modprobe loop
/var # ls *.image
plugin-samba.image
/var # mount -o loop var/plugin-samba.image y
mount: mounting var/plugin-samba.image on y failed: No such file or directory
/var # mkdir y
/var # mount -o loop /var/plugin-samba.image /var/y
mount: mounting /dev/loop0 on /var/y failed: Invalid argument
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
dev on /dev type tmpfs (rw,nosuid)
proc on /proc type proc (rw,nodiratime,nosuid,nodev,noexec)
tmpfs on /var type tmpfs (rw)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec)
usbfs on /proc/bus/usb type usbfs (rw)
/dev/sda1 on /var/media/ftp/uStor01 type ext2 (rw,noatime,nodiratime)
/dev/sda2 on /var/media/ftp/uStor02 type vfat (rw,nodiratime,fmask=0000,dmask=0000,codepage=cp437,iocharset=iso8859-1)
/dev/sda3 on /var/media/ftp/uStor03 type ext2 (rw,noatime,nodiratime)
Übrigens, SWAP habe ich mir gestern eingerichtet, es taucht aber nicht in mount-Tabelle auf
http://boxplugin.avm.de./cgi-bin/boxplugin?name=FRITZ!Box+Fon+WLAN+7270&revision=13286&version=54.04.97&subversion=&hw=139&OEM=avm
http://boxplugin.avm.de./cgi-bin/boxplugin?name=FRITZ!Box+Fon+WLAN+7270&revision=13286&version=54.04.97&subversion=-13286&hw=139&OEM=avm
Aha, da findet er auch was.Da fehlt ja auch was:
EXTERNAL_CREATEPAK=y
EXTERNAL_DIR1=y
EXTERNAL_DIRECTORY="/var/media/ftp/uStor01/external/"
EXTERNAL_ENABLED=y
EXTERNAL_OWN_FILES=""
FREETZ_APACHE_STATIC=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
FREETZ_AUTOMOUNT_NTFS=y
FREETZ_AUTOMOUNT_REISER_FS=y
FREETZ_AVM_VERSION_7270_04_67=y
FREETZ_AVM_VERSION_STRING="7270_04.67"
FREETZ_BUSYBOX_AR=y
FREETZ_BUSYBOX_BRCTL=y
FREETZ_BUSYBOX_BRCTL_FANCY=y
FREETZ_BUSYBOX_DIFF=y
FREETZ_BUSYBOX_FASTPROC=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_INETD=y
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_KEYS=y
FREETZ_BUSYBOX_LESS=y
FREETZ_BUSYBOX_LS_COLOR=y
FREETZ_BUSYBOX_MDEV_RENAME=y
FREETZ_BUSYBOX_MDEV_RENAME_REGEXP=y
FREETZ_BUSYBOX_MOUNT_HELPERS=y
FREETZ_BUSYBOX_MOUNT_LABEL=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_PATCH=y
FREETZ_BUSYBOX_SEQ=y
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_TAC=y
FREETZ_BUSYBOX_UDHCPD=y
FREETZ_BUSYBOX_UDHCPD_LEASES_FILE="/var/tmp/udhcpd.leases"
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_VOLUMEID_EXT=y
FREETZ_BUSYBOX_VOLUMEID_FAT=y
FREETZ_BUSYBOX_VOLUMEID_LINUXRAID=y
FREETZ_BUSYBOX_VOLUMEID_LUKS=y
FREETZ_BUSYBOX_VOLUMEID_NTFS=y
FREETZ_DEVELOPER_VERSION_STRING=y
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270.Labor.54.04.97-13483.image"
FREETZ_DOWNLOAD_TOOLCHAIN=y
FREETZ_FAVICON_DSL123=y
FREETZ_FAVICON_STRING="dsl123"
FREETZ_GROUP_APACHE_PHP=y
FREETZ_HAS_AVM_INETD=y
FREETZ_HAS_PHONE=y
FREETZ_HAS_USB_HOST=y
FREETZ_HAS_WLAN=y
FREETZ_HAVE_DOT_CONFIG=y
FREETZ_INSTALL_BASE=y
FREETZ_JLEVEL=2
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_KERNEL_MTD_SIZE=246
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_VERSION="2.6.19.2"
FREETZ_KERNEL_VERSION_2_6_19_2=y
FREETZ_LANG_DE=y
FREETZ_LANG_STRING="de"
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcapi20=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libfreetz=y
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libglib=y
FREETZ_LIB_libid3tag=y
FREETZ_LIB_libm=y
FREETZ_LIB_libmad=y
FREETZ_LIB_libncurses=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpcap=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
