; About php.ini ;
; PHP's initialization file, generally called php.ini, is responsible for
; configuring many of the aspects of PHP's behavior.
; PHP attempts to find and load this configuration from a number of locations.
; The following is a summary of its search order:
; 1. SAPI module specific location.
; 2. The PHPRC environment variable. (As of PHP 5.2.0)
; 3. A number of predefined registry keys on Windows (As of PHP 5.2.0)
; 4. Current working directory (except CLI)
; 5. The web server's directory (for SAPI modules), or directory of PHP
; (otherwise in Windows)
; 6. The directory from the --with-config-file-path compile time option, or the
; Windows directory (C:\windows or C:\winnt)
; See the PHP docs for more specific information.
; [url]http://php.net/configuration.file[/url]
; The syntax of the file is extremely simple. Whitespace and Lines
; beginning with a semicolon are silently ignored (as you probably guessed).
; Section headers (e.g. [Foo]) are also silently ignored, even though
; they might mean something in the future.
; Directives following the section heading [PATH=/www/mysite] only
; apply to PHP files in the /www/mysite directory. Directives
; following the section heading [HOST=www.example.com] only apply to
; PHP files served from [url]www.example.com[/url]. Directives set in these
; special sections cannot be overridden by user-defined INI files or
; at runtime. Currently, [PATH=] and [HOST=] sections only work under
; CGI/FastCGI.
; [url]http://php.net/ini.sections[/url]
; Directives are specified using the following syntax:
; directive = value
; Directive names are *case sensitive* - foo=bar is different from FOO=bar.
; Directives are variables used to configure PHP or PHP extensions.
; There is no name validation. If PHP can't find an expected
; directive because it is not set or is mistyped, a default value will be used.
; The value can be a string, a number, a PHP constant (e.g. E_ALL or M_PI), one
; of the INI constants (On, Off, True, False, Yes, No and None) or an expression
; (e.g. E_ALL & ~E_NOTICE), a quoted string ("bar"), or a reference to a
; previously set variable or directive (e.g. ${foo})
; Expressions in the INI file are limited to bitwise operators and parentheses:
; | bitwise OR
; ^ bitwise XOR
; & bitwise AND
; ~ bitwise NOT
; ! boolean NOT
; Boolean flags can be turned on using the values 1, On, True or Yes.
; They can be turned off using the values 0, Off, False or No.
; An empty string can be denoted by simply not writing anything after the equal
; sign, or by using the None keyword:
; foo = ; sets foo to an empty string
; foo = None ; sets foo to an empty string
; foo = "None" ; sets foo to the string 'None'
; If you use constants in your value, and these constants belong to a
; dynamically loaded extension (either a PHP extension or a Zend extension),
; you may only use these constants *after* the line that loads the extension.
; About this file ;
; PHP comes packaged with two INI files. One that is recommended to be used
; in production environments and one that is recommended to be used in
; development environments.
; php.ini-production contains settings which hold security, performance and
; best practices at its core. But please be aware, these settings may break
; compatibility with older or less security conscience applications. We
; recommending using the production ini in production and testing environments.
; php.ini-development is very similar to its production variant, except it's
; much more verbose when it comes to errors. We recommending using the
; development version only in development environments as errors shown to
; application users can inadvertently leak otherwise secure information.
; Quick Reference ;
; The following are all the settings which are different in either the production
; or development versions of the INIs with respect to PHP's default behavior.
; Please see the actual settings later in the document for more details as to why
; we recommend these changes in PHP's behavior.
; allow_call_time_pass_reference
; Default Value: On
; Development Value: Off
; Production Value: Off
; display_errors
; Default Value: On
; Development Value: On
; display_startup_errors
; Default Value: Off
; error_reporting
; Default Value: E_ALL & ~E_NOTICE & ~E_STRICT & ~E_DEPRECATED
; Development Value: E_ALL
; Production Value: E_ALL & ~E_DEPRECATED & ~E_STRICT
; html_errors
; Default Value: On
; Production value: Off
; log_errors
; Production Value: On
; magic_quotes_gpc
; Default Value: On
; max_input_time
; Default Value: -1 (Unlimited)
; Development Value: 60 (60 seconds)
; Production Value: 60 (60 seconds)
; output_buffering
; Development Value: 4096
; Production Value: 4096
; register_argc_argv
; Default Value: On
; register_long_arrays
; Default Value: On
; request_order
; Default Value: None
; Development Value: "GP"
; Production Value: "GP"
; session.bug_compat_42
; Default Value: On
; session.bug_compat_warn
; Default Value: On
; session.gc_divisor
; Default Value: 100
; Development Value: 1000
; Production Value: 1000
; session.hash_bits_per_character
; Default Value: 4
; Development Value: 5
; Production Value: 5
; short_open_tag
; Default Value: On
; track_errors
; url_rewriter.tags
; Default Value: "a=href,area=href,frame=src,form=,fieldset="
; Development Value: "a=href,area=href,frame=src,input=src,form=fakeentry"
; Production Value: "a=href,area=href,frame=src,input=src,form=fakeentry"
; variables_order
; Default Value: "EGPCS"
; Development Value: "GPCS"
; Production Value: "GPCS"
; php.ini Options ;
; Name for user-defined php.ini (.htaccess) files. Default is ".user.ini"
;user_ini.filename = ".user.ini"
; To disable this feature set this option to empty value
; TTL for user-defined php.ini files (time-to-live) in seconds. Default is 300 seconds (5 minutes)
;user_ini.cache_ttl = 300
; Language Options ;
; Enable the PHP scripting language engine under Apache.
; [url]http://php.net/engine[/url]
engine=On
; This directive determines whether or not PHP will recognize code between
; <? and ?> tags as PHP source which should be processed as such. It's been
; recommended for several years that you not use the short tag "short cut" and
; instead to use the full <?php and ?> tag combination. With the wide spread use
; of XML and use of these tags by other languages, the server can become easily
; confused and end up parsing the wrong code in the wrong context. But because
; this short cut has been a feature for such a long time, it's currently still
; supported for backwards compatibility, but we recommend you don't use them.
; Default Value: On
; [url]http://php.net/short-open-tag[/url]
short_open_tag=Off
; XAMPP for Linux is currently old fashioned
;short_open_tag = On
; Allow ASP-style <% %> tags.
; [url]http://php.net/asp-tags[/url]
asp_tags=Off
; The number of significant digits displayed in floating point numbers.
; [url]http://php.net/precision[/url]
precision=14
; Enforce year 2000 compliance (will cause problems with non-compliant browsers)
; [url]http://php.net/y2k-compliance[/url]
y2k_compliance=On
; Output buffering is a mechanism for controlling how much output data
; (excluding headers and cookies) PHP should keep internally before pushing that
; data to the client. If your application's output exceeds this setting, PHP
; will send that data in chunks of roughly the size you specify.
; Turning on this setting and managing its maximum buffer size can yield some
; interesting side-effects depending on your application and web server.
; You may be able to send headers and cookies after you've already sent output
; through print or echo. You also may see performance benefits if your server is
; emitting less packets due to buffered output versus PHP streaming the output
; as it gets it. On production servers, 4096 bytes is a good setting for performance
; reasons.
; Note: Output buffering can also be controlled via Output Buffering Control
; functions.
; Possible Values:
; On = Enabled and buffer is unlimited. (Use with caution)
; Off = Disabled
; Integer = Enables the buffer and sets its maximum size in bytes.
; Note: This directive is hardcoded to Off for the CLI SAPI
; [url]http://php.net/output-buffering[/url]
output_buffering=4096
; You can redirect all of the output of your scripts to a function. For
; example, if you set output_handler to "mb_output_handler", character
; encoding will be transparently converted to the specified encoding.
; Setting any output handler automatically turns on output buffering.
; Note: People who wrote portable scripts should not depend on this ini
; directive. Instead, explicitly set the output handler using ob_start().
; Using this ini directive may cause problems unless you know what script
; is doing.
; Note: You cannot use both "mb_output_handler" with "ob_iconv_handler"
; and you cannot use both "ob_gzhandler" and "zlib.output_compression".
; Note: output_handler must be empty if this is set 'On' !!!!
; Instead you must use zlib.output_handler.
; [url]http://php.net/output-handler[/url]
;output_handler =
; Transparent output compression using the zlib library
; Valid values for this option are 'off', 'on', or a specific buffer size
; to be used for compression (default is 4KB)
; Note: Resulting chunk size may vary due to nature of compression. PHP
; outputs chunks that are few hundreds bytes each as a result of
; compression. If you prefer a larger chunk size for better
; performance, enable output_buffering in addition.
; Note: You need to use zlib.output_handler instead of the standard
; output_handler, or otherwise the output will be corrupted.
; [url]http://php.net/zlib.output-compression[/url]
zlib.output_compression=Off
; [url]http://php.net/zlib.output-compression-level[/url]
;zlib.output_compression_level = -1
; You cannot specify additional output handlers if zlib.output_compression
; is activated here. This setting does the same as output_handler but in
; a different order.
