Hmm, cuma, Du?Das 180 Patch-Script ist um ...
Und wozu hat man ihn bebötigt?Da es eine ganz neue Kernelversion ist kann es sein dass der 170 Kernelpatch überflüssig ist
[14580.190000] kdsld: kdsld_vcc_preunregister: *
[14583.460000] AVM_WATCHDOG_disable()
[14585.590000] SQUASHFS error: Major/Minor mismatch, older Squashfs 0.0 filesystems are unsupported
[14592.650000] [avm_urlader_env_set_variable] opening ID 0x198 for writing
[14592.740000] SysRq : Emergency Sync
[14592.750000] SysRq : Emergency Remount R/O
[14596.280000] [avm_power] PowerManagmentRelease(0x8f139b80)
[14596.590000] __gmac_dev_event: ath0: 0x9 (NETDEV_GOING_DOWN), pid=3844 (hostapd)
[14596.640000] __gmac_dev_event: ath0: 0x2 (NETDEV_DOWN), pid=3844 (hostapd)
[14597.180000] __gmac_dev_event: ath1: 0x9 (NETDEV_GOING_DOWN), pid=3844 (hostapd)
[14597.230000] __gmac_dev_event: ath1: 0x2 (NETDEV_DOWN), pid=3844 (hostapd)
[14598.420000] get_ul_manager: error: ll_handle= (null)
[14598.480000] [avm_power] PowerManagmentRelease(0x8f141680)
[14598.480000] Res
ROM VER: 1.1.4
CFG 05
** START
RVEC bf200000
(AVM) EVA Revision: 1.1964 Version: 2964
(C) Copyright 2005 AVM Date: Nov 27 2013 Time: 14:33:10 (1) 3 0x0-0x740D
[FLASH:] MACRONIX Uniform-Flash 1MB 256 Bytes WriteBuffer
[FLASH:](Eraseregion [0] 16 sectors a 64kB)
[NAND:] 512MB MICRON 2048 Pagesize 128k Blocksize 4096 Blocks 8Bit 1 CS HW
[SYSTEM:] VR9 on 500MHz/250MHz/250MHz
.Atheros 8030/35 detected
Eva_AVM >##............................................................
Lantiq xDSL CPE VR9
phym = 10000000, mem = 10000000, max_pfn = 00010000
Reserving memory for CP1 @0xb0000000, size 0x00000000
[init_avm_kernel_config] AVM Kernel Config (ptr 80819000)
plat_device_tree_setup: AVM hardware subrevision 5
plat_device_tree_setup: Missing device-tree for AVM hardware subrevision 5
Lantiq xDSL CPE VR9
Lantiq xDSL CPE VR9
Damit wären wir dann bei der Frage, warum da im selbstgebauten Kernel an __avm_kernel_config_start offenbar gar kein Pointer auf weitere Einträge steht (dann würde Zeile 23/24 greifen und init_avm_kernel_config verlassen werden) oder warum bereits im allerersten Eintrag dort entweder ein vollkommen falsches Tag steht (dann greift das komplette "switch"-Statement ins Leere, wo ansonsten jeder beliebige Zweig zumindest eine Nachricht produziert) oder der Pointer ab Offset 4 an der Stelle, auf die der Pointer an __avm_kernel_config_start zeigt, bereits im allerersten Eintrag "NULL" ist (was dann zum Rücksprung in Zeile 27/28 führen würde).
