Apr 21 15:41:32 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:34 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:34 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.101
Apr 21 15:41:34 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:36 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:36 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.30
Apr 21 15:41:36 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:38 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:39 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.34
Apr 21 15:41:39 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:41 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:42 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.26
Apr 21 15:41:42 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:44 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.25
Apr 21 15:41:44 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:46 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:47 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.105
Apr 21 15:41:47 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:49 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:50 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.251
Apr 21 15:41:50 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:52 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:52 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.22
Apr 21 15:41:52 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:54 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:56 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.35
Apr 21 15:41:56 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:41:58 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:41:58 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:41:58 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:00 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:00 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:42:00 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:01 raspberrypi CRON[28317]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:42:01 raspberrypi CRON[28317]: pam_unix(cron:session): session closed for user root
Apr 21 15:42:02 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:02 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:42:02 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:03 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:42:03 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:03 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:03 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:42:03 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:42:03 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:42:04 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:42:04 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:04 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:04 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:42:06 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/pgrep pilight-daemon
Apr 21 15:42:06 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:07 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:35 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:42:35 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:35 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:35 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:42:35 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:42:35 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:42:36 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:42:36 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:36 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:36 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:42:40 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/local/bin/pilight-send -p intertechno_old -i 2 -u 0 -f
Apr 21 15:42:40 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:41 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:43 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.100
Apr 21 15:42:43 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:45 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:45 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.102
Apr 21 15:42:45 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:47 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:48 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.1
Apr 21 15:42:48 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:50 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:50 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.3
Apr 21 15:42:50 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:52 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:53 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.36
Apr 21 15:42:53 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:55 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:55 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.101
Apr 21 15:42:55 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:42:58 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:42:59 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.30
Apr 21 15:42:59 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:01 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:01 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.34
Apr 21 15:43:01 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:01 raspberrypi CRON[28493]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:43:01 raspberrypi CRON[28493]: pam_unix(cron:session): session closed for user root
Apr 21 15:43:03 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:04 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.26
Apr 21 15:43:04 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:06 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:06 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.25
Apr 21 15:43:06 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:08 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:10 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.105
Apr 21 15:43:10 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:12 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:13 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.251
Apr 21 15:43:13 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:15 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:15 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.22
Apr 21 15:43:15 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:17 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:19 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.35
Apr 21 15:43:19 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:21 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:21 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:43:21 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:23 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:23 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:43:23 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:25 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:26 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:43:26 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:26 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:26 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:43:27 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:43:27 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:27 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:27 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:43:27 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:43:27 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:43:30 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/pgrep pilight-daemon