; [url]http://php.net/zlib.output-handler[/url]
;zlib.output_handler =
; Implicit flush tells PHP to tell the output layer to flush itself
; automatically after every output block. This is equivalent to calling the
; PHP function flush() after each and every call to print() or echo() and each
; and every HTML block. Turning this option on has serious performance
; implications and is generally recommended for debugging purposes only.
; [url]http://php.net/implicit-flush[/url]
; Note: This directive is hardcoded to On for the CLI SAPI
implicit_flush=Off
; The unserialize callback function will be called (with the undefined class'
; name as parameter), if the unserializer finds an undefined class
; which should be instantiated. A warning appears if the specified function is
; not defined, or if the function doesn't include/implement the missing class.
; So only set this entry, if you really want to implement such a
; callback-function.
unserialize_callback_func=
; When floats & doubles are serialized store serialize_precision significant
; digits after the floating point. The default value ensures that when floats
; are decoded with unserialize, the data will remain the same.
serialize_precision=100
; This directive allows you to enable and disable warnings which PHP will issue
; if you pass a value by reference at function call time. Passing values by
; reference at function call time is a deprecated feature which will be removed
; from PHP at some point in the near future. The acceptable method for passing a
; value by reference to a function is by declaring the reference in the functions
; definition, not at call time. This directive does not disable this feature, it
; only determines whether PHP will warn you about it or not. These warnings
; should enabled in development environments only.
; Default Value: On (Suppress warnings)
; Development Value: Off (Issue warnings)
; Production Value: Off (Issue warnings)
; [url]http://php.net/allow-call-time-pass-reference[/url]
allow_call_time_pass_reference=Off
; Safe Mode
; [url]http://php.net/safe-mode[/url]
safe_mode=Off
; By default, Safe Mode does a UID compare check when
; opening files. If you want to relax this to a GID compare,
; then turn on safe_mode_gid.
; [url]http://php.net/safe-mode-gid[/url]
safe_mode_gid=Off
; When safe_mode is on, UID/GID checks are bypassed when
; including files from this directory and its subdirectories.
; (directory must also be in include_path or full path must
; be used when including)
; [url]http://php.net/safe-mode-include-dir[/url]
safe_mode_include_dir=
; When safe_mode is on, only executables located in the safe_mode_exec_dir
; will be allowed to be executed via the exec family of functions.
; [url]http://php.net/safe-mode-exec-dir[/url]
safe_mode_exec_dir=
; Setting certain environment variables may be a potential security breach.
; This directive contains a comma-delimited list of prefixes. In Safe Mode,
; the user may only alter environment variables whose names begin with the
; prefixes supplied here. By default, users will only be able to set
; environment variables that begin with PHP_ (e.g. PHP_FOO=BAR).
; Note: If this directive is empty, PHP will let the user modify ANY
; environment variable!
; [url]http://php.net/safe-mode-allowed-env-vars[/url]
safe_mode_allowed_env_vars=PHP_
; This directive contains a comma-delimited list of environment variables that
; the end user won't be able to change using putenv(). These variables will be
; protected even if safe_mode_allowed_env_vars is set to allow to change them.
; [url]http://php.net/safe-mode-protected-env-vars[/url]
safe_mode_protected_env_vars=LD_LIBRARY_PATH
; open_basedir, if set, limits all file operations to the defined directory
; and below. This directive makes most sense if used in a per-directory
; or per-virtualhost web server configuration file. This directive is
; *NOT* affected by whether Safe Mode is turned On or Off.
; [url]http://php.net/open-basedir[/url]
;open_basedir =
; This directive allows you to disable certain functions for security reasons.
; It receives a comma-delimited list of function names. This directive is
; [url]http://php.net/disable-functions[/url]
disable_functions=
; This directive allows you to disable certain classes for security reasons.
; It receives a comma-delimited list of class names. This directive is
; [url]http://php.net/disable-classes[/url]
disable_classes=
; Colors for Syntax Highlighting mode. Anything that's acceptable in
; <span style="color: ???????"> would work.
; [url]http://php.net/syntax-highlighting[/url]
;highlight.string = #DD0000
;highlight.comment = #FF9900
;highlight.keyword = #007700
;highlight.bg = #FFFFFF
;highlight.default = #0000BB
;highlight.html = #000000
; If enabled, the request will be allowed to complete even if the user aborts
; the request. Consider enabling it if executing long requests, which may end up
; being interrupted by the user or a browser timing out. PHP's default behavior
; is to disable this feature.
; [url]http://php.net/ignore-user-abort[/url]
;ignore_user_abort = On
; Determines the size of the realpath cache to be used by PHP. This value should
; be increased on systems where PHP opens many files to reflect the quantity of
; the file operations performed.
; [url]http://php.net/realpath-cache-size[/url]
;realpath_cache_size = 16k
; Duration of time, in seconds for which to cache realpath information for a given
; file or directory. For systems with rarely changing files, consider increasing this
; value.
; [url]http://php.net/realpath-cache-ttl[/url]
;realpath_cache_ttl = 120
; Enables or disables the circular reference collector.
; [url]http://php.net/zend.enable-gc[/url]
zend.enable_gc=On
; If enabled, scripts may be written in encodings that are incompatible with
; the scanner. CP936, Big5, CP949 and Shift_JIS are the examples of such
; encodings. To use this feature, mbstring extension must be enabled.
; Default: Off
;zend.multibyte = Off
; Allows to set the default encoding for the scripts. This value will be used
; unless "declare(encoding=...)" directive appears at the top of the script.
; Only affects if zend.multibyte is set.
; Default: ""
;zend.script_encoding =
; Miscellaneous ;
; Decides whether PHP may expose the fact that it is installed on the server
; (e.g. by adding its signature to the Web server header). It is no security
; threat in any way, but it makes it possible to determine whether you use PHP
; on your server or not.
; [url]http://php.net/expose-php[/url]
expose_php=On
; Resource Limits ;
; Maximum execution time of each script, in seconds
; [url]http://php.net/max-execution-time[/url]
; Note: This directive is hardcoded to 0 for the CLI SAPI
max_execution_time=30
; Maximum amount of time each script may spend parsing request data. It's a good
; idea to limit this time on productions servers in order to eliminate unexpectedly
; long running scripts.
; Note: This directive is hardcoded to -1 for the CLI SAPI
; [url]http://php.net/max-input-time[/url]
max_input_time=60
; Maximum input variable nesting level
; [url]http://php.net/max-input-nesting-level[/url]
;max_input_nesting_level = 64
; How many GET/POST/COOKIE input variables may be accepted
; max_input_vars = 1000
; Maximum amount of memory a script may consume (128MB)
; [url]http://php.net/memory-limit[/url]
memory_limit=128M
; Error handling and logging ;
; This directive informs PHP of which errors, warnings and notices you would like
; it to take action for. The recommended way of setting values for this
; directive is through the use of the error level constants and bitwise
; operators. The error level constants are below here for convenience as well as
; some common settings and their meanings.
; By default, PHP is set to take action on all errors, notices and warnings EXCEPT
; those related to E_NOTICE and E_STRICT, which together cover best practices and
; recommended coding standards in PHP. For performance reasons, this is the
; recommend error reporting setting. Your production server shouldn't be wasting
; resources complaining about best practices and coding standards. That's what
; development servers and development settings are for.
; Note: The php.ini-development file has this setting as E_ALL | E_STRICT. This
; means it pretty much reports everything which is exactly what you want during
; development and early testing.
; Error Level Constants:
; E_ALL - All errors and warnings (includes E_STRICT as of PHP 6.0.0)
; E_ERROR - fatal run-time errors
; E_RECOVERABLE_ERROR - almost fatal run-time errors
; E_WARNING - run-time warnings (non-fatal errors)
; E_PARSE - compile-time parse errors
; E_NOTICE - run-time notices (these are warnings which often result
; from a bug in your code, but it's possible that it was
; intentional (e.g., using an uninitialized variable and
; relying on the fact it's automatically initialized to an
; empty string)
; E_STRICT - run-time notices, enable to have PHP suggest changes
; to your code which will ensure the best interoperability
; and forward compatibility of your code
; E_CORE_ERROR - fatal errors that occur during PHP's initial startup
; E_CORE_WARNING - warnings (non-fatal errors) that occur during PHP's
; initial startup
; E_COMPILE_ERROR - fatal compile-time errors
; E_COMPILE_WARNING - compile-time warnings (non-fatal errors)
; E_USER_ERROR - user-generated error message
; E_USER_WARNING - user-generated warning message
; E_USER_NOTICE - user-generated notice message
; E_DEPRECATED - warn about code that will not work in future versions
; of PHP
; E_USER_DEPRECATED - user-generated deprecation warnings
; Common Values:
; E_ALL (Show all errors, warnings and notices including coding standards.)