if (p == NULL)
prom_printf("p is NULL\n");
return;
p is NULL
[COLOR="#0000FF"]~/avm$[/COLOR] [COLOR="#008000"]sha256sum source*[/COLOR]
242ac42d88027d9e3c2fc8dc8efbb28943eefdf8ba88b9f6da87ca3db4376251 source-files-FRITZ.Box_7490-06.30.tar.gz
dcc13f635bb280b6d63d194315a81ce94f4274a4647dd266c1561b89cf752d06 source-files-FRITZ.Box_7490-06.50.tar.gz
281eceab31b74947f1135b06cac0e8384258feac2c6bd9c847129405f4c64a0f source-files-FRITZ.Box_7490-06.51.tar.gz
--- 7490.06.51-v2-20160415_1026-kernel/linux-3.10/drivers/char/dect_io/init_dect_io
+++ 7490.06.51-v3-20160601_1118-kernel/linux-3.10/drivers/char/dect_io/init_dect_io
@@ -9,7 +9,7 @@
for i in `find . -name Makefile.$KERNEL_CLASS` ; do
dest=${i%.$KERNEL_CLASS}
- source="`pwd`/$i"
+ source="${i##*/}"
rm -f $dest
ln -fvs $source $dest
done
--- 7490.06.51-v2-20160415_1026-kernel/linux-3.10/drivers/char/flash_update/init_flash_update
+++ 7490.06.51-v3-20160601_1118-kernel/linux-3.10/drivers/char/flash_update/init_flash_update
@@ -9,7 +9,7 @@
- source="`pwd`/$i"
+ source="${i##*/}"
rm -f $dest
done
--- 7490.06.51-v2-20160415_1026-kernel/linux-3.10/drivers/isdn/avm_dect/init_avm_dect
+++ 7490.06.51-v3-20160601_1118-kernel/linux-3.10/drivers/isdn/avm_dect/init_avm_dect
@@ -9,7 +9,7 @@
- source="`pwd`/$i"
+ source="${i##*/}"
rm -f $dest
done
--- 7490.06.51-v2-20160415_1026-kernel/linux-3.10/drivers/isdn/isdn_fon5/init_isdn
+++ 7490.06.51-v3-20160601_1118-kernel/linux-3.10/drivers/isdn/isdn_fon5/init_isdn
@@ -9,7 +9,7 @@
- source="`pwd`/$i"
+ source="${i##*/}"
rm -f $dest
done
46c9c32a7a9381e881478025e1e951ee *7490.06.50-v1.tar.gz
431eb3938adf79b2a228b10004c6ba1f *7490.06.50-v2.tar.gz
8111e2da9808931cc7fdfb2ce8a4d242 *7490.06.50-v3.tar.gz
4ca0cb81f7525e359bfbeb1d86aa275d *7490.06.51-v1.tar.gz
96cf7c8b3e6a8cd156c7556543d2cc9f *7490.06.51-v2.tar.gz
491d599be71491e0072d4a62031860be *7490.06.51-v3.tar.gz
8d6468f9a2cf7d4f81bfd82ee380278c *7490.06.50-v1-20160109_0035/GPL/BSD-libflac.tar.gz
11df71503db113ebe37c6cd1233148c1 *7490.06.50-v1-20160109_0035/GPL/GPL-avmacllib2.tar.gz
9c94441bdb664d1f1ab409df80762e76 *7490.06.50-v1-20160109_0035/GPL/GPL-busybox.tar.gz
5b7da7941173fdd599e3bb1d332d9535 *7490.06.50-v1-20160109_0035/GPL/GPL-chrony.tar.gz
ee22c04b779bccb852a853e0e1e1c442 *7490.06.50-v1-20160109_0035/GPL/GPL-davfs2.tar.gz
02e9e15b322939a11aefea7e27e65878 *7490.06.50-v1-20160109_0035/GPL/GPL-ftpd.tar.gz
6042e6399bfc42da67168da75bc865eb *7490.06.50-v1-20160109_0035/GPL/GPL-gcc.tar.gz
850a7cef98cd189f4a202d2c1822174a *7490.06.50-v1-20160109_0035/GPL/GPL-lte_tools.tar.gz
fd842146c79c8ffdab886fa22839ca77 *7490.06.50-v1-20160109_0035/GPL/GPL-ntfs.tar.gz
