capncrunch schrieb:
Kannst du die Debug-Ausgaben hier posten, nachdem du die Kontakte aus Outlook nochmal importierst?
--Brian
(21:42:33) DEBUG: logging to file "D:\JFritz\debug.txt" has been enabled
(21:42:33) DEBUG: Save directory: E:\Dokumente und Einstellungen\XXXXXX\Eigene Dateien\JFritz\
(21:42:34) DEBUG: Save other properties
(21:42:34) DEBUG: Saving to file E:\Dokumente und Einstellungen\XXXXXX\Eigene Dateien\JFritz\jfritz.properties.xml
(Update) Program version: 0.6.2.01
(Update) Locale: de_de
(Update) Update on start: false
(Update) Saving update-properties......done
(21:42:34) DEBUG: Found file to backup: jfritz.calls.xml
(21:42:34) DEBUG: Found file to backup: jfritz.phonebook.xml
(21:42:34) DEBUG: Found file to backup: jfritz.properties.xml
(21:42:34) DEBUG: Found file to backup: jfritz.sipprovider.xml
(21:42:34) DEBUG: Found file to backup: jfritz.window.properties.xml
(21:42:34) DEBUG: Operating System : Windows XP
(21:42:34) DEBUG: JFritz runs on Windows
(21:42:34) DEBUG: Loading the german number to city list
(21:42:34) DEBUG: Subdirectory: /number
(21:42:34) DEBUG: full path: D:\JFritz/number
(21:42:34) DEBUG: 5205 Lines read from areacodes_germany.csv
(21:42:34) DEBUG: numberMap size: 5204
(21:42:34) DEBUG: Loading the austrian number to city list
(21:42:34) DEBUG: 1029 Lines read from areacodes_austria.csv
(21:42:34) DEBUG: numberMap size: 1029
(21:42:34) DEBUG: Urlstr:
http://192.168.178.1:80/cgi-bin/webcm
(21:42:34) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=home&var%3Apagename=home&login%3Acommand%2Fpassword=XXXXXXXXXXX
(21:42:35) DEBUG: Detected Firmware: 29.04.22 de
(21:42:35) DEBUG: Saving to file E:\Dokumente und Einstellungen\XXXXXX\Eigene Dateien\JFritz\jfritz.phonebook.xml
(21:42:36) DEBUG: Sorting unfiltered data
(21:42:36) DEBUG: searching lastCall for allPersons in the phonebook....
(21:42:36) DEBUG: ...done
(21:42:36) DEBUG: searching all Persons for the CallerList...
(21:42:36) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.callmonitor.DisplayCallsMonitor@1fc4bec
(21:42:36) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.callmonitor.DisconnectMonitor@1bab50a
(21:42:36) DEBUG: Start commandline parsing
(21:42:36) DEBUG: Multiple instance lock: set lock.
(21:42:36) DEBUG: New instance of JFrame
(21:42:36) DEBUG: Create JFritz-GUI
(21:42:37) DEBUG: reading Buttons
(21:42:37) DEBUG: Subdirectory: \lang
(21:42:37) DEBUG: full path: D:\JFritz\lang
(21:42:37) DEBUG: CallMonitorList: Added new event listener de.moonflower.jfritz.monitoring.CurrentCallsTable@1a52fdf
(21:42:37) DEBUG: Check Systray-Support
(21:42:37) DEBUG: Action fetchList
(21:42:37) DEBUG: Starting FBoxListener
(21:42:37) DEBUG: FBoxListener V3
(21:42:37) DEBUG: box.address: 192.168.178.1
(21:42:37) DEBUG: box.port: 80
(21:42:37) DEBUG: box.password: XXXXXXXXXXX
(21:42:37) DEBUG: Trying to connect to 192.168.178.1:1012
(21:42:37) DEBUG: Searching for FritzBox per UPnP / SSDP
(21:42:37) DEBUG: box.firmware: 29.04.22 de
(21:42:37) DEBUG: Opening HTML Callerlist page
(21:42:37) DEBUG: Urlstr:
(21:42:37) DEBUG: Postdata: getpage=../html/de/menus/menu2.html&var%3Alang=de&var%3Amenu=fon&var%3Apagename=foncalls&login%3Acommand%2Fpassword=XXXXXXXXXXX
(21:42:37) DEBUG: Connected
(21:42:38) DEBUG: Timeout for SSDP
(21:42:38) DEBUG: Box found at /192.168.178.1: XXXXXXX UPnP/1.0 AVM FRITZ!Box Fon WLAN 7170 (UI) 29.04.22
(21:42:38) DEBUG: Watchdog enabled
(21:42:42) DEBUG: Retrieving the CSV list from the box
(21:42:42) DEBUG: Received response, begin processing call list
(21:42:42) DEBUG: CSV-Header: Typ;Datum;Name;Rufnummer;Nebenstelle;Eigene Rufnummer;Dauer
(21:42:43) DEBUG: Show JFritz-Window
(21:42:54) DEBUG: 338 Lines read from csv file
(21:42:54) DEBUG: 0 New entries processed
(21:42:54) DEBUG: Sorting unfiltered data
(21:42:54) DEBUG: Time used to import CSV-File: 12548ms
(21:42:54) DEBUG: Finished processing response
Hoffe, dass dich diese Angaben schlauer machen. Danke schon mal im Voraus!
trodat21
