22:36:51.310 capi_events.c Source: unknown - Target: 9690902 - Account: 0
22:36:51.310 capi_events.c (CTRL 4099, PLCI: 3) - Call from unknown to 9690902...
22:36:51.311 script_funcs.c Run script: /var/media/ftp/cnmemory-Partition-0-1/dtmfbox-0.3.9/script/script_main.sh CONNECT CAPI OUTGOING 0 -1 "9690902" "unknown" &
22:36:51.392 capi_ctrl.c (IND, CTRL 3, PLCI: 4099) - CAPI_INFO (2c)
22:36:51.394 capi_ctrl.c (IND, CTRL 3, PLCI: 4099) - CAPI_INFO (800d)
22:36:51.395 capi_ctrl.c (IND, CTRL 3, PLCI: 4099) - CAPI_INFO (1e)
22:36:52.010 capi_ctrl.c (IND, CTRL 3, PLCI: 4099) - CAPI_INFO (8003)
22:36:58.869 capi_ctrl.c (IND, CTRL 3, PLCI: 4099) - CAPI_INFO (8)
22:36:58.989 capi_ctrl.c (IND, CTRL 3, PLCI: 4099) - CAPI_DISCONNECT
22:36:58.990 script_funcs.c Run script: /var/media/ftp/cnmemory-Partition-0-1/dtmfbox-0.3.9/script/script_main.sh DISCONNECT CAPI OUTGOING 0 -1 "9690902" "unknown" &
22:53:27.137 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_CONNECT
22:53:27.138 capi_events.c Source: unknown - Target: 12345 - Account: 0
22:53:27.138 capi_events.c (CTRL 3587, PLCI: 3) - Call from unknown to 12345...
22:53:27.138 script_funcs.c Run script: /var/media/ftp/usb/dtmfbox/script/script_main.sh CONNECT CAPI OUTGOING 0 -1 "12345" "unknown" &
22:53:27.221 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_INFO (800d)
22:53:27.222 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_INFO (1e)
22:53:27.222 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_INFO (70)
22:53:27.223 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - DIALED (*) (7)
22:53:27.224 capi_funcs.c DTMF RECEIVED: *
22:53:27.224 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - DIALED (#) (7)
22:53:27.224 capi_funcs.c DTMF RECEIVED: #
22:53:27.225 script_funcs.c Run script: /var/media/ftp/usb/dtmfbox/script/script_main.sh DTMF CAPI OUTGOING 0 -1 "12345" "*#100#" "*" &
22:53:27.299 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - DIALED (1) (7)
22:53:27.300 capi_funcs.c DTMF RECEIVED: 1
22:53:27.301 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - DIALED (0) (7)
22:53:27.302 capi_funcs.c DTMF RECEIVED: 0
22:53:27.303 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - DIALED (0) (7)
22:53:27.304 capi_funcs.c DTMF RECEIVED: 0
22:53:27.305 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - DIALED (#) (7)
22:53:27.308 capi_funcs.c DTMF RECEIVED: #
22:53:27.308 script_funcs.c Run script: /var/media/ftp/usb/dtmfbox/script/script_main.sh DTMF CAPI OUTGOING 0 -1 "12345" "*#100#" "100" &
22:53:27.597 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_INFO (8003)
22:53:28.637 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_INFO (8003)
22:53:29.410 capi_ctrl.c (IND, CTRL 3, PLCI: 3587) - CAPI_CONNECT_ACTIVE
22:53:29.412 script_funcs.c Hook up!
22:53:29.413 script_funcs.c Run script: /var/media/ftp/usb/dtmfbox/script/script_main.sh CONFIRMED CAPI OUTGOING 0 -1 "12345" "*#100#" &
22:53:29.503 capi_ctrl.c (IND, CTRL 3, NCCI: 69123) - CAPI_CONNECT_B3
bodega schrieb:[...]
Hab mal eine Version gepostet, die Keypad unterstützen sollte.
16:17:12.925 dtmfbox.c PJSIP 0.7.0
16:17:12.992 pjlib select() I/O Queue created (0x4e3654)
16:17:12.994 sip_endpoint.c Module "mod-msg-print" registered
16:17:12.996 capi_ctrl.c Init CAPI...
16:17:13.006 capi_ctrl.c CAPI initialized!
