/etc
A    freetz-trunk/make/dnsd-cgi/files/root/etc/init.d
A    freetz-trunk/make/dnsd-cgi/files/root/etc/init.d/rc.dnsd
A    freetz-trunk/make/dnsd-cgi/files/root/etc/default.dnsd
A    freetz-trunk/make/dnsd-cgi/files/root/etc/default.dnsd/dnsd.cfg
A    freetz-trunk/make/dnsd-cgi/files/root/etc/default.dnsd/dnsd_conf.def
A    freetz-trunk/make/dnsd-cgi/Config.in
A    freetz-trunk/make/dnsd-cgi/dnsd-cgi.mk
A    freetz-trunk/make/gocr
A    freetz-trunk/make/gocr/gocr.mk
A    freetz-trunk/make/gocr/external.files
A    freetz-trunk/make/gocr/external.in
A    freetz-trunk/make/gocr/patches
A    freetz-trunk/make/gocr/patches/01-netpbm_include_path.patch
A    freetz-trunk/make/gocr/Config.in
A    freetz-trunk/make/httpry
A    freetz-trunk/make/httpry/httpry.mk
A    freetz-trunk/make/httpry/files
A    freetz-trunk/make/httpry/files/.language
A    freetz-trunk/make/httpry/files/root
A    freetz-trunk/make/httpry/files/root/usr
A    freetz-trunk/make/httpry/files/root/usr/lib
A    freetz-trunk/make/httpry/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/httpry/files/root/usr/lib/cgi-bin/httpry
A    freetz-trunk/make/httpry/files/root/usr/lib/cgi-bin/httpry/httpry_log.cgi
A    freetz-trunk/make/httpry/files/root/usr/lib/cgi-bin/httpry.cgi
A    freetz-trunk/make/httpry/files/root/etc
A    freetz-trunk/make/httpry/files/root/etc/init.d
A    freetz-trunk/make/httpry/files/root/etc/init.d/rc.httpry
A    freetz-trunk/make/httpry/files/root/etc/default.httpry
A    freetz-trunk/make/httpry/files/root/etc/default.httpry/httpry.cfg
A    freetz-trunk/make/httpry/external.files
A    freetz-trunk/make/httpry/external.services
A    freetz-trunk/make/httpry/external.in
A    freetz-trunk/make/httpry/Config.in
A    freetz-trunk/make/ifstat
A    freetz-trunk/make/ifstat/ifstat.mk
A    freetz-trunk/make/ifstat/external.files
A    freetz-trunk/make/ifstat/external.in
A    freetz-trunk/make/ifstat/Config.in
A    freetz-trunk/make/dante
A    freetz-trunk/make/dante/dante.mk
A    freetz-trunk/make/dante/patches
A    freetz-trunk/make/dante/patches/017-cppcheck.patch
A    freetz-trunk/make/dante/patches/011-linux-eccentricities.patch
A    freetz-trunk/make/dante/patches/013-c-warnings.patch
A    freetz-trunk/make/dante/patches/130-GNU_SOURCE.patch
A    freetz-trunk/make/dante/patches/140-freeifaddrs_AF_NETLINK-fix.patch
A    freetz-trunk/make/dante/patches/141-disable-AF_NETLINK.patch
A    freetz-trunk/make/dante/patches/003-CFLAGS.patch
A    freetz-trunk/make/dante/patches/007-rconnect.patch
A    freetz-trunk/make/dante/patches/120-ifaddrs_compat.patch
A    freetz-trunk/make/dante/patches/110-cross_compile.patch
A    freetz-trunk/make/dante/Config.in
A    freetz-trunk/make/gdb
A    freetz-trunk/make/gdb/gdb.mk
A    freetz-trunk/make/gdb/external.files
A    freetz-trunk/make/gdb/external.in
A    freetz-trunk/make/gdb/patches
A    freetz-trunk/make/gdb/patches/7.3.1
A    freetz-trunk/make/gdb/patches/7.3.1/010-no_testsuite.patch
A    freetz-trunk/make/gdb/patches/7.3.1/600-fix-compile-flag-mismatch.patch
A    freetz-trunk/make/gdb/patches/6.8
A    freetz-trunk/make/gdb/patches/6.8/010-no_testsuite.patch
A    freetz-trunk/make/gdb/patches/6.8/600-fix-compile-flag-mismatch.patch
A    freetz-trunk/make/gdb/Config.in
A    freetz-trunk/make/mc
A    freetz-trunk/make/mc/external.files
A    freetz-trunk/make/mc/mc.mk
A    freetz-trunk/make/mc/external.in
A    freetz-trunk/make/mc/patches
A    freetz-trunk/make/mc/patches/030-bash_inputrc.patch
A    freetz-trunk/make/mc/patches/020-noman_nolang.patch
A    freetz-trunk/make/mc/patches/040-ash_as_subshell_additional.patch
A    freetz-trunk/make/mc/patches/020-nomacro_examples.patch
A    freetz-trunk/make/mc/patches/010-rpath.patch
A    freetz-trunk/make/mc/patches/015-drop_dependency_on_gmodule.patch
A    freetz-trunk/make/mc/patches/005-strverscmp_fix.patch
A    freetz-trunk/make/mc/patches/040-ash_as_subshell.patch
A    freetz-trunk/make/mc/Config.in
A    freetz-trunk/make/iptables-cgi
A    freetz-trunk/make/iptables-cgi/files
A    freetz-trunk/make/iptables-cgi/files/.language
A    freetz-trunk/make/iptables-cgi/files/root
A    freetz-trunk/make/iptables-cgi/files/root/usr
A    freetz-trunk/make/iptables-cgi/files/root/usr/share
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/REJECT.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/ACCEPT.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/LOG.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/DROP.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/MASQUERADE.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/SPORT.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/share/images/DPORT.gif
A    freetz-trunk/make/iptables-cgi/files/root/usr/lib
A    freetz-trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables
A    freetz-trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables/controller.cgi
A    freetz-trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables/editor.cgi
A    freetz-trunk/make/iptables-cgi/files/root/usr/lib/cgi-bin/iptables.cgi
A    freetz-trunk/make/iptables-cgi/files/root/etc
A    freetz-trunk/make/iptables-cgi/files/root/etc/init.d
A    freetz-trunk/make/iptables-cgi/files/root/etc/init.d/rc.iptables
A    freetz-trunk/make/iptables-cgi/files/root/etc/default.iptables
A    freetz-trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables.def
A    freetz-trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables.save
A    freetz-trunk/make/iptables-cgi/files/root/etc/default.iptables/services.def
A    freetz-trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables.cfg
A    freetz-trunk/make/iptables-cgi/files/root/etc/default.iptables/iptables_services
A    freetz-trunk/make/iptables-cgi/files/iptables_services
A    freetz-trunk/make/iptables-cgi/files/README
A    freetz-trunk/make/iptables-cgi/iptables-cgi.mk
A    freetz-trunk/make/iptables-cgi/Config.in
A    freetz-trunk/make/dtmfbox-cgi
A    freetz-trunk/make/dtmfbox-cgi/files
A    freetz-trunk/make/dtmfbox-cgi/files/root
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/bin
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/bin/webcfg-dtmfbox-cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/dtmfbox.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_cfg.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_cmd.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_status.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_main.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_webphone.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_help.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/cgi-bin/dtmfbox_scriptedit.cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/dtmfbox_style.css
A    freetz-trunk/make/dtmfbox-cgi/files/root/usr/mww-dtmfbox-cgi/index.html
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc/init.d
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc/init.d/rc.dtmfbox-cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi/dtmfbox-cgi.cfg
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi/dtmfbox-cgi.inetd
A    freetz-trunk/make/dtmfbox-cgi/files/root/etc/default.dtmfbox-cgi/httpd-dtmfbox-cgi_conf
A    freetz-trunk/make/dtmfbox-cgi/dtmfbox-cgi.mk
A    freetz-trunk/make/dtmfbox-cgi/Config.in
A    freetz-trunk/make/tesseract-eng
A    freetz-trunk/make/tesseract-eng/tesseract-eng.mk
A    freetz-trunk/make/fstyp
A    freetz-trunk/make/fstyp/patches
A    freetz-trunk/make/fstyp/patches/400-update_config_sub.patch
A    freetz-trunk/make/fstyp/patches/300-ext3.patch
A    freetz-trunk/make/fstyp/patches/200-fat_pattern.patch
A    freetz-trunk/make/fstyp/patches/500-squashfs_jffs2_pattern.patch
A    freetz-trunk/make/fstyp/patches/600-unknown_filesystem.patch
A    freetz-trunk/make/fstyp/patches/350-ext4.patch
A    freetz-trunk/make/fstyp/patches/100-includedir.patch
A    freetz-trunk/make/fstyp/Config.in
A    freetz-trunk/make/fstyp/fstyp.mk
A    freetz-trunk/make/hd-idle
A    freetz-trunk/make/hd-idle/files
A    freetz-trunk/make/hd-idle/files/.language
A    freetz-trunk/make/hd-idle/files/root
A    freetz-trunk/make/hd-idle/files/root/usr
A    freetz-trunk/make/hd-idle/files/root/usr/lib
A    freetz-trunk/make/hd-idle/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/hd-idle/files/root/usr/lib/cgi-bin/hd-idle.cgi
A    freetz-trunk/make/hd-idle/files/root/etc
A    freetz-trunk/make/hd-idle/files/root/etc/init.d
A    freetz-trunk/make/hd-idle/files/root/etc/init.d/rc.hd-idle
A    freetz-trunk/make/hd-idle/files/root/etc/default.hd-idle
A    freetz-trunk/make/hd-idle/files/root/etc/default.hd-idle/hd-idle.cfg
A    freetz-trunk/make/hd-idle/patches
A    freetz-trunk/make/hd-idle/patches/100-unnecessary_include.patch
A    freetz-trunk/make/hd-idle/Config.in
A    freetz-trunk/make/hd-idle/hd-idle.mk
A    freetz-trunk/make/espeak
A    freetz-trunk/make/espeak/files
A    freetz-trunk/make/espeak/files/root
A    freetz-trunk/make/espeak/files/root/usr
A    freetz-trunk/make/espeak/files/root/usr/share
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/default
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/croak
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m3
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m4
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m5
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/whisper
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m6
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f1
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f2
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f3
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/f4
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/fast
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m1
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/voices/!v/m2
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/de_dict
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/phontab
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/phonindex
A    freetz-trunk/make/espeak/files/root/usr/share/espeak-data/phondata
A    freetz-trunk/make/espeak/external.files
A    freetz-trunk/make/espeak/external.in
A    freetz-trunk/make/espeak/patches
A    freetz-trunk/make/espeak/patches/100-mipsel.patch
A    freetz-trunk/make/espeak/Config.in
A    freetz-trunk/make/espeak/espeak.mk
A    freetz-trunk/make/jamvm
A    freetz-trunk/make/jamvm/jamvm.mk
A    freetz-trunk/make/jamvm/external.files
A    freetz-trunk/make/jamvm/external.in
A    freetz-trunk/make/jamvm/patches
A    freetz-trunk/make/jamvm/patches/010-allow_mips.patch
A    freetz-trunk/make/jamvm/patches/001-heap_size.patch
A    freetz-trunk/make/jamvm/Config.in
A    freetz-trunk/make/Config.in
A    freetz-trunk/make/streamripper
A    freetz-trunk/make/streamripper/files
A    freetz-trunk/make/streamripper/files/.language
A    freetz-trunk/make/streamripper/files/root
A    freetz-trunk/make/streamripper/files/root/usr
A    freetz-trunk/make/streamripper/files/root/usr/lib
A    freetz-trunk/make/streamripper/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/streamripper/files/root/usr/lib/cgi-bin/streamripper
A    freetz-trunk/make/streamripper/files/root/usr/lib/cgi-bin/streamripper/log.cgi
A    freetz-trunk/make/streamripper/files/root/usr/lib/cgi-bin/streamripper.cgi
A    freetz-trunk/make/streamripper/files/root/etc
A    freetz-trunk/make/streamripper/files/root/etc/default.streamripper
A    freetz-trunk/make/streamripper/files/root/etc/default.streamripper/filter.def
A    freetz-trunk/make/streamripper/files/root/etc/default.streamripper/streamripper.cfg
A    freetz-trunk/make/streamripper/files/root/etc/init.d
A    freetz-trunk/make/streamripper/files/root/etc/init.d/rc.streamripper
A    freetz-trunk/make/streamripper/external.files
A    freetz-trunk/make/streamripper/streamripper.mk
A    freetz-trunk/make/streamripper/external.services
A    freetz-trunk/make/streamripper/external.in
A    freetz-trunk/make/streamripper/patches
A    freetz-trunk/make/streamripper/patches/200-prototypes.patch
A    freetz-trunk/make/streamripper/patches/100-cross_compile.patch
A    freetz-trunk/make/streamripper/Config.in
A    freetz-trunk/make/sundtek
A    freetz-trunk/make/sundtek/files
A    freetz-trunk/make/sundtek/files/.language
A    freetz-trunk/make/sundtek/files/root
A    freetz-trunk/make/sundtek/files/root/usr
A    freetz-trunk/make/sundtek/files/root/usr/lib
A    freetz-trunk/make/sundtek/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/sundtek/files/root/usr/lib/cgi-bin/sundtek.cgi
A    freetz-trunk/make/sundtek/files/root/etc
A    freetz-trunk/make/sundtek/files/root/etc/default.sundtek
A    freetz-trunk/make/sundtek/files/root/etc/default.sundtek/sundtek.cfg
A    freetz-trunk/make/sundtek/files/root/etc/init.d
A    freetz-trunk/make/sundtek/files/root/etc/init.d/rc.sundtek
A    freetz-trunk/make/sundtek/sundtek.mk
A    freetz-trunk/make/sundtek/Config.in
A    freetz-trunk/make/lighttpd
A    freetz-trunk/make/lighttpd/files
A    freetz-trunk/make/lighttpd/files/.language
A    freetz-trunk/make/lighttpd/files/root
A    freetz-trunk/make/lighttpd/files/root/usr
A    freetz-trunk/make/lighttpd/files/root/usr/lib
A    freetz-trunk/make/lighttpd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/lighttpd/files/root/usr/lib/cgi-bin/lighttpd
A    freetz-trunk/make/lighttpd/files/root/usr/lib/cgi-bin/lighttpd/lighttpd-log.cgi
A    freetz-trunk/make/lighttpd/files/root/usr/lib/cgi-bin/lighttpd.cgi
A    freetz-trunk/make/lighttpd/files/root/usr/bin
A    freetz-trunk/make/lighttpd/files/root/usr/bin/lighttpd_usersave
A    freetz-trunk/make/lighttpd/files/root/etc
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_ca.def
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_add.def
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_conf
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_crt.def
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_user.def
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd_rights.def
A    freetz-trunk/make/lighttpd/files/root/etc/default.lighttpd/lighttpd.cfg
A    freetz-trunk/make/lighttpd/files/root/etc/init.d
A    freetz-trunk/make/lighttpd/files/root/etc/init.d/rc.lighttpd
A    freetz-trunk/make/lighttpd/files/README
A    freetz-trunk/make/lighttpd/external.files
A    freetz-trunk/make/lighttpd/external.services
A    freetz-trunk/make/lighttpd/lighttpd.mk
A    freetz-trunk/make/lighttpd/external.in
A    freetz-trunk/make/lighttpd/patches
A    freetz-trunk/make/lighttpd/patches/020-missing_includes__missing_wrong_ifdefs.patch
A    freetz-trunk/make/lighttpd/patches/015-proper-ERR_error_string_usage.patch
A    freetz-trunk/make/lighttpd/patches/200-openssl-alternative.patch
A    freetz-trunk/make/lighttpd/patches/010-uuid_pic.patch
A    freetz-trunk/make/lighttpd/patches/300-pthread_main_binary.patch
A    freetz-trunk/make/lighttpd/Config.in
A    freetz-trunk/make/screen
A    freetz-trunk/make/screen/files
A    freetz-trunk/make/screen/files/root
A    freetz-trunk/make/screen/files/root/usr
A    freetz-trunk/make/screen/files/root/usr/bin
A    freetz-trunk/make/screen/files/root/usr/bin/screen
A    freetz-trunk/make/screen/files/README
A    freetz-trunk/make/screen/external.files
A    freetz-trunk/make/screen/screen.mk
A    freetz-trunk/make/screen/external.in
A    freetz-trunk/make/screen/patches
A    freetz-trunk/make/screen/patches/100-cross_compile_fix.patch
A    freetz-trunk/make/screen/patches/102-encoding.c.patch
A    freetz-trunk/make/screen/Config.in
A    freetz-trunk/make/vnstat-cgi
A    freetz-trunk/make/vnstat-cgi/files
A    freetz-trunk/make/vnstat-cgi/files/.language
A    freetz-trunk/make/vnstat-cgi/files/root
A    freetz-trunk/make/vnstat-cgi/files/root/usr
A    freetz-trunk/make/vnstat-cgi/files/root/usr/lib
A    freetz-trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat
A    freetz-trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat/stats.cgi
A    freetz-trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat/index.cgi
A    freetz-trunk/make/vnstat-cgi/files/root/usr/lib/cgi-bin/vnstat.cgi
A    freetz-trunk/make/vnstat-cgi/files/root/usr/bin
A    freetz-trunk/make/vnstat-cgi/files/root/usr/bin/webcfg-vns
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww/vnspix
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns/style
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns/images
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns/vnspix
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns/cgi-bin
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns/cgi-bin/index.cgi
A    freetz-trunk/make/vnstat-cgi/files/root/usr/mww-vns/favicon.ico
A    freetz-trunk/make/vnstat-cgi/files/root/etc
A    freetz-trunk/make/vnstat-cgi/files/root/etc/default.vnstat
A    freetz-trunk/make/vnstat-cgi/files/root/etc/default.vnstat/vnstat_conf.def
A    freetz-trunk/make/vnstat-cgi/files/root/etc/default.vnstat/webcfg-vns.inetd
A    freetz-trunk/make/vnstat-cgi/files/root/etc/default.vnstat/httpd-vns_conf
A    freetz-trunk/make/vnstat-cgi/files/root/etc/default.vnstat/vnstat.cfg
A    freetz-trunk/make/vnstat-cgi/files/root/etc/init.d
A    freetz-trunk/make/vnstat-cgi/files/root/etc/init.d/rc.vnstat
A    freetz-trunk/make/vnstat-cgi/external.services
A    freetz-trunk/make/vnstat-cgi/vnstat-cgi.mk
A    freetz-trunk/make/vnstat-cgi/Config.in
A    freetz-trunk/make/nagios
A    freetz-trunk/make/nagios/files
A    freetz-trunk/make/nagios/files/root
A    freetz-trunk/make/nagios/files/root/etc
A    freetz-trunk/make/nagios/files/root/etc/default.nagios
A    freetz-trunk/make/nagios/files/root/etc/default.nagios/commands.cfg
A    freetz-trunk/make/nagios/files/root/etc/default.nagios/cgi.cfg
A    freetz-trunk/make/nagios/files/root/etc/default.nagios/resource.cfg
A    freetz-trunk/make/nagios/files/root/etc/default.nagios/localhost.cfg
A    freetz-trunk/make/nagios/files/root/etc/default.nagios/nagios.cfg
A    freetz-trunk/make/nagios/nagios.mk
A    freetz-trunk/make/nagios/Config.in
A    freetz-trunk/make/python
A    freetz-trunk/make/python/external.in.libs
A    freetz-trunk/make/python/python-module-macros.mk.in
A    freetz-trunk/make/python/Config.in.libs
A    freetz-trunk/make/python/files
A    freetz-trunk/make/python/files/root
A    freetz-trunk/make/python/files/root/usr
A    freetz-trunk/make/python/files/root/usr/bin
A    freetz-trunk/make/python/files/root/usr/bin/python2.7
A    freetz-trunk/make/python/external.files
A    freetz-trunk/make/python/patches
A    freetz-trunk/make/python/patches/040-dont-import-cross-compiled-modules.openwrt.patch
A    freetz-trunk/make/python/patches/330-compileall-hostpython.patch
A    freetz-trunk/make/python/patches/350-readline-termcap.patch
A    freetz-trunk/make/python/patches/320-regen.patch
A    freetz-trunk/make/python/patches/080-distutils-dont_adjust_files.openwrt.patch
A    freetz-trunk/make/python/patches/110-zlib-as-builtin-module.openwrt.patch
A    freetz-trunk/make/python/patches/150-no-sqlite-rpath.openwrt.patch
A    freetz-trunk/make/python/patches/370-no-libdb-rpath.freetz.patch
A    freetz-trunk/make/python/patches/030-fixup-include-dirs.openwrt.patch
A    freetz-trunk/make/python/patches/000-cross-compile.openwrt.patch
A    freetz-trunk/make/python/patches/140-verbose-sharedmods.openwrt.patch
A    freetz-trunk/make/python/patches/310-disable_epoll.freetz.patch
A    freetz-trunk/make/python/patches/360-detect_modules-CROSS_TOOLCHAIN_SYSROOT.freetz.patch
A    freetz-trunk/make/python/patches/130-readline-setup.openwrt.patch
A    freetz-trunk/make/python/patches/300-dlopen_DYNLOADFILE_fix.freetz.patch
A    freetz-trunk/make/python/python.mk
A    freetz-trunk/make/python/python-filelists.mk.in
A    freetz-trunk/make/Makefile.in
A    freetz-trunk/make/checkmaild
A    freetz-trunk/make/checkmaild/files
A    freetz-trunk/make/checkmaild/files/.language
A    freetz-trunk/make/checkmaild/files/root
A    freetz-trunk/make/checkmaild/files/root/usr
A    freetz-trunk/make/checkmaild/files/root/usr/lib
A    freetz-trunk/make/checkmaild/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/checkmaild/files/root/usr/lib/cgi-bin/checkmaild.cgi
A    freetz-trunk/make/checkmaild/files/root/etc
A    freetz-trunk/make/checkmaild/files/root/etc/init.d
A    freetz-trunk/make/checkmaild/files/root/etc/init.d/rc.checkmaild
A    freetz-trunk/make/checkmaild/files/root/etc/default.checkmaild
A    freetz-trunk/make/checkmaild/files/root/etc/default.checkmaild/mailactions.def
A    freetz-trunk/make/checkmaild/files/root/etc/default.checkmaild/checkmaild.cfg
A    freetz-trunk/make/checkmaild/files/root/etc/default.checkmaild/mailactions-phone.example
A    freetz-trunk/make/checkmaild/files/root/etc/default.checkmaild/mailactions.default
A    freetz-trunk/make/checkmaild/files/root/etc/default.checkmaild/checkmaild_conf
A    freetz-trunk/make/checkmaild/external.files
A    freetz-trunk/make/checkmaild/external.services
A    freetz-trunk/make/checkmaild/external.in
A    freetz-trunk/make/checkmaild/Config.in
A    freetz-trunk/make/checkmaild/checkmaild.mk
A    freetz-trunk/make/netpbm
A    freetz-trunk/make/netpbm/external.in.libs
A    freetz-trunk/make/netpbm/Config.in.libs
A    freetz-trunk/make/netpbm/external.files
A    freetz-trunk/make/netpbm/patches
A    freetz-trunk/make/netpbm/patches/00-no_xml2-config_libpng-config_calls.patch
A    freetz-trunk/make/netpbm/patches/01-Makefile.config.patch
A    freetz-trunk/make/netpbm/netpbm.mk
A    freetz-trunk/make/openvpn
A    freetz-trunk/make/openvpn/files
A    freetz-trunk/make/openvpn/files/.language
A    freetz-trunk/make/openvpn/files/root
A    freetz-trunk/make/openvpn/files/root/usr
A    freetz-trunk/make/openvpn/files/root/usr/lib
A    freetz-trunk/make/openvpn/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/openvpn/files/root/usr/lib/cgi-bin/openvpn
A    freetz-trunk/make/openvpn/files/root/usr/lib/cgi-bin/openvpn/openvpn_clients.cgi
A    freetz-trunk/make/openvpn/files/root/usr/lib/cgi-bin/openvpn.cgi
A    freetz-trunk/make/openvpn/files/root/etc
A    freetz-trunk/make/openvpn/files/root/etc/init.d
A    freetz-trunk/make/openvpn/files/root/etc/init.d/rc.openvpn
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/openvpn.save
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/openvpn.cfg
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/ca_crt.def
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/dh_pem.def
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/openvpn_conf
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/static_key.def
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/box_crt.def
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/box_key.def
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/crl_pem.def
A    freetz-trunk/make/openvpn/files/root/etc/default.openvpn/openvpn_dynamic_conf
A    freetz-trunk/make/openvpn/files/README
A    freetz-trunk/make/openvpn/external.files
A    freetz-trunk/make/openvpn/external.services
A    freetz-trunk/make/openvpn/external.in
A    freetz-trunk/make/openvpn/patches
A    freetz-trunk/make/openvpn/patches/2.3.0
A    freetz-trunk/make/openvpn/patches/2.3.0/010-tcp_disconnect_fix.upstream.patch
A    freetz-trunk/make/openvpn/patches/2.3.0/200-no_in6addr_any_in_libc_without_IPv6_fix.patch
A    freetz-trunk/make/openvpn/patches/2.3.0/220-polarssl-1.2.x-support.patch
A    freetz-trunk/make/openvpn/patches/2.3.0/210-disable_epoll_poll_use_select.patch
A    freetz-trunk/make/openvpn/patches/2.2.2
A    freetz-trunk/make/openvpn/patches/2.2.2/200-no_in6addr_any_in_libc_without_IPv6_fix.patch
A    freetz-trunk/make/openvpn/patches/2.2.2/101-ipv6_payload_support.patch
A    freetz-trunk/make/openvpn/patches/2.2.2/100-ipv6_support.patch
A    freetz-trunk/make/openvpn/patches/2.2.2/210-disable_epoll_poll_use_select.patch
A    freetz-trunk/make/openvpn/Config.in
A    freetz-trunk/make/openvpn/openvpn.mk
A    freetz-trunk/make/tinyproxy
A    freetz-trunk/make/tinyproxy/files
A    freetz-trunk/make/tinyproxy/files/.language
A    freetz-trunk/make/tinyproxy/files/root
A    freetz-trunk/make/tinyproxy/files/root/usr
A    freetz-trunk/make/tinyproxy/files/root/usr/mww_tinyproxy
A    freetz-trunk/make/tinyproxy/files/root/usr/mww_tinyproxy/cgi-bin
A    freetz-trunk/make/tinyproxy/files/root/usr/mww_tinyproxy/cgi-bin/proxy.cgi
A    freetz-trunk/make/tinyproxy/files/root/usr/lib
A    freetz-trunk/make/tinyproxy/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/tinyproxy/files/root/usr/lib/cgi-bin/tinyproxy.cgi
A    freetz-trunk/make/tinyproxy/files/root/etc
A    freetz-trunk/make/tinyproxy/files/root/etc/init.d
A    freetz-trunk/make/tinyproxy/files/root/etc/init.d/rc.tinyproxy
A    freetz-trunk/make/tinyproxy/files/root/etc/default.tinyproxy
A    freetz-trunk/make/tinyproxy/files/root/etc/default.tinyproxy/tinyproxy.cfg
A    freetz-trunk/make/tinyproxy/files/root/etc/default.tinyproxy/tinyproxy_conf
A    freetz-trunk/make/tinyproxy/files/README
A    freetz-trunk/make/tinyproxy/external.files
A    freetz-trunk/make/tinyproxy/external.services
A    freetz-trunk/make/tinyproxy/external.in
A    freetz-trunk/make/tinyproxy/patches
A    freetz-trunk/make/tinyproxy/patches/130-fix_tmp_to_var_tmp.patch
A    freetz-trunk/make/tinyproxy/patches/120-fix_INET6.patch
A    freetz-trunk/make/tinyproxy/patches/020-config_and_pid-path.patch
A    freetz-trunk/make/tinyproxy/patches/030-no_libnsl_no_libresolv.patch
A    freetz-trunk/make/tinyproxy/patches/010-no-docs-and-tests.patch
A    freetz-trunk/make/tinyproxy/Config.in
A    freetz-trunk/make/tinyproxy/tinyproxy.mk
A    freetz-trunk/make/dvbstream
A    freetz-trunk/make/dvbstream/patches
A    freetz-trunk/make/dvbstream/patches/10-Makefile.patch
A    freetz-trunk/make/dvbstream/Config.in
A    freetz-trunk/make/dvbstream/dvbstream.mk
A    freetz-trunk/make/unrar
A    freetz-trunk/make/unrar/external.files
A    freetz-trunk/make/unrar/external.in
A    freetz-trunk/make/unrar/patches
A    freetz-trunk/make/unrar/patches/01-disable_exceptions.patch
A    freetz-trunk/make/unrar/patches/02-disable_strip.patch
A    freetz-trunk/make/unrar/Config.in
A    freetz-trunk/make/unrar/unrar.mk
A    freetz-trunk/make/irssi
A    freetz-trunk/make/irssi/irssi.mk
A    freetz-trunk/make/irssi/external.files
A    freetz-trunk/make/irssi/external.in
A    freetz-trunk/make/irssi/Config.in
A    freetz-trunk/make/iputils
A    freetz-trunk/make/iputils/iputils.mk
A    freetz-trunk/make/iputils/Config.in
A    freetz-trunk/make/spawn-fcgi
A    freetz-trunk/make/spawn-fcgi/external.files
A    freetz-trunk/make/spawn-fcgi/spawn-fcgi.mk
A    freetz-trunk/make/spawn-fcgi/external.in
A    freetz-trunk/make/spawn-fcgi/Config.in
A    freetz-trunk/make/synce-serial
A    freetz-trunk/make/synce-serial/synce-serial.mk
A    freetz-trunk/make/synce-serial/patches
A    freetz-trunk/make/synce-serial/patches/100-scripts_location.patch
A    freetz-trunk/make/synce-serial/Config.in
A    freetz-trunk/make/unfs3
A    freetz-trunk/make/unfs3/files
A    freetz-trunk/make/unfs3/files/.language
A    freetz-trunk/make/unfs3/files/root
A    freetz-trunk/make/unfs3/files/root/usr
A    freetz-trunk/make/unfs3/files/root/usr/lib
A    freetz-trunk/make/unfs3/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/unfs3/files/root/usr/lib/cgi-bin/unfs3.cgi
A    freetz-trunk/make/unfs3/files/root/etc
A    freetz-trunk/make/unfs3/files/root/etc/default.unfs3
A    freetz-trunk/make/unfs3/files/root/etc/default.unfs3/exports.def
A    freetz-trunk/make/unfs3/files/root/etc/default.unfs3/hosts_allow.def
A    freetz-trunk/make/unfs3/files/root/etc/default.unfs3/hosts_deny.def
A    freetz-trunk/make/unfs3/files/root/etc/default.unfs3/unfs3.cfg
A    freetz-trunk/make/unfs3/files/root/etc/init.d
A    freetz-trunk/make/unfs3/files/root/etc/init.d/rc.unfs3
A    freetz-trunk/make/unfs3/files/root/etc/hosts.allow
A    freetz-trunk/make/unfs3/files/root/etc/hosts.deny
A    freetz-trunk/make/unfs3/unfs3.mk
A    freetz-trunk/make/unfs3/patches
A    freetz-trunk/make/unfs3/patches/100-noyywrap.patch
A    freetz-trunk/make/unfs3/Config.in
A    freetz-trunk/make/nano-shell
A    freetz-trunk/make/nano-shell/files
A    freetz-trunk/make/nano-shell/files/root
A    freetz-trunk/make/nano-shell/files/root/usr
A    freetz-trunk/make/nano-shell/files/root/usr/www
A    freetz-trunk/make/nano-shell/files/root/usr/www/all
A    freetz-trunk/make/nano-shell/files/root/usr/www/all/cgi-bin
A    freetz-trunk/make/nano-shell/files/root/usr/www/all/cgi-bin/shell.cgi
A    freetz-trunk/make/nano-shell/files/root/usr/bin
A    freetz-trunk/make/nano-shell/files/root/usr/bin/shell.cgi
A    freetz-trunk/make/nano-shell/files/root/usr/mww
A    freetz-trunk/make/nano-shell/files/root/usr/mww/cgi-bin
A    freetz-trunk/make/nano-shell/files/root/usr/mww/cgi-bin/shell.cgi
A    freetz-trunk/make/nano-shell/files/README
A    freetz-trunk/make/nano-shell/nano-shell.mk
A    freetz-trunk/make/nano-shell/Config.in
A    freetz-trunk/make/ccid
A    freetz-trunk/make/ccid/ccid.mk
A    freetz-trunk/make/ccid/Config.in
A    freetz-trunk/make/fuse
A    freetz-trunk/make/fuse/external.in.libs
A    freetz-trunk/make/fuse/Config.in.libs
A    freetz-trunk/make/fuse/external.files
A    freetz-trunk/make/fuse/patches
A    freetz-trunk/make/fuse/patches/140-no_bb_mount.patch
A    freetz-trunk/make/fuse/patches/102-no_depmod.patch
A    freetz-trunk/make/fuse/patches/112-no_break_on_mknod.patch
A    freetz-trunk/make/fuse/fuse.mk
A    freetz-trunk/make/netatalk
A    freetz-trunk/make/netatalk/files
A    freetz-trunk/make/netatalk/files/.language
A    freetz-trunk/make/netatalk/files/root
A    freetz-trunk/make/netatalk/files/root/usr
A    freetz-trunk/make/netatalk/files/root/usr/lib
A    freetz-trunk/make/netatalk/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/netatalk/files/root/usr/lib/cgi-bin/netatalk.cgi
A    freetz-trunk/make/netatalk/files/root/etc
A    freetz-trunk/make/netatalk/files/root/etc/init.d
A    freetz-trunk/make/netatalk/files/root/etc/init.d/rc.netatalk
A    freetz-trunk/make/netatalk/files/root/etc/init.d/rc.cnid_metad
A    freetz-trunk/make/netatalk/files/root/etc/init.d/rc.afpd
A    freetz-trunk/make/netatalk/files/root/etc/default.netatalk
A    freetz-trunk/make/netatalk/files/root/etc/default.netatalk/netatalk.cfg
A    freetz-trunk/make/netatalk/files/root/etc/default.netatalk/afpd_conf_conf
A    freetz-trunk/make/netatalk/files/root/etc/default.netatalk/applevolumes_default_conf
A    freetz-trunk/make/netatalk/files/root/etc/default.netatalk/afpd_conf.def
A    freetz-trunk/make/netatalk/files/root/etc/default.netatalk/applevolumes_default.def
A    freetz-trunk/make/netatalk/external.files
A    freetz-trunk/make/netatalk/external.services
A    freetz-trunk/make/netatalk/external.in
A    freetz-trunk/make/netatalk/patches
A    freetz-trunk/make/netatalk/patches/010-AI_NUMERICSERV.patch
A    freetz-trunk/make/netatalk/patches/030-configure_no_export.patch
A    freetz-trunk/make/netatalk/netatalk.mk
A    freetz-trunk/make/netatalk/Config.in
A    freetz-trunk/make/iptables/patches
A    freetz-trunk/make/iptables/patches/006-iprange-typesh.patch
A    freetz-trunk/make/iptables/patches/007_add_IPT_ALIGN.patch
A    freetz-trunk/make/iptables/patches/010_no_ipv6_if_disabled.patch
A    freetz-trunk/make/iptables/patches/004-multiport_v1.patch
A    freetz-trunk/make/iptables/patches/2.6.13.1
A    freetz-trunk/make/iptables/patches/009_switch_XML_SAVE_RESTORE.patch
A    freetz-trunk/make/iptables/patches/001-ipp2p-0.8.2.patch
A    freetz-trunk/make/iptables/patches/008_fix_exit_error.patch
A    freetz-trunk/make/iptables/patches/2.6.19.2
A    freetz-trunk/make/iptables/patches/2.6.19.2/define_PROC_SUPER_MAGIC.patch
A    freetz-trunk/make/iptables/patches/2.6.19.2/layer7_2.19.patch
A    freetz-trunk/make/iptables/patches/2.6.28
A    freetz-trunk/make/iptables/patches/2.6.28/layer7_2.22.patch
A    freetz-trunk/make/iptables/iptables.mk
A    freetz-trunk/make/iptables/Config.in
A    freetz-trunk/make/iptables/standard-modules.in
A    freetz-trunk/make/inetd
A    freetz-trunk/make/inetd/files
A    freetz-trunk/make/inetd/files/.language
A    freetz-trunk/make/inetd/files/root
A    freetz-trunk/make/inetd/files/root/bin
A    freetz-trunk/make/inetd/files/root/bin/inetdctl
A    freetz-trunk/make/inetd/files/root/bin/inetdsamba
A    freetz-trunk/make/inetd/files/root/bin/inetdftp
A    freetz-trunk/make/inetd/files/root/usr
A    freetz-trunk/make/inetd/files/root/usr/lib
A    freetz-trunk/make/inetd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/inetd/files/root/usr/lib/cgi-bin/inetd.cgi
A    freetz-trunk/make/inetd/files/root/etc
A    freetz-trunk/make/inetd/files/root/etc/default.ftpd
A    freetz-trunk/make/inetd/files/root/etc/default.ftpd/ftpd.inetd
A    freetz-trunk/make/inetd/files/root/etc/default.webcfg
A    freetz-trunk/make/inetd/files/root/etc/default.webcfg/webcfg.inetd
A    freetz-trunk/make/inetd/files/root/etc/default.telnetd
A    freetz-trunk/make/inetd/files/root/etc/default.telnetd/telnetd.inetd
A    freetz-trunk/make/inetd/files/root/etc/init.d
A    freetz-trunk/make/inetd/files/root/etc/init.d/rc.inetd
A    freetz-trunk/make/inetd/files/root/etc/init.d/modlibinetd
A    freetz-trunk/make/inetd/files/root/etc/default.inetd
A    freetz-trunk/make/inetd/files/root/etc/default.inetd/inetd.save
A    freetz-trunk/make/inetd/files/root/etc/default.inetd/inetd.cfg
A    freetz-trunk/make/inetd/files/root/etc/default.inetd/inetd_conf.def
A    freetz-trunk/make/inetd/files/root/etc/default.inetd/inetd_user.def
A    freetz-trunk/make/inetd/files/root/etc/inetd.conf
A    freetz-trunk/make/inetd/files/root/etc/default.smbd
A    freetz-trunk/make/inetd/files/root/etc/default.smbd/smbd-139.inetd
A    freetz-trunk/make/inetd/files/root/etc/default.smbd/smbd-445.inetd
A    freetz-trunk/make/inetd/files/root/etc/default.websrv
A    freetz-trunk/make/inetd/files/root/etc/default.websrv/websrv.inetd
A    freetz-trunk/make/inetd/inetd.mk
A    freetz-trunk/make/inetd/Config.in
A    freetz-trunk/make/apache2
A    freetz-trunk/make/apache2/external.files
A    freetz-trunk/make/apache2/external.in
A    freetz-trunk/make/apache2/patches
A    freetz-trunk/make/apache2/patches/040-always-check-for-openssl.patch
A    freetz-trunk/make/apache2/patches/030-apr-util-check.patch
A    freetz-trunk/make/apache2/patches/100-hostmake.patch
A    freetz-trunk/make/apache2/patches/200-apxs-cross-compile-hacks.patch
A    freetz-trunk/make/apache2/apache2.mk
A    freetz-trunk/make/apache2/Config.in
A    freetz-trunk/make/dtmfbox/files
A    freetz-trunk/make/dtmfbox/files/root
A    freetz-trunk/make/dtmfbox/files/root/etc
A    freetz-trunk/make/dtmfbox/files/root/etc/init.d
A    freetz-trunk/make/dtmfbox/files/root/etc/init.d/rc.dtmfbox
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg/dtmfbox.cfg
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg/menu.cfg
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/cfg/script.cfg
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_cbct.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_reverse.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/espeak.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_radio.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_weather.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/callthrough.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/am_setup.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/funcs.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_anticallcenter.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_ctrl5.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/action_am.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/am_funcs.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_checkmaild.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/misc_fb.sh
A    freetz-trunk/make/dtmfbox/files/root/etc/default.dtmfbox/script/am_admin.sh
A    freetz-trunk/make/dtmfbox/files/README
A    freetz-trunk/make/dtmfbox/external.files
A    freetz-trunk/make/dtmfbox/external.in
A    freetz-trunk/make/dtmfbox/patches
A    freetz-trunk/make/dtmfbox/patches/020-check_for_null_ptr.patch
A    freetz-trunk/make/dtmfbox/patches/060-extra_flags.patch
A    freetz-trunk/make/dtmfbox/patches/010-no_host_paths.patch
A    freetz-trunk/make/dtmfbox/patches/030-plugin_execute_cmd-fixes.patch
A    freetz-trunk/make/dtmfbox/dtmfbox.mk
A    freetz-trunk/make/dtmfbox/Config.in
A    freetz-trunk/make/quagga
A    freetz-trunk/make/quagga/files
A    freetz-trunk/make/quagga/files/.language
A    freetz-trunk/make/quagga/files/root
A    freetz-trunk/make/quagga/files/root/usr
A    freetz-trunk/make/quagga/files/root/usr/lib
A    freetz-trunk/make/quagga/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/quagga/files/root/usr/lib/cgi-bin/quagga.cgi
A    freetz-trunk/make/quagga/files/root/etc
A    freetz-trunk/make/quagga/files/root/etc/init.d
A    freetz-trunk/make/quagga/files/root/etc/init.d/quagga
A    freetz-trunk/make/quagga/files/root/etc/init.d/rc.quagga
A    freetz-trunk/make/quagga/files/root/etc/default.quagga
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/ripd_conf.def
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/ospf6d_conf.def
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/quagga.cfg
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/ripngd_conf.def
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/zebra_conf.def
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/isisd_conf.def
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/ospfd_conf.def
A    freetz-trunk/make/quagga/files/root/etc/default.quagga/bgpd_conf.def
A    freetz-trunk/make/quagga/files/README
A    freetz-trunk/make/quagga/patches
A    freetz-trunk/make/quagga/patches/011-fix-cpp.patch
A    freetz-trunk/make/quagga/patches/100-quagga_multipath_caching_policy.patch
A    freetz-trunk/make/quagga/patches/101-incorrect_func_pow_test.patch
A    freetz-trunk/make/quagga/patches/120-fix-ipv6.patch
A    freetz-trunk/make/quagga/patches/010-fix-ipctl-forwarding.patch
A    freetz-trunk/make/quagga/patches/110-holdtimer-set.patch
A    freetz-trunk/make/quagga/Config.in
A    freetz-trunk/make/quagga/quagga.mk
A    freetz-trunk/make/xrelayd
A    freetz-trunk/make/xrelayd/files
A    freetz-trunk/make/xrelayd/files/.language
A    freetz-trunk/make/xrelayd/files/root
A    freetz-trunk/make/xrelayd/files/root/usr
A    freetz-trunk/make/xrelayd/files/root/usr/lib
A    freetz-trunk/make/xrelayd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/xrelayd/files/root/usr/lib/cgi-bin/xrelayd.cgi
A    freetz-trunk/make/xrelayd/files/root/etc
A    freetz-trunk/make/xrelayd/files/root/etc/init.d
A    freetz-trunk/make/xrelayd/files/root/etc/init.d/rc.xrelayd
A    freetz-trunk/make/xrelayd/files/root/etc/default.xrelayd
A    freetz-trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd_svcs.def
A    freetz-trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd_certchain.def
A    freetz-trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd.cfg
A    freetz-trunk/make/xrelayd/files/root/etc/default.xrelayd/xrelayd_key.def
A    freetz-trunk/make/xrelayd/patches
A    freetz-trunk/make/xrelayd/patches/020-polarssl-0.x.x-to-1.x.x.patch
A    freetz-trunk/make/xrelayd/patches/030-polarssl-1.2.x.patch
A    freetz-trunk/make/xrelayd/patches/010-use-polarssl.patch
A    freetz-trunk/make/xrelayd/patches/040-make-genstuff-optional.patch
A    freetz-trunk/make/xrelayd/Config.in
A    freetz-trunk/make/xrelayd/xrelayd.mk
A    freetz-trunk/make/htop
A    freetz-trunk/make/htop/htop.mk
A    freetz-trunk/make/htop/external.files
A    freetz-trunk/make/htop/external.in
A    freetz-trunk/make/htop/patches
A    freetz-trunk/make/htop/patches/010-ioprio_support.patch
A    freetz-trunk/make/htop/Config.in
A    freetz-trunk/make/haserl
A    freetz-trunk/make/haserl/haserl.mk
A    freetz-trunk/make/haserl/patches
A    freetz-trunk/make/haserl/patches/100-lualib_inc.patch
A    freetz-trunk/make/haserl/Config.in
A    freetz-trunk/make/xsltproc
A    freetz-trunk/make/xsltproc/external.in.libs
A    freetz-trunk/make/xsltproc/Config.in.libs
A    freetz-trunk/make/xsltproc/external.files
A    freetz-trunk/make/xsltproc/xsltproc.mk
A    freetz-trunk/make/xsltproc/patches
A    freetz-trunk/make/xsltproc/patches/100-no_docs_mans_tests.patch
A    freetz-trunk/make/virtualip-cgi
A    freetz-trunk/make/virtualip-cgi/files
A    freetz-trunk/make/virtualip-cgi/files/.language
A    freetz-trunk/make/virtualip-cgi/files/root
A    freetz-trunk/make/virtualip-cgi/files/root/usr
A    freetz-trunk/make/virtualip-cgi/files/root/usr/lib
A    freetz-trunk/make/virtualip-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/virtualip-cgi/files/root/usr/lib/cgi-bin/virtualip.cgi
A    freetz-trunk/make/virtualip-cgi/files/root/etc
A    freetz-trunk/make/virtualip-cgi/files/root/etc/default.virtualip
A    freetz-trunk/make/virtualip-cgi/files/root/etc/default.virtualip/virtualip.cfg
A    freetz-trunk/make/virtualip-cgi/files/root/etc/init.d
A    freetz-trunk/make/virtualip-cgi/files/root/etc/init.d/rc.virtualip
A    freetz-trunk/make/virtualip-cgi/files/README
A    freetz-trunk/make/virtualip-cgi/virtualip-cgi.mk
A    freetz-trunk/make/virtualip-cgi/Config.in
A    freetz-trunk/make/vnstat/external.files
A    freetz-trunk/make/vnstat/vnstat.mk
A    freetz-trunk/make/vnstat/external.in
A    freetz-trunk/make/vnstat/Config.in
A    freetz-trunk/make/phpxmail
A    freetz-trunk/make/phpxmail/files
A    freetz-trunk/make/phpxmail/files/.language
A    freetz-trunk/make/phpxmail/files/root
A    freetz-trunk/make/phpxmail/files/root/usr
A    freetz-trunk/make/phpxmail/files/root/usr/lib
A    freetz-trunk/make/phpxmail/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/phpxmail/files/root/usr/lib/cgi-bin/phpxmail.cgi
A    freetz-trunk/make/phpxmail/files/root/usr/mww
A    freetz-trunk/make/phpxmail/files/root/usr/mww/phpxmail
A    freetz-trunk/make/phpxmail/files/root/usr/mww/phpxmail/servers.php
A    freetz-trunk/make/phpxmail/files/root/usr/mww/phpxmail/config.php
A    freetz-trunk/make/phpxmail/files/root/etc
A    freetz-trunk/make/phpxmail/files/root/etc/default.phpxmail
A    freetz-trunk/make/phpxmail/files/root/etc/default.phpxmail/phpxmail.save
A    freetz-trunk/make/phpxmail/files/root/etc/default.phpxmail/phpxmail.cfg
A    freetz-trunk/make/phpxmail/files/root/etc/init.d
A    freetz-trunk/make/phpxmail/files/root/etc/init.d/rc.phpxmail
A    freetz-trunk/make/phpxmail/patches
A    freetz-trunk/make/phpxmail/patches/100-modsave.patch
A    freetz-trunk/make/phpxmail/phpxmail.mk
A    freetz-trunk/make/phpxmail/Config.in
A    freetz-trunk/make/oidentd
A    freetz-trunk/make/oidentd/files
A    freetz-trunk/make/oidentd/files/.language
A    freetz-trunk/make/oidentd/files/root
A    freetz-trunk/make/oidentd/files/root/usr
A    freetz-trunk/make/oidentd/files/root/usr/lib
A    freetz-trunk/make/oidentd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/oidentd/files/root/usr/lib/cgi-bin/oidentd.cgi
A    freetz-trunk/make/oidentd/files/root/etc
A    freetz-trunk/make/oidentd/files/root/etc/init.d
A    freetz-trunk/make/oidentd/files/root/etc/init.d/rc.oidentd
A    freetz-trunk/make/oidentd/files/root/etc/default.oidentd
A    freetz-trunk/make/oidentd/files/root/etc/default.oidentd/oidentd.cfg
A    freetz-trunk/make/oidentd/files/root/etc/default.oidentd/oidentd.inetd
A    freetz-trunk/make/oidentd/files/root/etc/default.oidentd/oidentd_conf.def
A    freetz-trunk/make/oidentd/external.files
A    freetz-trunk/make/oidentd/external.services
A    freetz-trunk/make/oidentd/external.in
A    freetz-trunk/make/oidentd/patches
A    freetz-trunk/make/oidentd/patches/010-inline_std_gnu99.patch
A    freetz-trunk/make/oidentd/Config.in
A    freetz-trunk/make/oidentd/oidentd.mk
A    freetz-trunk/make/stunnel
A    freetz-trunk/make/stunnel/files
A    freetz-trunk/make/stunnel/files/.language
A    freetz-trunk/make/stunnel/files/root
A    freetz-trunk/make/stunnel/files/root/usr
A    freetz-trunk/make/stunnel/files/root/usr/lib
A    freetz-trunk/make/stunnel/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/stunnel/files/root/usr/lib/cgi-bin/stunnel.cgi
A    freetz-trunk/make/stunnel/files/root/etc
A    freetz-trunk/make/stunnel/files/root/etc/init.d
A    freetz-trunk/make/stunnel/files/root/etc/init.d/rc.stunnel
A    freetz-trunk/make/stunnel/files/root/etc/default.stunnel
A    freetz-trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_svcs.def
A    freetz-trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_certchain.def
A    freetz-trunk/make/stunnel/files/root/etc/default.stunnel/stunnel.cfg
A    freetz-trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_conf
A    freetz-trunk/make/stunnel/files/root/etc/default.stunnel/stunnel_key.def
A    freetz-trunk/make/stunnel/external.files
A    freetz-trunk/make/stunnel/external.services
A    freetz-trunk/make/stunnel/external.in
A    freetz-trunk/make/stunnel/patches
A    freetz-trunk/make/stunnel/patches/400-openssl-alternative.patch.TODO
A    freetz-trunk/make/stunnel/patches/300-ocsp-missing-ifdef.patch
A    freetz-trunk/make/stunnel/patches/100-kerberos_include.patch
A    freetz-trunk/make/stunnel/patches/450-cross_compilation.patch
A    freetz-trunk/make/stunnel/patches/200-default-values.patch
A    freetz-trunk/make/stunnel/Config.in
A    freetz-trunk/make/stunnel/stunnel.mk
A    freetz-trunk/make/libs
A    freetz-trunk/make/libs/mpc
A    freetz-trunk/make/libs/mpc/Makefile.in
A    freetz-trunk/make/libs/mpc/external.files
A    freetz-trunk/make/libs/mpc/mpc.mk
A    freetz-trunk/make/libs/mpc/external.in
A    freetz-trunk/make/libs/mpc/patches
A    freetz-trunk/make/libs/mpc/patches/100-no_docs_no_tests.mpc.patch
A    freetz-trunk/make/libs/mpc/Config.in
