- Mitglied seit
- 17 Mrz 2009
- Beiträge
- 1,466
- Punkte für Reaktionen
- 3
- Punkte
- 38
kernel-config:Wie soll ich ohne die .config deines Kernels sagen, ob du alles richtig ausgewählt hast?
# Automatically generated make config: don't edit
# Linux kernel version: 2.6.28.8
# Sun Jul 8 17:50:40 2012
CONFIG_MIPS=y
# Machine selection
# CONFIG_MACH_ALCHEMY is not set
# CONFIG_BASLER_EXCITE is not set
# CONFIG_BCM47XX is not set
# CONFIG_MIPS_COBALT is not set
CONFIG_MACH_FUSIV=y
# CONFIG_MACH_DECSTATION is not set
# CONFIG_MACH_JAZZ is not set
# CONFIG_LASAT is not set
# CONFIG_LEMOTE_FULONG is not set
# CONFIG_MIPS_MALTA is not set
# CONFIG_MACH_AR7240 is not set
# CONFIG_MIPS_SIM is not set
# CONFIG_MACH_EMMA is not set
# CONFIG_MACH_VR41XX is not set
# CONFIG_NXP_STB220 is not set
# CONFIG_NXP_STB225 is not set
# CONFIG_PNX8550_JBS is not set
# CONFIG_PNX8550_STB810 is not set
# CONFIG_PMC_MSP is not set
# CONFIG_PMC_YOSEMITE is not set
# CONFIG_SGI_IP22 is not set
# CONFIG_SGI_IP27 is not set
# CONFIG_SGI_IP28 is not set
# CONFIG_SGI_IP32 is not set
# CONFIG_SIBYTE_CRHINE is not set
# CONFIG_SIBYTE_CARMEL is not set
# CONFIG_SIBYTE_CRHONE is not set
# CONFIG_SIBYTE_RHONE is not set
# CONFIG_SIBYTE_SWARM is not set
# CONFIG_SIBYTE_LITTLESUR is not set
# CONFIG_SIBYTE_SENTOSA is not set
# CONFIG_SIBYTE_BIGSUR is not set
# CONFIG_SNI_RM is not set
# CONFIG_MACH_TX39XX is not set
# CONFIG_MACH_TX49XX is not set
# CONFIG_MIKROTIK_RB532 is not set
# CONFIG_WR_PPMC is not set
# CONFIG_LANTIQ is not set
# CONFIG_EMULATOR is not set
# CONFIG_MACH_FUSIV_MIPS1 is not set
CONFIG_MACH_FUSIV_MIPS32=y
# CONFIG_FUSIV_VX200 is not set
# CONFIG_FUSIV_VX160 is not set
# CONFIG_FUSIV_AT300 is not set
CONFIG_FUSIV_VX180=y
CONFIG_RWSEM_GENERIC_SPINLOCK=y
# CONFIG_ARCH_HAS_ILOG2_U32 is not set
CONFIG_MIPS_FUSIV=y
# CONFIG_ARCH_HAS_ILOG2_U64 is not set
CONFIG_ARCH_SUPPORTS_OPROFILE=y
CONFIG_GENERIC_FIND_NEXT_BIT=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_GENERIC_TIME=y
CONFIG_GENERIC_CMOS_UPDATE=y
CONFIG_SCHED_NO_NO_OMIT_FRAME_POINTER=y
# CONFIG_GENERIC_HARDIRQS_NO__DO_IRQ is not set
CONFIG_DMA_NONCOHERENT=y
CONFIG_DMA_NEED_PCI_MAP_STATE=y
# CONFIG_HOTPLUG_CPU is not set
CONFIG_MIPS_FPU_EMU=y
# CONFIG_NO_IOPORT is not set
CONFIG_CPU_BIG_ENDIAN=y
# CONFIG_CPU_LITTLE_ENDIAN is not set
CONFIG_SYS_SUPPORTS_BIG_ENDIAN=y
CONFIG_IRQ_CPU=y
CONFIG_BOOT_ELF32=y
CONFIG_MIPS_L1_CACHE_SHIFT=5
# CPU selection
# CONFIG_CPU_LOONGSON2 is not set
# CONFIG_CPU_MIPS32_R1 is not set
# CONFIG_CPU_MIPS32_R2 is not set
CONFIG_CPU_MIPS_24K=y
# CONFIG_CPU_MIPS_34K is not set
# CONFIG_CPU_MIPS_74K is not set
# CONFIG_CPU_MIPS64_R1 is not set
# CONFIG_CPU_MIPS64_R2 is not set
# CONFIG_CPU_R3000 is not set
# CONFIG_CPU_TX39XX is not set
# CONFIG_CPU_VR41XX is not set
# CONFIG_CPU_R4300 is not set
# CONFIG_CPU_R4X00 is not set
# CONFIG_CPU_TX49XX is not set
# CONFIG_CPU_R5000 is not set
# CONFIG_CPU_R5432 is not set
# CONFIG_CPU_R5500 is not set
# CONFIG_CPU_R6000 is not set
# CONFIG_CPU_NEVADA is not set
# CONFIG_CPU_R8000 is not set
# CONFIG_CPU_R10000 is not set
# CONFIG_CPU_RM7000 is not set
# CONFIG_CPU_RM9000 is not set
# CONFIG_CPU_SB1 is not set
CONFIG_SYS_HAS_CPU_MIPS32_R1=y
CONFIG_SYS_HAS_CPU_MIPS32_R2=y
CONFIG_CPU_MIPS32=y
CONFIG_CPU_MIPSR2=y
CONFIG_SYS_SUPPORTS_32BIT_KERNEL=y
CONFIG_CPU_SUPPORTS_32BIT_KERNEL=y
CONFIG_HARDWARE_WATCHPOINTS=y
# Kernel type
CONFIG_32BIT=y
# CONFIG_64BIT is not set
CONFIG_PAGE_SIZE_4KB=y
# CONFIG_PAGE_SIZE_8KB is not set
# CONFIG_PAGE_SIZE_16KB is not set
# CONFIG_PAGE_SIZE_64KB is not set
CONFIG_THREAD_SIZE_ORDER=2
CONFIG_CPU_HAS_PREFETCH=y
CONFIG_MIPS_MT_DISABLED=y
# CONFIG_MIPS_MT_SMP is not set
# CONFIG_MIPS_MT_SMTC is not set
CONFIG_CPU_HAS_LLSC=y
CONFIG_CPU_HAS_SYNC=y
CONFIG_GENERIC_HARDIRQS=y
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_POPULATES_NODE_MAP=y
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_DISCONTIGMEM_MANUAL is not set
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_FLAT_NODE_MEM_MAP=y
CONFIG_PAGEFLAGS_EXTENDED=y
CONFIG_SPLIT_PTLOCK_CPUS=4
# CONFIG_RESOURCES_64BIT is not set
# CONFIG_PHYS_ADDR_T_64BIT is not set
CONFIG_ZONE_DMA_FLAG=0
CONFIG_VIRT_TO_BUS=y
# CONFIG_UNEVICTABLE_LRU is not set
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
CONFIG_GENERIC_CLOCKEVENTS_BUILD=y
# CONFIG_HZ_48 is not set
# CONFIG_HZ_100 is not set
# CONFIG_HZ_128 is not set
CONFIG_HZ_250=y
# CONFIG_HZ_256 is not set
# CONFIG_HZ_1000 is not set
# CONFIG_HZ_1024 is not set
CONFIG_SYS_SUPPORTS_ARBIT_HZ=y
CONFIG_HZ=250
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CONFIG_KEXEC is not set
# CONFIG_SECCOMP is not set
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_KERNELVERSION="2.6.28.8"
CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config"
# General setup
CONFIG_EXPERIMENTAL=y
CONFIG_BROKEN_ON_SMP=y
CONFIG_INIT_ENV_ARG_LIMIT=32
CONFIG_LOCALVERSION=""
# CONFIG_LOCALVERSION_AUTO is not set
CONFIG_SWAP=y
CONFIG_SYSVIPC=y
CONFIG_SYSVIPC_SYSCTL=y
# CONFIG_POSIX_MQUEUE is not set
CONFIG_BSD_PROCESS_ACCT=y
