cat: /var/dtrace.tx2: No such file or directory
<5>Linux version 2.6.19.2 (1378) (gcc version 3.4.6) #1 Mon Jan 7 13:26:39 CET 2008
<4>CPU revision is: 00019068
<3>[ur8_pci_init]
<3>[setup_pci_master]
<3>[setup_pci_slave]
<3>Exposing 67108864 memory over PCI
<3>Setup Complete, Enabling PCI Interface
<3>PCI Interface Running
<3>PCI controller initialized
<3>[ur8_vbus_set_prio] instance vbus_nwss_dma level 1 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_sar_pdsp level 1 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_buffer_manager level 1 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_usb level 4 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_vlynq level 7 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_pci level 4 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_c55 level 2 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_tdm level 0 escalator disabled (count 255, floor 7)
<3>[ur8_vbus_set_prio] instance vbus_mips level 2 escalator disabled (count 255, floor 7)
<4>Determined physical RAM map:
<4> memory: 0031c000 @ 14000000 (reserved)
<4> memory: 03ce4000 @ 1431c000 (usable)
<4>[init_bootmem]
<4>[free_bootmem]
<4>[reserve_bootmem]
<7>On node 0 totalpages: 98304
<7> DMA zone: 768 pages used for memmap
<7> DMA zone: 0 pages reserved
<7> DMA zone: 97536 pages, LIFO batch:31
<7> Normal zone: 0 pages used for memmap
<4>Built 1 zonelists. Total pages: 97536
<5>Kernel command line: console=ttyS0,38400n8r
<4>Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
<4>Primary data cache 16kB, 4-way, linesize 16 bytes.
<6>Synthesized TLB refill handler (20 instructions).
<6>Synthesized TLB load handler fastpath (32 instructions).
<6>Synthesized TLB store handler fastpath (32 instructions).
<6>Synthesized TLB modify handler fastpath (31 instructions).
<4>PID hash table entries: 2048 (order: 11, 8192 bytes)
<4>CPU frequency 360.00 MHz
<4>Using 180.000 MHz high precision timer.
<4>Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
<4>Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
<4>[free_all_bootmem]
<6>Memory: 58752k/62352k available (2054k kernel code, 3476k reserved, 649k data, 136k init, 0k highmem)
<7>Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
<4>Mount-cache hash table entries: 512
<4>Checking for 'wait' instruction... available.
<6>NET: Registered protocol family 16
<4>[ur8_mtd_init]
<4>[ur8_mtd_init] flashsize = 0x00800000 Byte 8 MBytes
<4>[ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
<4>[ur8_mtd_init] mtd[1] = 0x90010000,0x90780000
<4>[ur8_mtd_init] mtd[2] = 0x90000000,0x90010000
<4>[ur8_mtd_init] mtd[3] = 0x90780000,0x907C0000
<4>[ur8_mtd_init] mtd[4] = 0x907C0000,0x90800000
<4>[ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
<3>pcibios_read_config: accessing PCI slot not present: 0, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 1, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 2, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 3, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 4, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 5, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 6, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 7, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 8, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 9, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 10, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 11, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 12, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 13, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 15, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 16, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 17, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 18, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 19, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 20, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 21, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 22, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 23, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 24, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 25, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 26, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 27, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 28, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 29, where 0, size 4
<3>pcibios_read_config: accessing PCI slot not present: 30, where 0, size 4
<3>Master and Slave Enabled
<3>pcibios_read_config: accessing PCI slot not present: 31, where 0, size 4
<6>NET: Registered protocol family 2
<4>IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
<4>TCP established hash table entries: 16384 (order: 4, 65536 bytes)
<4>TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
<6>TCP: Hash tables configured (established 16384 bind 8192)
<6>TCP reno registered
<6>squashfs: version 3.2 (2007/01/02) Phillip Lougher
<6>Installing knfsd (copyright (C) 1996 [email protected]).
<6>io scheduler noop registered (default)
<6>avm_net_trace: Up and running.
<4>[avm] configured: watchdog event debug led enable direct gpio
<4>
<4>AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jan 7 2008 13:24:22)
<6>Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
<6>serial8250: ttyS0 at MMIO 0x0 (irq = 15) is a UR8_UART
<3>[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
<6>tun: Universal TUN/TAP device driver, 1.6
<6>tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
<5>physmap platform flash device: 00800001 at 10000000
<6>physmap-flash.1: Found 1 x16 devices at 0x0 in 16-bit bank
<4> Amd/Fujitsu Extended Query Table at 0x0040
<4>physmap-flash.1: Swapping erase regions for broken CFI table.
