Annex A 7170,7140, xx70,5010,5012
Hallo ,
I tried to convert my 5010 from ANNEX B to ANNEX A with the new tar file from H.A.N.D.
No luck for me because after upload firmware (uploading were now problem ofcoarse without unpakking file)my 5010 was still ANNEX B
SO MY QUESTION IS ...IS IT POSSIBLE WITH THE 5010????????:noidea:
gR. RONALD10
Hi Ronald10,
try to load the file from the board again.
Check if the DSL-information shows Annex A or Annex B.
I expect the menu should show Annex A.
Unfortunately I do not have a 5010 nor Annex A to test.
Best regards,
Haveaniceday
Hoi H.A.N.D. i man,
My dsl is an 5010 ANNEX B bought in germany. I'm from holland and my situation is analoog ISP Speedlinq and tried different modems run on ANNEX A.
This one however is a ANNEX B.
With the file fritz_als_avm_annex_A_new I put it in the menu firmware update...After new starting up know difference.(still ANNEX B)
This is what I have to do or do I mis something????
I"m now busy in making a new cable rj45 yo rj11 mayby it will help ....but I think I need both sollutions
Sorry writing in english but my german writing is like chinees
Gr ronald10
Hi Ronald10,
I supose your german is much better than my dutch ...
You need to take this file for the 5010: fritz_as_avm_annex_a_kernel_args.tar
http://www.ip-phone-forum.de/attachment.php?attachmentid=7057&d=1142888172
It's written in red. Just see the first posting of this thread.
Will not work: fritz_als_avm_annex_A_new for Boxes 7170, xx70,5010,5012
AVM changed the internal settings.
Haveaniceday
H.A.N.D.... NO GO NO LUCK
Still the same
ADSL-
Endgerät 0kBit/s0kBit/s ADSL-
Vermittlungs-
stelle
ADSL-Zustand ADSL-Kabel nicht angeschlossen
Hersteller AVM Berlin ---
DSL-Version 1.35.18.01 - H2
Annex B
Firmware 23.04.01
TAKE THE PINS 4 AND 5 FOR rj45 .... Mayby other pins ?????
I think it's not possible to go to ANNEX A with the 5010
Gr. ronald10
As long as the menu still tells us Annex B it should still be Annex B.
Hmm, no idea. It should make sense to think about the kabel before
the box is changed.
You might check with telnet if the kernel arguments for Annex A are set.
- login with telnet
- cat /proc/avalanche/env | grep kernel
=> should show:
kernel_args annex=A
Otherwise fritz_as_avm_annex_a_kernel_args.tar failed.
Haveaniceday
TO LOG IN ....
open IPFB
I wil have a try this evening
thanks
I've looked with telnet and this is what i saw....
# cat /proc/avalanche/env
HWRevision 86
ProductID Fritz_Box_5010
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 1.99
bootserport tty0
bluetooth 00:04:0E:7F:FF:07
cpufrequency 150000000
firstfreeaddress 0x946ABA30
firmware_version avm
firmware_info 23.04.01
flashsize 0x00400000
kernel_args annex=A
maca 00:04:0E:BA:59:59
macb 00:04:0E:BA:59:5A
macwlan 00:04:0E:BA:59:5B
macdsl 00:04:0E:BA:59:5C
memsize 0x01000000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x90000000,0x90000000
mtd1 0x90010000,0x903C0000
mtd2 0x90000000,0x90010000
mtd3 0x903C0000,0x903E0000
mtd4 0x903E0000,0x90400000
my_ipaddress 192.168.178.1
prompt AVM_Ar7
ptest
reserved 00:04:0E:7F:FF:00
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 1099
usb_board_mac 00:04:0E:BA:59:5D
usb_rndis_mac 00:04:0E:BA:59:5E
usb_device_id 0x3A00
usb_revision_id 0x0200
usb_device_name USB DSL Device
usb_manufacturer_name AVM
# cat /proc/avalanche/env | grep kernel
kernel_args annex=A
I still see ANNEX B in my webinterface???!!!!