# CONFIG_BSD_PROCESS_ACCT_V3 is not set
# CONFIG_TASKSTATS is not set
# CONFIG_AUDIT is not set
# CONFIG_IKCONFIG is not set
CONFIG_LOG_BUF_SHIFT=14
# CONFIG_CGROUPS is not set
# CONFIG_GROUP_SCHED is not set
# CONFIG_SYSFS_DEPRECATED_V2 is not set
# CONFIG_RELAY is not set
# CONFIG_NAMESPACES is not set
# CONFIG_BLK_DEV_INITRD is not set
CONFIG_CC_OPTIMIZE_FOR_SIZE=y
CONFIG_SYSCTL=y
CONFIG_ANON_INODES=y
CONFIG_EMBEDDED=y
CONFIG_SYSCTL_SYSCALL=y
CONFIG_KALLSYMS=y
# CONFIG_KALLSYMS_ALL is not set
# CONFIG_KALLSYMS_EXTRA_PASS is not set
CONFIG_HOTPLUG=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
# CONFIG_PCSPKR_PLATFORM is not set
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_PCI_QUIRKS=y
# CONFIG_COMPAT_BRK is not set
CONFIG_SLAB=y
# CONFIG_SLUB is not set
# CONFIG_SLOB is not set
CONFIG_PROFILING=y
CONFIG_AVM_SIMPLE_PROFILING=y
# CONFIG_MARKERS is not set
# CONFIG_OPROFILE is not set
CONFIG_HAVE_OPROFILE=y
CONFIG_AVM_ARCH_STATIC_WLAN_MEMORY=y
CONFIG_AVM_ARCH_STATIC_WLAN_MEMORY_SIZE=0x350
# CONFIG_HAVE_GENERIC_DMA_COHERENT is not set
CONFIG_SLABINFO=y
CONFIG_RT_MUTEXES=y
# CONFIG_TINY_SHMEM is not set
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
CONFIG_KMOD=y
CONFIG_BLOCK=y
# CONFIG_LBD is not set
# CONFIG_BLK_DEV_IO_TRACE is not set
# CONFIG_LSF is not set
# CONFIG_BLK_DEV_BSG is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# IO Schedulers
CONFIG_IOSCHED_NOOP=y
# CONFIG_IOSCHED_AS is not set
# CONFIG_IOSCHED_DEADLINE is not set
# CONFIG_IOSCHED_CFQ is not set
# CONFIG_DEFAULT_AS is not set
# CONFIG_DEFAULT_DEADLINE is not set
# CONFIG_DEFAULT_CFQ is not set
CONFIG_DEFAULT_NOOP=y
CONFIG_DEFAULT_IOSCHED="noop"
CONFIG_CLASSIC_RCU=y
# CONFIG_FREEZER is not set
# Bus options (PCI, PCMCIA, EISA, ISA, TC)
CONFIG_HW_HAS_PCI=y
CONFIG_PCI=y
CONFIG_PCI_DOMAINS=y
# CONFIG_PCIEPORTBUS is not set
# CONFIG_ARCH_SUPPORTS_MSI is not set
# CONFIG_PCI_LEGACY is not set
# CONFIG_PCI_DEBUG is not set
CONFIG_MMU=y
# CONFIG_PCCARD is not set
# CONFIG_HOTPLUG_PCI is not set
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set
# CONFIG_HAVE_AOUT is not set
# CONFIG_BINFMT_MISC is not set
CONFIG_TRAD_SIGNALS=y
# Power management options
CONFIG_ARCH_SUSPEND_POSSIBLE=y
# CONFIG_PM is not set
# CONFIG_CPU_FREQ is not set
# CONFIG_CPU_IDLE is not set
CONFIG_NET=y
# Networking options
# CONFIG_NET_DEV_LOAD is not set
# CONFIG_DEV_REFCNT_DEBUG is not set
# CONFIG_NET_DEBUG_SKBUFF_LEAK is not set
CONFIG_AVM_PA=y
CONFIG_KSPEEDTEST=m
CONFIG_PACKET=y
CONFIG_PACKET_MMAP=y
CONFIG_UNIX=y
CONFIG_XFRM=y
# CONFIG_XFRM_USER is not set
# CONFIG_XFRM_SUB_POLICY is not set
# CONFIG_XFRM_MIGRATE is not set
# CONFIG_XFRM_STATISTICS is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
CONFIG_IP_MULTICAST=y
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_FIB_HASH=y
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
CONFIG_IP_PNP_RARP=y
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE is not set
CONFIG_IP_MROUTE=y
CONFIG_IP_PIMSM_V1=y
CONFIG_IP_PIMSM_V2=y
# CONFIG_ARPD is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
# CONFIG_INET_XFRM_TUNNEL is not set
CONFIG_INET_TUNNEL=y
# CONFIG_INET_XFRM_MODE_TRANSPORT is not set
# CONFIG_INET_XFRM_MODE_TUNNEL is not set
# CONFIG_INET_XFRM_MODE_BEET is not set
# CONFIG_INET_LRO is not set
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
CONFIG_IP_MULTICAST_FASTFORWARD=y
CONFIG_IPV6=y
# CONFIG_IPV6_PRIVACY is not set
# CONFIG_IPV6_ROUTER_PREF is not set
# CONFIG_IPV6_OPTIMISTIC_DAD is not set
# CONFIG_INET6_AH is not set
# CONFIG_INET6_ESP is not set
# CONFIG_INET6_IPCOMP is not set
# CONFIG_IPV6_MIP6 is not set
# CONFIG_INET6_XFRM_TUNNEL is not set
# CONFIG_INET6_TUNNEL is not set
CONFIG_INET6_XFRM_MODE_TRANSPORT=y
CONFIG_INET6_XFRM_MODE_TUNNEL=y
CONFIG_INET6_XFRM_MODE_BEET=y
# CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set
CONFIG_IPV6_SIT=y
CONFIG_IPV6_NDISC_NODETYPE=y
# CONFIG_IPV6_TUNNEL is not set
# CONFIG_IPV6_MULTIPLE_TABLES is not set
# CONFIG_IPV6_MROUTE is not set
CONFIG_GENERIC_CONNTRACK=y
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NETFILTER=y
# CONFIG_NETFILTER_DEBUG is not set
CONFIG_NETFILTER_ADVANCED=y
CONFIG_BRIDGE_NETFILTER=y
# Core Netfilter Configuration
# CONFIG_NETFILTER_NETLINK_QUEUE is not set
# CONFIG_NETFILTER_NETLINK_LOG is not set
CONFIG_NF_CONNTRACK=y
CONFIG_NF_CT_ACCT=y
CONFIG_NF_CONNTRACK_MARK=y
CONFIG_NF_CONNTRACK_EVENTS=y
# CONFIG_NF_CT_PROTO_DCCP is not set
# CONFIG_NF_CT_PROTO_SCTP is not set
# CONFIG_NF_CT_PROTO_UDPLITE is not set
# CONFIG_NF_CONNTRACK_AMANDA is not set
# CONFIG_NF_CONNTRACK_FTP is not set
# CONFIG_NF_CONNTRACK_H323 is not set
# CONFIG_NF_CONNTRACK_IRC is not set
# CONFIG_NF_CONNTRACK_NETBIOS_NS is not set
# CONFIG_NF_CONNTRACK_PPTP is not set
# CONFIG_NF_CONNTRACK_SANE is not set
# CONFIG_NF_CONNTRACK_SIP is not set
# CONFIG_NF_CONNTRACK_TFTP is not set
# CONFIG_NF_CT_NETLINK is not set
# CONFIG_NETFILTER_TPROXY is not set
CONFIG_NETFILTER_XTABLES=y
CONFIG_NETFILTER_XT_TARGET_CLASSIFY=m
