ar7cfg {
mode = dsldmode_router;
tsdisabled = no;
igddenabled = yes;
igdd_control_enabled = no;
wan_bridge_with_dhcpc = yes;
wan_bridge_gateway = 0.0.0.0;
dhcpc_use_static_dns = no;
ethmode = ethmode_bridge;
StatisticStartOfMonth = 1;
macdsl_override = 00:00:00:00:00:00;
ethinterfaces {
name = "eth0";
dhcp = no;
ipaddr = 192.168.178.100;
netmask = 255.255.255.0;
dstipaddr = 0.0.0.0;
dhcpenabled = yes;
dhcpstart = 0.0.0.0;
dhcpend = 0.0.0.0;
name = "eth0:0";
dhcp = no;
ipaddr = 192.168.178.254;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "eth1";
dhcp = no;
ipaddr = 192.168.181.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "usbrndis";
dhcp = no;
ipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "wlan";
dhcp = no;
ipaddr = 192.168.182.1;
interfaces = "tiwlan0", "wdsup0", "wdsdw0", "wdsdw1",
"wdsdw2", "wdsdw3";
dhcpenabled = no;
dhcpend = 0.0.0.0;
brinterfaces {
name = "lan";
dhcp = no;
interfaces = "eth0", "usbrndis", "eth1", "tiwlan0", "wdsup0",
"wdsdw0", "wdsdw1", "wdsdw2", "wdsdw3";
dhcpenabled = yes;
dhcpend = 0.0.0.0;
name = "lan:0";
dhcp = no;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface {
name = "dsl";
dhcp = no;
netmask = 255.255.255.255;
dstipaddr = 192.168.179.1;
dhcpenabled = yes;
dhcpend = 0.0.0.0;
dslinterface_metric = 2;
pppoefw {
interfaces = "usbrndis", "eth0", "eth1", "tiwlan0", "wdsup0",
nofirewall = yes;
ipnetbiosfilter = yes;
dnsfilter_for_active_directory = yes;
hostuniq_filter = "";
dpconfig {
security = dpsec_host;
lowinput {
policy = "reject";
accesslist =
"permit ip any any connection outgoing-related",
"permit ip any any connection incoming-related",
"permit icmp any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
"reject ip any 242.0.0.0 255.0.0.0",
"deny ip any host 255.255.255.255",
"reject ip any 10.0.0.0 255.0.0.0",
"reject ip any 169.254.0.0 255.255.0.0",
"reject udp any any eq 135",
"reject tcp any any eq 135",
"reject udp any any range 137 139",
"reject tcp any any range 137 139",
"reject udp any any range 161 162",
"reject udp any any eq 520",
"reject udp any any eq 111",
"reject udp any any eq 22289",
"reject udp any any eq 1710",
"reject udp any any eq 1048",
"reject udp any any eq 158",
"reject udp any any eq 515",
"reject icmp any 149.1.1.0 255.255.255.0",
"reject tcp any host 202.106.185.127 eq 25";
shaper = "globalshaper";
budget {
Enabled = yes;
Period = 2;
VolumeLow = 2820000000;
VolumeHigh = 4;
ConnectionTime = 0;
WarnOnly = yes;
vccs {
VPI = 1;
VCI = 32;
dsl_encap = dslencap_ether;
ipbridgeing = no;
connections = "internet";
dslifaces {
name = "internet";
dsl_encap = dslencap_inherit;
ppptarget = "internet";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
stay_always_online = yes;
redial_delay_after_auth_failure = 1m;
redial_limit = 3;
redial_after_limit_reached = 1h;
username_prefix_after_auth_failure = "D";
dsldpconfig {
security = dpsec_firewall;
lowinput {
policy = "permit";
accesslist =
"deny ip any 242.0.0.0 255.0.0.0",
"deny udp any any eq 135",
"deny tcp any any eq 135",
"deny udp any any range 137 139",
"deny tcp any any range 137 139",
"deny udp any any range 161 162",
"deny udp any any eq 520",
"deny udp any any eq 111",
"deny udp any any eq 22289",
"deny udp any any eq 1710",
"deny udp any any eq 1048",
"deny udp any any eq 158",
"deny udp any any eq 515";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