3b3d9bbab998dfefa3ad35fc85b8e02c *7490.06.50-v1-20160109_0035/GPL/GPL-release_kernel.tar.gz
ebc19520b41e22b1e9f854563bc04d44 *7490.06.50-v1-20160109_0035/GPL/GPL-samba.tar.gz
2e47388e13b67b9adb74bf551f4b3ae0 *7490.06.50-v1-20160109_0035/GPL/GPL-usb_host_tools.tar.gz
883647c9d6d8857898a5cc638eab63f8 *7490.06.50-v1-20160109_0035/GPL/GPL-wlan.tar.gz
7c8c788b72969a5d4e7bb429f2304de6 *7490.06.50-v1-20160109_0035/GPL/LGPL-GPL-release_fon_tools.tar.gz
b5062e123ec837c4efff7dfbdbb45747 *7490.06.50-v1-20160109_0035/GPL/LGPL-GPL-release_target_tools.tar.gz
a65651503183e0408f1fb3854fab4771 *7490.06.50-v1-20160109_0035/GPL/LGPL-libexif.tar.gz
c6542af9b36cb83697a613c2d562a834 *7490.06.50-v1-20160109_0035/GPL/LGPL-libosip.tar.gz
d983cb8ac433915283c77ef985cbb557 *7490.06.50-v1-20160109_0035/GPL/LGPL-multimedia_fon.tar.gz
a47462b9c319c6aec0d28cbda042b75a *7490.06.50-v1-20160109_0035/GPL/LGPL-neon.tar.gz
8f6513e78eb0baea7d70306ce5eb8bf2 *7490.06.50-v1-20160109_0035/GPL/ZLIB-libz.tar.gz
78418073a293a277e622ed8e2533b60b *7490.06.50-v2-20160518_1613/GPL/BSD-libflac.tar.gz
4ead5a0da91ae3cc2d80b9a32131d9ee *7490.06.50-v2-20160518_1613/GPL/GPL-avmacllib2.tar.gz
dc11c4f340c1edaef87297aca85da62d *7490.06.50-v2-20160518_1613/GPL/GPL-bridge-utils.tar.gz
b3f48f322b65f139e0b427db90383039 *7490.06.50-v2-20160518_1613/GPL/GPL-busybox.tar.gz
31455200b17e171a55b72f57fc9da7be *7490.06.50-v2-20160518_1613/GPL/GPL-chrony.tar.gz
6094bfde5efd52c0069212df9db2a704 *7490.06.50-v2-20160518_1613/GPL/GPL-davfs2.tar.gz
0a4c6ac6fee7486848b6204c96e5b291 *7490.06.50-v2-20160518_1613/GPL/GPL-ftpd.tar.gz
3eb2aa81127c7a0db80938994843a5fa *7490.06.50-v2-20160518_1613/GPL/GPL-gcc.tar.gz
96db3708690ea55e4bca04a340934ee3 *7490.06.50-v2-20160518_1613/GPL/GPL-iproute2.tar.gz
70f20c902776c32137be7a2590d18c41 *7490.06.50-v2-20160518_1613/GPL/GPL-lte_tools.tar.gz
028211103467411bf4b013e0d37d16bb *7490.06.50-v2-20160518_1613/GPL/GPL-ntfs.tar.gz
a644d1809d6f5540191b48ad14a97d9e *7490.06.50-v2-20160518_1613/GPL/GPL-release_kernel.tar.gz
4bd298c51ff231d55710c08b989f4ee7 *7490.06.50-v2-20160518_1613/GPL/GPL-samba.tar.gz
f9af599f709ac548e36bb2dce685192c *7490.06.50-v2-20160518_1613/GPL/GPL-usb_host_tools.tar.gz
1ab5e834e22594d3d866107ece8bf336 *7490.06.50-v2-20160518_1613/GPL/GPL-wlan.tar.gz
04d5f0c26dffe7f923c685f754639656 *7490.06.50-v2-20160518_1613/GPL/LGPL-GPL-release_fon_tools.tar.gz
7efb36300575d7bcf39f12ad8ca22bb3 *7490.06.50-v2-20160518_1613/GPL/LGPL-GPL-release_target_tools.tar.gz
518d5c47587566c6927f5e7718b5d4dd *7490.06.50-v2-20160518_1613/GPL/LGPL-libexif.tar.gz
175b35ada0ca8469d69c733732f68360 *7490.06.50-v2-20160518_1613/GPL/LGPL-libosip.tar.gz
