Fritz!Box Fon im Ausland möglich?
Also es gibt Hardware Revision, welche Annex A unterstützen.
Haveaniceday
Hi
How many different Hardware revision of Fritzbox Fon are there ?
and how can I know which revision the fritzbox fon is ?
and which one of them support Annex A ?
thanks
regards
Hi hoppala00,
Just have a look at:
http://www.wehavemorefun.de/fritzbox/Image:HW-Revisions.jpeg
Offical only the Annex A boxes support Annex A ;-) . All Annex B boxes can be used with a different setting.
( can be done with an upload, see thread http://www.ip-phone-forum.de/forum/viewtopic.php?t=10201
and file http://www.ip-phone-forum.de/forum/download.php?id=1537 )
The file does also a branding to an "AVM-Box". => easier configuration of several providers.. )
Trouble which might happen with a Annex B-Box used for Annex A:
- if you have a bad line you might get:
A.) Just at the limit of DSL-quality => No full speed
B.) really bad line. just the limit of possible connection => No connection at all with a Annex-B Box.
Annex B is using a different frequency range. It's smaller and fits to "ISDN" requirements.
Annex A is designed to work with regular analog lines: larger frequency range for DSL.
The Annex B-boxes do have a filter wich cuts of some frequence ranges. This is not critical due the
negotiation of the frequencies for DSL but might give a lower connection speed under rare circumstances.
You can see the "real" HW revision for sure if you log in:
~ # cat /proc/avalanche/env | grep HWRe
HWRevision 61
You might see at the status page: FRITZ!Box Fon WLAN, Modified-Firmware 08.03.37
=> So in this case you can see MAJOR "08" => See at the picture: should be HWRevision 61.
The picture is an analysis of the current firmware-files. So I expect it's valid.
I do not know which other revisions exist nor if all Boxes had been sold or will be sold.
That's a "secret" of AVM.
Best regards,
Haveaniceday
Hi.
Here is a dump of a config file where you can see the different hardware revisions:
    # Fallback Einstellungen -> Fritz!Box SL, Annex B
HW=all OEM=all     CAPI=n
HW=all OEM=all     FON=n
HW=all OEM=all     WLAN=n
HW=all OEM=all     DSL=y
HW=all OEM=all     UBIK2=n
HW=all OEM=all     VLYNQ0=0
HW=all OEM=all     VLYNQ1=0
HW=all OEM=all     ANNEX=B
HW=all OEM=all     BASIS=n
HW=all OEM=all     PRODUKT=Fritz_Box_2MB
HW=all OEM=all     PRODUKT_NAME=Boot#Error:#running#as#FRITZ!Box#SL
HW=all OEM=all     OEM_DEFAULT=avm
HW=all OEM=all     INSTALL_TYPE=ar7_2MB_1eth_oem_AOL_32711
HW=all OEM=all     VERSION_MAJOR=10
HW=all OEM=all     ETH_COUNT=1
HW=all OEM=all     CDROM=n
HW=all OEM=all     FIRMWARE_URL=http://www.avm.de/Download
HW=all OEM=all     HOSTNAME=fritz.box
HW=all OEM=all     AB_COUNT=0
    # Fritz!Box SL, Annex B
HW=F OEM=all     CAPI=n
HW=F OEM=all     FON=n
HW=F OEM=all     WLAN=n
HW=F OEM=all     DSL=y
HW=F OEM=all     UBIK2=n
HW=F OEM=all     VLYNQ0=0
HW=F OEM=all     VLYNQ1=0
HW=F OEM=all     ANNEX=B
HW=F OEM=all     BASIS=n
HW=F OEM=all     PRODUKT=Fritz_Box_2MB
HW=F OEM=all     PRODUKT_NAME=FRITZ!Box#SL
HW=F OEM=all     OEM_DEFAULT=avm
HW=F OEM=all     INSTALL_TYPE=ar7_2MB_1eth_oem_AOL_32711