16:17:13.007 voip_ctrl.c Init VOIP...
16:17:13.008 voip_ctrl.c Resolve IP from stun.1und1.de:3478 ...
16:17:13.245 voip_ctrl.c Use IP: 87.169.48.80
16:17:13.247 udp0x506a0c SIP UDP transport started, published address is 87.169.48.80:5061
16:17:13.248 voip_ctrl.c UDP server listening on port 5061
16:17:13.252 sip_endpoint.c Module "mod-tsx-layer" registered
16:17:13.253 sip_endpoint.c Module "mod-stateful-util" registered
16:17:13.258 sip_endpoint.c Module "mod-ua" registered
16:17:13.259 voip_ctrl.c VOIP callbacks initialized
16:17:13.260 sip_endpoint.c Module "mod-invite" registered
16:17:13.261 sip_endpoint.c Module "dtmfbox" registered
16:17:13.279 pjlib select() I/O Queue created (0x52cd54)
16:17:13.382 icstr0x5065a0 ICE stream transport created
16:17:13.390 icstr0x54cbd0 ICE stream transport created
16:17:13.398 icstr0x550c08 ICE stream transport created
16:17:13.405 icstr0x554c40 ICE stream transport created
16:17:13.412 icstr0x558c78 ICE stream transport created
16:17:13.421 icstr0x55ccb0 ICE stream transport created
16:17:13.428 icstr0x560ce8 ICE stream transport created
16:17:13.436 icstr0x564d20 ICE stream transport created
16:17:13.445 icstr0x568d58 ICE stream transport created
16:17:13.453 icstr0x56cd90 ICE stream transport created
16:17:13.461 icstr0x570dc8 ICE stream transport created
16:17:13.470 icstr0x574e00 ICE stream transport created
16:17:13.479 icstr0x578e38 ICE stream transport created
16:17:13.487 icstr0x57ce70 ICE stream transport created
16:17:13.496 icstr0x580ea8 ICE stream transport created
16:17:13.503 icstr0x584ee0 ICE stream transport created
16:17:13.512 icstr0x588f18 ICE stream transport created
16:17:13.521 icstr0x58cf50 ICE stream transport created
16:17:13.530 icstr0x590f88 ICE stream transport created
16:17:13.538 icstr0x594fc0 ICE stream transport created
16:17:13.547 icstr0x598ff8 ICE stream transport created
16:17:15.328 voip_ctrl.c VOIP initialized!
16:17:15.336 voip_auth.c SIP (TX-REGISTER):
REGISTER sip:212.227.15.197 SIP/2.0
Via: SIP/2.0/UDP 87.169.48.80:5061;rport;branch=z9hG4bKPj09b400000003eb61797b
Max-Forwards: 70
From: "VOIP Nr1" <sip:[email protected]>;tag=09b400000002eb61797b
To: <sip:[email protected]>
Call-ID: 09b400000001eb61797b
CSeq: 8678 REGISTER
User-Agent: dtmfbox v0.3.9
Contact: <sip:[email protected]:5061>;expires=3600
Expires: 3600
Content-Length: 0
16:17:15.341 voip_auth.c SIP (TX-REGISTER):
Via: SIP/2.0/UDP 87.169.48.80:5061;rport;branch=z9hG4bKPj09b400000006eb61797b
Max-Forwards: 70
From: "VOIP Nr2" <sip:[email protected]>;tag=09b400000005eb61797b
Call-ID: 09b400000004eb61797b
CSeq: 23011 REGISTER
Expires: 3600
Content-Length: 0
16:17:15.343 capi_ctrl.c (0xff) - Listen to CAPI incoming controller 1...
16:17:15.345 capi_ctrl.c (0xff) - Listen to CAPI outgoing controller 1...
16:17:15.346 capi_ctrl.c (0xff) - Listen to CAPI internal controller 3...
16:17:15.348 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
16:17:15.349 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
16:17:15.350 capi_ctrl.c (CNF, CTRL 3, PLCI: 0) - CAPI_LISTEN
16:17:15.351 voip_ctrl.c Start VOIP listen loop...