# CONFIG_NETFILTER_XT_TARGET_CONNMARK is not set
CONFIG_NETFILTER_XT_TARGET_DSCP=m
CONFIG_NETFILTER_XT_TARGET_MARK=y
CONFIG_NETFILTER_XT_TARGET_NFLOG=m
CONFIG_NETFILTER_XT_TARGET_NFQUEUE=m
# CONFIG_NETFILTER_XT_TARGET_NOTRACK is not set
CONFIG_NETFILTER_XT_TARGET_RATEEST=m
CONFIG_NETFILTER_XT_TARGET_TRACE=m
CONFIG_NETFILTER_XT_TARGET_TCPMSS=m
CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP=m
CONFIG_NETFILTER_XT_MATCH_COMMENT=m
# CONFIG_NETFILTER_XT_MATCH_CONNBYTES is not set
# CONFIG_NETFILTER_XT_MATCH_CONNLIMIT is not set
# CONFIG_NETFILTER_XT_MATCH_CONNMARK is not set
CONFIG_NETFILTER_XT_MATCH_CONNTRACK=y
CONFIG_NETFILTER_XT_MATCH_DCCP=m
CONFIG_NETFILTER_XT_MATCH_DSCP=m
CONFIG_NETFILTER_XT_MATCH_ESP=m
CONFIG_NETFILTER_XT_MATCH_HASHLIMIT=m
# CONFIG_NETFILTER_XT_MATCH_HELPER is not set
CONFIG_NETFILTER_XT_MATCH_IPRANGE=m
CONFIG_NETFILTER_XT_MATCH_LENGTH=m
CONFIG_NETFILTER_XT_MATCH_LIMIT=y
CONFIG_NETFILTER_XT_MATCH_MAC=y
CONFIG_NETFILTER_XT_MATCH_MARK=m
CONFIG_NETFILTER_XT_MATCH_MULTIPORT=y
CONFIG_NETFILTER_XT_MATCH_OWNER=m
CONFIG_NETFILTER_XT_MATCH_POLICY=m
CONFIG_NETFILTER_XT_MATCH_PHYSDEV=m
CONFIG_NETFILTER_XT_MATCH_PKTTYPE=m
CONFIG_NETFILTER_XT_MATCH_QUOTA=m
CONFIG_NETFILTER_XT_MATCH_RATEEST=m
CONFIG_NETFILTER_XT_MATCH_REALM=m
CONFIG_NETFILTER_XT_MATCH_RECENT=m
CONFIG_NETFILTER_XT_MATCH_RECENT_PROC_COMPAT=y
CONFIG_NETFILTER_XT_MATCH_SCTP=m
CONFIG_NETFILTER_XT_MATCH_STATE=y
# CONFIG_NETFILTER_XT_MATCH_LAYER7 is not set
CONFIG_NETFILTER_XT_MATCH_STATISTIC=m
CONFIG_NETFILTER_XT_MATCH_STRING=m
CONFIG_NETFILTER_XT_MATCH_TCPMSS=y
CONFIG_NETFILTER_XT_MATCH_TIME=m
CONFIG_NETFILTER_XT_MATCH_U32=m
# CONFIG_IP_VS is not set
# IP: Netfilter Configuration
CONFIG_NF_DEFRAG_IPV4=y
CONFIG_NF_CONNTRACK_IPV4=y
CONFIG_NF_CONNTRACK_PROC_COMPAT=y
# CONFIG_IP_NF_QUEUE is not set
CONFIG_IP_NF_IPTABLES=y
CONFIG_IP_NF_MATCH_ADDRTYPE=m
CONFIG_IP_NF_MATCH_AH=m
CONFIG_IP_NF_MATCH_ECN=m
CONFIG_IP_NF_MATCH_TTL=m
CONFIG_IP_NF_FILTER=y
CONFIG_IP_NF_TARGET_REJECT=y
CONFIG_IP_NF_TARGET_LOG=y
CONFIG_IP_NF_TARGET_ULOG=m
# CONFIG_NF_NAT is not set
CONFIG_IP_NF_MANGLE=y
# CONFIG_IP_NF_TARGET_CLUSTERIP is not set
CONFIG_IP_NF_TARGET_ECN=m
CONFIG_IP_NF_TARGET_TTL=m
CONFIG_IP_NF_RAW=m
CONFIG_IP_NF_ARPTABLES=m
CONFIG_IP_NF_ARPFILTER=m
CONFIG_IP_NF_ARP_MANGLE=m
# IPv6: Netfilter Configuration
# CONFIG_NF_CONNTRACK_IPV6 is not set
# CONFIG_IP6_NF_QUEUE is not set
CONFIG_IP6_NF_IPTABLES=m
CONFIG_IP6_NF_MATCH_AH=m
CONFIG_IP6_NF_MATCH_EUI64=m
CONFIG_IP6_NF_MATCH_FRAG=m
CONFIG_IP6_NF_MATCH_OPTS=m
CONFIG_IP6_NF_MATCH_HL=m
CONFIG_IP6_NF_MATCH_IPV6HEADER=m
CONFIG_IP6_NF_MATCH_MH=m
CONFIG_IP6_NF_MATCH_RT=m
CONFIG_IP6_NF_TARGET_LOG=m
CONFIG_IP6_NF_FILTER=m
CONFIG_IP6_NF_TARGET_REJECT=m
CONFIG_IP6_NF_MANGLE=m
CONFIG_IP6_NF_TARGET_HL=m
CONFIG_IP6_NF_RAW=m
# CONFIG_BRIDGE_NF_EBTABLES is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_TIPC is not set
CONFIG_ATM=y
CONFIG_ATM_CLIP=y
# CONFIG_ATM_CLIP_NO_ICMP is not set
# CONFIG_ATM_LANE is not set
CONFIG_ATM_BR2684=y
# CONFIG_ATM_BR2684_IPFILTER is not set
CONFIG_STP=y
CONFIG_BRIDGE=y
# CONFIG_NET_DSA is not set
CONFIG_VLAN_8021Q=y
# CONFIG_VLAN_8021Q_GVRP is not set
# CONFIG_DECNET is not set
CONFIG_LLC=y
# CONFIG_LLC2 is not set
# CONFIG_IPX is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_ECONET is not set
# CONFIG_WAN_ROUTER is not set
CONFIG_NET_SCHED=y
# Queueing/Scheduling
CONFIG_NET_SCH_CBQ=m
CONFIG_NET_SCH_HTB=m
CONFIG_NET_SCH_HFSC=m
CONFIG_NET_SCH_ATM=m
CONFIG_NET_SCH_PRIO=m
# CONFIG_NET_SCH_MULTIQ is not set
CONFIG_NET_SCH_RED=m
CONFIG_NET_SCH_SFQ=m
# CONFIG_NET_SCH_TEQL is not set
CONFIG_NET_SCH_TBF=m
# CONFIG_NET_SCH_GRED is not set
# CONFIG_NET_SCH_DSMARK is not set
# CONFIG_NET_SCH_NETEM is not set
CONFIG_NET_SCH_LLQ=m
# Classification
CONFIG_NET_CLS=y
CONFIG_NET_CLS_BASIC=m
CONFIG_NET_CLS_TCINDEX=m
CONFIG_NET_CLS_ROUTE4=m
CONFIG_NET_CLS_ROUTE=y
# CONFIG_NET_CLS_FW is not set
CONFIG_NET_CLS_U32=m
# CONFIG_CLS_U32_PERF is not set
# CONFIG_CLS_U32_MARK is not set
# CONFIG_NET_CLS_RSVP is not set
# CONFIG_NET_CLS_RSVP6 is not set
# CONFIG_NET_CLS_FLOW is not set
# CONFIG_NET_EMATCH is not set
# CONFIG_NET_CLS_ACT is not set
# CONFIG_NET_CLS_IND is not set
CONFIG_NET_SCH_FIFO=y
# Network testing
# CONFIG_NET_PKTGEN is not set
# CONFIG_HAMRADIO is not set
# CONFIG_CAN is not set
# CONFIG_IRDA is not set
CONFIG_BT=m
CONFIG_BT_L2CAP=m
# CONFIG_BT_SCO is not set
CONFIG_BT_RFCOMM=m
CONFIG_BT_RFCOMM_TTY=y
CONFIG_BT_BNEP=m
CONFIG_BT_BNEP_MC_FILTER=y
CONFIG_BT_BNEP_PROTO_FILTER=y
# CONFIG_BT_CMTP is not set
# Bluetooth device drivers
CONFIG_BT_HCIBTUSB=m
# CONFIG_BT_HCIUART is not set
# CONFIG_BT_HCIBCM203X is not set
# CONFIG_BT_HCIBPA10X is not set
CONFIG_BT_HCIBFUSB=m
# CONFIG_BT_HCIVHCI is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_PHONET is not set
CONFIG_WIRELESS=y
# CONFIG_CFG80211 is not set
# CONFIG_WIRELESS_OLD_REGULATORY is not set
CONFIG_WIRELESS_EXT=y
# CONFIG_WIRELESS_EXT_SYSFS is not set
# CONFIG_MAC80211 is not set
# CONFIG_IEEE80211 is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# Device Drivers
# Generic Driver Options
CONFIG_UEVENT_HELPER_PATH=""