Apr 21 15:43:30 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:31 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:59 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:43:59 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:43:59 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:43:59 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:43:59 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:43:59 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:44:00 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:44:00 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:00 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:00 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:44:01 raspberrypi CRON[28670]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:44:01 raspberrypi CRON[28670]: pam_unix(cron:session): session closed for user root
Apr 21 15:44:04 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/local/bin/pilight-send -p intertechno_old -i 2 -u 0 -f
Apr 21 15:44:04 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:04 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:06 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.100
Apr 21 15:44:06 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:08 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:08 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.102
Apr 21 15:44:08 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:10 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:11 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.1
Apr 21 15:44:11 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:13 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:13 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.3
Apr 21 15:44:13 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:15 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:16 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.36
Apr 21 15:44:16 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:18 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:18 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.101
Apr 21 15:44:18 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:20 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:21 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.30
Apr 21 15:44:21 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:23 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:24 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.34
Apr 21 15:44:24 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:26 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:26 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.26
Apr 21 15:44:26 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:28 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:28 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.25
Apr 21 15:44:28 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:30 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:32 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.105
Apr 21 15:44:32 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:34 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:35 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.251
Apr 21 15:44:35 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:37 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:37 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.22
Apr 21 15:44:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:39 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:41 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.35
Apr 21 15:44:41 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:43 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:43 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:44:43 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:45 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:45 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:44:45 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:47 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:48 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:44:48 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:48 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:44:49 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:49 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:44:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:44:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:44:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:44:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:44:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:44:52 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/pgrep pilight-daemon
Apr 21 15:44:52 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:44:52 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:01 raspberrypi CRON[28839]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:45:01 raspberrypi CRON[28839]: pam_unix(cron:session): session closed for user root
Apr 21 15:45:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:45:20 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:20 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:45:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:45:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:45:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:45:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:45:25 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/local/bin/pilight-send -p intertechno_old -i 2 -u 0 -f
Apr 21 15:45:25 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:25 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:27 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.100
Apr 21 15:45:27 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:29 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:29 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.102
Apr 21 15:45:29 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:31 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:32 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.1
Apr 21 15:45:32 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:34 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:34 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.3
Apr 21 15:45:34 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:36 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:37 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.36
Apr 21 15:45:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:39 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:39 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.101
Apr 21 15:45:39 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:41 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:43 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.30
Apr 21 15:45:43 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:45 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:45 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.34
Apr 21 15:45:45 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:47 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.26
Apr 21 15:45:49 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:51 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:51 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.25
Apr 21 15:45:51 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:53 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:54 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.105
Apr 21 15:45:54 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:45:56 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:45:58 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.251
Apr 21 15:45:58 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:00 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:00 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.22
