name ist d4-config.txt und der Inhalt kann, je nach System, so aussehen:
[System]
; File: d4-config.txt
; Product id and version: CAA 158 0019 R5A
; Release date: 2005-10-14
; The system parameter may have the values MD110, WEBSWITCH3, MX-ONE, MD-E or BP
;System=WEBSWITCH3
;System=BP
System=BP-R15
;System=MD110
;System=MD-E
;System=MX-ONE
OverLap=YES
RRQTtl=600
GatekeeperID=LIM*
;Domain=ebc.ericsson.se
;PrimaryGKAddress=130.100.26.132
;SecondaryGKAddress=130.100.26.133
GatekeeperDiscovery=NO
AdminPasswd=RbdbSdc9c
CompatibleWithR3applications=NO
;LogOffRestriction=LogOffAllowed
;LogOffRestriction=DefaultNumberUsed
;LogOffRestriction=PermitIndividualLogOn
[Software]
; The following files are mandatory:
; Bootrom d4-boot_Rev.dat (CAA158 0017)
; Application File d4-appl_Rev.dat (CAA158 0018)
; Configuration File d4-config.txt (CAA158 0019)
; The following files are optional:
; Language File d4-Lang_Rev (CAA158 0020)
;Both DBC42201 and DBC42501 shall use same boot ,
;application and language file. It shall be stored
;in the dbc42501 directory.
HardwareRev=P1*
BootFile=/dbc42501/d4-boot_R5A.dat
BootVersion=R5A
ApplicationFile=/dbc42501/d4-applic_R5A.dat
ApplicationVersion=R5A
[Absence]
FollowMe=*21*extensionNo#,#21#
ExtFollowMe=*22*extensionNo#,#22#
AbsenceReason=*23*reasonCode#,#23#
Lunch=3hhmm
Trip=2mmdd
Absent=1hhmm
Meeting=4hhmm
Vacation=5mmdd
Illness=6mmdd
;[Authorization] ;replaces fthe following code with "-"
;Code=*61* ;Account code for Standard Appl. System
;Code=*72* ;Auth. code for Standard Appl. System
;Code=*73* ;Lock Central auth. code
;Code=#73* ;Unlock cent. auth. code
;Code=*74* ;Change individ. ath. code
;Code=*75*-*n# ;Dial with indiv. auth. code. n means that the nr will be visible
;Code=*76* ;Lock individ. auth. code
;Code=#76* ;Unlock individ. auth. code
[AutoNeg]
AutoNegLANPort=YES ;When AutoNeg is set to YES, Speed and Duplex will not
;DuplexLANPort=FULL ;be read. The resulting speed and duplex will be the
;SpeedLANPort=100 ;result of the negotiation between the phone and the
AutoNegPCPort=YES ;network device it is connected to(switch/hub/PC).
;DuplexPCPort=FULL
;SpeedPCPort=100
;[BackupGK]
;System=BP-R15 ;System=MD110 not allowed
;IPAddress=0.0.0.0
[Codecs]
; G.711 is mandatory but the priority order is optional
G.711A
G.711U
;GSMEFR
G.729A
G.729AB
G.723
[DIFFSERVTCP]
TrafficClass=2 ;Class B
DropPrecedence=2 ;Medium drop percentage
[DIFFSERVUDP]
TrafficClass=5 ;Expedited Forwarding
DropPrecedence=3 ;High drop percentage, recomended for EF
[Display]
ShowDTMFDigits=YES
;[Emergency]
;System1=BP-R15
;Address1=0.0.0.0 ; (BP IPU) Trunk Gateway IP-Address (CMD2152)
;Port1=10040 ; (BP IPU) Trunk Gateway Q.931 Port (CMD2194)
;System2=MD110
;Address2=0.0.0.0
;Port2=1720
;EmergencyNr=112 ; Number that is allowed to be dialed for emergency case
;A-Number=1234 ; Number that should be presented to B in emergency case
;RouteId=PASSW ; (BP IPU) Trunk Gateway Password (CMD2198)
;[FunctionKeysDBC425]
;CallBack=1
;FollowMe=2
;FreeOnSecond=3
;MessageWaiting=5
;Transfer=6
;Menu=
;Conference=
;CallPickUp=
;CallWaiting=
;Intrusion=
;HomeURL=10
;DirectoryURL=11
;EnablePBXStoring=YES
;[FunctionKeysDBC422]
;Conference=0
;Transfer=1
;Settings=5
;FollowMe=6
;MessageWaiting=7
;FreeOnSecond=8
;CallList=9
;CallPickUp=
;CallWaiting=
;Intrusion=
[Handsfree]
MicGainLow=NO ;May be used in small conference rooms. If it is set to YES and the
;current codec is NOT GSMEFR, the level of handsfree microphone and
;speaker output are lowered by 3 dB.