ed8f0170ab6a933cc4a6528f0eaa1808 *7490.06.50-v2-20160518_1613/GPL/LGPL-multimedia_fon.tar.gz
b79515bc2c20704e845ac825d3e805d1 *7490.06.50-v2-20160518_1613/GPL/LGPL-neon.tar.gz
d1f318a34b6edbf8c9607345e3def91a *7490.06.50-v2-20160518_1613/GPL/ZLIB-libz.tar.gz
97e3ff66543023187b454113bae0fd2f *7490.06.50-v3-20160601_1117/GPL/BSD-libflac.tar.gz
5f2bd8f21f5f2b421d316eafae6c7d23 *7490.06.50-v3-20160601_1117/GPL/GPL-avmacllib2.tar.gz
1ecb3953d9ee3ac9409ccb244e17b92a *7490.06.50-v3-20160601_1117/GPL/GPL-bridge-utils.tar.gz
5bfc1d5372b0e6dc8d850e49d34ef4fb *7490.06.50-v3-20160601_1117/GPL/GPL-busybox.tar.gz
1c6c61c4ba9c9ee2e66b1ef3e377dc46 *7490.06.50-v3-20160601_1117/GPL/GPL-chrony.tar.gz
e2018be7bd3f27b3758fa3ed9956f0c6 *7490.06.50-v3-20160601_1117/GPL/GPL-davfs2.tar.gz
98fa1baf464ef4d4e0c4f1c12f408a7f *7490.06.50-v3-20160601_1117/GPL/GPL-ftpd.tar.gz
0a7b2173108131f91d4a49f0c1096910 *7490.06.50-v3-20160601_1117/GPL/GPL-gcc.tar.gz
2086ea9971023150d461c22f8ed95f78 *7490.06.50-v3-20160601_1117/GPL/GPL-iproute2.tar.gz
de95d0e2794525054c0773658261ca59 *7490.06.50-v3-20160601_1117/GPL/GPL-lte_tools.tar.gz
9a385c81cd72a1f5cbc36bbd7fa5edfc *7490.06.50-v3-20160601_1117/GPL/GPL-ntfs.tar.gz
4868a53d72db7557694c8d2d1951b64f *7490.06.50-v3-20160601_1117/GPL/GPL-release_kernel.tar.gz
9e8d4ee67ba4dfcd0eae8287f86117a1 *7490.06.50-v3-20160601_1117/GPL/GPL-samba.tar.gz
411cbff8d199e3b2f82d68aebecd791b *7490.06.50-v3-20160601_1117/GPL/GPL-usb_host_tools.tar.gz
3f16a843345c2ae8caf2bd08587ae123 *7490.06.50-v3-20160601_1117/GPL/GPL-wlan.tar.gz
94003dc1ededdf012db0402cf79bb018 *7490.06.50-v3-20160601_1117/GPL/LGPL-GPL-release_fon_tools.tar.gz
17d358f8a923f87bc6fcf642ac1c8dde *7490.06.50-v3-20160601_1117/GPL/LGPL-GPL-release_target_tools.tar.gz
dedaa9d2f0ea649723f0a222357351a5 *7490.06.50-v3-20160601_1117/GPL/LGPL-libexif.tar.gz
dbab78591abc7f39e5e82e294b15e889 *7490.06.50-v3-20160601_1117/GPL/LGPL-libosip.tar.gz
a4420393d5def9b6750db4438788393f *7490.06.50-v3-20160601_1117/GPL/LGPL-multimedia_fon.tar.gz
ff06d75b3c6511f769ad514c5469eeda *7490.06.50-v3-20160601_1117/GPL/LGPL-neon.tar.gz
ce9fe4df1240f5b7ce9d6338e70fc992 *7490.06.50-v3-20160601_1117/GPL/ZLIB-libz.tar.gz
8ce3fc0720350eaf65a537f04e059ae0 *7490.06.51-v1-20160224_1141/GPL/BSD-libflac.tar.gz
0028c08c250ddcff31099aedf51ece3a *7490.06.51-v1-20160224_1141/GPL/GPL-avmacllib2.tar.gz
df7aab979aa6a4e100b60f4f19c24902 *7490.06.51-v1-20160224_1141/GPL/GPL-busybox.tar.gz
19552db2ec64e8d7623f4f735a39c782 *7490.06.51-v1-20160224_1141/GPL/GPL-chrony.tar.gz
d5f2ff974e229080fde7415ee0589343 *7490.06.51-v1-20160224_1141/GPL/GPL-davfs2.tar.gz