; E_ALL & ~E_NOTICE (Show all errors, except for notices)
; E_ALL & ~E_NOTICE & ~E_STRICT (Show all errors, except for notices and coding standards warnings.)
; E_COMPILE_ERROR|E_RECOVERABLE_ERROR|E_ERROR|E_CORE_ERROR (Show only errors)
; [url]http://php.net/error-reporting[/url]
error_reporting=E_ALL & ~E_DEPRECATED & ~E_STRICT
; This directive controls whether or not and where PHP will output errors,
; notices and warnings too. Error output is very useful during development, but
; it could be very dangerous in production environments. Depending on the code
; which is triggering the error, sensitive information could potentially leak
; out of your application such as database usernames and passwords or worse.
; It's recommended that errors be logged on production servers rather than
; having the errors sent to STDOUT.
; Possible Values:
; Off = Do not display any errors
; stderr = Display errors to STDERR (affects only CGI/CLI binaries!)
; On or stdout = Display errors to STDOUT
; Default Value: On
; [url]http://php.net/display-errors[/url]
display_errors=On
; The display of errors which occur during PHP's startup sequence are handled
; separately from display_errors. PHP's default behavior is to suppress those
; errors from clients. Turning the display of startup errors on can be useful in
; debugging configuration problems. But, it's strongly recommended that you
; leave this setting off on production servers.
; [url]http://php.net/display-startup-errors[/url]
; XAMPP: Turn display_startup_errors = Off here for a full Joomla support
display_startup_errors=On
; Besides displaying errors, PHP can also log errors to locations such as a
; server-specific log, STDERR, or a location specified by the error_log
; directive found below. While errors should not be displayed on productions
; servers they should still be monitored and logging is a great way to do that.
; [url]http://php.net/log-errors[/url]
log_errors=On
; Set maximum length of log_errors. In error_log information about the source is
; added. The default is 1024 and 0 allows to not apply any maximum length at all.
; [url]http://php.net/log-errors-max-len[/url]
log_errors_max_len=1024
; Do not log repeated messages. Repeated errors must occur in same file on same
; line unless ignore_repeated_source is set true.
; [url]http://php.net/ignore-repeated-errors[/url]
ignore_repeated_errors=Off
; Ignore source of message when ignoring repeated messages. When this setting
; is On you will not log errors with repeated messages from different files or
; source lines.
; [url]http://php.net/ignore-repeated-source[/url]
ignore_repeated_source=Off
; If this parameter is set to Off, then memory leaks will not be shown (on
; stdout or in the log). This has only effect in a debug compile, and if
; error reporting includes E_WARNING in the allowed list
; [url]http://php.net/report-memleaks[/url]
report_memleaks=On
; This setting is on by default.
;report_zend_debug = 0
; Store the last error/warning message in $php_errormsg (boolean). Setting this value
; to On can assist in debugging and is appropriate for development servers. It should
; however be disabled on production servers.
; [url]http://php.net/track-errors[/url]
track_errors=On
; Turn off normal error reporting and emit XML-RPC error XML
; [url]http://php.net/xmlrpc-errors[/url]
;xmlrpc_errors = 0
; An XML-RPC faultCode
;xmlrpc_error_number = 0
; When PHP displays or logs an error, it has the capability of inserting html
; links to documentation related to that error. This directive controls whether
; those HTML links appear in error messages or not. For performance and security
; reasons, it's recommended you disable this on production servers.
; Default Value: On
; Production value: On
; [url]http://php.net/html-errors[/url]
html_errors=On
; If html_errors is set On PHP produces clickable error messages that direct
; to a page describing the error or function causing the error in detail.
; You can download a copy of the PHP manual from [url]http://php.net/docs[/url]
; and change docref_root to the base URL of your local copy including the
; leading '/'. You must also specify the file extension being used including
; the dot. PHP's default behavior is to leave these settings empty.
; Note: Never use this feature for production boxes.
; [url]http://php.net/docref-root[/url]
; Examples
;docref_root = "/phpmanual/"
; [url]http://php.net/docref-ext[/url]
;docref_ext = .html
; String to output before an error message. PHP's default behavior is to leave
; this setting blank.
; [url]http://php.net/error-prepend-string[/url]
; Example:
;error_prepend_string = "<span style='color: #ff0000'>"
; String to output after an error message. PHP's default behavior is to leave
; [url]http://php.net/error-append-string[/url]
; Example:
;error_append_string = "</span>"
; Log errors to specified file. PHP's default behavior is to leave this value
; empty.
; [url]http://php.net/error-log[/url]
; Example:
;error_log = php_errors.log
error_log="C:\xampp\php\logs\php_error_log"
; Log errors to syslog (Event Log on NT, not valid in Windows 95).
;error_log = syslog
;windows.show_crt_warning
; Default value: 0
; Development value: 0
; Production value: 0
; Data Handling ;
; Note - track_vars is ALWAYS enabled
; The separator used in PHP generated URLs to separate arguments.
; PHP's default setting is "&".
; [url]http://php.net/arg-separator.output[/url]
; Example:
;arg_separator.output = "&"
; List of separator(s) used by PHP to parse input URLs into variables.
; NOTE: Every character in this directive is considered as separator!
; [url]http://php.net/arg-separator.input[/url]
; Example:
;arg_separator.input = ";&"
; This directive determines which super global arrays are registered when PHP
; starts up. G,P,C,E & S are abbreviations for the following respective super
; globals: GET, POST, COOKIE, ENV and SERVER. There is a performance penalty
; paid for the registration of these arrays and because ENV is not as commonly
; used as the others, ENV is not recommended on productions servers. You
; can still get access to the environment variables through getenv() should you
; need to.
; Production Value: "GPCS";
; [url]http://php.net/variables-order[/url]
variables_order="GPCS"
; This directive determines which super global data (G,P,C,E & S) should
; be registered into the super global array REQUEST. If so, it also determines
; the order in which that data is registered. The values for this directive are
; specified in the same manner as the variables_order directive, EXCEPT one.
; Leaving this value empty will cause PHP to use the value set in the
; variables_order directive. It does not mean it will leave the super globals
; array REQUEST empty.
; [url]http://php.net/request-order[/url]
request_order="GP"
; Whether or not to register the EGPCS variables as global variables. You may
; want to turn this off if you don't want to clutter your scripts' global scope
; with user data. This makes most sense when coupled with track_vars - in which
; case you can access all of the GPC variables through the $HTTP_*_VARS[],
; variables.
; You should do your best to write your scripts so that they do not require
; register_globals to be on; Using form variables as globals can easily lead
; to possible security problems, if the code is not very well thought of.
; [url]http://php.net/register-globals[/url]
register_globals=Off
; Determines whether the deprecated long $HTTP_*_VARS type predefined variables
; are registered by PHP or not. As they are deprecated, we obviously don't
; recommend you use them. They are on by default for compatibility reasons but
; they are not recommended on production servers.
; Default Value: On
; [url]http://php.net/register-long-arrays[/url]
register_long_arrays=Off
; This directive determines whether PHP registers $argv & $argc each time it
; runs. $argv contains an array of all the arguments passed to PHP when a script
; is invoked. $argc contains an integer representing the number of arguments
; that were passed when the script was invoked. These arrays are extremely
; useful when running scripts from the command line. When this directive is
; enabled, registering these variables consumes CPU cycles and memory each time
; a script is executed. For performance reasons, this feature should be disabled
; on production servers.
; Default Value: On
; [url]http://php.net/register-argc-argv[/url]
register_argc_argv=Off
; When enabled, the ENV, REQUEST and SERVER variables are created when they're
; first used (Just In Time) instead of when the script starts. If these
; variables are not used within a script, having this directive on will result
; in a performance gain. The PHP directive register_argc_argv must be disabled
; for this directive to have any affect.
; [url]http://php.net/auto-globals-jit[/url]
auto_globals_jit=On
; Whether PHP will read the POST data.
; This option is enabled by default.
; Most likely, you won't want to disable this option globally. It causes $_POST
; and $_FILES to always be empty; the only way you will be able to read the
; POST data will be through the php://input stream wrapper. This can be useful
; to proxy requests or to process the POST data in a memory efficient fashion.
; [url]http://php.net/enable-post-data-reading[/url]
;enable_post_data_reading = Off
; Maximum size of POST data that PHP will accept.
; Its value may be 0 to disable the limit. It is ignored if POST data reading
; is disabled through enable_post_data_reading.
; [url]http://php.net/post-max-size[/url]
post_max_size=8M
; Magic quotes are a preprocessing feature of PHP where PHP will attempt to
; escape any character sequences in GET, POST, COOKIE and ENV data which might
; otherwise corrupt data being placed in resources such as databases before
; making that data available to you. Because of character encoding issues and
; non-standard SQL implementations across many databases, it's not currently
; possible for this feature to be 100% accurate. PHP's default behavior is to
; enable the feature. We strongly recommend you use the escaping mechanisms
; designed specifically for the database your using instead of relying on this
; feature. Also note, this feature has been deprecated as of PHP 5.3.0 and is
; scheduled for removal in PHP 6.