A    freetz-trunk/make/libs/protobuf-c
A    freetz-trunk/make/libs/protobuf-c/Makefile.in
A    freetz-trunk/make/libs/protobuf-c/external.files
A    freetz-trunk/make/libs/protobuf-c/protobuf-c.mk
A    freetz-trunk/make/libs/protobuf-c/external.in
A    freetz-trunk/make/libs/protobuf-c/Config.in
A    freetz-trunk/make/libs/uclibcxx
A    freetz-trunk/make/libs/uclibcxx/Makefile.in
A    freetz-trunk/make/libs/uclibcxx/external.files
A    freetz-trunk/make/libs/uclibcxx/external.in
A    freetz-trunk/make/libs/uclibcxx/patches
A    freetz-trunk/make/libs/uclibcxx/patches/010-fpos_not_equal_fix.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/050-gcc47x-proper-two-phase-lookup.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/040-iostream_wchar_support.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/400-eabi_fix.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/020-avoid_not_equal.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/900-dependent_exception.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/009-compile_fixes.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/010-bitset_fix.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/030-istream_long_long_support.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/patches/300-wrapper.uclibcxx.patch
A    freetz-trunk/make/libs/uclibcxx/Config.in
A    freetz-trunk/make/libs/uclibcxx/Config.uclibc++
A    freetz-trunk/make/libs/uclibcxx/uclibc++.mk
A    freetz-trunk/make/libs/popt
A    freetz-trunk/make/libs/popt/Makefile.in
A    freetz-trunk/make/libs/popt/external.files
A    freetz-trunk/make/libs/popt/external.in
A    freetz-trunk/make/libs/popt/patches
A    freetz-trunk/make/libs/popt/patches/110-Makefile.popt.patch
A    freetz-trunk/make/libs/popt/patches/120-gnu_glob.popt.patch
A    freetz-trunk/make/libs/popt/patches/100-configure.popt.patch
A    freetz-trunk/make/libs/popt/popt.mk
A    freetz-trunk/make/libs/popt/Config.in
A    freetz-trunk/make/libs/libexif
A    freetz-trunk/make/libs/libexif/Makefile.in
A    freetz-trunk/make/libs/libexif/external.files
A    freetz-trunk/make/libs/libexif/external.in
A    freetz-trunk/make/libs/libexif/patches
A    freetz-trunk/make/libs/libexif/patches/100-no_docs.libexif.patch
A    freetz-trunk/make/libs/libexif/libexif.mk
A    freetz-trunk/make/libs/libexif/Config.in
A    freetz-trunk/make/libs/apr
A    freetz-trunk/make/libs/apr/Makefile.in
A    freetz-trunk/make/libs/apr/external.files
A    freetz-trunk/make/libs/apr/external.in
A    freetz-trunk/make/libs/apr/patches
A    freetz-trunk/make/libs/apr/patches/010-uuid_pic.apr.patch
A    freetz-trunk/make/libs/apr/apr.mk
A    freetz-trunk/make/libs/apr/Config.in
A    freetz-trunk/make/libs/ncurses
A    freetz-trunk/make/libs/ncurses/Makefile.in
A    freetz-trunk/make/libs/ncurses/external.files
A    freetz-trunk/make/libs/ncurses/external.in
A    freetz-trunk/make/libs/ncurses/patches
A    freetz-trunk/make/libs/ncurses/patches/100-PKG_CONFIG_LIBDIR_contains_DESTDIR.ncurses.patch
A    freetz-trunk/make/libs/ncurses/patches/005-emdebian-wchar.ncurses.patch
A    freetz-trunk/make/libs/ncurses/patches/130-terminfo-rxvt-unicode.ncurses.patch
A    freetz-trunk/make/libs/ncurses/patches/120-terminfo-konsole.ncurses.patch
A    freetz-trunk/make/libs/ncurses/patches/110-terminfo-kbs.ncurses.patch
A    freetz-trunk/make/libs/ncurses/ncurses.mk
A    freetz-trunk/make/libs/ncurses/Config.in
A    freetz-trunk/make/libs/ncurses/ncurses-Config.in
A    freetz-trunk/make/libs/freetype
A    freetz-trunk/make/libs/freetype/Makefile.in
A    freetz-trunk/make/libs/freetype/external.files
A    freetz-trunk/make/libs/freetype/external.in
A    freetz-trunk/make/libs/freetype/freetype.mk
A    freetz-trunk/make/libs/freetype/Config.in
A    freetz-trunk/make/libs/libosip2
A    freetz-trunk/make/libs/libosip2/Makefile.in
A    freetz-trunk/make/libs/libosip2/external.files
A    freetz-trunk/make/libs/libosip2/external.in
A    freetz-trunk/make/libs/libosip2/patches
A    freetz-trunk/make/libs/libosip2/patches/010-multiple_CFLAGS.libosip2.patch
A    freetz-trunk/make/libs/libosip2/libosip2.mk
A    freetz-trunk/make/libs/libosip2/Config.in
A    freetz-trunk/make/libs/wxWidgets
A    freetz-trunk/make/libs/wxWidgets/Makefile.in
A    freetz-trunk/make/libs/wxWidgets/external.files
A    freetz-trunk/make/libs/wxWidgets/external.in
A    freetz-trunk/make/libs/wxWidgets/patches
A    freetz-trunk/make/libs/wxWidgets/patches/101-no_optimize_flags.wxWidgets.patch
A    freetz-trunk/make/libs/wxWidgets/patches/100-wx-config-DESTDIR.wxWidgets.patch
A    freetz-trunk/make/libs/wxWidgets/patches/110-build_static_lib_along_with_shared.wxWidgets.patch
A    freetz-trunk/make/libs/wxWidgets/Config.in
A    freetz-trunk/make/libs/wxWidgets/wxWidgets.mk
A    freetz-trunk/make/libs/jpeg
A    freetz-trunk/make/libs/jpeg/Makefile.in
A    freetz-trunk/make/libs/jpeg/external.files
A    freetz-trunk/make/libs/jpeg/external.in
A    freetz-trunk/make/libs/jpeg/patches
A    freetz-trunk/make/libs/jpeg/patches/100-config_guess.jpeg.patch
A    freetz-trunk/make/libs/jpeg/Config.in
A    freetz-trunk/make/libs/jpeg/jpeg.mk
A    freetz-trunk/make/libs/opus
A    freetz-trunk/make/libs/opus/Makefile.in
A    freetz-trunk/make/libs/opus/external.files
A    freetz-trunk/make/libs/opus/external.in
A    freetz-trunk/make/libs/opus/Config.in
A    freetz-trunk/make/libs/opus/opus.mk
A    freetz-trunk/make/libs/sysfsutils
A    freetz-trunk/make/libs/sysfsutils/Makefile.in
A    freetz-trunk/make/libs/sysfsutils/external.files
A    freetz-trunk/make/libs/sysfsutils/external.in
A    freetz-trunk/make/libs/sysfsutils/Config.in
A    freetz-trunk/make/libs/sysfsutils/sysfsutils.mk
A    freetz-trunk/make/libs/libmad
A    freetz-trunk/make/libs/libmad/Makefile.in
A    freetz-trunk/make/libs/libmad/external.files
A    freetz-trunk/make/libs/libmad/external.in
A    freetz-trunk/make/libs/libmad/patches
A    freetz-trunk/make/libs/libmad/patches/100-configure.libmad.patch
A    freetz-trunk/make/libs/libmad/patches/001-mips_removal_h_constraint.libmad.patch
A    freetz-trunk/make/libs/libmad/Config.in
A    freetz-trunk/make/libs/libmad/libmad.mk
A    freetz-trunk/make/libs/libdaemon
A    freetz-trunk/make/libs/libdaemon/libdaemon.mk
A    freetz-trunk/make/libs/libdaemon/Makefile.in
A    freetz-trunk/make/libs/libdaemon/external.files
A    freetz-trunk/make/libs/libdaemon/external.in
A    freetz-trunk/make/libs/libdaemon/Config.in
A    freetz-trunk/make/libs/neon
A    freetz-trunk/make/libs/neon/Makefile.in
A    freetz-trunk/make/libs/neon/external.files
A    freetz-trunk/make/libs/neon/neon.mk
A    freetz-trunk/make/libs/neon/external.in
A    freetz-trunk/make/libs/neon/patches
A    freetz-trunk/make/libs/neon/patches/110-no_libintl.neon.patch
A    freetz-trunk/make/libs/neon/patches/120-dont-cache-openssl-version-dependent-values.neon.patch
A    freetz-trunk/make/libs/neon/patches/100-no_docs.neon.patch
A    freetz-trunk/make/libs/neon/Config.in
A    freetz-trunk/make/libs/libgcrypt
A    freetz-trunk/make/libs/libgcrypt/Makefile.in
A    freetz-trunk/make/libs/libgcrypt/external.files
A    freetz-trunk/make/libs/libgcrypt/libgcrypt.mk
A    freetz-trunk/make/libs/libgcrypt/external.in
A    freetz-trunk/make/libs/libgcrypt/patches
A    freetz-trunk/make/libs/libgcrypt/patches/002-no_docs_tests.libgcrypt.patch
A    freetz-trunk/make/libs/libgcrypt/Config.in
A    freetz-trunk/make/libs/polarssl
A    freetz-trunk/make/libs/polarssl/Makefile.in
A    freetz-trunk/make/libs/polarssl/external.files
A    freetz-trunk/make/libs/polarssl/polarssl.mk
A    freetz-trunk/make/libs/polarssl/external.in
A    freetz-trunk/make/libs/polarssl/patches
A    freetz-trunk/make/libs/polarssl/patches/100-shared.polarssl.patch
A    freetz-trunk/make/libs/polarssl/patches/200-x509write.polarssl.patch
A    freetz-trunk/make/libs/polarssl/patches/300-blowfish-openssl-compat.polarssl.patch
A    freetz-trunk/make/libs/polarssl/patches/020-reduce_size.polarssl.patch
A    freetz-trunk/make/libs/polarssl/Config.in
A    freetz-trunk/make/libs/zlib
A    freetz-trunk/make/libs/zlib/Makefile.in
A    freetz-trunk/make/libs/zlib/external.files
A    freetz-trunk/make/libs/zlib/zlib.mk
A    freetz-trunk/make/libs/zlib/external.in
A    freetz-trunk/make/libs/zlib/patches
A    freetz-trunk/make/libs/zlib/patches/120-four_byte_unsigned_int.zlib.patch
A    freetz-trunk/make/libs/zlib/patches/110-configure_no_exit.zlib.patch
A    freetz-trunk/make/libs/zlib/Config.in
A    freetz-trunk/make/libs/uclibc/Config.in
A    freetz-trunk/make/libs/pkcs11
A    freetz-trunk/make/libs/pkcs11/pkcs11.mk
A    freetz-trunk/make/libs/lzo
A    freetz-trunk/make/libs/lzo/Makefile.in
A    freetz-trunk/make/libs/lzo/external.files
A    freetz-trunk/make/libs/lzo/external.in
A    freetz-trunk/make/libs/lzo/Config.in
A    freetz-trunk/make/libs/lzo/lzo.mk
A    freetz-trunk/make/libs/libsynce
A    freetz-trunk/make/libs/libsynce/Makefile.in
A    freetz-trunk/make/libs/libsynce/external.files
A    freetz-trunk/make/libs/libsynce/external.in
A    freetz-trunk/make/libs/libsynce/Config.in
A    freetz-trunk/make/libs/libsynce/libsynce.mk
A    freetz-trunk/make/libs/bluez-libs
A    freetz-trunk/make/libs/bluez-libs/Makefile.in
A    freetz-trunk/make/libs/bluez-libs/external.files
A    freetz-trunk/make/libs/bluez-libs/external.in
A    freetz-trunk/make/libs/bluez-libs/Config.in
A    freetz-trunk/make/libs/bluez-libs/bluez-libs.mk
A    freetz-trunk/make/libs/libevent
A    freetz-trunk/make/libs/libevent/Makefile.in
A    freetz-trunk/make/libs/libevent/external.files
A    freetz-trunk/make/libs/libevent/external.in
A    freetz-trunk/make/libs/libevent/patches
A    freetz-trunk/make/libs/libevent/patches/upstream-b7577868a8975fa17d77cf438141884bf081a6b2.libevent.patch
A    freetz-trunk/make/libs/libevent/patches/010-no_unnecessary_libs_sample_test_pyscripts.libevent.patch
A    freetz-trunk/make/libs/libevent/patches/020-openssl_test_fix.libevent.patch
A    freetz-trunk/make/libs/libevent/Config.in
A    freetz-trunk/make/libs/libevent/libevent.mk
A    freetz-trunk/make/libs/libxml2
A    freetz-trunk/make/libs/libxml2/libxml2.mk
A    freetz-trunk/make/libs/libxml2/Makefile.in
A    freetz-trunk/make/libs/libxml2/external.files
A    freetz-trunk/make/libs/libxml2/external.in
A    freetz-trunk/make/libs/libxml2/patches
A    freetz-trunk/make/libs/libxml2/patches/100-no_docs_examples_tests.libxml2.patch
A    freetz-trunk/make/libs/libxml2/patches/110-pthread_fixes.libxml2.patch
A    freetz-trunk/make/libs/libxml2/Config.in
A    freetz-trunk/make/libs/attr
A    freetz-trunk/make/libs/attr/attr.mk
A    freetz-trunk/make/libs/attr/Makefile.in
A    freetz-trunk/make/libs/attr/external.files
A    freetz-trunk/make/libs/attr/external.in
A    freetz-trunk/make/libs/attr/patches
A    freetz-trunk/make/libs/attr/patches/10-allow-DESTDIR.attr.patch
A    freetz-trunk/make/libs/attr/patches/05-eliminate_a_memory_leak.attr.patch
A    freetz-trunk/make/libs/attr/patches/03-pull_in_string.h.attr.patch
A    freetz-trunk/make/libs/attr/patches/07-fix_thinko_in_restore.attr.patch
A    freetz-trunk/make/libs/attr/patches/02-fix_memory_leak_in_attr_copy_action.attr.patch
A    freetz-trunk/make/libs/attr/patches/06-eliminate_a_double_free.attr.patch
A    freetz-trunk/make/libs/attr/Config.in
A    freetz-trunk/make/libs/libctlmgr
A    freetz-trunk/make/libs/libctlmgr/Makefile.in
A    freetz-trunk/make/libs/libctlmgr/libctlmgr.mk
A    freetz-trunk/make/libs/libctlmgr/src
A    freetz-trunk/make/libs/libctlmgr/src/libctlmgr.c
A    freetz-trunk/make/libs/libctlmgr/src/Makefile
A    freetz-trunk/make/libs/libctlmgr/Config.in
A    freetz-trunk/make/libs/libdnet
A    freetz-trunk/make/libs/libdnet/Makefile.in
A    freetz-trunk/make/libs/libdnet/external.files
A    freetz-trunk/make/libs/libdnet/external.in
A    freetz-trunk/make/libs/libdnet/libdnet.mk
A    freetz-trunk/make/libs/libdnet/patches
A    freetz-trunk/make/libs/libdnet/patches/040-socklen_t.nmap_backport.libdnet.patch
A    freetz-trunk/make/libs/libdnet/patches/040-missing_part_of_r654.nmap_backport.libdnet.patch
A    freetz-trunk/make/libs/libdnet/patches/010-missing_tags.libdnet.patch
A    freetz-trunk/make/libs/libdnet/patches/030-no_man_python_test.libdnet.patch
A    freetz-trunk/make/libs/libdnet/patches/050-install_sctp_h.libdnet.patch
A    freetz-trunk/make/libs/libdnet/patches/020-dnet-config.libdnet.patch
A    freetz-trunk/make/libs/libdnet/patches/050-name_collision_sctp_h.libdnet.patch
A    freetz-trunk/make/libs/libdnet/Config.in
A    freetz-trunk/make/libs/gmp
A    freetz-trunk/make/libs/gmp/Makefile.in
A    freetz-trunk/make/libs/gmp/external.files
A    freetz-trunk/make/libs/gmp/external.in
A    freetz-trunk/make/libs/gmp/patches
A    freetz-trunk/make/libs/gmp/patches/100-no_tests_no_demos_no_docs.gmp.patch
A    freetz-trunk/make/libs/gmp/patches/010-dont_test_for_cxx_if_no_cxx_requested.gmp.patch
A    freetz-trunk/make/libs/gmp/gmp.mk
A    freetz-trunk/make/libs/gmp/Config.in
A    freetz-trunk/make/libs/gettext
A    freetz-trunk/make/libs/gettext/Makefile.in
A    freetz-trunk/make/libs/gettext/external.files
A    freetz-trunk/make/libs/gettext/external.in
A    freetz-trunk/make/libs/gettext/Config.in
A    freetz-trunk/make/libs/gettext/gettext.mk
A    freetz-trunk/make/libs/matrixssl
A    freetz-trunk/make/libs/matrixssl/Makefile.in
A    freetz-trunk/make/libs/matrixssl/external.files
A    freetz-trunk/make/libs/matrixssl/external.in
A    freetz-trunk/make/libs/matrixssl/Config.in
A    freetz-trunk/make/libs/matrixssl/matrixssl.mk
A    freetz-trunk/make/libs/pcre
A    freetz-trunk/make/libs/pcre/pcre.mk
A    freetz-trunk/make/libs/pcre/Makefile.in
A    freetz-trunk/make/libs/pcre/external.files
A    freetz-trunk/make/libs/pcre/external.in
A    freetz-trunk/make/libs/pcre/patches
A    freetz-trunk/make/libs/pcre/patches/100-no_docs_no_man.pcre.patch
A    freetz-trunk/make/libs/pcre/patches/110-unnecessary-tests.pcre.patch
A    freetz-trunk/make/libs/pcre/patches/750-pcre_config_cross.pcre.patch
A    freetz-trunk/make/libs/pcre/Config.in
A    freetz-trunk/make/libs/gd
A    freetz-trunk/make/libs/gd/gd.mk
A    freetz-trunk/make/libs/gd/Makefile.in
A    freetz-trunk/make/libs/gd/external.files
A    freetz-trunk/make/libs/gd/external.in
A    freetz-trunk/make/libs/gd/patches
A    freetz-trunk/make/libs/gd/patches/0004_fix_fprint_string_formatting.debian.gd.patch
A    freetz-trunk/make/libs/gd/patches/0010-additional_attributes.php.gd.patch
A    freetz-trunk/make/libs/gd/patches/0003_fix_support_large_images.debian.gd.patch
A    freetz-trunk/make/libs/gd/patches/0002_CVE-2009-3546.debian.gd.patch
A    freetz-trunk/make/libs/gd/patches/0001_fix_leak_in_gdImageCopyResized.debian.gd.patch
A    freetz-trunk/make/libs/gd/Config.in
A    freetz-trunk/make/libs/pjproject
A    freetz-trunk/make/libs/pjproject/Makefile.in
A    freetz-trunk/make/libs/pjproject/pjproject.mk
A    freetz-trunk/make/libs/pjproject/patches
A    freetz-trunk/make/libs/pjproject/patches/120-no_uuid.pjproject.patch
A    freetz-trunk/make/libs/pjproject/patches/100-stat_wav.pjproject.patch
A    freetz-trunk/make/libs/pjproject/patches/101-no-test.pjproject.patch
A    freetz-trunk/make/libs/pjproject/Config.in
A    freetz-trunk/make/libs/libusb1
A    freetz-trunk/make/libs/libusb1/Makefile.in
A    freetz-trunk/make/libs/libusb1/external.files
A    freetz-trunk/make/libs/libusb1/external.in
A    freetz-trunk/make/libs/libusb1/libusb1.mk
A    freetz-trunk/make/libs/libusb1/Config.in
A    freetz-trunk/make/libs/taglib
A    freetz-trunk/make/libs/taglib/Makefile.in
A    freetz-trunk/make/libs/taglib/external.files
A    freetz-trunk/make/libs/taglib/external.in
A    freetz-trunk/make/libs/taglib/patches
A    freetz-trunk/make/libs/taglib/patches/030-no-debug-warnings.taglib.patch
A    freetz-trunk/make/libs/taglib/patches/010-missing_not_equal_operator.taglib.patch
A    freetz-trunk/make/libs/taglib/patches/020-missing_libm.taglib.patch
A    freetz-trunk/make/libs/taglib/patches/100-no_libdir.uclibcxx.patch
A    freetz-trunk/make/libs/taglib/taglib.mk
A    freetz-trunk/make/libs/taglib/Config.in
A    freetz-trunk/make/libs/libid3tag
A    freetz-trunk/make/libs/libid3tag/Makefile.in
A    freetz-trunk/make/libs/libid3tag/external.files
A    freetz-trunk/make/libs/libid3tag/external.in
A    freetz-trunk/make/libs/libid3tag/patches
A    freetz-trunk/make/libs/libid3tag/patches/100-makefile.libid3tag.patch
A    freetz-trunk/make/libs/libid3tag/patches/100-configure_cflags.libid3tag.patch
A    freetz-trunk/make/libs/libid3tag/libid3tag.mk
A    freetz-trunk/make/libs/libid3tag/Config.in
A    freetz-trunk/make/libs/libavmhmac
A    freetz-trunk/make/libs/libavmhmac/Makefile.in
A    freetz-trunk/make/libs/libavmhmac/libavmhmac.mk
A    freetz-trunk/make/libs/libavmhmac/Config.in
A    freetz-trunk/make/libs/libtool
A    freetz-trunk/make/libs/libtool/Makefile.in
A    freetz-trunk/make/libs/libtool/external.files
A    freetz-trunk/make/libs/libtool/external.in
A    freetz-trunk/make/libs/libtool/patches
A    freetz-trunk/make/libs/libtool/patches/001-force_dlopen_deplibs.libtool.patch
A    freetz-trunk/make/libs/libtool/patches/100-libdir_path.libtool.patch
A    freetz-trunk/make/libs/libtool/patches/130-no_recheck.libtool.patch
A    freetz-trunk/make/libs/libtool/patches/200-package-specific-dlerror-test.libtool.patch
A    freetz-trunk/make/libs/libtool/patches/110-no_rpath.libtool.patch
A    freetz-trunk/make/libs/libtool/patches/120-libdir_search.libtool.patch
A    freetz-trunk/make/libs/libtool/Config.in
A    freetz-trunk/make/libs/libtool/libtool.mk
A    freetz-trunk/make/libs/libftdi
A    freetz-trunk/make/libs/libftdi/Makefile.in
A    freetz-trunk/make/libs/libftdi/external.files
A    freetz-trunk/make/libs/libftdi/libftdi.mk
A    freetz-trunk/make/libs/libftdi/external.in
A    freetz-trunk/make/libs/libftdi/patches
A    freetz-trunk/make/libs/libftdi/patches/100-no_docs.libftdi.patch
A    freetz-trunk/make/libs/libftdi/Config.in
A    freetz-trunk/make/libs/linux-atm
A    freetz-trunk/make/libs/linux-atm/Makefile.in
A    freetz-trunk/make/libs/linux-atm/external.files
A    freetz-trunk/make/libs/linux-atm/linux-atm.mk
A    freetz-trunk/make/libs/linux-atm/external.in
A    freetz-trunk/make/libs/linux-atm/patches
A    freetz-trunk/make/libs/linux-atm/patches/100-build_lib_only.linux-atm.patch
A    freetz-trunk/make/libs/linux-atm/patches/005-no_libresolv.linux-atm.patch
A    freetz-trunk/make/libs/linux-atm/Config.in
A    freetz-trunk/make/libs/expat
A    freetz-trunk/make/libs/expat/Makefile.in
A    freetz-trunk/make/libs/expat/external.files
A    freetz-trunk/make/libs/expat/expat.mk
A    freetz-trunk/make/libs/expat/external.in
A    freetz-trunk/make/libs/expat/patches
A    freetz-trunk/make/libs/expat/patches/560-901_CVE_2009_3560.expat.patch
A    freetz-trunk/make/libs/expat/patches/551-936_CVE_2009_2625.expat.patch
A    freetz-trunk/make/libs/expat/patches/302-191_install_expat_config_h.expat.patch
A    freetz-trunk/make/libs/expat/Config.in
A    freetz-trunk/make/libs/db
A    freetz-trunk/make/libs/db/Makefile.in
A    freetz-trunk/make/libs/db/external.files
A    freetz-trunk/make/libs/db/external.in
A    freetz-trunk/make/libs/db/patches
A    freetz-trunk/make/libs/db/patches/100-no_docs.db.patch
A    freetz-trunk/make/libs/db/Config.in
A    freetz-trunk/make/libs/db/db.mk
A    freetz-trunk/make/libs/libart_lgpl
A    freetz-trunk/make/libs/libart_lgpl/libart_lgpl.mk
A    freetz-trunk/make/libs/libart_lgpl/Makefile.in
A    freetz-trunk/make/libs/libart_lgpl/external.files
A    freetz-trunk/make/libs/libart_lgpl/external.in
A    freetz-trunk/make/libs/libart_lgpl/Config.in
A    freetz-trunk/make/libs/libgpg-error
A    freetz-trunk/make/libs/libgpg-error/libgpg-error.mk
A    freetz-trunk/make/libs/libgpg-error/Makefile.in
A    freetz-trunk/make/libs/libgpg-error/external.files
A    freetz-trunk/make/libs/libgpg-error/external.in
A    freetz-trunk/make/libs/libgpg-error/patches
A    freetz-trunk/make/libs/libgpg-error/patches/110-gnu_source__reentrant.libgpg-error.patch
A    freetz-trunk/make/libs/libgpg-error/patches/100-libtool.libgpg-error.patch
A    freetz-trunk/make/libs/libgpg-error/Config.in
A    freetz-trunk/make/libs/libvorbis
A    freetz-trunk/make/libs/libvorbis/libvorbis.mk
A    freetz-trunk/make/libs/libvorbis/Makefile.in
A    freetz-trunk/make/libs/libvorbis/external.files
A    freetz-trunk/make/libs/libvorbis/external.in
A    freetz-trunk/make/libs/libvorbis/patches
A    freetz-trunk/make/libs/libvorbis/patches/100-no_docs.libvorbis.patch
A    freetz-trunk/make/libs/libvorbis/patches/200-remove51.libvorbis.patch
A    freetz-trunk/make/libs/libvorbis/Config.in
A    freetz-trunk/make/libs/libconfig
A    freetz-trunk/make/libs/libconfig/Makefile.in
A    freetz-trunk/make/libs/libconfig/libconfig.mk
A    freetz-trunk/make/libs/libconfig/external.files
A    freetz-trunk/make/libs/libconfig/external.in
A    freetz-trunk/make/libs/libconfig/patches
A    freetz-trunk/make/libs/libconfig/patches/010-nodocs-notests.libconfig.patch
A    freetz-trunk/make/libs/libconfig/Config.in
A    freetz-trunk/make/libs/apr-util
A    freetz-trunk/make/libs/apr-util/Makefile.in
A    freetz-trunk/make/libs/apr-util/apr-util.mk
A    freetz-trunk/make/libs/apr-util/external.files
A    freetz-trunk/make/libs/apr-util/external.in
A    freetz-trunk/make/libs/apr-util/patches
A    freetz-trunk/make/libs/apr-util/patches/100-apu-config.apr-util.patch
A    freetz-trunk/make/libs/apr-util/Config.in
A    freetz-trunk/make/libs/glib2
A    freetz-trunk/make/libs/glib2/Makefile.in
A    freetz-trunk/make/libs/glib2/external.files
A    freetz-trunk/make/libs/glib2/glib2.mk
A    freetz-trunk/make/libs/glib2/external.in
A    freetz-trunk/make/libs/glib2/patches
A    freetz-trunk/make/libs/glib2/patches/030-no_in6addr_vars_in_libc_without_IPv6.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/120-unnecessary-GLIB_COMPILES.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/200-no_nls.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/300-configure-tests-unconditional-includes.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/010-pkgconfig-no-privates.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/110-drop-DBUS-dependency.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/020-no-tests-no-docs.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/100-drop-PYTHON-dependency.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/320-drop-libelf-dependency.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/310-fix-ac_cv_alignof-tests.glib2.patch
A    freetz-trunk/make/libs/glib2/patches/050-configure_generated_libtool_call.glib2.patch
A    freetz-trunk/make/libs/glib2/Config.in
A    freetz-trunk/make/libs/libcapi
A    freetz-trunk/make/libs/libcapi/Makefile.in
A    freetz-trunk/make/libs/libcapi/external.files
A    freetz-trunk/make/libs/libcapi/external.in
A    freetz-trunk/make/libs/libcapi/libcapi.mk
A    freetz-trunk/make/libs/libcapi/Config.in
A    freetz-trunk/make/libs/libogg
A    freetz-trunk/make/libs/libogg/Makefile.in
A    freetz-trunk/make/libs/libogg/external.files
A    freetz-trunk/make/libs/libogg/external.in
A    freetz-trunk/make/libs/libogg/patches
A    freetz-trunk/make/libs/libogg/patches/100-no_docs.libogg.patch
A    freetz-trunk/make/libs/libogg/patches/110-no_opt_cflags.libogg.patch
A    freetz-trunk/make/libs/libogg/libogg.mk
A    freetz-trunk/make/libs/libogg/Config.in
A    freetz-trunk/make/libs/liboping
A    freetz-trunk/make/libs/liboping/Makefile.in
A    freetz-trunk/make/libs/liboping/external.files
A    freetz-trunk/make/libs/liboping/external.in
A    freetz-trunk/make/libs/liboping/patches
A    freetz-trunk/make/libs/liboping/patches/110-IPv6_defines.liboping.patch
A    freetz-trunk/make/libs/liboping/patches/100-no-Werror.liboping.patch
A    freetz-trunk/make/libs/liboping/patches/120-IPv6_structs.liboping.patch
A    freetz-trunk/make/libs/liboping/liboping.mk
A    freetz-trunk/make/libs/liboping/Config.in
A    freetz-trunk/make/libs/libstdcxx
A    freetz-trunk/make/libs/libstdcxx/libstdc++.mk
A    freetz-trunk/make/libs/libstdcxx/Makefile.in
A    freetz-trunk/make/libs/libstdcxx/external.files
A    freetz-trunk/make/libs/libstdcxx/external.in
A    freetz-trunk/make/libs/libstdcxx/Config.in
A    freetz-trunk/make/libs/mpfr
A    freetz-trunk/make/libs/mpfr/Makefile.in
A    freetz-trunk/make/libs/mpfr/external.files
A    freetz-trunk/make/libs/mpfr/external.in
A    freetz-trunk/make/libs/mpfr/patches
A    freetz-trunk/make/libs/mpfr/patches/002-patch02_strtofr-ternary-value.mpfr.patch
A    freetz-trunk/make/libs/mpfr/patches/100-no_docs_no_tests.mpfr.patch
A    freetz-trunk/make/libs/mpfr/patches/001-patch01_get_decimal64.mpfr.patch
A    freetz-trunk/make/libs/mpfr/patches/003-patch03-gmp51-compat.mpfr.patch
A    freetz-trunk/make/libs/mpfr/Config.in
A    freetz-trunk/make/libs/mpfr/mpfr.mk
A    freetz-trunk/make/libs/libpcap
A    freetz-trunk/make/libs/libpcap/libpcap.mk
A    freetz-trunk/make/libs/libpcap/Makefile.in
A    freetz-trunk/make/libs/libpcap/external.files
A    freetz-trunk/make/libs/libpcap/external.in
A    freetz-trunk/make/libs/libpcap/patches
A    freetz-trunk/make/libs/libpcap/patches/100-reduce_buffer_size.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/100-shared-lib.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/103-flex_workaround.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/108-no_usb.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/107-no_man.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/105-protocol_api.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/106-fix_pcap-config.libpcap.patch
A    freetz-trunk/make/libs/libpcap/patches/104-space_optimization.libpcap.patch
A    freetz-trunk/make/libs/libpcap/Config.in
A    freetz-trunk/make/libs/libnet
A    freetz-trunk/make/libs/libnet/Makefile.in
A    freetz-trunk/make/libs/libnet/external.files
A    freetz-trunk/make/libs/libnet/libnet.mk
A    freetz-trunk/make/libs/libnet/external.in
A    freetz-trunk/make/libs/libnet/patches
A    freetz-trunk/make/libs/libnet/patches/100-cross-compilation.libnet.patch
A    freetz-trunk/make/libs/libnet/Config.in
A    freetz-trunk/make/libs/openobex
A    freetz-trunk/make/libs/openobex/Makefile.in
A    freetz-trunk/make/libs/openobex/external.files
A    freetz-trunk/make/libs/openobex/openobex.mk
A    freetz-trunk/make/libs/openobex/external.in
A    freetz-trunk/make/libs/openobex/patches
A    freetz-trunk/make/libs/openobex/patches/100-makefile_no_usb.openobex.patch
A    freetz-trunk/make/libs/openobex/Config.in
A    freetz-trunk/make/libs/libusb/Makefile.in
A    freetz-trunk/make/libs/libusb/external.files
A    freetz-trunk/make/libs/libusb/libusb.mk
A    freetz-trunk/make/libs/libusb/external.in
A    freetz-trunk/make/libs/libusb/patches
A    freetz-trunk/make/libs/libusb/patches/100-fix_dirs.libusb.patch
A    freetz-trunk/make/libs/libusb/patches/01-no_libusbpp.libusb.patch
A    freetz-trunk/make/libs/libusb/Config.in
A    freetz-trunk/make/libs/readline
A    freetz-trunk/make/libs/readline/Makefile.in
A    freetz-trunk/make/libs/readline/external.files
A    freetz-trunk/make/libs/readline/external.in
A    freetz-trunk/make/libs/readline/patches
A    freetz-trunk/make/libs/readline/patches/120-curses-link.readline.patch
A    freetz-trunk/make/libs/readline/patches/110-no_old_libs.readline.patch
A    freetz-trunk/make/libs/readline/patches/001-no_doc__no_examples.readline.patch
A    freetz-trunk/make/libs/readline/patches/001-no_rpath.readline.patch
A    freetz-trunk/make/libs/readline/patches/101-readline62-001.readline.patch
A    freetz-trunk/make/libs/readline/patches/102-readline62-002.readline.patch
A    freetz-trunk/make/libs/readline/patches/103-readline62-003.readline.patch
A    freetz-trunk/make/libs/readline/patches/104-readline62-004.readline.patch
A    freetz-trunk/make/libs/readline/readline.mk
A    freetz-trunk/make/libs/readline/Config.in
A    freetz-trunk/make/libs/devmapper
A    freetz-trunk/make/libs/devmapper/Makefile.in
A    freetz-trunk/make/libs/devmapper/external.files
A    freetz-trunk/make/libs/devmapper/external.in
A    freetz-trunk/make/libs/devmapper/devmapper.mk
A    freetz-trunk/make/libs/devmapper/Config.in
A    freetz-trunk/make/libs/libmultid
A    freetz-trunk/make/libs/libmultid/Makefile.in
A    freetz-trunk/make/libs/libmultid/src
A    freetz-trunk/make/libs/libmultid/src/libmultid.c
A    freetz-trunk/make/libs/libmultid/src/Makefile
A    freetz-trunk/make/libs/libmultid/Config.in
A    freetz-trunk/make/libs/libmultid/libmultid.mk
A    freetz-trunk/make/libs/external.in
A    freetz-trunk/make/libs/libffi
A    freetz-trunk/make/libs/libffi/libffi.mk
A    freetz-trunk/make/libs/libffi/Makefile.in
A    freetz-trunk/make/libs/libffi/external.files
A    freetz-trunk/make/libs/libffi/external.in
A    freetz-trunk/make/libs/libffi/patches
A    freetz-trunk/make/libs/libffi/patches/010-no-tests-no-docs.libffi.patch
A    freetz-trunk/make/libs/libffi/patches/020-includedir.libffi.patch
A    freetz-trunk/make/libs/libffi/Config.in
A    freetz-trunk/make/libs/libelf
A    freetz-trunk/make/libs/libelf/Makefile.in
A    freetz-trunk/make/libs/libelf/external.files
A    freetz-trunk/make/libs/libelf/libelf.mk
A    freetz-trunk/make/libs/libelf/external.in
A    freetz-trunk/make/libs/libelf/patches
A    freetz-trunk/make/libs/libelf/patches/100-configure.libelf.patch
A    freetz-trunk/make/libs/libelf/Config.in
A    freetz-trunk/make/libs/cyassl
A    freetz-trunk/make/libs/cyassl/Makefile.in
A    freetz-trunk/make/libs/cyassl/external.files
A    freetz-trunk/make/libs/cyassl/cyassl.mk
A    freetz-trunk/make/libs/cyassl/external.in
A    freetz-trunk/make/libs/cyassl/patches
A    freetz-trunk/make/libs/cyassl/patches/030-export_compile_time_defines.cyassl.patch
A    freetz-trunk/make/libs/cyassl/patches/020-missing-pthread-dependency.cyassl.patch
A    freetz-trunk/make/libs/cyassl/patches/010-mark_unsupported_features.cyassl.patch
A    freetz-trunk/make/libs/cyassl/Config.in
A    freetz-trunk/make/libs/yaml
A    freetz-trunk/make/libs/yaml/Makefile.in
A    freetz-trunk/make/libs/yaml/external.files
A    freetz-trunk/make/libs/yaml/external.in
A    freetz-trunk/make/libs/yaml/yaml.mk
A    freetz-trunk/make/libs/yaml/Config.in
A    freetz-trunk/make/libs/libiconv
A    freetz-trunk/make/libs/libiconv/Makefile.in
A    freetz-trunk/make/libs/libiconv/external.files
A    freetz-trunk/make/libs/libiconv/external.in
A    freetz-trunk/make/libs/libiconv/patches
A    freetz-trunk/make/libs/libiconv/patches/100-strip_charsets.libiconv.patch
A    freetz-trunk/make/libs/libiconv/Config.in
A    freetz-trunk/make/libs/libiconv/libiconv.mk
A    freetz-trunk/make/libs/flac
A    freetz-trunk/make/libs/flac/Makefile.in
A    freetz-trunk/make/libs/flac/external.files
A    freetz-trunk/make/libs/flac/external.in
A    freetz-trunk/make/libs/flac/patches
A    freetz-trunk/make/libs/flac/patches/200-CFLAGS.flac.patch
A    freetz-trunk/make/libs/flac/patches/100-no-docs-and-examples.flac.patch
A    freetz-trunk/make/libs/flac/Config.in
A    freetz-trunk/make/libs/flac/flac.mk
A    freetz-trunk/make/libs/libgcc_s
A    freetz-trunk/make/libs/libgcc_s/Makefile.in
A    freetz-trunk/make/libs/libgcc_s/Config.in
A    freetz-trunk/make/libs/libgcc_s/libgcc_s.mk
A    freetz-trunk/make/libs/openjpeg
A    freetz-trunk/make/libs/openjpeg/Makefile.in
A    freetz-trunk/make/libs/openjpeg/external.files
A    freetz-trunk/make/libs/openjpeg/external.in
A    freetz-trunk/make/libs/openjpeg/patches
A    freetz-trunk/make/libs/openjpeg/patches/100-freetz_cflags.openjpeg.patch
A    freetz-trunk/make/libs/openjpeg/Config.in
A    freetz-trunk/make/libs/openjpeg/openjpeg.mk
A    freetz-trunk/make/libs/Config.in
A    freetz-trunk/make/libs/libpng
A    freetz-trunk/make/libs/libpng/libpng.mk
A    freetz-trunk/make/libs/libpng/Makefile.in
A    freetz-trunk/make/libs/libpng/external.files
A    freetz-trunk/make/libs/libpng/external.in
A    freetz-trunk/make/libs/libpng/Config.in
A    freetz-trunk/make/libs/libtasn1
A    freetz-trunk/make/libs/libtasn1/Makefile.in
A    freetz-trunk/make/libs/libtasn1/external.files
A    freetz-trunk/make/libs/libtasn1/libtasn1.mk
A    freetz-trunk/make/libs/libtasn1/external.in
A    freetz-trunk/make/libs/libtasn1/patches
A    freetz-trunk/make/libs/libtasn1/patches/100-lib_only.libtasn1.patch
A    freetz-trunk/make/libs/libtasn1/Config.in
A    freetz-trunk/make/libs/leptonica
A    freetz-trunk/make/libs/leptonica/Makefile.in
A    freetz-trunk/make/libs/leptonica/external.files
A    freetz-trunk/make/libs/leptonica/leptonica.mk
A    freetz-trunk/make/libs/leptonica/external.in
A    freetz-trunk/make/libs/leptonica/patches
A    freetz-trunk/make/libs/leptonica/patches/030-no_demo_code_in_lib.leptonica.patch
A    freetz-trunk/make/libs/leptonica/patches/020-no_xtractprotos.leptonica.patch
A    freetz-trunk/make/libs/leptonica/patches/010-enforce-libpng12.leptonica.patch
A    freetz-trunk/make/libs/leptonica/Config.in
A    freetz-trunk/make/htpdate
A    freetz-trunk/make/htpdate/htpdate.mk
A    freetz-trunk/make/htpdate/files
A    freetz-trunk/make/htpdate/files/.language
A    freetz-trunk/make/htpdate/files/root
A    freetz-trunk/make/htpdate/files/root/usr
A    freetz-trunk/make/htpdate/files/root/usr/lib
A    freetz-trunk/make/htpdate/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/htpdate/files/root/usr/lib/cgi-bin/htpdate.cgi
A    freetz-trunk/make/htpdate/files/root/etc
A    freetz-trunk/make/htpdate/files/root/etc/init.d
A    freetz-trunk/make/htpdate/files/root/etc/init.d/rc.htpdate
A    freetz-trunk/make/htpdate/files/root/etc/default.htpdate
A    freetz-trunk/make/htpdate/files/root/etc/default.htpdate/htpdate.save
A    freetz-trunk/make/htpdate/files/root/etc/default.htpdate/htpdate.cfg
A    freetz-trunk/make/htpdate/files/root/etc/onlinechanged
A    freetz-trunk/make/htpdate/files/root/etc/onlinechanged/10-htpdate
A    freetz-trunk/make/htpdate/patches
A    freetz-trunk/make/htpdate/patches/100_htpdate_c.patch
A    freetz-trunk/make/htpdate/Config.in
A    freetz-trunk/make/br2684ctl
A    freetz-trunk/make/br2684ctl/br2684ctl.mk
A    freetz-trunk/make/br2684ctl/patches
A    freetz-trunk/make/br2684ctl/patches/101-routed_support.patch
A    freetz-trunk/make/br2684ctl/patches/100-debian.patch
A    freetz-trunk/make/br2684ctl/Config.in
A    freetz-trunk/make/README.Makefiles
A    freetz-trunk/make/vtun
A    freetz-trunk/make/vtun/files
A    freetz-trunk/make/vtun/files/.language
A    freetz-trunk/make/vtun/files/root
A    freetz-trunk/make/vtun/files/root/usr
A    freetz-trunk/make/vtun/files/root/usr/lib
A    freetz-trunk/make/vtun/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/vtun/files/root/usr/lib/cgi-bin/vtun.cgi
A    freetz-trunk/make/vtun/files/root/etc
A    freetz-trunk/make/vtun/files/root/etc/default.vtun
A    freetz-trunk/make/vtun/files/root/etc/default.vtun/vtun.cfg
A    freetz-trunk/make/vtun/files/root/etc/init.d
A    freetz-trunk/make/vtun/files/root/etc/init.d/rc.vtun
A    freetz-trunk/make/vtun/vtun.mk
A    freetz-trunk/make/vtun/external.files
A    freetz-trunk/make/vtun/external.services
A    freetz-trunk/make/vtun/external.in
A    freetz-trunk/make/vtun/patches
A    freetz-trunk/make/vtun/patches/110-debian_sslauth.patch
A    freetz-trunk/make/vtun/patches/111-debian_ipv6.patch
A    freetz-trunk/make/vtun/patches/100-extra_ldflags.patch
A    freetz-trunk/make/vtun/Config.in
A    freetz-trunk/make/linux
A    freetz-trunk/make/linux/Config.ur8.7270_04.86
A    freetz-trunk/make/linux/Config.ohio.04.67
A    freetz-trunk/make/linux/Config.ohio.04.76
A    freetz-trunk/make/linux/Config.iks.7390_05.21
A    freetz-trunk/make/linux/Config.ohio.04.87
A    freetz-trunk/make/linux/Makefile.in
A    freetz-trunk/make/linux/Config.iks.7390_05.50
A    freetz-trunk/make/linux/Config.ohio.7140_04.33
A    freetz-trunk/make/linux/kernel.mk
A    freetz-trunk/make/linux/patches
A    freetz-trunk/make/linux/patches/2.6.13.1
A    freetz-trunk/make/linux/patches/2.6.13.1/320-ipp2p_0.8.2.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.ipv6_multicast.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.87
A    freetz-trunk/make/linux/patches/2.6.13.1/04.87/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.87/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/500-unionfs.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/310-autofs4-2.6.13-v5-update-20081027.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-missing_skb_truesize_increment.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/209-mini_fo.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/004-extra_optimization.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/300-mppe-mppc-1.3.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/800-nfsd_custom_port.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.congestion_BIC_b.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/100-evaloader.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.tcp_clamp_window.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/350-kernel-2.6.13-2.6.16-layer7-2.2.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.30
A    freetz-trunk/make/linux/patches/2.6.13.1/04.30/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/101-depmod.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.33
A    freetz-trunk/make/linux/patches/2.6.13.1/04.33/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.70
A    freetz-trunk/make/linux/patches/2.6.13.1/04.70/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.70/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/520-lib-lzo.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.14.x-branch.unlink_expect_leak.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/110-unistd_h_inotify.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/700-cifs-1.45.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/r7203
A    freetz-trunk/make/linux/patches/2.6.13.1/r7203/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.57
A    freetz-trunk/make/linux/patches/2.6.13.1/04.57/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.57/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.76
A    freetz-trunk/make/linux/patches/2.6.13.1/04.76/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.76/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/012-mips_cpu_tlb.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.default_congestion.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/210-jff2nfsexport-2.6.13.1.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/400-ftdi-smartmouse.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.14.x-branch.dont_increase_master_refcount_on_expectations.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/201-ip_conntrack_rtsp_2.6.13.1.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/360-netfilter-ipv6-Backport-ip6t_REJECT-from-2.6.14.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/011-mips_boot.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/900-mute_printk_speedup.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.DHCP_MASQUERADE.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.congestion_BIC.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.wrong_BUG_ON.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/120-capi-missing-compiler-includes.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/999-ip_tables_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.request_key_auth-memleak.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/102-squashfs3.3_lzma.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.40
A    freetz-trunk/make/linux/patches/2.6.13.1/04.40/makefile.lib.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.40/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/710-scall32.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.MPOL_F_VERIFY.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/200-ip_conntrack.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.80
A    freetz-trunk/make/linux/patches/2.6.13.1/04.80/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.80/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/9999-2.6.13.x-branch.putname_memleak.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/130-Add-missing-linux-compiler.h-include-to-blkpg.h.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.49
A    freetz-trunk/make/linux/patches/2.6.13.1/04.49/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.49/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.67
A    freetz-trunk/make/linux/patches/2.6.13.1/04.67/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.13.1/04.67/600-cpmac-ioctl.patch
A    freetz-trunk/make/linux/patches/2.6.32
A    freetz-trunk/make/linux/patches/2.6.32/7330_05.20
A    freetz-trunk/make/linux/patches/2.6.32/7330_05.20/003-pppoatm.c.patch
A    freetz-trunk/make/linux/patches/2.6.32/7330_05.20/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.32/7330_05.20/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.32/7330_05.20/690-no_system-load-1_messages.patch
A    freetz-trunk/make/linux/patches/2.6.32/7330_05.20/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.32/3370_05.21
A    freetz-trunk/make/linux/patches/2.6.32/3370_05.21/003-pppoatm.c.patch
A    freetz-trunk/make/linux/patches/2.6.32/3370_05.21/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.32/3370_05.21/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.32/3370_05.21/690-no_system-load-1_messages.patch
A    freetz-trunk/make/linux/patches/2.6.32/3370_05.21/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.32/022-mips_use_generic_thread_info_allocator.patch
A    freetz-trunk/make/linux/patches/2.6.32/230-cifs_revert_slow_work.patch
A    freetz-trunk/make/linux/patches/2.6.32/300-skbuff-nf_conntrack.patch
A    freetz-trunk/make/linux/patches/2.6.32/400-ftdi-smartmouse.patch
A    freetz-trunk/make/linux/patches/2.6.32/7360_05.20
A    freetz-trunk/make/linux/patches/2.6.32/7360_05.20/003-pppoatm.c.patch
A    freetz-trunk/make/linux/patches/2.6.32/7360_05.20/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.32/7360_05.20/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.32/7360_05.20/690-no_system-load-1_messages.patch
A    freetz-trunk/make/linux/patches/2.6.32/7360_05.20/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21/003-pppoatm.c.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21/500-fix_7270v1_hw_config.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21/690-no_system-load-1_messages.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.21/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.32/009-jffs-fix-min-max-confusion.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.50
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.50/500-fix_7270v1_hw_config.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.50/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.50/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.50/690-no_system-load-1_messages.patch
A    freetz-trunk/make/linux/patches/2.6.32/7270_05.50/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.32/012-extra_optimization.patch
A    freetz-trunk/make/linux/patches/2.6.32/023-mips-fix-kexec.patch
A    freetz-trunk/make/linux/patches/2.6.32/300-mppe-mppc.patch
A    freetz-trunk/make/linux/patches/2.6.32/120-capi-missing-compiler-includes.patch
A    freetz-trunk/make/linux/patches/2.6.32/100-evaloader.patch
A    freetz-trunk/make/linux/patches/2.6.32/010-shell_bash.patch
A    freetz-trunk/make/linux/patches/2.6.32/540-export_scsi_headers.patch
A    freetz-trunk/make/linux/patches/2.6.32/401-ftdi-working.patch
A    freetz-trunk/make/linux/patches/2.6.32/115-netfilter_recent_reap.patch
A    freetz-trunk/make/linux/patches/2.6.32/710-scall32.patch
A    freetz-trunk/make/linux/patches/2.6.32/199-remove_double_hash_conntrack.patch
A    freetz-trunk/make/linux/patches/2.6.32/002-usb_musb_kconfig.patch
A    freetz-trunk/make/linux/patches/2.6.32/001-drivers_dsl_kconfig.patch
A    freetz-trunk/make/linux/patches/2.6.32/100-netfilter_layer7_2.21.patch
A    freetz-trunk/make/linux/patches/2.6.32/530-scsi_user_space.patch
A    freetz-trunk/make/linux/patches/2.6.32/203-slab_maxsize.patch.dont-use
A    freetz-trunk/make/linux/patches/2.6.19.2
A    freetz-trunk/make/linux/patches/2.6.19.2/350-kernel-2.6.18-2.6.19-layer7-2.9.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/752-usb-ehci--fix-isochronous-URB-leak.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/001-fix_mixed_rules.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/770-revert--endpoint-attributes-track-altsetting-changes.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/9999-missing_skb_truesize_increment.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/209-mini_fo.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/900-mute_dma_busy__caused_by_dvb_device.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/998-fix-unifdef.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/757-fix-device_add-error-path.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/7270_04.86
A    freetz-trunk/make/linux/patches/2.6.19.2/7270_04.86/110-hwrev_list.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/7270_04.86/200-7570_mtd.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/7270_04.86/120-remove_fusiv.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/100-evaloader.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/130-revert_skbuff_changes.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/99999-enable_syslog.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/310-autofs.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/762-debug-device_register.patch!