6ab84f60b07937f10ab79fe57f50a266 *7490.06.51-v1-20160224_1141/GPL/GPL-ftpd.tar.gz
da50bf2307148f6fdee1d95b3c355bb2 *7490.06.51-v1-20160224_1141/GPL/GPL-gcc.tar.gz
9853cd56cc77b09be6d14ea17a072f31 *7490.06.51-v1-20160224_1141/GPL/GPL-lte_tools.tar.gz
e0e58073f090dcfed7c4d4254bd31f95 *7490.06.51-v1-20160224_1141/GPL/GPL-ntfs.tar.gz
a40371df0a90570939143404dbb153a3 *7490.06.51-v1-20160224_1141/GPL/GPL-release_kernel.tar.gz
580431bc1d9b42b92ab495b4ee305187 *7490.06.51-v1-20160224_1141/GPL/GPL-samba.tar.gz
379f94e979637951d08c2b6c4e6d4259 *7490.06.51-v1-20160224_1141/GPL/GPL-usb_host_tools.tar.gz
1b700ddb025f11eae59782694bca77b0 *7490.06.51-v1-20160224_1141/GPL/GPL-wlan.tar.gz
a8f88fe384000bfed46233fd81a4122a *7490.06.51-v1-20160224_1141/GPL/LGPL-GPL-release_fon_tools.tar.gz
215a189240b44c811956afac523758ad *7490.06.51-v1-20160224_1141/GPL/LGPL-GPL-release_target_tools.tar.gz
9a14df35ce062b04730c233083b3d3dd *7490.06.51-v1-20160224_1141/GPL/LGPL-libexif.tar.gz
a868072c5133fcd234b75b5d155f6517 *7490.06.51-v1-20160224_1141/GPL/LGPL-libosip.tar.gz
f578d91f2f31b72e5cd2e7d78cfc3f93 *7490.06.51-v1-20160224_1141/GPL/LGPL-multimedia_fon.tar.gz
0489f7eef60c67bf71bdb8aeba05b7c1 *7490.06.51-v1-20160224_1141/GPL/LGPL-neon.tar.gz
940d6b8024d1e9d61ff17b65d2ce2157 *7490.06.51-v1-20160224_1141/GPL/ZLIB-libz.tar.gz
3700cf9111afc580e70293d3dec517e9 *7490.06.51-v2-20160415_1026/GPL/BSD-libflac.tar.gz
c1244b891d9cc388aaf3dab2c0ffa08f *7490.06.51-v2-20160415_1026/GPL/GPL-avmacllib2.tar.gz
c8d3dfa6dbdaf6405545db844565d007 *7490.06.51-v2-20160415_1026/GPL/GPL-bridge-utils.tar.gz
1ebb30ef0436ee5697759f2c265e04f1 *7490.06.51-v2-20160415_1026/GPL/GPL-busybox.tar.gz
0dd9e441d0bdc652815dd9f9e15fa99a *7490.06.51-v2-20160415_1026/GPL/GPL-chrony.tar.gz
be3edadd6aabae599fb88ecd076ef2ab *7490.06.51-v2-20160415_1026/GPL/GPL-davfs2.tar.gz
2c5d9c0762d1d28a787824d1dbb8372a *7490.06.51-v2-20160415_1026/GPL/GPL-ftpd.tar.gz
b5e9b6d8c418d0e7c47f04b29dca2bed *7490.06.51-v2-20160415_1026/GPL/GPL-gcc.tar.gz
73b521fd3c5c4d346b965d34cdd5ca72 *7490.06.51-v2-20160415_1026/GPL/GPL-iproute2.tar.gz
7742489ca817a49cc08b3f24523f6eab *7490.06.51-v2-20160415_1026/GPL/GPL-lte_tools.tar.gz
4294258a7a060e702d45126119c44fc1 *7490.06.51-v2-20160415_1026/GPL/GPL-ntfs.tar.gz
1600ba509bf5e4235f3a9bb1e9306535 *7490.06.51-v2-20160415_1026/GPL/GPL-release_kernel.tar.gz
b6f171c3cb06e01d51423fa5ea04e8de *7490.06.51-v2-20160415_1026/GPL/GPL-samba.tar.gz
c33bcbcb2f493f3d14b3c0b795ece81b *7490.06.51-v2-20160415_1026/GPL/GPL-usb_host_tools.tar.gz
6772794b509ab19275094052830015ba *7490.06.51-v2-20160415_1026/GPL/GPL-wlan.tar.gz
