olistudent
IPPF-Urgestein
- Mitglied seit
- 19 Okt 2004
- Beiträge
- 14,787
- Punkte für Reaktionen
- 13
- Punkte
- 38
/var/mod/root # ctlmgr -s
/var/mod/root # ctlmgr -fv
ctlmgr: process priority is 19
ctlmgr: [main.c:821] **** cwd -> {/var/mod/root}
/var/mod/root # ctlmgr: /var/flash/user.cfg:10: member mac not found in ST_struct internet_user
ctlmgr: /var/flash/user.cfg:10: member mac not in internet_user, try to recover
ctlmgr: load_config(user): warning: converted
ctlmgr: /var/flash/tr069.cfg: is empty
ctlmgr: FactoryDefault=/etc/default/avm/tr069.cfg (tr069)
ctlmgr: load_config(tr069): factory default loaded
ctlmgr: dlopen(/usr/share/ctlmgr/libdect.so) failed: File not found
ctlmgr: VPNConn_Register called...
ctlmgr: internal vcc:
ctlmgr: name=voip vpi=1 vci=32 encap=1 sep_config=0 vcc=0x2aab6840
ctlmgr: name=internet vpi=1 vci=32 encap=1 sep_config=0 vcc=0x2aab6840
ctlmgr: UNMAP budget,0
ctlmgr: DOUBLE pppoe,0 TO info,0
ctlmgr: box init ok
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:0 0.0.0.0:0 1 out'
ctlmgr: forwardrules: parse errror
ctlmgr: ipmasqfwruleex_parse ret=0 'udp 0.0.0.0:0 0.0.0.0:0 1 out'
ctlmgr: ipmasqfwruleex_parse ret=0 'udp 0.0.0.0:1194 0.0.0.0:1194'
ctlmgr: forwardrules: internal rule
ctlmgr: ipmasqfwruleex_parse ret=0 'udp 0.0.0.0:5060 0.0.0.0:5060'
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:22 0.0.0.0:22'
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:222 192.168.201.253:22 0 # SSH Blechbuechse'
ctlmgr: FWRule ON TCP 222 192.168.201.253 22
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:65534 192.168.201.253:65534 0 # transmission'
ctlmgr: FWRule ON TCP 65534 192.168.201.253 65534
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:223 192.168.201.252:22 0 # SSH Schaetzchen'
ctlmgr: FWRule ON TCP 223 192.168.201.252 22
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:8089 0.0.0.0:8089'
ctlmgr: ipmasqfwruleex_parse ret=0 'tcp 0.0.0.0:5060 0.0.0.0:5060'
ctlmgr: ipmasqfwruleex_parse ret=0 'udp 0.0.0.0:7078+32 0.0.0.0:7078'
ctlmgr: next auto check for firmware updates sheduled in 473905 seconds (2008-05-19 04:15:42)
ctlmgr: sipextra my_init
ctlmgr: capiotcp My_Init
ctlmgr: FactoryDefault=/etc/default/avm/vpn.cfg (vpn)
ctlmgr: load_config(vpn): factory default loaded
ctlmgr: VPNConn_Init called...
ctlmgr: /dev/avm_power <-- MODE=dsl
ctlmgr: WAN (ata) led value = 0
ctlmgr: [../webserver/webserver.c:583] Initialisation of webserver configuration
ctlmgr: symbol TI_Interpreter_LookupDBField not found
ctlmgr: startup (Apr 22 2008 11:01:35)
ctlmgr: [main.c:1163] *** WEBSERVER started successfully
ctlmgr: status change eth-interfaces
ctlmgr: box_led_update_status
ctlmgr: got led event 16
ctlmgr: Now doing actions: ActionMask is 0x2000
ctlmgr: calling samba_control reconfig_pw
/var/mod/root # cat /etc/default/avm/tr069.cfg
tr069cfg {
enabled = no;
igd {
managementserver {
url = "";
username = "";
password = "";
URLAlreadyContacted = no;
FirmwareDownload {
enabled = no;
?Code:ctlmgr -s ctlmgr -fv
MfG Oliver
ctlmgr: FWRule ON TCP 46612 192.168.1.50 46612
ctlmgr: ipmasqfwruleex_parse ret=0 '# tcp 0.0.0.0:81 192.168.178.252:81 0 # Freetz'
ctlmgr: FWRule ON TCP 1111 192.168.1.50 1111
ctlmgr: ipmasqfwruleex_parse ret=0 '# tcp 0.0.0.0:1111 192.168.178.253:1111 0 # Freetz'