FREETZ_LIB_libterminfo=y
FREETZ_LIB_libterminfo_ansi=y
FREETZ_LIB_libterminfo_gnome=y
FREETZ_LIB_libterminfo_konsole=y
FREETZ_LIB_libterminfo_linux=y
FREETZ_LIB_libterminfo_putty=y
FREETZ_LIB_libterminfo_rxvt=y
FREETZ_LIB_libterminfo_screen=y
FREETZ_LIB_libterminfo_screenminusw=y
FREETZ_LIB_libterminfo_sun=y
FREETZ_LIB_libterminfo_vt100=y
FREETZ_LIB_libterminfo_vt102=y
FREETZ_LIB_libterminfo_vt102minusnsgr=y
FREETZ_LIB_libterminfo_vt102minusw=y
FREETZ_LIB_libterminfo_vt200=y
FREETZ_LIB_libterminfo_vt220=y
FREETZ_LIB_libterminfo_vt52=y
FREETZ_LIB_libterminfo_xterm=y
FREETZ_LIB_libterminfo_xtermminuscolor=y
FREETZ_LIB_libterminfo_xtermminusxfree86=y
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libuClibcxx=y
FREETZ_LIB_libusb=y
FREETZ_LIB_libutil=y
FREETZ_LIB_libz=y
FREETZ_MC_INTERNAL_EDITOR=y
FREETZ_MODULE_exportfs=y
FREETZ_MODULE_ext2=y
FREETZ_MODULE_ext3=y
FREETZ_MODULE_fuse=y
FREETZ_MODULE_jbd=y
FREETZ_MODULE_lockd=y
FREETZ_MODULE_mbcache=y
FREETZ_MODULE_nfsd=y
FREETZ_MODULE_reiserfs=y
FREETZ_MODULE_sunrpc=y
FREETZ_MOD_DL_NUM_SITES="5"
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
FREETZ_MOD_DL_SITE_4=""
FREETZ_MOD_DL_SITE_5=""
FREETZ_PACKAGE_APACHE=y
FREETZ_PACKAGE_AVM_FIREWALL=y
FREETZ_PACKAGE_CALLMONITOR=y
FREETZ_PACKAGE_CURL=y
FREETZ_PACKAGE_CURL_STATIC=y
FREETZ_PACKAGE_DNSMASQ=y
FREETZ_PACKAGE_DOWNLOADER=y
FREETZ_PACKAGE_DROPBEAR=y
FREETZ_PACKAGE_DTMFBOX=y
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK=y
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY=y
FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE=y
FREETZ_PACKAGE_ESPEAK=y
FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES=y
FREETZ_PACKAGE_FSTYP=y
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_HD_IDLE=y
FREETZ_PACKAGE_KNOCK=y
FREETZ_PACKAGE_LYNX=y
FREETZ_PACKAGE_MADPLAY=y
FREETZ_PACKAGE_MC=y
FREETZ_PACKAGE_MICROPERL=y
FREETZ_PACKAGE_MICROPERL_MODULES=""
FREETZ_PACKAGE_MODCGI=y
FREETZ_PACKAGE_MTR=y
FREETZ_PACKAGE_NAGIOS=y
FREETZ_PACKAGE_NANO_SHELL=y
FREETZ_PACKAGE_NETSNMP=y
FREETZ_PACKAGE_NFSD_CGI=y
FREETZ_PACKAGE_NFS_UTILS=y
FREETZ_PACKAGE_NTFS=y
FREETZ_PACKAGE_OPENNTPD=y
FREETZ_PACKAGE_PHP=y
FREETZ_PACKAGE_PORTMAP=y
FREETZ_PACKAGE_SG3UTILS=y
FREETZ_PACKAGE_SPINDOWN_CGI=y
FREETZ_PACKAGE_SYSLOGD_CGI=y
FREETZ_PACKAGE_TCP_WRAPPERS=y
FREETZ_PACKAGE_USBUTILS=y
FREETZ_PACKAGE_USBUTILS_IDS=y
FREETZ_PACKAGE_VIRTUALIP_CGI=y
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WOL_CGI=y
FREETZ_PACKAGE_WPUT=y
FREETZ_PATCH_DSL_EXPERT=y
FREETZ_PATCH_GETCONS=y
FREETZ_PATCH_SIGNED=y
FREETZ_PATCH_USBSTORAGE=y
FREETZ_PHP_STATIC=y
FREETZ_REMOVE_BRANDING_1und1=y
FREETZ_REMOVE_TR069=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_STATUS_STYLE=y
FREETZ_SUBVERSION_STRING=y
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_GXX=y
FREETZ_TARGET_LFS=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_UCLIBC_VERSION="0.9.29"
FREETZ_TARGET_UCLIBC_VERSION_0_9_29=y
FREETZ_TYPE_FON_WLAN_7270=y
FREETZ_TYPE_FON_WLAN_7270_16MB=y
FREETZ_TYPE_LABOR=y
FREETZ_TYPE_LABOR_PHONE=y
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="7270_labor_phone"
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_VERBOSITY_LEVEL=0
# /var/flash/tr069.cfg
tr069cfg{
enabled = yes;
cat /etc/default.Fritz_Box_7270/avm/tr069.cfg > /var/flash/tr069.cfg