A    freetz-trunk/make/linux/patches/2.6.19.2/761-debug-device_add.patch!
A    freetz-trunk/make/linux/patches/2.6.19.2/500-compcache-0.5.4-ramzswap-xvmalloc.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/753-V4L-DVB-9605--usb-urb_fix-memory-leak.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/520-lib-lzo.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/758-driver_core--dont-fail-attaching-device-if-cannot-be-bound.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/751-as1352--fix-isochronous-usbfs-input.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/760-debug-cpmac.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/763-debug-usb_create_ep_files.patch!
A    freetz-trunk/make/linux/patches/2.6.19.2/400-ftdi-smartmouse.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/754-Fix-memory-leak-on-Tx-data-path.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/320-kernel-2.6.19-ipp2p-0.82.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/290-revert_ppp_generic.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/510-compcache-0.5.4-swap_notifier_generic.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/300-mppe-mppc.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/120-capi-missing-compiler-includes.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/210-jff2nfsexport.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/110-missing_limits_header.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/755-fix-cleanup-when-failing-device_add.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/102-squashfs3.3_lzma.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/756-dont_add-del_interfaces__register-unregister_them.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/710-scall32.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/764-debug-usb_create_sysfs_intf_files.patch!
A    freetz-trunk/make/linux/patches/2.6.19.2/200-ip_conntrack.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/201-ip_conntrack_rtsp.2.6.19.2.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/530-scsi_user_space.patch
A    freetz-trunk/make/linux/patches/2.6.19.2/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/patches/2.6.28
A    freetz-trunk/make/linux/patches/2.6.28/001-fix_mixed_rules.patch
A    freetz-trunk/make/linux/patches/2.6.28/006-gcc4_inline_fix.patch
A    freetz-trunk/make/linux/patches/2.6.28/209-mini_fo.patch
A    freetz-trunk/make/linux/patches/2.6.28/350-kernel-2.6.25-2.6.28-layer7-2.22.patch
A    freetz-trunk/make/linux/patches/2.6.28/215-mini_fo_2.6.30.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.50
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.50/150-expand-module_alloc_size_list.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.50/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.50/004-extra_optimization.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.50/120-missing_fusiv_optimization.patch
A    freetz-trunk/make/linux/patches/2.6.28/216-mini_fo_locking.patch
A    freetz-trunk/make/linux/patches/2.6.28/310-autofs4-2.6.28-v5-update-20090903.patch
A    freetz-trunk/make/linux/patches/2.6.28/213-mini_fo_2.6.27_fixes.patch
A    freetz-trunk/make/linux/patches/2.6.28/100-evaloader.patch
A    freetz-trunk/make/linux/patches/2.6.28/401-ftdi-working.patch
A    freetz-trunk/make/linux/patches/2.6.28/402-ftdi-bump-to-1-5-0.patch
A    freetz-trunk/make/linux/patches/2.6.28/550-fix_swapfile_on_fat.patch
A    freetz-trunk/make/linux/patches/2.6.28/200-AVM_fixes.patch
A    freetz-trunk/make/linux/patches/2.6.28/300-skbuff-nf_conntrack.patch
A    freetz-trunk/make/linux/patches/2.6.28/400-ftdi-smartmouse.patch
A    freetz-trunk/make/linux/patches/2.6.28/028-slab_maxsize.patch.dont-use
A    freetz-trunk/make/linux/patches/2.6.28/027-mips-freestanding.patch
A    freetz-trunk/make/linux/patches/2.6.28/210-mini_fo_2.6.25_fixes.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.21
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.21/200-no_avm_extras.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.21/004-extra_optimization.patch
A    freetz-trunk/make/linux/patches/2.6.28/7390_05.21/120-missing_fusiv_optimization.patch
A    freetz-trunk/make/linux/patches/2.6.28/011-mips_boot.patch
A    freetz-trunk/make/linux/patches/2.6.28/290-revert_ppp_generic.patch
A    freetz-trunk/make/linux/patches/2.6.28/212-mini_fo_2.6.26_fixes.patch
A    freetz-trunk/make/linux/patches/2.6.28/690-no_system-load-1_messages.patch
A    freetz-trunk/make/linux/patches/2.6.28/300-mppe-mppc.patch
A    freetz-trunk/make/linux/patches/2.6.28/120-capi-missing-compiler-includes.patch
A    freetz-trunk/make/linux/patches/2.6.28/010-shell_bash.patch
A    freetz-trunk/make/linux/patches/2.6.28/540-export_scsi_headers.patch
A    freetz-trunk/make/linux/patches/2.6.28/710-scall32.patch
A    freetz-trunk/make/linux/patches/2.6.28/024-mips_disable_fpu.patch
A    freetz-trunk/make/linux/patches/2.6.28/217-mini_fo_dentry_check.patch
A    freetz-trunk/make/linux/patches/2.6.28/211-mini_fo_2.6.25_dentry_open_war.patch
A    freetz-trunk/make/linux/patches/2.6.28/300-fix_byteorder_header.patch
A    freetz-trunk/make/linux/patches/2.6.28/025-mips_fix_loading_of_modules_with_unresolved_weak_sy.patch
A    freetz-trunk/make/linux/patches/2.6.28/530-scsi_user_space.patch
A    freetz-trunk/make/linux/patches/2.6.28/531-scsi_user_space.patch
A    freetz-trunk/make/linux/patches/2.6.28/999-cpmac_debug_sk_buff.patch
A    freetz-trunk/make/linux/Config.ohio.5140_04.67
A    freetz-trunk/make/linux/Config.ar7.04.30
A    freetz-trunk/make/linux/Config.ar7.04.40
A    freetz-trunk/make/linux/Config.ar7.04.33
A    freetz-trunk/make/linux/Config.vr9.3370_05.21
A    freetz-trunk/make/linux/Config.ur8.7270_05.21
A    freetz-trunk/make/linux/Config.vr9.7360_05.20
A    freetz-trunk/make/linux/Config.ur8.7270_05.50
A    freetz-trunk/make/linux/Config.ohio.04.33
A    freetz-trunk/make/linux/Config.ohio.04.70
A    freetz-trunk/make/linux/Config.ohio.04.80
A    freetz-trunk/make/linux/Config.ar7.04.49
A    freetz-trunk/make/linux/Config.ohio.04.57
A    freetz-trunk/make/linux/Config.ar9.7330_05.20
A    freetz-trunk/make/linux/Config.ohio.r7203
A    freetz-trunk/make/dosfstools
A    freetz-trunk/make/dosfstools/external.files
A    freetz-trunk/make/dosfstools/dosfstools.mk
A    freetz-trunk/make/dosfstools/external.in
A    freetz-trunk/make/dosfstools/patches
A    freetz-trunk/make/dosfstools/patches/100-fix_missing_blksszget.patch
A    freetz-trunk/make/dosfstools/patches/110-consider-freetz-LFS-flags.patch
A    freetz-trunk/make/dosfstools/Config.in
A    freetz-trunk/make/inadyn-mt
A    freetz-trunk/make/inadyn-mt/files
A    freetz-trunk/make/inadyn-mt/files/.language
A    freetz-trunk/make/inadyn-mt/files/root
A    freetz-trunk/make/inadyn-mt/files/root/usr
A    freetz-trunk/make/inadyn-mt/files/root/usr/lib
A    freetz-trunk/make/inadyn-mt/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/inadyn-mt/files/root/usr/lib/cgi-bin/inadyn-mt.cgi
A    freetz-trunk/make/inadyn-mt/files/root/etc
A    freetz-trunk/make/inadyn-mt/files/root/etc/default.inadyn-mt
A    freetz-trunk/make/inadyn-mt/files/root/etc/default.inadyn-mt/inadyn-mt.cfg
A    freetz-trunk/make/inadyn-mt/files/root/etc/init.d
A    freetz-trunk/make/inadyn-mt/files/root/etc/init.d/rc.inadyn-mt
A    freetz-trunk/make/inadyn-mt/inadyn-mt.mk
A    freetz-trunk/make/inadyn-mt/patches
A    freetz-trunk/make/inadyn-mt/patches/200-multiservices.patch
A    freetz-trunk/make/inadyn-mt/Config.in
A    freetz-trunk/make/autofs
A    freetz-trunk/make/autofs/files
A    freetz-trunk/make/autofs/files/.language
A    freetz-trunk/make/autofs/files/root
A    freetz-trunk/make/autofs/files/root/usr
A    freetz-trunk/make/autofs/files/root/usr/lib
A    freetz-trunk/make/autofs/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/autofs/files/root/usr/lib/cgi-bin/autofs.cgi
A    freetz-trunk/make/autofs/files/root/etc
A    freetz-trunk/make/autofs/files/root/etc/auto.master
A    freetz-trunk/make/autofs/files/root/etc/default.autofs
A    freetz-trunk/make/autofs/files/root/etc/default.autofs/autofs.cfg
A    freetz-trunk/make/autofs/files/root/etc/default.autofs/auto_conf.def
A    freetz-trunk/make/autofs/files/root/etc/init.d
A    freetz-trunk/make/autofs/files/root/etc/init.d/rc.autofs
A    freetz-trunk/make/autofs/external.files
A    freetz-trunk/make/autofs/external.services
A    freetz-trunk/make/autofs/autofs.mk
A    freetz-trunk/make/autofs/external.in
A    freetz-trunk/make/autofs/patches
A    freetz-trunk/make/autofs/patches/004_autofs-5.0.5-special-case-cifs-escapes.patch
A    freetz-trunk/make/autofs/patches/033_autofs-5.0.5-fix-random-selection-for-host-on-different-network.patch
A    freetz-trunk/make/autofs/patches/056_autofs-5.0.5-fix-direct-map-not-updating-on-reread.patch
A    freetz-trunk/make/autofs/patches/014_autofs-5.0.5-check-for-path-mount-location-in-generic-module.patch
A    freetz-trunk/make/autofs/patches/039_autofs-5.0.5-dont-check-null-cache-on-expire.patch
A    freetz-trunk/make/autofs/patches/003_autofs-5.0.4-add-mount-wait-parameter.patch
A    freetz-trunk/make/autofs/patches/005_autofs-5.0.5-fix-libxml2-workaround-configure.patch
A    freetz-trunk/make/autofs/patches/057_autofs-5.0.5-add-external-bind-method.patch
A    freetz-trunk/make/autofs/patches/021_autofs-5.0.5-fix-disable-timeout.patch
A    freetz-trunk/make/autofs/patches/046_autofs-5.0.5-remove-extra-read-master-map-call.patch
A    freetz-trunk/make/autofs/patches/060_autofs-5.0.5-fix-submount-shutdown-wait.patch
A    freetz-trunk/make/autofs/patches/038_autofs-5.0.5-fix-parse_sun-module-init.patch
A    freetz-trunk/make/autofs/patches/008_autofs-5.0.5-fix-stale-init-for-file-map-instance.patch
A    freetz-trunk/make/autofs/patches/035_autofs-5.0.5-dont-hold-lock-for-simple-mounts.patch
A    freetz-trunk/make/autofs/patches/028_autofs-5.0.5-add-locality-as-valid-ldap-master-map-attribute-fix.patch
A    freetz-trunk/make/autofs/patches/051_autofs-5.0.5-make-verbose-mode-a-little-less-verbose.patch
A    freetz-trunk/make/autofs/patches/017_autofs-5.0.5-fix-memory-leak-on-reload.patch
A    freetz-trunk/make/autofs/patches/013_autofs-5.0.5-fix-pidof-init-script-usage.patch
A    freetz-trunk/make/autofs/patches/016_autofs-5.0.5-fix-rpc-large-export-list.patch
A    freetz-trunk/make/autofs/patches/002_autofs-5.0.5-refactor-ldap-sasl-bind.patch
A    freetz-trunk/make/autofs/patches/150-uclibc-0_9_28-compat.patch
A    freetz-trunk/make/autofs/patches/025_autofs-5.0.5-fix-get-qdn-fail.patch
A    freetz-trunk/make/autofs/patches/032_autofs-5.0.5-add-autofs_ldap_auth_conf-man-page.patch
A    freetz-trunk/make/autofs/patches/140-conf.patch
A    freetz-trunk/make/autofs/patches/009_autofs-5.0.5-fix-ext4-fsck-at-mount.patch
A    freetz-trunk/make/autofs/patches/007_autofs-5.0.5-fix-backwards-ifndef-INET6.patch
A    freetz-trunk/make/autofs/patches/043_autofs-5.0.5-check-each-dc-server.patch
A    freetz-trunk/make/autofs/patches/022_autofs-5.0.5-fix-strdup-return-value-check.patch
A    freetz-trunk/make/autofs/patches/011_autofs-5.0.5-make-documentation-for-set-log-priority-clearer.patch
A    freetz-trunk/make/autofs/patches/018_autofs-5.0.5-update-kernel-patches-2.6.18-and-2.6.19.patch
A    freetz-trunk/make/autofs/patches/012_autofs-5.0.5-fix-timeout-in-connect_nb.patch
A    freetz-trunk/make/autofs/patches/045_autofs-5.0.5-remove-state-machine-timed-wait.patch
A    freetz-trunk/make/autofs/patches/006_autofs-5.0.5-more-code-analysis-corrections.patch
A    freetz-trunk/make/autofs/patches/058_autofs-5.0.5-fix-add-simple-bind-auth.patch
A    freetz-trunk/make/autofs/patches/037_autofs-5.0.5-fix-wildcard-map-entry-match.patch
A    freetz-trunk/make/autofs/patches/026_autofs-5.0.5-fix-ampersand-escape-in-auto-smb.patch
A    freetz-trunk/make/autofs/patches/034_autofs-5.0.5-make-redhat-init-script-more-lsb-compliant.patch
A    freetz-trunk/make/autofs/patches/020_autofs-5.0.5-fix-random-selection-option.patch
A    freetz-trunk/make/autofs/patches/027_autofs-5.0.5-add-locality-as-valid-ldap-master-map-attribute.patch
A    freetz-trunk/make/autofs/patches/042_autofs-5.0.5-mapent-becomes-negative-during-lookup.patch
A    freetz-trunk/make/autofs/patches/031_autofs-5.0.5-fix-master-map-source-server-unavialable-handling.patch
A    freetz-trunk/make/autofs/patches/015_autofs-5.0.5-dont-fail-mount-on-access-fail.patch
A    freetz-trunk/make/autofs/patches/044_autofs-5.0.5-fix-negative-cache-included-map-lookup.patch
A    freetz-trunk/make/autofs/patches/048_autofs-5.0.5-fix-error-handing-in-do_mount_indirect.patch
A    freetz-trunk/make/autofs/patches/024_autofs-5.0.5-add-sasl-mutex-callbacks.patch
A    freetz-trunk/make/autofs/patches/110-fix_cross_compilation.patch
A    freetz-trunk/make/autofs/patches/059_autofs-5.0.5-add-dump-maps-option.patch
A    freetz-trunk/make/autofs/patches/120-fix_nfs_header_dir.patch
A    freetz-trunk/make/autofs/patches/047_autofs-5.0.5-fix-fix-cache_init-on-source-re-read.patch
A    freetz-trunk/make/autofs/patches/052_autofs-5.0.5-remove-ERR_remove_state-openssl-call.patch
A    freetz-trunk/make/autofs/patches/041_autofs-5.0.5-fix-cache_init-on-source-re-read.patch
A    freetz-trunk/make/autofs/patches/029_autofs-5.0.5-make-nfs4-default-for-redhat-replicated-selection.patch
A    freetz-trunk/make/autofs/patches/036_autofs-5.0.5-fix-remount-locking.patch
A    freetz-trunk/make/autofs/patches/040_autofs-5.0.5-fix-null-cache-race.patch
A    freetz-trunk/make/autofs/patches/055_autofs-5.0.4-always-read-file-maps-mount-lookup-map-read-fix.patch
A    freetz-trunk/make/autofs/patches/130-remove_ypclnt_header.patch
A    freetz-trunk/make/autofs/patches/019_autofs-5.0.5-dont-connect-at-ldap-lookup-module-init.patch
A    freetz-trunk/make/autofs/patches/053_autofs-5.0.5-fix-restart.patch
A    freetz-trunk/make/autofs/patches/049_autofs-5.0.5-expire-thread-use-pending-mutex.patch
A    freetz-trunk/make/autofs/patches/030_autofs-5.0.5-add-simple-bind-auth.patch
A    freetz-trunk/make/autofs/patches/001_autofs-5.0.5-fix-included-map-read-fail-handling.patch
A    freetz-trunk/make/autofs/patches/050_autofs-5.0.5-include-krb5-library.patch
A    freetz-trunk/make/autofs/patches/054_autofs-5.0.5-fix-status-privilege-error.patch
A    freetz-trunk/make/autofs/patches/010_autofs-5.0.5-dont-use-master_lex_destroy-to-clear-parse-buffer.patch
A    freetz-trunk/make/autofs/patches/023_autofs-5.0.5-fix-reconnect-get-base-dn.patch
A    freetz-trunk/make/autofs/Config.in
A    freetz-trunk/make/spindown-cgi
A    freetz-trunk/make/spindown-cgi/files
A    freetz-trunk/make/spindown-cgi/files/.language
A    freetz-trunk/make/spindown-cgi/files/root
A    freetz-trunk/make/spindown-cgi/files/root/usr
A    freetz-trunk/make/spindown-cgi/files/root/usr/lib
A    freetz-trunk/make/spindown-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/spindown-cgi/files/root/usr/lib/cgi-bin/spindown.cgi
A    freetz-trunk/make/spindown-cgi/files/root/usr/bin
A    freetz-trunk/make/spindown-cgi/files/root/usr/bin/spindown
A    freetz-trunk/make/spindown-cgi/files/root/etc
A    freetz-trunk/make/spindown-cgi/files/root/etc/default.spindown
A    freetz-trunk/make/spindown-cgi/files/root/etc/default.spindown/spindown.cfg
A    freetz-trunk/make/spindown-cgi/files/root/etc/init.d
A    freetz-trunk/make/spindown-cgi/files/root/etc/init.d/rc.spindown
A    freetz-trunk/make/spindown-cgi/files/README
A    freetz-trunk/make/spindown-cgi/spindown-cgi.mk
A    freetz-trunk/make/spindown-cgi/Config.in
A    freetz-trunk/make/rcapid
A    freetz-trunk/make/rcapid/files
A    freetz-trunk/make/rcapid/files/.language
A    freetz-trunk/make/rcapid/files/root
A    freetz-trunk/make/rcapid/files/root/usr
A    freetz-trunk/make/rcapid/files/root/usr/lib
A    freetz-trunk/make/rcapid/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/rcapid/files/root/usr/lib/cgi-bin/rcapid.cgi
A    freetz-trunk/make/rcapid/files/root/etc
A    freetz-trunk/make/rcapid/files/root/etc/default.rcapid
A    freetz-trunk/make/rcapid/files/root/etc/default.rcapid/rcapid.cfg
A    freetz-trunk/make/rcapid/files/root/etc/default.rcapid/rcapid.inetd
A    freetz-trunk/make/rcapid/files/root/etc/init.d
A    freetz-trunk/make/rcapid/files/root/etc/init.d/rc.rcapid
A    freetz-trunk/make/rcapid/files/README
A    freetz-trunk/make/rcapid/patches
A    freetz-trunk/make/rcapid/patches/100-makefile.in.patch
A    freetz-trunk/make/rcapid/rcapid.mk
A    freetz-trunk/make/rcapid/Config.in
A    freetz-trunk/make/slurm
A    freetz-trunk/make/slurm/external.files
A    freetz-trunk/make/slurm/external.in
A    freetz-trunk/make/slurm/patches
A    freetz-trunk/make/slurm/patches/001-no_host_curses.patch
A    freetz-trunk/make/slurm/slurm.mk
A    freetz-trunk/make/slurm/Config.in
A    freetz-trunk/make/ldd
A    freetz-trunk/make/ldd/external.files
A    freetz-trunk/make/ldd/external.in
A    freetz-trunk/make/ldd/patches
A    freetz-trunk/make/ldd/patches/030-null-check.upstream.patch
A    freetz-trunk/make/ldd/patches/010-open_3rd_param.upstream.patch
A    freetz-trunk/make/ldd/patches/020-lib_segfault.upstream.patch
A    freetz-trunk/make/ldd/ldd.mk
A    freetz-trunk/make/ldd/Config.in
A    freetz-trunk/make/gw6
A    freetz-trunk/make/gw6/files
A    freetz-trunk/make/gw6/files/.language
A    freetz-trunk/make/gw6/files/root
A    freetz-trunk/make/gw6/files/root/usr
A    freetz-trunk/make/gw6/files/root/usr/share
A    freetz-trunk/make/gw6/files/root/usr/share/gw6
A    freetz-trunk/make/gw6/files/root/usr/share/gw6/template
A    freetz-trunk/make/gw6/files/root/usr/share/gw6/template/linux.sh
A    freetz-trunk/make/gw6/files/root/usr/lib
A    freetz-trunk/make/gw6/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/gw6/files/root/usr/lib/cgi-bin/gw6.cgi
A    freetz-trunk/make/gw6/files/root/etc
A    freetz-trunk/make/gw6/files/root/etc/init.d
A    freetz-trunk/make/gw6/files/root/etc/init.d/rc.gw6
A    freetz-trunk/make/gw6/files/root/etc/default.gw6
A    freetz-trunk/make/gw6/files/root/etc/default.gw6/gw6.cfg
A    freetz-trunk/make/gw6/files/root/etc/default.gw6/gw6_conf
A    freetz-trunk/make/gw6/external.files
A    freetz-trunk/make/gw6/external.services
A    freetz-trunk/make/gw6/external.in
A    freetz-trunk/make/gw6/patches
A    freetz-trunk/make/gw6/patches/020-build_system.patch
A    freetz-trunk/make/gw6/patches/010-no_tests.patch
A    freetz-trunk/make/gw6/patches/040-fix_out_of_bounds_access.patch
A    freetz-trunk/make/gw6/patches/030-missing_includes.patch
A    freetz-trunk/make/gw6/gw6.mk
A    freetz-trunk/make/gw6/Config.in
A    freetz-trunk/make/pppd
A    freetz-trunk/make/pppd/files
A    freetz-trunk/make/pppd/files/root
A    freetz-trunk/make/pppd/files/root/etc
A    freetz-trunk/make/pppd/files/root/etc/ppp
A    freetz-trunk/make/pppd/files/root/etc/init.d
A    freetz-trunk/make/pppd/files/root/etc/init.d/rc.pppd
A    freetz-trunk/make/pppd/files/root/etc/default.pppd
A    freetz-trunk/make/pppd/files/root/etc/default.pppd/chap_secrets.def
A    freetz-trunk/make/pppd/files/root/etc/default.pppd/pppd_ip-down
A    freetz-trunk/make/pppd/files/root/etc/default.pppd/pap_secrets.def
A    freetz-trunk/make/pppd/files/root/etc/default.pppd/pppd_options.def
A    freetz-trunk/make/pppd/files/root/etc/default.pppd/pppd_ip-up
A    freetz-trunk/make/pppd/files/README
A    freetz-trunk/make/pppd/external.files
A    freetz-trunk/make/pppd/external.in
A    freetz-trunk/make/pppd/patches
A    freetz-trunk/make/pppd/patches/206-radius_config.patch
A    freetz-trunk/make/pppd/patches/204-opt_flags.patch
A    freetz-trunk/make/pppd/patches/100-debian_close_dev_ppp.patch
A    freetz-trunk/make/pppd/patches/113-debian_ipv6_accept_remote.patch
A    freetz-trunk/make/pppd/patches/101-debian_ip-up_option.patch
A    freetz-trunk/make/pppd/patches/209-compensate_time_change.patch
A    freetz-trunk/make/pppd/patches/105-debian_pppoatm_cleanup.patch
A    freetz-trunk/make/pppd/patches/208-no_exponential_timeout.patch
A    freetz-trunk/make/pppd/patches/203-no_strip.patch
A    freetz-trunk/make/pppd/patches/201-mppe_mppc_1.1.patch
A    freetz-trunk/make/pppd/patches/107-debian_stripMSdomain.patch
A    freetz-trunk/make/pppd/patches/109-debian_demand.patch
A    freetz-trunk/make/pppd/patches/104-debian_fix_linkpidfile.patch
A    freetz-trunk/make/pppd/patches/111-debian_fix_null_pppdb.patch
A    freetz-trunk/make/pppd/patches/210-lcp_mtu_max.patch
A    freetz-trunk/make/pppd/patches/112-debian_dont_exit_pado_timeout.patch
A    freetz-trunk/make/pppd/patches/102-debian_readable_connerrs.patch
A    freetz-trunk/make/pppd/patches/108-debian_defaultroute.patch
A    freetz-trunk/make/pppd/patches/200-makefile.patch
A    freetz-trunk/make/pppd/patches/202-no_atm.patch
A    freetz-trunk/make/pppd/patches/300-filter-pcap-includes-lib.patch
A    freetz-trunk/make/pppd/patches/110-debian_adaptive_echos.patch
A    freetz-trunk/make/pppd/patches/099-debian_git_20100307.patch
A    freetz-trunk/make/pppd/pppd.mk
A    freetz-trunk/make/pppd/Config.in
A    freetz-trunk/make/ffmpeg
A    freetz-trunk/make/ffmpeg/external.in.libs
A    freetz-trunk/make/ffmpeg/Config.in.libs
A    freetz-trunk/make/ffmpeg/Makefile.in
A    freetz-trunk/make/ffmpeg/external.files
A    freetz-trunk/make/ffmpeg/patches
A    freetz-trunk/make/ffmpeg/patches/120-IPv6_defines.patch
A    freetz-trunk/make/ffmpeg/patches/110-quiet.patch
A    freetz-trunk/make/ffmpeg/ffmpeg.mk
A    freetz-trunk/make/dnsmasq
A    freetz-trunk/make/dnsmasq/files
A    freetz-trunk/make/dnsmasq/files/.language
A    freetz-trunk/make/dnsmasq/files/root
A    freetz-trunk/make/dnsmasq/files/root/usr
A    freetz-trunk/make/dnsmasq/files/root/usr/lib
A    freetz-trunk/make/dnsmasq/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/dnsmasq/files/root/usr/lib/cgi-bin/dnsmasq.cgi
A    freetz-trunk/make/dnsmasq/files/root/etc
A    freetz-trunk/make/dnsmasq/files/root/etc/init.d
A    freetz-trunk/make/dnsmasq/files/root/etc/init.d/rc.dnsmasq
A    freetz-trunk/make/dnsmasq/files/root/etc/default.dnsmasq
A    freetz-trunk/make/dnsmasq/files/root/etc/default.dnsmasq/dnsmasq.cfg
A    freetz-trunk/make/dnsmasq/files/root/etc/default.dnsmasq/dnsmasq_extra.def
A    freetz-trunk/make/dnsmasq/files/root/etc/default.dnsmasq/dnsmasq_conf
A    freetz-trunk/make/dnsmasq/patches
A    freetz-trunk/make/dnsmasq/patches/120-tftp-dir-check.patch
A    freetz-trunk/make/dnsmasq/patches/100-multid-leases.patch
A    freetz-trunk/make/dnsmasq/patches/110-largefile.patch
A    freetz-trunk/make/dnsmasq/patches/020-do-fork.patch
A    freetz-trunk/make/dnsmasq/Config.in
A    freetz-trunk/make/dnsmasq/dnsmasq.mk
A    freetz-trunk/make/vpnc
A    freetz-trunk/make/vpnc/files
A    freetz-trunk/make/vpnc/files/root
A    freetz-trunk/make/vpnc/files/root/usr
A    freetz-trunk/make/vpnc/files/root/usr/lib
A    freetz-trunk/make/vpnc/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/vpnc/files/root/usr/lib/cgi-bin/vpnc.cgi
A    freetz-trunk/make/vpnc/files/root/etc
A    freetz-trunk/make/vpnc/files/root/etc/init.d
A    freetz-trunk/make/vpnc/files/root/etc/init.d/rc.vpnc
A    freetz-trunk/make/vpnc/files/root/etc/default.vpnc
A    freetz-trunk/make/vpnc/files/root/etc/default.vpnc/vpnc.cfg
A    freetz-trunk/make/vpnc/files/root/etc/default.vpnc/vpnc-script
A    freetz-trunk/make/vpnc/files/root/etc/default.vpnc/vpnc_conf
A    freetz-trunk/make/vpnc/patches
A    freetz-trunk/make/vpnc/patches/01-cross.patch
A    freetz-trunk/make/vpnc/Config.in
A    freetz-trunk/make/vpnc/vpnc.mk
A    freetz-trunk/make/wget
A    freetz-trunk/make/wget/external.files
A    freetz-trunk/make/wget/external.in
A    freetz-trunk/make/wget/patches
A    freetz-trunk/make/wget/patches/010-openssl_zlib_dependency_fix.patch
A    freetz-trunk/make/wget/patches/200-no_compile_link_strings.patch
A    freetz-trunk/make/wget/patches/101-drop-libuuid-dependency.patch
A    freetz-trunk/make/wget/patches/020-consider-with-zlib.patch
A    freetz-trunk/make/wget/patches/030-static_linking_workaround.patch
A    freetz-trunk/make/wget/patches/102-drop-libpcre-dependency.patch
A    freetz-trunk/make/wget/Config.in
A    freetz-trunk/make/wget/wget.mk
A    freetz-trunk/make/rtmpdump
A    freetz-trunk/make/rtmpdump/external.files
A    freetz-trunk/make/rtmpdump/external.in
A    freetz-trunk/make/rtmpdump/Config.in
A    freetz-trunk/make/rtmpdump/rtmpdump.mk
A    freetz-trunk/make/bittwist
A    freetz-trunk/make/bittwist/bittwist.mk
A    freetz-trunk/make/bittwist/external.files
A    freetz-trunk/make/bittwist/external.in
A    freetz-trunk/make/bittwist/patches
A    freetz-trunk/make/bittwist/patches/100_ifaddrs_SIOCGIFHWADDR.patch
A    freetz-trunk/make/bittwist/patches/120-uClibc-0.9.28-conflicting-inet_aton-prototype.patch
A    freetz-trunk/make/bittwist/patches/110-Makefile.patch
A    freetz-trunk/make/bittwist/Config.in
A    freetz-trunk/make/opendd
A    freetz-trunk/make/opendd/opendd.mk
A    freetz-trunk/make/opendd/files
A    freetz-trunk/make/opendd/files/.language
A    freetz-trunk/make/opendd/files/root
A    freetz-trunk/make/opendd/files/root/usr
A    freetz-trunk/make/opendd/files/root/usr/lib
A    freetz-trunk/make/opendd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/opendd/files/root/usr/lib/cgi-bin/opendd.cgi
A    freetz-trunk/make/opendd/files/root/etc
A    freetz-trunk/make/opendd/files/root/etc/init.d
A    freetz-trunk/make/opendd/files/root/etc/init.d/rc.opendd
A    freetz-trunk/make/opendd/files/root/etc/default.opendd
A    freetz-trunk/make/opendd/files/root/etc/default.opendd/opendd.save
A    freetz-trunk/make/opendd/files/root/etc/default.opendd/opendd.cfg
A    freetz-trunk/make/opendd/files/root/etc/default.opendd/opendd_pem.def
A    freetz-trunk/make/opendd/files/root/etc/default.opendd/opendd_conf
A    freetz-trunk/make/opendd/files/root/etc/onlinechanged
A    freetz-trunk/make/opendd/files/root/etc/onlinechanged/20-opendd
A    freetz-trunk/make/opendd/external.files
A    freetz-trunk/make/opendd/external.services
A    freetz-trunk/make/opendd/external.in
A    freetz-trunk/make/opendd/patches
A    freetz-trunk/make/opendd/patches/150_opendd_h.patch
A    freetz-trunk/make/opendd/patches/130_setproctitle_c.patch
A    freetz-trunk/make/opendd/patches/170_smtpserverport.patch
A    freetz-trunk/make/opendd/patches/200_add-sender.patch
A    freetz-trunk/make/opendd/patches/120_setproctitle_h.patch
A    freetz-trunk/make/opendd/patches/100_Makefile.patch
A    freetz-trunk/make/opendd/patches/160_get_ip.patch
A    freetz-trunk/make/opendd/patches/140_opendd_c.patch
A    freetz-trunk/make/opendd/patches/110_util_c.patch
A    freetz-trunk/make/opendd/Config.in
A    freetz-trunk/make/deco
A    freetz-trunk/make/deco/deco.mk
A    freetz-trunk/make/deco/files
A    freetz-trunk/make/deco/files/root
A    freetz-trunk/make/deco/files/root/usr
A    freetz-trunk/make/deco/files/root/usr/lib
A    freetz-trunk/make/deco/files/root/usr/lib/deco
A    freetz-trunk/make/deco/files/root/usr/lib/deco/profile
A    freetz-trunk/make/deco/files/root/usr/lib/deco/menu
A    freetz-trunk/make/deco/external.files
A    freetz-trunk/make/deco/external.in
A    freetz-trunk/make/deco/patches
A    freetz-trunk/make/deco/patches/100-tty.c.patch
A    freetz-trunk/make/deco/Config.in
A    freetz-trunk/make/ntfs
A    freetz-trunk/make/ntfs/external.in.libs
A    freetz-trunk/make/ntfs/ntfs.mk
A    freetz-trunk/make/ntfs/Config.in.libs
A    freetz-trunk/make/ntfs/external.files
A    freetz-trunk/make/ntfs/patches
A    freetz-trunk/make/ntfs/patches/300-dont_messup_up_config_cache_with_host_linker_characteristics.patch
A    freetz-trunk/make/ntfs/patches/100-no_libintlh.patch
A    freetz-trunk/make/mini-snmpd
A    freetz-trunk/make/mini-snmpd/mini-snmpd.mk
A    freetz-trunk/make/mini-snmpd/external.files
A    freetz-trunk/make/mini-snmpd/external.in
A    freetz-trunk/make/mini-snmpd/patches
A    freetz-trunk/make/mini-snmpd/patches/100-cross_compile.patch
A    freetz-trunk/make/mini-snmpd/Config.in
A    freetz-trunk/make/python-pyopenssl
A    freetz-trunk/make/python-pyopenssl/python-pyopenssl.mk
A    freetz-trunk/make/python-pyopenssl/patches
A    freetz-trunk/make/python-pyopenssl/patches/010-no_tests.patch
A    freetz-trunk/make/python-pyopenssl/Config.in
A    freetz-trunk/make/iftop
A    freetz-trunk/make/iftop/external.files
A    freetz-trunk/make/iftop/external.in
A    freetz-trunk/make/iftop/iftop.mk
A    freetz-trunk/make/iftop/patches
A    freetz-trunk/make/iftop/patches/110_cfgfile_c.patch
A    freetz-trunk/make/iftop/patches/130_ui_c.patch
A    freetz-trunk/make/iftop/patches/100_ether_h.patch
A    freetz-trunk/make/iftop/patches/120_options_c.patch
A    freetz-trunk/make/iftop/Config.in
A    freetz-trunk/make/smartmontools
A    freetz-trunk/make/smartmontools/files
A    freetz-trunk/make/smartmontools/files/.language
A    freetz-trunk/make/smartmontools/files/root
A    freetz-trunk/make/smartmontools/files/root/usr
A    freetz-trunk/make/smartmontools/files/root/usr/lib
A    freetz-trunk/make/smartmontools/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/smartmontools/files/root/usr/lib/cgi-bin/smartmontools
A    freetz-trunk/make/smartmontools/files/root/usr/lib/cgi-bin/smartmontools/status.cgi
A    freetz-trunk/make/smartmontools/files/root/etc
A    freetz-trunk/make/smartmontools/files/root/etc/init.d
A    freetz-trunk/make/smartmontools/files/root/etc/init.d/rc.smartmontools
A    freetz-trunk/make/smartmontools/external.files
A    freetz-trunk/make/smartmontools/external.services
A    freetz-trunk/make/smartmontools/external.in
A    freetz-trunk/make/smartmontools/smartmontools.mk
A    freetz-trunk/make/smartmontools/Config.in
A    freetz-trunk/make/strace
A    freetz-trunk/make/strace/external.files
A    freetz-trunk/make/strace/external.in
A    freetz-trunk/make/strace/patches
A    freetz-trunk/make/strace/patches/030-lseek.patch
A    freetz-trunk/make/strace/patches/100-add-TRACE_IPC-to-sys_ipc.patch
A    freetz-trunk/make/strace/patches/010-disabled-largefile-syscalls.patch
A    freetz-trunk/make/strace/patches/040-missing_HAVE_LONG_LONG_OFF_T.patch
A    freetz-trunk/make/strace/patches/099-Fix-MIPS-syscall-entries.patch
A    freetz-trunk/make/strace/patches/050-no__long_long_off_t__long_long_rlim_t.patch
A    freetz-trunk/make/strace/patches/020-statfs64.patch
A    freetz-trunk/make/strace/patches/060-BLKTRACESTOP.patch
A    freetz-trunk/make/strace/strace.mk
A    freetz-trunk/make/strace/Config.in
A    freetz-trunk/make/debootstrap
A    freetz-trunk/make/debootstrap/files
A    freetz-trunk/make/debootstrap/files/root
A    freetz-trunk/make/debootstrap/files/root/usr
A    freetz-trunk/make/debootstrap/files/root/usr/share
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/devices.tar.gz
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/sid
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/squeeze
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/etch
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/lenny
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/natty
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/lucid
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/maverick
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/etch-m68k
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/karmic
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/hardy
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/jaunty
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/stable
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/wheezy
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/gutsy
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/testing
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/unstable
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/scripts/intrepid
A    freetz-trunk/make/debootstrap/files/root/usr/share/debootstrap/functions
A    freetz-trunk/make/debootstrap/files/root/usr/sbin
A    freetz-trunk/make/debootstrap/files/root/usr/sbin/debootstrap
A    freetz-trunk/make/debootstrap/files/README
A    freetz-trunk/make/debootstrap/patches
A    freetz-trunk/make/debootstrap/src
A    freetz-trunk/make/debootstrap/src/pkgdetails.c
A    freetz-trunk/make/debootstrap/src/Makefile
A    freetz-trunk/make/debootstrap/Config.in
A    freetz-trunk/make/debootstrap/debootstrap.mk
A    freetz-trunk/make/tcpproxy
A    freetz-trunk/make/tcpproxy/external.files
A    freetz-trunk/make/tcpproxy/external.in
A    freetz-trunk/make/tcpproxy/Config.in
A    freetz-trunk/make/tcpproxy/tcpproxy.mk
A    freetz-trunk/make/collectd
A    freetz-trunk/make/collectd/collectd.mk
A    freetz-trunk/make/collectd/files
A    freetz-trunk/make/collectd/files/.language
A    freetz-trunk/make/collectd/files/root
A    freetz-trunk/make/collectd/files/root/usr
A    freetz-trunk/make/collectd/files/root/usr/share
A    freetz-trunk/make/collectd/files/root/usr/share/collectd
A    freetz-trunk/make/collectd/files/root/usr/share/collectd/generate_graphs
A    freetz-trunk/make/collectd/files/root/usr/lib
A    freetz-trunk/make/collectd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/collectd/files/root/usr/lib/cgi-bin/collectd
A    freetz-trunk/make/collectd/files/root/usr/lib/cgi-bin/collectd/view.cgi
A    freetz-trunk/make/collectd/files/root/usr/lib/cgi-bin/collectd.cgi
A    freetz-trunk/make/collectd/files/root/usr/mww
A    freetz-trunk/make/collectd/files/root/usr/mww/graph
A    freetz-trunk/make/collectd/files/root/etc
A    freetz-trunk/make/collectd/files/root/etc/init.d
A    freetz-trunk/make/collectd/files/root/etc/init.d/rc.collectd
A    freetz-trunk/make/collectd/files/root/etc/default.collectd
A    freetz-trunk/make/collectd/files/root/etc/default.collectd/collectd.cfg
A    freetz-trunk/make/collectd/files/root/etc/default.collectd/collectd_conf.def
A    freetz-trunk/make/collectd/external.files
A    freetz-trunk/make/collectd/external.services
A    freetz-trunk/make/collectd/external.in
A    freetz-trunk/make/collectd/patches
A    freetz-trunk/make/collectd/patches/300-allow-plugin-symlinks.patch
A    freetz-trunk/make/collectd/patches/200-fritzbox-plugin-buildsystem.patch
A    freetz-trunk/make/collectd/patches/100-system_libltdl.patch
A    freetz-trunk/make/collectd/patches/210-fritzbox-plugin-src.patch
A    freetz-trunk/make/collectd/patches/130-PLUGINDIR.patch
A    freetz-trunk/make/collectd/patches/110-unnecessary_tests.patch
A    freetz-trunk/make/collectd/patches/120-wrong-dependencies.patch
A    freetz-trunk/make/collectd/Config.in
A    freetz-trunk/make/mcabber
A    freetz-trunk/make/mcabber/mcabber.mk
A    freetz-trunk/make/mcabber/files
A    freetz-trunk/make/mcabber/files/.language
A    freetz-trunk/make/mcabber/files/root
A    freetz-trunk/make/mcabber/files/root/usr
A    freetz-trunk/make/mcabber/files/root/usr/lib
A    freetz-trunk/make/mcabber/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/mcabber/files/root/usr/lib/cgi-bin/mcabber.cgi
A    freetz-trunk/make/mcabber/files/root/etc
A    freetz-trunk/make/mcabber/files/root/etc/init.d
A    freetz-trunk/make/mcabber/files/root/etc/init.d/rc.mcabber
A    freetz-trunk/make/mcabber/files/root/etc/default.mcabber
A    freetz-trunk/make/mcabber/files/root/etc/default.mcabber/mcabber_conf
A    freetz-trunk/make/mcabber/files/root/etc/default.mcabber/mcabber.save
A    freetz-trunk/make/mcabber/files/root/etc/default.mcabber/mcabber.cfg
A    freetz-trunk/make/mcabber/patches
A    freetz-trunk/make/mcabber/patches/100-libm.patch
A    freetz-trunk/make/mcabber/patches/200-ldl.patch
A    freetz-trunk/make/mcabber/Config.in
A    freetz-trunk/make/dropbear
A    freetz-trunk/make/dropbear/files
A    freetz-trunk/make/dropbear/files/.language
A    freetz-trunk/make/dropbear/files/root
A    freetz-trunk/make/dropbear/files/root/usr
A    freetz-trunk/make/dropbear/files/root/usr/lib
A    freetz-trunk/make/dropbear/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/dropbear/files/root/usr/lib/cgi-bin/dropbear.cgi
A    freetz-trunk/make/dropbear/files/root/usr/bin
A    freetz-trunk/make/dropbear/files/root/usr/bin/scp
A    freetz-trunk/make/dropbear/files/root/usr/bin/dropbearkey
A    freetz-trunk/make/dropbear/files/root/usr/bin/ssh
A    freetz-trunk/make/dropbear/files/root/usr/sbin
A    freetz-trunk/make/dropbear/files/root/usr/sbin/dropbear
A    freetz-trunk/make/dropbear/files/root/etc
A    freetz-trunk/make/dropbear/files/root/etc/default.dropbear
A    freetz-trunk/make/dropbear/files/root/etc/default.dropbear/dropbear.inetd
A    freetz-trunk/make/dropbear/files/root/etc/default.dropbear/dropbear.cfg
A    freetz-trunk/make/dropbear/files/root/etc/init.d
A    freetz-trunk/make/dropbear/files/root/etc/init.d/rc.dropbear
A    freetz-trunk/make/dropbear/external.files
A    freetz-trunk/make/dropbear/dropbear.mk
A    freetz-trunk/make/dropbear/external.services
A    freetz-trunk/make/dropbear/external.in
A    freetz-trunk/make/dropbear/patches
A    freetz-trunk/make/dropbear/patches/100-root-login-only.patch
A    freetz-trunk/make/dropbear/patches/140-disable_assert.patch
A    freetz-trunk/make/dropbear/patches/130-standalone.patch
A    freetz-trunk/make/dropbear/patches/111_configure_hostlookup.patch
A    freetz-trunk/make/dropbear/patches/200-lcrypt_bsdfix.patch
A    freetz-trunk/make/dropbear/patches/250-login-limits.patch
A    freetz-trunk/make/dropbear/patches/210-pidfile.patch
A    freetz-trunk/make/dropbear/patches/300-extra-FLAGS.patch
A    freetz-trunk/make/dropbear/patches/003-uninit-defect.patch
A    freetz-trunk/make/dropbear/patches/001-charo-io.patch
A    freetz-trunk/make/dropbear/patches/110-options.h.patch
A    freetz-trunk/make/dropbear/Config.in
A    freetz-trunk/make/sane-backends
A    freetz-trunk/make/sane-backends/config-update.pl
A    freetz-trunk/make/sane-backends/files
A    freetz-trunk/make/sane-backends/files/.language
A    freetz-trunk/make/sane-backends/files/root
A    freetz-trunk/make/sane-backends/files/root/usr
A    freetz-trunk/make/sane-backends/files/root/usr/lib
A    freetz-trunk/make/sane-backends/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/sane-backends/files/root/usr/lib/cgi-bin/sane-backends.cgi
A    freetz-trunk/make/sane-backends/files/root/etc
A    freetz-trunk/make/sane-backends/files/root/etc/default.sane-backends
A    freetz-trunk/make/sane-backends/files/root/etc/default.sane-backends/saned_conf
A    freetz-trunk/make/sane-backends/files/root/etc/default.sane-backends/sane-backends.inetd
A    freetz-trunk/make/sane-backends/files/root/etc/default.sane-backends/sane-backends.save
A    freetz-trunk/make/sane-backends/files/root/etc/default.sane-backends/sane-backends.cfg
A    freetz-trunk/make/sane-backends/files/root/etc/init.d
A    freetz-trunk/make/sane-backends/files/root/etc/init.d/rc.sane-backends
A    freetz-trunk/make/sane-backends/files/TODO
A    freetz-trunk/make/sane-backends/files/README
A    freetz-trunk/make/sane-backends/external.files
A    freetz-trunk/make/sane-backends/sane-backends.in
A    freetz-trunk/make/sane-backends/external.services
A    freetz-trunk/make/sane-backends/sane-backends.mk
A    freetz-trunk/make/sane-backends/external.in
A    freetz-trunk/make/sane-backends/patches
A    freetz-trunk/make/sane-backends/patches/011-no_host_cups.patch
A    freetz-trunk/make/sane-backends/patches/300-libtool_sys_lib_search_path_spec.patch
A    freetz-trunk/make/sane-backends/patches/100-no_docs_and_translations.patch
A    freetz-trunk/make/sane-backends/patches/401-debian_missing_pthreads.patch
A    freetz-trunk/make/sane-backends/patches/201-backends_lib_path.patch
A    freetz-trunk/make/sane-backends/patches/010-dont-add-host-include-path.patch
A    freetz-trunk/make/sane-backends/patches/403-debian_libsane_deps.patch
A    freetz-trunk/make/sane-backends/patches/020-non-i386-qcam.patch
A    freetz-trunk/make/sane-backends/patches/200-config_path.patch
A    freetz-trunk/make/sane-backends/patches/402-debian_frontends_libs.patch
A    freetz-trunk/make/sane-backends/Config.in
A    freetz-trunk/make/sispmctl
A    freetz-trunk/make/sispmctl/files
A    freetz-trunk/make/sispmctl/files/.language
A    freetz-trunk/make/sispmctl/files/root
A    freetz-trunk/make/sispmctl/files/root/usr
A    freetz-trunk/make/sispmctl/files/root/usr/lib
A    freetz-trunk/make/sispmctl/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/sispmctl/files/root/usr/lib/cgi-bin/sispmctl.cgi
A    freetz-trunk/make/sispmctl/files/root/etc
A    freetz-trunk/make/sispmctl/files/root/etc/default.sispmctl
A    freetz-trunk/make/sispmctl/files/root/etc/default.sispmctl/sispmctl.cfg
A    freetz-trunk/make/sispmctl/files/root/etc/init.d
A    freetz-trunk/make/sispmctl/files/root/etc/init.d/rc.sispmctl
A    freetz-trunk/make/sispmctl/files/README
A    freetz-trunk/make/sispmctl/external.files
A    freetz-trunk/make/sispmctl/external.services
A    freetz-trunk/make/sispmctl/sispmctl.mk
A    freetz-trunk/make/sispmctl/external.in
A    freetz-trunk/make/sispmctl/Config.in
A    freetz-trunk/make/wol-cgi
A    freetz-trunk/make/wol-cgi/files
A    freetz-trunk/make/wol-cgi/files/.language
A    freetz-trunk/make/wol-cgi/files/root
A    freetz-trunk/make/wol-cgi/files/root/usr
A    freetz-trunk/make/wol-cgi/files/root/usr/www
A    freetz-trunk/make/wol-cgi/files/root/usr/www/cgi-bin
A    freetz-trunk/make/wol-cgi/files/root/usr/www/cgi-bin/freetz_wol
A    freetz-trunk/make/wol-cgi/files/root/usr/lib
A    freetz-trunk/make/wol-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/wol-cgi/files/root/usr/lib/cgi-bin/wol.cgi
A    freetz-trunk/make/wol-cgi/files/root/usr/bin
A    freetz-trunk/make/wol-cgi/files/root/usr/bin/freetz_wol
A    freetz-trunk/make/wol-cgi/files/root/usr/bin/webcfg-wol
A    freetz-trunk/make/wol-cgi/files/root/usr/mww-wol
A    freetz-trunk/make/wol-cgi/files/root/usr/mww-wol/style
A    freetz-trunk/make/wol-cgi/files/root/usr/mww-wol/images
A    freetz-trunk/make/wol-cgi/files/root/usr/mww-wol/cgi-bin
A    freetz-trunk/make/wol-cgi/files/root/usr/mww-wol/cgi-bin/index.cgi
A    freetz-trunk/make/wol-cgi/files/root/usr/mww-wol/cgi-bin/wake.cgi
A    freetz-trunk/make/wol-cgi/files/root/etc
A    freetz-trunk/make/wol-cgi/files/root/etc/default.wol
A    freetz-trunk/make/wol-cgi/files/root/etc/default.wol/wol.cfg
A    freetz-trunk/make/wol-cgi/files/root/etc/default.wol/wol.inetd
A    freetz-trunk/make/wol-cgi/files/root/etc/default.wol/httpd-wol_conf
A    freetz-trunk/make/wol-cgi/files/root/etc/init.d
A    freetz-trunk/make/wol-cgi/files/root/etc/init.d/rc.wol
A    freetz-trunk/make/wol-cgi/wol-cgi.mk
A    freetz-trunk/make/wol-cgi/Config.in
A    freetz-trunk/make/digitemp
A    freetz-trunk/make/digitemp/external.files
A    freetz-trunk/make/digitemp/external.in
A    freetz-trunk/make/digitemp/patches
A    freetz-trunk/make/digitemp/patches/200-linebuf.patch
A    freetz-trunk/make/digitemp/patches/100-cflags.patch
A    freetz-trunk/make/digitemp/digitemp.mk
A    freetz-trunk/make/digitemp/Config.in
A    freetz-trunk/make/polipo
A    freetz-trunk/make/polipo/files
A    freetz-trunk/make/polipo/files/.language
A    freetz-trunk/make/polipo/files/root
A    freetz-trunk/make/polipo/files/root/usr
A    freetz-trunk/make/polipo/files/root/usr/lib
A    freetz-trunk/make/polipo/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/polipo/files/root/usr/lib/cgi-bin/polipo.cgi
A    freetz-trunk/make/polipo/files/root/etc
A    freetz-trunk/make/polipo/files/root/etc/default.polipo
A    freetz-trunk/make/polipo/files/root/etc/default.polipo/polipo.cfg
A    freetz-trunk/make/polipo/files/root/etc/default.polipo/polipo_conf
A    freetz-trunk/make/polipo/files/root/etc/init.d
A    freetz-trunk/make/polipo/files/root/etc/init.d/rc.polipo
A    freetz-trunk/make/polipo/external.files
A    freetz-trunk/make/polipo/external.services
A    freetz-trunk/make/polipo/external.in
A    freetz-trunk/make/polipo/polipo.mk
A    freetz-trunk/make/polipo/Config.in
A    freetz-trunk/make/ripmime
A    freetz-trunk/make/ripmime/external.files
A    freetz-trunk/make/ripmime/external.in
A    freetz-trunk/make/ripmime/ripmime.mk
A    freetz-trunk/make/ripmime/Config.in
A    freetz-trunk/make/lsof
A    freetz-trunk/make/lsof/external.files
