... or I can put my box to the garbage can?
No, your 7170 isn't dead, it is just a little sick. The permanent reboot loop is a well known symptoma. It is easy to cure, using ftp/adam2 access to the bootloader and adjusting the environment parameters.
If you are not familiar with ftp/adam2, you should first try the following:
According to your explanation, the 7170 was selled to you as a original version A/CH AnnexA (german). The appropiate recovery file is fritz.box_fon_wlan_7170.annexa.04.43.recover-image.exe, which you will find at the FTP server at the avm homepage. Try to execute this file. But I'm afraid, it will not help, too.
The reason seems to be that your 7170 isn't originally A/CH AnnexA, but AnnexB patched with "firmware_version annex=A". In this case the environment parameters are contradictory after running "fritz_as_avme_newer.tar" and the Fritz!Box rebootes continously after any recovery.
The only solution is to correct the environment parameters using ftp access to the bootloader with username and password "adam2". See [post=1205536]here[/post] how to do that (points 1 to 5).
Use "quote GETENV <parameter>" to see the values of the following parameters and post them here in the forum. Then I will tell you the right values.
- parameter
annex (value can be "B" or "A")
- parameter
HWRevision (value can be "94" or "127")
- parameter
firmware_version (value can be "avm" or "avme")
- parameter
kernel_args (value can be "not set" or "annex=A")
I suppose, the present values are "annex B", "HWRevision 94", "firmware_version avme" and "kernel_args annex=A".
This combination is "forbidden" and the box necessarily enters into a permanent reboot loop - as it is the case.