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
CONFIG_FW_LOADER=m
CONFIG_FIRMWARE_IN_KERNEL=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_DEBUG_DRIVER is not set
# CONFIG_DEBUG_DEVRES is not set
# CONFIG_SYS_HYPERVISOR is not set
# CONFIG_CONNECTOR is not set
CONFIG_MTD=y
# CONFIG_MTD_DEBUG is not set
# CONFIG_MTD_CONCAT is not set
CONFIG_MTD_PARTITIONS=y
# CONFIG_MTD_REDBOOT_PARTS is not set
CONFIG_MTD_CMDLINE_PARTS=y
# CONFIG_MTD_AR7_PARTS is not set
# User Modules And Translation Layers
CONFIG_MTD_CHAR=y
CONFIG_MTD_BLKDEVS=y
CONFIG_MTD_BLOCK=y
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_MTD_OOPS is not set
# RAM/ROM/Flash chip drivers
CONFIG_MTD_CFI=y
# CONFIG_MTD_SPI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_GEN_PROBE=y
CONFIG_MTD_CFI_ADV_OPTIONS=y
CONFIG_MTD_CFI_NOSWAP=y
# CONFIG_MTD_CFI_BE_BYTE_SWAP is not set
# CONFIG_MTD_CFI_LE_BYTE_SWAP is not set
CONFIG_MTD_CFI_GEOMETRY=y
# CONFIG_MTD_MAP_BANK_WIDTH_1 is not set
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
# CONFIG_MTD_MAP_BANK_WIDTH_8 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_16 is not set
# CONFIG_MTD_MAP_BANK_WIDTH_32 is not set
CONFIG_MTD_CFI_I1=y
# CONFIG_MTD_CFI_I2 is not set
# CONFIG_MTD_CFI_I4 is not set
# CONFIG_MTD_CFI_I8 is not set
# CONFIG_MTD_OTP is not set
# CONFIG_MTD_CFI_INTELEXT is not set
CONFIG_MTD_CFI_AMDSTD=y
# CONFIG_MTD_CFI_STAA is not set
CONFIG_MTD_CFI_UTIL=y
CONFIG_MTD_RAM=y
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
CONFIG_MTD_PHYSMAP=y
CONFIG_MTD_PHYSMAP_START=0x10000000
CONFIG_MTD_PHYSMAP_LEN=0x0
CONFIG_MTD_PHYSMAP_BANKWIDTH=2
# CONFIG_MTD_INTEL_VR_NOR is not set
CONFIG_MTD_PLATRAM=y
# CONFIG_MTD_PLATNOR is not set
# Self-contained MTD device drivers
# CONFIG_MTD_PMC551 is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
CONFIG_MTD_BLOCK2MTD=m
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOC2000 is not set
# CONFIG_MTD_DOC2001 is not set
# CONFIG_MTD_DOC2001PLUS is not set
# CONFIG_MTD_AR7240_SPI_FLASH is not set
CONFIG_MTD_NAND=y
CONFIG_MTD_NAND_VERIFY_WRITE=y
# CONFIG_MTD_NAND_ECC_SMC is not set
# CONFIG_MTD_NAND_MUSEUM_IDS is not set
CONFIG_MTD_NAND_IDS=y
# CONFIG_MTD_NAND_DISKONCHIP is not set
# CONFIG_MTD_NAND_CAFE is not set
# CONFIG_MTD_NAND_NANDSIM is not set
# CONFIG_MTD_NAND_PLATFORM is not set
# CONFIG_MTD_ALAUDA is not set
CONFIG_MTD_NAND_DIRECT_AVM=y
# CONFIG_MTD_NAND_DIRECT_AVM_ADDR is not set
CONFIG_MTD_NAND_DIRECT_AVM_GPIO=y
CONFIG_MTD_NAND_DIRECT_AVM_DATA=0x1E000000
CONFIG_MTD_NAND_DIRECT_AVM_READY0=21
CONFIG_MTD_NAND_DIRECT_AVM_READY1=7
CONFIG_MTD_NAND_DIRECT_AVM_NCE0=16
CONFIG_MTD_NAND_DIRECT_AVM_NCE1=17
CONFIG_MTD_NAND_DIRECT_AVM_ALE=19
CONFIG_MTD_NAND_DIRECT_AVM_CLE=18
CONFIG_MTD_NAND_DIRECT_AVM_NWP=20
# CONFIG_MTD_ONENAND is not set
# UBI - Unsorted block images
# CONFIG_MTD_UBI is not set
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
CONFIG_COMPCACHE=m
# CONFIG_BLK_DEV_VIRTUAL_FAT is not set
# CONFIG_BLK_CPQ_DA is not set
# CONFIG_BLK_CPQ_CISS_DA is not set
# CONFIG_BLK_DEV_DAC960 is not set
# CONFIG_BLK_DEV_UMEM is not set
# CONFIG_BLK_DEV_COW_COMMON is not set
CONFIG_BLK_DEV_LOOP=m
# CONFIG_BLK_DEV_CRYPTOLOOP is not set
CONFIG_BLK_DEV_NBD=m
# CONFIG_BLK_DEV_SX8 is not set
# CONFIG_BLK_DEV_UB is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_HD is not set
# CONFIG_MISC_DEVICES is not set
CONFIG_HAVE_IDE=y
# CONFIG_IDE is not set
# SCSI device support
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI=m
CONFIG_SCSI_DMA=y
# CONFIG_SCSI_TGT is not set
# CONFIG_SCSI_NETLINK is not set
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=m
# CONFIG_CHR_DEV_ST is not set
# CONFIG_CHR_DEV_OSST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
# CONFIG_CHR_DEV_SCH is not set
# Some SCSI devices (e.g. CD jukebox) support multiple LUNs
CONFIG_SCSI_MULTI_LUN=y
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
CONFIG_SCSI_WAIT_SCAN=m
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# CONFIG_SCSI_LOWLEVEL is not set
# CONFIG_SCSI_DH is not set
# CONFIG_ATA is not set
CONFIG_MD=y
# CONFIG_BLK_DEV_MD is not set
CONFIG_BLK_DEV_DM=m
# CONFIG_DM_DEBUG is not set
CONFIG_DM_CRYPT=m
# CONFIG_DM_SNAPSHOT is not set
# CONFIG_DM_MIRROR is not set
# CONFIG_DM_ZERO is not set
# CONFIG_DM_MULTIPATH is not set
# CONFIG_DM_DELAY is not set
# CONFIG_DM_UEVENT is not set
# CONFIG_FUSION is not set
# IEEE 1394 (FireWire) support
# Enable only one of the two stacks, unless you know what you are doing
# CONFIG_FIREWIRE is not set
# CONFIG_IEEE1394 is not set
# CONFIG_I2O is not set
CONFIG_NETDEVICES=y
CONFIG_DUMMY=m
# CONFIG_BONDING is not set
# CONFIG_MACVLAN is not set
# CONFIG_EQUALIZER is not set
CONFIG_TUN=y
# CONFIG_VETH is not set
# CONFIG_ARCNET is not set
# CONFIG_PHYLIB is not set
CONFIG_NET_ETHERNET=y
# CONFIG_MII is not set
CONFIG_AVM_CPMAC=y
CONFIG_AVM_CPMAC_NUM_RX_BUFFERS=256
CONFIG_AVM_CPMAC_SWITCH=y
