ADAM2 Revision TI:0.18.01 AVM: Version:78
(C) Copyright 1996-2003 Texas Instruments Inc. All Rights Reserved.
(C) Copyright 2003 Telogy Networks, Inc.
(C) Copyright 2003-2004 AVM
AVM_Ar7 >
Press any key to abort OS load, or wait 5 seconds for OS to boot...
Launching kernel decompressor.
Starting LZMA Uncompression Algorithm.
Copyright (C) 2003 Texas Instruments Incorporated; Copyright (C) 1999-2003 Igor
Pavlov.
Compressed file is LZMA format.
Kernel decompressor was successful ... launching kernel.
LINUX started...
Config serial console: ttyS0,38400
This SOC has MDIX cababilities on chip: HWRevision="61"
AutoMDIX="<unknown>"
MDIX enabled.
prom_init: local_env_buffer 885 used (max 2048)
CPU revision is: 00018448
Primary instruction cache 16kb, linesize 16 bytes (4 ways)
Primary data cache 16kb, linesize 16 bytes (4 ways)
Number of TLB entries 16.
Linux version 2.4.17_mvl21-malta-mips_fp_le (daniel@powerwiesel) (gcc version 3.3.2) #1 So Dez 18 16:17:50 CET 2005
Reset Status: SW reset 1
DEBUG: Bring MDIO out of reset.
Determined physical RAM map:
memory: 14000000 @ 00000000 (reserved)
memory: 00020000 @ 14000000 (ROM data)
memory: 01fe0000 @ 14020000 (usable)
On node 0 totalpages: 8192
zone(0): 8192 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line:
calculating r4koff... 000b71b0(750000)
CPU frequency 150.00 MHz
Calibrating delay loop... 149.91 BogoMIPS
Freeing Adam2 reserved memory [0x14001000,0x0001f000]
Memory: 30660k/32768k available (1307k kernel code, 2108k reserved, 79k data, 52
k init)
Dentry-cache hash table entries: 4096 (order: 3, 32768 bytes)
Inode-cache hash table entries: 2048 (order: 2, 16384 bytes)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 8192 (order: 3, 32768 bytes)
Checking for 'wait' instruction... available.
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
Disabling the Out Of Memory Killer
devfs: v1.7 (20011216) Richard Gooch ([email protected])
devfs: boot_options: 0x1
Squashfs 2.1-r2 (released 2004/12/15) (C) 2002-2004 Phillip Lougher
pty: 32 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with no serial options enabled
ttyS00 at 0xa8610e00 (irq = 15) is a 16550A
block: 64 slots per queue, batch=16
Universal TUN/TAP device driver 1.4 (C)1999-2001 Maxim Krasnyansky
resize flash to 0x400000 Bytes
avalanche flash device: 0x400000 at 0x10000000.
Amd/Fujitsu Extended Query Table v1.1 at 0x0040
Physically mapped flash:0: Swapping erase regions for broken CFI table.
number of CFI chips: 1
Looking for mtd device :mtd0:
NOTICE: possible hidden SquashFs continuation found at 0xb00c0000 (900c0000 - 903c0000)
Found a mtd0 image (0xc0000), with size (0x300000).
Creating 1 MTD partitions on "Physically mapped flash:0":
0x000c0000-0x003c0000 : "mtd0"
Looking for mtd device :mtd1:
locking for hidden SquashFs image (0x90010000 - 0x900c0000)
hidden SquashFs image found at 0xb007eb00
add to memory config: hidden squashfs 0x9007eb00-0x900c0000
Found a mtd1 image (0x10000), with size (0xb0000).
0x00010000-0x000c0000 : "mtd1"
Looking for mtd device :mtd2:
Found a mtd2 image (0x0), with size (0x10000).
0x00000000-0x00010000 : "mtd2"
Looking for mtd device :mtd3:
Found a mtd3 image (0x3c0000), with size (0x20000).
0x003c0000-0x003e0000 : "mtd3"
Looking for mtd device :mtd4:
Found a mtd4 image (0x3e0000), with size (0x20000).
0x003e0000-0x00400000 : "mtd4"
NOTICE: create contiguous segment and register as root device
Found a mtd5 image (0x7eb00), with size (0x341500).
0x0007eb00-0x003c0000 : "mtd5"
mtd: partition "mtd5" doesn't start on an erase block boundary -- force read-only
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
mount on mtd3 and mtd4 (double buffering)
Adam2 environment variables API installed.
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 2048 bind 4096)
Linux IP multicast router 0.06 plus PIM-SM
ip_conntrack version 2.0 (256 buckets, 2048 max) - 364 bytes per conntrack
ip_tables: (c)2000 Netfilter core team
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NET4: Ethernet Bridge 008 for NET4.0
Initializing the WAN Bridge.
Please set the MAC Address for the WAN Bridge.
Set the Environment variable 'wan_br_mac'.