16:17:15.361 icstr0x5065a0 STUN mapped address: 87.169.48.80:4000
16:17:15.363 icstr0x5065a0 STUN mapped address: 87.169.48.80:4001
16:17:15.364 icstr0x54cbd0 STUN mapped address: 87.169.48.80:4002
16:17:15.366 icstr0x54cbd0 STUN mapped address: 87.169.48.80:4003
16:17:15.367 icstr0x550c08 STUN mapped address: 87.169.48.80:4004
16:17:15.368 icstr0x550c08 STUN mapped address: 87.169.48.80:4005
16:17:15.370 icstr0x554c40 STUN mapped address: 87.169.48.80:4006
16:17:15.371 icstr0x554c40 STUN mapped address: 87.169.48.80:4007
16:17:15.372 icstr0x558c78 STUN mapped address: 87.169.48.80:4008
16:17:15.373 icstr0x558c78 STUN mapped address: 87.169.48.80:4009
16:17:15.375 icstr0x55ccb0 STUN mapped address: 87.169.48.80:4010
16:17:15.376 icstr0x55ccb0 STUN mapped address: 87.169.48.80:4011
16:17:15.378 icstr0x560ce8 STUN mapped address: 87.169.48.80:4012
16:17:15.379 icstr0x560ce8 STUN mapped address: 87.169.48.80:4013
16:17:15.380 icstr0x564d20 STUN mapped address: 87.169.48.80:4014
16:17:15.381 icstr0x564d20 STUN mapped address: 87.169.48.80:4015
16:17:15.387 icstr0x568d58 STUN mapped address: 87.169.48.80:4016
16:17:15.388 icstr0x568d58 STUN mapped address: 87.169.48.80:4017
16:17:15.389 icstr0x56cd90 STUN mapped address: 87.169.48.80:4018
16:17:15.390 icstr0x56cd90 STUN mapped address: 87.169.48.80:4019
16:17:15.391 icstr0x570dc8 STUN mapped address: 87.169.48.80:4020
16:17:15.393 icstr0x570dc8 STUN mapped address: 87.169.48.80:4021
16:17:15.395 icstr0x574e00 STUN mapped address: 87.169.48.80:4022
16:17:15.396 icstr0x574e00 STUN mapped address: 87.169.48.80:4023
16:17:15.397 icstr0x578e38 STUN mapped address: 87.169.48.80:4024
16:17:15.398 icstr0x578e38 STUN mapped address: 87.169.48.80:4025
16:17:15.400 icstr0x57ce70 STUN mapped address: 87.169.48.80:4026
16:17:15.401 icstr0x57ce70 STUN mapped address: 87.169.48.80:4027
16:17:15.402 icstr0x580ea8 STUN mapped address: 87.169.48.80:4028
16:17:15.405 icstr0x580ea8 STUN mapped address: 87.169.48.80:4029
16:17:15.406 icstr0x584ee0 STUN mapped address: 87.169.48.80:4030
16:17:15.407 icstr0x584ee0 STUN mapped address: 87.169.48.80:4031
16:17:15.421 icstr0x588f18 STUN mapped address: 87.169.48.80:4032
16:17:15.422 icstr0x588f18 STUN mapped address: 87.169.48.80:4033
16:17:15.424 icstr0x58cf50 STUN mapped address: 87.169.48.80:4034
16:17:15.426 icstr0x58cf50 STUN mapped address: 87.169.48.80:4035
16:17:15.427 icstr0x590f88 STUN mapped address: 87.169.48.80:4036
16:17:15.428 icstr0x590f88 STUN mapped address: 87.169.48.80:4037
16:17:15.429 icstr0x594fc0 STUN mapped address: 87.169.48.80:4038
16:17:15.431 icstr0x594fc0 STUN mapped address: 87.169.48.80:4039
16:17:15.432 icstr0x598ff8 STUN mapped address: 87.169.48.80:4040
16:17:15.433 icstr0x598ff8 STUN mapped address: 87.169.48.80:4041
16:17:15.483 voip_auth.c SIP (RX-REGISTER):
SIP/2.0 200 OK
Via: SIP/2.0/UDP 87.169.48.80:5061;rport=5061;branch=z9hG4bKPj09b400000007eb61797b
To: <sip:[email protected]>;tag=a6a1c5f60faecf035a1ae5b6e96e979a-8fbb
CSeq: 8679 REGISTER
Contact: <sip:[email protected]:5061>;expires=5415, <sip:[email protected]:5061>;expires=28301, <sip:[email protected];uniq=CAB8543514A0F46EAE7B3F0EC2C75>;expires=28255
Server: UI OpenSer
Content-Length: 0
16:17:15.485 voip_auth.c SIP registration successful (212.227.15.197), status=14
16:17:15.485 voip_auth.c Next registration in 5415 sec
16:17:15.495 voip_auth.c SIP (RX-REGISTER):
SIP/2.0 403 User und Anrufernummer verschieden
Via: SIP/2.0/UDP 87.169.48.80:5061;rport=5061;branch=z9hG4bKPj09b400000008eb61797b
To: <sip:[email protected]>;tag=329cfeaa6ded039da25ff8cbb8668bd2.ec5a
CSeq: 23012 REGISTER
Server: UI OpenSer
Content-Length: 0
16:17:15.496 voip_auth.c ERR: SIP registration failed (212.227.15.197), status=14!