; Default Value: On
; [url]http://php.net/magic-quotes-gpc[/url]
magic_quotes_gpc=Off
; Magic quotes for runtime-generated data, e.g. data from SQL, from exec(), etc.
; [url]http://php.net/magic-quotes-runtime[/url]
magic_quotes_runtime=Off
; Use Sybase-style magic quotes (escape ' with '' instead of \').
; [url]http://php.net/magic-quotes-sybase[/url]
magic_quotes_sybase=Off
; Automatically add files before PHP document.
; [url]http://php.net/auto-prepend-file[/url]
auto_prepend_file=
; Automatically add files after PHP document.
; [url]http://php.net/auto-append-file[/url]
auto_append_file=
; By default, PHP will output a character encoding using
; the Content-type: header. To disable sending of the charset, simply
; set it to be empty.
; PHP's built-in default is text/html
; [url]http://php.net/default-mimetype[/url]
default_mimetype="text/html"
; PHP's default character set is set to empty.
; [url]http://php.net/default-charset[/url]
;default_charset = "UTF-8"
; Always populate the $HTTP_RAW_POST_DATA variable. PHP's default behavior is
; to disable this feature. If post reading is disabled through
; enable_post_data_reading, $HTTP_RAW_POST_DATA is *NOT* populated.
; [url]http://php.net/always-populate-raw-post-data[/url]
;always_populate_raw_post_data = On
; Paths and Directories ;
; UNIX: "/path1:/path2"
;include_path = ".:/php/includes"
; Windows: "\path1;\path2"
include_path=".;C:\xampp\php\PEAR"
; PHP's default setting for include_path is ".;/path/to/php/pear"
; [url]http://php.net/include-path[/url]
; The root of the PHP pages, used only if nonempty.
; if PHP was not compiled with FORCE_REDIRECT, you SHOULD set doc_root
; if you are running php as a CGI under any web server (other than IIS)
; see documentation for security issues. The alternate is to use the
; cgi.force_redirect configuration below
; [url]http://php.net/doc-root[/url]
doc_root=
; The directory under which PHP opens the script using /~username used only
; if nonempty.
; [url]http://php.net/user-dir[/url]
user_dir=
; Directory in which the loadable extensions (modules) reside.
; [url]http://php.net/extension-dir[/url]
; extension_dir = "./"
; On windows:
extension_dir="C:\xampp\php\ext"
; Whether or not to enable the dl() function. The dl() function does NOT work
; properly in multithreaded servers, such as IIS or Zeus, and is automatically
; disabled on them.
; [url]http://php.net/enable-dl[/url]
enable_dl=On
; cgi.force_redirect is necessary to provide security running PHP as a CGI under
; most web servers. Left undefined, PHP turns this on by default. You can
; turn it off here AT YOUR OWN RISK
; **You CAN safely turn this off for IIS, in fact, you MUST.**
; [url]http://php.net/cgi.force-redirect[/url]
;cgi.force_redirect = 1
; if cgi.nph is enabled it will force cgi to always sent Status: 200 with
; every request. PHP's default behavior is to disable this feature.
;cgi.nph = 1
; if cgi.force_redirect is turned on, and you are not running under Apache or Netscape
; (iPlanet) web servers, you MAY need to set an environment variable name that PHP
; will look for to know it is OK to continue execution. Setting this variable MAY
; cause security issues, KNOW WHAT YOU ARE DOING FIRST.
; [url]http://php.net/cgi.redirect-status-env[/url]
;cgi.redirect_status_env = ;
; cgi.fix_pathinfo provides *real* PATH_INFO/PATH_TRANSLATED support for CGI. PHP's
; previous behaviour was to set PATH_TRANSLATED to SCRIPT_FILENAME, and to not grok
; what PATH_INFO is. For more information on PATH_INFO, see the cgi specs. Setting
; this to 1 will cause PHP CGI to fix its paths to conform to the spec. A setting
; of zero causes PHP to behave as before. Default is 1. You should fix your scripts
; to use SCRIPT_FILENAME rather than PATH_TRANSLATED.
; [url]http://php.net/cgi.fix-pathinfo[/url]
;cgi.fix_pathinfo=1
; FastCGI under IIS (on WINNT based OS) supports the ability to impersonate
; security tokens of the calling client. This allows IIS to define the
; security context that the request runs under. mod_fastcgi under Apache
; does not currently support this feature (03/17/2002)
; Set to 1 if running under IIS. Default is zero.
; [url]http://php.net/fastcgi.impersonate[/url]
;fastcgi.impersonate = 1;
; Disable logging through FastCGI connection. PHP's default behavior is to enable
; this feature.
;fastcgi.logging = 0
; cgi.rfc2616_headers configuration option tells PHP what type of headers to
; use when sending HTTP response code. If it's set 0 PHP sends Status: header that
; is supported by Apache. When this option is set to 1 PHP will send
; RFC2616 compliant header.
; Default is zero.
; [url]http://php.net/cgi.rfc2616-headers[/url]
;cgi.rfc2616_headers = 0
; File Uploads ;
; Whether to allow HTTP file uploads.
; [url]http://php.net/file-uploads[/url]
file_uploads=On
; Temporary directory for HTTP uploaded files (will use system default if not
; specified).
; [url]http://php.net/upload-tmp-dir[/url]
upload_tmp_dir="C:\xampp\tmp"
; Maximum allowed size for uploaded files.
; [url]http://php.net/upload-max-filesize[/url]
upload_max_filesize=2M
; Maximum number of files that can be uploaded via a single request
max_file_uploads=20
; Fopen wrappers ;
; Whether to allow the treatment of URLs (like http:// or [url]ftp://)[/url] as files.
; [url]http://php.net/allow-url-fopen[/url]
allow_url_fopen=On
; Whether to allow include/require to open URLs (like http:// or [url]ftp://)[/url] as files.
; [url]http://php.net/allow-url-include[/url]
allow_url_include=Off
; Define the anonymous ftp password (your email address). PHP's default setting
; for this is empty.
; [url]http://php.net/from[/url]
;from="[email protected]"
; Define the User-Agent string. PHP's default setting for this is empty.
; [url]http://php.net/user-agent[/url]
;user_agent="PHP"
; Default timeout for socket based streams (seconds)
; [url]http://php.net/default-socket-timeout[/url]
default_socket_timeout=60
; If your scripts have to deal with files from Macintosh systems,
; or you are running on a Mac and need to deal with files from
; unix or win32 systems, setting this flag will cause PHP to
; automatically detect the EOL character in those files so that
; fgets() and file() will work regardless of the source of the file.
; [url]http://php.net/auto-detect-line-endings[/url]
;auto_detect_line_endings = Off
; Dynamic Extensions ;
; If you wish to have an extension loaded automatically, use the following
; syntax:
; extension=modulename.extension
; For example, on Windows:
; extension=msql.dll
; ... or under UNIX:
; extension=msql.so
; ... or with a path:
; extension=/path/to/extension/msql.so
; If you only provide the name of the extension, PHP will look for it in its
; default extension directory.
; Windows Extensions
; Note that ODBC support is built in, so no dll is needed for it.
; Note that many DLL files are located in the extensions/ (PHP 4) ext/ (PHP 5)
; extension folders as well as the separate PECL DLL download (PHP 5).
; Be sure to appropriately set the extension_dir directive.
extension=php_bz2.dll
extension=php_curl.dll
extension=php_mbstring.dll
extension=php_exif.dll
;extension=php_fileinfo.dll
extension=php_gd2.dll
extension=php_gettext.dll
;extension=php_gmp.dll
;extension=php_intl.dll
;extension=php_imap.dll
;extension=php_interbase.dll
;extension=php_ldap.dll
;extension=php_mssql.dll
;extension=php_mbstring.dll
;extension=php_exif.dll ; Must be after mbstring as it depends on it
extension=php_mysql.dll
extension=php_mysqli.dll
;extension=php_oci8.dll ; Use with Oracle 10gR2 Instant Client
;extension=php_oci8_11g.dll ; Use with Oracle 11gR2 Instant Client
extension=php_openssl.dll
;extension=php_pdo_firebird.dll
extension=php_pdo_mysql.dll
;extension=php_pdo_oci.dll
;extension=php_pdo_odbc.dll
;extension=php_pdo_pgsql.dll
extension=php_pdo_sqlite.dll
;extension=php_pdo_sqlite_external.dll
;extension=php_pgsql.dll
;extension=php_pspell.dll
;extension=php_shmop.dll
; The MIBS data available in the PHP distribution must be installed.