Apr 21 15:46:00 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:01 raspberrypi CRON[28994]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:46:01 raspberrypi CRON[28994]: pam_unix(cron:session): session closed for user root
Apr 21 15:46:02 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:02 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.35
Apr 21 15:46:02 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:04 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:04 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:46:04 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:06 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:06 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:46:06 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:09 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:10 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:46:10 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:10 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:11 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:46:11 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:11 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:12 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:46:12 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:12 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:12 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:46:12 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:46:12 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:46:12 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:46:15 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/pgrep pilight-daemon
Apr 21 15:46:15 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:15 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:46:44 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:44 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:46:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:46:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:46:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:46:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:46:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/local/bin/pilight-send -p intertechno_old -i 2 -u 0 -f
Apr 21 15:46:49 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:49 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:51 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.100
Apr 21 15:46:51 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:53 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:53 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.102
Apr 21 15:46:53 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:55 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:57 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.1
Apr 21 15:46:57 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:46:59 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:46:59 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.3
Apr 21 15:46:59 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:01 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:01 raspberrypi CRON[29171]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:47:02 raspberrypi CRON[29171]: pam_unix(cron:session): session closed for user root
Apr 21 15:47:02 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.36
Apr 21 15:47:02 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:04 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:04 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.101
Apr 21 15:47:04 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:06 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:08 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.30
Apr 21 15:47:08 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:10 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:10 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.34
Apr 21 15:47:10 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:12 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:13 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.26
Apr 21 15:47:13 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:15 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:15 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.25
Apr 21 15:47:15 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:17 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:19 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.105
Apr 21 15:47:19 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:21 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:22 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.251
Apr 21 15:47:22 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:24 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:24 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.22
Apr 21 15:47:24 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:26 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:28 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.35
Apr 21 15:47:28 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:30 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:30 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:47:30 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:32 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:32 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:47:32 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:34 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:37 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:47:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:37 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:38 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:47:38 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:38 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:38 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:47:38 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:47:39 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:47:39 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:39 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:47:39 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:47:39 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:47:41 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/pgrep pilight-daemon
Apr 21 15:47:41 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:47:41 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:01 raspberrypi CRON[29327]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:48:01 raspberrypi CRON[29327]: pam_unix(cron:session): session closed for user root
Apr 21 15:48:08 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:48:08 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:08 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:08 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:48:08 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:48:09 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:48:09 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:09 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:09 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:48:09 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:48:16 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/local/bin/pilight-send -p intertechno_old -i 2 -u 0 -f
Apr 21 15:48:16 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:16 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:17 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.100
Apr 21 15:48:17 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:19 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:20 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.102
Apr 21 15:48:20 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:22 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:23 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.1