16:17:15.497 voip_auth.c ERR: 403 - User und Anrufernummer verschieden
16:38:13.991 voip_auth.c SIP registration successful (212.227.15.197), status=14
16:38:13.992 voip_auth.c Next registration in 28472 sec
16:38:35.812 capi_ctrl.c (IND, CTRL 1, PLCI: 6401) - CAPI_CONNECT
16:38:35.813 capi_events.c Source: 176xxxxxx94 - Target: 8xxxx7 - Account: 0
16:38:35.816 capi_events.c (CTRL 6401, PLCI: 1) - Call from 176xxxxxx94 to 8xxxx7...
16:38:35.818 script_funcs.c Run script: /var/media/ftp/USBDISK2-0-Partition-0-1/dtmfbox-0.3.9/script/script_main.sh CONNECT CAPI INCOMING 0 -1 "8xxxx7" "176xxxxxx94" &
16:38:35.908 capi_ctrl.c (IND, CTRL 1, PLCI: 6401) - CAPI_INFO (70)
16:38:35.909 capi_ctrl.c (CNF, CTRL 1, PLCI: 6401) - CAPI_ALERT
16:38:37.011 capi_ctrl.c (IND, CTRL 3, PLCI: 771) - CAPI_CONNECT
16:38:37.012 capi_events.c Source: unknown - Target: 5xxxx9 - Account: -1
16:38:37.013 capi_events.c ERR: Account not found!
16:38:37.016 capi_ctrl.c (IND, CTRL 3, PLCI: 771) - CAPI_INFO (800d)
16:38:37.017 capi_ctrl.c (IND, CTRL 3, PLCI: 771) - CAPI_INFO (1e)
16:38:37.128 capi_ctrl.c (IND, CTRL 3, PLCI: 771) - CAPI_INFO (70)
16:38:39.046 capi_ctrl.c (IND, CTRL 1, PLCI: 6401) - CAPI_INFO (8)
16:38:39.048 capi_ctrl.c (IND, CTRL 1, PLCI: 6401) - CAPI_DISCONNECT
16:38:39.049 script_funcs.c Run script: /var/media/ftp/USBDISK2-0-Partition-0-1/dtmfbox-0.3.9/script/script_main.sh DISCONNECT CAPI INCOMING 0 -1 "8xxxx7" "176xxxxxx94" &
16:38:39.269 capi_ctrl.c (IND, CTRL 3, PLCI: 771) - CAPI_INFO (8)
16:38:39.408 capi_ctrl.c (IND, CTRL 3, PLCI: 771) - CAPI_DISCONNECT
22:20:25.276 dtmfbox.c PJSIP 0.7.0
22:20:25.339 pjlib select() I/O Queue created (0x4e3654)
22:20:25.339 sip_endpoint.c Module "mod-msg-print" registered
22:20:25.341 capi_ctrl.c Init CAPI...
22:20:25.352 capi_ctrl.c CAPI initialized!
22:20:25.353 voip_ctrl.c Init VOIP...
22:20:25.354 voip_ctrl.c Resolve local IP ...