; See [url]http://www.php.net/manual/en/snmp.installation.php[/url]
;extension=php_snmp.dll
extension=php_soap.dll
extension=php_sockets.dll
extension=php_sqlite3.dll
;extension=php_sybase_ct.dll
;extension=php_tidy.dll
extension=php_xmlrpc.dll
extension=php_xsl.dll
; Module Settings ;
[CLI Server]
; Whether the CLI web server uses ANSI color coding in its terminal output.
cli_server.color=On
[Date]
; Defines the default timezone used by the date functions
; [url]http://php.net/date.timezone[/url]
date.timezone=Europe/Berlin
; [url]http://php.net/date.default-latitude[/url]
;date.default_latitude = 31.7667
; [url]http://php.net/date.default-longitude[/url]
;date.default_longitude = 35.2333
; [url]http://php.net/date.sunrise-zenith[/url]
;date.sunrise_zenith = 90.583333
; [url]http://php.net/date.sunset-zenith[/url]
;date.sunset_zenith = 90.583333
[filter]
; [url]http://php.net/filter.default[/url]
;filter.default = unsafe_raw
; [url]http://php.net/filter.default-flags[/url]
;filter.default_flags =
[iconv]
;iconv.input_encoding = ISO-8859-1
;iconv.internal_encoding = ISO-8859-1
;iconv.output_encoding = ISO-8859-1
[intl]
;intl.default_locale =
; This directive allows you to produce PHP errors when some error
; happens within intl functions. The value is the level of the error produced.
; Default is 0, which does not produce any errors.
;intl.error_level = E_WARNING
[sqlite]
; [url]http://php.net/sqlite.assoc-case[/url]
;sqlite.assoc_case = 0
[sqlite3]
;sqlite3.extension_dir =
[Pcre]
;PCRE library backtracking limit.
; [url]http://php.net/pcre.backtrack-limit[/url]
;pcre.backtrack_limit=100000
;PCRE library recursion limit.
;Please note that if you set this value to a high number you may consume all
;the available process stack and eventually crash PHP (due to reaching the
;stack size limit imposed by the Operating System).
; [url]http://php.net/pcre.recursion-limit[/url]
;pcre.recursion_limit=100000
[Pdo]
; Whether to pool ODBC connections. Can be one of "strict", "relaxed" or "off"
; [url]http://php.net/pdo-odbc.connection-pooling[/url]
;pdo_odbc.connection_pooling=strict
;pdo_odbc.db2_instance_name
[Pdo_mysql]
; If mysqlnd is used: Number of cache slots for the internal result set cache
; [url]http://php.net/pdo_mysql.cache_size[/url]
pdo_mysql.cache_size=2000
; Default socket name for local MySQL connects. If empty, uses the built-in
; MySQL defaults.
; [url]http://php.net/pdo_mysql.default-socket[/url]
pdo_mysql.default_socket="MySQL"
[Phar]
; [url]http://php.net/phar.readonly[/url]
;phar.readonly = On
; [url]http://php.net/phar.require-hash[/url]
;phar.require_hash = On
;phar.cache_list =
[Syslog]
; Whether or not to define the various syslog variables (e.g. $LOG_PID,
; $LOG_CRON, etc.). Turning it off is a good idea performance-wise. In
; runtime, you can define these variables by calling define_syslog_variables().
; [url]http://php.net/define-syslog-variables[/url]
define_syslog_variables=Off
[mail function]
; XAMPP: Comment out this if you want to work with an SMTP Server like Mercury
; SMTP = localhost
; smtp_port = 25
; For Win32 only.
; [url]http://php.net/sendmail-from[/url]
;sendmail_from = postmaster@localhost
; XAMPP IMPORTANT NOTE (1): If XAMPP is installed in a base directory with spaces (e.g. c:\program filesC:\xampp) fakemail and mailtodisk do not work correctly.
; XAMPP IMPORTANT NOTE (2): In this case please copy the sendmail or mailtodisk folder in your root folder (e.g. C:\sendmail) and use this for sendmail_path.
; XAMPP: Comment out this if you want to work with fakemail for forwarding to your mailbox (sendmail.exe in the sendmail folder)
;sendmail_path = "\"C:\xampp\sendmail\sendmail.exe\" -t"
; XAMPP: Comment out this if you want to work with mailToDisk, It writes all mails in the C:\xampp\mailoutput folder
sendmail_path="C:\xampp\mailtodisk\mailtodisk.exe"
; Force the addition of the specified parameters to be passed as extra parameters
; to the sendmail binary. These parameters will always replace the value of
; the 5th parameter to mail(), even in safe mode.
;mail.force_extra_parameters =
; Add X-PHP-Originating-Script: that will include uid of the script followed by the filename
mail.add_x_header=Off
; Log all mail() calls including the full path of the script, line #, to address and headers
;mail.log = "C:\xampp\php\logs\php_mail.log"
[SQL]
; [url]http://php.net/sql.safe-mode[/url]
sql.safe_mode=Off
[ODBC]
; [url]http://php.net/odbc.default-db[/url]
;odbc.default_db = Not yet implemented
; [url]http://php.net/odbc.default-user[/url]
;odbc.default_user = Not yet implemented
; [url]http://php.net/odbc.default-pw[/url]
;odbc.default_pw = Not yet implemented
; Controls the ODBC cursor model.
; Default: SQL_CURSOR_STATIC (default).
;odbc.default_cursortype
; Allow or prevent persistent links.
; [url]http://php.net/odbc.allow-persistent[/url]
odbc.allow_persistent=On
; Check that a connection is still valid before reuse.
; [url]http://php.net/odbc.check-persistent[/url]
odbc.check_persistent=On
; Maximum number of persistent links. -1 means no limit.
; [url]http://php.net/odbc.max-persistent[/url]
odbc.max_persistent=-1
; Maximum number of links (persistent + non-persistent). -1 means no limit.
; [url]http://php.net/odbc.max-links[/url]
odbc.max_links=-1
; Handling of LONG fields. Returns number of bytes to variables. 0 means
; passthru.
; [url]http://php.net/odbc.defaultlrl[/url]
odbc.defaultlrl=4096
; Handling of binary data. 0 means passthru, 1 return as is, 2 convert to char.
; See the documentation on odbc_binmode and odbc_longreadlen for an explanation
; of odbc.defaultlrl and odbc.defaultbinmode
; [url]http://php.net/odbc.defaultbinmode[/url]
odbc.defaultbinmode=1
;birdstep.max_links = -1
[Interbase]
ibase.allow_persistent=1
ibase.max_persistent=-1
ibase.max_links=-1
; Default database name for ibase_connect().
;ibase.default_db =
; Default username for ibase_connect().
;ibase.default_user =
; Default password for ibase_connect().
;ibase.default_password =
; Default charset for ibase_connect().
;ibase.default_charset =
; Default timestamp format.
ibase.timestampformat="%Y-%m-%d %H:%M:%S"
; Default date format.
ibase.dateformat="%Y-%m-%d"
; Default time format.
ibase.timeformat="%H:%M:%S"
[MySQL]
; Allow accessing, from PHP's perspective, local files with LOAD DATA statements
; [url]http://php.net/mysql.allow_local_infile[/url]
mysql.allow_local_infile=On
; [url]http://php.net/mysql.allow-persistent[/url]
mysql.allow_persistent=On
; [url]http://php.net/mysql.cache_size[/url]
; [url]http://php.net/mysql.max-persistent[/url]
mysql.max_persistent=-1
; [url]http://php.net/mysql.max-links[/url]
mysql.max_links=-1
; Default port number for mysql_connect(). If unset, mysql_connect() will use
; the $MYSQL_TCP_PORT or the mysql-tcp entry in /etc/services or the
; compile-time value defined MYSQL_PORT (in that order). Win32 will only look
; at MYSQL_PORT.
; [url]http://php.net/mysql.default-port[/url]
mysql.default_port=3306
; MySQL defaults.
; [url]http://php.net/mysql.default-socket[/url]
; Default host for mysql_connect() (doesn't apply in safe mode).
; [url]http://php.net/mysql.default-host[/url]
mysql.default_host=
; Default user for mysql_connect() (doesn't apply in safe mode).
; [url]http://php.net/mysql.default-user[/url]
mysql.default_user=
; Default password for mysql_connect() (doesn't apply in safe mode).
; Note that this is generally a *bad* idea to store passwords in this file.
; *Any* user with PHP access can run 'echo get_cfg_var("mysql.default_password")
; and reveal this password! And of course, any users with read access to this
; file will be able to reveal the password as well.
; [url]http://php.net/mysql.default-password[/url]
mysql.default_password=
; Maximum time (in seconds) for connect timeout. -1 means no limit
; [url]http://php.net/mysql.connect-timeout[/url]
mysql.connect_timeout=3
; Trace mode. When trace_mode is active (=On), warnings for table/index scans and
; SQL-Errors will be displayed.
; [url]http://php.net/mysql.trace-mode[/url]
mysql.trace_mode=Off
[MySQLi]
; [url]http://php.net/mysqli.max-persistent[/url]
mysqli.max_persistent=-1
; [url]http://php.net/mysqli.allow_local_infile[/url]
mysqli.allow_local_infile=On
; [url]http://php.net/mysqli.allow-persistent[/url]
mysqli.allow_persistent=On
; Maximum number of links. -1 means no limit.