accesslist =
forwardrules = "tcp 0.0.0.0:0 0.0.0.0:0 1 out",
"udp 0.0.0.0:0 0.0.0.0:0 1 out",
"udp 0.0.0.0:5060 0.0.0.0:5060",
"udp 0.0.0.0:7078 0.0.0.0:7078",
"udp 0.0.0.0:7079 0.0.0.0:7079",
"udp 0.0.0.0:7080 0.0.0.0:7080",
"udp 0.0.0.0:7081 0.0.0.0:7081",
"udp 0.0.0.0:7082 0.0.0.0:7082",
"udp 0.0.0.0:7083 0.0.0.0:7083",
"udp 0.0.0.0:7084 0.0.0.0:7084",
"udp 0.0.0.0:7085 0.0.0.0:7085",
"tcp 0.0.0.0:21 192.168.178.20:21 0 # FTP-Server",
"# tcp 0.0.0.0:80 192.168.178.20:80 0 # HTTP-Server",
"tcp 0.0.0.0:4662 192.168.178.20:4662 0 # eMule",
"udp 0.0.0.0:4672 192.168.178.20:4672 0 # eMule",
"# tcp 0.0.0.0:3389 192.168.178.20:3389 0 # MS Remote Desktop",
"tcp 0.0.0.0:5001 192.168.178.22:5001 0 # Beschreibung";
name = "voip";
ppptarget = "voip";
etherencapcfg {
use_dhcp = yes;
ipaddr = 0.0.0.0;
netmask = 0.0.0.0;
gateway = 0.0.0.0;
dns1 = 0.0.0.0;
dns2 = 0.0.0.0;
redial_limit = 3;
username_prefix_after_auth_failure = "";
dsldpconfig {
lowinput {
policy = "permit";
accesslist = "permit udp any any",
"permit icmp any any",
"reject ip any any";
lowoutput {
policy = "permit";
highinput {
policy = "permit";
highoutput {
policy = "permit";
"udp 0.0.0.0:7085 0.0.0.0:7085";
voip_routes = "permit ip any any connection exists",
"permit udp any eq 5060 any",
"permit udp any eq 7077 any eq 53",
"permit udp any range 7078 7085 any";
targets {
type = pppcfg_target_internet;
name = "internet";
only_crypt_auth = no;
local {
username = "$$$$QDLDNBQS2VR6RXRLX5FIX3VNHOFTS4VFN51C4CQVDPFNCPZLN1TWNOMRURHUYVTT2FAF6XJJVKHAV1GUJOA12FPK5N6YGC2YKH5TGZRJ";
passwd = "";
remoteauth = pppcfg_authtype_chap;
remoteauth_only_on_incoming = yes;
remote {
inactivity_timeout = 0w;
bUseChargeInterval = no;
nChargeInterval = 1m;
logicaldisconnect_with_physical = yes;
disconnect_timeout = 0w;
finaldisconnectcall = no;
ipnetbiosspoofing = no;
dnsfilter_for_active_directory = no;
no_outgoing_calls = no;
coso = pppcfg_coso_caller;
callback_delay = 1s;
icbmode = pppcfg_icbmode_none;
ocbmode = pppcfg_ocbmode_none;
mscbprefered = no;
multilink {
extra_static_channels = 0;
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
header_compression = yes;
data_compression = pppcfg_datacomp_auto;
stac_reset_with_history_number = no;
encryption = pppcfg_crypt_none;
inactivity_prevention_interval = 0w;
new_ipaddr_on_connect = no;
my_ipaddr = 0.0.0.0;
his_ipaddr = 0.0.0.0;
bVolumeRoundUp = no;
VolumeRoundUpBytes = 1000000;
bProviderDisconnectPrevention = no;
ProviderDisconnectPreventionInterval = 1d;
ProviderDisconnectPreventionHour = 3;
name = "voip";
local {
username = "";
passwd = "";
remote {
mscbprefered = no;
multilink {
max_channels = 1;
automatic = no;
automatic_param {
window = 20s;
add_percent = 85;
drop_percent = 70;
sportlich = no;
VolumeRoundUpBytes = 0;
dslglobalconfig {
autodetect = yes;
pppoeiface = "eth0";
speed_in_netto = 1024;
speed_out_netto = 128;
connect_delay_when_synced = 3s;
templates {
VPI = 1;
VCI = 32;
manu = 0;
encap = dslencap_pppoe;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 48;
manu = 0;
encap = dslencap_pppoa;
VPI = 8;
VCI = 48;
manu = 0;
encap = dslencap_pppoa_llc;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 67;
manu = 0;
VPI = 8;
VCI = 64;
manu = 0;
VPI = 8;
VCI = 36;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 35;
manu = 0;
