/var/media/ftp/uStor02/FritzBox # free
total used free shared buffers
Mem: 30276 29352 924 0 468
Swap: 63992 0 63992
Total: 94268 29352 64916
config.status: creating macosx/Makefile
config.status: creating wx/Makefile
config.status: creating wx/images/Makefile
config.status: creating gtk/Makefile
config.status: creating gtk/icons/Makefile
config.status: creating po/Makefile.in
config.status: executing depfiles commands
config.status: executing intltool commands
config.status: executing default-1 commands
config.status: executing po/stamp-it commands
=== configuring in third-party/libevent (/media/hdd2/freetz-trunk7270kernel/source/transmission-1.34/third-party/libevent)
configure: running /bin/bash ./configure '--prefix=/usr' '--target=mipsel-linux' '--host=mipsel-linux' '--build=i386-pc-linux-gnu' '--program-prefix=' '--program-suffix=' '--exec-prefix=/usr' '--bindir=/usr/bin' '--datadir=/usr/share' '--includedir=/usr/include' '--infodir=/usr/share/info' '--libdir=/usr/lib' '--libexecdir=/usr/lib' '--localstatedir=/var' '--mandir=/usr/share/man' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--with-gnu-ld' '--disable-nls' '--disable-beos' '--disable-darwin' '--disable-gtk' '--disable-wx' 'build_alias=i386-pc-linux-gnu' 'host_alias=mipsel-linux' 'target_alias=mipsel-linux' 'CC=/media/hdd2/freetz-trunk7270kernel/toolchain/target/bin/mipsel-linux-uclibc-gcc' 'CFLAGS=-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64' 'LDFLAGS=' 'CXX=/media/hdd2/freetz-trunk7270kernel/toolchain/target/bin/mipsel-linux-uclibc-g++-uc' 'CXXFLAGS=-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64' '--enable-static' '--disable-shared' '-q' --cache-file=/media/hdd2/freetz-trunk7270kernel/make/config.cache --srcdir=.
appending configuration tag "CXX" to libtool
appending configuration tag "F77" to libtool
Configuration:
Source code location: .
Compiler: /media/hdd2/freetz-trunk7270kernel/toolchain/target/bin/mipsel-linux-uclibc-g++-uc
Build Command-Line client: yes
Build Daemon: yes
Build BeOS client: no
Build GTK+ client: no
... gio support: no
... dbus-glib support: no
... libnotify support: no
Build OS X client: no
Build wxWidgets client: no
touch source/transmission-1.34/.configured
PATH="/media/hdd2/freetz-trunk7270kernel/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin" \
make -j2 -C source/transmission-1.34 \
CFLAGS="-Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" \
CXXFLAGS=""
make[1]: Betrete Verzeichnis '/media/hdd2/freetz-trunk7270kernel/source/transmission-1.34'
Making all in doc
make[2]: Betrete Verzeichnis '/media/hdd2/freetz-trunk7270kernel/source/transmission-1.34/doc'
make[2]: *** Keine Regel, um »all« zu erstellen. Schluss.
make[2]: Verlasse Verzeichnis '/media/hdd2/freetz-trunk7270kernel/source/transmission-1.34/doc'
make[1]: *** [all-recursive] Fehler 1
make[1]: Verlasse Verzeichnis '/media/hdd2/freetz-trunk7270kernel/source/transmission-1.34'
make: *** [source/transmission-1.34/cli/transmissioncli] Fehler 2
cru@Kubuntu:/media/hdd2/freetz-trunk7270kernel$
/var/media/ftp/uStor02/FritzBox/webtransmission # ./rc.webtransmission start
Starting webtransmission...
Stopping httpd...done.
Starting webinterface...done.
Webtransmission started.
/var/media/ftp/uStor02/FritzBox/webtransmission # ./rc.webtransmission status
Webtransmission is not running
/var/media/ftp/uStor02/FritzBox/webtransmission # more webtransmission.log
./rc.webtransmission: line 142: nice: not found
Could not connect to socket: /var/tmp/transmissiond
HOME="$BASEDIR" [color=red]nice[/color] "$BASEDIR/transmissiond" -v2 >> "$LOG" 2>&1 &
HOME="$BASEDIR" "$BASEDIR/transmissiond" -v2 >> "$LOG" 2>&1 &
/var/media/ftp/uStor02/FritzBox/webtransmission_neu # ./rc.webtransmission start
/var/media/ftp/uStor02/FritzBox/webtransmission_neu # ./rc.webtransmission status
ln -sf ../webtransmission/tmpl /var/tmp/wwwdir/cgi-bin/tmpl
ln -sf "$BASEDIR/wwwroot/tmpl" /var/tmp/wwwdir/cgi-bin/tmpl
# Set BASEDIR to match your setup
BASEDIR="/var/media/ftp/uStor02/FritzBox/webtransmission_neu"
WebTransmission 1.34 (6778) (revision: NON-SVN 1.34_v2)
modded by ChilliChilli, Mulder & coolphoenix
Segmentation fault
Webtransmission failed.
/var/media/ftp/uStor02/FritzBox/webtransmission_neu # ps | grep transmission
2352 root 1156 S grep transmission