A    freetz-trunk/make/lsof/external.in
A    freetz-trunk/make/lsof/patches
A    freetz-trunk/make/lsof/patches/030-LFS_controlled_by_freetz.patch
A    freetz-trunk/make/lsof/patches/040-crosscompiling-strftime-test.patch
A    freetz-trunk/make/lsof/patches/005-IPv6.patch
A    freetz-trunk/make/lsof/patches/010-configure_quiet.patch
A    freetz-trunk/make/lsof/patches/001-AR_RANLIB.patch
A    freetz-trunk/make/lsof/patches/020-remove-susvlegacy-funcs.patch
A    freetz-trunk/make/lsof/patches/002-noportmap.patch
A    freetz-trunk/make/lsof/lsof.mk
A    freetz-trunk/make/lsof/Config.in
A    freetz-trunk/make/gnu-make
A    freetz-trunk/make/gnu-make/external.files
A    freetz-trunk/make/gnu-make/external.in
A    freetz-trunk/make/gnu-make/Config.in
A    freetz-trunk/make/gnu-make/gnu-make.mk
A    freetz-trunk/make/noip
A    freetz-trunk/make/noip/files
A    freetz-trunk/make/noip/files/root
A    freetz-trunk/make/noip/files/root/var
A    freetz-trunk/make/noip/files/root/var/tmp
A    freetz-trunk/make/noip/files/root/var/tmp/noip.update
A    freetz-trunk/make/noip/patches
A    freetz-trunk/make/noip/patches/201-noip2c.patch
A    freetz-trunk/make/noip/patches/101-makefile.patch
A    freetz-trunk/make/noip/Config.in
A    freetz-trunk/make/noip/noip.mk
A    freetz-trunk/make/sablevm-sdk
A    freetz-trunk/make/sablevm-sdk/files
A    freetz-trunk/make/sablevm-sdk/files/root
A    freetz-trunk/make/sablevm-sdk/files/root/usr
A    freetz-trunk/make/sablevm-sdk/files/root/usr/share
A    freetz-trunk/make/sablevm-sdk/files/root/usr/share/sablevm-classpath
A    freetz-trunk/make/sablevm-sdk/files/root/usr/share/sablevm-classpath/.gitignore
A    freetz-trunk/make/sablevm-sdk/files/root/usr/lib
A    freetz-trunk/make/sablevm-sdk/files/root/usr/lib/security
A    freetz-trunk/make/sablevm-sdk/files/root/usr/lib/security/classpath.security
A    freetz-trunk/make/sablevm-sdk/files/root/usr/lib/sablevm-classpath
A    freetz-trunk/make/sablevm-sdk/files/root/usr/lib/sablevm-classpath/.gitignore
A    freetz-trunk/make/sablevm-sdk/external.files
A    freetz-trunk/make/sablevm-sdk/external.in
A    freetz-trunk/make/sablevm-sdk/patches
A    freetz-trunk/make/sablevm-sdk/patches/001-heap_size.patch
A    freetz-trunk/make/sablevm-sdk/patches/020-missing_popt_dependency.patch
A    freetz-trunk/make/sablevm-sdk/patches/010-link_binary_against_pthread.patch
A    freetz-trunk/make/sablevm-sdk/Config.in
A    freetz-trunk/make/sablevm-sdk/example
A    freetz-trunk/make/sablevm-sdk/example/HelloWorld.class
A    freetz-trunk/make/sablevm-sdk/example/HelloWorld.java
A    freetz-trunk/make/sablevm-sdk/mini.classlist
A    freetz-trunk/make/sablevm-sdk/sablevm-sdk.mk
A    freetz-trunk/make/bip
A    freetz-trunk/make/bip/bip.mk
A    freetz-trunk/make/bip/files
A    freetz-trunk/make/bip/files/.language
A    freetz-trunk/make/bip/files/root
A    freetz-trunk/make/bip/files/root/usr
A    freetz-trunk/make/bip/files/root/usr/lib
A    freetz-trunk/make/bip/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/bip/files/root/usr/lib/cgi-bin/bip.cgi
A    freetz-trunk/make/bip/files/root/etc
A    freetz-trunk/make/bip/files/root/etc/init.d
A    freetz-trunk/make/bip/files/root/etc/init.d/rc.bip
A    freetz-trunk/make/bip/files/root/etc/default.bip
A    freetz-trunk/make/bip/files/root/etc/default.bip/bip_conf
A    freetz-trunk/make/bip/files/root/etc/default.bip/bip.cfg
A    freetz-trunk/make/bip/files/root/etc/default.bip/bip_user_conf.def
A    freetz-trunk/make/bip/files/root/etc/default.bip/bip_user.conf
A    freetz-trunk/make/bip/external.files
A    freetz-trunk/make/bip/external.services
A    freetz-trunk/make/bip/external.in
A    freetz-trunk/make/bip/patches
A    freetz-trunk/make/bip/patches/010-remove-unnecessary-conflicting-declaration.patch
A    freetz-trunk/make/bip/patches/110-no_libintl.patch
A    freetz-trunk/make/bip/patches/100-freenode-quiet.patch
A    freetz-trunk/make/bip/Config.in
A    freetz-trunk/make/owfs
A    freetz-trunk/make/owfs/external.files
A    freetz-trunk/make/owfs/owfs.mk
A    freetz-trunk/make/owfs/external.in
A    freetz-trunk/make/owfs/patches
A    freetz-trunk/make/owfs/patches/120-invalid-tags-ltmain.patch
A    freetz-trunk/make/owfs/patches/110-rpath-in-extralibs-flags.patch
A    freetz-trunk/make/owfs/patches/100-owphp-irritating-warning.patch
A    freetz-trunk/make/owfs/Config.in
A    freetz-trunk/make/bird
A    freetz-trunk/make/bird/files
A    freetz-trunk/make/bird/files/.language
A    freetz-trunk/make/bird/files/root
A    freetz-trunk/make/bird/files/root/usr
A    freetz-trunk/make/bird/files/root/usr/lib
A    freetz-trunk/make/bird/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/bird/files/root/usr/lib/cgi-bin/bird.cgi
A    freetz-trunk/make/bird/files/root/etc
A    freetz-trunk/make/bird/files/root/etc/default.bird
A    freetz-trunk/make/bird/files/root/etc/default.bird/bird_conf.def
A    freetz-trunk/make/bird/files/root/etc/default.bird/bird.cfg
A    freetz-trunk/make/bird/files/root/etc/init.d
A    freetz-trunk/make/bird/files/root/etc/init.d/rc.bird
A    freetz-trunk/make/bird/files/README
A    freetz-trunk/make/bird/external.files
A    freetz-trunk/make/bird/external.services
A    freetz-trunk/make/bird/bird.mk
A    freetz-trunk/make/bird/external.in
A    freetz-trunk/make/bird/patches
A    freetz-trunk/make/bird/patches/003_birdc-fix-buffer-overflow.patch
A    freetz-trunk/make/bird/patches/102_rules_in.patch
A    freetz-trunk/make/bird/patches/002_netlink.patch
A    freetz-trunk/make/bird/patches/101_disable-default-debug.patch
A    freetz-trunk/make/bird/patches/100_fix-debugging-paths.patch
A    freetz-trunk/make/bird/patches/004_birdc-include-more-headers.patch
A    freetz-trunk/make/bird/Config.in
A    freetz-trunk/make/privoxy
A    freetz-trunk/make/privoxy/files
A    freetz-trunk/make/privoxy/files/.language
A    freetz-trunk/make/privoxy/files/root
A    freetz-trunk/make/privoxy/files/root/usr
A    freetz-trunk/make/privoxy/files/root/usr/lib
A    freetz-trunk/make/privoxy/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/privoxy/files/root/usr/lib/cgi-bin/privoxy.cgi
A    freetz-trunk/make/privoxy/files/root/etc
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy/filter.def
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy/privoxy_conf
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy/action.def
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy/privoxy.save
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy/privoxy_loadeasylist
A    freetz-trunk/make/privoxy/files/root/etc/default.privoxy/privoxy.cfg
A    freetz-trunk/make/privoxy/files/root/etc/init.d
A    freetz-trunk/make/privoxy/files/root/etc/init.d/rc.privoxy
A    freetz-trunk/make/privoxy/files/README
A    freetz-trunk/make/privoxy/external.files
A    freetz-trunk/make/privoxy/external.services
A    freetz-trunk/make/privoxy/privoxy.mk
A    freetz-trunk/make/privoxy/external.in
A    freetz-trunk/make/privoxy/patches
A    freetz-trunk/make/privoxy/patches/100-missing_strptime_prototype.patch
A    freetz-trunk/make/privoxy/patches/110-dont_link_libnsl.patch
A    freetz-trunk/make/privoxy/Config.in
A    freetz-trunk/make/lua
A    freetz-trunk/make/lua/external.in.libs
A    freetz-trunk/make/lua/Config.in.libs
A    freetz-trunk/make/lua/external.files
A    freetz-trunk/make/lua/lua.mk
A    freetz-trunk/make/lua/patches
A    freetz-trunk/make/lua/patches/130-optimization_flags.patch
A    freetz-trunk/make/lua/patches/020-shared-liblua_LUA_API.patch
A    freetz-trunk/make/lua/patches/030-archindependent-bytecode.patch
A    freetz-trunk/make/lua/patches/200-lua-path.patch
A    freetz-trunk/make/lua/patches/020-shared-liblua.patch
A    freetz-trunk/make/lua/patches/100-noreadline.patch
A    freetz-trunk/make/netsnmp
A    freetz-trunk/make/netsnmp/files
A    freetz-trunk/make/netsnmp/files/.language
A    freetz-trunk/make/netsnmp/files/root
A    freetz-trunk/make/netsnmp/files/root/usr
A    freetz-trunk/make/netsnmp/files/root/usr/lib
A    freetz-trunk/make/netsnmp/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/netsnmp/files/root/usr/lib/cgi-bin/netsnmp.cgi
A    freetz-trunk/make/netsnmp/files/root/etc
A    freetz-trunk/make/netsnmp/files/root/etc/init.d
A    freetz-trunk/make/netsnmp/files/root/etc/init.d/rc.netsnmp
A    freetz-trunk/make/netsnmp/files/root/etc/default.netsnmp
A    freetz-trunk/make/netsnmp/files/root/etc/default.netsnmp/netsnmp.cfg
A    freetz-trunk/make/netsnmp/files/root/etc/default.netsnmp/snmpd_conf.def
A    freetz-trunk/make/netsnmp/files/README
A    freetz-trunk/make/netsnmp/patches
A    freetz-trunk/make/netsnmp/patches/140-no_ldconfig.patch
A    freetz-trunk/make/netsnmp/patches/750-ieee802dot11.patch
A    freetz-trunk/make/netsnmp/patches/050-no_SIOCMIIPHY_syscall.patch
A    freetz-trunk/make/netsnmp/patches/120-debian-searchdirs.patch
A    freetz-trunk/make/netsnmp/patches/200-openssl_test_fix.patch
A    freetz-trunk/make/netsnmp/patches/100-debian-statistics.patch
A    freetz-trunk/make/netsnmp/patches/300-fix_ASN_INT64.patch
A    freetz-trunk/make/netsnmp/patches/010-disable_inline.patch
A    freetz-trunk/make/netsnmp/patches/110-debian-makefiles.patch
A    freetz-trunk/make/netsnmp/patches/130-debian-extramibs.patch
A    freetz-trunk/make/netsnmp/patches/150-ldflags.patch
A    freetz-trunk/make/netsnmp/Config.in
A    freetz-trunk/make/netsnmp/netsnmp.mk
A    freetz-trunk/make/syslogd-cgi
A    freetz-trunk/make/syslogd-cgi/files
A    freetz-trunk/make/syslogd-cgi/files/.language
A    freetz-trunk/make/syslogd-cgi/files/root
A    freetz-trunk/make/syslogd-cgi/files/root/usr
A    freetz-trunk/make/syslogd-cgi/files/root/usr/lib
A    freetz-trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin/syslogd
A    freetz-trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin/syslogd/log.cgi
A    freetz-trunk/make/syslogd-cgi/files/root/usr/lib/cgi-bin/syslogd.cgi
A    freetz-trunk/make/syslogd-cgi/files/root/etc
A    freetz-trunk/make/syslogd-cgi/files/root/etc/init.d
A    freetz-trunk/make/syslogd-cgi/files/root/etc/init.d/rc.syslogd
A    freetz-trunk/make/syslogd-cgi/files/root/etc/default.syslogd
A    freetz-trunk/make/syslogd-cgi/files/root/etc/default.syslogd/syslogd.cfg
A    freetz-trunk/make/syslogd-cgi/Config.in
A    freetz-trunk/make/syslogd-cgi/syslogd-cgi.mk
A    freetz-trunk/make/rrdtool
A    freetz-trunk/make/rrdtool/external.in.libs
A    freetz-trunk/make/rrdtool/Config.in.libs
A    freetz-trunk/make/rrdtool/Makefile.in
A    freetz-trunk/make/rrdtool/files
A    freetz-trunk/make/rrdtool/files/root
A    freetz-trunk/make/rrdtool/files/root/usr
A    freetz-trunk/make/rrdtool/files/root/usr/share
A    freetz-trunk/make/rrdtool/files/root/usr/share/rrdtool
A    freetz-trunk/make/rrdtool/files/root/usr/share/rrdtool/fonts
A    freetz-trunk/make/rrdtool/files/root/usr/share/rrdtool/fonts/DejaVuSansMono-Roman.ttf
A    freetz-trunk/make/rrdtool/files/README
A    freetz-trunk/make/rrdtool/external.files
A    freetz-trunk/make/rrdtool/patches
A    freetz-trunk/make/rrdtool/patches/010-dont-add-host-include-paths.patch
A    freetz-trunk/make/rrdtool/rrdtool.mk
A    freetz-trunk/make/nc6
A    freetz-trunk/make/nc6/external.files
A    freetz-trunk/make/nc6/external.in
A    freetz-trunk/make/nc6/Config.in
A    freetz-trunk/make/nc6/nc6.mk
A    freetz-trunk/make/inadyn-opendns
A    freetz-trunk/make/inadyn-opendns/files
A    freetz-trunk/make/inadyn-opendns/files/.language
A    freetz-trunk/make/inadyn-opendns/files/root
A    freetz-trunk/make/inadyn-opendns/files/root/usr
A    freetz-trunk/make/inadyn-opendns/files/root/usr/lib
A    freetz-trunk/make/inadyn-opendns/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/inadyn-opendns/files/root/usr/lib/cgi-bin/inadyn-opendns.cgi
A    freetz-trunk/make/inadyn-opendns/files/root/etc
A    freetz-trunk/make/inadyn-opendns/files/root/etc/init.d
A    freetz-trunk/make/inadyn-opendns/files/root/etc/init.d/rc.inadyn-opendns
A    freetz-trunk/make/inadyn-opendns/files/root/etc/default.inadyn-opendns
A    freetz-trunk/make/inadyn-opendns/files/root/etc/default.inadyn-opendns/inadyn-opendns.cfg
A    freetz-trunk/make/inadyn-opendns/files/root/etc/default.inadyn-opendns/inadyn-opendns_conf
A    freetz-trunk/make/inadyn-opendns/patches
A    freetz-trunk/make/inadyn-opendns/patches/100-makefile.patch
A    freetz-trunk/make/inadyn-opendns/Config.in
A    freetz-trunk/make/inadyn-opendns/inadyn-opendns.mk
A    freetz-trunk/make/external.in
A    freetz-trunk/make/openntpd
A    freetz-trunk/make/openntpd/files
A    freetz-trunk/make/openntpd/files/.language
A    freetz-trunk/make/openntpd/files/root
A    freetz-trunk/make/openntpd/files/root/usr
A    freetz-trunk/make/openntpd/files/root/usr/lib
A    freetz-trunk/make/openntpd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/openntpd/files/root/usr/lib/cgi-bin/openntpd.cgi
A    freetz-trunk/make/openntpd/files/root/etc
A    freetz-trunk/make/openntpd/files/root/etc/init.d
A    freetz-trunk/make/openntpd/files/root/etc/init.d/rc.openntpd
A    freetz-trunk/make/openntpd/files/root/etc/default.openntpd
A    freetz-trunk/make/openntpd/files/root/etc/default.openntpd/openntpd.cfg
A    freetz-trunk/make/openntpd/files/root/etc/default.openntpd/openntpd_conf.def
A    freetz-trunk/make/openntpd/files/README.extension
A    freetz-trunk/make/openntpd/patches
A    freetz-trunk/make/openntpd/patches/110-TIK_extension.patch
A    freetz-trunk/make/openntpd/patches/101-adjtimex_linux.patch
A    freetz-trunk/make/openntpd/patches/102-save_freq_drift.patch
A    freetz-trunk/make/openntpd/patches/010-ar_fix.patch
A    freetz-trunk/make/openntpd/patches/011-missing_prototypes_fix.patch
A    freetz-trunk/make/openntpd/patches/200-warn-unsupp-servers.debian.patch
A    freetz-trunk/make/openntpd/Config.in
A    freetz-trunk/make/openntpd/openntpd.mk
A    freetz-trunk/make/smusbutil
A    freetz-trunk/make/smusbutil/patches
A    freetz-trunk/make/smusbutil/patches/more_devices.patch
A    freetz-trunk/make/smusbutil/patches/make_variables.patch
A    freetz-trunk/make/smusbutil/Config.in
A    freetz-trunk/make/smusbutil/smusbutil.mk
A    freetz-trunk/make/transmission-cgi
A    freetz-trunk/make/transmission-cgi/transmission-cgi.mk
A    freetz-trunk/make/transmission-cgi/files
A    freetz-trunk/make/transmission-cgi/files/.language
A    freetz-trunk/make/transmission-cgi/files/root
A    freetz-trunk/make/transmission-cgi/files/root/usr
A    freetz-trunk/make/transmission-cgi/files/root/usr/lib
A    freetz-trunk/make/transmission-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/transmission-cgi/files/root/usr/lib/cgi-bin/transmission.cgi
A    freetz-trunk/make/transmission-cgi/files/root/etc
A    freetz-trunk/make/transmission-cgi/files/root/etc/init.d
A    freetz-trunk/make/transmission-cgi/files/root/etc/init.d/rc.transmission
A    freetz-trunk/make/transmission-cgi/files/root/etc/default.transmission
A    freetz-trunk/make/transmission-cgi/files/root/etc/default.transmission/transmission.cfg
A    freetz-trunk/make/transmission-cgi/Config.in
A    freetz-trunk/make/bridge-utils
A    freetz-trunk/make/bridge-utils/bridge-utils.mk
A    freetz-trunk/make/bridge-utils/patches
A    freetz-trunk/make/bridge-utils/patches/100-Makefile.patch
A    freetz-trunk/make/bridge-utils/Config.in
A    freetz-trunk/make/nano
A    freetz-trunk/make/nano/nano.mk
A    freetz-trunk/make/nano/files
A    freetz-trunk/make/nano/files/.language
A    freetz-trunk/make/nano/files/root
A    freetz-trunk/make/nano/files/root/usr
A    freetz-trunk/make/nano/files/root/usr/bin
A    freetz-trunk/make/nano/files/root/usr/bin/mnano
A    freetz-trunk/make/nano/files/root/usr/bin/nnano
A    freetz-trunk/make/nano/files/root/etc
A    freetz-trunk/make/nano/files/root/etc/nanorc
A    freetz-trunk/make/nano/files/root/etc/init.d
A    freetz-trunk/make/nano/files/root/etc/init.d/rc.nano
A    freetz-trunk/make/nano/files/root/etc/.nanorc
A    freetz-trunk/make/nano/files/root/etc/default.nano
A    freetz-trunk/make/nano/files/root/etc/default.nano/nanorc.options-fancy
A    freetz-trunk/make/nano/files/root/etc/default.nano/nanorc.options-tiny
A    freetz-trunk/make/nano/files/root/etc/default.nano/nanorc.def
A    freetz-trunk/make/nano/files/README
A    freetz-trunk/make/nano/external.files
A    freetz-trunk/make/nano/external.in
A    freetz-trunk/make/nano/patches
A    freetz-trunk/make/nano/patches/100_no_libintl.patch
A    freetz-trunk/make/nano/patches/200_force-GNU-wordbounds.patch
A    freetz-trunk/make/nano/patches/300_fix-segfault-on-file-overwrite.patch
A    freetz-trunk/make/nano/Config.in
A    freetz-trunk/make/minidlna
A    freetz-trunk/make/minidlna/minidlna.mk
A    freetz-trunk/make/minidlna/files
A    freetz-trunk/make/minidlna/files/.language
A    freetz-trunk/make/minidlna/files/root
A    freetz-trunk/make/minidlna/files/root/usr
A    freetz-trunk/make/minidlna/files/root/usr/lib
A    freetz-trunk/make/minidlna/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/minidlna/files/root/usr/lib/cgi-bin/minidlna.cgi
A    freetz-trunk/make/minidlna/files/root/etc
A    freetz-trunk/make/minidlna/files/root/etc/init.d
A    freetz-trunk/make/minidlna/files/root/etc/init.d/rc.minidlna
A    freetz-trunk/make/minidlna/files/root/etc/default.minidlna
A    freetz-trunk/make/minidlna/files/root/etc/default.minidlna/minidlna_conf
A    freetz-trunk/make/minidlna/files/root/etc/default.minidlna/minidlna.cfg
A    freetz-trunk/make/minidlna/external.files
A    freetz-trunk/make/minidlna/external.services
A    freetz-trunk/make/minidlna/external.in
A    freetz-trunk/make/minidlna/patches
A    freetz-trunk/make/minidlna/patches/120-ignore_own_pid.patch
A    freetz-trunk/make/minidlna/patches/110-include-fixes.patch
A    freetz-trunk/make/minidlna/patches/100-cross_compile.patch
A    freetz-trunk/make/minidlna/Config.in
A    freetz-trunk/make/busybox
A    freetz-trunk/make/busybox/busybox.mk
A    freetz-trunk/make/busybox/Makefile.in
A    freetz-trunk/make/busybox/generate.sh
A    freetz-trunk/make/busybox/Config.in.busybox
A    freetz-trunk/make/busybox/patches
A    freetz-trunk/make/busybox/patches/604-httpdstar.patch
A    freetz-trunk/make/busybox/patches/130-scripts_bash.patch
A    freetz-trunk/make/busybox/patches/470-insmod_search.patch
A    freetz-trunk/make/busybox/patches/000-busybox-1.21.0-platform.patch
A    freetz-trunk/make/busybox/patches/711-revert_crtscts_fix.patch
A    freetz-trunk/make/busybox/patches/480-copy_file_dev_node_fix.patch
A    freetz-trunk/make/busybox/patches/101-init_avoid_loop_opening_tty.patch
A    freetz-trunk/make/busybox/patches/110-wget_getopt_fix.patch
A    freetz-trunk/make/busybox/patches/000-busybox-1.21.0-mdev.patch
A    freetz-trunk/make/busybox/patches/220-httpd-pidfile.patch
A    freetz-trunk/make/busybox/patches/602-telnetd_intr.patch
A    freetz-trunk/make/busybox/patches/110-busybox-nolock-as-default.patch
A    freetz-trunk/make/busybox/patches/320-mdev_scan_file.patch
A    freetz-trunk/make/busybox/patches/440-httpd_chdir.patch
A    freetz-trunk/make/busybox/patches/000-busybox-1.21.0-xz.patch
A    freetz-trunk/make/busybox/patches/720-stun-ip.patch
A    freetz-trunk/make/busybox/patches/503-id_getgrouplist.patch
A    freetz-trunk/make/busybox/patches/712-revert_read_sighandler.patch
A    freetz-trunk/make/busybox/patches/100-autoconf.patch
A    freetz-trunk/make/busybox/patches/450-httpd_REDIRECT_STATUS.patch
A    freetz-trunk/make/busybox/patches/350-httpd_redir.patch
A    freetz-trunk/make/busybox/patches/605-blkid_mtdworkaround.patch
A    freetz-trunk/make/busybox/patches/620-findfs.patch
A    freetz-trunk/make/busybox/patches/210-telnet-close-on-exit.patch
A    freetz-trunk/make/busybox/patches/615-blkid_bogus_device_handling.patch
A    freetz-trunk/make/busybox/busybox.rebuild-subopts.mk.in
A    freetz-trunk/make/vim
A    freetz-trunk/make/vim/vim.mk
A    freetz-trunk/make/vim/files
A    freetz-trunk/make/vim/files/root
A    freetz-trunk/make/vim/files/root/usr
A    freetz-trunk/make/vim/files/root/usr/share
A    freetz-trunk/make/vim/files/root/usr/share/vim
A    freetz-trunk/make/vim/files/root/usr/share/vim/vimrc
A    freetz-trunk/make/vim/files/root/etc
A    freetz-trunk/make/vim/files/root/etc/vimrc
A    freetz-trunk/make/vim/external.files
A    freetz-trunk/make/vim/external.in
A    freetz-trunk/make/vim/patches
A    freetz-trunk/make/vim/patches/100-cross_compile.patch
A    freetz-trunk/make/vim/Config.in
A    freetz-trunk/make/python-pycurl
A    freetz-trunk/make/python-pycurl/python-pycurl.mk
A    freetz-trunk/make/python-pycurl/patches
A    freetz-trunk/make/python-pycurl/patches/020-dont_install_data_files.patch
A    freetz-trunk/make/python-pycurl/patches/010-no_static.openwrt.patch
A    freetz-trunk/make/python-pycurl/Config.in
A    freetz-trunk/make/fowsr
A    freetz-trunk/make/fowsr/external.files
A    freetz-trunk/make/fowsr/fowsr.mk
A    freetz-trunk/make/fowsr/external.in
A    freetz-trunk/make/fowsr/Config.in
A    freetz-trunk/make/bfusb
A    freetz-trunk/make/bfusb/bfusb.mk
A    freetz-trunk/make/bfusb/Config.in
A    freetz-trunk/make/wol/external.files
A    freetz-trunk/make/wol/external.in
A    freetz-trunk/make/wol/wol.mk
A    freetz-trunk/make/wol/Config.in
A    freetz-trunk/make/cpmaccfg-cgi
A    freetz-trunk/make/cpmaccfg-cgi/files
A    freetz-trunk/make/cpmaccfg-cgi/files/root
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr/share
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr/share/images
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr/share/images/avm-hinten.jpg
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr/lib
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/cpmaccfg-cgi/files/root/usr/lib/cgi-bin/cpmaccfg.cgi
A    freetz-trunk/make/cpmaccfg-cgi/files/root/etc
A    freetz-trunk/make/cpmaccfg-cgi/files/root/etc/init.d
A    freetz-trunk/make/cpmaccfg-cgi/files/root/etc/init.d/rc.cpmaccfg
A    freetz-trunk/make/cpmaccfg-cgi/files/root/etc/default.cpmaccfg
A    freetz-trunk/make/cpmaccfg-cgi/files/root/etc/default.cpmaccfg/cpmaccfg.save
A    freetz-trunk/make/cpmaccfg-cgi/files/root/etc/default.cpmaccfg/cpmaccfg.cfg
A    freetz-trunk/make/cpmaccfg-cgi/files/README
A    freetz-trunk/make/cpmaccfg-cgi/cpmaccfg-cgi.mk
A    freetz-trunk/make/cpmaccfg-cgi/Config.in
A    freetz-trunk/make/knock
A    freetz-trunk/make/knock/files
A    freetz-trunk/make/knock/files/.language
A    freetz-trunk/make/knock/files/root
A    freetz-trunk/make/knock/files/root/usr
A    freetz-trunk/make/knock/files/root/usr/share
A    freetz-trunk/make/knock/files/root/usr/share/doc
A    freetz-trunk/make/knock/files/root/usr/share/doc/knock
A    freetz-trunk/make/knock/files/root/usr/share/doc/knock/knockd.conf
A    freetz-trunk/make/knock/files/root/usr/lib
A    freetz-trunk/make/knock/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/knock/files/root/usr/lib/cgi-bin/knock.cgi
A    freetz-trunk/make/knock/files/root/etc
A    freetz-trunk/make/knock/files/root/etc/init.d
A    freetz-trunk/make/knock/files/root/etc/init.d/rc.knock
A    freetz-trunk/make/knock/files/root/etc/default.knock
A    freetz-trunk/make/knock/files/root/etc/default.knock/knock.cfg
A    freetz-trunk/make/knock/files/root/etc/default.knock/knockd_conf.def
A    freetz-trunk/make/knock/files/root/etc/onlinechanged
A    freetz-trunk/make/knock/files/root/etc/onlinechanged/knock
A    freetz-trunk/make/knock/external.files
A    freetz-trunk/make/knock/external.services
A    freetz-trunk/make/knock/external.in
A    freetz-trunk/make/knock/patches
A    freetz-trunk/make/knock/patches/100-debian-reap_child_procs.patch
A    freetz-trunk/make/knock/patches/101-smaller_snaplen.patch
A    freetz-trunk/make/knock/Config.in
A    freetz-trunk/make/knock/knock.mk
A    freetz-trunk/make/.gitignore
A    freetz-trunk/make/ngircd
A    freetz-trunk/make/ngircd/files
A    freetz-trunk/make/ngircd/files/.language
A    freetz-trunk/make/ngircd/files/root
A    freetz-trunk/make/ngircd/files/root/usr
A    freetz-trunk/make/ngircd/files/root/usr/lib
A    freetz-trunk/make/ngircd/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/ngircd/files/root/usr/lib/cgi-bin/ngircd.cgi
A    freetz-trunk/make/ngircd/files/root/etc
A    freetz-trunk/make/ngircd/files/root/etc/init.d
A    freetz-trunk/make/ngircd/files/root/etc/init.d/rc.ngircd
A    freetz-trunk/make/ngircd/files/root/etc/default.ngircd
A    freetz-trunk/make/ngircd/files/root/etc/default.ngircd/ngircd.cfg
A    freetz-trunk/make/ngircd/files/root/etc/default.ngircd/ngircd_conf.def
A    freetz-trunk/make/ngircd/external.files
A    freetz-trunk/make/ngircd/external.services
A    freetz-trunk/make/ngircd/external.in
A    freetz-trunk/make/ngircd/patches
A    freetz-trunk/make/ngircd/patches/100_static_crypto.patch
A    freetz-trunk/make/ngircd/Config.in
A    freetz-trunk/make/ngircd/ngircd.mk
A    freetz-trunk/make/rrdstats
A    freetz-trunk/make/rrdstats/files
A    freetz-trunk/make/rrdstats/files/.language
A    freetz-trunk/make/rrdstats/files/root
A    freetz-trunk/make/rrdstats/files/root/usr
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd/style
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd/images
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd/cgi-bin
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd/cgi-bin/index.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd/statpix
A    freetz-trunk/make/rrdstats/files/root/usr/mww-rrd/favicon.ico
A    freetz-trunk/make/rrdstats/files/root/usr/lib
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/stats.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/rrddt.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/index-stats.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/index-rrddt.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/main.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats/dt-init.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/lib/cgi-bin/rrdstats.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/bin
A    freetz-trunk/make/rrdstats/files/root/usr/bin/webcfg-rrd
A    freetz-trunk/make/rrdstats/files/root/usr/bin/rrdstats
A    freetz-trunk/make/rrdstats/files/root/usr/bin/webcfg-one
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one/style
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one/images
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one/cgi-bin
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one/cgi-bin/index.cgi
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one/statpix
A    freetz-trunk/make/rrdstats/files/root/usr/mww-one/favicon.ico
A    freetz-trunk/make/rrdstats/files/root/usr/mww/statpix
A    freetz-trunk/make/rrdstats/files/root/etc
A    freetz-trunk/make/rrdstats/files/root/etc/init.d
A    freetz-trunk/make/rrdstats/files/root/etc/init.d/rc.rrdstats
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/rrdstats.cfg
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/webcfg-rrd.inetd
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-conf.def
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/httpd-one_conf
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-alert.def
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-alias.def
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/httpd-rrd_conf
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/dt-group.def
A    freetz-trunk/make/rrdstats/files/root/etc/default.rrdstats/webcfg-one.inetd
A    freetz-trunk/make/rrdstats/external.services
A    freetz-trunk/make/rrdstats/Config.in
A    freetz-trunk/make/rrdstats/rrdstats.mk
A    freetz-trunk/make/obexftp
A    freetz-trunk/make/obexftp/external.files
A    freetz-trunk/make/obexftp/external.in
A    freetz-trunk/make/obexftp/Config.in
A    freetz-trunk/make/obexftp/obexftp.mk
A    freetz-trunk/make/python-pycrypto
A    freetz-trunk/make/python-pycrypto/patches
A    freetz-trunk/make/python-pycrypto/patches/010-no_host_paths.openwrt.patch
A    freetz-trunk/make/python-pycrypto/patches/030-honor_freetz_compiler_flags.patch
A    freetz-trunk/make/python-pycrypto/patches/020-target_endianess.patch
A    freetz-trunk/make/python-pycrypto/patches/040-no_tests.patch
A    freetz-trunk/make/python-pycrypto/Config.in
A    freetz-trunk/make/python-pycrypto/python-pycrypto.mk
A    freetz-trunk/make/bash
A    freetz-trunk/make/bash/bash.mk
A    freetz-trunk/make/bash/external.files
A    freetz-trunk/make/bash/external.in
A    freetz-trunk/make/bash/patches
A    freetz-trunk/make/bash/patches/bash32-050.patch
A    freetz-trunk/make/bash/patches/bash32-051.patch
A    freetz-trunk/make/bash/patches/bash32-049.patch
A    freetz-trunk/make/bash/Config.in
 U   freetz-trunk
Ausgecheckt, Revision 10273.
joerg@joerg-desktop:/run/shm/tmp$ cd freetz-trunk/
joerg@joerg-desktop:/run/shm/tmp/freetz-trunk$ ls .config
ls: Zugriff auf .config nicht möglich: Datei oder Verzeichnis nicht gefunden
joerg@joerg-desktop:/run/shm/tmp/freetz-trunk$ make menuconfig
tools/freetz_download dl kconfig-v3.8.tar.xz git_archive@git://repo.or.cz/linux-2.6.git,scripts/basic,scripts/kconfig,scripts/Kbuild.include,scripts/Makefile.build,scripts/Makefile.host,scripts/Makefile.lib
--2013-03-18 20:30:16--  http://freetz.3dfxatwork.de/kconfig-v3.8.tar.xz
Auflösen des Hostnamen »freetz.3dfxatwork.de (freetz.3dfxatwork.de)«... 85.214.81.232, 2a01:238:4362:b900:fc60:1b77:4435:1ba9
Verbindungsaufbau zu freetz.3dfxatwork.de (freetz.3dfxatwork.de)|85.214.81.232|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 129520 (126K) [application/x-tar]
In »»dl/kconfig-v3.8.tar.xz«« speichern.
100%[===================================================================================================================================>] 129.520      837K/s   in 0,2s
2013-03-18 20:30:16 (837 KB/s) - »»dl/kconfig-v3.8.tar.xz«« gespeichert [129520/129520]
Download succeeded - "http://freetz.3dfxatwork.de/kconfig-v3.8.tar.xz"  ->  saved to folder "dl"
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf dl/kconfig-v3.8.tar.xz
for i in tools/make/patches/*.kconfig.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8 $i; \
	done;
    applying patch file tools/make/patches/300-main_makefile.kconfig.patch
    patching file Makefile
    applying patch file tools/make/patches/310-fix_make.kconfig.patch
    patching file scripts/kconfig/Makefile
    applying patch file tools/make/patches/320-unchangable_style.kconfig.patch
    patching file scripts/kconfig/mconf.c
    applying patch file tools/make/patches/330-comment_style.kconfig.patch
    applying patch file tools/make/patches/340-fix_randconfig_choice.kconfig.patch
    patching file scripts/kconfig/confdata.c
    applying patch file tools/make/patches/350-do_not_select_unmet_direct_dependencies.kconfig.patch
    patching file scripts/kconfig/symbol.c
    applying patch file tools/make/patches/360-max_item_count_for_choice_dialog.kconfig.patch
    applying patch file tools/make/patches/370-save-hidden-prompts-to-file.kconfig.patch
    patching file scripts/kconfig/menu.c
touch /run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8/.unpacked
make -j -C /run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8 menuconfig
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
  HOSTCC  scripts/basic/fixdep
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
  HOSTCC  scripts/kconfig/conf.o
  HOSTCC  scripts/kconfig/mconf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/zconf.lex.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/lxdialog/checklist.o
  HOSTCC  scripts/kconfig/lxdialog/inputbox.o
  HOSTCC  scripts/kconfig/lxdialog/menubox.o
  HOSTCC  scripts/kconfig/lxdialog/textbox.o
  HOSTCC  scripts/kconfig/lxdialog/util.o
  HOSTCC  scripts/kconfig/lxdialog/yesno.o
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/mconf
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
cp /run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8/scripts/kconfig/mconf tools/config/mconf
# configuration written to .config
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
.config
joerg@joerg-desktop:/run/shm/tmp/freetz-trunk$ cat .config
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
FREETZ_USER_LEVEL_BEGINNER=y
# FREETZ_USER_LEVEL_ADVANCED is not set
# FREETZ_USER_LEVEL_EXPERT is not set
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6840 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
FREETZ_TYPE_7270_V3=y
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_XL is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7390 is not set
# VDSL
# FREETZ_TYPE_7570 is not set
FREETZ_TYPE_7270=y
# FREETZ_TYPE_LANG_DE is not set
FREETZ_TYPE_LANG_EN=y
FREETZ_TYPE_FIRMWARE_05_2X=y
# FREETZ_TYPE_FIRMWARE_05_5X is not set
FREETZ_TYPE_FIRMWARE_FINAL=y
FREETZ_TYPE_LANGUAGE="en"
# FREETZ_TYPE_ALIEN_HARDWARE is not set
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Removal patches
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
# Remove piglet
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_NAS is not set
# FREETZ_REMOVE_FHEM is not set
# FREETZ_REMOVE_AVM_VPN is not set
# Remove brandings
# FREETZ_REMOVE_BRANDING_avme is not set
# FREETZ_REMOVE_BRANDING_otwo is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_CHRONYD is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_JFFS2 is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NTFS is not set
# FREETZ_REMOVE_PRINTSERV is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SAMBA is not set
# FREETZ_REMOVE_SUPPORT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_REMOVE_UMTSD is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
FREETZ_REMOVE_AVM_E2FSPROGS=y
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WEBDAV is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_DSL_EXPERT is not set
# FREETZ_PATCH_GSMVOICE is not set
# FREETZ_PATCH_SIGNED is not set
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_EXT4 is not set
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_MODIFY_UMTSD is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# FREETZ_REPLACE_DTRACE is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
# FREETZ_AVMDAEMON_DISABLE_TR069 is not set
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Additional components ------------------
# Packages
# *** not all packages support selected language ***
# FREETZ_SELECTED_LANG_ONLY is not set
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Standard packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# Cifsmount (not available, needs replace kernel)
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FUSE is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PORTMAP is not set
# Point-to-Point
# FREETZ_PACKAGE_PPPD is not set
# FREETZ_PACKAGE_PPPD_CHAT is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_XMAIL is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_HAPROXY is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
# FREETZ_PACKAGE_OPENSSH_sftp_server is not set
# FREETZ_PACKAGE_OPENSSL is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RIPMIME is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_TIFF is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Web interfaces
# FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
# FREETZ_PACKAGE_AVM_FIREWALL is not set
# FREETZ_PACKAGE_CPMACCFG_CGI is not set
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HP_UTILS is not set
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_IPTABLES is not set
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# FREETZ_PACKAGE_SQUID is not set
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md5 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libpolarssl_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl_WITH_GENRSA is not set
# FREETZ_LIB_libcrypto is not set
# FREETZ_OPENSSL_VERSION_PROMPT is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libexif is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_liblept is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libopus is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# USB & FTDI
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libffi is not set
FREETZ_LIB_libctlmgr=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprotobuf_c is not set
# FREETZ_LIB_librrd is not set
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
FREETZ_KERNEL_VERSION_2_6_32=y
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_UR8=y
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_MODULES_KVER="2.6.32.41"
# block
# FREETZ_MODULE_block2mtd is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
# FREETZ_MODULE_crypto_algapi is not set
# FREETZ_MODULE_crypto_blkcipher is not set
# FREETZ_MODULE_crypto_hash is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_sha1_generic is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_ext4 is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd2 is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc16 is not set
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_BUNZIP2 is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
# FREETZ_BUSYBOX_UNLZMA is not set
# FREETZ_BUSYBOX_UNXZ is not set
# FREETZ_BUSYBOX_UNZIP is not set
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
# FREETZ_BUSYBOX_GROUPS is not set
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
# FREETZ_BUSYBOX_CHGRP is not set
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
# FREETZ_BUSYBOX_CHROOT is not set
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
# FREETZ_BUSYBOX_LOGNAME is not set
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
# FREETZ_BUSYBOX_MD5SUM is not set
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
# FREETZ_BUSYBOX_NICE is not set
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
# FREETZ_BUSYBOX_PRINTENV is not set
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
# FREETZ_BUSYBOX_READLINK is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
# FREETZ_BUSYBOX_UNIQ is not set
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
# FREETZ_BUSYBOX_UUENCODE is not set
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
# FREETZ_BUSYBOX_FGCONSOLE is not set
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
# FREETZ_BUSYBOX_RESET is not set
# FREETZ_BUSYBOX_RESIZE is not set
# FREETZ_BUSYBOX_SETCONSOLE is not set
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WHICH=y
# Editors
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
# FREETZ_BUSYBOX_CMP is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
# FREETZ_BUSYBOX_FLOCK is not set
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
# FREETZ_BUSYBOX_HEXDUMP is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
# FREETZ_BUSYBOX_MORE is not set
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
# FREETZ_BUSYBOX_SWITCH_ROOT is not set
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SQUASHFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_SETSERIAL is not set
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
# FREETZ_BUSYBOX_UBIMKVOL is not set
# FREETZ_BUSYBOX_UBIRMVOL is not set
# FREETZ_BUSYBOX_UBIRSVOL is not set
# FREETZ_BUSYBOX_UBIUPDATEVOL is not set
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RFKILL is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
# FREETZ_BUSYBOX_TASKSET is not set
# FREETZ_BUSYBOX_TIME is not set
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
# FREETZ_BUSYBOX_NBDCLIENT is not set
# FREETZ_BUSYBOX_NC is not set
FREETZ_BUSYBOX_PING=y
# FREETZ_BUSYBOX_PING6 is not set
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
# FREETZ_BUSYBOX_ARP is not set
# FREETZ_BUSYBOX_ARPING is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
# FREETZ_BUSYBOX_FTPGET is not set
# FREETZ_BUSYBOX_FTPPUT is not set
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
# FREETZ_BUSYBOX_NSLOOKUP is not set
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
# FREETZ_BUSYBOX_TELNET is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
# FREETZ_BUSYBOX_TFTP is not set
# FREETZ_BUSYBOX_TFTPD is not set
# FREETZ_BUSYBOX_TRACEROUTE is not set
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
# FREETZ_BUSYBOX_WGET is not set
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
# FREETZ_BUSYBOX_IOSTAT is not set
# FREETZ_BUSYBOX_LSOF is not set
# FREETZ_BUSYBOX_MPSTAT is not set
# FREETZ_BUSYBOX_NMETER is not set
# FREETZ_BUSYBOX_PMAP is not set
# FREETZ_BUSYBOX_POWERTOP is not set
# FREETZ_BUSYBOX_PSTREE is not set
# FREETZ_BUSYBOX_PWDX is not set
# FREETZ_BUSYBOX_SMEMCAP is not set
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
# FREETZ_BUSYBOX_KILLALL5 is not set
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
# FREETZ_BUSYBOX_RENICE is not set
FREETZ_BUSYBOX_BB_SYSCTL=y
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
FREETZ_SECURITY_LEVEL=1
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
# FREETZ_SKIN_phoenix is not set
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_DEVELOPER_VERSION_STRING is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# FREETZ_GCC_3_4_COMPILED_KERNEL is not set
FREETZ_GCC_4_6_COMPILED_KERNEL=y
# FREETZ_UCLIBC_0_9_28_BASED_BOX is not set
# FREETZ_UCLIBC_0_9_29_BASED_BOX is not set
FREETZ_UCLIBC_0_9_32_BASED_BOX=y
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_COMPILER_GCC_4_6=y
FREETZ_KERNEL_GCC_VERSION="4.6.3"
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_VERSION_0_9_32=y
FREETZ_TARGET_COMPILER_GCC_4_6=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_GCC_VERSION="4.6.3"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_SCRIPTS is not set
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r9637"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="b17b7f26931ad8f263953a2dfc1d08b7"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r9637"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="bc1fa16bb96c2460207059539c9bee00"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="e396bbfcbd88c09cfcc652f94b7f8a57"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7270_v3/firmware/english"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image"
FREETZ_DL_SOURCE_MD5="0f2406d342e7ce0ce987296bca46cfe6"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
# FREETZ_HAS_AVM_LABOR is not set
# FREETZ_HAS_AVM_FW55X is not set
FREETZ_HAS_AVM_FW52X=y
# FREETZ_HAS_AVM_FW4XX is not set
FREETZ_HAS_AVM_PRINTK=y
# FREETZ_HAS_AVM_PIGLET is not set
FREETZ_HAS_AVM_PTY_SUPPORT=y
# FREETZ_HAS_AVM_CDROM_ISO is not set
FREETZ_HAS_AVM_AURA_USB=y
# FREETZ_HAS_AVM_MINID is not set
FREETZ_HAS_AVM_NTFS=y
FREETZ_HAS_AVM_IPV6=y
FREETZ_HAS_AVM_WEBDAV=y
FREETZ_HAS_AVM_INETD=y
FREETZ_HAS_AVM_EXT3=y
# FREETZ_HAS_AVM_ISOFS is not set
FREETZ_HAS_AVM_TR069=y
FREETZ_HAS_AVM_TR069_FWUPDATE=y
FREETZ_HAS_AVM_CHRONYD=y
FREETZ_HAS_AVM_DECT=y
FREETZ_HAS_AVM_OPENSSL_LIBS=y
FREETZ_HAS_AVM_LSOF=y
# FREETZ_HAS_AVM_SOCAT is not set
FREETZ_HAS_AVM_NAS=y
FREETZ_HAS_AVM_MYFRITZ=y
FREETZ_HAS_AVM_FHEM=y
FREETZ_HAS_AVM_PHONE=y
# FREETZ_HAS_AVM_STRACE is not set
FREETZ_HAS_AVM_TAM=y
FREETZ_HAS_AVM_UDEV=y
# FREETZ_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_AVM_USB_HOST=y
# FREETZ_HAS_AVM_USB_HOST_AHCI is not set
FREETZ_HAS_AVM_E2FSPROGS=y
FREETZ_HAS_AVM_WLAN=y
FREETZ_HAS_AVM_UMTS=y
FREETZ_HAS_AVM_JFFS2=y
# FREETZ_HAS_AVM_JUNK_BYTES is not set
# FREETZ_HAS_AVM_MICROVOIP_DSL is not set
# FREETZ_HAS_AVM_ANNEX_A_AND_B is not set
FREETZ_HAS_AVM_MULTI_ANNEX=y
FREETZ_HAS_AVM_RAMZSWAP=y
# FREETZ_HAS_AVM_AHA is not set
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_AVM_VERSION_7270_05_21=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_2X=y
FREETZ_TYPE_7270_16=y
FREETZ_AVM_VERSION_STRING="7270_05.21"
FREETZ_TYPE_PREFIX="7270_v3"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="05_2X"
--2013-03-18 20:30:52--  ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270_v3/firmware/english/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image
           => »dl/fw/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image«
Auflösen des Hostnamen »ftp.avm.de (ftp.avm.de)«... 212.42.244.90
Verbindungsaufbau zu ftp.avm.de (ftp.avm.de)|212.42.244.90|:21... verbunden.
