ADAM2 Revision TI:0.18.01 AVM: Version:97
(C) Copyright 1996-2003 Texas Instruments Inc. All Rights Reserved.
(C) Copyright 2003 Telogy Networks, Inc.
(C) Copyright 2003-2004 AVM
AVM_Ar7 >
Press any key to abort OS load, or wait 5 seconds for OS to boot...
-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\|/-\Launching kernel decompressor.
Kernel decompressor was successful ... launching kernel.
LINUX started...
Config serial console: ttyS0,38400
This SOC has MDIX cababilities on chip: HWRevision="F"
AutoMDIX="<unknown>"
MDIX disabled.
init started: BusyBox v1.2.1 (2007.07.29-17:19+0000) multi-call binary
Starting pid 11, console /dev/tts/0: '/etc/init.d/rc.S'
**** adam2 environment ****
HWRevision F
ProductID Fritz_Box_2MB
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 0.18.01
bootserport tty0
bluetooth 00:04:0E:FF:FF:07
cpufrequency 150000000
firstfreeaddress 0x94730258
firmware_version avm
firmware_info 10.03.94
flashsize 0x00200000
maca 00:04:0E:2E:7F:D5
macb 00:04:0E:FF:FF:02
macwlan 00:04:0E:FF:FF:03
macdsl 00:04:0E:2E:7F:D6
memsize 0x00800000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x900B0000,0x901F0000
mtd1 0x90010000,0x900B0000
mtd2 0x90000000,0x90010000
mtd3 0x901F0000,0x901F8000
mtd4 0x901F8000,0x90200000
my_ipaddress 192.168.178.2
prompt AVM_Ar7
reserved 00:04:0E:FF:FF:00
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 97
usb_board_mac 00:04:0E:2E:7F:D7
usb_rndis_mac 00:04:0E:2E:7F:D8
usb_device_id 0x3701
usb_revision_id 0x0100
usb_device_name USB DSL Device
usb_manufacturer_name AVM
HWRevision='F'
ANNEX='B'
OEM='avm'
Language='de'
Country='049'
TZ='CET-1CEST,M3.5.0,M10.5.0'
CONFIG_AB_COUNT='0'
CONFIG_ANNEX='B'
CONFIG_ASSIST='n'
CONFIG_ATA='n'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='n'
CONFIG_CAPI_MIPS='n'
CONFIG_CAPI_UBIK='n'
CONFIG_CAPI_XILINX='n'
CONFIG_CDROM='n'
CONFIG_CDROM_FALLBACK='y'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ENVIRONMENT_PATH='/proc/sys/dev/adam2'
CONFIG_ETH_COUNT='1'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.php?hardware=F&o
em=avm&language=de&country='
CONFIG_FON='n'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_2MB_1eth_oem_AOL_32711'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_2MB'
CONFIG_PRODUKT_NAME='FRITZ!Box SL'
CONFIG_RAMSIZE='8'
CONFIG_ROMSIZE='2'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-portal.php?hardware
=F&oem=avm&language=de&country='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION=''
CONFIG_UBIK2='n'
CONFIG_USB='y'
CONFIG_USB_HOST_AVM='n'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='n'
CONFIG_USB_STORAGE='n'
CONFIG_USB_WLAN_AUTH='n'
CONFIG_VERSION='03.94'
CONFIG_VERSION_MAJOR='10'
CONFIG_VLYNQ0='0'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='n'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
checkempty: : No such file or directory
checkempty: warning, /var/flash/ar7.cfg not found - nop
insmod: avalanche_usb.o: no module by that name found
attempting to load DSL Firmware '/lib/modules/ar0700xx.bin'
**** ANNEX: 'B'
setting DSL Firmware to Annex B
Warning: loading tiatm will taint the kernel: non-GPL license -
(C) Copyright 2003, Texas Instruments, Inc
(C) Copyright 2004, AVM
See http://www.tux.org/lkml/#export-tainted for information about tainted modu
les
c0032df0 __insmod_tiatm_S.data_L6480 [tiatm]
c0035620 __insmod_tiatm_S.bss_L3296 [tiatm]
c0031c60 __insmod_tiatm_S.rodata_L4496 [tiatm]
c0022060 __insmod_tiatm_S.text_L64480 [tiatm]
c0022000 __insmod_tiatm_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drive