; [url]http://php.net/mysqli.max-links[/url]
mysqli.max_links=-1
; [url]http://php.net/mysqli.cache_size[/url]
mysqli.cache_size=2000
; Default port number for mysqli_connect(). If unset, mysqli_connect() will use
; at MYSQL_PORT.
; [url]http://php.net/mysqli.default-port[/url]
mysqli.default_port=3306
; MySQL defaults.
; [url]http://php.net/mysqli.default-socket[/url]
mysqli.default_socket="MySQL"
; [url]http://php.net/mysqli.default-host[/url]
mysqli.default_host=
; [url]http://php.net/mysqli.default-user[/url]
mysqli.default_user=
; Default password for mysqli_connect() (doesn't apply in safe mode).
; *Any* user with PHP access can run 'echo get_cfg_var("mysqli.default_pw")
; [url]http://php.net/mysqli.default-pw[/url]
mysqli.default_pw=
; Allow or prevent reconnect
mysqli.reconnect=Off
[mysqlnd]
; Enable / Disable collection of general statstics by mysqlnd which can be
; used to tune and monitor MySQL operations.
; [url]http://php.net/mysqlnd.collect_statistics[/url]
mysqlnd.collect_statistics=On
; Enable / Disable collection of memory usage statstics by mysqlnd which can be
; [url]http://php.net/mysqlnd.collect_memory_statistics[/url]
mysqlnd.collect_memory_statistics=Off
; Size of a pre-allocated buffer used when sending commands to MySQL in bytes.
; [url]http://php.net/mysqlnd.net_cmd_buffer_size[/url]
;mysqlnd.net_cmd_buffer_size = 2048
; Size of a pre-allocated buffer used for reading data sent by the server in
; bytes.
; [url]http://php.net/mysqlnd.net_read_buffer_size[/url]
;mysqlnd.net_read_buffer_size = 32768
[OCI8]
; Connection: Enables privileged connections using external
; credentials (OCI_SYSOPER, OCI_SYSDBA)
; [url]http://php.net/oci8.privileged-connect[/url]
;oci8.privileged_connect = Off
; Connection: The maximum number of persistent OCI8 connections per
; process. Using -1 means no limit.
; [url]http://php.net/oci8.max-persistent[/url]
;oci8.max_persistent = -1
; Connection: The maximum number of seconds a process is allowed to
; maintain an idle persistent connection. Using -1 means idle
; persistent connections will be maintained forever.
; [url]http://php.net/oci8.persistent-timeout[/url]
;oci8.persistent_timeout = -1
; Connection: The number of seconds that must pass before issuing a
; ping during oci_pconnect() to check the connection validity. When
; set to 0, each oci_pconnect() will cause a ping. Using -1 disables
; pings completely.
; [url]http://php.net/oci8.ping-interval[/url]
;oci8.ping_interval = 60
; Connection: Set this to a user chosen connection class to be used
; for all pooled server requests with Oracle 11g Database Resident
; Connection Pooling (DRCP). To use DRCP, this value should be set to
; the same string for all web servers running the same application,
; the database pool must be configured, and the connection string must
; specify to use a pooled server.
;oci8.connection_class =
; High Availability: Using On lets PHP receive Fast Application
; Notification (FAN) events generated when a database node fails. The
; database must also be configured to post FAN events.
;oci8.events = Off
; Tuning: This option enables statement caching, and specifies how
; many statements to cache. Using 0 disables statement caching.
; [url]http://php.net/oci8.statement-cache-size[/url]
;oci8.statement_cache_size = 20
; Tuning: Enables statement prefetching and sets the default number of
; rows that will be fetched automatically after statement execution.
; [url]http://php.net/oci8.default-prefetch[/url]
;oci8.default_prefetch = 100
; Compatibility. Using On means oci_close() will not close
; oci_connect() and oci_new_connect() connections.
; [url]http://php.net/oci8.old-oci-close-semantics[/url]
;oci8.old_oci_close_semantics = Off
[PostgresSQL]
; [url]http://php.net/pgsql.allow-persistent[/url]
pgsql.allow_persistent=On
; Detect broken persistent links always with pg_pconnect().
; Auto reset feature requires a little overheads.
; [url]http://php.net/pgsql.auto-reset-persistent[/url]
pgsql.auto_reset_persistent=Off
; [url]http://php.net/pgsql.max-persistent[/url]
pgsql.max_persistent=-1
; Maximum number of links (persistent+non persistent). -1 means no limit.
; [url]http://php.net/pgsql.max-links[/url]
pgsql.max_links=-1
; Ignore PostgreSQL backends Notice message or not.
; Notice message logging require a little overheads.
; [url]http://php.net/pgsql.ignore-notice[/url]
pgsql.ignore_notice=0
; Log PostgreSQL backends Noitce message or not.
; Unless pgsql.ignore_notice=0, module cannot log notice message.
; [url]http://php.net/pgsql.log-notice[/url]
pgsql.log_notice=0
[Sybase-CT]
; [url]http://php.net/sybct.allow-persistent[/url]
sybct.allow_persistent=On
; [url]http://php.net/sybct.max-persistent[/url]
sybct.max_persistent=-1
; [url]http://php.net/sybct.max-links[/url]
sybct.max_links=-1
; Minimum server message severity to display.
; [url]http://php.net/sybct.min-server-severity[/url]
sybct.min_server_severity=10
; Minimum client message severity to display.
; [url]http://php.net/sybct.min-client-severity[/url]
sybct.min_client_severity=10
; Set per-context timeout
; [url]http://php.net/sybct.timeout[/url]
;sybct.timeout=
;sybct.packet_size
; The maximum time in seconds to wait for a connection attempt to succeed before returning failure.
; Default: one minute
;sybct.login_timeout=
; The name of the host you claim to be connecting from, for display by sp_who.
; Default: none
;sybct.hostname=
; Allows you to define how often deadlocks are to be retried. -1 means "forever".
; Default: 0
;sybct.deadlock_retry_count=
[bcmath]
; Number of decimal digits for all bcmath functions.
; [url]http://php.net/bcmath.scale[/url]
bcmath.scale=0
[browscap]
; [url]http://php.net/browscap[/url]
browscap="C:\xampp\php\extras\browscap.ini"
[Session]
; Handler used to store/retrieve data.
; [url]http://php.net/session.save-handler[/url]
session.save_handler=files
; Argument passed to save_handler. In the case of files, this is the path
; where data files are stored. Note: Windows users have to change this
; variable in order to use PHP's session functions.
; The path can be defined as:
; session.save_path = "N;/path"
; where N is an integer. Instead of storing all the session files in
; /path, what this will do is use subdirectories N-levels deep, and
; store the session data in those directories. This is useful if you
; or your OS have problems with lots of files in one directory, and is
; a more efficient layout for servers that handle lots of sessions.
; NOTE 1: PHP will not create this directory structure automatically.
; You can use the script in the ext/session dir for that purpose.
; NOTE 2: See the section on garbage collection below if you choose to
; use subdirectories for session storage
; The file storage module creates files using mode 600 by default.
; You can change that by using
; session.save_path = "N;MODE;/path"
; where MODE is the octal representation of the mode. Note that this
; does not overwrite the process's umask.
; [url]http://php.net/session.save-path[/url]
session.save_path="C:\xampp\tmp"
; Whether to use cookies.
; [url]http://php.net/session.use-cookies[/url]
session.use_cookies=1
; [url]http://php.net/session.cookie-secure[/url]
;session.cookie_secure =
; This option forces PHP to fetch and use a cookie for storing and maintaining
; the session id. We encourage this operation as it's very helpful in combatting
; session hijacking when not specifying and managing your own session id. It is
; not the end all be all of session hijacking defense, but it's a good start.
; [url]http://php.net/session.use-only-cookies[/url]
session.use_only_cookies=0
; Name of the session (used as cookie name).
; [url]http://php.net/session.name[/url]
session.name=PHPSESSID
; Initialize session on request startup.
; [url]http://php.net/session.auto-start[/url]
session.auto_start=0
; Lifetime in seconds of cookie or, if 0, until browser is restarted.
; [url]http://php.net/session.cookie-lifetime[/url]
session.cookie_lifetime=0
; The path for which the cookie is valid.
; [url]http://php.net/session.cookie-path[/url]
session.cookie_path=/
; The domain for which the cookie is valid.
; [url]http://php.net/session.cookie-domain[/url]
session.cookie_domain=
; Whether or not to add the httpOnly flag to the cookie, which makes it inaccessible to browser scripting languages such as JavaScript.
; [url]http://php.net/session.cookie-httponly[/url]
session.cookie_httponly=
; Handler used to serialize data. php is the standard serializer of PHP.