22:20:25.706 voip_ctrl.c Use IP: 192.168.179.1
22:20:25.708 udp0x506604 SIP UDP transport started, published address is 192.168.179.1:5061
22:20:25.709 voip_ctrl.c UDP server listening on port 5061
22:20:25.714 sip_endpoint.c Module "mod-tsx-layer" registered
22:20:25.715 sip_endpoint.c Module "mod-stateful-util" registered
22:20:25.720 sip_endpoint.c Module "mod-ua" registered
22:20:25.721 voip_ctrl.c VOIP callbacks initialized
22:20:25.722 sip_endpoint.c Module "mod-invite" registered
22:20:25.723 sip_endpoint.c Module "dtmfbox" registered
22:20:25.741 pjlib select() I/O Queue created (0x52c94c)
22:20:26.362 voip_ctrl.c RTP/RTCP: 192.168.179.1:4000-4001
22:20:26.894 voip_ctrl.c RTP/RTCP: 192.168.179.1:4002-4003
22:20:27.430 voip_ctrl.c RTP/RTCP: 192.168.179.1:4004-4005
22:20:27.960 voip_ctrl.c RTP/RTCP: 192.168.179.1:4006-4007
22:20:28.493 voip_ctrl.c RTP/RTCP: 192.168.179.1:4008-4009
22:20:29.024 voip_ctrl.c RTP/RTCP: 192.168.179.1:4010-4011
22:20:29.551 voip_ctrl.c RTP/RTCP: 192.168.179.1:4012-4013
22:20:30.086 voip_ctrl.c RTP/RTCP: 192.168.179.1:4014-4015
22:20:30.087 voip_ctrl.c RTP/RTCP media transport created!
22:20:31.868 voip_ctrl.c VOIP initialized!
22:20:31.872 capi_ctrl.c (0xff) - Listen to CAPI incoming controller 1...
22:20:31.874 capi_ctrl.c (0xff) - Listen to CAPI outgoing controller 1...
22:20:31.876 capi_ctrl.c (0xff) - Listen to CAPI internal controller 3...
22:20:31.877 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
22:20:31.878 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
22:20:31.880 capi_ctrl.c (CNF, CTRL 3, PLCI: 0) - CAPI_LISTEN
22:20:31.881 voip_ctrl.c Start VOIP listen loop...
22:20:33.921 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_CONNECT
22:20:33.922 capi_events.c Source: unknown - Target: 9690901 - Account: -1
22:20:33.925 capi_events.c ERR: Account not found!
22:20:33.926 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_INFO (2c)
22:20:33.927 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_INFO (800d)
22:20:33.929 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_INFO (1e)
22:20:39.254 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_INFO (8003)
22:20:39.329 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_INFO (8003)
22:20:41.337 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_INFO (8)
22:20:41.338 capi_ctrl.c (IND, CTRL 3, PLCI: 5891) - CAPI_DISCONNECT
Probiere bitte folgendes:
Du legst einen 1und1-Account an (mit Registrar, Username...).
Dann legst du einen Zweiten an (als Type: VoIP), jedoch ohne Registrar, Username, Passwort, ID. Nur MSN und Name (so dass sich der zweite Account nicht registriert).
Dann schauen ob es läuft
Das mit dem Callback funktioniert wie von Dir beschrieben. Nur wenn der Callback mit dem 1und1 Acount (MSN) geführt werden soll bekomme ich keinen Rückruf??Der Callback müsste so aussehen: 176xxxxxx94/0176xxxxxx94/8xxxx7
22:37:33.714 voip_auth.c SIP registration successful (212.227.15.197), status=14
22:37:33.715 voip_auth.c Next registration in 28428 sec
22:37:33.717 icstr0x590f88 STUN mapped address: 87.169.48.80:4037
22:37:33.718 icstr0x594fc0 STUN mapped address: 87.169.48.80:4038
