/var/media/ftp/uStor00 # igmpproxy -vv -d igmp.conf
Searching for config file at 'igmp.conf'
Config: Quick leave mode enabled.
Config: Got a phyint token.
Config: IF: Config for interface nas0.
Config: IF: Got upstream token.
Config: IF: Got ratelimit token '0'.
Config: IF: Got threshold token '1'.
Config: IF: Got altnet token 85.183.255.0/24.
Config: IF: Altnet: Parsed altnet to 85.183.255/24.
IF name : nas0
Next ptr : 0
Ratelimit : 0
Threshold : 1
State : 1
Allowednet ptr : 419f30
Config: IF: Config for interface lan.
Config: IF: Got downstream token.
IF name : lan
Next ptr : 0
Ratelimit : 0
Threshold : 1
State : 2
Allowednet ptr : 0
Config: IF: Config for interface lan:0.
Config: IF: Got disabled token.
IF name : lan:0
Next ptr : 0
Ratelimit : 0
Threshold : 1
State : 0
Allowednet ptr : 0
Config: IF: Config for interface dsl.
IF name : dsl
Next ptr : 0
Ratelimit : 0
Threshold : 1
State : 0
Allowednet ptr : 0
Config: IF: Config for interface lo.
IF name : lo
Next ptr : 0
Ratelimit : 0
Threshold : 1
State : 0
Allowednet ptr : 0
buildIfVc: Interface lo Addr: 127.0.0.1, Flags: 0x0049, Network: 127/8
buildIfVc: Interface lan Addr: 192.168.0.253, Flags: 0x1243, Network: 192.168.0/ 24
buildIfVc: Interface lan:0 Addr: 169.254.1.1, Flags: 0x1243, Network: 169.254/16
buildIfVc: Interface dsl Addr: 169.254.2.1, Flags: 0x10d1, Network: 169.254.2.1/ 32
buildIfVc: Interface nas0 Addr: 10.26.53.12, Flags: 0x1043, Network: 10.26.53.12 /30
Found config for lan
Found config for lan:0
Found config for dsl
Found config for nas0
adding VIF, Ix 0 Fl 0x0 IP 0xfd00a8c0 lan, Threshold: 1, Ratelimit: 0
Network for [lan] : 192.168.0/24
adding VIF, Ix 1 Fl 0x0 IP 0x0101fea9 lan:0, Threshold: 1, Ratelimit: 0
Network for [lan:0] : 169.254/16
adding VIF, Ix 2 Fl 0x0 IP 0x0102fea9 dsl, Threshold: 1, Ratelimit: 0
Network for [dsl] : 169.254.2.1/32
adding VIF, Ix 3 Fl 0x0 IP 0x0c351a0a nas0, Threshold: 1, Ratelimit: 0
Network for [nas0] : 10.26.53.12/30
Network for [nas0] : 85.183.255/24
Got 262144 byte buffer size in 0 iterations
Joining all-routers group 224.0.0.2 on vif 192.168.0.253
joinMcGroup: 224.0.0.2 on lan
SENT Membership query from 192.168.0.253 to 224.0.0.1
Sent membership query from 192.168.0.253 to 224.0.0.1. Delay: 10
Created timeout 1 (#0) - delay 10 secs
(Id:1, Time:10)
Created timeout 2 (#1) - delay 21 secs
(Id:1, Time:10)
(Id:2, Time:21)
RECV Membership query from 192.168.0.253 to 224.0.0.1
RECV V2 member report from 192.168.0.253 to 224.0.0.2
The IGMP message was from myself. Ignoring.
RECV V2 member report from 192.168.0.253 to 239.255.255.250
The source address 192.168.0.253 for group 239.255.255.250, is not in any valid net for upstream VIF.
RECV V2 member report from 192.168.0.1 to 228.10.31.1
Should insert group 228.10.31.1 (from: 192.168.0.1) to route table. Vif Ix : 0
No existing route for 228.10.31.1. Create new.
No routes in table. Insert at beginning.
Inserted route table entry for 228.10.31.1 on VIF #0
Joining group 228.10.31.1 upstream on IF address 10.26.53.12
joinMcGroup: 228.10.31.1 on nas0
Current routing table (Insert Route):
#0: Src: 0.0.0.0, Dst: 228.10.31.1, Age:2, St: I, OutVifs: 0x00000001
RECV V2 member report from 192.168.0.1 to 228.10.51.1
Should insert group 228.10.51.1 (from: 192.168.0.1) to route table. Vif Ix : 0
No existing route for 228.10.51.1. Create new.
Found existing routes. Find insert location.
Inserting after route 228.10.31.1
Inserted route table entry for 228.10.51.1 on VIF #0
Joining group 228.10.51.1 upstream on IF address 10.26.53.12
joinMcGroup: 228.10.51.1 on nas0
#1: Src: 0.0.0.0, Dst: 228.10.51.1, Age:2, St: I, OutVifs: 0x00000001
RECV V2 member report from 192.168.0.1 to 228.10.41.1
Should insert group 228.10.41.1 (from: 192.168.0.1) to route table. Vif Ix : 0
No existing route for 228.10.41.1. Create new.
