[Info] Firmware N510IP A510IP C430IP C530IP C590IP C595IP C610IP N300IP GOBox100
Your actual release is?
logon to your C430 first.
look at the IP presented.
after that copy/past the link in a new tab.
"IP_C430" has to be be replaced before hit enter.
Thank you for explaining, but I can not load firmware in this way
Maybe I'm not expert about this, but I really do not understand how to downgrade to firmware 42.238
Once again, thank you!
Before you start your task dont forget to export current settings !
logon C430
goto settings > management > fimware update
there you can see the fimware downgrade possibilities: former or delivery version only.
once downgraded successfully, enter the version 42.238 to be upgraded.
logon C430
provide a screenshot please just like the one as shown below
Respected,
I do everything as you said but will not start downgrade, but says the server is not available.
I can not even restore the previous version of firmware 42.241!
I can only update to version 42.243 again, maybe something's wrong with my GO-Box 100!?
As I said, I can only update firmware to release 42.243!
former version: fail ?
delivery version: fail ?
- remove substring "latest" only
- set automatic check for firmware update to yes
try again to get the delivery version
Dataserver without http://
I tried without "http://" but it can not start updating in the delivery version.
Maybe not because I have repeatedly updated several times in latest version 42.243?
Here's the picture without "http://"
Maybe server is temporarily down, try again next week.
- server is up and running again
- inofficially pipe just loaded: 42.244
Hallo MuP,
wie kommt man an die "inofficially pipe" :) ....
Kann man schon sagen, was neu an dieser Beta ist? Haben die das Problem Wählregeln mit der "0" Bei Ruflisten gelöst?
Michael
Hallo MuP,
leider kann man Dich nicht per PN erreichen. Gibt auch Fragen, die per PN einfacher zu klären wären.
Du scheinst also direkten Kontakt zu Gigaset zu haben. Kannst Du mal testen bzw. klären, warum die Wählregel "Ziffern für IP Gespräche" "0" bei Ruflisten verwenden nicht funktioniert?!
Mindestens bei LDAP (ist doch wohl eine Rufliste) funktioniert das nämlich nicht. Es funktioniert "0" "Immer verwenden", doch dann habe ich das Problem, dass immer die "0" als Amtsziffer
vorgewählt wird. Ein Anwender der mal das Gigaset, mal einen normen kabelgebundenen Apparat verwendet kommt total durcheinander in dem mal die "0" manuell vorgewählt werden
muss und bei Gigaset eben nicht. Ist einfach unschön der bisherige Workaround.
Wäre einfach ideal für TK-Anlagen-Anwender, die "0" als Amtsziffer in Ihren Anlagen verwenden.
Michael
wollte doch mal nachhaken: Was gibts Neues an der Firmwarefront für die N 510 IP? Nachdem endlich, nach 5 Jahren Firmware (die N 510 kam doch 2012 auf den Markt oder?),
auch deutsche Umlaute hier im LDAP unterstützt werden, hoffe ich doch inständig, das der Bug auf meinem vorhergehenden Beitrag #618 beseitigt wird. Dann wäre die N 510 IP
endlich auch an Anlagen mit Amtszugang Vorwahl "0" problemlos einsetzbar. Im Moment ist es ja ein bisschen "krampfig".
Hier hat doch jemand Kontakt zum Betabereich und/oder Support von Gigaset. Bin ja nicht der Einzigste, der dringend eine Lösung für das Problem hätte ...
Michael