Apr 21 15:48:23 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:25 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:25 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.3
Apr 21 15:48:25 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:27 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:27 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.36
Apr 21 15:48:27 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:29 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:29 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.101
Apr 21 15:48:29 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:31 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:32 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.30
Apr 21 15:48:32 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:34 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:34 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.34
Apr 21 15:48:34 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:36 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:37 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.26
Apr 21 15:48:37 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:39 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:39 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.25
Apr 21 15:48:39 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:41 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:41 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.105
Apr 21 15:48:41 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:43 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:44 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.251
Apr 21 15:48:44 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:46 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:46 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.22
Apr 21 15:48:46 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:48 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:49 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.35
Apr 21 15:48:49 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:51 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:51 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:48:51 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:53 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:53 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/ping -w 2 192.168.178.31
Apr 21 15:48:53 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:55 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:55 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:48:56 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:56 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:48:56 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_temp
Apr 21 15:48:56 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock arm
Apr 21 15:48:56 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_volts core
Apr 21 15:48:56 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/vcgencmd measure_clock core
Apr 21 15:48:56 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/free
Apr 21 15:48:57 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/bin/df
Apr 21 15:48:57 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:48:57 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:49:01 raspberrypi CRON[29514]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:49:01 raspberrypi CRON[29514]: pam_unix(cron:session): session closed for user root
Apr 21 15:49:01 raspberrypi sudo: www-data : TTY=unknown ; PWD=/var/www/sas4 ; USER=root ; COMMAND=/usr/bin/pgrep pilight-daemon
Apr 21 15:49:01 raspberrypi sudo: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 21 15:49:01 raspberrypi sudo: pam_unix(sudo:session): session closed for user root
Apr 21 15:50:01 raspberrypi CRON[29867]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:50:01 raspberrypi CRON[29867]: pam_unix(cron:session): session closed for user root
Apr 21 15:51:01 raspberrypi CRON[30291]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:51:01 raspberrypi CRON[30291]: pam_unix(cron:session): session closed for user root
Apr 21 15:52:01 raspberrypi CRON[30727]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:52:01 raspberrypi CRON[30727]: pam_unix(cron:session): session closed for user root
Apr 21 15:53:01 raspberrypi CRON[31153]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:53:01 raspberrypi CRON[31153]: pam_unix(cron:session): session closed for user root
Apr 21 15:54:01 raspberrypi CRON[31573]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:54:02 raspberrypi CRON[31573]: pam_unix(cron:session): session closed for user root
Apr 21 15:55:01 raspberrypi CRON[32006]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:55:01 raspberrypi CRON[32006]: pam_unix(cron:session): session closed for user root
Apr 21 15:56:01 raspberrypi CRON[32435]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:56:01 raspberrypi CRON[32435]: pam_unix(cron:session): session closed for user root
Apr 21 15:57:01 raspberrypi CRON[395]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:57:01 raspberrypi CRON[395]: pam_unix(cron:session): session closed for user root
Apr 21 15:58:01 raspberrypi CRON[830]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:58:01 raspberrypi CRON[830]: pam_unix(cron:session): session closed for user root
Apr 21 15:59:01 raspberrypi CRON[1256]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 15:59:01 raspberrypi CRON[1256]: pam_unix(cron:session): session closed for user root
Apr 21 16:00:01 raspberrypi CRON[1690]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:00:01 raspberrypi CRON[1690]: pam_unix(cron:session): session closed for user root
Apr 21 16:01:01 raspberrypi CRON[2122]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:01:01 raspberrypi CRON[2122]: pam_unix(cron:session): session closed for user root
Apr 21 16:02:02 raspberrypi CRON[2572]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:02:02 raspberrypi CRON[2572]: pam_unix(cron:session): session closed for user root
Apr 21 16:03:01 raspberrypi CRON[3005]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:03:01 raspberrypi CRON[3005]: pam_unix(cron:session): session closed for user root
Apr 21 16:04:01 raspberrypi CRON[3432]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:04:01 raspberrypi CRON[3432]: pam_unix(cron:session): session closed for user root
Apr 21 16:05:01 raspberrypi CRON[3870]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:05:01 raspberrypi CRON[3870]: pam_unix(cron:session): session closed for user root
Apr 21 16:06:01 raspberrypi CRON[4297]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:06:01 raspberrypi CRON[4297]: pam_unix(cron:session): session closed for user root
Apr 21 16:07:01 raspberrypi CRON[4727]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:07:01 raspberrypi CRON[4727]: pam_unix(cron:session): session closed for user root
Apr 21 16:08:01 raspberrypi CRON[5160]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:08:01 raspberrypi CRON[5160]: pam_unix(cron:session): session closed for user root
Apr 21 16:09:02 raspberrypi CRON[5590]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:09:02 raspberrypi CRON[5589]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:09:02 raspberrypi CRON[5590]: pam_unix(cron:session): session closed for user root
Apr 21 16:09:03 raspberrypi CRON[5589]: pam_unix(cron:session): session closed for user root
Apr 21 16:10:01 raspberrypi CRON[6025]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:10:01 raspberrypi CRON[6025]: pam_unix(cron:session): session closed for user root
Apr 21 16:11:01 raspberrypi CRON[6452]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:11:01 raspberrypi CRON[6452]: pam_unix(cron:session): session closed for user root
