BMU GIGE clock
Slave Mem Alloc: Req size 32 Ptr2Block 0x191f0000
Load into BM APU Successful !!!
Timers are getting initalized
Timers are initilized SUCCESSFULLY...
periApDriverInit: doneSlave Mem Alloc: Req size 32 Ptr2Block 0x191f0020
*******LOAD firmware to AP:PERI_ID result:0Load into PERI_AP APU Successful !!!
cpmac0: Netpro Sierra Ethernet found at 0xb9110000, irq 14
GIGE 1 clock dev->baseAddr b9110000
Setting unknown egress to SPA
Slave Mem Alloc: Req size 32 Ptr2Block 0x191f0040
Ethernet Driver is initialized SUCCESSFULLY
ACL-AP is initializing...
ACL major allocated is 201
Slave Mem Alloc: Req size 32 Ptr2Block 0x191f0060
Configuring host ACL Layer-2 ruleset (128/4 Rules/Intf)
Intf Addr
0 07a88000
1 07a88e00
2 07a89c00
3 07a8aa00
Configuring host ACL Layer-3 ruleset (128/4 Rules/Intf)
Intf Addr
0 07ac0000
1 07ac0e00
2 07ac1c00
3 07ac2a00
Load into ACL_AP APU Successful !!!
Need to run mknod ...
bmedrv_init: Registered BME device with Major number 247
Request Region 0xa6000000 - 0xa67fffff
bmedrv_init: Region 0xa6000000 - 0xa67fffff allocated successfully
BME Driver has been loaded SUCCESSFULLY
yaffs: dev is 32505862 name is "mtdblock6" rw
yaffs: passed flags ""
yaffs: yaffs: Attempting MTD mount of 31.6,"mtdblock6"
yaffs: yaffs_read_super: is_checkpointed 1
[avm_debug]standard kernel-messages
[piglet]use gpio-settings for 156
patch_dectfw: c138c000, totallen = 70047(1119f)
patch_dectfw: patch_adress: f1038 max_len: 26 with Version 2 Len: 17
dect_loader: fast-bootmode
dect144xx_file_process: upload of '/lib/modules/dectfw_secondlevel_488.hex' succ
essfull
[piglet]bitfile '/lib/modules/bitfile.bit'
[piglet] try to preload in progress-context: /lib/modules/bitfile.bit
[piglet] bitfile 169309 bytes done
[piglet] "wyatt_earp_unload_xilinx" loaded
[pcmlink]svn: 1525
system-load 6 curr: busybox runnable: 2
driver params overwritten io_addr=0x0 irq_num=0
[pcmlink]chrony-support
[adsp_load] file loaded svnVersion 34
PCMLINK-Version(Fusiv): 6.1525 - dsp: 34 time 14:06:55 date Feb 27 2012
capicodec_init()
[capi_codec] support fax
[capi_codec] support Codecs
dect_uicp_from_dect, ignore 8 bytes, dect_manager not up: 2F7B
ramzswap: /dev/ramzswap0 initialized: disksize_kb=16384<6>Adding 16376k swap on
/dev/ramzswap0. Priority:-1 extents:1 across:16376k
dect_uicp_from_dect, ignore 16 bytes, dect_manager not up: F614
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: Ikanos On-Chip EHCI Host Controller
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: new USB bus registered, assigned bus number
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: irq 35, io mem 0x19230000
ikf68xx-ehci-hcd ikf68xx-ehci-hcd.0: USB 0.0 started, EHCI 1.00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
avm_net_trace: New net trace device 'usb1' registered with minor 161.
