Mounting USB-DISK2-0-01 to device /dev/sda1...
mount: mounting /dev/sda1 on /var/media/ftp/USB-DISK2-0-01 failed: Invalid argument
ntfs not yet ready -> mount later
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[31] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <data> page[14] found - skipped
VINAX_DRV[00]: BM-7 CS: EMPTY <code> page[37] found - skipped
create sema UPNPAPI_DATA_phonebook
Jan 1 01:00:59 telefon[976]: SIGCHLD received!
/sbin/start_plugin.sh[1013]: Plugins awaited: samba mini ntfs
run_clock demon started
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (183240 ms noch verfuegbar)
Mounting USB-FlashDisk-01 to device /dev/sdb1...
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=0 div=1 offset=974 NormP=974 mW -> SumNormP=974 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=100 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=3417 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=0 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=4357 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=4457 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=4557 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=200 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=7477 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=7883 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=1073742084 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=8400 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=8400 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=11200 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=11200 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=11200 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=100 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=11473 mW
SysRq : Changing Loglevel
Loglevel set to 4
/sbin/start_plugin.sh[1057]: Plugins awaited: samba mini ntfs
/sbin/start_plugin.sh[1057]: explicit Mount Point '/var/media/ftp/USB-FlashDisk-01' announced - (skip install; send trigger: msgsend ctlmgr check-plugins)
DSL LINE FAIL: debug information
DSL[00]: Error Code 0x0000
DSL[00]: SubError Code 0x00
DSL[00]: Fail Code 0x005A
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000001
dsl_daemon: new modem state 1
unlocking interrupts
Info: have to stop cat /dev/debug.
/etc/init.d/rc.S[105]: trigger: msgsend ctlmgr init-done
DSL: ++++++++++++++++ loading ADSL FW ++++++++++++++++++++
file path is /lib/modules/vinax_fw_adsl.bin
fw size is 0
DSL: loading firmware binary /lib/modules/vinax_fw_adsl.bin
DSL: firmware binary size 540916 bytes
[idle]: 16% (run 83%)
cat: read error: Broken pipe
/etc/init.d/rc.S[105]: trigger: msgsend ctlmgr check-plugins
mkdir: cannot create directory '/var/samba/private': File exists
Please press Enter to activate this console. Jan 1 01:01:03 capiotcp_server[1131]:
capiotcp_server - Version 0.1.01.05
TCP/UDP Port = 5031
MaxCntrl = 5
OffsetCntrl = 0
/sbin/start_plugin.sh[1132]: Plugins awaited: samba mini ntfs
/sbin/start_plugin.sh[1132]: Extract SOFTWARE-PLUGIN file:///data/plugins.update
ERROR file not found (ftp, file, http)
/sbin/start_plugin.sh[1132]: ACHTUNG: es ist ein Fehler aufgetreten.
/sbin/start_plugin.sh[1166]: Plugins awaited: samba mini ntfs
/sbin/start_plugin.sh[1166]: searching Mount Point ...
/sbin/start_plugin.sh[1166]read) found Mount Device: /dev/sdb1
/sbin/start_plugin.sh[1166]read) found Mount Point: /var/media/ftp/USB-FlashDisk-01
/sbin/start_plugin.sh[1166]: found Mount Point /var/media/ftp/USB-FlashDisk-01
/sbin/start_plugin.sh[1166]: Extract SOFTWARE-PLUGIN file:///var/media/ftp/USB-FlashDisk-01/FRITZ/plugins/plugins.update
./var/
./var/plugin-samba.image
./var/plugin-mediasrv.image
./var/plugin-ntfs.image
./var/install
./var/plugin-mini.image
./var/signature
/sbin/start_plugin.sh[1166]: Prepare SOFTWARE-PLUGIN mediasrv ...
/sbin/start_plugin.sh[1166]: Mount SOFTWARE-PLUGIN mediasrv ...
next free loop devive: /dev/loop0
/sbin/start_plugin.sh[1166]: Start SOFTWARE-PLUGIN mediasrv ...
Starte Mediaserver Plugin.
/sbin/start_plugin.sh[1166]: Prepare SOFTWARE-PLUGIN mini ...
/sbin/start_plugin.sh[1166]: Mount SOFTWARE-PLUGIN mini ...
/dev/loop0 on /var/plugin-mediasrv type squashfs (ro)
next free loop devive: /dev/loop1
/sbin/start_plugin.sh[1166]: Start SOFTWARE-PLUGIN mini ...
Starte Mini Plugin.
/sbin/start_plugin.sh[1166]: Prepare SOFTWARE-PLUGIN ntfs ...
/sbin/start_plugin.sh[1166]: Mount SOFTWARE-PLUGIN ntfs ...
/dev/loop1 on /var/plugin-mini type squashfs (ro)
next free loop devive: /dev/loop2
/sbin/start_plugin.sh[1166]: Start SOFTWARE-PLUGIN ntfs ...
Starte NTFS-3G Plugin.
/sbin/start_plugin.sh[1166]: Prepare SOFTWARE-PLUGIN samba ...
/sbin/start_plugin.sh[1166]: Mount SOFTWARE-PLUGIN samba ...
NTFS mount retry: /proc/bus/usb/001/003 sdev:sda
/dev/loop2 on /var/plugin-ntfs type squashfs (ro)
next free loop devive: /dev/loop3
/sbin/start_plugin.sh[1166]: Start SOFTWARE-PLUGIN samba ...
Starte Samba Plugin.
/sbin/start_plugin.sh[1166]: break usb_mount - plugins installed from /var/media/ftp/USB-FlashDisk-01
Jan 1 01:01:08 mediasrv[1219]: DEBUG: _db_intf_get_last_db_file: cannot open file: /etc/default/avm/mediapath/USB-DISK2-0-01/FRITZ/mediabox/mediaserver.db3
Jan 1 01:01:08 mediasrv[1219]: startup (Oct 13 2008 12:02:52)
DSL[00]: Device Start EVT - UsrRst, DrvState 1 --> 1
DSL[00]: Line in reset - block!
DSL[00]: VINAX line recovered.
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000100
dsl_daemon: new modem state 256
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000200
dsl_daemon: new modem state 512
NTFS mount retry: /proc/bus/usb/001/005 sdev:sdb
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000300
dsl_daemon: new modem state 768
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000380
dsl_daemon: new modem state 896
sCommand=DSL_CBS_LINE_STATE nLine=00 nLineState=00000801
dsl_daemon: new modem state 2049
Dec 14 23:30:18 telefon[976]: set initial telefon time from linux time to 23:30 14.12 2008!