Apr 21 16:12:01 raspberrypi CRON[6878]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:12:01 raspberrypi CRON[6878]: pam_unix(cron:session): session closed for user root
Apr 21 16:13:01 raspberrypi CRON[7314]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:13:01 raspberrypi CRON[7314]: pam_unix(cron:session): session closed for user root
Apr 21 16:14:01 raspberrypi CRON[7740]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:14:01 raspberrypi CRON[7740]: pam_unix(cron:session): session closed for user root
Apr 21 16:15:01 raspberrypi CRON[8173]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:15:02 raspberrypi CRON[8173]: pam_unix(cron:session): session closed for user root
Apr 21 16:16:01 raspberrypi CRON[8592]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:16:01 raspberrypi CRON[8592]: pam_unix(cron:session): session closed for user root
Apr 21 16:17:01 raspberrypi CRON[9024]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:17:01 raspberrypi CRON[9025]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:17:01 raspberrypi CRON[9024]: pam_unix(cron:session): session closed for user root
Apr 21 16:17:01 raspberrypi CRON[9025]: pam_unix(cron:session): session closed for user root
Apr 21 16:18:01 raspberrypi CRON[9465]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:18:01 raspberrypi CRON[9465]: pam_unix(cron:session): session closed for user root
Apr 21 16:19:01 raspberrypi CRON[9891]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:19:01 raspberrypi CRON[9891]: pam_unix(cron:session): session closed for user root
Apr 21 16:20:01 raspberrypi CRON[10338]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:20:01 raspberrypi CRON[10338]: pam_unix(cron:session): session closed for user root
Apr 21 16:21:01 raspberrypi CRON[10764]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:21:01 raspberrypi CRON[10764]: pam_unix(cron:session): session closed for user root
Apr 21 16:22:01 raspberrypi CRON[11201]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:22:02 raspberrypi CRON[11201]: pam_unix(cron:session): session closed for user root
Apr 21 16:23:01 raspberrypi CRON[11626]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:23:01 raspberrypi CRON[11626]: pam_unix(cron:session): session closed for user root
Apr 21 16:24:01 raspberrypi CRON[12053]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:24:01 raspberrypi CRON[12053]: pam_unix(cron:session): session closed for user root
Apr 21 16:25:01 raspberrypi CRON[12486]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:25:01 raspberrypi CRON[12486]: pam_unix(cron:session): session closed for user root
Apr 21 16:26:01 raspberrypi CRON[12912]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:26:01 raspberrypi CRON[12912]: pam_unix(cron:session): session closed for user root
Apr 21 16:27:01 raspberrypi CRON[13344]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:27:01 raspberrypi CRON[13344]: pam_unix(cron:session): session closed for user root
Apr 21 16:28:01 raspberrypi CRON[13774]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:28:01 raspberrypi CRON[13774]: pam_unix(cron:session): session closed for user root
Apr 21 16:29:01 raspberrypi CRON[14205]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:29:01 raspberrypi CRON[14205]: pam_unix(cron:session): session closed for user root
Apr 21 16:30:01 raspberrypi CRON[14638]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:30:02 raspberrypi CRON[14638]: pam_unix(cron:session): session closed for user root
Apr 21 16:31:01 raspberrypi CRON[15057]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:31:01 raspberrypi CRON[15057]: pam_unix(cron:session): session closed for user root
Apr 21 16:32:01 raspberrypi CRON[15496]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:32:01 raspberrypi CRON[15496]: pam_unix(cron:session): session closed for user root
Apr 21 16:33:01 raspberrypi CRON[15922]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:33:01 raspberrypi CRON[15922]: pam_unix(cron:session): session closed for user root
Apr 21 16:34:01 raspberrypi CRON[16349]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:34:01 raspberrypi CRON[16349]: pam_unix(cron:session): session closed for user root
Apr 21 16:35:01 raspberrypi CRON[16786]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:35:01 raspberrypi CRON[16786]: pam_unix(cron:session): session closed for user root
Apr 21 16:36:01 raspberrypi CRON[17212]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:36:01 raspberrypi CRON[17212]: pam_unix(cron:session): session closed for user root
Apr 21 16:37:01 raspberrypi CRON[17646]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:37:02 raspberrypi CRON[17646]: pam_unix(cron:session): session closed for user root
Apr 21 16:38:01 raspberrypi CRON[18072]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:38:01 raspberrypi CRON[18072]: pam_unix(cron:session): session closed for user root
Apr 21 16:39:01 raspberrypi CRON[18499]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:39:01 raspberrypi CRON[18498]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:39:01 raspberrypi CRON[18499]: pam_unix(cron:session): session closed for user root
Apr 21 16:39:02 raspberrypi CRON[18498]: pam_unix(cron:session): session closed for user root
Apr 21 16:40:01 raspberrypi CRON[18942]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:40:01 raspberrypi CRON[18942]: pam_unix(cron:session): session closed for user root
Apr 21 16:41:01 raspberrypi CRON[19367]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:41:01 raspberrypi CRON[19367]: pam_unix(cron:session): session closed for user root
Apr 21 16:42:01 raspberrypi CRON[19802]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:42:01 raspberrypi CRON[19802]: pam_unix(cron:session): session closed for user root
Apr 21 16:43:01 raspberrypi CRON[20228]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:43:01 raspberrypi CRON[20228]: pam_unix(cron:session): session closed for user root
Apr 21 16:44:01 raspberrypi CRON[20661]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:44:02 raspberrypi CRON[20661]: pam_unix(cron:session): session closed for user root
Apr 21 16:45:01 raspberrypi CRON[21080]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:45:01 raspberrypi CRON[21080]: pam_unix(cron:session): session closed for user root
Apr 21 16:46:01 raspberrypi CRON[21512]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:46:01 raspberrypi CRON[21512]: pam_unix(cron:session): session closed for user root
Apr 21 16:47:01 raspberrypi CRON[21946]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:47:01 raspberrypi CRON[21946]: pam_unix(cron:session): session closed for user root
Apr 21 16:48:01 raspberrypi CRON[22369]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:48:01 raspberrypi CRON[22369]: pam_unix(cron:session): session closed for user root
Apr 21 16:49:01 raspberrypi CRON[22801]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:49:01 raspberrypi CRON[22801]: pam_unix(cron:session): session closed for user root
Apr 21 16:50:01 raspberrypi CRON[23235]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:50:01 raspberrypi CRON[23235]: pam_unix(cron:session): session closed for user root
Apr 21 16:51:01 raspberrypi CRON[23661]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:51:02 raspberrypi CRON[23661]: pam_unix(cron:session): session closed for user root
Apr 21 16:52:01 raspberrypi CRON[24083]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:52:01 raspberrypi CRON[24083]: pam_unix(cron:session): session closed for user root
Apr 21 16:53:01 raspberrypi CRON[24514]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:53:01 raspberrypi CRON[24514]: pam_unix(cron:session): session closed for user root
Apr 21 16:54:01 raspberrypi CRON[24941]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:54:01 raspberrypi CRON[24941]: pam_unix(cron:session): session closed for user root