; [url]http://php.net/session.serialize-handler[/url]
session.serialize_handler=php
; Defines the probability that the 'garbage collection' process is started
; on every session initialization. The probability is calculated by using
; gc_probability/gc_divisor. Where session.gc_probability is the numerator
; and gc_divisor is the denominator in the equation. Setting this value to 1
; when the session.gc_divisor value is 100 will give you approximately a 1% chance
; the gc will run on any give request.
; Default Value: 1
; [url]http://php.net/session.gc-probability[/url]
session.gc_probability=1
; Defines the probability that the 'garbage collection' process is started on every
; session initialization. The probability is calculated by using the following equation:
; gc_probability/gc_divisor. Where session.gc_probability is the numerator and
; session.gc_divisor is the denominator in the equation. Setting this value to 1
; the gc will run on any give request. Increasing this value to 1000 will give you
; a 0.1% chance the gc will run on any give request. For high volume production servers,
; this is a more efficient approach.
; [url]http://php.net/session.gc-divisor[/url]
session.gc_divisor=1000
; After this number of seconds, stored data will be seen as 'garbage' and
; cleaned up by the garbage collection process.
; [url]http://php.net/session.gc-maxlifetime[/url]
session.gc_maxlifetime=1440
; NOTE: If you are using the subdirectory option for storing session files
; (see session.save_path above), then garbage collection does *not*
; happen automatically. You will need to do your own garbage
; collection through a shell script, cron entry, or some other method.
; For example, the following script would is the equivalent of
; setting session.gc_maxlifetime to 1440 (1440 seconds = 24 minutes):
; cd /path/to/sessions; find -cmin +24 | xargs rm
; PHP 4.2 and less have an undocumented feature/bug that allows you to
; to initialize a session variable in the global scope.
; PHP 4.3 and later will warn you, if this feature is used.
; You can disable the feature and the warning separately. At this time,
; the warning is only displayed, if bug_compat_42 is enabled. This feature
; introduces some serious security problems if not handled correctly. It's
; recommended that you do not use this feature on production servers. But you
; should enable this on development servers and enable the warning as well. If you
; do not enable the feature on development servers, you won't be warned when it's
; used and debugging errors caused by this can be difficult to track down.
; Default Value: On
; [url]http://php.net/session.bug-compat-42[/url]
session.bug_compat_42=On
; This setting controls whether or not you are warned by PHP when initializing a
; session value into the global space. session.bug_compat_42 must be enabled before
; these warnings can be issued by PHP. See the directive above for more information.
; Default Value: On
; [url]http://php.net/session.bug-compat-warn[/url]
session.bug_compat_warn=On
; Check HTTP Referer to invalidate externally stored URLs containing ids.
; HTTP_REFERER has to contain this substring for the session to be
; considered as valid.
; [url]http://php.net/session.referer-check[/url]
session.referer_check=
; How many bytes to read from the file.
; [url]http://php.net/session.entropy-length[/url]
session.entropy_length=0
; Specified here to create the session id.
; [url]http://php.net/session.entropy-file[/url]
; Defaults to /dev/urandom
; On systems that don't have /dev/urandom but do have /dev/arandom, this will default to /dev/arandom
; If neither are found at compile time, the default is no entropy file.
; On windows, setting the entropy_length setting will activate the
; Windows random source (using the CryptoAPI)
;session.entropy_file = /dev/urandom
session.entropy_file=
;session.entropy_length = 16
; Set to {nocache,private,public,} to determine HTTP caching aspects
; or leave this empty to avoid sending anti-caching headers.
; [url]http://php.net/session.cache-limiter[/url]
session.cache_limiter=nocache
; Document expires after n minutes.
; [url]http://php.net/session.cache-expire[/url]
session.cache_expire=180
; trans sid support is disabled by default.
; Use of trans sid may risk your users security.
; Use this option with caution.
; - User may send URL contains active session ID
; to other person via. email/irc/etc.
; - URL that contains active session ID may be stored
; in publically accessible computer.
; - User may access your site with the same session ID
; always using URL stored in browser's history or bookmarks.
; [url]http://php.net/session.use-trans-sid[/url]
session.use_trans_sid=0
; Select a hash function for use in generating session ids.
; Possible Values
; 0 (MD5 128 bits)
; 1 (SHA-1 160 bits)
; This option may also be set to the name of any hash function supported by
; the hash extension. A list of available hashes is returned by the hash_algos()
; function.
; [url]http://php.net/session.hash-function[/url]
session.hash_function=0
; Define how many bits are stored in each character when converting
; the binary hash data to something readable.
; Possible values:
; 4 (4 bits: 0-9, a-f)
; 5 (5 bits: 0-9, a-v)
; 6 (6 bits: 0-9, a-z, A-Z, "-", ",")
; Default Value: 4
; [url]http://php.net/session.hash-bits-per-character[/url]
session.hash_bits_per_character=5
; The URL rewriter will look for URLs in a defined set of HTML tags.
; form/fieldset are special; if you include them here, the rewriter will
; add a hidden <input> field with the info which is otherwise appended
; to URLs. If you want XHTML conformity, remove the form entry.
; Note that all valid entries require a "=", even if no value follows.
; [url]http://php.net/url-rewriter.tags[/url]
url_rewriter.tags="a=href,area=href,frame=src,input=src,form=fakeentry"
; Enable upload progress tracking in $_SESSION
; Default Value: On
; [url]http://php.net/session.upload-progress.enabled[/url]
;session.upload_progress.enabled = On
; Cleanup the progress information as soon as all POST data has been read
; (i.e. upload completed).
; Default Value: On
; [url]http://php.net/session.upload-progress.cleanup[/url]
;session.upload_progress.cleanup = On
; A prefix used for the upload progress key in $_SESSION
; Default Value: "upload_progress_"
; Development Value: "upload_progress_"
; Production Value: "upload_progress_"
; [url]http://php.net/session.upload-progress.prefix[/url]
;session.upload_progress.prefix = "upload_progress_"
; The index name (concatenated with the prefix) in $_SESSION
; containing the upload progress information
; Default Value: "PHP_SESSION_UPLOAD_PROGRESS"
; Development Value: "PHP_SESSION_UPLOAD_PROGRESS"
; Production Value: "PHP_SESSION_UPLOAD_PROGRESS"
; [url]http://php.net/session.upload-progress.name[/url]
;session.upload_progress.name = "PHP_SESSION_UPLOAD_PROGRESS"
; How frequently the upload progress should be updated.
; Given either in percentages (per-file), or in bytes
; Default Value: "1%"
; Development Value: "1%"
; Production Value: "1%"
; [url]http://php.net/session.upload-progress.freq[/url]
;session.upload_progress.freq = "1%"
; The minimum delay between updates, in seconds
; Default Value: 1
; [url]http://php.net/session.upload-progress.min-freq[/url]
;session.upload_progress.min_freq = "1"
[MSSQL]
mssql.allow_persistent=On
mssql.max_persistent=-1
mssql.max_links=-1
; Minimum error severity to display.
mssql.min_error_severity=10
; Minimum message severity to display.
mssql.min_message_severity=10
; Compatibility mode with old versions of PHP 3.0.
mssql.compatability_mode=Off
; Connect timeout
;mssql.connect_timeout = 5
; Query timeout
;mssql.timeout = 60
; Valid range 0 - 2147483647. Default = 4096.
;mssql.textlimit = 4096
;mssql.textsize = 4096
; Limits the number of records in each batch. 0 = all records in one batch.
;mssql.batchsize = 0
; Specify how datetime and datetim4 columns are returned
; On => Returns data converted to SQL server settings
; Off => Returns values as YYYY-MM-DD hh:mm:ss
;mssql.datetimeconvert = On
; Use NT authentication when connecting to the server
mssql.secure_connection=Off
; Specify max number of processes. -1 = library default
; msdlib defaults to 25
; FreeTDS defaults to 4096
;mssql.max_procs = -1
; Specify client character set.
; If empty or not set the client charset from freetds.comf is used
; This is only used when compiled with FreeTDS
;mssql.charset = "ISO-8859-1"
[Assertion]
; Assert(expr); active by default.
; [url]http://php.net/assert.active[/url]
;assert.active = On
; Issue a PHP warning for each failed assertion.
; [url]http://php.net/assert.warning[/url]
;assert.warning = On
; Don't bail out by default.
; [url]http://php.net/assert.bail[/url]
;assert.bail = Off
; User-function to be called if an assertion fails.
; [url]http://php.net/assert.callback[/url]
;assert.callback = 0
; Eval the expression with current error_reporting(). Set to true if you want
; error_reporting(0) around the eval().
; [url]http://php.net/assert.quiet-eval[/url]
;assert.quiet_eval = 0
[COM]
; path to a file containing GUIDs, IIDs or filenames of files with TypeLibs
; [url]http://php.net/com.typelib-file[/url]
;com.typelib_file =
; allow Distributed-COM calls
; [url]http://php.net/com.allow-dcom[/url]
;com.allow_dcom = true
; autoregister constants of a components typlib on com_load()
; [url]http://php.net/com.autoregister-typelib[/url]
;com.autoregister_typelib = true
; register constants casesensitive
; [url]http://php.net/com.autoregister-casesensitive[/url]
;com.autoregister_casesensitive = false
; show warnings on duplicate constant registrations
; [url]http://php.net/com.autoregister-verbose[/url]
;com.autoregister_verbose = true
; The default character set code-page to use when passing strings to and from COM objects.