VPI = 9;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 34;
manu = 0;
VPI = 0;
VCI = 30;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 8;
VCI = 32;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 0;
VCI = 38;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 8;
VCI = 35;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 8;
VCI = 81;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
VPI = 0;
VCI = 100;
manu = 0;
shapers {
name = "globalshaper";
OutFragmentWhenVoIP = 0;
shaperconnection {
enabled = yes;
targets = "";
name = "Fritz!Box";
limiters {
name = "default-out";
bps_limit {
limit_total = 100;
limit_p0 = 0;
limit_p1 = 95;
limit_p2 = 95;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 3;
grouping_by_source_ip = no;
grouping_by_dest_ip = no;
grouping_by_source_port = no;
grouping_by_dest_port = no;
dynamic_balancing = no;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
shapeOutgoingOnIncomingCounters = no;
name = "default-in";
bps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
min_priority = 0;
max_priority = 0;
bps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
pps_child_limit {
limit_total = 0;
limit_p0 = 0;
limit_p1 = 0;
limit_p2 = 0;
limit_p3 = 0;
out_rules {
name = "download-tcp-ack";
filter = "tcp and len <= 64";
priority = 2;
limiters = "default-out";
name = "dns";
filter = "udp port 53";
priority = 1;
name = "fon-rtp";
filter = "udp[8] = 0x80 or udp port 5060";
priority = 3;
name = "http-requests";
filter = "(tcp dst port 80 or dst port 8080 or dst port 3128) and (len <= 800)";
priority = 1;
name = "pri-out";
filter = "icmp";
priority = 1;
name = "default";
filter = "";
priority = 0;
in_rules {
name = "default";
filter = "";
priority = 0;
limiters = "default-in";
demasquerade = no;
servercfg {
dns1 = 192.168.180.1;
dns2 = 192.168.180.2;
websrv {
port = "80";
read_timeout = 15m;
request_timeout = 30s;
keepalive_timeout = 5m;
nokeepalive = "*";
errordir = "/usr/lib/websrv/errors";
webdir = "/usr/www";
cgidir = "cgi-bin";
indexfn = "index.var", "index.htm", "index.html";
dhcpserver {
saveinterval = 1h;
generic {
default_lease_time = 10d;
max_lease_time = 13d;
dhcpclient {
metric = 9;
dnsserver {
cache_maxKB = 16;
negative_ttl = 5m;
ddns {
accounts {
enabled = no;
domain = "";
iface = 0;
username =
passwd =
ddnsprovider = "No-IP.com";
types {
type = "dyndns";
url = "/nic/update?system=dyndns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-custom";
url = "/nic/update?system=custom&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "dyndns-statdns";
url = "/nic/update?system=statdns&hostname=<domain>&myip=<ipaddr>&wildcard=NOCHG";
type = "noip";
url = "/ducupdate.php?update=<b64>username=<username>&pass=<pass>&h[]=<domain>&ip=<ipaddr></b64>";
type = "2mydns";
url = "/dyn.asp?username=<username>&password=<pass>&hostname=<domain>&myip=<ipaddr>";
type = "dns4biz";
url = "/nic/update?hostname=<domain>&myip=<ipaddr>";
type = "selfhost";
url = "/nic/update?myip=<ipaddr>";
type = "userdefined";
url = "";
provider {
name = "dyndns.org";
type = "dyndns";
livedelay = 0w;
touchtime = 30d;
server = "members.dyndns.org";
infourl = "http://www.dyndns.org/";
name = "dyndns.org-custom";
livedelay = 0w;
touchtime = 30d;
name = "dyndns.org-statdns";
livedelay = 0w;
touchtime = 30d;
name = "No-IP.com";
type = "noip";
livedelay = 4m;