# CONFIG_AX88796 is not set
# CONFIG_HAPPYMEAL is not set
# CONFIG_SUNGEM is not set
# CONFIG_CASSINI is not set
# CONFIG_NET_VENDOR_3COM is not set
# CONFIG_SMC91X is not set
# CONFIG_DM9000 is not set
# CONFIG_NET_TULIP is not set
# CONFIG_HP100 is not set
# CONFIG_IBM_NEW_EMAC_ZMII is not set
# CONFIG_IBM_NEW_EMAC_RGMII is not set
# CONFIG_IBM_NEW_EMAC_TAH is not set
# CONFIG_IBM_NEW_EMAC_EMAC4 is not set
# CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set
# CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set
# CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set
# CONFIG_NET_PCI is not set
# CONFIG_B44 is not set
# CONFIG_ATL2 is not set
CONFIG_NETDEV_1000=y
# CONFIG_ACENIC is not set
# CONFIG_DL2K is not set
# CONFIG_E1000 is not set
# CONFIG_E1000E is not set
# CONFIG_IP1000 is not set
# CONFIG_IGB is not set
# CONFIG_NS83820 is not set
# CONFIG_HAMACHI is not set
# CONFIG_YELLOWFIN is not set
# CONFIG_R8169 is not set
# CONFIG_SIS190 is not set
# CONFIG_SKGE is not set
# CONFIG_SKY2 is not set
# CONFIG_VIA_VELOCITY is not set
# CONFIG_TIGON3 is not set
# CONFIG_BNX2 is not set
# CONFIG_QLA3XXX is not set
# CONFIG_ATL1 is not set
# CONFIG_ATL1E is not set
# CONFIG_JME is not set
# CONFIG_NETDEV_10000 is not set
# CONFIG_TR is not set
# Wireless LAN
# CONFIG_WLAN_PRE80211 is not set
# CONFIG_WLAN_80211 is not set
# CONFIG_IWLWIFI_LEDS is not set
# USB Network Adapters
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_USBNET is not set
# CONFIG_WAN is not set
CONFIG_ATM_DRIVERS=y
# CONFIG_ATM_DUMMY is not set
# CONFIG_ATM_TCP is not set
# CONFIG_ATM_LANAI is not set
# CONFIG_ATM_ENI is not set
# CONFIG_ATM_FIRESTREAM is not set
# CONFIG_ATM_ZATM is not set
# CONFIG_ATM_NICSTAR is not set
# CONFIG_ATM_IDT77252 is not set
# CONFIG_ATM_AMBASSADOR is not set
# CONFIG_ATM_HORIZON is not set
# CONFIG_ATM_IA is not set
# CONFIG_ATM_FORE200E is not set
# CONFIG_ATM_HE is not set
# CONFIG_FDDI is not set
# CONFIG_HIPPI is not set
CONFIG_PPP=y
CONFIG_PPP_MULTILINK=y
CONFIG_PPP_FILTER=y
CONFIG_PPP_ASYNC=y
CONFIG_PPP_SYNC_TTY=y
CONFIG_PPP_DEFLATE=m
# CONFIG_PPP_BSDCOMP is not set
CONFIG_PPP_MPPE_MPPC=m
CONFIG_PPPOE=y
CONFIG_PPPOATM=y
# CONFIG_PPPOL2TP is not set
# CONFIG_SLIP is not set
CONFIG_SLHC=y
# CONFIG_NET_FC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_NETPOLL is not set
# CONFIG_NET_POLL_CONTROLLER is not set
CONFIG_AVM_NET_LINK_AUDIO=m
CONFIG_ISDN=y
# CONFIG_MISDN is not set
# CONFIG_ISDN_I4L is not set
CONFIG_ISDN_CAPI=y
CONFIG_CAPI_OSLIB=y
# CONFIG_CAPI_OSLIB_DEBUG is not set
CONFIG_CAPI_CODEC=m
# CONFIG_CAPI_CODEC_SPEEX is not set
CONFIG_CAPI_CODEC_ILBC=y
CONFIG_CAPI_CODEC_G729=y
CONFIG_CAPI_CODEC_G711=y
CONFIG_CAPI_CODEC_G726=y
CONFIG_CAPI_CODEC_G722=y
CONFIG_CAPI_CODEC_VAD=y
CONFIG_CAPI_CODEC_CNG=y
CONFIG_CAPI_CODEC_FAX=y
CONFIG_AVM_DECT=m
# CONFIG_AVM_DECT_DEBUG is not set
# CONFIG_ISDN_DRV_AVMB1_VERBOSE_REASON is not set
# CONFIG_CAPI_TRACE is not set
# CONFIG_ISDN_CAPI_MIDDLEWARE is not set
# CONFIG_ISDN_CAPI_CAPI20 is not set
# CAPI hardware drivers
CONFIG_CAPI_AVM=y
# CONFIG_ISDN_DRV_AVMB1_B1PCI is not set
# CONFIG_ISDN_DRV_AVMB1_B1PCMCIA is not set
# CONFIG_ISDN_DRV_AVMB1_T1PCI is not set
# CONFIG_ISDN_DRV_AVMB1_C4 is not set
CONFIG_ISDN_CAPI_ISDN_NT_PCMLINK=m
CONFIG_ISDN_NT_PCMLINK_BLK=m
CONFIG_ISDN_NT_PCMLINK_E1=m
CONFIG_ISDN_NT_PCMLINK_STACK=m
CONFIG_ISDN_NT_PCMLINK_ISDN_AB=m
# CONFIG_ISDN_NT_PCMLINK_DEBUG is not set
# CONFIG_ISDN_NT_PCMLINK_NO_BCHANNEL is not set
# CONFIG_ISDN_NT_PCMLINK_FAX is not set
# CONFIG_ISDN_NT_PCMLINK_COMPRESS is not set
# CONFIG_ISDN_NT_PCMLINK_MODEM is not set
# CONFIG_ISDN_NT_PCMLINK_DTMF is not set
CONFIG_ISDN_NT_PCMLINK_VCTRLS=y
CONFIG_ISDN_NT_PCMLINK_VCTRLS_NUMBER=5
CONFIG_ISDN_NT_PCMLINK_FRITZX=y
# CONFIG_CAPI_EICON is not set
# CONFIG_PHONE is not set
# Input device support
# CONFIG_INPUT is not set
# Hardware I/O ports
# CONFIG_SERIO is not set
# CONFIG_GAMEPORT is not set
# Character devices
# CONFIG_VT is not set
CONFIG_DEVKMEM=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_NOZOMI is not set
# Serial drivers
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_PCI=y
CONFIG_SERIAL_8250_NR_UARTS=2
CONFIG_SERIAL_8250_CONSOLE_UART=1
CONFIG_SERIAL_8250_RUNTIME_UARTS=1
# CONFIG_SERIAL_8250_EXTENDED is not set
# Non-8250 serial port support
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_JSM is not set
# CONFIG_SERIAL_AVM_8250 is not set
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=16
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_R3964 is not set
# CONFIG_APPLICOM is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
CONFIG_TFFS=y
CONFIG_TFFS_ENV=y
# CONFIG_TFFS_CRYPT is not set
CONFIG_AVM_NET_TRACE=y
CONFIG_AVM_DECT_IO=m
CONFIG_AVM_DECT_SYNC=-1
CONFIG_AVM_SAMMEL=y
CONFIG_AVM_EVENT=y
CONFIG_AVM_LED_EVENTS=m
CONFIG_AVM_WATCHDOG=y
CONFIG_AVM_DEBUG=y
# CONFIG_AVM_PUSH_BUTTON is not set
# CONFIG_AVM_PUSH_BUTTON2 is not set
# CONFIG_AVM_PUSH_BUTTON3 is not set
# CONFIG_AVM_PUSH_BUTTON4 is not set
# CONFIG_AVM_PUSH_BUTTON5 is not set
CONFIG_AVM_FLASH_UPDATE=m
# CONFIG_AVM_PIGLET is not set
CONFIG_AVM_PIGLET_NOEMIF=m
CONFIG_AVM_PIGLET_DECT=y
