manuel@bigbrother:/public/sources/fritzbox/ffgtk-0.6.2> make distclean
Making distclean in plugins
make[1]: Entering directory `/public/sources/fritzbox/ffgtk-0.6.2/plugins'
rm -rf .libs _libs
test -z "lib_rl_oertliche.la lib_rl_11880.la lib_rl_goyellow.la lib_rl_gelbeseiten.la lib_rl_fritzfon.la lib_ab_local.la lib_ab_thunderbird.la lib_fax_efax.la lib_fax_capifax.la" || rm -f lib_rl_oertliche.la lib_rl_11880.la lib_rl_goyellow.la lib_rl_gelbeseiten.la lib_rl_fritzfon.la lib_ab_local.la lib_ab_thunderbird.la lib_fax_efax.la lib_fax_capifax.la
rm -f "./so_locations"
rm -f *.o
rm -f *.lo
rm -f *.tab.c
test -z "" || rm -f
rm -f TAGS ID GTAGS GRTAGS GSYMS GPATH tags
rm -rf ./.deps
rm -f Makefile
make[1]: Leaving directory `/public/sources/fritzbox/ffgtk-0.6.2/plugins'
Making distclean in ffgtk
make[1]: Entering directory `/public/sources/fritzbox/ffgtk-0.6.2/ffgtk'
rm -f ffgtk ffgtk
rm -rf .libs _libs
rm -f *.o
rm -f *.lo
rm -f *.tab.c
test -z "" || rm -f
rm -rf ./.deps
rm -f Makefile
make[1]: Leaving directory `/public/sources/fritzbox/ffgtk-0.6.2/ffgtk'
Making distclean in po
make[1]: Entering directory `/public/sources/fritzbox/ffgtk-0.6.2/po'
rm -f *.pox ffgtk.pot *.old.po cat-id-tbl.tmp
rm -f .intltool-merge-cache
rm -f Makefile Makefile.in POTFILES stamp-it
rm -f *.mo *.msg *.cat *.cat.m *.gmo
make[1]: Leaving directory `/public/sources/fritzbox/ffgtk-0.6.2/po'
Making distclean in .
make[1]: Entering directory `/public/sources/fritzbox/ffgtk-0.6.2'
rm -rf .libs _libs
rm -f *.lo
test -z "" || rm -f
test -z "ffgtk.desktop intltool-extract intltool-merge intltool-update" || rm -f ffgtk.desktop intltool-extract intltool-merge intltool-update
rm -f config.h stamp-h1
rm -f libtool
make[1]: Leaving directory `/public/sources/fritzbox/ffgtk-0.6.2'
rm -f config.status config.cache config.log configure.lineno config.status.lineno
rm -f Makefile
manuel@bigbrother:/public/sources/fritzbox/ffgtk-0.6.2> autoconf
manuel@bigbrother:/public/sources/fritzbox/ffgtk-0.6.2> ./configure --prefix=/usr --sysconfdir=/etc
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for gcc... yes
checking whether gcc and cc understand -c and -o together... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /usr/bin/sed
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ld used by gcc... /usr/i586-suse-linux/bin/ld
checking if the linker (/usr/i586-suse-linux/bin/ld) is GNU ld... yes
checking for /usr/i586-suse-linux/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognize dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... no
checking for g95... no
checking for xlf95... no
checking for f95... no
checking for fort... no
checking for ifort... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for ftn... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether accepts -g... no
checking the maximum length of command line arguments... 98304
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/i586-suse-linux/bin/ld
checking whether the g++ linker (/usr/i586-suse-linux/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ static flag -static works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for g_thread_init in -lgthread-2.0... yes
checking for msgmerge... /usr/bin/msgmerge
checking for xgettext... /usr/bin/xgettext
checking for pkg-config... /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking for EXTRA... yes
checking for gstreamer-0.10... no
checking for libebook-1.2... no
checking for capifax... yes
checking for intltool-update... /usr/bin/intltool-update
checking for intltool-merge... /usr/bin/intltool-merge
checking for intltool-extract... /usr/bin/intltool-extract
checking for msgfmt... /usr/bin/msgfmt
checking for perl... /usr/bin/perl
checking for XML::Parser... ok
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for ngettext in libc... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... (cached) /usr/bin/msgfmt
checking for dcgettext... yes
checking if msgfmt accepts -c... yes
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... (cached) /usr/bin/xgettext
configure: creating ./config.status
config.status: creating Makefile
config.status: creating po/Makefile.in
config.status: creating ffgtk/Makefile
config.status: creating plugins/Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing default-1 commands
config.status: executing po/stamp-it commands
make all-recursive
Making all in po
make[2]: Entering directory `/public/sources/fritzbox/ffgtk-0.6.2/po'
file=`echo de | sed 's,.*/,,'`.gmo \
&& rm -f $file && /usr/bin/msgfmt -o $file de.po
make[2]: Leaving directory `/public/sources/fritzbox/ffgtk-0.6.2/po'
Making all in ffgtk
make[2]: Entering directory `/public/sources/fritzbox/ffgtk-0.6.2/ffgtk'
