SatBandit
- Mitglied seit
- 29 Jan 2005
- Beiträge
- 81
- Punkte für Reaktionen
- 0
- Punkte
- 0
so hier mal mein log für ein analoges fax über festnetz mit aktueller ivcall aud einer 7170:
/var/fax # ./ivcall -pv 5 -d capi/1/95xxxx -a 95xxxx -F /var/fax/recv01.tif -n koweco
**CaPi*DeV**> CAPI controller=1
**CaPi*DeV**> controller 1: listen_change_state 0 -> 1
**CaPi*DeV**> contr 1: listenconf Info=0x0000 (No additional information) infomask=0x145 cipmask=0x32 capimask2=0x0
**CaPi*DeV**> controller 1: listen_change_state 1 -> 2
**CaPi*DeV**> plci_change_state:0x1701 0 -> 4 event=5
**CaPi*DeV**> incoming call contr=1 cip=1 604795xxxx -> 95xxxx
**CaPi*DeV**> CAPI incoming call to 95xxxx from 604795xxxx on controller 1
**CaPi*DeV**> -> incoming call cipvalue: 1
**CaPi*DeV**> ---> msn MATCH: 95xxxx <-> 95xxxx
**CaPi*DeV**> accept plci 0x1701 1,1,0
**CaPi*DeV**> plci_change_state:0x1701 4 -> 6 event=12
**CaPi*DeV**> --> accepting voice call
**CaPi*DeV**> -> call from 6047xxxxxx accepted with connid 1 .. now connecting
**CaPi*DeV**> plci_change_state:0x1701 6 -> 3 event=6
**CaPi*DeV**> ncci_change_state:0x11701 0 -> 2 event=2
**CaPi*DeV**> ncci_change_state:0x11701 2 -> 3 event=6
**CaPi*DeV**> ncci_change_state:0x11701 3 -> 4 event=7
**CaPi*DeV**> ncci 0x11701 up
**CaPi*DeV**> CAPI connected connid: 1
:..IVCALL..: Entering fax fax_loop capi
sine create complex
HDLC carrier up
create integer sine dds
HDLC carrier down
HDLC carrier up
HDLC carrier down
HDLC carrier up
>>PROFILER> time after RX 20 ms --
>>PROFILER> time after TX 10 ms
Changed from phase 1 to 4
Sending ident
>>> CSI: 40 6f 63 65 77 6f 6b 20 20 20 20 20 20 20 20 20 20 20 20 20 20
>>> DIS: 80 00 ce f4 80 80 81 80 80 80 18
HDLC underflow in state 9
Changed from phase 4 to 3
**CaPi*DeV**> WARNING: CAPI async send buffer underrun!
T4 timeout in state 9
Changed from phase 3 to 4
Sending ident
T2 timeout
Start receiving document
Sending ident
HDLC carrier up
HDLC framing OK
<<< TSI: 43 20 20 35 31 31 34 30 37 20 38 32 34 36 20 39 34 2b 20 20 20
TSI without final frame tag
Remote fax gave TSI as: "+49 6428 70xxxx "
<<< DCS: 83 00 86 94 00
DCS with final frame tag
In state 9
Get at 9600bps, modem 1
Changed from phase 3 to 5
Non-ECM carrier up
Non-ECM carrier down
Non-ECM carrier up
>>PROFILER> time after RX 30 ms --
>>PROFILER> time after RX 90 ms --
>>PROFILER> time after RX 110 ms --
>>PROFILER> time after RX 80 ms --
Non-ECM carrier training failed
Non-ECM carrier up
>>PROFILER> time after RX 50 ms --
>>PROFILER> time after RX 150 ms --
>>PROFILER> time after RX 60 ms --
Non-ECM carrier up
>>PROFILER> time after RX 40 ms --
Non-ECM carrier up
>>PROFILER> time after RX 70 ms --
Non-ECM carrier up
Non-ECM carrier up
Non-ECM carrier up
Non-ECM carrier up
**CaPi*DeV**> cause bytes for plci 0x1701: 80 90
**CaPi*DeV**> ncci_change_state:0x11701 4 -> 7 event=10
**CaPi*DeV**> ncci_change_state:0x11701 7 -> 0 event=13
**CaPi*DeV**> plci_change_state:0x1701 3 -> 7 event=8
**CaPi*DeV**> DISCONNECT_IND reason 0x3490 (Normal call clearing) for plci 0x1701
**CaPi*DeV**> plci_change_state:0x1701 7 -> 8 event=9
**CaPi*DeV**> plci_change_state:0x1701 8 -> 0 event=11
**CaPi*DeV**> --> disconnected callback <-- localdisconnect: 0, connid: 1
**CaPi*DeV**> CAPI disconnected connid: 1
:..IVCALL..: CAPI connection no longer connected! return code: -1
:..IVCALL..: fax_loop finish
:..IVCALL..: capi-failed
/var/fax #