HW=F OEM=all     VERSION_MAJOR=10
HW=F OEM=all     ETH_COUNT=1
HW=F OEM=all     CDROM=n
HW=F OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_sl_firmware
HW=F OEM=all     HOSTNAME=fritz.box
HW=F OEM=aol     PRODUKT_NAME=FRITZ!Box#SL#(AOL)
HW=F OEM=1und1   PRODUKT_NAME=FRITZ!Box#SL#(UI)
    # Fritz!Box, Annex B     (ANM.: alte HWR 'D' wird bei Installation zu 'G' geändert)
HW=G OEM=all     CAPI=n
HW=G OEM=all     FON=n
HW=G OEM=all     WLAN=n
HW=G OEM=all     DSL=y
HW=G OEM=all     UBIK2=n
HW=G OEM=all     VLYNQ0=0
HW=G OEM=all     VLYNQ1=0
HW=G OEM=all     ANNEX=B
HW=G OEM=all     BASIS=n
HW=G OEM=all     PRODUKT=Fritz_Box_4MB
HW=G OEM=all     PRODUKT_NAME=FRITZ!Box
HW=G OEM=all     OEM_DEFAULT=avm
HW=G OEM=all     INSTALL_TYPE=ar7_4MB_2eth_28724
HW=G OEM=all     VERSION_MAJOR=05
HW=G OEM=all     ETH_COUNT=2
HW=G OEM=all     CDROM=n
HW=G OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_firmware
HW=G OEM=all     HOSTNAME=fritz.box
HW=G OEM=avme    FIRMWARE_URL=http://www.avm.de/en/fritz_box_firmware
HW=G OEM=aol     PRODUKT_NAME=FRITZ!Box#(AOL) BASIS=w
HW=G OEM=1und1   PRODUKT_NAME=FRITZ!Box#(UI) BASIS=n
    # Fritz!Box FON, Annex B     (ANM.: alte HWR 'K' bleibt erhalten)
HW=58 OEM=all     CAPI=y
HW=58 OEM=all     FON=y
HW=58 OEM=all     WLAN=n
HW=58 OEM=all     DSL=y
HW=58 OEM=all     UBIK2=n
HW=58 OEM=all     VLYNQ0=0
HW=58 OEM=all     VLYNQ1=0
HW=58 OEM=all     ANNEX=B
HW=58 OEM=all     BASIS=y
HW=58 OEM=all     PRODUKT=Fritz_Box_FON
HW=58 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon
HW=58 OEM=all     OEM_DEFAULT=freenet
HW=58 OEM=all     INSTALL_TYPE=ar7_4MB_2eth_2ab_isdn_pots_05804
HW=58 OEM=all     VERSION_MAJOR=06
HW=58 OEM=all     ETH_COUNT=1
HW=58 OEM=all     CDROM=n
HW=58 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_fon_firmware
HW=58 OEM=all     HOSTNAME=fritz.fon.box
HW=58 OEM=all     AB_COUNT=2
HW=58 OEM=avme    FIRMWARE_URL=http://www.avm.de/en/fritz_box_fon_firmware
HW=58 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#(AOL) BASIS=w
HW=58 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#(UI) BASIS=w
HW=K OEM=all     CAPI=y
HW=K OEM=all     FON=y
HW=K OEM=all     WLAN=n
HW=K OEM=all     DSL=y
HW=K OEM=all     UBIK2=n
HW=K OEM=all     VLYNQ0=0
HW=K OEM=all     VLYNQ1=0
HW=K OEM=all     ANNEX=B
HW=K OEM=all     BASIS=y
HW=K OEM=all     PRODUKT=Fritz_Box_FON
HW=K OEM=all     PRODUKT_NAME=FRITZ!Box#Fon
HW=K OEM=all     OEM_DEFAULT=freenet
HW=K OEM=all     INSTALL_TYPE=ar7_4MB_2eth_2ab_isdn_pots_05804
HW=K OEM=all     VERSION_MAJOR=06
HW=K OEM=all     ETH_COUNT=1
HW=K OEM=all     CDROM=n
HW=K OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_fon_firmware
HW=K OEM=all     HOSTNAME=fritz.fon.box
HW=K OEM=all     AB_COUNT=2
HW=K OEM=avme    FIRMWARE_URL=http://www.avm.de/en/fritz_box_fon_firmware
HW=K OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#(AOL) BASIS=w
HW=K OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#(UI) BASIS=w
    # Fritz!Box FON 2, Annex B
HW=72 OEM=all     CAPI=y
HW=72 OEM=all     FON=y
HW=72 OEM=all     WLAN=n
HW=72 OEM=all     DSL=y
HW=72 OEM=all     UBIK2=y
HW=72 OEM=all     VLYNQ0=0
HW=72 OEM=all     VLYNQ1=0
