root@fritz:/var/mod/root# /mod/sbin/strace openvpn --version
execve("/usr/sbin/openvpn", ["openvpn", "--version"], [/* 216 vars */]) = 0
old_mmap(NULL, 20, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaad000
open("/home/freetz/freetz-stable/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libssl.so.0.9.8", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libssl.so.0.9.8", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libssl.so.0.9.8", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=212456, ...}) = 0
old_mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aaae000
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\320{\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 262144, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aabe000
old_mmap(0x2aabe000, 184516, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aabe000
old_mmap(0x2aafc000, 7936, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2e000) = 0x2aafc000
close(3) = 0
munmap(0x2aaae000, 4096) = 0
open("/home/freetz/freetz-stable/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libcrypto.so.0.9.8", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libcrypto.so.0.9.8", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libcrypto.so.0.9.8", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0755, st_size=1043676, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\320\221\2\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 1015808, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2aafe000
old_mmap(0x2aafe000, 877804, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2aafe000
old_mmap(0x2abe4000, 64688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0xd6000) = 0x2abe4000
old_mmap(0x2abf4000, 6960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x2abf4000
close(3) = 0
open("/home/freetz/freetz-stable/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/libdl.so.0", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/libdl.so.0", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0777, st_size=9444, ...}) = 0
read(3, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\10\0\1\0\0\0\220\7\0\0004\0\0\0"..., 4096) = 4096
old_mmap(NULL, 77824, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x2abf6000
old_mmap(0x2abf6000, 6128, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED, 3, 0) = 0x2abf6000
old_mmap(0x2ac07000, 4200, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1000) = 0x2ac07000
close(3) = 0
open("/home/freetz/freetz-stable/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/usr/lib/liblzo2.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/mod/lib/liblzo2.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/lib/liblzo2.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/lib/liblzo2.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
open("/usr/X11R6/lib/liblzo2.so.2", O_RDONLY) = -1 ENOENT (No such file or directory)
write(2, "", 0) = 0
write(2, "openvpn", 7openvpn) = 7
write(2, ": can't load library '", 22: can't load library ') = 22
write(2, "liblzo2.so.2", 12liblzo2.so.2) = 12
write(2, "'\n", 2'
) = 2
exit(16) = ?
