Zapata Telephony Interface Registered on major 196
Using /lib/modules/2.4.26/misc/zaptel.o
PCI: Enabling device 00:0c.0 (0104 -> 0107)
PCI: Assigned IRQ 10 for device 00:c:0
zaphfc: CCD/Billion/Asuscom 2BD0 configured at mem 0xd0a04c00 fifo 0xcf798000(0xf798000) IRQ 11 HZ 100
Zaphfc: Card 0 configured for NT mode
zaphfc: 1 hfc-pci card(s) in this box.
Registered tone zone 3 (Netherlands)
Zaptel Configuration
SPAN 1: CCS/ AMI Build-out: 399-533 feet (DSX-1)
Channel map:
Channel 01: Individual Clear channel (Default) (Slaves: 01)
Channel 02: Individual Clear channel (Default) (Slaves: 02)
Channel 03: D-channel (Default) (Slaves: 03)
3 channels configured.
DS001 2.1.8 # asterisk -vvvvc
== Parsing '/etc/asterisk/asterisk.conf': Found
== Parsing '/etc/asterisk/extconfig.conf': Found
Asterisk CVS-HEAD-08/13/04-12:00:00-BRI-stuffed-0.1.0-RC4a, Copyright (C) 1999-2004 Digium.
Written by Mark Spencer <[email protected]>
== Parsing '/etc/asterisk/logger.conf': Found
Asterisk Event Logger Started /var/log/asterisk/event_log
== Manager registered action Ping
== Manager registered action Events
== Manager registered action Logoff
== Manager registered action Hangup
== Manager registered action Status
== Manager registered action Setvar
== Manager registered action Getvar
== Manager registered action Redirect
== Manager registered action Originate
== Manager registered action MailboxStatus
== Manager registered action Command
== Manager registered action ExtensionState
== Manager registered action AbsoluteTimeout
== Manager registered action MailboxCount
== Manager registered action ListCommands
== Parsing '/etc/asterisk/manager.conf': Found
== Parsing '/etc/asterisk/rtp.conf': Found
== RTP Allocating from port range 10000 -> 20000
Asterisk PBX Core Initializing
Registering builtin applications:
[AbsoluteTimeout]
== Registered application 'AbsoluteTimeout'
[Answer]
== Registered application 'Answer'
[BackGround]
== Registered application 'BackGround'
[Busy]
== Registered application 'Busy'
[Congestion]
== Registered application 'Congestion'
[DigitTimeout]
== Registered application 'DigitTimeout'
[Goto]
== Registered application 'Goto'
[GotoIf]
== Registered application 'GotoIf'
[GotoIfTime]
== Registered application 'GotoIfTime'
[Hangup]
== Registered application 'Hangup'
[NoOp]
== Registered application 'NoOp'
[Prefix]
== Registered application 'Prefix'
[Progress]
== Registered application 'Progress'
[ResetCDR]
== Registered application 'ResetCDR'
[ResponseTimeout]
== Registered application 'ResponseTimeout'
[Ringing]
== Registered application 'Ringing'
[SayNumber]
== Registered application 'SayNumber'
[SayDigits]
== Registered application 'SayDigits'
[SayAlpha]
== Registered application 'SayAlpha'
[SayPhonetic]
== Registered application 'SayPhonetic'
[SetAccount]
== Registered application 'SetAccount'
[SetAMAFlags]
== Registered application 'SetAMAFlags'
[SetGlobalVar]
== Registered application 'SetGlobalVar'
[SetLanguage]
== Registered application 'SetLanguage'
[SetVar]
== Registered application 'SetVar'
[StripMSD]
== Registered application 'StripMSD'
[Suffix]
== Registered application 'Suffix'
[Wait]
== Registered application 'Wait'
[WaitExten]
== Registered application 'WaitExten'
Asterisk Dynamic Loader Starting:
== Parsing '/etc/asterisk/modules.conf': Found
[chan_capi.so]Nov 21 14:15:46 WARNING[1024]: loader.c:242 ast_load_resource: libcapi20.so.2: cannot open shared object file: No such file or directory
Nov 21 14:15:46 WARNING[1024]: loader.c:374 load_modules: Loading module chan_capi.so failed!
Netview schrieb:Das opt lässt sich leider nicht installieren!
Bei mir kommt die Meldung von mkopt "too many files >1024", da ich noch weiter Pakete installiert habe (es werden mehr als 600 Dateien hinzugefügt - ich denke dies ist für das verwendete Filesystem + zusätzliche Pakete einfach zuviel!).
Ich war mit der früheren Lösung, asterisk auf die HD auszulagern, besser bedient!
Könnte man dies nicht als Option weiterhin anbieten???
Zusätzlich habe ich festgestellt das unbedingt OPt_Faxrcv installiert sein muss sonst läuft die Capi nicht und Asterisk erzeugt diverse Fehlermeldungen.
Achtung
es kann bei manchen Boards vorkommen, das sich nach der Installation der CAPI-Treiber nicht laden läßt. Fehlermeldung in /var/log/messages:
fcpci: Error: Invalid parameters (base=0xd800, irq=12)
Hier muß dann der Ordner "hisax" im Verzeichnis "/lib/modules/2.4.21-i586-cdv/kernel/drivers/isdn" gelöscht werden