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
drivers/usb/host/ohci-ikf68xx.c: Probing USB OHCI
drivers/usb/host/ohci-ikf68xx.c: starting IKF68XX OHCI USB Host Controller
drivers/usb/host/ohci-ikf68xx.c: Clock to USB host has been enabled
ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: Ikanos On-Chip OHCI Host Controller
ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: new USB bus registered, assigned bus number
2
ikf68xx-ohci-hcd ikf68xx-ohci-hcd.0: irq 35, io mem 0x19240800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
avm_net_trace: New net trace device 'usb2' registered with minor 162.
system-load 7 curr: ar7cfgctl runnable: 2
dect_uicp_from_dect, ignore 8 bytes, dect_manager not up: 2FE7
kdsldmod: init start (Feb 27 2012 14:15:35) sizeof(struct sk_buff)=536
kdsldmod: init done
dect_uicp_from_dect, ignore 9 bytes, dect_manager not up: 2FD4
eth: port 0 status 2 throttle 0
eth: port 1 status 1 throttle 1
eth: port 2 status 1 throttle 1
eth: port 3 status 1 throttle 1
ADDRCONF(NETDEV_UP): eth0: link is not ready
device eth0 entered promiscuous mode
device cpmac0 entered promiscuous mode
[wlan_eeprom] calibration data blocks found = 2
[wlan_eeprom] Got calibration data version 255 for instance #1
[wlan_eeprom] Using complete eeprom from flash
[wlan_eeprom] Got calibration data version 255 for instance #2
system-load 100 % curr: dsld runnable: 6
AVM_WATCHDOG: System Init UEberwachung abgeschlossen (518730 ms noch verfuegbar)
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=
100 act_rate=100 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_ra
te=100 act_rate=100 mul=0 div=1 offset=3500 NormP=3500 mW -> SumNormP=3500 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=
100 act_rate=100 mul=0 div=1 offset=1500 NormP=1500 mW -> SumNormP=5000 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=
100 act_rate=100 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=5273 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=20
0 act_rate=0 mul=141 div=10 offset=100 NormP=2920 mW -> SumNormP=8193 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=10
0 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=8293 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=10
0 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=8393 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100
act_rate=100 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=9333 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=
500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=12083 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host2: norm_power_rate
=500 act_rate=0 mul=55 div=10 offset=0 NormP=2750 mW -> SumNormP=14833 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100
act_rate=0 mul=200 div=78 offset=150 NormP=406 mW -> SumNormP=15239 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 a
ct_rate=0 mul=15 div=1 offset=0 NormP=1500 mW -> SumNormP=16739 mW
[avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=
467 act_rate=160 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=17256 mW
SysRq : Changing Loglevel
Loglevel set to 4
ath_hal: 0.9.17.1 (AR5212, AR5416, RF5111, RF5112, RF2413, RF5413, RF2316, RF231
7, REGOPS_FUNC, WRITE_EEPROM, 11D)
ath_rate_atheros: Copyright (c) 2001-2005 Atheros Communications, Inc, All Right
s Reserved
ath_spectral: Version 2.0.0
Copyright (c) 2005-2009 Atheros Communications, Inc. All Rights Reserved
SPECTRAL module built on Feb 24 2012 13:42:08
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_dev: Copyright (c) 2001-2007 Atheros Communications, Inc, All Rights Reserve
d
system-load 100 % curr: ctlmgr runnable: 9
ath_pci: 9.2.0_U7.717 (Atheros/multi-bss)
PCI: Enabling device 0000:00:01.0 (0000 -> 0002)
dfs_attach: use DFS enhancements
DFS min filter rssiThresh = 15
DFS max pulse dur = 151 ticks
ath_get_caps[4921] rx chainmask mismatch actual 3 sc_chainmak 0
ath_get_caps[4896] tx chainmask mismatch actual 3 sc_chainmak 0
ic_num_chains=2x2
_avm_ath_ext_attach_ah:65
_avm_ath_ext_attach_ieee:47
Using WLAN static memory @0x05f2c000
avm_net_trace: New net trace device 'HW (2.4 + 5 GHz, wifi0)' registered with mi
nor 128.
wifi0: Atheros ???: mem=0x1a000000, irq=25 hw_base=0xba000000
PCI: Enabling device 0000:00:02.0 (0000 -> 0002)
ic_num_chains=2x2
avm_net_trace: New net trace device 'HW2 (2.4 + 5 GHz, wifi1)' registered with m
inor 129.
wifi1: Atheros ???: mem=0x1a010000, irq=25 hw_base=0xba010000
userman: LAN Client Internet-Accounting and Blocking
userman: device registerd with major=228
userman: init ok
system-load 100 % curr: upnpd runnable: 5
wlan_vap_create : enter. devhandle=0x834583a0, opmode=IEEE80211_M_HOSTAP, flags=
0x1
wlan_vap_create : exit. devhandle=0x834583a0, opmode=IEEE80211_M_HOSTAP, flags=0
x1.
avm_net_trace: New net trace device 'AP (2.4 + 5 GHz, ath0)' registered with min
or 130.
or 131.
