Speedport W920V zu Fritzbox 7270 flashen?! Teil 2
Eine Frage noch
Wenn ich jetzt die AVM Firmware (FW) auf der BOX habe – reicht dann der FW Update auf der neuen AVM WEB Oberfläche? Es kommt zwar die Meldung, dass das nicht die richtige FW ist. Trotzdem hat es aber geklappt. Danach führe ich noch den Punkt FRITZ!Box neu starten und Werkseinstellungen laden aus.
download_speed-to-fritz.sh
Hardware type (Speedport W920V)
[**] Select a special T-Home Firmware
T-Home alternative Firmware (TCOM_BETA_74)
Select Firmware default language (de - german)
[**] Select a special AVM Firmware as 2nd Firmware
Labor or any other non default (AIO - Alles in einem prerelease)
[**] 3rd Firmware (only for experiments!)
All possible Firmware (AVM_AIO_7270_14518)
Annex (B)
[ ] Set Branding (NEW)
Untermenu Options
[ ] Restore original T-Home Firmware (NEW)
[ ] Push Firmware to box via FTP
[**] COPY HEADER (NEW)
[**] Add modinfo icon on status page (NEW)
[ ] Set Timeout for reconnect to 3600 (NEW)
[**] Include reverse lookup patch (NEW)
[**] Onlinecounter volume patch
[**] Unusable menu's (remove) (NEW)
[**] Support menu-item (add) (NEW)
[**] Assistant menu-item (replace) (NEW)
[ ] Show GSM Page, if present (NEW)
[ ] Own product name (setup) (NEW)
[ ] Box hostname (setup) (NEW)
[ ] Box MOD ID (setup) (NEW)
[ ] Box Hardware revision (setup) (NEW)
[ ] add ext2 (ext3) driver (NEW)
[ ] Use source 3 webfiles (NEW)
--- DSL Options ---
[ ] Remove ADSL - ATA only (NEW)
[ ] Use source 3 DSL web files (NEW)
[ ] Use T-Home ksldmod driver (NEW)
[ ] Use T-Home pcmlink driver (NEW)
[ ] Use source 3 ksldmod driver (NEW)
[ ] Use source 3 (V)DSL driver (NEW)
[ ] Use own (V)DSL driver (NEW)
[**] Force T-Home (V)DSL driver (NEW)
[ ] Save source 3 (V)DSL driver (NEW)
[ ] Save T-Home (V)DSL driver (NEW)
[ ] Wrap dsld (NEW)
--- SYSTEM Options ---
[ ] Xchange kernel between T-Home and avm source (NEW)
[ ] Take kernel from source 3 (NEW)
[ ] Force use of T-Home piglet driver (NEW)
[**] Force use of T-Home LED driver (NEW)
[ ] Force use of T-Home fon driver (NEW)
[ ] Copy addon/tmp (NEW)
[ ] Update module dependency information (NEW)
[**] MOVE ALL to OEM (NEW)
[ ] MOVE avm to OEM (NEW)
[**] Clear mtd3 and mtd4 (NEW)
[ ] Enable TR069 disable ATA (NEW)
[**] Enable LAN autoconfiguration TR064 (NEW)
--- TEST Options ---
[**] Verbose display for debugging (NEW)
[ ] Just do a setup run (NEW)
[ ] Keep configuration (NEW)
[ ] Do not STOP on ERROR (NEW)
[ ] Do DIFF between AVM source and source 3 (NEW)
[ ] Do DIFF between T-Home source and source 3 (NEW)
[ ] Do final DIFF, show changes on AVM source (NEW)
[ ] Do final DIFF, show difference to source 3 (NEW)
[ ] Do KDIFF3, show AVM source, source 3 and T-Home (NEW)
[ ] Do final KDIFF3, show changed AVM, original AVM and source 3 (NEW)
--- Netcard Options ---
[ ] Setup a fixed Netcard port (NEW)
[ ] Setup a fixed FTP IP Address (NEW)
P.S.
[**] weil das [*] einen CRLF unterdrückt
@MrBean
mit der 3rd Firmware soll es nun klappen?
Halt uns auf dem Laufenden.
@mr.bean:
wieso zweimal die aio?
hmr.Bean klappt das bei dir??
hab das gerade veruscht und folgendes wird gemeldet:
21.06.09 13:31:39 Internetverbindung wurde getrennt.
21.06.09 13:31:39 Zeitüberschreitung bei der PPP-Aushandlung.
21.06.09 13:30:47 Die FRITZ!Box-Einstellungen wurden über die Benutzeroberfläche geändert.
21.06.09 13:30:39 Anmeldung an der FRITZ!Box Benutzeroberfläche von IP-Adresse 192.168.178.20.
21.06.09 13:30:27 DSL ist verfügbar (DSL-Synchronisierung besteht mit 16468/1148 kbit/s).
21.06.09 13:30:12 DSL-Synchronisierung beginnt (Training).
21.06.09 13:29:56 DSL antwortet nicht (Keine DSL-Synchronisierung).
21.06.09 13:26:20 DSL ist verfügbar (DSL-Synchronisierung besteht mit 16432/1148 kbit/s).
21.06.09 13:26:20 DSL-Synchronisierung beginnt (Training).
Mit der Option "Use T-Home ksldmod driver" hat es nicht funktioniert. Sehe im Ereignis nur den DSL Sync. Die Anmeldung fehlt dort, obwohl ich die Providerdaten eingetragen habe.