Apr 21 16:55:01 raspberrypi CRON[25381]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:55:01 raspberrypi CRON[25381]: pam_unix(cron:session): session closed for user root
Apr 21 16:56:01 raspberrypi CRON[25807]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:56:01 raspberrypi CRON[25807]: pam_unix(cron:session): session closed for user root
Apr 21 16:57:01 raspberrypi CRON[26240]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:57:01 raspberrypi CRON[26240]: pam_unix(cron:session): session closed for user root
Apr 21 16:58:01 raspberrypi CRON[26668]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:58:01 raspberrypi CRON[26668]: pam_unix(cron:session): session closed for user root
Apr 21 16:59:02 raspberrypi CRON[27095]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 16:59:02 raspberrypi CRON[27095]: pam_unix(cron:session): session closed for user root
Apr 21 17:00:01 raspberrypi CRON[27521]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:00:01 raspberrypi CRON[27521]: pam_unix(cron:session): session closed for user root
Apr 21 17:01:01 raspberrypi CRON[27957]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:01:01 raspberrypi CRON[27957]: pam_unix(cron:session): session closed for user root
Apr 21 17:02:01 raspberrypi CRON[28391]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:02:01 raspberrypi CRON[28391]: pam_unix(cron:session): session closed for user root
Apr 21 17:03:01 raspberrypi CRON[28817]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:03:01 raspberrypi CRON[28817]: pam_unix(cron:session): session closed for user root
Apr 21 17:04:01 raspberrypi CRON[29244]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:04:01 raspberrypi CRON[29244]: pam_unix(cron:session): session closed for user root
Apr 21 17:05:01 raspberrypi CRON[29676]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:05:02 raspberrypi CRON[29676]: pam_unix(cron:session): session closed for user root
Apr 21 17:06:01 raspberrypi CRON[30101]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:06:01 raspberrypi CRON[30101]: pam_unix(cron:session): session closed for user root
Apr 21 17:07:01 raspberrypi CRON[30535]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:07:01 raspberrypi CRON[30535]: pam_unix(cron:session): session closed for user root
Apr 21 17:08:01 raspberrypi CRON[30961]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:08:01 raspberrypi CRON[30961]: pam_unix(cron:session): session closed for user root
Apr 21 17:09:01 raspberrypi CRON[31388]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:09:01 raspberrypi CRON[31387]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:09:01 raspberrypi CRON[31388]: pam_unix(cron:session): session closed for user root
Apr 21 17:09:02 raspberrypi CRON[31387]: pam_unix(cron:session): session closed for user root
Apr 21 17:10:01 raspberrypi CRON[31831]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:10:01 raspberrypi CRON[31831]: pam_unix(cron:session): session closed for user root
Apr 21 17:11:01 raspberrypi CRON[32257]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:11:01 raspberrypi CRON[32257]: pam_unix(cron:session): session closed for user root
Apr 21 17:12:01 raspberrypi CRON[32690]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:12:01 raspberrypi CRON[32690]: pam_unix(cron:session): session closed for user root
Apr 21 17:13:01 raspberrypi CRON[645]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:13:01 raspberrypi CRON[645]: pam_unix(cron:session): session closed for user root
Apr 21 17:14:01 raspberrypi CRON[1080]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:14:01 raspberrypi CRON[1080]: pam_unix(cron:session): session closed for user root
Apr 21 17:15:01 raspberrypi CRON[1514]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:15:01 raspberrypi CRON[1514]: pam_unix(cron:session): session closed for user root
Apr 21 17:16:01 raspberrypi CRON[1944]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:16:01 raspberrypi CRON[1944]: pam_unix(cron:session): session closed for user root
Apr 21 17:17:01 raspberrypi CRON[2390]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:17:01 raspberrypi CRON[2391]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:17:01 raspberrypi CRON[2390]: pam_unix(cron:session): session closed for user root
Apr 21 17:17:01 raspberrypi CRON[2391]: pam_unix(cron:session): session closed for user root
Apr 21 17:18:01 raspberrypi CRON[2844]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:18:01 raspberrypi CRON[2844]: pam_unix(cron:session): session closed for user root
Apr 21 17:19:01 raspberrypi CRON[3277]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:19:02 raspberrypi CRON[3277]: pam_unix(cron:session): session closed for user root
Apr 21 17:20:01 raspberrypi CRON[3696]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:20:01 raspberrypi CRON[3696]: pam_unix(cron:session): session closed for user root
Apr 21 17:21:01 raspberrypi CRON[4128]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:21:01 raspberrypi CRON[4128]: pam_unix(cron:session): session closed for user root
Apr 21 17:22:01 raspberrypi CRON[4562]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:22:01 raspberrypi CRON[4562]: pam_unix(cron:session): session closed for user root
Apr 21 17:23:01 raspberrypi CRON[4992]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:23:01 raspberrypi CRON[4992]: pam_unix(cron:session): session closed for user root
Apr 21 17:24:01 raspberrypi CRON[5425]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:24:01 raspberrypi CRON[5425]: pam_unix(cron:session): session closed for user root
Apr 21 17:25:01 raspberrypi CRON[5851]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:25:01 raspberrypi CRON[5851]: pam_unix(cron:session): session closed for user root
Apr 21 17:26:01 raspberrypi CRON[6282]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:26:01 raspberrypi CRON[6282]: pam_unix(cron:session): session closed for user root
Apr 21 17:27:02 raspberrypi CRON[6719]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:27:02 raspberrypi CRON[6719]: pam_unix(cron:session): session closed for user root
Apr 21 17:28:01 raspberrypi CRON[7139]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:28:01 raspberrypi CRON[7139]: pam_unix(cron:session): session closed for user root
Apr 21 17:29:01 raspberrypi CRON[7567]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:29:01 raspberrypi CRON[7567]: pam_unix(cron:session): session closed for user root
Apr 21 17:30:01 raspberrypi CRON[8002]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:30:01 raspberrypi CRON[8002]: pam_unix(cron:session): session closed for user root
Apr 21 17:31:01 raspberrypi CRON[8432]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:31:01 raspberrypi CRON[8432]: pam_unix(cron:session): session closed for user root
Apr 21 17:32:01 raspberrypi CRON[8866]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:32:01 raspberrypi CRON[8866]: pam_unix(cron:session): session closed for user root
Apr 21 17:33:01 raspberrypi CRON[9293]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:33:02 raspberrypi CRON[9293]: pam_unix(cron:session): session closed for user root
Apr 21 17:34:01 raspberrypi CRON[9712]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:34:01 raspberrypi CRON[9712]: pam_unix(cron:session): session closed for user root
Apr 21 17:35:01 raspberrypi CRON[10145]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:35:01 raspberrypi CRON[10145]: pam_unix(cron:session): session closed for user root
Apr 21 17:36:01 raspberrypi CRON[10585]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:36:01 raspberrypi CRON[10585]: pam_unix(cron:session): session closed for user root
Apr 21 17:37:01 raspberrypi CRON[11019]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:37:01 raspberrypi CRON[11019]: pam_unix(cron:session): session closed for user root
