kriegaex@xander:~/src/qemu-ar7/trunk$ mipsel-softmmu/qemu-system-mipsel \
> -M fbox-8mb -L ~/fritz-mtdblocks/w701v /dev/null -parallel none -nographic \
> -redir tcp:2323::23 -redir tcp:8080::80 -redir tcp:8181::81 \
> 2> /dev/null
ram_offset (internal RAM) = 2000000
(AVM) EVA Revision: 1.203 Version: 1203
(C) Copyright 2005 AVM Date: Feb 7 2007 Time: 19:03:32 (0) 2 0-11011
[FLASH:] MACRONIX Top-Flash 8MB
[FLASH:](Eraseregion [0] 127 sectors a 64kB)
[FLASH:](Eraseregion [1] 8 sectors a 8kB)
[SYSTEM:] AR7 on 150MHz/125MHz
Eva_W701V >AVM decompress Kernel:
.............done
start kernel
[ohio_pre_init] System Clk = 12500000 Hz
LINUX started...
Linux version 2.6.13.1-ohio () (gcc version 3.4.6) #1 Thu Nov 15 22:19:52 CET 2007
memsize=32 MByte
flashsize=8 MByte
&_end=0x9423bc64 PFN_ALIGN(&_end)=0x9423c000 CPHYSADDR(PFN_ALIGN(&_end))=0x1423c000 memsize=0x2000000
CPU revision is: 00018448
[ohio_gpio_init]
Determined physical RAM map:
memory: 0023c000 @ 14000000 (reserved)
memory: 01dc4000 @ 1423c000 (usable)
On node 0 totalpages: 8192
[alloc_node_mem_map] reduce size from 2883616 Bytes to 262176 Bytes
[alloc_node_mem_map]: (org) sizeof(mem_map) = 262176 mem_map=0x9423f000-0x9427f020
[alloc_node_mem_map]: sizeof(mem_map) = 2883616 mem_map=0x93fbf000-0x9427f020
zone=0 zone_size[j]=0x90112
realsize=8192
DMA zone: 8192 pages, LIFO batch:3
zone=1 zone_size[j]=0x0
realsize=0
Normal zone: 0 pages, LIFO batch:1
zone=2 zone_size[j]=0x0
realsize=0
HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line: init=/etc/init.d/rc.nfsroot idle=4 mini_fo=ram console=ttyS0,38400n8r
[ld_mmu_r4xx0] memcpy((void *)(CAC_BASE + 0x100), &except_vec2_generic, 0x30)
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 16kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions). Base=0x9420ea94
TLB synthesizer field overflow (simm)
Synthesized TLB load handler fastpath (34 instructions) Base=0x94212620.
Synthesized TLB store handler fastpath (34 instructions) Base=0x94212820.
Synthesized TLB modify handler fastpath (33 instructions) Base=0x94212a20.
PID hash table entries: 256 (order: 8, 4096 bytes)
CPU frequency 176.64 MHz
Using 88.320 MHz high precision timer.
[setup_irq]: irq 255 irqaction->handler 0x94042fd0 (no_action+0x0/0x8 )
[register_console] enable commandline console 0
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 30104k/30480k available (1605k kernel code, 320k reserved, 390k data, 116k init, 0k highmem)
totalram_pages= 7540
Calibrating delay loop...
