Mar 18 19:10:27 fritz syslog.info syslogd started: BusyBox v1.15.3
Mar 18 19:10:27 fritz user.notice kernel: klogd started: BusyBox v1.15.3 (2010-03-11 23:13:18 CET)
Mar 18 19:10:27 fritz user.notice kernel: Linux version 2.6.19.2 (2884) (gcc version 3.4.6) #2 Mon Feb 15 16:49:45 CET 2010
Mar 18 19:10:27 fritz user.warn kernel: cpu-probe: Manufacturer MIPS
Mar 18 19:10:27 fritz user.warn kernel: mips-config1: JTAG pressent
Mar 18 19:10:27 fritz user.warn kernel: mips-config1: TLB size 16
Mar 18 19:10:27 fritz user.warn kernel: mips-config3: Vectored interrupts implmented
Mar 18 19:10:27 fritz user.warn kernel: CPU revision is: 00019068
Mar 18 19:10:27 fritz user.err kernel: [mips_clock] default 360000000 MHz
Mar 18 19:10:27 fritz user.warn kernel: [ur8_clk_set_emif] SDRAM Refresh 0x3a8 Timing 0x2214717 Bank 0x21 Async 0xc42c301
Mar 18 19:10:27 fritz user.err kernel: [ur8_pci_init]
Mar 18 19:10:27 fritz user.err kernel: [pci] default: 33 MHz
Mar 18 19:10:27 fritz user.err kernel: [setup_pci_master]
Mar 18 19:10:27 fritz user.err kernel: [setup_pci_slave]
Mar 18 19:10:27 fritz user.err kernel: Exposing 67108864 memory over PCI
Mar 18 19:10:27 fritz user.err kernel: Setup Complete, Enabling PCI Interface
Mar 18 19:10:27 fritz user.err kernel: PCI Interface Running
Mar 18 19:10:27 fritz user.err kernel: PCI controller initialized
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_nwss_dma level 2 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_sar_pdsp level 2 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_buffer_manager level 2 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_usb level 5 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_vlynq level 7 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_pci level 5 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_c55 level 3 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_tdm level 0 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.err kernel: [ur8_vbus_set_prio] instance vbus_mips level 3 escalator disabled (count 255, floor 7)
Mar 18 19:10:27 fritz user.warn kernel: Determined physical RAM map:
Mar 18 19:10:27 fritz user.warn kernel: memory: 03fc0000 @ 14000000 (usable)
Mar 18 19:10:27 fritz user.warn kernel: memory: 00040000 @ 17fc0000 (reserved)
Mar 18 19:10:27 fritz user.warn kernel: [init_bootmem]
Mar 18 19:10:27 fritz user.warn kernel: [free_bootmem]
Mar 18 19:10:27 fritz user.warn kernel: [reserve_bootmem]
Mar 18 19:10:27 fritz user.debug kernel: On node 0 totalpages: 98240
Mar 18 19:10:27 fritz user.err kernel: [mem_map-hack]: reduce size from 3145728 524288 Bytes
Mar 18 19:10:27 fritz user.err kernel: [mem_map-hack]: move map base from 0x94329000 to 0x940a9000
Mar 18 19:10:27 fritz user.debug kernel: DMA zone: 767 pages used for memmap
Mar 18 19:10:27 fritz user.debug kernel: DMA zone: 0 pages reserved
Mar 18 19:10:27 fritz user.debug kernel: DMA zone: 97473 pages, LIFO batch:31
Mar 18 19:10:27 fritz user.debug kernel: Normal zone: 0 pages used for memmap
Mar 18 19:10:27 fritz user.err kernel: [request_resource] Kernel code: start 0x14000000 < root->start 0x17fc0000
Mar 18 19:10:27 fritz user.err kernel: [request_resource] Kernel data: start 0x14208f90 < root->start 0x17fc0000
Mar 18 19:10:27 fritz user.warn kernel: Built 1 zonelists. Total pages: 97473
Mar 18 19:10:27 fritz user.notice kernel: Kernel command line: console=ttyS0,38400n8r
Mar 18 19:10:27 fritz user.warn kernel: Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Mar 18 19:10:27 fritz user.warn kernel: Primary data cache 16kB, 4-way, linesize 16 bytes.
Mar 18 19:10:27 fritz user.info kernel: Synthesized TLB refill handler (20 instructions).
Mar 18 19:10:27 fritz user.info kernel: Synthesized TLB load handler fastpath (32 instructions).
Mar 18 19:10:27 fritz user.info kernel: Synthesized TLB store handler fastpath (32 instructions).