MAC Address should be in the following format: xx.xx.xx.xx.xx.xx
802.1Q VLAN Support v1.6 Ben Greear <[email protected]>
vlan Initialization complete.
VFS: Mounted root (squashfs filesystem) readonly.
root device=/dev/mtdblock/6
Mounted devfs on /dev
Freeing unused kernel memory: 52k freed
[sys_reboot]: cmd=0x0
init started: BusyBox v1.1.0-pre1 (2005.12.18-15:19+0000) multi-call binary
Algorithmics/MIPS FPU Emulator v1.5
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avm.o
Warning: loading avm will taint the kernel: non-GPL license -
(C) Copyright 20AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Oct 21 2005 11:43:03)
03, Texas Instruments, Inc
(C) Copyright 2004, 2005, AVM
See http://www.tux.org/lkml/#export-tainted for information about tainted modules
c001b000 __insmod_avm_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avm.o_M43A720C6_V-1 [avm]
c001b060 __insmod_avm_S.text_L28976 [avm]
c00221b0 __insmod_avm_S.rodata_L3952 [avm]
c0023430 __insmod_avm_S.data_L416 [avm]
c00235d0 __insmod_avm_S.bss_L5408 [avm]
AR7WDT: System Init UEberwachung 120 Sekunden
**** adam2 environment ****
HWRevision 61
ProductID Fritz_Box_WLAN
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 0.18.01
bootserport tty0
bluetooth 00:04:44:44:44:07
cpufrequency 150000000
firstfreeaddress 0x947310d8
firmware_version avm
firmware_info 08.03.91
flashsize 0x00400000
maca 00:04:44:44:44:5B
macb 00:04:44:44:44:02
macwlan 00:04:44:44:44:5C
macdsl 00:0444:44:44::5D
memsize 0x02000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x900C0000,0x903C0000
mtd1 0x90010000,0x900C0000
mtd2 0x90000000,0x90010000
mtd3 0x903C0000,0x903E0000
mtd4 0x903E0000,0x90400000
my_ipaddress 192.168.1.1
prompt AVM_Ar7
ptest
reserved 00:04:44:44:44:00
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 78
usb_board_mac 00:04:44:44:44:5E
usb_rndis_mac 00:04:44:44:44:5F
usb_device_id 0x3D00
usb_revision_id 0x0100
usb_device_name USB DSL Device
usb_manufacturer_name AVM
HWRevision='61'
ANNEX='B'
OEM='avm'
Language='de'
Country='049'
TZ='CET-1CEST,M3.5.0,M10.5.0'
CONFIG_AB_COUNT='2'
CONFIG_ANNEX='B'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='n'
CONFIG_AUDIO='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='y'
CONFIG_CAPI_MIPS='y'
CONFIG_CAPI_UBIK='n'
CONFIG_CAPI_XILINX='n'
CONFIG_CDROM='y'
CONFIG_CDROM_FALLBACK='y'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ETH_COUNT='1'
CONFIG_FIRMWARE_URL='http://www.avm.de/fritzbox-firmware-update.php?hardware=61&
oem=avm&language=de&country='
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.fonwlan.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_4MB_1eth_2ab_isdn_pots_wlan_43040'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_WLAN'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon WLAN'
CONFIG_RAMSIZE='32'
CONFIG_ROMSIZE='4'
CONFIG_SERVICEPORTAL_URL='http://www.avm.de/fritzbox-service-portal.php?hardware
=61&oem=avm&language=de&country='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION='ds-0.1'
CONFIG_UBIK2='n'
CONFIG_USB='y'
CONFIG_USB_HOST_AVM='n'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='n'
CONFIG_USB_STORAGE='n'
CONFIG_USB_WLAN_AUTH='n'
CONFIG_VERSION='03.91'
CONFIG_VERSION_MAJOR='08'
CONFIG_VLYNQ0='1'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='y'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='n'
set 'Activate Wizzard'
ln -s /etc/default.049/fx_moh.default /var/fx_moh
checkempty: : No such file or directory
checkempty: warning, /var/flash/ar7.cfg not found - nop
checkempty: warning, /var/flash/voip.cfg not found - nop
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_cpmac.o
Warning: loading avalanche_cpmac will taint the kernel: non-GPL license -
(C) Copyright 2003, Texas Instruments, Inc
(C) Copycpmac .bss-address: 0xc003b45c (&cpmac_cpu_freq - 0x4)
right 2004, AVM
les
eth0 irq= 0 io=a8610000
Installed 1 cpmac instances.
