user@host:~# make precompiled
/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/target/bin/mipsel-linux-uclibc-strip
--remove-section=.comment --remove-section=.note
/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/target/bin/../lib/libgcc_s.so.1
cp
root/lib/
chmod +x root/lib/libgcc_s.so.1
/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/build/gcc-4.1.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libffi*.so*
cp -a
root/usr/lib/
/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/build/gcc-4.1.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo*.so*
cp -a
root/usr/lib/
/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/build/gcc-4.1.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libevent*.so*
cp -a
root/usr/lib/
/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/build/gcc-4.1.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/libncurses*.so*
cp -a
root/usr/lib/
PATH=/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/build/gcc-4.1.1-uClibc-0.9.28/mipsel-linux-uclibc/bin:/bin:/sbin:/usr/bin:/usr/sbin
make \
-C source/libpcap-0.9.5 \
PATH="/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/target/bin:/bin:/sbin:/usr/bin:/usr/sbin"
all
make[1]: Betrete Verzeichnis
'/home/user/ds-mod/ds-0.2.9_26-14.1/source/libpcap-0.9.5'
mipsel-linux-gcc -O2 -Os -W -Wall -pipe -march=mips32 -mips32 -Wa,--trap
-msoft-float
-I/home/user/ds-mod/ds-0.2.9_26-14.1/toolchain/build/gcc-4.1.1-uClibc-0.9.28/mipsel-linux-uclibc/usr/include
-I. -D_BSD_SOURCE -DHAVE_CONFIG_H -D_U_="__attribute__((unused))"
-Dyylval=pcap_lval -c grammar.c
btyaccpa.ske:96: error: expected '=', ',', ';', 'asm' or '__attribute__'
before 'pcap_lval'
btyaccpa.ske:100: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'yyretlval'
btyaccpa.ske:111: error: expected specifier-qualifier-list before
'yyparsestate'
btyaccpa.ske:128: error: expected '=', ',', ';', 'asm' or
'__attribute__' before '*' token
btyaccpa.ske:131: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:134: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:137: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:140: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:143: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:178: error: expected ')' before '*' token
btyaccpa.ske:180: error: expected ')' before '*' token
btyaccpa.ske:181: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:182: error: expected ')' before '*' token
btyaccpa.ske: In function 'yyparse':
btyaccpa.ske:193: error: 'yyparsestate' undeclared (first use in this
function)
btyaccpa.ske:193: error: (Each undeclared identifier is reported only
once
btyaccpa.ske:193: error: for each function it appears in.)
btyaccpa.ske:193: error: 'yyerrctx' undeclared (first use in this
function)
btyaccpa.ske:206: error: 'yyps' undeclared (first use in this function)
btyaccpa.ske:206: warning: implicit declaration of function 'YYNewState'
btyaccpa.ske:257: error: 'yypath' undeclared (first use in this
function)
btyaccpa.ske:265: error: 'save' undeclared (first use in this function)
btyaccpa.ske:270: warning: implicit declaration of function
'YYFreeState'
btyaccpa.ske:294: warning: implicit declaration of function 'YYSCopy'
btyaccpa.ske:309: error: 'new' undeclared (first use in this function)
btyaccpa.ske:309: error: expected ';' before 'Yshort'
btyaccpa.ske:310: error: 'yylvals' undeclared (first use in this
function)
btyaccpa.ske:310: error: expected ';' before 'YYSTYPE'
btyaccpa.ske:311: error: 'yylvlim' undeclared (first use in this
function)
btyaccpa.ske:312: error: expected ';' before 'int'
btyaccpa.ske:315: error: 'yylvp' undeclared (first use in this function)
btyaccpa.ske:315: error: 'yylve' undeclared (first use in this function)
btyaccpa.ske:320: error: 'pcap_lval' undeclared (first use in this
function)
btyaccpa.ske:328: warning: left-hand operand of comma expression has no
effect
btyaccpa.ske:328: warning: value computed is not used
btyaccpa.ske:341: warning: left-hand operand of comma expression has no
effect
btyaccpa.ske:341: warning: value computed is not used
btyaccpa.ske:369: warning: implicit declaration of function
'YYMoreStack'
btyaccpa.ske:479: error: 'YYERRCODE' undeclared (first use in this
function)
grammar.y:246: warning: left-hand operand of comma expression has no
effect
effect
grammar.y:246: warning: statement with no effect
grammar.y:247: warning: left-hand operand of comma expression has no
effect
effect
grammar.y:247: warning: statement with no effect
grammar.y:248: warning: left-hand operand of comma expression has no
effect
effect
grammar.y:248: warning: statement with no effect
grammar.y:249: warning: left-hand operand of comma expression has no
effect
effect
grammar.y:249: warning: statement with no effect
grammar.y:250: warning: left-hand operand of comma expression has no
effect
effect
grammar.y:250: warning: statement with no effect
grammar.y:251: warning: left-hand operand of comma expression has no
effect
effect
grammar.y:251: warning: statement with no effect
btyaccpa.ske:609: error: 'yyretlval' undeclared (first use in this
function)
btyaccpa.ske:691: error: 'YYSTYPE' undeclared (first use in this
function)
btyaccpa.ske:691: error: 'pv' undeclared (first use in this function)
btyaccpa.ske: In function 'YYLex1':
btyaccpa.ske:734: error: 'yylvp' undeclared (first use in this function)
btyaccpa.ske:734: error: 'yylve' undeclared (first use in this function)
btyaccpa.ske:735: error: 'pcap_lval' undeclared (first use in this
function)
btyaccpa.ske:739: error: 'yyps' undeclared (first use in this function)
btyaccpa.ske:740: error: 'yylvlim' undeclared (first use in this
function)
btyaccpa.ske: In function 'yyexpand':
btyaccpa.ske:756: error: 'yylvp' undeclared (first use in this function)
btyaccpa.ske:756: error: 'yylvals' undeclared (first use in this
function)
btyaccpa.ske:757: error: 'yylvlim' undeclared (first use in this
function)
btyaccpa.ske:760: error: 'YYSTYPE' undeclared (first use in this
function)
btyaccpa.ske:760: error: 'tv' undeclared (first use in this function)
btyaccpa.ske:762: error: 'new' undeclared (first use in this function)
btyaccpa.ske:762: error: expected ';' before 'YYSTYPE'
btyaccpa.ske:763: error: expected ';' before 'int'
btyaccpa.ske:764: error: expected ';' before 'Yshort'
btyaccpa.ske:768: error: 'delete' undeclared (first use in this
function)
btyaccpa.ske:768: error: expected expression before ']' token
btyaccpa.ske:769: error: expected expression before ']' token
btyaccpa.ske:770: error: expected expression before ']' token
btyaccpa.ske:772: error: 'yylve' undeclared (first use in this function)
btyaccpa.ske: At top level:
btyaccpa.ske:780: error: expected ')' before '*' token
btyaccpa.ske:794: error: expected ')' before '*' token
btyaccpa.ske:814: error: expected '=', ',', ';', 'asm' or
btyaccpa.ske:825: error: expected ')' before '*' token
btyaccpa.ske:753: warning: control reaches end of non-void function
make[1]: *** [grammar.o] Fehler 1
make[1]: Verlasse Verzeichnis
make: *** [source/libpcap-0.9.5/.compiled] Fehler 2
