- Mitglied seit
- 28 Jul 2005
- Beiträge
- 451
- Punkte für Reaktionen
- 0
- Punkte
- 0
Moin Jungs,
so, hier die Mittschnitte beim Flashen und Starten der original Firmware 10.03.94.
Komischerweise meckert er dort auch die Checksumme an, aber daran wird wohl der falsche Eintrag in der install schuld sein.
Flashen der 10.03.94
Booten der 10.03.94
HS
/var/copy_firmware: copy /var/tmp/kernel.image to /dev/mtdblock/1
programming: ...........
/var/copy_firmware: write 1310720 0xFF to end of mtd
/var/copy_firmware: write error 0 errno 28
closing: /dev/mtdblock/1
check firmware on: /dev/mtdblock/1 check firmware /dev/mtdblock/1 success /var/c
opy_firmware: successful!
/var/copy_firmware: copy /var/tmp/filesystem.image to /dev/mtdblock/0
programming: ....................
/var/copy_firmware: write 6144 0xFF to end of mtd
closing: /dev/mtdblock/0
check firmware on: /dev/mtdblock/0 check firmware /dev/mtdblock/0 success /var/c
/var/post_install: done
reboot now ...
Booten der 10.03.94
ADAM2 Revision TI:0.18.01 AVM:
(C) Copyright 1996-2003 Texas Instruments Inc. All Rights Reserved.
(C) Copyright 2003 Telogy Networks, Inc.
(C) Copyright 2003-2004 AVM
AVM_Ar7 >
Press any key to abort OS load, or wait 5 seconds for OS to boot...
Launching kernel decompressor.
Kernel decompressor was successful ... launching kernel.
LINUX started...
Config serial console: ttyS0,38400
This SOC has MDIX cababilities on chip: HWRevision="F"
AutoMDIX="<unknown>"
MDIX disabled.
init started: BusyBox v1.00-pre3 (2005.08.18-13:20+0000) multi-call bi
init started: BusyBox v1.00-pre3 (2005.08.18-13:20+0000) multi-call binary
Starting pid 11, console /dev/tts/0: '/etc/init.d/rc.S'
**** adam2 environment ****
HWRevision F
ProductID Fritz_Box_2MB
SerialNumber 0000000000000000
annex B
autoload yes
bootloaderVersion 0.18.01
bootserport tty0
bluetooth 00:04:0E:FF:FF:07
cpufrequency 150000000
firstfreeaddress 0x94730258
firmware_version avm
firmware_info 10.03.94
flashsize 0x00200000
maca 00:04:0E:2E:7F:D5
macb 00:04:0E:FF:FF:02
macwlan 00:04:0E:FF:FF:03
macdsl 00:04:0E:2E:7F:D6
memsize 0x00800000
modetty0 38400,n,8,1,hw
modetty1 38400,n,8,1,hw
mtd0 0x900B0000,0x901F0000
mtd1 0x90010000,0x900B0000
mtd2 0x90000000,0x90010000
mtd3 0x901F0000,0x901F8000
mtd4 0x901F8000,0x90200000
my_ipaddress 192.168.178.2
prompt AVM_Ar7
reserved 00:04:0E:FF:FF:00
req_fullrate_freq 125000000
sysfrequency 125000000
urlader-version 97
usb_board_mac 00:04:0E:2E:7F:D7
usb_rndis_mac 00:04:0E:2E:7F:D8
usb_device_id 0x3701
usb_revision_id 0x0100
usb_device_name USB DSL Device
usb_manufacturer_name AVM
HS
