Heatpump reports Version 4.19
Using protocol definition from Robert Penz <[email protected]> and Jack Sleuters (Tested with LWZ 303/403 Sol, send me a line if it works on others too.)
{'fault10date': '00.00', 'fault07time': '00:00', 'fault08code': 0, 'fault06code': 0, 'number_of_faults': 0, 'collector_temp': 7.6, 'fault05time': '00:00', 'booster_dhw': 504, 'fault10code': 0, 'compressor_cooling': 0, 'fault02time': '00:00', 'return_temp': 27.5, 'outside_temp': 5.6, 'fault01time': '00:00', 'fault03time': '00:00', 'expel_speed_set': 60.0, 'fault09time': '00:00', 'fault02code': 0, 'dhw_temp': 43.0, 'p_nd': 3.93, 'fault01date': '00.00', 'dont_know_2_ausgang': 8200, 'vent_speed_set': 44.0, 'p_hd': 13.43, 'fault09date': '00.00', 'fault08date': '00.00', 'flow_temp_hc2': -60.0, 'fault04code': 0, 'dont_know_1': 5.8, 'hot_gas_temp': 77.4, 'fault03date': '00.00', 'fault04date': '00.00', 'fault08time': '00:00', 'fault06date': '00.00', 'fault09code': 0, 'fault05date': '00.00', 'evaporator_temp': -2.2999999999999997, 'fault03code': 0, 'extr_speed_actual': 16, 'compressor_heating': 2740, 'dont_know_3_status': 17, 'fault05code': 0, 'expel_speed_actual': 17, 'inside_temp': -60.0, 'flow_temp': 31.7, 'fault01code': 0, 'rel_humidity': 0.0, 'extr_speed_set': 44.0, 'fault10time': '00:00', 'fault04time': '00:00', 'fault02date': '00.00', 'dew_point_temp': 0.0, 'fault07code': 0, 'fault07date': '00.00', 'fault06time': '00:00', 'booster_heating': 411, 'condenser_temp': 33.2, 'compressor_dhw': 1241, 'vent_speed_actual': 32}