CONFIG_AVM_POWER=y
CONFIG_AVM_POWERMETER=y
CONFIG_UBIK2=m
CONFIG_UBIK2_DEVELOPMENT_SUPPORT=0
CONFIG_TFFS_PANIC_LOG=y
CONFIG_TFFS_PANIC_LOG_ID=96
CONFIG_DEVPORT=y
# CONFIG_I2C is not set
# CONFIG_SPI is not set
# CONFIG_W1 is not set
# CONFIG_POWER_SUPPLY is not set
# CONFIG_HWMON is not set
# CONFIG_THERMAL is not set
# CONFIG_THERMAL_HWMON is not set
# CONFIG_WATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# Sonics Silicon Backplane
# CONFIG_SSB is not set
# Multifunction device drivers
# CONFIG_MFD_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_MFD_TMIO is not set
# CONFIG_REGULATOR is not set
# Multimedia devices
# Multimedia core support
# CONFIG_VIDEO_DEV is not set
# CONFIG_DVB_CORE is not set
# CONFIG_VIDEO_MEDIA is not set
# Multimedia drivers
# CONFIG_DAB is not set
# Graphics support
# CONFIG_DRM is not set
# CONFIG_VGASTATE is not set
# CONFIG_VIDEO_OUTPUT_CONTROL is not set
# CONFIG_FB is not set
# CONFIG_BACKLIGHT_LCD_SUPPORT is not set
# Display device support
# CONFIG_DISPLAY_SUPPORT is not set
# CONFIG_SOUND is not set
CONFIG_USB_SUPPORT=y
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB_ARCH_HAS_OHCI=y
CONFIG_USB_ARCH_HAS_EHCI=y
CONFIG_USB=m
# CONFIG_USB_DEBUG is not set
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEVICEFS=y
# CONFIG_USB_DEVICE_CLASS is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_WHITELIST is not set
# CONFIG_USB_OTG_BLACKLIST_HUB is not set
# CONFIG_USB_MON is not set
# CONFIG_USB_WUSB is not set
# CONFIG_USB_WUSB_CBAF is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
CONFIG_USB_EHCI_HCD=m
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
# CONFIG_USB_EHCI_TT_NEWSCHED is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_ISP1760_HCD is not set
CONFIG_USB_OHCI_HCD=m
# CONFIG_USB_OHCI_BIG_ENDIAN_DESC is not set
# CONFIG_USB_OHCI_BIG_ENDIAN_MMIO is not set
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
# CONFIG_USB_UHCI_HCD is not set
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_WHCI_HCD is not set
# CONFIG_USB_HWA_HCD is not set
# USB Device Class drivers
CONFIG_USB_ACM=m
CONFIG_USB_PRINTER=m
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may also be needed;
# see USB_STORAGE Help for more information
CONFIG_USB_STORAGE=m
# CONFIG_USB_STORAGE_DEBUG is not set
# CONFIG_USB_STORAGE_DATAFAB is not set
# CONFIG_USB_STORAGE_FREECOM is not set
# CONFIG_USB_STORAGE_ISD200 is not set
# CONFIG_USB_STORAGE_DPCM is not set
# CONFIG_USB_STORAGE_USBAT is not set
# CONFIG_USB_STORAGE_SDDR09 is not set
# CONFIG_USB_STORAGE_SDDR55 is not set
# CONFIG_USB_STORAGE_JUMPSHOT is not set
# CONFIG_USB_STORAGE_ALAUDA is not set
# CONFIG_USB_STORAGE_KARMA is not set
# CONFIG_USB_STORAGE_CYPRESS_ATACB is not set
# CONFIG_USB_LIBUSUAL is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# USB port drivers
CONFIG_USB_SERIAL=m
# CONFIG_USB_EZUSB is not set
CONFIG_USB_SERIAL_GENERIC=y
# CONFIG_USB_SERIAL_AIRCABLE is not set
# CONFIG_USB_SERIAL_ARK3116 is not set
# CONFIG_USB_SERIAL_BELKIN is not set
# CONFIG_USB_SERIAL_CH341 is not set
# CONFIG_USB_SERIAL_WHITEHEAT is not set
# CONFIG_USB_SERIAL_DIGI_ACCELEPORT is not set
CONFIG_USB_SERIAL_CP2101=m
# CONFIG_USB_SERIAL_CYPRESS_M8 is not set
# CONFIG_USB_SERIAL_EMPEG is not set
CONFIG_USB_SERIAL_FTDI_SIO=m
# CONFIG_USB_SERIAL_FUNSOFT is not set
# CONFIG_USB_SERIAL_VISOR is not set
CONFIG_USB_SERIAL_IPAQ=m
# CONFIG_USB_SERIAL_IR is not set
# CONFIG_USB_SERIAL_EDGEPORT is not set
# CONFIG_USB_SERIAL_EDGEPORT_TI is not set
# CONFIG_USB_SERIAL_GARMIN is not set
# CONFIG_USB_SERIAL_IPW is not set
# CONFIG_USB_SERIAL_IUU is not set
# CONFIG_USB_SERIAL_KEYSPAN_PDA is not set
# CONFIG_USB_SERIAL_KEYSPAN is not set
# CONFIG_USB_SERIAL_KLSI is not set
# CONFIG_USB_SERIAL_KOBIL_SCT is not set
# CONFIG_USB_SERIAL_MCT_U232 is not set
# CONFIG_USB_SERIAL_MOS7720 is not set
# CONFIG_USB_SERIAL_MOS7840 is not set
# CONFIG_USB_SERIAL_MOTOROLA is not set
# CONFIG_USB_SERIAL_NAVMAN is not set
CONFIG_USB_SERIAL_PL2303=m
# CONFIG_USB_SERIAL_OTI6858 is not set
# CONFIG_USB_SERIAL_SPCP8X5 is not set
# CONFIG_USB_SERIAL_HP4X is not set
# CONFIG_USB_SERIAL_SAFE is not set
# CONFIG_USB_SERIAL_SIERRAWIRELESS is not set
# CONFIG_USB_SERIAL_TI is not set
# CONFIG_USB_SERIAL_CYBERJACK is not set
# CONFIG_USB_SERIAL_XIRCOM is not set
CONFIG_USB_SERIAL_OPTION=m
# CONFIG_USB_SERIAL_OMNINET is not set
# CONFIG_USB_SERIAL_DEBUG is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_RIO500 is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_BERRY_CHARGE is not set
# CONFIG_USB_LED is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_PHIDGET is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_VST is not set
# CONFIG_USB_ATM is not set
# CONFIG_USB_GADGET is not set
# CONFIG_UWB is not set
# CONFIG_MMC is not set
# CONFIG_MEMSTICK is not set
# CONFIG_NEW_LEDS is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=m
# RTC interfaces
CONFIG_RTC_INTF_SYSFS=y
CONFIG_RTC_INTF_PROC=y
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# SPI RTC drivers