22:37:33.720 icstr0x594fc0 STUN mapped address: 87.169.48.80:4039
22:37:33.721 icstr0x598ff8 STUN mapped address: 87.169.48.80:4040
22:37:33.722 icstr0x598ff8 STUN mapped address: 87.169.48.80:4041
22:37:44.433 voip_events.c RX-REQUEST 1780 bytes Request msg INVITE/cseq=1 (rdata0x507a94) from UDP 212.227.15.197:5060
22:37:44.453 voip_events.c Incoming request (49176xxxxxx94:0 -> 496xxx5xxxx7:0)
22:37:44.456 voip_events.c Create UAS dialog
22:37:44.460 icstr0x5065a0 ICE session created, comp_cnt=2, role is Controlled agent
22:37:44.461 icstr0x5065a0 Candidate 0 added: comp_id=1, type=Host, foundation=Hc0a80101, addr=192.168.1.1:4000, base=192.168.1.1:4000, prio=0x64ffffff (1694498815)
22:37:44.461 icstr0x5065a0 Candidate 1 added: comp_id=1, type=Server Reflexive, foundation=Sc0a80101, addr=87.169.48.80:4000, base=192.168.1.1:4000, prio=0x7effffff (2130706431)
22:37:44.463 icstr0x5065a0 Candidate 2 added: comp_id=2, type=Host, foundation=Hc0a80101, addr=192.168.1.1:4001, base=192.168.1.1:4001, prio=0x64fffffe (1694498814)
22:37:44.464 icstr0x5065a0 Candidate 3 added: comp_id=2, type=Server Reflexive, foundation=Sc0a80101, addr=87.169.48.80:4001, base=192.168.1.1:4001, prio=0x7efffffe (2130706430)
22:37:44.465 voip_events.c Create media capability
22:37:44.467 voip_events.c Create invite session
22:37:44.472 voip_events.c Call state changed to INCOMING [port=0]
22:37:44.473 voip_events.c Respond stateless with code 180 (*ring*)
22:37:44.476 voip_events.c Call EARLY [port=0, reason=0 (Default status message)]
22:37:44.626 script_funcs.c Run script: /var/media/ftp/USBDISK2-0-Partition-0-1/dtmfbox-0.3.9/script/script_main.sh CONNECT VOIP INCOMING 0 -1 "496xxx5xxxx7" "[email protected]" &
22:37:44.705 sip_endpoint.c Message Request msg INVITE/cseq=1 (rdata0x507a94) from 212.227.15.197:5060 was dropped/unhandled by any modules
22:37:47.031 voip_events.c Call DISCONNECTED [port=0, reason=487 (Request Terminated)]
22:37:47.032 voip_events.c Hangup [0]
22:37:47.033 script_funcs.c Run script: /var/media/ftp/USBDISK2-0-Partition-0-1/dtmfbox-0.3.9/script/script_main.sh DISCONNECT VOIP INCOMING 0 -1 "496xxx5xxxx7" "[email protected]" &
22:37:47.396 icstr0x5065a0 Destroying ICE session
die 5xxxx9 ist eine 1und1 MSN die ich eigentlich nicht in der dtmfbox eingetragen habe, aber trotzdem im LOG steht warum auch immer.Ich bin mit 1und1 nicht so vertraut. Ist 5xxxx9 ein Username?
Mein zweites Problem ist, wie das Senden der DTMF Kommandos funktionieren soll? Dazu muss der AB auch dran gehen oder wie? Dann Admin-Pin eingeben und dann ein DTMF Command z.B. *1#?
05:49:08.571 voip_auth.c SIP (TX-REGISTER):
REGISTER sip:freenet.de SIP/2.0
Via: SIP/2.0/UDP 169.254.2.1:5061;rport;branch=z9hG4bKPj0fe60000000675cb6c55
Max-Forwards: 70
From: "freenet" <sip:[email protected]>;tag=0fe60000000575cb6c55
Call-ID: 0fe60000000475cb6c55
CSeq: 48414 REGISTER
Contact: <sip:[email protected]>;expires=3600
Expires: 3600
Content-Length: 0
05:49:08.581 capi_ctrl.c (0xff) - Listen to CAPI incoming controller 1...
05:49:08.584 capi_ctrl.c (0xff) - Listen to CAPI outgoing controller 1...
05:49:08.585 capi_ctrl.c (0xff) - Listen to CAPI internal controller 3...