Loudspeaking=YES ;only for DBC422
StaticComfortNoise=NO
[Language]
;Default language is English. Optional languages can be selected
LanguageFile=/dbc42501/D4-lang_R5A.txt
LanguageVersion=R5A
OptionalLanguage=EN,*08*0#
OptionalLanguage=FR,*08*1#
OptionalLanguage=DE,*08*2#
OptionalLanguage=ES,*08*3#
OptionalLanguage=IT,*08*4#
OptionalLanguage=SV,*08*5#
OptionalLanguage=FI,*08*6#
OptionalLanguage=DA,*08*7#
OptionalLanguage=NO,*08*8#
OptionalLanguage=NL,*08*9#
;OptionalLanguage=PB,*08*9#
;OptionalLanguage=PL,*08*9#
;OptionalLanguage=PT,*08*9#
;OptionalLanguage=XL,*08*9#
;OptionalLanguage=SK,*08*9#
;OptionalLanguage=CS,*08*9#
;OptionalLanguage=ET,*08*9#
;OptionalLanguage=HU,*08*9#
;OptionalLanguage=LT,*08*9#
;OptionalLanguage=SL,*08*9#
StartupLanguage=EN
[LEDs]
Cad0=185,5,5,5 ; LED flash 0 cadence, first on,first off,second on,second off: in a call
Cad1=50,50,0,0 ; LED flash 1 cadence: incoming call
Cad2=30,30,0,0 ; LED flash 2 cadence: call parked
[L2QOS]
MIIPort=6,1 ;prio (0-7) ,VID(1-4095)
PCPort=0,2 ;prio (0-7) ,VID(1-4095)
LANPort=0,0 ;MAC based VLAN/802.1Q based VLAN , untagged/tagged PC originating traffic
;[OMD]
;SNAddress=130.100.188.111
;SNPort=1700
[RingCads] ; CCITT Standard
Internal=20,80,0,0,0,0
External=6,8,6,80,0,0
Callback=6,8,6,8,6,8
Extra=6,8,6,8,6,8
[STOREPHONEBOOKS]
EnableStoring=NO
[SuffixServices] ;DBC422 only
Intrusion=8
CallWaiting=4
CallBack=5
CallPickUp=6
[Time]
;TIMEZONE=CET:60:0:032804:103104
;NTP-server=0.0.0.0
[Tones] ; Tones for CCITT Standard
Dial tone=0,0,500,0,0,0,0,0,425,-10,0,0,0,0,0,0
Special dial tone=1,0,320,10,0,0,0,0,425,-10,0,0,0,0,0,0
Alerting tone=1,0,1000,4000,0,0,0,0,425,-10,0,0,0,0,0,0
Busy tone=1,0,500,500,0,0,0,0,425,-10,0,0,0,0,0,0
Congestion tone=1,0,200,200,0,0,0,0,425,-10,0,0,0,0,0,0
Special information tone=3,4,330,30,330,30,330,1000,950,-10,1400,-10,1800,-10,0,0
Offhook queuing tone=3,0,30,330,30,330,30,2000,425,-10,0,0,0,0,0,0
Call waiting tone=1,0,100,4900,0,0,0,0,425,-10,0,0,0,0,1,0
; [Tones] ; Tones for Australia
; Dial tone=0,0,500,0,0,0,0,0,425,-10,0,0,0,0,0,0
; Special dial tone=1,0,320,10,0,0,0,0,425,-10,0,0,0,0,0,0
; Alerting tone=2,1,400,200,400,2000,0,0,450,-10,400,-10,0,0,0,0
; Busy tone=1,0,370,370,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,2500,500,0,0,0,0,425,-10,0,0,0,0,0,0
; Special information tone=1,0,2500,500,0,0,0,0,425,-10,0,0,0,0,0,0
; Offhook queuing tone=3,0,30,330,30,330,30,2000,425,-10,0,0,0,0,0,0
; Call waiting tone=1,0,100,4900,0,0,0,0,425,-10,0,0,0,0,1,0
; [RingCads] ; Australia
; Internal=20,80,0,0,0,0
; External=6,8,6,80,0,0
; Callback=6,8,6,8,6,8
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Austria
; Dial tone=3,0,150,150,150,150,150,750,425,-10,0,0,0,0,0,0
; Special dial tone=1,0,500,30,0,0,0,0,425,-10,0,0,0,0,0,0
; Alerting tone=1,0,1000,4000,0,0,0,0,425,-10,0,0,0,0,0,0
; Busy tone=1,0,330,330,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,200,200,0,0,0,0,425,-10,0,0,0,0,0,0
; Special information tone=3,4,330,30,330,30,330,1000,950,-10,1400,-10,1800,-10,0,0