Erstelle mir nochmal die FW zusammen. Vielleicht klappt es dann...
@BurningCrash
wurde im Posting 1597 ebenfalls angewandt - habe es einfach übernommen
Hallo meierchen006,
So wie auf dein Screenshot sieht es bei mir auch aus Ausser das ich 1728 Down und 224 Upload habe.
Ich habe diese drauf
fw_Speedport_W920V_65.04.74-0_Fritz_Box_DECT_W920V_54.04.74-14518-sp2fr-09.06.19-r-346M_OEM-avm_annexB.image
Aber das hier tritt bei mir nich auf. blinkt die Online LED grün und die Status LED rot
Ich sehe gerade auf dem Screenshot von meierchen006
DSL Version:
9.5.2.1.1.6 A
mit meiner 7570-72 Firmware habe ich
DSL-Version
9.5.3.0.1.6 A
liegt es daran, daß mein DSLAM eine höhere Version braucht um eine Verbindung aufzubauen?
Was wiederum nicht sein kann, schließlich "synct" er ja.
Mit der DSL Option "Use T-Home ksldmod driver" geht es nicht. Weiterhin sehe ich im Ereignis keine Provideranmeldung.
P.S. Kann mir einer meine Frage vom Post 1621 beantworten?
Ich habe bisher nur über die Weboberfläche das Update durchgeführt.
so ich jetzt auch - habe mich getraut....
Folgende FW habe ich genutzt:
fw_Speedport_W920V_65.04.74-0_Fritz_Box_DECT_W920V_54.04.74-14518-sp2fr-09.06.04_OEM-avm_annexB.image
Habe die Firmware.conf von Mac_ aus der Script Tabelle genutzt.
Mein vorgehen:
- habe diese FW per Webinterface auf die Box gebracht
- nachdem Neu - Start der Box blinkte die Status LED - ROT
- die Online LED blinkte GRÜN
- Splitterkabel abgezogen nach 20 Sek. wieder angesteckt
Online gewesen... alles OK Vielen Dank an alle Mitwirkenden
"Warten auf die Finale FW" :-Ö
war bei mir genauso @ moonsorrox
Ich habe nur nach dem Flashen - noch mal Werkseinstellungen gemacht und alles eingegeben.
DSL gezogen und genau in dem Momente blinkte status und Online erst.
Dann ging DSL weg und ich habe es eingesteckt. Dann ging er Online.
Hallo Hauptmann Eric,
genauso wie Du schreibst
Online LED grün
Status LED rot
Hier mal ein Screenshot von mir, damit geht keine Einwahl.
also ohne "Use T-Home ksldmod driver" die fw ^^ dann klappts auch
die fw läuft ohne große anpassung in sachen wrap dsl oder "Use T-Home ksldmod driver".
ohne alles halt :)
@_Sven_
du hast das nur mit dem 201 die FW zum laufen gebracht?
Hallo Swen,
Du hast doch ADSL2+, dies läuft doch eigentlich unter VDSL also solltest Du doch keine Probleme haben mit der Firmware.
Ich sehe aber das bei deiner Firmware kein löschen des mtd3 und mtd4 gemacht wurde, warum?
Dann kann es auch zu Problemen kommen, deshal ist es jetzt ja standartmäßig eingeschaltet.
Ja ohne geht überhaupt nicht, auch nicht mit Trick (oder Kabel ziehen). Clear 3+4, Werksreset usw. habe ich alles durch keine Chance.
@meierchen006: Weil ich nicht alle paar Minuten die Signatur anpasse ;) Das ist noch von dem Update auf die letzte Labor, bevor ich mit dem Basteln angefangen habe...
--EDIT--
Wie ich auf einer der Seiten weiter vorne schon gesagt habe, beim Kumpel sync er und geht online. Gleiche Firmware und sonst keine Änderungen außer eben Reset an einem DSL6000-Anschluss
heyho alle
also hab jetz 2 speedport w920v erfolgreich auf 'fw_SpeedportW920V_v_65.04.74.image'.
AVM Systemimage:'FRITZ.Box_Fon_WLAN_7270.Labor.54.04.74-14518.image'. geflasht ohne probleme ... ohne mac conf ... nur richtigen router gewahlt und drunter die 2 puntke ausgewahlt .. sonst standart config ! p.s. ich hab immer auf virtuele maschiene immer auf bridged und wenn man feste ip vergibt sollte man nach dem der script auf reboot der box wartet auch ins fritznetz wechseln (192.168.178.x) damit der script fertig lauft und die weboberlfache auch funktioniert XP
TEST: 2 Router w920v hinter 2 verschieden leitung ... einma ein vdsl25 .. keine probleme
... und einem tdsl 16 000 .. auch ohne probleme online ... was allerdings ungewöhnlich ist was ich die tage nochmal testen will das die avm box sagt nur ein dsl 2000 mit 228 up ... extrem wenig glaube vorher ging mehr rein ... werde es nochmla mit der orginal firmware brobieren obs da unterscheide gibt .... aber an sich scheint alles soweit zu funktionieren (dyndns,tapi,vpn) ... ausser die anzeige wieviel mb down geladen wurden (Übertragungsvolumen Downstream (MB)) zeigt er nicht an und Resyncs ..
werde weiter testen und bericht geben