; Default: system ANSI code page
;com.code_page=
[mbstring]
; language for internal character representation.
; [url]http://php.net/mbstring.language[/url]
;mbstring.language = Japanese
; internal/script encoding.
; Some encoding cannot work as internal encoding.
; (e.g. SJIS, BIG5, ISO-2022-*)
; [url]http://php.net/mbstring.internal-encoding[/url]
;mbstring.internal_encoding = EUC-JP
; http input encoding.
; [url]http://php.net/mbstring.http-input[/url]
;mbstring.http_input = auto
; http output encoding. mb_output_handler must be
; registered as output buffer to function
; [url]http://php.net/mbstring.http-output[/url]
;mbstring.http_output = SJIS
; enable automatic encoding translation according to
; mbstring.internal_encoding setting. Input chars are
; converted to internal encoding by setting this to On.
; Note: Do _not_ use automatic encoding translation for
; portable libs/applications.
; [url]http://php.net/mbstring.encoding-translation[/url]
;mbstring.encoding_translation = Off
; automatic encoding detection order.
; auto means
; [url]http://php.net/mbstring.detect-order[/url]
;mbstring.detect_order = auto
; substitute_character used when character cannot be converted
; one from another
; [url]http://php.net/mbstring.substitute-character[/url]
;mbstring.substitute_character = none;
; overload(replace) single byte functions by mbstring functions.
; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
; etc. Possible values are 0,1,2,4 or combination of them.
; For example, 7 for overload everything.
; 0: No overload
; 1: Overload mail() function
; 2: Overload str*() functions
; 4: Overload ereg*() functions
; [url]http://php.net/mbstring.func-overload[/url]
;mbstring.func_overload = 0
; enable strict encoding detection.
;mbstring.strict_detection = Off
; This directive specifies the regex pattern of content types for which mb_output_handler()
; is activated.
; Default: mbstring.http_output_conv_mimetype=^(text/|application/xhtml\+xml)
;mbstring.http_output_conv_mimetype=
; Allows to set script encoding. Only affects if PHP is compiled with --enable-zend-multibyte
; Default: ""
;mbstring.script_encoding=
[gd]
; Tell the jpeg decode to ignore warnings and try to create
; a gd image. The warning will then be displayed as notices
; disabled by default
; [url]http://php.net/gd.jpeg-ignore-warning[/url]
;gd.jpeg_ignore_warning = 0
[exif]
; Exif UNICODE user comments are handled as UCS-2BE/UCS-2LE and JIS as JIS.
; With mbstring support this will automatically be converted into the encoding
; given by corresponding encode setting. When empty mbstring.internal_encoding
; is used. For the decode settings you can distinguish between motorola and
; intel byte order. A decode setting cannot be empty.
; [url]http://php.net/exif.encode-unicode[/url]
;exif.encode_unicode = ISO-8859-15
; [url]http://php.net/exif.decode-unicode-motorola[/url]
;exif.decode_unicode_motorola = UCS-2BE
; [url]http://php.net/exif.decode-unicode-intel[/url]
;exif.decode_unicode_intel = UCS-2LE
; [url]http://php.net/exif.encode-jis[/url]
;exif.encode_jis =
; [url]http://php.net/exif.decode-jis-motorola[/url]
;exif.decode_jis_motorola = JIS
; [url]http://php.net/exif.decode-jis-intel[/url]
;exif.decode_jis_intel = JIS
[Tidy]
; The path to a default tidy configuration file to use when using tidy
; [url]http://php.net/tidy.default-config[/url]
;tidy.default_config = "C:\xampp\php\extras\default.tcfg"
; Should tidy clean and repair output automatically?
; WARNING: Do not use this option if you are generating non-html content
; such as dynamic images
; [url]http://php.net/tidy.clean-output[/url]
tidy.clean_output=Off
[soap]
; Enables or disables WSDL caching feature.
; [url]http://php.net/soap.wsdl-cache-enabled[/url]
soap.wsdl_cache_enabled=1
; Sets the directory name where SOAP extension will put cache files.
; [url]http://php.net/soap.wsdl-cache-dir[/url]
soap.wsdl_cache_dir="/tmp"
; (time to live) Sets the number of second while cached file will be used
; instead of original one.
; [url]http://php.net/soap.wsdl-cache-ttl[/url]
soap.wsdl_cache_ttl=86400
; Sets the size of the cache limit. (Max. number of WSDL files to cache)
soap.wsdl_cache_limit=5
[sysvshm]
; A default size of the shared memory segment
;sysvshm.init_mem = 10000
[ldap]
; Sets the maximum number of open links or -1 for unlimited.
ldap.max_links=-1
[mcrypt]
; For more information about mcrypt settings see [url]http://php.net/mcrypt-module-open[/url]
; Directory where to load mcrypt algorithms
; Default: Compiled in into libmcrypt (usually /usr/local/lib/libmcrypt)
;mcrypt.algorithms_dir=
; Directory where to load mcrypt modes
;mcrypt.modes_dir=
[dba]
;dba.default_handler=
[FrontBase]
;fbsql.allow_persistent = On
;fbsql.autocommit = On
;fbsql.show_timestamp_decimals = Off
;fbsql.default_database =
;fbsql.default_database_password =
;fbsql.default_host =
;fbsql.default_password =
;fbsql.default_user = "_SYSTEM"
;fbsql.generate_warnings = Off
;fbsql.max_connections = 128
;fbsql.max_links = 128
;fbsql.max_persistent = -1
;fbsql.max_results = 128
[mime_magic]
mime_magic.magicfile="C:\xampp\php\extras\magic.mime"
;mime_magic.debug = On
[eAccelerator]
;zend_extension = "C:\xampp\php\ext\php_eaccelerator_ts.dll"
; The amount of shared memory (in megabytes) that eAccelerator will use.
; "0" means OS default. Default value is "0".
eaccelerator.shm_size="0"
; The directory that is used for disk cache. eAccelerator stores precompiled
; code, session data, content and user entries here. The same data can be
; stored in shared memory also (for more quick access). Default value is
; "/tmp/eaccelerator".
eaccelerator.cache_dir="C:\xampp\tmp"
; Enables or disables eAccelerator. Should be "1" for enabling or
; "0" for disabling. Default value is "1".
eaccelerator.enable="1"
; Enables or disables debug logging. Setting this to 1 will print information
; to the log file about the cach hits of a file.
eaccelerator.debug=0
; Set the log file for eaccelerator. When this option isn't set then the data
; will be logged to stderr
;eaccelerator.log_file = "C:\xampp\apache\logs\eaccelerator.log"
; Enables or disables PHP file modification checking. Should be "1"
; for enabling or "0" for disabling. You should set it to "1" if you want
; to recompile PHP files after modification. Default value is "1".
eaccelerator.check_mtime="1"
; Determine which PHP files must be cached. You may specify the number of
; patterns (for example "*.php *.phtml") which specifies to cache or
; not to cache. If pattern starts with the character "!", it means to ignore
; files which are matched by the following pattern. Default value is "" that
; means - all PHP scripts will be cached.
eaccelerator.filter=""
; Disables putting large values into shared memory by "eaccelerator_put()"
; function.
; It indicates the largest allowed size in bytes (10240, 10K, 1M). The "0"
; disables the limit. Default value is "0".
eaccelerator.shm_max="0"
; When eAccelerator fails to get shared memory for new script it removes
; all scripts which were not accessed at last "shm_ttl" seconds from shared
; memory. Default value is "0" that means - don't remove any files from
; shared memory.
eaccelerator.shm_ttl="0"
; When eAccelerator fails to get shared memory for new script it tryes to
; remove old script if the previous try was made more then "shm_prune_period"
; seconds ago. Default value is "0" that means - don't try to remove any
; files from shared memory.
eaccelerator.shm_prune_period="0"
; Enables or disables caching of compiled scripts on disk. It has no effect
; on session data and content caching.
; Default value is "0" that means - use disk and shared memory for caching.
eaccelerator.shm_only="0"
[XDebug]
;zend_extension = "C:\xampp\php\ext\php_xdebug.dll"
;xdebug.profiler_append = 0
;xdebug.profiler_enable = 1
;xdebug.profiler_enable_trigger = 0
;xdebug.profiler_output_dir = "C:\xampp\tmp"
;xdebug.profiler_output_name = "cachegrind.out.%t-%s"
;xdebug.remote_enable = 0
;xdebug.remote_handler = "dbgp"
;xdebug.remote_host = "127.0.0.1"
;xdebug.trace_output_dir = "C:\xampp\tmp"