c003b450 __insmod_avalanche_cpmac_S.bss_L624 [avalanche_cpmac]
c00374a0 __insmod_avalanche_cpmac_S.rodata_L12960 [avalanche_cpmac]
c003a740 __insmod_avalanche_cpmac_S.data_L1104 [avalanche_cpmac]
c0028000 __insmod_avalanche_cpmac_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/ke
rnel/hidden/avalanche_cpmac.o_M43A720C6_V-1 [avalanche_cpmac]
c0028060 __insmod_avalanche_cpmac_S.text_L62496 [avalanche_cpmac]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/char/avalanche_v
lynq/avalanche_vlynq.o
Warning: loading avalanche_vlynqvlynq_dev_init: 1/2 VLYNQs, mask 0x0001
will taint the GPIO pin reskernel: non-GPL et, bit 6
license - (C) CoSetup registers for VLYNQ0
pyright 2003, TeSet local_mem.RxSize to 0x2000000
xas Instruments,VLYNQ_TXMAP_REG = 4000000
Inc
(C) CopyriVLYNQ_R_RXMAP_OFFSET_REG(map=1) = c0000000
ght 2004, AVM
VLYNQ_R_RXMAP_SIZE_REG(map=1) = 40000
See http://www.VLYNQ_R_RXMAP_OFFSET_REG(map=2) = f0000000
tux.org/lkml/#exVLYNQ_R_RXMAP_SIZE_REG(map=2) = 22000
port-tainted forVLYNQ_R_TXMAP_REG = 0
information aboVLYNQ_RXMAP_OFFSET_REG(map=1) = 14000000
ut tainted modulVLYNQ_RXMAP_SIZE_REG(map=1) = 2000000
es
VLYNQ_REV_REG = 1010b
VLYNQ0: init succeeded!
vlynq init done
VLYNQ0: Misc device vlynq0 registered, minor #63. (0)
VLYNQ0: Running on IRQ 29.
VLYNQ1: Misc device vlynq1 registered, minor #62. (0)
VLYNQ1: Init failed!
c003f000 __insmod_avalanche_vlynq_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/char/avalanche_vlynq/avalanche_vlynq.o_M43A720C5_V-1 [avalanche_vlynq]
c003f060 __insmod_avalanche_vlynq_S.text_L7856 [avalanche_vlynq]
c0040f30 __insmod_avalanche_vlynq_S.rodata_L2064 [avalanche_vlynq]
c0041a70 __insmod_avalanche_vlynq_S.data_L1168 [avalanche_vlynq]
c0041f00 __insmod_avalanche_vlynq_S.bss_L2448 [avalanche_vlynq]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_usb.o
Warning: loading avalanche_usb will taint the kernel: non-GPL license - Propriet
AVM netusb, revision 02.01.06
ary
See http:
//www.tux.org/lkInitializing USB CDC/CDROM driver (starting in CDC mode)...
ml/#export-taint
ed for informatinetusb: device_id=0x3d00 , revision_id=0x0100
Loaded.
c0044000 __insmod_avalanche_usb_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/avalanche_usb.o_M43A720C6_V-1 [avalanche_usb]
c0044060 __insmod_avalanche_usb_S.text_L29488 [avalanche_usb]
c004b3b0 __insmod_avalanche_usb_S.rodata_L2656 [avalanche_usb]
c004be10 __insmod_avalanche_usb_S.data_L2912 [avalanche_usb]
c004caa0 __insmod_avalanche_usb_S.bss_L4512 [avalanche_usb]
usb: CDROM Fallback=y ISO=/lib/modules/cdrom.iso
attempting to load DSL Firmware '/lib/modules/ar0700xx.bin'
**** ANNEX: 'B'
setting DSL Firmware to Annex B
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/atm/tiatm.o
Warning: loading tiatm will taint the kernel: non-GPL license -
(C) Copyright 2004.text 0xc004f060, AVM
See h.bss 0xc0063040
ttp://www.tux.or.data 0xc0061be0
g/lkml/#export-t.rodata 0xc005f030
ainted for inforregistered device TI Avalanche SAR
mation about taitiatm driver (patch_annex=0xc0063040)
nted modules
Sangam detected
rev = 21, timecode=4280226 > 4208000-> boost
** overclocking possible
PM_STATUS2(before switch on) = 0x03
12 Volt:up korrekt 1.5 Volt: up korrekt Fuse Mode is disabled
PM_STATUS2(after switch on) = 0x03
power up success !