Mar 18 19:10:27 fritz user.info kernel: Synthesized TLB modify handler fastpath (31 instructions).
Mar 18 19:10:27 fritz user.warn kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Mar 18 19:10:27 fritz user.warn kernel: CPU frequency 360.00 MHz
Mar 18 19:10:27 fritz user.warn kernel: Using 180.000 MHz high precision timer.
Mar 18 19:10:27 fritz user.warn kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Mar 18 19:10:27 fritz user.warn kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Mar 18 19:10:27 fritz user.warn kernel: [free_all_bootmem]
Mar 18 19:10:27 fritz user.info kernel: Memory: 61056k/65280k available (2083k kernel code, 4140k reserved, 640k data, 140k init, 0k highmem)
Mar 18 19:10:27 fritz user.debug kernel: Calibrating delay loop... 359.62 BogoMIPS (lpj=1798144)
Mar 18 19:10:27 fritz user.warn kernel: Mount-cache hash table entries: 512
Mar 18 19:10:27 fritz user.warn kernel: Checking for 'wait' instruction... available.
Mar 18 19:10:27 fritz user.info kernel: NET: Registered protocol family 16
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init]
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] flashsize = 0x01000000 Byte 16 MBytes
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] mtd[0] = 0x90000000,0x90000000
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] mtd[1] = 0x90020000,0x90F80000
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] mtd[2] = 0x90000000,0x90020000
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] mtd[3] = 0x90F80000,0x90FC0000
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] mtd[4] = 0x90FC0000,0x91000000
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_init] mtd[5] = 0x90000000,0x90000000
Mar 18 19:10:27 fritz user.err kernel: pcibios_read_config: accessing present PCI slot : 14, where 0, size 4
Mar 18 19:10:27 fritz user.err kernel: Master and Slave Enabled
Mar 18 19:10:27 fritz user.info kernel: pktsched: using high resolution timer
Mar 18 19:10:27 fritz user.info kernel: NET: Registered protocol family 2
Mar 18 19:10:27 fritz user.warn kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Mar 18 19:10:27 fritz user.warn kernel: TCP established hash table entries: 16384 (order: 4, 65536 bytes)
Mar 18 19:10:27 fritz user.warn kernel: TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
Mar 18 19:10:27 fritz user.info kernel: TCP: Hash tables configured (established 16384 bind 8192)
Mar 18 19:10:27 fritz user.info kernel: TCP reno registered
Mar 18 19:10:27 fritz user.info kernel: squashfs: version 3.2 (2007/01/02) Phillip Lougher
Mar 18 19:10:27 fritz user.info kernel: Installing knfsd (copyright (C) 1996 [email protected]).
Mar 18 19:10:27 fritz user.warn kernel: fuse init (API version 7.8)
Mar 18 19:10:27 fritz user.info kernel: io scheduler noop registered (default)
Mar 18 19:10:27 fritz user.info kernel: avm_net_trace: Up and running.
Mar 18 19:10:27 fritz user.warn kernel: [avm] configured: watchdog event debug enable direct gpio
Mar 18 19:10:27 fritz user.warn kernel: AVM_WATCHDOG: Watchdog Driver for AR7 Hardware (Version 1.0, build: Feb 15 2010 16:49:16)
Mar 18 19:10:27 fritz user.info kernel: Serial: 8250/16550 driver $Revision: 1.3 $ 1 ports, IRQ sharing disabled
Mar 18 19:10:27 fritz user.info kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 15) is a UR8_UART
Mar 18 19:10:27 fritz user.err kernel: [cpmac] Version: 1.124 - Revision 538:916 - Mo 15.02.2010 16:49:34
Mar 18 19:10:27 fritz user.err kernel: [dectsync] inactive
Mar 18 19:10:27 fritz user.err kernel: [cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
Mar 18 19:10:27 fritz user.info kernel: tun: Universal TUN/TAP device driver, 1.6
Mar 18 19:10:27 fritz user.info kernel: tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
Mar 18 19:10:27 fritz user.notice kernel: physmap platform flash device: 01000001 at 10000000
Mar 18 19:10:27 fritz user.info kernel: physmap-flash.1: Found 1 x16 devices at 0x0 in 16-bit bank
Mar 18 19:10:27 fritz user.warn kernel: Amd/Fujitsu Extended Query Table at 0x0040
Mar 18 19:10:27 fritz user.warn kernel: physmap-flash.1: CFI does not contain boot bank location. Assuming top.
