D/VPN_Connections( 1346): Read PS header line as USER PID PPID VSIZE RSS WCHAN PC NAME
D/VPN_Connections( 1346): PID is in column #1
D/VPN_Connections( 1346): VpncProcessHandler instantiated
D/VPN_Connections( 1346): Read vpnc process line as null
D/VPN_Connections( 1346): Attempt to read vpnc process id did not return anything
D/VPN_Connections( 1346): NetworkDatabase:allNetworks - Start
D/VPN_Connections( 1346): Preference Window: Creating new NetworkPreference
D/VPN_Connections( 1346): Adding NetworkPreference with ID:1
D/VPN_Connections( 1346): Monitoring will not start
D/VPN_Connections( 1346): filemanager: File: /data/data/org.codeandroid.vpnc_frontend/files/vpncexists, not copying
D/VPN_Connections( 1346): filemanager: File: /data/data/org.codeandroid.vpnc_frontend/files/vpnc-scriptexists, not copying
I/ActivityManager( 172): Displayed activity org.codeandroid.vpnc_frontend/.BackendFileManager: 184 ms (total 959 ms)
D/su ( 1363): 10217 org.codeandroid.vpnc_frontend executing 0 sh using shell /system/bin/sh : sh
D/VPN_Connections( 1346): filemanager: Done creating directory /dev/net with return code 0
D/VPN_Connections( 1346): filemanager: ln -s /dev/tun /dev/net/tun
D/su ( 1371): 10217 org.codeandroid.vpnc_frontend executing 0 sh using shell /system/bin/sh : sh
D/VPN_Connections( 1346): filemanager: Done creating sym link /dev/net/tun with return code 0
D/su ( 1378): 10217 org.codeandroid.vpnc_frontend executing 0 sh using shell /system/bin/sh : sh
D/VPN_Connections( 1346): filemanager: Done setting permission with return code 0
D/VPN_Connections( 1346): On Activity Result: resultcode 0
I/ActivityManager( 172): Displayed activity org.codeandroid.vpnc_frontend/.VPNC: 2688 ms (total 2688 ms)
D/VPN_Connections( 1346): long press handler, handling the choice
D/VPN_Connections( 1346): NetworkDatabase:singleNetwork - Start
D/su ( 1386): 10217 org.codeandroid.vpnc_frontend executing 0 sh using shell /system/bin/sh : sh
D/VPN_Connections( 1346): Enter IPSec gateway address:
D/VPN_Connections( 1346): IP hanswurst.dyndns.org
D/VPN_Connections( 1346): Enter IPSec ID for hanswurst.dyndns.org:
D/VPN_Connections( 1346): group id: [email protected]
D/VPN_Connections( 1346): Enter IPSec secret for [email protected]@hanswurst.dyndns.org:
D/VPN_Connections( 1346): group pwd PASSWORT
D/VPN_Connections( 1346): Enter username for hanswurst.dyndns.org:
D/VPN_Connections( 1346): user hans.wurst
D/VPN_Connections( 1346): Enter password for [email protected]:
D/VPN_Connections( 1346): password *****************
D/VPN_Connections( 1346): done interacting with vpnc
D/VPN_Connections( 1346): process stderr:
D/VPN_Connections( 1346): Read vpnc process line as root 1389 1388 1420 504 c00ce8f4 afd0df14 S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 1346): Read vpnc process id as 1389
D/VPN_Connections( 1346): vpnc still trying to connect. Will check again in 500 milliseconds
D/MobileDataStateTracker( 172): replacing old mInterfaceName (rmnet0) with rmnet0 for hipri
D/MobileDataStateTracker( 172): replacing old mInterfaceName (rmnet0) with rmnet0 for supl
D/MobileDataStateTracker( 172): replacing old mInterfaceName (rmnet0) with rmnet0 for mms
D/MobileDataStateTracker( 172): default Received state= CONNECTED, old= CONNECTED, reason= (unspecified), apnTypeList= default,supl,mms
D/NetworkLocationProvider( 172): onDataConnectionStateChanged 3
D/VPN_Connections( 1346): Read vpnc process line as root 1389 1388 1352 508 c005bc0c afd0ea7c S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/Tethering( 172): tun0 is not a tetherable iface, ignoring
D/VPN_Connections( 1346): Read vpnc process line as root 1389 1388 1360 596 c00ce8f4 afd0ec6c S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 1346): Read vpnc process line as root 1389 1388 1364 652 c00ce8f4 afd0ec6c S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 1346): process stdout: backing up dns and resolve.conf
D/VPN_Connections( 1346): Read vpnc process line as root 1389 1388 1364 660 c00ce8f4 afd0ec6c S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 1346): process stdout: vpnc-script ran to completion
D/VPN_Connections( 1346): process stderr: vpnc[1389]: can't open pidfile /var/run/vpnc/pid for writing
D/VPN_Connections( 1346): Connect string detected!
D/VPN_Connections( 1346): Monitoring is enabled and we should be connected to vpn connection #1
D/VPN_Connections( 1346): Will connect to service
D/VPN_Connections( 1346): MonitorServiceImpl.CTR()
D/VPN_Connections( 1346): MonitorServiceImpl.onCreate()
D/VPN_Connections( 1346): MonitorService.startMonitor called
D/VPN_Connections( 1346): Found a vpn id, will monitor it
D/VPN_Connections( 1346): MonitorServiceImpl.onStart()
D/VPN_Connections( 1346): onBind called on MonitorService for intent with action of org.codeandroid.vpnc_frontend.MonitorServiceImpl
D/VPN_Connections( 1346): Connected to monitor service
D/VPN_Connections( 1346): Read vpnc process line as root 1389 1388 1364 696 c00ce8f4 afd0df14 S /data/data/org.codeandroid.vpnc_frontend/files/vpnc
D/VPN_Connections( 1346): Monitor service: We're still connected
D/dalvikvm( 1221): GC_EXPLICIT freed 2151 objects / 134608 bytes in 76ms
D/dalvikvm( 1290): GC_FOR_MALLOC freed 3493 objects / 484536 bytes in 32ms