<5>number of CFI chips: 1
<5>cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
<5>RedBoot partition parsing not available
<4>[ur8_jffs2_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x947984bc
<4>[ur8_jffs2_parser_function] try partition kernel (offset 0x10000 len 7798784)
<4>mtd1: size 7798784
<4>[ur8_jffs2_parser_function] magic found @pos 0x6a0000, size 917504
<4>[ur8_squashfs_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x947984bc
<4>[ur8_squashfs_parser_function] *p_mtd_pat->name filesystem
<4>[ur8_squashfs_parser_function] try partition kernel (offset 0x10000 len 7798784)
<4>[ur8_squashfs_parser_function] magic found @pos 0xef200
<5>Using physmap partition information
<5>Creating 6 MTD partitions on "physmap-flash.1":
<5>0x000ef200-0x00780000 : "rootfs"
<4>mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
<4>[ur8_mtd_add_notifier]
<4>[ur8_mtd_add_notifier] use rootfs
<4>[ur8_mtd_add_notifier] root device: /dev/mtdblock0 (rootfs)
<5>0x00010000-0x000ef200 : "kernel"
<4>mtd: partition "kernel" doesn't end on an erase block -- force read-only
<4>[ur8_mtd_add_notifier] skip kernel
<5>0x00000000-0x00010000 : "urlader"
<4>[ur8_mtd_add_notifier] skip urlader
<5>0x00780000-0x007c0000 : "tffs (1)"
<4>[ur8_mtd_add_notifier] skip tffs (1)
<5>0x007c0000-0x00800000 : "tffs (2)"
<4>[ur8_mtd_add_notifier] skip tffs (2)
<5>0x006a0000-0x00780000 : "jffs2"
<4>[ur8_mtd_add_notifier] skip jffs2
<4>Generic platform RAM MTD, (c) 2004 Simtec Electronics
<3>mtd-ram mtd-ram.2: no memory resource specified
<3>[ur8_ram_mtd_set_rw] PLATRAM_RO
<4>mtd-ram: probe of mtd-ram.2 failed with error -2
<5>CAPI Subsystem Rev 1.1.2.8
<6>TCP cubic registered
<6>mcfw: IGMPv3 fast forwarding
<6>NET: Registered protocol family 17
<6>NET: Registered protocol family 8
<6>NET: Registered protocol family 20
<4>MUSB UR8 pdev active!
<3>PCI_STATUS_SET: 40000
<3>PCI_STATUS_CLR: 40000
<3>PCI_HOST_INT_EN: 0
<3>PCI_HOST_INT_CLR: 0
<3>PCI_BE_INT_En: 0
<3>PCI_BE_INT_CLR: 0
<3>[pci_int_init] done
<4>TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
<4> mount on mtd3 and mtd4 (double buffering)
<6>Adam2 environment variables API installed.
<6>[avm_new] push_button_gpio=25 value=0 enabled
<4>VFS: Mounted root (squashfs filesystem) readonly.
<4>Freeing prom memory: 0kb freed
<6>Freeing unused kernel memory: 136k freed
<4>[avm_led_gpio_bit_driver_init] gpio 1 pos 0 name power
<4>[avm_led_gpio_bit_driver_init] gpio 9 pos 1 name internet
<4>[avm_led_gpio_bit_driver_init] gpio 27 pos 2 name festnetz
<4>[avm_led_gpio_bit_driver_init] gpio 28 pos 3 name wlan
<4>[avm_led_gpio_bit_driver_init] gpio 17 pos 4 name info
<4>[avm_led_gpio_bit_driver_init] gpio 35 pos 5 name rot1
<4>[avm_led_gpio_bit_driver_init] gpio 36 pos 6 name rot2
<4>[avm_led_gpio_bit_driver_init] gpio 32 pos 7 name rot3
<4>[avm_led_gpio_bit_driver_init] gpio 22 pos 8 name rot4
<4>[avm_led_gpio_bit_driver_init] gpio 21 pos 9 name rot5
<4>AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
<4>TFFS Name Table A
<6>[avm_new]push_button 'Wlan-Taster' presses: GPIO=25 time=4294937863
<6>[avm_new]push_button 'Wlan-Taster', released: GPIO=25 presses=260 key=button_key_1
<4>Piglet_noemif: module license '
<4>(C) Copyright 2007 by AVM
<4>' taintskernel.