05:49:08.587 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
05:49:08.588 capi_ctrl.c (CNF, CTRL 1, PLCI: 0) - CAPI_LISTEN
05:49:08.589 capi_ctrl.c (CNF, CTRL 3, PLCI: 0) - CAPI_LISTEN
05:49:08.684 voip_auth.c SIP (RX-REGISTER):
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 169.254.2.1:5061;branch=z9hG4bKPj0fe60000000775cb6c55;rport
From: "voipstunt" <sip:[email protected]>;tag=0fe60000000275cb6c55
Call-ID: 0fe60000000175cb6c55
CSeq: 33622 REGISTER
Server: (Very nice Sip Registrar/Proxy Server)
Allow: ACK,BYE,CANCEL,INVITE,REGISTER,OPTIONS,INFO
Content-Length: 0
05:49:08.685 voip_auth.c SIP registration successful (sip.voipstunt.com), st
atus=17
05:49:08.685 voip_auth.c Next registration in 3600 sec
05:49:36.865 capi_ctrl.c (IND, CTRL 1, PLCI: 3585) - CAPI_CONNECT
05:49:36.866 capi_events.c Source: 163xxxxxx - Target: 38xxxxxx - Account: 0
05:49:36.867 capi_events.c (CTRL 3585, PLCI: 1) - Call from 163xxxxxxx to 38xxxxxx...
05:49:36.868 script_funcs.c Run script: /var/dtmfbox/script/script_main.sh CONN
ECT CAPI INCOMING 0 -1 "38995212" "1632765348" &
05:49:36.966 capi_ctrl.c (IND, CTRL 1, PLCI: 3585) - CAPI_INFO (70)
05:49:36.967 capi_ctrl.c (IND, CTRL 1, PLCI: 3585) - CAPI_INFO (c000)
05:49:36.968 capi_ctrl.c (CNF, CTRL 1, PLCI: 3585) - CAPI_ALERT
sh: Can't open /var/tmp/parse_telefon.sh
telefon: SIGCHLD received!
Killed
Jul 2 06:07:15 voipd[463]: capiconn_send: failed 1
07:00:38.0
SENDING TO: 194.97.54.97:5060
To: 069XXXXXXXX<sip:[email protected]>
From: 069XXXXXXXX<sip:[email protected]>;tag=2a371f16
Via: SIP/2.0/UDP 89.61.XXX.XX:61005;branch=z9hG4bK-d87543-140862288-1--d87543-;rport
Call-ID: 1220d758e6238755
CSeq: 2 REGISTER
Contact: <sip:[email protected]:61005>
Expires: 3600
Max-Forwards: 70
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, SUBSCRIBE, INFO
User-Agent: eyeBeam release 3004t stamp 16741
Authorization: Digest username="julXXXXXXXX",realm="freenet.de",nonce="468887a49722edb4f7025e65205a03193cd10c67",uri="sip:freenet.de",response="0ad7dda47517aecfc493fad53aed61cc",cnonce="694ce0469b3d8c03",nc=00000001,qop=auth,algorithm=MD5
Content-Length: 0
07:00:38.1
RECEIVING FROM: 194.97.54.97:5060
SIP/2.0 200 OK
Record-Route: <sip:194.97.54.97;ftag=2a371f16;lr=on>
To: 069XXXXXXXX<sip:[email protected]>;tag=b1208d4ae3b06be8af84ae138f482e74.b15d
Via: SIP/2.0/UDP 89.61.XXX.XX:61005;branch=z9hG4bK-d87543-140862288-1--d87543-;rport=61005
CSeq: 2 REGISTER
Contact: <sip:[email protected];uniq=130CE2EBD4441BD867550042D17BC>;expires=1753, <sip:[email protected]:61005>;expires=3600
Content-Length: 0
REGISTER sip:194.97.54.97 SIP/2.0
Via: SIP/2.0/UDP 169.254.2.1:5061;rport;branch=z9hG4bKPj014b0000000875cb6c55
Max-Forwards: 70
From: "freenet" <sip:[email protected]>;tag=014b0000000775cb6c55
Call-ID: 014b0000000675cb6c55
Expires: 3600
Content-Length: 0
07:14:46.924 voip_auth.c SIP (RX-REGISTER):
SIP/2.0 403 %25FRN-0021 Forbidden Destination
Via: SIP/2.0/UDP 169.254.2.1:5061;received=89.61.XXX.XX;rport=5061;branch=z9hG4bKPj014b0000000575cb6c55
From: "freenet" <sip:[email protected]>;tag=014b0000000475cb6c55
To: <sip:[email protected]>;tag=b1208d4ae3b06be8af84ae138f482e74.3d98
Call-ID: 014b0000000175cb6c55
Content-Length: 0
07:14:46.925 voip_auth.c ERR: SIP registration failed (194.97.54.97), status=12!
07:14:46.926 voip_auth.c ERR: 403 - %25FRN-0021 Forbidden Destination