#### DSP Core voltage set to 1,5 V ####
p_dsp_voltage_set = 0xc0058028
avm event register
Texas Instruments ATM driver: version:[4.03.03.00]
c004f000 __insmod_tiatm_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/atm/tiatm.o_M43A720C5_V-1 [tiatm]
c004f060 __insmod_tiatm_S.text_L67472 [tiatm]
c005f810 __insmod_tiatm_S.rodata_L8512 [tiatm]
c0061be0 __insmod_tiatm_S.data_L5216 [tiatm]
c0063040 __insmod_tiatm_S.bss_L5632 [tiatm]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capifs.o
capifs: Rev 1.1.4.1
c0068000 __insmod_capifs_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capifs.o_M43A720C5_V-1 [capifs]
c0068060 __insmod_capifs_S.text_L3632 [capifs]
c0068eb0 __insmod_capifs_S.rodata_L224 [capifs]
c00690e0 __insmod_capifs_S.data_L272 [capifs]
c00691f0 __insmod_capifs_S.bss_L16 [capifs]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/capiutil.o
c006b000 __insmod_capiutil_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/capiutil.o_M43A720C6_V-1 [capiutil]
c006b060 __insmod_capiutil_S.text_L3888 [capiutil]
c006bfb0 __insmod_capiutil_S.rodata_L1920 [capiutil]
c006c900 __insmod_capiutil_S.data_L1216 [capiutil]
c006cdc0 __insmod_capiutil_S.bss_L8208 [capiutil]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/kernelcapi.o
CAPI-driver Rev 1.1.4.1: loaded
c0070000 __insmod_kernelcapi_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/hidden/kernelcapi.o_M43A720C6_V-1 [kernelcapi]
c0070060 __insmod_kernelcapi_S.text_L15968 [kernelcapi]
c0073ee0 __insmod_kernelcapi_S.rodata_L2288 [kernelcapi]
c0074970 __insmod_kernelcapi_S.data_L304 [kernelcapi]
c0074aa0 __insmod_kernelcapi_S.bss_L14608 [kernelcapi]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capi.o
capi20: started up with major 68
kcapi: capi20 attached
capi20: Rev 1.1.4.2: started up with major 68 (middleware+capifs)
c007e960 __insmod_capi_S.rodata_L1104 [capi]
c007a000 __insmod_capi_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/avmb1/capi.o_M43A720C5_V-1 [capi]
c007a060 __insmod_capi_S.text_L18656 [capi]
c007edb0 __insmod_capi_S.data_L224 [capi]
c007efa0 __insmod_capi_S.bss_L3328 [capi]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/isdn/isdn_fon/isdn_fbox.o
Warning: loading isdn_fbox will taint the kernel: non-GPL license - Proprietary
isdn_fbox: AVM F!Box driver, revision 1.7 #825
isdn_fbox: (isdn_fbox built on Nov 7 2005 at 13:09:50)
isdn_fbox: Loading...
isdn_fbox: Driver 'isdn_fbox' attached to stack
kcapi: driver isdn_fbox attached
isdn_fbox: Auto-attaching with io 0xbc000000, irq 1...
isdn_fbox: Stack version 3.11-07
gpio_dataonly_test: 0
gpio_ssi_init: done
4 DUSLIC_SlotsAvail
DuSlic reseted
Slot0 LM_INT=0x1 0x91 (571)
Slot0 LMstopped 0x0 0x34 (27)
Slot0 LM_INT=0x1 0x91 (562)
Slot0 LMstopped 0x0 0x3d (27)
Slot0 LM_INT=0x0 0x79 (562) IT_RING_OK
Slot0 LMstopped 0x0 0x1f (26)
Slot0 LM_INT=0x1 0x9d (562) IT_TIP_OK
Slot0 LMstopped 0x0 0x37 (20)
Slot0 LM=0xdf 0x97 (0) TIP=-57V
Slot0 LM=0x4 0x4e (94) TIP0V=-6V
Slot0 LM=0x8 0x2d (173) TIPLOOP=-13V
Slot0 LM=0x12 0xcb (0)
Slot1 LM_INT=0x2 0x82 (574)
Slot1 LMstopped 0x0 0x54 (26)
Slot1 LM_INT=0x2 0x84 (562)
Slot1 LMstopped 0x2 0x46 (26)
Slot1 LM_INT=0x0 0x88 (562) IT_RING_OK
Slot1 LMstopped 0x0 0x1d (27)
Slot1 LM_INT=0x1 0x5e (562) IT_TIP_OK
Slot1 LMstopped 0x1 0xf2 (21)
Slot1 LM=0xdf 0xc3 (0) TIP=-57V
Slot1 LM=0x3 0x80 (94) TIP0V=-5V
Slot1 LM=0x8 0x5a (173) TIPLOOP=-14V
Slot1 LM=0x12 0x6a (0)
Slot2 Found NO_SLIC
Slot3 Found POTS_SLIC
Max_Usable_XSC: 4
DuSlic reseted
Slot 3: used as POTS_SLIC
V23 FSK SW-Workaround_D!
kcapi: Controller 1: fritz-ar7 attached
kcapi: Controller 2: fritz-ar7 attached
kcapi: Controller 3: fritz-ar7 attached
kcapi: Controller 4: fritz-ar7 attached
kcapi: card 1 "fritz-ar7" ready.
kcapi: card 2 "fritz-ar7" ready.
kcapi: notify up contr 1
capi: controller 1 up
kcapi: card 3 "fritz-ar7" ready.
kcapi: notify up contr 2
capi: controller 2 up
kcapi: card 4 "fritz-ar7" ready.
kcapi: notify up contr 3
capi: controller 3 up
isdn_fbox: Loaded.
