G
gandalf94305
Guest
However, ISDN in the U.S. is different from ISDN in Europe, so you won't be able to connect any U.S. ISDN equipment, only European devices.
On analogue end devices you get in the U.S., you may have troubles with CLIP as signalling is different.
DSL won't work there, of course... but in most cases, you'll get a DSL Router from your ISP, anyway, so that's easy to take care of.
The only connectivity that's based on a global standard are the LAN (Ethernet) and WLAN features. ;-)
Cheers,
--gandalf.
Cheers,
--gandalf.