; [RingCads] ; Austria
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Belgium
; Special dial tone=1,0,1000,250,0,0,0,0,425,-10,0,0,0,0,0,0
; Alerting tone=1,0,1000,3000,0,0,0,0,425,-10,0,0,0,0,0,0
; Busy tone=1,0,500,500,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,250,250,0,0,0,0,425,-10,0,0,0,0,0,0
; Special information tone=3,4,330,20,330,20,330,1000,950,-10,1400,-10,1800,-10,0,0
; Offhook queuing tone=1,0,40,40,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Belgium
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Brazil
; Dial tone=1,0,980,60,0,0,0,0,425,-10,0,0,0,0,0,0
; Busy tone=1,0,250,250,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,100,100,0,0,0,0,425,-10,0,0,0,0,0,0
; Offhook queuing tone=1,0,30,330,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Brazil
; Internal=6,8,6,80,0,0
; External=20,80,0,0,0,0
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Switzerland
; Alerting tone=2,0,1000,4000,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Switzerland
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for China
; Dial tone=0,0,500,0,0,0,0,0,450,-10,0,0,0,0,0,0
; Special dial tone=1,0,400,40,0,0,0,0,450,-10,0,0,0,0,0,0
; Alerting tone=1,0,1000,4000,0,0,0,0,450,-10,0,0,0,0,0,0
; Busy tone=1,0,350,350,0,0,0,0,450,-10,0,0,0,0,0,0
; Congestion tone=1,0,700,700,0,0,0,0,450,-10,0,0,0,0,0,0
; Special information tone=3,0,100,100,100,100,100,100,450,-10,0,0,0,0,0,0
; Offhook queuing tone=3,0,30,330,30,330,30,2000,450,-10,0,0,0,0,0,0
; Call waiting tone=1,0,400,4000,0,0,0,0,450,-10,0,0,0,0,1,0
; [RingCads] ; China
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Czechia and Slovakia
; Special dial tone=3,0,320,170,170,170,170,170,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,170,170,0,0,0,0,425,-10,0,0,0,0,0,0
; Call waiting tone=1,0,330,9000,0,0,0,0,425,-10,0,0,0,0,1,0
; [RingCads] ; Czechia and Slovakia
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Denmark
; Offhook queuing tone=1,0,320,10,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Denmark
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Spain
; Special dial tone=1,0,1000,100,0,0,0,0,425,-10,0,0,0,0,0,0
; Alerting tone=1,0,1500,3000,0,0,0,0,425,-10,0,0,0,0,0,0
; Busy tone=1,0,200,200,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=3,0,200,200,200,200,200,600,425,-10,0,0,0,0,0,0
; Special information tone=2,0,200,200,200,600,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Spain
; Internal=20,30,0,0,0,0
; External=30,60,0,0,0,0
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Finland
; Dial tone=3,0,200,300,200,300,200,800,425,-10,0,0,0,0,0,0
; Special dial tone=1,0,640,30,0,0,0,0,425,-10,0,0,0,0,0,0
; Busy tone=1,0,300,300,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,220,220,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Finland
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Germany