Anmelden als anonymous ... Angemeldet!
==> SYST ... fertig.    ==> PWD ... fertig.
==> TYPE I ... fertig.  ==> CWD (1) /fritz.box/fritzbox.fon_wlan_7270_v3/firmware/english ... fertig.
==> SIZE FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image ... 15697920
==> PASV ... fertig.    ==> RETR FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image ... fertig.
Länge: 15697920 (15M) (unmaßgeblich)
100%[===================================================================================================================================>] 15.697.920  1,51M/s   in 11s
2013-03-18 20:31:03 (1,42 MB/s) - »dl/fw/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image« gespeichert [15697920]
Download succeeded - "ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7270_v3/firmware/english/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image"  ->  saved to folder "dl/fw"
MD5 verified for dl/fw/FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image: 0f2406d342e7ce0ce987296bca46cfe6
tools/freetz_download dl busybox-1.21.0.tar.bz2 http://www.busybox.net/downloads d613f2e4b580305c1de8691f7b84285e
--2013-03-18 20:31:03--  http://www.busybox.net/downloads/busybox-1.21.0.tar.bz2
Auflösen des Hostnamen »www.busybox.net (www.busybox.net)«... 140.211.167.224
Verbindungsaufbau zu www.busybox.net (www.busybox.net)|140.211.167.224|:80... verbunden.
Länge: 2200841 (2,1M) [application/x-bzip2]
In »»dl/busybox-1.21.0.tar.bz2«« speichern.
100%[===================================================================================================================================>] 2.200.841    498K/s   in 4,7s
2013-03-18 20:31:08 (453 KB/s) - »»dl/busybox-1.21.0.tar.bz2«« gespeichert [2200841/2200841]
Download succeeded - "http://www.busybox.net/downloads/busybox-1.21.0.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/busybox-1.21.0.tar.bz2: d613f2e4b580305c1de8691f7b84285e
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf dl/busybox-1.21.0.tar.bz2
shopt -s nullglob; for i in tools/make/patches/*.busybox.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0 $i; \
	done
    applying patch file tools/make/patches/tar_preserve_directory_permissions.busybox.patch
    patching file archival/libarchive/data_extract_all.c
touch /run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0/.unpacked
cp tools/make/Config.busybox /run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0/.config
make -j2 -C /run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0 oldconfig
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0'
  GEN     include/applets.h
  HOSTCC  scripts/basic/split-include
scripts/basic/split-include.c: In Funktion »main«:
scripts/basic/split-include.c:134:11: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  HOSTCC  scripts/basic/docproc
  GEN     include/usage.h
  GEN     console-tools/Kbuild
  GEN     console-tools/Config.in
  GEN     mailutils/Kbuild
  GEN     mailutils/Config.in
  GEN     printutils/Kbuild
  GEN     printutils/Config.in
  GEN     debianutils/Kbuild
  GEN     debianutils/Config.in
  GEN     coreutils/Kbuild
  GEN     coreutils/Config.in
  GEN     coreutils/libcoreutils/Kbuild
  GEN     applets/Kbuild
  GEN     networking/Kbuild
  GEN     networking/Config.in
  GEN     networking/libiproute/Kbuild
  GEN     networking/udhcp/Kbuild
  GEN     networking/udhcp/Config.in
  GEN     sysklogd/Kbuild
  GEN     sysklogd/Config.in
  GEN     e2fsprogs/Kbuild
  GEN     e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/ext2fs/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/blkid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/uuid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/e2p/Kbuild
  GEN     procps/Kbuild
  GEN     procps/Config.in
  GEN     archival/Kbuild
  GEN     archival/Config.in
  GEN     archival/libarchive/Kbuild
  GEN     modutils/Kbuild
  GEN     modutils/Config.in
  GEN     findutils/Kbuild
  GEN     findutils/Config.in
  GEN     selinux/Kbuild
  GEN     selinux/Config.in
  GEN     scripts/Kbuild
  GEN     editors/Kbuild
  GEN     editors/Config.in
  GEN     libpwdgrp/Kbuild
  GEN     runit/Kbuild
  GEN     runit/Config.in
  GEN     shell/Kbuild
  GEN     shell/Config.in
  GEN     libbb/Kbuild
  GEN     libbb/Config.in
  GEN     miscutils/Kbuild
  GEN     miscutils/Config.in
  GEN     util-linux/Kbuild
  GEN     util-linux/Config.in
  GEN     util-linux/volume_id/Kbuild
  GEN     init/Kbuild
  GEN     init/Config.in
  GEN     loginutils/Kbuild
  GEN     loginutils/Config.in
scripts/kconfig/conf.c: In Funktion »conf_choice«:
scripts/kconfig/conf.c:354:9: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
scripts/kconfig/conf.c: In Funktion »conf_askvalue«:
scripts/kconfig/conf.c:106:8: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  HOSTCC  scripts/kconfig/kxgettext.o
  HOSTCC  scripts/kconfig/mconf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/lex.zconf.c
  SHIPPED scripts/kconfig/zconf.hash.c
scripts/kconfig/mconf.c: In Funktion »show_textbox«:
scripts/kconfig/mconf.c:847:7: Warnung: Der Rückgabewert von »write«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
scripts/kconfig/mconf.c: In Funktion »exec_conf«:
scripts/kconfig/mconf.c:481:6: Warnung: Der Rückgabewert von »pipe«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -o Config.in
# using defaults found in .config
* Busybox Configuration
* Busybox Settings
* General Configuration
Enable options for full-blown desktop systems (DESKTOP) [N/y/?] n
Provide compatible behavior for rare corner cases (bigger code) (EXTRA_COMPAT) [N/y/?] n
Enable obsolete features removed before SUSv3 (INCLUDE_SUSv2) [Y/n/?] y
Avoid using GCC-specific code constructs (USE_PORTABLE_CODE) [N/y/?] n
Enable Linux-specific applets and features (PLATFORM_LINUX) [Y/?] y
Buffer allocation policy
> 1. Allocate with Malloc (FEATURE_BUFFERS_USE_MALLOC)
  2. Allocate on the Stack (FEATURE_BUFFERS_GO_ON_STACK)
  3. Allocate in the .bss section (FEATURE_BUFFERS_GO_IN_BSS)
choice[1-3?]: 1
Show applet usage messages (SHOW_USAGE) [Y/n/?] y
  Show verbose applet usage messages (FEATURE_VERBOSE_USAGE) [N/y/?] n
  Store applet usage messages in compressed form (FEATURE_COMPRESS_USAGE) [Y/n/?] y
Support --install [-s] to install applet links at runtime (FEATURE_INSTALLER) [N/y/?] n
Don't use /usr (INSTALL_NO_USR) [N/y/?] n
Enable locale support (system needs locale for this to work) (LOCALE_SUPPORT) [N/y/?] n
Support Unicode (UNICODE_SUPPORT) [N/y/?] n
Support for --long-options (LONG_OPTS) [Y/n/?] y
Use the devpts filesystem for Unix98 PTYs (FEATURE_DEVPTS) [Y/n/?] y
Clean up all memory before exiting (usually not needed) (FEATURE_CLEAN_UP) [N/y/?] n
Support utmp file (FEATURE_UTMP) [N/y/?] n
Support writing pidfiles (FEATURE_PIDFILE) [N/y/?] n
Support for SUID/SGID handling (FEATURE_SUID) [N/y/?] n
Support NSA Security Enhanced Linux (SELINUX) [N/y/?] n
exec prefers applets (FEATURE_PREFER_APPLETS) [N/y/?] n
Path to BusyBox executable (BUSYBOX_EXEC_PATH) [/proc/self/exe] /proc/self/exe
* Build Options
Build BusyBox as a static binary (no shared libs) (STATIC) [N/y/?] n
  Build BusyBox as a position independent executable (PIE) [N/y/?] n
Force NOMMU build (NOMMU) [N/y/?] n
Build shared libbusybox (BUILD_LIBBUSYBOX) [N/y/?] n
Build with Large File Support (for accessing files > 2 GB) (LFS) [Y/n/?] y
Cross Compiler prefix (CROSS_COMPILER_PREFIX) []
Path to sysroot (SYSROOT) []
Additional CFLAGS (EXTRA_CFLAGS) []
Additional LDFLAGS (EXTRA_LDFLAGS) []
Additional LDLIBS (EXTRA_LDLIBS) []
* Debugging Options
Build BusyBox with extra Debugging symbols (DEBUG) [N/y/?] n
Abort compilation on any warning (WERROR) [N/y/?] n
Additional debugging library
> 1. None (NO_DEBUG_LIB)
  2. Dmalloc (DMALLOC)
  3. Electric-fence (EFENCE)
choice[1-3?]: 1
* Installation Options ("make install" behavior)
What kind of applet links to install
> 1. as soft-links (INSTALL_APPLET_SYMLINKS)
  2. as hard-links (INSTALL_APPLET_HARDLINKS)
  3. as script wrappers (INSTALL_APPLET_SCRIPT_WRAPPERS)
  4. not installed (INSTALL_APPLET_DONT)
choice[1-4?]: 1
BusyBox installation prefix (PREFIX) [./_install] ./_install
* Busybox Library Tuning
Enable systemd support (FEATURE_SYSTEMD) [N/y/?] n
Support RTMIN[+n] and RTMAX[-n] signal names (FEATURE_RTMINMAX) [N/y/?] n
Minimum password length (PASSWORD_MINLEN) [6] 6
MD5: Trade bytes for speed (0:fast, 3:slow) (MD5_SMALL) [1] 1
SHA3: Trade bytes for speed (0:fast, 1:slow) (SHA3_SMALL) [1] 1
Faster /proc scanning code (+100 bytes) (FEATURE_FAST_TOP) [N/y/?] n
Support for /etc/networks (FEATURE_ETC_NETWORKS) [N/y/?] n
Command line editing (FEATURE_EDITING) [N/y/?] n
Non-POSIX, but safer, copying to special nodes (FEATURE_NON_POSIX_CP) [Y/n/?] y
Give more precise messages when copy fails (cp, mv etc) (FEATURE_VERBOSE_CP_MESSAGE) [N/y/?] n
Copy buffer size, in kilobytes (FEATURE_COPYBUF_KB) [4] 4
Skip rootfs in mount table (FEATURE_SKIP_ROOTFS) [N/y/?] n
Use clock_gettime(CLOCK_MONOTONIC) syscall (MONOTONIC_SYSCALL) [Y/n/?] y
Use ioctl names rather than hex values in error messages (IOCTL_HEX2STR_ERROR) [Y/n/?] y
Support infiniband HW (FEATURE_HWIB) [Y/n/?] y
* Applets
* Archival Utilities
Make tar, rpm, modprobe etc understand .xz data (FEATURE_SEAMLESS_XZ) [Y/n/?] y
Make tar, rpm, modprobe etc understand .lzma data (FEATURE_SEAMLESS_LZMA) [Y/n/?] y
Make tar, rpm, modprobe etc understand .bz2 data (FEATURE_SEAMLESS_BZ2) [Y/n/?] y
Make tar, rpm, modprobe etc understand .gz data (FEATURE_SEAMLESS_GZ) [Y/n/?] y
tar, rpm, modprobe etc understand .Z data (FEATURE_SEAMLESS_Z) [Y/n/?] y
ar (AR) [N/y/?] n
bunzip2 (BUNZIP2) [Y/n/?] y
bzip2 (BZIP2) [N/y/?] n
cpio (CPIO) [N/y/?] n
dpkg (DPKG) [N/y/?] n
dpkg_deb (DPKG_DEB) [N/y/?] n
gunzip (GUNZIP) [Y/n/?] y
gzip (GZIP) [N/y/?] n
lzop (LZOP) [N/y/?] n
rpm2cpio (RPM2CPIO) [N/y/?] n
rpm (RPM) [N/y/?] n
tar (TAR) [Y/n/?] y
  Enable archive creation (FEATURE_TAR_CREATE) [Y/n/?] y
  Autodetect compressed tarballs (FEATURE_TAR_AUTODETECT) [Y/n/?] y
  Enable -X (exclude from) and -T (include from) options) (FEATURE_TAR_FROM) [Y/n/?] y
  Support for old tar header format (FEATURE_TAR_OLDGNU_COMPATIBILITY) [Y/n/?] y
  Enable untarring of tarballs with checksums produced by buggy Sun tar (FEATURE_TAR_OLDSUN_COMPATIBILITY) [N/y/?] n
  Support for GNU tar extensions (long filenames) (FEATURE_TAR_GNU_EXTENSIONS) [Y/n/?] y
  Enable long options (FEATURE_TAR_LONG_OPTIONS) [Y/n/?] y
    Support for writing to an external program (FEATURE_TAR_TO_COMMAND) [N/y/?] n
  Enable use of user and group names (FEATURE_TAR_UNAME_GNAME) [Y/n/?] y
  Enable -m (do not preserve time) option (FEATURE_TAR_NOPRESERVE_TIME) [N/y/?] n
uncompress (UNCOMPRESS) [Y/n/?] y
unlzma (UNLZMA) [Y/n/?] y
  Optimize unlzma for speed (FEATURE_LZMA_FAST) [Y/n/?] y
  Provide lzma alias which supports only unpacking (LZMA) [N/y/?] n
unxz (UNXZ) [Y/n/?] y
  Provide xz alias which supports only unpacking (XZ) [N/y/?] n
unzip (UNZIP) [Y/n/?] y
* Coreutils
basename (BASENAME) [N/y/?] n
cat (CAT) [N/y/?] n
date (DATE) [N/y/?] n
hostid (HOSTID) [N/y/?] n
id (ID) [N/y/?] n
groups (GROUPS) [N/y/?] n
test (TEST) [N/y/?] n
touch (TOUCH) [N/y/?] n
tr (TR) [N/y/?] n
base64 (BASE64) [N/y/?] n
cal (CAL) [N/y/?] n
catv (CATV) [N/y/?] n
chgrp (CHGRP) [N/y/?] n
chmod (CHMOD) [N/y/?] n
chown (CHOWN) [N/y/?] n
chroot (CHROOT) [N/y/?] n
cksum (CKSUM) [N/y/?] n
comm (COMM) [N/y/?] n
cp (CP) [N/y/?] n
cut (CUT) [N/y/?] n
dd (DD) [N/y/?] n
df (DF) [N/y/?] n
dirname (DIRNAME) [N/y/?] n
dos2unix/unix2dos (DOS2UNIX) [N/y/?] n
du (default blocksize of 512 bytes) (DU) [N/y/?] n
echo (basic SuSv3 version taking no options) (ECHO) [N/y/?] n
env (ENV) [N/y/?] n
expand (EXPAND) [N/y/?] n
expr (EXPR) [N/y/?] n
false (FALSE) [N/y/?] n
fold (FOLD) [N/y/?] n
fsync (FSYNC) [N/y/?] n
head (HEAD) [N/y/?] n
install (INSTALL) [N/y/?] n
ln (LN) [N/y/?] n
logname (LOGNAME) [N/y/?] n
ls (LS) [N/y/?] n
md5sum (MD5SUM) [Y/n/?] y
mkdir (MKDIR) [N/y/?] n
mkfifo (MKFIFO) [N/y/?] n
mknod (MKNOD) [N/y/?] n
mv (MV) [N/y/?] n
nice (NICE) [N/y/?] n
nohup (NOHUP) [N/y/?] n
od (OD) [N/y/?] n
printenv (PRINTENV) [N/y/?] n
printf (PRINTF) [N/y/?] n
pwd (PWD) [N/y/?] n
readlink (READLINK) [N/y/?] n
realpath (REALPATH) [N/y/?] n
rm (RM) [N/y/?] n
rmdir (RMDIR) [N/y/?] n
seq (SEQ) [N/y/?] n
sha1sum (SHA1SUM) [N/y/?] n
sha256sum (SHA256SUM) [N/y/?] n
sha512sum (SHA512SUM) [N/y/?] n
sha3sum (SHA3SUM) [N/y/?] n
sleep (SLEEP) [N/y/?] n
sort (SORT) [N/y/?] n
split (SPLIT) [N/y/?] n
stat (STAT) [N/y/?] n
stty (STTY) [N/y/?] n
sum (SUM) [N/y/?] n
sync (SYNC) [N/y/?] n
tac (TAC) [N/y/?] n
tail (TAIL) [N/y/?] n
tee (TEE) [N/y/?] n
true (TRUE) [N/y/?] n
tty (TTY) [N/y/?] n
uname (UNAME) [N/y/?] n
unexpand (UNEXPAND) [N/y/?] n
uniq (UNIQ) [N/y/?] n
usleep (USLEEP) [N/y/?] n
uudecode (UUDECODE) [N/y/?] n
uuencode (UUENCODE) [N/y/?] n
wc (WC) [N/y/?] n
whoami (WHOAMI) [N/y/?] n
yes (YES) [N/y/?] n
* Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
Enable -c, -s and -w options (FEATURE_MD5_SHA1_SUM_CHECK) [Y/n/?] y
* Console Utilities
chvt (CHVT) [N/y/?] n
fgconsole (FGCONSOLE) [N/y/?] n
clear (CLEAR) [N/y/?] n
deallocvt (DEALLOCVT) [N/y/?] n
dumpkmap (DUMPKMAP) [N/y/?] n
kbd_mode (KBD_MODE) [N/y/?] n
loadfont (LOADFONT) [N/y/?] n
loadkmap (LOADKMAP) [N/y/?] n
openvt (OPENVT) [N/y/?] n
reset (RESET) [N/y/?] n
resize (RESIZE) [N/y/?] n
setconsole (SETCONSOLE) [N/y/?] n
setfont (SETFONT) [N/y/?] n
setkeycodes (SETKEYCODES) [N/y/?] n
setlogcons (SETLOGCONS) [N/y/?] n
showkey (SHOWKEY) [N/y/?] n
* Debian Utilities
mktemp (MKTEMP) [N/y/?] n
pipe_progress (PIPE_PROGRESS) [N/y/?] n
run-parts (RUN_PARTS) [N/y/?] n
start-stop-daemon (START_STOP_DAEMON) [N/y/?] n
which (WHICH) [N/y/?] n
* Editors
patch (PATCH) [N/y/?] n
vi (VI) [N/y/?] n
awk (AWK) [N/y/?] n
cmp (CMP) [N/y/?] n
diff (DIFF) [N/y/?] n
ed (ED) [N/y/?] n
sed (SED) [N/y/?] n
* Finding Utilities
find (FIND) [N/y/?] n
grep (GREP) [N/y/?] n
xargs (XARGS) [N/y/?] n
* Init Utilities
bootchartd (BOOTCHARTD) [N/y/?] n
poweroff, halt, and reboot (HALT) [N/y/?] n
init (INIT) [N/y/?] n
mesg (MESG) [N/y/?] n
* Login/Password Management Utilities
add-shell (ADD_SHELL) [N/y/?] n
remove-shell (REMOVE_SHELL) [N/y/?] n
Support for shadow passwords (FEATURE_SHADOWPASSWDS) [N/y/?] n
Use internal password and group functions rather than system functions (USE_BB_PWD_GRP) [N/y/?] n
Use internal crypt functions (USE_BB_CRYPT) [Y/n/?] y
  Enable SHA256/512 crypt functions (USE_BB_CRYPT_SHA) [N/y/?] n
adduser (ADDUSER) [N/y/?] n
addgroup (ADDGROUP) [N/y/?] n
deluser (DELUSER) [N/y/?] n
delgroup (DELGROUP) [N/y/?] n
getty (GETTY) [N/y/?] n
login (LOGIN) [N/y/?] n
passwd (PASSWD) [N/y/?] n
cryptpw (CRYPTPW) [N/y/?] n
chpasswd (CHPASSWD) [N/y/?] n
su (SU) [N/y/?] n
sulogin (SULOGIN) [N/y/?] n
vlock (VLOCK) [N/y/?] n
* Linux Ext2 FS Progs
chattr (CHATTR) [N/y/?] n
fsck (FSCK) [N/y/?] n
lsattr (LSATTR) [N/y/?] n
tune2fs (TUNE2FS) [N/y/?] n
* Linux Module Utilities
modinfo (MODINFO) [N/y/?] n
Simplified modutils (MODPROBE_SMALL) [N/y/?] n
  insmod (INSMOD) [N/y/?] n
  rmmod (RMMOD) [N/y/?] n
  lsmod (LSMOD) [N/y/?] n
  modprobe (MODPROBE) [N/y/?] n
  depmod (DEPMOD) [N/y/?] n
* Options common to multiple modutils
* Linux System Utilities
blockdev (BLOCKDEV) [N/y/?] n
mdev (MDEV) [N/y/?] n
rev (REV) [N/y/?] n
acpid (ACPID) [N/y/?] n
blkid (BLKID) [N/y/?] n
dmesg (DMESG) [N/y/?] n
fbset (FBSET) [N/y/?] n
fdflush (FDFLUSH) [N/y/?] n
fdformat (FDFORMAT) [N/y/?] n
fdisk (FDISK) [N/y/?] n
findfs (FINDFS) [N/y/?] n
flock (FLOCK) [N/y/?] n
freeramdisk (FREERAMDISK) [N/y/?] n
fsck_minix (FSCK_MINIX) [N/y/?] n
mkfs_ext2 (MKFS_EXT2) [N/y/?] n
mkfs_minix (MKFS_MINIX) [N/y/?] n
mkfs_reiser (MKFS_REISER) [N/y/?] n
mkfs_vfat (MKFS_VFAT) [N/y/?] n
getopt (GETOPT) [N/y/?] n
hexdump (HEXDUMP) [N/y/?] n
hwclock (HWCLOCK) [N/y/?] n
ipcrm (IPCRM) [N/y/?] n
ipcs (IPCS) [N/y/?] n
losetup (LOSETUP) [N/y/?] n
lspci (LSPCI) [N/y/?] n
lsusb (LSUSB) [N/y/?] n
mkswap (MKSWAP) [N/y/?] n
more (MORE) [N/y/?] n
mount (MOUNT) [N/y/?] n
pivot_root (PIVOT_ROOT) [N/y/?] n
rdate (RDATE) [N/y/?] n
rdev (RDEV) [N/y/?] n
readprofile (READPROFILE) [N/y/?] n
rtcwake (RTCWAKE) [N/y/?] n
script (SCRIPT) [N/y/?] n
scriptreplay (SCRIPTREPLAY) [N/y/?] n
setarch (SETARCH) [N/y/?] n
swaponoff (SWAPONOFF) [N/y/?] n
switch_root (SWITCH_ROOT) [N/y/?] n
umount (UMOUNT) [N/y/?] n
* Miscellaneous Utilities
conspy (CONSPY) [N/y/?] n
less (LESS) [N/y/?] n
nandwrite (NANDWRITE) [N/y/?] n
nanddump (NANDDUMP) [N/y/?] n
setserial (SETSERIAL) [N/y/?] n
ubiattach (UBIATTACH) [N/y/?] n
ubidetach (UBIDETACH) [N/y/?] n
ubimkvol (UBIMKVOL) [N/y/?] n
ubirmvol (UBIRMVOL) [N/y/?] n
ubirsvol (UBIRSVOL) [N/y/?] n
ubiupdatevol (UBIUPDATEVOL) [N/y/?] n
adjtimex (ADJTIMEX) [N/y/?] n
bbconfig (BBCONFIG) [N/y/?] n
beep (BEEP) [N/y/?] n
chat (CHAT) [N/y/?] n
chrt (CHRT) [N/y/?] n
crond (CROND) [N/y/?] n
crontab (CRONTAB) [N/y/?] n
dc (DC) [N/y/?] n
devfsd (obsolete) (DEVFSD) [N/y/?] n
Use devfs names for all devices (obsolete) (FEATURE_DEVFS) [N/y/?] n
devmem (DEVMEM) [N/y/?] n
eject (EJECT) [N/y/?] n
fbsplash (FBSPLASH) [N/y/?] n
flashcp (FLASHCP) [N/y/?] n
flash_lock (FLASH_LOCK) [N/y/?] n
flash_unlock (FLASH_UNLOCK) [N/y/?] n
flash_eraseall (FLASH_ERASEALL) [N/y/?] n
ionice (IONICE) [N/y/?] n
inotifyd (INOTIFYD) [N/y/?] n
hdparm (HDPARM) [N/y/?] n
makedevs (MAKEDEVS) [Y/n/?] y
  Choose makedevs behaviour
    1. leaf (FEATURE_MAKEDEVS_LEAF)
  > 2. table (FEATURE_MAKEDEVS_TABLE)
  choice[1-2]: 2
man (MAN) [N/y/?] n
microcom (MICROCOM) [N/y/?] n
mountpoint (MOUNTPOINT) [N/y/?] n
mt (MT) [N/y/?] n
raidautorun (RAIDAUTORUN) [N/y/?] n
readahead (READAHEAD) [N/y/?] n
rfkill (RFKILL) [N/y/?] n
rx (RX) [N/y/?] n
setsid (SETSID) [N/y/?] n
strings (STRINGS) [N/y/?] n
taskset (TASKSET) [N/y/?] n
time (TIME) [N/y/?] n
timeout (TIMEOUT) [N/y/?] n
ttysize (TTYSIZE) [N/y/?] n
volname (VOLNAME) [N/y/?] n
watchdog (WATCHDOG) [N/y/?] n
* Networking Utilities
nameif (NAMEIF) [N/y/?] n
nbd-client (NBDCLIENT) [N/y/?] n
nc (NC) [N/y/?] n
ping (PING) [N/y/?] n
whois (WHOIS) [N/y/?] n
Enable IPv6 support (FEATURE_IPV6) [N/y/?] n
Enable Unix domain socket support (usually not needed) (FEATURE_UNIX_LOCAL) [N/y/?] n
Verbose resolution errors (VERBOSE_RESOLUTION_ERRORS) [N/y/?] n
arp (ARP) [N/y/?] n
arping (ARPING) [N/y/?] n
brctl (BRCTL) [N/y/?] n
dnsd (DNSD) [N/y/?] n
ether-wake (ETHER_WAKE) [N/y/?] n
fakeidentd (FAKEIDENTD) [N/y/?] n
ftpd (FTPD) [N/y/?] n
ftpget (FTPGET) [N/y/?] n
ftpput (FTPPUT) [N/y/?] n
hostname (HOSTNAME) [N/y/?] n
httpd (HTTPD) [N/y/?] n
ifconfig (IFCONFIG) [N/y/?] n
ifenslave (IFENSLAVE) [N/y/?] n
ifplugd (IFPLUGD) [N/y/?] n
ifupdown (IFUPDOWN) [N/y/?] n
inetd (INETD) [N/y/?] n
ip (IP) [N/y/?] n
ipcalc (IPCALC) [N/y/?] n
netstat (NETSTAT) [N/y/?] n
nslookup (NSLOOKUP) [N/y/?] n
ntpd (NTPD) [N/y/?] n
pscan (PSCAN) [N/y/?] n
route (ROUTE) [N/y/?] n
slattach (SLATTACH) [N/y/?] n
tcpsvd (TCPSVD) [N/y/?] n
telnet (TELNET) [N/y/?] n
telnetd (TELNETD) [N/y/?] n
tftp (TFTP) [N/y/?] n
tftpd (TFTPD) [N/y/?] n
traceroute (TRACEROUTE) [N/y/?] n
tunctl (TUNCTL) [N/y/?] n
udhcp server (udhcpd) (UDHCPD) [N/y/?] n
udhcp client (udhcpc) (UDHCPC) [N/y/?] n
udpsvd (UDPSVD) [N/y/?] n
vconfig (VCONFIG) [N/y/?] n
wget (WGET) [N/y/?] n
zcip (ZCIP) [N/y/?] n
* Print Utilities
lpd (LPD) [N/y/?] n
lpr (LPR) [N/y/?] n
lpq (LPQ) [N/y/?] n
* Mail Utilities
makemime (MAKEMIME) [N/y/?] n
popmaildir (POPMAILDIR) [N/y/?] n
reformime (REFORMIME) [N/y/?] n
sendmail (SENDMAIL) [N/y/?] n
* Process Utilities
iostat (IOSTAT) [N/y/?] n
lsof (LSOF) [N/y/?] n
mpstat (MPSTAT) [N/y/?] n
nmeter (NMETER) [N/y/?] n
pmap (PMAP) [N/y/?] n
powertop (POWERTOP) [N/y/?] n
pstree (PSTREE) [N/y/?] n
pwdx (PWDX) [N/y/?] n
smemcap (SMEMCAP) [N/y/?] n
top (TOP) [N/y/?] n
uptime (UPTIME) [N/y/?] n
free (FREE) [N/y/?] n
fuser (FUSER) [N/y/?] n
kill (KILL) [N/y/?] n
pgrep (PGREP) [N/y/?] n
pidof (PIDOF) [N/y/?] n
pkill (PKILL) [N/y/?] n
ps (PS) [N/y/?] n
renice (RENICE) [N/y/?] n
sysctl (BB_SYSCTL) [N/y/?] n
watch (WATCH) [N/y/?] n
* Runit Utilities
runsv (RUNSV) [N/y/?] n
runsvdir (RUNSVDIR) [N/y/?] n
sv (SV) [N/y/?] n
svlogd (SVLOGD) [N/y/?] n
chpst (CHPST) [N/y/?] n
setuidgid (SETUIDGID) [N/y/?] n
envuidgid (ENVUIDGID) [N/y/?] n
envdir (ENVDIR) [N/y/?] n
softlimit (SOFTLIMIT) [N/y/?] n
* Shells
ash (ASH) [Y/n/?] y
  bash-compatible extensions (ASH_BASH_COMPAT) [N/y/?] n
  Idle timeout variable (ASH_IDLE_TIMEOUT) [N/y/?] n
  Job control (ASH_JOB_CONTROL) [N/y/?] n
  Alias support (ASH_ALIAS) [N/y/?] n
  Builtin getopt to parse positional parameters (ASH_GETOPTS) [N/y/?] n
  Builtin version of 'echo' (ASH_BUILTIN_ECHO) [N/y/?] n
  Builtin version of 'printf' (ASH_BUILTIN_PRINTF) [N/y/?] n
  Builtin version of 'test' (ASH_BUILTIN_TEST) [N/y/?] n
  'command' command to override shell builtins (ASH_CMDCMD) [N/y/?] n
  Check for new mail on interactive shells (ASH_MAIL) [N/y/?] n
  Optimize for size instead of speed (ASH_OPTIMIZE_FOR_SIZE) [N/y/?] n
  Pseudorandom generator and $RANDOM variable (ASH_RANDOM_SUPPORT) [N/y/?] n
  Expand prompt string (ASH_EXPAND_PRMT) [N/y/?] n
cttyhack (CTTYHACK) [N/y/?] n
hush (HUSH) [N/y/?] n
msh (deprecated: aliased to hush) (MSH) [N/y/?] n
Choose which shell is aliased to 'sh' name
  1. ash (FEATURE_SH_IS_ASH)
> 2. none (FEATURE_SH_IS_NONE)
choice[1-2?]: 2
Choose which shell is aliased to 'bash' name
  1. ash (FEATURE_BASH_IS_ASH)
> 2. none (FEATURE_BASH_IS_NONE)
choice[1-2?]: 2
POSIX math support (SH_MATH_SUPPORT) [N/y/?] n
Hide message on interactive shell startup (FEATURE_SH_EXTRA_QUIET) [N/y/?] n
Use $HISTFILESIZE (FEATURE_SH_HISTFILESIZE) [N/y/?] n
* System Logging Utilities
syslogd (SYSLOGD) [N/y/?] n
klogd (KLOGD) [N/y/?] n
logger (LOGGER) [N/y/?] n
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0'
touch /run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0/.configured
  SPLIT   include/autoconf.h -> include/config/*
  HOSTCC  applets/usage
applets/usage.c: In Funktion »main«:
applets/usage.c:52:8: Warnung: Der Rückgabewert von »write«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  GEN     include/bbconfigopts.h
  HOSTCC  applets/applet_tables
applets/applet_tables.c: In Funktion »main«:
applets/applet_tables.c:144:9: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  GEN     include/usage_compressed.h
  GEN     include/applet_tables.h
  HOSTCC  applets/usage_pod
  CC      applets/applets.o
applets/usage_pod.c: In Funktion »main«:
applets/usage_pod.c:74:3: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
  LD      applets/built-in.o
  DOC     busybox.pod
  DOC     BusyBox.txt
  DOC     busybox.1
  DOC     BusyBox.html
  LD      archival/built-in.o
  CC      archival/bbunzip.o
  CC      archival/tar.o
  LD      archival/libarchive/built-in.o
  CC      archival/libarchive/data_align.o
  CC      archival/libarchive/data_extract_all.o
  CC      archival/unzip.o
archival/libarchive/data_extract_all.c: In Funktion »data_extract_all«:
archival/libarchive/data_extract_all.c:177:9: Warnung: Der Rückgabewert von »chown«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  CC      archival/libarchive/data_extract_to_stdout.o
  AR      archival/lib.a
  LD      console-tools/built-in.o
  AR      console-tools/lib.a
  CC      archival/libarchive/data_skip.o
  LD      coreutils/built-in.o
  CC      coreutils/echo.o
  CC      archival/libarchive/decompress_bunzip2.o
  CC      coreutils/md5_sha1_sum.o
  CC      coreutils/test.o
  CC      archival/libarchive/decompress_gunzip.o
  CC      coreutils/test_ptr_hack.o
  AR      coreutils/lib.a
  LD      coreutils/libcoreutils/built-in.o
  AR      coreutils/libcoreutils/lib.a
  LD      debianutils/built-in.o
  AR      debianutils/lib.a
  LD      e2fsprogs/built-in.o
  AR      e2fsprogs/lib.a
  LD      editors/built-in.o
  AR      editors/lib.a
  LD      findutils/built-in.o
  AR      findutils/lib.a
  LD      init/built-in.o
  AR      init/lib.a
  LD      libbb/built-in.o
  CC      libbb/appletlib.o
libbb/appletlib.c: In Funktion »busybox_main«:
libbb/appletlib.c:691:7: Warnung: Variable »use_symbolic_links« gesetzt, aber nicht verwendet [-Wunused-but-set-variable]
  CC      archival/libarchive/decompress_uncompress.o
  CC      libbb/ask_confirmation.o
  CC      libbb/bb_askpass.o
  CC      archival/libarchive/decompress_unlzma.o
  CC      libbb/bb_bswap_64.o
  CC      libbb/bb_do_delay.o
  CC      archival/libarchive/decompress_unxz.o
  CC      libbb/bb_pwd.o
  CC      libbb/bb_qsort.o
  CC      libbb/bb_strtonum.o
  CC      libbb/change_identity.o
  CC      libbb/chomp.o
  CC      archival/libarchive/filter_accept_all.o
  CC      libbb/compare_string_array.o
  CC      archival/libarchive/filter_accept_list.o
  CC      archival/libarchive/filter_accept_reject_list.o
  CC      libbb/concat_path_file.o
  CC      archival/libarchive/find_list_entry.o
  CC      libbb/concat_subpath_file.o
  CC      libbb/copy_file.o
  CC      archival/libarchive/get_header_tar.o
  CC      libbb/copyfd.o
  CC      archival/libarchive/header_list.o
  CC      libbb/crc32.o
  CC      archival/libarchive/header_skip.o
  CC      archival/libarchive/header_verbose_list.o
  CC      libbb/create_icmp6_socket.o
  CC      archival/libarchive/init_handle.o
  CC      libbb/create_icmp_socket.o
  CC      archival/libarchive/open_transformer.o
  CC      libbb/default_error_retval.o
  CC      libbb/device_open.o
  CC      archival/libarchive/seek_by_jump.o
  CC      libbb/dump.o
  CC      archival/libarchive/seek_by_read.o
  AR      archival/libarchive/lib.a
  LD      libpwdgrp/built-in.o
  CC      libpwdgrp/uidgid_get.o
  AR      libpwdgrp/lib.a
  LD      loginutils/built-in.o
  AR      loginutils/lib.a
  LD      mailutils/built-in.o
  AR      mailutils/lib.a
  LD      miscutils/built-in.o
  CC      miscutils/makedevs.o
  CC      libbb/execable.o
  CC      libbb/fclose_nonstdin.o
  AR      miscutils/lib.a
  LD      modutils/built-in.o
  AR      modutils/lib.a
  LD      networking/built-in.o
  AR      networking/lib.a
  LD      networking/libiproute/built-in.o
  AR      networking/libiproute/lib.a
  LD      networking/udhcp/built-in.o
  AR      networking/udhcp/lib.a
  LD      printutils/built-in.o
  AR      printutils/lib.a
  LD      procps/built-in.o
  CC      procps/kill.o
  CC      libbb/fflush_stdout_and_exit.o
  CC      libbb/fgets_str.o
  AR      procps/lib.a
  LD      runit/built-in.o
  AR      runit/lib.a
  LD      selinux/built-in.o
  AR      selinux/lib.a
  LD      shell/built-in.o
  CC      shell/ash.o
  CC      libbb/find_pid_by_name.o
  CC      libbb/find_root_device.o
  CC      libbb/full_write.o
  CC      libbb/get_console.o
  CC      libbb/get_last_path_component.o
  CC      libbb/get_line_from_file.o
  CC      libbb/get_shell_name.o
  CC      libbb/get_volsize.o
  CC      libbb/getopt32.o
  CC      libbb/getpty.o
  CC      libbb/hash_md5_sha.o
  CC      libbb/herror_msg.o
  CC      libbb/human_readable.o
  CC      libbb/inet_common.o
  CC      libbb/info_msg.o
  CC      libbb/inode_hash.o
  CC      libbb/isdirectory.o
  CC      shell/ash_ptr_hack.o
  CC      shell/shell_common.o
  CC      libbb/kernel_version.o
  CC      libbb/last_char_is.o
  AR      shell/lib.a
  CC      libbb/lineedit.o
  CC      libbb/lineedit_ptr_hack.o
  CC      libbb/llist.o
  LD      sysklogd/built-in.o
  AR      sysklogd/lib.a
  LD      util-linux/built-in.o
  AR      util-linux/lib.a
  LD      util-linux/volume_id/built-in.o
  AR      util-linux/volume_id/lib.a
  CC      libbb/login.o
  CC      libbb/make_directory.o
  CC      libbb/makedev.o
  CC      libbb/match_fstype.o
  CC      libbb/messages.o
  CC      libbb/mode_string.o
  CC      libbb/missing_syscalls.o
  CC      libbb/parse_config.o
  CC      libbb/parse_mode.o
  CC      libbb/percent_decode.o
  CC      libbb/perror_msg.o
  CC      libbb/perror_nomsg.o
  CC      libbb/perror_nomsg_and_die.o
  CC      libbb/pidfile.o
  CC      libbb/platform.o
  CC      libbb/print_flags.o
  CC      libbb/printable.o
  CC      libbb/printable_string.o
  CC      libbb/process_escape_sequence.o
  CC      libbb/procps.o
  CC      libbb/progress.o
  CC      libbb/ptr_to_globals.o
  CC      libbb/read.o
  CC      libbb/read_key.o
  CC      libbb/read_printf.o
  CC      libbb/recursive_action.o
  CC      libbb/remove_file.o
  CC      libbb/run_shell.o
  CC      libbb/safe_gethostname.o
  CC      libbb/safe_poll.o
  CC      libbb/safe_strncpy.o
  CC      libbb/safe_write.o
  CC      libbb/setup_environment.o
  CC      libbb/signals.o
  CC      libbb/simplify_path.o
  CC      libbb/single_argv.o
  CC      libbb/skip_whitespace.o
  CC      libbb/speed_table.o
  CC      libbb/str_tolower.o
  CC      libbb/strrstr.o
  CC      libbb/time.o
  CC      libbb/trim.o
  CC      libbb/u_signal_names.o
  CC      libbb/uuencode.o
  CC      libbb/vdprintf.o
  CC      libbb/verror_msg.o
  CC      libbb/vfork_daemon_rexec.o
  CC      libbb/warn_ignoring_args.o
  CC      libbb/wfopen.o
  CC      libbb/wfopen_input.o
  CC      libbb/write.o
  CC      libbb/xatonum.o
  CC      libbb/xconnect.o
  CC      libbb/xfunc_die.o
  CC      libbb/xfuncs.o
  CC      libbb/xfuncs_printf.o
libbb/xfuncs_printf.c: In Funktion »generate_uuid«:
libbb/xfuncs_printf.c:593:7: Warnung: Der Rückgabewert von »read«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  CC      libbb/xgetcwd.o
  CC      libbb/xgethostbyname.o
  CC      libbb/xreadlink.o
  CC      libbb/xrealloc_vector.o
  AR      libbb/lib.a
  LINK    busybox_unstripped
Trying libraries: crypt m
 Library crypt is not needed, excluding it
 Library m is not needed, excluding it
Final link with: <none>
cp /run/shm/tmp/freetz-trunk/source/host-tools/busybox-1.21.0/busybox tools/busybox
find tools -lname busybox -delete
for i in $(tools/busybox --list); do \
		ln -fs busybox tools/$i; \
	done
tools/freetz_download dl fakeroot_1.18.4.orig.tar.bz2 http://ftp.debian.org/debian/pool/main/f/fakeroot 706171d8d520b1ca1576ac73f2ceb4f3
--2013-03-18 20:31:25--  http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.18.4.orig.tar.bz2
Auflösen des Hostnamen »ftp.debian.org (ftp.debian.org)«... 130.89.148.12, 2001:610:1908:b000::148:12
Verbindungsaufbau zu ftp.debian.org (ftp.debian.org)|130.89.148.12|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 309298 (302K) [application/x-bzip2]
In »»dl/fakeroot_1.18.4.orig.tar.bz2«« speichern.
100%[===================================================================================================================================>] 309.298      808K/s   in 0,4s
2013-03-18 20:31:26 (808 KB/s) - »»dl/fakeroot_1.18.4.orig.tar.bz2«« gespeichert [309298/309298]
Download succeeded - "http://ftp.debian.org/debian/pool/main/f/fakeroot/fakeroot_1.18.4.orig.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/fakeroot_1.18.4.orig.tar.bz2: 706171d8d520b1ca1576ac73f2ceb4f3
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf dl/fakeroot_1.18.4.orig.tar.bz2
sed -i "s,getopt --version,getopt --version 2>/dev/null," \
		/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/scripts/fakeroot.in
for i in tools/make/patches/*.fakeroot.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4 $i; \
	done
    applying patch file tools/make/patches/100-fakeroot-doc.fakeroot.patch
    patching file Makefile.am
    patching file Makefile.in
touch /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/.unpacked
(mkdir -p /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch; cd /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch; rm -f config.cache; \
		CFLAGS="-O3 -Wall" \
		CC="gcc" \
		../../configure \
		--prefix=/run/shm/tmp/freetz-trunk/tools/build \
		--enable-shared \
		--disable-nls \
configure: WARNING: unrecognized options: --disable-nls
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make sets $(MAKE)... (cached) yes
checking how to print strings... printf
checking for style of include used by make... GNU
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking dependency style of gcc... gcc3
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 3458764513820540925
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking which IPC method to use... (cached) sysv
checking which database format to use... (cached) inode
checking for dlopen in -ldl... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for unistd.h... (cached) yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking sys/feature_tests.h usability... no
checking sys/feature_tests.h presence... no
checking for sys/feature_tests.h... no
checking pthread.h usability... yes
checking pthread.h presence... yes
checking for pthread.h... yes
checking for stdint.h... (cached) yes
checking for inttypes.h... (cached) yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking endian.h usability... yes
checking endian.h presence... yes
checking for endian.h... yes
checking sys/sysmacros.h usability... yes
checking sys/sysmacros.h presence... yes
checking for sys/sysmacros.h... yes
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking sys/acl.h usability... no
checking sys/acl.h presence... no
checking for sys/acl.h... no
checking fts.h usability... yes
checking fts.h presence... yes
checking for fts.h... yes
checking for an ANSI C-conforming const... yes
checking for mode_t... yes
checking for off_t... yes
checking for size_t... yes
checking for return value and second and third argument of readlink... ssize_t, char, size_t
checking for first argument of setgroups... size_t
checking for union semun... no
checking for type of arg of __xmknod... needs *
checking for type of arg of __xmknodat... needs *
checking for type of arg of initgroups... gid_t
checking for type of arg of setreuid... gid_t
checking for type of arg of setregid... gid_t
checking for type of second arg to stat... struct stat *
checking for d_off in struct dirent... yes
checking for d_type in struct dirent... yes
checking for acl_t struct... no
checking for fchmodat... yes
checking for fchownat... yes
checking for fstatat... yes
checking for mkdirat... yes
checking for mknodat... yes
checking for openat... yes
checking for renameat... yes
checking for unlinkat... yes
checking for lchmod... no
checking for fgetattrlist... no
checking for __xstat... yes
checking for __fxstat... yes
checking for __lxstat... yes
checking for __fxstatat... yes
checking for __xstat64... yes
checking for __fxstat64... yes
checking for __lxstat64... yes
checking for __fxstatat64... yes
checking for __xmknod... yes
checking for __xmknodat... yes
created fakerootconfig.h
checking for strdup... yes
checking for strstr... yes
checking for getresuid... yes
checking for setresuid... yes
checking for getresgid... yes
checking for setresgid... yes
checking for setfsuid... yes
checking for setfsgid... yes
checking for fts_read... yes
checking for fts_children... yes
checking whether setenv is declared... yes
checking whether unsetenv is declared... yes
checking for setenv... yes
checking for MacOS X/Darwin... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating scripts/Makefile
config.status: creating doc/Makefile
config.status: creating doc/de/Makefile
config.status: creating doc/es/Makefile
config.status: creating doc/fr/Makefile
config.status: creating doc/nl/Makefile
config.status: creating doc/sv/Makefile
config.status: creating test/Makefile
config.status: creating test/defs
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
touch /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/.configured
make -j2 -C /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch install
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch'
Making install in scripts
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
sed -e 's,[@]prefix[@],/run/shm/tmp/freetz-trunk/tools/build,g' -e 's,[@]bindir[@],/run/shm/tmp/freetz-trunk/tools/build/bin,g' -e 's,[@]libdir[@],/run/shm/tmp/freetz-trunk/tools/build/lib,g' -e 's,[@]fakeroot_transformed[@],'`echo fakeroot | sed -e 's,x,x,'`',g' -e 's,[@]faked_transformed[@],'`echo faked | sed -e 's,x,x,'`',g' -e 's,[@]signal[@],TERM,g' -e 's,[@]SHELL[@],/bin/bash,g' -e 's,[@]VERSION[@],1.18.4,g' -e 's,[@]DLSUFFIX[@],.so,g' -e 's,[@]LDLIBPATHVAR[@],LD_LIBRARY_PATH,g' -e 's,[@]LDPRELOADVAR[@],LD_PRELOAD,g' -e 's,[@]LDPRELOADABS[@],0,g' -e 's,[@]LDEXTRAVAR[@],,g' -e 's,[@]MACOSX_FALSE[@],,g' -e 's,[@]MACOSX_TRUE[@],#,g' < ../../../scripts/fakeroot.in > fakeroot
chmod +x fakeroot
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
make[3]: Für das Ziel »install-data-am« ist nichts zu tun.
test -z "/run/shm/tmp/freetz-trunk/tools/build/bin" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/tools/build/bin"
 /usr/bin/install -c fakeroot '/run/shm/tmp/freetz-trunk/tools/build/bin'
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/scripts'
Making install in test
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[3]: Für das Ziel »install-exec-am« ist nichts zu tun.