197fcbf6e68090f52edbaf20efbe055a *7490.06.51-v2-20160415_1026/GPL/LGPL-GPL-release_fon_tools.tar.gz
ea46e3e0c5219577336a4378ddfc381f *7490.06.51-v2-20160415_1026/GPL/LGPL-GPL-release_target_tools.tar.gz
43259e280beb24d79693a27592f938de *7490.06.51-v2-20160415_1026/GPL/LGPL-libexif.tar.gz
75c03c0659a95a99a3fbb4ad5c7c044e *7490.06.51-v2-20160415_1026/GPL/LGPL-libosip.tar.gz
27594e12f7f9cf40149521945d36928c *7490.06.51-v2-20160415_1026/GPL/LGPL-multimedia_fon.tar.gz
e9087b3448351a1ef5fd0f1987e21493 *7490.06.51-v2-20160415_1026/GPL/LGPL-neon.tar.gz
dbac5d8d75159be7e3cd3995a5be91da *7490.06.51-v2-20160415_1026/GPL/ZLIB-libz.tar.gz
8fa754dfda95f1defadd7b8e3cc851fa *7490.06.51-v3-20160601_1118/GPL/BSD-libflac.tar.gz
a1bba62f799525316b9d9e9a59eea0c7 *7490.06.51-v3-20160601_1118/GPL/GPL-avmacllib2.tar.gz
1788468c7d781f9b6d5a49b6d7a9b0e3 *7490.06.51-v3-20160601_1118/GPL/GPL-bridge-utils.tar.gz
7a5958e57d1fe5e8f9f86671826159a3 *7490.06.51-v3-20160601_1118/GPL/GPL-busybox.tar.gz
77164e45d9e2a5050b44709ce62f75c2 *7490.06.51-v3-20160601_1118/GPL/GPL-chrony.tar.gz
2f1f56b4bcf23460619ebbd60dfd0a3e *7490.06.51-v3-20160601_1118/GPL/GPL-davfs2.tar.gz
05c85a44202ea33d148e7abd74bba4a5 *7490.06.51-v3-20160601_1118/GPL/GPL-ftpd.tar.gz
3a741860ceba18b26b19e28fa15bb5f9 *7490.06.51-v3-20160601_1118/GPL/GPL-gcc.tar.gz
635495aa43980ad1e482bbb232037cd6 *7490.06.51-v3-20160601_1118/GPL/GPL-iproute2.tar.gz
9c0dfbba0981cfd2d77f012c80e2d932 *7490.06.51-v3-20160601_1118/GPL/GPL-lte_tools.tar.gz
642fd1656add221416105b51072c73b7 *7490.06.51-v3-20160601_1118/GPL/GPL-ntfs.tar.gz
c7047f975ee0162fd652b92dc05f41f3 *7490.06.51-v3-20160601_1118/GPL/GPL-release_kernel.tar.gz
2e622858e48fc8637a774bb1bc192d6a *7490.06.51-v3-20160601_1118/GPL/GPL-samba.tar.gz
fc73a33b29d5f59233f2cd4ce88ed066 *7490.06.51-v3-20160601_1118/GPL/GPL-usb_host_tools.tar.gz
b7655941a5d194976f22cf3ec6381d6a *7490.06.51-v3-20160601_1118/GPL/GPL-wlan.tar.gz
6c4f458210dc85adb4ef6504d21e7575 *7490.06.51-v3-20160601_1118/GPL/LGPL-GPL-release_fon_tools.tar.gz
d2268f3112fc0baaab8fddffaa7f4520 *7490.06.51-v3-20160601_1118/GPL/LGPL-GPL-release_target_tools.tar.gz
4a36fece5d0cf554af651dbc7080db2e *7490.06.51-v3-20160601_1118/GPL/LGPL-libexif.tar.gz
247f484c8f0899f4b611bb0fa4dc11d5 *7490.06.51-v3-20160601_1118/GPL/LGPL-libosip.tar.gz
fb51c60055313ded8c0c958053577571 *7490.06.51-v3-20160601_1118/GPL/LGPL-multimedia_fon.tar.gz
5814b34797975a05d180ab52a19aee1a *7490.06.51-v3-20160601_1118/GPL/LGPL-neon.tar.gz
bd2d378f5e965fcd862d0ab1d9846c4d *7490.06.51-v3-20160601_1118/GPL/ZLIB-libz.tar.gz
_sdata = .; /* Start of data section */
RODATA
/* writeable */
__data_start = .;
.data : { /* Data */