HW=72 OEM=all     ANNEX=B
HW=72 OEM=all     BASIS=y
HW=72 OEM=all     PRODUKT=Fritz_Box_FON_2
HW=72 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#II
HW=72 OEM=all     OEM_DEFAULT=avm
HW=72 OEM=all     INSTALL_TYPE=ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_39535
HW=72 OEM=all     VERSION_MAJOR=12
HW=72 OEM=all     ETH_COUNT=1
HW=72 OEM=all     CDROM=n
HW=72 OEM=all     HOSTNAME=fritz.fon.box
HW=72 OEM=all     AB_COUNT=2
HW=72 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#II#(AOL) BASIS=w
HW=72 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#II#(UI) BASIS=n
    # Fritz!Box FON 2 plus WLAN, Annex B
HW=76 OEM=all     CAPI=y
HW=76 OEM=all     FON=y
HW=76 OEM=all     WLAN=y
HW=76 OEM=all     DSL=y
HW=76 OEM=all     UBIK2=y
HW=76 OEM=all     VLYNQ0=1
HW=76 OEM=all     VLYNQ1=0
HW=76 OEM=all     ANNEX=B
HW=76 OEM=all     BASIS=y
HW=76 OEM=all     PRODUKT=Fritz_Box_FON_2_WLAN
HW=76 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#II#plus#WLAN
HW=76 OEM=all     OEM_DEFAULT=avm
HW=76 OEM=all     INSTALL_TYPE=ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_wlan_50494
HW=76 OEM=all     VERSION_MAJOR=14
HW=76 OEM=all     ETH_COUNT=2
HW=76 OEM=all     CDROM=n
HW=76 OEM=all     HOSTNAME=fritz.fonwlan.box
HW=76 OEM=all     AB_COUNT=3
HW=76 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#II#plus#WLAN#(AOL) BASIS=w
HW=76 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#II#plus#WLAN#(UI) BASIS=n
    # Fritz!Box SL WLAN, Annex B
HW=60 OEM=all     CAPI=n
HW=60 OEM=all     FON=n
HW=60 OEM=all     WLAN=y
HW=60 OEM=all     DSL=y
HW=60 OEM=all     UBIK2=n
HW=60 OEM=all     VLYNQ0=1
HW=60 OEM=all     VLYNQ1=0
HW=60 OEM=all     ANNEX=B
HW=60 OEM=all     BASIS=n
HW=60 OEM=all     PRODUKT=Fritz_Box_SL_WLAN
HW=60 OEM=all     PRODUKT_NAME=FRITZ!Box#SL#WLAN
HW=60 OEM=all     OEM_DEFAULT=avm
HW=60 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_wlan_60332
HW=60 OEM=all     VERSION_MAJOR=09
HW=60 OEM=all     ETH_COUNT=1
HW=60 OEM=all     CDROM=n
HW=60 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_sl_wlan_firmware
HW=60 OEM=all     HOSTNAME=fritz.slwlan.box
HW=60 OEM=aol     PRODUKT_NAME=FRITZ!Box#SL#WLAN#(AOL) BASIS=w
HW=60 OEM=1und1   PRODUKT_NAME=FRITZ!Box#SL#WLAN#(UI) BASIS=n
    # Fritz!Box FON WLAN, Annex B
HW=61 OEM=all     CAPI=y
HW=61 OEM=all     FON=y
HW=61 OEM=all     WLAN=n
HW=61 OEM=all     DSL=y
HW=61 OEM=all     UBIK2=n
HW=61 OEM=all     VLYNQ0=1
HW=61 OEM=all     VLYNQ1=0
HW=61 OEM=all     ANNEX=B
HW=61 OEM=all     BASIS=n
HW=61 OEM=all     PRODUKT=Fritz_Box_WLAN
HW=61 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#WLAN
HW=61 OEM=all     OEM_DEFAULT=avm
HW=61 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_2ab_isdn_pots_wlan_43040
HW=61 OEM=all     VERSION_MAJOR=08
HW=61 OEM=all     ETH_COUNT=1
HW=61 OEM=all     CDROM=n
HW=61 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_fon_wlan_firmware
HW=61 OEM=all     HOSTNAME=fritz.fonwlan.box
HW=61 OEM=all     AB_COUNT=2
HW=61 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#WLAN#(AOL) BASIS=w
HW=61 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#WLAN#(UI) BASIS=w