Do I have something to chance
Still hoping for ANNEX A to establish a ISP connection
Gr.Ronald10
Hi Ronald10,
try at the telnet prompt:
echo "annex A" > /proc/avalanche/env
reboot
Check the output after the reboot.
Hmmm, very strange.
Haveaniceday
Did I do something wrong ???
Got this:
Console Ausgaben auf dieses Terminal umgelenkt
kernel_args annex=A
# echo "annex A" > proc/avalanche/env
# reboot
-sh: reboot: not found
Strange, on my box is a /sbin/reboot which can be called by reboot
Do a power off/on
I do not have any more ideas than this for Annex A..
Haveaniceday
PFFFFFF,
I found a strange thing too...in your previous post about the 5010 you wrote
Im Zweifelsfall per telnet auf die Box und mit
Umgebung checken:
cat /proc/avalanche/env | grep kernel_args
=> sollte annex=A enthalten
cat /proc/cmdline
=> Sollte annex=A enthalten
When I telnet with cat /proc/cmdline there was no response...
WHAT DOES THIS MEAN ????
See below:
 BusyBox v1.00-pre3 (2005.11.04-09:38+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
HWRevision='86'
HWSubRevision=''
ANNEX='B'
OEM='avm'
Language='de'
Country='049'
TZ='CET-1CEST,M3.5.0,M10.5.0'
CONFIG_AB_COUNT='1'
CONFIG_ANNEX='B'
CONFIG_ANSWER='n'
CONFIG_ASSIST='y'
CONFIG_ATA='y'
CONFIG_ATA_FULL='y'
CONFIG_AUDIO='n'
CONFIG_AURA='n'
CONFIG_BLUETOOTH='n'
CONFIG_BLUETOOTH_CTP='n'
CONFIG_BUTTON='n'
CONFIG_CAPI='y'
CONFIG_CAPI_MIPS='n'
CONFIG_CAPI_UBIK='n'
CONFIG_CAPI_XILINX='y'
CONFIG_CDROM='n'
CONFIG_CDROM_FALLBACK='n'
CONFIG_DECT='n'
CONFIG_DSL='y'
CONFIG_ENVIRONMENT_PATH='/proc/sys/dev/adam2'
CONFIG_ETH_COUNT='2'
 CONFIG_FIRMWARE_URL='[URL="http://www.avm.de/fritzbox-firmware-update.php?hardware=86&"]http://www.avm.de/fritzbox-firmware-update.php?hardware=86&[/URL]
oem=avm&language=de&country='
CONFIG_FON='y'
CONFIG_HOMEI2C='n'
CONFIG_HOSTNAME='fritz.fon.box'
CONFIG_I2C='n'
CONFIG_INSTALL_TYPE='ar7_4MB_xilinx_isdn_pots_1ab_fon_2eth_48151'
CONFIG_JFFS2='n'
CONFIG_LED_NO_DSL_LED='n'
CONFIG_MEDIACLI='n'
CONFIG_MEDIASRV='n'
CONFIG_NAND='n'
CONFIG_NFS='n'
CONFIG_OEM_DEFAULT='avm'
CONFIG_PRODUKT='Fritz_Box_5010'
CONFIG_PRODUKT_NAME='FRITZ!Box Fon 5010'
CONFIG_RAMSIZE='16'
CONFIG_ROMSIZE='4'
 CONFIG_SERVICEPORTAL_URL='[URL="http://www.avm.de/fritzbox-service-portal.php?hardware"]http://www.avm.de/fritzbox-service-portal.php?hardware[/URL]
=86&oem=avm&language=de&country='
CONFIG_STOREUSRCFG='y'
CONFIG_SUBVERSION=''
CONFIG_UBIK2='n'
CONFIG_USB='n'
CONFIG_USB_HOST_AVM='n'
CONFIG_USB_HOST_TI='n'
CONFIG_USB_PRINT_SERV='n'
CONFIG_USB_STORAGE='n'
CONFIG_USB_WLAN_AUTH='n'
CONFIG_VERSION='04.01'
CONFIG_VERSION_MAJOR='23'
CONFIG_VLYNQ0='0'
CONFIG_VLYNQ1='0'
CONFIG_VPN='n'
CONFIG_WLAN='n'
CONFIG_WLAN_GREEN='n'
CONFIG_WLAN_WDS='n'
CONFIG_XILINX='y'
ermittle die aktuelle TTY
tty is "/dev/pts/0"
# cat /proc/avalanche/env | grep kernel_args
kernel_args     annex=A
# cat /proc/cmdline
Edit Novize:
Please use the Code-Tags!
kernel_args annex=A
# cat /proc/cmdline
It looks like the bootloader adam2 works different for the 5010 !