. = . + DATAOFFSET; /* for CONFIG_MAPPED_KERNEL */
INIT_TASK_DATA(THREAD_SIZE)
NOSAVE_DATA
CACHELINE_ALIGNED_DATA(1 << CONFIG_MIPS_L1_CACHE_SHIFT)
READ_MOSTLY_DATA(1 << CONFIG_MIPS_L1_CACHE_SHIFT)
DATA_DATA
CONSTRUCTORS
. = ALIGN(4 * 1024);[COLOR="#FF0000"]
__avm_kernel_config_start = .;
. += 64 * 1024;
__avm_kernel_config_end = .;[/COLOR]
_gp = . + 0x8000;
.lit8 : {
*(.lit8)
.lit4 : {
*(.lit4)
/* We want the small data sections together, so single-instruction offsets
can access them all, and initialized data all before uninitialized, so
we can shorten the on-disk segment size. */
.sdata : {
*(.sdata)
_edata = .; /* End of data section */
$ grep -r __avm_kernel_config_start
include/linux/avm_kernel_config.h: extern unsigned int __avm_kernel_config_start __attribute__ ((weak));
include/linux/avm_kernel_config.h: if (IS_ERR(&__avm_kernel_config_start) ||
include/linux/avm_kernel_config.h: (&__avm_kernel_config_start == NULL))
include/linux/avm_kernel_config.h: (struct _avm_kernel_config **)&__avm_kernel_config_start;
arch/arm/kernel/head.S: .word __avm_kernel_config_start
arch/arm/kernel/vmlinux.lds.S: __avm_kernel_config_start = .;
arch/mips/kernel/vmlinux.lds.S: __avm_kernel_config_start = .;
Ja und nein ... das bringt aber nichts, es erneut zu erklären, Du müßtest dazu den Thread mehr oder weniger komplett lesen (oder zumindest ein paar Seiten zurück).evtl. habe ich es ja falsch verstanden, aber für die 50er und 51er sind die doch online:
(im Original)GPLv2-Lizenz §3 - deutsche Übersetzung auf gnu.de schrieb:Für ein ausführbares Programm bedeutet „der komplette Quelltext“: Der Quelltext aller im Programm enthaltenen Module einschließlich aller zugehörigen Modulschnittstellen-Definitionsdateien sowie der zur Compilation und Installation verwendeten Skripte.
, aber es war bis vor ca. 1,5 Jahren ja sogar so, daß es von AVM nicht einmal das "gpl_compile_kernel.sh" gab, dort kann man jetzt ja wenigstens sehen, welche (teilweise auch nur Dummy-)Module zusätzlich in den Kernel-Build integriert werden müssen. Von einem Skript zum "Bauen" eines FRITZ!OS-Images (das wäre theoretisch die komplette Image-Datei, so wie sie von AVM bereitgestellt wird in binärer Form, ggf. mit Ausnahme der Signatur, weil da wohl niemand das Veröffentlichen des privaten Schlüssels fordern würde) ist da weit und breit definitiv (und das schreibe ich selten so deutlich) nichts zu sehen.GPLv2 License schrieb:For an executable work, complete source code means all the source code for all modules it contains, plus any associated interface definition files, plus the scripts used to control compilation and installation of the executable.