    # Fritz!Box FON Mini VoIP, Annex B
HW=75 OEM=all     CAPI=y
HW=75 OEM=all     FON=y
HW=75 OEM=all     WLAN=n
HW=75 OEM=all     DSL=y
HW=75 OEM=all     UBIK2=n
HW=75 OEM=all     VLYNQ0=0
HW=75 OEM=all     VLYNQ1=0
HW=75 OEM=all     ANNEX=B
HW=75 OEM=all     BASIS=y
HW=75 OEM=all     PRODUKT=Fritz_Box_MVoIP
HW=75 OEM=all     PRODUKT_NAME=FRITZ!Box#Mini#VoIP
HW=75 OEM=all     OEM_DEFAULT=avm
HW=75 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_1ab_isdn_pots_usb_host_19693
HW=75 OEM=all     VERSION_MAJOR=13
HW=75 OEM=all     ETH_COUNT=1
HW=75 OEM=all     CDROM=n
HW=75 OEM=all     HOSTNAME=fritz.fon.box
HW=75 OEM=all     AB_COUNT=1
    # Eumex 300 IP, Annex B
HW=78 OEM=all     CAPI=y
HW=78 OEM=all     FON=y
HW=78 OEM=all     WLAN=n
HW=78 OEM=all     DSL=y
HW=78 OEM=all     UBIK2=n
HW=78 OEM=all     VLYNQ0=0
HW=78 OEM=all     VLYNQ1=0
HW=78 OEM=all     ANNEX=B
HW=78 OEM=all     BASIS=y
HW=78 OEM=all     PRODUKT=Fritz_Box_Eumex300IP
HW=78 OEM=all     PRODUKT_NAME=Eumex#300#IP
HW=78 OEM=all     OEM_DEFAULT=tcom
HW=78 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_3ab_isdn_pots_63151
HW=78 OEM=all     VERSION_MAJOR=15
HW=78 OEM=all     ETH_COUNT=1
HW=78 OEM=all     CDROM=n
HW=78 OEM=all     HOSTNAME=eumex.ip
HW=78 OEM=all     AB_COUNT=3
HW=78 OEM=tcom    BASIS=w
    # Fritz!Box, Annex A
HW=62 OEM=all     CAPI=n
HW=62 OEM=all     FON=n
HW=62 OEM=all     WLAN=n
HW=62 OEM=all     DSL=y
HW=62 OEM=all     UBIK2=n
HW=62 OEM=all     VLYNQ0=0
HW=62 OEM=all     VLYNQ1=0
HW=62 OEM=all     ANNEX=A
HW=62 OEM=all     BASIS=n
HW=62 OEM=all     PRODUKT=Fritz_Box_4MB
HW=62 OEM=all     PRODUKT_NAME=FRITZ!Box#Annex#A
HW=62 OEM=all     OEM_DEFAULT=avm
HW=62 OEM=all     INSTALL_TYPE=ar7_4MB_2eth_28724
HW=62 OEM=all     VERSION_MAJOR=05
HW=62 OEM=all     ETH_COUNT=2
HW=62 OEM=all     CDROM=n
HW=62 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_firmware
HW=62 OEM=all     HOSTNAME=fritz.box
HW=62 OEM=avme    FIRMWARE_URL=http://www.avm.de/en/fritz_box_firmware
HW=62 OEM=aol     PRODUKT_NAME=FRITZ!Box#Annex#A#(AOL) BASIS=w
HW=62 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Annex#A#(UI) BASIS=n
    # Fritz!Box SL, Annex A
HW=63 OEM=all     CAPI=n
HW=63 OEM=all     FON=n
HW=63 OEM=all     WLAN=n
HW=63 OEM=all     DSL=y
HW=63 OEM=all     UBIK2=n
HW=63 OEM=all     VLYNQ0=0
HW=63 OEM=all     VLYNQ1=0
HW=63 OEM=all     ANNEX=A
HW=63 OEM=all     BASIS=n
HW=63 OEM=all     PRODUKT=Fritz_Box_2MB
HW=63 OEM=all     PRODUKT_NAME=FRITZ!Box#SL#Annex#A
HW=63 OEM=all     OEM_DEFAULT=avm
HW=63 OEM=all     INSTALL_TYPE=ar7_2MB_1eth_oem_AOL_32711
HW=63 OEM=all     VERSION_MAJOR=10
HW=63 OEM=all     ETH_COUNT=1
HW=63 OEM=all     CDROM=n
HW=63 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_sl_firmware
HW=63 OEM=all     HOSTNAME=fritz.box
HW=63 OEM=aol     PRODUKT_NAME=FRITZ!Box#SL#Annex#A#(AOL) BASIS=w
HW=63 OEM=1und1   PRODUKT_NAME=FRITZ!Box#SL#Annex#A#(UI) BASIS=n
    # Fritz!Box Fon, Annex A
HW=64 OEM=all     CAPI=y
HW=64 OEM=all     FON=y
HW=64 OEM=all     WLAN=n
HW=64 OEM=all     DSL=y
HW=64 OEM=all     UBIK2=n
HW=64 OEM=all     VLYNQ0=0
HW=64 OEM=all     VLYNQ1=0
HW=64 OEM=all     ANNEX=A
