[Edit frank_m24: Mehrere Beiträge zusammengefasst. Man kann seine Beiträge auch editieren.]
Beim bauen des aktuellesten freetz-trunks schleicht sich folgender Fehler ein:
[Beitrag 2:]
danke, jetzt gehts wieder!
[Beitrag 3:]
hier das nächste patch-problem:
applying patch file make/openntpd/patches/100-close_fds_before_ntp_dns.patch
patching file ntp.c
Hunk #1 FAILED at 116.
Hunk #2 succeeded at 125 (offset -17 lines).
1 out of 2 hunks FAILED -- saving rejects to file ntp.c.rej
ERROR: modpatch: Error in patch-file make/openntpd/patches/100-close_fds_before_ntp_dns.patch
make: *** [source/target-mipsel_uClibc-0.9.29/openntpd-3.9p1/.unpacked] Fehler 2
[Beitrag 2:]
[Beitrag 3:]
removing AVM inetd
rm build/modified/filesystem/bin/inetdctl
rm build/modified/filesystem/etc/inetd.conf
patching build/modified/filesystem/etc/init.d/rc.S
applying patch file ./patches/260-remove_tr069.sh
applying patch file ./patches/270-remove_usb_module.sh
applying patch file ./patches/275-multiple_printers.sh
adding support for multiple printers
patching build/modified/filesystem/usr/www/avm/html/de/usb/status.js
/home/xsapling/freetz-stable/freetz-usb-root-replace/./tools/freetz_patch: line 68: ./md5sum: No such file or directory
ERROR: modpatch: No matching patch found in ./patches/cond/275-multiple_printers/
make: *** [firmware-nocompile] Fehler 2