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/test'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch'
awk -f ../../wrapawk < ../../wrapfunc.inp
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c -o communicate.lo ../../communicate.c
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT libfakeroot_inode64.lo -MD -MP -MF .deps/libfakeroot_inode64.Tpo -c -o libfakeroot_inode64.lo ../../libfakeroot_inode64.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c  -fPIC -DPIC -o .libs/communicate.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_inode64.lo -MD -MP -MF .deps/libfakeroot_inode64.Tpo -c ../../libfakeroot_inode64.c  -fPIC -DPIC -o .libs/libfakeroot_inode64.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_inode64.lo -MD -MP -MF .deps/libfakeroot_inode64.Tpo -c ../../libfakeroot_inode64.c -o libfakeroot_inode64.o >/dev/null 2>&1
mv -f .deps/libfakeroot_inode64.Tpo .deps/libfakeroot_inode64.Plo
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT libfakeroot_unix2003.lo -MD -MP -MF .deps/libfakeroot_unix2003.Tpo -c -o libfakeroot_unix2003.lo ../../libfakeroot_unix2003.c
../../communicate.c: In function 'send_get_fakem':
../../communicate.c:540:7: warning: variable 'l' set but not used [-Wunused-but-set-variable]
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_unix2003.lo -MD -MP -MF .deps/libfakeroot_unix2003.Tpo -c ../../libfakeroot_unix2003.c  -fPIC -DPIC -o .libs/libfakeroot_unix2003.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot_unix2003.lo -MD -MP -MF .deps/libfakeroot_unix2003.Tpo -c ../../libfakeroot_unix2003.c -o libfakeroot_unix2003.o >/dev/null 2>&1
mv -f .deps/libfakeroot_unix2003.Tpo .deps/libfakeroot_unix2003.Plo
gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT faked.o -MD -MP -MF .deps/faked.Tpo -c -o faked.o ../../faked.c
../../faked.c: In Funktion »save_database«:
../../faked.c:524:13: Warnung: Format »%llx« erwartet Argumenttyp »long long unsigned int«, aber Argument 3 hat Typ »fake_dev_t« [-Wformat]
../../faked.c:524:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int«, aber Argument 4 hat Typ »fake_ino_t« [-Wformat]
../../faked.c:524:13: Warnung: Format »%llo« erwartet Argumenttyp »long long unsigned int«, aber Argument 5 hat Typ »long unsigned int« [-Wformat]
../../faked.c:524:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int«, aber Argument 6 hat Typ »long unsigned int« [-Wformat]
../../faked.c:524:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int«, aber Argument 7 hat Typ »long unsigned int« [-Wformat]
../../faked.c:524:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int«, aber Argument 8 hat Typ »long unsigned int« [-Wformat]
../../faked.c:524:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int«, aber Argument 9 hat Typ »fake_dev_t« [-Wformat]
../../faked.c: In Funktion »load_database«:
../../faked.c:563:13: Warnung: Format »%llx« erwartet Argumenttyp »long long unsigned int *«, aber Argument 2 hat Typ »uint64_t *« [-Wformat]
../../faked.c:563:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int *«, aber Argument 3 hat Typ »uint64_t *« [-Wformat]
../../faked.c:563:13: Warnung: Format »%llo« erwartet Argumenttyp »long long unsigned int *«, aber Argument 4 hat Typ »uint64_t *« [-Wformat]
../../faked.c:563:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int *«, aber Argument 5 hat Typ »uint64_t *« [-Wformat]
../../faked.c:563:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int *«, aber Argument 6 hat Typ »uint64_t *« [-Wformat]
../../faked.c:563:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int *«, aber Argument 7 hat Typ »uint64_t *« [-Wformat]
../../faked.c:563:13: Warnung: Format »%llu« erwartet Argumenttyp »long long unsigned int *«, aber Argument 8 hat Typ »uint64_t *« [-Wformat]
../../faked.c: In Funktion »debug_stat«:
../../faked.c:596:4: Warnung: Format »%llx« erwartet Argumenttyp »long long unsigned int«, aber Argument 3 hat Typ »fake_dev_t« [-Wformat]
../../faked.c:596:4: Warnung: Format »%lli« erwartet Argumenttyp »long long int«, aber Argument 4 hat Typ »fake_ino_t« [-Wformat]
../../faked.c:596:4: Warnung: Format »%lli« erwartet Argumenttyp »long long int«, aber Argument 9 hat Typ »fake_dev_t« [-Wformat]
../../faked.c: In Funktion »process_chmod«:
../../faked.c:694:9: Warnung: Klammern um Operand von »!« empfohlen, oder Änderung von »&« in »&&« oder »!« in »~« [-Wparentheses]
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c -o communicate.o >/dev/null 2>&1
mv -f .deps/communicate.Tpo .deps/communicate.Plo
gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT simple.o -MD -MP -MF .deps/simple.Tpo -c -o simple.o ../../simple.c
mv -f .deps/simple.Tpo .deps/simple.Po
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c -o libfakeroot.lo ../../libfakeroot.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c  -fPIC -DPIC -o .libs/libfakeroot.o
mv -f .deps/faked.Tpo .deps/faked.Po
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o libcommunicate.la  communicate.lo  -ldl
../../libfakeroot.c: In function 'fts_read':
../../libfakeroot.c:1583:5: warning: passing argument 1 of 'send_get_stat64' from incompatible pointer type [enabled by default]
../../communicate.h:191:13: note: expected 'struct stat64 *' but argument is of type 'struct stat *'
../../libfakeroot.c: In function 'fts_children':
../../libfakeroot.c:1606:7: warning: passing argument 1 of 'send_get_stat64' from incompatible pointer type [enabled by default]
libtool: link: ar cru .libs/libcommunicate.a .libs/communicate.o
libtool: link: ranlib .libs/libcommunicate.a
libtool: link: ( cd ".libs" && rm -f "libcommunicate.la" && ln -s "../libcommunicate.la" "libcommunicate.la" )
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o libmacosx.la  libfakeroot_inode64.lo libfakeroot_unix2003.lo  -ldl
libtool: link: ar cru .libs/libmacosx.a .libs/libfakeroot_inode64.o .libs/libfakeroot_unix2003.o
libtool: link: ranlib .libs/libmacosx.a
libtool: link: ( cd ".libs" && rm -f "libmacosx.la" && ln -s "../libmacosx.la" "libmacosx.la" )
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o faked faked.o libcommunicate.la -ldl
libtool: link: gcc -O3 -Wall -o faked faked.o  ./.libs/libcommunicate.a -ldl
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall   -o simple simple.o  -ldl
libtool: link: gcc -O3 -Wall -o simple simple.o  -ldl
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c -o libfakeroot.o >/dev/null 2>&1
mv -f .deps/libfakeroot.Tpo .deps/libfakeroot.Plo
/bin/bash ./libtool --tag=CC   --mode=link gcc  -O3 -Wall -release 0  -o libfakeroot.la -rpath /run/shm/tmp/freetz-trunk/tools/build/lib libfakeroot.lo libcommunicate.la  -ldl
libtool: link: gcc -shared  -fPIC -DPIC  .libs/libfakeroot.o  -Wl,--whole-archive ./.libs/libcommunicate.a -Wl,--no-whole-archive  -ldl  -O3   -Wl,-soname -Wl,libfakeroot-0.so -o .libs/libfakeroot-0.so
libtool: link: (cd ".libs" && rm -f "libfakeroot.so" && ln -s "libfakeroot-0.so" "libfakeroot.so")
libtool: link: (cd .libs/libfakeroot.lax/libcommunicate.a && ar x "/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch/./.libs/libcommunicate.a")
libtool: link: ar cru .libs/libfakeroot.a  libfakeroot.o  .libs/libfakeroot.lax/libcommunicate.a/communicate.o
libtool: link: ranlib .libs/libfakeroot.a
libtool: link: rm -fr .libs/libfakeroot.lax
libtool: link: ( cd ".libs" && rm -f "libfakeroot.la" && ln -s "../libfakeroot.la" "libfakeroot.la" )
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch'
CONFIG_FILES= CONFIG_HEADERS= /bin/sh ./config.status
test -z "/run/shm/tmp/freetz-trunk/tools/build/lib" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/tools/build/lib"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   libfakeroot.la '/run/shm/tmp/freetz-trunk/tools/build/lib'
libtool: install: /usr/bin/install -c .libs/libfakeroot-0.so /run/shm/tmp/freetz-trunk/tools/build/lib/libfakeroot-0.so
libtool: install: (cd /run/shm/tmp/freetz-trunk/tools/build/lib && { ln -s -f libfakeroot-0.so libfakeroot.so || { rm -f libfakeroot.so && ln -s libfakeroot-0.so libfakeroot.so; }; })
libtool: install: /usr/bin/install -c .libs/libfakeroot.lai /run/shm/tmp/freetz-trunk/tools/build/lib/libfakeroot.la
libtool: install: /usr/bin/install -c .libs/libfakeroot.a /run/shm/tmp/freetz-trunk/tools/build/lib/libfakeroot.a
libtool: install: chmod 644 /run/shm/tmp/freetz-trunk/tools/build/lib/libfakeroot.a
libtool: install: ranlib /run/shm/tmp/freetz-trunk/tools/build/lib/libfakeroot.a
libtool: finish: PATH="/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/sbin" ldconfig -n /run/shm/tmp/freetz-trunk/tools/build/lib
Libraries have been installed in:
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the `-LLIBDIR'
flag during linking and do at least one of the following:
   - add LIBDIR to the `LD_LIBRARY_PATH' environment variable
     during execution
   - add LIBDIR to the `LD_RUN_PATH' environment variable
     during linking
   - use the `-Wl,-rpath -Wl,LIBDIR' linker flag
   - have your system administrator add LIBDIR to `/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
  /bin/bash ./libtool   --mode=install /usr/bin/install -c faked '/run/shm/tmp/freetz-trunk/tools/build/bin'
libtool: install: /usr/bin/install -c faked /run/shm/tmp/freetz-trunk/tools/build/bin/faked
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch'
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/arch'
sed -i -e 's,^PATHS=.*,PATHS=/run/shm/tmp/freetz-trunk/tools/build/lib:/run/shm/tmp/freetz-trunk/tools/build/lib32,g' /run/shm/tmp/freetz-trunk/tools/build/bin/fakeroot
(mkdir -p /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch; cd /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch; rm -f config.cache; \
		CFLAGS="-m32 -O3 -Wall" \
		CC="gcc" \
		../../configure \
		--enable-shared \
		--disable-nls \
checking whether the gcc linker (/usr/bin/ld -m elf_i386) supports shared libraries... yes
checking for return value and second and third argument of readlink... int, char, size_t
touch /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch/.configured
make -j2 -C /run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch libdir="/run/shm/tmp/freetz-trunk/tools/build/lib32" install-libLTLIBRARIES
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch'
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -m32 -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c -o communicate.lo ../../communicate.c
/bin/bash ./libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I../..     -m32 -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c -o libfakeroot.lo ../../libfakeroot.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c  -fPIC -DPIC -o .libs/communicate.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c  -fPIC -DPIC -o .libs/libfakeroot.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT communicate.lo -MD -MP -MF .deps/communicate.Tpo -c ../../communicate.c -o communicate.o >/dev/null 2>&1
/bin/bash ./libtool --tag=CC   --mode=link gcc  -m32 -O3 -Wall   -o libcommunicate.la  communicate.lo  -ldl
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I../.. -m32 -O3 -Wall -MT libfakeroot.lo -MD -MP -MF .deps/libfakeroot.Tpo -c ../../libfakeroot.c -o libfakeroot.o >/dev/null 2>&1
/bin/bash ./libtool --tag=CC   --mode=link gcc  -m32 -O3 -Wall -release 0  -o libfakeroot.la -rpath /run/shm/tmp/freetz-trunk/tools/build/lib32 libfakeroot.lo libcommunicate.la  -ldl
libtool: link: gcc -shared  -fPIC -DPIC  .libs/libfakeroot.o  -Wl,--whole-archive ./.libs/libcommunicate.a -Wl,--no-whole-archive  -ldl  -m32 -O3   -Wl,-soname -Wl,libfakeroot-0.so -o .libs/libfakeroot-0.so
libtool: link: (cd .libs/libfakeroot.lax/libcommunicate.a && ar x "/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch/./.libs/libcommunicate.a")
test -z "/run/shm/tmp/freetz-trunk/tools/build/lib32" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/tools/build/lib32"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   libfakeroot.la '/run/shm/tmp/freetz-trunk/tools/build/lib32'
libtool: install: /usr/bin/install -c .libs/libfakeroot-0.so /run/shm/tmp/freetz-trunk/tools/build/lib32/libfakeroot-0.so
libtool: install: (cd /run/shm/tmp/freetz-trunk/tools/build/lib32 && { ln -s -f libfakeroot-0.so libfakeroot.so || { rm -f libfakeroot.so && ln -s libfakeroot-0.so libfakeroot.so; }; })
libtool: install: /usr/bin/install -c .libs/libfakeroot.lai /run/shm/tmp/freetz-trunk/tools/build/lib32/libfakeroot.la
libtool: install: /usr/bin/install -c .libs/libfakeroot.a /run/shm/tmp/freetz-trunk/tools/build/lib32/libfakeroot.a
libtool: install: chmod 644 /run/shm/tmp/freetz-trunk/tools/build/lib32/libfakeroot.a
libtool: install: ranlib /run/shm/tmp/freetz-trunk/tools/build/lib32/libfakeroot.a
libtool: finish: PATH="/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/sbin" ldconfig -n /run/shm/tmp/freetz-trunk/tools/build/lib32
     during execution
     during linking
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/fakeroot-1.18.4/build/biarch'
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf tools/source/find-squashfs.tar.bz2
touch /run/shm/tmp/freetz-trunk/source/host-tools/find-squashfs/.unpacked
make -j2 CC="gcc" LD="ld -static" \
		-C /run/shm/tmp/freetz-trunk/source/host-tools/find-squashfs
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/find-squashfs'
gcc -W -Wall -O2   -c -o find-squashfs.o find-squashfs.c
gcc -o find-squashfs find-squashfs.o
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/find-squashfs'
cp /run/shm/tmp/freetz-trunk/source/host-tools/find-squashfs/find-squashfs tools/find-squashfs
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf tools/source/sstrip-1.0.tar.bz2
touch /run/shm/tmp/freetz-trunk/source/host-tools/sstrip-1.0/.unpacked
make -j2 -C /run/shm/tmp/freetz-trunk/source/host-tools/sstrip-1.0 \
		CC="gcc" \
		CFLAGS="-Wall -O2" \
		all
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/sstrip-1.0'
gcc -Wall -O2    sstrip.c   -o sstrip
sstrip.c: In Funktion »main«:
sstrip.c:367:1: Warnung: »p.phdrs32« könnte in dieser Funktion uninitialisiert verwendet werden [-Wuninitialized]
sstrip.c:430:4: Anmerkung: »p.phdrs32« wurde hier deklariert
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/sstrip-1.0'
cp /run/shm/tmp/freetz-trunk/source/host-tools/sstrip-1.0/sstrip tools/sstrip
make -j2 -C /run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8 config
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8'
cp /run/shm/tmp/freetz-trunk/source/host-tools/kconfig-v3.8/scripts/kconfig/conf tools/config/conf
tools/freetz_download dl lzma443.tar.bz2 @SF/sevenzip c4e1b467184c7cffd4371c74df2baf0f
--2013-03-18 20:31:50--  http://downloads.sourceforge.net/sevenzip/lzma443.tar.bz2
Auflösen des Hostnamen »downloads.sourceforge.net (downloads.sourceforge.net)«... 216.34.181.59
Verbindungsaufbau zu downloads.sourceforge.net (downloads.sourceforge.net)|216.34.181.59|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 301 Moved Permanently
Platz: http://downloads.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2 [folge]
--2013-03-18 20:31:50--  http://downloads.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2
Wiederverwendung der bestehenden Verbindung zu downloads.sourceforge.net:80.
HTTP-Anforderung gesendet, warte auf Antwort... 302 Found
Platz: http://garr.dl.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2 [folge]
--2013-03-18 20:31:50--  http://garr.dl.sourceforge.net/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2
Auflösen des Hostnamen »garr.dl.sourceforge.net (garr.dl.sourceforge.net)«... 193.206.140.34, 2001:760:ffff:b0::34
Verbindungsaufbau zu garr.dl.sourceforge.net (garr.dl.sourceforge.net)|193.206.140.34|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 302 Moved Temporarily
Platz: http://cdn.mirror.garr.it/sf/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2 [folge]
--2013-03-18 20:31:51--  http://cdn.mirror.garr.it/sf/project/sevenzip/LZMA%20SDK/4.43/lzma443.tar.bz2
Auflösen des Hostnamen »cdn.mirror.garr.it (cdn.mirror.garr.it)«... 193.206.140.45, 193.206.139.45, 2001:760:ffff:b0::45, ...
Verbindungsaufbau zu cdn.mirror.garr.it (cdn.mirror.garr.it)|193.206.140.45|:80... verbunden.
Länge: 178493 (174K) [application/octet-stream]
In »»dl/lzma443.tar.bz2«« speichern.
100%[===================================================================================================================================>] 178.493      538K/s   in 0,3s
2013-03-18 20:31:51 (538 KB/s) - »»dl/lzma443.tar.bz2«« gespeichert [178493/178493]
Download succeeded - "http://downloads.sourceforge.net/sevenzip/lzma443.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/lzma443.tar.bz2: c4e1b467184c7cffd4371c74df2baf0f
mkdir -p /run/shm/tmp/freetz-trunk/source/host-tools/lzma443
tar -C /run/shm/tmp/freetz-trunk/source/host-tools/lzma443  -xf dl/lzma443.tar.bz2
for i in tools/make/patches/*.lzma.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/lzma443 $i; \
	done
    applying patch file tools/make/patches/100-lzma_zlib.lzma.patch
    patching file C/7zip/Compress/LZMA/LZMADecoder.cpp
    patching file C/7zip/Compress/LZMA/LZMADecoder.h
    patching file C/7zip/Compress/LZMA_Lib/makefile
    patching file C/7zip/Compress/LZMA_Lib/ZLib.cpp
    applying patch file tools/make/patches/100-outbuffer.lzma.patch
    patching file C/7zip/Common/OutBuffer.cpp
touch /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/.unpacked
make -j2 -C /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib'
g++ -O3 -Wall -c  -I ../../../ ZLib.cpp
g++ -O3 -Wall -c  -I ../../../ ../LZMA/LZMADecoder.cpp
../LZMA/LZMADecoder.cpp: In Elementfunktion »virtual LONG NCompress::NLZMA::CDecoder::SetOutStreamSize(const UInt64*)«:
../LZMA/LZMADecoder.cpp:317:42: Warnung: Um Zuweisung, die als Wahrheitswert verwendet wird, werden Klammern empfohlen [-Wparentheses]
g++ -O3 -Wall -c  -I ../../../ ../LZMA/LZMAEncoder.cpp
../LZMA/LZMAEncoder.cpp: In Elementfunktion »LONG NCompress::NLZMA::CEncoder::GetOptimumFast(UInt32, UInt32&, UInt32&)«:
../LZMA/LZMAEncoder.cpp:1207:68: Warnung: Klammern um »&&« innerhalb von »||« empfohlen [-Wparentheses]
../LZMA/LZMAEncoder.cpp:1208:69: Warnung: Klammern um »&&« innerhalb von »||« empfohlen [-Wparentheses]
../LZMA/LZMAEncoder.cpp:1223:82: Warnung: Klammern um »&&« innerhalb von »||« empfohlen [-Wparentheses]
../LZMA/LZMAEncoder.cpp:1225:97: Warnung: Klammern um »&&« innerhalb von »||« empfohlen [-Wparentheses]
g++ -O3 -Wall -c  -I ../../../ ../LZ/LZInWindow.cpp
g++ -O3 -Wall -c  -I ../../../ ../LZ/LZOutWindow.cpp
g++ -O3 -Wall -c  -I ../../../ ../RangeCoder/RangeCoderBit.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/InBuffer.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/OutBuffer.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/FileStreams.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/Alloc.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/C_FileIO.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/CommandLineParser.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/CRC.cpp
g++ -O3 -Wall -c  -I ../../../ ../../Common/StreamUtils.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/String.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/StringConvert.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/StringToInt.cpp
g++ -O3 -Wall -c  -I ../../../ ../../../Common/Vector.cpp
ar r liblzma.a ZLib.o LZMADecoder.o LZMAEncoder.o LZInWindow.o LZOutWindow.o RangeCoderBit.o InBuffer.o OutBuffer.o FileStreams.o Alloc.o C_FileIO.o CommandLineParser.o CRC.o StreamUtils.o String.o StringConvert.o StringToInt.o Vector.o
ar: creating liblzma.a
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib'
touch -c /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib/liblzma.a
cp -f /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Lib/liblzma.a /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/liblzma.a
make -j2 -f makefile.gcc -C /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone'
g++ -O2 -Wall -c -I ../../../ LzmaAlone.cpp
g++ -O2 -Wall -c -I ../../../ LzmaBench.cpp
LzmaBench.cpp: In Funktion »void ThrowError(FILE*, LONG, const char*)«:
LzmaBench.cpp:366:17: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
LzmaAlone.cpp: In Funktion »int main2(int, const char**)«:
LzmaAlone.cpp:371:76: Warnung: Um Zuweisung, die als Wahrheitswert verwendet wird, werden Klammern empfohlen [-Wparentheses]
LzmaAlone.cpp:447:36: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
LzmaAlone.cpp:473:33: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
LzmaAlone.cpp:478:33: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
LzmaAlone.cpp:492:35: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
LzmaAlone.cpp:497:35: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
g++ -O2 -Wall -c -I ../../../ LzmaRam.cpp
gcc -O2 -Wall -c -I ../../../ LzmaRamDecode.c
gcc -O2 -Wall -c -I ../../../ ../LZMA_C/LzmaDecode.c
gcc -O2 -Wall -c -I ../../../ ../Branch/BranchX86.c
g++ -O2 -Wall -c -I ../../../ ../LZMA/LZMADecoder.cpp
g++ -O2 -Wall -c -I ../../../ ../LZMA/LZMAEncoder.cpp
g++ -O2 -Wall -c -I ../../../ ../LZ/LZInWindow.cpp
g++ -O2 -Wall -c -I ../../../ ../LZ/LZOutWindow.cpp
g++ -O2 -Wall -c -I ../../../ ../RangeCoder/RangeCoderBit.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/InBuffer.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/OutBuffer.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/FileStreams.cpp
g++ -O2 -Wall -c -I ../../../ ../../Common/StreamUtils.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/Alloc.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/C_FileIO.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/CommandLineParser.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/CRC.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/String.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/StringConvert.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/StringToInt.cpp
g++ -O2 -Wall -c -I ../../../ ../../../Common/Vector.cpp
g++ -O2 -Wall -o lzma  LzmaAlone.o LzmaBench.o LzmaRam.o LzmaRamDecode.o LzmaDecode.o BranchX86.o LZMADecoder.o LZMAEncoder.o LZInWindow.o LZOutWindow.o RangeCoderBit.o InBuffer.o OutBuffer.o FileStreams.o StreamUtils.o Alloc.o C_FileIO.o CommandLineParser.o CRC.o String.o StringConvert.o StringToInt.o Vector.o  -lm
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone'
cp /run/shm/tmp/freetz-trunk/source/host-tools/lzma443/C/7zip/Compress/LZMA_Alone/lzma tools/lzma
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf tools/source/lzma2eva.tar.bz2
for i in tools/make/patches/*.lzma2eva.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/lzma2eva $i; \
	done
    applying patch file tools/make/patches/100-fix_missing_crc32.lzma2eva.patch
touch /run/shm/tmp/freetz-trunk/source/host-tools/lzma2eva/.unpacked
make -j2 CC="gcc" LD="ld" -C /run/shm/tmp/freetz-trunk/source/host-tools/lzma2eva
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/lzma2eva'
gcc -o lzma2eva lzma2eva.c -lz
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/lzma2eva'
cp /run/shm/tmp/freetz-trunk/source/host-tools/lzma2eva/lzma2eva tools/lzma2eva
tools/freetz_download dl sfk165.zip @SF/swissfileknife/1-swissfileknife/1.6.5 8694d73033dde496c023258f08daa918
--2013-03-18 20:31:57--  http://downloads.sourceforge.net/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip
Platz: http://garr.dl.sourceforge.net/project/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip [folge]
--2013-03-18 20:31:58--  http://garr.dl.sourceforge.net/project/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip
Länge: 2817916 (2,7M) [application/octet-stream]
In »»dl/sfk165.zip«« speichern.
100%[===================================================================================================================================>] 2.817.916   1,13M/s   in 2,4s
2013-03-18 20:32:01 (1,13 MB/s) - »»dl/sfk165.zip«« gespeichert [2817916/2817916]
Download succeeded - "http://downloads.sourceforge.net/swissfileknife/1-swissfileknife/1.6.5/sfk165.zip"  ->  saved to folder "dl"
MD5 verified for dl/sfk165.zip: 8694d73033dde496c023258f08daa918
unzip -d /run/shm/tmp/freetz-trunk/source/host-tools dl/sfk165.zip
Archive:  dl/sfk165.zip
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/bsd-license.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/do-compile-unix.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/do-compile-win.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/do-prep-linux-bin.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/do-view-all-win.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/do-view-readme-win.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/inst.cpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/macbin/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/macbin/readme.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/macbin/sfk-mac-i686.exe
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/macbin/sfk-mac-ppc.exe
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/memdeb.cpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/mtk/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/mtk/mtktrace.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/mtk/mtktrace.hpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/mtk/readme.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/patch.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/readme.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/01-sfk-selftest-win.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/02-conv-win-to-ux.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/03-sfk-selftest-ux.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/10-sfk-selftest-db.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/10-sfk-selftest-db.txt2
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/11-sub-test-win.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/12-sub-test-ux.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/13-sfk-selftest-ux-pre.bat
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/14-sfk-selftest-ux-fix.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/15-sfk-selftest-ux-fix.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/50-patch-all-ux.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/50-patch-all-win.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/scripts/readme.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.exe
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfkbase.hpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfknet.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfknet.hpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/BaseLib/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/BaseLib/Trace/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/BaseLib/Trace/include/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/BaseLib/Trace/include/Trace.hpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarBottle.hpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarDriver.hpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarGlass.hpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/BarMug.hpp
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/include/ExtremelyLongHeaderFileNameForRatherSeldomUsedClass.hpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarBottle.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarDriver.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarGlass.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/BarDriver/source/BarMug.cpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/DB/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/DB/include/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/DB/include/DBController.hpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/DB/source/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/DB/source/DBController.cpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/include/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/include/FooGUI.hpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/source/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/FooBank/GUI/source/FooGUI.cpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/01-native-tab-crlf.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/02-crlf.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/03-native-tab-lf.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/04-lf.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/05-split-text.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/06-binary.jpg
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/07-filter-src.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/08-head-tail.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/09 blank file name.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/10-dir-list.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/11-wide-line.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/12-foo-jam.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/13-eof-null.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/14-all-codes.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/15-float-text.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/16-short-words.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/17 blank dir/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/17 blank dir/tree with blank/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/17 blank dir/tree with blank/file name.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/18-ziptest.zip
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/19-jartest.jar
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/20-tab-data-line.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/21-patch-bin.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/22-umlauts-???????-name.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/23-filt-patterns.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/24-line-blocks.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/25-nested-zip.zip
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/26-flat-tar.tar
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/27-pack-text1.txt.gz
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/28-pack-text2.txt.bz2
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/29-pack-tape1.tar.gz
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/30-pack-tape2.tar.bz2
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/31-nested-arc.tar.gz
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/32-pack-tape3.tgz
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/33-nested-any.zip
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/Formats/34-csv-data-lines.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/.myscm/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/.myscm/root.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/.myscm.bak/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/.myscm.bak/root.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/01-make-all.sh
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/base/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/base/Tools.cpp
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/base/Tools.hpp
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/login/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/app/gui/login/Screen.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/config.h
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/config.h.bak
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/myscm-use.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/save/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/save/config.h
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/save2/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/save2/config.h
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/save3/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/save3/config.h
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tmp/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tmp/trash1.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tmp/trash2.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tmp/trash3.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/.myscm/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/.myscm/sub1.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/.myscm/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/.myscm/sub2.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/Tools.hpp
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/include/Tools.hpp.bak
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/new.myscm/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/new.myscm/sub1.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/org.myscm/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/org.myscm/sub1.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/.myscm/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/.myscm/sub3.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/other1.myscm
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/other1.myscm.bak
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/.myscm
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/.myscm-file.txt
 extracting: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/save/Tools.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/Tools.cpp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/myproj/tools/source/Tools.tmp
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/testfiles/readme.txt
   creating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/uxbin/
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/uxbin/readme.txt
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/uxbin/sfk-linux-lib5.exe
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/uxbin/sfk-linux.exe
  inflating: /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/zz-bookmarks.1.dvbm
touch /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/.unpacked
g++ -s /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfknet.cpp /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/patch.cpp /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/inst.cpp -o /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk
/run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp: In Funktion »unsigned char matchstr(char*, char*, int, int&, int&)«:
/run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp:8075:86: Warnung: Format »%d« erwartet Argumenttyp »int«, aber Argument 3 hat Typ »long int« [-Wformat]
/run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp:8080:90: Warnung: Format »%d« erwartet Argumenttyp »int«, aber Argument 3 hat Typ »long int« [-Wformat]
/run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp:8180:102: Warnung: Format »%d« erwartet Argumenttyp »int«, aber Argument 4 hat Typ »long int« [-Wformat]
/run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp: In Funktion »int prtFile(char*, char*, Coi*, char*, int, const char*, ...)«:
/run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk.cpp:17655:103: Warnung: Format »%u« erwartet Argumenttyp »unsigned int«, aber Argument 3 hat Typ »size_t {aka long unsigned int}« [-Wformat]
cp /run/shm/tmp/freetz-trunk/source/host-tools/sfk165/sfk tools/sfk
tools/freetz_download dl squashfs2.2-r2.tar.gz @SF/squashfs a8d09a217240127ae4d339e8368d2de1
--2013-03-18 20:32:06--  http://downloads.sourceforge.net/squashfs/squashfs2.2-r2.tar.gz
Platz: http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz [folge]
--2013-03-18 20:32:06--  http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz
Platz: http://freefr.dl.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz [folge]
--2013-03-18 20:32:07--  http://freefr.dl.sourceforge.net/project/squashfs/squashfs/squashfs2.2-r2/squashfs2.2-r2.tar.gz
Auflösen des Hostnamen »freefr.dl.sourceforge.net (freefr.dl.sourceforge.net)«... 158.255.96.7, 2001:1b48:10f::7
Verbindungsaufbau zu freefr.dl.sourceforge.net (freefr.dl.sourceforge.net)|158.255.96.7|:80... verbunden.
Länge: 234231 (229K) [application/x-gzip]
In »»dl/squashfs2.2-r2.tar.gz«« speichern.
100%[===================================================================================================================================>] 234.231      130K/s   in 1,8s
2013-03-18 20:32:17 (130 KB/s) - »»dl/squashfs2.2-r2.tar.gz«« gespeichert [234231/234231]
Download succeeded - "http://downloads.sourceforge.net/squashfs/squashfs2.2-r2.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/squashfs2.2-r2.tar.gz: a8d09a217240127ae4d339e8368d2de1
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf dl/squashfs2.2-r2.tar.gz
for i in tools/make/patches/*.squashfs.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2 $i; \
	done
    applying patch file tools/make/patches/100-lzma-and-unsquashfs.squashfs.patch
    patching file squashfs-tools/Makefile
    patching file squashfs-tools/squashfs_fs.h
    patching file squashfs-tools/unsquashfs.c
    applying patch file tools/make/patches/110-allow-symlinks.squashfs.patch
    patching file squashfs-tools/mksquashfs.c
    applying patch file tools/make/patches/115-osx.squashfs.patch
    patching file squashfs-tools/read_fs.c
touch /run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/.unpacked
make -j2 CC="gcc" CXX="g++" LZMA_DIR="/run/shm/tmp/freetz-trunk/source/host-tools/lzma443" \
		-C /run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/squashfs-tools mksquashfs-lzma unsquashfs-lzma
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/squashfs-tools'
sed -e 's/#define SQUASHFS_MINOR\t\t\t1/#define SQUASHFS_MINOR\t\t\t76/g' squashfs_fs.h > squashfs_fs-lzma.h
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o read_fs.o read_fs.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o sort.o sort.c
sed -e 's/squashfs_fs\.h/squashfs_fs-lzma.h/g' unsquashfs.c > unsquashfs-lzma.c
sed -e 's/squashfs_fs\.h/squashfs_fs-lzma.h/g' mksquashfs.c > mksquashfs-lzma.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o unsquashfs-lzma.o unsquashfs-lzma.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -g   -c -o mksquashfs-lzma.o mksquashfs-lzma.c
mksquashfs-lzma.c: In Funktion »dir_scan«:
mksquashfs-lzma.c:1456:6: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
g++ unsquashfs-lzma.o -L/run/shm/tmp/freetz-trunk/source/host-tools/lzma443 -llzma -o unsquashfs-lzma
g++ mksquashfs-lzma.o read_fs.o sort.o -L/run/shm/tmp/freetz-trunk/source/host-tools/lzma443 -llzma -o mksquashfs-lzma
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/squashfs-tools'
touch -c /run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/squashfs-tools/mksquashfs-lzma
cp /run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/squashfs-tools/mksquashfs-lzma tools/mksquashfs-lzma
strip tools/mksquashfs-lzma
cp /run/shm/tmp/freetz-trunk/source/host-tools/squashfs2.2-r2/squashfs-tools/unsquashfs-lzma tools/unsquashfs-lzma
strip tools/unsquashfs-lzma
tools/freetz_download dl squashfs3.4.tar.gz @SF/squashfs 2a4d2995ad5aa6840c95a95ffa6b1da6
--2013-03-18 20:32:18--  http://downloads.sourceforge.net/squashfs/squashfs3.4.tar.gz
Platz: http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz [folge]
--2013-03-18 20:32:18--  http://downloads.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz
Platz: http://heanet.dl.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz [folge]
--2013-03-18 20:32:18--  http://heanet.dl.sourceforge.net/project/squashfs/squashfs/squashfs3.4/squashfs3.4.tar.gz
Auflösen des Hostnamen »heanet.dl.sourceforge.net (heanet.dl.sourceforge.net)«... 193.1.193.66, 2001:770:18:aa40::c101:c142
Verbindungsaufbau zu heanet.dl.sourceforge.net (heanet.dl.sourceforge.net)|193.1.193.66|:80... verbunden.
Länge: 352660 (344K) [application/x-gzip]
In »»dl/squashfs3.4.tar.gz«« speichern.
100%[===================================================================================================================================>] 352.660      792K/s   in 0,4s
2013-03-18 20:32:19 (792 KB/s) - »»dl/squashfs3.4.tar.gz«« gespeichert [352660/352660]
Download succeeded - "http://downloads.sourceforge.net/squashfs/squashfs3.4.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/squashfs3.4.tar.gz: 2a4d2995ad5aa6840c95a95ffa6b1da6
tar -C /run/shm/tmp/freetz-trunk/source/host-tools  -xf dl/squashfs3.4.tar.gz
for i in tools/make/patches/*.squashfs3.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4 $i; \
	done
    applying patch file tools/make/patches/100-lzma.squashfs3.patch
    applying patch file tools/make/patches/120-memset-sBlk.squashfs3.patch
    applying patch file tools/make/patches/130-inode_number.squashfs3.patch
    applying patch file tools/make/patches/140-hide_output.squashfs3.patch
    applying patch file tools/make/patches/150-malloc_size.squashfs3.patch
    applying patch file tools/make/patches/160-queue_race_condition.squashfs3.patch
    applying patch file tools/make/patches/170-read_EINTR_or_EOF.squashfs3.patch
    applying patch file tools/make/patches/180-no_empty_files_on_read_error_abort_instead.squashfs3.patch
    applying patch file tools/make/patches/190-memcpy_memmove.squashfs3.patch
    applying patch file tools/make/patches/200-writer_buffer_leak.squashfs3.patch
    applying patch file tools/make/patches/210-progress_bar-floating_point_exception.squashfs3.patch
    applying patch file tools/make/patches/220-osx.squashfs3.patch
touch /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/.unpacked
		-C /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools all
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools'
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o mksquashfs.o mksquashfs.c
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o read_fs.o read_fs.c
mksquashfs.c: In Funktion »dir_scan2«:
mksquashfs.c:3033:6: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
mksquashfs.c:3087:7: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
mksquashfs.c: In Funktion »write_file_blocks_dup«:
mksquashfs.c:2572:13: Warnung: Der Rückgabewert von »ftruncate«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
mksquashfs.c:2600:12: Warnung: Der Rückgabewert von »ftruncate«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
mksquashfs.c: In Funktion »write_file_blocks«:
mksquashfs.c:2476:12: Warnung: Der Rückgabewert von »ftruncate«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o sort.o sort.c
sort.c: In Funktion »sort_files_and_write«:
sort.c:238:5: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
sort.c:245:5: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o unsquashfs.o unsquashfs.c
sed -e 's/#define SQUASHFS_MINOR\t\t\t0/#define SQUASHFS_MINOR\t\t\t76/g' squashfs_fs.h > squashfs_fs-lzma.h
gcc unsquashfs.o -lz -lpthread -lm -o unsquashfs3
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o mksquashfs-lzma.o mksquashfs-lzma.c
mksquashfs-lzma.c: In Funktion »dir_scan2«:
mksquashfs-lzma.c:3033:6: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
mksquashfs-lzma.c:3087:7: Warnung: Format »%lld« erwartet Argumenttyp »long long int«, aber Argument 3 hat Typ »__off_t« [-Wformat]
mksquashfs-lzma.c: In Funktion »write_file_blocks_dup«:
mksquashfs-lzma.c:2572:13: Warnung: Der Rückgabewert von »ftruncate«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
mksquashfs-lzma.c:2600:12: Warnung: Der Rückgabewert von »ftruncate«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
mksquashfs-lzma.c: In Funktion »write_file_blocks«:
mksquashfs-lzma.c:2476:12: Warnung: Der Rückgabewert von »ftruncate«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
gcc -I. -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_GNU_SOURCE -O2   -c -o unsquashfs-lzma.o unsquashfs-lzma.c
gcc mksquashfs.o read_fs.o sort.o -lz -lpthread -lm -o mksquashfs3
g++ unsquashfs-lzma.o -L/run/shm/tmp/freetz-trunk/source/host-tools/lzma443 -llzma -lpthread -lm -o unsquashfs3-lzma
g++ mksquashfs-lzma.o read_fs.o sort.o -L/run/shm/tmp/freetz-trunk/source/host-tools/lzma443 -llzma -lpthread -lm -o mksquashfs3-lzma
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools'
touch -c /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools/mksquashfs3
cp /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools/mksquashfs3 tools/mksquashfs3
strip tools/mksquashfs3
cp /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools/unsquashfs3 tools/unsquashfs3
strip tools/unsquashfs3
cp /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools/mksquashfs3-lzma tools/mksquashfs3-lzma
strip tools/mksquashfs3-lzma
cp /run/shm/tmp/freetz-trunk/source/host-tools/squashfs3.4/squashfs-tools/unsquashfs3-lzma tools/unsquashfs3-lzma
strip tools/unsquashfs3-lzma
rm -f -r /run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2
mkdir -p /run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2
tar cC tools/make/tichksum/src . | tar xC /run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2  --exclude=.svn
touch /run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2/.unpacked
make -j2 CC="gcc" LD="ld" \
		-C /run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2'
gcc -W -Wall -O2   -c -o ckmain.o ckmain.c
gcc -W -Wall -O2   -c -o cksum.o cksum.c
cksum.c: In Funktion »cs_is_tagged«:
cksum.c:102:3: Warnung: Dereferenzierung eines Type-Pun-Zeigers verletzt strict-aliasing-Regeln [-Wstrict-aliasing]
cksum.c: In Funktion »cs_get_sum«:
cksum.c:193:8: Warnung: Der Rückgabewert von »fread«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
cksum.c:194:8: Warnung: Der Rückgabewert von »fread«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
cksum.c: In Funktion »cs_read_sum«:
cksum.c:112:8: Warnung: Der Rückgabewert von »fread«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
cksum.c:101:8: Warnung: Der Rückgabewert von »fread«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
gcc -o tichksum ckmain.o cksum.o
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2'
cp /run/shm/tmp/freetz-trunk/source/host-tools/TI-chksum-0.2/tichksum tools/tichksum
--2013-03-18 20:32:24--  http://freetz.magenbrot.net/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma
Auflösen des Hostnamen »freetz.magenbrot.net (freetz.magenbrot.net)«... 85.25.156.176
Verbindungsaufbau zu freetz.magenbrot.net (freetz.magenbrot.net)|85.25.156.176|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 5192957 (5,0M) [application/x-tar]
In »»dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma«« speichern.
100%[===================================================================================================================================>] 5.192.957   1,43M/s   in 3,6s
2013-03-18 20:32:28 (1,36 MB/s) - »»dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma«« gespeichert [5192957/5192957]
Download succeeded - "http://freetz.magenbrot.net/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma"  ->  saved to folder "dl"
MD5 verified for dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma: b17b7f26931ad8f263953a2dfc1d08b7
mkdir -p toolchain/build
rm -f -r toolchain/build/mipsel_gcc-4.6.3
tools/busybox tar  -xf dl/mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma -C toolchain/build
---> kernel:  downloading...tools/freetz_download dl/fw ""7270_05.21"-release_kernel.tar.xz" "" "e396bbfcbd88c09cfcc652f94b7f8a57"
--2013-03-18 20:32:29--  http://freetz.wirsind.info/7270_05.21-release_kernel.tar.xz
Auflösen des Hostnamen »freetz.wirsind.info (freetz.wirsind.info)«... 87.98.242.177
Verbindungsaufbau zu freetz.wirsind.info (freetz.wirsind.info)|87.98.242.177|:80... verbunden.
Länge: 58215296 (56M) [application/octet-stream]
In »»dl/fw/7270_05.21-release_kernel.tar.xz«« speichern.
