10:17:39 [RegisterPlugin]: Adding 'Thunderbird Addressbook'
10:17:39 [RegisterPlugin]: Adding 'Standard'
10:17:39 [RegisterPlugin]: Adding 'FritzFon'
10:17:39 [RegisterPlugin]: Adding 'VCard (KDE)'
10:17:39 [RegisterPlugin]: Adding 'efax'
10:17:39 [RegisterPlugin]: Adding '11880.com'
10:17:39 [RegisterPlugin]: Adding 'goyellow.de'
10:17:39 [RegisterPlugin]: Adding 'gelbeseiten.de'
10:17:39 [RegisterPlugin]: Adding 'CapiFax'
10:17:39 [RegisterPlugin]: Adding 'Das Oertliche'
10:17:39 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:39 - libcapifax v0.6b successfully initialized!
10:17:39 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:39 - ctrl: 5, loglevel: 2, ev_status: 0x7fcd2e303c70, ev_progress: 0x7fcd2e303bd0, ev_log: 0x7fcd2e303b80
10:17:39 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:39 - CNF: CAPI_LISTEN - (0)
10:17:39 [server]: FritzFax Server von Jan-Michael Brummer
10:17:39 [server]: Laufe auf Port 9901
10:17:39 [monitor]: Connecting to 'fritz.box'
10:17:49 [readSocket]: Druckauftrag am Socket empfangen
10:17:56 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:56 - capifax_send("/tmp/fax.test-2dKYSj.tif", 14400, 1, "xxxxxxx", "xxxxxx", "+49 xxxxxx", "Fritz!Fax")
10:17:56 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:56 - REQ: CONNECT (xxxxxx -> xxxxxx)
10:17:56 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:56 - CNF: CAPI_CONNECT - (0) (PLCI: 2053)
10:17:56 [StatusCapiFax]: Outgoing fax
10:17:56 [StatusCapiFax]: Phase : 1
10:17:56 [StatusCapiFax]: Connection: 0
10:17:56 [StatusCapiFax]: Src-No : xxxxxxxxx
10:17:56 [StatusCapiFax]: Dst-No : xxxxxxxxx
10:17:57 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:57 - IND: CAPI_CONNECT - CON: -1, PLCI: 2309, NCCI: 0 - IGNORING (xxxxxx <- 0#xxxxxx)
10:17:59 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:59 - IND: CAPI_CONNECT_ACTIVE - CON: 0, PLCI: 2053, NCCI: 0
10:17:59 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:59 - CNF: CAPI_CONNECT_B3 - (0)
10:17:59 [LogCapiFax]: [libcapifax] 06.01.2009 10:17:59 - IND: CAPI_CONNECT_B3_ACTIVE - CON: 0, PLCI: 2053, NCCI: 133125
10:18:11 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:11 - Phase B handler (0x80) DIS
10:18:11 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:11 - Phase B: bit rate 9600
10:18:11 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:11 - Phase B: ECM off
10:18:11 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:11 - ??? Encoding Type (null)
10:18:11 [StatusCapiFax]: Sending fax (START)
10:18:11 [StatusCapiFax]: Phase : 2
10:18:11 [StatusCapiFax]: Connection: 0
10:18:11 [StatusCapiFax]: Bitrate : 9600
10:18:11 [StatusCapiFax]: Encoding : ???
10:18:11 [StatusCapiFax]: Bad rows : 0
10:18:11 [StatusCapiFax]: Page : 1/0
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - Phase E handler (0x30) Disconnected after permitted retries
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - Phase E: pages transferred 0
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - Phase E: image resolution 8031 x 7700
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - Phase E: compression type 2
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - Phase E: coding method T.4 2-D
10:18:37 [StatusCapiFax]: Sending fax (END)
10:18:37 [StatusCapiFax]: Phase : 4
10:18:37 [StatusCapiFax]: Connection: 0
10:18:37 [StatusCapiFax]: Bitrate : 9600
10:18:37 [StatusCapiFax]: Encoding : T.4 2-D
10:18:37 [StatusCapiFax]: Bad rows : 0
10:18:37 [StatusCapiFax]: Page : 0/1
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - CAPI 0x3490 - Normal call clearing
10:18:37 [LogCapiFax]: [libcapifax] 06.01.2009 10:18:37 - IND: CAPI_DISCONNECT - CON: 0, PLCI: 2053, NCCI: 0
10:18:37 [StatusCapiFax]: Sending fax (FAILED)
10:18:37 [monitor]: Got '06.01.09 10:18:36;CALL;0;5;xxxxxx;xxxxxx;SIP0;
10:18:37 [StatusCapiFax]: Phase : 6
10:18:37 [HandleCall]: nType 1
10:18:37 [monitor]: Got '06.01.09 10:18:36;CONNECT;0;5;xxxxxx;
06.01.09 10:18:36;DISCONNECT;0;38;