For some other boxes kernel_args had been passed to the kernel,
/proc/cmdline had been filled with the value, ( so annex=A in this case )
and the box had switched to Annex A.
So the 5010 seem to require still an image modification. Not so nice...
Haveaniceday
Edit: So you have to do the xx70_annex_a.tar ( see first thread ).
OK H.A.N.D. ie man,
For a mod.image I have to do
- Cygwin installieren ( wenn du windows-user bist/bleiben willst/kein Linux ausprobieren willst ) . http://www.cygwin.com/
- oder Linux installieren, bzw. mit Knoppix booten ( ist eine Distribution Linux von DVD/CD )
- Downloade das Image von AVM welches zu deiner Box passt.
- Das tar-File xx70_annex_a.tar hier aus dem Thread runterladen.
- mit "tar xvf xx70_annex_a.tar" das File auspacken.
- cd xx70_annex_a
- ./fritz_xx70_annex_a.sh
Und dann das entstandene Image auf deine Fritzbox laden.
Can you explain a little bit more what is in red and thick. I just use XP professional so what to do with Cygwin...:confused:
You have read the first posting in english ?
xx70_annex_a.tar is a collection of files and script prepared by me.
"tar xvf xx70_annex_a.tar" unpack the files to xx70_annex_a/*
cd xx70_annex_a You should know from XP
./fritz_xx70_annex_a.sh call the prepared script...
cygwin contains an API-interface and a collection of UNIX tools to run
lots of software from the GNU-world under Windows.
My shell scripts rely on those UNIX tools. Did you look on the cygwin page ?
Haveaniceday
First of all haveaniceday...
although it's not so easy for me I want to thank you for the support sofar.Your knowlage is much more than mine so I appreciate your support and lots of others I think very much.:rock:
oke so far my struggling for A annex ....
What I don't understand is how you create a image for annex A for my 5010
I read the postings a couple of times....
unpack a file oke
make a dir oke
but then I don't know??? call./xx70_annex_a
where have I to put in???
its acracadabra....
1. unpack xx70_annex_a.tar
2. put fritz.box_2070.20.03.99.image fritz.box_fon_5010.23.04.01.image fritz.box_fon_5012.25.04.01.image fritz.box_fon_wlan_7170.29.04.01.image fritz.box_wlan_3070.19.03.99.image
a directory up
3. call ./xx70_annex_a
The image can be uploaded with the regular update function.
I hope haveaniceday that you don't go grazy about me!!!!!:noidea:
Hi Ronald10,
I updated the text of the first posting.
No I will not become crazy, I am already :silly:
Haveaniceday
7170 mit annex a
Hi, habe grade eine compilierte firm, 29.04.01 fuer 7170, mit annex a patch bekommen und installiert, und hat wunderbar gefunzt, habe jetzt ein 7170 mit annex a, und wird auch so angezeigt. Danke !!!
Yesssssssssssss My 5010 is alive (with mod.from anex B to annex A..)
thanks to HAVEANICEDAY.
My next post I wil explain my difficulties.At the moment my download is 60% of normal and my upstream is 40% of normal.
This can be better I suppose but at the moment I'm happy
Gr. ronald10 :) :) :) :)
Hallo Cardwizar,
schön dass zu lesen :) wo hast Du diese FW herbekommen?
ich möchte mir nämlich auch sehr gerne eine 7170 wohne aber in Spanien und da MUSS ich Annex A haben ...
funktioniert sie mit voller download-Geschwindigkeit?
kannst Du mir mal sagen wo Du sie gedownloaded hast, oder ev. auch per PM zuschicken?
Danke schon mal
ciao
Isidar :)
