Converting a German targeted Fritz!Box Fon Wlan to an International version
Hi Aussi,
I think, your tz_strting is too short.
It does not contain any parameter for daylight savings.
Please try this:
TZ_string = "EET-2EEST-3,M3.5.0/03:00:00,M10.5.0/04:00:00";
Explanation for this example (Turky):
EET-2EEST-3 is the timezone segment (East European Time / East European Summer Time)
M3.5.0/03:00:00 is the start of summertime (5th of march)
M10.5.0/04:00:00 is the end of summertime (5th of october)
Joe
cannot connect to my FB fon ata 1020
I have a fritz box fon ata 1020 that was in dutch (got it from ebay.de).
I used the recovery file fritz.box_fon_ata.en.04.01.recover-image.exe to change it to english. The application said that the recovery was successfull but when rebooted I cannot connet to it anymore. No web interface no telnet.
Could you please tell me how I can proceed to get access to it again.
thank you.
Hi mbelmir,
please check out if one of the "emergancy" ip addresses would work.
Those are 192.168.178.253 and 169.254.1.1
Just punch them in to your explorers address field.... :dance:
Joe
How did you prepare it to accept the English firmware? Set it to avme?
Hi mbelmir,
Joe
Thank you joe for your response. I tryed to connect using the IPs you gave but no hope. I used the connection over the usb and the the one with network red LAN rj45 cable. when using usb cable I have the message: A network cabel is unplugged.for the LAN connection it is: The connection has limited or no connectivity. You may not be able to access the internet or some network resources...
thank you.
I just used the recovery software fritz.box_fon_ata.en.04.01.recover-image.exe to restore the image in english. I'm not sure it is changed to english. it said recovery successfull but was not able to use the web interface to check that it is realy done.
regards,
I'm not sure it is changed to english ...
Telefonicus is right with his question: The german FW needs "firmware_version avm"; the english FW needs "firmware_version avme".
I don't understand why you was able to run the english recover-image.exe without changing the parameter "firmware_version" to "avme".
Anyway, I suppose, that's the problem: "firmware_version" must be settled to "avme"
As you have no access neither to the web interface nor to telnet, you must change the parameter using ftp/adam2. The "how to login" is described elsewhere in this forum, use the search function.
Once logged in with adam2, insert the following commands:
- quote SETENV firmware_version avme
- quote GETENV firmware_version
- quote REBOOT
- quit
comment: The GETENV command is just to confirm; the answer must be "avme"
If your ftp version doesn't understand, try comma instead of space:
- quote SETENV firmware_version,avme
- quote REBOOT
- quit
Having done that, your english FW should work as usual - good luck !
Internation Edition to German edition or other help
Hi everybody..
i have a problem! If i am downloading something from the internet and i have a voip phonecall my fritz box 7140 is restarting because of an ppoe-error...
now i would like to change from eng to german because there is a newer firmware for the german once..
Could somebody tell me, how i do that, or how i could resolve my problem??
I hope you can...
... how i could resolve my problem?? ... or other help ...
You will enjoy the maximum comfort with your FB7140 by installing the firmware of the FB7170!
You can install the newest firm 29.04.67 using all the beautyful functions it contains.
There is a thread specifically dedicated to this theme [post=1102236]here[/post] ...
Good luck!
But does this work with my international edition and this guide... or do i have to change some lines or settings???
Yeah, you must change some settings. But most of them you must also change to convert an international version into a german version. It is not so easy.
You must change the following settings (at the appropiate time!):
- HWRevision: change present value to 94 (=7170, AnnexB firmware)
your present value of HWRevision is either 95 (7140, AnnexA) or 107 (7140, AnnexB)
- firmware_version: change from avme (english) to avm (german)
- in case of AnnexB firmware in AnnexA country: set "kernel_args" to value "annex=A"
To change these parameters you may use Telnet or FTP.
Are you familiar with these tools? This would make things easier.
Could be these changes are too difficult for a beginner ... what do you think?
Good luck!
So i uploaded the firmware from the 7170 international edition... and i can't see any improvement or comfort...!!!
but still the same problem.. if i download something with my browser and telephone at the same time, the internet call gets lost... it seems, that traffic shaping isn't working right...
Other ideas how to solve the problem?? Or did I something wrong?
Kann ich auch Deu sprechen? Wäre einfacher für mich... Kann mir jemand eine Schritt-für-Schritt Anleitung in deu machen, die leicht zu verstehen ist?!
Kann ich auch Deu sprechen? Wäre einfacher für mich!