kcapi: notify up contr 4
capi: controller 4 up
c0081000 __insmod_isdn_fbox_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/d
rivers/isdn/isdn_fon/isdn_fbox.o_M43A720C5_V-1 [isdn_fbox]
c0081060 __insmod_isdn_fbox_S.text_L308080 [isdn_fbox]
c00cc3f0 __insmod_isdn_fbox_S.rodata_L17808 [isdn_fbox]
c00d0980 __insmod_isdn_fbox_S.data_L8128 [isdn_fbox]
c00d2a50 __insmod_isdn_fbox_S.bss_L181616 [isdn_fbox]
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/dsld/kdsldmod.o
Warning: loading kdsldmod will taint the kernel: no license
kdsldmod: init start
kdsld: cache_create(datapipe)
kdsld: cache_create(datapipe_mod)
kdsld: cache_create(ipaccessset)
kdsld: cache_create(ipaccessrule)
kdsld: cache_create(ipfragid)
kdsld: cache_create(ipmasqentry)
kdsld: cache_create(ipmasqfwinfo)
kdsld: cache_create(ipmasqigdpm)
kdsld: cache_create(ipmasqappldata)
kdsld: cache_create(dnsmasqentry)
kdsld: cache_create(dnsstaticentry)
kdsld: cache_create(pingerentry)
kdsld: cache_create(pingerwaiter)
kdsld: cache_create(iprouteset)
kdsld: DATAPIPE: with header optimization
kdsld_thread: start
kdsld: PPP led: off (value=0)
kdsldmod: init done
c0100000 __insmod_kdsldmod_O/lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/dr
ivers/dsld/kdsldmod.o_M43A720C5_V-1 [kdsldmod]
c0100060 __insmod_kdsldmod_S.text_L351216 [kdsldmod]
c015cb10 __insmod_kdsldmod_S.data_L56688 [kdsldmod]
c0155c70 __insmod_kdsldmod_S.rodata_L28288 [kdsldmod]
c016fe90 __insmod_kdsldmod_S.bss_L11840 [kdsldmod]
2002-09-08 14:00:31 cltmgr: csock: using poll
Sep 8 14:00:31 cltmgr[456]: csock: using poll
2002-09-08 14:00:31 cltmgr: process priority is 19
Sep 8 14:00:31 cltmgr[456]: process priority is 19
Sep 8 14:00:31 cltmgr[463]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
MAC WLAN: 00:04:44:44:44:5C
Using /lib/modules/2.4.17_mvl21-malta-mips_fp_le/kernel/drivers/wlan/tiap.o
Sep 8 14:00:32 cltmgr[463]: load_config(ar7): factory default loaded
Warning: loading tiap will taint the kernel: non-GPL license -
(C) Copyright 2003, 2004, Texas Instruments, Inc
(C) Copyright 2005, AVM
Sep 8 14:00:34 cltmgr[463]: FactoryDefault=/etc/default/avm/voip.cfg (voip)
Sep 8 14:00:34 cltmgr[463]: load_config(voip): factory default loaded
Sep 8 14:00:34 cltmgr[463]: box init csock_add_fd ok
Sep 8 14:00:34 cltmgr[463]: FactoryDefault=/etc/default/avm/stat.cfg (stat)
Sep 8 14:00:34 cltmgr[463]: /etc/default/avm/stat.cfg: is empty
Sep 8 14:00:34 cltmgr[463]: load_config(stat): file empty - factory default loaded
Sep 8 14:00:34 cltmgr[463]: Statistic load_config failed
Sep 8 14:00:34 cltmgr[463]: status change eth-interfaces
WSTART (Oct 28 2005 10:25:33)Wstart - no WEP/WPA key set - no WLAN encryption
wstart: config ok(1)
*** sending hello msg with cipher = 0 SecurityType = 2***
*** sending hello msg with cipher = 4 SecurityType = 8***
wpa auth:waiting for driver to come up...
Wstart - made configure_wpa_authenticator
374: 802.11d is disabled
374: 802.11h is disabled
374: For SSID 0 vlan tag received is 0
374: wdrv_dbMainInit : WME disabled
374: wdrv_dbMainInit: wdsEnabled=0
374: Configuration succeeded !!!
remote_vlynq_dev_reset_ctrl(0(VLYNQ0), IN_RESET)
gpio[a8610904] &= ~(1 << 6);
Resetting the remote device.
remote_vlynq_dev_reset_ctrl: done
remote_vlynq_dev_reset_ctrl(0(VLYNQ0), OUT_OF_RESET)
Un-resetting the remote device...
GPIO pin reset, bit 6
vlynq init done
VLYNQ re-initialized.