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-about-dialog.o -MD -MP -MF .deps/ffgtk-about-dialog.Tpo -c -o ffgtk-about-dialog.o `test -f 'about-dialog.c' || echo './'`about-dialog.c
mv -f .deps/ffgtk-about-dialog.Tpo .deps/ffgtk-about-dialog.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-address-add.o -MD -MP -MF .deps/ffgtk-address-add.Tpo -c -o ffgtk-address-add.o `test -f 'address-add.c' || echo './'`address-add.c
mv -f .deps/ffgtk-address-add.Tpo .deps/ffgtk-address-add.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-address-dialog.o -MD -MP -MF .deps/ffgtk-address-dialog.Tpo -c -o ffgtk-address-dialog.o `test -f 'address-dialog.c' || echo './'`address-dialog.c
mv -f .deps/ffgtk-address-dialog.Tpo .deps/ffgtk-address-dialog.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-main.o -MD -MP -MF .deps/ffgtk-main.Tpo -c -o ffgtk-main.o `test -f 'main.c' || echo './'`main.c
mv -f .deps/ffgtk-main.Tpo .deps/ffgtk-main.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-preferences.o -MD -MP -MF .deps/ffgtk-preferences.Tpo -c -o ffgtk-preferences.o `test -f 'preferences.c' || echo './'`preferences.c
mv -f .deps/ffgtk-preferences.Tpo .deps/ffgtk-preferences.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-server.o -MD -MP -MF .deps/ffgtk-server.Tpo -c -o ffgtk-server.o `test -f 'server.c' || echo './'`server.c
mv -f .deps/ffgtk-server.Tpo .deps/ffgtk-server.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-monitor.o -MD -MP -MF .deps/ffgtk-monitor.Tpo -c -o ffgtk-monitor.o `test -f 'monitor.c' || echo './'`monitor.c
mv -f .deps/ffgtk-monitor.Tpo .deps/ffgtk-monitor.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-urlHandler.o -MD -MP -MF .deps/ffgtk-urlHandler.Tpo -c -o ffgtk-urlHandler.o `test -f 'urlHandler.c' || echo './'`urlHandler.c
mv -f .deps/ffgtk-urlHandler.Tpo .deps/ffgtk-urlHandler.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-strings.o -MD -MP -MF .deps/ffgtk-strings.Tpo -c -o ffgtk-strings.o `test -f 'strings.c' || echo './'`strings.c
mv -f .deps/ffgtk-strings.Tpo .deps/ffgtk-strings.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-ffgtk.o -MD -MP -MF .deps/ffgtk-ffgtk.Tpo -c -o ffgtk-ffgtk.o `test -f 'ffgtk.c' || echo './'`ffgtk.c
mv -f .deps/ffgtk-ffgtk.Tpo .deps/ffgtk-ffgtk.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-rl.o -MD -MP -MF .deps/ffgtk-rl.Tpo -c -o ffgtk-rl.o `test -f 'rl.c' || echo './'`rl.c
mv -f .deps/ffgtk-rl.Tpo .deps/ffgtk-rl.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-plugins.o -MD -MP -MF .deps/ffgtk-plugins.Tpo -c -o ffgtk-plugins.o `test -f 'plugins.c' || echo './'`plugins.c
mv -f .deps/ffgtk-plugins.Tpo .deps/ffgtk-plugins.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-configfile.o -MD -MP -MF .deps/ffgtk-configfile.Tpo -c -o ffgtk-configfile.o `test -f 'configfile.c' || echo './'`configfile.c
mv -f .deps/ffgtk-configfile.Tpo .deps/ffgtk-configfile.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-csv.o -MD -MP -MF .deps/ffgtk-csv.Tpo -c -o ffgtk-csv.o `test -f 'csv.c' || echo './'`csv.c
mv -f .deps/ffgtk-csv.Tpo .deps/ffgtk-csv.Po
gcc -DHAVE_CONFIG_H -I. -I.. -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -MT ffgtk-print.o -MD -MP -MF .deps/ffgtk-print.Tpo -c -o ffgtk-print.o `test -f 'print.c' || echo './'`print.c
mv -f .deps/ffgtk-print.Tpo .deps/ffgtk-print.Po
/bin/sh ../libtool --tag=CC --mode=link gcc -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/freetype2 -I/usr/include/libpng12 -I/usr/include/dbus-1.0 -I/usr/lib/dbus-1.0/include -I/usr/include/libxml2 -DSOUNDSDIR=\"/usr/share/ffgtk/\" -DLIBDIR=\"/usr/lib/ffgtk/\" -rdynamic -Werror -D_GNU_SOURCE -O0 -g -g -O2 -L/lib -lnotify -lgtk-x11-2.0 -ldbus-glib-1 -lgdk-x11-2.0 -latk-1.0 -lgdk_pixbuf-2.0 -lpangocairo-1.0 -lpango-1.0 -lcairo -lgmodule-2.0 -ldl -ldbus-1 -lgobject-2.0 -lglib-2.0 -lxml2 -lcurl -o ffgtk ffgtk-about-dialog.o ffgtk-address-add.o ffgtk-address-dialog.o ffgtk-main.o ffgtk-preferences.o ffgtk-server.o ffgtk-monitor.o ffgtk-urlHandler.o ffgtk-strings.o ffgtk-ffgtk.o ffgtk-rl.o ffgtk-plugins.o ffgtk-configfile.o ffgtk-csv.o ffgtk-print.o -lgthread-2.0
../libtool: line 463: CDPATH: command not found
../libtool: line 1141: func_opt_split: command not found
libtool: Version mismatch error. This is libtool 2.2.4 Debian-2.2.4-0ubuntu3, but the
libtool: definition of this LT_INIT comes from an older release.
libtool: You should recreate aclocal.m4 with macros from libtool 2.2.4 Debian-2.2.4-0ubuntu3
libtool: and run autoconf again.
make[2]: *** [ffgtk] Fehler 63
make[2]: Leaving directory `/public/sources/fritzbox/ffgtk-0.6.2/ffgtk'
make[1]: *** [all-recursive] Fehler 1
make: *** [all] Fehler 2