HW=64 OEM=all     BASIS=y
HW=64 OEM=all     PRODUKT=Fritz_Box_FON
HW=64 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#Annex#A
HW=64 OEM=all     OEM_DEFAULT=freenet
HW=64 OEM=all     INSTALL_TYPE=ar7_4MB_2eth_2ab_isdn_pots_05804
HW=64 OEM=all     VERSION_MAJOR=06
HW=64 OEM=all     ETH_COUNT=1
HW=64 OEM=all     CDROM=n
HW=64 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_fon_firmware
HW=64 OEM=all     HOSTNAME=fritz.fon.box
HW=64 OEM=all     AB_COUNT=2
HW=64 OEM=avme    FIRMWARE_URL=http://www.avm.de/en/fritz_box_fon_firmware
HW=64 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#Annex#A#(AOL) BASIS=w
HW=64 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#Annex#A#(UI) BASIS=w
    # Fritz!Box Fon 2, Annex A
HW=73 OEM=all     CAPI=y
HW=73 OEM=all     FON=y
HW=73 OEM=all     WLAN=n
HW=73 OEM=all     DSL=y
HW=73 OEM=all     UBIK2=y
HW=73 OEM=all     VLYNQ0=0
HW=73 OEM=all     VLYNQ1=0
HW=73 OEM=all     ANNEX=A
HW=73 OEM=all     BASIS=y
HW=73 OEM=all     PRODUKT=Fritz_Box_FON_2
HW=73 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#II#Annex#A
HW=73 OEM=all     OEM_DEFAULT=avm
HW=73 OEM=all     INSTALL_TYPE=ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_39535
HW=73 OEM=all     VERSION_MAJOR=12
HW=73 OEM=all     ETH_COUNT=1
HW=73 OEM=all     CDROM=n
HW=73 OEM=all     HOSTNAME=fritz.fon.box
HW=73 OEM=all     AB_COUNT=2
HW=73 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#II#Annex#A#(AOL) BASIS=w
HW=73 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#II#Annex#A#(UI) BASIS=n
    # Fritz!Box SL WLAN, Annex A
HW=65 OEM=all     CAPI=n
HW=65 OEM=all     FON=n
HW=65 OEM=all     WLAN=y
HW=65 OEM=all     DSL=y
HW=65 OEM=all     UBIK2=n
HW=65 OEM=all     VLYNQ0=1
HW=65 OEM=all     VLYNQ1=0
HW=65 OEM=all     ANNEX=A
HW=65 OEM=all     BASIS=n
HW=65 OEM=all     PRODUKT=Fritz_Box_SL_WLAN
HW=65 OEM=all     PRODUKT_NAME=FRITZ!Box#SL#WLAN#Annex#A
HW=65 OEM=all     OEM_DEFAULT=avm
HW=65 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_wlan_60332
HW=65 OEM=all     VERSION_MAJOR=09
HW=65 OEM=all     ETH_COUNT=1
HW=65 OEM=all     CDROM=n
HW=65 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_sl_wlan_firmware
HW=65 OEM=all     HOSTNAME=fritz.slwlan.box
HW=65 OEM=aol     PRODUKT_NAME=FRITZ!Box#SL#WLAN#Annex#A#(AOL) BASIS=w
HW=65 OEM=1und1   PRODUKT_NAME=FRITZ!Box#SL#WLAN#Annex#A#(UI) BASIS=n
    # Fritz!Box Fon WLAN, Annex A
HW=66 OEM=all     CAPI=y
HW=66 OEM=all     FON=y
HW=66 OEM=all     WLAN=y
HW=66 OEM=all     DSL=y
HW=66 OEM=all     UBIK2=n
HW=66 OEM=all     VLYNQ0=1
HW=66 OEM=all     VLYNQ1=0
HW=66 OEM=all     ANNEX=A
HW=66 OEM=all     BASIS=n
HW=66 OEM=all     PRODUKT=Fritz_Box_WLAN
HW=66 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#WLAN
HW=66 OEM=all     OEM_DEFAULT=avm
HW=66 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_2ab_isdn_pots_wlan_43040
HW=66 OEM=all     VERSION_MAJOR=08
HW=66 OEM=all     ETH_COUNT=1
HW=66 OEM=all     CDROM=n
HW=66 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_fon_wlan_firmware
HW=66 OEM=all     HOSTNAME=fritz.fonwlan.box
HW=66 OEM=all     AB_COUNT=2
HW=66 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#WLAN#Annex#A#(AOL) BASIS=w