Test, reading from a4000004... result = 0xeafffffe
377: whal_acxProcLoadFwImage() -- Loading FW image
380: whal_acxProcWaitInitComplete:
384: ----------------------------------------------------------------
384: ACX Firmaware Version = Rev 3.0.0.90
384: EEPROM Version = 5.1.0
385:
408: WDRV_MAINSM: WLAN Driver initialized successfully
408: WDRV_4X: 4x Enabled
408: WDRV_4X: Concatenation Enabled
408: WDRV_4X: Ack Emulation Disabled
408: whal_apiStartBss: Enable Tx, Rx and Start the Bss
408: ----------------------------------------------------------------
409: START BSS, SSID=FRITZ!Box Fon WLAN, BSSID=00-04-44-44-44-5C
409: ----------------------------------------------------------------
409: AP Power Level = 1
409: Regulatory Domain = ETSI
409: Net[0] : Channel=6
412: FW Watchdog is Enabled
dda: tiwlan0 in initializing Succeeded wireless extensions: ret = 0
wlan started (OK)
Wstart - made configure_and_start_ap_driver
WSTART: done(0)
WLAN is enabled
tiwlan0 device is activated
Sep 8 14:00:42 websrv[490]: csock: using poll
Sep 8 14:00:42 websrv[490]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:42 igdd[494]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:42 igdd[494]: load_config(ar7): factory default loaded
Sep 8 14:00:43 igdd[494]: csock: using poll
Sep 8 14:00:43 websrv[490]: load_config(ar7): factory default loaded
Sep 8 14:00:45 websrv[490]: startup (Oct 28 2005 10:25:18)
Sep 8 14:00:46 multid[535]: not running
Sep 8 14:00:46 multid[539]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:46 multid[539]: load_config(ar7): factory default loaded
Sep 8 14:00:46 multid[539]: startup (Oct 28 2005 10:25:21)
Sep 8 14:00:46 multid[539]: csock: using poll
request_module(lan)
Sep 8 14:00:46 request_module(eth1)
multid[545]: if_setup: lan:0: SIOCSIFADDR failed - No such device (19)
2002-09-08 14:00:46 multid: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:46 multid[544]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
request_module(wlan)
device eth0 entered promiscuous mode
lan: port 1(eth0) entering learning state
device usbrndis entered promiscuous mode
lan: port 2(usbrndis) entering learning state
2002-09-08 14:00:47 multid: load_config(ar7): factory default loaded
Sep 8 14:00:47 multid[544]: load_config(ar7): factory default loaded
Sep 8 14:00:47 request_module(eth1)
multid[545]: if_setup: eth1: SIOCSIFADDR failed - No such device (19)
Sep 8 14:00:47 device tiwlan0 entered promiscuous mode
multid[545]: br_lan: port 3(tiwlan0) entering learning state
add_if: get indedevice wdsup0 entered promiscuous mode
x for eth1 failewdsup0 device is activated
d - No such devilan: port 4(wdsup0) entering learning state
ce (19)
device wdsdw0 entered promiscuous mode
wdsdw0 device is activated
lan: port 5(wdsdw0) entering learning state
device wdsdw1 entered promiscuous mode
2002-09-08 14:00:47 multid: startup (Oct 28 2005 10:25:21)
Sepwdsdw1 device is activated
8 14:00:47 mullan: port 6(wdsdw1) entering learning state
tid[544]: startudevice wdsdw2 entered promiscuous mode
p (Oct 28 2005 1wdsdw2 device is activated
0:25:21)
lan: port 7(wdsdw2) entering learning state
device wdsdw3 entered promiscuous mode
wdsdw3 device is activated
lan: port 8(wdsdw3) entering learning state
2002-09-08 14:00:47 multid: csock: using poll
Sep 8 14:00:47 multid[544]: csock: using poll
Sep 8 14:00:47 multid[554]: already running (545), exit
Sep 8 14:00:47 multid[545]: static routes: 0 deleted (0 failed), 0 added (0 failed)
Sep 8 14:00:47 multid[545]: udpserver: 0.0.0.0:53: bind failed - Address already in use (125)
Sep 8 14:00:47 multid[545]: DHCPD on lan
Sep 8 14:00:47 multid[545]: DHCPD on lan:0 skipped, is virtual interface
Sep 8 14:00:47 multid[545]: DDNS: no valid accounts
Sep 8 14:00:47 multid[545]: ONLINE: script /bin/onlinechanged not found.