Inserted route table entry for 228.10.41.1 on VIF #0
Joining group 228.10.41.1 upstream on IF address 10.26.53.12
joinMcGroup: 228.10.41.1 on nas0
#1: Src: 0.0.0.0, Dst: 228.10.41.1, Age:2, St: I, OutVifs: 0x00000001
#2: Src: 0.0.0.0, Dst: 228.10.51.1, Age:2, St: I, OutVifs: 0x00000001
RECV V2 member report from 192.168.0.1 to 228.10.56.1
Should insert group 228.10.56.1 (from: 192.168.0.1) to route table. Vif Ix : 0
No existing route for 228.10.56.1. Create new.
Inserting after route 228.10.51.1
Inserted route table entry for 228.10.56.1 on VIF #0
Joining group 228.10.56.1 upstream on IF address 10.26.53.12
joinMcGroup: 228.10.56.1 on nas0
#3: Src: 0.0.0.0, Dst: 228.10.56.1, Age:2, St: I, OutVifs: 0x00000001
The source address 192.168.0.1 for group 228.10.56.1, is not in any valid net for upstream VIF.
About to call timeout 1 (#0)
Aging routes in table.
Current routing table (Age active routes):
#0: Src: 0.0.0.0, Dst: 228.10.31.1, Age:1, St: I, OutVifs: 0x00000001
#1: Src: 0.0.0.0, Dst: 228.10.41.1, Age:1, St: I, OutVifs: 0x00000001
#2: Src: 0.0.0.0, Dst: 228.10.51.1, Age:1, St: I, OutVifs: 0x00000001
#3: Src: 0.0.0.0, Dst: 228.10.56.1, Age:1, St: I, OutVifs: 0x00000001
RECV V2 member report from 192.168.0.128 to 233.51.128.24
Should insert group 233.51.128.24 (from: 192.168.0.128) to route table. Vif Ix : 0
No existing route for 233.51.128.24. Create new.
Inserting after route 228.10.56.1
Inserted route table entry for 233.51.128.24 on VIF #0
Joining group 233.51.128.24 upstream on IF address 10.26.53.12
joinMcGroup: 233.51.128.24 on nas0
#4: Src: 0.0.0.0, Dst: 233.51.128.24, Age:2, St: I, OutVifs: 0x00000001
Updated route entry for 233.51.128.24 on VIF #0
The source address 192.168.0.1 for group 228.10.31.1, is not in any valid net for upstream VIF.
The source address 192.168.0.1 for group 228.10.51.1, is not in any valid net for upstream VIF.
About to call timeout 2 (#0)
Created timeout 3 (#0) - delay 10 secs
(Id:3, Time:10)
Created timeout 4 (#1) - delay 21 secs
(Id:3, Time:10)
(Id:4, Time:21)
RECV V2 member report from 192.168.0.128 to 239.255.255.250
Should insert group 239.255.255.250 (from: 192.168.0.128) to route table. Vif Ix : 0
No existing route for 239.255.255.250. Create new.
Inserting after route 233.51.128.24
Inserted route table entry for 239.255.255.250 on VIF #0
Joining group 239.255.255.250 upstream on IF address 10.26.53.12
joinMcGroup: 239.255.255.250 on nas0
#5: Src: 0.0.0.0, Dst: 239.255.255.250, Age:2, St: I, OutVifs: 0x00000001
The source address 192.168.0.128 for group 239.255.255.250, is not in any valid net for upstream VIF.
Updated route entry for 228.10.31.1 on VIF #0
Updated route entry for 228.10.56.1 on VIF #0
Updated route entry for 228.10.51.1 on VIF #0
About to call timeout 3 (#0)
Removing group 228.10.41.1. Died of old age.
Removed route entry for 228.10.41.1 from table.
Route is not active. No kernel updates done.
Leaving group 228.10.41.1 upstream on IF address 10.26.53.12
leaveMcGroup: 228.10.41.1 on nas0
Current routing table (Remove route):
#1: Src: 0.0.0.0, Dst: 228.10.51.1, Age:1, St: I, OutVifs: 0x00000001
#2: Src: 0.0.0.0, Dst: 228.10.56.1, Age:1, St: I, OutVifs: 0x00000001
#3: Src: 0.0.0.0, Dst: 233.51.128.24, Age:2, St: I, OutVifs: 0x00000001
#4: Src: 0.0.0.0, Dst: 239.255.255.250, Age:2, St: I, OutVifs: 0x00000001
#2: Src: 0.0.0.0, Dst: 228.10.56.1, Age:2, St: I, OutVifs: 0x00000001
#4: Src: 0.0.0.0, Dst: 239.255.255.250, Age:1, St: I, OutVifs: 0x00000001
#5: Src: 0.0.0.0, Dst: 239.255.255.250, Age:1, St: I, OutVifs: 0x00000001
The source address 192.168.0.1 for group 228.10.41.1, is not in any valid net for upstream VIF.
About to call timeout 4 (#0)
Created timeout 5 (#0) - delay 10 secs
(Id:5, Time:10)
Created timeout 6 (#1) - delay 115 secs
(Id:5, Time:10)
(Id:6, Time:115)
Updated route entry for 228.10.41.1 on VIF #0
About to call timeout 5 (#0)
Removing group 239.255.255.250. Died of old age.
Removed route entry for 239.255.255.250 from table.
Leaving group 239.255.255.250 upstream on IF address 10.26.53.12
leaveMcGroup: 239.255.255.250 on nas0