Mar 18 19:10:27 fritz user.notice kernel: number of CFI chips: 1
Mar 18 19:10:27 fritz user.notice kernel: cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Mar 18 19:10:27 fritz user.notice kernel: RedBoot partition parsing not available
Mar 18 19:10:27 fritz user.warn kernel: [ur8_jffs2_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f6343c
Mar 18 19:10:27 fritz user.warn kernel: [ur8_jffs2_parser_function] try partition kernel (offset 0x20000 len 16121856)
Mar 18 19:10:27 fritz user.warn kernel: [ur8_jffs2_parser_function] magic 20031985 found @pos 0xe80000, size 1048576
Mar 18 19:10:27 fritz user.warn kernel: [ur8_squashfs_parser_function] mtd_info->name physmap-flash.1 mtd_info->index 0 param=0 p_mtd_pat=0x97f6343c
Mar 18 19:10:27 fritz user.warn kernel: [ur8_squashfs_parser_function] *p_mtd_pat->name filesystem
Mar 18 19:10:27 fritz user.warn kernel: [ur8_squashfs_parser_function] try partition kernel (offset 0x20000 len 16121856 blocksize=20000)
Mar 18 19:10:27 fritz user.warn kernel: [ur8_squashfs_parser_function] magic found @pos 0x103b00
Mar 18 19:10:27 fritz user.notice kernel: 6 find_squashfs partitions found on MTD device physmap-flash.1
Mar 18 19:10:27 fritz user.notice kernel: Creating 6 MTD partitions on "physmap-flash.1":
Mar 18 19:10:27 fritz user.notice kernel: 0x00103b00-0x00f80000 : "rootfs"
Mar 18 19:10:27 fritz user.warn kernel: mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] name rootfs
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] use rootfs
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] root device: /dev/mtdblock0 (rootfs)
Mar 18 19:10:27 fritz user.notice kernel: 0x00020000-0x00103b00 : "kernel"
Mar 18 19:10:27 fritz user.warn kernel: mtd: partition "kernel" doesn't end on an erase block -- force read-only
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] name kernel
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] skip kernel
Mar 18 19:10:27 fritz user.notice kernel: 0x00000000-0x00020000 : "urlader"
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] name urlader
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] skip urlader
Mar 18 19:10:27 fritz user.notice kernel: 0x00f80000-0x00fc0000 : "tffs (1)"
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] name tffs (1)
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] skip tffs (1)
Mar 18 19:10:27 fritz user.notice kernel: 0x00fc0000-0x01000000 : "tffs (2)"
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] name tffs (2)
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] skip tffs (2)
Mar 18 19:10:27 fritz user.notice kernel: 0x00e80000-0x00f80000 : "jffs2"
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] name jffs2
Mar 18 19:10:27 fritz user.warn kernel: [ur8_mtd_add_notifier] skip jffs2
Mar 18 19:10:27 fritz user.warn kernel: Generic platform RAM MTD, (c) 2004 Simtec Electronics
Mar 18 19:10:27 fritz user.err kernel: mtd-ram mtd-ram.2: no memory resource specified
Mar 18 19:10:27 fritz user.err kernel: [ur8_ram_mtd_set_rw] PLATRAM_RO
Mar 18 19:10:27 fritz user.warn kernel: mtd-ram: probe of mtd-ram.2 failed with error -2
Mar 18 19:10:27 fritz user.notice kernel: CAPI Subsystem Rev 1.1.2.8
Mar 18 19:10:27 fritz user.info kernel: TCP cubic registered
Mar 18 19:10:27 fritz user.info kernel: mcfw: IGMPv3 fast forwarding
Mar 18 19:10:27 fritz user.info kernel: NET: Registered protocol family 17
Mar 18 19:10:27 fritz user.info kernel: NET: Registered protocol family 8
Mar 18 19:10:27 fritz user.info kernel: NET: Registered protocol family 20
Mar 18 19:10:27 fritz user.warn kernel: MUSB UR8 pdev active!
Mar 18 19:10:27 fritz user.err kernel: PCI_STATUS_SET: 40000
Mar 18 19:10:27 fritz user.err kernel: PCI_STATUS_CLR: 40000
Mar 18 19:10:27 fritz user.err kernel: PCI_HOST_INT_EN: 0
Mar 18 19:10:27 fritz user.err kernel: PCI_HOST_INT_CLR: 0
Mar 18 19:10:27 fritz user.err kernel: PCI_BE_INT_En: 0
Mar 18 19:10:27 fritz user.err kernel: PCI_BE_INT_CLR: 0
Mar 18 19:10:27 fritz user.err kernel: [pci_int_init] done
Mar 18 19:10:27 fritz user.warn kernel: TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
Mar 18 19:10:27 fritz user.info kernel: Time: MIPS clocksource has been installed.
