Tue Jul 23 15:15:20 2013 Successful ARP Flush on interface [2] {174F1F12-8BEB-4452-868F-EDCD63A68F86}
Tue Jul 23 15:15:25 2013 TEST ROUTES: 3/3 succeeded len=2 ret=1 a=0 u/d=up
Tue Jul 23 15:15:25 2013 C:\WINDOWS\system32\route.exe ADD 127.0.0.1 MASK 255.255.255.255 *.*.*.1
Tue Jul 23 15:15:25 2013 ROUTE: route addition failed using CreateIpForwardEntry: Falscher Parameter. [status=87 if_index=3]
Tue Jul 23 15:15:25 2013 Route addition via IPAPI failed [adaptive]
Tue Jul 23 15:15:25 2013 Route addition fallback to route.exe
Tue Jul 23 15:15:25 2013 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Tue Jul 23 15:15:25 2013 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 0.0.0.0 *.*.*.1
Tue Jul 23 15:15:25 2013 Route deletion via IPAPI succeeded [adaptive]
Tue Jul 23 15:15:25 2013 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 0.0.0.0 192.168.178.1
Tue Jul 23 15:15:25 2013 Route addition via IPAPI succeeded [adaptive]
Tue Jul 23 15:15:25 2013 MANAGEMENT: >STATE:1374585325,ADD_ROUTES,,,
Tue Jul 23 15:15:25 2013 C:\WINDOWS\system32\route.exe ADD 192.168.178.0 MASK 255.255.255.0 192.168.178.1
Tue Jul 23 15:15:25 2013 Initialization Sequence Completed
Tue Jul 23 15:15:25 2013 MANAGEMENT: >STATE:1374585325,CONNECTED,SUCCESS,192.168.178.100,127.0.0.1
Tue Jul 23 15:15:46 2013 Connection reset, restarting [0]
Tue Jul 23 15:15:46 2013 SIGUSR1[soft,connection-reset] received, process restarting
Tue Jul 23 15:15:46 2013 MANAGEMENT: >STATE:1374585346,RECONNECTING,connection-reset,,
Tue Jul 23 15:15:46 2013 Restart pause, 5 second(s)
Tue Jul 23 15:15:51 2013 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Jul 23 15:15:51 2013 Socket Buffers: R=[8192->8192] S=[8192->8192]
Tue Jul 23 15:15:51 2013 MANAGEMENT: >STATE:1374585351,RESOLVE,,,
Tue Jul 23 15:15:51 2013 Attempting to establish TCP connection with [AF_INET]127.0.0.1:3128
Tue Jul 23 15:15:51 2013 MANAGEMENT: >STATE:1374585351,TCP_CONNECT,,,
Tue Jul 23 15:15:51 2013 TCP connection established with [AF_INET]127.0.0.1:3128
Tue Jul 23 15:15:51 2013 Send to HTTP proxy: 'CONNECT *:* HTTP/1.0'
Tue Jul 23 15:15:56 2013 C:\WINDOWS\system32\route.exe DELETE 192.168.178.0 MASK 255.255.255.0 192.168.178.1
Tue Jul 23 15:15:56 2013 Route deletion via IPAPI succeeded [adaptive]
Tue Jul 23 15:15:56 2013 ROUTE: route deletion failed using DeleteIpForwardEntry: Falscher Parameter.
Tue Jul 23 15:15:56 2013 Route deletion via IPAPI failed [adaptive]
Tue Jul 23 15:15:56 2013 Route deletion fallback to route.exe
Tue Jul 23 15:15:56 2013 env_block: add PATH=C:\Windows\System32;C:\WINDOWS;C:\WINDOWS\System32\Wbem
Tue Jul 23 15:15:56 2013 C:\WINDOWS\system32\route.exe DELETE 127.0.0.1 MASK 255.255.255.255 *.*.*.1
Tue Jul 23 15:15:56 2013 C:\WINDOWS\system32\route.exe DELETE 0.0.0.0 MASK 0.0.0.0 192.168.178.1
Tue Jul 23 15:15:56 2013 C:\WINDOWS\system32\route.exe ADD 0.0.0.0 MASK 0.0.0.0 *.*.*.1
Tue Jul 23 15:15:56 2013 Route addition via IPAPI succeeded [adaptive]
Tue Jul 23 15:15:56 2013 Closing TUN/TAP interface
Tue Jul 23 15:15:56 2013 SIGTERM[hard,init_instance] received, process exiting
Tue Jul 23 15:15:56 2013 MANAGEMENT: >STATE:1374585356,EXITING,init_instance,,