; Busy tone=1,0,150,450,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,240,240,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Germany
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Netherlands
; [RingCads] ; Netherlands
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Italy
; Dial tone=0,1,500,0,0,0,0,0,350,-10,425,-10,0,0,0,0
; Special dial tone=1,1,320,10,0,0,0,0,350,-10,425,-10,0,0,0,0
; Special information tone=1,0,100,100,0,0,0,0,425,-10,0,0,0,0,0,0
; Offhook queuing tone=3,0,100,100,100,100,100,1500,425,-10,0,0,0,0,0,0
; [RingCads] ; Italy
; Internal=12,4,4,80,0,0
; Callback=4,4,4,4,4,80
; Extra=4,4,4,4,4,80
; [Tones] ; Tones for Malaysia
; Special dial tone=3,0,250,250,250,250,2000,250,425,-10,0,0,0,0,0,0
; Alerting tone=2,0,400,200,400,2000,0,0,425,-10,0,0,0,0,0,0
; Offhook queuing tone=3,0,100,200,100,200,100,200,425,-10,0,0,0,0,0,0
; Call waiting tone=3,0,1000,10000,500,250,500,10000,425,-10,0,0,0,0,1,0
; [RingCads] ; Malaysia
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Norway
; Special dial tone=1,1,600,20,0,0,0,0,350,-10,440,-10,0,0,0,0
; [RingCads] ; Norway
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for New Zealand
; Dial tone=0,1,500,0,0,0,0,0,375,-10,425,-10,0,0,0,0
; Special dial tone=2,1,740,10,0,0,0,0,425,-10,550,-10,0,0,0,0
; Alerting tone=2,1,400,200,400,2000,0,0,375,-10,425,-10,0,0,0,0
; Congestion tone=0,0,500,0,0,0,0,0,425,-10,0,0,0,0,0,0
; Special information tone=0,0,500,0,0,0,0,0,425,-10,0,0,0,0,0,0
; Call waiting tone=2,0,100,100,100,5000,0,0,425,-10,0,0,0,0,1,0
; [RingCads] ; New Zealand
; External=8,4,8,40,0,0
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Portugal
; [RingCads] ; Portugal
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for South Africa
; [RingCads] ; South Africa
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Singapore
; Busy tone=1,0,375,375,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Singapore
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Sweden
; Alerting tone=1,0,1000,5000,0,0,0,0,425,-10,0,0,0,0,0,0
; Congestion tone=1,0,250,750,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Sweden
; Internal=20,100,0,0,0,0
; External=7,6,7,100,0,0
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for UK
; Special dial tone=1,1,740,10,0,0,0,0,425,-10,550,-10,0,0,0,0
; Busy tone=1,1,370,370,0,0,0,0,375,-10,425,-10,0,0,0,0
; [RingCads] ; UK
; Extra=6,8,6,8,6,8
; [Tones] ; Tones for Yugoslavia
; Dial tone=0,1,500,0,0,0,0,0,380,-10,425,-10,0,0,0,0
; Special dial tone=1,0,500,1500,0,0,0,0,425,-10,0,0,0,0,0,0
; [RingCads] ; Yugoslavia
; Extra=6,8,6,8,6,8
[WAP]
;WAPGateway=0.0.0.0
;DirectoryAddress=0.0.0.0/MobileExec/default.asp
HomeAddress=wap.ericsson.com
MaxAttempts=3 ;2-8
RetransPeriod=3000 ;3000-7000
CountryCode=46 ;The code of the country where the PBX is located
RouteAccessNumber=00 ;The route access number
CountryCodePrefix=00 ;The prefix of the code of the country where the PBX is located
AreaCodePrefix=0 ;The prefix of the area code in the country where the PBX is located