Mar 18 19:10:27 fritz user.warn kernel: mount on mtd3 and mtd4 (double buffering)
Mar 18 19:10:27 fritz user.info kernel: Adam2 environment variables API installed.
Mar 18 19:10:27 fritz user.info kernel: [avm_new] push_button_gpio=25 value=0 enabled
Mar 18 19:10:27 fritz user.warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Mar 18 19:10:27 fritz user.warn kernel: Freeing prom memory: 0kb freed
Mar 18 19:10:27 fritz user.info kernel: Freeing unused kernel memory: 140k freed
Mar 18 19:10:27 fritz user.err kernel: [4294937503]maxrun: 1
Mar 18 19:10:27 fritz user.warn kernel: AVM_WATCHDOG: System Init UEberwachung 240 Sekunden
Mar 18 19:10:27 fritz user.warn kernel: TFFS Name Table 1
Mar 18 19:10:27 fritz user.warn kernel: led_modul_Fritz_Box_7270_16: module license '
Mar 18 19:10:27 fritz user.warn kernel: (C) Copyright 2008 by AVM
Mar 18 19:10:27 fritz user.warn kernel: ' taintskernel.
Mar 18 19:10:27 fritz user.warn kernel: [led_gpio_bit_driver_init] gpio 1 name power
Mar 18 19:10:27 fritz user.warn kernel: [led_gpio_bit_driver_init] gpio 9 name internet
Mar 18 19:10:27 fritz user.warn kernel: [led_gpio_bit_driver_init] gpio 27 name festnetz
Mar 18 19:10:27 fritz user.warn kernel: [led_gpio_bit_driver_init] gpio 28 name wlan
Mar 18 19:10:27 fritz user.warn kernel: [led_gpio_bit_driver_init] gpio 17 name dual1
Mar 18 19:10:27 fritz user.warn kernel: [led_gpio_bit_driver_init] gpio 35 name dual2
Mar 18 19:10:27 fritz user.err kernel: [BUTTON] no buttons defined - disable new button controls
Mar 18 19:10:27 fritz user.err kernel: [LED] "wyatt_earp_turn_off_leds" (0x00000000) not loaded
Mar 18 19:10:27 fritz user.info kernel: [avm_new]push_button_ctrl: gpio=23 value=1 enabled
Mar 18 19:10:27 fritz user.info kernel: [avm_new]push_button_ctrl:'Taster_4': enable=2 gpio=23 regaddr=00000000 button_type=0
Mar 18 19:10:27 fritz user.info kernel: [avm_new]push_button 'Taster_4', released: GPIO=23 presses=0 key=button_key_10
Mar 18 19:10:27 fritz user.warn kernel: patch_dectfw: patch_adress: 7536 max_len: 22 with Version 2 Len: 16
Mar 18 19:10:27 fritz user.warn kernel: patch_dectfw: c0068000, datalen = 32717,
Mar 18 19:10:27 fritz user.warn kernel: ***************************************************************
Mar 18 19:10:27 fritz user.err kernel: [4294938602]maxrun: 1
Mar 18 19:10:27 fritz user.warn kernel: dect_file_process: upload of '/lib/modules/dectfw_secondlevel.hex' successfull
Mar 18 19:10:27 fritz user.err kernel: [piglet]bitfile '/lib/modules/microvoip_isdn_top.bit'
Mar 18 19:10:27 fritz user.err kernel: [piglet] Read 169291 bytes total from file
Mar 18 19:10:27 fritz user.warn kernel: [piglet]TDM: FS: 8000 Hz CLK:2047975 Hz
Mar 18 19:10:27 fritz user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2006 Red Hat, Inc.