touchtime = 0w;
server = "dynupdate.no-ip.com:8245";
infourl = "http://www.no-ip.com/";
name = "2myDNS";
type = "2mydns";
livedelay = 0w;
touchtime = 0w;
server = "dyn.2mydns.com";
infourl = "http://www.2mydns.com/";
name = "DNS4BIZ.DE Premium";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.net";
infourl = "http://www.dns4biz.com/services_avm.php3";
name = "DNS4BIZ.DE Business";
type = "dns4biz";
livedelay = 0w;
touchtime = 0w;
server = "au-eu.dns4biz.biz";
name = "selfhost.de";
type = "selfhost";
livedelay = 0w;
touchtime = 0w;
server = "carol.selfhost.de";
infourl = "http://www.selfhost.de";
name = "Benutzerdefiniert";
livedelay = 4m;
touchtime = 0w;
server = "";
infourl = "http://";
webui {
username = "";
password = "$$$$XMXWKLALOKGR5TNWUB6LQ2DIRRJ4G4ZC4WUERZIPEMW546IZMHBAYDUF1XBSSP1Q6X5HRHJB2QLH5MZJ";
expertmode = yes;
wizard_completed = no;
capiovertcp {
enabled = no;
maxctrl = 1;
port = 5031;
emailnotify {
enabled = no;
interval = daily;
From = "";
To = "";
SMTPServer = "";
accountname = "";
passwd = "";
usbhost {
readonly = no;
password = "";
autoprov_enabled = yes;
// EOF
**** END OF FILE ****
**** CFGFILE:voip.cfg
* /var/flash/voip.cfg
* Thu Sep 15 14:21:11 2005
voipcfg {
dnsport = 7077;
rtpport_start = 7078;
ua1 {
enabled = yes;
username =
authname = "";
passwd =
registrar = "sipgate.de";
ttl = 30m;
sipping_enabled = yes;
sipping_interval = 280s;
name = "*GEHEIM*";
authenticatemode = authenticate_mode_none;
infodtmfnotsupported = no;
register_failwaitmax = 30m;
stunserver = "";
stunserverport = 3478;
is_nat_aware = no;
clirtype = clir_displayname;
only_one_dialog = no;
presence_supported = no;
mwi_supported = yes;
tx_packetsize_in_ms = 30;
ua2 {
enabled = yes;
username =
authname = "";
passwd =
ttl = 30m;
name = "*GEHEIM*";
stunserver = "";
is_nat_aware = no;
use_audiocodecs = no;
audiocodecs = "PCMA", "PCMU", "G726-32";
verbose = no;
sip_prio = 0;
rtp_prio = 0;
dyn_codecs = yes;
send_ringtone = no;
enum_support_enabled = no;
enumdomains = "e164.arpa", "e164.org";
rtpstream {
voice_activity_detection {
enabled = no;
vad_threshold = 10000;
generate_noise {
on_packetloss = no;
on_capi_underrun = yes;
jitter {
auto_on = yes;
in_ms = 50;
in_packets = 0;
// EOF
**** CFGFILE:wlan.cfg
* /var/flash/wlan.cfg
* Thu Sep 15 14:24:26 2005
wlancfg {
ap_enabled = 1;
channel = 11;
ssid = "FRITZ!Box Fon WLAN";
hidden_ssid = 0;
power_level = 1;
bg_mode = 0;
user_isolation = 0;
encryption = 1;
passwd = "";
wep_auth_type = "open";
key_id = 0;
key_value0 = "$$$$G1DBFXLD6DPCXP3KRPZK1O5ZLLWGIOWD3TXCAFMAOCFKLQ4TXUZXVWRUM15IBLBFRYRBYBKB5UNMW4T26IGGVROLECSIV2KCX5NJ6RAA";
key_len0 = 13;
key_value1 = "$$$$G6H3O2KV2FF2RURJ3SI2G23DMC414RTYOV6RJSDBCIOZ616VUXAS2WYKPRYZ2NX2DPBAYTTIVS5J4JGXG5JR1HIG36DXMIRYWD5AGYQA";
key_len1 = 13;
key_value2 = "$$$$2QGGCE52FCATCAWM4HKPLTLFVA4JYVF5TPD3E6NGAJ6XTZW6BLWJS5Q52DOHWIMGN5UMLD4PRFF43YE5DYTDHFPR5OAYTZD155RNDSYA";
key_len2 = 13;
key_value3 = "$$$$F4SSYC2SRUPU2NVAP13GY1EMMHY5LKE1KI341HBFAFU6YLN2EH1LOPDLW2OQYLJV6ZJVRFL5INDMD6SEOC1SS4ZXHNKC1HNQQKLIMFIA";
key_len3 = 13;
pskvalue = "";
interval = 3600;
turbomode = yes;
WDS_enabled = no;
WDS_hop = 0;
WDS_mac_master = 00:00:00:00:00:00;
WDS_mac_slave0 = 00:00:00:00:00:00;
WDS_mac_slave1 = 00:00:00:00:00:00;
WDS_mac_slave2 = 00:00:00:00:00:00;
WDS_mac_slave3 = 00:00:00:00:00:00;
WDS_encryption = 0;
WDS_key = "";