rs/atm/tiatm.o_M445B1130_V-1 [tiatm]
Warning: loading kdsldmod will taint the kernel: no license
les
kdsldmod: init start
kdsld_thread: start
kdsldmod: init done
c003a000 __insmod_kdsldmod_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/dr
ivers/dsld/kdsldmod.o_M445B1130_V-1 [kdsldmod]
c009f4e0 __insmod_kdsldmod_S.bss_L11392 [kdsldmod]
c008c280 __insmod_kdsldmod_S.data_L56688 [kdsldmod]
c00878a0 __insmod_kdsldmod_S.rodata_L18880 [kdsldmod]
c003a060 __insmod_kdsldmod_S.text_L317472 [kdsldmod]
2002-09-08 14:00:05 cltmgr: csock: using poll
Sep 8 14:00:05 cltmgr[138]: csock: using poll
Sep 8 14:00:05 cltmgr[140]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:06 cltmgr[140]: load_config(ar7): factory default loaded
Sep 8 14:00:06 websrv[145]: csock: using poll
Sep 8 14:00:06 websrv[145]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:06 websrv[145]: load_config(ar7): factory default loaded
Sep 8 14:00:06 igdd[149]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:06 cltmgr[140]: FactoryDefault=/etc/default/avm/stat.cfg (stat)
Sep 8 14:00:06 cltmgr[140]: /etc/default/avm/stat.cfg: is empty
Sep 8 14:00:06 cltmgr[140]: load_config(stat): file empty - factory default loa
ded
Sep 8 14:00:06 cltmgr[140]: Statistic load_config failed
Sep 8 14:00:06 igdd[149]: load_config(ar7): factory default loaded
Sep 8 14:00:07 igdd[149]: csock: using poll
2002-09-08 14:00:07 multid: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:07 multid[154]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
2002-09-08 14:00:07 multid: load_config(ar7): factory default loaded
Sep 8 14:00:07 multid[154]: load_config(ar7): factory default loaded
2002-09-08 14:00:07 multid: csock: using poll
Sep 8 14:00:07 multid[154]: csock: using poll
Sep 8 14:00:08 multid[157]: if_setup: lan:0: SIOCSIFADDR failed - No such devic
e (19)
Sep 8 14:00:08 multid[157]: if_setup: usbrndis: SIOCSIFADDR failed - No such de
vice (19)
Sep 8 14:00:08 multid[157]: br_add_if: get index for usbrndis failed - No such
device (19)
Sep 8 14:00:08 multid[157]: if_setup: tiwlan0: SIOCSIFADDR failed - No such dev
ice (19)
Sep 8 14:00:08 multid[157]: br_add_if: get index for tiwlan0 failed - No such d
evice (19)
Sep 8 14:00:08 multid[157]: if_setup: wdsup0: SIOCSIFADDR failed - No such devi
ce (19)
Sep 8 14:00:08 multid[157]: br_add_if: get index for wdsup0 failed - No such de
vice (19)
Sep 8 14:00:08 multid[157]: if_setup: wdsdw0: SIOCSIFADDR failed - No such devi
ce (19)
Sep 8 14:00:08 multid[157]: br_add_if: get index for wdsdw0 failed - No such de
vice (19)
Sep 8 14:00:08 multid[157]: if_setup: wdsdw1: SIOCSIFADDR failed - No such devi
ce (19)
2002-09-08 14:00:08 dsld: csock: using poll
Sep 8 14:00:08 dsld[158]: csock: using poll
2002-09-08 14:00:08 dsld: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:08 dsld[158]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:08 multid[157]: br_add_if: get index for wdsdw1 failed - No such de
vice (19)
Sep 8 14:00:08 multid[157]: if_setup: wdsdw2: SIOCSIFADDR failed - No such devi
ce (19)
Sep 8 14:00:08 multid[157]: br_add_if: get index for wdsdw2 failed - No such de
vice (19)
Sep 8 14:00:08 multid[157]: if_setup: wdsdw3: SIOCSIFADDR failed - No such devi
ce (19)
Sep 8 14:00:08 multid[157]: br_add_if: get index for wdsdw3 failed - No such de
vice (19)
2002-09-08 14:00:08 dsld: load_config(ar7): factory default loaded
Sep 8 14:00:08 dsld[158]: load_config(ar7): factory default loaded
run_clock demon started
check continuos reboot ...
