Fritz Fon Ata - Firmware to convert German to English
This is NOT a german Firmware! This is an international Firmware with german Text only!: FritzBox_Fon_ata avme de 11.03.64 (Austria Schweiz Edition)
This Firmware needs "oem" = "avme"
Real german Firmware need "oem" = "avm"
voipd.
Great news I have managed to get it working!
I used recover to load fritz.box_fon_ata.de.11.03.64.image
Switched off the unit for a min.
Loaded web interface
The applied fritz.box_fon_ata.en.11.03.08.image using web interface.
Thanks for all your assistance I could not have done it without you!
If any of you are ever in the Manchester, UK area, get in touch and I'll buy you a drink ;)
Thanks again
MackeyUk
I'm almost there....
I did the telnet thing, then I used recover to load fritz.box_fon_ata.de.11.03.64.image, but when I reboot the FBF nothing happens. The Web interface never appears.
Does anyone know what I might be doing wrong?
Thanks,
Paul.
Don't worry - I got there.
The telnet command in several of the previous message is wrong.
Instead of: echo "firmware_version avm" > /proc/avalanche/env
You need to useL echo "firmware_version avme" > /proc/avalanche/env
Hope that helps someone in the future!
P.
das_schaf schrieb:
1. download starttelnet.image from http://www.wehavemorefun.de/fritzbox/Starten_von_telnetd and install it like a new firmware.
Hello,
I am about to get a FRITZ!Box Fon ata from Germany. It will probably have the German firmware on it and I would like to convert it as well to English.
I am trying to get all the files ready so I can flash it as soon as it arrives. I am trying to download the file you mentioned from this website:
but am unable to load the webpage.
Do you have a copy of that file?
One other question. If I am successful with this conversion from German to English firmware, will I from now on be able to just update the firmware normally to the latest English version that comes out?
Thank you.
starttelnet.image??? where I can find this file?
1. download starttelnet.image from http://www.wehavemorefun.de/fritzbo... know some mirrors??? Thanks for any help!
der_Gersthofer schrieb:
I have this manual into our WIKI. Everybody is free to improve / correct the manual.
http://wiki.ip-phone-forum.de/router:avm:ata:interner_link
I have FRITZ!Box Fon ata 1020, Firmware-Version 11.04.01 (german - it was freenet edition but I have just remove it) and I am trying to load into it an english firmware (11.04.01)
when I'm rebooting my fritz and running command:
recover -f fritz.austia.image (this is international firmware ver 11.04.01) I get error = 1 (can not find fritz???)
what is wrong??? do you have any suggestions???
thanks in advance for any help,
wladziu
Hello!!!
I just bought a german FRITZ!Box Fon ata 1020, Firmware-Version 11.04.01.
I am trying to change to the english language, but i don't have the "recover.exe" file on my CD.
Could you please help me?
Thanks!
Petros
[2nd Posting]
:noidea:
While trynig to follow the procedure described above, i managed to ... make fritz unavailable. No ping, no telnet, no web-interface...
Could you please, help me? I am desparate!!!!! :noidea: :noidea: :noidea:
Does anyone knows where i can find "recover.exe"? (its not in my installation CD)
Thanks!
[Edit DM41] Problem is already discussed here
dmobi