Sep 8 14:00:47 multid[545]: 1 Packets
Sep 8 14:00:47 multid[545]: 2 Packets
Sep 8 14:00:47 multid[545]: DHCPD: lan: arpping test (192.168.178.20)
2002-09-08 14:00:48 dsld: csock: using poll
Sep 8 14:00:48 dsld[559]: csock: using poll
2002-09-08 14:00:48 dsld: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:48 dsld[559]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
2002-09-08 14:00:48 dsld: load_config(ar7): factory default loaded
Sep 8 14:00:48 dsld[559]: load_config(ar7): factory default loaded
2002-09-08 14:00:48 dsld: startup (Oct 28 2005 10:25:14)
Sep 8 14:00:48 dsld[559]: startup (Oct 28 2005 10:25:14)
Sep 8 14:00:48 dsld[564]: DSL Mac 00:04:0e:4e:4d:5d
Sep 8 14:00:48 dsld[564]: VOIP Mac 00:04:0e:4e:4d:5e
Sep 8 14:00:48 dsld[564]: voip: ppptarget voip disabled, ignored
Sep 8 14:00:48 dsld[564]: tiatm version: 4.03.03.00
Sep 8 14:00:48 dsld[564]: using avm_event for dslstatus and speed (polling)
Sep 8 14:00:48 dsld[564]: normal scheduling
Sep 8 14:00:48 dsld[564]: Factorkdsld: sync lost
Sep 8 14:00:48 dsld[564]: /etc/default/avm/stat.cfg: is empty
Sep 8 14:00:48 dsld[564]: load_config(stat): file empty - factory default loade
d
Sep 8 14:00:48 dsld[564]: Statistic load_config failed
Sep 8 14:00:48 dsld[564]: no sync
Sep 8 14:00:48 multid[545]: DHCPD: lan: 192.168.178.20 is free
Sep 8 14:00:48 multid[545]: DHCPD: lan: OFFER(192.168.178.20)
lan: port 1(eth0) entering forwarding state
lan: topology change detected, propagating
lan: port 2(usbrndis) entering forwarding state
lan: port 3(tiwlan0) entering forwarding state
lan: port 4(wdsup0) entering forwarding state
lan: port 5(wdsdw0) entering forwarding state
lan: port 6(wdsdw1) entering forwarding state
lan: port 7(wdsdw2) entering forwarding state
lan: port 8(wdsdw3) entering forwarding state
kcapi: appl 1 up
3 DUSLIC_SlotsAvail
DuSlic reseted
Slot0 LM_INT=0x1 0x8d (555)
Slot0 LMstopped 0x0 0x34 (23)
Slot0 LM_INT=0x1 0x8c (553)
Slot0 LMstopped 0x0 0x34 (24)
Slot0 LM_INT=0x0 0x77 (554) IT_RING_OK
Slot0 LMstopped 0x0 0xf (15)
Slot0 LM_INT=0x1 0x99 (554) IT_TIP_OK
Slot0 LMstopped 0x1 0x36 (19)
Slot0 LM=0xdf 0x83 (0) TIP=-57V
Slot0 LM=0x4 0x5e (90) TIP0V=-6V
Slot0 LM=0x8 0x48 (171) TIPLOOP=-14V
Slot0 LM=0x12 0xe3 (0)
Slot1 LM_INT=0x2 0x7f (562)
Slot1 LMstopped 0x2 0x54 (24)
Slot1 LM_INT=0x2 0x82 (553)
Slot1 LMstopped 0x2 0x6a (24)
Slot1 LM_INT=0x0 0x81 (553) IT_RING_OK
Slot1 LMstopped 0x0 0x16 (27)
Slot1 LM_INT=0x1 0x62 (553) IT_TIP_OK
Slot1 LMstopped 0x1 0xf1 (16)
Slot1 LM=0xdf 0xb2 (0) TIP=-57V
Slot1 LM=0x3 0x90 (89) TIP0V=-5V
Slot1 LM=0x8 0x77 (168) TIPLOOP=-14V
Slot1 LM=0x12 0x83 (0)
Slot2 Found NO_SLIC
Max_Usable_XSC: 4
Sep 8 14:00:52 multid[545]: DHCPD: lan: arpping test (192.168.178.20)
voipd: csock: using poll
Sep 8 14:00:52 voipd[596]: FactoryDefault=/etc/default/avm/voip.cfg (voip)
Sep 8 14:00:52 voipd[596]: load_config(voip): factory default loaded
kcapi: appl 2 up
Sep 8 14:00:53 voipd[596]: startup (AVM FRITZ!Box Fon WLAN 08.03.91 AVM SIP v3.01.25 Oct 28 2005 10:27:40)
Sep 8 14:00:53 vokcapi: appl 3 up
ipd[596]: using capi controller 4
Sep 8 14:00:53 voipd[596]: using b1 protocol 1
2002-09-08 14:00:53 ar7cfgctl: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:53 ar7cfgctl[595]: FactoryDefault=/etc/default/avm/ar7.cfg (ar7)
Sep 8 14:00:53 igdd[494]: startup (Oct 28 2005 10:25:19)
DEBUG: SKB->Priority=0x0
Sep 8 14:00:53 voipd[596]: tel: supported
Sep 8 14:00:53 voipd[596]: ENUM NOT enabled
Sep 8 14:00:53 voipd[596]: enumdomain: e164.arpa
Sep 8 14:00:53 voipd[596]: enumdomain: e164.org
Sep 8 14:00:53 voipd[596]: no useragent configured