<3>VFS: Close: file count is 0
<4>patch_dectfw: patch_adress: 51dc max_len: 19 with Version 2 Len: 16
<4>
<4>**********************************************
<4>dect_file_process: upload of '/lib/modules/dectfw_secondlevel.hex' successfull
<6>[avm_new]push_button_ctrl: gpio=23 value=1 enabled
<6>[avm_new]push_button_ctrl:'Werkseinstellungs-Taster': enable=2 gpio=23 regaddr=00000000 button_type=1
<3>[piglet]bitfile '/lib/modules/microvoip_isdn_top.bit'
<6>[avm_new]push_button 'Werkseinstellungs-Taster', released: GPIO=23 presses=0 key=button_key_4
<3>[piglet] Read 169291 bytes total from file
<4>[piglet]TDM: FS: 8000 Hz CLK:2047815 Hz
<6>JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
<4>
<4>[avm_debug]redirect kernel-messages (/dev/debug)
<1>CPU 0 Unable to handle kernel paging request at virtual address 03011f0c, epc == 94173234, ra == 94173e1c
<4>Oops[#1]:
<4>Cpu 0
<4>$ 0 : 00000000 00000000 00000000 00000000
<4>$ 4 : 942285cc 9422871c 942286b4 0000046b
<4>$ 8 : e5527584 584a1c00 008137d9 00081000
<4>$12 : 9469f808 ffffffff 00200200 00000000
<4>$16 : 00000000 00000000 0000003a 03011eac
<4>$20 : 0000003a 978a4078 00000001 00000000
<4>$24 : 00000000 c03a4628
<4>$28 : 94244000 94247d20 00000000 94173e1c
<4>Hi : 10fdc300
<4>Lo : 47cfb3f9
<4>epc : 94173234 skb_copy_bits+0x1a4/0x240 Tainted: P
<4>ra : 94173e1c __pskb_pull_tail+0x98/0x33c
<4>Status: 1000ce03 KERNEL EXL IE
<4>Cause : 10800008
<4>BadVA : 03011f0c
<4>PrId : 00019068
<4>Modules linked in: wlan_scan_ap wlan_acl wlan_wep wlan_tkip wlan_ccmp wlan_xauth ath_pci ath_rate_atheros(P) wlan ath_hal(P) ath_dfs(P) avm_ath_extensions(P) userman(P) kdsldmod(P) musb_hdrc usbcore dect_io(P) avm_dect(P) capi_codec(P) isdn_fbox_fon5(P) pcmlink(P) dsl_ur8(P) jffs2 Piglet_noemif(P)
<4>Process swapper (pid: 0, threadinfo=94244000, task=94248000)
<4>Stack : c00e0250 0000000b 00000000 c00f0000 947d4000 fffffa18 9666c6a0 978a4064
<4> 9666c6a0 00000000 00000001 978a4050 94173e1c 9666c6a0 96890400 96f9aa00
<4> 96ff9830 00000001 947d4000 9666c6a0 fffffff4 978a4064 9666c6a0 00006488
<4> 9417a7a8 a40a4948 94107600 96733380 978a4050 978a4064 94107600 96733380
<4> 978a4050 c03a2a68 95d3a840 9766cc00 00000047 94179e30 c30846a8 03011eac
<4> ...
<4>Call Trace:
<4>[<94173234>] skb_copy_bits+0x1a4/0x240
<4>[<94173e1c>] __pskb_pull_tail+0x98/0x33c
<4>[<9417a7a8>] dev_queue_xmit+0x78/0x264
<4>[<c03a2a68>] kdsld_fastforward+0x32c/0xffd308c4 [kdsldmod]
<4>[<c03acfd4>] TokenQueue_Hook+0xd0/0xffd260fc [kdsldmod]
<4>[<c03ac4f0>] kdsld_tasklet_function+0x56c/0xffd2707c [kdsldmod]
<4>[<9402d72c>] tasklet_action+0xa0/0xe0
<4>[<9402d240>] __do_softirq+0x60/0xcc
<4>[<9402d2f4>] do_softirq+0x48/0x68
<4>[<94007b5c>] do_IRQ+0x24/0x34
<4>[<94006320>] ret_from_irq+0x0/0xc
<4>[<94005eb0>] r4k_wait+0x4/0xc
<4>[<94007e24>] cpu_idle+0x6c/0x174
<4>[<942a5894>] start_kernel+0x27c/0x28c
<4>
<4>
<4>Code: 8c42a988 0040f809 00000000 <8e620060> 02542823 02602021 02821021 00528023 0040a021
<4>Call Trace:
<4>[<9400cae4>] dump_stack+0x8/0x34
<4>[<9402756c>] panic+0x34/0x1f0
<4>[<9400d298>] die+0xc8/0xd0
<4>[<94010c9c>] do_page_fault+0x24c/0x390
<4>[<9400632c>] ret_from_exception+0x0/0x14
<4>
<0>Kernel panic - not syncing: Fatal exception in interrupt
<4>
End Of Support Data