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_V3020 is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_AVM_REF_CLOCK=m
# CONFIG_DMADEVICES is not set
# CONFIG_UIO is not set
CONFIG_STAGING=y
# CONFIG_STAGING_EXCLUDE_BUILD is not set
# CONFIG_ET131X is not set
# CONFIG_ME4000 is not set
CONFIG_USB_IP_COMMON=m
CONFIG_USB_IP_VHCI_HCD=m
CONFIG_USB_IP_HOST=m
# CONFIG_ECHO is not set
# File systems
CONFIG_EXT2_FS=y
CONFIG_EXT2_FS_XATTR=y
# CONFIG_EXT2_FS_POSIX_ACL is not set
# CONFIG_EXT2_FS_SECURITY is not set
# CONFIG_EXT2_FS_XIP is not set
CONFIG_EXT3_FS=y
CONFIG_EXT3_FS_XATTR=y
# CONFIG_EXT3_FS_POSIX_ACL is not set
# CONFIG_EXT3_FS_SECURITY is not set
CONFIG_EXT4_FS=m
# CONFIG_EXT4DEV_COMPAT is not set
CONFIG_EXT4_FS_XATTR=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
CONFIG_JBD=y
CONFIG_JBD2=m
CONFIG_FS_MBCACHE=y
CONFIG_REISERFS_FS=m
# CONFIG_REISERFS_CHECK is not set
# CONFIG_REISERFS_PROC_INFO is not set
# CONFIG_REISERFS_FS_XATTR is not set
# CONFIG_JFS_FS is not set
# CONFIG_FS_POSIX_ACL is not set
CONFIG_FILE_LOCKING=y
# CONFIG_XFS_FS is not set
# CONFIG_OCFS2_FS is not set
# CONFIG_DNOTIFY is not set
CONFIG_INOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS_FS is not set
CONFIG_AUTOFS4_FS=m
CONFIG_FUSE_FS=m
# CD-ROM/DVD Filesystems
CONFIG_ISO9660_FS=m
CONFIG_JOLIET=y
# CONFIG_ZISOFS is not set
CONFIG_UDF_FS=m
CONFIG_UDF_NLS=y
# DOS/FAT/NT Filesystems
CONFIG_FAT_FS=m
CONFIG_MSDOS_FS=m
CONFIG_VFAT_FS=m
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_NTFS_FS is not set
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_KCORE=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_HUGETLB_PAGE is not set
CONFIG_RAMFS=y
# CONFIG_CONFIGFS_FS is not set
# Layered filesystems
# CONFIG_UNION_FS is not set
# Miscellaneous filesystems
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
CONFIG_HFS_FS=m
CONFIG_HFSPLUS_FS=m
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
CONFIG_YAFFS_FS=y
CONFIG_YAFFS_YAFFS1=y
# CONFIG_YAFFS_9BYTE_TAGS is not set
# CONFIG_YAFFS_DOES_ECC is not set
CONFIG_YAFFS_YAFFS2=y
CONFIG_YAFFS_AUTO_YAFFS2=y
CONFIG_YAFFS_DISABLE_TAGS_ECC=y
# CONFIG_YAFFS_ALWAYS_CHECK_CHUNK_ERASED is not set
# CONFIG_YAFFS_EMPTY_LOST_AND_FOUND is not set
# CONFIG_YAFFS_DISABLE_BLOCK_REFRESHING is not set
# CONFIG_YAFFS_DISABLE_BACKGROUND is not set
CONFIG_YAFFS_XATTR=y
CONFIG_JFFS2_FS=m
CONFIG_JFFS2_FS_DEBUG=0
CONFIG_JFFS2_FS_WRITEBUFFER=y
# CONFIG_JFFS2_FS_WBUF_VERIFY is not set
# CONFIG_JFFS2_SUMMARY is not set
# CONFIG_JFFS2_FS_XATTR is not set
# CONFIG_JFFS2_COMPRESSION_OPTIONS is not set
CONFIG_JFFS2_ZLIB=y
# CONFIG_JFFS2_LZO is not set
CONFIG_JFFS2_RTIME=y
# CONFIG_JFFS2_RUBIN is not set
# CONFIG_CRAMFS is not set
CONFIG_SQUASHFS=y
CONFIG_SQUASHFS_EMBEDDED=y
CONFIG_SQUASHFS_FRAGMENT_CACHE_SIZE=3
# CONFIG_VXFS_FS is not set
CONFIG_MINI_FO=m
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V3=y
# CONFIG_NFS_V3_ACL is not set
# CONFIG_NFS_V4 is not set
CONFIG_ROOT_NFS=y
CONFIG_NFSD=y
CONFIG_NFSD_V3=y
# CONFIG_NFSD_V3_ACL is not set
# CONFIG_NFSD_V4 is not set
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_EXPORTFS=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
# CONFIG_SUNRPC_REGISTER_V4 is not set
# CONFIG_RPCSEC_GSS_KRB5 is not set
# CONFIG_RPCSEC_GSS_SPKM3 is not set
# CONFIG_SMB_FS is not set
CONFIG_CIFS=m
# CONFIG_CIFS_STATS is not set
# CONFIG_CIFS_WEAK_PW_HASH is not set
# CONFIG_CIFS_XATTR is not set
# CONFIG_CIFS_DEBUG2 is not set
# CONFIG_CIFS_EXPERIMENTAL is not set
# CONFIG_NCP_FS is not set
CONFIG_CODA_FS=m
# CONFIG_AFS_FS is not set
# Partition Types
CONFIG_PARTITION_ADVANCED=y
# CONFIG_ACORN_PARTITION is not set
# CONFIG_OSF_PARTITION is not set
# CONFIG_AMIGA_PARTITION is not set
# CONFIG_ATARI_PARTITION is not set
# CONFIG_MAC_PARTITION is not set
CONFIG_MSDOS_PARTITION=y
# CONFIG_BSD_DISKLABEL is not set
# CONFIG_MINIX_SUBPARTITION is not set
# CONFIG_SOLARIS_X86_PARTITION is not set
# CONFIG_UNIXWARE_DISKLABEL is not set
# CONFIG_LDM_PARTITION is not set
# CONFIG_SGI_PARTITION is not set
# CONFIG_ULTRIX_PARTITION is not set
# CONFIG_SUN_PARTITION is not set
# CONFIG_KARMA_PARTITION is not set
CONFIG_EFI_PARTITION=y
# CONFIG_SYSV68_PARTITION is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=m
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
CONFIG_NLS_CODEPAGE_850=m
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
CONFIG_NLS_ASCII=m
CONFIG_NLS_ISO8859_1=m
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
CONFIG_NLS_ISO8859_15=m
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
CONFIG_NLS_UTF8=m
# CONFIG_DLM is not set
# Kernel hacking
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
# CONFIG_PRINTK_TIME is not set
CONFIG_ENABLE_WARN_DEPRECATED=y
CONFIG_ENABLE_MUST_CHECK=y
CONFIG_FRAME_WARN=1024
CONFIG_MAGIC_SYSRQ=y
# CONFIG_UNUSED_SYMBOLS is not set
# CONFIG_DEBUG_FS is not set
# CONFIG_HEADERS_CHECK is not set
CONFIG_DEBUG_KERNEL=y
# CONFIG_DEBUG_SHIRQ is not set
CONFIG_DETECT_SOFTLOCKUP=y
# CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC is not set
CONFIG_BOOTPARAM_SOFTLOCKUP_PANIC_VALUE=0
# CONFIG_SCHED_DEBUG is not set
# CONFIG_SCHEDSTATS is not set
# CONFIG_TIMER_STATS is not set
# CONFIG_DEBUG_OBJECTS is not set
# CONFIG_DEBUG_SLAB is not set
# CONFIG_DEBUG_RT_MUTEXES is not set
# CONFIG_RT_MUTEX_TESTER is not set
# CONFIG_DEBUG_SPINLOCK is not set
# CONFIG_DEBUG_MUTEXES is not set
# CONFIG_DEBUG_LOCK_ALLOC is not set
# CONFIG_PROVE_LOCKING is not set
# CONFIG_LOCK_STAT is not set
# CONFIG_DEBUG_SPINLOCK_SLEEP is not set
# CONFIG_DEBUG_LOCKING_API_SELFTESTS is not set
# CONFIG_DEBUG_KOBJECT is not set
# CONFIG_DEBUG_INFO is not set
# CONFIG_DEBUG_VM is not set
# CONFIG_DEBUG_WRITECOUNT is not set
# CONFIG_DEBUG_MEMORY_INIT is not set
# CONFIG_DEBUG_LIST is not set
# CONFIG_DEBUG_SG is not set
# CONFIG_BOOT_PRINTK_DELAY is not set
# CONFIG_RCU_TORTURE_TEST is not set
# CONFIG_RCU_CPU_STALL_DETECTOR is not set
# CONFIG_BACKTRACE_SELF_TEST is not set
# CONFIG_DEBUG_BLOCK_EXT_DEVT is not set
# CONFIG_FAULT_INJECTION is not set
# CONFIG_SYSCTL_SYSCALL_CHECK is not set
# Tracers
# CONFIG_IRQSOFF_TRACER is not set
# CONFIG_SCHED_TRACER is not set
# CONFIG_CONTEXT_SWITCH_TRACER is not set
# CONFIG_BOOT_TRACER is not set
# CONFIG_DYNAMIC_PRINTK_DEBUG is not set
# CONFIG_SAMPLES is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_KGDB is not set
CONFIG_CMDLINE="console=ttyS1,115200n8r"
# CONFIG_DEBUG_STACK_USAGE is not set
# CONFIG_RUNTIME_DEBUG is not set
# CONFIG_DEBUG_LL is not set
# Security options
# CONFIG_KEYS is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
# CONFIG_SECURITY_FILE_CAPABILITIES is not set
CONFIG_CRYPTO=y
# Crypto core or helper
# CONFIG_CRYPTO_FIPS is not set
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_BLKCIPHER=y
CONFIG_CRYPTO_BLKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_GF128MUL is not set
# CONFIG_CRYPTO_NULL is not set
# CONFIG_CRYPTO_CRYPTD is not set
CONFIG_CRYPTO_AUTHENC=y
# CONFIG_CRYPTO_TEST is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_SEQIV is not set
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=m
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# Hash modes
CONFIG_CRYPTO_HMAC=y
# CONFIG_CRYPTO_XCBC is not set
# Digest
# CONFIG_CRYPTO_CRC32C is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD128 is not set
# CONFIG_CRYPTO_RMD160 is not set
# CONFIG_CRYPTO_RMD256 is not set
# CONFIG_CRYPTO_RMD320 is not set
CONFIG_CRYPTO_SHA1=y
CONFIG_CRYPTO_SHA256=m
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_TGR192 is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_ANUBIS is not set
CONFIG_CRYPTO_ARC4=m
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_KHAZAD is not set
# CONFIG_CRYPTO_SALSA20 is not set
# CONFIG_CRYPTO_SEED is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_TEA is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
CONFIG_CRYPTO_DEFLATE=y
# CONFIG_CRYPTO_LZO is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
CONFIG_CRYPTO_HW=y
# CONFIG_CRYPTO_DEV_HIFN_795X is not set
# Library routines
CONFIG_BITREVERSE=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=m
# CONFIG_CRC_T10DIF is not set
CONFIG_CRC_ITU_T=m
CONFIG_CRC32=y
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_ZLIB_DEFLATE=y
CONFIG_LZO_COMPRESS=m
CONFIG_LZO_DECOMPRESS=m
CONFIG_TEXTSEARCH=y
CONFIG_TEXTSEARCH_KMP=m
CONFIG_TEXTSEARCH_BM=m
CONFIG_TEXTSEARCH_FSM=m
CONFIG_PLIST=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT=y
CONFIG_HAS_DMA=y
# FUSIV Source Kernel Configuration
CONFIG_FUSIV_LIBRARY=m
CONFIG_FUSIV_TIMERS=m
CONFIG_FUSIV_KERNEL_AP_2_AP=m
# CONFIG_MCAST_AP_SUPPORT is not set
CONFIG_FUSIV_BMDRIVER=m
CONFIG_FUSIV_KERNEL_ETHERNET=m
CONFIG_FUSIV_KERNEL_ATM=m
CONFIG_FUSIV_KERNEL_ACL=m
# CONFIG_FUSIV_KERNEL_ACL_EMAC3 is not set
CONFIG_FUSIV_KERNEL_ACL_SPA=y
# CONFIG_FUSIV_KERNEL_PPPOE_RELAY is not set
# CONFIG_FUSIV_KERNEL_WLAN is not set
CONFIG_FUSIV_KERNEL_PERI_AP=m
# CONFIG_FUSIV_KERNEL_WLAN_ATH_11G is not set
CONFIG_FUSIV_KERNEL_WLAN_ATH_11N=y
# CONFIG_FUSIV_KERNEL_WLAN_RT_11N is not set
# CONFIG_FUSIV_KERNEL_DSP is not set
# Voice Drivers Selection
CONFIG_FUSIV_KERNEL_BME_DRIVER_VX180=m
CONFIG_FUSIV_KERNEL_VX180_AVDSL=m
# Fusiv IPQoS Configurations
CONFIG_FUSIV_KERNEL_HOST_IPQOS=m
CONFIG_FUSIV_KERNEL_IPQOS_TRAFFIC_SCHEDULER=y
CONFIG_FUSIV_KERNEL_IPQOS_APQOS=y
# CONFIG_FUSIV_KERNEL_IPQOS_TC_RATE_CONTROL is not set
CONFIG_FUSIV_KERNEL_IPQOS_TC_MAPPING=y
CONFIG_FUSIV_KERNEL_IPQOS_TC_MARKING=y
CONFIG_FUSIV_KERNEL_IPQOS_TC_PRIORITY_CONVERSION=y
CONFIG_FUSIV_KERNEL_IPQOS_STATISTICS=y
CONFIG_FUSIV_KERNEL_IPQOS_DEBUG_LOG=y
# CONFIG_FUSIV_KERNEL_PROFILER is not set
# CONFIG_FUSIV_KERNEL_MONIF is not set
# CONFIG_FUSIV_KERNEL_IGMP_SNOOP is not set
# CONFIG_FUSIV_KERNEL_POLICY_VLAN is not set
# CONFIG_FUSIV_KERNEL_GPON is not set
# AP-BUF and SK-BUFF Mapping
CONFIG_FUSIV_ENABLE_AP_MBUF=y
CONFIG_FUSIV_ENABLE_MBUF_AP=y
# CONFIG_FUSIV_VX180_WRITE_THRU is not set
CONFIG_FUSIV_VX180_WRITE_BACK=y
CONFIG_FUSIV_USB_OPTIMIZATION=y
Das war mit ein Grund für den Thread.
Grüße,
JD.