Sep 8 14:00:53 voipd[596]: INFO led: off (value=0)
Sep 8 14:00:53 voipd[596]: priority is -20
Sep 8 14:00:53 voipd[596]: encaplen 32
Sep 8 14:00:53 voipd[596]: brutto speed unknown
Sep 8 14:00:53 voipd[596]: PCMA: 98933 bits/second (encaplen=32,30ms)
Sep 8 14:00:53 voipd[596]: PCMU: 98933 bits/second (encaplen=32,30ms)
Sep 8 14:00:53 voipd[596]: G726-32: 70666 bits/second (encaplen=32,30ms)
Sep 8 14:00:53 voipd[596]: G726-40: 70666 bits/second (encaplen=32,30ms)
2002-09-08 14:00:53 ar7cfgctl: load_config(ar7): factory default loaded
Sep 8 14:00:53 ar7cfgctl[595]: load_config(ar7): factory default loaded
Sep 8 14:00:53 voipd[596]: G726-24: 56533 bits/second (encaplen=32,30ms)
Sep 8 14:00:53 voipd[596]: iLBC: 63600 bits/second (encaplen=32,30ms)
Sep 8 14:00:53 voipd[596]: PCMA: 106000 bits/second (encaplen=32,20ms)
Sep 8 14:00:53 voipd[596]: PCMU: 106000 bits/second (encaplen=32,20ms)
Sep 8 14:00:53 voipd[596]: G726-32: 84800 bits/second (encaplen=32,20ms)
Sep 8 14:00:53 voipd[596]: G726-40: 84800 bits/second (encaplen=32,20ms)
Sep 8 14:00:53 voipd[596]: G726-24: 63600 bits/second (encaplen=32,20ms)
Sep 8 14:00:53 voipd[596]: iLBC: 63600 bits/second (encaplen=32,20ms)
Sep 8 14:00:53 multid[545]: DHCPD: lan: 192.168.178.20 is free
Sep 8 14:00:53 multid[545]: DHCPD: lan: OFFER(192.168.178.20)
Sep 8 14:00:53 multid[545]: DHCPD: lan: ACK(192.168.178.20)
run_clock demon started
AR7WDT: System Init UEberwachung abgeschlossen (70960 ms noch verfuegbar)
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface eth0 found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface usbrndis found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface tiwlan0 found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface wdsup0 found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface wdsdw0 found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface wdsdw1 found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface wdsdw2 found or changed
Sep 8 14:00:54 igdd[494]: check_noip_devices: new iface wdsdw3 found or changed
Sep 8 14:00:55 cltmgr[463]: box_led_update_status
Sep 8 14:00:55 cltmgr[463]: got led event 16
Sep 8 14:00:59 igdd[494]: leave mcast group 239.255.255.250 at interface 192.168.178.1 for 0.0.0.0:1900 failed - Cannot assign requested address (126)
kcapi: appl 2 down
DuSlic reseted
kcapi: appl 1 down
kcapi: recv_handler: applid 1 ? (MANUFACTURER_CONF ID=001 #0x0000 LEN=0025
Controller/PLCI/NCCI = 0x2
ManuID = 0x214d5641
Class = 0x0
Function = 0x8001
ManuData = default
kcapi: appl 1 up
3 DUSLIC_SlotsAvail
DuSlic reseted
Slot0 LM_INT=0x1 0x89 (564)
Slot0 LMstopped 0x0 0x33 (22)
Slot0 LM_INT=0x1 0x88 (553)
Slot0 LMstopped 0x0 0x34 (21)
Slot0 LM_INT=0x0 0x7c (549) IT_RING_OK
Slot0 LMstopped 0x0 0xf (17)
Slot0 LM_INT=0x1 0x98 (553) IT_TIP_OK
Slot0 LMstopped 0x1 0x36 (17)
Slot0 LM=0xdf 0x80 (0) TIP=-58V
Slot0 LM=0x4 0x64 (98) TIP0V=-6V
Slot0 LM=0x8 0x47 (168) TIPLOOP=-14V
Slot0 LM=0x12 0xe5 (0)
Slot1 LM_INT=0x2 0x83 (563)
Slot1 LMstopped 0x0 0x57 (25)
Slot1 LM_INT=0x2 0x86 (553)
Slot1 LM_INT=0x0 0x87 (554) IT_RING_OK
Slot1 LMstopped 0x0 0x1c (26)
Slot1 LM_INT=0x1 0x63 (552) IT_TIP_OK
Slot1 LMstopped 0xff 0xf1 (20)
Slot1 LM=0xdf 0xae (0) TIP=-57V
Slot1 LM=0x3 0x93 (97) TIP0V=-5V
Slot1 LM=0x8 0x7a (173) TIPLOOP=-14V
Slot1 LM=0x12 0xdc (0)
Slot2 Found NO_SLIC
Max_Usable_XSC: 4
kcapi: appl 2 up
BusyBox v1.1.0-pre1 (2005.12.18-15:19+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
DEBUG: SKB->Priority=0x6
ermittle die aktuelle TTY
tty is "/dev/tts/0"
Serielles Terminal