Mar 18 19:10:27 fritz user.warn kernel: Empty flash at 0x000c0228 ends at 0x000d0000
Mar 18 19:10:27 fritz user.notice kernel: CLEANMARKER node found at 0x000d0000, not first node in block (0x000c0000)
Mar 18 19:10:27 fritz user.info kernel: loop: loaded (max 8 devices)
Mar 18 19:10:27 fritz user.warn kernel: [avm_debug]redirect kernel-messages (/dev/debug)
Mar 18 19:10:27 fritz user.warn kernel: [pcmlink]c55_isr: d=00003d00 r=00003cbe s=00003cd6 m=00002090
Mar 18 19:10:30 fritz user.info configd[1832]: rpcGetConfig-OK
Mar 18 19:10:31 fritz daemon.info hostapd: ath0: STA 00:23:df:42:a5:5e IEEE 802.11: associated
Mar 18 19:10:31 fritz daemon.info hostapd: ath0: STA 00:23:df:42:a5:5e WPA: pairwise key handshake completed (RSN)
Mar 18 19:10:54 fritz mark.debug syslog: davfs2 1.3.3
Mar 18 19:10:54 fritz mark.err syslog: opening /home/hjortmann/LaborNAS/MASSENSPEICHER_TOOLS_ur8_build/webdav/../filesystem/etc/davfs2/davfs2.conf failed
Mar 18 19:10:54 fritz mark.err syslog: opening /home/hjortmann/LaborNAS/MASSENSPEICHER_TOOLS_ur8_build/webdav/../filesystem/etc/davfs2/secrets failed
Mar 18 19:11:06 fritz daemon.info transmission-daemon: Transmission 1.92 (10363) started (session.c:618)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:772)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: RPC Server Adding address to whitelist: 192.168.178.* (rpc-server.c:772)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: RPC Server Serving RPC and Web requests on port 9091 (rpc-server.c:945)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: RPC Server Whitelist enabled (rpc-server.c:949)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: Port Forwarding Stopped (port-forwarding.c:176)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: DHT Generating new id (tr-dht.c:369)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: Using settings from "/var/media/ftp/uStor01/no_backup/files/downloads/torrents/config" (daemon.c:430)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: Saved "/var/media/ftp/uStor01/no_backup/files/downloads/torrents/config/settings.json" (bencode.c:1645)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: Watching "/var/media/ftp/uStor01/no_backup/files/downloads/torrents/." for new .torrent files (daemon.c:446)
Mar 18 19:11:06 fritz daemon.info transmission-daemon: Using inotify to watch directory "/var/media/ftp/uStor01/no_backup/files/downloads/torrents/." (watch.c:77)
Mar 18 19:11:19 fritz daemon.info chronyd[1931]: Trimming RTC, error = -1268939362.050 seconds
Mar 18 19:11:37 fritz user.warn kernel: unable to read inode block - inode=6193153, block=12386306
Mar 18 19:11:38 fritz user.info kernel: Detected aborted journal
Mar 18 19:11:38 fritz user.info kernel: reading directory #3039239 offset 0
Mar 18 19:11:44 fritz daemon.info transmission-daemon: DHT Attempting bootstrap from dht.transmissionbt.com (tr-dht.c:234)
Mar 18 19:12:12 fritz mark.err syslog: PROPFIND failed: errno (11) - neon (6) - http (Could not read status line: connection timed out (aborted))
Mar 18 19:12:42 fritz mark.err syslog: PROPFIND failed: errno (11) - neon (6) - http (Could not read status line: connection timed out (aborted))
Mar 18 19:13:04 fritz user.info kernel: reading directory #3039237 offset 0
Mar 18 19:13:04 fritz user.info kernel: reading directory #105578497 offset 0
Mar 18 19:13:05 fritz user.warn kernel: printk: 4 messages suppressed.
Mar 18 19:13:05 fritz user.warn kernel: Cannot read inode bitmap - block_group = 6444, inode_bitmap = 211156993
Mar 18 19:13:05 fritz user.info kernel: Cannot read inode bitmap - block_group = 6444, inode_bitmap = 211156993
Mar 18 19:13:12 fritz mark.err syslog: PROPFIND failed: errno (11) - neon (6) - http (Could not read status line: connection timed out (aborted))
Mar 18 19:13:12 fritz mark.debug syslog: davfs2 1.3.3
Mar 18 19:13:12 fritz mark.err syslog: opening /home/hjortmann/LaborNAS/MASSENSPEICHER_TOOLS_ur8_build/webdav/../filesystem/etc/davfs2/davfs2.conf failed
Mar 18 19:13:12 fritz mark.err syslog: opening /var/tmp/davfs2.conf failed
Mar 18 19:14:14 fritz daemon.notice mountd[2366]: authenticated mount request from 192.168.178.20:910 for /var/media/ftp/WD (/var/media/ftp/WD)
Mar 18 19:19:26 fritz daemon.info hostapd: ath0: STA 00:23:df:42:a5:5e IEEE 802.11: disassociated
Mar 18 19:20:10 fritz daemon.info hostapd: ath0: STA 00:0e:35:fa:60:62 IEEE 802.11: disassociated
Mar 18 19:21:10 fritz user.info kernel: reading directory #2 offset 0
Mar 18 19:27:26 fritz daemon.info hostapd: ath0: STA 00:0e:35:fa:60:62 IEEE 802.11: associated
Mar 18 19:27:26 fritz daemon.info hostapd: ath0: STA 00:0e:35:fa:60:62 WPA: pairwise key handshake completed (RSN)