100%[===================================================================================================================================>] 58.215.296  1,34M/s   in 41s
2013-03-18 20:33:10 (1,35 MB/s) - »»dl/fw/7270_05.21-release_kernel.tar.xz«« gespeichert [58215296/58215296]
Download succeeded - "http://freetz.wirsind.info/7270_05.21-release_kernel.tar.xz"  ->  saved to folder "dl/fw"
MD5 verified for dl/fw/7270_05.21-release_kernel.tar.xz: e396bbfcbd88c09cfcc652f94b7f8a57
rm -f -r source/kernel/ref-ur8-7270_05.21
mkdir -p source/kernel/ref-ur8-7270_05.21
checking structure...  unpacking...  preparing...     applying patch file make/linux/patches/2.6.32/001-drivers_dsl_kconfig.patch
    patching file linux-2.6.32/drivers/dsl/Kconfig
    patching file linux-2.6.32/drivers/dsl/Makefile.26
    patching file linux-2.6.32/drivers/Kconfig
    applying patch file make/linux/patches/2.6.32/002-usb_musb_kconfig.patch
    patching file linux-2.6.32/drivers/usb/Kconfig
    applying patch file make/linux/patches/2.6.32/009-jffs-fix-min-max-confusion.patch
    patching file linux-2.6.32/fs/jffs2/summary.c
    applying patch file make/linux/patches/2.6.32/010-shell_bash.patch
    patching file linux-2.6.32/Makefile
    applying patch file make/linux/patches/2.6.32/012-extra_optimization.patch
    applying patch file make/linux/patches/2.6.32/022-mips_use_generic_thread_info_allocator.patch
    patching file linux-2.6.32/arch/mips/include/asm/thread_info.h
    applying patch file make/linux/patches/2.6.32/023-mips-fix-kexec.patch
    patching file linux-2.6.32/arch/mips/kernel/machine_kexec.c
    applying patch file make/linux/patches/2.6.32/100-evaloader.patch
    patching file linux-2.6.32/arch/mips/Makefile
    applying patch file make/linux/patches/2.6.32/100-netfilter_layer7_2.21.patch
    patching file linux-2.6.32/net/netfilter/regexp/regexp.c
    patching file linux-2.6.32/net/netfilter/regexp/regexp.h
    patching file linux-2.6.32/net/netfilter/regexp/regmagic.h
    patching file linux-2.6.32/net/netfilter/regexp/regsub.c
    applying patch file make/linux/patches/2.6.32/115-netfilter_recent_reap.patch
    patching file linux-2.6.32/include/linux/netfilter/xt_recent.h
    patching file linux-2.6.32/net/netfilter/xt_recent.c
    applying patch file make/linux/patches/2.6.32/120-capi-missing-compiler-includes.patch
    patching file linux-2.6.32/include/linux/capi.h
    patching file linux-2.6.32/include/linux/kernelcapi.h
    applying patch file make/linux/patches/2.6.32/199-remove_double_hash_conntrack.patch
    patching file linux-2.6.32/net/netfilter/nf_conntrack_core.c
    applying patch file make/linux/patches/2.6.32/230-cifs_revert_slow_work.patch
    patching file linux-2.6.32/fs/cifs/cifsfs.c
    patching file linux-2.6.32/fs/cifs/cifsglob.h
    patching file linux-2.6.32/fs/cifs/cifsproto.h
    patching file linux-2.6.32/fs/cifs/cifssmb.c
    patching file linux-2.6.32/fs/cifs/connect.c
    patching file linux-2.6.32/fs/cifs/dir.c
    patching file linux-2.6.32/fs/cifs/Kconfig
    patching file linux-2.6.32/fs/cifs/misc.c
    patching file linux-2.6.32/fs/cifs/transport.c
    patching file linux-2.6.32/fs/cifs/file.c
    applying patch file make/linux/patches/2.6.32/300-mppe-mppc.patch
    patching file linux-2.6.32/crypto/api.c
    patching file linux-2.6.32/drivers/net/Kconfig
    patching file linux-2.6.32/drivers/net/Makefile
    patching file linux-2.6.32/drivers/net/ppp_mppe_mppc.c
    patching file linux-2.6.32/include/linux/crypto.h
    patching file linux-2.6.32/include/linux/ppp-comp.h
    patching file linux-2.6.32/drivers/net/ppp_generic.c
    applying patch file make/linux/patches/2.6.32/300-skbuff-nf_conntrack.patch
    patching file linux-2.6.32/include/linux/skbuff.h
    patching file linux-2.6.32/net/core/skbuff.c
    applying patch file make/linux/patches/2.6.32/400-ftdi-smartmouse.patch
    patching file linux-2.6.32/drivers/usb/serial/ftdi_sio_ids.h
    patching file linux-2.6.32/drivers/usb/serial/ftdi_sio.c
    applying patch file make/linux/patches/2.6.32/401-ftdi-working.patch
    applying patch file make/linux/patches/2.6.32/530-scsi_user_space.patch
    patching file linux-2.6.32/include/scsi/scsi.h
    patching file linux-2.6.32/include/scsi/scsi_netlink.h
    applying patch file make/linux/patches/2.6.32/540-export_scsi_headers.patch
    patching file linux-2.6.32/include/scsi/Kbuild
    applying patch file make/linux/patches/2.6.32/710-scall32.patch
    patching file linux-2.6.32/arch/mips/kernel/scall32-o32.S
#Version specific patches
    applying patch file make/linux/patches/2.6.32/7270_05.21/003-pppoatm.c.patch
    patching file linux-2.6.32/net/atm/pppoatm.c
    applying patch file make/linux/patches/2.6.32/7270_05.21/110-hwrev_list.patch
    patching file linux-2.6.32/drivers/net/avm_cpmac/Makefile
    applying patch file make/linux/patches/2.6.32/7270_05.21/200-no_avm_extras.patch
    patching file linux-2.6.32/drivers/block/compcache/Makefile
    patching file linux-2.6.32/drivers/rtc/Makefile
    applying patch file make/linux/patches/2.6.32/7270_05.21/500-fix_7270v1_hw_config.patch
    patching file linux-2.6.32/arch/mips/ur8/avm_hw_config.c
    patching file linux-2.6.32/arch/mips/include/asm/avm_cache.h
    patching file linux-2.6.32/drivers/net/avm_cpmac/cpmac_product_conf.c
    applying patch file make/linux/patches/2.6.32/7270_05.21/690-no_system-load-1_messages.patch
    patching file linux-2.6.32/arch/mips/kernel/process.c
    applying patch file make/linux/patches/2.6.32/7270_05.21/999-cpmac_debug_sk_buff.patch
    patching file linux-2.6.32/drivers/net/avm_cpmac/cpphy_entry.c
 Linking  source/kernel/ref-ur8-7270_05.21/linux-2.6.32/include/linux/new_capi_debug.h
 Linking  source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/dsl/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/kernel/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/kvm/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/lib/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/mm/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/oprofile/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/platforms/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/sysdev/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/powerpc/xmon/-Werror/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/x86/vdso/vdso32-syms.lds/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/arch/x86/vdso/vdso-syms.lds/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/infiniband/hw/amso1100/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/infiniband/ulp/srp/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/mei/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/mtd/nand/avm_nand/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/scsi/cxgb3i/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/scsi/osd/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/drivers/usb/host/whci/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/firmware/dummy/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fs/exofs/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fusiv_src/kernel/drivers/bmedriver/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fusiv_src/kernel/drivers/policyVlan/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/fusiv_src/kernel/drivers/voice/ipvoice/Makefile
 Creating source/kernel/ref-ur8-7270_05.21/linux-2.6.32/source
ln -s linux-2.6.32 source/kernel/ref-ur8-7270_05.21/linux
touch source/kernel/ref-ur8-7270_05.21/.unpacked
if [ ! -e source/.echo_item_start ]; then 	echo -n "---> "; case "" in BIN)	echo -n "package/: " ;; LIB)	echo -n "library/: " ;; TOOL)	echo -n "tool/: " ;; *)	echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n " configuring... ";
 configuring... cp make/linux/Config.ur8.7270_05.21 source/kernel/ref-ur8-7270_05.21/linux-2.6.32/.config
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ur8-7270_05.21/linux-2.6.32 CROSS_COMPILE="mipsel-unknown-linux-gnu-" KERNEL_MAKE_PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" ARCH="mips" INSTALL_HDR_PATH=/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32 INSTALL_MOD_PATH="/run/shm/tmp/freetz-trunk/source/kernel/ref-ur8-7270_05.21" oldconfig
building... make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/kernel/ref-ur8-7270_05.21/linux-2.6.32'
Makefile:197: use: CROSS_COMPILE=mipsel-unknown-linux-gnu-
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/docproc
  HOSTCC  scripts/basic/hash
  HOSTCC  scripts/kconfig/conf.o
scripts/kconfig/conf.c: In Funktion »conf_sym«:
scripts/kconfig/conf.c:162:6: Warnung: Variable »type« gesetzt, aber nicht verwendet [-Wunused-but-set-variable]
scripts/kconfig/conf.c: In Funktion »conf_choice«:
scripts/kconfig/conf.c:234:6: Warnung: Variable »type« gesetzt, aber nicht verwendet [-Wunused-but-set-variable]
  HOSTCC  scripts/kconfig/kxgettext.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/lex.zconf.c
  SHIPPED scripts/kconfig/zconf.hash.c
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -o arch/mips/Kconfig
fusiv_src/kernel/Kconfig:79:warning: defaults for choice values not supported
# configuration written to .config
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/kernel/ref-ur8-7270_05.21/linux-2.6.32'
touch source/kernel/ref-ur8-7270_05.21/.configured
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ur8-7270_05.21/linux-2.6.32 CROSS_COMPILE="mipsel-unknown-linux-gnu-" KERNEL_MAKE_PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" ARCH="mips" INSTALL_HDR_PATH=/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32 INSTALL_MOD_PATH="/run/shm/tmp/freetz-trunk/source/kernel/ref-ur8-7270_05.21" prepare
/run/shm/tmp/freetz-trunk/source/kernel/ref-ur8-7270_05.21/linux-2.6.32/Makefile:197: use: CROSS_COMPILE=mipsel-unknown-linux-gnu-
scripts/kconfig/conf -s arch/mips/Kconfig
  CHK     include/linux/version.h
  UPD     include/linux/version.h
  CHK     include/linux/utsrelease.h
  UPD     include/linux/utsrelease.h
  SYMLINK include/asm -> include/asm-mips
  CC      kernel/bounds.s
  GEN     include/linux/bounds.h
  CC      arch/mips/kernel/asm-offsets.s
  GEN     include/asm/asm-offsets.h
  CALL    scripts/checksyscalls.sh
<stdin>:1655:2: warning: #warning syscall shmget not implemented [-Wcpp]
<stdin>:1659:2: warning: #warning syscall shmat not implemented [-Wcpp]
<stdin>:1663:2: warning: #warning syscall shmctl not implemented [-Wcpp]
<stdin>:1791:2: warning: #warning syscall semget not implemented [-Wcpp]
<stdin>:1795:2: warning: #warning syscall semop not implemented [-Wcpp]
<stdin>:1799:2: warning: #warning syscall semctl not implemented [-Wcpp]
<stdin>:1803:2: warning: #warning syscall shmdt not implemented [-Wcpp]
<stdin>:1807:2: warning: #warning syscall msgget not implemented [-Wcpp]
<stdin>:1811:2: warning: #warning syscall msgsnd not implemented [-Wcpp]
<stdin>:1815:2: warning: #warning syscall msgrcv not implemented [-Wcpp]
<stdin>:1819:2: warning: #warning syscall msgctl not implemented [-Wcpp]
<stdin>:2251:2: warning: #warning syscall reserved177 not implemented [-Wcpp]
<stdin>:2315:2: warning: #warning syscall reserved193 not implemented [-Wcpp]
<stdin>:2399:2: warning: #warning syscall semtimedop not implemented [-Wcpp]
<stdin>:2843:2: warning: #warning syscall shmget not implemented [-Wcpp]
<stdin>:2847:2: warning: #warning syscall shmat not implemented [-Wcpp]
<stdin>:2851:2: warning: #warning syscall shmctl not implemented [-Wcpp]
<stdin>:2979:2: warning: #warning syscall semget not implemented [-Wcpp]
<stdin>:2983:2: warning: #warning syscall semop not implemented [-Wcpp]
<stdin>:2987:2: warning: #warning syscall semctl not implemented [-Wcpp]
<stdin>:2991:2: warning: #warning syscall shmdt not implemented [-Wcpp]
<stdin>:2995:2: warning: #warning syscall msgget not implemented [-Wcpp]
<stdin>:2999:2: warning: #warning syscall msgsnd not implemented [-Wcpp]
<stdin>:3003:2: warning: #warning syscall msgrcv not implemented [-Wcpp]
<stdin>:3007:2: warning: #warning syscall msgctl not implemented [-Wcpp]
<stdin>:3439:2: warning: #warning syscall reserved177 not implemented [-Wcpp]
<stdin>:3503:2: warning: #warning syscall reserved193 not implemented [-Wcpp]
<stdin>:3591:2: warning: #warning syscall semtimedop not implemented [-Wcpp]
touch source/kernel/ref-ur8-7270_05.21/.prepared
--2013-03-18 20:33:36--  http://freetz.wirsind.info/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma
Länge: 8924371 (8,5M) [application/octet-stream]
In »»dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma«« speichern.
100%[===================================================================================================================================>] 8.924.371   1,31M/s   in 6,0s
2013-03-18 20:33:43 (1,41 MB/s) - »»dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma«« gespeichert [8924371/8924371]
Download succeeded - "http://freetz.wirsind.info/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma"  ->  saved to folder "dl"
MD5 verified for dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma: bc1fa16bb96c2460207059539c9bee00
rm -f -r toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1
tools/busybox tar  -xf dl/mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma -C toolchain/build
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/kernel/ref-ur8-7270_05.21/linux-2.6.32 CROSS_COMPILE="mipsel-unknown-linux-gnu-" KERNEL_MAKE_PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" ARCH="mips" INSTALL_HDR_PATH=/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32 INSTALL_MOD_PATH="/run/shm/tmp/freetz-trunk/source/kernel/ref-ur8-7270_05.21" headers_install
  HOSTCC  scripts/unifdef
  INSTALL include/drm (12 files)
  INSTALL include/asm-generic (34 files)
  INSTALL include/linux/byteorder (2 files)
  INSTALL include/linux/can (4 files)
  INSTALL include/linux/dvb (8 files)
  INSTALL include/mtd (5 files)
  INSTALL include/rdma (1 file)
  INSTALL include/linux/hdlc (1 file)
  INSTALL include/linux/isdn (1 file)
  INSTALL include/scsi (6 files)
  INSTALL include/linux/netfilter (58 files)
  INSTALL include/sound (9 files)
  INSTALL include/video (3 files)
  INSTALL include/xen (1 file)
  INSTALL include (0 file)
  INSTALL include/linux/netfilter_arp (2 files)
  INSTALL include/linux/netfilter_bridge (16 files)
  INSTALL include/linux/netfilter_ipv4 (14 files)
  INSTALL include/linux/netfilter_ipv6 (11 files)
  INSTALL include/linux/nfsd (6 files)
  INSTALL include/linux/raid (2 files)
  INSTALL include/linux/spi (1 file)
  INSTALL include/linux/sunrpc (1 file)
  INSTALL include/linux/tc_ematch (4 files)
  INSTALL include/linux/tc_act (6 files)
  INSTALL include/linux/usb (8 files)
  INSTALL include/linux/wimax (1 file)
  INSTALL include/linux (353 files)
  INSTALL include/asm (33 files)
find "/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32" \( -name "..install.cmd" -o -name ".install" \) -exec rm -f \{\} \+
touch /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/linux-dev/2.6.32/include/linux/version.h
touch -c /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libc.a
for i in ld-uClibc-0.9.32.1.so ld-uClibc.so.0 libc.so libc.so.0 libcrypt-0.9.32.1.so libcrypt.so libcrypt.so.0 libdl-0.9.32.1.so libdl.so libdl.so.0 libm-0.9.32.1.so libm.so libm.so.0 libpthread-0.9.32.1.so libpthread.so libpthread.so.0 librt-0.9.32.1.so librt.so librt.so.0 libthread_db-0.9.32.1.so libthread_db.so libthread_db.so.1 libuClibc-0.9.32.1.so libutil-0.9.32.1.so libutil.so libutil.so.0; do \
		cp -a /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/lib/$i packages/target-mipsel_uClibc-0.9.32.1/root/lib/$i; \
	done
ln -sf libuClibc-0.9.32.1.so packages/target-mipsel_uClibc-0.9.32.1/root/lib/libc.so
touch -c packages/target-mipsel_uClibc-0.9.32.1/root/lib/libc.so.0
if [ ! -e source/.echo_item_start ]; then 	echo -n "---> "; case "LIB" in BIN)	echo -n "package/uclibcxx: " ;; LIB)	echo -n "library/uclibcxx: " ;; TOOL)	echo -n "tool/uclibcxx: " ;; *)	echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
downloading...
--2013-03-18 20:33:48--  http://git.uclibc.org/uClibc++/snapshot/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2
Auflösen des Hostnamen »git.uclibc.org (git.uclibc.org)«... 140.211.167.224
Verbindungsaufbau zu git.uclibc.org (git.uclibc.org)|140.211.167.224|:80... verbunden.
Länge: 257792 (252K) [application/x-bzip2]
In »»dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2«« speichern.
100%[===================================================================================================================================>] 257.792      261K/s   in 1,0s
2013-03-18 20:33:50 (261 KB/s) - »»dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2«« gespeichert [257792/257792]
Download succeeded - "http://git.uclibc.org/uClibc++/snapshot/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2: 838aa335ef7f2fcf7191e82d375d0178
preparing... tools/bunzip2 -c dl/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2 | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/libs/uclibcxx/patches/*.uclibcxx.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30 $i; done
    applying patch file make/libs/uclibcxx/patches/009-compile_fixes.uclibcxx.patch
    patching file include/associative_base
    patching file include/string
    patching file src/string.cpp
    applying patch file make/libs/uclibcxx/patches/010-bitset_fix.uclibcxx.patch
    patching file include/bitset
    applying patch file make/libs/uclibcxx/patches/010-fpos_not_equal_fix.uclibcxx.patch
    patching file include/ios
    applying patch file make/libs/uclibcxx/patches/020-avoid_not_equal.uclibcxx.patch
    patching file include/algorithm
    patching file include/set
    applying patch file make/libs/uclibcxx/patches/030-istream_long_long_support.uclibcxx.patch
    patching file include/istream
    patching file include/istream_helpers
    applying patch file make/libs/uclibcxx/patches/040-iostream_wchar_support.uclibcxx.patch
    patching file include/ostream
    applying patch file make/libs/uclibcxx/patches/050-gcc47x-proper-two-phase-lookup.uclibcxx.patch
    patching file include/fstream
    applying patch file make/libs/uclibcxx/patches/300-wrapper.uclibcxx.patch
    patching file bin/Makefile
    applying patch file make/libs/uclibcxx/patches/400-eabi_fix.uclibcxx.patch
    patching file include/typeinfo
    patching file include/unwind-cxx.h
    applying patch file make/libs/uclibcxx/patches/900-dependent_exception.uclibcxx.patch
    patching file src/eh_alloc.cpp
cp make/libs/uclibcxx/Config.uclibc++ source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/.config
sed -i -r -e 's%^(# )?(UCLIBCXX_HAS_LFS)[ =].*%\2=y%g' -e 's%^(# )?(UCLIBCXX_HAS_WCHAR)[ =].*%# \2 is not set%g' -e 's%^(# )?(UCLIBCXX_SUPPORT_WCIN)[ =].*%# \2 is not set%g' -e 's%^(# )?(UCLIBCXX_SUPPORT_WCOUT)[ =].*%# \2 is not set%g' -e 's%^(# )?(UCLIBCXX_SUPPORT_WCERR)[ =].*%# \2 is not set%g' source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/.config
touch source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/.configured
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30 \
		CPU_CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" \
		CROSS="mipsel-linux-uclibc-" \
		all
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/extra/config'
make[2]: Warnung: Kein Jobserver verfügbar: -j1 wird gesetzt. »+« zur Ursprungsregel
hinzufügen.
cp zconf.tab.h_shipped zconf.tab.h
gcc -O2 -Wall -I. -c conf.c -o conf.o
conf.c: In Funktion »conf_string«:
conf.c:163:20: Warnung: Variable »help« gesetzt, aber nicht verwendet [-Wunused-but-set-variable]
conf.c:197:6: Warnung: Variable »type« gesetzt, aber nicht verwendet [-Wunused-but-set-variable]
conf.c:272:6: Warnung: Variable »type« gesetzt, aber nicht verwendet [-Wunused-but-set-variable]
conf.c:349:9: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
conf.c: In Funktion »conf_askvalue«:
conf.c:93:8: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
cp zconf.tab.c_shipped zconf.tab.c
cp lex.zconf.c_shipped lex.zconf.c
gcc -O2 -Wall -I. -c zconf.tab.c -o zconf.tab.o
lex.zconf.c:2969:16: Warnung: »input« definiert, aber nicht verwendet [-Wunused-function]
gcc  conf.o zconf.tab.o -o conf
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/extra/config'
# using defaults found in .config
* uClibc++ Configuration
* Target Features and Options
Enable floating point number support (UCLIBCXX_HAS_FLOATS) [Y/n/?] y
  Math operations with long double (UCLIBCXX_HAS_LONG_DOUBLE) [N/y/?] n
Toolchain supports Thread-Local Storage (UCLIBCXX_HAS_TLS) [N/y/?] n
Compiler Warnings (WARNINGS) []
Extra Library Link Flags (BUILD_EXTRA_LIBRARIES) []
* String and I/O Stream Support
Wide Character Support (Not Currently Supported) (UCLIBCXX_HAS_WCHAR) [N/y/?] n
I/O stream buffer size (UCLIBCXX_IOSTREAM_BUFSIZE) [32] 32
Large File Support (UCLIBCXX_HAS_LFS) [Y/n/?] y
Enable support for standard streams like cin and cout (UCLIBCXX_SUPPORT_CDIR) [Y/n/?] y
  Enable cin (UCLIBCXX_SUPPORT_CIN) [Y/n/?] y
  Enable cout (UCLIBCXX_SUPPORT_COUT) [Y/n/?] y
  Enable cerr (UCLIBCXX_SUPPORT_CERR) [Y/n/?] y
  Enable clog (UCLIBCXX_SUPPORT_CLOG) [N/y/?] n
* STL and Code Expansion
STL buffer size (UCLIBCXX_STL_BUFFER_SIZE) [32] 32
Template code expansion (UCLIBCXX_CODE_EXPANSION) [Y/n/?] y
  Expand constructors and destructors (UCLIBCXX_EXPAND_CONSTRUCTORS_DESTRUCTORS) [N/y/?] n
  Expand std::basic_string for <char> (UCLIBCXX_EXPAND_STRING_CHAR) [Y/n/?] y
  Expand std::vector for basic data types (UCLIBCXX_EXPAND_VECTOR_BASIC) [Y/n/?] y
  Expand ios core code for char (UCLIBCXX_EXPAND_IOS_CHAR) [N/y/?] n
  Expand std::streambuf for char (UCLIBCXX_EXPAND_STREAMBUF_CHAR) [N/y/?] n
  Expand std::istream for <char> (UCLIBCXX_EXPAND_ISTREAM_CHAR) [Y/n/?] y
  Expand std::ostream for <char> (UCLIBCXX_EXPAND_OSTREAM_CHAR) [Y/n/?] y
  Expand std::fstream for <char> (UCLIBCXX_EXPAND_FSTREAM_CHAR) [Y/n/?] y
  Expand std::sstream for <char> (UCLIBCXX_EXPAND_SSTREAM_CHAR) [N/y/?] n
* Library Installation Options
uClibc++ runtime prefix directory (UCLIBCXX_RUNTIME_PREFIX) []
uClibc++ header file subdirectory (UCLIBCXX_RUNTIME_INCLUDE_SUBDIR) [/include/uClibc++] /include/uClibc++
uClibc++ library subdirectory (UCLIBCXX_RUNTIME_LIB_SUBDIR) [/lib] /lib
uClibc++ application file subdirectory (UCLIBCXX_RUNTIME_BIN_SUBDIR) [/bin] /bin
Exception and RTTI support (UCLIBCXX_EXCEPTION_SUPPORT) [Y/n/?] y
  Import libsupc++.a (IMPORT_LIBSUP) [Y/n/?] y
  Import libgcc_eh.a (IMPORT_LIBGCC_EH) [N/y/?] n
Build static library (BUILD_STATIC_LIB) [Y/n/?] y
  Build only static library (BUILD_ONLY_STATIC_LIB) [N/y/?] n
Build uClibc++ with debugging symbols (DODEBUG) [N/y/?] n
for dir in bin include src ; do \
		make -C $dir all; \
	done
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/bin'
echo "#!/bin/sh" > g++-uc
echo "" >> g++-uc
echo 'WRAPPER_INCLUDEDIR="${WRAPPER_INCLUDEDIR:=-I/include/uClibc++/}"' >> g++-uc
echo 'WRAPPER_LIBDIR="${WRAPPER_LIBDIR:=-L/lib/}"' >> g++-uc
echo "" >> g++-uc
echo "WRAPPER_LIBS=\" -L/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/ -lc -lgcc -Wl,--as-needed -lgcc_s -Wl,--no-as-needed\"" >> g++-uc
echo "" >> g++-uc
echo 'WRAPPER_INCLIB=$(echo " $@ " | sed -ne "s/.* -\([cES]\|MF\) .*/NO/p;t;aYES")' >> g++-uc
echo 'WRAPPER_STATIC=$(echo " $@ " | sed -ne "s/.* -static .*/YES/p;t;aNO")' >> g++-uc
echo 'if [ "$WRAPPER_STATIC" = "YES" ]' >> g++-uc
echo 'then' >> g++-uc
echo "	WRAPPER_LIBS=\"-Wl,--start-group  -L/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/ -lc -lgcc -lgcc_eh -Wl,--end-group\"" >> g++-uc
echo 'fi' >> g++-uc
echo 'if [ "$WRAPPER_INCLIB" = "YES" ]' >> g++-uc
echo '	exec mipsel-linux-uclibc-g++ -fno-builtin -nostdinc++ -DGCC_HASCLASSVISIBILITY  $WRAPPER_INCLUDEDIR "$@" -nodefaultlibs $WRAPPER_LIBDIR -luClibc++ $WRAPPER_LIBS' >> g++-uc
echo 'fi' >> g++-uc
echo "" >> g++-uc
echo 'exec mipsel-linux-uclibc-g++ -fno-builtin -nostdinc++ -DGCC_HASCLASSVISIBILITY  $WRAPPER_INCLUDEDIR "$@"' >> g++-uc
chmod 755 g++-uc
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/bin'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/include'
make[2]: Für das Ziel »all« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/include'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src'
make -C abi/libsupc all
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o algorithm.o -c algorithm.cpp
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src/abi/libsupc'
mipsel-linux-uclibc-ar x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/../../../../mipsel-linux-uclibc/lib/libsupc++.a
rm -f -f new_op*.o del_op*.o pure.o new_handler.o eh_alloc.o eh_globals.o
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src/abi/libsupc'
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o associative_base.o -c associative_base.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment algorithm.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o bitset.o -c bitset.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment associative_base.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o char_traits.o -c char_traits.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment char_traits.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o complex.o -c complex.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment bitset.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_op.o -c del_op.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_op.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_opnt.o -c del_opnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_opnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_opv.o -c del_opv.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_opv.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o del_opvnt.o -c del_opvnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment del_opvnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o deque.o -c deque.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment complex.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o eh_alloc.o -c eh_alloc.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment deque.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o eh_globals.o -c eh_globals.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment eh_globals.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o exception.o -c exception.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment exception.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o fstream.o -c fstream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment eh_alloc.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o func_exception.o -c func_exception.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment func_exception.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o iomanip.o -c iomanip.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment iomanip.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o ios.o -c ios.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment fstream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o iostream.o -c iostream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment ios.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o istream.o -c istream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment iostream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o iterator.o -c iterator.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment iterator.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o limits.o -c limits.cpp
In file included from limits.cpp:20:0:
../include/limits:24:2: warning: #warning is a GCC extension [enabled by default]
../include/limits:24:2: warning: #warning limits header is nowhere complete or accurate [-Wcpp]
mipsel-linux-uclibc-strip -x -R .note -R .comment limits.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o list.o -c list.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment list.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o locale.o -c locale.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment locale.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o map.o -c map.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment istream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_handler.o -c new_handler.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_handler.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_op.o -c new_op.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_op.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_opnt.o -c new_opnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment map.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_opv.o -c new_opv.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_opnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o new_opvnt.o -c new_opvnt.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_opv.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o numeric.o -c numeric.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment new_opvnt.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o ostream.o -c ostream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment numeric.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o queue.o -c queue.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment queue.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o set.o -c set.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment set.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o sstream.o -c sstream.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment ostream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o stack.o -c stack.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment stack.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o stdexcept.o -c stdexcept.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment stdexcept.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o streambuf.o -c streambuf.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment streambuf.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o string.o -c string.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment sstream.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o utility.o -c utility.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment utility.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o valarray.o -c valarray.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment valarray.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o vector.o -c vector.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment vector.o
WRAPPER_INCLUDEDIR=-I../include ../bin/g++-uc   -Wno-trigraphs -pedantic -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -ansi  -Os -fPIC -o abi/abi.o -c abi/abi.cpp
mipsel-linux-uclibc-strip -x -R .note -R .comment abi/abi.o
mipsel-linux-uclibc-strip -x -R .note -R .comment string.o
mipsel-linux-uclibc-ar rcs libuClibc++.a algorithm.o associative_base.o bitset.o char_traits.o complex.o del_op.o del_opnt.o del_opv.o del_opvnt.o deque.o eh_alloc.o eh_globals.o exception.o fstream.o func_exception.o iomanip.o ios.o iostream.o istream.o iterator.o limits.o list.o locale.o map.o new_handler.o new_op.o new_opnt.o new_opv.o new_opvnt.o numeric.o ostream.o queue.o set.o sstream.o stack.o stdexcept.o streambuf.o string.o utility.o valarray.o vector.o abi/abi.o  abi/libsupc/array_type_info.o abi/libsupc/atexit_arm.o abi/libsupc/bad_alloc.o abi/libsupc/bad_cast.o abi/libsupc/bad_typeid.o abi/libsupc/class_type_info.o abi/libsupc/cp-demangle.o abi/libsupc/dyncast.o abi/libsupc/eh_arm.o abi/libsupc/eh_aux_runtime.o abi/libsupc/eh_call.o abi/libsupc/eh_catch.o abi/libsupc/eh_exception.o abi/libsupc/eh_personality.o abi/libsupc/eh_ptr.o abi/libsupc/eh_term_handler.o abi/libsupc/eh_terminate.o abi/libsupc/eh_throw.o abi/libsupc/eh_type.o abi/libsupc/eh_unex_handler.o abi/libsupc/enum_type_info.o abi/libsupc/function_type_info.o abi/libsupc/fundamental_type_info.o abi/libsupc/guard_error.o abi/libsupc/guard.o abi/libsupc/hash_bytes.o abi/libsupc/nested_exception.o abi/libsupc/pbase_type_info.o abi/libsupc/pmem_type_info.o abi/libsupc/pointer_type_info.o abi/libsupc/si_class_type_info.o abi/libsupc/tinfo2.o abi/libsupc/tinfo.o abi/libsupc/vec.o abi/libsupc/vmi_class_type_info.o abi/libsupc/vterminate.o
mipsel-linux-uclibc-gcc -Wl,--warn-common -Wl,--warn-once -Wl,-z,combreloc -Wl,-z,defs -nodefaultlibs -shared -Wl,-soname,libuClibc++.so.0 `echo ""` -Wl,-s -o libuClibc++-0.2.3.so algorithm.o associative_base.o bitset.o char_traits.o complex.o del_op.o del_opnt.o del_opv.o del_opvnt.o deque.o eh_alloc.o eh_globals.o exception.o fstream.o func_exception.o iomanip.o ios.o iostream.o istream.o iterator.o limits.o list.o locale.o map.o new_handler.o new_op.o new_opnt.o new_opv.o new_opvnt.o numeric.o ostream.o queue.o set.o sstream.o stack.o stdexcept.o streambuf.o string.o utility.o valarray.o vector.o abi/abi.o abi/libsupc/array_type_info.o abi/libsupc/atexit_arm.o abi/libsupc/bad_alloc.o abi/libsupc/bad_cast.o abi/libsupc/bad_typeid.o abi/libsupc/class_type_info.o abi/libsupc/cp-demangle.o abi/libsupc/dyncast.o abi/libsupc/eh_arm.o abi/libsupc/eh_aux_runtime.o abi/libsupc/eh_call.o abi/libsupc/eh_catch.o abi/libsupc/eh_exception.o abi/libsupc/eh_personality.o abi/libsupc/eh_ptr.o abi/libsupc/eh_term_handler.o abi/libsupc/eh_terminate.o abi/libsupc/eh_throw.o abi/libsupc/eh_type.o abi/libsupc/eh_unex_handler.o abi/libsupc/enum_type_info.o abi/libsupc/function_type_info.o abi/libsupc/fundamental_type_info.o abi/libsupc/guard_error.o abi/libsupc/guard.o abi/libsupc/hash_bytes.o abi/libsupc/nested_exception.o abi/libsupc/pbase_type_info.o abi/libsupc/pmem_type_info.o abi/libsupc/pointer_type_info.o abi/libsupc/si_class_type_info.o abi/libsupc/tinfo2.o abi/libsupc/tinfo.o abi/libsupc/vec.o abi/libsupc/vmi_class_type_info.o abi/libsupc/vterminate.o   -L/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/gcc/mipsel-linux-uclibc/4.6.3/ -lc -lgcc -Wl,--as-needed -lgcc_s -Wl,--no-as-needed
mipsel-linux-uclibc-ranlib libuClibc++.a
ln -s -f libuClibc++-0.2.3.so libuClibc++.so.0
ln -s -f libuClibc++.so.0 libuClibc++.so
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30/src'
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30'
		DESTDIR="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr" \
		install
		make -C $dir install; \
	done
install -d /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/
install -m 755 g++-uc /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/
install -d /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include/uClibc++/
install -m 644 algorithm associative_base basic_definitions bitset cassert cctype cerrno cfloat char_traits climits clocale cmath complex csetjmp csignal cstdarg cstddef cstdio cstdlib cstring ctime cwchar cwctype deque exception fstream func_exception functional iomanip ios iosfwd iostream istream istream_helpers iterator iterator_base limits list locale map memory new numeric ostream ostream_helpers queue set sstream stack stdexcept streambuf string string_iostream support system_configuration.h typeinfo type_traits unwind-cxx.h utility valarray vector /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include/uClibc++/
install -d /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/
install -m 755 libuClibc++-0.2.3.so \
cp -fa libuClibc++.so.0 libuClibc++.so /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/
install -m 644 libuClibc++.a /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/
sed -i -e 's|-I/include/uClibc++|-I/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/include/uClibc++|g' /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/g++-uc
sed -i -e 's|-L/lib/|-L/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/|g' /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/g++-uc
mv	/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/g++-uc \
		/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/mipsel-linux-uclibc-g++-uc
ln -sf mipsel-linux-uclibc-g++-uc /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/bin/mipsel-linux-g++-uc
if [ ! -e source/.echo_item_start ]; then 	echo -n "---> "; case "LIB" in BIN)	echo -n "package/libtool: " ;; LIB)	echo -n "library/libtool: " ;; TOOL)	echo -n "tool/libtool: " ;; *)	echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
downloading...
--2013-03-18 20:33:59--  http://ftpmirror.gnu.org/libtool/libtool-1.5.26.tar.gz
Auflösen des Hostnamen »ftpmirror.gnu.org (ftpmirror.gnu.org)«... 140.186.70.73
Verbindungsaufbau zu ftpmirror.gnu.org (ftpmirror.gnu.org)|140.186.70.73|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 302 Found
Platz: http://www.artfiles.org/gnu.org/libtool/libtool-1.5.26.tar.gz [folge]
--2013-03-18 20:33:59--  http://www.artfiles.org/gnu.org/libtool/libtool-1.5.26.tar.gz
Auflösen des Hostnamen »www.artfiles.org (www.artfiles.org)«... 80.252.110.38
Verbindungsaufbau zu www.artfiles.org (www.artfiles.org)|80.252.110.38|:80... verbunden.
Länge: 2961939 (2,8M) [application/x-gzip]
In »»dl/libtool-1.5.26.tar.gz«« speichern.
100%[===================================================================================================================================>] 2.961.939   1,32M/s   in 2,1s
2013-03-18 20:34:02 (1,32 MB/s) - »»dl/libtool-1.5.26.tar.gz«« gespeichert [2961939/2961939]
Download succeeded - "http://ftpmirror.gnu.org/libtool/libtool-1.5.26.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/libtool-1.5.26.tar.gz: aa9c5107f3ec9ef4200eb6556f3b3c29
rm -f -r /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26
mkdir -p /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26
tar -C /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1  -xf dl/libtool-1.5.26.tar.gz
for i in toolchain/make/target/libtool-host/patches/*.patch; do \
		tools/freetz_patch /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26 $i; \
	done
    applying patch file toolchain/make/target/libtool-host/patches/001-force_dlopen_deplibs.libtool.patch
    patching file ltdl.m4
    patching file libltdl/acinclude.m4
    patching file libltdl/configure
    applying patch file toolchain/make/target/libtool-host/patches/100-libdir_path.libtool.patch
    patching file Makefile.in
    patching file ltmain.in
    patching file Makefile.am
    applying patch file toolchain/make/target/libtool-host/patches/110-no_rpath.libtool.patch
    patching file acinclude.m4
    patching file cdemo/acinclude.m4
    patching file cdemo/configure
    patching file configure
    patching file demo/acinclude.m4
    patching file demo/configure
    patching file depdemo/acinclude.m4
    patching file depdemo/configure
    patching file f77demo/acinclude.m4
    patching file f77demo/configure
    patching file libtool.m4
    patching file mdemo/acinclude.m4
    patching file mdemo/configure
    patching file mdemo2/acinclude.m4
    patching file mdemo2/configure
    patching file pdemo/acinclude.m4
    patching file pdemo/configure
    patching file tagdemo/acinclude.m4
    patching file tagdemo/configure
    applying patch file toolchain/make/target/libtool-host/patches/120-libdir_search.libtool.patch
    applying patch file toolchain/make/target/libtool-host/patches/130-no_recheck.libtool.patch
    patching file libltdl/Makefile.am
    patching file libltdl/Makefile.in
    applying patch file toolchain/make/target/libtool-host/patches/200-package-specific-dlerror-test.libtool.patch
for i in $(find /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26 -type f \( \( -name "*.m4" -o -name "*.am" \) -a ! -name "aclocal.m4" \)); do \
		touch -t 200001010000.00 $i; \
	done; \
	touch /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/.unpacked
(cd /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26; rm -rf config.cache; \
		CC=/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc \
		CXX=/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper \
		PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" \
		./configure \
		--build=x86_64-pc-linux-gnu \
		--host=mipsel-linux-uclibc \
		--target=mipsel-linux-uclibc \
		--prefix=/usr \
		--disable-ltdl-install \
		--enable-shared \
		--enable-static \
		--disable-nls \
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for mipsel-linux-uclibc-strip... mipsel-linux-uclibc-strip
checking for mipsel-linux-uclibc-gcc... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... yes
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc accepts -g... yes
checking for /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... none
checking for a sed that does not truncate output... /bin/sed
checking build system type... x86_64-pc-linux-gnu
checking host system type... mipsel-unknown-linux-uclibc
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ld used by /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking if the linker (/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld... yes
checking for BSD-compatible nm... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-nm -B
checking whether ln -s works... yes
checking whether we are using the GNU C++ compiler... yes
checking whether /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper accepts -g... yes
checking dependency style of /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper... none
checking for mipsel-linux-uclibc-g77... no
checking for mipsel-linux-uclibc-xlf... no
checking for mipsel-linux-uclibc-f77... no
checking for mipsel-linux-uclibc-frt... no
checking for mipsel-linux-uclibc-pgf77... no
checking for mipsel-linux-uclibc-cf77... no
checking for mipsel-linux-uclibc-fort77... no
checking for mipsel-linux-uclibc-fl32... no
checking for mipsel-linux-uclibc-af77... no
checking for mipsel-linux-uclibc-xlf90... no
checking for mipsel-linux-uclibc-f90... no
checking for mipsel-linux-uclibc-pgf90... no
checking for mipsel-linux-uclibc-pghpf... no
checking for mipsel-linux-uclibc-epcf90... no
checking for mipsel-linux-uclibc-gfortran... no
checking for mipsel-linux-uclibc-g95... no
checking for mipsel-linux-uclibc-xlf95... no
checking for mipsel-linux-uclibc-f95... no
checking for mipsel-linux-uclibc-fort... no
checking for mipsel-linux-uclibc-ifort... no
checking for mipsel-linux-uclibc-ifc... no
checking for mipsel-linux-uclibc-efc... no
checking for mipsel-linux-uclibc-pgf95... no
checking for mipsel-linux-uclibc-lf95... no
checking for mipsel-linux-uclibc-ftn... no
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking for mipsel-linux-uclibc-gcj... no
checking for gcj... no
checking for mipsel-linux-uclibc-windres... no
checking for windres... no
checking for /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld option to reload object files... -r
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking how to run the C++ preprocessor... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper -E
checking the maximum length of command line arguments... 3458764513820540925
checking command to parse /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-nm -B output from /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc object... ok
checking for objdir... .libs
checking for mipsel-linux-uclibc-ar... mipsel-linux-uclibc-ar
checking for mipsel-linux-uclibc-ranlib... mipsel-linux-uclibc-ranlib
checking for mipsel-linux-uclibc-strip... (cached) mipsel-linux-uclibc-strip
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc supports -fno-rtti -fno-exceptions... no
checking for /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc option to produce PIC... -fPIC
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc PIC flag -fPIC works... yes
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc static flag -static works... yes
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc supports -c -o file.o... yes
checking whether the /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc linker (/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... cross
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking whether the /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper linker (/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking for /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper option to produce PIC... -fPIC
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper PIC flag -fPIC works... yes
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper static flag -static works... yes
checking if /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper supports -c -o file.o... yes
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
appending configuration tag "GCJ" to libtool
configure: creating ./config.status
config.status: creating Makefile
config.status: creating doc/Makefile
config.status: creating tests/Makefile
config.status: executing depfiles commands
=== configuring in libltdl (/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl)
configure: running /bin/bash ./configure '--prefix=/usr'  '--build=x86_64-pc-linux-gnu' '--host=mipsel-linux-uclibc' '--target=mipsel-linux-uclibc' '--disable-ltdl-install' '--enable-shared' '--enable-static' '--disable-nls' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=mipsel-linux-uclibc' 'target_alias=mipsel-linux-uclibc' 'CC=/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc' 'CFLAGS=-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64' 'CXX=/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper' --cache-file=/dev/null --srcdir=.
checking for an ANSI C-conforming const... yes
checking for inline... inline
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking which extension is used for loadable modules... .so
checking which variable specifies run-time library path... LD_LIBRARY_PATH
checking for the default library search path... /lib /usr/lib /usr/lib/i386-linux-gnu/mesa /lib/i386-linux-gnu /usr/lib/i386-linux-gnu /lib/i686-linux-gnu /usr/lib/i686-linux-gnu /usr/local/lib /lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu /usr/lib/x86_64-linux-gnu/mesa /lib32 /usr/lib32
checking whether libtool supports -dlopen/-dlpreopen... yes
checking for dlerror... yes
checking for _ prefix in compiled symbols... no
checking whether deplibs are loaded by dlopen... yes
checking argz.h usability... no
checking argz.h presence... no
checking for argz.h... no
checking for error_t... no
checking for argz_append... no
checking for argz_create_sep... no
checking for argz_insert... no
checking for argz_next... no
checking for argz_stringify... no
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for memory.h... (cached) yes
checking for stdlib.h... (cached) yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for unistd.h... (cached) yes
checking dl.h usability... no
checking dl.h presence... no
checking for dl.h... no
checking sys/dl.h usability... no
checking sys/dl.h presence... no
checking for sys/dl.h... no
checking dld.h usability... no
checking dld.h presence... no
checking for dld.h... no
checking mach-o/dyld.h usability... no
checking mach-o/dyld.h presence... no
checking for mach-o/dyld.h... no
checking for string.h... (cached) yes
checking for strchr... yes
checking for strrchr... yes
checking for memcpy... yes
checking for memmove... yes
checking for strcmp... yes
checking for closedir... yes
checking for opendir... yes
checking for readdir... yes
config.status: creating config.h
touch /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/.configured
		make -j2 -C /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26 \
		GLOBAL_LIBDIR=/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib \
		all
make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
Making all in .
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
rm -f ltmain.shT
CONFIG_FILES=libtoolize CONFIG_HEADERS= /bin/bash ./config.status
date=`/bin/bash ./mkstamp < ./ChangeLog` && \
	sed -e 's/@''PACKAGE@/libtool/' -e 's/@''VERSION@/1.5.26/' \
		-e 's#@''GLOBAL_LIBDIR@#/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib#' \
	    -e "s%@""TIMESTAMP@%$date%" ./ltmain.in > ltmain.shT
mv -f ltmain.shT ltmain.sh || \
	(rm -f ltmain.sh && cp ltmain.shT ltmain.sh && rm -f ltmain.shT)
cp ltmain.sh ./libltdl/
chmod +x libtool
config.status: creating libtoolize
chmod +x libtoolize
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
Making all in libltdl
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
make  all-am
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libltdl'
Making all in doc
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
Updating ./version.texi
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
Making all in tests
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
touch -c /run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/libtool
make -j2 DESTDIR="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr" \
		MAKEINFO=true \
		install
Making install in .
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
test -z "/usr/bin" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/bin"
test -z "/usr/share/aclocal" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/aclocal"
 /usr/bin/install -c 'libtool' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/bin/libtool'
 /usr/bin/install -c -m 644 'libtool.m4' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/aclocal/libtool.m4'
 /usr/bin/install -c 'libtoolize' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/bin/libtoolize'
 /usr/bin/install -c -m 644 'ltdl.m4' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/aclocal/ltdl.m4'
test -z "/usr/share/libtool/libltdl" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl"
test -z "/usr/share/libtool" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool"
 /usr/bin/install -c -m 644 'libltdl/COPYING.LIB' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/COPYING.LIB'
 /usr/bin/install -c -m 644 'config.guess' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.guess'
 /usr/bin/install -c -m 644 'libltdl/README' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/README'
 /usr/bin/install -c -m 644 'config.sub' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.sub'
 /usr/bin/install -c -m 644 'libltdl/configure.ac' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/configure.ac'
 /usr/bin/install -c -m 644 'install-sh' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/install-sh'
 /usr/bin/install -c -m 644 'libltdl/Makefile.am' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/Makefile.am'
 /usr/bin/install -c -m 644 'ltmain.sh' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/ltmain.sh'
 /usr/bin/install -c -m 644 'libltdl/ltdl.c' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/ltdl.c'
 /usr/bin/install -c -m 644 'libltdl/ltdl.h' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/ltdl.h'
 /usr/bin/install -c -m 644 'libltdl/config.guess' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.guess'
 /usr/bin/install -c -m 644 'libltdl/config.sub' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.sub'
 /usr/bin/install -c -m 644 'libltdl/install-sh' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/install-sh'
 /usr/bin/install -c -m 644 'libltdl/missing' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/missing'
 /usr/bin/install -c -m 644 'libltdl/ltmain.sh' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/ltmain.sh'
 /usr/bin/install -c -m 644 'libltdl/acinclude.m4' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/acinclude.m4'
 /usr/bin/install -c -m 644 'libltdl/aclocal.m4' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/aclocal.m4'
 /usr/bin/install -c -m 644 'libltdl/Makefile.in' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/Makefile.in'
 /usr/bin/install -c -m 644 'libltdl/configure' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/configure'
 /usr/bin/install -c -m 644 'libltdl/config-h.in' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config-h.in'
make  install-data-hook
make[4]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.guess
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/config.sub
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/install-sh
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.guess
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/config.sub
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/install-sh
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/configure
chmod +x /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/libtool/libltdl/missing
make[4]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26'
Making install in libltdl
test -z "/usr/lib" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/lib"
test -z "/usr/include" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/include"
Making install in doc
restore=: && backupdir=".am$$" && \
	am__cwd=`pwd` && cd . && \
	rm -rf $backupdir && mkdir $backupdir && \
	if (true --version) >/dev/null 2>&1; then \
	  for f in libtool.info libtool.info-[0-9] libtool.info-[0-9][0-9] libtool.i[0-9] libtool.i[0-9][0-9]; do \
	    if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
	  done; \
	else :; fi && \
	cd "$am__cwd"; \
	if true   -I . \
	 -o libtool.info libtool.texi; \
	then \
	  rc=0; \
	  cd .; \
	else \
	  rc=$?; \
	  cd . && \
	  $restore $backupdir/* `echo "./libtool.info" | sed 's|[^/]*$||'`; \
	fi; \
	rm -rf $backupdir; exit $rc
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
make[3]: Für das Ziel »install-exec-am« ist nichts zu tun.
	  done; \
	else :; fi && \
	cd "$am__cwd"; \
	if true   -I . \
	then \
	  rc=0; \
	  cd .; \
	else \
	  rc=$?; \
	  cd . && \
	fi; \
test -z "/usr/share/info" || /bin/mkdir -p "/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info"
 install-info --info-dir='/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info' '/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info/libtool.info'
This is not dpkg install-info anymore, but GNU install-info
See the man page for ginstall-info for command line arguments
install-info: Datei oder Verzeichnis nicht gefunden für /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/usr/share/info/libtool.info
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/doc'
Making install in tests
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
make[3]: Für das Ziel »install-data-am« ist nichts zu tun.