Welches ist denn Deine "eigene" Sprache? Natürlich kannst Du hier alles in Deutsch abwickeln - dies ist DIE Forums-Sprache. Daß es daneben noch eine Menge User gibt, die auch Englisch beherrschen und Hilfen geben können, steht auf einem anderen Blatt.
Um beurteilen zu können, ob Du etwas falsch gemacht hast, müsste man natürlich zunächst einmal wissen, WAS GENAU Du gemacht hast? Ich habe bisher verstanden, daß Du Deine Internationale (Annex-A?) 7140 mit einer FW der 7170 geflasht hast nach einer von "el_valiente" (nur?) für die Annex-B-Internationalen erprobten Methode.
Aber die Umstellung auf 7170 FW International (welche FW hast Du denn nun auf der Box?) ist wohl problemlos verlaufen, hat nur Dein Problem nicht gelöst - weil vermutlich Dein Problem (VoIP-Telefonate und Daten-Download stören sich gegenseitig) nichts mit der FW zu tun hat. Wer ist denn Dein DSL-Provider.? Hast Du die richtigen ATM-Daten eingetragen (VPI/VCI und Kapselung)? Woher hast Du diese Daten? Eine Screenshot mit der "Internet"-Seite der Box könnte auch Hinweise geben.
Ja ich habe meine internationale 7140 auf 7170 geflasht...alles noch in englisch und Annex-A... macht es einen Unterschied auf Annex-B?? Welchen??
Mir kommt es eben nur so vor, dass die FB nicht die wirkliche Bandbreite erkennt und das Traffic-shaping nicht funktioniert...
was sind ATM-Daten und wo gebe ich diese ein?
Ich möchte jetzt gerne die deu-version von dieser firmware installieren: FRITZ!Box Fon WLAN 7170 Firmware Version 29.04.67
Annex A
muss ich dabei etwas besonderes beachten, oder geht alles reibungslos wie die umstellung von 7140 engl auf 7170 engl???
So hab jetzt diese Firmware-Version 29.04.67 von 7170 in deu oben... aber das firmware-update sagt mir dasses eine neuere Version gibt, die allerdings am 25.10.2008 erstellt wurde und meine aktuelle am 25.11.2008 ?! Irgendwas muss da doch falsch sein?
Die 29.... sind immer FW für Annex-B-Boxen. Sprache ist immer zweitrangig. Die 29.04.67 ist die neueste final FW für die 7170-B.
Die für 7170-Annex-A-Boxen bestimmten FW fangen immer mit 58...an. Es gibt seit langem Hinweise -mit Begründung- in diesem Forum, daß es zu Problemen führen kann, wenn eine ORIGINAL-Annex-A auf Annex B umgestellt wird - umgekehrt führt die Umstellung einer ORIGINAL Annex B Box in aller Regel zu keinen Problemen, allenfalls zu schwächeren Sync-Werten.
Welchen Annex hatte denn Deine Box im ORIGINAL-Zustand? Eine Umstellung Deiner 7140, falls sie ORIGINAL Annex A war, auf die deutsche Annex-A-FW (D-A-CH) der 7170 sollte nach meiner Einschätzung sehr viel problemloser möglich sein als die Umstellung auf eine Annex-B-FW. Auch "el_valiente" ist -wenn ich das alles richtig mitverfolgt habe- bei seinem erfolgreichen Flashen von 7170-FW auf eine 7140-Box immer im selben Annex (B) geblieben - und hat nur schliesslich den Modem-Modus auf A umgestellt - nie aber eine B-FW auf eine ORIGINAL-A-Box geflasht.
ok bin jetzt auf der Firmware-Version 58.04.59
mal ein paar tage austesten... ansonsten wird es wohl an der verbindungslinie fehlen...
Danke nochmal für die rasche Hilfe und die Geduld mit mir...!!!
Danke!!!!!
Lass uns aber wissen, wie es ausgeht!!
Aber sicher!!! Auf jeden Fall....
P. S. ich habe Internet aus der Steckdose (PLC) ... vll haben auch andere dieses System und das gleiche Problem...
Das heitß, daß die deutsche Annex-A-FW (D-A-CH) ordentlich auf Deiner Boxläuft, aber Dein EIGENTLICHES Problem weiter besteht? Denke, daß die Vermutung zutrifft, daß es an der DSL-Leitung liegt. Teste doch Deine Box mal an einem ganz normalen DSL-Anschluß Wenn auch dort das Problem auftritt, könnte es auch ein Hardware-Fehler der Box sein. Dann recover auf die ursprüngliche FW-AVM machen und bei AVM als Garantiefall anmelden.
