Annex A 7170,7140, xx70,5010,5012
Thanks a lot! This worked on my 7170 which I bought on eBay.
Annex B to A change failed with the 29.04.06 firmware
Dear Haveaniceday,
a few days ago I was happy to report that your prescription for switching to Annex A in the 7170 (firmware 29.04.02) worked for me. Unfortunately, I had another problem: my USB multifunction printer (Canon MC190) was not recognized by the 7170- and it was the principal reason for getting the 7170, to have a network printer at home. The AVM support replied very quickly: they said: load the latest firmware 29.04.06 and everything will be OK. I did so, but a) the printer is still not recognized b) I lost a possibility to switch to Annex A, because your beautuful fritz_as_avm_annex_a_kernel_args.tar does not work anymore. The box gives me an error message saying something like: this file is incompatible with the hardware but lets me continue at my risk.
When I continue, the box remains at Annex B (apparently, because the DSL fails to synchronize) and a warning appears on the summary page, saying that the latest firmware upgrade failed and the device might have a limited functionality.
Please, do you know where can a find the image of the older firmware version (>=29.04.02) that is known to be compatible with your patch?
May be you can give a hint on how to tweek the 29.04.06?
Thanking in advance,
Gorby (Geneva)
Hallo Gorby, du kannst es unter http:www.zdnet.de finden
Gruß Mäcki
ipboy schrieb:
So - nun auch mal von mir was positives. Ich habe heute eine Firmware auf meine FBF 7170 gespielt die genau so zuverlässig in der Anmeldung und im VOIP Betrieb funktioniert wie die Firmware auf der 7050.
Ich benutze die Box im ANNEX A Betrieb in Österreich. Der Provider ist AON (Telekom Austria). Die Geschwindigkeit am Anschluss wird von der Box mit 1189/232 kBit/s angezeigt, was auch dem Zugang entspricht und auch in der 7050 schon so angezeigt wurde. Der Sync dauert ungefähr 5 - 10 Sekunden. Dann dauert es ca. nochmals 10 Sekunden bis die Internetverbindung steht und alle Rufnummern in der Box (5 Stück) registriert sind.
FRITZ!Box Fon WLAN 7170, Firmware-Version 29.04.01 mit ANNEX A
Kann ich nur bestätigen und gilt auch für Südtirol und Italien
Gruß Mäcki
Probelm mit firmware fritz.box_fon_5010.23.04.15.image
HALO,
l
Ich freue mich sehr, daß Haveaniceday die Annex A- Lösung entwickelt hat. Das hat mir Hoffnung für die preiswerte gespräche per Telefon gegeben. Leider auf meinem Gerät habe ich neue Software und trotz Mühe immer wieder finde ich ANNEX B. :(
Hat jemand eine Idee wo ich die ältere Software finden könnte. Ich habe schon bei ZDNET gesucht, habe aber nicht gefunden.:confused:
Gruß an Alle!
Romaan
7170 auf Annex A
Ich kann es kaum glauben. Meine 7170 hängt am Schweizer Netz, gepatcht auf Annex A und mit der Firmware 29.04.01. Mit der .15 ging es nicht.
Aber das hätte ich auch früher schon mal probieren können. Sogar das Telefon geht.
Anscheinend liegt es an der Firmware. Hat jemand eine neuere Version in Verbindung mit dem Annex A Patch aufspielen können?
Würde mich interessieren.
Obwohl, ich glaub, ich lass es lieber wie es ist.
Vielen Dank an alle, die mir behilflich waren.
Moni
:p :p :p :p :p :p :p :p :p :p :p :p
Zyxel Prestige 660HW-67 firmware Annex a?
hallo,
kann der Annex A firmware von Zyxel 660HW auch an der 660HW-67 (deutschland) laufen? Das ist sehr wichtig, kann jemand hilfen? gibt es hier ein post wo ich dieser info finden kann?
vielen dank
Meine 7170 will einfach nicht mit Annex A funktionieren
Habe die FritzBox gestern bekommen. Von Anfang an hatte ich Firmware 29.04.01 drauf.