Apr 21 17:38:01 raspberrypi CRON[11451]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:38:01 raspberrypi CRON[11451]: pam_unix(cron:session): session closed for user root
Apr 21 17:39:01 raspberrypi CRON[11885]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:39:01 raspberrypi CRON[11884]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:39:01 raspberrypi CRON[11885]: pam_unix(cron:session): session closed for user root
Apr 21 17:39:02 raspberrypi CRON[11884]: pam_unix(cron:session): session closed for user root
Apr 21 17:40:01 raspberrypi CRON[12325]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:40:01 raspberrypi CRON[12325]: pam_unix(cron:session): session closed for user root
Apr 21 17:41:01 raspberrypi CRON[12757]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:41:01 raspberrypi CRON[12757]: pam_unix(cron:session): session closed for user root
Apr 21 17:42:02 raspberrypi CRON[13184]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:42:02 raspberrypi CRON[13184]: pam_unix(cron:session): session closed for user root
Apr 21 17:43:01 raspberrypi CRON[13603]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:43:01 raspberrypi CRON[13603]: pam_unix(cron:session): session closed for user root
Apr 21 17:44:01 raspberrypi CRON[14043]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:44:01 raspberrypi CRON[14043]: pam_unix(cron:session): session closed for user root
Apr 21 17:45:01 raspberrypi CRON[14469]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:45:01 raspberrypi CRON[14469]: pam_unix(cron:session): session closed for user root
Apr 21 17:46:01 raspberrypi CRON[14895]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:46:01 raspberrypi CRON[14895]: pam_unix(cron:session): session closed for user root
Apr 21 17:47:01 raspberrypi CRON[15323]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:47:01 raspberrypi CRON[15323]: pam_unix(cron:session): session closed for user root
Apr 21 17:48:01 raspberrypi CRON[15756]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:48:01 raspberrypi CRON[15756]: pam_unix(cron:session): session closed for user root
Apr 21 17:49:01 raspberrypi CRON[16185]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:49:02 raspberrypi CRON[16185]: pam_unix(cron:session): session closed for user root
Apr 21 17:50:01 raspberrypi CRON[16610]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:50:01 raspberrypi CRON[16610]: pam_unix(cron:session): session closed for user root
Apr 21 17:51:01 raspberrypi CRON[17036]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:51:01 raspberrypi CRON[17036]: pam_unix(cron:session): session closed for user root
Apr 21 17:52:01 raspberrypi CRON[17470]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:52:01 raspberrypi CRON[17470]: pam_unix(cron:session): session closed for user root
Apr 21 17:53:01 raspberrypi CRON[17899]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:53:01 raspberrypi CRON[17899]: pam_unix(cron:session): session closed for user root
Apr 21 17:54:01 raspberrypi CRON[18332]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:54:01 raspberrypi CRON[18332]: pam_unix(cron:session): session closed for user root
Apr 21 17:55:01 raspberrypi CRON[18764]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:55:01 raspberrypi CRON[18764]: pam_unix(cron:session): session closed for user root
Apr 21 17:56:01 raspberrypi CRON[19198]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:56:01 raspberrypi CRON[19198]: pam_unix(cron:session): session closed for user root
Apr 21 17:57:01 raspberrypi CRON[19624]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:57:02 raspberrypi CRON[19624]: pam_unix(cron:session): session closed for user root
Apr 21 17:58:01 raspberrypi CRON[20043]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:58:01 raspberrypi CRON[20043]: pam_unix(cron:session): session closed for user root
Apr 21 17:59:01 raspberrypi CRON[20478]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 17:59:01 raspberrypi CRON[20478]: pam_unix(cron:session): session closed for user root
Apr 21 18:00:01 raspberrypi CRON[20903]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:00:01 raspberrypi CRON[20903]: pam_unix(cron:session): session closed for user root
Apr 21 18:01:01 raspberrypi CRON[21329]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:01:01 raspberrypi CRON[21329]: pam_unix(cron:session): session closed for user root
Apr 21 18:02:01 raspberrypi CRON[21764]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:02:01 raspberrypi CRON[21764]: pam_unix(cron:session): session closed for user root
Apr 21 18:03:01 raspberrypi CRON[22195]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:03:01 raspberrypi CRON[22195]: pam_unix(cron:session): session closed for user root
Apr 21 18:04:01 raspberrypi CRON[22628]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:04:02 raspberrypi CRON[22628]: pam_unix(cron:session): session closed for user root
Apr 21 18:05:01 raspberrypi CRON[23047]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:05:01 raspberrypi CRON[23047]: pam_unix(cron:session): session closed for user root
Apr 21 18:06:01 raspberrypi CRON[23480]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:06:01 raspberrypi CRON[23480]: pam_unix(cron:session): session closed for user root
Apr 21 18:07:01 raspberrypi CRON[23916]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:07:01 raspberrypi CRON[23916]: pam_unix(cron:session): session closed for user root
Apr 21 18:08:01 raspberrypi CRON[24343]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:08:01 raspberrypi CRON[24343]: pam_unix(cron:session): session closed for user root
Apr 21 18:09:01 raspberrypi CRON[24776]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:09:01 raspberrypi CRON[24777]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:09:01 raspberrypi CRON[24777]: pam_unix(cron:session): session closed for user root
Apr 21 18:09:02 raspberrypi CRON[24776]: pam_unix(cron:session): session closed for user root
Apr 21 18:10:01 raspberrypi CRON[25206]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:10:01 raspberrypi CRON[25206]: pam_unix(cron:session): session closed for user root
Apr 21 18:11:01 raspberrypi CRON[25646]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:11:02 raspberrypi CRON[25646]: pam_unix(cron:session): session closed for user root
Apr 21 18:12:01 raspberrypi CRON[26065]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:12:01 raspberrypi CRON[26065]: pam_unix(cron:session): session closed for user root
Apr 21 18:13:01 raspberrypi CRON[26493]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:13:01 raspberrypi CRON[26493]: pam_unix(cron:session): session closed for user root
Apr 21 18:14:01 raspberrypi CRON[26928]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:14:01 raspberrypi CRON[26928]: pam_unix(cron:session): session closed for user root
Apr 21 18:15:01 raspberrypi CRON[27359]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:15:01 raspberrypi CRON[27359]: pam_unix(cron:session): session closed for user root
Apr 21 18:16:01 raspberrypi CRON[27794]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:16:01 raspberrypi CRON[27794]: pam_unix(cron:session): session closed for user root
Apr 21 18:17:01 raspberrypi CRON[28221]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:17:01 raspberrypi CRON[28220]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:17:01 raspberrypi CRON[28220]: pam_unix(cron:session): session closed for user root
Apr 21 18:17:01 raspberrypi CRON[28221]: pam_unix(cron:session): session closed for user root
Apr 21 18:18:01 raspberrypi CRON[28659]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:18:02 raspberrypi CRON[28659]: pam_unix(cron:session): session closed for user root
Apr 21 18:19:01 raspberrypi CRON[29089]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:19:01 raspberrypi CRON[29089]: pam_unix(cron:session): session closed for user root
