Immer wieder gern enpfohlen, die Seiten von OpenVPN selbst:
http://openvpn.net/man.html
Ansonsten nochmal die Config geprüft? Vielleicht auf beiden Seiten die gleiche IP?
Jörg
--verb n
Set output verbosity to n (default=1). Each level shows all info from the previous levels. Level 3 is recommended if you want a good summary of what's happening without being swamped by output.
0 -- No output except fatal errors.
1 to 4 -- Normal usage range.
5 -- Output R and W characters to the console for each packet read and write, uppercase is used for TCP/UDP packets and lowercase is used for TUN/TAP packets.
6 to 11 -- Debug info range (see errlevel.h for additional information on debug levels).
Jörg