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/toolchain-mipsel_gcc-4.6.3_uClibc-0.9.32.1/libtool-1.5.26/tests'
rm -f -r /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/info /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/man /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/doc /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/locale /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/info /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/man /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/doc /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/locale /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/info /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/man /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/doc /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/share/locale /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/info /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/man /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/doc /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/share/locale
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/root/usr/lib/freetz/root
if test -d make/libs/libctlmgr/files; then tar -c -C make/libs/libctlmgr/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/root/usr/lib/freetz ; fi
---> library/libctlmgr: preparing... mkdir -p source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6
cp -a make/libs/libctlmgr/src/libctlmgr.c make/libs/libctlmgr/src/Makefile source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6 \
		CC="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" \
		LIB_VERSION="0.6" \
		all
building... make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6'
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -fPIC -D_GNU_SOURCE  -c -o libctlmgr.o libctlmgr.c
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -shared -ldl -o libctlmgr.so.0.6 libctlmgr.o
ln -sf libctlmgr.so.0.6 libctlmgr.so
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6'
chmod 755 source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6/libctlmgr.so.0.6; mkdir -p packages/target-mipsel_uClibc-0.9.32.1/root/lib/; cp -a source/target-mipsel_uClibc-0.9.32.1/libctlmgr-0.6/libctlmgr.so* packages/target-mipsel_uClibc-0.9.32.1/root/lib/; /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/root/lib/libctlmgr.so.0.6;
done.
chmod 755 /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libgcc_s.so.1; mkdir -p packages/target-mipsel_uClibc-0.9.32.1/root/lib/; cp -a /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib/libgcc_s.so* packages/target-mipsel_uClibc-0.9.32.1/root/lib/; /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/root/lib/libgcc_s.so.1;
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/busybox/root
if test -d make/busybox/files; then tar -c -C make/busybox/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/busybox ; fi
---> package/busybox: preparing... tools/bunzip2 -c dl/busybox-1.21.0.tar.bz2 | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/busybox/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0 $i; done
    applying patch file make/busybox/patches/000-busybox-1.21.0-mdev.patch
    patching file util-linux/mdev.c
    applying patch file make/busybox/patches/000-busybox-1.21.0-platform.patch
    patching file archival/libarchive/decompress_unxz.c
    patching file include/platform.h
    applying patch file make/busybox/patches/000-busybox-1.21.0-xz.patch
    applying patch file make/busybox/patches/100-autoconf.patch
    patching file applets/Kbuild.src
    applying patch file make/busybox/patches/101-init_avoid_loop_opening_tty.patch
    patching file init/init.c
    applying patch file make/busybox/patches/110-busybox-nolock-as-default.patch
    patching file util-linux/mount.c
    applying patch file make/busybox/patches/110-wget_getopt_fix.patch
    patching file networking/wget.c
    applying patch file make/busybox/patches/130-scripts_bash.patch
    patching file scripts/trylink
    patching file scripts/gen_build_files.sh
    applying patch file make/busybox/patches/210-telnet-close-on-exit.patch
    patching file networking/telnetd.c
    applying patch file make/busybox/patches/220-httpd-pidfile.patch
    patching file networking/httpd.c
    applying patch file make/busybox/patches/320-mdev_scan_file.patch
    applying patch file make/busybox/patches/350-httpd_redir.patch
    applying patch file make/busybox/patches/440-httpd_chdir.patch
    applying patch file make/busybox/patches/450-httpd_REDIRECT_STATUS.patch
    applying patch file make/busybox/patches/470-insmod_search.patch
    patching file modutils/insmod.c
    patching file modutils/Config.src
    applying patch file make/busybox/patches/480-copy_file_dev_node_fix.patch
    patching file libbb/copy_file.c
    applying patch file make/busybox/patches/503-id_getgrouplist.patch
    patching file coreutils/id.c
    applying patch file make/busybox/patches/602-telnetd_intr.patch
    applying patch file make/busybox/patches/604-httpdstar.patch
    patching file libbb/appletlib.c
    applying patch file make/busybox/patches/605-blkid_mtdworkaround.patch
    patching file util-linux/volume_id/get_devname.c
    applying patch file make/busybox/patches/615-blkid_bogus_device_handling.patch
    patching file util-linux/blkid.c
    applying patch file make/busybox/patches/620-findfs.patch
    patching file util-linux/findfs.c
    patching file include/volume_id.h
    applying patch file make/busybox/patches/711-revert_crtscts_fix.patch
    applying patch file make/busybox/patches/712-revert_read_sighandler.patch
    patching file shell/shell_common.c
    applying patch file make/busybox/patches/720-stun-ip.patch
    patching file networking/stun-ip.c
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0 \
		CC="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CROSS_COMPILE="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-" EXTRA_CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" ARCH="mips"
building... make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0'
  GEN     include/applets.h
  GEN     include/usage.h
  GEN     console-tools/Kbuild
  GEN     console-tools/Config.in
  GEN     mailutils/Kbuild
  GEN     mailutils/Config.in
  GEN     printutils/Kbuild
  GEN     printutils/Config.in
  GEN     debianutils/Kbuild
  GEN     debianutils/Config.in
  GEN     coreutils/Kbuild
  GEN     coreutils/Config.in
  GEN     coreutils/libcoreutils/Kbuild
  GEN     applets/Kbuild
  GEN     networking/Kbuild
  GEN     networking/Config.in
  GEN     networking/libiproute/Kbuild
  GEN     networking/udhcp/Kbuild
  GEN     networking/udhcp/Config.in
  GEN     sysklogd/Kbuild
  GEN     sysklogd/Config.in
  GEN     e2fsprogs/Kbuild
  GEN     e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/Config.in
  GEN     e2fsprogs/old_e2fsprogs/ext2fs/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/blkid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/uuid/Kbuild
  GEN     e2fsprogs/old_e2fsprogs/e2p/Kbuild
  GEN     procps/Kbuild
  GEN     procps/Config.in
  GEN     archival/Kbuild
  GEN     archival/Config.in
  GEN     archival/libarchive/Kbuild
  GEN     modutils/Kbuild
  GEN     modutils/Config.in
  GEN     findutils/Kbuild
  GEN     findutils/Config.in
  GEN     selinux/Kbuild
  GEN     selinux/Config.in
  GEN     scripts/Kbuild
  GEN     editors/Kbuild
  GEN     editors/Config.in
  GEN     libpwdgrp/Kbuild
  GEN     runit/Kbuild
  GEN     runit/Config.in
  GEN     shell/Kbuild
  GEN     shell/Config.in
  GEN     libbb/Kbuild
  GEN     libbb/Config.in
  GEN     miscutils/Kbuild
  GEN     miscutils/Config.in
  GEN     util-linux/Kbuild
  GEN     util-linux/Config.in
  GEN     util-linux/volume_id/Kbuild
  GEN     init/Kbuild
  GEN     init/Config.in
  GEN     loginutils/Kbuild
  GEN     loginutils/Config.in
  HOSTCC  scripts/basic/fixdep
  HOSTCC  scripts/basic/split-include
scripts/basic/split-include.c: In Funktion »main«:
scripts/basic/split-include.c:134:11: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  HOSTCC  scripts/basic/docproc
  HOSTCC  scripts/kconfig/conf.o
scripts/kconfig/conf.c: In Funktion »conf_choice«:
scripts/kconfig/conf.c:354:9: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
scripts/kconfig/conf.c: In Funktion »conf_askvalue«:
scripts/kconfig/conf.c:106:8: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  HOSTCC  scripts/kconfig/kxgettext.o
  HOSTCC  scripts/kconfig/mconf.o
  SHIPPED scripts/kconfig/zconf.tab.c
  SHIPPED scripts/kconfig/lex.zconf.c
  SHIPPED scripts/kconfig/zconf.hash.c
scripts/kconfig/mconf.c: In Funktion »show_textbox«:
scripts/kconfig/mconf.c:847:7: Warnung: Der Rückgabewert von »write«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
scripts/kconfig/mconf.c: In Funktion »exec_conf«:
scripts/kconfig/mconf.c:481:6: Warnung: Der Rückgabewert von »pipe«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  HOSTCC  scripts/kconfig/zconf.tab.o
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -s Config.in
# using defaults found in .config
.config:655:warning: trying to reassign symbol LOCALE_SUPPORT
  SPLIT   include/autoconf.h -> include/config/*
  HOSTCC  applets/usage
applets/usage.c: In Funktion »main«:
applets/usage.c:52:8: Warnung: Der Rückgabewert von »write«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  GEN     include/bbconfigopts.h
  HOSTCC  applets/applet_tables
applets/applet_tables.c: In Funktion »main«:
applets/applet_tables.c:144:9: Warnung: Der Rückgabewert von »fgets«, der mit dem Attribut warn_unused_result deklariert wurde, wird ignoriert [-Wunused-result]
  GEN     include/usage_compressed.h
  GEN     include/applet_tables.h
  HOSTCC  applets/usage_pod
applets/usage_pod.c: In Funktion »main«:
applets/usage_pod.c:74:3: Warnung: Format ist kein Zeichenkettenliteral, und keine Formatargumente [-Wformat-security]
  CC      applets/applets.o
  LD      applets/built-in.o
  DOC     busybox.pod
  DOC     BusyBox.txt
  DOC     busybox.1
  DOC     BusyBox.html
  LD      archival/built-in.o
  CC      archival/bbunzip.o
  LD      archival/libarchive/built-in.o
  CC      archival/libarchive/data_align.o
  CC      archival/libarchive/data_extract_all.o
  CC      archival/gzip.o
  CC      archival/libarchive/data_extract_to_stdout.o
  CC      archival/libarchive/data_skip.o
  CC      archival/libarchive/decompress_gunzip.o
  CC      archival/libarchive/filter_accept_all.o
  CC      archival/tar.o
  CC      archival/libarchive/filter_accept_list.o
  CC      archival/libarchive/filter_accept_reject_list.o
  CC      archival/libarchive/find_list_entry.o
  CC      archival/libarchive/get_header_tar.o
  AR      archival/lib.a
  LD      console-tools/built-in.o
  AR      console-tools/lib.a
  LD      coreutils/built-in.o
  CC      coreutils/basename.o
  CC      coreutils/cat.o
  CC      coreutils/chmod.o
  CC      archival/libarchive/header_list.o
  CC      coreutils/chown.o
  CC      archival/libarchive/header_skip.o
  CC      coreutils/cp.o
  CC      archival/libarchive/header_verbose_list.o
  CC      coreutils/cut.o
  CC      archival/libarchive/init_handle.o
  CC      archival/libarchive/open_transformer.o
  CC      coreutils/date.o
  CC      archival/libarchive/seek_by_jump.o
  CC      coreutils/dd.o
  CC      archival/libarchive/seek_by_read.o
  AR      archival/libarchive/lib.a
  LD      coreutils/libcoreutils/built-in.o
  CC      coreutils/libcoreutils/cp_mv_stat.o
  CC      coreutils/df.o
  CC      coreutils/libcoreutils/getopt_mk_fifo_nod.o
  CC      coreutils/dirname.o
  AR      coreutils/libcoreutils/lib.a
  LD      debianutils/built-in.o
  CC      debianutils/which.o
  CC      coreutils/du.o
  AR      debianutils/lib.a
  LD      e2fsprogs/built-in.o
  AR      e2fsprogs/lib.a
  LD      editors/built-in.o
  CC      editors/awk.o
  CC      coreutils/echo.o
  CC      coreutils/env.o
  CC      coreutils/expr.o
  CC      coreutils/false.o
  CC      coreutils/head.o
  CC      coreutils/id.o
  CC      coreutils/ln.o
  CC      coreutils/ls.o
  CC      editors/sed.o
  CC      coreutils/mkdir.o
  CC      coreutils/mkfifo.o
  CC      coreutils/mknod.o
  CC      coreutils/mv.o
  CC      coreutils/nohup.o
  CC      coreutils/printf.o
  CC      editors/vi.o
  CC      coreutils/pwd.o
  CC      coreutils/realpath.o
  CC      coreutils/rm.o
  CC      coreutils/rmdir.o
  CC      coreutils/sleep.o
  CC      coreutils/sort.o
  CC      coreutils/stat.o
  CC      coreutils/stty.o
  CC      coreutils/sync.o
  CC      coreutils/tail.o
  CC      coreutils/tee.o
  AR      editors/lib.a
  CC      coreutils/test.o
  LD      findutils/built-in.o
  CC      findutils/find.o
  CC      coreutils/test_ptr_hack.o
  CC      coreutils/touch.o
  CC      coreutils/tr.o
  CC      findutils/grep.o
  CC      coreutils/true.o
  CC      coreutils/tty.o
  CC      findutils/xargs.o
  CC      coreutils/uname.o
  CC      coreutils/uudecode.o
  AR      findutils/lib.a
  LD      init/built-in.o
  CC      init/halt.o
  CC      coreutils/wc.o
  CC      init/init.o
  CC      coreutils/yes.o
  AR      coreutils/lib.a
  LD      libbb/built-in.o
  CC      libbb/appletlib.o
libbb/appletlib.c: In function 'busybox_main':
libbb/appletlib.c:693:7: warning: variable 'use_symbolic_links' set but not used [-Wunused-but-set-variable]
  CC      libbb/ask_confirmation.o
  AR      init/lib.a
  LD      libpwdgrp/built-in.o
  CC      libpwdgrp/uidgid_get.o
  CC      libbb/bb_askpass.o
  AR      libpwdgrp/lib.a
  LD      loginutils/built-in.o
  CC      loginutils/addgroup.o
  CC      libbb/bb_bswap_64.o
  CC      loginutils/adduser.o
  CC      libbb/bb_do_delay.o
  CC      libbb/bb_pwd.o
  CC      loginutils/cryptpw.o
  CC      loginutils/deluser.o
  CC      libbb/bb_qsort.o
  CC      libbb/bb_strtonum.o
  CC      loginutils/login.o
  CC      libbb/change_identity.o
  CC      loginutils/passwd.o
  CC      libbb/chomp.o
  CC      libbb/compare_string_array.o
  AR      loginutils/lib.a
  LD      mailutils/built-in.o
  AR      mailutils/lib.a
  LD      miscutils/built-in.o
  CC      miscutils/crond.o
  CC      libbb/concat_path_file.o
  CC      libbb/concat_subpath_file.o
  CC      libbb/copy_file.o
  CC      miscutils/crontab.o
  CC      libbb/copyfd.o
  CC      miscutils/makedevs.o
  CC      libbb/correct_password.o
  AR      miscutils/lib.a
  CC      libbb/crc32.o
  LD      modutils/built-in.o
  CC      modutils/insmod.o
  CC      libbb/create_icmp6_socket.o
modutils/insmod.c: In function 'check_module_name_match':
modutils/insmod.c:23:81: warning: unused parameter 'statbuf' [-Wunused-parameter]
modutils/insmod.c:24:28: warning: unused parameter 'depth' [-Wunused-parameter]
modutils/insmod.c: In function 'find_module':
modutils/insmod.c:45:31: warning: variable 'k_version' set but not used [-Wunused-but-set-variable]
  CC      modutils/lsmod.o
  CC      libbb/create_icmp_socket.o
  CC      modutils/modprobe.o
  CC      libbb/default_error_retval.o
  CC      libbb/device_open.o
  CC      libbb/dump.o
  CC      modutils/modutils.o
  CC      modutils/rmmod.o
  AR      modutils/lib.a
  CC      libbb/execable.o
  LD      networking/built-in.o
  CC      networking/ether-wake.o
  CC      libbb/fclose_nonstdin.o
  CC      libbb/fflush_stdout_and_exit.o
  CC      networking/hostname.o
  CC      libbb/fgets_str.o
  CC      networking/httpd.o
  CC      libbb/find_mount_point.o
  CC      libbb/find_pid_by_name.o
  CC      libbb/find_root_device.o
  CC      libbb/full_write.o
  CC      libbb/get_console.o
  CC      libbb/get_last_path_component.o
  CC      libbb/get_line_from_file.o
  CC      networking/ifconfig.o
  CC      libbb/get_shell_name.o
  CC      libbb/get_volsize.o
  CC      networking/ifupdown.o
  CC      libbb/getopt32.o
  CC      libbb/getpty.o
  CC      libbb/hash_md5_sha.o
  CC      networking/inetd.o
  CC      libbb/herror_msg.o
  CC      libbb/human_readable.o
  CC      libbb/inet_cksum.o
  CC      networking/interface.o
  CC      libbb/inet_common.o
  CC      libbb/info_msg.o
  CC      libbb/inode_hash.o
  CC      libbb/isdirectory.o
  CC      libbb/kernel_version.o
  CC      networking/netstat.o
  CC      libbb/last_char_is.o
  CC      libbb/lineedit.o
  CC      networking/ping.o
  CC      networking/route.o
  CC      libbb/lineedit_ptr_hack.o
  CC      libbb/llist.o
  CC      libbb/login.o
  CC      networking/stun-ip.o
  CC      libbb/loop.o
  CC      networking/telnetd.o
  CC      libbb/make_directory.o
  CC      libbb/makedev.o
  CC      libbb/match_fstype.o
  CC      libbb/messages.o
  CC      networking/vconfig.o
  CC      libbb/missing_syscalls.o
  CC      libbb/mode_string.o
  CC      networking/whois.o
  CC      libbb/obscure.o
  AR      networking/lib.a
  LD      networking/libiproute/built-in.o
  AR      networking/libiproute/lib.a
  LD      networking/udhcp/built-in.o
  AR      networking/udhcp/lib.a
  LD      printutils/built-in.o
  AR      printutils/lib.a
  LD      procps/built-in.o
  CC      procps/free.o
  CC      libbb/parse_config.o
  CC      procps/kill.o
  CC      libbb/parse_mode.o
  CC      procps/pidof.o
  CC      libbb/percent_decode.o
  CC      libbb/perror_msg.o
  CC      procps/ps.o
  CC      libbb/perror_nomsg.o
  CC      libbb/perror_nomsg_and_die.o
procps/ps.c: In function 'ps_main':
procps/ps.c:748:14: warning: 'uptime' may be used uninitialized in this function [-Wuninitialized]
  CC      libbb/pidfile.o
  CC      procps/sysctl.o
  CC      libbb/platform.o
  CC      libbb/print_flags.o
  CC      libbb/printable.o
  CC      procps/top.o
procps/top.c: In function 'handle_input':
procps/top.c:921:16: warning: variable 'pfd' set but not used [-Wunused-but-set-variable]
  CC      libbb/printable_string.o
  CC      libbb/process_escape_sequence.o
  CC      libbb/procps.o
  CC      procps/uptime.o
  AR      procps/lib.a
  LD      runit/built-in.o
  AR      runit/lib.a
  LD      selinux/built-in.o
  AR      selinux/lib.a
  LD      shell/built-in.o
  CC      shell/ash.o
  CC      libbb/progress.o
  CC      libbb/ptr_to_globals.o
  CC      libbb/pw_encrypt.o
  CC      libbb/read.o
  CC      libbb/read_key.o
  CC      libbb/read_printf.o
  CC      libbb/recursive_action.o
  CC      libbb/remove_file.o
  CC      libbb/run_shell.o
  CC      libbb/safe_gethostname.o
  CC      libbb/safe_poll.o
  CC      libbb/safe_strncpy.o
  CC      libbb/safe_write.o
  CC      libbb/setup_environment.o
  CC      libbb/signals.o
  CC      libbb/simplify_path.o
  CC      libbb/single_argv.o
  CC      libbb/skip_whitespace.o
  CC      libbb/speed_table.o
  CC      libbb/str_tolower.o
  CC      libbb/strrstr.o
  CC      libbb/time.o
  CC      libbb/trim.o
  CC      libbb/u_signal_names.o
  CC      libbb/update_passwd.o
  CC      libbb/uuencode.o
  CC      libbb/vdprintf.o
  CC      libbb/verror_msg.o
  CC      libbb/vfork_daemon_rexec.o
  CC      libbb/warn_ignoring_args.o
  CC      libbb/wfopen.o
  CC      libbb/wfopen_input.o
  CC      libbb/write.o
  CC      libbb/xatonum.o
  CC      shell/ash_ptr_hack.o
  CC      shell/math.o
  CC      libbb/xconnect.o
  CC      shell/shell_common.o
  CC      libbb/xfunc_die.o
  CC      libbb/xfuncs.o
  AR      shell/lib.a
  LD      sysklogd/built-in.o
  CC      sysklogd/klogd.o
  CC      libbb/xfuncs_printf.o
  CC      sysklogd/logread.o
  CC      sysklogd/syslogd_and_logger.o
  CC      libbb/xgetcwd.o
  CC      libbb/xgethostbyname.o
  CC      libbb/xreadlink.o
  CC      libbb/xrealloc_vector.o
  AR      sysklogd/lib.a
  LD      util-linux/built-in.o
  CC      util-linux/blkid.o
  CC      libbb/xregcomp.o
  CC      util-linux/dmesg.o
  AR      libbb/lib.a
  LD      util-linux/volume_id/built-in.o
  CC      util-linux/volume_id/ext.o
  CC      util-linux/getopt.o
  CC      util-linux/volume_id/fat.o
  CC      util-linux/volume_id/get_devname.o
  CC      util-linux/mkswap.o
  CC      util-linux/volume_id/ntfs.o
  CC      util-linux/mount.o
  CC      util-linux/volume_id/util.o
  CC      util-linux/volume_id/volume_id.o
  AR      util-linux/volume_id/lib.a
  CC      util-linux/pivot_root.o
  CC      util-linux/swaponoff.o
  CC      util-linux/umount.o
  AR      util-linux/lib.a
  LINK    busybox_unstripped
Trying libraries: crypt m
 Library crypt is not needed, excluding it
 Library m is not needed, excluding it
Final link with: <none>
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0'
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/busybox/; cp source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0/busybox packages/target-mipsel_uClibc-0.9.32.1/busybox/busybox; /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/busybox/busybox;
		CC="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CROSS_COMPILE="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-" EXTRA_CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" ARCH="mips" \
		busybox.links
touch -c source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0/busybox.links
cp source/target-mipsel_uClibc-0.9.32.1/busybox-1.21.0/busybox.links packages/target-mipsel_uClibc-0.9.32.1/busybox/busybox.links
done.
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root
if test -d make/haserl/files; then tar -c -C make/haserl/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29 ; fi
if [ ! -e source/.echo_item_start ]; then 	echo -n "---> "; case "BIN" in BIN)	echo -n "package/haserl: " ;; LIB)	echo -n "library/haserl: " ;; TOOL)	echo -n "tool/haserl: " ;; *)	echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
---> package/haserl: downloading...
--2013-03-18 20:34:58--  http://downloads.sourceforge.net/haserl/haserl-0.9.29.tar.gz
Auflösen des Hostnamen »downloads.sourceforge.net (downloads.sourceforge.net)«... 216.34.181.59
Verbindungsaufbau zu downloads.sourceforge.net (downloads.sourceforge.net)|216.34.181.59|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 301 Moved Permanently
Platz: http://downloads.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz [folge]
--2013-03-18 20:34:58--  http://downloads.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz
Wiederverwendung der bestehenden Verbindung zu downloads.sourceforge.net:80.
Platz: http://freefr.dl.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz [folge]
--2013-03-18 20:34:59--  http://freefr.dl.sourceforge.net/project/haserl/haserl-devel/haserl-0.9.29.tar.gz
Auflösen des Hostnamen »freefr.dl.sourceforge.net (freefr.dl.sourceforge.net)«... 158.255.96.7, 2001:1b48:10f::7
Verbindungsaufbau zu freefr.dl.sourceforge.net (freefr.dl.sourceforge.net)|158.255.96.7|:80... verbunden.
HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
Länge: 135230 (132K) [application/x-gzip]
In »»dl/haserl-0.9.29.tar.gz«« speichern.
100%[===================================================================================================================================>] 135.230     91,9K/s   in 1,4s
2013-03-18 20:35:01 (91,9 KB/s) - »»dl/haserl-0.9.29.tar.gz«« gespeichert [135230/135230]
Download succeeded - "http://downloads.sourceforge.net/haserl/haserl-0.9.29.tar.gz"  ->  saved to folder "dl"
MD5 verified for dl/haserl-0.9.29.tar.gz: 4cac9409530200b4a7a82a48ec174800
preparing... tools/gunzip -c dl/haserl-0.9.29.tar.gz | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/haserl/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29 $i; done
    applying patch file make/haserl/patches/100-lualib_inc.patch
    patching file src/Makefile.in
    patching file src/haserl_lualib.inc
configuring... (conf_cmd() { ./configure  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; cd source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29;   rm -f config.{cache,status};    PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" CC="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CXX="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper" CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/../lib/pkgconfig" GLOBAL_LIBDIR=/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/usr/lib  FREETZ_TARGET_LFS="y" CONFIG_SITE=/run/shm/tmp/freetz-trunk/include/site/mipsel-linux-uclibc conf_cmd   --cache-file=/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/config.cache --target=mipsel-linux --host=mipsel-linux --build=x86_64-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls      )
configure: WARNING: unrecognized options: --with-gnu-ld, --disable-nls
configure: loading site script /run/shm/tmp/freetz-trunk/include/site/mipsel-linux-uclibc
configure: creating cache /run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/config.cache
checking for mipsel-linux-strip... mipsel-linux-strip
checking for mipsel-linux-gcc... /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
checking dependency style of /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... gcc3
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for size_t... yes
checking for working memcmp... (cached) yes
checking for memset... yes
checking for putenv... yes
checking for strcasecmp... yes
checking for strdup... yes
checking for strncasecmp... yes
checking for strstr... yes
configure: updating cache /run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/config.cache
config.status: creating src/Makefile
config.status: creating src/config.h
** Configuration summary for haserl 0.9.29:
	Building haserl with with lua disabled
	Building haserl with with bash-extensions disabled
	libs:
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29
building... make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
Making all in src
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
make  all-am
make[3]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT common.o -MD -MP -MF .deps/common.Tpo -c -o common.o common.c
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT sliding_buffer.o -MD -MP -MF .deps/sliding_buffer.Tpo -c -o sliding_buffer.o sliding_buffer.c
mv -f .deps/sliding_buffer.Tpo .deps/sliding_buffer.Po
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT h_error.o -MD -MP -MF .deps/h_error.Tpo -c -o h_error.o h_error.c
mv -f .deps/common.Tpo .deps/common.Po
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT h_script.o -MD -MP -MF .deps/h_script.Tpo -c -o h_script.o h_script.c
mv -f .deps/h_error.Tpo .deps/h_error.Po
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT rfc2388.o -MD -MP -MF .deps/rfc2388.Tpo -c -o rfc2388.o rfc2388.c
mv -f .deps/h_script.Tpo .deps/h_script.Po
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT h_bash.o -MD -MP -MF .deps/h_bash.Tpo -c -o h_bash.o h_bash.c
mv -f .deps/rfc2388.Tpo .deps/rfc2388.Po
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -DHAVE_CONFIG_H -I.     -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall -MT haserl.o -MD -MP -MF .deps/haserl.Tpo -c -o haserl.o haserl.c
mv -f .deps/h_bash.Tpo .deps/h_bash.Po
haserl.c: In function 'main':
haserl.c:695:7: warning: variable 'retval' set but not used [-Wunused-but-set-variable]
mv -f .deps/haserl.Tpo .deps/haserl.Po
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc  -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -Wall   -o haserl common.o sliding_buffer.o h_error.o h_script.o rfc2388.o h_bash.o  haserl.o
make[3]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src'
Making all in doc
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/doc'
make[2]: Für das Ziel »all« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/doc'
make[2]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
make[2]: Für das Ziel »all-am« ist nichts zu tun.
make[2]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29'
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root/usr/bin/; cp source/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/src/haserl packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root/usr/bin/haserl; /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/haserl-0.9.29/root/usr/bin/haserl;
done.
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/inetd-0.2/root
if test -d make/inetd/files; then tar -c -C make/inetd/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/inetd-0.2 ; fi
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/mod-1.0/root
if test -d make/mod/files; then tar -c -C make/mod/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/mod-1.0 ; fi
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root
if test -d make/modcgi/files; then tar -c -C make/modcgi/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3 ; fi
if [ ! -e source/.echo_item_start ]; then 	echo -n "---> "; case "BIN" in BIN)	echo -n "package/modcgi: " ;; LIB)	echo -n "library/modcgi: " ;; TOOL)	echo -n "tool/modcgi: " ;; *)	echo -n "kernel: " ;; esac; rm -f source/.echo_item_build; touch source/.echo_item_start; fi; echo -n "downloading... ";
---> package/modcgi: downloading...
--2013-03-18 20:35:07--  http://freetz.magenbrot.net/modcgi-0.3.tar.bz2
Auflösen des Hostnamen »freetz.magenbrot.net (freetz.magenbrot.net)«... 85.25.156.176
Verbindungsaufbau zu freetz.magenbrot.net (freetz.magenbrot.net)|85.25.156.176|:80... verbunden.
Länge: 2343 (2,3K) [application/x-bzip2]
In »»dl/modcgi-0.3.tar.bz2«« speichern.
100%[===================================================================================================================================>] 2.343       --.-K/s   in 0s
2013-03-18 20:35:07 (6,74 MB/s) - »»dl/modcgi-0.3.tar.bz2«« gespeichert [2343/2343]
Download succeeded - "http://freetz.magenbrot.net/modcgi-0.3.tar.bz2"  ->  saved to folder "dl"
MD5 verified for dl/modcgi-0.3.tar.bz2: 5323ce1a98492bd78d2fbe097268fe83
preparing... tools/bunzip2 -c dl/modcgi-0.3.tar.bz2 | tar -C source/target-mipsel_uClibc-0.9.32.1 -x
set -e; shopt -s nullglob; for i in make/modcgi/patches/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3 $i; done
    applying patch file make/modcgi/patches/100-proccgi.patch
    patching file proccgi/proccgi.c
cmd() { PATH="/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin:/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3/mipsel-unknown-linux-gnu/bin:/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j2  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3 \
building... make[1]: Betrete Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3'
cp proccgi/proccgi.c proccgi.c ; \
	mv proccgi.c modcgi.c
/run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -o modcgi modcgi.c
make[1]: Verlasse Verzeichnis '/run/shm/tmp/freetz-trunk/source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3'
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root/usr/bin/; cp source/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/modcgi packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root/usr/bin/modcgi; /run/shm/tmp/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.32.1/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.32.1/modcgi-0.3/root/usr/bin/modcgi;
done.
mkdir -p packages/target-mipsel_uClibc-0.9.32.1/syslogd-cgi-0.2.3/root
if test -d make/syslogd-cgi/files; then tar -c -C make/syslogd-cgi/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.32.1/syslogd-cgi-0.2.3 ; fi
STEP 1: UNPACK
unpacking firmware image
Skipping 0 Bytes garbage...splitting kernel image
unpacking filesystem image
    3446 inodes (3881 blocks) to write
    created 2707 files
    created 198 directories
    created 652 symlinks
    created 87 devices
    created 0 fifos
unpacking var.tar
done.
detected firmware 7270 v3 74.05.23 rev22845 (26.07.2012 12:13:40)
STEP 2: MODIFY
applying symlinks, deleting additional webinterfaces in: usr/www usr/www.nas usr/www.myfritz
applying patches
  applying patches: 7270_v3-en (05_2X)
    applying patch file ./patches/devices/05_2X/105-S06-logging.sh
    applying patch file ./patches/devices/05_2X/115-S20-modload.sh
    applying patch file ./patches/devices/05_2X/200-tun-device.sh
    patching build/modified/filesystem/etc/udev/rules.d/50-udev-default.rules
    applying patch file ./patches/devices/05_2X/120-rc.S-dev.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/devices/05_2X/140-rc.tail.sh-no_exit.patch
    patching file etc/init.d/rc.tail.sh
    applying patch file ./patches/devices/05_2X/en/210-notmountable.patch
    patching file usr/www/all/html/de/home/home.js
    applying patch file ./patches/devices/05_2X/7270/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/devices/05_2X/7270/190-webmenu.patch
    patching file usr/www/all/templates/menu_page_end.html
    patching file usr/www/all/menus/menu_freetz.lua
    patching file usr/www/all/templates/menu_page_head.html
    applying patch file ./patches/devices/05_2X/7270/200-sperre1.patch
    patching file usr/www/all/html/de/fon/sperre1.js
  creating symlinks /tmp, /mod and /home
  creating /mnt and /opt
  setting freetz-version 'freetz-devel'
    applying patch file ./patches/scripts/100-3170_7170.sh
    applying patch file ./patches/scripts/100-7112_7170.sh
    applying patch file ./patches/scripts/100-7113_7170.sh
    applying patch file ./patches/scripts/100-7140_7170.sh
    applying patch file ./patches/scripts/100-7141_7170.sh
    applying patch file ./patches/scripts/100-7240_7270.sh
    applying patch file ./patches/scripts/100-7270v1_7270v2.sh
    applying patch file ./patches/scripts/100-7270v2_7270v1.sh
    applying patch file ./patches/scripts/100-7320_7330.sh
    applying patch file ./patches/scripts/100-7570_iad7570.sh
    applying patch file ./patches/scripts/100-enforce-urlader-settings.sh
    applying patch file ./patches/scripts/100_iad3331_7170.sh
    applying patch file ./patches/scripts/100-w701v_7170.sh
    applying patch file ./patches/scripts/100-w900v_7170.sh
    applying patch file ./patches/scripts/100-w920v_7570.sh
    applying patch file ./patches/scripts/101-ctlmgr_wrapper.sh
    applying patch file ./patches/scripts/105-onlinechanged.sh
  patching /bin/onlinechanged
    applying patch file ./patches/scripts/108-tffs_nodes.sh
  applying tffs_nodes patch
    patching build/modified/filesystem/etc/init.d/S08-tffs
    applying patch file ./patches/scripts/109-rc.net-multid-wrapper.sh
  replacing multid by a wrapper
    patching build/modified/filesystem/etc/init.d/rc.net
    applying patch file ./patches/scripts/110-inittab.sh
    applying patch file ./patches/scripts/110-multid-wait.sh
  applying multid-wait patch
    applying patch file ./patches/scripts/110-system_status.sh
    applying patch file ./patches/scripts/115-rc.S.sh
    applying patch file ./patches/scripts/116-usbroot_S46-usb.sh
    applying patch file ./patches/scripts/120-dev_led.sh
  applying /dev/led patch
    patching build/modified/filesystem/bin/update_led_on
    patching build/modified/filesystem/bin/update_led_off
    applying patch file ./patches/scripts/130-fstab.sh
    applying patch file ./patches/scripts/140-remove-uClibc.sh
  removing uClibc-0.9.32 files
    rm -rf build/modified/filesystem/lib/*0.9.32*
  removing uClibc links
    rm -rf build/modified/filesystem/lib/ld-linux.so*
    rm -rf build/modified/filesystem/lib/ld-uClibc.so*
    rm -rf build/modified/filesystem/lib/ld.so*
    rm -rf build/modified/filesystem/lib/libc.so*
    rm -rf build/modified/filesystem/lib/libcrypt.so*
    rm -rf build/modified/filesystem/lib/libdl.so*
    rm -rf build/modified/filesystem/lib/libld-uClibc*
    rm -rf build/modified/filesystem/lib/libm.so*
    rm -rf build/modified/filesystem/lib/libnsl.so*
    rm -rf build/modified/filesystem/lib/libpthread.so*
    rm -rf build/modified/filesystem/lib/libthread_db.so*
    rm -rf build/modified/filesystem/lib/libresolv.so*
    rm -rf build/modified/filesystem/lib/librt.so*
    rm -rf build/modified/filesystem/lib/libubacktrace.so*
    rm -rf build/modified/filesystem/lib/libutil.so*
  linking ld.so.1
    applying patch file ./patches/scripts/170-rename_ar7login.sh
  renaming ar7login to make way for wrapper script
    applying patch file ./patches/scripts/180-printk.sh
  applying printk patch
    patching build/modified/filesystem/etc/init.d/S11-piglet
    applying patch file ./patches/scripts/190-webmenu.sh
  applying webmenu patch
    patching build/modified/filesystem/usr/www/all/html/de/menus/menu2.html
    applying patch file ./patches/scripts/191-webmenu_wol.sh
    applying patch file ./patches/scripts/195-webmenu_signed.sh
    applying patch file ./patches/scripts/197-freetzmount.sh
  applying FREETZMOUNT patch
    patching build/modified/filesystem/etc/hotplug/storage
    patching build/modified/filesystem/etc/hotplug/udev-mount-sd
    patching run_mount script
    patching /etc/hotplug/storage
    applying patch file ./patches/scripts/198-usbroot.sh
    applying patch file ./patches/scripts/200-vcc.sh
    applying patch file ./patches/scripts/210-ata.sh
    applying patch file ./patches/scripts/210-enum.sh
    applying patch file ./patches/scripts/210-international.sh
    applying patch file ./patches/scripts/220-assistant.sh
    applying patch file ./patches/scripts/220-cdrom-iso.sh
    applying patch file ./patches/scripts/220-chronyd.sh
    applying patch file ./patches/scripts/220-help.sh
    applying patch file ./patches/scripts/220-remove-nas.sh
    applying patch file ./patches/scripts/221-remove_myfritz.sh
    applying patch file ./patches/scripts/225-remove_fhem.sh
    applying patch file ./patches/scripts/230-openssl.sh
    applying patch file ./patches/scripts/240-add-dsl-expert-pages.sh
    applying patch file ./patches/scripts/250-remove_avm_inetd.sh
  removing AVM inetd
    rm -rf build/modified/filesystem/bin/inetdctl
    rm -rf build/modified/filesystem/etc/inetd.conf
    rm -rf build/modified/filesystem/etc/init.d/S75-inetd
    applying patch file ./patches/scripts/260-remove_tr069.sh
    applying patch file ./patches/scripts/270-remove_usb_module.sh
    applying patch file ./patches/scripts/275-multiple_printers.sh
    applying patch file ./patches/scripts/280-remove_upnp.sh
    applying patch file ./patches/scripts/290-replace_websrv.sh
    applying patch file ./patches/scripts/300-remove-samba.sh
    applying patch file ./patches/scripts/310-remove_kids.sh
    applying patch file ./patches/scripts/315-remove-qos.sh
    applying patch file ./patches/scripts/320-remove_capiotcp.sh
    applying patch file ./patches/scripts/320-remove-dsld.sh
    applying patch file ./patches/scripts/325-remove-showdsldstat.sh
    applying patch file ./patches/scripts/330-remove-telephony.sh
    applying patch file ./patches/scripts/331-remove-voipd.sh
    applying patch file ./patches/scripts/340-remove_dect_update.sh
    applying patch file ./patches/scripts/345-hide_dsl.sh
    applying patch file ./patches/scripts/350-add_remove_annex_file.sh
    applying patch file ./patches/scripts/355-remove_dsl_control.sh
    applying patch file ./patches/scripts/360-remove-wlan.sh
    applying patch file ./patches/scripts/370-remove_dtrace.sh
  removing dtrace file
    rm -rf build/modified/filesystem/usr/bin/dtrace
    applying patch file ./patches/scripts/380-remove-umtsd.sh
    applying patch file ./patches/scripts/381-modify-umtsd.sh
    applying patch file ./patches/scripts/382-enable-gsmvoice.sh
    applying patch file ./patches/scripts/385-remove-ntfs.sh
    applying patch file ./patches/scripts/386-remove_fat.sh
    applying patch file ./patches/scripts/390-remove_e2fsprogs.sh
  remove AVM's e2fsprogs binaries
    rm -rf build/modified/filesystem/sbin/blkid
    rm -rf build/modified/filesystem/usr/sbin/blkid
    rm -rf build/modified/filesystem/usr/sbin/e2fsck
    rm -rf build/modified/filesystem/usr/sbin/fsck
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext2
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext3
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext4
    rm -rf build/modified/filesystem/usr/sbin/fsck.ext4dev
    rm -rf build/modified/filesystem/sbin/mkfs
    rm -rf build/modified/filesystem/sbin/mkswap
  remove AVM's e2fsprogs libraries
    rm -rf build/modified/filesystem/usr/lib/libblkid*
    rm -rf build/modified/filesystem/usr/lib/libcom_err*
    rm -rf build/modified/filesystem/usr/lib/libe2p*
    rm -rf build/modified/filesystem/usr/lib/libext2fs*
    rm -rf build/modified/filesystem/usr/lib/libuuid*
    applying patch file ./patches/scripts/400-remove-inetdctl.sh
    applying patch file ./patches/scripts/401-remove_ftpd.sh
  remove banner from AVM ftpd
    applying patch file ./patches/scripts/410-remove_piglet.sh
    applying patch file ./patches/scripts/420-remove_printserv.sh
    applying patch file ./patches/scripts/460-MAXDEVCOUNT.sh
    applying patch file ./patches/scripts/480-alarmclock.sh
    applying patch file ./patches/scripts/490-remove-ramzswap.sh
    applying patch file ./patches/scripts/500-remove-mediasrv.sh
    applying patch file ./patches/scripts/510-remove_aha.sh
    applying patch file ./patches/scripts/510-remove_aura_usb.sh
    applying patch file ./patches/scripts/510-remove_avm_vpn.sh
    applying patch file ./patches/scripts/510-remove_minid.sh
    applying patch file ./patches/scripts/520-remove_dect.sh
    applying patch file ./patches/scripts/530-remove_support.sh
    applying patch file ./patches/scripts/540-remove_webdav.sh
    applying patch file ./patches/scripts/550-add_reg_external_in_gui.sh
    applying patch file ./patches/scripts/560-remove_lsof.sh
    applying patch file ./patches/scripts/565-remove_more.sh
  removing more
    rm -rf build/modified/filesystem/bin/more
    applying patch file ./patches/scripts/570-remove_strace.sh
    applying patch file ./patches/scripts/580-remove_jffs2.sh
    applying patch file ./patches/scripts/585-remove_isofs.sh
    applying patch file ./patches/scripts/590-remove_libfuse.sh
    applying patch file ./patches/scripts/600-replace_mdev.sh
    applying patch file ./patches/scripts/610-remove_socat.sh
    applying patch file ./patches/scripts/700-add_bash_to_etc_shells.sh
    applying patch file ./patches/scripts/700-set_lang_to_utf8.sh
    applying patch file ./patches/scripts/900-add_options_cfg.sh
  creating options.cfg
    by symlinking it to .config
    applying patch file ./patches/scripts/999-remove_run_clock.sh
  removing oem: none
installing mod base
  installing libs
  ld_uClibc ....................   10.30 Kb
  libcrypt .....................    6.97 Kb
  libctlmgr ....................    1.82 Kb
  libdl ........................    4.30 Kb
  libgcc_s .....................   20.58 Kb
  libm .........................   31.64 Kb
  libpthread ...................   21.59 Kb
  librt ........................    2.43 Kb
  libuClibc ....................  194.41 Kb
installing busybox
  replacing busybox
  installing symlinks
installing packages
  syslogd-cgi-0.2.3 ............    3.13 Kb
  inetd-0.2 ....................    2.98 Kb
  haserl-0.9.29 ................    8.88 Kb
  mod-1.0 ......................   98.69 Kb
  modcgi-0.3 ...................    3.44 Kb
invoking custom script
processing mod base options
  setting colored style as default
  patching security level
  rc.external was not integrated into image
  integrating stripped .config file into image
stripping leftover unstripped binaries
    build/modified/filesystem/bin/wlancfgconv
    build/modified/filesystem/bin/wlancfgctl
    build/modified/filesystem/lib/libuClibc-0.9.32.1.so
    build/modified/filesystem/lib/librt-0.9.32.1.so
    build/modified/filesystem/lib/libpthread-0.9.32.1.so
    build/modified/filesystem/lib/libm-0.9.32.1.so
    build/modified/filesystem/lib/libdl-0.9.32.1.so
    build/modified/filesystem/lib/libcrypt-0.9.32.1.so
    build/modified/filesystem/lib/ld-uClibc-0.9.32.1.so
    build/modified/filesystem/lib/libtiinterpreter.so.0.0.0
    build/modified/filesystem/lib/libwcfg.so
    build/modified/filesystem/lib/libwlanparams.so
    build/modified/filesystem/lib/libz.so.1.2.3
    build/modified/filesystem/usr/bin/bspatch
    build/modified/filesystem/usr/sbin/80211stats
    build/modified/filesystem/usr/sbin/athstats
    build/modified/filesystem/usr/sbin/athstatsclr
    build/modified/filesystem/usr/sbin/dsl_monitor
    build/modified/filesystem/usr/share/ctlmgr/libctlwebdav.so
    build/modified/filesystem/usr/share/ctlmgr/libplcctlmgr.so
    build/modified/filesystem/usr/share/ctlmgr/libwlan.so
done.
STEP 3: PACK
  checking for left over Subversion directories
  integrate freetz info file into image
packing var.tar
creating filesystem image
  SquashFS block size: 65536 (64 kB)
merging kernel image
  kernel image size: 14584832 (max: 16121856, free: 1537024)
  Aproximately free time for the answering machine: 599s (9min 59s)
packing images/7270_v3_05.23-freetz-devel.en_20130318-203516.image
done.
FINISHED
joerg@joerg-desktop:/run/shm/tmp/freetz-trunk$
The fresh checkout Maxmuster made, did NOT work.
This means there's something wrong with the trunk....
Things are missing which are there on development boxes that exist for a while
Comparing the build output for the version with working and not working ADSL, which is quite difficult, because of differences in language, folder and order, I found these differences (but I could have missed others):
No ADSL:
  libcrypt .....................    6.98 Kb
  libctlmgr ....................    1.83 Kb
  mod-1.0 ......................   98.54 Kb
  kernel image size: 14588928 (max: 16121856, free: 1532928)
  Aproximately free time for the answering machine: 597s (9min 57s)
With ADSL:
Just a side note, maybe somebody can fix the spelling mistake Aproximately -> Approximately.
Maybe there is a difference in installed packages on the build system.
I got this problem (no ADSL) after installing Ubuntu again, because I needed a 64-bit version to build Android.
I always built Freetz on Ubuntu 32-bit before without problems.
My development PC is used for a lot of things, so maybe there were more packages installed before.
If you both list the output of:
dpkg -l
I will compare the differences.
I can only think of a difference in one of the downloads, for the “old“ build started with some of the downloads already in place...
I can only think of a differenc. in one of the downloads, for the “old“ build started with some of the downloads already in place...
The test I made with you, showed that it's not the box itself. After doing a fresh checkout on your working box it started to make invalid images.
My conclusion is that the current trunk is invalid which is masked by most people merely updating their trunk...
Do you agree?
As I said I have already made valid 7390 images with this new checkout. Only the 7270v3 (the only other model I tested) has no ADSL.
I prefer to wait for a solution before I start updating all my 7390's
If you both post a 'ls -al' of the dl folder, we can check the differences.
Here it is.
There are some packages you probably don't have (sudo, zabbix) because it is not the "virgin" setup anymore...
freetz@freetz:~/trunk/dl$ ls -altr
total 49892
-rw-r--r--  1 freetz freetz  234231 Sep 11  2005 squashfs2.2-r2.tar.gz
-rw-r--r--  1 freetz freetz  160381 Feb 12  2006 iftop-0.17.tar.gz
-rw-r--r--  1 freetz freetz  178493 Jun  4  2006 lzma443.tar.bz2
-rw-r--r--  1 freetz freetz 2961939 Jan 31  2008 libtool-1.5.26.tar.gz
-rw-r--r--  1 freetz freetz  352660 Aug 27  2008 squashfs3.4.tar.gz
-rw-r--r--  1 freetz freetz  581984 Apr  6  2010 libpcap-1.1.1.tar.gz
-rw-r--r--  1 freetz freetz 1587392 Apr  6  2010 tcpdump-4.1.1.tar.gz
-rw-r--r--  1 freetz freetz  963663 Sep  6  2010 sudo-1.7.4p4.tar.gz
-rw-r--r--  1 freetz freetz    2343 Mar  1  2011 modcgi-0.3.tar.bz2
-rw-r--r--  1 freetz freetz 2826473 Apr  4  2011 ncurses-5.9.tar.gz
-rw-r--r--  1 freetz freetz  135230 May 10  2011 haserl-0.9.29.tar.gz
-rw-r--r--  1 freetz freetz 1774927 Feb 27  2012 dropbear_2012.55.orig.tar.gz
-rw-r--r--  1 freetz freetz  309298 Jun  2  2012 fakeroot_1.18.4.orig.tar.bz2
-rw-r--r--  1 freetz freetz 2817916 Jul 14  2012 sfk165.zip
-rw-r--r--  1 freetz freetz 4241782 Aug 20  2012 zabbix-1.8.15.tar.gz
-rw-r--r--  1 freetz freetz 9122078 Dec  1 11:14 mips_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma
-rw-r--r--  1 freetz freetz 8924371 Dec  1 11:14 mipsel_gcc-4.6.3_uClibc-0.9.32.1-freetz-r9637-shared-glibc.tar.lzma
-rw-r--r--  1 freetz freetz 5192957 Dec  1 11:14 mipsel_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma
-rw-r--r--  1 freetz freetz 5119273 Dec  1 11:14 mips_gcc-4.6.3-freetz-r9637-shared-glibc.tar.lzma
-rw-r--r--  1 freetz freetz  536832 Dec 14 13:06 dnsmasq-2.65.tar.gz
-rw-r--r--  1 freetz freetz 2200841 Jan 21 08:53 busybox-1.21.0.tar.bz2
-rw-r--r--  1 freetz freetz  129520 Mar  5 09:34 kconfig-v3.8.tar.xz
-rw-r--r--  1 freetz freetz  257792 Mar  6 16:46 uClibc++-5976d7536d8c7a8d5a7f60fd2a3c34876a224f30.tar.bz2
-rw-r--r--  1 freetz freetz  272750 Mar  6 18:02 mtr-0.80.tar.gz
drwxr-xr-x  2 freetz freetz    4096 Mar  9 13:45 fw
drwxr-xr-x  3 freetz freetz    4096 Mar 19 14:57 .
drwxr-xr-x 18 freetz freetz    4096 Mar 19 14:58 ..
Also dl/fw might be relevant.
freetz@freetz:~/trunk/dl/fw$ ls -altr
total 150388
-rw-r--r-- 1 freetz freetz 58215296 Jun 15  2012 7270_05.21-release_kernel.tar.xz
-rw-r--r-- 1 freetz freetz 48289784 Jun 15  2012 7390_05.21-release_kernel.tar.xz
-rw-r--r-- 1 freetz freetz 15697920 Mar  6 16:43 FRITZ.Box_Fon_WLAN_7270_v3.en-de-es-it-fr.74.05.23.image
-rw-r--r-- 1 freetz freetz 15943680 Mar  6 18:39 FRITZ.Box_Fon_WLAN_7390.en-de-es-it-fr.84.05.22.image
drwxr-xr-x 2 freetz freetz     4096 Mar  9 13:45 .
-rw-r--r-- 1 freetz freetz 15656960 Mar  9 13:46 FRITZ.Box_Fon_WLAN_7270_16.en-de-es-it-fr.54.05.23.image
drwxr-xr-x 3 freetz freetz     4096 Mar 19 14:57 ..
Okay. Found the problem:
+ cd /var/dsl/dspfw
+ md5sum -c /lib/modules/dsp_ur8/ur8-A-dsl.bin.md5sum
/etc/init.d/E40-dsl: line 1: md5sum: not found
Thanks for your patience...
Regards
Oliver
I just did a new svn update and nothing changed....
Shouldn't the md5sum become mandatory in Busybox applets???
I just enabled it and it still doesn't work.....
root@fritz:/var/mod/root# md5sum -c /lib/modules/dsp_ur8/ur8-A-dsl.bin.md5sum
md5sum: can't open '-c': No such file or directory
2894ddf6c28ce003ce60f5219343bc93  /lib/modules/dsp_ur8/ur8-A-dsl.bin.md5sum
the md5sum in busybox applets doesn't take "-c"
Ticket #2046
Regards
Oliver
I can't seem to find that option....
I'm only using "make menuconfig"
On my previous system I had to use "make busybox-menuconfig" but that seems to be deprecated....
Where exactly do I change this?
But shouldn't both become mandatory?
Why didn't I see any change in svn?
PS...
Found the option at the bottom of that section!!
I made the change of make/busybox/Config.in manually...
My ADSL is working, but I still don't trust it....
Maybe you saw I am using a Zabbix Agent on Freetz.
It is working and showed me that there is no space on /var
Is there some special reason why /var is not mounted on tmpfs ????
root@fritz:/var# df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/root                13.1M     13.1M         0 100% /
/dev/mtdblock5          768.0K    388.0K    380.0K  51% /data
/dev/loop0              274.0K    253.0K      7.0K  97% /var/media/ftp
On my previous firmwares I have this output:
root@fritz:/var/mod/root# df -h
/dev/root                12.2M     12.2M         0 100% /
tmpfs                    29.4M      4.9M     24.5M  17% /var
dev                      29.4M     68.0K     29.3M   0% /dev
/dev/mtdblock5            1.8M    388.0K      1.4M  22% /data
/dev/loop0                3.9M    259.0K      3.4M   7% /var/media/ftp
If I build a firmware for the 7390 I DO have tmpfs:
root@Pluspunt:/var/mod/root# df -h
tmpfs                    56.1M    876.0K     55.3M   2% /var
dev                      56.1M     16.0K     56.1M   0% /dev
/var/dev/nand           512.0M      1.4M    510.6M   0% /var/media/ftp
These are the differences I found...
With tmpfs
FREETZ_REPLACE_KERNEL=y
FREETZ_HAS_AVM_PTY_SUPPORT=y
FREETZ_HAS_AVM_CTLMGR_STRUCT_V2=y
FREETZ_MODULE_jffs2=y
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_BLKID_TYPE=y
FREETZ_LIB_libctlmgr_WITH_STRUCT_V2=y
FREETZ_GCC_4_4_COMPILED_KERNEL=y
No tmpfs
FREETZ_KERNEL_VERSION_2_6_32_21=y
FREETZ_MODULE_mbcache=y
FREETZ_LIB_libctlmgr_WITH_STRUCT_V1=y
What's the output of "mount" on this device? I can't believe that there is no tmpfs because this firmware would not work at all...
Regards
Oliver
root@fritz:/var# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
proc on /proc type proc (rw,relatime)
tmpfs on /var type tmpfs (rw,relatime)
dev on /dev type tmpfs (rw,nosuid,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/mtdblock5 on /data type jffs2 (rw,relatime)
/dev/loop0 on /var/media/ftp type ext2 (rw,relatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
But it's not only df that doesn't see /var
Zabbix is unable to see the free space of /var
There has to be something that's off.....