VAP device ath0 created
ieee80211_ioctl_siwmode: imr.ifm_active=131712, new mode=3, valid=1
wlan_vap_create : enter. devhandle=0x846f83a0, opmode=IEEE80211_M_HOSTAP, flags=
0x1
wlan_vap_create : exit. devhandle=0x846f83a0, opmode=IEEE80211_M_HOSTAP, flags=0
x1.
avm_net_trace: New net trace device 'AP2 (2.4 + 5 GHz, ath1)' registered with mi
nor 136.
nor 137.
VAP device ath1 created
ieee80211_ioctl_siwmode: imr.ifm_active=66176, new mode=3, valid=1
device ath0 entered promiscuous mode
lan: topology change detected, propagating
lan: port 2(ath0) entering forwarding state
device ath1 entered promiscuous mode
lan: port 3(ath1) entering forwarding state
VDSL AP and VDSL PHY clocks are enabled
vdsl: Netpro VDSL Ethernet found at 0x0, irq 36
User parameters for VDSL AP configured successfully
Slave Mem Alloc: Req size 32 Ptr2Block 0x191f0080
VDSL AP started successfully
default parameters configured successfully
VDSL Driver is initialized SUCCESSFULLY
device vdsl entered promiscuous mode
userman: device registerd (userman_url) with major=241
kdsld_token_thread: start
sch_llq: Feb 27 2012 14:07:14
usbcore: registered new interface driver iowarrior
/proc/tffs: info request: success
hub 1-0:1.0: unable to enumerate USB device on port 2
usb 2-2: new low speed USB device using ikf68xx-ohci-hcd and address 2
Port#2 config: AVM Powermeter changed to 500 mA
usb 2-2: configuration #1 chosen from 1 choice
iowarrior 2-2:1.0: IOWarrior product=0x1501, serial=000030DF interface=0 now att
ached to iowarrior0
iowarrior 2-2:1.1: IOWarrior product=0x1501, serial=000030DF interface=1 now att
ached to iowarrior1
iowarrior 2-2:1.0: I/O-Warror #0 now disconnected
iowarrior 2-2:1.1: I/O-Warror #1 now disconnected
usb 2-2: reset low speed USB device using ikf68xx-ohci-hcd and address 2
usb 2-2: USB disconnect, address 2
Port#2 disconnect: AVM Powermeter changed to 0 mA
usb 2-2: new low speed USB device using ikf68xx-ohci-hcd and address 3
ached to iowarrior0
ached to iowarrior1
usb 2-2: reset low speed USB device using ikf68xx-ohci-hcd and address 3
usb 2-2: USB disconnect, address 3
avm_pa: telephony active
avm_pa: telephony inactive
usb 2-2: new low speed USB device using ikf68xx-ohci-hcd and address 4
ached to iowarrior0
ached to iowarrior1
usb 2-2: reset low speed USB device using ikf68xx-ohci-hcd and address 4
usb 2-2: USB disconnect, address 4
usb 2-2: new low speed USB device using ikf68xx-ohci-hcd and address 5
ached to iowarrior0
ached to iowarrior1
usb 2-2: reset low speed USB device using ikf68xx-ohci-hcd and address 5
usb 2-2: USB disconnect, address 5
usb 2-2: new low speed USB device using ikf68xx-ohci-hcd and address 6
ached to iowarrior0
ached to iowarrior1
usb 2-2: reset low speed USB device using ikf68xx-ohci-hcd and address 6
root@fritz:/var/mod/root#