HW=66 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#WLAN#Annex#A#(UI) BASIS=w
    # Fritz!Box FON 2 plus WLAN, Annex A
HW=77 OEM=all     CAPI=y
HW=77 OEM=all     FON=y
HW=77 OEM=all     WLAN=y
HW=77 OEM=all     DSL=y
HW=77 OEM=all     UBIK2=y
HW=77 OEM=all     VLYNQ0=1
HW=77 OEM=all     VLYNQ1=0
HW=77 OEM=all     ANNEX=B
HW=77 OEM=all     BASIS=y
HW=77 OEM=all     PRODUKT=Fritz_Box_FON_2_WLAN
HW=77 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#II#plus#WLAN
HW=77 OEM=all     OEM_DEFAULT=avm
HW=77 OEM=all     INSTALL_TYPE=ar7_ubik2_4MB_2eth_3ab_isdn_nt_te_pots_wlan_50494
HW=77 OEM=all     VERSION_MAJOR=14
HW=77 OEM=all     ETH_COUNT=2
HW=77 OEM=all     CDROM=n
HW=77 OEM=all     HOSTNAME=fritz.fonwlan.box
HW=77 OEM=all     AB_COUNT=3
HW=77 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#II#plus#WLAN#(AOL) BASIS=w
HW=77 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#II#plus#WLAN#(UI) BASIS=n
    # Fritz!Box Fon ATA     (kein Annex)
HW=71 OEM=all     CAPI=y
HW=71 OEM=all     FON=y
HW=71 OEM=all     WLAN=n
HW=71 OEM=all     DSL=n
HW=71 OEM=all     UBIK2=n
HW=71 OEM=all     VLYNQ0=0
HW=71 OEM=all     VLYNQ1=0
HW=71 OEM=all     ANNEX=n
HW=71 OEM=all     BASIS=y
HW=71 OEM=all     PRODUKT=Fritz_Box_FON_ATA
HW=71 OEM=all     PRODUKT_NAME=FRITZ!Box#Fon#ata
HW=71 OEM=all     OEM_DEFAULT=avm
HW=71 OEM=all     INSTALL_TYPE=ar7_4MB_0dsl_2eth_2ab_isdn_pots_15751
HW=71 OEM=all     VERSION_MAJOR=11
HW=71 OEM=all     ETH_COUNT=2
HW=71 OEM=all     CDROM=n
HW=71 OEM=all     FIRMWARE_URL=http://www.avm.de/fritz_box_fon_ata_firmware
HW=71 OEM=all     HOSTNAME=fritz.fonata.box
HW=71 OEM=all     AB_COUNT=2
HW=71 OEM=aol     PRODUKT_NAME=FRITZ!Box#Fon#ata#(AOL) BASIS=w
HW=71 OEM=1und1   PRODUKT_NAME=FRITZ!Box#Fon#ata#(UI) BASIS=n
    # Fritz!Box, user defined
HW=100 OEM=all     CAPI=n
HW=100 OEM=all     FON=n
HW=100 OEM=all     WLAN=y
HW=100 OEM=all     DSL=n
HW=100 OEM=all     UBIK2=n
HW=100 OEM=all     VLYNQ0=1
HW=100 OEM=all     VLYNQ1=0
HW=100 OEM=all     ANNEX=B
HW=100 OEM=all     BASIS=n
HW=100 OEM=all     PRODUKT=Fritz_Box_SL_WLAN
HW=100 OEM=all     PRODUKT_NAME=FRITZ!Box#User
HW=100 OEM=all     OEM_DEFAULT=avm
HW=100 OEM=all     INSTALL_TYPE=ar7_4MB_1eth_wlan_60332
HW=100 OEM=all     VERSION_MAJOR=99
HW=100 OEM=all     ETH_COUNT=1
HW=100 OEM=all     CDROM=n
HW=100 OEM=all     HOSTNAME=fritz.box
Oliver
edit: Da war jemand schneller :)
Hi again
thanks for your posting ....
currently I do not have this hardware to check it right now :-(
I won an auction and paid for it ... should be here at the middle of this week ..
but the thing that I know is ... it is freenet version Friztbox fon ( without wlan )
it is 6 months old ..
and I think ... Annex A hardware is not that much on the market ... so should not hope that much from coming hardware
and according to what you say ... it is a bit annoying if I chance the Annex B to A and have slow internet connection time to time ...
or am I wrong ?
and also as far as I know ...in germany only Annex B is used ... so to whom are those Annex A version sold ? ...are there still some provider using Annex A in germany ?