Nach Update des Annex A Patches sehe ich auch im Webinterface folgenden Text "ADSL (ITU G.992.1) Annex A"
Von nun an habe ich im EventLog immer folgenden Eintrag:
04.09.06 19:54:26 DSL-Synchronisierung beginnt (Training).
Per Telnet sehe ich folgende Ausgaben:
Sep 8 14:08:18 dsld[519]: EVENT(12): DSL-Synchronisierung beginnt (Training).
Sep 8 14:08:18 dsld[519]: dsl training
Sep 8 14:08:20 multid[489]: 0.0.0.0:1025: failed to send UDP-datagram to 192.168.180.1:53 - Network is unreachable (128)
Mit meiner alten FritzBoxFon funktioniert der Annex A Patch im Moment auf gleicher Leitung einwandfrei.
Es war jedoch so, dass vor ein paar Monaten auch die alte FBF nicht mehr funktionierte. Gleiche Meldungen im Log wie jetzt mit der 7170. Erst mit der aktuellen Firmware bekam die alte FBF wieder eine Verbindung.
Hat jemand eine Idee was ich bei der 7170 noch probieren könnte?
mfg
soelli
Hi Haveaniceday,
I have a German Fritzbox 7170 with the latest German firmware installed but I want to install an English firmware for ANNEX B.
Why Annex B??...Because I am living in Germany but German is not my 1st language and Im finding some things difficult to figure out.
I basically just want the web interface in English!, so the easiest way to do this.
HELP!, all the info here involves Annex A.
Moni
Hi Moni
neuere Software kommt erst mit der FBF 7170 international
Gruß Mäcki
tupo schrieb:
Hi Haveaniceday,
Hi Tupo,
as I Know there is no english version for the FBF 7170, only for the FBF 7050. But maybe it's not the worst thing to learn german for living in Germany!!?
Mäcki
But people above have sucessfully managed to change the 7170 to English Annex A. All I want is Annex B in english.
Im trying to learn German at the moment :) , but I would still prefer it in English so I fully understand everything. Not just 50 or 60%
Hi Tupo,
I have changed it to Annex A but still in German. I think there is no FBF 7170 international version, maybe in autumn.
Bye Mäcki
Aaaah, I see. Many thanks for your reply.
Roll on Autumn!!
Kann man den Mod auch rückgängig machen? Sprich von Annex-A wieder zurück auf Annex-B?
obexa
Ja, das kann man.
Man kann immer wieder den Originalzustand herstellen.
Auch den ohne BRANDING eines Anbieters.
Ja gut, aber wie? Ich habs versucht, mit der Wiederherstellung des Originalzustandes über das entsprechende Patchfile von AVM (fritz.box_fon_wlan_7170.04.15.recover-image.exe) -> In der Konsole steht immer noch ANNEX A
Dann über das Firmwaredowngrade (downgrade.tar) auf die Originalfirmware (fritz.box_fon_wlan_7170.29.04.01.image) -> immer noch ANNEX A
Das File fritz_als_annex_b.tar wird von der 7170 gar nicht mal aktzeptiert...
Wäre sehr dankbar, wenn mir jemand weithelfen kann!
Greets
obexa
Weiß es niemand?
Hi!
Was ich meine, ist das Zurücksetzen von Annex-A auf Annex-B... :mad:
Bei mir hauts trotz der erfolgreichen Umstellung auf Annex-A nicht hin bei der Synchronisierung (Südtirol, Telecom-Italia). Werd wohl oder übel meine 7170 verscherbeln müssen, deshalb würd ich gern wieder auf Annex-B switchen, was wie erwähnt leider nicht hinhaut...
Help!!!
obexa
i cant patch the firmware for the 7170..
when i hit ./fritz_xx70_annex_a.sh
i get a list of all images that are not found .. the image for the 7170 is not in that list
but i dont have a hacked firmware .. any ideas?
i'm trying to fix this image: fritz.box_fon_wlan_7170.29.04.21.image
ok .. seems i need 04.01 .. where can i find that one?