/etc/init.d/rc.S: .: 164: Can't open /var/flash/debug.cfg
Starting pid 184, console /dev/tts/0: '/bin/sh'
BusyBox v1.2.1 (2007.07.29-17:19+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
Sep 8 14:00:10 dsld[181]: FactoryDefault=/etc/default/avm/stat.cfg (stat)
Sep 8 14:00:10 dsld[181]: /etc/default/avm/stat.cfg: is empty
Sep 8 14:00:11 dsld[181]: load_config(stat): file empty - factory default loade
d
Sep 8 14:00:11 dsld[181]: Statistic load_config failed
kdsld: sync lost
HWRevision='F'
ANNEX='B'
OEM='avm'
Language='de'
Country='049'
CONFIG_AB_COUNT='0'
CONFIG_ANNEX='B'
CONFIG_ASSIST='n'
CONFIG_ATA='n'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='n'
CONFIG_CDROM='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_FON='n'
CONFIG_HOMEI2C='n'
CONFIG_I2C='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_RAMSIZE='8'
CONFIG_ROMSIZE='2'
CONFIG_UBIK2='n'
CONFIG_USB='y'
CONFIG_VLYNQ0='0'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='n'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
ermittle die aktuelle TTY
tty is "/dev/tts/0"
-sh: stty: not found
Serielles Terminal
# Sep 8 14:00:23 igdd[149]: leave mcast group 239.255.255.250 at interface 192.
168.178.1 for 0.0.0.0:1900 failed - Cannot assign requested address (126)
Sep 8 14:00:54 websrv[145]: 192.168.178.1:80: POLLHUP
kdsld: unsetup done.
Sep 8 14:01:11 igdd[257]: csock: using poll
Sep 8 14:01:22 igdd[259]: csock: using poll
Starting pid 274, console /dev/tts/0: '/bin/sh'
system is going down ..
The system is going down NOW !!
Sending SIGTERM to all processes.
Sending SIGKILL to all processes.
Requesting system reboot.
AVM_Ar7 >
LINUX started...
MDIX disabled.
HWRevision F
annex B
autoload yes
bootserport tty0
memsize 0x00800000
prompt AVM_Ar7
urlader-version 97
HWRevision='F'
ANNEX='B'
OEM='avm'
Language='de'
Country='049'
CONFIG_AB_COUNT='0'
CONFIG_ANNEX='B'
CONFIG_ASSIST='n'
CONFIG_ATA='n'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='n'
CONFIG_CDROM='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_FON='n'
CONFIG_HOMEI2C='n'
CONFIG_I2C='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_RAMSIZE='8'
CONFIG_ROMSIZE='2'
CONFIG_UBIK2='n'
CONFIG_USB='y'
CONFIG_VLYNQ0='0'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='n'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
**** ANNEX: 'B'
les
les
kdsld_thread: start
kdsldmod: init done
Sep 8 14:00:05 cltmgr[141]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:06 cltmgr[141]: load_config(ar7): factory default loaded
Sep 8 14:00:06 igdd[148]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:06 igdd[148]: load_config(ar7): factory default loaded
Sep 8 14:00:06 cltmgr[141]: FactoryDefault=/etc/default/avm/stat.cfg (stat)
Sep 8 14:00:06 cltmgr[141]: /etc/default/avm/stat.cfg: is empty
Sep 8 14:00:06 cltmgr[141]: load_config(stat): file empty - factory default loa
ded
Sep 8 14:00:06 cltmgr[141]: Statistic load_config failed
Sep 8 14:00:07 igdd[148]: csock: using poll
e (19)
vice (19)
device (19)
ice (19)
evice (19)
ce (19)
vice (19)
ce (19)
vice (19)
ce (19)
vice (19)
ce (19)
vice (19)
ce (19)
vice (19)
Sep 8 14:00:10 dsld[179]: FactoryDefault=/etc/default/avm/stat.cfg (stat)
Sep 8 14:00:10 dsld[179]: /etc/default/avm/stat.cfg: is empty
Sep 8 14:00:10 dsld[179]: load_config(stat): file empty - factory default loade
d
Sep 8 14:00:10 dsld[179]: Statistic load_config failed
kdsld: sync lost
HWRevision='F'
ANNEX='B'
OEM='avm'
Language='de'
Country='049'
CONFIG_AB_COUNT='0'
CONFIG_ANNEX='B'
CONFIG_ASSIST='n'
CONFIG_ATA='n'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='n'
CONFIG_CDROM='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_FON='n'
CONFIG_HOMEI2C='n'
CONFIG_I2C='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_RAMSIZE='8'
CONFIG_ROMSIZE='2'
CONFIG_UBIK2='n'
CONFIG_USB='y'
CONFIG_VLYNQ0='0'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='n'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
tty is "/dev/tts/0"
Serielles Terminal