How can I get such hardware ... or is it only chance ?
it looks like ,... best thing to do that ... buy only ATA version ... so no need to worry about such problem !
well I see the hardware revision whenever I have it .... and then give a decision !
thanks
regards
Hi hoppala00,
I suppose you don't have to worry about. I personal expect a 99.99 % chance that you do not have any trouble. So it should work fine.
I do not know where Annex A is used or sold. I haven't seen any offer for it.
But I do not have much knowledge about the "outside Germany"-DSL-world.
But as you can see in this thread: a lot of Annex A-relabeling worked fine.
And just look for your current DSL-modem:
- instable connection => upcomming trouble
- stable connection => expect everything works fine..
Where do you want to use the Annex-A Fritz ?
Haveaniceday
Hi again ...
I would like to use it in Turkey ... there I have ADSL modem ( POTS ) and we use over there ADSL
PPPoE/LLC
VPI 8 / VCI 35
what I have red at this forum is confirming that it would most probably work in Turkey too ...
well if I can get the item on time ... I will let you know next week on monday whether it work in TR or not ...
... is there any specific fritzbox fon revision which makes trouble for dsl POTS connections ? or are they only personal problem ... like lack of knowledge and etc.
thanks
regards
@hoppala00
The Turkey-parameter are same as the swedish and it is working fine for me after running the script from haveaniceday (look att his link). I had contact to the international product manager from AVM. He told me that international version is not sold yet, but he informed me that there is no differens in hardware, just english firmware and ANNEX-A and it will be available for the FRITZ!Box fon (no WLAN) on the download section soon! So long there is only german firmware (and ANNEX-B) offically from AVM, some box are for testing on international providers, but not released.
I expect the "regular" use always works, including Annex A. DSL should always work fine,
except for one dutch provider with a strange ppp protocol.
Rare trouble I have heard of:
-"R-Key", the duration is different for countries
- CLIP. ( do not know if this is still true )
The modification is sometimes difficult due to memory limitation for additional features.
( e.g. SL-WLAN: WLAN on => no space for modification...)
The SL-WLan should have 16 MB Ram, Fon 16 MB and Fon WLAN 32 MB ( my favorite).
Haveaniceday
For me CLIP-problem is still true, but not for all telephones. CLIP does not work with my Siemens A200 (swedish version) but is working fine with DORO 530+1 (swedish as well).
@ oilstudent
standardmäßig ist ja nach dem patchen der FBF auf Annex A die automatische Auswahl unter Internet->DSL-Einstellungen->ATM-Parameter eingestellt. Habs auch mit dieser Einstellung versucht, leider hat es nicht geklappt.
Dann habe ich auf dem alten Router die Einstellung
PPPoA/VC-Mux
VPI 0 / VCI 35
gefunden und auch bei der FBF eingestell, aber das ging auch nicht.
Ich werde mich die Tage wieder dran machen und schauen ob ich weiter komme.
Einstellungen für Belgien (Belgacom / Skynet)
Habe die FBF mit Hilfe von haveaniceday auf Annex A umgeschaltet. Ausserdem noch VPI 8, VCI 35 und Enkapsulierung PPPoE (das waren die Einstellungen aus meinem Belgacom/Netgear ADSL-Modem). Klappt bestens, Einwahl ca. 6 Sekunden.
Dann noch Zwangstrennung auf 3-4 Uhr gestellt (Skynet trennt sonst alle 36 Stunden, das ist noch blöder als alle 24 Stunden).
Der Tobi
was ist mit spanien???
hiho, ich will die fritzbox fon wlan in spanien im telefonica-netz betreiben. mit 512 down und 128 up.
hat jemand erfahrungen wie und ob es überhaupt dort mit der box funktioniert?!?!!?
vielen dank für erfahrungsberichte
gruss
charly1
@charly
In Spanien werden FBF für Annex A und Annex B verkauft, also gibt es dort anscheinend wie in Belgien ADSL Annex A: http://www.santabarbara.es/
Die in Deutschland verkauften Boxen sind nur für Annex B bestimmt. Laut Auskunft von AVM sind die eigentlich nicht für Annex A gedacht, auch wegen Hardware-Unterschieden (angeblich). Ich habe meine Box auf Annex A umgestellt und es geht (in Belgien).