Apr 21 18:20:01 raspberrypi CRON[29515]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:20:01 raspberrypi CRON[29515]: pam_unix(cron:session): session closed for user root
Apr 21 18:21:01 raspberrypi CRON[29948]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:21:01 raspberrypi CRON[29948]: pam_unix(cron:session): session closed for user root
Apr 21 18:22:01 raspberrypi CRON[30374]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:22:01 raspberrypi CRON[30374]: pam_unix(cron:session): session closed for user root
Apr 21 18:23:01 raspberrypi CRON[30812]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:23:01 raspberrypi CRON[30812]: pam_unix(cron:session): session closed for user root
Apr 21 18:24:01 raspberrypi CRON[31240]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:24:01 raspberrypi CRON[31240]: pam_unix(cron:session): session closed for user root
Apr 21 18:25:01 raspberrypi CRON[31666]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:25:01 raspberrypi CRON[31666]: pam_unix(cron:session): session closed for user root
Apr 21 18:26:01 raspberrypi CRON[32099]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:26:02 raspberrypi CRON[32099]: pam_unix(cron:session): session closed for user root
Apr 21 18:27:01 raspberrypi CRON[32518]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:27:01 raspberrypi CRON[32518]: pam_unix(cron:session): session closed for user root
Apr 21 18:28:01 raspberrypi CRON[480]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:28:01 raspberrypi CRON[480]: pam_unix(cron:session): session closed for user root
Apr 21 18:29:01 raspberrypi CRON[915]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:29:01 raspberrypi CRON[915]: pam_unix(cron:session): session closed for user root
Apr 21 18:30:01 raspberrypi CRON[1346]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:30:01 raspberrypi CRON[1346]: pam_unix(cron:session): session closed for user root
Apr 21 18:31:01 raspberrypi CRON[1783]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:31:01 raspberrypi CRON[1783]: pam_unix(cron:session): session closed for user root
Apr 21 18:32:01 raspberrypi CRON[2215]: pam_unix(cron:session): session opened for user root by (uid=0)
Apr 21 18:32:01 raspberrypi CRON[2215]: pam_unix(cron:session): session closed for user root
Apr 21 18:33:01 raspberrypi CRON[2668]: pam_unix(cron:session): session opened for user root by (uid=0)
[Apr 21 15:09:00:946308] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 51755
[Apr 21 15:09:00:947713] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:10:21:986399] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 51990
[Apr 21 15:10:21:987806] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:11:51:326313] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 52225
[Apr 21 15:11:51:327698] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:13:13:476303] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 52458
[Apr 21 15:13:13:477797] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:14:37:136291] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 52693
[Apr 21 15:14:37:137696] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:16:03:266396] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 52928
[Apr 21 15:16:03:267805] pilight-daemon: INFO: client recognized as sender
[ Apr 21 15:17:29:16593] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 53165
[ Apr 21 15:17:29:18016] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:18:54:196366] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 53400
[Apr 21 15:18:54:197758] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:20:17:736307] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 53635
[Apr 21 15:20:17:737824] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:21:41:656312] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 53870
[Apr 21 15:21:41:657708] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:23:06:736352] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 54105
[Apr 21 15:23:06:737749] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:24:25:116368] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 54338
[Apr 21 15:24:25:117771] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:25:52:896476] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 54576
[Apr 21 15:25:52:897930] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:27:18:656311] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 54809
[Apr 21 15:27:18:657711] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:28:43:306307] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 55044
[Apr 21 15:28:43:307716] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:30:11:976305] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 55280
[Apr 21 15:30:11:977712] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:31:34:776385] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 55513
[Apr 21 15:31:34:777791] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:32:54:876316] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 55746
[Apr 21 15:32:54:877715] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:34:30:136291] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 55984
[Apr 21 15:34:30:137699] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:35:50:476357] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 56217
[Apr 21 15:35:50:477860] pilight-daemon: INFO: client recognized as sender
[ Apr 21 15:37:12:66300] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 56452
[ Apr 21 15:37:12:67700] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:38:33:306395] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 56685
[Apr 21 15:38:33:307788] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:39:56:366323] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 56920
[Apr 21 15:39:56:367728] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:41:18:276406] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 57153
[Apr 21 15:41:18:277957] pilight-daemon: INFO: client recognized as sender
[ Apr 21 15:42:41:66311] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 57390
[ Apr 21 15:42:41:67708] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:44:04:656309] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 57625
[Apr 21 15:44:04:657709] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:45:25:616469] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 57860
[Apr 21 15:45:25:617865] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:46:49:666396] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 58095
[Apr 21 15:46:49:667791] pilight-daemon: INFO: client recognized as sender
[Apr 21 15:48:16:336308] pilight-daemon: INFO: new client, ip: 192.168.178.20, port: 58330
[Apr 21 15:48:16:337804] pilight-daemon: INFO: client recognized as sender
[Apr 21 21:46:26:982362] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50300
[ Apr 21 21:46:27:75100] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50301
[ Apr 21 21:46:27:76881] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50302
[Apr 21 21:46:27:110121] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50303
[Apr 21 21:46:27:114309] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50304
[Apr 21 21:46:27:128794] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50305
[Apr 21 21:46:27:133903] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50306
[Apr 21 21:46:27:276157] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50307
[Apr 21 21:46:27:295124] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50308
[Apr 21 21:46:27:340265] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50308
[Apr 21 21:46:27:712757] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50308
[Apr 21 21:46:27:724962] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50309
[Apr 21 21:46:27:744982] pilight-daemon: INFO: client connected, ip 192.168.178.30, port 50311