Der Tobi
@tjhooker
Ich habe mir die Seite gerade angesehen. Nun ist mein Spanisch nicht viel mehr als Urlaubsniveu, aber soweit ich erkenne kann gibt es die Fritz!Box SL dort in zwei Versionen, die FRITZ!Box Fon (con (mit) VoIP) jedoch nur in einer (ANNEX-B). Da diese jedoch in Spainen verkauft wird scheint es ja auch zu gehen.
512Up/128Down hat mein ADSL hier in Schweden offiziell auch. Die Box zeigt zwar (nach Autokonfiguration) 2176/640 an (weniger gibts wohl in Deutschland nicht?), aber leider geht es so schnell dann doch nicht, allerdings sogar ein wenig schneller als mit dem Orginalmodem meines Anbieters.
Hi ...
good news from Turkey ...
Fritz box fon also works great in Turkey ... ( POTS,ANNEX A )
without any problem at all ....
thanks to everyone who helped to make this work !
But I really need a codec settings only for 723 ( first ) and 729 ... ...
i did one ... but it gave error ... I do not know why !
@ haveniceday ....
I will be really glad if you can make the ready to upload codec settings only for 723 and 729 ... ( I do not want from fritz fon to use any other codec for me unnnecesarry)
I do not need anything else ....
many thanks in advance
regards
ACHTUNG:
Leider musste ich die Erfahrung machen, dass der AVM-Support sich weigert zu helfen, wenn man zugibt die Firmware modifiziert zu haben und das tut man im Prinzip schon dadurch, dass man eine Adresse angibt, die in einem Land liegt wo ANNEX-B nicht funktioniert. Dachte mal anzufragen ob die mir bei dem CLIP-Problem weiterhelfen können, habe aber leider nur eine direkte Weigerung als Antwort bekommen.
Hi Turbo64,
ist zu befürchten. Arbeiten ausserhalb der Spezifikation...
( Was AVM wohl zu einer ATA hinter einem Router sagen würde... ob irgendwo steht, das für CLIP ein deutsches Handset genutzt werden muss *grins
Zum Thema:
-Hast du die Firmware 3.37 aktiv ?
- Da dein anderes Handset geht: Frag mal bei Siemens nach, du wolltest dein schwedisches Handset nach Deutschlang "wandern" und hättest ein
CLIP-Problem. => Update auf deutsche Firmware möglich... ?
- So aus Erfahrung mit amerkanischen Modems weiß ich von mehreren Standards... Könnte mir vorstellen nur Siemens kann helfen..
Haveaniceday
PS: Frage mich gerade nach der analogen CLIP Übertragung. Die Box erkennt diese ? ( sollte sichbar sein nach Telnetanmeldung )
Gegentest mit VoIP-Anruf bei dem CLIP übertragen wird...
PPS: Ich schaue in andere Threads, ob du das Problem dort weiter diskutierst. Hier im Thread würde es unnütz voll bei einer Diskussion. Aber ich hab ja angefangen ;-)
Today I will write in English, might be more useful for this CLIP information.
Hi to everybody,
I have found some settings from another Fritz!X product. These settings are changing the CLIP messaging
"fritz => handset" and seems to work also for the fritz!box.
E.g. We had success with the dutch settings for a Swedish handset with the dutch settings. ( thread http://www.ip-phone-forum.de/forum/viewtopic.php?t=13724 )
I have found the relation "dutch/swedish/denmark" here: http://lists.digium.com/pipermail/asterisk-users/2003-August/017480.html
- #99*1*: Holland (CLIP settings)
- #99*2*: Spain (CLIP settings, no leading '0' used for national numbers)
- #99*3*: Denmark (CLIP settings, no leading '0' used for national numbers)
- #99*4*: Austria (CLIP settings, short ringing sequence and frequency)
- #99*5*: UK (CLIP settings and short ringing sequence)
- #99*6*: France (explicit 50Hz ringing signal)
- #99*7*: Argentina (long flash setting)
- #99*8*: Hungary (long ringing sequence)
- #99*9*: Latvia (longer flash setting, no leading '0' used for national numbers)
- #99*0*: reloads the original default CLIP configuration in effect at time of purchase
"Werksreset" does not reset this settings. Only #99*0* resets.
So if you have some trouble with CLIP at your country you might try this undocumented feature.
Best regards,
Haveaniceday
fuer Belgien gilt :
ADSL auf 'ner ISDN Leitung -> FBF Annex B
ADSL auf 'ner PSTN Leitung -> FBF Annex A
und seit einigen wochen ( war's FW ..3.37 ? ) mit bis zu 8 sip nummern in der UK Ausfuehrung der FBF
dmobi
